[cgma-dev] r2483 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Dec 15 13:30:48 CST 2008
Author: janehu
Date: 2008-12-15 13:30:48 -0600 (Mon, 15 Dec 2008)
New Revision: 2483
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added reader for iges or step files, not testing yet.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-12 20:02:20 UTC (rev 2482)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-15 19:30:48 UTC (rev 2483)
@@ -35,6 +35,9 @@
#include "Handle_Poly_Triangulation.hxx"
#include "GCPnts_TangentialDeflection.hxx"
#include "BRepAdaptor_Curve.hxx"
+#include "STEPControl_Reader.hxx"
+#include "IGESControl_Reader.hxx"
+#include "IFSelect_ReturnStatus.hxx"
#include "BndLib_Add3dCurve.hxx"
#include "Poly_Polygon3D.hxx"
#include "Handle_Poly_Polygon3D.hxx"
@@ -1122,7 +1125,8 @@
DLIList<TopologyBridge*> &bridge_list )
//make sure that file_type == "OCC"
- if( !strcmp( file_type,"OCC") )
+ if( !strcmp( file_type,"OCC") || !strcmp( file_type,"IGES") ||
+ !strcmp( file_type,"STEP") )
return import_solid_model( file_name, file_type, bridge_list );
else
return CUBIT_FAILURE;
@@ -1150,10 +1154,38 @@
CubitBoolean free_surfaces)
TopoDS_Shape *aShape = new TopoDS_Shape;
- BRep_Builder aBuilder;
- Standard_Boolean result = Read(*aShape, (char*) file_name, mainLabel, print_results);
- if (result==0) return CUBIT_FAILURE;
+ //BRep_Builder aBuilder;
+ if(strcmp(file_type ,"OCC") == 0)
+ Standard_Boolean result = Read(*aShape, (char*) file_name, mainLabel, print_results);
+ if (result==0) return CUBIT_FAILURE;
+ else if (strcmp(file_type, "STEP") == 0)
+ STEPControl_Reader reader;
+ IFSelect_ReturnStatus stat = reader.ReadFile( (char*) file_name);
+ if (stat != IFSelect_RetDone)
+ PRINT_INFO("%s: Cannot open file", file_name );
+ return CUBIT_FAILURE;
+ reader.TransferRoots();
+ *aShape = reader.OneShape();
+ else if(strcmp(file_type, "IGES") == 0)
+ IGESControl_Reader reader;
imported_entities = populate_topology_bridge(*aShape);
return CUBIT_SUCCESS;
More information about the cgma-dev
