[cgma-dev] CGMA check for *32-occ* failed.
Nightly Test kraftche at cae.wisc.edu
Wed Dec 10 10:55:55 CST 2008
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh ../trunk/configure  --enable-debug --enable-release --enable-32bit --with-occ=/opt/OpenCascade6.3-32bit  --no-create --no-recursion
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking how to run the C preprocessor... cc -E
checking for CC... no
checking for aCC... no
checking for cxx... no
checking for xlC_r... no
checking for xlC... no
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking dependency style of c++... gcc3
checking how to run the C++ preprocessor... c++ -E
checking for gfortran... gfortran
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking whether we are using the GNU Fortran 77 compiler... yes
checking for known C compilers... GNU
checking for known compiler/OS combinations... GNU:x86_64
checking for known c++ compilers... GNU
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by cc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if cc supports -fno-rtti -fno-exceptions... no
checking for cc option to produce PIC... -fPIC
checking if cc PIC flag -fPIC works... yes
checking if cc static flag -static works... yes
checking if cc supports -c -o file.o... yes
checking whether the cc linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by c++... /usr/bin/ld -m elf_i386
checking if the linker (/usr/bin/ld -m elf_i386) is GNU ld... yes
checking whether the c++ linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes
checking for c++ option to produce PIC... -fPIC
checking if c++ PIC flag -fPIC works... yes
checking if c++ static flag -static works... yes
checking if c++ supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes
checking whether byte ordering is bigendian... no
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... unknown
configure: WARNING: unknown Fortran name-mangling scheme
checking for C++-standard library in std:: namespace... yes
checking for C++-standard I/O in std:: namespace... yes
checking if C++ template definitions should be included... yes
checking for 'include' subdir of /opt/OpenCascade6.3-32bit... inc
checking for 'lib' subdir of /opt/OpenCascade6.3-32bit... lib
checking if platform is 64-bit (-D_OCC64)... no
checking iostream usability... yes
checking iostream presence... yes
checking for iostream... yes
checking iostream.h usability... no
checking iostream.h presence... no
checking for iostream.h... no
checking iomanip usability... yes
checking iomanip presence... yes
checking for iomanip... yes
checking iomanip.h usability... no
checking iomanip.h presence... no
checking for iomanip.h... no
checking fstream usability... yes
checking fstream presence... yes
checking for fstream... yes
checking fstream.h usability... no
checking fstream.h presence... no
checking for fstream.h... no
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking Standard_Version.hxx usability... yes
checking Standard_Version.hxx presence... yes
checking for Standard_Version.hxx... yes
checking for create_mailbox in -lTKernel... no
checking for create_mailbox in -lTKernel... yes
CXXFLAGS =  -Wall -pipe -pedantic -g -m32
configure: creating ./config.status
config.status: creating Makefile
config.status: creating util/Makefile
config.status: creating geom/Makefile
config.status: creating geom/ACIS/Makefile
config.status: creating geom/Cholla/Makefile
config.status: creating geom/facet/Makefile
config.status: creating geom/facetbool/Makefile
config.status: creating geom/OCC/Makefile
config.status: creating geom/parallel/Makefile
config.status: creating geom/virtual/Makefile
config.status: creating init/Makefile
config.status: creating compat/Makefile
config.status: creating cgm.make
config.status: creating itaps/Makefile
config.status: creating itaps/iGeom-Defs.inc
config.status: creating itaps/SIDL/Makefile
config.status: creating test/Makefile
config.status: creating cgm_apps/Makefile
config.status: creating cgm_apps/examples/Makefile
config.status: creating cgm_apps/examples/driverc++/Makefile
config.status: creating cgm_apps/examples/facetdriver/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating itaps/iBase_FCDefs.h
config.status: itaps/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/jason/cgm/test/32-occ'
Making all in compat
make[2]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making all in util
make[2]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making all in geom
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making all in .
