[cgma-dev] r1628 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Fri Feb 29 15:01:17 CST 2008
Author: janehu
Date: 2008-02-29 15:01:17 -0600 (Fri, 29 Feb 2008)
New Revision: 1628
Modified:
   cgm/trunk/geom/OCC/OCCCurve.hpp
   cgm/trunk/geom/OCC/OCCLoop.cpp
   cgm/trunk/geom/OCC/OCCLoop.hpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added logic to delete OCCCoEdge and sheet body.
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp	2008-02-29 18:47:12 UTC (rev 1627)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp	2008-02-29 21:01:17 UTC (rev 1628)
@@ -55,6 +55,7 @@
   void add_loop(OCCLoop* loop) { myLoopList.append_unique(loop);}
   DLIList<OCCLoop*> loops() {return myLoopList;}
   void remove_loop(OCCLoop* loop) {myLoopList.remove(loop);}
+  void clean_loops(){myLoopList.clean_out();}
   virtual void append_simple_attribute_virt(CubitSimpleAttrib*);
     //R void
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp	2008-02-29 18:47:12 UTC (rev 1627)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp	2008-02-29 21:01:17 UTC (rev 1628)
@@ -80,12 +80,15 @@
     OCCCoEdge* coedge = myCoEdgeList.get_and_step();
     assert(coedge->loop() == this);
-    OCCCurve* curve = CAST_TO(coedge->curve(), OCCCurve);
-    curve->remove_loop(this);
   myCoEdgeList.clean_out();
+OCCCoEdge* OCCLoop::remove_coedge(OCCCoEdge *coedge)
+  return myCoEdgeList.remove(coedge);
 // Purpose       : The purpose of this function is to append a
 //                 attribute to the GE. The name is attached to the
Modified: cgm/trunk/geom/OCC/OCCLoop.hpp
--- cgm/trunk/geom/OCC/OCCLoop.hpp	2008-02-29 18:47:12 UTC (rev 1627)
+++ cgm/trunk/geom/OCC/OCCLoop.hpp	2008-02-29 21:01:17 UTC (rev 1628)
@@ -43,6 +43,8 @@
   DLIList<OCCCoEdge*> coedges() {return myCoEdgeList;}
+  OCCCoEdge* remove_coedge(OCCCoEdge *coedge);
   void disconnect_all_curves();
   inline TopoDS_Wire* get_TopoDS_Wire() {return myTopoDSWire;}
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-02-29 18:47:12 UTC (rev 1627)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-02-29 21:01:17 UTC (rev 1628)
@@ -1414,6 +1414,15 @@
   if (!occ_body)
     return CUBIT_FAILURE;
+  OCCSurface* occ_surface = occ_body->my_sheet_surface();
+  if(occ_surface)
+    delete occ_surface->my_body();
+    delete occ_surface->my_shell();
+    delete occ_surface->my_lump();
+    return delete_solid_model_entities(occ_surface);
   for(int i =0; i < occ_body->lumps().size(); i++)
      Lump* lump = occ_body->lumps().get_and_step();
@@ -1422,6 +1431,7 @@
        occ_lump->remove_body();
      unhook_Lump_from_OCC(lump);
   return unhook_BodySM_from_OCC(bodysm);
@@ -1646,10 +1656,43 @@
   DLIList<OCCCoEdge*> children;
-  occ_loop->coedges(children);
-  for(int i = 0; i < children.size(); i++)
+  children = occ_loop->coedges();
+  int size = children.size();
+  while(size > 0)
-     Curve* curve = children.get_and_step()->curve();
+     OCCCoEdge* coedge = children.pop();
+     Curve* curve = coedge->curve();
+     OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
+     if (occ_curve == NULL)
+	continue;
+     DLIList<OCCLoop*> loops;
+     //remove all coedges corresponding to this curve from their loops.
+     loops =  occ_curve->loops();
+     for(int j = 0; j < loops.size(); j++)
+       OCCLoop* occ_loop = loops.get_and_step();
+       OCCCoEdge* found_coedge = occ_loop->remove_coedge(coedge);
+       if (found_coedge)
+	 delete found_coedge;
+       //there might be 2 coedges in the same loop that uses the same curve
+       //as in a scar curve situation
+       DLIList<OCCCoEdge*> coedges = occ_loop->coedges();
+       for(int k =0; k < coedges.size(); k++)
+         found_coedge = coedges.get_and_step();
+         if (CAST_TO(found_coedge->curve(), OCCCurve) == occ_curve)
+           occ_loop->remove_coedge(found_coedge);
+           children.remove(found_coedge);
+     size = children.size();
      delete_solid_model_entities(curve);
@@ -1739,6 +1782,7 @@
   if (!fcurve )
+  fcurve->clean_loops();
   TopoDS_Edge * edge = fcurve->get_TopoDS_Edge();
   if (!edge)
More information about the cgma-dev mailing list
