[cgma-dev] MOAB distcheck failed.
Nightly Test
kraftche at cae.wisc.edu
Sun Aug 17 02:01:15 CDT 2008
../../util/ArrayBasedContainer.cpp: In member function 'ArrayBasedContainer& ArrayBasedContainer::operator=(const ArrayBasedContainer&)':
../../util/ArrayBasedContainer.cpp:143: warning: suggest explicit braces to avoid ambiguous 'else'
../../util/CubitMessage.cpp: In static member function 'static void CubitMessage::initialize_settings()':
../../util/CubitMessage.cpp:795: warning: deprecated conversion from string constant to 'char*'
../../util/CubitMessage.cpp:803: warning: deprecated conversion from string constant to 'char*'
../../util/CubitMessage.cpp:807: warning: deprecated conversion from string constant to 'char*'
../../util/CubitVector.cpp: In member function 'CubitBoolean CubitVector::within_scaled_tolerance(const CubitVector&, double) const':
../../util/CubitVector.cpp:350: warning: suggest parentheses around comparison in operand of ==
../../util/CubitVector.cpp:351: warning: suggest parentheses around comparison in operand of ==
../../util/CubitVector.cpp:352: warning: suggest parentheses around comparison in operand of ==
../../util/CubitString.cpp: In constructor 'CubitString::CubitString()':
../../util/CubitString.cpp:117: warning: unused variable 'dummy'
../../util/CubitString.cpp: In constructor 'CubitString::CubitString(const char*)':
../../util/CubitString.cpp:139: warning: unused variable 'dummy'
../../util/ParamCubitPlane.cpp: In member function 'void ParamCubitPlane::make_parameterization()':
../../util/ParamCubitPlane.cpp:108: warning: unused variable 's'
../../util/MemoryManager.cpp: In static member function 'static void MemoryManager::show_object_memory(const char*)':
../../util/MemoryManager.cpp:230: warning: format '%d' expects type 'int', but argument 3 has type 'size_t'
../../util/MemoryManager.cpp:232: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
../../util/MemoryManager.cpp:237: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
../../util/MemoryManager.cpp:240: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
../../util/MemoryManager.cpp: In static member function 'static void MemoryManager::show_all_object_memory()':
../../util/MemoryManager.cpp:297: warning: format '%d' expects type 'int', but argument 3 has type 'size_t'
../../util/SettingHandler.cpp: In member function 'void SettingHandler::save_settings()':
../../util/SettingHandler.cpp:222: warning: deprecated conversion from string constant to 'char*'
../../geom/BoundingBoxTool.cpp: In static member function 'static void BoundingBoxTool::initialize_settings()':
../../geom/BoundingBoxTool.cpp:380: warning: deprecated conversion from string constant to 'char*'
../../geom/BoundingBoxTool.cpp:384: warning: deprecated conversion from string constant to 'char*'
../../geom/BoundingBoxTool.cpp:388: warning: deprecated conversion from string constant to 'char*'
../../geom/CAEntityId.cpp: In constructor 'CAEntityId::CAEntityId(RefEntity*, CubitSimpleAttrib*)':
../../geom/CAEntityId.cpp:64: warning: unused variable 'edge'
../../geom/CubitAttribManager.cpp: In member function 'CubitStatus CubitAttribManager::register_attrib_type(int, const char*, const char*, CubitAttrib* (*)(RefEntity*, CubitSimpleAttrib*), CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean, CubitBoolean)':
../../geom/CubitAttribManager.cpp:82: warning: unused variable 'size'
../../geom/CubitAttribUser.cpp: In member function 'CubitStatus CubitAttribUser::remove_cubit_attrib(CubitAttrib*)':
../../geom/CubitAttribUser.cpp:786: warning: suggest explicit braces to avoid ambiguous 'else'
../../geom/CubitPolygon.cpp: In member function 'CubitPointContainment CubitPolygon::pnt_containment(Cubit2DPoint&, double)':
../../geom/CubitPolygon.cpp:95: warning: suggest parentheses around && within ||
../../geom/CubitSimpleAttrib.cpp: In static member function 'static void CubitSimpleAttrib::initialize_settings()':
../../geom/CubitSimpleAttrib.cpp:339: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp: In static member function 'static void GeometryModifyTool::initialize_settings()':
../../geom/GeometryModifyTool.cpp:3555: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp:3559: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp:3563: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp:3567: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp:3571: warning: deprecated conversion from string constant to 'char*'
../../geom/GeomMeasureTool.cpp: In static member function 'static void GeomMeasureTool::report_intersected_volumes(DLIList<RefVolume*>&, DLIList<RefVolume*>&)':
../../geom/GeomMeasureTool.cpp:1182: warning: unused variable 'curr_vol_2'
../../geom/GeometryQueryTool.cpp: In static member function 'static void GeometryQueryTool::initialize_settings()':
../../geom/GeometryQueryTool.cpp:2456: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryQueryTool.cpp:2460: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryQueryTool.cpp:2464: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryQueryTool.cpp:2468: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryQueryTool.cpp: In member function 'CubitStatus GeometryQueryTool::get_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)':
../../geom/GeometryQueryTool.cpp:2997: warning: unused variable 'status'
../../geom/GeometryQueryTool.cpp: In member function 'CubitStatus GeometryQueryTool::straightline_intersections(RefEdge*, CubitVector&, CubitVector&, DLIList<CubitVector*>&, CubitBoolean, CubitBoolean)':
../../geom/GeometryQueryTool.cpp:3026: warning: unused variable 'status'
../../geom/MergeTool.cpp: In member function 'CubitStatus MergeTool::find_mergeable_refedges(DLIList<RefEntity*>&, DLIList<DLIList<RefEdge*>*>&, bool)':
../../geom/MergeTool.cpp:1282: warning: unused variable 'retained_id'
../../geom/MergeTool.cpp:1283: warning: unused variable 'deleted_id'
../../geom/MergeTool.cpp: In member function 'CubitStatus MergeTool::find_mergeable_refvertices(DLIList<RefEntity*>&, DLIList<DLIList<RefVertex*>*>&, bool)':
../../geom/MergeTool.cpp:1622: warning: unused variable 'retained_id'
../../geom/MergeTool.cpp:1623: warning: unused variable 'deleted_id'
../../geom/MergeTool.cpp: In member function 'RefEdge* MergeTool::separate_edge(DLIList<Curve*>&, bool)':
../../geom/MergeTool.cpp:4973: warning: unused variable 'vtx'
../../geom/GeomMeasureTool.cpp: In static member function 'static CubitStatus GeomMeasureTool::center(DLIList<RefFace*>)':
../../geom/GeomMeasureTool.cpp:3515: warning: 'id' may be used uninitialized in this function
../../geom/OldUnmergeCode.cpp: In static member function 'static void OldUnmergeCode::initialize_settings()':
../../geom/OldUnmergeCode.cpp:40: warning: deprecated conversion from string constant to 'char*'
../../geom/OldUnmergeCode.cpp: In member function 'RefFace* OldUnmergeCode::unmerge(RefFace*, RefVolume*)':
../../geom/OldUnmergeCode.cpp:540: warning: unused variable 'lump_ptr'
../../geom/RefEntityName.cpp: In static member function 'static void RefEntityName::initialize_settings()':
../../geom/RefEntityName.cpp:743: warning: deprecated conversion from string constant to 'char*'
../../geom/RefEntityName.cpp:747: warning: deprecated conversion from string constant to 'char*'
../../geom/RefEntityName.cpp:751: warning: deprecated conversion from string constant to 'char*'
../../geom/RefEntityName.cpp:755: warning: deprecated conversion from string constant to 'char*'
../../geom/RefEntityName.cpp:759: warning: deprecated conversion from string constant to 'char*'
../../geom/GeometryModifyTool.cpp: In member function 'CubitStatus GeometryModifyTool::get_mid_surface(RefFace*, RefFace*, Body*, DLIList<RefFace*>&) const':
../../geom/GeometryModifyTool.cpp:7412: warning: 'ret' may be used uninitialized in this function
../../geom/SplitSurfaceTool.cpp: In static member function 'static void SplitSurfaceTool::initialize_settings()':
../../geom/SplitSurfaceTool.cpp:77: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:81: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:85: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:89: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:93: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp: In member function 'CubitStatus SplitSurfaceTool::adjust_for_split_direction(RefEdge*, RefEdge*, DLIList<RefVertex*>&)':
../../geom/SplitSurfaceTool.cpp:3445: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:3480: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:3561: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:3593: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp:3618: warning: deprecated conversion from string constant to 'char*'
../../geom/SplitSurfaceTool.cpp: In member function 'CubitStatus SplitSurfaceTool::check_through_vertices(char*)':
../../geom/SplitSurfaceTool.cpp:3840: warning: too few arguments for format
../../geom/SplitSurfaceTool.cpp: In member function 'Curve* SplitSurfaceTool::create_curve(DLIList<CubitVector*>&, Surface*, double, CubitBoolean, CubitBoolean, CubitBoolean)':
../../geom/SplitSurfaceTool.cpp:5647: warning: suggest explicit braces to avoid ambiguous 'else'
../../geom/SurfaceOverlapTool.cpp: In member function 'CubitBoolean SurfaceOverlapTool::check_overlap(Surface*, Surface*, std::map<Surface*, DLIList<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, DLIList<SurfaceOverlapFacet*>*> > >*, std::map<Surface*, double, std::less<Surface*>, std::allocator<std::pair<Surface* const, double> > >*, std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>*, std::less<Surface*>, std::allocator<std::pair<Surface* const, AbstractTree<SurfaceOverlapFacet*>*> > >*)':
../../geom/SurfaceOverlapTool.cpp:816: warning: unused variable 'num_samples'
../../geom/SurfaceOverlapTool.cpp: In static member function 'static void SurfaceOverlapTool::initialize_settings()':
../../geom/SurfaceOverlapTool.cpp:1406: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1410: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1414: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1418: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1422: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1426: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1430: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1434: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1438: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1442: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1446: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1450: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp:1454: warning: deprecated conversion from string constant to 'char*'
../../geom/SurfaceOverlapTool.cpp: In member function 'CubitStatus SurfaceOverlapTool::find_overlapping_curves(DLIList<Body*>&, std::multimap<RefEdge*, RefEdge*, std::less<RefEdge*>, std::allocator<std::pair<RefEdge* const, RefEdge*> > >&)':
../../geom/SurfaceOverlapTool.cpp:1620: warning: unused variable 'co_facet_list'
../../geom/TopologyEntity.cpp: In member function 'CubitBoolean TopologyEntity::is_directly_related(TopologyEntity*)':
../../geom/TopologyEntity.cpp:247: warning: unused variable 'result'
../../../geom/Cholla/ChollaCurve.cpp: In member function 'CubitStatus ChollaCurve::determine_ends()':
../../../geom/Cholla/ChollaCurve.cpp:445: warning: suggest parentheses around && within ||
../../../geom/Cholla/Cholla.cpp: In function 'CubitStatus build_facets(int, int, int, int, int*, int*, int*, double*, CubitPoint**, CubitFacetEdge**, CubitFacet**, CubitQuadFacet**, DLIList<FacetEntity*>&)':
../../../geom/Cholla/Cholla.cpp:599: warning: deprecated conversion from string constant to 'char*'
../../../geom/Cholla/ChollaEngine.cpp: In member function 'CubitStatus ChollaEngine::create_geometry(CubitBoolean, double, int, CubitBoolean, CubitBoolean)':
../../../geom/Cholla/ChollaEngine.cpp:233: warning: deprecated conversion from string constant to 'char*'
../../../geom/Cholla/CubitFacet.cpp: In member function 'CubitFacetEdge* CubitFacet::edge_from_pts(CubitPoint*, CubitPoint*, int&)':
../../../geom/Cholla/CubitFacet.cpp:780: warning: suggest parentheses around && within ||
../../../geom/Cholla/CubitFacet.cpp:785: warning: suggest parentheses around && within ||
../../../geom/Cholla/CubitFacet.cpp:790: warning: suggest parentheses around && within ||
../../../geom/Cholla/ChordalAxis.cpp: In member function 'CubitVector ChordalAxis::get_center(CubitVector, CubitVector, CubitVector)':
../../../geom/Cholla/ChordalAxis.cpp:809: warning: 'cy' may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp:809: warning: 'cx' may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp: In member function 'CubitStatus ChordalAxis::junction_triangle(CubitFacet*, TDChordal*, DLIList<CubitFacetEdge*>&)':
../../../geom/Cholla/ChordalAxis.cpp:701: warning: 'segment2' may be used uninitialized in this function
../../../geom/Cholla/ChordalAxis.cpp:701: warning: 'segment1' may be used uninitialized in this function
../../../geom/Cholla/CurveFacetEvalTool.cpp: In member function 'void CurveFacetEvalTool::fix_point_edge_order()':
../../../geom/Cholla/CurveFacetEvalTool.cpp:1937: warning: unused variable 'this_pt0'
../../../geom/Cholla/FacetEvalTool.cpp: In member function 'CubitStatus FacetEvalTool::mark_edge_pairs(CubitPoint*)':
../../../geom/Cholla/FacetEvalTool.cpp:532: warning: unused variable 'status'
../../../geom/Cholla/FacetDataUtil.cpp: In static member function 'static CubitStatus FacetDataUtil::merge_coincident_vertices(DLIList<DLIList<CubitFacet*>*>&, double, int&, int&, DLIList<CubitPoint*>&)':
../../../geom/Cholla/FacetDataUtil.cpp:2112: warning: unused variable 'np'
../../../geom/Cholla/FacetDataUtil.cpp:2113: warning: unused variable 'na'
../../../geom/Cholla/GeoTet.cpp: In member function 'void GeoTet::opposite_edge(GeoNode*, GeoNode*, GeoNode*&, GeoNode*&)':
../../../geom/Cholla/GeoTet.cpp:155: warning: suggest explicit braces to avoid ambiguous 'else'
../../../geom/Cholla/LoopParamTool.cpp: In member function 'CubitStatus LoopParamTool::check_selfintersecting_coincident_edges(DLIList<DLIList<CubitPoint*>*>&)':
../../../geom/Cholla/LoopParamTool.cpp:649: warning: suggest parentheses around && within ||
../../../geom/Cholla/FacetEvalTool.cpp: In static member function 'static void FacetEvalTool::ac_at_edge(CubitVector&, CubitVector&, int)':
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: 'w' may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: 'v' may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp:1673: warning: 'u' may be used uninitialized in this function
../../../geom/Cholla/FacetEvalTool.cpp: In static member function 'static CubitStatus FacetEvalTool::project_to_facetedge(CubitFacet*, int, int, CubitVector&, CubitVector&, CubitVector&, CubitBoolean&, CubitBoolean)':
../../../geom/Cholla/FacetEvalTool.cpp:2651: warning: 'edge_id' may be used uninitialized in this function
../../../geom/facetbool/FBPolyhedron.cpp: In member function 'bool FBPolyhedron::edge_exists_in_tri(FB_Triangle&, int, int)':
../../../geom/facetbool/FBPolyhedron.cpp:407: warning: suggest parentheses around && within ||
../../../geom/facet/FacetCurve.cpp: In member function 'void FacetCurve::adjust_periodic_parameter(double&)':
../../../geom/facet/FacetCurve.cpp:937: warning: unused variable 'edge_range'
../../../geom/facet/FacetModifyEngine.cpp: In static member function 'static void FacetModifyEngine::initialize_settings()':
../../../geom/facet/FacetModifyEngine.cpp:112: warning: deprecated conversion from string constant to 'char*'
../../../geom/facet/FacetQueryEngine.cpp: In static member function 'static CubitStatus FacetQueryEngine::read_facets(const char*, int*&, int&, int&, int&, FacetFileFormat)':
../../../geom/facet/FacetQueryEngine.cpp:3393: warning: suggest parentheses around && within ||
../../../geom/virtual/CompositeCoEdge.cpp: In constructor 'CompositeCoEdge::CompositeCoEdge(CompositeCurve*)':
../../../geom/virtual/CompositeCoEdge.cpp:54: warning: unused variable 'stat'
../../../geom/virtual/CACompositeVG.cpp: In member function 'virtual CubitStatus CACompositeVG::actuate()':
../../../geom/virtual/CACompositeVG.cpp:137: warning: suggest explicit braces to avoid ambiguous 'else'
../../../geom/virtual/CompositeEngine.cpp: In constructor 'CompositeEngine::CompositeEngine()':
../../../geom/virtual/CompositeEngine.cpp:1279: warning: unused variable 'result'
../../../geom/virtual/CompositeEngine.cpp: In member function 'CompositeCurve* CompositeEngine::composite(Curve*, Curve*, Point*, bool)':
../../../geom/virtual/CompositeEngine.cpp:1404: warning: unused variable 's'
../../../geom/virtual/CompositeEngine.cpp:1409: warning: unused variable 's'