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making all in Cholla
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making all in facetbool
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
Making all in facet
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making all in virtual
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making all in OCC
make[3]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H    -Wall -pipe -pedantic -g -m32 -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c -o OCCShapeAttributeSet.lo ../../../trunk/geom/OCC/OCCShapeAttributeSet.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCShapeAttributeSet.lo -MD -MP -MF .deps/OCCShapeAttributeSet.Tpo -c ../../../trunk/geom/OCC/OCCShapeAttributeSet.cpp -o OCCShapeAttributeSet.o
mv -f .deps/OCCShapeAttributeSet.Tpo .deps/OCCShapeAttributeSet.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H    -Wall -pipe -pedantic -g -m32 -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c -o OCCModifyEngine.lo ../../../trunk/geom/OCC/OCCModifyEngine.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCModifyEngine.lo -MD -MP -MF .deps/OCCModifyEngine.Tpo -c ../../../trunk/geom/OCC/OCCModifyEngine.cpp -o OCCModifyEngine.o
mv -f .deps/OCCModifyEngine.Tpo .deps/OCCModifyEngine.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H    -Wall -pipe -pedantic -g -m32 -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c -o OCCQueryEngine.lo ../../../trunk/geom/OCC/OCCQueryEngine.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCQueryEngine.lo -MD -MP -MF .deps/OCCQueryEngine.Tpo -c ../../../trunk/geom/OCC/OCCQueryEngine.cpp -o OCCQueryEngine.o
mv -f .deps/OCCQueryEngine.Tpo .deps/OCCQueryEngine.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H    -Wall -pipe -pedantic -g -m32 -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c -o OCCDrawTool.lo ../../../trunk/geom/OCC/OCCDrawTool.cpp
 c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../trunk/util -I../../../trunk/geom -I../../../trunk/geom/Cholla -I../../../trunk/geom/facetbool -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall -pipe -pedantic -g -m32 -MT OCCDrawTool.lo -MD -MP -MF .deps/OCCDrawTool.Tpo -c ../../../trunk/geom/OCC/OCCDrawTool.cpp -o OCCDrawTool.o
mv -f .deps/OCCDrawTool.Tpo .deps/OCCDrawTool.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32   -o libcubit_OCC.la  OCCShapeAttributeSet.lo OCCAttribSet.lo OCCBody.lo OCCCoEdge.lo OCCCoFace.lo OCCCurve.lo OCCLoop.lo OCCLump.lo OCCModifyEngine.lo OCCParamTool.lo OCCPoint.lo OCCQueryEngine.lo OCCShell.lo OCCSurface.lo OCCDrawTool.lo -L/opt/OpenCascade6.3-32bit/lib -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl -lm
rm -fr  .libs/libcubit_OCC.a .libs/libcubit_OCC.la
ar cru .libs/libcubit_OCC.a  OCCShapeAttributeSet.o OCCAttribSet.o OCCBody.o OCCCoEdge.o OCCCoFace.o OCCCurve.o OCCLoop.o OCCLump.o OCCModifyEngine.o OCCParamTool.o OCCPoint.o OCCQueryEngine.o OCCShell.o OCCSurface.o OCCDrawTool.o
ranlib .libs/libcubit_OCC.a
creating libcubit_OCC.la
(cd .libs && rm -f libcubit_OCC.la && ln -s ../libcubit_OCC.la libcubit_OCC.la)
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making all in init
make[2]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making all in .
make[2]: Entering directory `/home/jason/cgm/test/32-occ'
/bin/sh ./libtool --tag=CC   --mode=link cc  -Wall -pipe -pedantic -g -m32   -o libcgm.la -rpath /usr/local/lib  init/libcgma_init.la  geom/OCC/libcubit_OCC.la  geom/virtual/libcubit_virtual.la geom/facet/libcubit_facet.la geom/Cholla/libcholla.la geom/facetbool/libcubit_facetbool.la geom/libcubit_geom.la util/libcubit_util.la -lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -ldl no -lm
rm -fr  .libs/libcgm.a .libs/libcgm.la .libs/libcgm.lai
rm -fr .libs/libcgm.lax
mkdir .libs/libcgm.lax
rm -fr .libs/libcgm.lax/libcgma_init.a
mkdir .libs/libcgm.lax/libcgma_init.a
(cd .libs/libcgm.lax/libcgma_init.a && ar x /home/jason/cgm/test/32-occ/init/.libs/libcgma_init.a)
rm -fr .libs/libcgm.lax/libcubit_OCC.a
mkdir .libs/libcgm.lax/libcubit_OCC.a
(cd .libs/libcgm.lax/libcubit_OCC.a && ar x /home/jason/cgm/test/32-occ/geom/OCC/.libs/libcubit_OCC.a)
rm -fr .libs/libcgm.lax/libcubit_virtual.a
