[cgma-dev] r1296 - cgm/trunk/geom
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Sep 27 09:18:45 CDT 2007
Author: janehu
Date: 2007-09-27 09:18:44 -0500 (Thu, 27 Sep 2007)
New Revision: 1296
Modified:
   cgm/trunk/geom/GeometryModifyEngine.cpp
   cgm/trunk/geom/GeometryModifyEngine.hpp
   cgm/trunk/geom/GeometryModifyTool.cpp
   cgm/trunk/geom/GeometryModifyTool.hpp
Log:
move operations to GeometryModifyTool level and keep GeometryModifyEngine pure virtual
Modified: cgm/trunk/geom/GeometryModifyEngine.cpp
--- cgm/trunk/geom/GeometryModifyEngine.cpp	2007-09-26 17:10:31 UTC (rev 1295)
+++ cgm/trunk/geom/GeometryModifyEngine.cpp	2007-09-27 14:18:44 UTC (rev 1296)
@@ -9,599 +9,3 @@
 #include "GeometryQueryEngine.hpp"
 #include "GeometryQueryTool.hpp"
-CubitStatus GeometryModifyEngine::webcut_with_brick(
-                                     DLIList<BodySM*>& webcut_body_list,
-                                     const CubitVector &center,
-                                     const CubitVector axes[3],
-                                     const CubitVector &extension,
-                                     DLIList<BodySM*> &results_list,
-                                     bool imprint )
-   // Create the brick to cut with
-   BodySM *cutting_tool_ptr = brick( center, axes, extension );
-   if( cutting_tool_ptr == NULL )
-      return CUBIT_FAILURE;
-   CubitStatus stat =
-       this->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ;
-   // Delete the BodySM that was created to be used as a tool
-   get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ;
-   return stat;
-CubitStatus GeometryModifyEngine::webcut_with_cylinder(
-                                        DLIList<BodySM*> &webcut_body_list,
-                                        double radius,
-                                        const CubitVector &axis,
-                                        DLIList<BodySM*>& results_list,
-                                        bool imprint )
-  double max_size =  0.;
-  //lets find the distance to the center for each body and take
-  //the max.
-  double curr;
-  CubitVector cent_bod;
-  CubitBox bounding_box;
-  BodySM *body_ptr;
-  bounding_box = webcut_body_list[0]->bounding_box();
-  cent_bod =  bounding_box.center();
-  cent_bod = cent_bod - center;
-  curr = cent_bod.length();
-  if ( curr > max_size )
-     max_size = curr;
-  for ( int ii = webcut_body_list.size()-1; ii > 0; ii-- )
-      body_ptr = webcut_body_list[ii];
-      bounding_box |= body_ptr->bounding_box();
-      cent_bod = body_ptr->bounding_box().center();
-	max_size = curr;
-  curr = bounding_box.diagonal().length();
-     max_size = curr;
-  double height = 0.0;
-  if ( center.x() > max_size )
-      height = 500.0 * center.x();
-  else if ( center.y() > max_size )
-      height = 500.0 * center.y();
-  else if ( center.z() > max_size )
-      height = 500.0 * center.z();
-  else
-      height = 500.0 * max_size;
-  //lets make certain we have a valid height..
-  if ( height < GEOMETRY_RESABS )
-      height = 500.0;
-  BodySM *cutting_tool_ptr = cylinder( height, radius, radius, radius );
-  //transform the cyclinder to cernter and axis
-  // The current frustum is centered on the z axis.
-  CubitVector axis2(0., 0., 1.0 );
-  //now find the normal to the current axis and axis we want to be
-  //at. This normal is where we will rotate about.
-  CubitVector normal_axis = axis2 * axis;
-  if ( normal_axis.length() > CUBIT_RESABS )
-       //angle in degrees.
