[cgma-dev] CGM distcheck failed.
Nightly Test
kraftche at cae.wisc.edu
Sun Dec 14 02:08:49 CST 2008
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh ../trunk/configure --with-acis=/opt/acis16.7/ --with-occ=/opt/occ6.3-64 --no-create --no-recursion
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking how to run the C preprocessor... cc -E
checking for CC... no
checking for aCC... no
checking for cxx... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking dependency style of c++... gcc3
checking how to run the C++ preprocessor... c++ -E
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether byte ordering is bigendian... no
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for C++-standard library in std:: namespace... yes
checking for C++-standard I/O in std:: namespace... yes
checking if C++ template definitions should be included... yes
checking for ../trunk/geom/ACIS/AcisQueryEngine.hpp... yes
checking for /opt/acis16.7//include/acis.hxx... yes
checking ACIS version of /opt/acis16.7//bin/linux_amd_64_so ... 1607
checking ACIS platform name... linux
checking for main in -lxstep... no
checking for main in -lxiges... no
checking new.h usability... no
checking new.h presence... no
checking for new.h... no
checking for 'include' subdir of /opt/occ6.3-64... inc
checking for 'lib' subdir of /opt/occ6.3-64... lib
checking if platform is 64-bit (-D_OCC64)... yes
checking iostream usability... yes
checking iostream presence... yes
checking for iostream... yes
checking iostream.h usability... no
checking iostream.h presence... no
checking for iostream.h... no
checking iomanip usability... yes
checking iomanip presence... yes
checking for iomanip... yes
checking iomanip.h usability... no
checking iomanip.h presence... no
checking for iomanip.h... no
checking fstream usability... yes
checking fstream presence... yes
checking for fstream... yes
checking fstream.h usability... no
checking fstream.h presence... no
checking for fstream.h... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking Standard_Version.hxx usability... yes
checking Standard_Version.hxx presence... yes
checking for Standard_Version.hxx... yes
checking for create_mailbox in -lTKernel... no
checking for create_mailbox in -lTKernel... yes
CXXFLAGS = -Wall -pipe -pedantic -O2 -DNDEBUG
configure: creating ./config.status
config.status: creating Makefile
config.status: creating util/Makefile
config.status: creating geom/Makefile
config.status: creating geom/ACIS/Makefile
config.status: creating geom/Cholla/Makefile
config.status: creating geom/facet/Makefile
config.status: creating geom/facetbool/Makefile
config.status: creating geom/OCC/Makefile
config.status: creating geom/parallel/Makefile
config.status: creating geom/virtual/Makefile
config.status: creating init/Makefile
config.status: creating compat/Makefile
config.status: creating cgm.make
config.status: creating itaps/Makefile
config.status: creating itaps/iGeom-Defs.inc
config.status: creating itaps/SIDL/Makefile
config.status: creating test/Makefile
config.status: creating cgm_apps/Makefile
config.status: creating cgm_apps/examples/Makefile
config.status: creating cgm_apps/examples/driverc++/Makefile
config.status: creating cgm_apps/examples/facetdriver/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating itaps/iBase_FCDefs.h
config.status: itaps/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
{ test ! -d CGMA-10.2.2 || { find CGMA-10.2.2 -type d ! -perm -200 -exec chmod u+w {} ';' && rm -fr CGMA-10.2.2; }; }
test -d CGMA-10.2.2 || mkdir CGMA-10.2.2
list='compat util geom init . itaps test cgm_apps'; for subdir in $list; do \
if test "$subdir" = .; then :; else \
test -d "CGMA-10.2.2/$subdir" \
|| /bin/mkdir -p "CGMA-10.2.2/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd CGMA-10.2.2 && pwd`; \
top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd CGMA-10.2.2 && pwd`; \
(cd $subdir && \
make \
top_distdir="$top_distdir" \
distdir="$distdir/$subdir" \
am__remove_distdir=: \
am__skip_length_check=: \
distdir) \
|| exit 1; \
fi; \
done
make[1]: Entering directory `/home/jason/cgm/test/dist/compat'
make[1]: Leaving directory `/home/jason/cgm/test/dist/compat'
make[1]: Entering directory `/home/jason/cgm/test/dist/util'
make[1]: Leaving directory `/home/jason/cgm/test/dist/util'
make[1]: Entering directory `/home/jason/cgm/test/dist/geom'
list='. Cholla facetbool facet virtual ACIS parallel OCC'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/geom/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/geom/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/geom && pwd`; \
top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2 && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/Cholla'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/Cholla'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/facet'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/virtual'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/ACIS'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/parallel'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/parallel'
make[2]: Entering directory `/home/jason/cgm/test/dist/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/dist/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/dist/geom'
make[1]: Entering directory `/home/jason/cgm/test/dist/init'
make[1]: Leaving directory `/home/jason/cgm/test/dist/init'
make[1]: Entering directory `/home/jason/cgm/test/dist/itaps'
cd ../../trunk && /bin/sh /home/jason/cgm/test/trunk/missing --run autoheader
rm -f stamp-h2
touch ../../trunk/itaps/iBase_FCDefs.h.in
cd .. && /bin/sh ./config.status itaps/iBase_FCDefs.h
list='. SIDL'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/itaps/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/itaps/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/itaps && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/itaps/SIDL'
make[2]: Leaving directory `/home/jason/cgm/test/dist/itaps/SIDL'
make[1]: Leaving directory `/home/jason/cgm/test/dist/itaps'
make[1]: Entering directory `/home/jason/cgm/test/dist/test'
make[1]: Leaving directory `/home/jason/cgm/test/dist/test'
make[1]: Entering directory `/home/jason/cgm/test/dist/cgm_apps'
list='examples'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[2]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples'
list='driverc++ facetdriver'; for subdir in $list; do \
test -d "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples/$subdir" \
|| /bin/mkdir -p "/home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /home/jason/cgm/test/dist/CGMA-10.2.2/cgm_apps/examples && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[3]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples/driverc++'
make[3]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples/driverc++'
make[3]: Entering directory `/home/jason/cgm/test/dist/cgm_apps/examples/facetdriver'
make[3]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples/facetdriver'
make[2]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps/examples'
make[1]: Leaving directory `/home/jason/cgm/test/dist/cgm_apps'
find CGMA-10.2.2 -type d ! -perm -777 -exec chmod a+rwx {} \; -o \
! -type d ! -perm -444 -links 1 -exec chmod a+r {} \; -o \
! -type d ! -perm -400 -exec chmod a+r {} \; -o \
! -type d ! -perm -444 -exec /bin/sh /home/jason/cgm/test/trunk/install-sh -c -m a+r {} {} \; \
|| chmod -R a+r CGMA-10.2.2
tardir=CGMA-10.2.2 && /bin/sh /home/jason/cgm/test/trunk/missing --run tar chof - "$tardir" | GZIP=--best gzip -c >CGMA-10.2.2.tar.gz
case 'CGMA-10.2.2.tar.gz' in \
*.tar.gz*) \
GZIP=--best gunzip -c CGMA-10.2.2.tar.gz | /bin/sh /home/jason/cgm/test/trunk/missing --run tar xf - ;;\
*.tar.bz2*) \
bunzip2 -c CGMA-10.2.2.tar.bz2 | /bin/sh /home/jason/cgm/test/trunk/missing --run tar xf - ;;\
*.tar.lzma*) \
unlzma -c CGMA-10.2.2.tar.lzma | /bin/sh /home/jason/cgm/test/trunk/missing --run tar xf - ;;\
*.tar.Z*) \
uncompress -c CGMA-10.2.2.tar.Z | /bin/sh /home/jason/cgm/test/trunk/missing --run tar xf - ;;\
*.shar.gz*) \
GZIP=--best gunzip -c CGMA-10.2.2.shar.gz | unshar ;;\
*.zip*) \
unzip CGMA-10.2.2.zip ;;\
esac
chmod -R a-w CGMA-10.2.2; chmod a+w CGMA-10.2.2
mkdir CGMA-10.2.2/_build
mkdir CGMA-10.2.2/_inst
chmod a-w CGMA-10.2.2
dc_install_base=`CDPATH="${ZSH_VERSION+.}:" && cd CGMA-10.2.2/_inst && pwd | sed -e 's,^[^:\\/]:[\\/],/,'` \
&& dc_destdir="${TMPDIR-/tmp}/am-dc-$$/" \
&& cd CGMA-10.2.2/_build \
&& ../configure --srcdir=.. --prefix="$dc_install_base" \
--with-acis="/opt/acis16.7/" --with-occ="/opt/occ6.3-64" \
&& make \
&& make dvi \
&& make check \
&& make install \
&& make installcheck \
&& make uninstall \
&& make distuninstallcheck_dir="$dc_install_base" \
distuninstallcheck \
&& chmod -R a-w "$dc_install_base" \
(cd ../.. && umask 077 && mkdir "$dc_destdir") \
&& make DESTDIR="$dc_destdir" install \
&& make DESTDIR="$dc_destdir" uninstall \
&& make DESTDIR="$dc_destdir" \
distuninstallcheck_dir="$dc_destdir" distuninstallcheck; \
} || { rm -rf "$dc_destdir"; exit 1; }) \
&& rm -rf "$dc_destdir" \
&& make dist \
&& rm -rf CGMA-10.2.2.tar.gz \
&& make distcleancheck
checking for ../geom/ACIS/AcisQueryEngine.hpp... yes
make[1]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make all-recursive
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
Making all in compat
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/compat'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/compat'
Making all in util
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersList.lo -MD -MP -MF .deps/AllocMemManagersList.Tpo -c -o AllocMemManagersList.lo ../../util/AllocMemManagersList.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersList.lo -MD -MP -MF .deps/AllocMemManagersList.Tpo -c ../../util/AllocMemManagersList.cpp -o AllocMemManagersList.o
mv -f .deps/AllocMemManagersList.Tpo .deps/AllocMemManagersList.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AppUtil.lo -MD -MP -MF .deps/AppUtil.Tpo -c -o AppUtil.lo ../../util/AppUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AppUtil.lo -MD -MP -MF .deps/AppUtil.Tpo -c ../../util/AppUtil.cpp -o AppUtil.o
mv -f .deps/AppUtil.Tpo .deps/AppUtil.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ArrayBasedContainer.lo -MD -MP -MF .deps/ArrayBasedContainer.Tpo -c -o ArrayBasedContainer.lo ../../util/ArrayBasedContainer.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ArrayBasedContainer.lo -MD -MP -MF .deps/ArrayBasedContainer.Tpo -c ../../util/ArrayBasedContainer.cpp -o ArrayBasedContainer.o
../../util/ArrayBasedContainer.cpp: In member function ‘ArrayBasedContainer& ArrayBasedContainer::operator=(const ArrayBasedContainer&)’:
../../util/ArrayBasedContainer.cpp:143: warning: suggest explicit braces to avoid ambiguous ‘else’
mv -f .deps/ArrayBasedContainer.Tpo .deps/ArrayBasedContainer.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CpuTimer.lo -MD -MP -MF .deps/CpuTimer.Tpo -c -o CpuTimer.lo ../../util/CpuTimer.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CpuTimer.lo -MD -MP -MF .deps/CpuTimer.Tpo -c ../../util/CpuTimer.cpp -o CpuTimer.o
mv -f .deps/CpuTimer.Tpo .deps/CpuTimer.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Cubit2DPoint.lo -MD -MP -MF .deps/Cubit2DPoint.Tpo -c -o Cubit2DPoint.lo ../../util/Cubit2DPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Cubit2DPoint.lo -MD -MP -MF .deps/Cubit2DPoint.Tpo -c ../../util/Cubit2DPoint.cpp -o Cubit2DPoint.o
mv -f .deps/Cubit2DPoint.Tpo .deps/Cubit2DPoint.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitBox.lo -MD -MP -MF .deps/CubitBox.Tpo -c -o CubitBox.lo ../../util/CubitBox.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitBox.lo -MD -MP -MF .deps/CubitBox.Tpo -c ../../util/CubitBox.cpp -o CubitBox.o
mv -f .deps/CubitBox.Tpo .deps/CubitBox.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitCollection.lo -MD -MP -MF .deps/CubitCollection.Tpo -c -o CubitCollection.lo ../../util/CubitCollection.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitCollection.lo -MD -MP -MF .deps/CubitCollection.Tpo -c ../../util/CubitCollection.cpp -o CubitCollection.o
mv -f .deps/CubitCollection.Tpo .deps/CubitCollection.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitContainer.lo -MD -MP -MF .deps/CubitContainer.Tpo -c -o CubitContainer.lo ../../util/CubitContainer.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitContainer.lo -MD -MP -MF .deps/CubitContainer.Tpo -c ../../util/CubitContainer.cpp -o CubitContainer.o
mv -f .deps/CubitContainer.Tpo .deps/CubitContainer.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitCoordinateSystem.lo -MD -MP -MF .deps/CubitCoordinateSystem.Tpo -c -o CubitCoordinateSystem.lo ../../util/CubitCoordinateSystem.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitCoordinateSystem.lo -MD -MP -MF .deps/CubitCoordinateSystem.Tpo -c ../../util/CubitCoordinateSystem.cpp -o CubitCoordinateSystem.o
mv -f .deps/CubitCoordinateSystem.Tpo .deps/CubitCoordinateSystem.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitDynamicLoader.lo -MD -MP -MF .deps/CubitDynamicLoader.Tpo -c -o CubitDynamicLoader.lo ../../util/CubitDynamicLoader.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitDynamicLoader.lo -MD -MP -MF .deps/CubitDynamicLoader.Tpo -c ../../util/CubitDynamicLoader.cpp -o CubitDynamicLoader.o
mv -f .deps/CubitDynamicLoader.Tpo .deps/CubitDynamicLoader.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitEntity.lo -MD -MP -MF .deps/CubitEntity.Tpo -c -o CubitEntity.lo ../../util/CubitEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitEntity.lo -MD -MP -MF .deps/CubitEntity.Tpo -c ../../util/CubitEntity.cpp -o CubitEntity.o
mv -f .deps/CubitEntity.Tpo .deps/CubitEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFile.lo -MD -MP -MF .deps/CubitFile.Tpo -c -o CubitFile.lo ../../util/CubitFile.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFile.lo -MD -MP -MF .deps/CubitFile.Tpo -c ../../util/CubitFile.cpp -o CubitFile.o
mv -f .deps/CubitFile.Tpo .deps/CubitFile.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileFEModel.lo -MD -MP -MF .deps/CubitFileFEModel.Tpo -c -o CubitFileFEModel.lo ../../util/CubitFileFEModel.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileFEModel.lo -MD -MP -MF .deps/CubitFileFEModel.Tpo -c ../../util/CubitFileFEModel.cpp -o CubitFileFEModel.o
mv -f .deps/CubitFileFEModel.Tpo .deps/CubitFileFEModel.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileIOWrapper.lo -MD -MP -MF .deps/CubitFileIOWrapper.Tpo -c -o CubitFileIOWrapper.lo ../../util/CubitFileIOWrapper.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileIOWrapper.lo -MD -MP -MF .deps/CubitFileIOWrapper.Tpo -c ../../util/CubitFileIOWrapper.cpp -o CubitFileIOWrapper.o
mv -f .deps/CubitFileIOWrapper.Tpo .deps/CubitFileIOWrapper.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileMetaData.lo -MD -MP -MF .deps/CubitFileMetaData.Tpo -c -o CubitFileMetaData.lo ../../util/CubitFileMetaData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileMetaData.lo -MD -MP -MF .deps/CubitFileMetaData.Tpo -c ../../util/CubitFileMetaData.cpp -o CubitFileMetaData.o
mv -f .deps/CubitFileMetaData.Tpo .deps/CubitFileMetaData.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileUtil.lo -MD -MP -MF .deps/CubitFileUtil.Tpo -c -o CubitFileUtil.lo ../../util/CubitFileUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFileUtil.lo -MD -MP -MF .deps/CubitFileUtil.Tpo -c ../../util/CubitFileUtil.cpp -o CubitFileUtil.o
mv -f .deps/CubitFileUtil.Tpo .deps/CubitFileUtil.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitMatrix.lo -MD -MP -MF .deps/CubitMatrix.Tpo -c -o CubitMatrix.lo ../../util/CubitMatrix.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitMatrix.lo -MD -MP -MF .deps/CubitMatrix.Tpo -c ../../util/CubitMatrix.cpp -o CubitMatrix.o
mv -f .deps/CubitMatrix.Tpo .deps/CubitMatrix.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitMessage.lo -MD -MP -MF .deps/CubitMessage.Tpo -c -o CubitMessage.lo ../../util/CubitMessage.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitMessage.lo -MD -MP -MF .deps/CubitMessage.Tpo -c ../../util/CubitMessage.cpp -o CubitMessage.o
../../util/CubitMessage.cpp: In static member function ‘static void CubitMessage::initialize_settings()’:
../../util/CubitMessage.cpp:795: warning: deprecated conversion from string constant to ‘char*’
../../util/CubitMessage.cpp:803: warning: deprecated conversion from string constant to ‘char*’
../../util/CubitMessage.cpp:807: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/CubitMessage.Tpo .deps/CubitMessage.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitObservable.lo -MD -MP -MF .deps/CubitObservable.Tpo -c -o CubitObservable.lo ../../util/CubitObservable.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitObservable.lo -MD -MP -MF .deps/CubitObservable.Tpo -c ../../util/CubitObservable.cpp -o CubitObservable.o
mv -f .deps/CubitObservable.Tpo .deps/CubitObservable.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitObserver.lo -MD -MP -MF .deps/CubitObserver.Tpo -c -o CubitObserver.lo ../../util/CubitObserver.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitObserver.lo -MD -MP -MF .deps/CubitObserver.Tpo -c ../../util/CubitObserver.cpp -o CubitObserver.o
mv -f .deps/CubitObserver.Tpo .deps/CubitObserver.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPlane.lo -MD -MP -MF .deps/CubitPlane.Tpo -c -o CubitPlane.lo ../../util/CubitPlane.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPlane.lo -MD -MP -MF .deps/CubitPlane.Tpo -c ../../util/CubitPlane.cpp -o CubitPlane.o
mv -f .deps/CubitPlane.Tpo .deps/CubitPlane.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitStack.lo -MD -MP -MF .deps/CubitStack.Tpo -c -o CubitStack.lo ../../util/CubitStack.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitStack.lo -MD -MP -MF .deps/CubitStack.Tpo -c ../../util/CubitStack.cpp -o CubitStack.o
mv -f .deps/CubitStack.Tpo .deps/CubitStack.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitString.lo -MD -MP -MF .deps/CubitString.Tpo -c -o CubitString.lo ../../util/CubitString.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitString.lo -MD -MP -MF .deps/CubitString.Tpo -c ../../util/CubitString.cpp -o CubitString.o
../../util/CubitString.cpp: In constructor ‘CubitString::CubitString()’:
../../util/CubitString.cpp:117: warning: unused variable ‘dummy’
../../util/CubitString.cpp: In constructor ‘CubitString::CubitString(const char*)’:
../../util/CubitString.cpp:139: warning: unused variable ‘dummy’
mv -f .deps/CubitString.Tpo .deps/CubitString.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitTransformMatrix.lo -MD -MP -MF .deps/CubitTransformMatrix.Tpo -c -o CubitTransformMatrix.lo ../../util/CubitTransformMatrix.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitTransformMatrix.lo -MD -MP -MF .deps/CubitTransformMatrix.Tpo -c ../../util/CubitTransformMatrix.cpp -o CubitTransformMatrix.o
mv -f .deps/CubitTransformMatrix.Tpo .deps/CubitTransformMatrix.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitUtil.lo -MD -MP -MF .deps/CubitUtil.Tpo -c -o CubitUtil.lo ../../util/CubitUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitUtil.lo -MD -MP -MF .deps/CubitUtil.Tpo -c ../../util/CubitUtil.cpp -o CubitUtil.o
mv -f .deps/CubitUtil.Tpo .deps/CubitUtil.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitVector.lo -MD -MP -MF .deps/CubitVector.Tpo -c -o CubitVector.lo ../../util/CubitVector.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitVector.lo -MD -MP -MF .deps/CubitVector.Tpo -c ../../util/CubitVector.cpp -o CubitVector.o
../../util/CubitVector.cpp: In member function ‘CubitBoolean CubitVector::within_scaled_tolerance(const CubitVector&, double) const’:
../../util/CubitVector.cpp:350: warning: suggest parentheses around comparison in operand of ==
../../util/CubitVector.cpp:351: warning: suggest parentheses around comparison in operand of ==
../../util/CubitVector.cpp:352: warning: suggest parentheses around comparison in operand of ==
mv -f .deps/CubitVector.Tpo .deps/CubitVector.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DIntArray.lo -MD -MP -MF .deps/DIntArray.Tpo -c -o DIntArray.lo ../../util/DIntArray.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DIntArray.lo -MD -MP -MF .deps/DIntArray.Tpo -c ../../util/DIntArray.cpp -o DIntArray.o
mv -f .deps/DIntArray.Tpo .deps/DIntArray.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DLList.lo -MD -MP -MF .deps/DLList.Tpo -c -o DLList.lo ../../util/DLList.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DLList.lo -MD -MP -MF .deps/DLList.Tpo -c ../../util/DLList.cpp -o DLList.o
mv -f .deps/DLList.Tpo .deps/DLList.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DynamicArray.lo -MD -MP -MF .deps/DynamicArray.Tpo -c -o DynamicArray.lo ../../util/DynamicArray.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DynamicArray.lo -MD -MP -MF .deps/DynamicArray.Tpo -c ../../util/DynamicArray.cpp -o DynamicArray.o
mv -f .deps/DynamicArray.Tpo .deps/DynamicArray.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GMem.lo -MD -MP -MF .deps/GMem.Tpo -c -o GMem.lo ../../util/GMem.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GMem.lo -MD -MP -MF .deps/GMem.Tpo -c ../../util/GMem.cpp -o GMem.o
mv -f .deps/GMem.Tpo .deps/GMem.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GetLongOpt.lo -MD -MP -MF .deps/GetLongOpt.Tpo -c -o GetLongOpt.lo ../../util/GetLongOpt.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GetLongOpt.lo -MD -MP -MF .deps/GetLongOpt.Tpo -c ../../util/GetLongOpt.cpp -o GetLongOpt.o
mv -f .deps/GetLongOpt.Tpo .deps/GetLongOpt.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GfxDebug.lo -MD -MP -MF .deps/GfxDebug.Tpo -c -o GfxDebug.lo ../../util/GfxDebug.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GfxDebug.lo -MD -MP -MF .deps/GfxDebug.Tpo -c ../../util/GfxDebug.cpp -o GfxDebug.o
mv -f .deps/GfxDebug.Tpo .deps/GfxDebug.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT IntersectionTool.lo -MD -MP -MF .deps/IntersectionTool.Tpo -c -o IntersectionTool.lo ../../util/IntersectionTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT IntersectionTool.lo -MD -MP -MF .deps/IntersectionTool.Tpo -c ../../util/IntersectionTool.cpp -o IntersectionTool.o
mv -f .deps/IntersectionTool.Tpo .deps/IntersectionTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MemoryBlock.lo -MD -MP -MF .deps/MemoryBlock.Tpo -c -o MemoryBlock.lo ../../util/MemoryBlock.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MemoryBlock.lo -MD -MP -MF .deps/MemoryBlock.Tpo -c ../../util/MemoryBlock.cpp -o MemoryBlock.o
mv -f .deps/MemoryBlock.Tpo .deps/MemoryBlock.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MemoryManager.lo -MD -MP -MF .deps/MemoryManager.Tpo -c -o MemoryManager.lo ../../util/MemoryManager.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MemoryManager.lo -MD -MP -MF .deps/MemoryManager.Tpo -c ../../util/MemoryManager.cpp -o MemoryManager.o
../../util/MemoryManager.cpp: In static member function ‘static void MemoryManager::show_object_memory(const char*)’:
../../util/MemoryManager.cpp:230: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘size_t’
../../util/MemoryManager.cpp:232: warning: format ‘%d’ expects type ‘int’, but argument 4 has type ‘long unsigned int’
../../util/MemoryManager.cpp:237: warning: format ‘%d’ expects type ‘int’, but argument 4 has type ‘long unsigned int’
../../util/MemoryManager.cpp:240: warning: format ‘%d’ expects type ‘int’, but argument 4 has type ‘long unsigned int’
../../util/MemoryManager.cpp: In static member function ‘static void MemoryManager::show_all_object_memory()’:
../../util/MemoryManager.cpp:297: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘size_t’
mv -f .deps/MemoryManager.Tpo .deps/MemoryManager.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ParamCubitPlane.lo -MD -MP -MF .deps/ParamCubitPlane.Tpo -c -o ParamCubitPlane.lo ../../util/ParamCubitPlane.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ParamCubitPlane.lo -MD -MP -MF .deps/ParamCubitPlane.Tpo -c ../../util/ParamCubitPlane.cpp -o ParamCubitPlane.o
../../util/ParamCubitPlane.cpp: In member function ‘void ParamCubitPlane::make_parameterization()’:
../../util/ParamCubitPlane.cpp:108: warning: unused variable ‘s’
mv -f .deps/ParamCubitPlane.Tpo .deps/ParamCubitPlane.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PlanarParamTool.lo -MD -MP -MF .deps/PlanarParamTool.Tpo -c -o PlanarParamTool.lo ../../util/PlanarParamTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PlanarParamTool.lo -MD -MP -MF .deps/PlanarParamTool.Tpo -c ../../util/PlanarParamTool.cpp -o PlanarParamTool.o
mv -f .deps/PlanarParamTool.Tpo .deps/PlanarParamTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Queue.lo -MD -MP -MF .deps/Queue.Tpo -c -o Queue.lo ../../util/Queue.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Queue.lo -MD -MP -MF .deps/Queue.Tpo -c ../../util/Queue.cpp -o Queue.o
mv -f .deps/Queue.Tpo .deps/Queue.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RandomMersenne.lo -MD -MP -MF .deps/RandomMersenne.Tpo -c -o RandomMersenne.lo ../../util/RandomMersenne.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RandomMersenne.lo -MD -MP -MF .deps/RandomMersenne.Tpo -c ../../util/RandomMersenne.cpp -o RandomMersenne.o
mv -f .deps/RandomMersenne.Tpo .deps/RandomMersenne.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SDLList.lo -MD -MP -MF .deps/SDLList.Tpo -c -o SDLList.lo ../../util/SDLList.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SDLList.lo -MD -MP -MF .deps/SDLList.Tpo -c ../../util/SDLList.cpp -o SDLList.o
mv -f .deps/SDLList.Tpo .deps/SDLList.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SettingHandler.lo -MD -MP -MF .deps/SettingHandler.Tpo -c -o SettingHandler.lo ../../util/SettingHandler.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SettingHandler.lo -MD -MP -MF .deps/SettingHandler.Tpo -c ../../util/SettingHandler.cpp -o SettingHandler.o
../../util/SettingHandler.cpp: In member function ‘void SettingHandler::save_settings()’:
../../util/SettingHandler.cpp:222: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/SettingHandler.Tpo .deps/SettingHandler.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SettingHolder.lo -MD -MP -MF .deps/SettingHolder.Tpo -c -o SettingHolder.lo ../../util/SettingHolder.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SettingHolder.lo -MD -MP -MF .deps/SettingHolder.Tpo -c ../../util/SettingHolder.cpp -o SettingHolder.o
mv -f .deps/SettingHolder.Tpo .deps/SettingHolder.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT StubProgressTool.lo -MD -MP -MF .deps/StubProgressTool.Tpo -c -o StubProgressTool.lo ../../util/StubProgressTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT StubProgressTool.lo -MD -MP -MF .deps/StubProgressTool.Tpo -c ../../util/StubProgressTool.cpp -o StubProgressTool.o
mv -f .deps/StubProgressTool.Tpo .deps/StubProgressTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDUPtr.lo -MD -MP -MF .deps/TDUPtr.Tpo -c -o TDUPtr.lo ../../util/TDUPtr.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDUPtr.lo -MD -MP -MF .deps/TDUPtr.Tpo -c ../../util/TDUPtr.cpp -o TDUPtr.o
mv -f .deps/TDUPtr.Tpo .deps/TDUPtr.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TextProgressTool.lo -MD -MP -MF .deps/TextProgressTool.Tpo -c -o TextProgressTool.lo ../../util/TextProgressTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TextProgressTool.lo -MD -MP -MF .deps/TextProgressTool.Tpo -c ../../util/TextProgressTool.cpp -o TextProgressTool.o
mv -f .deps/TextProgressTool.Tpo .deps/TextProgressTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ToolData.lo -MD -MP -MF .deps/ToolData.Tpo -c -o ToolData.lo ../../util/ToolData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ToolData.lo -MD -MP -MF .deps/ToolData.Tpo -c ../../util/ToolData.cpp -o ToolData.o
mv -f .deps/ToolData.Tpo .deps/ToolData.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ToolDataUser.lo -MD -MP -MF .deps/ToolDataUser.Tpo -c -o ToolDataUser.lo ../../util/ToolDataUser.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ToolDataUser.lo -MD -MP -MF .deps/ToolDataUser.Tpo -c ../../util/ToolDataUser.cpp -o ToolDataUser.o
mv -f .deps/ToolDataUser.Tpo .deps/ToolDataUser.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Tree.lo -MD -MP -MF .deps/Tree.Tpo -c -o Tree.lo ../../util/Tree.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Tree.lo -MD -MP -MF .deps/Tree.Tpo -c ../../util/Tree.cpp -o Tree.o
mv -f .deps/Tree.Tpo .deps/Tree.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TtyProgressTool.lo -MD -MP -MF .deps/TtyProgressTool.Tpo -c -o TtyProgressTool.lo ../../util/TtyProgressTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TtyProgressTool.lo -MD -MP -MF .deps/TtyProgressTool.Tpo -c ../../util/TtyProgressTool.cpp -o TtyProgressTool.o
mv -f .deps/TtyProgressTool.Tpo .deps/TtyProgressTool.Plo
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_util.la AllocMemManagersList.lo AppUtil.lo ArrayBasedContainer.lo CpuTimer.lo Cubit2DPoint.lo CubitBox.lo CubitCollection.lo CubitContainer.lo CubitCoordinateSystem.lo CubitDynamicLoader.lo CubitEntity.lo CubitFile.lo CubitFileFEModel.lo CubitFileIOWrapper.lo CubitFileMetaData.lo CubitFileUtil.lo CubitMatrix.lo CubitMessage.lo CubitObservable.lo CubitObserver.lo CubitPlane.lo CubitStack.lo CubitString.lo CubitTransformMatrix.lo CubitUtil.lo CubitVector.lo DIntArray.lo DLList.lo DynamicArray.lo GMem.lo GetLongOpt.lo GfxDebug.lo IntersectionTool.lo MemoryBlock.lo MemoryManager.lo ParamCubitPlane.lo PlanarParamTool.lo Queue.lo RandomMersenne.lo SDLList.lo SettingHandler.lo SettingHolder.lo StubProgressTool.lo TDUPtr.lo TextProgressTool.lo ToolData.lo ToolDataUser.lo Tree.lo TtyProgressTool.lo -lm
mkdir .libs
ar cru .libs/libcubit_util.a AllocMemManagersList.o AppUtil.o ArrayBasedContainer.o CpuTimer.o Cubit2DPoint.o CubitBox.o CubitCollection.o CubitContainer.o CubitCoordinateSystem.o CubitDynamicLoader.o CubitEntity.o CubitFile.o CubitFileFEModel.o CubitFileIOWrapper.o CubitFileMetaData.o CubitFileUtil.o CubitMatrix.o CubitMessage.o CubitObservable.o CubitObserver.o CubitPlane.o CubitStack.o CubitString.o CubitTransformMatrix.o CubitUtil.o CubitVector.o DIntArray.o DLList.o DynamicArray.o GMem.o GetLongOpt.o GfxDebug.o IntersectionTool.o MemoryBlock.o MemoryManager.o ParamCubitPlane.o PlanarParamTool.o Queue.o RandomMersenne.o SDLList.o SettingHandler.o SettingHolder.o StubProgressTool.o TDUPtr.o TextProgressTool.o ToolData.o ToolDataUser.o Tree.o TtyProgressTool.o
ranlib .libs/libcubit_util.a
creating libcubit_util.la
(cd .libs && rm -f libcubit_util.la && ln -s ../libcubit_util.la libcubit_util.la)
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
Making all in geom
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in .
