[cgma-dev] r2466 - cgm/trunk/test
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Dec 4 10:44:16 CST 2008
Author: kraftche
Date: 2008-12-04 10:44:16 -0600 (Thu, 04 Dec 2008)
New Revision: 2466
Removed:
   cgm/trunk/test/unite2.occ
   cgm/trunk/test/unite3.occ
   cgm/trunk/test/unite4.occ
   cgm/trunk/test/unite5.occ
   cgm/trunk/test/unite6.occ
   cgm/trunk/test/webcut_with_brick.sat
Modified:
   cgm/trunk/test/Makefile.am
   cgm/trunk/test/webcut.cpp
Log:
Clean up mess with test output files.  Files created by tests should
*not* be checked into SVN? or included in tarballs.  Such files *must*
be written to the test build directory (not the source directory if
they are different) and must be cleaned up during "make clean".
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/Makefile.am	2008-12-04 16:44:16 UTC (rev 2466)
@@ -46,6 +46,8 @@
 r_w_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 test_occ_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
+# Files that are used as input to tests, and therefore
+# must be included in tarball for tests to run.
 EXTRA_DIST = 62_shaver1.brep \
              66_shaver3.brep \
              72_shaver6.brep \
@@ -54,11 +56,6 @@
              beforesub.occ_ref \
              beforesub2.occ_ref \
              unite1.occ\
-             unite2.occ\
-             unite3.occ\
-             unite4.occ\
-             unite5.occ\
-             unite6.occ\
              huge.sat \
              model1.sat \
              model2.sat \
@@ -68,13 +65,31 @@
              model6.sat \
              model7.sat \
              hollow.sat \
-             stitch.occ_name \
-             webcut_with_brick.sat \
-             webcut_with_curve_loop.sat \
-             webcut_with_extended_surf.sat \
-             webcut_with_sheet.sat \
-             webcut_with_sweep_along_curve.sat \
-             webcut_with_sweep_surfaces.sat \
-             webcut_with_sweep_surfaces_along_curve.sat \
-             webcut_with_sweep_surfaces_rotated.sat
+             stitch.occ_name
+# Files that are created by tests, and that therefore
+#  - should be removed during 'make clean'
+#  - should not be included in tarball
+MOSTLYCLEANFILES = \
+	webcut_with_brick.sat \
+	webcut_with_cylinder.sat \
+	webcut_with_sheet.sat \
+	webcut_with_sweep_rotational.sat \
+	webcut_with_sweep_curves.sat \
+	webcut_with_sweep_along_curve.sat \
+	webcut_with_curve_loop.sat \
+	webcut_with_extended_surf.sat \
+	webcut_with_sweep_surfaces_rotated.sat \
+	webcut_with_sweep_surfaces.sat \
+	webcut_with_sweep_surfaces_along_curve.sat \
+	webcut_with_sweep_surfaces_perp.sat \
+	point.occ \
+	stitch.occ \
+	beforesub.occ \
+	beforesub2.occ \
+	aftersub.occ \
+	unite2.occ \
+	unite3.occ \
+	unite5.occ \
+	unite6.occ
Deleted: cgm/trunk/test/unite2.occ
--- cgm/trunk/test/unite2.occ	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/unite2.occ	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,464 +0,0 @@
-DBRep_DrawableShape
-CASCADE Topology V1, (c) Matra-Datavision
-Locations 4
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-2  1 1 2 1 0
-2  2 -1 1 -1 0
-Curve2ds 40
-1 0 0 0 1
-1 0 1 1 0
-1 0 -1 1 0
-1 0 1 1 0
-1 1 0 0 1
-1 0 1 1 0
-1 0 -1 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 1 0 0 1
-1 1 0 0 -1
-1 0 0 0 1
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 1 0 0 1
-1 1 0 0 -1
-1 0 0 0 1
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-Curves 20
-1 0 1 0 1 0 -0
-1 1 1 0 0 0 1
-1 0 1 1 1 0 -0
-1 0 1 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 1 0 0 -0 1 0
-1 1 0 0 0 0 1
-1 1 0 1 0 1 0
-1 0 0 1 -0 1 0
-1 0 0 1 1 0 -0
-1 0 0 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 1 0 0 -0 1 0
-1 1 0 0 0 0 1
-1 1 0 1 0 1 0
-1 0 0 1 -0 1 0
-1 0 0 1 1 0 -0
-1 0 0 0 0 0 1
-Polygon3D 0
-PolygonOnTriangulations 0
-Surfaces 11
-1 0 1 0 -0 1 0 0 0 1 1 0 -0
-1 0 0 0 0 0 1 1 0 -0 -0 1 0
-1 1 0 0 1 0 -0 0 0 1 0 -1 0
-1 0 0 1 0 0 1 1 0 -0 -0 1 0
-1 0 0 0 1 0 -0 0 0 1 0 -1 0
-1 0 0 0 -0 1 0 0 0 1 1 0 -0
-Triangulations 0
-TShapes 55
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 1
-2  1 1 0 0 1
-2  2 2 0 0 1
-0
-0101000
--55 0 +54 0 *
-Ve
-1e-07
-1 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  2 0 0 1
-2  3 3 0 0 1
-2  4 1 0 0 1
-0
-0101000
--52 0 +55 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  3 0 0 1
-2  5 1 0 0 1
-2  6 4 0 0 1
-0
-0101000
--52 0 +50 0 *
-Ed
- 1e-07 1 1 0
-1  4 0 0 1
-2  7 5 0 0 1
-2  8 1 0 0 1
-0
-0101000
--50 0 +54 0 *
-Wi
-0101000
--53 0 -51 0 +49 0 +48 0 *
-Fa
-0  1e-07 1 0
-0111000
-+47 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 0 1
-2  9 5 0 0 1
-2  10 2 0 0 1
-0
-0101000
-+45 4 -54 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  6 0 0 1
-2  11 6 0 0 1
-2  12 2 0 0 1
-0
-0101000
-+45 4 -43 4 *
-Ed
- 1e-07 1 1 0
-1  7 0 0 1
-2  13 3 0 0 1
-2  14 2 0 0 1
-0
-0101000
-+43 4 -55 0 *
-Wi
-0101000
--44 3 +42 3 -53 3 +41 3 *
-Fa
-0  1e-07 2 3
-0101000
-+40 0 *
-Ve
-1e-07
-1 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  8 0 0 1
-2  15 3 0 0 1
-2  16 6 0 0 1
-0
-0101000
-+43 4 -38 4 *
-Ed
- 1e-07 1 1 0
-1  9 0 0 1
-2  17 3 0 0 1
-2  18 4 0 0 1
-0
-0101000
-+38 4 -52 0 *
-Wi
-0101000
--37 3 +41 3 -36 3 +51 3 *
-Fa
-0  1e-07 3 3
-0101000
-+35 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  10 0 0 1
-2  19 5 0 0 1
-2  20 4 0 0 1
-0
-0101000
-+33 4 -50 0 *
-Ed
- 1e-07 1 1 0
-1  11 0 0 1
