[cgma-dev] r1509 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Jan 7 12:40:57 CST 2008
Author: janehu
Date: 2008-01-07 12:40:57 -0600 (Mon, 07 Jan 2008)
New Revision: 1509
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCBody.hpp
Log:
for moving/reflecting etc. funtions, OCC operation gives a new
object, need to update for body/lump of their underling CompSolid/solid. now crashs at lump->set_TopoDS_Solid(TopoDS::Solid(M(i))); need to investigate.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-01-04 01:42:37 UTC (rev 1508)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-01-07 18:40:57 UTC (rev 1509)
@@ -66,6 +66,7 @@
void OCCBody::lumps(DLIList<Lump*>& my_lumps)
+ myLumps.clean_out();
myLumps += my_lumps;
@@ -204,13 +205,14 @@
// Function: reflect
-// Description: reflect the body about a exis
+// Description: reflect the body about an plane given the normal
+// vector.
// Author: Jane Hu
CubitStatus OCCBody::reflect( double reflect_axis_x,
- double reflect_axis_y,
- double reflect_axis_z )
+ double reflect_axis_y,
+ double reflect_axis_z )
gp_Pnt aOrigin(0,0,0);
gp_Dir aDir(reflect_axis_x, reflect_axis_y,reflect_axis_z);
@@ -220,11 +222,37 @@
aTrsf.SetMirror(anAx2);
BRepBuilderAPI_Transform aBRepTrsf(*myTopoDSShape, aTrsf);
+ TopoDS_Shape shape = aBRepTrsf.ModifiedShape(*myTopoDSShape);
+ update_OCC_entity(shape);
update_bounding_box();
return CUBIT_SUCCESS;
+// Function: private function to update the core compsolid and
+// for any movement of the body.
+// Note: input shape must have the same number of CompSolids
+// as the body's lumps number.
+// Author: Jane Hu
+CubitStatus OCCBody::update_OCC_entity( TopoDS_Shape shape)
+ TopoDS_CompSolid compsolid = TopoDS::CompSolid(shape);
+ set_TopoDS_Shape(compsolid);
+ //set the lumps
+ DLIList<Lump *> lumps;
+ lumps = this->lumps();
+ TopTools_IndexedMapOfShape M;
+ TopExp::MapShapes(*myTopoDSShape, TopAbs_SOLID, M);
+ for (int i = 0; i < lumps.size(); i++)
+ OCCLump *lump = CAST_TO(lumps.get_and_step(), OCCLump);
+ lump->set_TopoDS_Solid(TopoDS::Solid(M(i)));
// Function: update_bounding_box
// Description: calculate for bounding box of this OCCBody
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2008-01-04 01:42:37 UTC (rev 1508)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2008-01-07 18:40:57 UTC (rev 1509)
@@ -61,7 +61,7 @@
//- associated with the object.
TopoDS_CompSolid *get_TopoDS_Shape() {return myTopoDSShape; }
- void set_TopoDS_Shape( TopoDS_CompSolid shape){*myTopoDSShape = shape;}
+ void set_TopoDS_Shape( TopoDS_CompSolid theshape){*myTopoDSShape = theshape;}
virtual CubitStatus get_transforms( CubitTransformMatrix &tfm );
//R CubitStatus
@@ -175,6 +175,7 @@
TopoDS_CompSolid *myTopoDSShape;
CubitBox boundingbox;
+ CubitStatus update_OCC_entity( TopoDS_Shape shape); //update the lumps
More information about the cgma-dev
