[cgma-dev] r1574 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Fri Feb 1 14:09:22 CST 2008
Author: janehu
Date: 2008-02-01 14:09:22 -0600 (Fri, 01 Feb 2008)
New Revision: 1574
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added make_Curve for parabola and hyperbola type.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-01-31 22:40:16 UTC (rev 1573)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-02-01 20:09:22 UTC (rev 1574)
@@ -14,13 +14,22 @@
#include "config.h"
#include "gp_Pnt.hxx"
+#include "gp_Ax2.hxx"
+#include "gp_Dir.hxx"
+#include "gp_Hypr.hxx"
+#include "gp_Parab.hxx"
#include "TopoDS_Shape.hxx"
#include "TColgp_Array1OfPnt.hxx"
+#include "GC_MakeArcOfCircle.hxx"
+#include "GC_MakeArcOfHyperbola.hxx"
+#include "GC_MakeArcOfParabola.hxx"
+#include "GC_MakeSegment.hxx"
#include "Geom_BezierCurve.hxx"
#include "BRepBuilderAPI_MakeEdge.hxx"
#include "BRep_Tool.hxx"
#include "TopoDS.hxx"
#include "TopologyBridge.hpp"
+#include "Handle_Geom_TrimmedCurve.hxx"
#include "OCCModifyEngine.hpp"
#include "OCCQueryEngine.hpp"
#include "CubitMessage.hpp"
@@ -292,6 +301,9 @@
// For PARABOLA_CURVE_TYPE
// intermediate_point_ptr is the tip of the parabola
+// For HYPERBOLA_CURVE_TYPE
+// intermediate_point_ptr is the center of its two foci
// For ELLIPSE_CURVE_TYPE
// intermediate_point_ptr is the center of the ellipse
// sense is used to determine which part of the ellipse is required
@@ -314,13 +326,6 @@
if (intermediate_point_ptr != NULL )
mid_points.append(&mid_point);
- Point const* tmp_point = point1_ptr;
- if (sense == CUBIT_REVERSED)
- point1_ptr = point2_ptr;
- point2_ptr = tmp_point;
if(curve_type == SPLINE_CURVE_TYPE)
return make_Curve(curve_type, point1_ptr, point2_ptr, mid_points);
@@ -332,76 +337,100 @@
CubitVector v3;
gp_Pnt pt3;
+ double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
+ Handle(Geom_TrimmedCurve) curve_ptr;
if(intermediate_point_ptr != NULL)
v3 = point1_ptr->coordinates();
- pt3.SetValue(v3.x(),v3.y(), v3.z());
+ pt3.SetCoord(v3.x(),v3.y(), v3.z());
if (curve_type == STRAIGHT_CURVE_TYPE)
- Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeSegment(pt1,pt2);
+ curve_ptr = GC_MakeSegment(pt1,pt2);
else if (curve_type == ARC_CURVE_TYPE)
assert(intermediate_point_ptr != NULL);
- Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeArcOfCircle(pt1, pt2, pt3);
+ curve_ptr = GC_MakeArcOfCircle(pt1, pt2, pt3);
else if (curve_type == ELLIPSE_CURVE_TYPE)
- Handle(Geom_TrimmedCurve) curve_ptr = GC_MakeArcOfEllipse(
+ //curve_ptr = GC_MakeArcOfEllipse(
- else if(curve_type == PARABOLA_CURVE_TYPE)
+ else if(curve_type == PARABOLA_CURVE_TYPE ||
+ curve_type == HYPERBOLA_CURVE_TYPE)
- //find the directrix and focus of this parabola
+ //find the directrix and focus of the parabola
+ //or the axis, major radius and minor radius of the hyperbola
CubitVector width_vec = v2 - v1;
CubitVector midpoint_vec = (v1 + v2)/2.0;
- CubitVector height_vec = v3 - midpoint_vec;
- // Find the focus of this parabola.
- // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2,
- // and since we have restricted this parabola to be symmetric (per the FastQ
- // method, see the FastQ file getwt.f), we can use the following relationship
- // to determine "a", the distance the focus lies from the peak on the line
- // formed by the peak and the midpoint of the start and end points`
- else if(curve_type == HYPERBOLA_CURVE_TYPE)
- assert(intermediate_point_ptr != NULL);
- //given two foci and a third point on the curve
- // if a = 1/2 length major axis, b = 1/2 length minor axis and
- // c = distance center to focus, then a*a + b*b = c*c
- CubitVector midpoint_vec = (v1 + v2)/2.0;
- gp_Pnt center(midpoint_vec.x(), midpoint_vec.y(), midpoint_vec.z());
- //x direction:
- CubitVector x = v1 - v2;
- if(x.length() > 0.000001)
- x.normalize();
- else
+ CubitVector height_vec = midpoint_vec - v3;
+ gp_Pnt center(v3.x(), v3.y(), v3.z());
+ if (height_vec.length_squared() < tol * tol)
+ PRINT_ERROR("Cannot create a parabola or hyperbola curve from the given points.\n"
+ "3 points are in the same line.\n");
+ return (Curve *)NULL;
+ CubitVector x = height_vec;
+ x.normalize();
+ gp_Dir x_dir(x.x(), x.y(), x.z());
+ CubitVector N = x * (v2 - v1);
+ if (N.length_squared() < tol * tol)
- //main direction:
- CubitVector N = x * (v3 - v1);
- if (N.length() > 0.000001)
- N.normalize();
+ gp_Dir N_dir(N.x(), N.y(), N.z());
+ gp_Ax2 axis(center, N_dir, x_dir);
+ if(curve_type == HYPERBOLA_CURVE_TYPE)
+ // (focus2) (v3) . (v2)
+ // . . . (midpoint = focus1)
+ // . (v1)
+ CubitVector focus2 = 2 * v3 - midpoint_vec;
+ //according to the definition of hyperbola,
+ //2 * a = length(v2 - focus2)-length(v2 - focus1)
+ double major = (v2 - focus2).length()/2.0 - (v2 - midpoint_vec).length()/2.0;
+ // if a = 1/2 length major axis, b = 1/2 length minor axis and
+ // c = distance center to focus, then a*a + b*b = c*c
+ double c_squared = (midpoint_vec - v3).length_squared();
+ double minor = sqrt(c_squared - major*major );
+ gp_Hypr hypt(axis, major, minor);
+ curve_ptr =
+ GC_MakeArcOfHyperbola(hypt, pt1, pt2, CUBIT_TRUE);
else
- gp_Ax2 axis(center, N, x);
- double major = x.length()/2.0;
- double minor = sqrt((center - v1).length() ^ 2 - major ^ 2);
- gp_Hypr hypt(axis, major, minor);
-A
-A
+ // Find the focus of this parabola.
+ // Since for a parabola with its peak at the origin, y = (1/(4*a))*x^2,
+ // and since we have restricted this parabola to be symmetric (per the
+ // FastQ method, see the FastQ file getwt.f), we can use the following
+ // relationship to
+ // determine "a", the distance the focus lies from the peak on the line
+ // formed by the peak and the midpoint of the start and end points`
+ double a = width_vec.length_squared()/(16. * height_vec.length());
+ gp_Parab parab(axis, a);
+ curve_ptr =
+ GC_MakeArcOfParabola(parab, pt1, pt2, CUBIT_TRUE);
TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
More information about the cgma-dev