-2  21 6 0 0 1
-2  22 4 0 0 1
-0
-0101000
-+33 4 -38 4 *
-Wi
-0101000
--32 3 +31 3 -49 3 +36 3 *
-Fa
-0  1e-07 4 3
-0101000
-+30 0 *
-Ed
- 1e-07 1 1 0
-1  12 0 0 1
-2  23 5 0 0 1
-2  24 6 0 0 1
-0
-0101000
-+45 4 -33 4 *
-Wi
-0101000
--28 3 +44 3 -32 3 +48 3 *
-Fa
-0  1e-07 5 3
-0101000
-+27 0 *
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  13 0 0 1
-2  25 8 0 0 1
-2  26 7 0 0 1
-0
-0101000
-+25 0 -45 0 *
-Ve
-1e-07
-1 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0 1
-2  27 9 0 0 1
-2  28 7 0 0 1
-0
-0101000
--23 0 +25 0 *
-Ed
- 1e-07 1 1 0
-1  15 0 0 1
-2  29 10 0 0 1
-2  30 7 0 0 1
-0
-0101000
-+23 0 -43 0 *
-Wi
-0101000
--24 0 +22 0 -42 3 +21 0 *
-Fa
-0  1e-07 7 0
-0101000
-+20 0 *
-Ve
-1e-07
-1 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  16 0 0 1
-2  31 10 0 0 1
-2  32 9 0 0 1
-0
-0101000
--18 0 +23 0 *
-Ed
- 1e-07 1 1 0
-1  17 0 0 1
-2  33 10 0 0 1
-2  34 11 0 0 1
-0
-0101000
-+18 0 -38 0 *
-Wi
-0101000
--17 0 -16 0 +21 0 +37 3 *
-Fa
-0  1e-07 10 0
-0101000
-+15 0 *
-Ve
-1e-07
-0 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  18 0 0 1
-2  35 8 0 0 1
-2  36 11 0 0 1
-0
-0101000
-+13 0 -33 0 *
-Ed
- 1e-07 1 1 0
-1  19 0 0 1
-2  37 9 0 0 1
-2  38 11 0 0 1
-0
-0101000
--18 0 +13 0 *
-Wi
-0101000
--12 0 +11 0 -31 3 +16 0 *
-Fa
-0  1e-07 11 0
-0101000
-+10 0 *
-Ed
- 1e-07 1 1 0
-1  20 0 0 1
-2  39 8 0 0 1
-2  40 9 0 0 1
-0
-0101000
--13 0 +25 0 *
-Wi
-0101000
--8 0 -12 0 +24 0 +28 3 *
-Fa
-0  1e-07 8 0
-0101000
-+7 0 *
-Wi
-0101000
--22 0 -17 0 +11 0 +8 0 *
-Fa
-0  1e-07 9 0
-0111000
-+5 0 *
-Sh
-0101000
-+46 3 -39 0 +34 0 +29 0 -26 0 -19 0 +14 0 +9 0 -6 0 -4 0
-So
-CGM_ATTRIB ENTITY_NAME* volumeB* * *
-0100000
-+3 0 *
-Co
-1100000
-+2 0 *
-+1 0
\ No newline at end of file
Deleted: cgm/trunk/test/unite3.occ
--- cgm/trunk/test/unite3.occ	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/unite3.occ	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,464 +0,0 @@
-Locations 4
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-2  1 1 2 1 0
-2  2 -1 1 -1 0
-Curve2ds 40
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 1 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 1 0 0 -1
-1 1 0 0 1
-1 0 -1 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 0 0 0 1
-1 1 0 0 1
-1 0 1 1 0
-1 0 -1 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 1 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 1 0 0 -1
-1 1 0 0 1
-1 0 -1 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 0 0 0 1
-1 1 0 0 1
-1 0 1 1 0
-1 0 -1 1 0
-1 0 0 1 0
-Curves 20
-1 0 0 0 1 0 -0
-1 1 0 0 0 0 1
-1 0 0 1 1 0 -0
-1 0 0 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 1 0 1 0 -0
-1 1 0 0 -0 1 0
-1 1 0 1 0 1 0
-1 1 1 0 0 0 1
-1 0 0 1 -0 1 0
-1 0 1 1 1 0 -0
-1 0 1 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 1 0 1 0 -0
-1 1 0 0 -0 1 0
-1 1 0 1 0 1 0
-1 1 1 0 0 0 1
-1 0 0 1 -0 1 0
-1 0 1 1 1 0 -0
-1 0 1 0 0 0 1
-Polygon3D 0
-Surfaces 11
-Triangulations 0
-TShapes 55
-Ve
-1e-07
-1 0 0
-0 0
-0101101
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 1
-2  1 1 0 0 1
-2  2 2 0 0 1
-0
-0101000
--55 0 +54 0 *
-Ve
-1e-07
-1 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  2 0 0 1
-2  3 3 0 0 1
-2  4 1 0 0 1
-0
-0101000
--52 0 +55 0 *
-Ve
-1e-07
-0 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  3 0 0 1
-2  5 1 0 0 1
-2  6 4 0 0 1
-0
-0101000
--52 0 +50 0 *
-Ed
- 1e-07 1 1 0
-1  4 0 0 1
-2  7 5 0 0 1
-2  8 1 0 0 1
-0
-0101000
--50 0 +54 0 *
-Wi
-0101000
-Fa
-0  1e-07 1 0
-0111000
-+47 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 0 1
-2  9 5 0 0 1
-2  10 2 0 0 1
-0
-0101000
-+54 0 -45 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  6 0 0 1
-2  11 6 0 0 1
-2  12 2 0 0 1
-0
-0101000
-+45 0 -43 0 *
-Ed
- 1e-07 1 1 0
-1  7 0 0 1
-2  13 3 0 0 1
-2  14 2 0 0 1
-0
-0101000
-+55 0 -43 0 *
-Wi
-0101000
--44 0 +53 0 -42 0 +41 0 *
-Fa
-0  1e-07 2 0
-0101000
-+40 0 *
-Ve
-1e-07
-1 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  8 0 0 1
-2  15 3 0 0 1
-2  16 4 0 0 1
-0
-0101000
-+52 0 -38 0 *
-Ed
- 1e-07 1 1 0
-1  9 0 0 1
-2  17 3 0 0 1
-2  18 6 0 0 1
-0
-0101000
-+43 0 -38 0 *
-Wi
-0101000
--51 0 -37 0 +41 0 +36 0 *
-Fa
-0  1e-07 3 0
-0101000
-+35 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  10 0 0 1
-2  19 5 0 0 1
-2  20 4 0 0 1
-0
-0101000
-+50 0 -33 0 *
-Ed
- 1e-07 1 1 0
-1  11 0 0 1
-2  21 6 0 0 1
-2  22 4 0 0 1
-0
-0101000
-+33 0 -38 0 *
-Wi
-0101000
--32 0 +49 0 -31 0 +37 0 *
-Fa
-0  1e-07 4 0
-0101000
-+30 0 *
-Ed
- 1e-07 1 1 0
-1  12 0 0 1
-2  23 5 0 0 1
-2  24 6 0 0 1
-0
-0101000
-+45 0 -33 0 *
-Wi
-0101000
--48 0 -32 0 +44 0 +28 0 *
-Fa
-0  1e-07 5 0
-0101000
-+27 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  13 0 0 1
-2  25 8 0 0 1
-2  26 7 0 0 1
-0
-0101000
-+45 4 -25 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0 1
-2  27 9 0 0 1
-2  28 7 0 0 1
-0
-0101000
--23 0 +25 0 *
-Ed
- 1e-07 1 1 0
-1  15 0 0 1
-2  29 10 0 0 1
-2  30 7 0 0 1
-0
-0101000
-+43 4 -23 0 *
-Wi
-0101000
--24 3 +42 0 -22 3 +21 3 *
-Fa
-0  1e-07 7 3
-0101000
-+20 0 *
-Ve
-1e-07
-1 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  16 0 0 1
-2  31 10 0 0 1
-2  32 11 0 0 1
-0
-0101000
-+38 4 -18 0 *
-Ed
- 1e-07 1 1 0
-1  17 0 0 1
-2  33 10 0 0 1
-2  34 9 0 0 1
-0
-0101000
--18 0 +23 0 *
-Wi
-0101000
--36 0 +21 3 -17 3 +16 3 *
-Fa
-0  1e-07 10 3
-0101000
-+15 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  18 0 0 1
-2  35 8 0 0 1