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersGeom.lo -MD -MP -MF .deps/AllocMemManagersGeom.Tpo -c -o AllocMemManagersGeom.lo ../../geom/AllocMemManagersGeom.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersGeom.lo -MD -MP -MF .deps/AllocMemManagersGeom.Tpo -c ../../geom/AllocMemManagersGeom.cpp -o AllocMemManagersGeom.o
mv -f .deps/AllocMemManagersGeom.Tpo .deps/AllocMemManagersGeom.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AnalyticGeometryTool.lo -MD -MP -MF .deps/AnalyticGeometryTool.Tpo -c -o AnalyticGeometryTool.lo ../../geom/AnalyticGeometryTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AnalyticGeometryTool.lo -MD -MP -MF .deps/AnalyticGeometryTool.Tpo -c ../../geom/AnalyticGeometryTool.cpp -o AnalyticGeometryTool.o
mv -f .deps/AnalyticGeometryTool.Tpo .deps/AnalyticGeometryTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BasicTopologyEntity.lo -MD -MP -MF .deps/BasicTopologyEntity.Tpo -c -o BasicTopologyEntity.lo ../../geom/BasicTopologyEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BasicTopologyEntity.lo -MD -MP -MF .deps/BasicTopologyEntity.Tpo -c ../../geom/BasicTopologyEntity.cpp -o BasicTopologyEntity.o
mv -f .deps/BasicTopologyEntity.Tpo .deps/BasicTopologyEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Body.lo -MD -MP -MF .deps/Body.Tpo -c -o Body.lo ../../geom/Body.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Body.lo -MD -MP -MF .deps/Body.Tpo -c ../../geom/Body.cpp -o Body.o
mv -f .deps/Body.Tpo .deps/Body.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BodySM.lo -MD -MP -MF .deps/BodySM.Tpo -c -o BodySM.lo ../../geom/BodySM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BodySM.lo -MD -MP -MF .deps/BodySM.Tpo -c ../../geom/BodySM.cpp -o BodySM.o
mv -f .deps/BodySM.Tpo .deps/BodySM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BoundingBoxTool.lo -MD -MP -MF .deps/BoundingBoxTool.Tpo -c -o BoundingBoxTool.lo ../../geom/BoundingBoxTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BoundingBoxTool.lo -MD -MP -MF .deps/BoundingBoxTool.Tpo -c ../../geom/BoundingBoxTool.cpp -o BoundingBoxTool.o
../../geom/BoundingBoxTool.cpp: In static member function ‘static void BoundingBoxTool::initialize_settings()’:
../../geom/BoundingBoxTool.cpp:380: warning: deprecated conversion from string constant to ‘char*’
../../geom/BoundingBoxTool.cpp:384: warning: deprecated conversion from string constant to ‘char*’
../../geom/BoundingBoxTool.cpp:388: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/BoundingBoxTool.Tpo .deps/BoundingBoxTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BridgeManager.lo -MD -MP -MF .deps/BridgeManager.Tpo -c -o BridgeManager.lo ../../geom/BridgeManager.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BridgeManager.lo -MD -MP -MF .deps/BridgeManager.Tpo -c ../../geom/BridgeManager.cpp -o BridgeManager.o
mv -f .deps/BridgeManager.Tpo .deps/BridgeManager.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAActuateSet.lo -MD -MP -MF .deps/CAActuateSet.Tpo -c -o CAActuateSet.lo ../../geom/CAActuateSet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAActuateSet.lo -MD -MP -MF .deps/CAActuateSet.Tpo -c ../../geom/CAActuateSet.cpp -o CAActuateSet.o
mv -f .deps/CAActuateSet.Tpo .deps/CAActuateSet.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CADeferredAttrib.lo -MD -MP -MF .deps/CADeferredAttrib.Tpo -c -o CADeferredAttrib.lo ../../geom/CADeferredAttrib.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CADeferredAttrib.lo -MD -MP -MF .deps/CADeferredAttrib.Tpo -c ../../geom/CADeferredAttrib.cpp -o CADeferredAttrib.o
mv -f .deps/CADeferredAttrib.Tpo .deps/CADeferredAttrib.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityColor.lo -MD -MP -MF .deps/CAEntityColor.Tpo -c -o CAEntityColor.lo ../../geom/CAEntityColor.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityColor.lo -MD -MP -MF .deps/CAEntityColor.Tpo -c ../../geom/CAEntityColor.cpp -o CAEntityColor.o
mv -f .deps/CAEntityColor.Tpo .deps/CAEntityColor.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityId.lo -MD -MP -MF .deps/CAEntityId.Tpo -c -o CAEntityId.lo ../../geom/CAEntityId.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityId.lo -MD -MP -MF .deps/CAEntityId.Tpo -c ../../geom/CAEntityId.cpp -o CAEntityId.o
../../geom/CAEntityId.cpp: In constructor ‘CAEntityId::CAEntityId(RefEntity*, CubitSimpleAttrib*)’:
../../geom/CAEntityId.cpp:64: warning: unused variable ‘edge’
mv -f .deps/CAEntityId.Tpo .deps/CAEntityId.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityName.lo -MD -MP -MF .deps/CAEntityName.Tpo -c -o CAEntityName.lo ../../geom/CAEntityName.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAEntityName.lo -MD -MP -MF .deps/CAEntityName.Tpo -c ../../geom/CAEntityName.cpp -o CAEntityName.o
mv -f .deps/CAEntityName.Tpo .deps/CAEntityName.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAGroup.lo -MD -MP -MF .deps/CAGroup.Tpo -c -o CAGroup.lo ../../geom/CAGroup.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAGroup.lo -MD -MP -MF .deps/CAGroup.Tpo -c ../../geom/CAGroup.cpp -o CAGroup.o
mv -f .deps/CAGroup.Tpo .deps/CAGroup.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAMergePartner.lo -MD -MP -MF .deps/CAMergePartner.Tpo -c -o CAMergePartner.lo ../../geom/CAMergePartner.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAMergePartner.lo -MD -MP -MF .deps/CAMergePartner.Tpo -c ../../geom/CAMergePartner.cpp -o CAMergePartner.o
mv -f .deps/CAMergePartner.Tpo .deps/CAMergePartner.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAMergeStatus.lo -MD -MP -MF .deps/CAMergeStatus.Tpo -c -o CAMergeStatus.lo ../../geom/CAMergeStatus.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAMergeStatus.lo -MD -MP -MF .deps/CAMergeStatus.Tpo -c ../../geom/CAMergeStatus.cpp -o CAMergeStatus.o
mv -f .deps/CAMergeStatus.Tpo .deps/CAMergeStatus.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CASourceFeature.lo -MD -MP -MF .deps/CASourceFeature.Tpo -c -o CASourceFeature.lo ../../geom/CASourceFeature.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CASourceFeature.lo -MD -MP -MF .deps/CASourceFeature.Tpo -c ../../geom/CASourceFeature.cpp -o CASourceFeature.o
mv -f .deps/CASourceFeature.Tpo .deps/CASourceFeature.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAUniqueId.lo -MD -MP -MF .deps/CAUniqueId.Tpo -c -o CAUniqueId.lo ../../geom/CAUniqueId.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAUniqueId.lo -MD -MP -MF .deps/CAUniqueId.Tpo -c ../../geom/CAUniqueId.cpp -o CAUniqueId.o
mv -f .deps/CAUniqueId.Tpo .deps/CAUniqueId.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMApp.lo -MD -MP -MF .deps/CGMApp.Tpo -c -o CGMApp.lo ../../geom/CGMApp.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMApp.lo -MD -MP -MF .deps/CGMApp.Tpo -c ../../geom/CGMApp.cpp -o CGMApp.o
mv -f .deps/CGMApp.Tpo .deps/CGMApp.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMEngineDynamicLoader.lo -MD -MP -MF .deps/CGMEngineDynamicLoader.Tpo -c -o CGMEngineDynamicLoader.lo ../../geom/CGMEngineDynamicLoader.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CGMEngineDynamicLoader.lo -MD -MP -MF .deps/CGMEngineDynamicLoader.Tpo -c ../../geom/CGMEngineDynamicLoader.cpp -o CGMEngineDynamicLoader.o
../../geom/CGMEngineDynamicLoader.cpp: In member function ‘CubitBoolean CGMEngineDynamicLoader::check_engine_version()’:
../../geom/CGMEngineDynamicLoader.cpp:136: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object
../../geom/CGMEngineDynamicLoader.cpp: In member function ‘GeometryQueryEngine* CGMEngineDynamicLoader::get_gqe()’:
../../geom/CGMEngineDynamicLoader.cpp:175: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object
../../geom/CGMEngineDynamicLoader.cpp: In member function ‘GeometryModifyEngine* CGMEngineDynamicLoader::get_gme()’:
../../geom/CGMEngineDynamicLoader.cpp:210: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object
mv -f .deps/CGMEngineDynamicLoader.Tpo .deps/CGMEngineDynamicLoader.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Chain.lo -MD -MP -MF .deps/Chain.Tpo -c -o Chain.lo ../../geom/Chain.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Chain.lo -MD -MP -MF .deps/Chain.Tpo -c ../../geom/Chain.cpp -o Chain.o
mv -f .deps/Chain.Tpo .deps/Chain.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdge.lo -MD -MP -MF .deps/CoEdge.Tpo -c -o CoEdge.lo ../../geom/CoEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdge.lo -MD -MP -MF .deps/CoEdge.Tpo -c ../../geom/CoEdge.cpp -o CoEdge.o
mv -f .deps/CoEdge.Tpo .deps/CoEdge.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdgeSM.lo -MD -MP -MF .deps/CoEdgeSM.Tpo -c -o CoEdgeSM.lo ../../geom/CoEdgeSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdgeSM.lo -MD -MP -MF .deps/CoEdgeSM.Tpo -c ../../geom/CoEdgeSM.cpp -o CoEdgeSM.o
mv -f .deps/CoEdgeSM.Tpo .deps/CoEdgeSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoFace.lo -MD -MP -MF .deps/CoFace.Tpo -c -o CoFace.lo ../../geom/CoFace.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoFace.lo -MD -MP -MF .deps/CoFace.Tpo -c ../../geom/CoFace.cpp -o CoFace.o
mv -f .deps/CoFace.Tpo .deps/CoFace.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CollectionEntity.lo -MD -MP -MF .deps/CollectionEntity.Tpo -c -o CollectionEntity.lo ../../geom/CollectionEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CollectionEntity.lo -MD -MP -MF .deps/CollectionEntity.Tpo -c ../../geom/CollectionEntity.cpp -o CollectionEntity.o
mv -f .deps/CollectionEntity.Tpo .deps/CollectionEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoVertex.lo -MD -MP -MF .deps/CoVertex.Tpo -c -o CoVertex.lo ../../geom/CoVertex.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoVertex.lo -MD -MP -MF .deps/CoVertex.Tpo -c ../../geom/CoVertex.cpp -o CoVertex.o
mv -f .deps/CoVertex.Tpo .deps/CoVertex.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoVolume.lo -MD -MP -MF .deps/CoVolume.Tpo -c -o CoVolume.lo ../../geom/CoVolume.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoVolume.lo -MD -MP -MF .deps/CoVolume.Tpo -c ../../geom/CoVolume.cpp -o CoVolume.o
mv -f .deps/CoVolume.Tpo .deps/CoVolume.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttrib.lo -MD -MP -MF .deps/CubitAttrib.Tpo -c -o CubitAttrib.lo ../../geom/CubitAttrib.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttrib.lo -MD -MP -MF .deps/CubitAttrib.Tpo -c ../../geom/CubitAttrib.cpp -o CubitAttrib.o
mv -f .deps/CubitAttrib.Tpo .deps/CubitAttrib.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c -o CubitAttribManager.lo ../../geom/CubitAttribManager.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c ../../geom/CubitAttribManager.cpp -o CubitAttribManager.o
../../geom/CubitAttribManager.cpp: In member function ‘CubitStatus CubitAttribManager::register_attrib_type(int, const char*, const char*, CubitAttrib* (*)(RefEntity*, CubitSimpleAttrib*), CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean)’:
../../geom/CubitAttribManager.cpp:82: warning: unused variable ‘size’
mv -f .deps/CubitAttribManager.Tpo .deps/CubitAttribManager.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttribUser.lo -MD -MP -MF .deps/CubitAttribUser.Tpo -c -o CubitAttribUser.lo ../../geom/CubitAttribUser.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitAttribUser.lo -MD -MP -MF .deps/CubitAttribUser.Tpo -c ../../geom/CubitAttribUser.cpp -o CubitAttribUser.o
../../geom/CubitAttribUser.cpp: In member function ‘CubitStatus CubitAttribUser::remove_cubit_attrib(CubitAttrib*)’:
../../geom/CubitAttribUser.cpp:786: warning: suggest explicit braces to avoid ambiguous ‘else’
mv -f .deps/CubitAttribUser.Tpo .deps/CubitAttribUser.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPolygon.lo -MD -MP -MF .deps/CubitPolygon.Tpo -c -o CubitPolygon.lo ../../geom/CubitPolygon.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPolygon.lo -MD -MP -MF .deps/CubitPolygon.Tpo -c ../../geom/CubitPolygon.cpp -o CubitPolygon.o
../../geom/CubitPolygon.cpp: In member function ‘CubitPointContainment CubitPolygon::pnt_containment(Cubit2DPoint&, double)’:
../../geom/CubitPolygon.cpp:95: warning: suggest parentheses around && within ||
mv -f .deps/CubitPolygon.Tpo .deps/CubitPolygon.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitSimpleAttrib.lo -MD -MP -MF .deps/CubitSimpleAttrib.Tpo -c -o CubitSimpleAttrib.lo ../../geom/CubitSimpleAttrib.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitSimpleAttrib.lo -MD -MP -MF .deps/CubitSimpleAttrib.Tpo -c ../../geom/CubitSimpleAttrib.cpp -o CubitSimpleAttrib.o
../../geom/CubitSimpleAttrib.cpp: In static member function ‘static void CubitSimpleAttrib::initialize_settings()’:
../../geom/CubitSimpleAttrib.cpp:339: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/CubitSimpleAttrib.Tpo .deps/CubitSimpleAttrib.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Curve.lo -MD -MP -MF .deps/Curve.Tpo -c -o Curve.lo ../../geom/Curve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Curve.lo -MD -MP -MF .deps/Curve.Tpo -c ../../geom/Curve.cpp -o Curve.o
mv -f .deps/Curve.Tpo .deps/Curve.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveOverlapFacet.lo -MD -MP -MF .deps/CurveOverlapFacet.Tpo -c -o CurveOverlapFacet.lo ../../geom/CurveOverlapFacet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveOverlapFacet.lo -MD -MP -MF .deps/CurveOverlapFacet.Tpo -c ../../geom/CurveOverlapFacet.cpp -o CurveOverlapFacet.o
mv -f .deps/CurveOverlapFacet.Tpo .deps/CurveOverlapFacet.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveSM.lo -MD -MP -MF .deps/CurveSM.Tpo -c -o CurveSM.lo ../../geom/CurveSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveSM.lo -MD -MP -MF .deps/CurveSM.Tpo -c ../../geom/CurveSM.cpp -o CurveSM.o
mv -f .deps/CurveSM.Tpo .deps/CurveSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CylinderEvaluator.lo -MD -MP -MF .deps/CylinderEvaluator.Tpo -c -o CylinderEvaluator.lo ../../geom/CylinderEvaluator.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CylinderEvaluator.lo -MD -MP -MF .deps/CylinderEvaluator.Tpo -c ../../geom/CylinderEvaluator.cpp -o CylinderEvaluator.o
mv -f .deps/CylinderEvaluator.Tpo .deps/CylinderEvaluator.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DAG.lo -MD -MP -MF .deps/DAG.Tpo -c -o DAG.lo ../../geom/DAG.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DAG.lo -MD -MP -MF .deps/DAG.Tpo -c ../../geom/DAG.cpp -o DAG.o
mv -f .deps/DAG.Tpo .deps/DAG.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DagDrawingTool.lo -MD -MP -MF .deps/DagDrawingTool.Tpo -c -o DagDrawingTool.lo ../../geom/DagDrawingTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT DagDrawingTool.lo -MD -MP -MF .deps/DagDrawingTool.Tpo -c ../../geom/DagDrawingTool.cpp -o DagDrawingTool.o
mv -f .deps/DagDrawingTool.Tpo .deps/DagDrawingTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeomDataObserver.lo -MD -MP -MF .deps/GeomDataObserver.Tpo -c -o GeomDataObserver.lo ../../geom/GeomDataObserver.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeomDataObserver.lo -MD -MP -MF .deps/GeomDataObserver.Tpo -c ../../geom/GeomDataObserver.cpp -o GeomDataObserver.o
mv -f .deps/GeomDataObserver.Tpo .deps/GeomDataObserver.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryEntity.lo -MD -MP -MF .deps/GeometryEntity.Tpo -c -o GeometryEntity.lo ../../geom/GeometryEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryEntity.lo -MD -MP -MF .deps/GeometryEntity.Tpo -c ../../geom/GeometryEntity.cpp -o GeometryEntity.o
mv -f .deps/GeometryEntity.Tpo .deps/GeometryEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryFeatureEngine.lo -MD -MP -MF .deps/GeometryFeatureEngine.Tpo -c -o GeometryFeatureEngine.lo ../../geom/GeometryFeatureEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryFeatureEngine.lo -MD -MP -MF .deps/GeometryFeatureEngine.Tpo -c ../../geom/GeometryFeatureEngine.cpp -o GeometryFeatureEngine.o
mv -f .deps/GeometryFeatureEngine.Tpo .deps/GeometryFeatureEngine.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryFeatureTool.lo -MD -MP -MF .deps/GeometryFeatureTool.Tpo -c -o GeometryFeatureTool.lo ../../geom/GeometryFeatureTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryFeatureTool.lo -MD -MP -MF .deps/GeometryFeatureTool.Tpo -c ../../geom/GeometryFeatureTool.cpp -o GeometryFeatureTool.o
mv -f .deps/GeometryFeatureTool.Tpo .deps/GeometryFeatureTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryHealerEngine.lo -MD -MP -MF .deps/GeometryHealerEngine.Tpo -c -o GeometryHealerEngine.lo ../../geom/GeometryHealerEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryHealerEngine.lo -MD -MP -MF .deps/GeometryHealerEngine.Tpo -c ../../geom/GeometryHealerEngine.cpp -o GeometryHealerEngine.o
mv -f .deps/GeometryHealerEngine.Tpo .deps/GeometryHealerEngine.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryHealerTool.lo -MD -MP -MF .deps/GeometryHealerTool.Tpo -c -o GeometryHealerTool.lo ../../geom/GeometryHealerTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryHealerTool.lo -MD -MP -MF .deps/GeometryHealerTool.Tpo -c ../../geom/GeometryHealerTool.cpp -o GeometryHealerTool.o
mv -f .deps/GeometryHealerTool.Tpo .deps/GeometryHealerTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryModifyEngine.lo -MD -MP -MF .deps/GeometryModifyEngine.Tpo -c -o GeometryModifyEngine.lo ../../geom/GeometryModifyEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryModifyEngine.lo -MD -MP -MF .deps/GeometryModifyEngine.Tpo -c ../../geom/GeometryModifyEngine.cpp -o GeometryModifyEngine.o
mv -f .deps/GeometryModifyEngine.Tpo .deps/GeometryModifyEngine.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryModifyTool.lo -MD -MP -MF .deps/GeometryModifyTool.Tpo -c -o GeometryModifyTool.lo ../../geom/GeometryModifyTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryModifyTool.lo -MD -MP -MF .deps/GeometryModifyTool.Tpo -c ../../geom/GeometryModifyTool.cpp -o GeometryModifyTool.o
../../geom/GeometryModifyTool.cpp: In static member function ‘static void GeometryModifyTool::initialize_settings()’:
../../geom/GeometryModifyTool.cpp:3587: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryModifyTool.cpp:3591: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryModifyTool.cpp:3595: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryModifyTool.cpp:3599: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryModifyTool.cpp:3603: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryModifyTool.cpp: In member function ‘CubitStatus GeometryModifyTool::tolerant_imprint(DLIList<Body*>&, DLIList<Body*>&, bool)’:
../../geom/GeometryModifyTool.cpp:9395: warning: ISO C++ does not support the ‘%lf’ printf format
../../geom/GeometryModifyTool.cpp: In member function ‘CubitStatus GeometryModifyTool::get_mid_surface(RefFace*, RefFace*, Body*, DLIList<RefFace*>&) const’:
../../geom/GeometryModifyTool.cpp:7529: warning: ‘ret’ may be used uninitialized in this function
mv -f .deps/GeometryModifyTool.Tpo .deps/GeometryModifyTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryQueryEngine.lo -MD -MP -MF .deps/GeometryQueryEngine.Tpo -c -o GeometryQueryEngine.lo ../../geom/GeometryQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryQueryEngine.lo -MD -MP -MF .deps/GeometryQueryEngine.Tpo -c ../../geom/GeometryQueryEngine.cpp -o GeometryQueryEngine.o
mv -f .deps/GeometryQueryEngine.Tpo .deps/GeometryQueryEngine.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryQueryTool.lo -MD -MP -MF .deps/GeometryQueryTool.Tpo -c -o GeometryQueryTool.lo ../../geom/GeometryQueryTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryQueryTool.lo -MD -MP -MF .deps/GeometryQueryTool.Tpo -c ../../geom/GeometryQueryTool.cpp -o GeometryQueryTool.o
../../geom/GeometryQueryTool.cpp: In static member function ‘static void GeometryQueryTool::initialize_settings()’:
../../geom/GeometryQueryTool.cpp:2456: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryQueryTool.cpp:2460: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryQueryTool.cpp:2464: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryQueryTool.cpp:2468: warning: deprecated conversion from string constant to ‘char*’
../../geom/GeometryQueryTool.cpp: In member function ‘CubitStatus GeometryQueryTool::get_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)’:
../../geom/GeometryQueryTool.cpp:2997: warning: unused variable ‘status’
../../geom/GeometryQueryTool.cpp: In member function ‘CubitStatus GeometryQueryTool::straightline_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)’:
../../geom/GeometryQueryTool.cpp:3026: warning: unused variable ‘status’
mv -f .deps/GeometryQueryTool.Tpo .deps/GeometryQueryTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryUtil.lo -MD -MP -MF .deps/GeometryUtil.Tpo -c -o GeometryUtil.lo ../../geom/GeometryUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeometryUtil.lo -MD -MP -MF .deps/GeometryUtil.Tpo -c ../../geom/GeometryUtil.cpp -o GeometryUtil.o
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_shell_cofaces(Shell*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:1942: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Body*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2279: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefVolume*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2381: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Shell*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2415: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Shell*’
../../geom/GeometryUtil.cpp:2432: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2432: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Shell*’
../../geom/GeometryUtil.cpp:2506: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2506: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Shell*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefFace*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2612: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(Loop*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2649: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2742: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2742: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2778: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2778: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2799: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2799: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2822: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2822: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2839: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Loop*’
../../geom/GeometryUtil.cpp:2839: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(CoEdge*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:2872: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’
../../geom/GeometryUtil.cpp:2893: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdgeSM*’
../../geom/GeometryUtil.cpp:2893: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdge*’
../../geom/GeometryUtil.cpp:2913: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:2970: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CoEdge*’
../../geom/GeometryUtil.cpp:3014: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp:3014: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefEdge*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:3111: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
