[cgma-dev] r2461 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Dec 3 16:32:31 CST 2008
Author: janehu
Date: 2008-12-03 16:32:31 -0600 (Wed, 03 Dec 2008)
New Revision: 2461
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Fix for get graphics for surfaces.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-03 22:01:38 UTC (rev 2460)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-12-03 22:32:31 UTC (rev 2461)
@@ -304,6 +304,7 @@
//needs to test that N1, N2, N3 index are starting from 0 to number_points-1
//otherwise needs to update either facetList or gPnts to make consistent.
//It's possible also that N's starting from 1.
+ int minN = 100;
for (int i = 0; i < triangles.Length(); i++)
Poly_Triangle triangle = triangles.Value( i );
@@ -311,9 +312,22 @@
triangle.Get(N1, N2, N3);
facetList[4 * i] = 3;
facetList[4 * i + 1] = N1;
+ minN = (minN < N1 ? minN : N1);
facetList[4 * i + 2] = N2;
+ minN = (minN < N2 ? minN : N2);
facetList[4 * i + 3] = N3;
+ minN = (minN < N3 ? minN : N3);
+ if(minN != 0)
+ //subtract the minN from the facetList for all i+1, i+2, i+3 points
+ for (int i = 0; i < triangles.Length(); i++)
+ facetList[4 * i + 1] -= minN;
+ facetList[4 * i + 2] -= minN;
+ facetList[4 * i + 3] -= minN;
g_mem->replace_facet_list( facetList, number_facets, number_facets);
TColgp_Array1OfPnt points(0, number_points-1);
More information about the cgma-dev