../../../geom/virtual/CompositeEngine.cpp: In static member function 'static CubitStatus CompositeEngine::find_coedges(CompositeSurface*, CompositeCurve*, CompositePoint*, CompositeCoEdge*&, CompositeCoEdge*&)':
../../../geom/virtual/CompositeEngine.cpp:3773: warning: unused variable 'next_owner'
../../../geom/virtual/CompositeLoop.cpp: In destructor 'virtual CompositeLoop::~CompositeLoop()':
../../../geom/virtual/CompositeLoop.cpp:39: warning: unused variable 's'
../../../geom/virtual/CompositeCurve.hpp: In constructor 'CompositeCurve::CompositeCurve(Curve*)':
../../../geom/virtual/CompositeCurve.hpp:213: warning: 'CompositeCurve::stitchNext' will be initialized after
../../../geom/virtual/CompositeCurve.hpp:31: warning: 'int CompositeCurve::HadBridgeRemoved'
../../../geom/virtual/CompositeCurve.cpp:34: warning: when initialized here
../../../geom/virtual/CompositeCurve.hpp: In constructor 'CompositeCurve::CompositeCurve(CompositeGeom*)':
../../../geom/virtual/CompositeCurve.cpp:51: warning: when initialized here
../../../geom/virtual/CompositeCurve.hpp: In constructor 'CompositeCurve::CompositeCurve(CompositePoint*)':
../../../geom/virtual/CompositeCurve.cpp:79: warning: when initialized here
../../../geom/virtual/CompositeCurve.cpp: In member function 'virtual void CompositeCurve::notify_split(TopologyBridge*, TopologyBridge*)':
../../../geom/virtual/CompositeCurve.cpp:1402: warning: unused variable 's'
../../../geom/virtual/CompositeCurve.cpp:1324: warning: unused variable 'ep'
../../../geom/virtual/CompositePoint.hpp: In constructor 'CompositePoint::CompositePoint(Point*)':
../../../geom/virtual/CompositePoint.hpp:80: warning: 'CompositePoint::stitchNext' will be initialized after
../../../geom/virtual/CompositePoint.hpp:28: warning: 'int CompositePoint::HadBridgeRemoved'
../../../geom/virtual/CompositePoint.cpp:17: warning: when initialized here
../../../geom/virtual/CompositeSurface.hpp: In constructor 'CompositeSurface::CompositeSurface(Surface*)':
../../../geom/virtual/CompositeSurface.hpp:235: warning: 'CompositeSurface::facetTool' will be initialized after
../../../geom/virtual/CompositeSurface.hpp:217: warning: 'int CompositeSurface::HadBridgeRemoved'
../../../geom/virtual/CompositeSurface.cpp:43: warning: when initialized here
../../../geom/virtual/CompositeSurface.hpp: In constructor 'CompositeSurface::CompositeSurface(CompositeGeom*)':
../../../geom/virtual/CompositeSurface.cpp:55: warning: when initialized here
../../../geom/virtual/CompositeTool.cpp: In member function 'CubitStatus CompositeTool::restore_merged_point(Point*, DLIList<RefFace*>&, bool)':
../../../geom/virtual/CompositeTool.cpp:1377: warning: unused variable 'ccurve'
../../../geom/virtual/CompSurfFacets.cpp:254:1: warning: multi-line comment
../../../geom/virtual/CompSurfFacets.cpp:256:1: warning: multi-line comment
../../../geom/virtual/CompSurfFacets.cpp:262:1: warning: multi-line comment
../../../geom/virtual/CompositeSurface.cpp: In member function 'virtual CubitStatus CompositeSurface::closest_point(const CubitVector&, CubitVector*, CubitVector*, CubitVector*, CubitVector*)':
../../../geom/virtual/CompositeSurface.cpp:852: warning: 'result' may be used uninitialized in this function
../../../geom/virtual/FacetProjectTool.cpp: In member function 'CubitStatus FacetProjectTool::project(DLIList<CubitVector*>&, const std::vector<double, std::allocator<double> >&, const std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, std::vector<double, std::allocator<double> >&, std::vector<int, std::allocator<int> >&, std::vector<int, std::allocator<int> >&, const double*)':
../../../geom/virtual/FacetProjectTool.cpp:144: warning: unused variable 'facet'
../../../geom/virtual/FacetProjectTool.cpp:130: warning: unused variable 'orig_num_facets'
../../../geom/virtual/ImprintBoundaryTool.cpp: In member function 'CubitStatus ImprintBoundaryTool::intersect_segments(ImprintLineSegment*, ImprintLineSegment*, IntersectResult&, ImprintLineSegment**)':
../../../geom/virtual/ImprintBoundaryTool.cpp:955: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:970: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:985: warning: suggest parentheses around && within ||
../../../geom/virtual/ImprintBoundaryTool.cpp:1000: warning: suggest parentheses around && within ||
../../../geom/virtual/PartitionLoop.cpp: In destructor 'virtual PartitionLoop::~PartitionLoop()':
../../../geom/virtual/PartitionLoop.cpp:39: warning: unused variable 's'
../../../geom/virtual/PartitionLump.cpp: In member function 'void PartitionLump::remove_all_shells()':
../../../geom/virtual/PartitionLump.cpp:69: warning: unused variable 's'
../../../geom/virtual/PartitionEngine.cpp: In constructor 'PartitionEngine::PartitionEngine()':
../../../geom/virtual/PartitionEngine.cpp:80: warning: unused variable 'r'
../../../geom/virtual/PartitionEngine.cpp: In member function 'SubCurve* PartitionEngine::replace_curve(Curve*)':
../../../geom/virtual/PartitionEngine.cpp:235: warning: unused variable 's'
../../../geom/virtual/PartitionEngine.cpp: In member function 'SubSurface* PartitionEngine::replace_surface(Surface*)':
../../../geom/virtual/PartitionEngine.cpp:335: warning: unused variable 'pcurve'
../../../geom/virtual/PartitionEngine.cpp: In member function 'PartitionCurve* PartitionEngine::next_curve_around_point(PartitionSurface*, CubitFacetEdgeData*, CubitPointData*, bool)':
../../../geom/virtual/PartitionEngine.cpp:1459: warning: unused variable 'facet2_index'
../../../geom/virtual/CompositeEngine.cpp: In member function 'CubitStatus CompositeEngine::restore_curve(Curve*)':
../../../geom/virtual/CompositeEngine.cpp:3532: warning: 'other_coedge' may be used uninitialized in this function
../../../geom/virtual/PartitionSurface.hpp: In constructor 'PartitionSurface::PartitionSurface()':
../../../geom/virtual/PartitionSurface.hpp:203: warning: 'PartitionSurface::firstCoSurf' will be initialized after
../../../geom/virtual/PartitionSurface.hpp:194: warning: 'CubitSense PartitionSurface::geometry_sense'
../../../geom/virtual/PartitionSurface.cpp:118: warning: when initialized here
../../../geom/virtual/PartitionSurface.hpp: In constructor 'PartitionSurface::PartitionSurface(PartitionLump*)':
../../../geom/virtual/PartitionSurface.cpp:122: warning: when initialized here
../../../geom/virtual/PartitionSurface.hpp: In constructor 'PartitionSurface::PartitionSurface(PartitionSurface*)':
../../../geom/virtual/PartitionSurface.cpp:893: warning: when initialized here
../../../geom/virtual/PartitionSurface.cpp: In member function 'virtual void PartitionSurface::notify_split(FacetEntity*, FacetEntity*)':
../../../geom/virtual/PartitionSurface.cpp:975: warning: unused variable 'old_ptr'
../../../geom/virtual/PartitionTool.cpp: In member function 'virtual CubitStatus PartitionTool::insert_edge(DLIList<RefFace*>&, DLIList<CubitVector*>&, DLIList<RefFace*>&, DLIList<RefEdge*>&, CubitBoolean)':
../../../geom/virtual/PartitionTool.cpp:875: warning: unused variable 'status'
../../../geom/virtual/PartitionTool.cpp: In member function 'CubitStatus PartitionTool::partition_face_by_curves(RefFace*, const DLIList<Curve*>&, DLIList<RefFace*>&, CubitBoolean, DLIList<RefEdge*>*, CubitBoolean)':
../../../geom/virtual/PartitionTool.cpp:1524: warning: unused variable 'sta'
../../../geom/virtual/PartitionTool.cpp:1530: warning: unused variable 'sta'
../../../geom/virtual/PartitionTool.cpp:1544: warning: unused variable 'sta'
../../../geom/virtual/PartitionTool.cpp:1550: warning: unused variable 'stat'
../../../geom/virtual/PartitionTool.cpp: In function 'void pt_print_bte_list(int, DLIList<BasicTopologyEntity*>&, const char*)':
../../../geom/virtual/PartitionTool.cpp:1931: warning: suggest explicit braces to avoid ambiguous 'else'
../../../geom/virtual/PartSurfFacetTool.cpp: In member function 'CubitStatus PartSurfFacetTool::init_facet_data(DLIList<CubitFacetData*>&)':
../../../geom/virtual/PartSurfFacetTool.cpp:687: warning: unused variable 'curv1'
../../../geom/virtual/PartSurfFacetTool.cpp:688: warning: unused variable 'curv2'
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function 'static CubitStatus PartSurfFacetTool::split_edge(CubitFacetEdge*, const CubitVector&, CubitFacet*, CubitPoint*&, CubitFacetEdge*&, CubitFacet*&)':
../../../geom/virtual/PartSurfFacetTool.cpp:986: warning: unused variable 'dot'
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function 'static CubitStatus PartSurfFacetTool::seam_curve(DLIList<CubitFacetEdgeData*>&, PartitionCurve*, DLIList<CubitFacetData*>&, DLIList<CubitFacetEdgeData*>*)':
../../../geom/virtual/PartSurfFacetTool.cpp:1541: warning: unused variable 's1'
../../../geom/virtual/PartSurfFacetTool.cpp:1542: warning: unused variable 's2'
../../../geom/virtual/PartSurfFacetTool.cpp: In static member function 'static CubitPoint* PartSurfFacetTool::split_edge_closest(CubitFacetEdgeData*, const CubitVector&, double, CubitFacetEdgeData*&, DLIList<CubitFacetData*>&)':
../../../geom/virtual/PartSurfFacetTool.cpp:2003: warning: unused variable 'surf'
../../../geom/virtual/PartitionTool.cpp: In member function 'virtual RefVertex* PartitionTool::partition(RefEdge*, const CubitVector&, RefEdge*&, RefEdge*&, CubitBoolean)':
../../../geom/virtual/PartitionTool.cpp:245: warning: 'is_start' may be used uninitialized in this function
../../../geom/virtual/PST_Data.cpp: In member function 'PST_Edge* PST_Point::common(PST_Point*)':
../../../geom/virtual/PST_Data.cpp:26: warning: unused variable 'debug'
../../../geom/virtual/PST_Data.cpp: In member function 'void PST_Face::append_points(DLIList<PST_Point*>&)':
../../../geom/virtual/PST_Data.cpp:85: warning: unused variable 'debug'
../../../geom/virtual/PST_Data.cpp: In member function 'PST_Point* PST_Face::opposite(PST_Edge*)':
../../../geom/virtual/PST_Data.cpp:98: warning: unused variable 'debug'
../../../geom/virtual/PST_Data.cpp: In member function 'PST_Edge* PST_Face::opposite(PST_Point*)':
../../../geom/virtual/PST_Data.cpp:114: warning: unused variable 'debug'
../../../geom/virtual/PST_Data.cpp: In member function 'bool PST_Face::two_edges(PST_Point*, PST_Edge*&, PST_Edge*&)':
../../../geom/virtual/PST_Data.cpp:131: warning: unused variable 'debug'
../../../geom/virtual/PST_Data.cpp: In member function 'PST_CoEdge* PST_CoEdge::previous()':
../../../geom/virtual/PST_Data.cpp:210: warning: unused variable 'debug'
../../../geom/virtual/SubEntitySet.cpp: In member function 'void SubEntitySet::add_lower_order(PartitionEntity*, CubitSimpleAttrib&, int, DLIList<CubitVector*>&, DLIList<int>&, DLIList<int>&, DLIList<int>&)':
../../../geom/virtual/SubEntitySet.cpp:190: warning: unused variable 'result'
../../../geom/virtual/VirtualQueryEngine.cpp: In member function 'virtual CubitStatus VirtualQueryEngine::entity_entity_distance(GeometryEntity*, GeometryEntity*, CubitVector&, CubitVector&, double&)':
../../../geom/virtual/VirtualQueryEngine.cpp:1396: warning: unused variable 'gqe2'
../../itaps/testgeom.cc: In function âbool topology_adjacencies_test(void*)â:
../../itaps/testgeom.cc:858: error: no matching function for call to âfind(void**, void**, void*&)â
make[4]: *** [testgeom-testgeom.o] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[1]: *** [check-recursive] Error 1
make: *** [distcheck] Error 2
ubitEntity.lo -MD -MP -MF .deps/CubitEntity.Tpo -c ../../util/CubitEntity.cpp -o CubitEntity.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitFileFEModel.lo -MD -MP -MF .deps/CubitFileFEModel.Tpo -c ../../util/CubitFileFEModel.cpp -o CubitFileFEModel.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitFileIOWrapper.lo -MD -MP -MF .deps/CubitFileIOWrapper.Tpo -c ../../util/CubitFileIOWrapper.cpp -o CubitFileIOWrapper.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitFile.lo -MD -MP -MF .deps/CubitFile.Tpo -c ../../util/CubitFile.cpp -o CubitFile.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitMatrix.lo -MD -MP -MF ".deps/CubitMatrix.Tpo" -c -o CubitMatrix.lo ../../util/CubitMatrix.cpp; \
then mv -f ".deps/CubitMatrix.Tpo" ".deps/CubitMatrix.Plo"; else rm -f ".deps/CubitMatrix.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitMessage.lo -MD -MP -MF ".deps/CubitMessage.Tpo" -c -o CubitMessage.lo ../../util/CubitMessage.cpp; \
then mv -f ".deps/CubitMessage.Tpo" ".deps/CubitMessage.Plo"; else rm -f ".deps/CubitMessage.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitObservable.lo -MD -MP -MF ".deps/CubitObservable.Tpo" -c -o CubitObservable.lo ../../util/CubitObservable.cpp; \
then mv -f ".deps/CubitObservable.Tpo" ".deps/CubitObservable.Plo"; else rm -f ".deps/CubitObservable.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitFileMetaData.lo -MD -MP -MF .deps/CubitFileMetaData.Tpo -c ../../util/CubitFileMetaData.cpp -o CubitFileMetaData.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitFileUtil.lo -MD -MP -MF .deps/CubitFileUtil.Tpo -c ../../util/CubitFileUtil.cpp -o CubitFileUtil.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitObserver.lo -MD -MP -MF ".deps/CubitObserver.Tpo" -c -o CubitObserver.lo ../../util/CubitObserver.cpp; \
then mv -f ".deps/CubitObserver.Tpo" ".deps/CubitObserver.Plo"; else rm -f ".deps/CubitObserver.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitMessage.lo -MD -MP -MF .deps/CubitMessage.Tpo -c ../../util/CubitMessage.cpp -o CubitMessage.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitMatrix.lo -MD -MP -MF .deps/CubitMatrix.Tpo -c ../../util/CubitMatrix.cpp -o CubitMatrix.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitObservable.lo -MD -MP -MF .deps/CubitObservable.Tpo -c ../../util/CubitObservable.cpp -o CubitObservable.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitPlane.lo -MD -MP -MF ".deps/CubitPlane.Tpo" -c -o CubitPlane.lo ../../util/CubitPlane.cpp; \
then mv -f ".deps/CubitPlane.Tpo" ".deps/CubitPlane.Plo"; else rm -f ".deps/CubitPlane.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitObserver.lo -MD -MP -MF .deps/CubitObserver.Tpo -c ../../util/CubitObserver.cpp -o CubitObserver.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitStack.lo -MD -MP -MF ".deps/CubitStack.Tpo" -c -o CubitStack.lo ../../util/CubitStack.cpp; \
then mv -f ".deps/CubitStack.Tpo" ".deps/CubitStack.Plo"; else rm -f ".deps/CubitStack.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitString.lo -MD -MP -MF ".deps/CubitString.Tpo" -c -o CubitString.lo ../../util/CubitString.cpp; \
then mv -f ".deps/CubitString.Tpo" ".deps/CubitString.Plo"; else rm -f ".deps/CubitString.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitTransformMatrix.lo -MD -MP -MF ".deps/CubitTransformMatrix.Tpo" -c -o CubitTransformMatrix.lo ../../util/CubitTransformMatrix.cpp; \
then mv -f ".deps/CubitTransformMatrix.Tpo" ".deps/CubitTransformMatrix.Plo"; else rm -f ".deps/CubitTransformMatrix.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitPlane.lo -MD -MP -MF .deps/CubitPlane.Tpo -c ../../util/CubitPlane.cpp -o CubitPlane.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitUtil.lo -MD -MP -MF ".deps/CubitUtil.Tpo" -c -o CubitUtil.lo ../../util/CubitUtil.cpp; \
then mv -f ".deps/CubitUtil.Tpo" ".deps/CubitUtil.Plo"; else rm -f ".deps/CubitUtil.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitStack.lo -MD -MP -MF .deps/CubitStack.Tpo -c ../../util/CubitStack.cpp -o CubitStack.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitVector.lo -MD -MP -MF ".deps/CubitVector.Tpo" -c -o CubitVector.lo ../../util/CubitVector.cpp; \
then mv -f ".deps/CubitVector.Tpo" ".deps/CubitVector.Plo"; else rm -f ".deps/CubitVector.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitTransformMatrix.lo -MD -MP -MF .deps/CubitTransformMatrix.Tpo -c ../../util/CubitTransformMatrix.cpp -o CubitTransformMatrix.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitString.lo -MD -MP -MF .deps/CubitString.Tpo -c ../../util/CubitString.cpp -o CubitString.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DIntArray.lo -MD -MP -MF ".deps/DIntArray.Tpo" -c -o DIntArray.lo ../../util/DIntArray.cpp; \
then mv -f ".deps/DIntArray.Tpo" ".deps/DIntArray.Plo"; else rm -f ".deps/DIntArray.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitVector.lo -MD -MP -MF .deps/CubitVector.Tpo -c ../../util/CubitVector.cpp -o CubitVector.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DLList.lo -MD -MP -MF ".deps/DLList.Tpo" -c -o DLList.lo ../../util/DLList.cpp; \
then mv -f ".deps/DLList.Tpo" ".deps/DLList.Plo"; else rm -f ".deps/DLList.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT CubitUtil.lo -MD -MP -MF .deps/CubitUtil.Tpo -c ../../util/CubitUtil.cpp -o CubitUtil.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DynamicArray.lo -MD -MP -MF ".deps/DynamicArray.Tpo" -c -o DynamicArray.lo ../../util/DynamicArray.cpp; \
