[cgma-dev] CGMA check for *32* failed.
Nightly Test kraftche at cae.wisc.edu
Mon Aug 18 02:01:22 CDT 2008
In file included from /opt/acis16-32bit/include/base.hxx:55,
                 from /opt/acis16-32bit/include/acis.hxx:12,
                 from /opt/acis16-32bit/include/meshmg.hxx:14,
                 from ../../../trunk/geom/ACIS/AcisFacetManager.hpp:15,
                 from ../../../trunk/geom/ACIS/AcisFacetManager.cpp:9:
/opt/acis16-32bit/include/mmgr.hxx:354:17: error: new.h: No such file or directory
In file included from /opt/acis16-32bit/include/api.hxx:24,
                 from ../../../trunk/geom/ACIS/AcisBridge.cpp:18:
/opt/acis16-32bit/include/api.hxx:362:1: warning: multi-line comment
                 from /opt/acis16-32bit/include/err_info.hxx:20,
                 from /opt/acis16-32bit/include/errorbase.hxx:42,
                 from /opt/acis16-32bit/include/errorsys.hxx:12,
                 from /opt/acis16-32bit/include/api.hxx:32,
In file included from ../../../trunk/geom/ACIS/AcisBridge.cpp:18:
                 from ../../../trunk/geom/ACIS/AcisSurfaceTool.cpp:54:
                 from ../../../trunk/geom/ACIS/AcisSurfaceTool.cpp:55:
In file included from ../../../trunk/geom/ACIS/AcisSurfaceTool.cpp:55:
                 from /opt/acis16-32bit/include/method.hxx:23,
                 from /opt/acis16-32bit/include/entity.hxx:31,
                 from /opt/acis16-32bit/include/tophdr.hxx:21,
                 from /opt/acis16-32bit/include/edge.hxx:59,
                 from ../../../trunk/geom/ACIS/CurveACIS.hpp:26,
                 from ../../../trunk/geom/ACIS/AcisFeatureEngine.cpp:16:
                 from ../../../trunk/geom/ACIS/AcisQueryEngine.cpp:42:
                 from /opt/acis16-32bit/include/cstrapi.hxx:62,
                 from ../../../trunk/geom/ACIS/AcisQueryEngine.cpp:44:
In file included from /opt/acis16-32bit/include/cstrapi.hxx:62,
In file included from ../../../trunk/geom/ACIS/AcisQueryEngine.cpp:47:
In file included from /opt/acis16-32bit/include/chk_stat.hxx:15,
                 from ../../../trunk/geom/ACIS/AcisQueryEngine.cpp:81:
/opt/acis16-32bit/include/bsf.hxx:84:1: warning: multi-line comment
                 from /opt/acis16-32bit/include/transf.hxx:23,
                 from ../../../trunk/geom/ACIS/BodyACIS.hpp:26,
                 from ../../../trunk/geom/ACIS/AcisToolUtil.cpp:27:
/opt/acis16-32bit/include/mmgr.hxx:96: warning: 'alloc_file_index' defined but not used
                 from /opt/acis16-32bit/include/kernapi.hxx:24,
                 from ../../../trunk/geom/ACIS/AcisEdgeTool.cpp:17:
                 from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:37:
make[3]: *** [AcisFacetManager.lo] Error 1
make[3]: *** Waiting for unfinished jobs....
