[cgma-dev] r1619 - in cgm/trunk/geom: . OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Feb 27 14:42:13 CST 2008
Author: janehu
Date: 2008-02-27 14:42:12 -0600 (Wed, 27 Feb 2008)
New Revision: 1619
Modified:
   cgm/trunk/geom/GeometryModifyTool.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
Log:
modified delete solid modeling entities to cooperate with delete lower entities flag, when using a list of RefVolumns to create a single body, it puts all lumps into a single body without unite them, and delete old bodies
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp	2008-02-27 16:45:17 UTC (rev 1618)
+++ cgm/trunk/geom/GeometryModifyTool.cpp	2008-02-27 20:42:12 UTC (rev 1619)
@@ -1520,7 +1520,18 @@
       return (Body *)NULL;
-   return GeometryQueryTool::instance()->make_Body(bodySM_ptr);
+   DLIList<BodySM*> bodysm_list;
+   bodysm_list.append(bodySM_ptr);
+   DLIList<Body*> input_bodies;
+   for (int i =0; i < ref_volume_list.size(); i++)
+     input_bodies.append(ref_volume_list.get_and_step()->get_body_ptr());
+   DLIList<Body*> results;
+   finish_sm_op(input_bodies, bodysm_list, results, CUBIT_TRUE);
+   return results.get();
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-02-27 16:45:17 UTC (rev 1618)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-02-27 20:42:12 UTC (rev 1619)
@@ -820,7 +820,7 @@
       aWire.Add(*(topo_edges->step_and_get()));
     test_Wire = aWire.Wire();
-    wires.append(&(aWire.Wire()));
+    wires.append(&test_Wire);
     if (topo_edges_list.size() == 1)
       break;
@@ -981,7 +981,7 @@
 // Function   : make_BodySM
 // Member Type: PUBLIC
-// Description: make a BodySM
+// Description: make a BodySM from a surface
 // Author     : Jane Hu
 // Date       : 02/08
@@ -1037,39 +1037,26 @@
      TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid();
      B.Add(CS, *solid);
+  BodySM* bodysm = OCCQueryEngine::instance()->populate_topology_bridge(CS);
+  if(bodysm)
      //remove each Lump's body from the BodyList
-     BodySM* bodysm = occ_lump->get_body();
-     if(bodysm == NULL)
-	continue;
-     occ_lump->remove_body();
-     OCCBody * occ_body = dynamic_cast<OCCBody*>(bodysm);
-     if(occ_body == NULL)
-	continue;
-     TopoDS_Shape* shape = occ_body->get_TopoDS_Shape();
-     if (shape == NULL)
-	continue;
-     int k;
-     if(OCCQueryEngine::instance()->OCCMap->IsBound(*shape))
+     for(int i = 0; i < lump_list.size(); i++)
-         k = OCCQueryEngine::instance()->OCCMap->Find(*shape);
+        Lump* lump = lump_list.get_and_step();
+        OCCLump* occ_lump = CAST_TO(lump, OCCLump);
+        BodySM* bodysm_ptr = occ_lump->get_body();
+        if(bodysm_ptr == NULL)
+      	  continue;
-         if(!OCCQueryEngine::instance()->OCCMap->UnBind(*shape))
-           PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
-         if(!OCCQueryEngine::instance()->OccToCGM->erase(k))
+        OCCQueryEngine::instance()->unhook_BodySM_from_OCC(bodysm_ptr);
+  return bodysm;
-  return
-    OCCQueryEngine::instance()->populate_topology_bridge(CS);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-02-27 16:45:17 UTC (rev 1618)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-02-27 20:42:12 UTC (rev 1619)
@@ -1362,6 +1362,42 @@
   return;
+CubitStatus OCCQueryEngine::delete_solid_model_entities(
+    GeometryEntity* ref_entity_ptr,
+    bool remove_lower_entities) const
+     // Surface
+   Surface* ref_face_ptr = CAST_TO(ref_entity_ptr, Surface);
+   if (ref_face_ptr != NULL)
+      if (remove_lower_entities)
+        return ( this->delete_solid_model_entities(ref_face_ptr) );
+      return ( this->unhook_Surface_from_OCC(ref_face_ptr));
+     // Curve
+   Curve* ref_edge_ptr = CAST_TO(ref_entity_ptr, Curve);
+   if (ref_edge_ptr != NULL)
+        return ( this->delete_solid_model_entities(ref_edge_ptr));
+      return ( this->unhook_Curve_from_OCC(ref_edge_ptr));
+     // Point
+   Point* ref_vertex_ptr = CAST_TO(ref_entity_ptr, Point);
+   if (ref_vertex_ptr != NULL)
+      return ( this->delete_solid_model_entities(ref_vertex_ptr) );
+     // Oops!