then mv -f ".deps/DynamicArray.Tpo" ".deps/DynamicArray.Plo"; else rm -f ".deps/DynamicArray.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GMem.lo -MD -MP -MF ".deps/GMem.Tpo" -c -o GMem.lo ../../util/GMem.cpp; \
then mv -f ".deps/GMem.Tpo" ".deps/GMem.Plo"; else rm -f ".deps/GMem.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DIntArray.lo -MD -MP -MF .deps/DIntArray.Tpo -c ../../util/DIntArray.cpp -o DIntArray.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GetLongOpt.lo -MD -MP -MF ".deps/GetLongOpt.Tpo" -c -o GetLongOpt.lo ../../util/GetLongOpt.cpp; \
then mv -f ".deps/GetLongOpt.Tpo" ".deps/GetLongOpt.Plo"; else rm -f ".deps/GetLongOpt.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GfxDebug.lo -MD -MP -MF ".deps/GfxDebug.Tpo" -c -o GfxDebug.lo ../../util/GfxDebug.cpp; \
then mv -f ".deps/GfxDebug.Tpo" ".deps/GfxDebug.Plo"; else rm -f ".deps/GfxDebug.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT IntersectionTool.lo -MD -MP -MF ".deps/IntersectionTool.Tpo" -c -o IntersectionTool.lo ../../util/IntersectionTool.cpp; \
then mv -f ".deps/IntersectionTool.Tpo" ".deps/IntersectionTool.Plo"; else rm -f ".deps/IntersectionTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GMem.lo -MD -MP -MF .deps/GMem.Tpo -c ../../util/GMem.cpp -o GMem.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DLList.lo -MD -MP -MF .deps/DLList.Tpo -c ../../util/DLList.cpp -o DLList.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT DynamicArray.lo -MD -MP -MF .deps/DynamicArray.Tpo -c ../../util/DynamicArray.cpp -o DynamicArray.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT MemoryBlock.lo -MD -MP -MF ".deps/MemoryBlock.Tpo" -c -o MemoryBlock.lo ../../util/MemoryBlock.cpp; \
then mv -f ".deps/MemoryBlock.Tpo" ".deps/MemoryBlock.Plo"; else rm -f ".deps/MemoryBlock.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT IntersectionTool.lo -MD -MP -MF .deps/IntersectionTool.Tpo -c ../../util/IntersectionTool.cpp -o IntersectionTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GetLongOpt.lo -MD -MP -MF .deps/GetLongOpt.Tpo -c ../../util/GetLongOpt.cpp -o GetLongOpt.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT MemoryManager.lo -MD -MP -MF ".deps/MemoryManager.Tpo" -c -o MemoryManager.lo ../../util/MemoryManager.cpp; \
then mv -f ".deps/MemoryManager.Tpo" ".deps/MemoryManager.Plo"; else rm -f ".deps/MemoryManager.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT GfxDebug.lo -MD -MP -MF .deps/GfxDebug.Tpo -c ../../util/GfxDebug.cpp -o GfxDebug.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT MemoryBlock.lo -MD -MP -MF .deps/MemoryBlock.Tpo -c ../../util/MemoryBlock.cpp -o MemoryBlock.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ParamCubitPlane.lo -MD -MP -MF ".deps/ParamCubitPlane.Tpo" -c -o ParamCubitPlane.lo ../../util/ParamCubitPlane.cpp; \
then mv -f ".deps/ParamCubitPlane.Tpo" ".deps/ParamCubitPlane.Plo"; else rm -f ".deps/ParamCubitPlane.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT PlanarParamTool.lo -MD -MP -MF ".deps/PlanarParamTool.Tpo" -c -o PlanarParamTool.lo ../../util/PlanarParamTool.cpp; \
then mv -f ".deps/PlanarParamTool.Tpo" ".deps/PlanarParamTool.Plo"; else rm -f ".deps/PlanarParamTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT MemoryManager.lo -MD -MP -MF .deps/MemoryManager.Tpo -c ../../util/MemoryManager.cpp -o MemoryManager.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT Queue.lo -MD -MP -MF ".deps/Queue.Tpo" -c -o Queue.lo ../../util/Queue.cpp; \
then mv -f ".deps/Queue.Tpo" ".deps/Queue.Plo"; else rm -f ".deps/Queue.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT RandomMersenne.lo -MD -MP -MF ".deps/RandomMersenne.Tpo" -c -o RandomMersenne.lo ../../util/RandomMersenne.cpp; \
then mv -f ".deps/RandomMersenne.Tpo" ".deps/RandomMersenne.Plo"; else rm -f ".deps/RandomMersenne.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SDLList.lo -MD -MP -MF ".deps/SDLList.Tpo" -c -o SDLList.lo ../../util/SDLList.cpp; \
then mv -f ".deps/SDLList.Tpo" ".deps/SDLList.Plo"; else rm -f ".deps/SDLList.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ParamCubitPlane.lo -MD -MP -MF .deps/ParamCubitPlane.Tpo -c ../../util/ParamCubitPlane.cpp -o ParamCubitPlane.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SettingHandler.lo -MD -MP -MF ".deps/SettingHandler.Tpo" -c -o SettingHandler.lo ../../util/SettingHandler.cpp; \
then mv -f ".deps/SettingHandler.Tpo" ".deps/SettingHandler.Plo"; else rm -f ".deps/SettingHandler.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SettingHolder.lo -MD -MP -MF ".deps/SettingHolder.Tpo" -c -o SettingHolder.lo ../../util/SettingHolder.cpp; \
then mv -f ".deps/SettingHolder.Tpo" ".deps/SettingHolder.Plo"; else rm -f ".deps/SettingHolder.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT PlanarParamTool.lo -MD -MP -MF .deps/PlanarParamTool.Tpo -c ../../util/PlanarParamTool.cpp -o PlanarParamTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT StubProgressTool.lo -MD -MP -MF ".deps/StubProgressTool.Tpo" -c -o StubProgressTool.lo ../../util/StubProgressTool.cpp; \
then mv -f ".deps/StubProgressTool.Tpo" ".deps/StubProgressTool.Plo"; else rm -f ".deps/StubProgressTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SettingHandler.lo -MD -MP -MF .deps/SettingHandler.Tpo -c ../../util/SettingHandler.cpp -o SettingHandler.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT Queue.lo -MD -MP -MF .deps/Queue.Tpo -c ../../util/Queue.cpp -o Queue.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SDLList.lo -MD -MP -MF .deps/SDLList.Tpo -c ../../util/SDLList.cpp -o SDLList.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TDUPtr.lo -MD -MP -MF ".deps/TDUPtr.Tpo" -c -o TDUPtr.lo ../../util/TDUPtr.cpp; \
then mv -f ".deps/TDUPtr.Tpo" ".deps/TDUPtr.Plo"; else rm -f ".deps/TDUPtr.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TextProgressTool.lo -MD -MP -MF ".deps/TextProgressTool.Tpo" -c -o TextProgressTool.lo ../../util/TextProgressTool.cpp; \
then mv -f ".deps/TextProgressTool.Tpo" ".deps/TextProgressTool.Plo"; else rm -f ".deps/TextProgressTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT SettingHolder.lo -MD -MP -MF .deps/SettingHolder.Tpo -c ../../util/SettingHolder.cpp -o SettingHolder.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT StubProgressTool.lo -MD -MP -MF .deps/StubProgressTool.Tpo -c ../../util/StubProgressTool.cpp -o StubProgressTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ToolData.lo -MD -MP -MF ".deps/ToolData.Tpo" -c -o ToolData.lo ../../util/ToolData.cpp; \
then mv -f ".deps/ToolData.Tpo" ".deps/ToolData.Plo"; else rm -f ".deps/ToolData.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ToolDataUser.lo -MD -MP -MF ".deps/ToolDataUser.Tpo" -c -o ToolDataUser.lo ../../util/ToolDataUser.cpp; \
then mv -f ".deps/ToolDataUser.Tpo" ".deps/ToolDataUser.Plo"; else rm -f ".deps/ToolDataUser.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TDUPtr.lo -MD -MP -MF .deps/TDUPtr.Tpo -c ../../util/TDUPtr.cpp -o TDUPtr.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TextProgressTool.lo -MD -MP -MF .deps/TextProgressTool.Tpo -c ../../util/TextProgressTool.cpp -o TextProgressTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT Tree.lo -MD -MP -MF ".deps/Tree.Tpo" -c -o Tree.lo ../../util/Tree.cpp; \
then mv -f ".deps/Tree.Tpo" ".deps/Tree.Plo"; else rm -f ".deps/Tree.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ToolData.lo -MD -MP -MF .deps/ToolData.Tpo -c ../../util/ToolData.cpp -o ToolData.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT RandomMersenne.lo -MD -MP -MF .deps/RandomMersenne.Tpo -c ../../util/RandomMersenne.cpp -o RandomMersenne.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TtyProgressTool.lo -MD -MP -MF ".deps/TtyProgressTool.Tpo" -c -o TtyProgressTool.lo ../../util/TtyProgressTool.cpp; \
then mv -f ".deps/TtyProgressTool.Tpo" ".deps/TtyProgressTool.Plo"; else rm -f ".deps/TtyProgressTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT ToolDataUser.lo -MD -MP -MF .deps/ToolDataUser.Tpo -c ../../util/ToolDataUser.cpp -o ToolDataUser.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT Tree.lo -MD -MP -MF .deps/Tree.Tpo -c ../../util/Tree.cpp -o Tree.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../util -I.. -I../itaps -Wall -pipe -O2 -DNDEBUG -MT TtyProgressTool.lo -MD -MP -MF .deps/TtyProgressTool.Tpo -c ../../util/TtyProgressTool.cpp -o TtyProgressTool.o
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcubit_util.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib AllocMemManagersList.lo AppUtil.lo ArrayBasedContainer.lo CpuTimer.lo Cubit2DPoint.lo CubitBox.lo CubitCollection.lo CubitContainer.lo CubitCoordinateSystem.lo CubitDynamicLoader.lo CubitEntity.lo CubitFile.lo CubitFileFEModel.lo CubitFileIOWrapper.lo CubitFileMetaData.lo CubitFileUtil.lo CubitMatrix.lo CubitMessage.lo CubitObservable.lo CubitObserver.lo CubitPlane.lo CubitStack.lo CubitString.lo CubitTransformMatrix.lo CubitUtil.lo CubitVector.lo DIntArray.lo DLList.lo DynamicArray.lo GMem.lo GetLongOpt.lo GfxDebug.lo IntersectionTool.lo MemoryBlock.lo MemoryManager.lo ParamCubitPlane.lo PlanarParamTool.lo Queue.lo RandomMersenne.lo SDLList.lo SettingHandler.lo SettingHolder.lo StubProgressTool.lo TDUPtr.lo TextProgressTool.lo ToolData.lo ToolDataUser.lo Tree.lo TtyProgressTool.lo -lm
mkdir .libs
ar cru .libs/libcubit_util.a AllocMemManagersList.o AppUtil.o ArrayBasedContainer.o CpuTimer.o Cubit2DPoint.o CubitBox.o CubitCollection.o CubitContainer.o CubitCoordinateSystem.o CubitDynamicLoader.o CubitEntity.o CubitFile.o CubitFileFEModel.o CubitFileIOWrapper.o CubitFileMetaData.o CubitFileUtil.o CubitMatrix.o CubitMessage.o CubitObservable.o CubitObserver.o CubitPlane.o CubitStack.o CubitString.o CubitTransformMatrix.o CubitUtil.o CubitVector.o DIntArray.o DLList.o DynamicArray.o GMem.o GetLongOpt.o GfxDebug.o IntersectionTool.o MemoryBlock.o MemoryManager.o ParamCubitPlane.o PlanarParamTool.o Queue.o RandomMersenne.o SDLList.o SettingHandler.o SettingHolder.o StubProgressTool.o TDUPtr.o TextProgressTool.o ToolData.o ToolDataUser.o Tree.o TtyProgressTool.o
ranlib .libs/libcubit_util.a
creating libcubit_util.la
(cd .libs && rm -f libcubit_util.la && ln -s ../libcubit_util.la libcubit_util.la)
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
Making all in geom
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in .
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersGeom.lo -MD -MP -MF ".deps/AllocMemManagersGeom.Tpo" -c -o AllocMemManagersGeom.lo ../../geom/AllocMemManagersGeom.cpp; \
then mv -f ".deps/AllocMemManagersGeom.Tpo" ".deps/AllocMemManagersGeom.Plo"; else rm -f ".deps/AllocMemManagersGeom.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT AnalyticGeometryTool.lo -MD -MP -MF ".deps/AnalyticGeometryTool.Tpo" -c -o AnalyticGeometryTool.lo ../../geom/AnalyticGeometryTool.cpp; \
then mv -f ".deps/AnalyticGeometryTool.Tpo" ".deps/AnalyticGeometryTool.Plo"; else rm -f ".deps/AnalyticGeometryTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BasicTopologyEntity.lo -MD -MP -MF ".deps/BasicTopologyEntity.Tpo" -c -o BasicTopologyEntity.lo ../../geom/BasicTopologyEntity.cpp; \
then mv -f ".deps/BasicTopologyEntity.Tpo" ".deps/BasicTopologyEntity.Plo"; else rm -f ".deps/BasicTopologyEntity.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Body.lo -MD -MP -MF ".deps/Body.Tpo" -c -o Body.lo ../../geom/Body.cpp; \
then mv -f ".deps/Body.Tpo" ".deps/Body.Plo"; else rm -f ".deps/Body.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BodySM.lo -MD -MP -MF ".deps/BodySM.Tpo" -c -o BodySM.lo ../../geom/BodySM.cpp; \
then mv -f ".deps/BodySM.Tpo" ".deps/BodySM.Plo"; else rm -f ".deps/BodySM.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BoundingBoxTool.lo -MD -MP -MF ".deps/BoundingBoxTool.Tpo" -c -o BoundingBoxTool.lo ../../geom/BoundingBoxTool.cpp; \
then mv -f ".deps/BoundingBoxTool.Tpo" ".deps/BoundingBoxTool.Plo"; else rm -f ".deps/BoundingBoxTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BridgeManager.lo -MD -MP -MF ".deps/BridgeManager.Tpo" -c -o BridgeManager.lo ../../geom/BridgeManager.cpp; \
then mv -f ".deps/BridgeManager.Tpo" ".deps/BridgeManager.Plo"; else rm -f ".deps/BridgeManager.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAActuateSet.lo -MD -MP -MF ".deps/CAActuateSet.Tpo" -c -o CAActuateSet.lo ../../geom/CAActuateSet.cpp; \
then mv -f ".deps/CAActuateSet.Tpo" ".deps/CAActuateSet.Plo"; else rm -f ".deps/CAActuateSet.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersGeom.lo -MD -MP -MF .deps/AllocMemManagersGeom.Tpo -c ../../geom/AllocMemManagersGeom.cpp -o AllocMemManagersGeom.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BridgeManager.lo -MD -MP -MF .deps/BridgeManager.Tpo -c ../../geom/BridgeManager.cpp -o BridgeManager.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Body.lo -MD -MP -MF .deps/Body.Tpo -c ../../geom/Body.cpp -o Body.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BodySM.lo -MD -MP -MF .deps/BodySM.Tpo -c ../../geom/BodySM.cpp -o BodySM.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAActuateSet.lo -MD -MP -MF .deps/CAActuateSet.Tpo -c ../../geom/CAActuateSet.cpp -o CAActuateSet.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT AnalyticGeometryTool.lo -MD -MP -MF .deps/AnalyticGeometryTool.Tpo -c ../../geom/AnalyticGeometryTool.cpp -o AnalyticGeometryTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BasicTopologyEntity.lo -MD -MP -MF .deps/BasicTopologyEntity.Tpo -c ../../geom/BasicTopologyEntity.cpp -o BasicTopologyEntity.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT BoundingBoxTool.lo -MD -MP -MF .deps/BoundingBoxTool.Tpo -c ../../geom/BoundingBoxTool.cpp -o BoundingBoxTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CADeferredAttrib.lo -MD -MP -MF ".deps/CADeferredAttrib.Tpo" -c -o CADeferredAttrib.lo ../../geom/CADeferredAttrib.cpp; \
then mv -f ".deps/CADeferredAttrib.Tpo" ".deps/CADeferredAttrib.Plo"; else rm -f ".deps/CADeferredAttrib.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityColor.lo -MD -MP -MF ".deps/CAEntityColor.Tpo" -c -o CAEntityColor.lo ../../geom/CAEntityColor.cpp; \
then mv -f ".deps/CAEntityColor.Tpo" ".deps/CAEntityColor.Plo"; else rm -f ".deps/CAEntityColor.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityId.lo -MD -MP -MF ".deps/CAEntityId.Tpo" -c -o CAEntityId.lo ../../geom/CAEntityId.cpp; \
then mv -f ".deps/CAEntityId.Tpo" ".deps/CAEntityId.Plo"; else rm -f ".deps/CAEntityId.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityName.lo -MD -MP -MF ".deps/CAEntityName.Tpo" -c -o CAEntityName.lo ../../geom/CAEntityName.cpp; \
then mv -f ".deps/CAEntityName.Tpo" ".deps/CAEntityName.Plo"; else rm -f ".deps/CAEntityName.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAGroup.lo -MD -MP -MF ".deps/CAGroup.Tpo" -c -o CAGroup.lo ../../geom/CAGroup.cpp; \
then mv -f ".deps/CAGroup.Tpo" ".deps/CAGroup.Plo"; else rm -f ".deps/CAGroup.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CADeferredAttrib.lo -MD -MP -MF .deps/CADeferredAttrib.Tpo -c ../../geom/CADeferredAttrib.cpp -o CADeferredAttrib.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAMergePartner.lo -MD -MP -MF ".deps/CAMergePartner.Tpo" -c -o CAMergePartner.lo ../../geom/CAMergePartner.cpp; \
then mv -f ".deps/CAMergePartner.Tpo" ".deps/CAMergePartner.Plo"; else rm -f ".deps/CAMergePartner.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityColor.lo -MD -MP -MF .deps/CAEntityColor.Tpo -c ../../geom/CAEntityColor.cpp -o CAEntityColor.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAGroup.lo -MD -MP -MF .deps/CAGroup.Tpo -c ../../geom/CAGroup.cpp -o CAGroup.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityId.lo -MD -MP -MF .deps/CAEntityId.Tpo -c ../../geom/CAEntityId.cpp -o CAEntityId.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAEntityName.lo -MD -MP -MF .deps/CAEntityName.Tpo -c ../../geom/CAEntityName.cpp -o CAEntityName.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAMergeStatus.lo -MD -MP -MF ".deps/CAMergeStatus.Tpo" -c -o CAMergeStatus.lo ../../geom/CAMergeStatus.cpp; \
then mv -f ".deps/CAMergeStatus.Tpo" ".deps/CAMergeStatus.Plo"; else rm -f ".deps/CAMergeStatus.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAMergePartner.lo -MD -MP -MF .deps/CAMergePartner.Tpo -c ../../geom/CAMergePartner.cpp -o CAMergePartner.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CASourceFeature.lo -MD -MP -MF ".deps/CASourceFeature.Tpo" -c -o CASourceFeature.lo ../../geom/CASourceFeature.cpp; \
then mv -f ".deps/CASourceFeature.Tpo" ".deps/CASourceFeature.Plo"; else rm -f ".deps/CASourceFeature.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAMergeStatus.lo -MD -MP -MF .deps/CAMergeStatus.Tpo -c ../../geom/CAMergeStatus.cpp -o CAMergeStatus.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAUniqueId.lo -MD -MP -MF ".deps/CAUniqueId.Tpo" -c -o CAUniqueId.lo ../../geom/CAUniqueId.cpp; \
