[cgma-dev] r2501 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Dec 29 14:13:12 CST 2008
Author: janehu
Date: 2008-12-29 14:13:12 -0600 (Mon, 29 Dec 2008)
New Revision: 2501
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Simplified create_arc_three for curves;Implemented create_arc_center_edge mothod.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-24 18:30:44 UTC (rev 2500)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-29 20:13:12 UTC (rev 2501)
@@ -19,6 +19,7 @@
#include "gp_Parab.hxx"
#include "gp_Elips.hxx"
#include "gp_Pln.hxx"
+#include "gp_Circ.hxx"
#include "gp_Cylinder.hxx"
#include "gp_Cone.hxx"
#include "gp_Sphere.hxx"
@@ -36,6 +37,7 @@
#include "TColgp_Array1OfPnt.hxx"
#include "GC_MakeArcOfCircle.hxx"
#include "GC_MakeCircle.hxx"
+#include "Geom_Circle.hxx"
#include "GC_MakeArcOfHyperbola.hxx"
#include "GC_MakeArcOfParabola.hxx"
#include "GC_MakeArcOfEllipse.hxx"
@@ -5161,7 +5163,7 @@
assert(0);
int_tool.closest_points_on_segments(vt1, int_pt11, vt3, int_pt31, c_p11, c_p12, sc, tc);
- if(c_p11.distance_between(c_p12) < tol && sc < 1.0 && tc < 1.0) //intersect
+ if(c_p11.distance_between(c_p12) < tol ) //intersect
if(c_p.distance_between(c_p12) < tol) //three line intersects at same point
@@ -5179,7 +5181,7 @@
int_pt11 = int_pt12;
else
- continue;
+ i++;
if(i == 1)
@@ -5191,14 +5193,14 @@
int_pt21 = int_pt22;
else
- continue;
+ i += 2;
if(i == 2)
if(found[1] && found[3])
else
- continue;
+ assert(0);
if(i == 3)
@@ -5212,7 +5214,7 @@
int_pt31 = int_pt32;
else
- continue;
+ break;
if(i == 4)
@@ -5255,17 +5257,99 @@
// Function : create_arc_center_edge
// Member Type: PUBLIC
// Description:
-// Author : John Fowler
-// Date : 10/02
+// Author : Jane Hu
+// Date : 12/08
-Curve* OCCModifyEngine::create_arc_center_edge( Point* /*ref_vertex1*/,
- Point* /*ref_vertex2*/,
- Point* /*ref_vertex3*/,
- const CubitVector& /*normal*/,
- double /*radius*/,
- bool /*full*/ )
+Curve* OCCModifyEngine::create_arc_center_edge( Point* pt1,
+ Point* pt2,
+ Point* pt3,
+ const CubitVector& normal,
+ double radius,
+ bool full )
- return NULL;
+ CubitVector vec1 = pt1->coordinates(); // Center of arc
+ CubitVector vec2 = pt2->coordinates(); // Position on arc
+ CubitVector vec3 = pt3->coordinates(); // Position on arc
+ CubitVector dir1( vec1, vec2 );
+ CubitVector dir2( vec1, vec3 );
+ double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
+ // Re-adjust vec2, vec3 if radius was given
+ if( radius != CUBIT_DBL_MAX )
+ CubitVector vec;
+ vec1.next_point( dir1, radius, vec );
+ if(vec.distance_between(vec2) > tol)
+ vec2 = vec;
+ pt2 = new OCCPoint(vec);
+ vec1.next_point( dir2, radius, vec );
+ if(vec.distance_between(vec3) > tol)
+ vec3 = vec;
+ pt3 = new OCCPoint(vec);
+ else
+ radius = vec1.distance_between(vec2);
+ CubitVector vec;
+ vec3 = vec;
+ CubitVector normal_dir = normal;
+ if(normal_dir.length() > tol)
+ normal_dir.normalize();
+ //verify sense
+ if((dir1 * dir2) % normal_dir < 0.0)
+ Point* p = pt2;
+ pt2 = pt3;
+ pt3 = p;
+ else if((dir1 * dir2) % normal_dir == 0.0)
+ PRINT_ERROR("Normal can't be on the plan of the arc.\n");
+ return (Curve*) NULL;
+ else
+ normal_dir = dir1 * dir2;
+ Handle(Geom_Circle) curve_ptr;
+ gp_Dir norm(normal_dir.x(), normal_dir.y(), normal_dir.z());
+ gp_Pnt center = gp_Pnt( vec1.x(), vec1.y(), vec1.z());
+ curve_ptr = GC_MakeCircle(center,norm,radius);
+ OCCPoint* occ_pt1 = CAST_TO(const_cast<Point*>(pt2),OCCPoint);
+ TopoDS_Vertex * vt1 = occ_pt1->get_TopoDS_Vertex();
+ if(full)
+ TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr, *vt1, *vt1);
+ return OCCQueryEngine::instance()->populate_topology_bridge(new_edge);
+ else
+ Handle(Geom_TrimmedCurve) arc;
+ gp_Pnt on_arc1 = gp_Pnt( vec2.x(), vec2.y(), vec2.z());
+ gp_Pnt on_arc2 = gp_Pnt( vec3.x(), vec3.y(), vec3.z());
+ arc = GC_MakeArcOfCircle(curve_ptr->Circ(), on_arc1, on_arc2, Standard_True);
+ OCCPoint* occ_pt2 = CAST_TO(const_cast<Point*>(pt3),OCCPoint);
+ TopoDS_Vertex * vt2 = occ_pt2->get_TopoDS_Vertex();
+ TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(arc, *vt1, *vt2);
CubitStatus
More information about the cgma-dev