../../geom/GeometryUtil.cpp: In member function ‘CubitBoolean GeometryUtil::valid_sm_topology(RefVertex*, CubitBoolean)’:
../../geom/GeometryUtil.cpp:3156: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘TopologyBridge*’
mv -f .deps/GeometryUtil.Tpo .deps/GeometryUtil.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeomMeasureTool.lo -MD -MP -MF .deps/GeomMeasureTool.Tpo -c -o GeomMeasureTool.lo ../../geom/GeomMeasureTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeomMeasureTool.lo -MD -MP -MF .deps/GeomMeasureTool.Tpo -c ../../geom/GeomMeasureTool.cpp -o GeomMeasureTool.o
../../geom/GeomMeasureTool.cpp: In static member function ‘static void GeomMeasureTool::report_intersected_volumes(DLIList<RefVolume*>&, DLIList<RefVolume*>&)’:
../../geom/GeomMeasureTool.cpp:1182: warning: unused variable ‘curr_vol_2’
../../geom/GeomMeasureTool.cpp: In static member function ‘static CubitStatus GeomMeasureTool::center(DLIList<RefFace*>)’:
../../geom/GeomMeasureTool.cpp:3515: warning: ‘id’ may be used uninitialized in this function
mv -f .deps/GeomMeasureTool.Tpo .deps/GeomMeasureTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GfxPreview.lo -MD -MP -MF .deps/GfxPreview.Tpo -c -o GfxPreview.lo ../../geom/GfxPreview.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GfxPreview.lo -MD -MP -MF .deps/GfxPreview.Tpo -c ../../geom/GfxPreview.cpp -o GfxPreview.o
mv -f .deps/GfxPreview.Tpo .deps/GfxPreview.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GroupingEntity.lo -MD -MP -MF .deps/GroupingEntity.Tpo -c -o GroupingEntity.lo ../../geom/GroupingEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GroupingEntity.lo -MD -MP -MF .deps/GroupingEntity.Tpo -c ../../geom/GroupingEntity.cpp -o GroupingEntity.o
mv -f .deps/GroupingEntity.Tpo .deps/GroupingEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GSaveOpen.lo -MD -MP -MF .deps/GSaveOpen.Tpo -c -o GSaveOpen.lo ../../geom/GSaveOpen.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GSaveOpen.lo -MD -MP -MF .deps/GSaveOpen.Tpo -c ../../geom/GSaveOpen.cpp -o GSaveOpen.o
mv -f .deps/GSaveOpen.Tpo .deps/GSaveOpen.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Loop.lo -MD -MP -MF .deps/Loop.Tpo -c -o Loop.lo ../../geom/Loop.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Loop.lo -MD -MP -MF .deps/Loop.Tpo -c ../../geom/Loop.cpp -o Loop.o
mv -f .deps/Loop.Tpo .deps/Loop.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopSM.lo -MD -MP -MF .deps/LoopSM.Tpo -c -o LoopSM.lo ../../geom/LoopSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopSM.lo -MD -MP -MF .deps/LoopSM.Tpo -c ../../geom/LoopSM.cpp -o LoopSM.o
mv -f .deps/LoopSM.Tpo .deps/LoopSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Lump.lo -MD -MP -MF .deps/Lump.Tpo -c -o Lump.lo ../../geom/Lump.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Lump.lo -MD -MP -MF .deps/Lump.Tpo -c ../../geom/Lump.cpp -o Lump.o
mv -f .deps/Lump.Tpo .deps/Lump.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LumpSM.lo -MD -MP -MF .deps/LumpSM.Tpo -c -o LumpSM.lo ../../geom/LumpSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LumpSM.lo -MD -MP -MF .deps/LumpSM.Tpo -c ../../geom/LumpSM.cpp -o LumpSM.o
mv -f .deps/LumpSM.Tpo .deps/LumpSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MedialTool2D.lo -MD -MP -MF .deps/MedialTool2D.Tpo -c -o MedialTool2D.lo ../../geom/MedialTool2D.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MedialTool2D.lo -MD -MP -MF .deps/MedialTool2D.Tpo -c ../../geom/MedialTool2D.cpp -o MedialTool2D.o
mv -f .deps/MedialTool2D.Tpo .deps/MedialTool2D.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MedialTool3D.lo -MD -MP -MF .deps/MedialTool3D.Tpo -c -o MedialTool3D.lo ../../geom/MedialTool3D.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MedialTool3D.lo -MD -MP -MF .deps/MedialTool3D.Tpo -c ../../geom/MedialTool3D.cpp -o MedialTool3D.o
mv -f .deps/MedialTool3D.Tpo .deps/MedialTool3D.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MergeToolAssistant.lo -MD -MP -MF .deps/MergeToolAssistant.Tpo -c -o MergeToolAssistant.lo ../../geom/MergeToolAssistant.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MergeToolAssistant.lo -MD -MP -MF .deps/MergeToolAssistant.Tpo -c ../../geom/MergeToolAssistant.cpp -o MergeToolAssistant.o
mv -f .deps/MergeToolAssistant.Tpo .deps/MergeToolAssistant.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MergeTool.lo -MD -MP -MF .deps/MergeTool.Tpo -c -o MergeTool.lo ../../geom/MergeTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MergeTool.lo -MD -MP -MF .deps/MergeTool.Tpo -c ../../geom/MergeTool.cpp -o MergeTool.o
../../geom/MergeTool.cpp: In member function ‘CubitStatus MergeTool::find_mergeable_refedges(DLIList<RefEntity*>&, DLIList<DLIList<RefEdge*>*>&, bool)’:
../../geom/MergeTool.cpp:1282: warning: unused variable ‘retained_id’
../../geom/MergeTool.cpp:1283: warning: unused variable ‘deleted_id’
../../geom/MergeTool.cpp: In member function ‘CubitStatus MergeTool::find_mergeable_refvertices(DLIList<RefEntity*>&, DLIList<DLIList<RefVertex*>*>&, bool)’:
../../geom/MergeTool.cpp:1622: warning: unused variable ‘retained_id’
../../geom/MergeTool.cpp:1623: warning: unused variable ‘deleted_id’
../../geom/MergeTool.cpp: In member function ‘RefEdge* MergeTool::separate_edge(DLIList<Curve*>&, bool)’:
../../geom/MergeTool.cpp:4973: warning: unused variable ‘vtx’
mv -f .deps/MergeTool.Tpo .deps/MergeTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MidPlaneTool.lo -MD -MP -MF .deps/MidPlaneTool.Tpo -c -o MidPlaneTool.lo ../../geom/MidPlaneTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT MidPlaneTool.lo -MD -MP -MF .deps/MidPlaneTool.Tpo -c ../../geom/MidPlaneTool.cpp -o MidPlaneTool.o
mv -f .deps/MidPlaneTool.Tpo .deps/MidPlaneTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ModelEntity.lo -MD -MP -MF .deps/ModelEntity.Tpo -c -o ModelEntity.lo ../../geom/ModelEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ModelEntity.lo -MD -MP -MF .deps/ModelEntity.Tpo -c ../../geom/ModelEntity.cpp -o ModelEntity.o
mv -f .deps/ModelEntity.Tpo .deps/ModelEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ModelQueryEngine.lo -MD -MP -MF .deps/ModelQueryEngine.Tpo -c -o ModelQueryEngine.lo ../../geom/ModelQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ModelQueryEngine.lo -MD -MP -MF .deps/ModelQueryEngine.Tpo -c ../../geom/ModelQueryEngine.cpp -o ModelQueryEngine.o
mv -f .deps/ModelQueryEngine.Tpo .deps/ModelQueryEngine.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OffsetSplitTool.lo -MD -MP -MF .deps/OffsetSplitTool.Tpo -c -o OffsetSplitTool.lo ../../geom/OffsetSplitTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OffsetSplitTool.lo -MD -MP -MF .deps/OffsetSplitTool.Tpo -c ../../geom/OffsetSplitTool.cpp -o OffsetSplitTool.o
mv -f .deps/OffsetSplitTool.Tpo .deps/OffsetSplitTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OldUnmergeCode.lo -MD -MP -MF .deps/OldUnmergeCode.Tpo -c -o OldUnmergeCode.lo ../../geom/OldUnmergeCode.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OldUnmergeCode.lo -MD -MP -MF .deps/OldUnmergeCode.Tpo -c ../../geom/OldUnmergeCode.cpp -o OldUnmergeCode.o
../../geom/OldUnmergeCode.cpp: In static member function ‘static void OldUnmergeCode::initialize_settings()’:
../../geom/OldUnmergeCode.cpp:40: warning: deprecated conversion from string constant to ‘char*’
../../geom/OldUnmergeCode.cpp: In member function ‘RefFace* OldUnmergeCode::unmerge(RefFace*, RefVolume*)’:
../../geom/OldUnmergeCode.cpp:540: warning: unused variable ‘lump_ptr’
mv -f .deps/OldUnmergeCode.Tpo .deps/OldUnmergeCode.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Point.lo -MD -MP -MF .deps/Point.Tpo -c -o Point.lo ../../geom/Point.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Point.lo -MD -MP -MF .deps/Point.Tpo -c ../../geom/Point.cpp -o Point.o
mv -f .deps/Point.Tpo .deps/Point.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointSM.lo -MD -MP -MF .deps/PointSM.Tpo -c -o PointSM.lo ../../geom/PointSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointSM.lo -MD -MP -MF .deps/PointSM.Tpo -c ../../geom/PointSM.cpp -o PointSM.o
mv -f .deps/PointSM.Tpo .deps/PointSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefCollection.lo -MD -MP -MF .deps/RefCollection.Tpo -c -o RefCollection.lo ../../geom/RefCollection.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefCollection.lo -MD -MP -MF .deps/RefCollection.Tpo -c ../../geom/RefCollection.cpp -o RefCollection.o
mv -f .deps/RefCollection.Tpo .deps/RefCollection.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEdge.lo -MD -MP -MF .deps/RefEdge.Tpo -c -o RefEdge.lo ../../geom/RefEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEdge.lo -MD -MP -MF .deps/RefEdge.Tpo -c ../../geom/RefEdge.cpp -o RefEdge.o
mv -f .deps/RefEdge.Tpo .deps/RefEdge.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntity.lo -MD -MP -MF .deps/RefEntity.Tpo -c -o RefEntity.lo ../../geom/RefEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntity.lo -MD -MP -MF .deps/RefEntity.Tpo -c ../../geom/RefEntity.cpp -o RefEntity.o
mv -f .deps/RefEntity.Tpo .deps/RefEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntityFactory.lo -MD -MP -MF .deps/RefEntityFactory.Tpo -c -o RefEntityFactory.lo ../../geom/RefEntityFactory.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntityFactory.lo -MD -MP -MF .deps/RefEntityFactory.Tpo -c ../../geom/RefEntityFactory.cpp -o RefEntityFactory.o
mv -f .deps/RefEntityFactory.Tpo .deps/RefEntityFactory.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntityName.lo -MD -MP -MF .deps/RefEntityName.Tpo -c -o RefEntityName.lo ../../geom/RefEntityName.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefEntityName.lo -MD -MP -MF .deps/RefEntityName.Tpo -c ../../geom/RefEntityName.cpp -o RefEntityName.o
../../geom/RefEntityName.cpp: In static member function ‘static void RefEntityName::initialize_settings()’:
../../geom/RefEntityName.cpp:743: warning: deprecated conversion from string constant to ‘char*’
../../geom/RefEntityName.cpp:747: warning: deprecated conversion from string constant to ‘char*’
../../geom/RefEntityName.cpp:751: warning: deprecated conversion from string constant to ‘char*’
../../geom/RefEntityName.cpp:755: warning: deprecated conversion from string constant to ‘char*’
../../geom/RefEntityName.cpp:759: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/RefEntityName.Tpo .deps/RefEntityName.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefFace.lo -MD -MP -MF .deps/RefFace.Tpo -c -o RefFace.lo ../../geom/RefFace.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefFace.lo -MD -MP -MF .deps/RefFace.Tpo -c ../../geom/RefFace.cpp -o RefFace.o
mv -f .deps/RefFace.Tpo .deps/RefFace.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefGroup.lo -MD -MP -MF .deps/RefGroup.Tpo -c -o RefGroup.lo ../../geom/RefGroup.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefGroup.lo -MD -MP -MF .deps/RefGroup.Tpo -c ../../geom/RefGroup.cpp -o RefGroup.o
mv -f .deps/RefGroup.Tpo .deps/RefGroup.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefVertex.lo -MD -MP -MF .deps/RefVertex.Tpo -c -o RefVertex.lo ../../geom/RefVertex.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefVertex.lo -MD -MP -MF .deps/RefVertex.Tpo -c ../../geom/RefVertex.cpp -o RefVertex.o
mv -f .deps/RefVertex.Tpo .deps/RefVertex.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefVolume.lo -MD -MP -MF .deps/RefVolume.Tpo -c -o RefVolume.lo ../../geom/RefVolume.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT RefVolume.lo -MD -MP -MF .deps/RefVolume.Tpo -c ../../geom/RefVolume.cpp -o RefVolume.o
mv -f .deps/RefVolume.Tpo .deps/RefVolume.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SenseEntity.lo -MD -MP -MF .deps/SenseEntity.Tpo -c -o SenseEntity.lo ../../geom/SenseEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SenseEntity.lo -MD -MP -MF .deps/SenseEntity.Tpo -c ../../geom/SenseEntity.cpp -o SenseEntity.o
mv -f .deps/SenseEntity.Tpo .deps/SenseEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Shell.lo -MD -MP -MF .deps/Shell.Tpo -c -o Shell.lo ../../geom/Shell.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Shell.lo -MD -MP -MF .deps/Shell.Tpo -c ../../geom/Shell.cpp -o Shell.o
mv -f .deps/Shell.Tpo .deps/Shell.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ShellSM.lo -MD -MP -MF .deps/ShellSM.Tpo -c -o ShellSM.lo ../../geom/ShellSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ShellSM.lo -MD -MP -MF .deps/ShellSM.Tpo -c ../../geom/ShellSM.cpp -o ShellSM.o
mv -f .deps/ShellSM.Tpo .deps/ShellSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SphereEvaluator.lo -MD -MP -MF .deps/SphereEvaluator.Tpo -c -o SphereEvaluator.lo ../../geom/SphereEvaluator.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SphereEvaluator.lo -MD -MP -MF .deps/SphereEvaluator.Tpo -c ../../geom/SphereEvaluator.cpp -o SphereEvaluator.o
mv -f .deps/SphereEvaluator.Tpo .deps/SphereEvaluator.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SplitSurfaceTool.lo -MD -MP -MF .deps/SplitSurfaceTool.Tpo -c -o SplitSurfaceTool.lo ../../geom/SplitSurfaceTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SplitSurfaceTool.lo -MD -MP -MF .deps/SplitSurfaceTool.Tpo -c ../../geom/SplitSurfaceTool.cpp -o SplitSurfaceTool.o
../../geom/SplitSurfaceTool.cpp: In static member function ‘static void SplitSurfaceTool::initialize_settings()’:
../../geom/SplitSurfaceTool.cpp:77: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:81: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:85: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:89: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:93: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp: In member function ‘CubitStatus SplitSurfaceTool::adjust_for_split_direction(RefEdge*, RefEdge*, DLIList<RefVertex*>&)’:
../../geom/SplitSurfaceTool.cpp:3445: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:3480: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:3561: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:3593: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp:3618: warning: deprecated conversion from string constant to ‘char*’
../../geom/SplitSurfaceTool.cpp: In member function ‘CubitStatus SplitSurfaceTool::check_through_vertices(char*)’:
../../geom/SplitSurfaceTool.cpp:3840: warning: too few arguments for format
../../geom/SplitSurfaceTool.cpp: In member function ‘Curve* SplitSurfaceTool::create_curve(DLIList<CubitVector*>&, Surface*, double, CubitBoolean, CubitBoolean, CubitBoolean)’:
../../geom/SplitSurfaceTool.cpp:5647: warning: suggest explicit braces to avoid ambiguous ‘else’
mv -f .deps/SplitSurfaceTool.Tpo .deps/SplitSurfaceTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Surface.lo -MD -MP -MF .deps/Surface.Tpo -c -o Surface.lo ../../geom/Surface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Surface.lo -MD -MP -MF .deps/Surface.Tpo -c ../../geom/Surface.cpp -o Surface.o
mv -f .deps/Surface.Tpo .deps/Surface.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceOverlapFacet.lo -MD -MP -MF .deps/SurfaceOverlapFacet.Tpo -c -o SurfaceOverlapFacet.lo ../../geom/SurfaceOverlapFacet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceOverlapFacet.lo -MD -MP -MF .deps/SurfaceOverlapFacet.Tpo -c ../../geom/SurfaceOverlapFacet.cpp -o SurfaceOverlapFacet.o
mv -f .deps/SurfaceOverlapFacet.Tpo .deps/SurfaceOverlapFacet.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceOverlapTool.lo -MD -MP -MF .deps/SurfaceOverlapTool.Tpo -c -o SurfaceOverlapTool.lo ../../geom/SurfaceOverlapTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceOverlapTool.lo -MD -MP -MF .deps/SurfaceOverlapTool.Tpo -c ../../geom/SurfaceOverlapTool.cpp -o SurfaceOverlapTool.o
../../geom/SurfaceOverlapTool.cpp: In member function ‘CubitBoolean SurfaceOverlapTool::check_overlap(Surface*, Surface*, std::map<Surface*, DLIList<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, DLIList<SurfaceOverlapFacet*>*> > >*, std::map<Surface*, double, std::less<Surface*>, std::allocator<std::pair<Surface* const, double> > >*, std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, AbstractTree<SurfaceOverlapFacet*>*> > >*)’:
../../geom/SurfaceOverlapTool.cpp:816: warning: unused variable ‘num_samples’
../../geom/SurfaceOverlapTool.cpp: In static member function ‘static void SurfaceOverlapTool::initialize_settings()’:
../../geom/SurfaceOverlapTool.cpp:1406: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1410: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1414: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1418: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1422: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1426: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1430: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1434: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1438: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1442: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1446: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1450: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp:1454: warning: deprecated conversion from string constant to ‘char*’
../../geom/SurfaceOverlapTool.cpp: In member function ‘CubitStatus SurfaceOverlapTool::find_overlapping_curves(DLIList<Body*>&, std::multimap<RefEdge*, RefEdge*, std::less<RefEdge*>, std::allocator<std::pair<RefEdge* const, RefEdge*> > >&)’:
../../geom/SurfaceOverlapTool.cpp:1620: warning: unused variable ‘co_facet_list’
mv -f .deps/SurfaceOverlapTool.Tpo .deps/SurfaceOverlapTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfParamTool.lo -MD -MP -MF .deps/SurfParamTool.Tpo -c -o SurfParamTool.lo ../../geom/SurfParamTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfParamTool.lo -MD -MP -MF .deps/SurfParamTool.Tpo -c ../../geom/SurfParamTool.cpp -o SurfParamTool.o
mv -f .deps/SurfParamTool.Tpo .deps/SurfParamTool.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceSM.lo -MD -MP -MF .deps/SurfaceSM.Tpo -c -o SurfaceSM.lo ../../geom/SurfaceSM.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceSM.lo -MD -MP -MF .deps/SurfaceSM.Tpo -c ../../geom/SurfaceSM.cpp -o SurfaceSM.o
mv -f .deps/SurfaceSM.Tpo .deps/SurfaceSM.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDCAGE.lo -MD -MP -MF .deps/TDCAGE.Tpo -c -o TDCAGE.lo ../../geom/TDCAGE.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDCAGE.lo -MD -MP -MF .deps/TDCAGE.Tpo -c ../../geom/TDCAGE.cpp -o TDCAGE.o
mv -f .deps/TDCAGE.Tpo .deps/TDCAGE.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSourceFeature.lo -MD -MP -MF .deps/TDSourceFeature.Tpo -c -o TDSourceFeature.lo ../../geom/TDSourceFeature.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSourceFeature.lo -MD -MP -MF .deps/TDSourceFeature.Tpo -c ../../geom/TDSourceFeature.cpp -o TDSourceFeature.o
mv -f .deps/TDSourceFeature.Tpo .deps/TDSourceFeature.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSplitSurface.lo -MD -MP -MF .deps/TDSplitSurface.Tpo -c -o TDSplitSurface.lo ../../geom/TDSplitSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSplitSurface.lo -MD -MP -MF .deps/TDSplitSurface.Tpo -c ../../geom/TDSplitSurface.cpp -o TDSplitSurface.o
mv -f .deps/TDSplitSurface.Tpo .deps/TDSplitSurface.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSurfaceOverlap.lo -MD -MP -MF .deps/TDSurfaceOverlap.Tpo -c -o TDSurfaceOverlap.lo ../../geom/TDSurfaceOverlap.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDSurfaceOverlap.lo -MD -MP -MF .deps/TDSurfaceOverlap.Tpo -c ../../geom/TDSurfaceOverlap.cpp -o TDSurfaceOverlap.o
mv -f .deps/TDSurfaceOverlap.Tpo .deps/TDSurfaceOverlap.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDUniqueId.lo -MD -MP -MF .deps/TDUniqueId.Tpo -c -o TDUniqueId.lo ../../geom/TDUniqueId.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDUniqueId.lo -MD -MP -MF .deps/TDUniqueId.Tpo -c ../../geom/TDUniqueId.cpp -o TDUniqueId.o
mv -f .deps/TDUniqueId.Tpo .deps/TDUniqueId.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TopologyBridge.lo -MD -MP -MF .deps/TopologyBridge.Tpo -c -o TopologyBridge.lo ../../geom/TopologyBridge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TopologyBridge.lo -MD -MP -MF .deps/TopologyBridge.Tpo -c ../../geom/TopologyBridge.cpp -o TopologyBridge.o
mv -f .deps/TopologyBridge.Tpo .deps/TopologyBridge.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TopologyEntity.lo -MD -MP -MF .deps/TopologyEntity.Tpo -c -o TopologyEntity.lo ../../geom/TopologyEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TopologyEntity.lo -MD -MP -MF .deps/TopologyEntity.Tpo -c ../../geom/TopologyEntity.cpp -o TopologyEntity.o
../../geom/TopologyEntity.cpp: In member function ‘CubitBoolean TopologyEntity::is_directly_related(TopologyEntity*)’:
../../geom/TopologyEntity.cpp:247: warning: unused variable ‘result’
mv -f .deps/TopologyEntity.Tpo .deps/TopologyEntity.Plo
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_geom.la AllocMemManagersGeom.lo AnalyticGeometryTool.lo BasicTopologyEntity.lo Body.lo BodySM.lo BoundingBoxTool.lo BridgeManager.lo CAActuateSet.lo CADeferredAttrib.lo CAEntityColor.lo CAEntityId.lo CAEntityName.lo CAGroup.lo CAMergePartner.lo CAMergeStatus.lo CASourceFeature.lo CAUniqueId.lo CGMApp.lo CGMEngineDynamicLoader.lo Chain.lo CoEdge.lo CoEdgeSM.lo CoFace.lo CollectionEntity.lo CoVertex.lo CoVolume.lo CubitAttrib.lo CubitAttribManager.lo CubitAttribUser.lo CubitPolygon.lo CubitSimpleAttrib.lo Curve.lo CurveOverlapFacet.lo CurveSM.lo CylinderEvaluator.lo DAG.lo DagDrawingTool.lo GeomDataObserver.lo GeometryEntity.lo GeometryFeatureEngine.lo GeometryFeatureTool.lo GeometryHealerEngine.lo GeometryHealerTool.lo GeometryModifyEngine.lo GeometryModifyTool.lo GeometryQueryEngine.lo GeometryQueryTool.lo GeometryUtil.lo GeomMeasureTool.lo GfxPreview.lo GroupingEntity.lo GSaveO!
pen.lo Loop.lo LoopSM.lo Lump.lo LumpSM.lo MedialTool2D.lo MedialTool3D.lo MergeToolAssistant.lo MergeTool.lo MidPlaneTool.lo ModelEntity.lo ModelQueryEngine.lo OffsetSplitTool.lo OldUnmergeCode.lo Point.lo PointSM.lo RefCollection.lo RefEdge.lo RefEntity.lo RefEntityFactory.lo RefEntityName.lo RefFace.lo RefGroup.lo RefVertex.lo RefVolume.lo SenseEntity.lo Shell.lo ShellSM.lo SphereEvaluator.lo SplitSurfaceTool.lo Surface.lo SurfaceOverlapFacet.lo SurfaceOverlapTool.lo SurfParamTool.lo SurfaceSM.lo TDCAGE.lo TDSourceFeature.lo TDSplitSurface.lo TDSurfaceOverlap.lo TDUniqueId.lo TopologyBridge.lo TopologyEntity.lo -lm
mkdir .libs
ar cru .libs/libcubit_geom.a AllocMemManagersGeom.o AnalyticGeometryTool.o BasicTopologyEntity.o Body.o BodySM.o BoundingBoxTool.o BridgeManager.o CAActuateSet.o CADeferredAttrib.o CAEntityColor.o CAEntityId.o CAEntityName.o CAGroup.o CAMergePartner.o CAMergeStatus.o CASourceFeature.o CAUniqueId.o CGMApp.o CGMEngineDynamicLoader.o Chain.o CoEdge.o CoEdgeSM.o CoFace.o CollectionEntity.o CoVertex.o CoVolume.o CubitAttrib.o CubitAttribManager.o CubitAttribUser.o CubitPolygon.o CubitSimpleAttrib.o Curve.o CurveOverlapFacet.o CurveSM.o CylinderEvaluator.o DAG.o DagDrawingTool.o GeomDataObserver.o GeometryEntity.o GeometryFeatureEngine.o GeometryFeatureTool.o GeometryHealerEngine.o GeometryHealerTool.o GeometryModifyEngine.o GeometryModifyTool.o GeometryQueryEngine.o GeometryQueryTool.o GeometryUtil.o GeomMeasureTool.o GfxPreview.o GroupingEntity.o GSaveOpen.o Loop.o LoopSM.o Lump.o LumpSM.o MedialTool2D.o MedialTool3D.o MergeToolAssistant.o MergeTool.o MidPlaneTool.o ModelEntity!
