[cgma-dev] r1768 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Apr 15 14:15:02 CDT 2008
Author: janehu
Date: 2008-04-15 14:15:02 -0500 (Tue, 15 Apr 2008)
New Revision: 1768
Modified:
cgm/trunk/geom/OCC/OCCBody.cpp
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCLoop.cpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
cgm/trunk/geom/OCC/OCCShell.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
Log:
Still working on the entity update for boolean operation, it's a little confusion that when a TopoDS_Face get a map to newly generated TopoDS_Face, the Wire under it can't find the corresponding new Wire. Investigating why.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCBody.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -69,6 +69,14 @@
update_bounding_box();
+void OCCBody::set_sheet_surface(OCCSurface* surface)
+ IsSheetBody = CUBIT_TRUE;
+ mySheetSurface = surface;
+ if(surface == NULL)
+ IsSheetBody = CUBIT_FALSE;
void OCCBody::lumps(DLIList<Lump*>& my_lumps)
myLumps.clean_out();
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -180,6 +180,8 @@
OCCSurface* my_sheet_surface(){if(IsSheetBody) return mySheetSurface;
return (OCCSurface*) NULL;}
+ void set_sheet_surface(OCCSurface* surface);
protected:
private:
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -227,6 +227,7 @@
assert(aBRepTrsf != NULL || op != NULL);
TopoDS_Shape shape;
+ CubitBoolean need_update = CUBIT_TRUE;
if (aBRepTrsf)
shape = aBRepTrsf->ModifiedShape(*get_TopoDS_Wire());
else
@@ -236,18 +237,21 @@
if(shapes.Extent())
shape = shapes.First();
else
- return CUBIT_SUCCESS;
+ need_update = CUBIT_FALSE;
- TopoDS_Wire loop = TopoDS::Wire(shape);
- OCCQueryEngine::instance()->update_OCC_map(*myTopoDSWire, loop);
+ TopoDS_Wire loop;
+ if (need_update)
+ loop = TopoDS::Wire(shape);
+ OCCQueryEngine::instance()->update_OCC_map(*myTopoDSWire, loop);
//set the curves
for (int i = 1; i <= myCoEdgeList.size(); i++)
OCCCurve *curve = CAST_TO(myCoEdgeList.get_and_step()->curve(), OCCCurve);
curve->update_OCC_entity(aBRepTrsf, op);
- set_TopoDS_Wire(loop);
+ if (need_update)
+ set_TopoDS_Wire(loop);
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -47,6 +47,11 @@
OCCLump(TopoDS_Solid *theSolid, OCCSurface* surface = NULL,
OCCShell* shell = NULL);
+ OCCSurface* my_sheet_surface() {return mySheetSurface;}
+ OCCShell * my_shell() {return myShell;}
+ void set_surface(OCCSurface* surface) {mySheetSurface = surface;}
+ void set_shell(OCCShell* shell) {myShell = shell;}
virtual ~OCCLump();
//- The destructor
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -1532,7 +1532,6 @@
faces_to_stitch.reset();
surf_bodies.reset();
TopoDS_Shape* first_face = faces_to_stitch.pop();
- surf_bodies.pop(); //make consistance with faces_to_stitch.
TopoDS_Face* second_face = NULL;
TopoDS_Shape fuse;
@@ -1542,7 +1541,8 @@
BRepAlgoAPI_Fuse fuser(*second_face, *first_face);
fuse = fuser.Shape();
first_face = &fuse;
- CAST_TO(surf_bodies[i], OCCBody)->my_sheet_surface()->my_shell()->update_OCC_entity(NULL, &fuser);
+ OCCBody* occ_body = CAST_TO(surf_bodies[i], OCCBody);
+ occ_body->my_sheet_surface()->update_OCC_entity(NULL, &fuser);
TopExp_Explorer Ex;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -1242,6 +1242,8 @@
surface->set_body(body);
surface->set_lump(lump);
surface->set_shell(shell);
+ shell->set_body(body);
+ shell->set_lump(lump);
//Doesn't need to save sheet bodies.
TopExp_Explorer Ex;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -32,6 +32,7 @@
#include <TopExp.hxx>
#include <TopTools_IndexedMapOfShape.hxx>
+#include "TopExp_Explorer.hxx"
#include "TopTools_IndexedDataMapOfShapeListOfShape.hxx"
#include "TopoDS.hxx"
#include "TopTools_ListIteratorOfListOfShape.hxx"
@@ -71,6 +72,13 @@
+void OCCShell::set_TopoDS_Shell(TopoDS_Shell shell)
+ if (!myTopoDSShell)
+ myTopoDSShell = new TopoDS_Shell();
+ *myTopoDSShell = shell;
// Purpose : Get geometry modeling engine: OCCQueryEngine
@@ -169,15 +177,34 @@
CubitStatus OCCShell::update_OCC_entity( BRepBuilderAPI_Transform *aBRepTrsf,
BRepAlgoAPI_BooleanOperation *op)
- if(mySheetSurface)
+ if(mySheetSurface && op == NULL)
return CUBIT_FAILURE;
+ else if(mySheetSurface && op)//stitch surface body into shell body
+ mySheetSurface->update_OCC_entity(aBRepTrsf, op);
+ TopoDS_Shape shape = op->Shape();
+ TopExp_Explorer Ex;
+ TopoDS_Shell shell;
+ for (Ex.Init(shape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
+ shell = TopoDS::Shell(Ex.Current());
+ this->set_TopoDS_Shell(shell);
+ this->my_lump()->set_surface(NULL);
+ this->my_lump()->set_shell(this);
+ this->my_body()->shell(this);
+ this->my_body()->set_sheet_surface(NULL);
+ this->set_sheet_surface(NULL);
+ break;
+ return CUBIT_SUCCESS;
assert (aBRepTrsf != NULL || op != NULL);
TopoDS_Shape shape;
if (aBRepTrsf)
shape = aBRepTrsf->ModifiedShape(*get_TopoDS_Shell());
- else
+ else if(!mySheetSurface)
TopTools_ListOfShape shapes;
shapes.Assign(op->Modified(*get_TopoDS_Shell()));
Modified: cgm/trunk/geom/OCC/OCCShell.hpp
--- cgm/trunk/geom/OCC/OCCShell.hpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCShell.hpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -49,10 +49,13 @@
//- Destructor.
TopoDS_Shell* get_TopoDS_Shell() {return myTopoDSShell;}
- void set_TopoDS_Shell(TopoDS_Shell shell){*myTopoDSShell = shell;}
+ void set_TopoDS_Shell(TopoDS_Shell shell);
OCCLump* my_lump() {return myLump;}
OCCBody* my_body() {return myBody;}
+ OCCSurface* my_surface() {return mySheetSurface;}
+ void set_sheet_surface (OCCSurface* surface) {mySheetSurface = surface;}
void set_lump(OCCLump* lump) {myLump = lump;}
void set_body(OCCBody* body) {myBody = body;}
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-15 14:48:02 UTC (rev 1767)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-04-15 19:15:02 UTC (rev 1768)
@@ -773,7 +773,6 @@
TopoDS_Shape shape;
- CubitBoolean need_update = CUBIT_TRUE;
if (aBRepTrsf)
shape = aBRepTrsf->ModifiedShape(*get_TopoDS_Face());
else
More information about the cgma-dev