-2  36 11 0 0 1
-0
-0101000
-+33 4 -13 0 *
-Ed
- 1e-07 1 1 0
-1  19 0 0 1
-2  37 9 0 0 1
-2  38 11 0 0 1
-0
-0101000
--18 0 +13 0 *
-Wi
-0101000
--12 3 +31 0 -11 3 +17 3 *
-Fa
-0  1e-07 11 3
-0101000
-+10 0 *
-Ed
- 1e-07 1 1 0
-1  20 0 0 1
-2  39 8 0 0 1
-2  40 9 0 0 1
-0
-0101000
--13 0 +25 0 *
-Wi
-0101000
--28 0 +24 3 -12 3 +8 3 *
-Fa
-0  1e-07 8 3
-0101000
-+7 0 *
-Wi
-0101000
--22 0 -16 0 +11 0 +8 0 *
-Fa
-0  1e-07 9 0
-0111000
-+5 0 *
-Sh
-0101000
--46 0 -39 0 +34 0 +29 0 -26 0 -19 0 +14 0 +9 0 -6 0 +4 3
-So
-CGM_ATTRIB ENTITY_NAME* volumeA* * *
-0100000
-+3 0 *
-Co
-1100000
-+2 0 *
-+1 0
Deleted: cgm/trunk/test/unite4.occ
--- cgm/trunk/test/unite4.occ	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/unite4.occ	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,562 +0,0 @@
-Locations 1
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-Curve2ds 48
-1 0 0 1 0
-1 0 0 1 0
-1 4 0 0 -1
-1 0 0 0 1
-1 0 -4 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 1 0
-1 0 4 1 0
-1 4 0 0 -1
-1 4 0 0 1
-1 0 -4 1 0
-1 0 4 1 0
-1 0 0 0 -1
-1 4 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 4 0 0 1
-1 0 0 1 0
-1 0 0 0 1
-1 0 4 1 0
-1 4 0 0 1
-1 0 4 1 0
-1 0 0 1 0
-1 0 0 1 0
-1 1 0 0 -1
-1 0 0 0 1
-1 0 -1 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 1 0 0 1
-1 0 -1 1 0
-1 0 1 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 0 1
-1 0 1 1 0
-1 1 0 0 1
-1 0 1 1 0
-Curves 24
-1 0 0 0 0 0 1
-1 0 0 4 -0 1 0
-1 0 4 0 0 0 1
-1 0 0 0 -0 1 0
-1 4 0 0 0 0 1
-1 4 0 4 0 1 0
-1 4 4 0 0 0 1
-1 4 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 0 0 4 1 0 -0
-1 0 4 0 1 0 -0
-1 0 4 4 1 0 -0
-1 0 0 0 0 0 1
-1 0 0 1 -0 1 0
-1 0 1 0 0 0 1
-1 0 0 0 -0 1 0
-1 1 0 0 0 0 1
-1 1 0 1 0 1 0
-1 1 1 0 0 0 1
-1 1 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 0 0 1 1 0 -0
-1 0 1 0 1 0 -0
-1 0 1 1 1 0 -0
-Polygon3D 0
-Surfaces 12
-1 0 0 4 0 0 1 1 0 -0 -0 1 0
-1 0 4 0 -0 1 0 0 0 1 1 0 -0
-1 4 0 0 1 0 -0 0 0 1 0 -1 0
-Triangulations 0
-TShapes 69
-Ve
-1e-07
-0 0 4
-0 0
-0101101
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 4
-2  1 1 0 0 4
-2  2 2 0 0 4
-0
-0101000
--69 0 +68 0 *
-Ve
-1e-07
-0 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  2 0 0 4
-2  3 1 0 0 4
-2  4 3 0 0 4
-0
-0101000
--66 0 +69 0 *
-Ve
-1e-07
-0 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  3 0 0 4
-2  5 1 0 0 4
-2  6 4 0 0 4
-0
-0101000
--66 0 +64 0 *
-Ed
- 1e-07 1 1 0
-1  4 0 0 4
-2  7 1 0 0 4
-2  8 5 0 0 4
-0
-0101000
--64 0 +68 0 *
-Wi
-0101000
--67 0 -65 0 +63 0 +62 0 *
-Fa
-0  1e-07 1 0
-0111000
-+61 0 *
-Ve
-1e-07
-4 0 4
-0 0
-0101101
-Ve
-1e-07
-4 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 0 4
-2  9 6 0 0 4
-2  10 2 0 0 4
-0
-0101000
--59 0 +58 0 *
-Ve
-1e-07
-4 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  6 0 0 4
-2  11 6 0 0 4
-2  12 3 0 0 4
-0
-0101000
--56 0 +59 0 *
-Ve
-1e-07
-4 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  7 0 0 4
-2  13 6 0 0 4
-2  14 4 0 0 4
-0
-0101000
--56 0 +54 0 *
-Ed
- 1e-07 1 1 0
-1  8 0 0 4
-2  15 6 0 0 4
-2  16 5 0 0 4
-0
-0101000
--54 0 +58 0 *
-Wi
-0101000
--57 0 -55 0 +53 0 +52 0 *
-Fa
-0  1e-07 6 0
-0111000
-+51 0 *
-Ed
- 1e-07 1 1 0
-1  9 0 0 4
-2  17 2 0 0 4
-2  18 5 0 0 4
-0
-0101000
--58 0 +68 0 *
-Ed
- 1e-07 1 1 0
-1  10 0 0 4
-2  19 2 0 0 4
-2  20 3 0 0 4
-0
-0101000
--59 0 +69 0 *
-Wi
-0101000
--49 0 -57 0 +48 0 +67 0 *
-Fa
-0  1e-07 2 0
-0111000
-+47 0 *
-Ed
- 1e-07 1 1 0
-1  11 0 0 4
-2  21 4 0 0 4
-2  22 5 0 0 4
-0
-0101000
--54 0 +64 0 *
-Ed
- 1e-07 1 1 0
-1  12 0 0 4
-2  23 4 0 0 4
-2  24 3 0 0 4
-0
-0101000
--56 0 +66 0 *
-Wi
-0101000
--45 0 -53 0 +44 0 +63 0 *
-Fa
-0  1e-07 4 0
-0111000
-+43 0 *
-Wi
-0101000
--62 0 -45 0 +52 0 +49 0 *
-Fa
-0  1e-07 5 0
-0111000
-+41 0 *
-Wi
-0101000
--65 0 -44 0 +55 0 +48 0 *
-Fa
-0  1e-07 3 0
-0111000
-+39 0 *
-Sh
-0101100
--60 0 +50 0 -46 0 +42 0 -40 0 +38 0 *
-So
-0100000
-+37 0 *
-Ve
-1e-07
-0 0 1
-0 0
-0101101
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  13 0 0 1
-2  25 7 0 0 1
-2  26 8 0 0 1
-0
-0101000
--35 0 +34 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0 1
-2  27 7 0 0 1
-2  28 9 0 0 1
-0
-0101000
--32 0 +35 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  15 0 0 1
-2  29 7 0 0 1
-2  30 10 0 0 1
-0
-0101000
--32 0 +30 0 *
-Ed
- 1e-07 1 1 0
-1  16 0 0 1
-2  31 7 0 0 1
-2  32 11 0 0 1
-0
-0101000
--30 0 +34 0 *
-Wi
-0101000
--33 0 -31 0 +29 0 +28 0 *
-Fa
-0  1e-07 7 0
-0111000
-+27 0 *
-Ve
-1e-07
-1 0 1
-0 0
-0101101
-Ve
-1e-07
-1 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  17 0 0 1
-2  33 12 0 0 1
-2  34 8 0 0 1
-0
-0101000
--25 0 +24 0 *
-Ve
-1e-07
-1 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  18 0 0 1
-2  35 12 0 0 1
-2  36 9 0 0 1
-0
-0101000
--22 0 +25 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  19 0 0 1
-2  37 12 0 0 1
-2  38 10 0 0 1
-0
-0101000
--22 0 +20 0 *
-Ed
- 1e-07 1 1 0
-1  20 0 0 1
-2  39 12 0 0 1
-2  40 11 0 0 1
-0
-0101000
--20 0 +24 0 *
-Wi
-0101000
--23 0 -21 0 +19 0 +18 0 *
-Fa
-0  1e-07 12 0
-0111000
-+17 0 *
-Ed
- 1e-07 1 1 0
-1  21 0 0 1
-2  41 8 0 0 1
-2  42 11 0 0 1
-0
-0101000
--24 0 +34 0 *
-Ed
- 1e-07 1 1 0
-1  22 0 0 1
-2  43 8 0 0 1
-2  44 9 0 0 1
-0
-0101000
--25 0 +35 0 *
-Wi
-0101000
--15 0 -23 0 +14 0 +33 0 *
-Fa
-0  1e-07 8 0
-0111000
-+13 0 *
-Ed
- 1e-07 1 1 0
-1  23 0 0 1
-2  45 10 0 0 1
-2  46 11 0 0 1
-0
-0101000
--20 0 +30 0 *
-Ed
- 1e-07 1 1 0
-1  24 0 0 1