mkdir .libs/libcgm.lax/libcubit_virtual.a
(cd .libs/libcgm.lax/libcubit_virtual.a && ar x /home/jason/cgm/test/32-occ/geom/virtual/.libs/libcubit_virtual.a)
rm -fr .libs/libcgm.lax/libcubit_facet.a
mkdir .libs/libcgm.lax/libcubit_facet.a
(cd .libs/libcgm.lax/libcubit_facet.a && ar x /home/jason/cgm/test/32-occ/geom/facet/.libs/libcubit_facet.a)
rm -fr .libs/libcgm.lax/libcholla.a
mkdir .libs/libcgm.lax/libcholla.a
(cd .libs/libcgm.lax/libcholla.a && ar x /home/jason/cgm/test/32-occ/geom/Cholla/.libs/libcholla.a)
rm -fr .libs/libcgm.lax/libcubit_facetbool.a
mkdir .libs/libcgm.lax/libcubit_facetbool.a
(cd .libs/libcgm.lax/libcubit_facetbool.a && ar x /home/jason/cgm/test/32-occ/geom/facetbool/.libs/libcubit_facetbool.a)
rm -fr .libs/libcgm.lax/libcubit_geom.a
mkdir .libs/libcgm.lax/libcubit_geom.a
(cd .libs/libcgm.lax/libcubit_geom.a && ar x /home/jason/cgm/test/32-occ/geom/.libs/libcubit_geom.a)
rm -fr .libs/libcgm.lax/libcubit_util.a
mkdir .libs/libcgm.lax/libcubit_util.a
(cd .libs/libcgm.lax/libcubit_util.a && ar x /home/jason/cgm/test/32-occ/util/.libs/libcubit_util.a)
ar cru .libs/libcgm.a   .libs/libcgm.lax/libcgma_init.a/InitCGMA.o  .libs/libcgm.lax/libcubit_OCC.a/OCCBody.o .libs/libcgm.lax/libcubit_OCC.a/OCCLump.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoFace.o .libs/libcgm.lax/libcubit_OCC.a/OCCCurve.o .libs/libcgm.lax/libcubit_OCC.a/OCCQueryEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCDrawTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCAttribSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCShell.o .libs/libcgm.lax/libcubit_OCC.a/OCCModifyEngine.o .libs/libcgm.lax/libcubit_OCC.a/OCCCoEdge.o .libs/libcgm.lax/libcubit_OCC.a/OCCParamTool.o .libs/libcgm.lax/libcubit_OCC.a/OCCPoint.o .libs/libcgm.lax/libcubit_OCC.a/OCCShapeAttributeSet.o .libs/libcgm.lax/libcubit_OCC.a/OCCSurface.o .libs/libcgm.lax/libcubit_OCC.a/OCCLoop.o  .libs/libcgm.lax/libcubit_virtual.a/ImprintBoundaryTool.o .libs/libcgm.lax/libcubit_virtual.a/SegmentedCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLump.o .libs/libcgm.lax/libcubit_virtual.a/VirtualImprintTool.o .libs/libcgm.lax/l!
 ibcubit_virtual.a/CompositeCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionPoint.o .libs/libcgm.lax/libcubit_virtual.a/CompositeGeom.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLumpImprint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCurve.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLoop.o .libs/libcgm.lax/libcubit_virtual.a/VirtualQueryEngine.o .libs/libcgm.lax/libcubit_virtual.a/CAPartitionVG.o .libs/libcgm.lax/libcubit_virtual.a/PartSurfFacetTool.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetSplit.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoEdge.o .libs/libcgm.lax/libcubit_virtual.a/PartitionLump.o .libs/libcgm.lax/libcubit_virtual.a/PartitionBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeTool.o .libs/libcgm.lax/libcubit_virtual.a/FaceterPointData.o .libs/libcgm.lax/libcubit_virtual.a/FaceterFacetData.o .libs/libcgm.lax/libcubit_virtual.a/Faceter.o .libs/libcgm.lax/libcubit_virtual.a/CollapseAngleTool.o .libs/libcgm.lax/libcubit_virtual.a/HiddenE!
 ntitySet.o .libs/libcgm.lax/libcubit_virtual.a/CAVirtualVG.o .libs/lib
cgm.lax/libcubit_virtual.a/SubCurve.o .libs/libcgm.lax/libcubit_virtual.a/PST_Data.o .libs/libcgm.lax/libcubit_virtual.a/PartitionTool.o .libs/libcgm.lax/libcubit_virtual.a/ImprintPointData.o .libs/libcgm.lax/libcubit_virtual.a/SubSurface.o .libs/libcgm.lax/libcubit_virtual.a/CACompositeVG.o .libs/libcgm.lax/libcubit_virtual.a/SubEntitySet.o .libs/libcgm.lax/libcubit_virtual.a/FacetProjectTool.o .libs/libcgm.lax/libcubit_virtual.a/CompositeEngine.o .libs/libcgm.lax/libcubit_virtual.a/PartPTCurve.o .libs/libcgm.lax/libcubit_virtual.a/TDVGFacetOwner.o .libs/libcgm.lax/libcubit_virtual.a/ImprintLineSegment.o .libs/libcgm.lax/libcubit_virtual.a/AllocMemManagersVirtual.o .libs/libcgm.lax/libcubit_virtual.a/CompositeAttrib.o .libs/libcgm.lax/libcubit_virtual.a/CompSurfFacets.o .libs/libcgm.lax/libcubit_virtual.a/CompositeBody.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionCoSurf.o .libs/libcgm.lax/libcubit_virtual.a/PartitionSh!
