[cgma-dev] r1616 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Feb 25 13:48:53 CST 2008
Author: janehu
Date: 2008-02-25 13:48:53 -0600 (Mon, 25 Feb 2008)
New Revision: 1616
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added make_Lump function, fine-tuned make_Surface function.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-22 22:02:08 UTC (rev 1615)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-25 19:48:53 UTC (rev 1616)
@@ -47,6 +47,7 @@
#include "BRepGProp.hxx"
#include "TopoDS.hxx"
#include "TopologyBridge.hpp"
+#include "BRepAlgoAPI_Fuse.hxx"
#include "Handle_Geom_TrimmedCurve.hxx"
#include "Handle_Geom_RectangularTrimmedSurface.hxx"
#include "TopExp_Explorer.hxx"
@@ -809,7 +810,7 @@
//check and make sure the outer loop is in the first
for(int i = 0; i < topo_edges_list.size() ; i++)
- topo_edges = topo_edges_list.step_and_get();
+ topo_edges = topo_edges_list.get_and_step();
BRepBuilderAPI_MakeWire aWire(*(topo_edges->get()));
for(int j = 1; j < topo_edges->size(); j++)
aWire.Add(*(topo_edges->step_and_get()));
@@ -817,24 +818,29 @@
TopoDS_Wire test_Wire = aWire.Wire();
wires.append(&test_Wire);
+ if (topo_edges_list.size() == 1)
+ break;
BRepBuilderAPI_MakeFace made_face(test_Wire);
if (!made_face.IsDone())
- PRINT_ERROR("In OCCModifyEngine::make_TopoDS_Face\n"
+ PRINT_ERROR("In OCCModifyEngine::make_TopoDS_Face\n"
" Cannot find the best fit surface for given curves.\n");
- return (TopoDS_Face *)NULL;
+ return (TopoDS_Face *)NULL;
TopoDS_Face test_face = made_face.Face();
BRepGProp::SurfaceProperties(test_face, myProps);
double area = myProps.Mass();
out_Wire = max_area > area ? out_Wire : &test_Wire;
max_area = max_area > area ? max_area : area;
+ if (out_Wire)
+ wires.remove(out_Wire);
+ wires.insert_first(out_Wire);
- wires.remove(out_Wire);
- wires.insert_first(out_Wire);
//create the TopoDS_Face
const TopoDS_Face* topo_face = NULL;
@@ -857,7 +863,9 @@
else
- BRepBuilderAPI_MakeFace made_face(*the_wire);
+ CubitBoolean is_planar = (surface_type == PLANE_SURFACE_TYPE ?
+ CUBIT_TRUE : CUBIT_FALSE);
+ BRepBuilderAPI_MakeFace made_face(*the_wire, is_planar);
error = CUBIT_TRUE;
@@ -892,22 +900,84 @@
// Function : make_Lump
// Member Type: PUBLIC
-// Description: make a lump
-// Author : John Fowler
-// Date : 10/02
+// Description: make a lump of one shell
+// Author : Jane Hu
+// Date : 02/08
-Lump* OCCModifyEngine::make_Lump( DLIList<Surface*>& /*surface_list*/ ) const
+Lump* OCCModifyEngine::make_Lump( DLIList<Surface*>& surface_list ) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return (Lump*) NULL;
+ if (surface_list.size() == 0)
+ return (Lump*) NULL;
+ Surface* surface = surface_list.get();
+ OCCSurface* occ_surface = CAST_TO(surface, OCCSurface);
+ if(!occ_surface)
+ PRINT_ERROR("Cannot create an OCC Lump from the given surfaces.\n"
+ "Possible incompatible geometry engines.\n");
+ return (Lump *)NULL;
+ TopoDS_Face* face_ptr = occ_surface->get_TopoDS_Face();
+ for(int i = 1; i < surface_list.size(); i++)
+ Surface* surface = surface_list.step_and_get();
+ if(!occ_surface)
+ TopoDS_Face* face2_ptr = occ_surface->get_TopoDS_Face();
+ BRepAlgoAPI_Fuse aFuse(*face_ptr, *face2_ptr);
+ if(aFuse.ErrorStatus() == 1) //The Object is created but Nothing is Done
+ "Check surface connectivities.\n");
+ else if (aFuse.ErrorStatus() != 0)
+ "OCC internal error.\n");
+ TopTools_ListOfShape shapes;
+ shapes.Assign( aFuse.Modified(*face_ptr));
+ face_ptr = & (TopoDS::Face(shapes.First()));
+ Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(*face_ptr);
+ BRepBuilderAPI_MakeShell aMakeShell(HGeom_surface);
+ if(!aMakeShell.IsDone())
+ TopoDS_Shell aShell = aMakeShell.Shell();
+ BRepBuilderAPI_MakeSolid aMakeSolid(aShell);
+ if (!aMakeSolid.IsDone())
+ TopoDS_Solid aSolid = aMakeSolid.Solid();
+ return
+ OCCQueryEngine::instance()->populate_topology_bridge(aSolid, CUBIT_TRUE);
// Function : make_BodySM
// Description: make a BodySM
-// Date : 10/02
+// Date : 02/08
BodySM* OCCModifyEngine::make_BodySM( Surface *surface ) const
More information about the cgma-dev