-       double angle = normal_axis.vector_angle( axis2, axis );
-       get_gqe()->rotate(cutting_tool_ptr, normal_axis, angle);
-  get_gqe()->translate(cutting_tool_ptr, center);
-  return stat;
-CubitStatus GeometryModifyEngine::webcut_with_planar_sheet(
-                                     const CubitVector axes[2],
-				     double width,
-				     double height,
-                                     bool imprint )
-   // Create the planar sheet to cut with
-   CubitVector p1, p2, p3, p4;
-   // Get the corners of the sheet
-   center.next_point( axes[0], width/2.0, p1 );
-   p1.next_point( axes[1], -height/2.0, p1 );
-   p1.next_point( axes[1], height, p2 );
-   p2.next_point( axes[0], -width, p3 );
-   p3.next_point( axes[1], -height, p4 );
-   BodySM *cutting_tool_ptr = planar_sheet(p1,p2,p3,p4);
-   return stat;
-CubitStatus GeometryModifyEngine::webcut_with_sweep_curves_rotated(
-                              DLIList<BodySM*> &blank_bodies,
-                              DLIList<Curve*> &curves,
-                              const CubitVector& point,
-                              const CubitVector& sweep_axis,
-                              double angle,
-                              Surface *stop_surf,
-                              CubitBoolean imprint )
-  if(curves.size() == 0 )
-  DLIList<GeometryEntity*> ref_ent_list;
-  for(int i = 0; i < curves.size(); i++)
-    ref_ent_list.append((GeometryEntity*)(curves.get_and_step()));
-  DLIList<BodySM*> swept_bodies;
-  CubitStatus stat = sweep_rotational(ref_ent_list,swept_bodies,point,
-                                      sweep_axis,angle,0, 0.0, 0,false,false,
-                                      false,stop_surf);
-  if(stat == CUBIT_FAILURE  && swept_bodies.size() == 0)
-    return stat;
-  //stitch faces together
-  BodySM* cutting_tool_ptr = NULL;
-  stat = stitch_surfs(swept_bodies, cutting_tool_ptr);
-  if(stat == CUBIT_FAILURE)
-      //delete all swept faces
-      for(int i = 0; i < swept_bodies.size(); i++)
-	get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ;
-      return stat;
-  stat =
-       this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint) ;
-   return stat;
-CubitStatus GeometryModifyEngine::webcut_with_sweep_curves(
-                              const CubitVector& sweep_vector,
-                              bool through_all,
-                              Curve *curve_to_sweep_along,
-  CubitVector tmp_sweep_vector = sweep_vector;
-  //get model bbox info...will scale sweep vector by its diagonal
-  //so that we go far enough
-  if( through_all || stop_surf )
-      CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
-      tmp_sweep_vector.normalize();
-      tmp_sweep_vector*=(2*bounding_box.diagonal().length());
-  CubitStatus stat;
-  //see if we're sweeping along a specified curve
-  if( curve_to_sweep_along )
-      DLIList<Curve*> curves_to_sweep_along;
-      curves_to_sweep_along.append(curve_to_sweep_along);
-      stat = sweep_along_curve(ref_ent_list, swept_bodies,
-			       curves_to_sweep_along,0.0,0,false,stop_surf);
-      if (!stat && swept_bodies.size() == 0)
-	return stat;
-  else
-      stat = sweep_translational(ref_ent_list, swept_bodies,
-			     tmp_sweep_vector,0.0,0, false, false, stop_surf);
-	return stat;
-      return stat;
-  stat =
-   return stat;
-CubitStatus GeometryModifyEngine::webcut_with_curve_loop(
-                              bool imprint )
-  GeometryType surface_type = PLANE_SURFACE_TYPE;
-  CubitStatus stat;
-  //make copies of the curves.
-  DLIList<Curve*> copied_curves;
-  Curve* temp_curve = NULL;
-  for (int i = curves.size(); i--;)
-      temp_curve = make_Curve(curves.get_and_step());
-      if(temp_curve != NULL)
-        copied_curves.append(temp_curve);
-  //make a face out of the curves
-  Surface * surf = make_Surface(surface_type, copied_curves, NULL, false );
-  if (surf == NULL)
-      PRINT_ERROR("webcut tool surface is not created from acis.\n");
-  //get cutting tool BodySM.
