[cgma-dev] r2500 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Dec 24 12:30:44 CST 2008
Author: janehu
Date: 2008-12-24 12:30:44 -0600 (Wed, 24 Dec 2008)
New Revision: 2500
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Since multiple solutions are possible for create_arc_three with 3 curves, it needs to verify that the 3 bisection lines are intersecting at the same point, if multipul solutions exist, find the first reasonable solution, otherwise gives error messages.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-23 20:15:23 UTC (rev 2499)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-12-24 18:30:44 UTC (rev 2500)
@@ -30,6 +30,7 @@
#include "BRepBuilderAPI_MakeWire.hxx"
#include "BRepPrimAPI_MakeHalfSpace.hxx"
#include "BRepBndLib.hxx"
+#include "IntersectionTool.hpp"
#include "TopoDS_Shape.hxx"
#include "TopAbs_Orientation.hxx"
#include "TColgp_Array1OfPnt.hxx"
@@ -5042,68 +5043,211 @@
CubitVector p32 = vt3 + t_curve32;
//3. find the intersection of each of the bisection curve with the third curve
- CubitVector int_pt1, int_pt2, int_pt3;
+ //Error out if there's multiple solutions,urge user to shorten the curves to
+ //make the intention clear.
+ CubitVector int_pt11, int_pt12, int_pt21, int_pt22, int_pt31, int_pt32;
intscts.clean_out();
OCCQueryEngine::instance()->get_intersections(curve3, vt1, p11, intscts,none,none);
CubitVector int_pt = *intscts.pop();
u = occ_crv3->u_from_position (int_pt);
+ CubitBoolean found[6] = {CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE,
+ CUBIT_FALSE, CUBIT_FALSE};
if(u >= u31-tol && u <= u32+tol) //found intersection point
- int_pt1 = int_pt;
- else
- OCCQueryEngine::instance()->get_intersections(curve3, vt1, p12, intscts,none,none);
- int_pt = *intscts.pop();
- u = occ_crv3->u_from_position (int_pt);
- if(u >= u31-tol && u <= u32+tol)
- int_pt1 = int_pt;
+ int_pt11 = int_pt;
+ found[0] = CUBIT_TRUE;
+ OCCQueryEngine::instance()->get_intersections(curve3, vt1, p12, intscts,none,none);
+ int_pt = *intscts.pop();
+ u = occ_crv3->u_from_position (int_pt);
+ if(u >= u31-tol && u <= u32+tol)
+ if(found[0])
+ found[1] = CUBIT_TRUE;
+ int_pt12 = int_pt;
else
- PRINT_ERROR("Can't find the intesection point to create circle.\n");
- return (Curve*) NULL;
+ if(!found[0] )
+ PRINT_ERROR("Can't find the intesection point to create circle.\n");
+ return (Curve*) NULL;
OCCQueryEngine::instance()->get_intersections(curve1, vt2, p21, intscts,none,none);
u = occ_crv1->u_from_position (int_pt);
if(u >= u11-tol && u <= u12+tol) //found intersection point
- int_pt2 = int_pt;
- else
- OCCQueryEngine::instance()->get_intersections(curve1, vt2, p22, intscts,none,none);
- u = occ_crv1->u_from_position (int_pt);
- if(u >= u11-tol && u <= u12+tol)
- int_pt2 = int_pt;
+ found[2] = CUBIT_TRUE;
+ int_pt21 = int_pt;
+ OCCQueryEngine::instance()->get_intersections(curve1, vt2, p22, intscts,none,none);
+ u = occ_crv1->u_from_position (int_pt);
+ if(u >= u11-tol && u <= u12+tol)
+ if(found[2])
+ int_pt22 = int_pt;
+ found[3] = CUBIT_TRUE;
else
+ if(!found[2] )
OCCQueryEngine::instance()->get_intersections(curve2, vt3, p31, intscts,none,none);
u = occ_crv2->u_from_position (int_pt);
if(u >= u21-tol && u <= u22+tol) //found intersection point
- int_pt3 = int_pt;
- else
- OCCQueryEngine::instance()->get_intersections(curve2, vt3, p32, intscts,none,none);
- u = occ_crv2->u_from_position (int_pt);
- if(u >= u21-tol && u <= u22+tol)
- int_pt3 = int_pt;
+ found[4] = CUBIT_TRUE;
+ int_pt31 = int_pt;
+ OCCQueryEngine::instance()->get_intersections(curve2, vt3, p32, intscts,none,none);
+ u = occ_crv2->u_from_position (int_pt);
+ if(u >= u21-tol && u <= u22+tol)
+ if(found[4])
+ int_pt32 = int_pt;
+ found[5] = CUBIT_TRUE;
else
+ if(!found[4] )
+ //find the three intersection points which when connected with the vertices,
+ //intersect at same point.
+ CubitVector c_p11, c_p12, c_p21, c_p22, c_p31, c_p32, c_p;
+ double sc, tc;
+ CubitVector int_pt1, int_pt2, int_pt3;
+ CubitBoolean find = CUBIT_FALSE;
+ IntersectionTool int_tool;
+ for(int i = 0; i < 8 ; i++)
+ int_tool.closest_points_on_segments(vt1, int_pt11, vt2, int_pt21, c_p11, c_p12, sc, tc);
+ if(c_p11.distance_between(c_p12) < tol) //intersect
+ c_p = c_p11;
+ else
+ assert(0);
+ int_tool.closest_points_on_segments(vt1, int_pt11, vt3, int_pt31, c_p11, c_p12, sc, tc);
+ if(c_p11.distance_between(c_p12) < tol && sc < 1.0 && tc < 1.0) //intersect
+ if(c_p.distance_between(c_p12) < tol) //three line intersects at same point
+ find = CUBIT_TRUE;
+ break;
+ else //not interscting at same points or parallel
+ if(i == 0)
+ if(found[1])
+ int_pt1 = int_pt11;
+ int_pt11 = int_pt12;
+ else
+ continue;
+ if(i == 1)
+ if(found[1])
+ int_pt11 = int_pt1;
+ if(found[3])
+ int_pt2 = int_pt21;
+ int_pt21 = int_pt22;
+ else
+ continue;
+ if(i == 2)
+ if(found[1] && found[3])
+ else
+ continue;
+ if(i == 3)
+ if(found[1])
+ if(found[3])
+ int_pt21 = int_pt2;
+ if(found[5])
+ int_pt3 = int_pt31;
+ int_pt31 = int_pt32;
+ else
+ continue;
+ if(i == 4)
+ if(found[1] && found[5])
+ else
+ continue;
+ if(i == 5)
+ if(found[1])
+ if(found[3] && found[5])
+ else
+ continue;
+ if(i == 6)
+ if(found[1] && found[3] && found[5])
+ else
+ continue;
+ if(!find)
//4. use the 3 intersection points to find the arc or circle.
- OCCPoint occ_p1(int_pt1);
- OCCPoint occ_p2(int_pt2);
- OCCPoint occ_p3(int_pt3);
+ OCCPoint occ_p1(int_pt11);
+ OCCPoint occ_p2(int_pt21);
+ OCCPoint occ_p3(int_pt31);
return create_arc_three(&occ_p1, &occ_p2, &occ_p3, full);
More information about the cgma-dev