 ell.o .libs/libcgm.lax/libcubit_virtual.a/CompositeSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositePoint.o .libs/libcgm.lax/libcubit_virtual.a/PartitionSurface.o .libs/libcgm.lax/libcubit_virtual.a/CompositeCurve.o .libs/libcgm.lax/libcubit_virtual.a/CompositeShell.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEntity.o .libs/libcgm.lax/libcubit_virtual.a/CompositeLoop.o .libs/libcgm.lax/libcubit_virtual.a/PartitionEngine.o  .libs/libcgm.lax/libcubit_facet.a/FacetAttribSet.o .libs/libcgm.lax/libcubit_facet.a/GridSearchTree.o .libs/libcgm.lax/libcubit_facet.a/FacetLoop.o .libs/libcgm.lax/libcubit_facet.a/FacetLump.o .libs/libcgm.lax/libcubit_facet.a/FacetParamTool.o .libs/libcgm.lax/libcubit_facet.a/FacetCoEdge.o .libs/libcgm.lax/libcubit_facet.a/FacetSurface.o .libs/libcgm.lax/libcubit_facet.a/FacetCurve.o .libs/libcgm.lax/libcubit_facet.a/FacetShell.o .libs/libcgm.lax/libcubit_facet.a/FacetBody.o .libs/libcgm.lax/libcubit_facet.a/FacetboolInterface.o .libs/libcgm.la!
 x/libcubit_facet.a/FacetModifyEngine.o .libs/libcgm.lax/libcubit_facet
.a/FacetPoint.o .libs/libcgm.lax/libcubit_facet.a/FacetAttrib.o .libs/libcgm.lax/libcubit_facet.a/FacetQueryEngine.o  .libs/libcgm.lax/libcholla.a/TDChordal.o .libs/libcgm.lax/libcholla.a/CubitPoint.o .libs/libcgm.lax/libcholla.a/ChollaPoint.o .libs/libcgm.lax/libcholla.a/FacetEvalTool.o .libs/libcgm.lax/libcholla.a/CubitQuadFacet.o .libs/libcgm.lax/libcholla.a/PointGridSearch.o .libs/libcgm.lax/libcholla.a/FacetEntity.o .libs/libcgm.lax/libcholla.a/Cholla.o .libs/libcgm.lax/libcholla.a/GeoNode.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryEdge.o .libs/libcgm.lax/libcholla.a/ChordalAxis.o .libs/libcgm.lax/libcholla.a/PointLoopFacetor.o .libs/libcgm.lax/libcholla.a/ChollaEngine.o .libs/libcgm.lax/libcholla.a/debug.o .libs/libcgm.lax/libcholla.a/ChollaSkinTool.o .libs/libcgm.lax/libcholla.a/ChollaEntity.o .libs/libcgm.lax/libcholla.a/LoopParamTool.o .libs/libcgm.lax/libcholla.a/CubitFacetData.o .libs/libcgm.lax/libcholla.a/GeoTet.o .libs/libcgm.lax/libcholla.a/AllocMemManagers!
 Cholla.o .libs/libcgm.lax/libcholla.a/CubitFacetEdge.o .libs/libcgm.lax/libcholla.a/CubitFacet.o .libs/libcgm.lax/libcholla.a/CurveFacetEvalTool.o .libs/libcgm.lax/libcholla.a/FacetDataUtil.o .libs/libcgm.lax/libcholla.a/CubitFacetEdgeData.o .libs/libcgm.lax/libcholla.a/TDGeomFacet.o .libs/libcgm.lax/libcholla.a/CubitPointData.o .libs/libcgm.lax/libcholla.a/ChollaSurface.o .libs/libcgm.lax/libcholla.a/CubitQuadFacetData.o .libs/libcgm.lax/libcholla.a/TDFacetboolData.o .libs/libcgm.lax/libcholla.a/ChollaCurve.o .libs/libcgm.lax/libcholla.a/TDFacetBoundaryPoint.o  .libs/libcgm.lax/libcubit_facetbool.a/FBRetriangulate.o .libs/libcgm.lax/libcubit_facetbool.a/FBDataUtil.o .libs/libcgm.lax/libcubit_facetbool.a/FBIntersect.o .libs/libcgm.lax/libcubit_facetbool.a/KdTree.o .libs/libcgm.lax/libcubit_facetbool.a/FBImprint.o .libs/libcgm.lax/libcubit_facetbool.a/FBTiler.o .libs/libcgm.lax/libcubit_facetbool.a/IntegerHash.o .libs/libcgm.lax/libcubit_facetbool.a/FBClassify.o .libs/libcgm!
