[cgma-dev] r1754 - cgm/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Apr 10 11:17:17 CDT 2008
Author: kraftche
Date: 2008-04-10 11:17:17 -0500 (Thu, 10 Apr 2008)
New Revision: 1754
Modified:
   cgm/trunk/cgm.make.in
   cgm/trunk/configure.in
Log:
o Handle libcgma_init like all other CGM libraries
o Remove bogus linker search paths for libcgma_init
o Reference .la files rather than .a files in CGM_LIBS_FILES
  because a) the .a files won't exist if shared libraries are
  built, b) the .la will get a new timestamp whenever either
  the .a or the .so is updated and c) this variable is presumably
  only used in dependency lists so any file with an appropriate
  timestamp should suffice.
Modified: cgm/trunk/cgm.make.in
--- cgm/trunk/cgm.make.in	2008-04-09 18:02:53 UTC (rev 1753)
+++ cgm/trunk/cgm.make.in	2008-04-10 16:17:17 UTC (rev 1754)
@@ -56,6 +56,8 @@
                ${OCC_INCLUDES}
 CGM_LIBS_LINK_INTERNAL = ${LDFLAGS} \
+	-L$(CGM_LIBDIR) \
+        -L$(CGM_LIBDIR)/init/.libs \
 	-L$(CGM_LIBDIR)/geom/virtual/.libs \
         -L$(CGM_LIBDIR)/geom/facetbool/.libs \
         -L$(CGM_LIBDIR)/geom/facet/.libs \
@@ -72,8 +74,8 @@
         -L$(CGM_LIBDIR)/geom \
         -L$(CGM_LIBDIR)/util \
 	-L${ACIS_LIB_DIR} \
-	-L$(CGM_LIBDIR) \
         ${OCC_LIB_DIR} \
+        -lcgma_init \
 	${ACIS_LIBS} \
         -lcubit_virtual \
         -lcubit_facet \
@@ -86,20 +88,21 @@
         ${OCC_LIBS}
 CGM_LIBS_FILES_INTERNAL = \
-       $(CGM_LIBDIR)/libcubit_virtual.a \
-       $(CGM_LIBDIR)/libcubit_facetbool.a \
-       $(CGM_LIBDIR)/libcubit_facet.a \
-       $(CGM_LIBDIR)/libcholla.a \
-       $(CGM_LIBDIR)/libcubit_geom.a \
-       $(CGM_LIBDIR)/libcubit_util.a \
+       $(CGM_LIBDIR)/libcgma_init.la \
+       $(CGM_LIBDIR)/libcubit_virtual.la \
+       $(CGM_LIBDIR)/libcubit_facetbool.la \
+       $(CGM_LIBDIR)/libcubit_facet.la \
+       $(CGM_LIBDIR)/libcholla.la \
+       $(CGM_LIBDIR)/libcubit_geom.la \
+       $(CGM_LIBDIR)/libcubit_util.la \
        ${CGM_PARALLEL_LIB_FILE}
 CUBIT_LDFwAGS = @CUBIT_LDFLAGS@
 CUBIT_LTFLAGS = @CUBIT_LTFLAGS@
 CUBIT_LIBS = @CUBIT_LIBS@
 CUBIT_FILE = @CUBIT_FILE@
-CGM_LIBS_LINK = -L$(CGM_LIBDIR)/init -L$(CGM_LIBDIR)/init/.libs -lcgma_init @CGM_LIBS_LINK@
-CGM_LIBS_FILES = @CGM_LIBS_FILES@ $(CGM_LIBDIR)/libcgma_init.a
+CGM_LIBS_LINK = @CGM_LIBS_LINK@
+CGM_LIBS_FILES = @CGM_LIBS_FILES@
 CGM_LIBS_LTFLAGS = @CGM_LIBS_LTFLAGS@
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in	2008-04-09 18:02:53 UTC (rev 1753)
+++ cgm/trunk/configure.in	2008-04-10 16:17:17 UTC (rev 1754)
@@ -32,7 +32,7 @@
   CXXFLAGS="$CXXFLAGS -DUSE_MPI"
   CGM_PARALLEL_INCLUDE='-I${CGM_DIR}/geom/parallel'
   CGM_PARALLEL_LIB='-L${CGM_DIR}/geom/parallel -lcubit_parallel'
-  CGM_PARALLEL_LIB_FILE='${CGM_LIBDIR}/libcubit_parallel.a'
+  CGM_PARALLEL_LIB_FILE='${CGM_LIBDIR}/libcubit_parallel.la'
 fi
 AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
 AC_SUBST(CGM_PARALLEL_INCLUDE)
More information about the cgma-dev mailing list