.o ModelQueryEngine.o OffsetSplitTool.o OldUnmergeCode.o Point.o PointSM.o RefCollection.o RefEdge.o RefEntity.o RefEntityFactory.o RefEntityName.o RefFace.o RefGroup.o RefVertex.o RefVolume.o SenseEntity.o Shell.o ShellSM.o SphereEvaluator.o SplitSurfaceTool.o Surface.o SurfaceOverlapFacet.o SurfaceOverlapTool.o SurfParamTool.o SurfaceSM.o TDCAGE.o TDSourceFeature.o TDSplitSurface.o TDSurfaceOverlap.o TDUniqueId.o TopologyBridge.o TopologyEntity.o
ranlib .libs/libcubit_geom.a
creating libcubit_geom.la
(cd .libs && rm -f libcubit_geom.la && ln -s ../libcubit_geom.la libcubit_geom.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in Cholla
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersCholla.lo -MD -MP -MF .deps/AllocMemManagersCholla.Tpo -c -o AllocMemManagersCholla.lo ../../../geom/Cholla/AllocMemManagersCholla.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersCholla.lo -MD -MP -MF .deps/AllocMemManagersCholla.Tpo -c ../../../geom/Cholla/AllocMemManagersCholla.cpp -o AllocMemManagersCholla.o
mv -f .deps/AllocMemManagersCholla.Tpo .deps/AllocMemManagersCholla.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Cholla.lo -MD -MP -MF .deps/Cholla.Tpo -c -o Cholla.lo ../../../geom/Cholla/Cholla.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Cholla.lo -MD -MP -MF .deps/Cholla.Tpo -c ../../../geom/Cholla/Cholla.cpp -o Cholla.o
../../../geom/Cholla/Cholla.cpp: In function ‘void constructQuadNormals(double, int, int, int, int*, int*, double*, double*, double*, int*)’:
../../../geom/Cholla/Cholla.cpp:437: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:438: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:439: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:440: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:441: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp: In function ‘CubitStatus build_facets(int, int, int, int, int*, int*, int*, double*, CubitPoint**, CubitFacetEdge**, CubitFacet**, CubitQuadFacet**, DLIList<FacetEntity*>&)’:
../../../geom/Cholla/Cholla.cpp:599: warning: deprecated conversion from string constant to ‘char*’
../../../geom/Cholla/Cholla.cpp: In function ‘void evalBezierFaceFromNorms(int, int, int, int, int*, int*, double*, double*, double*, int, double*, double*, double*, double*)’:
../../../geom/Cholla/Cholla.cpp:893: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:894: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:895: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:896: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:897: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp: In function ‘void evalBezierEdgeFromTans(int, int, int*, double*, double*, int, double*, double*, double*)’:
../../../geom/Cholla/Cholla.cpp:1904: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:1905: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:1906: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:1907: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/Cholla.cpp:1908: warning: ISO C++ does not support the ‘%lf’ printf format
mv -f .deps/Cholla.Tpo .deps/Cholla.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaCurve.lo -MD -MP -MF .deps/ChollaCurve.Tpo -c -o ChollaCurve.lo ../../../geom/Cholla/ChollaCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaCurve.lo -MD -MP -MF .deps/ChollaCurve.Tpo -c ../../../geom/Cholla/ChollaCurve.cpp -o ChollaCurve.o
../../../geom/Cholla/ChollaCurve.cpp: In member function ‘CubitStatus ChollaCurve::determine_ends()’:
../../../geom/Cholla/ChollaCurve.cpp:445: warning: suggest parentheses around && within ||
mv -f .deps/ChollaCurve.Tpo .deps/ChollaCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaEngine.lo -MD -MP -MF .deps/ChollaEngine.Tpo -c -o ChollaEngine.lo ../../../geom/Cholla/ChollaEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaEngine.lo -MD -MP -MF .deps/ChollaEngine.Tpo -c ../../../geom/Cholla/ChollaEngine.cpp -o ChollaEngine.o
../../../geom/Cholla/ChollaEngine.cpp: In member function ‘CubitStatus ChollaEngine::create_geometry(CubitBoolean, double, int, CubitBoolean, CubitBoolean)’:
../../../geom/Cholla/ChollaEngine.cpp:233: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/ChollaEngine.Tpo .deps/ChollaEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaEntity.lo -MD -MP -MF .deps/ChollaEntity.Tpo -c -o ChollaEntity.lo ../../../geom/Cholla/ChollaEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaEntity.lo -MD -MP -MF .deps/ChollaEntity.Tpo -c ../../../geom/Cholla/ChollaEntity.cpp -o ChollaEntity.o
mv -f .deps/ChollaEntity.Tpo .deps/ChollaEntity.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaPoint.lo -MD -MP -MF .deps/ChollaPoint.Tpo -c -o ChollaPoint.lo ../../../geom/Cholla/ChollaPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaPoint.lo -MD -MP -MF .deps/ChollaPoint.Tpo -c ../../../geom/Cholla/ChollaPoint.cpp -o ChollaPoint.o
mv -f .deps/ChollaPoint.Tpo .deps/ChollaPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaSkinTool.lo -MD -MP -MF .deps/ChollaSkinTool.Tpo -c -o ChollaSkinTool.lo ../../../geom/Cholla/ChollaSkinTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaSkinTool.lo -MD -MP -MF .deps/ChollaSkinTool.Tpo -c ../../../geom/Cholla/ChollaSkinTool.cpp -o ChollaSkinTool.o
mv -f .deps/ChollaSkinTool.Tpo .deps/ChollaSkinTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaSurface.lo -MD -MP -MF .deps/ChollaSurface.Tpo -c -o ChollaSurface.lo ../../../geom/Cholla/ChollaSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChollaSurface.lo -MD -MP -MF .deps/ChollaSurface.Tpo -c ../../../geom/Cholla/ChollaSurface.cpp -o ChollaSurface.o
mv -f .deps/ChollaSurface.Tpo .deps/ChollaSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChordalAxis.lo -MD -MP -MF .deps/ChordalAxis.Tpo -c -o ChordalAxis.lo ../../../geom/Cholla/ChordalAxis.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ChordalAxis.lo -MD -MP -MF .deps/ChordalAxis.Tpo -c ../../../geom/Cholla/ChordalAxis.cpp -o ChordalAxis.o
../../../geom/Cholla/ChordalAxis.cpp: In member function ‘CubitVector ChordalAxis::get_center(CubitVector, CubitVector, CubitVector)’:
../../../geom/Cholla/ChordalAxis.cpp:809: warning: ‘cy’ may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp:809: warning: ‘cx’ may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp: In member function ‘CubitStatus ChordalAxis::junction_triangle(CubitFacet*, TDChordal*, DLIList<CubitFacetEdge*>&)’:
../../../geom/Cholla/ChordalAxis.cpp:701: warning: ‘segment2’ may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp:701: warning: ‘segment1’ may be used uninitialized in this function
mv -f .deps/ChordalAxis.Tpo .deps/ChordalAxis.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacet.lo -MD -MP -MF .deps/CubitFacet.Tpo -c -o CubitFacet.lo ../../../geom/Cholla/CubitFacet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacet.lo -MD -MP -MF .deps/CubitFacet.Tpo -c ../../../geom/Cholla/CubitFacet.cpp -o CubitFacet.o
../../../geom/Cholla/CubitFacet.cpp: In member function ‘CubitFacetEdge* CubitFacet::edge_from_pts(CubitPoint*, CubitPoint*, int&)’:
../../../geom/Cholla/CubitFacet.cpp:780: warning: suggest parentheses around && within ||
../../../geom/Cholla/CubitFacet.cpp:785: warning: suggest parentheses around && within ||
../../../geom/Cholla/CubitFacet.cpp:790: warning: suggest parentheses around && within ||
mv -f .deps/CubitFacet.Tpo .deps/CubitFacet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetData.lo -MD -MP -MF .deps/CubitFacetData.Tpo -c -o CubitFacetData.lo ../../../geom/Cholla/CubitFacetData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetData.lo -MD -MP -MF .deps/CubitFacetData.Tpo -c ../../../geom/Cholla/CubitFacetData.cpp -o CubitFacetData.o
mv -f .deps/CubitFacetData.Tpo .deps/CubitFacetData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetEdge.lo -MD -MP -MF .deps/CubitFacetEdge.Tpo -c -o CubitFacetEdge.lo ../../../geom/Cholla/CubitFacetEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetEdge.lo -MD -MP -MF .deps/CubitFacetEdge.Tpo -c ../../../geom/Cholla/CubitFacetEdge.cpp -o CubitFacetEdge.o
mv -f .deps/CubitFacetEdge.Tpo .deps/CubitFacetEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetEdgeData.lo -MD -MP -MF .deps/CubitFacetEdgeData.Tpo -c -o CubitFacetEdgeData.lo ../../../geom/Cholla/CubitFacetEdgeData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitFacetEdgeData.lo -MD -MP -MF .deps/CubitFacetEdgeData.Tpo -c ../../../geom/Cholla/CubitFacetEdgeData.cpp -o CubitFacetEdgeData.o
mv -f .deps/CubitFacetEdgeData.Tpo .deps/CubitFacetEdgeData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPoint.lo -MD -MP -MF .deps/CubitPoint.Tpo -c -o CubitPoint.lo ../../../geom/Cholla/CubitPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPoint.lo -MD -MP -MF .deps/CubitPoint.Tpo -c ../../../geom/Cholla/CubitPoint.cpp -o CubitPoint.o
mv -f .deps/CubitPoint.Tpo .deps/CubitPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPointData.lo -MD -MP -MF .deps/CubitPointData.Tpo -c -o CubitPointData.lo ../../../geom/Cholla/CubitPointData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitPointData.lo -MD -MP -MF .deps/CubitPointData.Tpo -c ../../../geom/Cholla/CubitPointData.cpp -o CubitPointData.o
mv -f .deps/CubitPointData.Tpo .deps/CubitPointData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitQuadFacet.lo -MD -MP -MF .deps/CubitQuadFacet.Tpo -c -o CubitQuadFacet.lo ../../../geom/Cholla/CubitQuadFacet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitQuadFacet.lo -MD -MP -MF .deps/CubitQuadFacet.Tpo -c ../../../geom/Cholla/CubitQuadFacet.cpp -o CubitQuadFacet.o
mv -f .deps/CubitQuadFacet.Tpo .deps/CubitQuadFacet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitQuadFacetData.lo -MD -MP -MF .deps/CubitQuadFacetData.Tpo -c -o CubitQuadFacetData.lo ../../../geom/Cholla/CubitQuadFacetData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CubitQuadFacetData.lo -MD -MP -MF .deps/CubitQuadFacetData.Tpo -c ../../../geom/Cholla/CubitQuadFacetData.cpp -o CubitQuadFacetData.o
mv -f .deps/CubitQuadFacetData.Tpo .deps/CubitQuadFacetData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveFacetEvalTool.lo -MD -MP -MF .deps/CurveFacetEvalTool.Tpo -c -o CurveFacetEvalTool.lo ../../../geom/Cholla/CurveFacetEvalTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveFacetEvalTool.lo -MD -MP -MF .deps/CurveFacetEvalTool.Tpo -c ../../../geom/Cholla/CurveFacetEvalTool.cpp -o CurveFacetEvalTool.o
../../../geom/Cholla/CurveFacetEvalTool.cpp: In member function ‘void CurveFacetEvalTool::fix_point_edge_order()’:
../../../geom/Cholla/CurveFacetEvalTool.cpp:1937: warning: unused variable ‘this_pt0’
mv -f .deps/CurveFacetEvalTool.Tpo .deps/CurveFacetEvalTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT debug.lo -MD -MP -MF .deps/debug.Tpo -c -o debug.lo ../../../geom/Cholla/debug.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT debug.lo -MD -MP -MF .deps/debug.Tpo -c ../../../geom/Cholla/debug.cpp -o debug.o
mv -f .deps/debug.Tpo .deps/debug.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetDataUtil.lo -MD -MP -MF .deps/FacetDataUtil.Tpo -c -o FacetDataUtil.lo ../../../geom/Cholla/FacetDataUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetDataUtil.lo -MD -MP -MF .deps/FacetDataUtil.Tpo -c ../../../geom/Cholla/FacetDataUtil.cpp -o FacetDataUtil.o
../../../geom/Cholla/FacetDataUtil.cpp: In static member function ‘static CubitStatus FacetDataUtil::write_facets(char*, DLIList<CubitFacet*>&)’:
../../../geom/Cholla/FacetDataUtil.cpp:1274: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/FacetDataUtil.cpp: In static member function ‘static CubitStatus FacetDataUtil::merge_colinear_vertices(DLIList<DLIList<CubitFacet*>*>&, double, DLIList<CubitPoint*>&, int&, int&, int&)’:
../../../geom/Cholla/FacetDataUtil.cpp:1798: warning: ISO C++ does not support the ‘%lf’ printf format
../../../geom/Cholla/FacetDataUtil.cpp: In static member function ‘static CubitStatus FacetDataUtil::merge_coincident_vertices(DLIList<DLIList<CubitFacet*>*>&, double, int&, int&, DLIList<CubitPoint*>&)’:
../../../geom/Cholla/FacetDataUtil.cpp:2112: warning: unused variable ‘np’
../../../geom/Cholla/FacetDataUtil.cpp:2113: warning: unused variable ‘na’
mv -f .deps/FacetDataUtil.Tpo .deps/FacetDataUtil.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetEntity.lo -MD -MP -MF .deps/FacetEntity.Tpo -c -o FacetEntity.lo ../../../geom/Cholla/FacetEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetEntity.lo -MD -MP -MF .deps/FacetEntity.Tpo -c ../../../geom/Cholla/FacetEntity.cpp -o FacetEntity.o
mv -f .deps/FacetEntity.Tpo .deps/FacetEntity.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetEvalTool.lo -MD -MP -MF .deps/FacetEvalTool.Tpo -c -o FacetEvalTool.lo ../../../geom/Cholla/FacetEvalTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetEvalTool.lo -MD -MP -MF .deps/FacetEvalTool.Tpo -c ../../../geom/Cholla/FacetEvalTool.cpp -o FacetEvalTool.o
../../../geom/Cholla/FacetEvalTool.cpp: In member function ‘CubitStatus FacetEvalTool::mark_edge_pairs(CubitPoint*)’:
../../../geom/Cholla/FacetEvalTool.cpp:532: warning: unused variable ‘status’
../../../geom/Cholla/FacetEvalTool.cpp: In static member function ‘static void FacetEvalTool::ac_at_edge(CubitVector&, CubitVector&, int)’:
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: ‘w’ may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: ‘v’ may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: ‘u’ may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp: In static member function ‘static CubitStatus FacetEvalTool::project_to_facetedge(CubitFacet*, int, int, CubitVector&, CubitVector&, CubitVector&, CubitBoolean&, CubitBoolean)’:
../../../geom/Cholla/FacetEvalTool.cpp:2651: warning: ‘edge_id’ may be used uninitialized in this function
mv -f .deps/FacetEvalTool.Tpo .deps/FacetEvalTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeoNode.lo -MD -MP -MF .deps/GeoNode.Tpo -c -o GeoNode.lo ../../../geom/Cholla/GeoNode.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeoNode.lo -MD -MP -MF .deps/GeoNode.Tpo -c ../../../geom/Cholla/GeoNode.cpp -o GeoNode.o
mv -f .deps/GeoNode.Tpo .deps/GeoNode.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeoTet.lo -MD -MP -MF .deps/GeoTet.Tpo -c -o GeoTet.lo ../../../geom/Cholla/GeoTet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GeoTet.lo -MD -MP -MF .deps/GeoTet.Tpo -c ../../../geom/Cholla/GeoTet.cpp -o GeoTet.o
../../../geom/Cholla/GeoTet.cpp: In member function ‘void GeoTet::opposite_edge(GeoNode*, GeoNode*, GeoNode*&, GeoNode*&)’:
../../../geom/Cholla/GeoTet.cpp:155: warning: suggest explicit braces to avoid ambiguous ‘else’
mv -f .deps/GeoTet.Tpo .deps/GeoTet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopParamTool.lo -MD -MP -MF .deps/LoopParamTool.Tpo -c -o LoopParamTool.lo ../../../geom/Cholla/LoopParamTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopParamTool.lo -MD -MP -MF .deps/LoopParamTool.Tpo -c ../../../geom/Cholla/LoopParamTool.cpp -o LoopParamTool.o
../../../geom/Cholla/LoopParamTool.cpp: In member function ‘CubitStatus LoopParamTool::check_selfintersecting_coincident_edges(DLIList<DLIList<CubitPoint*>*>&)’:
../../../geom/Cholla/LoopParamTool.cpp:649: warning: suggest parentheses around && within ||
mv -f .deps/LoopParamTool.Tpo .deps/LoopParamTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointGridSearch.lo -MD -MP -MF .deps/PointGridSearch.Tpo -c -o PointGridSearch.lo ../../../geom/Cholla/PointGridSearch.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointGridSearch.lo -MD -MP -MF .deps/PointGridSearch.Tpo -c ../../../geom/Cholla/PointGridSearch.cpp -o PointGridSearch.o
mv -f .deps/PointGridSearch.Tpo .deps/PointGridSearch.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointLoopFacetor.lo -MD -MP -MF .deps/PointLoopFacetor.Tpo -c -o PointLoopFacetor.lo ../../../geom/Cholla/PointLoopFacetor.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointLoopFacetor.lo -MD -MP -MF .deps/PointLoopFacetor.Tpo -c ../../../geom/Cholla/PointLoopFacetor.cpp -o PointLoopFacetor.o
mv -f .deps/PointLoopFacetor.Tpo .deps/PointLoopFacetor.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDChordal.lo -MD -MP -MF .deps/TDChordal.Tpo -c -o TDChordal.lo ../../../geom/Cholla/TDChordal.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDChordal.lo -MD -MP -MF .deps/TDChordal.Tpo -c ../../../geom/Cholla/TDChordal.cpp -o TDChordal.o
mv -f .deps/TDChordal.Tpo .deps/TDChordal.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetboolData.lo -MD -MP -MF .deps/TDFacetboolData.Tpo -c -o TDFacetboolData.lo ../../../geom/Cholla/TDFacetboolData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetboolData.lo -MD -MP -MF .deps/TDFacetboolData.Tpo -c ../../../geom/Cholla/TDFacetboolData.cpp -o TDFacetboolData.o
mv -f .deps/TDFacetboolData.Tpo .deps/TDFacetboolData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetBoundaryEdge.lo -MD -MP -MF .deps/TDFacetBoundaryEdge.Tpo -c -o TDFacetBoundaryEdge.lo ../../../geom/Cholla/TDFacetBoundaryEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetBoundaryEdge.lo -MD -MP -MF .deps/TDFacetBoundaryEdge.Tpo -c ../../../geom/Cholla/TDFacetBoundaryEdge.cpp -o TDFacetBoundaryEdge.o
mv -f .deps/TDFacetBoundaryEdge.Tpo .deps/TDFacetBoundaryEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetBoundaryPoint.lo -MD -MP -MF .deps/TDFacetBoundaryPoint.Tpo -c -o TDFacetBoundaryPoint.lo ../../../geom/Cholla/TDFacetBoundaryPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDFacetBoundaryPoint.lo -MD -MP -MF .deps/TDFacetBoundaryPoint.Tpo -c ../../../geom/Cholla/TDFacetBoundaryPoint.cpp -o TDFacetBoundaryPoint.o
mv -f .deps/TDFacetBoundaryPoint.Tpo .deps/TDFacetBoundaryPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDGeomFacet.lo -MD -MP -MF .deps/TDGeomFacet.Tpo -c -o TDGeomFacet.lo ../../../geom/Cholla/TDGeomFacet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDGeomFacet.lo -MD -MP -MF .deps/TDGeomFacet.Tpo -c ../../../geom/Cholla/TDGeomFacet.cpp -o TDGeomFacet.o
mv -f .deps/TDGeomFacet.Tpo .deps/TDGeomFacet.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcholla.la AllocMemManagersCholla.lo Cholla.lo ChollaCurve.lo ChollaEngine.lo ChollaEntity.lo ChollaPoint.lo ChollaSkinTool.lo ChollaSurface.lo ChordalAxis.lo CubitFacet.lo CubitFacetData.lo CubitFacetEdge.lo CubitFacetEdgeData.lo CubitPoint.lo CubitPointData.lo CubitQuadFacet.lo CubitQuadFacetData.lo CurveFacetEvalTool.lo debug.lo FacetDataUtil.lo FacetEntity.lo FacetEvalTool.lo GeoNode.lo GeoTet.lo LoopParamTool.lo PointGridSearch.lo PointLoopFacetor.lo TDChordal.lo TDFacetboolData.lo TDFacetBoundaryEdge.lo TDFacetBoundaryPoint.lo TDGeomFacet.lo -lm
mkdir .libs
ar cru .libs/libcholla.a AllocMemManagersCholla.o Cholla.o ChollaCurve.o ChollaEngine.o ChollaEntity.o ChollaPoint.o ChollaSkinTool.o ChollaSurface.o ChordalAxis.o CubitFacet.o CubitFacetData.o CubitFacetEdge.o CubitFacetEdgeData.o CubitPoint.o CubitPointData.o CubitQuadFacet.o CubitQuadFacetData.o CurveFacetEvalTool.o debug.o FacetDataUtil.o FacetEntity.o FacetEvalTool.o GeoNode.o GeoTet.o LoopParamTool.o PointGridSearch.o PointLoopFacetor.o TDChordal.o TDFacetboolData.o TDFacetBoundaryEdge.o TDFacetBoundaryPoint.o TDGeomFacet.o
ranlib .libs/libcholla.a
creating libcholla.la
(cd .libs && rm -f libcholla.la && ln -s ../libcholla.la libcholla.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
Making all in facetbool
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBClassify.lo -MD -MP -MF .deps/FBClassify.Tpo -c -o FBClassify.lo ../../../geom/facetbool/FBClassify.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBClassify.lo -MD -MP -MF .deps/FBClassify.Tpo -c ../../../geom/facetbool/FBClassify.cpp -o FBClassify.o
mv -f .deps/FBClassify.Tpo .deps/FBClassify.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBDataUtil.lo -MD -MP -MF .deps/FBDataUtil.Tpo -c -o FBDataUtil.lo ../../../geom/facetbool/FBDataUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBDataUtil.lo -MD -MP -MF .deps/FBDataUtil.Tpo -c ../../../geom/facetbool/FBDataUtil.cpp -o FBDataUtil.o
mv -f .deps/FBDataUtil.Tpo .deps/FBDataUtil.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBImprint.lo -MD -MP -MF .deps/FBImprint.Tpo -c -o FBImprint.lo ../../../geom/facetbool/FBImprint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBImprint.lo -MD -MP -MF .deps/FBImprint.Tpo -c ../../../geom/facetbool/FBImprint.cpp -o FBImprint.o
mv -f .deps/FBImprint.Tpo .deps/FBImprint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBIntersect.lo -MD -MP -MF .deps/FBIntersect.Tpo -c -o FBIntersect.lo ../../../geom/facetbool/FBIntersect.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBIntersect.lo -MD -MP -MF .deps/FBIntersect.Tpo -c ../../../geom/facetbool/FBIntersect.cpp -o FBIntersect.o
../../../geom/facetbool/FBIntersect.cpp: In member function ‘CubitStatus FBIntersect::add_intersection_edges(FB_Triangle*, FB_Triangle*, double*, int*)’:
../../../geom/facetbool/FBIntersect.cpp:897: warning: ISO C++ does not support the ‘%le’ printf format
mv -f .deps/FBIntersect.Tpo .deps/FBIntersect.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBPolyhedron.lo -MD -MP -MF .deps/FBPolyhedron.Tpo -c -o FBPolyhedron.lo ../../../geom/facetbool/FBPolyhedron.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBPolyhedron.lo -MD -MP -MF .deps/FBPolyhedron.Tpo -c ../../../geom/facetbool/FBPolyhedron.cpp -o FBPolyhedron.o
../../../geom/facetbool/FBPolyhedron.cpp: In member function ‘bool FBPolyhedron::edge_exists_in_tri(FB_Triangle&, int, int)’:
../../../geom/facetbool/FBPolyhedron.cpp:407: warning: suggest parentheses around && within ||
mv -f .deps/FBPolyhedron.Tpo .deps/FBPolyhedron.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBRetriangulate.lo -MD -MP -MF .deps/FBRetriangulate.Tpo -c -o FBRetriangulate.lo ../../../geom/facetbool/FBRetriangulate.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBRetriangulate.lo -MD -MP -MF .deps/FBRetriangulate.Tpo -c ../../../geom/facetbool/FBRetriangulate.cpp -o FBRetriangulate.o
mv -f .deps/FBRetriangulate.Tpo .deps/FBRetriangulate.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBTiler.lo -MD -MP -MF .deps/FBTiler.Tpo -c -o FBTiler.lo ../../../geom/facetbool/FBTiler.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FBTiler.lo -MD -MP -MF .deps/FBTiler.Tpo -c ../../../geom/facetbool/FBTiler.cpp -o FBTiler.o
mv -f .deps/FBTiler.Tpo .deps/FBTiler.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT IntegerHash.lo -MD -MP -MF .deps/IntegerHash.Tpo -c -o IntegerHash.lo ../../../geom/facetbool/IntegerHash.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT IntegerHash.lo -MD -MP -MF .deps/IntegerHash.Tpo -c ../../../geom/facetbool/IntegerHash.cpp -o IntegerHash.o
mv -f .deps/IntegerHash.Tpo .deps/IntegerHash.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT KdTree.lo -MD -MP -MF .deps/KdTree.Tpo -c -o KdTree.lo ../../../geom/facetbool/KdTree.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT KdTree.lo -MD -MP -MF .deps/KdTree.Tpo -c ../../../geom/facetbool/KdTree.cpp -o KdTree.o
mv -f .deps/KdTree.Tpo .deps/KdTree.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_facetbool.la FBClassify.lo FBDataUtil.lo FBImprint.lo FBIntersect.lo FBPolyhedron.lo FBRetriangulate.lo FBTiler.lo IntegerHash.lo KdTree.lo -lm
mkdir .libs
ar cru .libs/libcubit_facetbool.a FBClassify.o FBDataUtil.o FBImprint.o FBIntersect.o FBPolyhedron.o FBRetriangulate.o FBTiler.o IntegerHash.o KdTree.o
ranlib .libs/libcubit_facetbool.a
creating libcubit_facetbool.la
(cd .libs && rm -f libcubit_facetbool.la && ln -s ../libcubit_facetbool.la libcubit_facetbool.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
Making all in facet
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetAttrib.lo -MD -MP -MF .deps/FacetAttrib.Tpo -c -o FacetAttrib.lo ../../../geom/facet/FacetAttrib.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetAttrib.lo -MD -MP -MF .deps/FacetAttrib.Tpo -c ../../../geom/facet/FacetAttrib.cpp -o FacetAttrib.o
mv -f .deps/FacetAttrib.Tpo .deps/FacetAttrib.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetAttribSet.lo -MD -MP -MF .deps/FacetAttribSet.Tpo -c -o FacetAttribSet.lo ../../../geom/facet/FacetAttribSet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetAttribSet.lo -MD -MP -MF .deps/FacetAttribSet.Tpo -c ../../../geom/facet/FacetAttribSet.cpp -o FacetAttribSet.o
mv -f .deps/FacetAttribSet.Tpo .deps/FacetAttribSet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetBody.lo -MD -MP -MF .deps/FacetBody.Tpo -c -o FacetBody.lo ../../../geom/facet/FacetBody.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetBody.lo -MD -MP -MF .deps/FacetBody.Tpo -c ../../../geom/facet/FacetBody.cpp -o FacetBody.o
mv -f .deps/FacetBody.Tpo .deps/FacetBody.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetboolInterface.lo -MD -MP -MF .deps/FacetboolInterface.Tpo -c -o FacetboolInterface.lo ../../../geom/facet/FacetboolInterface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetboolInterface.lo -MD -MP -MF .deps/FacetboolInterface.Tpo -c ../../../geom/facet/FacetboolInterface.cpp -o FacetboolInterface.o
mv -f .deps/FacetboolInterface.Tpo .deps/FacetboolInterface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetCoEdge.lo -MD -MP -MF .deps/FacetCoEdge.Tpo -c -o FacetCoEdge.lo ../../../geom/facet/FacetCoEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetCoEdge.lo -MD -MP -MF .deps/FacetCoEdge.Tpo -c ../../../geom/facet/FacetCoEdge.cpp -o FacetCoEdge.o
mv -f .deps/FacetCoEdge.Tpo .deps/FacetCoEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetCurve.lo -MD -MP -MF .deps/FacetCurve.Tpo -c -o FacetCurve.lo ../../../geom/facet/FacetCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetCurve.lo -MD -MP -MF .deps/FacetCurve.Tpo -c ../../../geom/facet/FacetCurve.cpp -o FacetCurve.o
../../../geom/facet/FacetCurve.cpp: In member function ‘void FacetCurve::adjust_periodic_parameter(double&)’:
../../../geom/facet/FacetCurve.cpp:937: warning: unused variable ‘edge_range’
mv -f .deps/FacetCurve.Tpo .deps/FacetCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetLoop.lo -MD -MP -MF .deps/FacetLoop.Tpo -c -o FacetLoop.lo ../../../geom/facet/FacetLoop.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetLoop.lo -MD -MP -MF .deps/FacetLoop.Tpo -c ../../../geom/facet/FacetLoop.cpp -o FacetLoop.o
mv -f .deps/FacetLoop.Tpo .deps/FacetLoop.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetLump.lo -MD -MP -MF .deps/FacetLump.Tpo -c -o FacetLump.lo ../../../geom/facet/FacetLump.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetLump.lo -MD -MP -MF .deps/FacetLump.Tpo -c ../../../geom/facet/FacetLump.cpp -o FacetLump.o
mv -f .deps/FacetLump.Tpo .deps/FacetLump.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetModifyEngine.lo -MD -MP -MF .deps/FacetModifyEngine.Tpo -c -o FacetModifyEngine.lo ../../../geom/facet/FacetModifyEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetModifyEngine.lo -MD -MP -MF .deps/FacetModifyEngine.Tpo -c ../../../geom/facet/FacetModifyEngine.cpp -o FacetModifyEngine.o
