[cgma-dev] CGMA check for *64* failed.
Nightly Test kraftche at cae.wisc.edu
Mon Aug 18 12:00:05 CDT 2008
../.libs/libcgm.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry':
/home/jason/cgm/test/64/itaps/../../trunk/itaps/iGeom_CGMA.cc:5794: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
/usr/bin/ld: warning: libstdc++.so.5, needed by /opt/acis16.7/bin/linux_amd_64_so/libSpaAVis.so, may conflict with libstdc++.so.6
In file included from /opt/occ6.2/ros/inc/TCollection_AsciiString.hxx:752,
                 from /opt/occ6.2/ros/inc/TDF_LabelNode.hxx:16,
                 from /opt/occ6.2/ros/inc/TDF_Label.lxx:11,
                 from /opt/occ6.2/ros/inc/TDF_Label.hxx:345,
                 from ../../trunk/geom/OCC/OCCQueryEngine.hpp:29,
                 from ../../trunk/test/makept.cpp:12:
/opt/occ6.2/ros/inc/TCollection_AsciiString.lxx: In member function ‘TCollection_AsciiString TCollection_AsciiString::SubString(Standard_Integer, Standard_Integer) const’:
/opt/occ6.2/ros/inc/TCollection_AsciiString.lxx:112: warning: deprecated conversion from string constant to ‘char*’
                 from ../../trunk/test/modify.cpp:13:
                 from ../../trunk/test/r_w.cpp:13:
../../trunk/test/webcut.cpp: In function ‘int main(int, char**)’:
../../trunk/test/webcut.cpp:67: warning: unused variable ‘gti’
../../trunk/test/webcut.cpp: In function ‘CubitStatus read_geometry(int, char**)’:
../../trunk/test/webcut.cpp:118: warning: unused variable ‘file_ptr’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_brick()’:
../../trunk/test/webcut.cpp:139: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_cylinder()’:
../../trunk/test/webcut.cpp:194: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_planar_sheet()’:
../../trunk/test/webcut.cpp:245: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_curves_rotated()’:
../../trunk/test/webcut.cpp:299: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_curves()’:
../../trunk/test/webcut.cpp:365: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_along_curve()’:
../../trunk/test/webcut.cpp:425: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_curve_loop()’:
../../trunk/test/webcut.cpp:496: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_extended_surf()’:
../../trunk/test/webcut.cpp:553: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_rotated()’:
../../trunk/test/webcut.cpp:600: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces()’:
../../trunk/test/webcut.cpp:651: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_along_curve()’:
../../trunk/test/webcut.cpp:701: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/webcut.cpp: In function ‘CubitStatus webcut_with_sweep_surfaces_perp()’:
../../trunk/test/webcut.cpp:761: warning: deprecated conversion from string constant to ‘char*’
                 from ../../trunk/test/sheet.cpp:27:
../../trunk/test/sheet.cpp: In function ‘int main(int, char**)’:
../../trunk/test/sheet.cpp:38: warning: unused variable ‘gqe_list’
../../trunk/test/makept.cpp: In function ‘CubitStatus make_Point()’:
../../trunk/test/makept.cpp:118: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/makept.cpp:122: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/makept.cpp:126: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/makept.cpp:266: warning: unused variable ‘d’
../../trunk/test/makept.cpp:183: warning: unused variable ‘is_equal’
../../trunk/test/makept.cpp:271: warning: unused variable ‘new_face2’
../../trunk/test/makept.cpp:312: warning: unused variable ‘area’
../../trunk/test/makept.cpp:351: warning: unused variable ‘pc2’
../../trunk/test/makept.cpp:355: warning: unused variable ‘num_loops’
../../trunk/test/makept.cpp:360: warning: unused variable ‘angle’
../../trunk/test/modify.cpp: In function ‘CubitStatus make_Point()’:
../../trunk/test/modify.cpp:196: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/modify.cpp:119: warning: unused variable ‘ref’
../../trunk/test/modify.cpp:166: warning: unused variable ‘gme’
../../trunk/test/modify.cpp:167: warning: unused variable ‘stitched_body’
../../trunk/test/modify.cpp:489: warning: unused variable ‘occ_bodies’
../../trunk/test/r_w.cpp: In function ‘CubitStatus make_Point()’:
../../trunk/test/r_w.cpp:128: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/r_w.cpp:155: warning: deprecated conversion from string constant to ‘char*’
../../trunk/test/r_w.cpp:177: warning: unused variable ‘d’
../../trunk/test/r_w.cpp:179: warning: unused variable ‘n’
terminate called after throwing an instance of 'Standard_TypeMismatch'