 .lax/libcubit_facetbool.a/FBPolyhedron.o  .libs/libcgm.lax/libcubit_ge
om.a/CoVolume.o .libs/libcgm.lax/libcubit_geom.a/RefGroup.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureEngine.o .libs/libcgm.lax/libcubit_geom.a/AllocMemManagersGeom.o .libs/libcgm.lax/libcubit_geom.a/OffsetSplitTool.o .libs/libcgm.lax/libcubit_geom.a/RefVertex.o .libs/libcgm.lax/libcubit_geom.a/CubitPolygon.o .libs/libcgm.lax/libcubit_geom.a/CAEntityColor.o .libs/libcgm.lax/libcubit_geom.a/TDSplitSurface.o .libs/libcgm.lax/libcubit_geom.a/GeomDataObserver.o .libs/libcgm.lax/libcubit_geom.a/SurfaceSM.o .libs/libcgm.lax/libcubit_geom.a/BridgeManager.o .libs/libcgm.lax/libcubit_geom.a/CoFace.o .libs/libcgm.lax/libcubit_geom.a/CAEntityName.o .libs/libcgm.lax/libcubit_geom.a/CAActuateSet.o .libs/libcgm.lax/libcubit_geom.a/GeometryHealerEngine.o .libs/libcgm.lax/libcubit_geom.a/GeomMeasureTool.o .libs/libcgm.lax/libcubit_geom.a/CAMergePartner.o .libs/libcgm.lax/libcubit_geom.a/GeometryUtil.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryEngine.o .libs/libcgm.lax/libcubit_geo!
 m.a/CGMEngineDynamicLoader.o .libs/libcgm.lax/libcubit_geom.a/PointSM.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribUser.o .libs/libcgm.lax/libcubit_geom.a/RefFace.o .libs/libcgm.lax/libcubit_geom.a/CAMergeStatus.o .libs/libcgm.lax/libcubit_geom.a/TDSurfaceOverlap.o .libs/libcgm.lax/libcubit_geom.a/Lump.o .libs/libcgm.lax/libcubit_geom.a/MedialTool2D.o .libs/libcgm.lax/libcubit_geom.a/RefEntityName.o .libs/libcgm.lax/libcubit_geom.a/GSaveOpen.o .libs/libcgm.lax/libcubit_geom.a/CAUniqueId.o .libs/libcgm.lax/libcubit_geom.a/TopologyBridge.o .libs/libcgm.lax/libcubit_geom.a/CubitAttribManager.o .libs/libcgm.lax/libcubit_geom.a/TDUniqueId.o .libs/libcgm.lax/libcubit_geom.a/CurveOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryFeatureTool.o .libs/libcgm.lax/libcubit_geom.a/CADeferredAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoVertex.o .libs/libcgm.lax/libcubit_geom.a/GeometryQueryTool.o .libs/libcgm.lax/libcubit_geom.a/RefEntity.o .libs/libcgm.lax/libcubit_geom.a/SphereEv!
 aluator.o .libs/libcgm.lax/libcubit_geom.a/Shell.o .libs/libcgm.lax/li
bcubit_geom.a/LumpSM.o .libs/libcgm.lax/libcubit_geom.a/BoundingBoxTool.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapTool.o .libs/libcgm.lax/libcubit_geom.a/CAEntityId.o .libs/libcgm.lax/libcubit_geom.a/Curve.o .libs/libcgm.lax/libcubit_geom.a/Point.o .libs/libcgm.lax/libcubit_geom.a/SplitSurfaceTool.o .libs/libcgm.lax/libcubit_geom.a/RefVolume.o .libs/libcgm.lax/libcubit_geom.a/Loop.o .libs/libcgm.lax/libcubit_geom.a/RefEdge.o .libs/libcgm.lax/libcubit_geom.a/TDCAGE.o .libs/libcgm.lax/libcubit_geom.a/MedialTool3D.o .libs/libcgm.lax/libcubit_geom.a/TDSourceFeature.o .libs/libcgm.lax/libcubit_geom.a/CubitSimpleAttrib.o .libs/libcgm.lax/libcubit_geom.a/CAGroup.o .libs/libcgm.lax/libcubit_geom.a/MergeToolAssistant.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyEngine.o .libs/libcgm.lax/libcubit_geom.a/GeometryEntity.o .libs/libcgm.lax/libcubit_geom.a/ModelQueryEngine.o .libs/libcgm.lax/libcubit_geom.a/AnalyticGeometryTool.o .libs/libcgm.lax/libcubit_geom.a/GfxPreview.o .l!