then mv -f ".deps/CAUniqueId.Tpo" ".deps/CAUniqueId.Plo"; else rm -f ".deps/CAUniqueId.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CGMApp.lo -MD -MP -MF ".deps/CGMApp.Tpo" -c -o CGMApp.lo ../../geom/CGMApp.cpp; \
then mv -f ".deps/CGMApp.Tpo" ".deps/CGMApp.Plo"; else rm -f ".deps/CGMApp.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CGMEngineDynamicLoader.lo -MD -MP -MF ".deps/CGMEngineDynamicLoader.Tpo" -c -o CGMEngineDynamicLoader.lo ../../geom/CGMEngineDynamicLoader.cpp; \
then mv -f ".deps/CGMEngineDynamicLoader.Tpo" ".deps/CGMEngineDynamicLoader.Plo"; else rm -f ".deps/CGMEngineDynamicLoader.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CASourceFeature.lo -MD -MP -MF .deps/CASourceFeature.Tpo -c ../../geom/CASourceFeature.cpp -o CASourceFeature.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CAUniqueId.lo -MD -MP -MF .deps/CAUniqueId.Tpo -c ../../geom/CAUniqueId.cpp -o CAUniqueId.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Chain.lo -MD -MP -MF ".deps/Chain.Tpo" -c -o Chain.lo ../../geom/Chain.cpp; \
then mv -f ".deps/Chain.Tpo" ".deps/Chain.Plo"; else rm -f ".deps/Chain.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CGMEngineDynamicLoader.lo -MD -MP -MF .deps/CGMEngineDynamicLoader.Tpo -c ../../geom/CGMEngineDynamicLoader.cpp -o CGMEngineDynamicLoader.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoEdge.lo -MD -MP -MF ".deps/CoEdge.Tpo" -c -o CoEdge.lo ../../geom/CoEdge.cpp; \
then mv -f ".deps/CoEdge.Tpo" ".deps/CoEdge.Plo"; else rm -f ".deps/CoEdge.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CGMApp.lo -MD -MP -MF .deps/CGMApp.Tpo -c ../../geom/CGMApp.cpp -o CGMApp.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoEdgeSM.lo -MD -MP -MF ".deps/CoEdgeSM.Tpo" -c -o CoEdgeSM.lo ../../geom/CoEdgeSM.cpp; \
then mv -f ".deps/CoEdgeSM.Tpo" ".deps/CoEdgeSM.Plo"; else rm -f ".deps/CoEdgeSM.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoFace.lo -MD -MP -MF ".deps/CoFace.Tpo" -c -o CoFace.lo ../../geom/CoFace.cpp; \
then mv -f ".deps/CoFace.Tpo" ".deps/CoFace.Plo"; else rm -f ".deps/CoFace.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CollectionEntity.lo -MD -MP -MF ".deps/CollectionEntity.Tpo" -c -o CollectionEntity.lo ../../geom/CollectionEntity.cpp; \
then mv -f ".deps/CollectionEntity.Tpo" ".deps/CollectionEntity.Plo"; else rm -f ".deps/CollectionEntity.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Chain.lo -MD -MP -MF .deps/Chain.Tpo -c ../../geom/Chain.cpp -o Chain.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoEdgeSM.lo -MD -MP -MF .deps/CoEdgeSM.Tpo -c ../../geom/CoEdgeSM.cpp -o CoEdgeSM.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoVertex.lo -MD -MP -MF ".deps/CoVertex.Tpo" -c -o CoVertex.lo ../../geom/CoVertex.cpp; \
then mv -f ".deps/CoVertex.Tpo" ".deps/CoVertex.Plo"; else rm -f ".deps/CoVertex.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoFace.lo -MD -MP -MF .deps/CoFace.Tpo -c ../../geom/CoFace.cpp -o CoFace.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoVolume.lo -MD -MP -MF ".deps/CoVolume.Tpo" -c -o CoVolume.lo ../../geom/CoVolume.cpp; \
then mv -f ".deps/CoVolume.Tpo" ".deps/CoVolume.Plo"; else rm -f ".deps/CoVolume.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoEdge.lo -MD -MP -MF .deps/CoEdge.Tpo -c ../../geom/CoEdge.cpp -o CoEdge.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttrib.lo -MD -MP -MF ".deps/CubitAttrib.Tpo" -c -o CubitAttrib.lo ../../geom/CubitAttrib.cpp; \
then mv -f ".deps/CubitAttrib.Tpo" ".deps/CubitAttrib.Plo"; else rm -f ".deps/CubitAttrib.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CollectionEntity.lo -MD -MP -MF .deps/CollectionEntity.Tpo -c ../../geom/CollectionEntity.cpp -o CollectionEntity.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttribManager.lo -MD -MP -MF ".deps/CubitAttribManager.Tpo" -c -o CubitAttribManager.lo ../../geom/CubitAttribManager.cpp; \
then mv -f ".deps/CubitAttribManager.Tpo" ".deps/CubitAttribManager.Plo"; else rm -f ".deps/CubitAttribManager.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoVertex.lo -MD -MP -MF .deps/CoVertex.Tpo -c ../../geom/CoVertex.cpp -o CoVertex.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttribUser.lo -MD -MP -MF ".deps/CubitAttribUser.Tpo" -c -o CubitAttribUser.lo ../../geom/CubitAttribUser.cpp; \
then mv -f ".deps/CubitAttribUser.Tpo" ".deps/CubitAttribUser.Plo"; else rm -f ".deps/CubitAttribUser.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CoVolume.lo -MD -MP -MF .deps/CoVolume.Tpo -c ../../geom/CoVolume.cpp -o CoVolume.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitPolygon.lo -MD -MP -MF ".deps/CubitPolygon.Tpo" -c -o CubitPolygon.lo ../../geom/CubitPolygon.cpp; \
then mv -f ".deps/CubitPolygon.Tpo" ".deps/CubitPolygon.Plo"; else rm -f ".deps/CubitPolygon.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttrib.lo -MD -MP -MF .deps/CubitAttrib.Tpo -c ../../geom/CubitAttrib.cpp -o CubitAttrib.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitSimpleAttrib.lo -MD -MP -MF ".deps/CubitSimpleAttrib.Tpo" -c -o CubitSimpleAttrib.lo ../../geom/CubitSimpleAttrib.cpp; \
then mv -f ".deps/CubitSimpleAttrib.Tpo" ".deps/CubitSimpleAttrib.Plo"; else rm -f ".deps/CubitSimpleAttrib.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c ../../geom/CubitAttribManager.cpp -o CubitAttribManager.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitAttribUser.lo -MD -MP -MF .deps/CubitAttribUser.Tpo -c ../../geom/CubitAttribUser.cpp -o CubitAttribUser.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Curve.lo -MD -MP -MF ".deps/Curve.Tpo" -c -o Curve.lo ../../geom/Curve.cpp; \
then mv -f ".deps/Curve.Tpo" ".deps/Curve.Plo"; else rm -f ".deps/Curve.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CurveOverlapFacet.lo -MD -MP -MF ".deps/CurveOverlapFacet.Tpo" -c -o CurveOverlapFacet.lo ../../geom/CurveOverlapFacet.cpp; \
then mv -f ".deps/CurveOverlapFacet.Tpo" ".deps/CurveOverlapFacet.Plo"; else rm -f ".deps/CurveOverlapFacet.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitSimpleAttrib.lo -MD -MP -MF .deps/CubitSimpleAttrib.Tpo -c ../../geom/CubitSimpleAttrib.cpp -o CubitSimpleAttrib.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CurveSM.lo -MD -MP -MF ".deps/CurveSM.Tpo" -c -o CurveSM.lo ../../geom/CurveSM.cpp; \
then mv -f ".deps/CurveSM.Tpo" ".deps/CurveSM.Plo"; else rm -f ".deps/CurveSM.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CubitPolygon.lo -MD -MP -MF .deps/CubitPolygon.Tpo -c ../../geom/CubitPolygon.cpp -o CubitPolygon.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CurveOverlapFacet.lo -MD -MP -MF .deps/CurveOverlapFacet.Tpo -c ../../geom/CurveOverlapFacet.cpp -o CurveOverlapFacet.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Curve.lo -MD -MP -MF .deps/Curve.Tpo -c ../../geom/Curve.cpp -o Curve.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CylinderEvaluator.lo -MD -MP -MF ".deps/CylinderEvaluator.Tpo" -c -o CylinderEvaluator.lo ../../geom/CylinderEvaluator.cpp; \
then mv -f ".deps/CylinderEvaluator.Tpo" ".deps/CylinderEvaluator.Plo"; else rm -f ".deps/CylinderEvaluator.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT DAG.lo -MD -MP -MF ".deps/DAG.Tpo" -c -o DAG.lo ../../geom/DAG.cpp; \
then mv -f ".deps/DAG.Tpo" ".deps/DAG.Plo"; else rm -f ".deps/DAG.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CylinderEvaluator.lo -MD -MP -MF .deps/CylinderEvaluator.Tpo -c ../../geom/CylinderEvaluator.cpp -o CylinderEvaluator.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT CurveSM.lo -MD -MP -MF .deps/CurveSM.Tpo -c ../../geom/CurveSM.cpp -o CurveSM.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT DagDrawingTool.lo -MD -MP -MF ".deps/DagDrawingTool.Tpo" -c -o DagDrawingTool.lo ../../geom/DagDrawingTool.cpp; \
then mv -f ".deps/DagDrawingTool.Tpo" ".deps/DagDrawingTool.Plo"; else rm -f ".deps/DagDrawingTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeomDataObserver.lo -MD -MP -MF ".deps/GeomDataObserver.Tpo" -c -o GeomDataObserver.lo ../../geom/GeomDataObserver.cpp; \
then mv -f ".deps/GeomDataObserver.Tpo" ".deps/GeomDataObserver.Plo"; else rm -f ".deps/GeomDataObserver.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT DAG.lo -MD -MP -MF .deps/DAG.Tpo -c ../../geom/DAG.cpp -o DAG.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryEntity.lo -MD -MP -MF ".deps/GeometryEntity.Tpo" -c -o GeometryEntity.lo ../../geom/GeometryEntity.cpp; \
then mv -f ".deps/GeometryEntity.Tpo" ".deps/GeometryEntity.Plo"; else rm -f ".deps/GeometryEntity.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryFeatureEngine.lo -MD -MP -MF ".deps/GeometryFeatureEngine.Tpo" -c -o GeometryFeatureEngine.lo ../../geom/GeometryFeatureEngine.cpp; \
then mv -f ".deps/GeometryFeatureEngine.Tpo" ".deps/GeometryFeatureEngine.Plo"; else rm -f ".deps/GeometryFeatureEngine.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryFeatureTool.lo -MD -MP -MF ".deps/GeometryFeatureTool.Tpo" -c -o GeometryFeatureTool.lo ../../geom/GeometryFeatureTool.cpp; \
then mv -f ".deps/GeometryFeatureTool.Tpo" ".deps/GeometryFeatureTool.Plo"; else rm -f ".deps/GeometryFeatureTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeomDataObserver.lo -MD -MP -MF .deps/GeomDataObserver.Tpo -c ../../geom/GeomDataObserver.cpp -o GeomDataObserver.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT DagDrawingTool.lo -MD -MP -MF .deps/DagDrawingTool.Tpo -c ../../geom/DagDrawingTool.cpp -o DagDrawingTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryEntity.lo -MD -MP -MF .deps/GeometryEntity.Tpo -c ../../geom/GeometryEntity.cpp -o GeometryEntity.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryHealerEngine.lo -MD -MP -MF ".deps/GeometryHealerEngine.Tpo" -c -o GeometryHealerEngine.lo ../../geom/GeometryHealerEngine.cpp; \
then mv -f ".deps/GeometryHealerEngine.Tpo" ".deps/GeometryHealerEngine.Plo"; else rm -f ".deps/GeometryHealerEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryFeatureTool.lo -MD -MP -MF .deps/GeometryFeatureTool.Tpo -c ../../geom/GeometryFeatureTool.cpp -o GeometryFeatureTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryHealerTool.lo -MD -MP -MF ".deps/GeometryHealerTool.Tpo" -c -o GeometryHealerTool.lo ../../geom/GeometryHealerTool.cpp; \
then mv -f ".deps/GeometryHealerTool.Tpo" ".deps/GeometryHealerTool.Plo"; else rm -f ".deps/GeometryHealerTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryFeatureEngine.lo -MD -MP -MF .deps/GeometryFeatureEngine.Tpo -c ../../geom/GeometryFeatureEngine.cpp -o GeometryFeatureEngine.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryModifyEngine.lo -MD -MP -MF ".deps/GeometryModifyEngine.Tpo" -c -o GeometryModifyEngine.lo ../../geom/GeometryModifyEngine.cpp; \
then mv -f ".deps/GeometryModifyEngine.Tpo" ".deps/GeometryModifyEngine.Plo"; else rm -f ".deps/GeometryModifyEngine.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryModifyTool.lo -MD -MP -MF ".deps/GeometryModifyTool.Tpo" -c -o GeometryModifyTool.lo ../../geom/GeometryModifyTool.cpp; \
then mv -f ".deps/GeometryModifyTool.Tpo" ".deps/GeometryModifyTool.Plo"; else rm -f ".deps/GeometryModifyTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryQueryEngine.lo -MD -MP -MF ".deps/GeometryQueryEngine.Tpo" -c -o GeometryQueryEngine.lo ../../geom/GeometryQueryEngine.cpp; \
then mv -f ".deps/GeometryQueryEngine.Tpo" ".deps/GeometryQueryEngine.Plo"; else rm -f ".deps/GeometryQueryEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryHealerEngine.lo -MD -MP -MF .deps/GeometryHealerEngine.Tpo -c ../../geom/GeometryHealerEngine.cpp -o GeometryHealerEngine.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryHealerTool.lo -MD -MP -MF .deps/GeometryHealerTool.Tpo -c ../../geom/GeometryHealerTool.cpp -o GeometryHealerTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryQueryTool.lo -MD -MP -MF ".deps/GeometryQueryTool.Tpo" -c -o GeometryQueryTool.lo ../../geom/GeometryQueryTool.cpp; \
then mv -f ".deps/GeometryQueryTool.Tpo" ".deps/GeometryQueryTool.Plo"; else rm -f ".deps/GeometryQueryTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryQueryEngine.lo -MD -MP -MF .deps/GeometryQueryEngine.Tpo -c ../../geom/GeometryQueryEngine.cpp -o GeometryQueryEngine.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryModifyEngine.lo -MD -MP -MF .deps/GeometryModifyEngine.Tpo -c ../../geom/GeometryModifyEngine.cpp -o GeometryModifyEngine.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryUtil.lo -MD -MP -MF ".deps/GeometryUtil.Tpo" -c -o GeometryUtil.lo ../../geom/GeometryUtil.cpp; \
then mv -f ".deps/GeometryUtil.Tpo" ".deps/GeometryUtil.Plo"; else rm -f ".deps/GeometryUtil.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeomMeasureTool.lo -MD -MP -MF ".deps/GeomMeasureTool.Tpo" -c -o GeomMeasureTool.lo ../../geom/GeomMeasureTool.cpp; \
then mv -f ".deps/GeomMeasureTool.Tpo" ".deps/GeomMeasureTool.Plo"; else rm -f ".deps/GeomMeasureTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GfxPreview.lo -MD -MP -MF ".deps/GfxPreview.Tpo" -c -o GfxPreview.lo ../../geom/GfxPreview.cpp; \
then mv -f ".deps/GfxPreview.Tpo" ".deps/GfxPreview.Plo"; else rm -f ".deps/GfxPreview.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryModifyTool.lo -MD -MP -MF .deps/GeometryModifyTool.Tpo -c ../../geom/GeometryModifyTool.cpp -o GeometryModifyTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GroupingEntity.lo -MD -MP -MF ".deps/GroupingEntity.Tpo" -c -o GroupingEntity.lo ../../geom/GroupingEntity.cpp; \
then mv -f ".deps/GroupingEntity.Tpo" ".deps/GroupingEntity.Plo"; else rm -f ".deps/GroupingEntity.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryUtil.lo -MD -MP -MF .deps/GeometryUtil.Tpo -c ../../geom/GeometryUtil.cpp -o GeometryUtil.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeomMeasureTool.lo -MD -MP -MF .deps/GeomMeasureTool.Tpo -c ../../geom/GeomMeasureTool.cpp -o GeomMeasureTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GSaveOpen.lo -MD -MP -MF ".deps/GSaveOpen.Tpo" -c -o GSaveOpen.lo ../../geom/GSaveOpen.cpp; \
then mv -f ".deps/GSaveOpen.Tpo" ".deps/GSaveOpen.Plo"; else rm -f ".deps/GSaveOpen.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GroupingEntity.lo -MD -MP -MF .deps/GroupingEntity.Tpo -c ../../geom/GroupingEntity.cpp -o GroupingEntity.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GeometryQueryTool.lo -MD -MP -MF .deps/GeometryQueryTool.Tpo -c ../../geom/GeometryQueryTool.cpp -o GeometryQueryTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GfxPreview.lo -MD -MP -MF .deps/GfxPreview.Tpo -c ../../geom/GfxPreview.cpp -o GfxPreview.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Loop.lo -MD -MP -MF ".deps/Loop.Tpo" -c -o Loop.lo ../../geom/Loop.cpp; \
then mv -f ".deps/Loop.Tpo" ".deps/Loop.Plo"; else rm -f ".deps/Loop.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT GSaveOpen.lo -MD -MP -MF .deps/GSaveOpen.Tpo -c ../../geom/GSaveOpen.cpp -o GSaveOpen.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Loop.lo -MD -MP -MF .deps/Loop.Tpo -c ../../geom/Loop.cpp -o Loop.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT LoopSM.lo -MD -MP -MF ".deps/LoopSM.Tpo" -c -o LoopSM.lo ../../geom/LoopSM.cpp; \
then mv -f ".deps/LoopSM.Tpo" ".deps/LoopSM.Plo"; else rm -f ".deps/LoopSM.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Lump.lo -MD -MP -MF ".deps/Lump.Tpo" -c -o Lump.lo ../../geom/Lump.cpp; \
then mv -f ".deps/Lump.Tpo" ".deps/Lump.Plo"; else rm -f ".deps/Lump.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT LumpSM.lo -MD -MP -MF ".deps/LumpSM.Tpo" -c -o LumpSM.lo ../../geom/LumpSM.cpp; \
then mv -f ".deps/LumpSM.Tpo" ".deps/LumpSM.Plo"; else rm -f ".deps/LumpSM.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Lump.lo -MD -MP -MF .deps/Lump.Tpo -c ../../geom/Lump.cpp -o Lump.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT LumpSM.lo -MD -MP -MF .deps/LumpSM.Tpo -c ../../geom/LumpSM.cpp -o LumpSM.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT LoopSM.lo -MD -MP -MF .deps/LoopSM.Tpo -c ../../geom/LoopSM.cpp -o LoopSM.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MedialTool2D.lo -MD -MP -MF ".deps/MedialTool2D.Tpo" -c -o MedialTool2D.lo ../../geom/MedialTool2D.cpp; \
then mv -f ".deps/MedialTool2D.Tpo" ".deps/MedialTool2D.Plo"; else rm -f ".deps/MedialTool2D.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MedialTool3D.lo -MD -MP -MF ".deps/MedialTool3D.Tpo" -c -o MedialTool3D.lo ../../geom/MedialTool3D.cpp; \
then mv -f ".deps/MedialTool3D.Tpo" ".deps/MedialTool3D.Plo"; else rm -f ".deps/MedialTool3D.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MergeToolAssistant.lo -MD -MP -MF ".deps/MergeToolAssistant.Tpo" -c -o MergeToolAssistant.lo ../../geom/MergeToolAssistant.cpp; \