-  BodySM* cutting_tool_ptr = make_BodySM(surf);
-  assert(cutting_tool_ptr );
-  stat =
-   return stat;
-CubitStatus GeometryModifyEngine::webcut_with_extended_surf(
-                              Surface *extend_from,
-                              int &num_cut,
-                              bool imprint )
-  assert(extend_from);
-  //make the extended face
-  Surface * surf = make_Surface(extend_from, true);
-  if (surf == NULL)
-  BodySM* cutting_tool_ptr = surf->bodysm();
-  CubitStatus stat;
-  stat =
-  num_cut = results_list.size();
-  return stat;
-CubitStatus GeometryModifyEngine::webcut_with_sweep_surfaces_rotated(
-                              DLIList<Surface*> &surfaces,
-                              double angle,
-                              bool up_to_next,
-  if(surfaces.size() == 0 )
-  Surface * temp_face = NULL;
-  for(int i = 0; i < surfaces.size(); i++)
-      //copy the faces before sweep
-      temp_face = make_Surface(surfaces.get_and_step());
-      if (temp_face)
-	ref_ent_list.append((GeometryEntity*)temp_face);
-  BodySM* to_body = NULL;
-  CubitStatus stat = CUBIT_SUCCESS;
-  if(up_to_next && blank_bodies.size() > 1) //unite all bland_bodies
-       DLIList<BodySM*> newBodies;
-       DLIList<BodySM*> copied_bodies;
-       for(int i = 0; i < blank_bodies.size(); i++)
-         copied_bodies.append(copy_body(blank_bodies.get_and_step()));
-       stat = unite(copied_bodies, newBodies);
-	   PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n");
-	   PRINT_INFO("Try the 'stop surface <id>' option instead\n");
-	   return stat;
-       to_body = newBodies.get();
-  else if(up_to_next && blank_bodies.size() == 1)
-    to_body = copy_body(blank_bodies.get());
-  stat = sweep_rotational(ref_ent_list,swept_bodies,point,
-                                      sweep_vector,angle,0, 0.0,0,false,false,
-                                      false,stop_surf, to_body);
-       //delete copied faces
-       GeometryEntity * temp_entity = NULL;
-       for(int i = ref_ent_list.size();i--;)
-            temp_entity = ref_ent_list.get_and_step();
-            if (temp_entity)
-              get_gqe()->delete_solid_model_entities( (Surface*)temp_entity);
-       return stat;
-  //if there are more than 1, unite them all
-  if (swept_bodies.size() > 1)
-     stat = unite(swept_bodies, newBodies);
-  else
-     newBodies = swept_bodies;
-  if(stat == CUBIT_FAILURE || newBodies.size()!= 1)
-       PRINT_ERROR("webcut tool body is not created from acis.\n");
-       //delete the swept_bodies
-       BodySM* tmp_body = NULL;
-       for (int i = swept_bodies.size(); i--;)
-	   tmp_body= swept_bodies.get_and_step();
-           if (tmp_body)
-	     get_gqe()->delete_solid_model_entities(tmp_body);
-            if (temp_entity)
-  BodySM *cutting_tool_ptr = newBodies.get();
-  stat =
-    this->webcut(blank_bodies, cutting_tool_ptr, results_list, imprint ) ;
-  return stat;
-CubitStatus GeometryModifyEngine::webcut_with_sweep_surfaces(
-                              bool sweep_perp,
-                              bool through_all,
-                              bool outward,
-                              bool up_to_next,
-  if( through_all || stop_surf || up_to_next)
-  if( sweep_perp == true )
-      tmp_sweep_vector.set(1,0,0);
-      tmp_sweep_vector = 2*(bounding_box.diagonal());
-	   return stat;
-      if (temp_face)
-  //Sweep surfaces
-			       curves_to_sweep_along, 0.0,0,false,stop_surf,
-			       to_body);
-  else if (sweep_perp )
-    stat = sweep_perpendicular(ref_ent_list, swept_bodies,
-			       tmp_sweep_vector.length(),0.0,0,outward,false,
-			       stop_surf, to_body);
-  else
-			       tmp_sweep_vector,0.0,0, false, false, stop_surf,
-			       to_body);
-  if (stat == CUBIT_FAILURE && swept_bodies.size() == 0)
-          if (temp_entity)
-       return stat;
-  else