 ibs/libcgm.lax/libcubit_geom.a/DAG.o .libs/libcgm.lax/libcubit_geom.a/RefCollection.o .libs/libcgm.lax/libcubit_geom.a/RefEntityFactory.o .libs/libcgm.lax/libcubit_geom.a/CASourceFeature.o .libs/libcgm.lax/libcubit_geom.a/SurfParamTool.o .libs/libcgm.lax/libcubit_geom.a/GeometryModifyTool.o .libs/libcgm.lax/libcubit_geom.a/LoopSM.o .libs/libcgm.lax/libcubit_geom.a/ModelEntity.o .libs/libcgm.lax/libcubit_geom.a/Surface.o .libs/libcgm.lax/libcubit_geom.a/SenseEntity.o .libs/libcgm.lax/libcubit_geom.a/CylinderEvaluator.o .libs/libcgm.lax/libcubit_geom.a/GroupingEntity.o .libs/libcgm.lax/libcubit_geom.a/BodySM.o .libs/libcgm.lax/libcubit_geom.a/CurveSM.o .libs/libcgm.lax/libcubit_geom.a/CoEdge.o .libs/libcgm.lax/libcubit_geom.a/MergeTool.o .libs/libcgm.lax/libcubit_geom.a/CGMApp.o .libs/libcgm.lax/libcubit_geom.a/CubitAttrib.o .libs/libcgm.lax/libcubit_geom.a/CoEdgeSM.o .libs/libcgm.lax/libcubit_geom.a/TopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/MidPlaneTool.o .libs/libcg!
 m.lax/libcubit_geom.a/OldUnmergeCode.o .libs/libcgm.lax/libcubit_geom.
a/Chain.o .libs/libcgm.lax/libcubit_geom.a/SurfaceOverlapFacet.o .libs/libcgm.lax/libcubit_geom.a/GeometryHealerTool.o .libs/libcgm.lax/libcubit_geom.a/Body.o .libs/libcgm.lax/libcubit_geom.a/DagDrawingTool.o .libs/libcgm.lax/libcubit_geom.a/BasicTopologyEntity.o .libs/libcgm.lax/libcubit_geom.a/CollectionEntity.o .libs/libcgm.lax/libcubit_geom.a/ShellSM.o  .libs/libcgm.lax/libcubit_util.a/GMem.o .libs/libcgm.lax/libcubit_util.a/CubitCoordinateSystem.o .libs/libcgm.lax/libcubit_util.a/GfxDebug.o .libs/libcgm.lax/libcubit_util.a/CubitString.o .libs/libcgm.lax/libcubit_util.a/StubProgressTool.o .libs/libcgm.lax/libcubit_util.a/TextProgressTool.o .libs/libcgm.lax/libcubit_util.a/TDUPtr.o .libs/libcgm.lax/libcubit_util.a/CubitStack.o .libs/libcgm.lax/libcubit_util.a/CubitMessage.o .libs/libcgm.lax/libcubit_util.a/CubitFileIOWrapper.o .libs/libcgm.lax/libcubit_util.a/CubitFileUtil.o .libs/libcgm.lax/libcubit_util.a/CubitEntity.o .libs/libcgm.lax/libcubit_util.a/CubitVector.o .lib!