then mv -f ".deps/MergeToolAssistant.Tpo" ".deps/MergeToolAssistant.Plo"; else rm -f ".deps/MergeToolAssistant.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MergeTool.lo -MD -MP -MF ".deps/MergeTool.Tpo" -c -o MergeTool.lo ../../geom/MergeTool.cpp; \
then mv -f ".deps/MergeTool.Tpo" ".deps/MergeTool.Plo"; else rm -f ".deps/MergeTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MedialTool2D.lo -MD -MP -MF .deps/MedialTool2D.Tpo -c ../../geom/MedialTool2D.cpp -o MedialTool2D.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MergeTool.lo -MD -MP -MF .deps/MergeTool.Tpo -c ../../geom/MergeTool.cpp -o MergeTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MedialTool3D.lo -MD -MP -MF .deps/MedialTool3D.Tpo -c ../../geom/MedialTool3D.cpp -o MedialTool3D.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MidPlaneTool.lo -MD -MP -MF ".deps/MidPlaneTool.Tpo" -c -o MidPlaneTool.lo ../../geom/MidPlaneTool.cpp; \
then mv -f ".deps/MidPlaneTool.Tpo" ".deps/MidPlaneTool.Plo"; else rm -f ".deps/MidPlaneTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MergeToolAssistant.lo -MD -MP -MF .deps/MergeToolAssistant.Tpo -c ../../geom/MergeToolAssistant.cpp -o MergeToolAssistant.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ModelEntity.lo -MD -MP -MF ".deps/ModelEntity.Tpo" -c -o ModelEntity.lo ../../geom/ModelEntity.cpp; \
then mv -f ".deps/ModelEntity.Tpo" ".deps/ModelEntity.Plo"; else rm -f ".deps/ModelEntity.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ModelQueryEngine.lo -MD -MP -MF ".deps/ModelQueryEngine.Tpo" -c -o ModelQueryEngine.lo ../../geom/ModelQueryEngine.cpp; \
then mv -f ".deps/ModelQueryEngine.Tpo" ".deps/ModelQueryEngine.Plo"; else rm -f ".deps/ModelQueryEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT MidPlaneTool.lo -MD -MP -MF .deps/MidPlaneTool.Tpo -c ../../geom/MidPlaneTool.cpp -o MidPlaneTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ModelQueryEngine.lo -MD -MP -MF .deps/ModelQueryEngine.Tpo -c ../../geom/ModelQueryEngine.cpp -o ModelQueryEngine.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ModelEntity.lo -MD -MP -MF .deps/ModelEntity.Tpo -c ../../geom/ModelEntity.cpp -o ModelEntity.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT OffsetSplitTool.lo -MD -MP -MF ".deps/OffsetSplitTool.Tpo" -c -o OffsetSplitTool.lo ../../geom/OffsetSplitTool.cpp; \
then mv -f ".deps/OffsetSplitTool.Tpo" ".deps/OffsetSplitTool.Plo"; else rm -f ".deps/OffsetSplitTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT OldUnmergeCode.lo -MD -MP -MF ".deps/OldUnmergeCode.Tpo" -c -o OldUnmergeCode.lo ../../geom/OldUnmergeCode.cpp; \
then mv -f ".deps/OldUnmergeCode.Tpo" ".deps/OldUnmergeCode.Plo"; else rm -f ".deps/OldUnmergeCode.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Point.lo -MD -MP -MF ".deps/Point.Tpo" -c -o Point.lo ../../geom/Point.cpp; \
then mv -f ".deps/Point.Tpo" ".deps/Point.Plo"; else rm -f ".deps/Point.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT PointSM.lo -MD -MP -MF ".deps/PointSM.Tpo" -c -o PointSM.lo ../../geom/PointSM.cpp; \
then mv -f ".deps/PointSM.Tpo" ".deps/PointSM.Plo"; else rm -f ".deps/PointSM.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT OldUnmergeCode.lo -MD -MP -MF .deps/OldUnmergeCode.Tpo -c ../../geom/OldUnmergeCode.cpp -o OldUnmergeCode.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT PointSM.lo -MD -MP -MF .deps/PointSM.Tpo -c ../../geom/PointSM.cpp -o PointSM.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Point.lo -MD -MP -MF .deps/Point.Tpo -c ../../geom/Point.cpp -o Point.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT OffsetSplitTool.lo -MD -MP -MF .deps/OffsetSplitTool.Tpo -c ../../geom/OffsetSplitTool.cpp -o OffsetSplitTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefCollection.lo -MD -MP -MF ".deps/RefCollection.Tpo" -c -o RefCollection.lo ../../geom/RefCollection.cpp; \
then mv -f ".deps/RefCollection.Tpo" ".deps/RefCollection.Plo"; else rm -f ".deps/RefCollection.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEdge.lo -MD -MP -MF ".deps/RefEdge.Tpo" -c -o RefEdge.lo ../../geom/RefEdge.cpp; \
then mv -f ".deps/RefEdge.Tpo" ".deps/RefEdge.Plo"; else rm -f ".deps/RefEdge.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntity.lo -MD -MP -MF ".deps/RefEntity.Tpo" -c -o RefEntity.lo ../../geom/RefEntity.cpp; \
then mv -f ".deps/RefEntity.Tpo" ".deps/RefEntity.Plo"; else rm -f ".deps/RefEntity.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEdge.lo -MD -MP -MF .deps/RefEdge.Tpo -c ../../geom/RefEdge.cpp -o RefEdge.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefCollection.lo -MD -MP -MF .deps/RefCollection.Tpo -c ../../geom/RefCollection.cpp -o RefCollection.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntity.lo -MD -MP -MF .deps/RefEntity.Tpo -c ../../geom/RefEntity.cpp -o RefEntity.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntityFactory.lo -MD -MP -MF ".deps/RefEntityFactory.Tpo" -c -o RefEntityFactory.lo ../../geom/RefEntityFactory.cpp; \
then mv -f ".deps/RefEntityFactory.Tpo" ".deps/RefEntityFactory.Plo"; else rm -f ".deps/RefEntityFactory.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntityName.lo -MD -MP -MF ".deps/RefEntityName.Tpo" -c -o RefEntityName.lo ../../geom/RefEntityName.cpp; \
then mv -f ".deps/RefEntityName.Tpo" ".deps/RefEntityName.Plo"; else rm -f ".deps/RefEntityName.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefFace.lo -MD -MP -MF ".deps/RefFace.Tpo" -c -o RefFace.lo ../../geom/RefFace.cpp; \
then mv -f ".deps/RefFace.Tpo" ".deps/RefFace.Plo"; else rm -f ".deps/RefFace.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntityName.lo -MD -MP -MF .deps/RefEntityName.Tpo -c ../../geom/RefEntityName.cpp -o RefEntityName.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefEntityFactory.lo -MD -MP -MF .deps/RefEntityFactory.Tpo -c ../../geom/RefEntityFactory.cpp -o RefEntityFactory.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefGroup.lo -MD -MP -MF ".deps/RefGroup.Tpo" -c -o RefGroup.lo ../../geom/RefGroup.cpp; \
then mv -f ".deps/RefGroup.Tpo" ".deps/RefGroup.Plo"; else rm -f ".deps/RefGroup.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefVertex.lo -MD -MP -MF ".deps/RefVertex.Tpo" -c -o RefVertex.lo ../../geom/RefVertex.cpp; \
then mv -f ".deps/RefVertex.Tpo" ".deps/RefVertex.Plo"; else rm -f ".deps/RefVertex.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefFace.lo -MD -MP -MF .deps/RefFace.Tpo -c ../../geom/RefFace.cpp -o RefFace.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefGroup.lo -MD -MP -MF .deps/RefGroup.Tpo -c ../../geom/RefGroup.cpp -o RefGroup.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefVolume.lo -MD -MP -MF ".deps/RefVolume.Tpo" -c -o RefVolume.lo ../../geom/RefVolume.cpp; \
then mv -f ".deps/RefVolume.Tpo" ".deps/RefVolume.Plo"; else rm -f ".deps/RefVolume.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefVertex.lo -MD -MP -MF .deps/RefVertex.Tpo -c ../../geom/RefVertex.cpp -o RefVertex.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SenseEntity.lo -MD -MP -MF ".deps/SenseEntity.Tpo" -c -o SenseEntity.lo ../../geom/SenseEntity.cpp; \
then mv -f ".deps/SenseEntity.Tpo" ".deps/SenseEntity.Plo"; else rm -f ".deps/SenseEntity.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Shell.lo -MD -MP -MF ".deps/Shell.Tpo" -c -o Shell.lo ../../geom/Shell.cpp; \
then mv -f ".deps/Shell.Tpo" ".deps/Shell.Plo"; else rm -f ".deps/Shell.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT RefVolume.lo -MD -MP -MF .deps/RefVolume.Tpo -c ../../geom/RefVolume.cpp -o RefVolume.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ShellSM.lo -MD -MP -MF ".deps/ShellSM.Tpo" -c -o ShellSM.lo ../../geom/ShellSM.cpp; \
then mv -f ".deps/ShellSM.Tpo" ".deps/ShellSM.Plo"; else rm -f ".deps/ShellSM.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SenseEntity.lo -MD -MP -MF .deps/SenseEntity.Tpo -c ../../geom/SenseEntity.cpp -o SenseEntity.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SphereEvaluator.lo -MD -MP -MF ".deps/SphereEvaluator.Tpo" -c -o SphereEvaluator.lo ../../geom/SphereEvaluator.cpp; \
then mv -f ".deps/SphereEvaluator.Tpo" ".deps/SphereEvaluator.Plo"; else rm -f ".deps/SphereEvaluator.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Shell.lo -MD -MP -MF .deps/Shell.Tpo -c ../../geom/Shell.cpp -o Shell.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT ShellSM.lo -MD -MP -MF .deps/ShellSM.Tpo -c ../../geom/ShellSM.cpp -o ShellSM.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SplitSurfaceTool.lo -MD -MP -MF ".deps/SplitSurfaceTool.Tpo" -c -o SplitSurfaceTool.lo ../../geom/SplitSurfaceTool.cpp; \
then mv -f ".deps/SplitSurfaceTool.Tpo" ".deps/SplitSurfaceTool.Plo"; else rm -f ".deps/SplitSurfaceTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Surface.lo -MD -MP -MF ".deps/Surface.Tpo" -c -o Surface.lo ../../geom/Surface.cpp; \
then mv -f ".deps/Surface.Tpo" ".deps/Surface.Plo"; else rm -f ".deps/Surface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SphereEvaluator.lo -MD -MP -MF .deps/SphereEvaluator.Tpo -c ../../geom/SphereEvaluator.cpp -o SphereEvaluator.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceOverlapFacet.lo -MD -MP -MF ".deps/SurfaceOverlapFacet.Tpo" -c -o SurfaceOverlapFacet.lo ../../geom/SurfaceOverlapFacet.cpp; \
then mv -f ".deps/SurfaceOverlapFacet.Tpo" ".deps/SurfaceOverlapFacet.Plo"; else rm -f ".deps/SurfaceOverlapFacet.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SplitSurfaceTool.lo -MD -MP -MF .deps/SplitSurfaceTool.Tpo -c ../../geom/SplitSurfaceTool.cpp -o SplitSurfaceTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceOverlapTool.lo -MD -MP -MF ".deps/SurfaceOverlapTool.Tpo" -c -o SurfaceOverlapTool.lo ../../geom/SurfaceOverlapTool.cpp; \
then mv -f ".deps/SurfaceOverlapTool.Tpo" ".deps/SurfaceOverlapTool.Plo"; else rm -f ".deps/SurfaceOverlapTool.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfParamTool.lo -MD -MP -MF ".deps/SurfParamTool.Tpo" -c -o SurfParamTool.lo ../../geom/SurfParamTool.cpp; \
then mv -f ".deps/SurfParamTool.Tpo" ".deps/SurfParamTool.Plo"; else rm -f ".deps/SurfParamTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceOverlapFacet.lo -MD -MP -MF .deps/SurfaceOverlapFacet.Tpo -c ../../geom/SurfaceOverlapFacet.cpp -o SurfaceOverlapFacet.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT Surface.lo -MD -MP -MF .deps/Surface.Tpo -c ../../geom/Surface.cpp -o Surface.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceSM.lo -MD -MP -MF ".deps/SurfaceSM.Tpo" -c -o SurfaceSM.lo ../../geom/SurfaceSM.cpp; \
then mv -f ".deps/SurfaceSM.Tpo" ".deps/SurfaceSM.Plo"; else rm -f ".deps/SurfaceSM.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceOverlapTool.lo -MD -MP -MF .deps/SurfaceOverlapTool.Tpo -c ../../geom/SurfaceOverlapTool.cpp -o SurfaceOverlapTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfParamTool.lo -MD -MP -MF .deps/SurfParamTool.Tpo -c ../../geom/SurfParamTool.cpp -o SurfParamTool.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDCAGE.lo -MD -MP -MF ".deps/TDCAGE.Tpo" -c -o TDCAGE.lo ../../geom/TDCAGE.cpp; \
then mv -f ".deps/TDCAGE.Tpo" ".deps/TDCAGE.Plo"; else rm -f ".deps/TDCAGE.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT SurfaceSM.lo -MD -MP -MF .deps/SurfaceSM.Tpo -c ../../geom/SurfaceSM.cpp -o SurfaceSM.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSourceFeature.lo -MD -MP -MF ".deps/TDSourceFeature.Tpo" -c -o TDSourceFeature.lo ../../geom/TDSourceFeature.cpp; \
then mv -f ".deps/TDSourceFeature.Tpo" ".deps/TDSourceFeature.Plo"; else rm -f ".deps/TDSourceFeature.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSplitSurface.lo -MD -MP -MF ".deps/TDSplitSurface.Tpo" -c -o TDSplitSurface.lo ../../geom/TDSplitSurface.cpp; \
then mv -f ".deps/TDSplitSurface.Tpo" ".deps/TDSplitSurface.Plo"; else rm -f ".deps/TDSplitSurface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSourceFeature.lo -MD -MP -MF .deps/TDSourceFeature.Tpo -c ../../geom/TDSourceFeature.cpp -o TDSourceFeature.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSurfaceOverlap.lo -MD -MP -MF ".deps/TDSurfaceOverlap.Tpo" -c -o TDSurfaceOverlap.lo ../../geom/TDSurfaceOverlap.cpp; \
then mv -f ".deps/TDSurfaceOverlap.Tpo" ".deps/TDSurfaceOverlap.Plo"; else rm -f ".deps/TDSurfaceOverlap.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDUniqueId.lo -MD -MP -MF ".deps/TDUniqueId.Tpo" -c -o TDUniqueId.lo ../../geom/TDUniqueId.cpp; \
then mv -f ".deps/TDUniqueId.Tpo" ".deps/TDUniqueId.Plo"; else rm -f ".deps/TDUniqueId.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSurfaceOverlap.lo -MD -MP -MF .deps/TDSurfaceOverlap.Tpo -c ../../geom/TDSurfaceOverlap.cpp -o TDSurfaceOverlap.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDUniqueId.lo -MD -MP -MF .deps/TDUniqueId.Tpo -c ../../geom/TDUniqueId.cpp -o TDUniqueId.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDCAGE.lo -MD -MP -MF .deps/TDCAGE.Tpo -c ../../geom/TDCAGE.cpp -o TDCAGE.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TopologyBridge.lo -MD -MP -MF ".deps/TopologyBridge.Tpo" -c -o TopologyBridge.lo ../../geom/TopologyBridge.cpp; \
then mv -f ".deps/TopologyBridge.Tpo" ".deps/TopologyBridge.Plo"; else rm -f ".deps/TopologyBridge.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TDSplitSurface.lo -MD -MP -MF .deps/TDSplitSurface.Tpo -c ../../geom/TDSplitSurface.cpp -o TDSplitSurface.o
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TopologyEntity.lo -MD -MP -MF ".deps/TopologyEntity.Tpo" -c -o TopologyEntity.lo ../../geom/TopologyEntity.cpp; \
then mv -f ".deps/TopologyEntity.Tpo" ".deps/TopologyEntity.Plo"; else rm -f ".deps/TopologyEntity.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TopologyBridge.lo -MD -MP -MF .deps/TopologyBridge.Tpo -c ../../geom/TopologyBridge.cpp -o TopologyBridge.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../geom -I.. -I../itaps -I../../util -I. -Wall -pipe -O2 -DNDEBUG -MT TopologyEntity.lo -MD -MP -MF .deps/TopologyEntity.Tpo -c ../../geom/TopologyEntity.cpp -o TopologyEntity.o
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcubit_geom.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib AllocMemManagersGeom.lo AnalyticGeometryTool.lo BasicTopologyEntity.lo Body.lo BodySM.lo BoundingBoxTool.lo BridgeManager.lo CAActuateSet.lo CADeferredAttrib.lo CAEntityColor.lo CAEntityId.lo CAEntityName.lo CAGroup.lo CAMergePartner.lo CAMergeStatus.lo CASourceFeature.lo CAUniqueId.lo CGMApp.lo CGMEngineDynamicLoader.lo Chain.lo CoEdge.lo CoEdgeSM.lo CoFace.lo CollectionEntity.lo CoVertex.lo CoVolume.lo CubitAttrib.lo CubitAttribManager.lo CubitAttribUser.lo CubitPolygon.lo CubitSimpleAttrib.lo Curve.lo CurveOverlapFacet.lo CurveSM.lo CylinderEvaluator.lo DAG.lo DagDrawingTool.lo GeomDataObserver.lo GeometryEntity.lo GeometryFeatureEngine.lo GeometryFeatureTool.lo GeometryHealerEngine.lo GeometryHealerTool.lo GeometryModifyEngine.lo GeometryModifyTool.lo GeometryQueryEngine.lo GeometryQueryTool.lo GeometryUtil.lo GeomMeasureToo!
l.lo GfxPreview.lo GroupingEntity.lo GSaveOpen.lo Loop.lo LoopSM.lo Lump.lo LumpSM.lo MedialTool2D.lo MedialTool3D.lo MergeToolAssistant.lo MergeTool.lo MidPlaneTool.lo ModelEntity.lo ModelQueryEngine.lo OffsetSplitTool.lo OldUnmergeCode.lo Point.lo PointSM.lo RefCollection.lo RefEdge.lo RefEntity.lo RefEntityFactory.lo RefEntityName.lo RefFace.lo RefGroup.lo RefVertex.lo RefVolume.lo SenseEntity.lo Shell.lo ShellSM.lo SphereEvaluator.lo SplitSurfaceTool.lo Surface.lo SurfaceOverlapFacet.lo SurfaceOverlapTool.lo SurfParamTool.lo SurfaceSM.lo TDCAGE.lo TDSourceFeature.lo TDSplitSurface.lo TDSurfaceOverlap.lo TDUniqueId.lo TopologyBridge.lo TopologyEntity.lo ../util/libcubit_util.la -lm
mkdir .libs
ar cru .libs/libcubit_geom.a AllocMemManagersGeom.o AnalyticGeometryTool.o BasicTopologyEntity.o Body.o BodySM.o BoundingBoxTool.o BridgeManager.o CAActuateSet.o CADeferredAttrib.o CAEntityColor.o CAEntityId.o CAEntityName.o CAGroup.o CAMergePartner.o CAMergeStatus.o CASourceFeature.o CAUniqueId.o CGMApp.o CGMEngineDynamicLoader.o Chain.o CoEdge.o CoEdgeSM.o CoFace.o CollectionEntity.o CoVertex.o CoVolume.o CubitAttrib.o CubitAttribManager.o CubitAttribUser.o CubitPolygon.o CubitSimpleAttrib.o Curve.o CurveOverlapFacet.o CurveSM.o CylinderEvaluator.o DAG.o DagDrawingTool.o GeomDataObserver.o GeometryEntity.o GeometryFeatureEngine.o GeometryFeatureTool.o GeometryHealerEngine.o GeometryHealerTool.o GeometryModifyEngine.o GeometryModifyTool.o GeometryQueryEngine.o GeometryQueryTool.o GeometryUtil.o GeomMeasureTool.o GfxPreview.o GroupingEntity.o GSaveOpen.o Loop.o LoopSM.o Lump.o LumpSM.o MedialTool2D.o MedialTool3D.o MergeToolAssistant.o MergeTool.o MidPlaneTool.o ModelEntity!
