[cgma-dev] r2292 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Dec 1 14:15:47 CST 2008
Author: janehu
Date: 2008-12-01 14:15:47 -0600 (Mon, 01 Dec 2008)
New Revision: 2292
Modified:
cgm/trunk/geom/OCC/OCCLump.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Fixed the problem of keeping old coedges undeleted problem for geometry operation that involves number of shells or loops to change.
Modified: cgm/trunk/geom/OCC/OCCLump.cpp
--- cgm/trunk/geom/OCC/OCCLump.cpp 2008-11-28 23:06:10 UTC (rev 2291)
+++ cgm/trunk/geom/OCC/OCCLump.cpp 2008-12-01 20:15:47 UTC (rev 2292)
@@ -458,6 +458,12 @@
shape2 = TopoDS::Shell(M2(1));
if(M2.Extent() == 1 && !shape.IsSame(shape2))
shape = shape2;
+ else if(M2.Extent() > 1)
+ shapes.Clear();
+ for(int jj = 0; jj < M2.Extent(); jj++)
+ shapes.Append(M2(jj));
else if(shapes.Extent() > 1)
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-11-28 23:06:10 UTC (rev 2291)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-12-01 20:15:47 UTC (rev 2292)
@@ -228,7 +228,7 @@
TopTools_ListIteratorOfListOfShape it;
it.Initialize(shapes);
- for(it; it.More(); it.Next())
+ for(; it.More(); it.Next())
shape = it.Value();
OCCQueryEngine::instance()->copy_attributes(*get_TopoDS_Shell(),
@@ -302,7 +302,7 @@
shape = it.Value();
OCCQueryEngine::instance()->copy_attributes(face, shape);
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-11-28 23:06:10 UTC (rev 2291)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-12-01 20:15:47 UTC (rev 2292)
@@ -865,7 +865,7 @@
if(shapes.Extent() == 0)
shapes.Assign(op->Generated(wire));
if(!new_surface.IsNull())
- TopExp::MapShapes(new_surface,TopAbs_WIRE, M2);
+ TopExp::MapShapes(new_surface,TopAbs_WIRE, M2);
else if(sp)
shapes.Assign(sp->DescendantShapes(wire));
@@ -879,6 +879,8 @@
if(!shape.IsSame(shape2))
shape = shape2;
+ shape.Nullify();
shape.Nullify();
More information about the cgma-dev