-2  47 10 0 0 1
-2  48 9 0 0 1
-0
-0101000
--22 0 +32 0 *
-Wi
-0101000
--11 0 -19 0 +10 0 +29 0 *
-Fa
-0  1e-07 10 0
-0111000
-+9 0 *
-Wi
-0101000
--28 0 -11 0 +18 0 +15 0 *
-Fa
-0  1e-07 11 0
-0111000
-+7 0 *
-Wi
-0101000
--31 0 -10 0 +21 0 +14 0 *
-Fa
-0  1e-07 9 0
-0111000
-+5 0 *
-Sh
-0101100
--26 0 +16 0 -12 0 +8 0 -6 0 +4 0 *
-So
-0100000
-+3 0 *
-Co
-1100000
-+36 1 +2 0 *
-+1 0
Deleted: cgm/trunk/test/unite5.occ
--- cgm/trunk/test/unite5.occ	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/unite5.occ	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,626 +0,0 @@
-Locations 2
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-2  1 -1 0
-Curve2ds 48
-1 0 0 1 0
-1 0 4 1 0
-1 4 0 0 -1
-1 4 0 0 1
-1 0 -4 1 0
-1 0 4 1 0
-1 0 0 0 -1
-1 4 0 0 1
-8 -1 0
-1 0 1 -1 0
-8 -1 0
-1 0 -0.5 -1 -0
-1 0 0 0 1
-1 0 0 1 0
-1 4 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-8 0 1
-1 1 0 0 1
-8 0 1
-1 0 0.5 1 0
-1 4 0 0 -1
-1 0 0 0 1
-1 4 0 0 1
-1 0 4 1 0
-1 0 0 0 1
-1 0 4 1 0
-1 0 -4 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 -1
-1 1 0 0 1
-1 0 0 0 1
-1 0 1 1 0
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 -1
-1 1 0 0 1
-1 0 -1 1 0
-1 0 0 1 0
-1 1 0 0 -1
-1 0 0 0 1
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-Curves 24
-1 4 0 0 0 0 1
-1 4 0 4 0 1 0
-1 4 4 0 0 0 1
-1 4 0 0 -0 1 0
-1 1 0.5 0 -0 0 -1
-1 0 0 0 1 0 -0
-1 0 0 4 1 0 -0
-1 0 0 0 0 0 1
-1 0 0.5 1 1 0 0
-1 0 0 4 -0 1 0
-1 0 4 4 1 0 -0
-1 0 4 0 1 0 -0
-1 0 4 0 0 0 1
-1 0 0 0 -0 1 0
-1 1 0 0 -0 1 0
-1 0 1 0 1 0 -0
-1 1 0 0 0 0 1
-1 1 0 1 0 1 0
-1 0 1 0 0 0 1
-1 0 0 1 -0 1 0
-1 0 0 1 1 0 -0
-1 0 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 0 0 0 0 0 1
-Polygon3D 0
-Surfaces 12
-Triangulations 0
-TShapes 76
-Ve
-1e-07
-4 0 4
-0 0
-0101101
-Ve
-1e-07
-4 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 4
-2  1 1 0 0 4
-2  2 2 0 0 4
-0
-0101000
--76 0 +75 0 *
-Ve
-1e-07
-4 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  2 0 0 4
-2  3 1 0 0 4
-2  4 3 0 0 4
-0
-0101000
--73 0 +76 0 *
-Ve
-1e-07
-4 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  3 0 0 4
-2  5 1 0 0 4
-2  6 4 0 0 4
-0
-0101000
--73 0 +71 0 *
-Ed
- 1e-07 1 1 0
-1  4 0 0 4
-2  7 1 0 0 4
-2  8 5 0 0 4
-0
-0101000
--71 0 +75 0 *
-Wi
-0101000
--74 0 -72 0 +70 0 +69 0 *
-Fa
-0  1e-07 1 0
-0111000
-+68 0 *
-Ve
-2.00001e-07
-1 0.5 1
-0 0
-0101101
-Ve
-1.24999999959086e-07
-1 0.500000025 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 -1 0
-2  9 2 1 -1 0
-2  10 6 0 -1 0
-0
-0101000
-+66 0 -65 0 *
-Ed
- 1e-07 1 1 0
-1  6 0 1 4
-2  11 2 0 1 4
-2  12 5 0 1 4
-0
-0101000
-+65 2 -75 0 *
-Ve
-1e-07
-0 0 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  7 0 0 4
-2  13 2 0 0 4
-2  14 3 0 0 4
-0
-0101000
--76 0 +62 0 *
-Ve
-0 0.500000025 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  8 0 1 4
-2  15 7 0 1 4
-2  16 2 0 1 4
-0
-0101000
-+60 2 -62 0 *
-Ed
- 1e-07 1 1 0
-1  9 0 0 1
-2  17 2 1 0 1
-2  18 8 0 0 1
-0
-0101000
-+60 0 -66 0 *
-Wi
-0101000
--64 0 -63 1 -74 1 +61 1 +59 1 -58 0 *
-Fa
-0  1e-07 2 1
-0101000
-+57 0 *
-Ve
-1e-07
-0 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  10 0 0 4
-2  19 7 0 0 4
-2  20 3 0 0 4
-0
-0101000
--55 0 +62 0 *
-Ed
- 1e-07 1 1 0
-1  11 0 0 4
-2  21 4 0 0 4
-2  22 3 0 0 4
-0
-0101000
--73 0 +55 0 *
-Wi
-0101000
--54 0 -53 0 +72 0 +61 0 *
-Fa
-0  1e-07 3 0
-0111000
-+52 0 *
-Ve
-1e-07
-0 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  12 0 0 4
-2  23 4 0 0 4
-2  24 5 0 0 4
-0
-0101000
--71 0 +50 0 *
-Ed
- 1e-07 1 1 0
-1  13 0 0 4
-2  25 7 0 0 4
-2  26 4 0 0 4
-0
-0101000
--55 0 +50 0 *
-Wi
-0101000
--49 0 -70 0 +53 0 +48 0 *
-Fa
-0  1e-07 4 0
-0111000
-+47 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0.5 4
-2  27 7 0 0.5 4
-2  28 5 0 0.5 4
-0
-0101000
-+45 2 -50 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  15 0 0.50000005 1
-2  29 6 0 0.50000005 1
-2  30 9 0 0.50000005 1
-0
-0101000
-+65 0 -43 0 *
-Ed
- 1e-07 1 1 0
-1  16 0 0 1
-2  31 10 0 0 1
-2  32 9 0 0 1
-0
-0101000
--43 0 +45 0 *
-Wi
-0101000
--44 1 -49 1 +69 1 +63 1 -42 0 +41 0 *
-Fa
-0  1e-07 5 1
-0101000
-+40 0 *
-Ve
-1e-07
-1 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  15 0 0 0.50000005
-2  29 6 0 0 0.50000005
-2  30 9 0 0 0.50000005
-0
-0101000
-+38 0 -65 0 *
-Ve
-1e-07
-1 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  17 0 0 1
-2  33 6 0 0 1
-2  34 11 0 0 1
-0
-0101000
--36 0 +38 0 *
-Ed
- 1e-07 1 1 0
-1  18 0 0 0.5
-2  35 6 0 0 0.5
-2  36 8 0 0 0.5
-0
-0101000
-+36 0 -66 0 *
-Wi
-0101000
--64 0 +37 0 -35 0 -34 0 *
-Fa
-0  1e-07 6 0
-0101000
-+33 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  19 0 0 1
-2  37 12 0 0 1
-2  38 10 0 0 1
-0
-0101000
--31 0 +45 0 *
-Ed
- 1e-07 1 1 0
-1  20 0 0.50000005 1
-2  39 12 0 0.50000005 1
-2  40 8 0 0.50000005 1
-0
-0101000
-+60 0 -31 0 *
-Wi
-0101000
--59 1 -54 1 +48 1 +44 1 -30 0 +29 0 *
-Fa
-0  1e-07 7 1
-0101000
-+28 0 *
-Ve
-1e-07
-0 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  21 0 0 1
-2  41 11 0 0 1
-2  42 8 0 0 1
-0
-0101000
--36 0 +26 0 *
-Ed
- 1e-07 1 1 0
-1  20 0 0 0.50000005
-2  39 12 0 0 0.50000005
-2  40 8 0 0 0.50000005
-0
-0101000
-+26 0 -60 0 *
-Wi
-0101000
--58 0 +34 0 +25 0 -24 0 *
-Fa
-0  1e-07 8 0
-0101000
-+23 0 *
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0 0.5
-2  27 7 0 0 0.5
-2  28 5 0 0 0.5
-0
-0101000
-+21 0 -45 2 *
-Ed
- 1e-07 1 1 0
-1  6 0 0 1
-2  11 2 0 0 1
-2  12 5 0 0 1
-0