.o ModelQueryEngine.o OffsetSplitTool.o OldUnmergeCode.o Point.o PointSM.o RefCollection.o RefEdge.o RefEntity.o RefEntityFactory.o RefEntityName.o RefFace.o RefGroup.o RefVertex.o RefVolume.o SenseEntity.o Shell.o ShellSM.o SphereEvaluator.o SplitSurfaceTool.o Surface.o SurfaceOverlapFacet.o SurfaceOverlapTool.o SurfParamTool.o SurfaceSM.o TDCAGE.o TDSourceFeature.o TDSplitSurface.o TDSurfaceOverlap.o TDUniqueId.o TopologyBridge.o TopologyEntity.o
ranlib .libs/libcubit_geom.a
creating libcubit_geom.la
(cd .libs && rm -f libcubit_geom.la && ln -s ../libcubit_geom.la libcubit_geom.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in Cholla
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersCholla.lo -MD -MP -MF ".deps/AllocMemManagersCholla.Tpo" -c -o AllocMemManagersCholla.lo ../../../geom/Cholla/AllocMemManagersCholla.cpp; \
then mv -f ".deps/AllocMemManagersCholla.Tpo" ".deps/AllocMemManagersCholla.Plo"; else rm -f ".deps/AllocMemManagersCholla.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT Cholla.lo -MD -MP -MF ".deps/Cholla.Tpo" -c -o Cholla.lo ../../../geom/Cholla/Cholla.cpp; \
then mv -f ".deps/Cholla.Tpo" ".deps/Cholla.Plo"; else rm -f ".deps/Cholla.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaCurve.lo -MD -MP -MF ".deps/ChollaCurve.Tpo" -c -o ChollaCurve.lo ../../../geom/Cholla/ChollaCurve.cpp; \
then mv -f ".deps/ChollaCurve.Tpo" ".deps/ChollaCurve.Plo"; else rm -f ".deps/ChollaCurve.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaEngine.lo -MD -MP -MF ".deps/ChollaEngine.Tpo" -c -o ChollaEngine.lo ../../../geom/Cholla/ChollaEngine.cpp; \
then mv -f ".deps/ChollaEngine.Tpo" ".deps/ChollaEngine.Plo"; else rm -f ".deps/ChollaEngine.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaEntity.lo -MD -MP -MF ".deps/ChollaEntity.Tpo" -c -o ChollaEntity.lo ../../../geom/Cholla/ChollaEntity.cpp; \
then mv -f ".deps/ChollaEntity.Tpo" ".deps/ChollaEntity.Plo"; else rm -f ".deps/ChollaEntity.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaPoint.lo -MD -MP -MF ".deps/ChollaPoint.Tpo" -c -o ChollaPoint.lo ../../../geom/Cholla/ChollaPoint.cpp; \
then mv -f ".deps/ChollaPoint.Tpo" ".deps/ChollaPoint.Plo"; else rm -f ".deps/ChollaPoint.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaSkinTool.lo -MD -MP -MF ".deps/ChollaSkinTool.Tpo" -c -o ChollaSkinTool.lo ../../../geom/Cholla/ChollaSkinTool.cpp; \
then mv -f ".deps/ChollaSkinTool.Tpo" ".deps/ChollaSkinTool.Plo"; else rm -f ".deps/ChollaSkinTool.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaSurface.lo -MD -MP -MF ".deps/ChollaSurface.Tpo" -c -o ChollaSurface.lo ../../../geom/Cholla/ChollaSurface.cpp; \
then mv -f ".deps/ChollaSurface.Tpo" ".deps/ChollaSurface.Plo"; else rm -f ".deps/ChollaSurface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT Cholla.lo -MD -MP -MF .deps/Cholla.Tpo -c ../../../geom/Cholla/Cholla.cpp -o Cholla.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaPoint.lo -MD -MP -MF .deps/ChollaPoint.Tpo -c ../../../geom/Cholla/ChollaPoint.cpp -o ChollaPoint.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaCurve.lo -MD -MP -MF .deps/ChollaCurve.Tpo -c ../../../geom/Cholla/ChollaCurve.cpp -o ChollaCurve.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaSurface.lo -MD -MP -MF .deps/ChollaSurface.Tpo -c ../../../geom/Cholla/ChollaSurface.cpp -o ChollaSurface.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaSkinTool.lo -MD -MP -MF .deps/ChollaSkinTool.Tpo -c ../../../geom/Cholla/ChollaSkinTool.cpp -o ChollaSkinTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersCholla.lo -MD -MP -MF .deps/AllocMemManagersCholla.Tpo -c ../../../geom/Cholla/AllocMemManagersCholla.cpp -o AllocMemManagersCholla.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChollaEngine.lo -MD -MP -MF .deps/ChollaEngine.Tpo -c ../../../geom/Cholla/ChollaEngine.cpp -o ChollaEngine.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChordalAxis.lo -MD -MP -MF ".deps/ChordalAxis.Tpo" -c -o ChordalAxis.lo ../../../geom/Cholla/ChordalAxis.cpp; \
then mv -f ".deps/ChordalAxis.Tpo" ".deps/ChordalAxis.Plo"; else rm -f ".deps/ChordalAxis.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacet.lo -MD -MP -MF ".deps/CubitFacet.Tpo" -c -o CubitFacet.lo ../../../geom/Cholla/CubitFacet.cpp; \
then mv -f ".deps/CubitFacet.Tpo" ".deps/CubitFacet.Plo"; else rm -f ".deps/CubitFacet.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetData.lo -MD -MP -MF ".deps/CubitFacetData.Tpo" -c -o CubitFacetData.lo ../../../geom/Cholla/CubitFacetData.cpp; \
then mv -f ".deps/CubitFacetData.Tpo" ".deps/CubitFacetData.Plo"; else rm -f ".deps/CubitFacetData.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetEdge.lo -MD -MP -MF ".deps/CubitFacetEdge.Tpo" -c -o CubitFacetEdge.lo ../../../geom/Cholla/CubitFacetEdge.cpp; \
then mv -f ".deps/CubitFacetEdge.Tpo" ".deps/CubitFacetEdge.Plo"; else rm -f ".deps/CubitFacetEdge.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacet.lo -MD -MP -MF .deps/CubitFacet.Tpo -c ../../../geom/Cholla/CubitFacet.cpp -o CubitFacet.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT ChordalAxis.lo -MD -MP -MF .deps/ChordalAxis.Tpo -c ../../../geom/Cholla/ChordalAxis.cpp -o ChordalAxis.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetEdge.lo -MD -MP -MF .deps/CubitFacetEdge.Tpo -c ../../../geom/Cholla/CubitFacetEdge.cpp -o CubitFacetEdge.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetEdgeData.lo -MD -MP -MF ".deps/CubitFacetEdgeData.Tpo" -c -o CubitFacetEdgeData.lo ../../../geom/Cholla/CubitFacetEdgeData.cpp; \
then mv -f ".deps/CubitFacetEdgeData.Tpo" ".deps/CubitFacetEdgeData.Plo"; else rm -f ".deps/CubitFacetEdgeData.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetData.lo -MD -MP -MF .deps/CubitFacetData.Tpo -c ../../../geom/Cholla/CubitFacetData.cpp -o CubitFacetData.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitPoint.lo -MD -MP -MF ".deps/CubitPoint.Tpo" -c -o CubitPoint.lo ../../../geom/Cholla/CubitPoint.cpp; \
then mv -f ".deps/CubitPoint.Tpo" ".deps/CubitPoint.Plo"; else rm -f ".deps/CubitPoint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitPoint.lo -MD -MP -MF .deps/CubitPoint.Tpo -c ../../../geom/Cholla/CubitPoint.cpp -o CubitPoint.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitFacetEdgeData.lo -MD -MP -MF .deps/CubitFacetEdgeData.Tpo -c ../../../geom/Cholla/CubitFacetEdgeData.cpp -o CubitFacetEdgeData.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitPointData.lo -MD -MP -MF ".deps/CubitPointData.Tpo" -c -o CubitPointData.lo ../../../geom/Cholla/CubitPointData.cpp; \
then mv -f ".deps/CubitPointData.Tpo" ".deps/CubitPointData.Plo"; else rm -f ".deps/CubitPointData.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitQuadFacet.lo -MD -MP -MF ".deps/CubitQuadFacet.Tpo" -c -o CubitQuadFacet.lo ../../../geom/Cholla/CubitQuadFacet.cpp; \
then mv -f ".deps/CubitQuadFacet.Tpo" ".deps/CubitQuadFacet.Plo"; else rm -f ".deps/CubitQuadFacet.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitQuadFacetData.lo -MD -MP -MF ".deps/CubitQuadFacetData.Tpo" -c -o CubitQuadFacetData.lo ../../../geom/Cholla/CubitQuadFacetData.cpp; \
then mv -f ".deps/CubitQuadFacetData.Tpo" ".deps/CubitQuadFacetData.Plo"; else rm -f ".deps/CubitQuadFacetData.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CurveFacetEvalTool.lo -MD -MP -MF ".deps/CurveFacetEvalTool.Tpo" -c -o CurveFacetEvalTool.lo ../../../geom/Cholla/CurveFacetEvalTool.cpp; \
then mv -f ".deps/CurveFacetEvalTool.Tpo" ".deps/CurveFacetEvalTool.Plo"; else rm -f ".deps/CurveFacetEvalTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitQuadFacetData.lo -MD -MP -MF .deps/CubitQuadFacetData.Tpo -c ../../../geom/Cholla/CubitQuadFacetData.cpp -o CubitQuadFacetData.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT debug.lo -MD -MP -MF ".deps/debug.Tpo" -c -o debug.lo ../../../geom/Cholla/debug.cpp; \
then mv -f ".deps/debug.Tpo" ".deps/debug.Plo"; else rm -f ".deps/debug.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitPointData.lo -MD -MP -MF .deps/CubitPointData.Tpo -c ../../../geom/Cholla/CubitPointData.cpp -o CubitPointData.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CubitQuadFacet.lo -MD -MP -MF .deps/CubitQuadFacet.Tpo -c ../../../geom/Cholla/CubitQuadFacet.cpp -o CubitQuadFacet.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetDataUtil.lo -MD -MP -MF ".deps/FacetDataUtil.Tpo" -c -o FacetDataUtil.lo ../../../geom/Cholla/FacetDataUtil.cpp; \
then mv -f ".deps/FacetDataUtil.Tpo" ".deps/FacetDataUtil.Plo"; else rm -f ".deps/FacetDataUtil.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetEntity.lo -MD -MP -MF ".deps/FacetEntity.Tpo" -c -o FacetEntity.lo ../../../geom/Cholla/FacetEntity.cpp; \
then mv -f ".deps/FacetEntity.Tpo" ".deps/FacetEntity.Plo"; else rm -f ".deps/FacetEntity.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT debug.lo -MD -MP -MF .deps/debug.Tpo -c ../../../geom/Cholla/debug.cpp -o debug.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT CurveFacetEvalTool.lo -MD -MP -MF .deps/CurveFacetEvalTool.Tpo -c ../../../geom/Cholla/CurveFacetEvalTool.cpp -o CurveFacetEvalTool.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetEvalTool.lo -MD -MP -MF ".deps/FacetEvalTool.Tpo" -c -o FacetEvalTool.lo ../../../geom/Cholla/FacetEvalTool.cpp; \
then mv -f ".deps/FacetEvalTool.Tpo" ".deps/FacetEvalTool.Plo"; else rm -f ".deps/FacetEvalTool.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT GeoNode.lo -MD -MP -MF ".deps/GeoNode.Tpo" -c -o GeoNode.lo ../../../geom/Cholla/GeoNode.cpp; \
then mv -f ".deps/GeoNode.Tpo" ".deps/GeoNode.Plo"; else rm -f ".deps/GeoNode.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetEvalTool.lo -MD -MP -MF .deps/FacetEvalTool.Tpo -c ../../../geom/Cholla/FacetEvalTool.cpp -o FacetEvalTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetDataUtil.lo -MD -MP -MF .deps/FacetDataUtil.Tpo -c ../../../geom/Cholla/FacetDataUtil.cpp -o FacetDataUtil.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT GeoTet.lo -MD -MP -MF ".deps/GeoTet.Tpo" -c -o GeoTet.lo ../../../geom/Cholla/GeoTet.cpp; \
then mv -f ".deps/GeoTet.Tpo" ".deps/GeoTet.Plo"; else rm -f ".deps/GeoTet.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT LoopParamTool.lo -MD -MP -MF ".deps/LoopParamTool.Tpo" -c -o LoopParamTool.lo ../../../geom/Cholla/LoopParamTool.cpp; \
then mv -f ".deps/LoopParamTool.Tpo" ".deps/LoopParamTool.Plo"; else rm -f ".deps/LoopParamTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FacetEntity.lo -MD -MP -MF .deps/FacetEntity.Tpo -c ../../../geom/Cholla/FacetEntity.cpp -o FacetEntity.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT GeoNode.lo -MD -MP -MF .deps/GeoNode.Tpo -c ../../../geom/Cholla/GeoNode.cpp -o GeoNode.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT PointGridSearch.lo -MD -MP -MF ".deps/PointGridSearch.Tpo" -c -o PointGridSearch.lo ../../../geom/Cholla/PointGridSearch.cpp; \
then mv -f ".deps/PointGridSearch.Tpo" ".deps/PointGridSearch.Plo"; else rm -f ".deps/PointGridSearch.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT GeoTet.lo -MD -MP -MF .deps/GeoTet.Tpo -c ../../../geom/Cholla/GeoTet.cpp -o GeoTet.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT PointLoopFacetor.lo -MD -MP -MF ".deps/PointLoopFacetor.Tpo" -c -o PointLoopFacetor.lo ../../../geom/Cholla/PointLoopFacetor.cpp; \
then mv -f ".deps/PointLoopFacetor.Tpo" ".deps/PointLoopFacetor.Plo"; else rm -f ".deps/PointLoopFacetor.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT LoopParamTool.lo -MD -MP -MF .deps/LoopParamTool.Tpo -c ../../../geom/Cholla/LoopParamTool.cpp -o LoopParamTool.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDChordal.lo -MD -MP -MF ".deps/TDChordal.Tpo" -c -o TDChordal.lo ../../../geom/Cholla/TDChordal.cpp; \
then mv -f ".deps/TDChordal.Tpo" ".deps/TDChordal.Plo"; else rm -f ".deps/TDChordal.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT PointLoopFacetor.lo -MD -MP -MF .deps/PointLoopFacetor.Tpo -c ../../../geom/Cholla/PointLoopFacetor.cpp -o PointLoopFacetor.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetboolData.lo -MD -MP -MF ".deps/TDFacetboolData.Tpo" -c -o TDFacetboolData.lo ../../../geom/Cholla/TDFacetboolData.cpp; \
then mv -f ".deps/TDFacetboolData.Tpo" ".deps/TDFacetboolData.Plo"; else rm -f ".deps/TDFacetboolData.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT PointGridSearch.lo -MD -MP -MF .deps/PointGridSearch.Tpo -c ../../../geom/Cholla/PointGridSearch.cpp -o PointGridSearch.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetBoundaryEdge.lo -MD -MP -MF ".deps/TDFacetBoundaryEdge.Tpo" -c -o TDFacetBoundaryEdge.lo ../../../geom/Cholla/TDFacetBoundaryEdge.cpp; \
then mv -f ".deps/TDFacetBoundaryEdge.Tpo" ".deps/TDFacetBoundaryEdge.Plo"; else rm -f ".deps/TDFacetBoundaryEdge.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDChordal.lo -MD -MP -MF .deps/TDChordal.Tpo -c ../../../geom/Cholla/TDChordal.cpp -o TDChordal.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetboolData.lo -MD -MP -MF .deps/TDFacetboolData.Tpo -c ../../../geom/Cholla/TDFacetboolData.cpp -o TDFacetboolData.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetBoundaryPoint.lo -MD -MP -MF ".deps/TDFacetBoundaryPoint.Tpo" -c -o TDFacetBoundaryPoint.lo ../../../geom/Cholla/TDFacetBoundaryPoint.cpp; \
then mv -f ".deps/TDFacetBoundaryPoint.Tpo" ".deps/TDFacetBoundaryPoint.Plo"; else rm -f ".deps/TDFacetBoundaryPoint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetBoundaryEdge.lo -MD -MP -MF .deps/TDFacetBoundaryEdge.Tpo -c ../../../geom/Cholla/TDFacetBoundaryEdge.cpp -o TDFacetBoundaryEdge.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDGeomFacet.lo -MD -MP -MF ".deps/TDGeomFacet.Tpo" -c -o TDGeomFacet.lo ../../../geom/Cholla/TDGeomFacet.cpp; \
then mv -f ".deps/TDGeomFacet.Tpo" ".deps/TDGeomFacet.Plo"; else rm -f ".deps/TDGeomFacet.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDFacetBoundaryPoint.lo -MD -MP -MF .deps/TDFacetBoundaryPoint.Tpo -c ../../../geom/Cholla/TDFacetBoundaryPoint.cpp -o TDFacetBoundaryPoint.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/Cholla -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT TDGeomFacet.lo -MD -MP -MF .deps/TDGeomFacet.Tpo -c ../../../geom/Cholla/TDGeomFacet.cpp -o TDGeomFacet.o
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcholla.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib AllocMemManagersCholla.lo Cholla.lo ChollaCurve.lo ChollaEngine.lo ChollaEntity.lo ChollaPoint.lo ChollaSkinTool.lo ChollaSurface.lo ChordalAxis.lo CubitFacet.lo CubitFacetData.lo CubitFacetEdge.lo CubitFacetEdgeData.lo CubitPoint.lo CubitPointData.lo CubitQuadFacet.lo CubitQuadFacetData.lo CurveFacetEvalTool.lo debug.lo FacetDataUtil.lo FacetEntity.lo FacetEvalTool.lo GeoNode.lo GeoTet.lo LoopParamTool.lo PointGridSearch.lo PointLoopFacetor.lo TDChordal.lo TDFacetboolData.lo TDFacetBoundaryEdge.lo TDFacetBoundaryPoint.lo TDGeomFacet.lo ../libcubit_geom.la -lm
mkdir .libs
ar cru .libs/libcholla.a AllocMemManagersCholla.o Cholla.o ChollaCurve.o ChollaEngine.o ChollaEntity.o ChollaPoint.o ChollaSkinTool.o ChollaSurface.o ChordalAxis.o CubitFacet.o CubitFacetData.o CubitFacetEdge.o CubitFacetEdgeData.o CubitPoint.o CubitPointData.o CubitQuadFacet.o CubitQuadFacetData.o CurveFacetEvalTool.o debug.o FacetDataUtil.o FacetEntity.o FacetEvalTool.o GeoNode.o GeoTet.o LoopParamTool.o PointGridSearch.o PointLoopFacetor.o TDChordal.o TDFacetboolData.o TDFacetBoundaryEdge.o TDFacetBoundaryPoint.o TDGeomFacet.o
ranlib .libs/libcholla.a
creating libcholla.la
(cd .libs && rm -f libcholla.la && ln -s ../libcholla.la libcholla.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
Making all in facetbool
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBClassify.lo -MD -MP -MF ".deps/FBClassify.Tpo" -c -o FBClassify.lo ../../../geom/facetbool/FBClassify.cpp; \
then mv -f ".deps/FBClassify.Tpo" ".deps/FBClassify.Plo"; else rm -f ".deps/FBClassify.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBDataUtil.lo -MD -MP -MF ".deps/FBDataUtil.Tpo" -c -o FBDataUtil.lo ../../../geom/facetbool/FBDataUtil.cpp; \
then mv -f ".deps/FBDataUtil.Tpo" ".deps/FBDataUtil.Plo"; else rm -f ".deps/FBDataUtil.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBImprint.lo -MD -MP -MF ".deps/FBImprint.Tpo" -c -o FBImprint.lo ../../../geom/facetbool/FBImprint.cpp; \
then mv -f ".deps/FBImprint.Tpo" ".deps/FBImprint.Plo"; else rm -f ".deps/FBImprint.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBIntersect.lo -MD -MP -MF ".deps/FBIntersect.Tpo" -c -o FBIntersect.lo ../../../geom/facetbool/FBIntersect.cpp; \
then mv -f ".deps/FBIntersect.Tpo" ".deps/FBIntersect.Plo"; else rm -f ".deps/FBIntersect.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBPolyhedron.lo -MD -MP -MF ".deps/FBPolyhedron.Tpo" -c -o FBPolyhedron.lo ../../../geom/facetbool/FBPolyhedron.cpp; \
then mv -f ".deps/FBPolyhedron.Tpo" ".deps/FBPolyhedron.Plo"; else rm -f ".deps/FBPolyhedron.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBRetriangulate.lo -MD -MP -MF ".deps/FBRetriangulate.Tpo" -c -o FBRetriangulate.lo ../../../geom/facetbool/FBRetriangulate.cpp; \
then mv -f ".deps/FBRetriangulate.Tpo" ".deps/FBRetriangulate.Plo"; else rm -f ".deps/FBRetriangulate.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBTiler.lo -MD -MP -MF ".deps/FBTiler.Tpo" -c -o FBTiler.lo ../../../geom/facetbool/FBTiler.cpp; \
then mv -f ".deps/FBTiler.Tpo" ".deps/FBTiler.Plo"; else rm -f ".deps/FBTiler.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT IntegerHash.lo -MD -MP -MF ".deps/IntegerHash.Tpo" -c -o IntegerHash.lo ../../../geom/facetbool/IntegerHash.cpp; \
then mv -f ".deps/IntegerHash.Tpo" ".deps/IntegerHash.Plo"; else rm -f ".deps/IntegerHash.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBIntersect.lo -MD -MP -MF .deps/FBIntersect.Tpo -c ../../../geom/facetbool/FBIntersect.cpp -o FBIntersect.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBImprint.lo -MD -MP -MF .deps/FBImprint.Tpo -c ../../../geom/facetbool/FBImprint.cpp -o FBImprint.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBPolyhedron.lo -MD -MP -MF .deps/FBPolyhedron.Tpo -c ../../../geom/facetbool/FBPolyhedron.cpp -o FBPolyhedron.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBRetriangulate.lo -MD -MP -MF .deps/FBRetriangulate.Tpo -c ../../../geom/facetbool/FBRetriangulate.cpp -o FBRetriangulate.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT IntegerHash.lo -MD -MP -MF .deps/IntegerHash.Tpo -c ../../../geom/facetbool/IntegerHash.cpp -o IntegerHash.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBClassify.lo -MD -MP -MF .deps/FBClassify.Tpo -c ../../../geom/facetbool/FBClassify.cpp -o FBClassify.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBTiler.lo -MD -MP -MF .deps/FBTiler.Tpo -c ../../../geom/facetbool/FBTiler.cpp -o FBTiler.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT KdTree.lo -MD -MP -MF ".deps/KdTree.Tpo" -c -o KdTree.lo ../../../geom/facetbool/KdTree.cpp; \
then mv -f ".deps/KdTree.Tpo" ".deps/KdTree.Plo"; else rm -f ".deps/KdTree.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT FBDataUtil.lo -MD -MP -MF .deps/FBDataUtil.Tpo -c ../../../geom/facetbool/FBDataUtil.cpp -o FBDataUtil.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facetbool -I../.. -I../../itaps -I../../../util -I../../../geom -Wall -pipe -O2 -DNDEBUG -MT KdTree.lo -MD -MP -MF .deps/KdTree.Tpo -c ../../../geom/facetbool/KdTree.cpp -o KdTree.o