                 from /opt/acis16-32bit/include/kernapi.hxx:25,
                 from /opt/acis16-32bit/include/operapi.hxx:38,
                 from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:39:
In file included from /opt/acis16-32bit/include/kernapi.hxx:25,
In file included from /opt/acis16-32bit/include/operapi.hxx:38,
In file included from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:96:
In file included from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:98:
/opt/acis16-32bit/include/sweepapi.hxx:598:1: warning: "/*" within comment
                 from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:173:
In file included from ../../../trunk/geom/ACIS/AcisQueryEngine.cpp:81:
/opt/acis16-32bit/include/chk_stat.hxx: In constructor 'check_fix::check_fix(int)':
/opt/acis16-32bit/include/chk_stat.hxx:450: warning: 'check_fix::_fix_mask' will be initialized after
/opt/acis16-32bit/include/chk_stat.hxx:427: warning:   'double check_fix::_interior_vertices'
/opt/acis16-32bit/include/chk_stat.hxx:460: warning:   when initialized here
make[3]: *** [AcisBridge.lo] Error 1
make[3]: *** [AcisFeatureEngine.lo] Error 1
../../../trunk/geom/ACIS/AcisEdgeTool.cpp: In member function 'CubitStatus AcisEdgeTool::create_curve_combine(DLIList<Curve*>&, Curve*&)':
../../../trunk/geom/ACIS/AcisEdgeTool.cpp:67: warning: unused variable 'AQE'
../../../trunk/geom/ACIS/AcisEdgeTool.cpp:68: warning: unused variable 'GQT'
In file included from ../../../trunk/geom/ACIS/AcisModifyEngine.cpp:173:
make[3]: *** [AcisToolUtil.lo] Error 1
/opt/acis16-32bit/include/mmgr.hxx: At global scope:
make[3]: *** [AcisEdgeTool.lo] Error 1
../../../trunk/geom/ACIS/AcisQueryEngine.cpp: In member function 'virtual CubitStatus AcisQueryEngine::import_solid_model(const char*, const char*, DLIList<TopologyBridge*>&, CubitBoolean, const char*, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean)':
../../../trunk/geom/ACIS/AcisQueryEngine.cpp:827: warning: unused variable 'i'
../../../trunk/geom/ACIS/AcisQueryEngine.cpp: In member function 'CubitStatus AcisQueryEngine::restore_entity_list(ENTITY_LIST&, DLIList<TopologyBridge*>&, bool, bool, bool, bool, bool, bool, bool, bool) const':
../../../trunk/geom/ACIS/AcisQueryEngine.cpp:986: warning: unused variable 'percent_after'
../../../trunk/geom/ACIS/AcisQueryEngine.cpp:987: warning: unused variable 'number_splines_simplified'
make[3]: *** [AcisSurfaceTool.lo] Error 1
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'virtual CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:7406: warning: deprecated conversion from string constant to 'char*'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:7421: warning: deprecated conversion from string constant to 'char*'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'virtual CubitStatus AcisModifyEngine::section(DLIList<BodySM*>&, const CubitVector&, const CubitVector&, const CubitVector&, DLIList<BodySM*>&, bool, bool, bool)':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:9645: warning: unused variable 'ref_entity'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'void AcisModifyEngine::webcut_imprint(BODY*, DLIList<BodySM*>&, DLIList<BODY*>&, DLIList<BODY*>&, DLIList<BodySM*>&, DLIList<BodySM*>&, DLIList<BODY*>&) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:11098: warning: unused variable 'webcut_debug_flag_on'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'BODY* AcisModifyEngine::create_infinite_plane_cutting_tool(const CubitVector&, const CubitVector&, const CubitVector&, const SPAbox&, bool) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:11379: warning: suggest explicit braces to avoid ambiguous 'else'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:11544: warning: suggest explicit bramake[3]: Leaving directory `/home/jason/cgm/test/32/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/32/geom'
make[1]: Leaving directory `/home/jason/cgm/test/32'
ifyEngine.cpp: In member function 'virtual CubitStatus AcisModifyEngine::create_solid_bodies_from_surfs(DLIList<Surface*>&, DLIList<BodySM*>&, bool, bool) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:11838: warning: unused variable 'success'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'virtual CubitStatus AcisModifyEngine::imprint(DLIList<BodySM*>&, DLIList<CubitVector*>&, DLIList<BodySM*>&, bool, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:12999: warning: deprecated conversion from string constant to 'char*'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:13006: warning: deprecated conversion from string constant to 'char*'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'CubitStatus AcisModifyEngine::imprint_overlapping_curves(DLIList<BodySM*>&, DLIList<BodySM*>&, ProgressTool*, DLIList<TopologyBridge*>*, DLIList<TopologyBridge*>*) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:14920: warning: unused variable 'status'
../../../trunk/geom/ACIS/AcisModifyEngine.cpp: In member function 'CubitStatus AcisModifyEngine::imprint_overlapping_surfaces(DLIList<BodySM*>&, DLIList<BodySM*>&, ProgressTool*) const':
../../../trunk/geom/ACIS/AcisModifyEngine.cpp:14944: warning: unused variable 'status'
make[3]: *** [AcisQueryEngine.lo] Error 1
make[3]: *** [AcisModifyEngine.lo] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
More information about the cgma-dev mailing list
