[cgma-dev] r1782 - in cgm/trunk/geom: . OCC facet virtual
janehu at mcs.anl.gov janehu at mcs.anl.gov
Mon Apr 28 13:09:47 CDT 2008
Author: janehu
Date: 2008-04-28 13:09:47 -0500 (Mon, 28 Apr 2008)
New Revision: 1782
Modified:
   cgm/trunk/geom/Body.cpp
   cgm/trunk/geom/BodySM.hpp
   cgm/trunk/geom/GeometryModifyTool.cpp
   cgm/trunk/geom/GeometryModifyTool.hpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
   cgm/trunk/geom/facet/FacetBody.hpp
   cgm/trunk/geom/virtual/CompositeBody.hpp
   cgm/trunk/geom/virtual/PartitionBody.hpp
Log:
worked on deleting free edge and vertices, still has some left, investgating.
Modified: cgm/trunk/geom/Body.cpp
--- cgm/trunk/geom/Body.cpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/Body.cpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -193,8 +193,19 @@
   DLIList<RefVolume*> volumes;
   ref_volumes(volumes);
   while (volumes.size())
     if (!volumes.pop()->is_sheet())
-      return CUBIT_FALSE;
+      //OCC sheet body just has one face or shell, not like Acis
+      BodySM* bodysm = get_body_sm_ptr();
+      if (bodysm == NULL)
+        PRINT_ERROR("Body %d is invalid -- no attached BodySM.\n", this->id());
+        return CUBIT_FALSE;
+      return bodysm->is_sheet_body();
   return CUBIT_TRUE;
Modified: cgm/trunk/geom/BodySM.hpp
--- cgm/trunk/geom/BodySM.hpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/BodySM.hpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -74,6 +74,7 @@
       CubitBox bounding_box();
+      virtual CubitBoolean is_sheet_body() = 0;
    protected:
    private:
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/GeometryModifyTool.cpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -1425,7 +1425,6 @@
 // Creation Date : 03/29/97
 RefVolume*
 GeometryModifyTool::make_RefVolume( DLIList<RefFace*>& ref_face_list) const
@@ -1465,13 +1464,14 @@
      // Use the Lump to make a RefVolume
+    CubitBoolean modified;
     RefVolume* ref_volume_ptr =
-      GeometryQueryTool::instance()->make_RefVolume(lump_ptr);
+      GeometryQueryTool::instance()->make_RefVolume(lump_ptr, modified);
      // Return the new RefVolume
    return ref_volume_ptr ;
 // Purpose       : This function takes a list of RefVolumes to create a
 //                 Body. The underlying representation of the Body is
Modified: cgm/trunk/geom/GeometryModifyTool.hpp
--- cgm/trunk/geom/GeometryModifyTool.hpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/GeometryModifyTool.hpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -916,7 +916,7 @@
     *  made for some reason.
-//  RefVolume* make_RefVolume(DLIList<RefFace*>& ref_face_list) const ;
+  RefVolume* make_RefVolume(DLIList<RefFace*>& ref_face_list) const ;
   /**<  \return  RefVlume*
     *  \return - A pointer to a newly created RefVlume
     *  \arg ref_volume_type
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -1632,16 +1632,7 @@
           else if(fuser.IsDeleted(face))
             TopoDS_Face null_face;
-            int k = OCCSurface::update_OCC_entity(face, null_face, &fuser);
-            std::map<int, TopologyBridge*>::iterator it =
-                OCCQueryEngine::instance()->OccToCGM->find(k);
-            TopologyBridge* tb = NULL;
-            if (it != OCCQueryEngine::instance()->OccToCGM->end())
-              OCCQueryEngine::instance()->OccToCGM->erase(k);
-              tb = (*it).second;
-              delete tb;
+            OCCSurface::update_OCC_entity(face, null_face, &fuser);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -2447,8 +2447,10 @@
   int k = OCCMap->Find(old_shape);
   assert (k > 0 && k <= iTotalTBCreated);
-  if (!new_shape.IsNull() && !old_shape.IsSame(new_shape)&&
-      OCCMap->IsBound(new_shape))
+  OCCMap->UnBind(old_shape);
+  if ((!new_shape.IsNull() && !old_shape.IsSame(new_shape)&&
+      OCCMap->IsBound(new_shape))|| new_shape.IsNull())
   //already has a TB built on new_shape
     //delete the second TB corresponding to old_shape
@@ -2462,8 +2464,7 @@
-  OCCMap->UnBind(old_shape);
-  if(!new_shape.IsNull())
+  else
     OCCMap->Bind(new_shape, k);
   return k;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -853,25 +853,12 @@
      for(Ex.Init(wire); Ex.More();Ex.Next())
        TopoDS_Edge edge = Ex.Current();
-       shape.Nullify();
        shapes.Assign(op->Modified(edge));
        shape.Nullify();
        if (shapes.Extent() > 0)
          shape = shapes.First();
        else if (op->IsDeleted(edge))
-         int k = OCCQueryEngine::instance()->update_OCC_map(edge, shape);
-           delete tb;
        else
          continue;
@@ -879,9 +866,9 @@
          shape.Orientation(
           shape.Orientation()==TopAbs_FORWARD? TopAbs_REVERSED:TopAbs_FORWARD);
-         OCCQueryEngine::instance()->update_OCC_map(edge, shape);
+       OCCQueryEngine::instance()->update_OCC_map(edge, shape);
        //update vertex
        TopoDS_Vertex vertex = Ex.CurrentVertex();
        shapes.Assign(op->Modified(vertex));
@@ -892,18 +879,7 @@
          OCCQueryEngine::instance()->update_OCC_map(vertex, shape);
        else if(op->IsDeleted(vertex))
-         int k = OCCQueryEngine::instance()->update_OCC_map(vertex, shape);
-           delete tb;
+         OCCQueryEngine::instance()->update_OCC_map(vertex, shape);
   return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/facet/FacetBody.hpp
--- cgm/trunk/geom/facet/FacetBody.hpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/facet/FacetBody.hpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -191,6 +191,7 @@
   virtual CubitPointContainment point_containment( const CubitVector& pos );
+  virtual CubitBoolean is_sheet_body(){return CUBIT_FALSE;}
 protected:
 private:
Modified: cgm/trunk/geom/virtual/CompositeBody.hpp
--- cgm/trunk/geom/virtual/CompositeBody.hpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/virtual/CompositeBody.hpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -78,6 +78,7 @@
     void combine( CompositeBody* other );
+    CubitBoolean is_sheet_body(){return CUBIT_FALSE;}
   private:
     CompositeLump* firstLump;
Modified: cgm/trunk/geom/virtual/PartitionBody.hpp
--- cgm/trunk/geom/virtual/PartitionBody.hpp	2008-04-28 17:27:52 UTC (rev 1781)
+++ cgm/trunk/geom/virtual/PartitionBody.hpp	2008-04-28 18:09:47 UTC (rev 1782)
@@ -100,7 +100,8 @@
     void transform(const CubitTransformMatrix&) {}
     void get_all_children( DLIList<PartitionEntity*>& list );
   protected:
   private:
More information about the cgma-dev mailing list