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcubit_facetbool.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib FBClassify.lo FBDataUtil.lo FBImprint.lo FBIntersect.lo FBPolyhedron.lo FBRetriangulate.lo FBTiler.lo IntegerHash.lo KdTree.lo ../libcubit_geom.la -lm
mkdir .libs
ar cru .libs/libcubit_facetbool.a FBClassify.o FBDataUtil.o FBImprint.o FBIntersect.o FBPolyhedron.o FBRetriangulate.o FBTiler.o IntegerHash.o KdTree.o
ranlib .libs/libcubit_facetbool.a
creating libcubit_facetbool.la
(cd .libs && rm -f libcubit_facetbool.la && ln -s ../libcubit_facetbool.la libcubit_facetbool.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
Making all in facet
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetAttrib.lo -MD -MP -MF ".deps/FacetAttrib.Tpo" -c -o FacetAttrib.lo ../../../geom/facet/FacetAttrib.cpp; \
then mv -f ".deps/FacetAttrib.Tpo" ".deps/FacetAttrib.Plo"; else rm -f ".deps/FacetAttrib.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetAttribSet.lo -MD -MP -MF ".deps/FacetAttribSet.Tpo" -c -o FacetAttribSet.lo ../../../geom/facet/FacetAttribSet.cpp; \
then mv -f ".deps/FacetAttribSet.Tpo" ".deps/FacetAttribSet.Plo"; else rm -f ".deps/FacetAttribSet.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetBody.lo -MD -MP -MF ".deps/FacetBody.Tpo" -c -o FacetBody.lo ../../../geom/facet/FacetBody.cpp; \
then mv -f ".deps/FacetBody.Tpo" ".deps/FacetBody.Plo"; else rm -f ".deps/FacetBody.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetboolInterface.lo -MD -MP -MF ".deps/FacetboolInterface.Tpo" -c -o FacetboolInterface.lo ../../../geom/facet/FacetboolInterface.cpp; \
then mv -f ".deps/FacetboolInterface.Tpo" ".deps/FacetboolInterface.Plo"; else rm -f ".deps/FacetboolInterface.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetCoEdge.lo -MD -MP -MF ".deps/FacetCoEdge.Tpo" -c -o FacetCoEdge.lo ../../../geom/facet/FacetCoEdge.cpp; \
then mv -f ".deps/FacetCoEdge.Tpo" ".deps/FacetCoEdge.Plo"; else rm -f ".deps/FacetCoEdge.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetCurve.lo -MD -MP -MF ".deps/FacetCurve.Tpo" -c -o FacetCurve.lo ../../../geom/facet/FacetCurve.cpp; \
then mv -f ".deps/FacetCurve.Tpo" ".deps/FacetCurve.Plo"; else rm -f ".deps/FacetCurve.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetLoop.lo -MD -MP -MF ".deps/FacetLoop.Tpo" -c -o FacetLoop.lo ../../../geom/facet/FacetLoop.cpp; \
then mv -f ".deps/FacetLoop.Tpo" ".deps/FacetLoop.Plo"; else rm -f ".deps/FacetLoop.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetLump.lo -MD -MP -MF ".deps/FacetLump.Tpo" -c -o FacetLump.lo ../../../geom/facet/FacetLump.cpp; \
then mv -f ".deps/FacetLump.Tpo" ".deps/FacetLump.Plo"; else rm -f ".deps/FacetLump.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetAttrib.lo -MD -MP -MF .deps/FacetAttrib.Tpo -c ../../../geom/facet/FacetAttrib.cpp -o FacetAttrib.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetboolInterface.lo -MD -MP -MF .deps/FacetboolInterface.Tpo -c ../../../geom/facet/FacetboolInterface.cpp -o FacetboolInterface.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetCurve.lo -MD -MP -MF .deps/FacetCurve.Tpo -c ../../../geom/facet/FacetCurve.cpp -o FacetCurve.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetBody.lo -MD -MP -MF .deps/FacetBody.Tpo -c ../../../geom/facet/FacetBody.cpp -o FacetBody.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetAttribSet.lo -MD -MP -MF .deps/FacetAttribSet.Tpo -c ../../../geom/facet/FacetAttribSet.cpp -o FacetAttribSet.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetLump.lo -MD -MP -MF .deps/FacetLump.Tpo -c ../../../geom/facet/FacetLump.cpp -o FacetLump.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetCoEdge.lo -MD -MP -MF .deps/FacetCoEdge.Tpo -c ../../../geom/facet/FacetCoEdge.cpp -o FacetCoEdge.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetLoop.lo -MD -MP -MF .deps/FacetLoop.Tpo -c ../../../geom/facet/FacetLoop.cpp -o FacetLoop.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetModifyEngine.lo -MD -MP -MF ".deps/FacetModifyEngine.Tpo" -c -o FacetModifyEngine.lo ../../../geom/facet/FacetModifyEngine.cpp; \
then mv -f ".deps/FacetModifyEngine.Tpo" ".deps/FacetModifyEngine.Plo"; else rm -f ".deps/FacetModifyEngine.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetParamTool.lo -MD -MP -MF ".deps/FacetParamTool.Tpo" -c -o FacetParamTool.lo ../../../geom/facet/FacetParamTool.cpp; \
then mv -f ".deps/FacetParamTool.Tpo" ".deps/FacetParamTool.Plo"; else rm -f ".deps/FacetParamTool.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetPoint.lo -MD -MP -MF ".deps/FacetPoint.Tpo" -c -o FacetPoint.lo ../../../geom/facet/FacetPoint.cpp; \
then mv -f ".deps/FacetPoint.Tpo" ".deps/FacetPoint.Plo"; else rm -f ".deps/FacetPoint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetParamTool.lo -MD -MP -MF .deps/FacetParamTool.Tpo -c ../../../geom/facet/FacetParamTool.cpp -o FacetParamTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetModifyEngine.lo -MD -MP -MF .deps/FacetModifyEngine.Tpo -c ../../../geom/facet/FacetModifyEngine.cpp -o FacetModifyEngine.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetQueryEngine.lo -MD -MP -MF ".deps/FacetQueryEngine.Tpo" -c -o FacetQueryEngine.lo ../../../geom/facet/FacetQueryEngine.cpp; \
then mv -f ".deps/FacetQueryEngine.Tpo" ".deps/FacetQueryEngine.Plo"; else rm -f ".deps/FacetQueryEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetPoint.lo -MD -MP -MF .deps/FacetPoint.Tpo -c ../../../geom/facet/FacetPoint.cpp -o FacetPoint.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetShell.lo -MD -MP -MF ".deps/FacetShell.Tpo" -c -o FacetShell.lo ../../../geom/facet/FacetShell.cpp; \
then mv -f ".deps/FacetShell.Tpo" ".deps/FacetShell.Plo"; else rm -f ".deps/FacetShell.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetSurface.lo -MD -MP -MF ".deps/FacetSurface.Tpo" -c -o FacetSurface.lo ../../../geom/facet/FacetSurface.cpp; \
then mv -f ".deps/FacetSurface.Tpo" ".deps/FacetSurface.Plo"; else rm -f ".deps/FacetSurface.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT GridSearchTree.lo -MD -MP -MF ".deps/GridSearchTree.Tpo" -c -o GridSearchTree.lo ../../../geom/facet/GridSearchTree.cpp; \
then mv -f ".deps/GridSearchTree.Tpo" ".deps/GridSearchTree.Plo"; else rm -f ".deps/GridSearchTree.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetQueryEngine.lo -MD -MP -MF .deps/FacetQueryEngine.Tpo -c ../../../geom/facet/FacetQueryEngine.cpp -o FacetQueryEngine.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetSurface.lo -MD -MP -MF .deps/FacetSurface.Tpo -c ../../../geom/facet/FacetSurface.cpp -o FacetSurface.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT FacetShell.lo -MD -MP -MF .deps/FacetShell.Tpo -c ../../../geom/facet/FacetShell.cpp -o FacetShell.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/facet -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/Cholla -I../../../geom/facetbool -Wall -pipe -O2 -DNDEBUG -MT GridSearchTree.lo -MD -MP -MF .deps/GridSearchTree.Tpo -c ../../../geom/facet/GridSearchTree.cpp -o GridSearchTree.o
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcubit_facet.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib FacetAttrib.lo FacetAttribSet.lo FacetBody.lo FacetboolInterface.lo FacetCoEdge.lo FacetCurve.lo FacetLoop.lo FacetLump.lo FacetModifyEngine.lo FacetParamTool.lo FacetPoint.lo FacetQueryEngine.lo FacetShell.lo FacetSurface.lo GridSearchTree.lo ../libcubit_geom.la ../facetbool/libcubit_facetbool.la ../Cholla/libcholla.la -lm
mkdir .libs
ar cru .libs/libcubit_facet.a FacetAttrib.o FacetAttribSet.o FacetBody.o FacetboolInterface.o FacetCoEdge.o FacetCurve.o FacetLoop.o FacetLump.o FacetModifyEngine.o FacetParamTool.o FacetPoint.o FacetQueryEngine.o FacetShell.o FacetSurface.o GridSearchTree.o
ranlib .libs/libcubit_facet.a
creating libcubit_facet.la
(cd .libs && rm -f libcubit_facet.la && ln -s ../libcubit_facet.la libcubit_facet.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
Making all in virtual
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersVirtual.lo -MD -MP -MF ".deps/AllocMemManagersVirtual.Tpo" -c -o AllocMemManagersVirtual.lo ../../../geom/virtual/AllocMemManagersVirtual.cpp; \
then mv -f ".deps/AllocMemManagersVirtual.Tpo" ".deps/AllocMemManagersVirtual.Plo"; else rm -f ".deps/AllocMemManagersVirtual.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CACompositeVG.lo -MD -MP -MF ".deps/CACompositeVG.Tpo" -c -o CACompositeVG.lo ../../../geom/virtual/CACompositeVG.cpp; \
then mv -f ".deps/CACompositeVG.Tpo" ".deps/CACompositeVG.Plo"; else rm -f ".deps/CACompositeVG.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CAPartitionVG.lo -MD -MP -MF ".deps/CAPartitionVG.Tpo" -c -o CAPartitionVG.lo ../../../geom/virtual/CAPartitionVG.cpp; \
then mv -f ".deps/CAPartitionVG.Tpo" ".deps/CAPartitionVG.Plo"; else rm -f ".deps/CAPartitionVG.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CAVirtualVG.lo -MD -MP -MF ".deps/CAVirtualVG.Tpo" -c -o CAVirtualVG.lo ../../../geom/virtual/CAVirtualVG.cpp; \
then mv -f ".deps/CAVirtualVG.Tpo" ".deps/CAVirtualVG.Plo"; else rm -f ".deps/CAVirtualVG.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CollapseAngleTool.lo -MD -MP -MF ".deps/CollapseAngleTool.Tpo" -c -o CollapseAngleTool.lo ../../../geom/virtual/CollapseAngleTool.cpp; \
then mv -f ".deps/CollapseAngleTool.Tpo" ".deps/CollapseAngleTool.Plo"; else rm -f ".deps/CollapseAngleTool.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeAttrib.lo -MD -MP -MF ".deps/CompositeAttrib.Tpo" -c -o CompositeAttrib.lo ../../../geom/virtual/CompositeAttrib.cpp; \
then mv -f ".deps/CompositeAttrib.Tpo" ".deps/CompositeAttrib.Plo"; else rm -f ".deps/CompositeAttrib.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeBody.lo -MD -MP -MF ".deps/CompositeBody.Tpo" -c -o CompositeBody.lo ../../../geom/virtual/CompositeBody.cpp; \
then mv -f ".deps/CompositeBody.Tpo" ".deps/CompositeBody.Plo"; else rm -f ".deps/CompositeBody.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCoEdge.lo -MD -MP -MF ".deps/CompositeCoEdge.Tpo" -c -o CompositeCoEdge.lo ../../../geom/virtual/CompositeCoEdge.cpp; \
then mv -f ".deps/CompositeCoEdge.Tpo" ".deps/CompositeCoEdge.Plo"; else rm -f ".deps/CompositeCoEdge.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CAVirtualVG.lo -MD -MP -MF .deps/CAVirtualVG.Tpo -c ../../../geom/virtual/CAVirtualVG.cpp -o CAVirtualVG.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CollapseAngleTool.lo -MD -MP -MF .deps/CollapseAngleTool.Tpo -c ../../../geom/virtual/CollapseAngleTool.cpp -o CollapseAngleTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeBody.lo -MD -MP -MF .deps/CompositeBody.Tpo -c ../../../geom/virtual/CompositeBody.cpp -o CompositeBody.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CAPartitionVG.lo -MD -MP -MF .deps/CAPartitionVG.Tpo -c ../../../geom/virtual/CAPartitionVG.cpp -o CAPartitionVG.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeAttrib.lo -MD -MP -MF .deps/CompositeAttrib.Tpo -c ../../../geom/virtual/CompositeAttrib.cpp -o CompositeAttrib.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCoEdge.lo -MD -MP -MF .deps/CompositeCoEdge.Tpo -c ../../../geom/virtual/CompositeCoEdge.cpp -o CompositeCoEdge.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CACompositeVG.lo -MD -MP -MF .deps/CACompositeVG.Tpo -c ../../../geom/virtual/CACompositeVG.cpp -o CACompositeVG.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT AllocMemManagersVirtual.lo -MD -MP -MF .deps/AllocMemManagersVirtual.Tpo -c ../../../geom/virtual/AllocMemManagersVirtual.cpp -o AllocMemManagersVirtual.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCoSurf.lo -MD -MP -MF ".deps/CompositeCoSurf.Tpo" -c -o CompositeCoSurf.lo ../../../geom/virtual/CompositeCoSurf.cpp; \
then mv -f ".deps/CompositeCoSurf.Tpo" ".deps/CompositeCoSurf.Plo"; else rm -f ".deps/CompositeCoSurf.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCurve.lo -MD -MP -MF ".deps/CompositeCurve.Tpo" -c -o CompositeCurve.lo ../../../geom/virtual/CompositeCurve.cpp; \
then mv -f ".deps/CompositeCurve.Tpo" ".deps/CompositeCurve.Plo"; else rm -f ".deps/CompositeCurve.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeEngine.lo -MD -MP -MF ".deps/CompositeEngine.Tpo" -c -o CompositeEngine.lo ../../../geom/virtual/CompositeEngine.cpp; \
then mv -f ".deps/CompositeEngine.Tpo" ".deps/CompositeEngine.Plo"; else rm -f ".deps/CompositeEngine.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeGeom.lo -MD -MP -MF ".deps/CompositeGeom.Tpo" -c -o CompositeGeom.lo ../../../geom/virtual/CompositeGeom.cpp; \
then mv -f ".deps/CompositeGeom.Tpo" ".deps/CompositeGeom.Plo"; else rm -f ".deps/CompositeGeom.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeLoop.lo -MD -MP -MF ".deps/CompositeLoop.Tpo" -c -o CompositeLoop.lo ../../../geom/virtual/CompositeLoop.cpp; \
then mv -f ".deps/CompositeLoop.Tpo" ".deps/CompositeLoop.Plo"; else rm -f ".deps/CompositeLoop.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCoSurf.lo -MD -MP -MF .deps/CompositeCoSurf.Tpo -c ../../../geom/virtual/CompositeCoSurf.cpp -o CompositeCoSurf.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeEngine.lo -MD -MP -MF .deps/CompositeEngine.Tpo -c ../../../geom/virtual/CompositeEngine.cpp -o CompositeEngine.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeGeom.lo -MD -MP -MF .deps/CompositeGeom.Tpo -c ../../../geom/virtual/CompositeGeom.cpp -o CompositeGeom.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeLump.lo -MD -MP -MF ".deps/CompositeLump.Tpo" -c -o CompositeLump.lo ../../../geom/virtual/CompositeLump.cpp; \
then mv -f ".deps/CompositeLump.Tpo" ".deps/CompositeLump.Plo"; else rm -f ".deps/CompositeLump.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeLoop.lo -MD -MP -MF .deps/CompositeLoop.Tpo -c ../../../geom/virtual/CompositeLoop.cpp -o CompositeLoop.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositePoint.lo -MD -MP -MF ".deps/CompositePoint.Tpo" -c -o CompositePoint.lo ../../../geom/virtual/CompositePoint.cpp; \
then mv -f ".deps/CompositePoint.Tpo" ".deps/CompositePoint.Plo"; else rm -f ".deps/CompositePoint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeCurve.lo -MD -MP -MF .deps/CompositeCurve.Tpo -c ../../../geom/virtual/CompositeCurve.cpp -o CompositeCurve.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeShell.lo -MD -MP -MF ".deps/CompositeShell.Tpo" -c -o CompositeShell.lo ../../../geom/virtual/CompositeShell.cpp; \
then mv -f ".deps/CompositeShell.Tpo" ".deps/CompositeShell.Plo"; else rm -f ".deps/CompositeShell.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeLump.lo -MD -MP -MF .deps/CompositeLump.Tpo -c ../../../geom/virtual/CompositeLump.cpp -o CompositeLump.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositePoint.lo -MD -MP -MF .deps/CompositePoint.Tpo -c ../../../geom/virtual/CompositePoint.cpp -o CompositePoint.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeSurface.lo -MD -MP -MF ".deps/CompositeSurface.Tpo" -c -o CompositeSurface.lo ../../../geom/virtual/CompositeSurface.cpp; \
then mv -f ".deps/CompositeSurface.Tpo" ".deps/CompositeSurface.Plo"; else rm -f ".deps/CompositeSurface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeShell.lo -MD -MP -MF .deps/CompositeShell.Tpo -c ../../../geom/virtual/CompositeShell.cpp -o CompositeShell.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeTool.lo -MD -MP -MF ".deps/CompositeTool.Tpo" -c -o CompositeTool.lo ../../../geom/virtual/CompositeTool.cpp; \
then mv -f ".deps/CompositeTool.Tpo" ".deps/CompositeTool.Plo"; else rm -f ".deps/CompositeTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeSurface.lo -MD -MP -MF .deps/CompositeSurface.Tpo -c ../../../geom/virtual/CompositeSurface.cpp -o CompositeSurface.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompSurfFacets.lo -MD -MP -MF ".deps/CompSurfFacets.Tpo" -c -o CompSurfFacets.lo ../../../geom/virtual/CompSurfFacets.cpp; \
then mv -f ".deps/CompSurfFacets.Tpo" ".deps/CompSurfFacets.Plo"; else rm -f ".deps/CompSurfFacets.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompositeTool.lo -MD -MP -MF .deps/CompositeTool.Tpo -c ../../../geom/virtual/CompositeTool.cpp -o CompositeTool.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT Faceter.lo -MD -MP -MF ".deps/Faceter.Tpo" -c -o Faceter.lo ../../../geom/virtual/Faceter.cpp; \
then mv -f ".deps/Faceter.Tpo" ".deps/Faceter.Plo"; else rm -f ".deps/Faceter.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FaceterFacetData.lo -MD -MP -MF ".deps/FaceterFacetData.Tpo" -c -o FaceterFacetData.lo ../../../geom/virtual/FaceterFacetData.cpp; \
then mv -f ".deps/FaceterFacetData.Tpo" ".deps/FaceterFacetData.Plo"; else rm -f ".deps/FaceterFacetData.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FaceterPointData.lo -MD -MP -MF ".deps/FaceterPointData.Tpo" -c -o FaceterPointData.lo ../../../geom/virtual/FaceterPointData.cpp; \
then mv -f ".deps/FaceterPointData.Tpo" ".deps/FaceterPointData.Plo"; else rm -f ".deps/FaceterPointData.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT Faceter.lo -MD -MP -MF .deps/Faceter.Tpo -c ../../../geom/virtual/Faceter.cpp -o Faceter.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FaceterFacetData.lo -MD -MP -MF .deps/FaceterFacetData.Tpo -c ../../../geom/virtual/FaceterFacetData.cpp -o FaceterFacetData.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT CompSurfFacets.lo -MD -MP -MF .deps/CompSurfFacets.Tpo -c ../../../geom/virtual/CompSurfFacets.cpp -o CompSurfFacets.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FacetProjectTool.lo -MD -MP -MF ".deps/FacetProjectTool.Tpo" -c -o FacetProjectTool.lo ../../../geom/virtual/FacetProjectTool.cpp; \
then mv -f ".deps/FacetProjectTool.Tpo" ".deps/FacetProjectTool.Plo"; else rm -f ".deps/FacetProjectTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FaceterPointData.lo -MD -MP -MF .deps/FaceterPointData.Tpo -c ../../../geom/virtual/FaceterPointData.cpp -o FaceterPointData.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT HiddenEntitySet.lo -MD -MP -MF ".deps/HiddenEntitySet.Tpo" -c -o HiddenEntitySet.lo ../../../geom/virtual/HiddenEntitySet.cpp; \
then mv -f ".deps/HiddenEntitySet.Tpo" ".deps/HiddenEntitySet.Plo"; else rm -f ".deps/HiddenEntitySet.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintBoundaryTool.lo -MD -MP -MF ".deps/ImprintBoundaryTool.Tpo" -c -o ImprintBoundaryTool.lo ../../../geom/virtual/ImprintBoundaryTool.cpp; \
then mv -f ".deps/ImprintBoundaryTool.Tpo" ".deps/ImprintBoundaryTool.Plo"; else rm -f ".deps/ImprintBoundaryTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT FacetProjectTool.lo -MD -MP -MF .deps/FacetProjectTool.Tpo -c ../../../geom/virtual/FacetProjectTool.cpp -o FacetProjectTool.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintLineSegment.lo -MD -MP -MF ".deps/ImprintLineSegment.Tpo" -c -o ImprintLineSegment.lo ../../../geom/virtual/ImprintLineSegment.cpp; \
then mv -f ".deps/ImprintLineSegment.Tpo" ".deps/ImprintLineSegment.Plo"; else rm -f ".deps/ImprintLineSegment.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT HiddenEntitySet.lo -MD -MP -MF .deps/HiddenEntitySet.Tpo -c ../../../geom/virtual/HiddenEntitySet.cpp -o HiddenEntitySet.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintPointData.lo -MD -MP -MF ".deps/ImprintPointData.Tpo" -c -o ImprintPointData.lo ../../../geom/virtual/ImprintPointData.cpp; \
