[cgma-dev] r2036 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Aug 5 12:52:08 CDT 2008
Author: janehu
Date: 2008-08-05 12:52:08 -0500 (Tue, 05 Aug 2008)
New Revision: 2036
Removed:
cgm/trunk/geom/OCC/OCCAttrib.cpp
cgm/trunk/geom/OCC/OCCAttrib.hpp
Modified:
cgm/trunk/geom/OCC/OCCAttribSet.cpp
cgm/trunk/geom/OCC/OCCAttribSet.hpp
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Updated for read-write attributes:delete lable after the shape is gone due to geometry operations.
Deleted: cgm/trunk/geom/OCC/OCCAttrib.cpp
--- cgm/trunk/geom/OCC/OCCAttrib.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCAttrib.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -1,194 +0,0 @@
-#include "OCCAttrib.hpp"
-#include "CubitString.hpp"
-#include "CubitSimpleAttrib.hpp"
-#include "CubitFileIOWrapper.hpp"
- // Constructor - copy from CubitSimpleAttrib
-OCCAttrib::OCCAttrib( CubitSimpleAttrib* csa) : listNext(0)
- int i;
- // reset all lists (if we didn't need to do this,
- // csa could be const)
- csa->string_data_list()->reset();
- csa->int_data_list()->reset();
- csa->double_data_list()->reset();
- // save counts
- numStrings = csa->string_data_list()->size();
- numDoubles = csa->double_data_list()->size();
- numIntegers = csa->int_data_list()->size();
- // allocate arrays, but don't try to allocate zero-length arrays
- stringArray = numStrings ? new CubitString[numStrings] : NULL;
- doubleArray = numDoubles ? new double[numDoubles] : NULL;
- integerArray = numIntegers ? new int[numIntegers] : NULL;
- // copy data into arrays
- for( i = 0; i < numStrings; i++ )
- stringArray[i] = *csa->string_data_list()->next(i);
- for( i = 0; i < numIntegers; i++ )
- integerArray[i] = *csa->int_data_list()->next(i);
- for( i = 0; i < numDoubles; i++ )
- doubleArray[i] = *csa->double_data_list()->next(i);
- // Private constructor for use by restore(FILE*)
-OCCAttrib::OCCAttrib( int string_count, CubitString strings[],
- int double_count, double doubles[],
- int int_count, int integers[] )
-: stringArray(strings), doubleArray(doubles), integerArray(integers),
- numStrings(string_count), numDoubles(double_count), numIntegers(int_count),
- listNext(0)
- // Destructor -- free arrays
-OCCAttrib::~OCCAttrib()
- // "delete"ing NULL pointers is okay.
- delete [] integerArray;
- delete [] doubleArray;
- delete [] stringArray;
- // Copy this into a new CubitSimpleAttrib
-CubitSimpleAttrib* OCCAttrib::get_CSA() const
- // Set initial list size
- DLIList<CubitString*> string_list(numStrings);
- DLIList<int> int_list(numIntegers);
- DLIList<double> double_list(numDoubles);
- // Don't need to 'new' objects in DLIList because
- // CSA will make copies. Just put addresses in list.
- int i;
- string_list.append( &stringArray[i] );
- int_list.append( integerArray[i] );
- double_list.append( doubleArray[i] );
- return new CubitSimpleAttrib( &string_list, &double_list, &int_list );
- // compare to a CubitSimpleAttrib
-bool OCCAttrib::equals( CubitSimpleAttrib* csa ) const
- // compare counts
- csa->string_data_list();
- csa->string_data_list()->size();
- //int size1 = numIntegers;
- //int size2 = numDoubles;
- //int size3 = numStrings;
- if( csa->int_data_list()->size() != numIntegers ||
- csa->double_data_list()->size() != numDoubles ||
- csa->string_data_list()->size() != numStrings )
- return false;
- // compare strings first because most likely the
- // first string (the name) will differ.