-0101000
-+21 0 -65 2 *
-Wi
-0101000
--20 1 -41 0 +42 0 +19 1 *
-Fa
-0  1e-07 5 1
-0111000
-+18 0 *
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  22 0 0 0.5
-2  43 12 0 0 0.5
-2  44 9 0 0 0.5
-0
-0101000
-+16 0 -21 1 *
-Ed
- 1e-07 1 1 0
-1  23 0 0 1
-2  45 11 0 0 1
-2  46 9 0 0 1
-0
-0101000
--38 0 +16 0 *
-Wi
-0101000
--15 0 -19 1 +37 0 +14 0 *
-Fa
-0  1e-07 9 0
-0101000
-+13 0 *
-Ed
- 1e-07 1 1 0
-1  24 0 0 1
-2  47 12 0 0 1
-2  48 11 0 0 1
-0
-0101000
--26 0 +16 0 *
-Wi
-0101000
--14 0 -35 0 +25 0 +11 0 *
-Fa
-0  1e-07 11 0
-0111000
-+10 0 *
-Ed
- 1e-07 1 1 0
-1  8 0 0 1
-2  15 7 0 0 1
-2  16 2 0 0 1
-0
-0101000
-+21 0 -60 2 *
-Wi
-0101000
--8 1 -29 0 +30 0 +20 1 *
-Fa
-0  1e-07 7 1
-0111000
-+7 0 *
-Wi
-0101000
--24 0 +8 1 +15 0 -11 0 *
-Fa
-0  1e-07 12 0
-0101000
-+5 0 *
-Sh
-0101000
-+67 1 -56 0 +51 1 +46 1 -39 0 +32 0 -27 0 +22 0 -17 0 -12 0
--9 0 -6 0 -4 0 *
-So
-0100000
-+3 0 *
-Co
-1100000
-+2 0 *
-+1 0
Deleted: cgm/trunk/test/unite6.occ
--- cgm/trunk/test/unite6.occ	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/unite6.occ	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,626 +0,0 @@
-Locations 2
-1
-              1               0               0               0
-              0               1               0             0.5
-              0               0               1               0
-2  1 -1 0
-Curve2ds 48
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 1 1 0
-1 1 0 0 1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 0 1 0
-1 0 0 0 -1
-1 1 0 0 1
-1 1 0 0 -1
-1 1 0 0 1
-8 0 1
-1 0 -0.5 1 0
-8 0 1
-1 0 1 1 0
-1 1 0 0 -1
-1 0 0 0 1
-8 -1 0
-1 0 0.5 -1 0
-8 -1 0
-1 1 0 0 -1
-1 0 0 1 0
-1 0 0 1 0
-1 0 0 0 1
-1 0 1 1 0
-1 0 0 1 0
-1 0 4 1 0
-1 4 0 0 1
-1 0 0 1 0
-1 0 -1 1 0
-1 0 0 1 0
-1 0 0 0 -1
-1 0 0 0 1
-1 0 0 0 1
-1 0 4 1 0
-1 0 0 0 -1
-1 4 0 0 1
-1 4 0 0 -1
-1 4 0 0 1
-1 0 -4 1 0
-1 0 4 1 0
-1 4 0 0 -1
-1 0 0 0 1
-1 4 0 0 1
-1 0 4 1 0
-1 0 -4 1 0
-1 0 0 1 0
-Curves 24
-1 0 0 0 1 0 -0
-1 1 0 0 0 0 1
-1 0 0 1 1 0 -0
-1 0 0 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 0 0 1 0 -0
-1 1 0 0 -0 1 0
-1 1 0 1 0 1 0
-1 1 0.5 0 0 -0 1
-1 0 0 1 -0 1 0
-1 0 0.5 1 -1 0 0
-1 0 0 0 0 0 1
-1 0 1 0 1 0 -0
-1 4 0 0 0 0 1
-1 0 0 4 1 0 -0
-1 0 1 0 0 0 1
-1 0 0 0 -0 1 0
-1 0 4 0 1 0 -0
-1 4 0 0 -0 1 0
-1 4 0 4 0 1 0
-1 4 4 0 0 0 1
-1 0 0 4 -0 1 0
-1 0 4 4 1 0 -0
-1 0 4 0 0 0 1
-Polygon3D 0
-Surfaces 12
-Triangulations 0
-TShapes 76
-Ve
-1e-07
-1 0 0
-0 0
-0101101
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  1 0 0 1
-2  1 1 0 0 1
-2  2 2 0 0 1
-0
-0101000
--76 0 +75 0 *
-Ve
-1e-07
-1 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  2 0 0 1
-2  3 3 0 0 1
-2  4 1 0 0 1
-0
-0101000
--73 0 +76 0 *
-Ve
-1e-07
-0 0 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  3 0 0 1
-2  5 1 0 0 1
-2  6 4 0 0 1
-0
-0101000
--73 0 +71 0 *
-Ed
- 1e-07 1 1 0
-1  4 0 0 1
-2  7 5 0 0 1
-2  8 1 0 0 1
-0
-0101000
--71 0 +75 0 *
-Wi
-0101000
-Fa
-0  1e-07 1 0
-0111000
-+68 0 *
-Ve
-1e-07
-0 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 0 0.5
-2  9 5 0 0 0.5
-2  10 2 0 0 0.5
-0
-0101000
-+75 0 -66 1 *
-Ve
-1 0.500000025 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  6 0 0 1
-2  11 6 0 0 1
-2  12 7 0 0 1
-0
-0101000
-+66 0 -64 2 *
-Ed
- 1e-07 1 1 0
-1  7 0 0 0.50000005
-2  13 3 0 0 0.50000005
-2  14 2 0 0 0.50000005
-0
-0101000
-+76 0 -64 0 *
-Wi
-0101000
--65 0 -63 1 +62 0 +74 0 *
-Fa
-0  1e-07 2 0
-0101000
-+61 0 *
-Ve
-2.00001e-07
-1 0.5 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  8 0 0 0.5
-2  15 3 0 0 0.5
-2  16 4 0 0 0.5
-0
-0101000
-+73 0 -59 0 *
-Ed
- 1e-07 1 1 0
-1  9 0 0 1
-2  17 3 0 0 1
-2  18 6 1 0 1
-0
-0101000
-+64 0 -59 0 *
-Wi
-0101000
-+62 0 -72 0 -58 0 +57 0 *
-Fa
-0  1e-07 3 0
-0101000
-+56 0 *
-Ve
-0 0.500000025 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  10 0 0 0.50000005
-2  19 5 0 0 0.50000005
-2  20 4 0 0 0.50000005
-0
-0101000
-+71 0 -54 0 *
-Ed
- 1e-07 1 1 0
-1  11 0 -1 0
-2  21 4 0 -1 0
-2  22 6 1 -1 0
-0
-0101000
-+59 0 -54 0 *
-Wi
-0101000
-+58 0 +70 0 -53 0 +52 0 *
-Fa
-0  1e-07 4 0
-0101000
-+51 0 *
-Ed
- 1e-07 1 1 0
-1  12 0 0 1
-2  23 8 0 0 1
-2  24 6 0 0 1
-0
-0101000
-+66 0 -54 2 *
-Wi
-0101000
--53 0 +49 1 +65 0 -69 0 *
-Fa
-0  1e-07 5 0
-0101000
-+48 0 *
-Ve
-1e-07
-0 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  5 0 0.5 1
-2  9 5 0 0.5 1
-2  10 2 0 0.5 1
-0
-0101000
-+66 1 -46 0 *
-Ve
-1e-07
-1 1 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  13 0 0 1
-2  25 9 0 0 1
-2  26 2 0 0 1
-0
-0101000
--44 0 +46 0 *
-Ed
- 1e-07 1 1 0
-1  7 0 0.50000005 1
-2  13 3 0 0.50000005 1
-2  14 2 0 0.50000005 1
-0
-0101000
-+64 0 -44 0 *
-Wi
-0101000
--45 0 -43 0 +42 0 +63 1 *
-Fa
-0  1e-07 2 0
-0111000
-+41 0 *
-Ve
-1e-07
-4 0 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  6 0 1 4
-2  11 6 0 1 4
-2  12 7 0 1 4
-0
-0101000
-+64 2 -39 0 *
-Ve
-1e-07
-4 0 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  14 0 0 4
-2  27 10 0 0 4
-2  28 6 0 0 4
-0
-0101000
--37 0 +39 0 *
-Ve
-1e-07
-0 0 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  15 0 0 4
-2  29 6 0 0 4
-2  30 11 0 0 4
-0
-0101000
--37 0 +35 0 *
-Ed
- 1e-07 1 1 0
-1  12 0 1 4
-2  23 8 0 1 4
-2  24 6 0 1 4
-0
-0101000
-+54 2 -35 0 *
-Wi
-0101000
--38 1 -36 1 +34 1 +33 1 +52 0 +57 0 *
-Fa
-0  1e-07 6 1
-0101000
-+32 0 *
-Ve
-1e-07
-0 1 1
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  10 0 0.50000005 1