 s/libcgm.lax/libcubit_util.a/IntersectionTool.o .libs/libcgm.lax/libcubit_util.a/MemoryBlock.o .libs/libcgm.lax/libcubit_util.a/Queue.o .libs/libcgm.lax/libcubit_util.a/SettingHolder.o .libs/libcgm.lax/libcubit_util.a/Cubit2DPoint.o .libs/libcgm.lax/libcubit_util.a/CubitCollection.o .libs/libcgm.lax/libcubit_util.a/PlanarParamTool.o .libs/libcgm.lax/libcubit_util.a/ArrayBasedContainer.o .libs/libcgm.lax/libcubit_util.a/GetLongOpt.o .libs/libcgm.lax/libcubit_util.a/CubitFileFEModel.o .libs/libcgm.lax/libcubit_util.a/AllocMemManagersList.o .libs/libcgm.lax/libcubit_util.a/CubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitDynamicLoader.o .libs/libcgm.lax/libcubit_util.a/TtyProgressTool.o .libs/libcgm.lax/libcubit_util.a/CubitObservable.o .libs/libcgm.lax/libcubit_util.a/DIntArray.o .libs/libcgm.lax/libcubit_util.a/DynamicArray.o .libs/libcgm.lax/libcubit_util.a/ToolData.o .libs/libcgm.lax/libcubit_util.a/ToolDataUser.o .libs/libcgm.lax/libcubit_util.a/RandomMersenne.o .libs/l!
 ibcgm.lax/libcubit_util.a/SDLList.o .libs/libcgm.lax/libcubit_util.a/C
ubitBox.o .libs/libcgm.lax/libcubit_util.a/CubitTransformMatrix.o .libs/libcgm.lax/libcubit_util.a/ParamCubitPlane.o .libs/libcgm.lax/libcubit_util.a/CubitFileMetaData.o .libs/libcgm.lax/libcubit_util.a/DLList.o .libs/libcgm.lax/libcubit_util.a/CubitFile.o .libs/libcgm.lax/libcubit_util.a/CubitMatrix.o .libs/libcgm.lax/libcubit_util.a/CubitObserver.o .libs/libcgm.lax/libcubit_util.a/CubitContainer.o .libs/libcgm.lax/libcubit_util.a/Tree.o .libs/libcgm.lax/libcubit_util.a/AppUtil.o .libs/libcgm.lax/libcubit_util.a/CpuTimer.o .libs/libcgm.lax/libcubit_util.a/MemoryManager.o .libs/libcgm.lax/libcubit_util.a/CubitUtil.o .libs/libcgm.lax/libcubit_util.a/SettingHandler.o
ranlib .libs/libcgm.a
creating libcgm.la
(cd .libs && rm -f libcgm.la && ln -s ../libcgm.la libcgm.la)
make[2]: Leaving directory `/home/jason/cgm/test/32-occ'
Making all in itaps
make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  all-recursive
make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making all in .
make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32   -o libiGeom.la -rpath /usr/local/lib CATag.lo iGeom_CGMA.lo iGeomError.lo ../libcgm.la -lm
rm -fr  .libs/libiGeom.a .libs/libiGeom.la .libs/libiGeom.lai
ar cru .libs/libiGeom.a  CATag.o iGeom_CGMA.o iGeomError.o
ranlib .libs/libiGeom.a
creating libiGeom.la
(cd .libs && rm -f libiGeom.la && ln -s ../libiGeom.la libiGeom.la)
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
Making all in test
make[2]: Entering directory `/home/jason/cgm/test/32-occ/test'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test'
Making all in cgm_apps
make[2]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps'
Making all in examples
make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples'
Making all in facetdriver
make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples/facetdriver'
make[4]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps/examples'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps/examples'
make[3]: Entering directory `/home/jason/cgm/test/32-occ/cgm_apps'
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/cgm_apps'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ'
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making check in .
make[2]: Nothing to be done for `check-am'.
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making check in .
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making check in .
make    testgeom_occ
c++ -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I.  -DSRCDIR=../../trunk/itaps -DFORCE_OCC   -Wall -pipe -pedantic -g -m32 -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo '../../trunk/itaps/'`testgeom.cc
mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib  -o testgeom_occ testgeom_occ-testgeom.o libiGeom.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o testgeom_occ testgeom_occ-testgeom.o  -L/opt/OpenCascade6.3-32bit/lib ./.libs/libiGeom.a /home/jason/cgm/test/32-occ/.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib!
 /libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKBRep.so /opt/OpenCascade6.3-32bit/lib/libTKGeomBase.so /opt/OpenCascade6.3-32bit/lib/libTKG3d.so /opt/OpenCascade6.3-32bit/lib/libTKG2d.so /opt/OpenCascade6.3-32bit/lib/libTKMath.so /opt/OpenCascade6.3-32bit/lib/libTKernel.so -lpthread -ldl -lm   -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib -Wl,--rpath -Wl,/opt/OpenCascade6.3-32bit/lib
./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry':
/home/jason/cgm/test/32-occ/itaps/../../trunk/itaps/iGeom_CGMA.cc:5883: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
make  check-TESTS
Using default input file: ../../trunk/itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
Success
   shutdown: Success
TSTT TEST SUMMARY:
   Number Tests:           9
   Number Successful:      9
   Number Not Implemented: 0
   Number Failed:          0
PASS: testgeom_occ
All 1 tests passed
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
Making check in test
make[1]: Entering directory `/home/jason/cgm/test/32-occ/test'
make  sheet   modify makept r_w test_occ
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib   -o sheet sheet.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o sheet sheet.o  -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /op!