- int i;
- if( stringArray[i] != *csa->string_data_list()->next(i) )
- return false;
- // compare integers
- if( integerArray[i] != *csa->int_data_list()->next(i) )
- return false;
- // compare doubles
- if( doubleArray[i] != *csa->double_data_list()->next(i) )
- return false;
- return true;
- // write to a file at the current file offset
-CubitStatus OCCAttrib::save(FILE *save_file) const
- if( save_file == NULL)
- PRINT_ERROR("Problem saving MBG attributes: null FILE ptr\n");
- return CUBIT_FAILURE;
- NCubitFile::CIOWrapper wrapper(save_file);
- // write a version number for the attribute data
- unsigned int Attrib_Version = 1;
- wrapper.Write(&Attrib_Version, 1);
- // write the number of strings, number of doubles, and number of integers
- int counts[3] = { numStrings, numDoubles, numIntegers };
- wrapper.Write(reinterpret_cast<unsigned int*>(counts), 3);
- // write the string data
- int i;
- wrapper.Write(stringArray[i].c_str());
- // write the doubles
- wrapper.Write(doubleArray, numDoubles);
- // write the integers
- wrapper.Write(reinterpret_cast<unsigned int*>(integerArray), numIntegers);
- return CUBIT_SUCCESS;
- // read from file starting at current file offset
-OCCAttrib* OCCAttrib::restore(FILE *restore_file, unsigned int endian)
- if( restore_file == NULL )
- return NULL;
- NCubitFile::CIOWrapper wrapper(endian, restore_file );
- unsigned int version;
- wrapper.Read(&version, 1);
- // haven't handled any version changes yet
- if( version != 1 )
- PRINT_ERROR("Wrong OCCAttrib version : %u\n", version );
- return NULL;
- // read the number of strings, number of doubles, and number of integers
- int counts[3];
- wrapper.Read(reinterpret_cast<unsigned int*>(counts), 3);
- int n_strings = counts[0];
- int n_doubles = counts[1];
- int n_ints = counts[2];
- CubitString* strings = n_strings ? new CubitString[n_strings] : NULL;
- double *doubles = n_doubles ? new double[n_doubles] : NULL;
- int *ints = n_ints ? new int[n_ints] : NULL;
- // read the string data
- int i;
- for( i = 0; i < n_strings; i++ )
- strings[i] = CubitString(wrapper.Read());
- wrapper.Read(doubles, n_doubles);
- wrapper.Read(reinterpret_cast<unsigned int*>(ints), n_ints);
- return new OCCAttrib(n_strings, strings, n_doubles, doubles, n_ints, ints);
Deleted: cgm/trunk/geom/OCC/OCCAttrib.hpp
--- cgm/trunk/geom/OCC/OCCAttrib.hpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCAttrib.hpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -1,52 +0,0 @@
-#ifndef OCC_ATTRIB_HPP
-#define OCC_ATTRIB_HPP
-#include "CubitDefines.h"
-class CubitSimpleAttrib;
-class CubitString;
-class OCCAttrib
-public:
- OCCAttrib( CubitSimpleAttrib* );
- ~OCCAttrib();
- CubitSimpleAttrib* get_CSA() const;
- bool equals( CubitSimpleAttrib* ) const;
- CubitStatus save( FILE* file ) const;
- static OCCAttrib* restore( FILE* file, unsigned int endian );
- CubitString name() const
- { return stringArray[0]; }
- // Use arrays rather than std::vector so IO routines
- // can use the data without making copies.
- CubitString* stringArray;
- double* doubleArray;
- int* integerArray;
- int numStrings;
- int numDoubles;
- int numIntegers;
- OCCAttrib* listNext;
-private:
- OCCAttrib( int string_count, CubitString* strings,
- int double_count, double* doubles,
- int integer_count, int* integers);
-#endif
Modified: cgm/trunk/geom/OCC/OCCAttribSet.cpp
--- cgm/trunk/geom/OCC/OCCAttribSet.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCAttribSet.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -270,6 +270,19 @@
+void OCCAttribSet::remove_attribute( TopoDS_Shape& shape)
+ CubitBoolean found = CUBIT_FALSE;
+ TDF_Label myLabel;
+ FindShape(shape, myLabel, found);
+ if(!found)
+ return;
+ myLabel.Nullify();
void OCCAttribSet::remove_attribute( CubitSimpleAttrib* csa,
Modified: cgm/trunk/geom/OCC/OCCAttribSet.hpp
--- cgm/trunk/geom/OCC/OCCAttribSet.hpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCAttribSet.hpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -38,10 +38,16 @@
static void append_attribute( CubitSimpleAttrib*, TopoDS_Shape& shape );
+ //remove this simple attrib from all shapes. useful when it's a shared
+ //feature like materials
static void remove_attribute( CubitSimpleAttrib* );
+ //remove this simple attrib from the shape attribs.
static void remove_attribute(CubitSimpleAttrib*, TopoDS_Shape& shape );
+ //remove this shape's label from the lable tree.
+ static void remove_attribute( TopoDS_Shape& shape);
static void get_attributes(TDF_Label &lab,
DLIList<CubitSimpleAttrib*>& list);
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -37,7 +37,6 @@
#include "OCCShell.hpp"
#include "OCCLump.hpp"
#include "OCCModifyEngine.hpp"
#include <TopExp.hxx>
#include <TopTools_IndexedMapOfShape.hxx>
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -23,7 +23,6 @@
#include "CubitBox.hpp"
#include "GeometryDefines.h"
#include "OCCCurve.hpp"
#include "GeometryQueryEngine.hpp"
#include "OCCQueryEngine.hpp"
#include "CoEdgeSM.hpp"
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -2632,12 +2632,12 @@
DLIList<CubitSimpleAttrib*> list;
OCCAttribSet::get_attributes(old_shape, list);
- for(int i = 0; i < list.size(); i ++)
+ OCCAttribSet::remove_attribute(old_shape);
+ for(int i = 0; !new_shape.IsNull() && i < list.size(); i ++)
CubitSimpleAttrib* s_attr = list.get_and_step();
- OCCAttribSet::remove_attribute(s_attr);
- if(!new_shape.IsNull())
- OCCAttribSet::append_attribute(s_attr, new_shape);
+ OCCAttribSet::append_attribute(s_attr, new_shape);
//update CGM-OCC map
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-08-04 18:36:34 UTC (rev 2035)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-08-05 17:52:08 UTC (rev 2036)
@@ -17,7 +17,6 @@
#include "OCCSurface.hpp"
#include "RefFace.hpp"
#include "OCCBody.hpp"
More information about the cgma-dev