-2  19 5 0 0.50000005 1
-2  20 4 0 0.50000005 1
-0
-0101000
-+54 0 -30 0 *
-Ed
- 1e-07 1 1 0
-1  16 0 0 1
-2  31 5 0 0 1
-2  32 9 0 0 1
-0
-0101000
--30 0 +46 0 *
-Wi
-0101000
--29 0 +28 0 +45 0 -49 1 *
-Fa
-0  1e-07 5 0
-0111000
-+27 0 *
-Ve
-1e-07
-0 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  17 0 0.5 4
-2  33 8 0 0.5 4
-2  34 7 0 0.5 4
-0
-0101000
-+46 2 -25 0 *
-Ve
-1e-07
-4 4 0
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  18 0 0 4
-2  35 12 0 0 4
-2  36 7 0 0 4
-0
-0101000
--23 0 +25 0 *
-Ed
- 1e-07 1 1 0
-1  19 0 0 4
-2  37 10 0 0 4
-2  38 7 0 0 4
-0
-0101000
--23 0 +39 0 *
-Wi
-0101000
--24 1 -22 1 +21 1 +38 1 -42 0 +43 0 *
-Fa
-0  1e-07 7 1
-0101000
-+20 0 *
-Ve
-1e-07
-4 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  20 0 0 4
-2  39 10 0 0 4
-2  40 11 0 0 4
-0
-0101000
--18 0 +37 0 *
-Ed
- 1e-07 1 1 0
-1  21 0 0 4
-2  41 10 0 0 4
-2  42 12 0 0 4
-0
-0101000
--18 0 +23 0 *
-Wi
-0101000
--36 0 -17 0 +16 0 +21 0 *
-Fa
-0  1e-07 10 0
-0111000
-+15 0 *
-Ve
-1e-07
-0 4 4
-0 0
-0101101
-Ed
- 1e-07 1 1 0
-1  22 0 0 4
-2  43 8 0 0 4
-2  44 11 0 0 4
-0
-0101000
--13 0 +35 0 *
-Ed
- 1e-07 1 1 0
-1  23 0 0 4
-2  45 12 0 0 4
-2  46 11 0 0 4
-0
-0101000
--18 0 +13 0 *
-Wi
-0101000
--12 0 -11 0 +17 0 +34 0 *
-Fa
-0  1e-07 11 0
-0111000
-+10 0 *
-Ed
- 1e-07 1 1 0
-1  24 0 0 4
-2  47 8 0 0 4
-2  48 12 0 0 4
-0
-0101000
--13 0 +25 0 *
-Wi
-0101000
--33 1 -12 1 +8 1 +24 1 -28 0 +29 0 *
-Fa
-0  1e-07 8 1
-0101000
-+7 0 *
-Wi
-0101000
-Fa
-0  1e-07 12 0
-0111000
-+5 0 *
-Sh
-0101000
--67 0 -60 0 +55 0 +50 0 -47 0 -40 0 -31 0 -26 0 -19 0 +14 1
-+9 1 -6 0 +4 1 *
-So
-0100000
-+3 0 *
-Co
-1100000
-+2 0 *
-+1 0
Modified: cgm/trunk/test/webcut.cpp
--- cgm/trunk/test/webcut.cpp	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/webcut.cpp	2008-12-04 16:44:16 UTC (rev 2466)
@@ -162,7 +162,7 @@
   DLIList<RefEntity*> ref_entity_list;
   int num_ents_exported=0;
   const CubitString cubit_version="10.2";
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_brick.sat";
+  const char * filename = "webcut_with_brick.sat";
   const char * filetype = "ACIS_SAT";
   rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
                                  num_ents_exported, cubit_version);
@@ -213,7 +213,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "webcut_with_cylinder.sat";
+  const char * filename = "webcut_with_cylinder.sat";
@@ -266,7 +266,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sheet.sat";
+  const char * filename = "webcut_with_sheet.sat";
@@ -334,7 +334,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_rotational.sat";
+  const char * filename = "webcut_with_sweep_rotational.sat";
@@ -394,7 +394,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "webcut_with_sweep_curves.sat";
+  const char * filename = "webcut_with_sweep_curves.sat";
@@ -465,7 +465,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_along_curve.sat";
+  const char * filename = "webcut_with_sweep_along_curve.sat";
@@ -522,7 +522,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_curve_loop.sat";
+  const char * filename = "webcut_with_curve_loop.sat";
@@ -575,7 +575,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_extended_surf.sat";
+  const char * filename = "webcut_with_extended_surf.sat";
@@ -626,7 +626,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_rotated.sat";
+  const char * filename = "webcut_with_sweep_surfaces_rotated.sat";
@@ -676,7 +676,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces.sat";
+  const char * filename = "webcut_with_sweep_surfaces.sat";
@@ -736,7 +736,7 @@
-  const char * filename = STRINGIFY(SRCDIR) "/webcut_with_sweep_surfaces_along_curve.sat";
+  const char * filename = "webcut_with_sweep_surfaces_along_curve.sat";
Deleted: cgm/trunk/test/webcut_with_brick.sat
--- cgm/trunk/test/webcut_with_brick.sat	2008-12-04 16:23:02 UTC (rev 2465)
+++ cgm/trunk/test/webcut_with_brick.sat	2008-12-04 16:44:16 UTC (rev 2466)
@@ -1,233 +0,0 @@
-1600 0 2 0
-10 Cubit 10.2 17 ACIS 16.0.7 Linux 24 Wed Nov 26 13:51:34 2008
-1 9.9999999999999995e-07 1e-10
-body $-1 -1 -1 $-1 $2 $-1 $3 T 4 4 4 14 14 14 #
-body $-1 -1 -1 $-1 $4 $-1 $5 T 4 4 4 5 5 5 #
-lump $-1 -1 -1 $-1 $-1 $6 $0 T 4 4 4 14 14 14 #
-transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear #
-lump $-1 -1 -1 $-1 $-1 $7 $1 T 4 4 4 5 5 5 #
-shell $-1 -1 -1 $-1 $-1 $-1 $8 $-1 $2 T 4 4 4 14 14 14 #
-shell $-1 -1 -1 $-1 $-1 $-1 $9 $-1 $4 T 4 4 4 5 5 5 #
-face $-1 -1 -1 $-1 $10 $11 $6 $-1 $12 reversed single T 4 4 5 5 5 5 F #
-face $-1 -1 -1 $-1 $13 $14 $7 $-1 $15 forward single T 4 4 5 5 5 5 F #
-face $-1 -1 -1 $-1 $16 $17 $6 $-1 $18 forward single T 4 5 4 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $19 $8 T 4 4 5 5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 4.5 4.5 5 0 0 1 1 0 0 forward_v I I I I #
-face $-1 -1 -1 $-1 $20 $21 $7 $-1 $22 reversed single T 4 5 4 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $23 $9 T 4 4 5 5 5 5 unknown #
-face $-1 -1 -1 $-1 $24 $25 $6 $-1 $26 forward single T 5 4 4 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $27 $10 T 4 5 4 5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 4.5 5 4.5 0 -1 0 0 0 -1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $28 $29 $30 $31 reversed $11 $-1 #
-face $-1 -1 -1 $-1 $32 $33 $7 $-1 $34 reversed single T 5 4 4 5 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $35 $13 T 4 5 4 5 5 5 unknown #