+   PRINT_ERROR("In AcisQueryEngine::delete_solid_model_entities\n"
+               "       Can only delete solid model entities underlying \n"
+               "RefFaces, RefEdges and RefVertices.\n");
+   return CUBIT_FAILURE;
 // Purpose       : Delete a OCCBody and child entities.
@@ -1378,6 +1414,25 @@
   if (!occ_body)
+  for(int i =0; i < occ_body->lumps().size(); i++)
+     Lump* lump = occ_body->lumps().get_and_step();
+     if (occ_lump)
+       occ_lump->remove_body();
+     unhook_Lump_from_OCC(lump);
+  return unhook_BodySM_from_OCC(bodysm);
+CubitStatus
+OCCQueryEngine::unhook_BodySM_from_OCC( BodySM* bodysm)const
+  OCCBody* occ_body = dynamic_cast<OCCBody*>(bodysm);
+  if (!occ_body)
   if (!shape)
@@ -1389,25 +1444,15 @@
   if(OCCMap->IsBound(*shape))
       k = OCCMap->Find(*shape);
       if(!OCCMap->UnBind(*shape))
+        PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
       occ_body_find = (OCCBody*)(OccToCGM->find(k))->second;
       if(!OccToCGM->erase(k))
-  for(int i =0; i < occ_body->lumps().size(); i++)
-     Lump* lump = occ_body->lumps().get_and_step();
-     OCCLump* occ_lump = CAST_TO(lump, OCCLump);
-     if (occ_lump)
-     unhook_Lump_from_OCC(lump);
   occ_body->lumps().clean_out();
   if (occ_body_find)
      BodyList->remove(occ_body_find);
@@ -1415,9 +1460,8 @@
      BodyList->remove(occ_body);
   delete shape;
   delete bodysm;
-  return CUBIT_SUCCESS;
 // Purpose       : Delete a OCClumps and child entities.
@@ -1464,6 +1508,7 @@
   if (occ_lump->body() != NULL)
     BodyList->remove(CAST_TO(occ_lump->body(), OCCBody));
+  delete solid;
   delete lump;
@@ -1507,9 +1552,10 @@
   for(int i = 0; i < children.size(); i++)
      Surface* surface = CAST_TO(children.get_and_step(), Surface);
-     unhook_Surface_from_OCC(surface);
+     delete_solid_model_entities(surface);
   ShellList->remove(CAST_TO(shell, OCCShell));
+  delete Shell;
   delete shell;
@@ -1530,16 +1576,16 @@
   if (!fsurf)
-  TopoDS_Face* face = fsurf->get_TopoDS_Face();
+  DLIList<TopologyBridge*> children;
+  fsurf->get_children_virt(children);
+  for(int i = 0; i < children.size(); i++)
+     LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM);
+     delete_loop(loop);
-  if(!face)
-    return CUBIT_FAILURE;
+  return unhook_Surface_from_OCC(surface);
-  delete face;
-  delete surface;
@@ -1578,14 +1624,36 @@
         PRINT_WARNING("The OccSurface and TopoDS_Face pair is not in the map!");
-  DLIList<TopologyBridge*> children;
-  fsurf->get_children_virt(children);
+  delete face;
+  delete surface;
+  return CUBIT_SUCCESS;
+// Purpose       : Delete a OCCSurface and child entities.