../../../geom/facet/FacetModifyEngine.cpp: In static member function ‘static void FacetModifyEngine::initialize_settings()’:
../../../geom/facet/FacetModifyEngine.cpp:112: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/FacetModifyEngine.Tpo .deps/FacetModifyEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetParamTool.lo -MD -MP -MF .deps/FacetParamTool.Tpo -c -o FacetParamTool.lo ../../../geom/facet/FacetParamTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetParamTool.lo -MD -MP -MF .deps/FacetParamTool.Tpo -c ../../../geom/facet/FacetParamTool.cpp -o FacetParamTool.o
mv -f .deps/FacetParamTool.Tpo .deps/FacetParamTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetPoint.lo -MD -MP -MF .deps/FacetPoint.Tpo -c -o FacetPoint.lo ../../../geom/facet/FacetPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetPoint.lo -MD -MP -MF .deps/FacetPoint.Tpo -c ../../../geom/facet/FacetPoint.cpp -o FacetPoint.o
mv -f .deps/FacetPoint.Tpo .deps/FacetPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetQueryEngine.lo -MD -MP -MF .deps/FacetQueryEngine.Tpo -c -o FacetQueryEngine.lo ../../../geom/facet/FacetQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetQueryEngine.lo -MD -MP -MF .deps/FacetQueryEngine.Tpo -c ../../../geom/facet/FacetQueryEngine.cpp -o FacetQueryEngine.o
../../../geom/facet/FacetQueryEngine.cpp: In static member function ‘static CubitStatus FacetQueryEngine::read_facets(const char*, int*&, int&, int&, int&, FacetFileFormat)’:
../../../geom/facet/FacetQueryEngine.cpp:3393: warning: suggest parentheses around && within ||
mv -f .deps/FacetQueryEngine.Tpo .deps/FacetQueryEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetShell.lo -MD -MP -MF .deps/FacetShell.Tpo -c -o FacetShell.lo ../../../geom/facet/FacetShell.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetShell.lo -MD -MP -MF .deps/FacetShell.Tpo -c ../../../geom/facet/FacetShell.cpp -o FacetShell.o
mv -f .deps/FacetShell.Tpo .deps/FacetShell.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetSurface.lo -MD -MP -MF .deps/FacetSurface.Tpo -c -o FacetSurface.lo ../../../geom/facet/FacetSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetSurface.lo -MD -MP -MF .deps/FacetSurface.Tpo -c ../../../geom/facet/FacetSurface.cpp -o FacetSurface.o
mv -f .deps/FacetSurface.Tpo .deps/FacetSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GridSearchTree.lo -MD -MP -MF .deps/GridSearchTree.Tpo -c -o GridSearchTree.lo ../../../geom/facet/GridSearchTree.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT GridSearchTree.lo -MD -MP -MF .deps/GridSearchTree.Tpo -c ../../../geom/facet/GridSearchTree.cpp -o GridSearchTree.o
mv -f .deps/GridSearchTree.Tpo .deps/GridSearchTree.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_facet.la FacetAttrib.lo FacetAttribSet.lo FacetBody.lo FacetboolInterface.lo FacetCoEdge.lo FacetCurve.lo FacetLoop.lo FacetLump.lo FacetModifyEngine.lo FacetParamTool.lo FacetPoint.lo FacetQueryEngine.lo FacetShell.lo FacetSurface.lo GridSearchTree.lo -lm
mkdir .libs
ar cru .libs/libcubit_facet.a FacetAttrib.o FacetAttribSet.o FacetBody.o FacetboolInterface.o FacetCoEdge.o FacetCurve.o FacetLoop.o FacetLump.o FacetModifyEngine.o FacetParamTool.o FacetPoint.o FacetQueryEngine.o FacetShell.o FacetSurface.o GridSearchTree.o
ranlib .libs/libcubit_facet.a
creating libcubit_facet.la
(cd .libs && rm -f libcubit_facet.la && ln -s ../libcubit_facet.la libcubit_facet.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
Making all in virtual
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersVirtual.lo -MD -MP -MF .deps/AllocMemManagersVirtual.Tpo -c -o AllocMemManagersVirtual.lo ../../../geom/virtual/AllocMemManagersVirtual.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AllocMemManagersVirtual.lo -MD -MP -MF .deps/AllocMemManagersVirtual.Tpo -c ../../../geom/virtual/AllocMemManagersVirtual.cpp -o AllocMemManagersVirtual.o
mv -f .deps/AllocMemManagersVirtual.Tpo .deps/AllocMemManagersVirtual.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CACompositeVG.lo -MD -MP -MF .deps/CACompositeVG.Tpo -c -o CACompositeVG.lo ../../../geom/virtual/CACompositeVG.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CACompositeVG.lo -MD -MP -MF .deps/CACompositeVG.Tpo -c ../../../geom/virtual/CACompositeVG.cpp -o CACompositeVG.o
../../../geom/virtual/CACompositeVG.cpp: In member function ‘virtual CubitStatus CACompositeVG::actuate()’:
../../../geom/virtual/CACompositeVG.cpp:137: warning: suggest explicit braces to avoid ambiguous ‘else’
mv -f .deps/CACompositeVG.Tpo .deps/CACompositeVG.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAPartitionVG.lo -MD -MP -MF .deps/CAPartitionVG.Tpo -c -o CAPartitionVG.lo ../../../geom/virtual/CAPartitionVG.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAPartitionVG.lo -MD -MP -MF .deps/CAPartitionVG.Tpo -c ../../../geom/virtual/CAPartitionVG.cpp -o CAPartitionVG.o
mv -f .deps/CAPartitionVG.Tpo .deps/CAPartitionVG.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAVirtualVG.lo -MD -MP -MF .deps/CAVirtualVG.Tpo -c -o CAVirtualVG.lo ../../../geom/virtual/CAVirtualVG.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CAVirtualVG.lo -MD -MP -MF .deps/CAVirtualVG.Tpo -c ../../../geom/virtual/CAVirtualVG.cpp -o CAVirtualVG.o
mv -f .deps/CAVirtualVG.Tpo .deps/CAVirtualVG.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CollapseAngleTool.lo -MD -MP -MF .deps/CollapseAngleTool.Tpo -c -o CollapseAngleTool.lo ../../../geom/virtual/CollapseAngleTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CollapseAngleTool.lo -MD -MP -MF .deps/CollapseAngleTool.Tpo -c ../../../geom/virtual/CollapseAngleTool.cpp -o CollapseAngleTool.o
mv -f .deps/CollapseAngleTool.Tpo .deps/CollapseAngleTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeAttrib.lo -MD -MP -MF .deps/CompositeAttrib.Tpo -c -o CompositeAttrib.lo ../../../geom/virtual/CompositeAttrib.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeAttrib.lo -MD -MP -MF .deps/CompositeAttrib.Tpo -c ../../../geom/virtual/CompositeAttrib.cpp -o CompositeAttrib.o
mv -f .deps/CompositeAttrib.Tpo .deps/CompositeAttrib.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeBody.lo -MD -MP -MF .deps/CompositeBody.Tpo -c -o CompositeBody.lo ../../../geom/virtual/CompositeBody.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeBody.lo -MD -MP -MF .deps/CompositeBody.Tpo -c ../../../geom/virtual/CompositeBody.cpp -o CompositeBody.o
mv -f .deps/CompositeBody.Tpo .deps/CompositeBody.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCoEdge.lo -MD -MP -MF .deps/CompositeCoEdge.Tpo -c -o CompositeCoEdge.lo ../../../geom/virtual/CompositeCoEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCoEdge.lo -MD -MP -MF .deps/CompositeCoEdge.Tpo -c ../../../geom/virtual/CompositeCoEdge.cpp -o CompositeCoEdge.o
../../../geom/virtual/CompositeCoEdge.cpp: In constructor ‘CompositeCoEdge::CompositeCoEdge(CompositeCurve*)’:
../../../geom/virtual/CompositeCoEdge.cpp:54: warning: unused variable ‘stat’
../../../geom/virtual/CompositeCoEdge.cpp: In member function ‘void CompositeCoEdge::print_debug_info(const char*, bool)’:
../../../geom/virtual/CompositeCoEdge.cpp:558: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeCoEdge*’
../../../geom/virtual/CompositeCoEdge.cpp:561: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CoEdgeSM*’
../../../geom/virtual/CompositeCoEdge.cpp:571: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CompositeCurve*’
mv -f .deps/CompositeCoEdge.Tpo .deps/CompositeCoEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCoSurf.lo -MD -MP -MF .deps/CompositeCoSurf.Tpo -c -o CompositeCoSurf.lo ../../../geom/virtual/CompositeCoSurf.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCoSurf.lo -MD -MP -MF .deps/CompositeCoSurf.Tpo -c ../../../geom/virtual/CompositeCoSurf.cpp -o CompositeCoSurf.o
../../../geom/virtual/CompositeCoSurf.cpp: In member function ‘void CompositeCoSurf::print_debug_info(const char*, bool)’:
../../../geom/virtual/CompositeCoSurf.cpp:38: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeCoSurf*’
../../../geom/virtual/CompositeCoSurf.cpp:43: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CompositeSurface*’
mv -f .deps/CompositeCoSurf.Tpo .deps/CompositeCoSurf.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCurve.lo -MD -MP -MF .deps/CompositeCurve.Tpo -c -o CompositeCurve.lo ../../../geom/virtual/CompositeCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeCurve.lo -MD -MP -MF .deps/CompositeCurve.Tpo -c ../../../geom/virtual/CompositeCurve.cpp -o CompositeCurve.o
../../../geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(Curve*)’:
../../../geom/virtual/CompositeCurve.hpp:213: warning: ‘CompositeCurve::stitchNext’ will be initialized after
../../../geom/virtual/CompositeCurve.hpp:31: warning: ‘int CompositeCurve::HadBridgeRemoved’
../../../geom/virtual/CompositeCurve.cpp:34: warning: when initialized here
../../../geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(CompositeGeom*)’:
../../../geom/virtual/CompositeCurve.cpp:51: warning: when initialized here
../../../geom/virtual/CompositeCurve.hpp: In constructor ‘CompositeCurve::CompositeCurve(CompositePoint*)’:
../../../geom/virtual/CompositeCurve.cpp:79: warning: when initialized here
../../../geom/virtual/CompositeCurve.cpp: In member function ‘void CompositeCurve::print_debug_info(const char*, bool) const’:
../../../geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositeCurve*’
../../../geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘CompositePoint*’
../../../geom/virtual/CompositeCurve.cpp:1078: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘CompositePoint*’
../../../geom/virtual/CompositeCurve.cpp:1080: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Curve*’
../../../geom/virtual/CompositeCurve.cpp:1094: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositeCurve*’
../../../geom/virtual/CompositeCurve.cpp:1125: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
../../../geom/virtual/CompositeCurve.cpp: In member function ‘virtual void CompositeCurve::notify_split(TopologyBridge*, TopologyBridge*)’:
../../../geom/virtual/CompositeCurve.cpp:1402: warning: unused variable ‘s’
../../../geom/virtual/CompositeCurve.cpp:1324: warning: unused variable ‘ep’
mv -f .deps/CompositeCurve.Tpo .deps/CompositeCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeEngine.lo -MD -MP -MF .deps/CompositeEngine.Tpo -c -o CompositeEngine.lo ../../../geom/virtual/CompositeEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeEngine.lo -MD -MP -MF .deps/CompositeEngine.Tpo -c ../../../geom/virtual/CompositeEngine.cpp -o CompositeEngine.o
../../../geom/virtual/CompositeEngine.cpp: In constructor ‘CompositeEngine::CompositeEngine()’:
../../../geom/virtual/CompositeEngine.cpp:1279: warning: unused variable ‘result’
../../../geom/virtual/CompositeEngine.cpp: In member function ‘CompositeCurve* CompositeEngine::composite(Curve*, Curve*, Point*, bool)’:
../../../geom/virtual/CompositeEngine.cpp:1404: warning: unused variable ‘s’
../../../geom/virtual/CompositeEngine.cpp:1409: warning: unused variable ‘s’
../../../geom/virtual/CompositeEngine.cpp: In static member function ‘static CubitStatus CompositeEngine::find_coedges(CompositeSurface*, CompositeCurve*, CompositePoint*, CompositeCoEdge*&, CompositeCoEdge*&)’:
../../../geom/virtual/CompositeEngine.cpp:3773: warning: unused variable ‘next_owner’
../../../geom/virtual/CompositeEngine.cpp: In member function ‘CubitStatus CompositeEngine::restore_curve(Curve*)’:
../../../geom/virtual/CompositeEngine.cpp:3532: warning: ‘other_coedge’ may be used uninitialized in this function
mv -f .deps/CompositeEngine.Tpo .deps/CompositeEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeGeom.lo -MD -MP -MF .deps/CompositeGeom.Tpo -c -o CompositeGeom.lo ../../../geom/virtual/CompositeGeom.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeGeom.lo -MD -MP -MF .deps/CompositeGeom.Tpo -c ../../../geom/virtual/CompositeGeom.cpp -o CompositeGeom.o
../../../geom/virtual/CompositeGeom.cpp: In member function ‘void CompositeGeom::print_debug_info(const char*)’:
../../../geom/virtual/CompositeGeom.cpp:714: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeGeom*’
mv -f .deps/CompositeGeom.Tpo .deps/CompositeGeom.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeLoop.lo -MD -MP -MF .deps/CompositeLoop.Tpo -c -o CompositeLoop.lo ../../../geom/virtual/CompositeLoop.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeLoop.lo -MD -MP -MF .deps/CompositeLoop.Tpo -c ../../../geom/virtual/CompositeLoop.cpp -o CompositeLoop.o
../../../geom/virtual/CompositeLoop.cpp: In destructor ‘virtual CompositeLoop::~CompositeLoop()’:
../../../geom/virtual/CompositeLoop.cpp:39: warning: unused variable ‘s’
../../../geom/virtual/CompositeLoop.cpp: In member function ‘void CompositeLoop::print_debug_info(const char*)’:
../../../geom/virtual/CompositeLoop.cpp:274: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLoop*’
mv -f .deps/CompositeLoop.Tpo .deps/CompositeLoop.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeLump.lo -MD -MP -MF .deps/CompositeLump.Tpo -c -o CompositeLump.lo ../../../geom/virtual/CompositeLump.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeLump.lo -MD -MP -MF .deps/CompositeLump.Tpo -c ../../../geom/virtual/CompositeLump.cpp -o CompositeLump.o
../../../geom/virtual/CompositeLump.cpp: In member function ‘void CompositeLump::print_debug_info(const char*, bool)’:
../../../geom/virtual/CompositeLump.cpp:328: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLump*’
../../../geom/virtual/CompositeLump.cpp:332: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeLump*’
mv -f .deps/CompositeLump.Tpo .deps/CompositeLump.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositePoint.lo -MD -MP -MF .deps/CompositePoint.Tpo -c -o CompositePoint.lo ../../../geom/virtual/CompositePoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositePoint.lo -MD -MP -MF .deps/CompositePoint.Tpo -c ../../../geom/virtual/CompositePoint.cpp -o CompositePoint.o
../../../geom/virtual/CompositePoint.hpp: In constructor ‘CompositePoint::CompositePoint(Point*)’:
../../../geom/virtual/CompositePoint.hpp:80: warning: ‘CompositePoint::stitchNext’ will be initialized after
../../../geom/virtual/CompositePoint.hpp:28: warning: ‘int CompositePoint::HadBridgeRemoved’
../../../geom/virtual/CompositePoint.cpp:17: warning: when initialized here
../../../geom/virtual/CompositePoint.cpp: In member function ‘void CompositePoint::print_debug_info(const char*, bool) const’:
../../../geom/virtual/CompositePoint.cpp:170: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const CompositePoint*’
../../../geom/virtual/CompositePoint.cpp:170: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘Point*’
mv -f .deps/CompositePoint.Tpo .deps/CompositePoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeShell.lo -MD -MP -MF .deps/CompositeShell.Tpo -c -o CompositeShell.lo ../../../geom/virtual/CompositeShell.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeShell.lo -MD -MP -MF .deps/CompositeShell.Tpo -c ../../../geom/virtual/CompositeShell.cpp -o CompositeShell.o
../../../geom/virtual/CompositeShell.cpp: In member function ‘void CompositeShell::print_debug_info(const char*)’:
../../../geom/virtual/CompositeShell.cpp:190: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeShell*’
mv -f .deps/CompositeShell.Tpo .deps/CompositeShell.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeSurface.lo -MD -MP -MF .deps/CompositeSurface.Tpo -c -o CompositeSurface.lo ../../../geom/virtual/CompositeSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeSurface.lo -MD -MP -MF .deps/CompositeSurface.Tpo -c ../../../geom/virtual/CompositeSurface.cpp -o CompositeSurface.o
../../../geom/virtual/CompositeSurface.hpp: In constructor ‘CompositeSurface::CompositeSurface(Surface*)’:
../../../geom/virtual/CompositeSurface.hpp:235: warning: ‘CompositeSurface::facetTool’ will be initialized after
../../../geom/virtual/CompositeSurface.hpp:217: warning: ‘int CompositeSurface::HadBridgeRemoved’
../../../geom/virtual/CompositeSurface.cpp:43: warning: when initialized here
../../../geom/virtual/CompositeSurface.hpp: In constructor ‘CompositeSurface::CompositeSurface(CompositeGeom*)’:
../../../geom/virtual/CompositeSurface.cpp:55: warning: when initialized here
../../../geom/virtual/CompositeSurface.cpp: In member function ‘void CompositeSurface::print_debug_info(const char*, bool)’:
../../../geom/virtual/CompositeSurface.cpp:1524: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CompositeSurface*’
../../../geom/virtual/CompositeSurface.cpp: In member function ‘virtual CubitStatus CompositeSurface::closest_point(const CubitVector&, CubitVector*, CubitVector*, CubitVector*, CubitVector*)’:
../../../geom/virtual/CompositeSurface.cpp:852: warning: ‘result’ may be used uninitialized in this function
mv -f .deps/CompositeSurface.Tpo .deps/CompositeSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeTool.lo -MD -MP -MF .deps/CompositeTool.Tpo -c -o CompositeTool.lo ../../../geom/virtual/CompositeTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompositeTool.lo -MD -MP -MF .deps/CompositeTool.Tpo -c ../../../geom/virtual/CompositeTool.cpp -o CompositeTool.o
../../../geom/virtual/CompositeTool.cpp: In member function ‘CubitStatus CompositeTool::restore_merged_point(Point*, DLIList<RefFace*>&, bool)’:
../../../geom/virtual/CompositeTool.cpp:1377: warning: unused variable ‘ccurve’
mv -f .deps/CompositeTool.Tpo .deps/CompositeTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompSurfFacets.lo -MD -MP -MF .deps/CompSurfFacets.Tpo -c -o CompSurfFacets.lo ../../../geom/virtual/CompSurfFacets.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CompSurfFacets.lo -MD -MP -MF .deps/CompSurfFacets.Tpo -c ../../../geom/virtual/CompSurfFacets.cpp -o CompSurfFacets.o
../../../geom/virtual/CompSurfFacets.cpp:254:1: warning: multi-line comment
../../../geom/virtual/CompSurfFacets.cpp:256:1: warning: multi-line comment
../../../geom/virtual/CompSurfFacets.cpp:262:1: warning: multi-line comment
mv -f .deps/CompSurfFacets.Tpo .deps/CompSurfFacets.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Faceter.lo -MD -MP -MF .deps/Faceter.Tpo -c -o Faceter.lo ../../../geom/virtual/Faceter.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT Faceter.lo -MD -MP -MF .deps/Faceter.Tpo -c ../../../geom/virtual/Faceter.cpp -o Faceter.o
mv -f .deps/Faceter.Tpo .deps/Faceter.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FaceterFacetData.lo -MD -MP -MF .deps/FaceterFacetData.Tpo -c -o FaceterFacetData.lo ../../../geom/virtual/FaceterFacetData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FaceterFacetData.lo -MD -MP -MF .deps/FaceterFacetData.Tpo -c ../../../geom/virtual/FaceterFacetData.cpp -o FaceterFacetData.o
mv -f .deps/FaceterFacetData.Tpo .deps/FaceterFacetData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FaceterPointData.lo -MD -MP -MF .deps/FaceterPointData.Tpo -c -o FaceterPointData.lo ../../../geom/virtual/FaceterPointData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FaceterPointData.lo -MD -MP -MF .deps/FaceterPointData.Tpo -c ../../../geom/virtual/FaceterPointData.cpp -o FaceterPointData.o
mv -f .deps/FaceterPointData.Tpo .deps/FaceterPointData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetProjectTool.lo -MD -MP -MF .deps/FacetProjectTool.Tpo -c -o FacetProjectTool.lo ../../../geom/virtual/FacetProjectTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT FacetProjectTool.lo -MD -MP -MF .deps/FacetProjectTool.Tpo -c ../../../geom/virtual/FacetProjectTool.cpp -o FacetProjectTool.o
../../../geom/virtual/FacetProjectTool.cpp: In member function ‘CubitStatus FacetProjectTool::project(DLIList<CubitVector*>&, const std::vector<double, std::allocator<double> >&, const std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<double, std::allocator<double> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, const double*)’:
../../../geom/virtual/FacetProjectTool.cpp:144: warning: unused variable ‘facet’
../../../geom/virtual/FacetProjectTool.cpp:130: warning: unused variable ‘orig_num_facets’
mv -f .deps/FacetProjectTool.Tpo .deps/FacetProjectTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT HiddenEntitySet.lo -MD -MP -MF .deps/HiddenEntitySet.Tpo -c -o HiddenEntitySet.lo ../../../geom/virtual/HiddenEntitySet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT HiddenEntitySet.lo -MD -MP -MF .deps/HiddenEntitySet.Tpo -c ../../../geom/virtual/HiddenEntitySet.cpp -o HiddenEntitySet.o
../../../geom/virtual/HiddenEntitySet.cpp: In member function ‘void HiddenEntitySet::print_debug_info(const char*) const’:
../../../geom/virtual/HiddenEntitySet.cpp:173: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const HiddenEntitySet*’
../../../geom/virtual/HiddenEntitySet.cpp:173: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘TBOwner*’
../../../geom/virtual/HiddenEntitySet.cpp:194: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
mv -f .deps/HiddenEntitySet.Tpo .deps/HiddenEntitySet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintBoundaryTool.lo -MD -MP -MF .deps/ImprintBoundaryTool.Tpo -c -o ImprintBoundaryTool.lo ../../../geom/virtual/ImprintBoundaryTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintBoundaryTool.lo -MD -MP -MF .deps/ImprintBoundaryTool.Tpo -c ../../../geom/virtual/ImprintBoundaryTool.cpp -o ImprintBoundaryTool.o
../../../geom/virtual/ImprintBoundaryTool.cpp: In member function ‘CubitStatus ImprintBoundaryTool::intersect_segments(ImprintLineSegment*, ImprintLineSegment*, IntersectResult&, ImprintLineSegment**)’:
../../../geom/virtual/ImprintBoundaryTool.cpp:955: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:970: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:985: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:1000: warning: suggest parentheses around && within ||
mv -f .deps/ImprintBoundaryTool.Tpo .deps/ImprintBoundaryTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintLineSegment.lo -MD -MP -MF .deps/ImprintLineSegment.Tpo -c -o ImprintLineSegment.lo ../../../geom/virtual/ImprintLineSegment.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintLineSegment.lo -MD -MP -MF .deps/ImprintLineSegment.Tpo -c ../../../geom/virtual/ImprintLineSegment.cpp -o ImprintLineSegment.o
mv -f .deps/ImprintLineSegment.Tpo .deps/ImprintLineSegment.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintPointData.lo -MD -MP -MF .deps/ImprintPointData.Tpo -c -o ImprintPointData.lo ../../../geom/virtual/ImprintPointData.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ImprintPointData.lo -MD -MP -MF .deps/ImprintPointData.Tpo -c ../../../geom/virtual/ImprintPointData.cpp -o ImprintPointData.o
mv -f .deps/ImprintPointData.Tpo .deps/ImprintPointData.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionBody.lo -MD -MP -MF .deps/PartitionBody.Tpo -c -o PartitionBody.lo ../../../geom/virtual/PartitionBody.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionBody.lo -MD -MP -MF .deps/PartitionBody.Tpo -c ../../../geom/virtual/PartitionBody.cpp -o PartitionBody.o
mv -f .deps/PartitionBody.Tpo .deps/PartitionBody.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCoEdge.lo -MD -MP -MF .deps/PartitionCoEdge.Tpo -c -o PartitionCoEdge.lo ../../../geom/virtual/PartitionCoEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCoEdge.lo -MD -MP -MF .deps/PartitionCoEdge.Tpo -c ../../../geom/virtual/PartitionCoEdge.cpp -o PartitionCoEdge.o
mv -f .deps/PartitionCoEdge.Tpo .deps/PartitionCoEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCoSurf.lo -MD -MP -MF .deps/PartitionCoSurf.Tpo -c -o PartitionCoSurf.lo ../../../geom/virtual/PartitionCoSurf.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCoSurf.lo -MD -MP -MF .deps/PartitionCoSurf.Tpo -c ../../../geom/virtual/PartitionCoSurf.cpp -o PartitionCoSurf.o
mv -f .deps/PartitionCoSurf.Tpo .deps/PartitionCoSurf.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCurve.lo -MD -MP -MF .deps/PartitionCurve.Tpo -c -o PartitionCurve.lo ../../../geom/virtual/PartitionCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionCurve.lo -MD -MP -MF .deps/PartitionCurve.Tpo -c ../../../geom/virtual/PartitionCurve.cpp -o PartitionCurve.o
../../../geom/virtual/PartitionCurve.cpp: In member function ‘virtual void PartitionCurve::print_debug_info(const char*, bool) const’:
../../../geom/virtual/PartitionCurve.cpp:298: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionCurve*’
../../../geom/virtual/PartitionCurve.cpp:315: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘Surface*’
../../../geom/virtual/PartitionCurve.cpp:318: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionCurve.cpp:325: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionPoint*’
mv -f .deps/PartitionCurve.Tpo .deps/PartitionCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionEngine.lo -MD -MP -MF .deps/PartitionEngine.Tpo -c -o PartitionEngine.lo ../../../geom/virtual/PartitionEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionEngine.lo -MD -MP -MF .deps/PartitionEngine.Tpo -c ../../../geom/virtual/PartitionEngine.cpp -o PartitionEngine.o
../../../geom/virtual/PartitionEngine.cpp: In constructor ‘PartitionEngine::PartitionEngine()’:
../../../geom/virtual/PartitionEngine.cpp:80: warning: unused variable ‘r’
../../../geom/virtual/PartitionEngine.cpp: In member function ‘SubCurve* PartitionEngine::replace_curve(Curve*)’:
../../../geom/virtual/PartitionEngine.cpp:235: warning: unused variable ‘s’
../../../geom/virtual/PartitionEngine.cpp: In member function ‘SubSurface* PartitionEngine::replace_surface(Surface*)’:
../../../geom/virtual/PartitionEngine.cpp:335: warning: unused variable ‘pcurve’
../../../geom/virtual/PartitionEngine.cpp: In member function ‘PartitionCurve* PartitionEngine::next_curve_around_point(PartitionSurface*, CubitFacetEdgeData*, CubitPointData*, bool)’:
../../../geom/virtual/PartitionEngine.cpp:1459: warning: unused variable ‘facet2_index’
../../../geom/virtual/PartitionEngine.cpp: In member function ‘CubitStatus PartitionEngine::restore_from_attrib(Surface*)’:
../../../geom/virtual/PartitionEngine.cpp:4660: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘Surface*’
../../../geom/virtual/PartitionEngine.cpp:4709: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionEngine.cpp:4751: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartPTCurve*’
../../../geom/virtual/PartitionEngine.cpp:4751: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘SegmentedCurve*’
../../../geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionEngine.cpp:4787: warning: format ‘%p’ expects type ‘void*’, but argument 11 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionEngine.cpp:4983: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