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make: *** [check-recursive] Error 1
 gLoad: Read 1 ACIS Entities from the input file
Constructed 1 Volume: 1
Model contents:
vertices: 36
edges: 60
faces: 33
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 3
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 10
Destroyed volume(s): 11
Updated volume(s): 12
Destroyed volume(s): 13
Success
TSTT TEST SUMMARY:
   Number Tests:           8
   Number Successful:      8
   Number Not Implemented: 0
   Number Failed:          0
PASS: testgeom
All 1 tests passed
make[3]: Leaving directory `/home/jason/cgm/test/64/itaps'
make[2]: Leaving directory `/home/jason/cgm/test/64/itaps'
make[1]: Leaving directory `/home/jason/cgm/test/64/itaps'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/64'
make[1]: Leaving directory `/home/jason/cgm/test/64'
Making check in test
make[1]: Entering directory `/home/jason/cgm/test/64/test'
make  sheet webcut modify makept r_w
make[2]: Entering directory `/home/jason/cgm/test/64/test'
if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC   -Wall -pipe -g -MT sheet.o -MD -MP -MF ".deps/sheet.Tpo" -c -o sheet.o ../../trunk/test/sheet.cpp; \
	then mv -f ".deps/sheet.Tpo" ".deps/sheet.Po"; else rm -f ".deps/sheet.Tpo"; exit 1; fi
if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC   -Wall -pipe -g -MT webcut.o -MD -MP -MF ".deps/webcut.Tpo" -c -o webcut.o ../../trunk/test/webcut.cpp; \
	then mv -f ".deps/webcut.Tpo" ".deps/webcut.Po"; else rm -f ".deps/webcut.Tpo"; exit 1; fi
if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC   -Wall -pipe -g -MT modify.o -MD -MP -MF ".deps/modify.Tpo" -c -o modify.o ../../trunk/test/modify.cpp; \
	then mv -f ".deps/modify.Tpo" ".deps/modify.Po"; else rm -f ".deps/modify.Tpo"; exit 1; fi
if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC   -Wall -pipe -g -MT makept.o -MD -MP -MF ".deps/makept.Tpo" -c -o makept.o ../../trunk/test/makept.cpp; \
	then mv -f ".deps/makept.Tpo" ".deps/makept.Po"; else rm -f ".deps/makept.Tpo"; exit 1; fi
if c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -DHAVE_ACIS  -I. -I../../trunk/test -I.. -I../itaps -I../../trunk/geom -I../../trunk/util -I../../trunk/geom/ACIS -I../../trunk/geom/virtual -I../../trunk/geom/facet -I../../trunk/geom/Cholla -I../../trunk/geom/OCC -I../../trunk/test -I/opt/occ6.2/ros/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DSRCDIR=../../trunk/test -DHAVE_ACIS -DHAVE_OCC   -Wall -pipe -g -MT r_w.o -MD -MP -MF ".deps/r_w.Tpo" -c -o r_w.o ../../trunk/test/r_w.cpp; \
	then mv -f ".deps/r_w.Tpo" ".deps/r_w.Po"; else rm -f ".deps/r_w.Tpo"; exit 1; fi
/bin/sh ../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o sheet  -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib sheet.o ../libcgm.la -lm
/bin/sh ../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o webcut  -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib webcut.o ../libcgm.la -lm
mkdir .libs
/bin/sh ../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o r_w  -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib r_w.o ../libcgm.la -lm
/bin/sh ../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o makept  -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib makept.o ../libcgm.la -lm
/bin/sh ../libtool --tag=CXX --mode=link c++  -Wall -pipe -g   -o modify  -R/opt/acis16.7/bin/linux_amd_64_so -R/opt/occ6.2/ros/Linux/lib modify.o ../libcgm.la -lm
c++ -Wall -pipe -g -o r_w r_w.o  ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenCascade!
 6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib
c++ -Wall -pipe -g -o sheet sheet.o  ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenCas!
 cade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib
c++ -Wall -pipe -g -o webcut webcut.o  ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC!
 ascade6.2/ros/lin/lib/libTKCDF.so /opt/OpenCascade6.2/ros/lin/lib/libTKTopAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomAlgo.so /opt/OpenCascade6.2/ros/lin/lib/libTKBRep.so /opt/OpenCascade6.2/ros/lin/lib/libTKGeomBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKG3d.so /opt/OpenCascade6.2/ros/lin/lib/libTKG2d.so /opt/OpenCascade6.2/ros/lin/lib/libTKMath.so /opt/OpenCascade6.2/ros/lin/lib/libTKernel.so -ldl -lpthread -lieee -lm -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/OpenCascade6.2/ros/lin/lib -Wl,--rpath -Wl,/opt/acis16.7/bin/linux_amd_64_so -Wl,--rpath -Wl,/opt/occ6.2/ros/Linux/lib
c++ -Wall -pipe -g -o makept makept.o  ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC!