-coedge $-1 -1 -1 $-1 $36 $37 $38 $39 forward $14 $-1 #
-face $-1 -1 -1 $-1 $40 $41 $6 $-1 $42 reversed single T 4 4 4 14 4 14 F #
-loop $-1 -1 -1 $-1 $-1 $43 $16 T 5 4 4 5 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 5 4.5 4.5 -1 0 0 0 0 1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $44 $45 $46 $47 reversed $17 $-1 #
-coedge $-1 -1 -1 $-1 $48 $19 $49 $50 reversed $11 $-1 #
-coedge $-1 -1 -1 $-1 $19 $48 $44 $51 reversed $11 $-1 #
-coedge $-1 -1 -1 $-1 $46 $43 $19 $31 forward $25 $-1 #
-edge $-1 -1 -1 $-1 $52 -0.5 $53 0.5 $30 $54 forward @7 unknown T 5 4 5 5 5 5 #
-face $-1 -1 -1 $-1 $55 $56 $7 $-1 $57 reversed single T 4 4 4 4 5 5 F #
-loop $-1 -1 -1 $-1 $-1 $58 $20 T 5 4 4 5 5 5 unknown #
-coedge $-1 -1 -1 $-1 $59 $60 $61 $62 forward $21 $-1 #
-coedge $-1 -1 -1 $-1 $63 $23 $60 $64 forward $14 $-1 #
-coedge $-1 -1 -1 $-1 $23 $63 $65 $66 forward $14 $-1 #
-coedge $-1 -1 -1 $-1 $58 $61 $23 $39 reversed $33 $-1 #
-edge $-1 -1 -1 $-1 $67 -0.5 $68 0.5 $38 $69 forward @7 unknown T 5 4 5 5 5 5 #
-face $-1 -1 -1 $-1 $70 $71 $6 $-1 $72 forward single T 4 4 14 14 14 14 F #
-loop $-1 -1 -1 $-1 $-1 $49 $24 T 4 4 4 14 4 14 unknown #
-plane-surface $-1 -1 -1 $-1 9 4 9 0 1 0 0 0 1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $30 $73 $74 $75 reversed $25 $-1 #
-coedge $-1 -1 -1 $-1 $76 $27 $29 $51 forward $17 $-1 #
-coedge $-1 -1 -1 $-1 $27 $76 $77 $78 reversed $17 $-1 #
-coedge $-1 -1 -1 $-1 $73 $30 $27 $47 forward $25 $-1 #
-edge $-1 -1 -1 $-1 $53 -0.5 $79 0.5 $46 $80 forward @7 unknown T 5 5 4 5 5 5 #
-coedge $-1 -1 -1 $-1 $29 $28 $81 $82 reversed $11 $-1 #
-coedge $-1 -1 -1 $-1 $74 $83 $28 $50 forward $41 $-1 #
-edge $-1 -1 -1 $-1 $84 -2.75 $52 -1.75 $49 $85 forward @7 unknown T 4 4 5 5 4 5 #
-edge $-1 -1 -1 $-1 $53 -0.5 $86 0.5 $44 $87 forward @7 unknown T 4 5 5 5 5 5 #
-vertex $-1 -1 -1 $-1 $50 $88 #
-vertex $-1 -1 -1 $-1 $31 $89 #
-straight-curve $-1 -1 -1 $-1 5 4.5 5 0 1 0 I I #
-face $-1 -1 -1 $-1 $90 $91 $7 $-1 $92 reversed single T 4 4 4 5 5 4 F #
-loop $-1 -1 -1 $-1 $-1 $93 $32 T 4 4 4 4 5 5 unknown #
-plane-surface $-1 -1 -1 $-1 4 9 9 1 0 0 0 0 -1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $94 $38 $95 $96 forward $33 $-1 #
-coedge $-1 -1 -1 $-1 $97 $35 $98 $99 forward $21 $-1 #
-coedge $-1 -1 -1 $-1 $35 $97 $36 $64 reversed $21 $-1 #
-coedge $-1 -1 -1 $-1 $38 $94 $35 $62 reversed $33 $-1 #
-edge $-1 -1 -1 $-1 $68 -0.5 $100 0.5 $61 $101 forward @7 unknown T 5 5 4 5 5 5 #
-coedge $-1 -1 -1 $-1 $37 $36 $93 $102 forward $14 $-1 #
-edge $-1 -1 -1 $-1 $68 -0.5 $103 0.5 $60 $104 forward @7 unknown T 4 5 5 5 5 5 #
-coedge $-1 -1 -1 $-1 $105 $95 $37 $66 reversed $106 $-1 #
-edge $-1 -1 -1 $-1 $107 -2.75 $67 -1.75 $65 $108 forward @7 unknown T 4 4 5 5 4 5 #
-vertex $-1 -1 -1 $-1 $66 $109 #
-vertex $-1 -1 -1 $-1 $39 $110 #
-face $-1 -1 -1 $-1 $111 $112 $6 $-1 $113 reversed single T 4 4 4 14 14 4 F #
-loop $-1 -1 -1 $-1 $-1 $114 $40 T 4 4 14 14 14 14 unknown #
-plane-surface $-1 -1 -1 $-1 9 9 14 0 0 1 1 0 0 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $43 $46 $115 $116 reversed $25 $-1 #
-coedge $-1 -1 -1 $-1 $117 $49 $43 $75 forward $41 $-1 #
-edge $-1 -1 -1 $-1 $52 1.75 $118 2.75 $74 $119 forward @7 unknown T 5 4 4 5 4 5 #
-coedge $-1 -1 -1 $-1 $45 $44 $120 $121 reversed $17 $-1 #
-coedge $-1 -1 -1 $-1 $122 $115 $45 $78 forward $112 $-1 #
-edge $-1 -1 -1 $-1 $79 1.75 $123 2.75 $77 $124 forward @7 unknown T 4 5 4 5 5 4 #
-vertex $-1 -1 -1 $-1 $78 $125 #
-straight-curve $-1 -1 -1 $-1 5 5 4.5 0 0 -1 I I #
-coedge $-1 -1 -1 $-1 $126 $120 $48 $82 forward $127 $-1 #
-edge $-1 -1 -1 $-1 $86 1.75 $84 2.75 $81 $128 forward @7 unknown T 4 4 5 4 5 5 #
-coedge $-1 -1 -1 $-1 $49 $129 $126 $130 forward $41 $-1 #
-vertex $-1 -1 -1 $-1 $50 $131 #
-straight-curve $-1 -1 -1 $-1 6.75 4 5 1 0 0 I I #
-vertex $-1 -1 -1 $-1 $82 $132 #
-straight-curve $-1 -1 -1 $-1 4.5 5 5 -1 0 0 I I #
-point $-1 -1 -1 $-1 5 4 5 #
-point $-1 -1 -1 $-1 5 5 5 #
-face $-1 -1 -1 $-1 $-1 $106 $7 $-1 $133 reversed single T 4 4 4 5 4 5 F #
-loop $-1 -1 -1 $-1 $-1 $98 $55 T 4 4 4 5 5 4 unknown #
-plane-surface $-1 -1 -1 $-1 9 9 4 0 0 1 1 0 0 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $134 $135 $63 $102 reversed $56 $-1 #
-coedge $-1 -1 -1 $-1 $61 $58 $136 $137 forward $33 $-1 #
-coedge $-1 -1 -1 $-1 $65 $138 $58 $96 reversed $106 $-1 #
-edge $-1 -1 -1 $-1 $67 1.75 $139 2.75 $95 $140 forward @7 unknown T 5 4 4 5 4 5 #
-coedge $-1 -1 -1 $-1 $60 $59 $134 $141 forward $21 $-1 #
-coedge $-1 -1 -1 $-1 $136 $142 $59 $99 reversed $91 $-1 #
-edge $-1 -1 -1 $-1 $100 1.75 $143 2.75 $98 $144 forward @7 unknown T 4 5 4 5 5 4 #
-vertex $-1 -1 -1 $-1 $99 $145 #
-edge $-1 -1 -1 $-1 $103 1.75 $107 2.75 $93 $146 forward @7 unknown T 4 4 5 4 5 5 #
-vertex $-1 -1 -1 $-1 $102 $147 #
-coedge $-1 -1 -1 $-1 $138 $65 $135 $148 forward $106 $-1 #
-loop $-1 -1 -1 $-1 $-1 $65 $90 T 4 4 4 5 4 5 unknown #
-vertex $-1 -1 -1 $-1 $148 $149 #
-face $-1 -1 -1 $-1 $150 $127 $6 $-1 $151 reversed single T 4 4 4 4 14 14 F #
-loop $-1 -1 -1 $-1 $-1 $77 $70 T 4 4 4 14 14 4 unknown #
-coedge $-1 -1 -1 $-1 $152 $153 $154 $155 forward $71 $-1 #
-coedge $-1 -1 -1 $-1 $77 $156 $73 $116 forward $112 $-1 #
-edge $-1 -1 -1 $-1 $118 -2.75 $79 -1.75 $115 $157 forward @7 unknown T 5 4 4 5 5 4 #
-coedge $-1 -1 -1 $-1 $158 $74 $156 $159 reversed $41 $-1 #
-vertex $-1 -1 -1 $-1 $75 $160 #
-straight-curve $-1 -1 -1 $-1 5 4 6.75 0 0 -1 I I #