mv -f .deps/PartitionEngine.Tpo .deps/PartitionEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionEntity.lo -MD -MP -MF .deps/PartitionEntity.Tpo -c -o PartitionEntity.lo ../../../geom/virtual/PartitionEntity.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionEntity.lo -MD -MP -MF .deps/PartitionEntity.Tpo -c ../../../geom/virtual/PartitionEntity.cpp -o PartitionEntity.o
../../../geom/virtual/PartitionEntity.cpp: In member function ‘virtual void PartitionEntity::print_debug_info(const char*, bool) const’:
../../../geom/virtual/PartitionEntity.cpp:32: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionEntity*’
../../../geom/virtual/PartitionEntity.cpp: In member function ‘void PartitionEntity::print_partitioned_entity(const char*) const’:
../../../geom/virtual/PartitionEntity.cpp:46: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
mv -f .deps/PartitionEntity.Tpo .deps/PartitionEntity.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLoop.lo -MD -MP -MF .deps/PartitionLoop.Tpo -c -o PartitionLoop.lo ../../../geom/virtual/PartitionLoop.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLoop.lo -MD -MP -MF .deps/PartitionLoop.Tpo -c ../../../geom/virtual/PartitionLoop.cpp -o PartitionLoop.o
../../../geom/virtual/PartitionLoop.cpp: In destructor ‘virtual PartitionLoop::~PartitionLoop()’:
../../../geom/virtual/PartitionLoop.cpp:39: warning: unused variable ‘s’
mv -f .deps/PartitionLoop.Tpo .deps/PartitionLoop.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLump.lo -MD -MP -MF .deps/PartitionLump.Tpo -c -o PartitionLump.lo ../../../geom/virtual/PartitionLump.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLump.lo -MD -MP -MF .deps/PartitionLump.Tpo -c ../../../geom/virtual/PartitionLump.cpp -o PartitionLump.o
../../../geom/virtual/PartitionLump.cpp: In member function ‘void PartitionLump::remove_all_shells()’:
../../../geom/virtual/PartitionLump.cpp:69: warning: unused variable ‘s’
mv -f .deps/PartitionLump.Tpo .deps/PartitionLump.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLumpImprint.lo -MD -MP -MF .deps/PartitionLumpImprint.Tpo -c -o PartitionLumpImprint.lo ../../../geom/virtual/PartitionLumpImprint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionLumpImprint.lo -MD -MP -MF .deps/PartitionLumpImprint.Tpo -c ../../../geom/virtual/PartitionLumpImprint.cpp -o PartitionLumpImprint.o
../../../geom/virtual/PartitionLumpImprint.cpp: In member function ‘void PartitionLumpImprint::set_point_owner(CubitPoint*, PartitionEntity*)’:
../../../geom/virtual/PartitionLumpImprint.cpp:356: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionEntity*’
../../../geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::partitionCurve(CubitPoint*)’:
../../../geom/virtual/PartitionLumpImprint.cpp:710: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
../../../geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::partitionSurface(int, int, PartitionSurface*)’:
../../../geom/virtual/PartitionLumpImprint.cpp:789: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionSurface*’
../../../geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::makePointCurve(CubitPoint*)’:
../../../geom/virtual/PartitionLumpImprint.cpp:1000: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionSurface*’
../../../geom/virtual/PartitionLumpImprint.cpp: In member function ‘CubitStatus PartitionLumpImprint::makeFreeCurve(int, int)’:
../../../geom/virtual/PartitionLumpImprint.cpp:1067: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’
../../../geom/virtual/PartitionLumpImprint.cpp:1067: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionPoint*’
mv -f .deps/PartitionLumpImprint.Tpo .deps/PartitionLumpImprint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionPoint.lo -MD -MP -MF .deps/PartitionPoint.Tpo -c -o PartitionPoint.lo ../../../geom/virtual/PartitionPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionPoint.lo -MD -MP -MF .deps/PartitionPoint.Tpo -c ../../../geom/virtual/PartitionPoint.cpp -o PartitionPoint.o
../../../geom/virtual/PartitionPoint.cpp: In member function ‘virtual void PartitionPoint::print_debug_info(const char*, bool) const’:
../../../geom/virtual/PartitionPoint.cpp:141: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionPoint*’
../../../geom/virtual/PartitionPoint.cpp:151: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘CubitPointData*’
mv -f .deps/PartitionPoint.Tpo .deps/PartitionPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionShell.lo -MD -MP -MF .deps/PartitionShell.Tpo -c -o PartitionShell.lo ../../../geom/virtual/PartitionShell.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionShell.lo -MD -MP -MF .deps/PartitionShell.Tpo -c ../../../geom/virtual/PartitionShell.cpp -o PartitionShell.o
mv -f .deps/PartitionShell.Tpo .deps/PartitionShell.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionSurface.lo -MD -MP -MF .deps/PartitionSurface.Tpo -c -o PartitionSurface.lo ../../../geom/virtual/PartitionSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionSurface.lo -MD -MP -MF .deps/PartitionSurface.Tpo -c ../../../geom/virtual/PartitionSurface.cpp -o PartitionSurface.o
../../../geom/virtual/PartitionSurface.cpp: In member function ‘virtual void PartitionSurface::print_debug_info(const char*, bool) const’:
../../../geom/virtual/PartitionSurface.cpp:96: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const PartitionSurface*’
../../../geom/virtual/PartitionSurface.cpp:100: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionLoop*’
../../../geom/virtual/PartitionSurface.cpp:107: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionCoEdge*’
../../../geom/virtual/PartitionSurface.cpp:107: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionCurve*’
../../../geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface()’:
../../../geom/virtual/PartitionSurface.hpp:203: warning: ‘PartitionSurface::firstCoSurf’ will be initialized after
../../../geom/virtual/PartitionSurface.hpp:194: warning: ‘CubitSense PartitionSurface::geometry_sense’
../../../geom/virtual/PartitionSurface.cpp:118: warning: when initialized here
../../../geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface(PartitionLump*)’:
../../../geom/virtual/PartitionSurface.cpp:122: warning: when initialized here
../../../geom/virtual/PartitionSurface.hpp: In constructor ‘PartitionSurface::PartitionSurface(PartitionSurface*)’:
../../../geom/virtual/PartitionSurface.cpp:893: warning: when initialized here
../../../geom/virtual/PartitionSurface.cpp: In member function ‘virtual void PartitionSurface::notify_split(FacetEntity*, FacetEntity*)’:
../../../geom/virtual/PartitionSurface.cpp:975: warning: unused variable ‘old_ptr’
mv -f .deps/PartitionSurface.Tpo .deps/PartitionSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionTool.lo -MD -MP -MF .deps/PartitionTool.Tpo -c -o PartitionTool.lo ../../../geom/virtual/PartitionTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartitionTool.lo -MD -MP -MF .deps/PartitionTool.Tpo -c ../../../geom/virtual/PartitionTool.cpp -o PartitionTool.o
../../../geom/virtual/PartitionTool.cpp: In member function ‘virtual CubitStatus PartitionTool::insert_edge(DLIList<RefFace*>&, DLIList<CubitVector*>&, DLIList<RefFace*>&, DLIList<RefEdge*>&, CubitBoolean)’:
../../../geom/virtual/PartitionTool.cpp:875: warning: unused variable ‘status’
../../../geom/virtual/PartitionTool.cpp: In member function ‘CubitStatus PartitionTool::partition_face_by_curves(RefFace*, const DLIList<Curve*>&, DLIList<RefFace*>&, CubitBoolean, DLIList<RefEdge*>*, CubitBoolean)’:
../../../geom/virtual/PartitionTool.cpp:1524: warning: unused variable ‘sta’
../../../geom/virtual/PartitionTool.cpp:1530: warning: unused variable ‘sta’
../../../geom/virtual/PartitionTool.cpp:1544: warning: unused variable ‘sta’
../../../geom/virtual/PartitionTool.cpp:1550: warning: unused variable ‘stat’
../../../geom/virtual/PartitionTool.cpp: In function ‘void pt_print_bte_list(int, DLIList<BasicTopologyEntity*>&, const char*)’:
../../../geom/virtual/PartitionTool.cpp:1931: warning: suggest explicit braces to avoid ambiguous ‘else’
../../../geom/virtual/PartitionTool.cpp: In member function ‘virtual RefVertex* PartitionTool::partition(RefEdge*, const CubitVector&, RefEdge*&, RefEdge*&, CubitBoolean)’:
../../../geom/virtual/PartitionTool.cpp:245: warning: ‘is_start’ may be used uninitialized in this function
mv -f .deps/PartitionTool.Tpo .deps/PartitionTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartPTCurve.lo -MD -MP -MF .deps/PartPTCurve.Tpo -c -o PartPTCurve.lo ../../../geom/virtual/PartPTCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartPTCurve.lo -MD -MP -MF .deps/PartPTCurve.Tpo -c ../../../geom/virtual/PartPTCurve.cpp -o PartPTCurve.o
mv -f .deps/PartPTCurve.Tpo .deps/PartPTCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartSurfFacetTool.lo -MD -MP -MF .deps/PartSurfFacetTool.Tpo -c -o PartSurfFacetTool.lo ../../../geom/virtual/PartSurfFacetTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PartSurfFacetTool.lo -MD -MP -MF .deps/PartSurfFacetTool.Tpo -c ../../../geom/virtual/PartSurfFacetTool.cpp -o PartSurfFacetTool.o
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function ‘static void PartSurfFacetTool::validate_facets(PartitionSurface*)’:
../../../geom/virtual/PartSurfFacetTool.cpp:258: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp:271: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionPoint*’
../../../geom/virtual/PartSurfFacetTool.cpp:271: warning: format ‘%p’ expects type ‘void*’, but argument 8 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp:281: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp:281: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’
../../../geom/virtual/PartSurfFacetTool.cpp:291: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp:291: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionPoint*’
../../../geom/virtual/PartSurfFacetTool.cpp:305: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp:305: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PartitionCurve*’
../../../geom/virtual/PartSurfFacetTool.cpp: In function ‘void draw_edges(DLIList<CubitFacetEdge*>&, int, bool, bool, int, bool)’:
../../../geom/virtual/PartSurfFacetTool.cpp:521: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CubitFacetEdge*’
../../../geom/virtual/PartSurfFacetTool.cpp:541: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘CubitPoint*’
../../../geom/virtual/PartSurfFacetTool.cpp: In member function ‘CubitStatus PartSurfFacetTool::init_facet_data(DLIList<CubitFacetData*>&)’:
../../../geom/virtual/PartSurfFacetTool.cpp:687: warning: unused variable ‘curv1’
../../../geom/virtual/PartSurfFacetTool.cpp:688: warning: unused variable ‘curv2’
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function ‘static CubitStatus PartSurfFacetTool::split_edge(CubitFacetEdge*, const CubitVector&, CubitFacet*, CubitPoint*&, CubitFacetEdge*&, CubitFacet*&)’:
../../../geom/virtual/PartSurfFacetTool.cpp:986: warning: unused variable ‘dot’
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function ‘static CubitStatus PartSurfFacetTool::seam_curve(DLIList<CubitFacetEdgeData*>&, PartitionCurve*, DLIList<CubitFacetData*>&, DLIList<CubitFacetEdgeData*>*)’:
../../../geom/virtual/PartSurfFacetTool.cpp:1541: warning: unused variable ‘s1’
../../../geom/virtual/PartSurfFacetTool.cpp:1542: warning: unused variable ‘s2’
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function ‘static CubitPoint* PartSurfFacetTool::split_edge_closest(CubitFacetEdgeData*, const CubitVector&, double, CubitFacetEdgeData*&, DLIList<CubitFacetData*>&)’:
../../../geom/virtual/PartSurfFacetTool.cpp:2003: warning: unused variable ‘surf’
mv -f .deps/PartSurfFacetTool.Tpo .deps/PartSurfFacetTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PST_Data.lo -MD -MP -MF .deps/PST_Data.Tpo -c -o PST_Data.lo ../../../geom/virtual/PST_Data.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PST_Data.lo -MD -MP -MF .deps/PST_Data.Tpo -c ../../../geom/virtual/PST_Data.cpp -o PST_Data.o
../../../geom/virtual/PST_Data.cpp: In member function ‘PST_Edge* PST_Point::common(PST_Point*)’:
../../../geom/virtual/PST_Data.cpp:26: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘void PST_Face::append_points(DLIList<PST_Point*>&)’:
../../../geom/virtual/PST_Data.cpp:85: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘PST_Point* PST_Face::opposite(PST_Edge*)’:
../../../geom/virtual/PST_Data.cpp:98: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘PST_Edge* PST_Face::opposite(PST_Point*)’:
../../../geom/virtual/PST_Data.cpp:114: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘bool PST_Face::two_edges(PST_Point*, PST_Edge*&, PST_Edge*&)’:
../../../geom/virtual/PST_Data.cpp:131: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘PST_CoEdge* PST_CoEdge::previous()’:
../../../geom/virtual/PST_Data.cpp:210: warning: unused variable ‘debug’
../../../geom/virtual/PST_Data.cpp: In member function ‘int PST_Point::validate(CubitBoolean)’:
../../../geom/virtual/PST_Data.cpp:996: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:996: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp: In member function ‘int PST_Edge::validate(CubitBoolean)’:
../../../geom/virtual/PST_Data.cpp:1011: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1026: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1038: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1053: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1066: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1066: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1074: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1074: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1082: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1082: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1090: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1090: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp: In member function ‘int PST_CoEdge::validate(CubitBoolean)’:
../../../geom/virtual/PST_Data.cpp:1102: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1111: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1111: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp: In member function ‘int PST_Face::validate(CubitBoolean)’:
../../../geom/virtual/PST_Data.cpp:1125: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1135: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1144: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1155: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1155: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1162: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1162: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp: In member function ‘void PST_Face::print()’:
../../../geom/virtual/PST_Data.cpp:1189: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 3 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 4 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 5 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 6 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1197: warning: format ‘%10p’ expects type ‘void*’, but argument 7 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 3 has type ‘PST_CoEdge*’
../../../geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 4 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 5 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1202: warning: format ‘%10p’ expects type ‘void*’, but argument 6 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp: In member function ‘void PST_Edge::print()’:
../../../geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp:1210: warning: format ‘%p’ expects type ‘void*’, but argument 7 has type ‘PST_Face*’
../../../geom/virtual/PST_Data.cpp: In member function ‘void PST_Point::print()’:
../../../geom/virtual/PST_Data.cpp:1215: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘PST_Point*’
../../../geom/virtual/PST_Data.cpp:1226: warning: format ‘%8p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
../../../geom/virtual/PST_Data.cpp:1230: warning: format ‘%8p’ expects type ‘void*’, but argument 3 has type ‘PST_Edge*’
mv -f .deps/PST_Data.Tpo .deps/PST_Data.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SegmentedCurve.lo -MD -MP -MF .deps/SegmentedCurve.Tpo -c -o SegmentedCurve.lo ../../../geom/virtual/SegmentedCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SegmentedCurve.lo -MD -MP -MF .deps/SegmentedCurve.Tpo -c ../../../geom/virtual/SegmentedCurve.cpp -o SegmentedCurve.o
../../../geom/virtual/SegmentedCurve.cpp: In member function ‘virtual void SegmentedCurve::print_debug_info(const char*, bool) const’:
../../../geom/virtual/SegmentedCurve.cpp:860: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘const SegmentedCurve*’
mv -f .deps/SegmentedCurve.Tpo .deps/SegmentedCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubCurve.lo -MD -MP -MF .deps/SubCurve.Tpo -c -o SubCurve.lo ../../../geom/virtual/SubCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubCurve.lo -MD -MP -MF .deps/SubCurve.Tpo -c ../../../geom/virtual/SubCurve.cpp -o SubCurve.o
mv -f .deps/SubCurve.Tpo .deps/SubCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubEntitySet.lo -MD -MP -MF .deps/SubEntitySet.Tpo -c -o SubEntitySet.lo ../../../geom/virtual/SubEntitySet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubEntitySet.lo -MD -MP -MF .deps/SubEntitySet.Tpo -c ../../../geom/virtual/SubEntitySet.cpp -o SubEntitySet.o
../../../geom/virtual/SubEntitySet.cpp: In member function ‘void SubEntitySet::add_lower_order(PartitionEntity*, CubitSimpleAttrib&, int, DLIList<CubitVector*>&, DLIList<int>&, DLIList<int>&, DLIList<int>&)’:
../../../geom/virtual/SubEntitySet.cpp:190: warning: unused variable ‘result’
../../../geom/virtual/SubEntitySet.cpp: In member function ‘void SubEntitySet::print_debug_info(const char*) const’:
../../../geom/virtual/SubEntitySet.cpp:335: warning: format ‘%p’ expects type ‘void*’, but argument 5 has type ‘TopologyBridge*’
../../../geom/virtual/SubEntitySet.cpp:342: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionEntity*’
../../../geom/virtual/SubEntitySet.cpp:351: warning: format ‘%p’ expects type ‘void*’, but argument 6 has type ‘PartitionEntity*’
../../../geom/virtual/SubEntitySet.cpp:355: warning: format ‘%p’ expects type ‘void*’, but argument 4 has type ‘PartitionBody*’
mv -f .deps/SubEntitySet.Tpo .deps/SubEntitySet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c -o SubSurface.lo ../../../geom/virtual/SubSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c ../../../geom/virtual/SubSurface.cpp -o SubSurface.o
mv -f .deps/SubSurface.Tpo .deps/SubSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c -o TDVGFacetOwner.lo ../../../geom/virtual/TDVGFacetOwner.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c ../../../geom/virtual/TDVGFacetOwner.cpp -o TDVGFacetOwner.o
mv -f .deps/TDVGFacetOwner.Tpo .deps/TDVGFacetOwner.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c -o TDVGFacetSplit.lo ../../../geom/virtual/TDVGFacetSplit.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c ../../../geom/virtual/TDVGFacetSplit.cpp -o TDVGFacetSplit.o
mv -f .deps/TDVGFacetSplit.Tpo .deps/TDVGFacetSplit.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c -o VirtualQueryEngine.lo ../../../geom/virtual/VirtualQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c ../../../geom/virtual/VirtualQueryEngine.cpp -o VirtualQueryEngine.o
../../../geom/virtual/VirtualQueryEngine.cpp: In member function ‘virtual CubitStatus VirtualQueryEngine::get_graphics(Surface*, int&, int&, int&, GMem*, short unsigned int, double, double) const’:
../../../geom/virtual/VirtualQueryEngine.cpp:201: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘Surface*’
../../../geom/virtual/VirtualQueryEngine.cpp:201: warning: format ‘%p’ expects type ‘void*’, but argument 7 has type ‘GMem*’
../../../geom/virtual/VirtualQueryEngine.cpp: In member function ‘virtual CubitStatus VirtualQueryEngine::entity_entity_distance(GeometryEntity*, GeometryEntity*, CubitVector&, CubitVector&, double&)’:
../../../geom/virtual/VirtualQueryEngine.cpp:1396: warning: unused variable ‘gqe2’
mv -f .deps/VirtualQueryEngine.Tpo .deps/VirtualQueryEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c -o VirtualImprintTool.lo ../../../geom/virtual/VirtualImprintTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c ../../../geom/virtual/VirtualImprintTool.cpp -o VirtualImprintTool.o
mv -f .deps/VirtualImprintTool.Tpo .deps/VirtualImprintTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_virtual.la AllocMemManagersVirtual.lo CACompositeVG.lo CAPartitionVG.lo CAVirtualVG.lo CollapseAngleTool.lo CompositeAttrib.lo CompositeBody.lo CompositeCoEdge.lo CompositeCoSurf.lo CompositeCurve.lo CompositeEngine.lo CompositeGeom.lo CompositeLoop.lo CompositeLump.lo CompositePoint.lo CompositeShell.lo CompositeSurface.lo CompositeTool.lo CompSurfFacets.lo Faceter.lo FaceterFacetData.lo FaceterPointData.lo FacetProjectTool.lo HiddenEntitySet.lo ImprintBoundaryTool.lo ImprintLineSegment.lo ImprintPointData.lo PartitionBody.lo PartitionCoEdge.lo PartitionCoSurf.lo PartitionCurve.lo PartitionEngine.lo PartitionEntity.lo PartitionLoop.lo PartitionLump.lo PartitionLumpImprint.lo PartitionPoint.lo PartitionShell.lo PartitionSurface.lo PartitionTool.lo PartPTCurve.lo PartSurfFacetTool.lo PST_Data.lo SegmentedCurve.lo SubCurve.lo SubEntitySet.lo SubSurface.lo TDVGFacetOwner.lo TDVG!
FacetSplit.lo VirtualQueryEngine.lo VirtualImprintTool.lo -lm
mkdir .libs
ar cru .libs/libcubit_virtual.a AllocMemManagersVirtual.o CACompositeVG.o CAPartitionVG.o CAVirtualVG.o CollapseAngleTool.o CompositeAttrib.o CompositeBody.o CompositeCoEdge.o CompositeCoSurf.o CompositeCurve.o CompositeEngine.o CompositeGeom.o CompositeLoop.o CompositeLump.o CompositePoint.o CompositeShell.o CompositeSurface.o CompositeTool.o CompSurfFacets.o Faceter.o FaceterFacetData.o FaceterPointData.o FacetProjectTool.o HiddenEntitySet.o ImprintBoundaryTool.o ImprintLineSegment.o ImprintPointData.o PartitionBody.o PartitionCoEdge.o PartitionCoSurf.o PartitionCurve.o PartitionEngine.o PartitionEntity.o PartitionLoop.o PartitionLump.o PartitionLumpImprint.o PartitionPoint.o PartitionShell.o PartitionSurface.o PartitionTool.o PartPTCurve.o PartSurfFacetTool.o PST_Data.o SegmentedCurve.o SubCurve.o SubEntitySet.o SubSurface.o TDVGFacetOwner.o TDVGFacetSplit.o VirtualQueryEngine.o VirtualImprintTool.o
ranlib .libs/libcubit_virtual.a
creating libcubit_virtual.la
(cd .libs && rm -f libcubit_virtual.la && ln -s ../libcubit_virtual.la libcubit_virtual.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
Making all in ACIS
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/ACIS'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c -o AcisBridge.lo ../../../geom/ACIS/AcisBridge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisBridge.lo -MD -MP -MF .deps/AcisBridge.Tpo -c ../../../geom/ACIS/AcisBridge.cpp -o AcisBridge.o
mv -f .deps/AcisBridge.Tpo .deps/AcisBridge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisEdgeTool.lo -MD -MP -MF .deps/AcisEdgeTool.Tpo -c -o AcisEdgeTool.lo ../../../geom/ACIS/AcisEdgeTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisEdgeTool.lo -MD -MP -MF .deps/AcisEdgeTool.Tpo -c ../../../geom/ACIS/AcisEdgeTool.cpp -o AcisEdgeTool.o
../../../geom/ACIS/AcisEdgeTool.cpp: In member function ‘CubitStatus AcisEdgeTool::create_curve_combine(DLIList<Curve*>&, Curve*&)’:
../../../geom/ACIS/AcisEdgeTool.cpp:67: warning: unused variable ‘AQE’
../../../geom/ACIS/AcisEdgeTool.cpp:68: warning: unused variable ‘GQT’
mv -f .deps/AcisEdgeTool.Tpo .deps/AcisEdgeTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisFacetManager.lo -MD -MP -MF .deps/AcisFacetManager.Tpo -c -o AcisFacetManager.lo ../../../geom/ACIS/AcisFacetManager.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisFacetManager.lo -MD -MP -MF .deps/AcisFacetManager.Tpo -c ../../../geom/ACIS/AcisFacetManager.cpp -o AcisFacetManager.o
mv -f .deps/AcisFacetManager.Tpo .deps/AcisFacetManager.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisFeatureEngine.lo -MD -MP -MF .deps/AcisFeatureEngine.Tpo -c -o AcisFeatureEngine.lo ../../../geom/ACIS/AcisFeatureEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisFeatureEngine.lo -MD -MP -MF .deps/AcisFeatureEngine.Tpo -c ../../../geom/ACIS/AcisFeatureEngine.cpp -o AcisFeatureEngine.o
mv -f .deps/AcisFeatureEngine.Tpo .deps/AcisFeatureEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisHealerTool.lo -MD -MP -MF .deps/AcisHealerTool.Tpo -c -o AcisHealerTool.lo ../../../geom/ACIS/AcisHealerTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisHealerTool.lo -MD -MP -MF .deps/AcisHealerTool.Tpo -c ../../../geom/ACIS/AcisHealerTool.cpp -o AcisHealerTool.o
mv -f .deps/AcisHealerTool.Tpo .deps/AcisHealerTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisModifyEngine.lo -MD -MP -MF .deps/AcisModifyEngine.Tpo -c -o AcisModifyEngine.lo ../../../geom/ACIS/AcisModifyEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisModifyEngine.lo -MD -MP -MF .deps/AcisModifyEngine.Tpo -c ../../../geom/ACIS/AcisModifyEngine.cpp -o AcisModifyEngine.o
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘virtual CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:7524: warning: deprecated conversion from string constant to ‘char*’
../../../geom/ACIS/AcisModifyEngine.cpp:7539: warning: deprecated conversion from string constant to ‘char*’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘virtual CubitStatus AcisModifyEngine::section(DLIList<BodySM*>&, const CubitVector&, const CubitVector&, const CubitVector&, DLIList<BodySM*>&, bool, bool, bool)’:
../../../geom/ACIS/AcisModifyEngine.cpp:9763: warning: unused variable ‘ref_entity’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘void AcisModifyEngine::webcut_imprint(BODY*, DLIList<BodySM*>&, DLIList<BODY*>&, DLIList<BODY*>&, DLIList<BodySM*>&, DLIList<BodySM*>&, DLIList<BODY*>&) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:11216: warning: unused variable ‘webcut_debug_flag_on’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘BODY* AcisModifyEngine::create_infinite_plane_cutting_tool(const CubitVector&, const CubitVector&, const CubitVector&, const SPAbox&, bool) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:11497: warning: suggest explicit braces to avoid ambiguous ‘else’
../../../geom/ACIS/AcisModifyEngine.cpp:11662: warning: suggest explicit braces to avoid ambiguous ‘else’
../../../geom/ACIS/AcisModifyEngine.cpp:11687: warning: suggest explicit braces to avoid ambiguous ‘else’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘virtual CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs(DLIList<Surface*>&, DLIList<BodySM*>&, bool, bool) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:11956: warning: unused variable ‘success’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘virtual CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*>&, DLIList<CubitVector*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:13117: warning: deprecated conversion from string constant to ‘char*’