c++ -Wall -pipe -g -o modify modify.o  ../.libs/libcgm.a -L/opt/acis16.7/bin/linux_amd_64_so -L/opt/occ6.2/ros/Linux/lib -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase /opt/OpenCascade6.2/ros/lin/lib/libTKFeat.so /opt/OpenCascade6.2/ros/lin/lib/libTKHLR.so /opt/OpenCascade6.2/ros/lin/lib/libTKIGES.so /opt/OpenCascade6.2/ros/lin/lib/libTKOffset.so /opt/OpenCascade6.2/ros/lin/lib/libTKFillet.so /opt/OpenCascade6.2/ros/lin/lib/libTKBool.so /opt/OpenCascade6.2/ros/lin/lib/libTKBO.so /opt/OpenCascade6.2/ros/lin/lib/libTKPrim.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPAttr.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEP209.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTEPBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKSTL.so /opt/OpenCascade6.2/ros/lin/lib/libTKMesh.so /opt/OpenCascade6.2/ros/lin/lib/libTKXSBase.so /opt/OpenCascade6.2/ros/lin/lib/libTKShHealing.so /opt/OpenCascade6.2/ros/lin/lib/libTKLCAF.so /opt/OpenC!
make[2]: Leaving directory `/home/jason/cgm/test/64/test'
make  check-TESTS
Success (16AcisModifyEngine)
Success (15OCCModifyEngine)
PASS: sheet
      Creating the new (webcut) volumes...
Created volume(s): 2
Exported:   2 Volumes
Constructed 1 Volume: 3
Created volume(s): 4
Updated volume(s): 3
Exported:   2 Volumes
Constructed 1 Volume: 5
Created volume(s): 6
Updated volume(s): 5
Exported:   2 Volumes
Read 3 ACIS Entities from the input file
Constructed 1 Volume: 7
Constructed 2 Free Curves: 4457, 4458
Created volume(s): 8
Updated volume(s): 7
CPU time taken to WEBCUT this body: 5.410000 secs
Exported:   2 Volumes
            2 Curves
Constructed 1 Volume: 9
Constructed 2 Free Curves: 5296, 5297
Created volume(s): 10
Updated volume(s): 9
Exported:   2 Volumes
            2 Curves
Constructed 1 Volume: 11
Constructed 2 Free Curves: 5322, 5323
Created volume(s): 12
Updated volume(s): 11
Exported:   2 Volumes
            2 Curves
Read 5 ACIS Entities from the input file
Constructed 1 Volume: 13
Constructed 4 Free Curves: 5348 to 5351
Created volume(s): 14
Updated volume(s): 13
Exported:   2 Volumes
            4 Curves
Read 2 ACIS Entities from the input file
Constructed 2 Volumes: 15, 16
Created volume(s): 17
Updated volume(s): 15
Exported:   3 Volumes
Constructed 2 Volumes: 18, 19
Created volume(s): 20
Updated volume(s): 18
Exported:   3 Volumes
Constructed 2 Volumes: 21, 22
Created volume(s): 23
Updated volume(s): 21
Exported:   3 Volumes
Constructed 2 Volumes: 24, 25
Created volume(s): 26
Updated volume(s): 24
Exported:   3 Volumes
Constructed 2 Volumes: 27, 28
Created volume(s): 29
Updated volume(s): 27
Exported:   3 Volumes
PASS: webcut
Destroyed volume(s): 2 to 7
Exported:   1 OCC Body
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
WARNING: WARNING: Edge found with zero arclength
  For cones, this may be normal.
FAIL: modify
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Constructed 1 Volume: 2
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding solids.
Adding shells.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding loops.
Adding edges.
Adding vertices.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding edges.
Adding vertices.
Adding loops.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding edges.
Adding vertices.
Adding edges.
Adding faces.
Adding loops.
Adding faces.
Adding loops.
Constructed 2 Volumes: 3, 4
Created volume(s): 5 to 8
Exported:   5 OCC Bodies
            3 OCC Points
Exported:   2 OCC Bodies
            3 OCC Points
PASS: makept
ERROR: Problems reading geometry file ./stitch.occ_name.
FAIL: r_w
2 of 5 tests failed
make[2]: Leaving directory `/home/jason/cgm/test/64/test'
make[1]: Leaving directory `/home/jason/cgm/test/64/test'
More information about the cgma-dev mailing list