-       PRINT_ERROR("the webcut tool body is not created from acis.\n");
-           if (tmp_body)
-            if (temp_entity)
-  stat =
-  return stat;
Modified: cgm/trunk/geom/GeometryModifyEngine.hpp
--- cgm/trunk/geom/GeometryModifyEngine.hpp	2007-09-26 17:10:31 UTC (rev 1295)
+++ cgm/trunk/geom/GeometryModifyEngine.hpp	2007-09-27 14:18:44 UTC (rev 1296)
@@ -293,11 +293,11 @@
                                    DLIList<BodySM*> &new_bodies,
                                    bool imprint = false,
                                    bool keep_old = false) const = 0;
       virtual CubitStatus imprint(BodySM* BodyPtr1, BodySM* BodyPtr2,
                                   BodySM*& newBody1, BodySM*& newBody2,
                                   bool keep_old) const = 0;
       virtual CubitStatus imprint(DLIList<BodySM*> &from_body_list,
                                   DLIList<BodySM*> &new_from_body_list,
                                   bool keep_old,
@@ -350,7 +350,7 @@
                                        DLIList<Curve*> &ref_edge_list,
                                        DLIList<BodySM*>& new_body_list,
                                        bool keep_old_body,
-                                       bool keep_free_edges) const = 0;
+                                       bool keep_free_edges) const= 0  ;
       //- Imprints a list of Surfaces with a list of projected RefEdges.
       virtual CubitStatus imprint_projected_edges(
@@ -359,7 +359,7 @@
                                        bool keep_old_body,
       //- Imprints a list of Bodies with a list of RefEdges which are projected
       //- to a list of Surfaces
@@ -569,118 +569,7 @@
       //- I- Bodies to be webcut, plane to define cuts, and imprint merge flags.
       //- This is an experimental function, hooked to the GUI for making
       //- bodies one to one sweeps.
-      virtual CubitStatus webcut_with_sheet(DLIList<BodySM*>& webcut_body_list,
-                                            BodySM *sheet_body,
-                                            DLIList<BodySM*> &new_bodies,
-                                            bool imprint = false) = 0;
-      //- webcuts a body using a sheet body.
-      //- It splits the sheet into two single sided bodies.
-      //- it then subtracts this with the webcut body.
-      //- The result is splitting the webcut_body into halves.
-      //- if the webcut body is a topological torus, this routine
-      //- will fail...
-      virtual CubitStatus webcut_with_extended_surf(
-                                            int &num_cut,
-                                            bool imprint = false );
-      //- creates a surface by extending one from the given surface then
-      //- webcuts using the this sheet.(see webcut_with_sheet.
-      virtual CubitStatus webcut_with_sweep_surfaces(
-                            bool sweep_perp,
-                            bool through_all,
-                            bool outward,
-                            bool up_to_next,
-                            CubitBoolean imprint = false);
-      virtual CubitStatus webcut_with_sweep_curves(
-                            bool through_all,
-                            CubitBoolean imprint = false) ;
-      virtual CubitStatus webcut_with_sweep_curves_rotated(
-                            const CubitVector &point,
-                            const CubitVector &sweep_axis,
-                            double angle,
-      virtual CubitStatus webcut_with_sweep_surfaces_rotated(
-                            double angle,
-                            bool up_to_next,
-      virtual CubitStatus webcut_with_cylinder(
-                                        double radius,
-                                        bool imprint = false) ;
-      //- webcuts a body using a cylinder give the input parameters.