../../../geom/ACIS/AcisModifyEngine.cpp:13124: warning: deprecated conversion from string constant to ‘char*’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘CubitStatus AcisModifyEngine::imprint_overlapping_curves(DLIList<BodySM*>&, DLIList<BodySM*>&, ProgressTool*, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:15038: warning: unused variable ‘status’
../../../geom/ACIS/AcisModifyEngine.cpp: In member function ‘CubitStatus AcisModifyEngine::imprint_overlapping_surfaces(DLIList<BodySM*>&, DLIList<BodySM*>&, ProgressTool*) const’:
../../../geom/ACIS/AcisModifyEngine.cpp:15062: warning: unused variable ‘status’
mv -f .deps/AcisModifyEngine.Tpo .deps/AcisModifyEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisQueryEngine.lo -MD -MP -MF .deps/AcisQueryEngine.Tpo -c -o AcisQueryEngine.lo ../../../geom/ACIS/AcisQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisQueryEngine.lo -MD -MP -MF .deps/AcisQueryEngine.Tpo -c ../../../geom/ACIS/AcisQueryEngine.cpp -o AcisQueryEngine.o
../../../geom/ACIS/AcisQueryEngine.cpp: In member function ‘virtual CubitStatus AcisQueryEngine::import_solid_model(const char*, const char*, DLIList<TopologyBridge*>&, CubitBoolean, const char*, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean)’:
../../../geom/ACIS/AcisQueryEngine.cpp:827: warning: unused variable ‘i’
../../../geom/ACIS/AcisQueryEngine.cpp: In member function ‘CubitStatus AcisQueryEngine::restore_entity_list(ENTITY_LIST&, DLIList<TopologyBridge*>&, bool, bool, bool, bool, bool, bool, bool, bool) const’:
../../../geom/ACIS/AcisQueryEngine.cpp:1056: warning: format ‘%p’ expects type ‘void*’, but argument 3 has type ‘BodySM*’
../../../geom/ACIS/AcisQueryEngine.cpp:986: warning: unused variable ‘percent_after’
../../../geom/ACIS/AcisQueryEngine.cpp:987: warning: unused variable ‘number_splines_simplified’
mv -f .deps/AcisQueryEngine.Tpo .deps/AcisQueryEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisSurfaceTool.lo -MD -MP -MF .deps/AcisSurfaceTool.Tpo -c -o AcisSurfaceTool.lo ../../../geom/ACIS/AcisSurfaceTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisSurfaceTool.lo -MD -MP -MF .deps/AcisSurfaceTool.Tpo -c ../../../geom/ACIS/AcisSurfaceTool.cpp -o AcisSurfaceTool.o
mv -f .deps/AcisSurfaceTool.Tpo .deps/AcisSurfaceTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisToolUtil.lo -MD -MP -MF .deps/AcisToolUtil.Tpo -c -o AcisToolUtil.lo ../../../geom/ACIS/AcisToolUtil.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisToolUtil.lo -MD -MP -MF .deps/AcisToolUtil.Tpo -c ../../../geom/ACIS/AcisToolUtil.cpp -o AcisToolUtil.o
mv -f .deps/AcisToolUtil.Tpo .deps/AcisToolUtil.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisTweakTool.lo -MD -MP -MF .deps/AcisTweakTool.Tpo -c -o AcisTweakTool.lo ../../../geom/ACIS/AcisTweakTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisTweakTool.lo -MD -MP -MF .deps/AcisTweakTool.Tpo -c ../../../geom/ACIS/AcisTweakTool.cpp -o AcisTweakTool.o
../../../geom/ACIS/AcisTweakTool.cpp:7567:3: warning: multi-line comment
../../../geom/ACIS/AcisTweakTool.cpp: In member function ‘CubitStatus AcisTweakTool::tweak_target_single(DLIList<Surface*>&, Surface*, DLIList<BodySM*>&, CubitBoolean, CubitBoolean, CubitBoolean)’:
../../../geom/ACIS/AcisTweakTool.cpp:1846: warning: unused variable ‘target_surface_ptr’
mv -f .deps/AcisTweakTool.Tpo .deps/AcisTweakTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisDrawTool.lo -MD -MP -MF .deps/AcisDrawTool.Tpo -c -o AcisDrawTool.lo ../../../geom/ACIS/AcisDrawTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT AcisDrawTool.lo -MD -MP -MF .deps/AcisDrawTool.Tpo -c ../../../geom/ACIS/AcisDrawTool.cpp -o AcisDrawTool.o
mv -f .deps/AcisDrawTool.Tpo .deps/AcisDrawTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_cubit_owner.lo -MD -MP -MF .deps/attrib_cubit_owner.Tpo -c -o attrib_cubit_owner.lo ../../../geom/ACIS/attrib_cubit_owner.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_cubit_owner.lo -MD -MP -MF .deps/attrib_cubit_owner.Tpo -c ../../../geom/ACIS/attrib_cubit_owner.cpp -o attrib_cubit_owner.o
../../../geom/ACIS/attrib_cubit_owner.cpp: In static member function ‘static void ATTRIB_CUBIT_OWNER::remove_cubit_owner(ENTITY*, CubitBoolean)’:
../../../geom/ACIS/attrib_cubit_owner.cpp:211: warning: unused variable ‘this_ENTITY’
mv -f .deps/attrib_cubit_owner.Tpo .deps/attrib_cubit_owner.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_snl.lo -MD -MP -MF .deps/attrib_snl.Tpo -c -o attrib_snl.lo ../../../geom/ACIS/attrib_snl.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_snl.lo -MD -MP -MF .deps/attrib_snl.Tpo -c ../../../geom/ACIS/attrib_snl.cpp -o attrib_snl.o
mv -f .deps/attrib_snl.Tpo .deps/attrib_snl.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_snl_simple.lo -MD -MP -MF .deps/attrib_snl_simple.Tpo -c -o attrib_snl_simple.lo ../../../geom/ACIS/attrib_snl_simple.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_snl_simple.lo -MD -MP -MF .deps/attrib_snl_simple.Tpo -c ../../../geom/ACIS/attrib_snl_simple.cpp -o attrib_snl_simple.o
mv -f .deps/attrib_snl_simple.Tpo .deps/attrib_snl_simple.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BodyACIS.lo -MD -MP -MF .deps/BodyACIS.Tpo -c -o BodyACIS.lo ../../../geom/ACIS/BodyACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT BodyACIS.lo -MD -MP -MF .deps/BodyACIS.Tpo -c ../../../geom/ACIS/BodyACIS.cpp -o BodyACIS.o
../../../geom/ACIS/BodyACIS.cpp: In member function ‘void BodyACIS::convert_entity_list(insanity_list*, DLIList<TopologyEntity*>&)’:
../../../geom/ACIS/BodyACIS.cpp:533: warning: unused variable ‘i’
mv -f .deps/BodyACIS.Tpo .deps/BodyACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdgeACIS.lo -MD -MP -MF .deps/CoEdgeACIS.Tpo -c -o CoEdgeACIS.lo ../../../geom/ACIS/CoEdgeACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CoEdgeACIS.lo -MD -MP -MF .deps/CoEdgeACIS.Tpo -c ../../../geom/ACIS/CoEdgeACIS.cpp -o CoEdgeACIS.o
mv -f .deps/CoEdgeACIS.Tpo .deps/CoEdgeACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveACIS.lo -MD -MP -MF .deps/CurveACIS.Tpo -c -o CurveACIS.lo ../../../geom/ACIS/CurveACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CurveACIS.lo -MD -MP -MF .deps/CurveACIS.Tpo -c ../../../geom/ACIS/CurveACIS.cpp -o CurveACIS.o
mv -f .deps/CurveACIS.Tpo .deps/CurveACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopACIS.lo -MD -MP -MF .deps/LoopACIS.Tpo -c -o LoopACIS.lo ../../../geom/ACIS/LoopACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LoopACIS.lo -MD -MP -MF .deps/LoopACIS.Tpo -c ../../../geom/ACIS/LoopACIS.cpp -o LoopACIS.o
mv -f .deps/LoopACIS.Tpo .deps/LoopACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LumpACIS.lo -MD -MP -MF .deps/LumpACIS.Tpo -c -o LumpACIS.lo ../../../geom/ACIS/LumpACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT LumpACIS.lo -MD -MP -MF .deps/LumpACIS.Tpo -c ../../../geom/ACIS/LumpACIS.cpp -o LumpACIS.o
mv -f .deps/LumpACIS.Tpo .deps/LumpACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointACIS.lo -MD -MP -MF .deps/PointACIS.Tpo -c -o PointACIS.lo ../../../geom/ACIS/PointACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT PointACIS.lo -MD -MP -MF .deps/PointACIS.Tpo -c ../../../geom/ACIS/PointACIS.cpp -o PointACIS.o
mv -f .deps/PointACIS.Tpo .deps/PointACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ShellACIS.lo -MD -MP -MF .deps/ShellACIS.Tpo -c -o ShellACIS.lo ../../../geom/ACIS/ShellACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT ShellACIS.lo -MD -MP -MF .deps/ShellACIS.Tpo -c ../../../geom/ACIS/ShellACIS.cpp -o ShellACIS.o
mv -f .deps/ShellACIS.Tpo .deps/ShellACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceACIS.lo -MD -MP -MF .deps/SurfaceACIS.Tpo -c -o SurfaceACIS.lo ../../../geom/ACIS/SurfaceACIS.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT SurfaceACIS.lo -MD -MP -MF .deps/SurfaceACIS.Tpo -c ../../../geom/ACIS/SurfaceACIS.cpp -o SurfaceACIS.o
../../../geom/ACIS/SurfaceACIS.cpp: In member function ‘virtual CubitPointContainment SurfaceACIS::point_containment(const CubitVector&)’:
../../../geom/ACIS/SurfaceACIS.cpp:1255: warning: enumeration value ‘point_unset_face’ not handled in switch
../../../geom/ACIS/SurfaceACIS.cpp: In member function ‘virtual CubitPointContainment SurfaceACIS::point_containment(double, double)’:
../../../geom/ACIS/SurfaceACIS.cpp:1293: warning: enumeration value ‘point_unset_face’ not handled in switch
../../../geom/ACIS/SurfaceACIS.cpp: In member function ‘virtual CubitPointContainment SurfaceACIS::point_containment(const CubitVector&, double, double)’:
../../../geom/ACIS/SurfaceACIS.cpp:1331: warning: enumeration value ‘point_unset_face’ not handled in switch
../../../geom/ACIS/SurfaceACIS.cpp: In member function ‘virtual CubitStatus SurfaceACIS::fire_ray(const CubitVector&, const CubitVector&, DLIList<double>&) const’:
../../../geom/ACIS/SurfaceACIS.cpp:1540: warning: unused variable ‘orig_hit_list’
mv -f .deps/SurfaceACIS.Tpo .deps/SurfaceACIS.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_edge_parametric_length.lo -MD -MP -MF .deps/attrib_edge_parametric_length.Tpo -c -o attrib_edge_parametric_length.lo `test -f 'gtcAttrib/src/attrib_edge_parametric_length.C' || echo '../../../geom/ACIS/'`gtcAttrib/src/attrib_edge_parametric_length.C
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_edge_parametric_length.lo -MD -MP -MF .deps/attrib_edge_parametric_length.Tpo -c ../../../geom/ACIS/gtcAttrib/src/attrib_edge_parametric_length.C -o attrib_edge_parametric_length.o
mv -f .deps/attrib_edge_parametric_length.Tpo .deps/attrib_edge_parametric_length.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_gtc.lo -MD -MP -MF .deps/attrib_gtc.Tpo -c -o attrib_gtc.lo `test -f 'gtcAttrib/src/attrib_gtc.C' || echo '../../../geom/ACIS/'`gtcAttrib/src/attrib_gtc.C
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_gtc.lo -MD -MP -MF .deps/attrib_gtc.Tpo -c ../../../geom/ACIS/gtcAttrib/src/attrib_gtc.C -o attrib_gtc.o
mv -f .deps/attrib_gtc.Tpo .deps/attrib_gtc.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_mark.lo -MD -MP -MF .deps/attrib_mark.Tpo -c -o attrib_mark.lo `test -f 'gtcAttrib/src/attrib_mark.C' || echo '../../../geom/ACIS/'`gtcAttrib/src/attrib_mark.C
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_mark.lo -MD -MP -MF .deps/attrib_mark.Tpo -c ../../../geom/ACIS/gtcAttrib/src/attrib_mark.C -o attrib_mark.o
mv -f .deps/attrib_mark.Tpo .deps/attrib_mark.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_name.lo -MD -MP -MF .deps/attrib_name.Tpo -c -o attrib_name.lo `test -f 'gtcAttrib/src/attrib_name.C' || echo '../../../geom/ACIS/'`gtcAttrib/src/attrib_name.C
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DCUBIT_ACIS_VERSION=1607 -DACIS_VERSION=1607 -Dlinux -DACIS_LOCAL_OPS -DACIS_VER=1607 -I. -I../../../geom/ACIS -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/ACIS/gtcAttrib/incl -I/opt/acis16.7//include -I../../../compat/new -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT attrib_name.lo -MD -MP -MF .deps/attrib_name.Tpo -c ../../../geom/ACIS/gtcAttrib/src/attrib_name.C -o attrib_name.o
mv -f .deps/attrib_name.Tpo .deps/attrib_name.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_ACIS.la AcisBridge.lo AcisEdgeTool.lo AcisFacetManager.lo AcisFeatureEngine.lo AcisHealerTool.lo AcisModifyEngine.lo AcisQueryEngine.lo AcisSurfaceTool.lo AcisToolUtil.lo AcisTweakTool.lo AcisDrawTool.lo attrib_cubit_owner.lo attrib_snl.lo attrib_snl_simple.lo BodyACIS.lo CoEdgeACIS.lo CurveACIS.lo LoopACIS.lo LumpACIS.lo PointACIS.lo ShellACIS.lo SurfaceACIS.lo attrib_edge_parametric_length.lo attrib_gtc.lo attrib_mark.lo attrib_name.lo -L/opt/acis16.7//bin/linux_amd_64_so -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -lm
mkdir .libs
ar cru .libs/libcubit_ACIS.a AcisBridge.o AcisEdgeTool.o AcisFacetManager.o AcisFeatureEngine.o AcisHealerTool.o AcisModifyEngine.o AcisQueryEngine.o AcisSurfaceTool.o AcisToolUtil.o AcisTweakTool.o AcisDrawTool.o attrib_cubit_owner.o attrib_snl.o attrib_snl_simple.o BodyACIS.o CoEdgeACIS.o CurveACIS.o LoopACIS.o LumpACIS.o PointACIS.o ShellACIS.o SurfaceACIS.o attrib_edge_parametric_length.o attrib_gtc.o attrib_mark.o attrib_name.o
ranlib .libs/libcubit_ACIS.a
creating libcubit_ACIS.la
(cd .libs && rm -f libcubit_ACIS.la && ln -s ../libcubit_ACIS.la libcubit_ACIS.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/ACIS'
Making all in OCC
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/OCC'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c -o OCCShapeAttributeSet.lo ../../../geom/OCC/OCCShapeAttributeSet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c ../../../geom/OCC/OCCShapeAttributeSet.cpp -o OCCShapeAttributeSet.o
mv -f .deps/OCCShapeAttributeSet.Tpo .deps/OCCShapeAttributeSet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c -o OCCAttribSet.lo ../../../geom/OCC/OCCAttribSet.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCAttribSet.lo -MD -MP -MF .deps/OCCAttribSet.Tpo -c ../../../geom/OCC/OCCAttribSet.cpp -o OCCAttribSet.o
../../../geom/OCC/OCCAttribSet.cpp: In static member function ‘static CubitStatus OCCAttribSet::get_attributes(TopoDS_Shape&, DLIList<CubitSimpleAttrib*>&)’:
../../../geom/OCC/OCCAttribSet.cpp:400: warning: unused variable ‘string’
mv -f .deps/OCCAttribSet.Tpo .deps/OCCAttribSet.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c -o OCCBody.lo ../../../geom/OCC/OCCBody.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCBody.lo -MD -MP -MF .deps/OCCBody.Tpo -c ../../../geom/OCC/OCCBody.cpp -o OCCBody.o
mv -f .deps/OCCBody.Tpo .deps/OCCBody.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c -o OCCCoEdge.lo ../../../geom/OCC/OCCCoEdge.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoEdge.lo -MD -MP -MF .deps/OCCCoEdge.Tpo -c ../../../geom/OCC/OCCCoEdge.cpp -o OCCCoEdge.o
mv -f .deps/OCCCoEdge.Tpo .deps/OCCCoEdge.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c -o OCCCoFace.lo ../../../geom/OCC/OCCCoFace.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCoFace.lo -MD -MP -MF .deps/OCCCoFace.Tpo -c ../../../geom/OCC/OCCCoFace.cpp -o OCCCoFace.o
mv -f .deps/OCCCoFace.Tpo .deps/OCCCoFace.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c -o OCCCurve.lo ../../../geom/OCC/OCCCurve.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCCurve.lo -MD -MP -MF .deps/OCCCurve.Tpo -c ../../../geom/OCC/OCCCurve.cpp -o OCCCurve.o
../../../geom/OCC/OCCCurve.cpp: In member function ‘void OCCCurve::adjust_periodic_parameter(double&)’:
../../../geom/OCC/OCCCurve.cpp:872: warning: unused variable ‘edge_range’
mv -f .deps/OCCCurve.Tpo .deps/OCCCurve.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c -o OCCLoop.lo ../../../geom/OCC/OCCLoop.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLoop.lo -MD -MP -MF .deps/OCCLoop.Tpo -c ../../../geom/OCC/OCCLoop.cpp -o OCCLoop.o
../../../geom/OCC/OCCLoop.cpp: In member function ‘void OCCLoop::disconnect_all_curves()’:
../../../geom/OCC/OCCLoop.cpp:91: warning: unused variable ‘coedge’
mv -f .deps/OCCLoop.Tpo .deps/OCCLoop.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c -o OCCLump.lo ../../../geom/OCC/OCCLump.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCLump.lo -MD -MP -MF .deps/OCCLump.Tpo -c ../../../geom/OCC/OCCLump.cpp -o OCCLump.o
mv -f .deps/OCCLump.Tpo .deps/OCCLump.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo ../../../geom/OCC/OCCModifyEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c ../../../geom/OCC/OCCModifyEngine.cpp -o OCCModifyEngine.o
../../../geom/OCC/OCCModifyEngine.cpp: In member function ‘CubitStatus OCCModifyEngine::sort_curves(DLIList<Curve*>, DLIList<DLIList<TopoDS_Edge*>*>&) const’:
../../../geom/OCC/OCCModifyEngine.cpp:799: warning: ‘new_end’ may be used uninitialized in this function
../../../geom/OCC/OCCModifyEngine.cpp: In member function ‘virtual CubitStatus OCCModifyEngine::sweep_translational(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, const CubitVector&, double, int, bool, bool, Surface*, BodySM*) const’:
../../../geom/OCC/OCCModifyEngine.cpp:3895: warning: ‘Cornertype’ may be used uninitialized in this function
../../../geom/OCC/OCCModifyEngine.cpp: In member function ‘virtual CubitStatus OCCModifyEngine::sweep_along_curve(DLIList<GeometryEntity*>&, DLIList<BodySM*>&, DLIList<Curve*>&, double, int, bool, Surface*, BodySM*) const’:
../../../geom/OCC/OCCModifyEngine.cpp:4343: warning: ‘type’ may be used uninitialized in this function
mv -f .deps/OCCModifyEngine.Tpo .deps/OCCModifyEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCParamTool.lo -MD -MP -MF .deps/OCCParamTool.Tpo -c -o OCCParamTool.lo ../../../geom/OCC/OCCParamTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCParamTool.lo -MD -MP -MF .deps/OCCParamTool.Tpo -c ../../../geom/OCC/OCCParamTool.cpp -o OCCParamTool.o
../../../geom/OCC/OCCParamTool.cpp: In member function ‘virtual CubitStatus OCCParamTool::transform_to_uv(CubitVector&, CubitVector&)’:
../../../geom/OCC/OCCParamTool.cpp:206: warning: ‘fetool’ is used uninitialized in this function
../../../geom/Cholla/CubitFacet.hpp: In member function ‘CubitStatus OCCParamTool::locate_point_in_uv(OCCSurface*, CubitVector&, CubitFacet*&)’:
../../../geom/Cholla/CubitFacet.hpp:273: warning: ‘tool_id’ may be used uninitialized in this function
../../../geom/OCC/OCCParamTool.cpp:335: note: ‘tool_id’ was declared here
mv -f .deps/OCCParamTool.Tpo .deps/OCCParamTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c -o OCCPoint.lo ../../../geom/OCC/OCCPoint.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCPoint.lo -MD -MP -MF .deps/OCCPoint.Tpo -c ../../../geom/OCC/OCCPoint.cpp -o OCCPoint.o
mv -f .deps/OCCPoint.Tpo .deps/OCCPoint.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c -o OCCQueryEngine.lo ../../../geom/OCC/OCCQueryEngine.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c ../../../geom/OCC/OCCQueryEngine.cpp -o OCCQueryEngine.o
mv -f .deps/OCCQueryEngine.Tpo .deps/OCCQueryEngine.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShell.lo -MD -MP -MF .deps/OCCShell.Tpo -c -o OCCShell.lo ../../../geom/OCC/OCCShell.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCShell.lo -MD -MP -MF .deps/OCCShell.Tpo -c ../../../geom/OCC/OCCShell.cpp -o OCCShell.o
mv -f .deps/OCCShell.Tpo .deps/OCCShell.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCSurface.lo -MD -MP -MF .deps/OCCSurface.Tpo -c -o OCCSurface.lo ../../../geom/OCC/OCCSurface.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCSurface.lo -MD -MP -MF .deps/OCCSurface.Tpo -c ../../../geom/OCC/OCCSurface.cpp -o OCCSurface.o
mv -f .deps/OCCSurface.Tpo .deps/OCCSurface.Plo
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c -o OCCDrawTool.lo ../../../geom/OCC/OCCDrawTool.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c ../../../geom/OCC/OCCDrawTool.cpp -o OCCDrawTool.o
mv -f .deps/OCCDrawTool.Tpo .deps/OCCDrawTool.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcubit_OCC.la OCCShapeAttributeSet.lo OCCAttribSet.lo OCCBody.lo OCCCoEdge.lo OCCCoFace.lo OCCCurve.lo OCCLoop.lo OCCLump.lo OCCModifyEngine.lo OCCParamTool.lo OCCPoint.lo OCCQueryEngine.lo OCCShell.lo OCCSurface.lo OCCDrawTool.lo -L/opt/occ6.3-64/lib -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl -lm
mkdir .libs
ar cru .libs/libcubit_OCC.a OCCShapeAttributeSet.o OCCAttribSet.o OCCBody.o OCCCoEdge.o OCCCoFace.o OCCCurve.o OCCLoop.o OCCLump.o OCCModifyEngine.o OCCParamTool.o OCCPoint.o OCCQueryEngine.o OCCShell.o OCCSurface.o OCCDrawTool.o
ranlib .libs/libcubit_OCC.a
creating libcubit_OCC.la
(cd .libs && rm -f libcubit_OCC.la && ln -s ../libcubit_OCC.la libcubit_OCC.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/OCC'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in init
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../init -I.. -I../itaps -I../../geom -I../../util -I../../geom/ACIS -I../../geom/OCC -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c -o InitCGMA.lo ../../init/InitCGMA.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../init -I.. -I../itaps -I../../geom -I../../util -I../../geom/ACIS -I../../geom/OCC -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c ../../init/InitCGMA.cpp -o InitCGMA.o
mv -f .deps/InitCGMA.Tpo .deps/InitCGMA.Plo
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libcgma_init.la InitCGMA.lo -lm
mkdir .libs
ar cru .libs/libcgma_init.a InitCGMA.o
ranlib .libs/libcgma_init.a
creating libcgma_init.la
(cd .libs && rm -f libcgma_init.la && ln -s ../libcgma_init.la libcgma_init.la)
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
Making all in .
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
/bin/sh ./libtool --tag=CC --mode=link cc -Wall -pipe -pedantic -O2 -DNDEBUG -o libcgm.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib init/libcgma_init.la geom/ACIS/libcubit_ACIS.la geom/OCC/libcubit_OCC.la geom/virtual/libcubit_virtual.la geom/facet/libcubit_facet.la geom/Cholla/libcholla.la geom/facetbool/libcubit_facetbool.la geom/libcubit_geom.la util/libcubit_util.la -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl no -lm
rm -fr .libs/libcgm.lax
mkdir .libs/libcgm.lax
rm -fr .libs/libcgm.lax/libcgma_init.a
mkdir .libs/libcgm.lax/libcgma_init.a
(cd .libs/libcgm.lax/libcgma_init.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/init/.libs/libcgma_init.a)
rm -fr .libs/libcgm.lax/libcubit_ACIS.a
mkdir .libs/libcgm.lax/libcubit_ACIS.a
(cd .libs/libcgm.lax/libcubit_ACIS.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/ACIS/.libs/libcubit_ACIS.a)
rm -fr .libs/libcgm.lax/libcubit_OCC.a
mkdir .libs/libcgm.lax/libcubit_OCC.a
(cd .libs/libcgm.lax/libcubit_OCC.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/OCC/.libs/libcubit_OCC.a)
rm -fr .libs/libcgm.lax/libcubit_virtual.a
mkdir .libs/libcgm.lax/libcubit_virtual.a
(cd .libs/libcgm.lax/libcubit_virtual.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual/.libs/libcubit_virtual.a)
rm -fr .libs/libcgm.lax/libcubit_facet.a
mkdir .libs/libcgm.lax/libcubit_facet.a
(cd .libs/libcgm.lax/libcubit_facet.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet/.libs/libcubit_facet.a)
rm -fr .libs/libcgm.lax/libcholla.a
mkdir .libs/libcgm.lax/libcholla.a
(cd .libs/libcgm.lax/libcholla.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla/.libs/libcholla.a)
rm -fr .libs/libcgm.lax/libcubit_facetbool.a
mkdir .libs/libcgm.lax/libcubit_facetbool.a
(cd .libs/libcgm.lax/libcubit_facetbool.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool/.libs/libcubit_facetbool.a)
rm -fr .libs/libcgm.lax/libcubit_geom.a
mkdir .libs/libcgm.lax/libcubit_geom.a
(cd .libs/libcgm.lax/libcubit_geom.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/.libs/libcubit_geom.a)
rm -fr .libs/libcgm.lax/libcubit_util.a
mkdir .libs/libcgm.lax/libcubit_util.a
(cd .libs/libcgm.lax/libcubit_util.a && ar x /home/jason/cgm/test/dist/CGMA-10.2.2/_build/util/.libs/libcubit_util.a)
ar cru .libs/libcgm.a .libs/libcgm.lax/libcgma_init.a/InitCGMA.o .libs/libcgm.lax/libcubit_ACIS.a/AcisModifyEngine.o .libs/libcgm.lax/libcubit_ACIS.a/AcisQueryEngine.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_name.o .libs/libcgm.lax/libcubit_ACIS.a/AcisBridge.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_gtc.o .libs/libcgm.lax/libcubit_ACIS.a/BodyACIS.o .libs/libcgm.lax/libcubit_ACIS.a/AcisFeatureEngine.o .libs/libcgm.lax/libcubit_ACIS.a/SurfaceACIS.o .libs/libcgm.lax/libcubit_ACIS.a/AcisDrawTool.o .libs/libcgm.lax/libcubit_ACIS.a/AcisTweakTool.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_snl.o .libs/libcgm.lax/libcubit_ACIS.a/AcisHealerTool.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_edge_parametric_length.o .libs/libcgm.lax/libcubit_ACIS.a/LumpACIS.o .libs/libcgm.lax/libcubit_ACIS.a/AcisToolUtil.o .libs/libcgm.lax/libcubit_ACIS.a/ShellACIS.o .libs/libcgm.lax/libcubit_ACIS.a/LoopACIS.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_cubit_owner.o .libs/libcgm.lax/libcubit_ACIS.a/CoEdgeACI!
S.o .libs/libcgm.lax/libcubit_ACIS.a/AcisSurfaceTool.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_mark.o .libs/libcgm.lax/libcubit_ACIS.a/AcisEdgeTool.o .libs/libcgm.lax/libcubit_ACIS.a/CurveACIS.o .libs/libcgm.lax/libcubit_ACIS.a/attrib_snl_simple.o .libs/libcgm.lax/libcubit_ACIS.a/AcisFacetManager.o .libs/libcgm.lax/libcubit_ACIS.a/PointACIS.o .libs/libcgm.lax/libcubit_OCC.a/OCCBody.o .libs/libcgm.lax/libcubit_OCC.a/OCCLump.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoFace.o .libs/libcgm.lax/libcubit_OCC.a/OCCCurve.o .libs/libcgm.lax/libcubit_OCC.a/OCCQueryEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCDrawTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCAttribSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCShell.o .libs/libcgm.lax/libcubit_OCC.a/OCCModifyEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoEdge.o .libs/libcgm.lax/libcubit_OCC.a/OCCParamTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCPoint.o .libs/libcgm.lax/libcubit_OCC.a/OCCShapeAttributeSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCSurface.o .l!
ibs/libcgm.lax/libcubit_OCC.a/OCCLoop.o .libs/libcgm.lax/libcubit_vir
tual.a/ImprintBoundaryTool.o .libs/libcgm.lax/libcubit_virtual.a/SegmentedCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLump.o .libs/libcgm.lax/libcubit_virtual.a/VirtualImprintTool.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionPoint.o .libs/libcgm.lax/libcubit_virtual.a/CompositeGeom.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLumpImprint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCurve.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLoop.o .libs/libcgm.lax/libcubit_virtual.a/VirtualQueryEngine.o .libs/libcgm.lax/libcubit_virtual.a/CAPartitionVG.o .libs/libcgm.lax/libcubit_virtual.a/PartSurfFacetTool.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetSplit.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLump.o .libs/libcgm.lax/libcubit_virtual.a/PartitionBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeTool.o .libs/libcgm.lax/libcubit_virtual.a/FaceterPoin!
tData.o .libs/libcgm.lax/libcubit_virtual.a/FaceterFacetData.o .libs/libcgm.lax/libcubit_virtual.a/Faceter.o .libs/libcgm.lax/libcubit_virtual.a/CollapseAngleTool.o .libs/libcgm.lax/libcubit_virtual.a/HiddenEntitySet.o .libs/libcgm.lax/libcubit_virtual.a/CAVirtualVG.o .libs/libcgm.lax/libcubit_virtual.a/SubCurve.o .libs/libcgm.lax/libcubit_virtual.a/PST_Data.o .libs/libcgm.lax/libcubit_virtual.a/PartitionTool.o .libs/libcgm.lax/libcubit_virtual.a/ImprintPointData.o .libs/libcgm.lax/libcubit_virtual.a/SubSurface.o .libs/libcgm.lax/libcubit_virtual.a/CACompositeVG.o .libs/libcgm.lax/libcubit_virtual.a/SubEntitySet.o .libs/libcgm.lax/libcubit_virtual.a/FacetProjectTool.o .libs/libcgm.lax/libcubit_virtual.a/CompositeEngine.o .libs/libcgm.lax/libcubit_virtual.a/PartPTCurve.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetOwner.o .libs/libcgm.lax/libcubit_virtual.a/ImprintLineSegment.o .libs/libcgm.lax/libcubit_virtual.a/AllocMemManagersVirtual.o .libs/libcgm.lax/libcubit_virtual.a!