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib   -o modify modify.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o modify modify.o  -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /!
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER  -DHAVE_OCC  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/init -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/OpenCascade6.3-32bit/inc -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test  -DHAVE_OCC   -Wall -pipe -pedantic -g -m32 -MT makept.o -MD -MP -MF .deps/makept.Tpo -c -o makept.o ../../trunk/test/makept.cpp
../../trunk/test/makept.cpp: In function ‘CubitStatus make_Point()’:
../../trunk/test/makept.cpp:289: warning: unused variable ‘d’
../../trunk/test/makept.cpp:206: warning: unused variable ‘is_equal’
../../trunk/test/makept.cpp:294: warning: unused variable ‘new_face2’
../../trunk/test/makept.cpp:335: warning: unused variable ‘area’
../../trunk/test/makept.cpp:374: warning: unused variable ‘pc2’
../../trunk/test/makept.cpp:378: warning: unused variable ‘num_loops’
../../trunk/test/makept.cpp:383: warning: unused variable ‘angle’
mv -f .deps/makept.Tpo .deps/makept.Po
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib   -o makept makept.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o makept makept.o  -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /!
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib   -o r_w r_w.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o r_w r_w.o  -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.so /opt/Op!
/bin/sh ../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g -m32  -L/opt/OpenCascade6.3-32bit/lib   -o test_occ test_occ.o ../libcgm.la -lm
c++ -Wall -pipe -pedantic -g -m32 -o test_occ test_occ.o  -L/opt/OpenCascade6.3-32bit/lib ../.libs/libcgm.a /opt/OpenCascade6.3-32bit/lib/libTKFeat.so /opt/OpenCascade6.3-32bit/lib/libTKHLR.so /opt/OpenCascade6.3-32bit/lib/libTKIGES.so /opt/OpenCascade6.3-32bit/lib/libTKOffset.so /opt/OpenCascade6.3-32bit/lib/libTKFillet.so /opt/OpenCascade6.3-32bit/lib/libTKBool.so /opt/OpenCascade6.3-32bit/lib/libTKBO.so /opt/OpenCascade6.3-32bit/lib/libTKPrim.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPAttr.so /opt/OpenCascade6.3-32bit/lib/libTKSTEP209.so /opt/OpenCascade6.3-32bit/lib/libTKSTEPBase.so /opt/OpenCascade6.3-32bit/lib/libTKSTL.so /opt/OpenCascade6.3-32bit/lib/libTKMesh.so /opt/OpenCascade6.3-32bit/lib/libTKXSBase.so /opt/OpenCascade6.3-32bit/lib/libTKShHealing.so /opt/OpenCascade6.3-32bit/lib/libTKLCAF.so /opt/OpenCascade6.3-32bit/lib/libTKCDF.so /opt/OpenCascade6.3-32bit/lib/libTKTopAlgo.so /opt/OpenCascade6.3-32bit/lib/libTKGeomAlgo.!
make  check-TESTS
PASS: sheet
Modified volume
Created volume(s): 9
Destroyed volume(s): 2 to 7
Exported:   1 OCC Body
Constructed 1 Volume: 10
Updated volume(s): 19
Destroyed volume(s): 20
Created volume(s): 22, 23
Destroyed volume(s): 19, 21
/bin/sh: line 4:  9101 Segmentation fault      /home/jason/bin/timeout 600 ${dir}$tst
FAIL: modify
Constructed 1 Volume: 2
Constructed 1 Volume: 3
Constructed 2 Volumes: 4, 5
Created volume(s): 6 to 10
Exported:   6 OCC Bodies
            3 OCC Points
Exported:   2 OCC Bodies
            3 OCC Points
PASS: makept
Constructed 2 Volumes: 1, 2
Constructed 2 Volumes: 3, 4
Created volume(s): 5, 6
Destroyed volume(s): 3, 4
/bin/sh: line 4:  9113 Segmentation fault      /home/jason/bin/timeout 600 ${dir}$tst
FAIL: r_w
done...
PASS: test_occ
2 of 5 tests failed
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/test'
make: *** [check-recursive] Error 1
More information about the cgma-dev mailing list