+// Special Notes :
+// Creator       : Jane Hu
+// Creation Date : 10/29/07
+CubitStatus
+OCCQueryEngine::delete_loop( LoopSM* loopsm)const
+  OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm);
+  if (!occ_loop)
+  DLIList<OCCCoEdge*> children;
+  occ_loop->coedges(children);
-     LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM);
-     unhook_LoopSM_from_OCC(loop);
+     Curve* curve = children.get_and_step()->curve();
+     delete_solid_model_entities(curve);
+  return unhook_LoopSM_from_OCC(loopsm);
@@ -1622,14 +1690,8 @@
         PRINT_ERROR("The OccLoop and TopoDS_Wire pair is not in the map!");
-  DLIList<OCCCoEdge*> children;
-  occ_loop->coedges(children);
-  for(int i = 0; i < children.size(); i++)
-     Curve* curve = children.get_and_step()->curve();
-     unhook_Curve_from_OCC(curve);
   WireList->remove(CAST_TO(loopsm, OCCLoop));
+  delete wire;
   delete loopsm;
@@ -1650,15 +1712,15 @@
   if (!fcurve )
-  TopoDS_Edge * edge = fcurve->get_TopoDS_Edge();
-  if (!edge)
+  fcurve->get_children_virt(children);
+     Point* point = CAST_TO(children.get_and_step(), Point);
+     delete_solid_model_entities(point);
-  delete edge;
-  delete curve;
+  return unhook_Curve_from_OCC(curve);
@@ -1694,13 +1756,8 @@
         PRINT_WARNING("The OccCurve and TopoDS_Edge pair is not in the map!");
-  fcurve->get_children_virt(children);
-     Point* point = CAST_TO(children.get_and_step(), Point);
-     unhook_Point_from_OCC(point);
+  delete edge;
+  delete curve;
@@ -1719,15 +1776,8 @@
   if (!fpoint)
-  TopoDS_Vertex *vertex = fpoint->get_TopoDS_Vertex();
-  if (!vertex)
+  return unhook_Point_from_OCC(point);
-  delete vertex;
-  delete point;
@@ -1762,6 +1812,8 @@
         PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
+  delete vertex;
+  delete point;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-02-27 16:45:17 UTC (rev 1618)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp	2008-02-27 20:42:12 UTC (rev 1619)
@@ -244,6 +244,9 @@
                                          CubitBoolean import_curves = CUBIT_TRUE,
                                          CubitBoolean import_vertices = CUBIT_TRUE,
                                          CubitBoolean free_surfaces = CUBIT_TRUE );
+  CubitStatus unhook_BodySM_from_OCC( BodySM* bodysm)const;
 private:
   CubitStatus import_solid_model(FILE *file_ptr,
                                  const char* /*file_type*/,
@@ -263,11 +266,15 @@
   CubitStatus unhook_Surface_from_OCC( Surface* surface ) const;
   CubitStatus unhook_Curve_from_OCC( Curve* curve ) const;
   CubitStatus unhook_Point_from_OCC( Point* point ) const;
+  CubitStatus delete_loop( LoopSM* loopsm)const;
 public:
   virtual void delete_solid_model_entities(DLIList<BodySM*>& body_list) const;
     //- Deletes all solid model entities associated with the Bodies in
     //- the input list.
+  virtual CubitStatus delete_solid_model_entities(
+          bool remove_lower_entities) const;
   virtual CubitStatus delete_solid_model_entities( BodySM* body_ptr ) const;
   virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr)const;
   virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr)const;
More information about the cgma-dev mailing list