/CompositeAttrib.o .libs/libcgm.lax/libcubit_virtual.a/CompSurfFacets.
o .libs/libcgm.lax/libcubit_virtual.a/CompositeBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionShell.o .libs/libcgm.lax/libcubit_virtual.a/CompositeSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositePoint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeShell.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEntity.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLoop.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEngine.o .libs/libcgm.lax/libcubit_facet.a/FacetAttribSet.o .libs/libcgm.lax/libcubit_facet.a/GridSearchTree.o .libs/libcgm.lax/libcubit_facet.a/FacetLoop.o .libs/libcgm.lax/libcubit_facet.a/FacetLump.o .libs/libcgm.lax/libcubit_facet.a/FacetParamTool.o .libs/libcgm.lax/libcubit_facet.a/FacetCoEdge.o .libs/libcgm.lax/libcubit_facet.a/FacetSurface.o .l!
ibs/libcgm.lax/libcubit_facet.a/FacetCurve.o .libs/libcgm.lax/libcubit_facet.a/FacetShell.o .libs/libcgm.lax/libcubit_facet.a/FacetBody.o .libs/libcgm.lax/libcubit_facet.a/FacetboolInterface.o .libs/libcgm.lax/libcubit_facet.a/FacetModifyEngine.o .libs/libcgm.lax/libcubit_facet.a/FacetPoint.o .libs/libcgm.lax/libcubit_facet.a/FacetAttrib.o .libs/libcgm.lax/libcubit_facet.a/FacetQueryEngine.o .libs/libcgm.lax/libcholla.a/TDChordal.o .libs/libcgm.lax/libcholla.a/CubitPoint.o .libs/libcgm.lax/libcholla.a/ChollaPoint.o .libs/libcgm.lax/libcholla.a/FacetEvalTool.o .libs/libcgm.lax/libcholla.a/CubitQuadFacet.o .libs/libcgm.lax/libcholla.a/PointGridSearch.o .libs/libcgm.lax/libcholla.a/FacetEntity.o .libs/libcgm.lax/libcholla.a/Cholla.o .libs/libcgm.lax/libcholla.a/GeoNode.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryEdge.o .libs/libcgm.lax/libcholla.a/ChordalAxis.o .libs/libcgm.lax/libcholla.a/PointLoopFacetor.o .libs/libcgm.lax/libcholla.a/ChollaEngine.o .libs/libcgm.lax/libch!
olla.a/debug.o .libs/libcgm.lax/libcholla.a/ChollaSkinTool.o .libs/lib
cgm.lax/libcholla.a/ChollaEntity.o .libs/libcgm.lax/libcholla.a/LoopParamTool.o .libs/libcgm.lax/libcholla.a/CubitFacetData.o .libs/libcgm.lax/libcholla.a/GeoTet.o .libs/libcgm.lax/libcholla.a/AllocMemManagersCholla.o .libs/libcgm.lax/libcholla.a/CubitFacetEdge.o .libs/libcgm.lax/libcholla.a/CubitFacet.o .libs/libcgm.lax/libcholla.a/CurveFacetEvalTool.o .libs/libcgm.lax/libcholla.a/FacetDataUtil.o .libs/libcgm.lax/libcholla.a/CubitFacetEdgeData.o .libs/libcgm.lax/libcholla.a/TDGeomFacet.o .libs/libcgm.lax/libcholla.a/CubitPointData.o .libs/libcgm.lax/libcholla.a/ChollaSurface.o .libs/libcgm.lax/libcholla.a/CubitQuadFacetData.o .libs/libcgm.lax/libcholla.a/TDFacetboolData.o .libs/libcgm.lax/libcholla.a/ChollaCurve.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryPoint.o .libs/libcgm.lax/libcubit_facetbool.a/FBRetriangulate.o .libs/libcgm.lax/libcubit_facetbool.a/FBDataUtil.o .libs/libcgm.lax/libcubit_facetbool.a/FBIntersect.o .libs/libcgm.lax/libcubit_facetbool.a/KdTree.o .libs!
/libcgm.lax/libcubit_facetbool.a/FBImprint.o .libs/libcgm.lax/libcubit_facetbool.a/FBTiler.o .libs/libcgm.lax/libcubit_facetbool.a/IntegerHash.o .libs/libcgm.lax/libcubit_facetbool.a/FBClassify.o .libs/libcgm.lax/libcubit_facetbool.a/FBPolyhedron.o .libs/libcgm.lax/libcubit_geom.a/CoVolume.o .libs/libcgm.lax/libcubit_geom.a/RefGroup.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureEngine.o .libs/libcgm.lax/libcubit_geom.a/AllocMemManagersGeom.o .libs/libcgm.lax/libcubit_geom.a/OffsetSplitTool.o .libs/libcgm.lax/libcubit_geom.a/RefVertex.o .libs/libcgm.lax/libcubit_geom.a/CubitPolygon.o .libs/libcgm.lax/libcubit_geom.a/CAEntityColor.o .libs/libcgm.lax/libcubit_geom.a/TDSplitSurface.o .libs/libcgm.lax/libcubit_geom.a/GeomDataObserver.o .libs/libcgm.lax/libcubit_geom.a/SurfaceSM.o .libs/libcgm.lax/libcubit_geom.a/BridgeManager.o .libs/libcgm.lax/libcubit_geom.a/CoFace.o .libs/libcgm.lax/libcubit_geom.a/CAEntityName.o .libs/libcgm.lax/libcubit_geom.a/CAActuateSet.o .libs/libc!
gm.lax/libcubit_geom.a/GeometryHealerEngine.o .libs/libcgm.lax/libcubi
t_geom.a/GeomMeasureTool.o .libs/libcgm.lax/libcubit_geom.a/CAMergePartner.o .libs/libcgm.lax/libcubit_geom.a/GeometryUtil.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryEngine.o .libs/libcgm.lax/libcubit_geom.a/CGMEngineDynamicLoader.o .libs/libcgm.lax/libcubit_geom.a/PointSM.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribUser.o .libs/libcgm.lax/libcubit_geom.a/RefFace.o .libs/libcgm.lax/libcubit_geom.a/CAMergeStatus.o .libs/libcgm.lax/libcubit_geom.a/TDSurfaceOverlap.o .libs/libcgm.lax/libcubit_geom.a/Lump.o .libs/libcgm.lax/libcubit_geom.a/MedialTool2D.o .libs/libcgm.lax/libcubit_geom.a/RefEntityName.o .libs/libcgm.lax/libcubit_geom.a/GSaveOpen.o .libs/libcgm.lax/libcubit_geom.a/CAUniqueId.o .libs/libcgm.lax/libcubit_geom.a/TopologyBridge.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribManager.o .libs/libcgm.lax/libcubit_geom.a/TDUniqueId.o .libs/libcgm.lax/libcubit_geom.a/CurveOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureTool.o .libs/libcgm.lax/libcubit_g!
eom.a/CADeferredAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoVertex.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryTool.o .libs/libcgm.lax/libcubit_geom.a/RefEntity.o .libs/libcgm.lax/libcubit_geom.a/SphereEvaluator.o .libs/libcgm.lax/libcubit_geom.a/Shell.o .libs/libcgm.lax/libcubit_geom.a/LumpSM.o .libs/libcgm.lax/libcubit_geom.a/BoundingBoxTool.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapTool.o .libs/libcgm.lax/libcubit_geom.a/CAEntityId.o .libs/libcgm.lax/libcubit_geom.a/Curve.o .libs/libcgm.lax/libcubit_geom.a/Point.o .libs/libcgm.lax/libcubit_geom.a/SplitSurfaceTool.o .libs/libcgm.lax/libcubit_geom.a/RefVolume.o .libs/libcgm.lax/libcubit_geom.a/Loop.o .libs/libcgm.lax/libcubit_geom.a/RefEdge.o .libs/libcgm.lax/libcubit_geom.a/TDCAGE.o .libs/libcgm.lax/libcubit_geom.a/MedialTool3D.o .libs/libcgm.lax/libcubit_geom.a/TDSourceFeature.o .libs/libcgm.lax/libcubit_geom.a/CubitSimpleAttrib.o .libs/libcgm.lax/libcubit_geom.a/CAGroup.o .libs/libcgm.lax/libcubit_geom.a/Merg!
eToolAssistant.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyEngine
.o .libs/libcgm.lax/libcubit_geom.a/GeometryEntity.o .libs/libcgm.lax/libcubit_geom.a/ModelQueryEngine.o .libs/libcgm.lax/libcubit_geom.a/AnalyticGeometryTool.o .libs/libcgm.lax/libcubit_geom.a/GfxPreview.o .libs/libcgm.lax/libcubit_geom.a/DAG.o .libs/libcgm.lax/libcubit_geom.a/RefCollection.o .libs/libcgm.lax/libcubit_geom.a/RefEntityFactory.o .libs/libcgm.lax/libcubit_geom.a/CASourceFeature.o .libs/libcgm.lax/libcubit_geom.a/SurfParamTool.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyTool.o .libs/libcgm.lax/libcubit_geom.a/LoopSM.o .libs/libcgm.lax/libcubit_geom.a/ModelEntity.o .libs/libcgm.lax/libcubit_geom.a/Surface.o .libs/libcgm.lax/libcubit_geom.a/SenseEntity.o .libs/libcgm.lax/libcubit_geom.a/CylinderEvaluator.o .libs/libcgm.lax/libcubit_geom.a/GroupingEntity.o .libs/libcgm.lax/libcubit_geom.a/BodySM.o .libs/libcgm.lax/libcubit_geom.a/CurveSM.o .libs/libcgm.lax/libcubit_geom.a/CoEdge.o .libs/libcgm.lax/libcubit_geom.a/MergeTool.o .libs/libcgm.lax/libcubit_geom.a/C!
GMApp.o .libs/libcgm.lax/libcubit_geom.a/CubitAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoEdgeSM.o .libs/libcgm.lax/libcubit_geom.a/TopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/MidPlaneTool.o .libs/libcgm.lax/libcubit_geom.a/OldUnmergeCode.o .libs/libcgm.lax/libcubit_geom.a/Chain.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryHealerTool.o .libs/libcgm.lax/libcubit_geom.a/Body.o .libs/libcgm.lax/libcubit_geom.a/DagDrawingTool.o .libs/libcgm.lax/libcubit_geom.a/BasicTopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/CollectionEntity.o .libs/libcgm.lax/libcubit_geom.a/ShellSM.o .libs/libcgm.lax/libcubit_util.a/GMem.o .libs/libcgm.lax/libcubit_util.a/CubitCoordinateSystem.o .libs/libcgm.lax/libcubit_util.a/GfxDebug.o .libs/libcgm.lax/libcubit_util.a/CubitString.o .libs/libcgm.lax/libcubit_util.a/StubProgressTool.o .libs/libcgm.lax/libcubit_util.a/TextProgressTool.o .libs/libcgm.lax/libcubit_util.a/TDUPtr.o .libs/libcgm.lax!
/libcubit_util.a/CubitStack.o .libs/libcgm.lax/libcubit_util.a/CubitMe
ssage.o .libs/libcgm.lax/libcubit_util.a/CubitFileIOWrapper.o .libs/libcgm.lax/libcubit_util.a/CubitFileUtil.o .libs/libcgm.lax/libcubit_util.a/CubitEntity.o .libs/libcgm.lax/libcubit_util.a/CubitVector.o .libs/libcgm.lax/libcubit_util.a/IntersectionTool.o .libs/libcgm.lax/libcubit_util.a/MemoryBlock.o .libs/libcgm.lax/libcubit_util.a/Queue.o .libs/libcgm.lax/libcubit_util.a/SettingHolder.o .libs/libcgm.lax/libcubit_util.a/Cubit2DPoint.o .libs/libcgm.lax/libcubit_util.a/CubitCollection.o .libs/libcgm.lax/libcubit_util.a/PlanarParamTool.o .libs/libcgm.lax/libcubit_util.a/ArrayBasedContainer.o .libs/libcgm.lax/libcubit_util.a/GetLongOpt.o .libs/libcgm.lax/libcubit_util.a/CubitFileFEModel.o .libs/libcgm.lax/libcubit_util.a/AllocMemManagersList.o .libs/libcgm.lax/libcubit_util.a/CubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitDynamicLoader.o .libs/libcgm.lax/libcubit_util.a/TtyProgressTool.o .libs/libcgm.lax/libcubit_util.a/CubitObservable.o .libs/libcgm.lax/libcubit_util.a/D!
IntArray.o .libs/libcgm.lax/libcubit_util.a/DynamicArray.o .libs/libcgm.lax/libcubit_util.a/ToolData.o .libs/libcgm.lax/libcubit_util.a/ToolDataUser.o .libs/libcgm.lax/libcubit_util.a/RandomMersenne.o .libs/libcgm.lax/libcubit_util.a/SDLList.o .libs/libcgm.lax/libcubit_util.a/CubitBox.o .libs/libcgm.lax/libcubit_util.a/CubitTransformMatrix.o .libs/libcgm.lax/libcubit_util.a/ParamCubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitFileMetaData.o .libs/libcgm.lax/libcubit_util.a/DLList.o .libs/libcgm.lax/libcubit_util.a/CubitFile.o .libs/libcgm.lax/libcubit_util.a/CubitMatrix.o .libs/libcgm.lax/libcubit_util.a/CubitObserver.o .libs/libcgm.lax/libcubit_util.a/CubitContainer.o .libs/libcgm.lax/libcubit_util.a/Tree.o .libs/libcgm.lax/libcubit_util.a/AppUtil.o .libs/libcgm.lax/libcubit_util.a/CpuTimer.o .libs/libcgm.lax/libcubit_util.a/MemoryManager.o .libs/libcgm.lax/libcubit_util.a/CubitUtil.o .libs/libcgm.lax/libcubit_util.a/SettingHandler.o
ranlib .libs/libcgm.a
creating libcgm.la
(cd .libs && rm -f libcgm.la && ln -s ../libcgm.la libcgm.la)
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
Making all in itaps
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make all-recursive
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making all in .
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c -o CATag.lo ../../itaps/CATag.cpp
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c ../../itaps/CATag.cpp -o CATag.o
mv -f .deps/CATag.Tpo .deps/CATag.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c -o iGeom_CGMA.lo ../../itaps/iGeom_CGMA.cc
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c ../../itaps/iGeom_CGMA.cc -o iGeom_CGMA.o
mv -f .deps/iGeom_CGMA.Tpo .deps/iGeom_CGMA.Plo
/bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c -o iGeomError.lo ../../itaps/iGeomError.cc
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c ../../itaps/iGeomError.cc -o iGeomError.o
mv -f .deps/iGeomError.Tpo .deps/iGeomError.Plo
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o libiGeom.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib CATag.lo iGeom_CGMA.lo iGeomError.lo ../libcgm.la -lm
mkdir .libs
ar cru .libs/libiGeom.a CATag.o iGeom_CGMA.o iGeomError.o
ranlib .libs/libiGeom.a
creating libiGeom.la
(cd .libs && rm -f libiGeom.la && ln -s ../libiGeom.la libiGeom.la)
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making all in test
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
Making all in cgm_apps
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
Making all in examples
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
Making all in driverc++
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/driverc++'
make[5]: Nothing to be done for `all'.
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/driverc++'
Making all in facetdriver
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[5]: Nothing to be done for `all-am'.
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[1]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[1]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
Making dvi in compat
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/compat'
make[2]: Nothing to be done for `dvi'.
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/compat'
Making dvi in util
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
Making dvi in geom
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making dvi in .
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
make[3]: Nothing to be done for `dvi-am'.
Making dvi in Cholla
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
make[3]: Nothing to be done for `dvi'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
Making dvi in facetbool
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
Making dvi in facet
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
Making dvi in virtual
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
Making dvi in ACIS
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/ACIS'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/ACIS'
Making dvi in OCC
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/OCC'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making dvi in init
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
Making dvi in .
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[2]: Nothing to be done for `dvi-am'.
Making dvi in itaps
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making dvi in .
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making dvi in test
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
Making dvi in cgm_apps
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
Making dvi in examples
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
Making dvi in driverc++
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/driverc++'
make[4]: Nothing to be done for `dvi'.
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/driverc++'
Making dvi in facetdriver
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[4]: Nothing to be done for `dvi-am'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
Making check in compat
make[2]: Nothing to be done for `check'.
Making check in util
Making check in geom
Making check in .
make[3]: Nothing to be done for `check-am'.
Making check in Cholla
make[3]: Nothing to be done for `check'.
Making check in facetbool
Making check in virtual
Making check in ACIS
Making check in OCC
Making check in init
Making check in .
make[2]: Nothing to be done for `check-am'.
Making check in itaps
Making check in .
make testgeom testgeom_occ
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -DSRCDIR=../../itaps -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom-testgeom.o -MD -MP -MF .deps/testgeom-testgeom.Tpo -c -o testgeom-testgeom.o `test -f 'testgeom.cc' || echo '../../itaps/'`testgeom.cc
mv -f .deps/testgeom-testgeom.Tpo .deps/testgeom-testgeom.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -R/opt/acis16.7//bin/linux_amd_64_so -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -o testgeom testgeom-testgeom.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o testgeom testgeom-testgeom.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ./.libs/libiGeom.a /home/jason/cgm/test/dist/CGMA-10.2.2/_build/.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt!
/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/acis16.7//bin/linux_amd_64_so
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry(char const*, int*)':
iGeom_CGMA.cc:(.text+0xa1c3): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7//bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -DHAVE_OCC -I. -I../../itaps -I.. -I../../util -I../../geom -I../../init -I. -isystem /opt/acis16.7//include -DSRCDIR=../../itaps -DFORCE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo '../../itaps/'`testgeom.cc
mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -R/opt/acis16.7//bin/linux_amd_64_so -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -o testgeom_occ testgeom_occ-testgeom.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o testgeom_occ testgeom_occ-testgeom.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ./.libs/libiGeom.a /home/jason/cgm/test/dist/CGMA-10.2.2/_build/.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF!
.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /opt/OpenCascade6.3//lib/libTKBRep.so /opt/OpenCascade6.3//lib/libTKGeomBase.so /opt/OpenCascade6.3//lib/libTKG3d.so /opt/OpenCascade6.3//lib/libTKG2d.so /opt/OpenCascade6.3//lib/libTKMath.so /opt/OpenCascade6.3//lib/libTKernel.so -lpthread -ldl -lm -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/OpenCascade6.3//lib -Wl,--rpath -Wl,/opt/acis16.7//bin/linux_amd_64_so
make check-TESTS
Using default input file: ../../itaps/testgeom.sat
Geometry engine set to: ACIS Version 16.0.7.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Model contents:
vertices: 36
edges: 60
faces: 33
regions: 1
Success
tags: Tags defined on model: GLOBAL_ID, NAME
Success
gentity sets: Success
topology adjacencies: Success
construct: Created swept volume 3
Success
primitives: Success
transforms: Success
booleans: Updated volume(s): 10
Destroyed volume(s): 11
Updated volume(s): 12
Destroyed volume(s): 13
Success
shutdown: Success
TSTT TEST SUMMARY:
Number Tests: 9
Number Successful: 9
Number Not Implemented: 0
Number Failed: 0
PASS: testgeom
Using default input file: ../../itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
gLoad:
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
Success
construct: Created swept volume 4
Success
primitives: Success
transforms: Success
booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
Success
shutdown: Success
TSTT TEST SUMMARY:
Number Tests: 9
Number Failed: 0
PASS: testgeom_occ
All 2 tests passed
Making check in test
make sheet webcut hollow_acis modify makept r_w test_occ
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT sheet.o -MD -MP -MF .deps/sheet.Tpo -c -o sheet.o ../../test/sheet.cpp
mv -f .deps/sheet.Tpo .deps/sheet.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o sheet sheet.o ../libcgm.la -lm
mkdir .libs
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o sheet sheet.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT webcut.o -MD -MP -MF .deps/webcut.Tpo -c -o webcut.o ../../test/webcut.cpp
mv -f .deps/webcut.Tpo .deps/webcut.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o webcut webcut.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o webcut webcut.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlg!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT hollow_acis.o -MD -MP -MF .deps/hollow_acis.Tpo -c -o hollow_acis.o ../../test/hollow_acis.cpp
mv -f .deps/hollow_acis.Tpo .deps/hollow_acis.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o hollow_acis hollow_acis.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o hollow_acis hollow_acis.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/li!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT modify.o -MD -MP -MF .deps/modify.Tpo -c -o modify.o ../../test/modify.cpp
../../test/modify.cpp: In function ‘CubitStatus make_Point()’:
../../test/modify.cpp:878: warning: unused variable ‘vt3’
mv -f .deps/modify.Tpo .deps/modify.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o modify modify.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o modify modify.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlg!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT makept.o -MD -MP -MF .deps/makept.Tpo -c -o makept.o ../../test/makept.cpp
../../test/makept.cpp: In function ‘CubitStatus make_Point()’:
../../test/makept.cpp:289: warning: unused variable ‘d’
../../test/makept.cpp:206: warning: unused variable ‘is_equal’
../../test/makept.cpp:294: warning: unused variable ‘new_face2’
../../test/makept.cpp:335: warning: unused variable ‘area’
../../test/makept.cpp:374: warning: unused variable ‘pc2’
../../test/makept.cpp:378: warning: unused variable ‘num_loops’
../../test/makept.cpp:383: warning: unused variable ‘angle’
mv -f .deps/makept.Tpo .deps/makept.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o makept makept.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o makept makept.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlg!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT r_w.o -MD -MP -MF .deps/r_w.Tpo -c -o r_w.o ../../test/r_w.cpp
../../test/r_w.cpp: In function ‘CubitStatus make_Point()’:
../../test/r_w.cpp:177: warning: unused variable ‘d’
../../test/r_w.cpp:179: warning: unused variable ‘n’
mv -f .deps/r_w.Tpo .deps/r_w.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o r_w r_w.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o r_w r_w.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeomAlgo.so /!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS -DHAVE_OCC -I. -I../../test -I.. -I../itaps -I../../geom -I../../util -I../../init -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/Cholla -I../../geom/OCC -I../../test -I/opt/occ6.3-64/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../test -DHAVE_ACIS -DHAVE_OCC -isystem /opt/acis16.7//include -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_occ.o -MD -MP -MF .deps/test_occ.Tpo -c -o test_occ.o ../../test/test_occ.cpp
mv -f .deps/test_occ.Tpo .deps/test_occ.Po
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib -R/opt/acis16.7//bin/linux_amd_64_so -o test_occ test_occ.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -O2 -DNDEBUG -o test_occ test_occ.o -L/opt/acis16.7//bin/linux_amd_64_so -L/opt/occ6.3-64/lib ../.libs/libcgm.a -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.3//lib/libTKFeat.so /opt/OpenCascade6.3//lib/libTKHLR.so /opt/OpenCascade6.3//lib/libTKIGES.so /opt/OpenCascade6.3//lib/libTKOffset.so /opt/OpenCascade6.3//lib/libTKFillet.so /opt/OpenCascade6.3//lib/libTKBool.so /opt/OpenCascade6.3//lib/libTKBO.so /opt/OpenCascade6.3//lib/libTKPrim.so /opt/OpenCascade6.3//lib/libTKSTEP.so /opt/OpenCascade6.3//lib/libTKSTEPAttr.so /opt/OpenCascade6.3//lib/libTKSTEP209.so /opt/OpenCascade6.3//lib/libTKSTEPBase.so /opt/OpenCascade6.3//lib/libTKSTL.so /opt/OpenCascade6.3//lib/libTKMesh.so /opt/OpenCascade6.3//lib/libTKXSBase.so /opt/OpenCascade6.3//lib/libTKShHealing.so /opt/OpenCascade6.3//lib/libTKLCAF.so /opt/OpenCascade6.3//lib/libTKCDF.so /opt/OpenCascade6.3//lib/libTKTopAlgo.so /opt/OpenCascade6.3//lib/libTKGeo!
make check-TESTS
PASS: sheet
Creating the new (webcut) volumes...
Created volume(s): 2
Exported: 2 Volumes
Constructed 1 Volume: 3
Created volume(s): 4
Updated volume(s): 3
Exported: 2 Volumes
Constructed 1 Volume: 5
Created volume(s): 6
Updated volume(s): 5
Exported: 2 Volumes
Read 3 ACIS Entities from the input file
Constructed 1 Volume: 7
Constructed 2 Free Curves: 4457, 4458
Created volume(s): 8
Updated volume(s): 7
CPU time taken to WEBCUT this body: 5.280000 secs
Exported: 2 Volumes
2 Curves
Constructed 1 Volume: 9
Constructed 2 Free Curves: 5296, 5297
Created volume(s): 10
Updated volume(s): 9
Exported: 2 Volumes
2 Curves
Constructed 1 Volume: 11
Constructed 2 Free Curves: 5322, 5323
Created volume(s): 12
Exported: 2 Volumes
2 Curves
Read 5 ACIS Entities from the input file
Constructed 1 Volume: 13
Constructed 4 Free Curves: 5348 to 5351
Created volume(s): 14
Exported: 2 Volumes
4 Curves
Read 2 ACIS Entities from the input file
Constructed 2 Volumes: 15, 16
Created volume(s): 17
Updated volume(s): 15
Exported: 3 Volumes
Constructed 2 Volumes: 18, 19
Created volume(s): 20
Updated volume(s): 18
Exported: 3 Volumes
Constructed 2 Volumes: 21, 22
Created volume(s): 23
Updated volume(s): 21
Exported: 3 Volumes
Constructed 2 Volumes: 24, 25
Created volume(s): 26
Updated volume(s): 24
Exported: 3 Volumes
Constructed 2 Volumes: 27, 28
Created volume(s): 29
Updated volume(s): 27
Exported: 3 Volumes
PASS: webcut
PASS: hollow_acis
Modified volume
Created volume(s): 9
Destroyed volume(s): 2 to 7
Exported: 1 OCC Body
Constructed 1 Volume: 10
Updated volume(s): 19
Destroyed volume(s): 20
Created volume(s): 22, 23
Destroyed volume(s): 19, 21
Total 0 cuts performed, with from_shape having 6 faces.
Total 1 cuts performed, with from_shape having 6 faces.
Total 1 cuts performed, with from_shape having 7 faces.
Total 1 cuts performed, with from_shape having 8 faces.
Updated volume(s): 26
Total 2 cuts performed, with from_shape having 8 faces.
Destroyed volume(s): 25
Modified volume
Total 0 cuts performed, with from_shape having 2 faces.
Updated volume(s): 32
WARNING: Cant make a scar on existing face without splitting it.
Updated volume(s): 33
Created volume(s): 34
WARNING: Surfaces or Shells can't be used to cut a body.
ERROR: Subtract FAILED
Total 4 cuts performed, with from_shape having 10 faces.
Total 3 cuts performed, with from_shape having 9 faces.
Updated volume(s): 35, 36
No projection on the surface.
Total 0 cuts performed, with from_shape having 8 faces.
Removing projected curves
Created volume(s): 39
Updated volume(s): 41
Destroyed volume(s): 40
Destroyed volume(s): 42
The 1 body did not have common part with the tool_body.
Destroyed volume(s): 41, 43
Created volume(s): 46
Destroyed volume(s): 44
Updated volume(s): 45
Created volume(s): 49
Destroyed volume(s): 48
Updated volume(s): 47
Updated volume(s): 51
Destroyed volume(s): 50
Updated volume(s): 53
Destroyed volume(s): 52
Updated volume(s): 54
Destroyed volume(s): 55
Modified volume
Created swept volume 60
Modified volume
Created swept volume 61
Created swept volume 62
Modified volume
Created swept volume 63
ERROR: Only surfaces with no intersection point with the axis can be revolve-swept.
Created swept volume 64
ERROR: Only curves with no intersection point with the axis can be revolve-swept.
Created swept volume 65
Created swept volume 66
Created swept volume 67
Created swept volume 68
ERROR: Sweep along curve itself is not allowed.
Created swept volume 69
Created swept volume 70
Modified volume
Created swept volume 71
Created swept volume 72
ERROR: Errors found during Mergechk session.
FAIL: modify
Constructed 1 Volume: 2
Constructed 2 Volumes: 4, 5
Created volume(s): 6 to 10
Exported: 6 OCC Bodies
3 OCC Points
Exported: 2 OCC Bodies
3 OCC Points
PASS: makept
Constructed 2 Volumes: 1, 2
Constructed 2 Volumes: 3, 4
Created volume(s): 5, 6
Destroyed volume(s): 3, 4
Constructed 2 Volumes: 7, 8
Destroyed volume(s): 8
Constructed 2 Volumes: 9, 10
Destroyed volume(s): 9
Constructed 2 Volumes: 11, 12
Constructed 2 Volumes: 13, 14
Updated volume(s): 14
PASS: r_w
done...
PASS: test_occ
1 of 7 tests failed
make[3]: *** [check-TESTS] Error 1
make[2]: *** [check-am] Error 2
make[1]: *** [check-recursive] Error 1
make: *** [distcheck] Error 2
More information about the cgma-dev