-coedge $-1 -1 -1 $-1 $81 $161 $76 $121 forward $127 $-1 #
-edge $-1 -1 -1 $-1 $123 -2.75 $86 -1.75 $120 $162 forward @7 unknown T 4 5 4 4 5 5 #
-coedge $-1 -1 -1 $-1 $163 $77 $161 $164 forward $112 $-1 #
-vertex $-1 -1 -1 $-1 $164 $165 #
-straight-curve $-1 -1 -1 $-1 6.75 5 4 -1 0 0 I I #
-point $-1 -1 -1 $-1 5 5 4 #
-coedge $-1 -1 -1 $-1 $166 $81 $83 $130 reversed $127 $-1 #
-loop $-1 -1 -1 $-1 $-1 $81 $111 T 4 4 4 4 14 14 unknown #
-straight-curve $-1 -1 -1 $-1 4 6.75 5 0 -1 0 I I #
-coedge $-1 -1 -1 $-1 $83 $158 $153 $167 reversed $41 $-1 #
-edge $-1 -1 -1 $-1 $168 -5 $84 4 $126 $169 forward @7 unknown T 4 4 5 4 4 14 #
-point $-1 -1 -1 $-1 4 4 5 #
-point $-1 -1 -1 $-1 4 5 5 #
-coedge $-1 -1 -1 $-1 $170 $93 $97 $141 reversed $56 $-1 #
-coedge $-1 -1 -1 $-1 $93 $170 $105 $148 reversed $56 $-1 #
-coedge $-1 -1 -1 $-1 $171 $98 $94 $137 reversed $91 $-1 #
-edge $-1 -1 -1 $-1 $139 -2.75 $100 -1.75 $136 $172 forward @7 unknown T 5 4 4 5 5 4 #
-coedge $-1 -1 -1 $-1 $95 $105 $171 $173 reversed $106 $-1 #
-vertex $-1 -1 -1 $-1 $173 $174 #
-edge $-1 -1 -1 $-1 $143 -2.75 $103 -1.75 $134 $175 forward @7 unknown T 4 5 4 4 5 5 #
-coedge $-1 -1 -1 $-1 $98 $171 $170 $176 forward $91 $-1 #
-vertex $-1 -1 -1 $-1 $99 $177 #
-edge $-1 -1 -1 $-1 $107 4 $178 5 $135 $179 forward @7 unknown T 4 4 4 4 4 5 #
-face $-1 -1 -1 $-1 $180 $181 $6 $-1 $182 reversed single T 4 14 4 14 14 14 F #
-coedge $-1 -1 -1 $-1 $183 $114 $184 $185 forward $71 $-1 #
-coedge $-1 -1 -1 $-1 $114 $183 $129 $167 forward $71 $-1 #
-coedge $-1 -1 -1 $-1 $186 $187 $114 $155 reversed $188 $-1 #
-edge $-1 -1 -1 $-1 $189 -5 $190 5 $154 $191 forward @7 unknown T 14 4 14 14 14 14 #
-coedge $-1 -1 -1 $-1 $115 $192 $117 $159 forward $112 $-1 #
-straight-curve $-1 -1 -1 $-1 5 6.75 4 0 1 -0 I I #
-coedge $-1 -1 -1 $-1 $129 $117 $186 $193 reversed $41 $-1 #
-edge $-1 -1 -1 $-1 $194 -5 $118 4 $117 $195 forward @7 unknown T 5 4 4 14 4 4 #
-point $-1 -1 -1 $-1 5 4 4 #
-coedge $-1 -1 -1 $-1 $120 $196 $122 $164 reversed $127 $-1 #
-straight-curve $-1 -1 -1 $-1 4 5 6.75 -0 0 1 I I #
-coedge $-1 -1 -1 $-1 $192 $122 $197 $198 forward $112 $-1 #
-edge $-1 -1 -1 $-1 $123 -4 $199 5 $161 $200 forward @7 unknown T 4 5 4 4 14 4 #
-point $-1 -1 -1 $-1 4 5 4 #
-coedge $-1 -1 -1 $-1 $196 $126 $183 $201 reversed $127 $-1 #
-edge $-1 -1 -1 $-1 $168 -5 $189 5 $129 $202 forward @7 unknown T 4 4 14 14 4 14 #
-vertex $-1 -1 -1 $-1 $201 $203 #
-straight-curve $-1 -1 -1 $-1 4 4 9 0 0 -1 I I #
-coedge $-1 -1 -1 $-1 $135 $134 $142 $176 reversed $56 $-1 #
-coedge $-1 -1 -1 $-1 $142 $136 $138 $173 forward $91 $-1 #
-edge $-1 -1 -1 $-1 $139 4 $178 5 $138 $204 forward @7 unknown T 4 4 4 5 4 4 #
-edge $-1 -1 -1 $-1 $178 -5 $143 -4 $170 $205 forward @7 unknown T 4 4 4 4 5 4 #
-vertex $-1 -1 -1 $-1 $176 $206 #
-face $-1 -1 -1 $-1 $-1 $188 $6 $-1 $207 reversed single T 14 4 4 14 14 14 F #
-loop $-1 -1 -1 $-1 $-1 $208 $150 T 4 14 4 14 14 14 unknown #
-plane-surface $-1 -1 -1 $-1 9 14 9 0 -1 0 0 0 -1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $153 $152 $166 $201 forward $71 $-1 #
-coedge $-1 -1 -1 $-1 $208 $209 $152 $185 reversed $181 $-1 #
-edge $-1 -1 -1 $-1 $190 -5 $210 5 $184 $211 forward @7 unknown T 4 14 14 14 14 14 #
-coedge $-1 -1 -1 $-1 $212 $154 $158 $193 forward $188 $-1 #
-coedge $-1 -1 -1 $-1 $154 $212 $208 $213 reversed $188 $-1 #
-loop $-1 -1 -1 $-1 $-1 $186 $180 T 14 4 4 14 14 14 unknown #
-vertex $-1 -1 -1 $-1 $155 $214 #
-vertex $-1 -1 -1 $-1 $155 $215 #
-straight-curve $-1 -1 -1 $-1 14 9 14 0 1 0 I I #
-coedge $-1 -1 -1 $-1 $156 $163 $212 $216 forward $112 $-1 #
-edge $-1 -1 -1 $-1 $189 -5 $194 5 $186 $217 forward @7 unknown T 14 4 4 14 4 14 #
-vertex $-1 -1 -1 $-1 $193 $218 #
-straight-curve $-1 -1 -1 $-1 9 4 4 -1 0 0 I I #
-coedge $-1 -1 -1 $-1 $161 $166 $209 $219 forward $127 $-1 #
-coedge $-1 -1 -1 $-1 $209 $208 $163 $198 reversed $181 $-1 #
-edge $-1 -1 -1 $-1 $199 -5 $220 5 $197 $221 forward @7 unknown T 4 14 4 14 14 4 #
-vertex $-1 -1 -1 $-1 $198 $222 #
-straight-curve $-1 -1 -1 $-1 4 9 4 0 1 0 I I #
-edge $-1 -1 -1 $-1 $210 -5 $168 5 $166 $223 forward @7 unknown T 4 4 14 4 14 14 #
-straight-curve $-1 -1 -1 $-1 9 4 14 1 0 0 I I #
-point $-1 -1 -1 $-1 4 4 14 #
-point $-1 -1 -1 $-1 4 4 4 #
-plane-surface $-1 -1 -1 $-1 14 9 9 -1 0 0 0 0 1 forward_v I I I I #
-coedge $-1 -1 -1 $-1 $197 $184 $187 $213 forward $181 $-1 #
-coedge $-1 -1 -1 $-1 $184 $197 $196 $219 reversed $181 $-1 #
-vertex $-1 -1 -1 $-1 $185 $224 #
-straight-curve $-1 -1 -1 $-1 9 14 14 -1 0 0 I I #
-coedge $-1 -1 -1 $-1 $187 $186 $192 $216 reversed $188 $-1 #
-edge $-1 -1 -1 $-1 $190 -5 $220 5 $187 $225 forward @7 unknown T 14 14 4 14 14 14 #
-point $-1 -1 -1 $-1 14 4 14 #
-point $-1 -1 -1 $-1 14 14 14 #
-edge $-1 -1 -1 $-1 $220 -5 $194 5 $212 $226 forward @7 unknown T 14 4 4 14 14 4 #
-straight-curve $-1 -1 -1 $-1 14 4 9 0 0 -1 I I #
-point $-1 -1 -1 $-1 14 4 4 #
-edge $-1 -1 -1 $-1 $210 -5 $199 5 $209 $227 forward @7 unknown T 4 14 4 4 14 14 #
-vertex $-1 -1 -1 $-1 $216 $228 #
-straight-curve $-1 -1 -1 $-1 9 14 4 1 0 0 I I #
-point $-1 -1 -1 $-1 4 14 4 #
-straight-curve $-1 -1 -1 $-1 4 9 14 0 -1 0 I I #
-point $-1 -1 -1 $-1 4 14 14 #
-straight-curve $-1 -1 -1 $-1 14 14 9 0 0 -1 I I #
-straight-curve $-1 -1 -1 $-1 14 9 4 0 -1 0 I I #
-straight-curve $-1 -1 -1 $-1 4 14 9 0 0 -1 I I #
-point $-1 -1 -1 $-1 14 14 4 #
-End-of-ACIS-data
More information about the cgma-dev mailing list