then mv -f ".deps/ImprintPointData.Tpo" ".deps/ImprintPointData.Plo"; else rm -f ".deps/ImprintPointData.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionBody.lo -MD -MP -MF ".deps/PartitionBody.Tpo" -c -o PartitionBody.lo ../../../geom/virtual/PartitionBody.cpp; \
then mv -f ".deps/PartitionBody.Tpo" ".deps/PartitionBody.Plo"; else rm -f ".deps/PartitionBody.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintBoundaryTool.lo -MD -MP -MF .deps/ImprintBoundaryTool.Tpo -c ../../../geom/virtual/ImprintBoundaryTool.cpp -o ImprintBoundaryTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintLineSegment.lo -MD -MP -MF .deps/ImprintLineSegment.Tpo -c ../../../geom/virtual/ImprintLineSegment.cpp -o ImprintLineSegment.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT ImprintPointData.lo -MD -MP -MF .deps/ImprintPointData.Tpo -c ../../../geom/virtual/ImprintPointData.cpp -o ImprintPointData.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionBody.lo -MD -MP -MF .deps/PartitionBody.Tpo -c ../../../geom/virtual/PartitionBody.cpp -o PartitionBody.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCoEdge.lo -MD -MP -MF ".deps/PartitionCoEdge.Tpo" -c -o PartitionCoEdge.lo ../../../geom/virtual/PartitionCoEdge.cpp; \
then mv -f ".deps/PartitionCoEdge.Tpo" ".deps/PartitionCoEdge.Plo"; else rm -f ".deps/PartitionCoEdge.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCoSurf.lo -MD -MP -MF ".deps/PartitionCoSurf.Tpo" -c -o PartitionCoSurf.lo ../../../geom/virtual/PartitionCoSurf.cpp; \
then mv -f ".deps/PartitionCoSurf.Tpo" ".deps/PartitionCoSurf.Plo"; else rm -f ".deps/PartitionCoSurf.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCurve.lo -MD -MP -MF ".deps/PartitionCurve.Tpo" -c -o PartitionCurve.lo ../../../geom/virtual/PartitionCurve.cpp; \
then mv -f ".deps/PartitionCurve.Tpo" ".deps/PartitionCurve.Plo"; else rm -f ".deps/PartitionCurve.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCoEdge.lo -MD -MP -MF .deps/PartitionCoEdge.Tpo -c ../../../geom/virtual/PartitionCoEdge.cpp -o PartitionCoEdge.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionEngine.lo -MD -MP -MF ".deps/PartitionEngine.Tpo" -c -o PartitionEngine.lo ../../../geom/virtual/PartitionEngine.cpp; \
then mv -f ".deps/PartitionEngine.Tpo" ".deps/PartitionEngine.Plo"; else rm -f ".deps/PartitionEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCurve.lo -MD -MP -MF .deps/PartitionCurve.Tpo -c ../../../geom/virtual/PartitionCurve.cpp -o PartitionCurve.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionCoSurf.lo -MD -MP -MF .deps/PartitionCoSurf.Tpo -c ../../../geom/virtual/PartitionCoSurf.cpp -o PartitionCoSurf.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionEntity.lo -MD -MP -MF ".deps/PartitionEntity.Tpo" -c -o PartitionEntity.lo ../../../geom/virtual/PartitionEntity.cpp; \
then mv -f ".deps/PartitionEntity.Tpo" ".deps/PartitionEntity.Plo"; else rm -f ".deps/PartitionEntity.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLoop.lo -MD -MP -MF ".deps/PartitionLoop.Tpo" -c -o PartitionLoop.lo ../../../geom/virtual/PartitionLoop.cpp; \
then mv -f ".deps/PartitionLoop.Tpo" ".deps/PartitionLoop.Plo"; else rm -f ".deps/PartitionLoop.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionEntity.lo -MD -MP -MF .deps/PartitionEntity.Tpo -c ../../../geom/virtual/PartitionEntity.cpp -o PartitionEntity.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLump.lo -MD -MP -MF ".deps/PartitionLump.Tpo" -c -o PartitionLump.lo ../../../geom/virtual/PartitionLump.cpp; \
then mv -f ".deps/PartitionLump.Tpo" ".deps/PartitionLump.Plo"; else rm -f ".deps/PartitionLump.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionEngine.lo -MD -MP -MF .deps/PartitionEngine.Tpo -c ../../../geom/virtual/PartitionEngine.cpp -o PartitionEngine.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLumpImprint.lo -MD -MP -MF ".deps/PartitionLumpImprint.Tpo" -c -o PartitionLumpImprint.lo ../../../geom/virtual/PartitionLumpImprint.cpp; \
then mv -f ".deps/PartitionLumpImprint.Tpo" ".deps/PartitionLumpImprint.Plo"; else rm -f ".deps/PartitionLumpImprint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLump.lo -MD -MP -MF .deps/PartitionLump.Tpo -c ../../../geom/virtual/PartitionLump.cpp -o PartitionLump.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLoop.lo -MD -MP -MF .deps/PartitionLoop.Tpo -c ../../../geom/virtual/PartitionLoop.cpp -o PartitionLoop.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionPoint.lo -MD -MP -MF ".deps/PartitionPoint.Tpo" -c -o PartitionPoint.lo ../../../geom/virtual/PartitionPoint.cpp; \
then mv -f ".deps/PartitionPoint.Tpo" ".deps/PartitionPoint.Plo"; else rm -f ".deps/PartitionPoint.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionPoint.lo -MD -MP -MF .deps/PartitionPoint.Tpo -c ../../../geom/virtual/PartitionPoint.cpp -o PartitionPoint.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionLumpImprint.lo -MD -MP -MF .deps/PartitionLumpImprint.Tpo -c ../../../geom/virtual/PartitionLumpImprint.cpp -o PartitionLumpImprint.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionShell.lo -MD -MP -MF ".deps/PartitionShell.Tpo" -c -o PartitionShell.lo ../../../geom/virtual/PartitionShell.cpp; \
then mv -f ".deps/PartitionShell.Tpo" ".deps/PartitionShell.Plo"; else rm -f ".deps/PartitionShell.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionSurface.lo -MD -MP -MF ".deps/PartitionSurface.Tpo" -c -o PartitionSurface.lo ../../../geom/virtual/PartitionSurface.cpp; \
then mv -f ".deps/PartitionSurface.Tpo" ".deps/PartitionSurface.Plo"; else rm -f ".deps/PartitionSurface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionShell.lo -MD -MP -MF .deps/PartitionShell.Tpo -c ../../../geom/virtual/PartitionShell.cpp -o PartitionShell.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionTool.lo -MD -MP -MF ".deps/PartitionTool.Tpo" -c -o PartitionTool.lo ../../../geom/virtual/PartitionTool.cpp; \
then mv -f ".deps/PartitionTool.Tpo" ".deps/PartitionTool.Plo"; else rm -f ".deps/PartitionTool.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartPTCurve.lo -MD -MP -MF ".deps/PartPTCurve.Tpo" -c -o PartPTCurve.lo ../../../geom/virtual/PartPTCurve.cpp; \
then mv -f ".deps/PartPTCurve.Tpo" ".deps/PartPTCurve.Plo"; else rm -f ".deps/PartPTCurve.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionTool.lo -MD -MP -MF .deps/PartitionTool.Tpo -c ../../../geom/virtual/PartitionTool.cpp -o PartitionTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartitionSurface.lo -MD -MP -MF .deps/PartitionSurface.Tpo -c ../../../geom/virtual/PartitionSurface.cpp -o PartitionSurface.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartSurfFacetTool.lo -MD -MP -MF ".deps/PartSurfFacetTool.Tpo" -c -o PartSurfFacetTool.lo ../../../geom/virtual/PartSurfFacetTool.cpp; \
then mv -f ".deps/PartSurfFacetTool.Tpo" ".deps/PartSurfFacetTool.Plo"; else rm -f ".deps/PartSurfFacetTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartPTCurve.lo -MD -MP -MF .deps/PartPTCurve.Tpo -c ../../../geom/virtual/PartPTCurve.cpp -o PartPTCurve.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PartSurfFacetTool.lo -MD -MP -MF .deps/PartSurfFacetTool.Tpo -c ../../../geom/virtual/PartSurfFacetTool.cpp -o PartSurfFacetTool.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PST_Data.lo -MD -MP -MF ".deps/PST_Data.Tpo" -c -o PST_Data.lo ../../../geom/virtual/PST_Data.cpp; \
then mv -f ".deps/PST_Data.Tpo" ".deps/PST_Data.Plo"; else rm -f ".deps/PST_Data.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SegmentedCurve.lo -MD -MP -MF ".deps/SegmentedCurve.Tpo" -c -o SegmentedCurve.lo ../../../geom/virtual/SegmentedCurve.cpp; \
then mv -f ".deps/SegmentedCurve.Tpo" ".deps/SegmentedCurve.Plo"; else rm -f ".deps/SegmentedCurve.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SegmentedCurve.lo -MD -MP -MF .deps/SegmentedCurve.Tpo -c ../../../geom/virtual/SegmentedCurve.cpp -o SegmentedCurve.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT PST_Data.lo -MD -MP -MF .deps/PST_Data.Tpo -c ../../../geom/virtual/PST_Data.cpp -o PST_Data.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubCurve.lo -MD -MP -MF ".deps/SubCurve.Tpo" -c -o SubCurve.lo ../../../geom/virtual/SubCurve.cpp; \
then mv -f ".deps/SubCurve.Tpo" ".deps/SubCurve.Plo"; else rm -f ".deps/SubCurve.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubEntitySet.lo -MD -MP -MF ".deps/SubEntitySet.Tpo" -c -o SubEntitySet.lo ../../../geom/virtual/SubEntitySet.cpp; \
then mv -f ".deps/SubEntitySet.Tpo" ".deps/SubEntitySet.Plo"; else rm -f ".deps/SubEntitySet.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubEntitySet.lo -MD -MP -MF .deps/SubEntitySet.Tpo -c ../../../geom/virtual/SubEntitySet.cpp -o SubEntitySet.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubSurface.lo -MD -MP -MF ".deps/SubSurface.Tpo" -c -o SubSurface.lo ../../../geom/virtual/SubSurface.cpp; \
then mv -f ".deps/SubSurface.Tpo" ".deps/SubSurface.Plo"; else rm -f ".deps/SubSurface.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubCurve.lo -MD -MP -MF .deps/SubCurve.Tpo -c ../../../geom/virtual/SubCurve.cpp -o SubCurve.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF ".deps/TDVGFacetOwner.Tpo" -c -o TDVGFacetOwner.lo ../../../geom/virtual/TDVGFacetOwner.cpp; \
then mv -f ".deps/TDVGFacetOwner.Tpo" ".deps/TDVGFacetOwner.Plo"; else rm -f ".deps/TDVGFacetOwner.Tpo"; exit 1; fi
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF ".deps/TDVGFacetSplit.Tpo" -c -o TDVGFacetSplit.lo ../../../geom/virtual/TDVGFacetSplit.cpp; \
then mv -f ".deps/TDVGFacetSplit.Tpo" ".deps/TDVGFacetSplit.Plo"; else rm -f ".deps/TDVGFacetSplit.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT SubSurface.lo -MD -MP -MF .deps/SubSurface.Tpo -c ../../../geom/virtual/SubSurface.cpp -o SubSurface.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT TDVGFacetSplit.lo -MD -MP -MF .deps/TDVGFacetSplit.Tpo -c ../../../geom/virtual/TDVGFacetSplit.cpp -o TDVGFacetSplit.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF ".deps/VirtualQueryEngine.Tpo" -c -o VirtualQueryEngine.lo ../../../geom/virtual/VirtualQueryEngine.cpp; \
then mv -f ".deps/VirtualQueryEngine.Tpo" ".deps/VirtualQueryEngine.Plo"; else rm -f ".deps/VirtualQueryEngine.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT TDVGFacetOwner.lo -MD -MP -MF .deps/TDVGFacetOwner.Tpo -c ../../../geom/virtual/TDVGFacetOwner.cpp -o TDVGFacetOwner.o
if /bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF ".deps/VirtualImprintTool.Tpo" -c -o VirtualImprintTool.lo ../../../geom/virtual/VirtualImprintTool.cpp; \
then mv -f ".deps/VirtualImprintTool.Tpo" ".deps/VirtualImprintTool.Plo"; else rm -f ".deps/VirtualImprintTool.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT VirtualImprintTool.lo -MD -MP -MF .deps/VirtualImprintTool.Tpo -c ../../../geom/virtual/VirtualImprintTool.cpp -o VirtualImprintTool.o
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../../geom/virtual -I../.. -I../../itaps -I../../../util -I../../../geom -I../../../geom/facet -I../../../geom/Cholla -Wall -pipe -O2 -DNDEBUG -MT VirtualQueryEngine.lo -MD -MP -MF .deps/VirtualQueryEngine.Tpo -c ../../../geom/virtual/VirtualQueryEngine.cpp -o VirtualQueryEngine.o
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcubit_virtual.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib AllocMemManagersVirtual.lo CACompositeVG.lo CAPartitionVG.lo CAVirtualVG.lo CollapseAngleTool.lo CompositeAttrib.lo CompositeBody.lo CompositeCoEdge.lo CompositeCoSurf.lo CompositeCurve.lo CompositeEngine.lo CompositeGeom.lo CompositeLoop.lo CompositeLump.lo CompositePoint.lo CompositeShell.lo CompositeSurface.lo CompositeTool.lo CompSurfFacets.lo Faceter.lo FaceterFacetData.lo FaceterPointData.lo FacetProjectTool.lo HiddenEntitySet.lo ImprintBoundaryTool.lo ImprintLineSegment.lo ImprintPointData.lo PartitionBody.lo PartitionCoEdge.lo PartitionCoSurf.lo PartitionCurve.lo PartitionEngine.lo PartitionEntity.lo PartitionLoop.lo PartitionLump.lo PartitionLumpImprint.lo PartitionPoint.lo PartitionShell.lo PartitionSurface.lo PartitionTool.lo PartPTCurve.lo PartSurfFacetTool.lo PST_Data.lo SegmentedCurve.lo SubCurve.lo SubEntity!
Set.lo SubSurface.lo TDVGFacetOwner.lo TDVGFacetSplit.lo VirtualQueryEngine.lo VirtualImprintTool.lo ../libcubit_geom.la -lm
mkdir .libs
ar cru .libs/libcubit_virtual.a AllocMemManagersVirtual.o CACompositeVG.o CAPartitionVG.o CAVirtualVG.o CollapseAngleTool.o CompositeAttrib.o CompositeBody.o CompositeCoEdge.o CompositeCoSurf.o CompositeCurve.o CompositeEngine.o CompositeGeom.o CompositeLoop.o CompositeLump.o CompositePoint.o CompositeShell.o CompositeSurface.o CompositeTool.o CompSurfFacets.o Faceter.o FaceterFacetData.o FaceterPointData.o FacetProjectTool.o HiddenEntitySet.o ImprintBoundaryTool.o ImprintLineSegment.o ImprintPointData.o PartitionBody.o PartitionCoEdge.o PartitionCoSurf.o PartitionCurve.o PartitionEngine.o PartitionEntity.o PartitionLoop.o PartitionLump.o PartitionLumpImprint.o PartitionPoint.o PartitionShell.o PartitionSurface.o PartitionTool.o PartPTCurve.o PartSurfFacetTool.o PST_Data.o SegmentedCurve.o SubCurve.o SubEntitySet.o SubSurface.o TDVGFacetOwner.o TDVGFacetSplit.o VirtualQueryEngine.o VirtualImprintTool.o
ranlib .libs/libcubit_virtual.a
creating libcubit_virtual.la
(cd .libs && rm -f libcubit_virtual.la && ln -s ../libcubit_virtual.la libcubit_virtual.la)
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making all in init
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../init -I.. -I../itaps -I../../geom -I../../util -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init -Wall -pipe -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF ".deps/InitCGMA.Tpo" -c -o InitCGMA.lo ../../init/InitCGMA.cpp; \
then mv -f ".deps/InitCGMA.Tpo" ".deps/InitCGMA.Plo"; else rm -f ".deps/InitCGMA.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -DLITTLE_ENDIAN=BYTE_ORDER -I. -I../../init -I.. -I../itaps -I../../geom -I../../util -I../../geom/ACIS -I../../geom/virtual -I../../geom/facet -I../../geom/cholla -I../../init -Wall -pipe -O2 -DNDEBUG -MT InitCGMA.lo -MD -MP -MF .deps/InitCGMA.Tpo -c ../../init/InitCGMA.cpp -o InitCGMA.o
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libcgma_init.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib InitCGMA.lo -lm
mkdir .libs
ar cru .libs/libcgma_init.a InitCGMA.o
ranlib .libs/libcgma_init.a
creating libcgma_init.la
(cd .libs && rm -f libcgma_init.la && ln -s ../libcgma_init.la libcgma_init.la)
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
Making all in itaps
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make all-recursive
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making all in .
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF ".deps/CATag.Tpo" -c -o CATag.lo ../../itaps/CATag.cpp; \
then mv -f ".deps/CATag.Tpo" ".deps/CATag.Plo"; else rm -f ".deps/CATag.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF ".deps/iGeom_CGMA.Tpo" -c -o iGeom_CGMA.lo ../../itaps/iGeom_CGMA.cc; \
then mv -f ".deps/iGeom_CGMA.Tpo" ".deps/iGeom_CGMA.Plo"; else rm -f ".deps/iGeom_CGMA.Tpo"; exit 1; fi
if /bin/sh ../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF ".deps/iGeomError.Tpo" -c -o iGeomError.lo ../../itaps/iGeomError.cc; \
then mv -f ".deps/iGeomError.Tpo" ".deps/iGeomError.Plo"; else rm -f ".deps/iGeomError.Tpo"; exit 1; fi
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT CATag.lo -MD -MP -MF .deps/CATag.Tpo -c ../../itaps/CATag.cpp -o CATag.o
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT iGeom_CGMA.lo -MD -MP -MF .deps/iGeom_CGMA.Tpo -c ../../itaps/iGeom_CGMA.cc -o iGeom_CGMA.o
c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -Wall -pipe -O2 -DNDEBUG -MT iGeomError.lo -MD -MP -MF .deps/iGeomError.Tpo -c ../../itaps/iGeomError.cc -o iGeomError.o
/bin/sh ../libtool --tag=CXX --mode=link c++ -Wall -pipe -O2 -DNDEBUG -o libiGeom.la -rpath /home/jason/cgm/test/dist/CGMA-10.2.2/_inst/lib CATag.lo iGeom_CGMA.lo iGeomError.lo -lm
mkdir .libs
ar cru .libs/libiGeom.a CATag.o iGeom_CGMA.o iGeomError.o
ranlib .libs/libiGeom.a
creating libiGeom.la
(cd .libs && rm -f libiGeom.la && ln -s ../libiGeom.la libiGeom.la)
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making all in test
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
Making all in cgm_apps
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
Making all in examples
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
Making all in facetdriver
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[5]: Nothing to be done for `all'.
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[5]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[5]: Nothing to be done for `all-am'.
make[5]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[1]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[1]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
Making dvi in util
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
make[2]: Nothing to be done for `dvi'.
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/util'
Making dvi in geom
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making dvi in .
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
make[3]: Nothing to be done for `dvi-am'.
Making dvi in Cholla
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
make[3]: Nothing to be done for `dvi'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/Cholla'
Making dvi in facetbool
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facetbool'
Making dvi in facet
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/facet'
Making dvi in virtual
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/geom'
Making dvi in init
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/init'
Making dvi in itaps
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making dvi in .
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/itaps'
Making dvi in test
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/test'
Making dvi in cgm_apps
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
Making dvi in examples
make[3]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
Making dvi in facetdriver
make[4]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[4]: Nothing to be done for `dvi'.
make[4]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples/facetdriver'
make[4]: Nothing to be done for `dvi-am'.
make[3]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps/examples'
make[2]: Leaving directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build/cgm_apps'
make[2]: Entering directory `/home/jason/cgm/test/dist/CGMA-10.2.2/_build'
make[2]: Nothing to be done for `dvi-am'.
Making check in util
make[2]: Nothing to be done for `check'.
Making check in geom
Making check in .
make[3]: Nothing to be done for `check-am'.
Making check in Cholla
make[3]: Nothing to be done for `check'.
Making check in facetbool
Making check in virtual
Making check in init
Making check in itaps
Making check in .
make testgeom
if c++ -DTEMPLATE_DEFS_INCLUDED -I. -I../../itaps -I.. -I. -I../../util -I../../geom -I../../init -I. -DSRCDIR=../../itaps -Wall -pipe -O2 -DNDEBUG -MT testgeom-testgeom.o -MD -MP -MF ".deps/testgeom-testgeom.Tpo" -c -o testgeom-testgeom.o `test -f 'testgeom.cc' || echo '../../itaps/'`testgeom.cc; \
then mv -f ".deps/testgeom-testgeom.Tpo" ".deps/testgeom-testgeom.Po"; else rm -f ".deps/testgeom-testgeom.Tpo"; exit 1; fi
More information about the cgma-dev
