[cgma-dev] r1515 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Thu Jan 10 13:43:44 CST 2008
Author: janehu
Date: 2008-01-10 13:43:44 -0600 (Thu, 10 Jan 2008)
New Revision: 1515
Modified:
   cgm/trunk/geom/OCC/OCCBody.cpp
   cgm/trunk/geom/OCC/OCCBody.hpp
   cgm/trunk/geom/OCC/OCCCurve.hpp
   cgm/trunk/geom/OCC/OCCPoint.hpp
Log:
Updated for body translation unmark underlining curve/vertex marker, added getting all points, curves, surfaces for body.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp	2008-01-09 22:05:06 UTC (rev 1514)
+++ cgm/trunk/geom/OCC/OCCBody.cpp	2008-01-10 19:43:44 UTC (rev 1515)
@@ -273,7 +273,19 @@
      lump->update_OCC_entity(aBRepTrsf);
   set_TopoDS_Shape(compsolid);
-  //unset_marks();
+  //unset marks.
+  DLIList<OCCCurve*> curves;
+  DLIList<OCCPoint*> points;
+  get_all_curves(curves);
+  get_all_points(points);
+  for(int i = 0; i < curves.size(); i++)
+    curves.get_and_step()->set_myMarked(CUBIT_FALSE);
+  for(int i = 0; i < points.size(); i++)
+    points.get_and_step()->set_myMarked(CUBIT_FALSE);
 // Function: update_bounding_box
@@ -371,4 +383,72 @@
   return CUBIT_PNT_OUTSIDE;
+// Purpose       : return all surfaces in this body.
+// Special Notes :
+// Creator       : Jane Hu
+// Creation Date : 01/10/08
+void OCCBody::get_all_surfaces(DLIList<OCCSurface*> &surfaces)
+  TopTools_IndexedMapOfShape M;
+  TopExp::MapShapes(*myTopoDSShape, TopAbs_FACE, M);
+  int ii;
+  for (ii=1; ii<=M.Extent(); ii++) {
+          TopologyBridge *surface = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
+          OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
+	  if (occ_surface)
+            surfaces.append_unique(occ_surface);
+// Purpose       : return all curves in this body.
+// Special Notes :
+void OCCBody::get_all_curves(DLIList<OCCCurve*> &curves)
+  TopExp::MapShapes(*myTopoDSShape, TopAbs_EDGE, M);
+  int ii;
+          TopologyBridge *curve = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
+          OCCCurve* occ_curve = CAST_TO(curve, OCCCurve);
+          if (occ_curve)
+            curves.append_unique(occ_curve);
+// Purpose       : return all points in this body.
+// Special Notes :
+void OCCBody::get_all_points(DLIList<OCCPoint*> &points)
+  TopExp::MapShapes(*myTopoDSShape, TopAbs_VERTEX, M);
+  int ii;
+          TopologyBridge *vertex = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
+          OCCPoint* occ_point = CAST_TO(vertex, OCCPoint);
+          if (occ_point)
+            points.append_unique(occ_point);
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp	2008-01-09 22:05:06 UTC (rev 1514)
+++ cgm/trunk/geom/OCC/OCCBody.hpp	2008-01-10 19:43:44 UTC (rev 1515)
@@ -161,6 +161,10 @@
   virtual void get_parents_virt( DLIList<TopologyBridge*>& parents );
   virtual void get_children_virt( DLIList<TopologyBridge*>& children );
+  void get_all_surfaces(DLIList<OCCSurface*> &surfaces);
+  void get_all_curves(DLIList<OCCCurve*> &curves);
+  void get_all_points(DLIList<OCCPoint*> &points);
   virtual CubitStatus mass_properties( CubitVector& result, double& volume );
   virtual CubitPointContainment point_containment( const CubitVector& pos );
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp	2008-01-09 22:05:06 UTC (rev 1514)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp	2008-01-10 19:43:44 UTC (rev 1515)
@@ -50,6 +50,8 @@
   virtual ~OCCCurve() ;
     //- The destructor
+  void set_myMarked( CubitBoolean marked) {myMarked = marked;}
   void add_loop(OCCLoop* loop) { myLoopList.append_unique(loop);}
   DLIList<OCCLoop*> loops() {return myLoopList;}
   void remove_loop(OCCLoop* loop) {myLoopList.remove(loop);}
Modified: cgm/trunk/geom/OCC/OCCPoint.hpp
--- cgm/trunk/geom/OCC/OCCPoint.hpp	2008-01-09 22:05:06 UTC (rev 1514)
+++ cgm/trunk/geom/OCC/OCCPoint.hpp	2008-01-10 19:43:44 UTC (rev 1515)
@@ -64,6 +64,7 @@
     //- The destructor
   void set_myMarked(CubitBoolean marked) {myMarked = marked;}
   TopoDS_Vertex *get_TopoDS_Vertex(){return myTopoDSVertex; }
   void set_TopoDS_Vertex(TopoDS_Vertex vertex){*myTopoDSVertex = vertex;}
More information about the cgma-dev