-      CubitStatus webcut_with_brick(
-      /**<  Webcuts the bodies in the list with a cutting brick.
-        *  The brick is created by the given parameters - center of
-        *  brick, xyz axes, and extension.  Extension is 1/2 width,
-        *  height and depth. If one of the brick dimensions is zero
-        *  the resultant planar sheet is used to webcut (webcut_with_
-        *  planar_sheet is called).  Brick creation is done in the
-        *  solid modeling engine to reduce the impact on body ids.
-      virtual CubitStatus webcut_with_planar_sheet(
-                                            double width, double height,
-      /**<  Webcuts the bodies in the list with a cutting planar sheet.
-        *  The sheet is created by the given parameters - center of
-        *  sheet, xy axes, and width and height. Sheet creation is done
-        *  in the solid modeling engine to reduce the impact on body ids.
-      virtual CubitStatus webcut_with_curve_loop(
-                                         DLIList<Curve*> &ref_edge_list,
-      //- webcuts a body list using a temp sheet body created from the curve loop
       virtual CubitStatus section( DLIList<BodySM*> &section_body_list,
                                    const CubitVector &point_1,
                                    const CubitVector &point_2,
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp	2007-09-26 17:10:31 UTC (rev 1295)
+++ cgm/trunk/geom/GeometryModifyTool.cpp	2007-09-27 14:18:44 UTC (rev 1296)
@@ -1837,7 +1837,7 @@
     push_vg_attributes_before_modify(engine_body_sms);
-    CubitStatus status = gme->webcut_with_cylinder(engine_body_sms, radius, axis,
+    CubitStatus status = webcut_w_cylinder( engine_body_sms, radius, axis,
               center, result_sm_list, imprint );
     restore_vg_after_modify(result_sm_list, engine_bodies);
@@ -1861,6 +1861,101 @@
   return rval;
+CubitStatus GeometryModifyTool::webcut_w_cylinder(
+                                        DLIList<BodySM*> &webcut_body_list,
+                                        double radius,
+                                        const CubitVector &axis,
+                                        const CubitVector &center,
+                                        DLIList<BodySM*>& results_list,
+                                        bool imprint )
+  GeometryModifyEngine* gme = 0;
+  gme = get_engine(webcut_body_list.get());
+  assert(gme);
+  double max_size =  0.;
+  //lets find the distance to the center for each body and take
+  //the max.
+  double curr;
+  CubitVector cent_bod;
+  CubitBox bounding_box;
+  BodySM *body_ptr;
+  bounding_box = webcut_body_list[0]->bounding_box();
+  cent_bod =  bounding_box.center();
+  cent_bod = cent_bod - center;
+  curr = cent_bod.length();
+  if ( curr > max_size )
+     max_size = curr;
+  for ( int ii = webcut_body_list.size()-1; ii > 0; ii-- )
+      body_ptr = webcut_body_list[ii];
+      bounding_box |= body_ptr->bounding_box();
+      cent_bod = body_ptr->bounding_box().center();
+        max_size = curr;
+  curr = bounding_box.diagonal().length();
+     max_size = curr;
+  double height = 0.0;
+  if ( center.x() > max_size )
+      height = 500.0 * center.x();
+  else if ( center.y() > max_size )
+      height = 500.0 * center.y();
+  else if ( center.z() > max_size )
+      height = 500.0 * center.z();
+  else
+      height = 500.0 * max_size;
+  //lets make certain we have a valid height..
+  if ( height < GEOMETRY_RESABS )
+      height = 500.0;
+  BodySM *cutting_tool_ptr = gme->cylinder( height, radius, radius, radius );
+  if( cutting_tool_ptr == NULL )
+    return CUBIT_FAILURE;
+  //transform the cyclinder to cernter and axis
+  // The current frustum is centered on the z axis.
+  CubitVector axis2(0., 0., 1.0 );
+  //now find the normal to the current axis and axis we want to be
+  //at. This normal is where we will rotate about.
+  CubitVector normal_axis = axis2 * axis;
+  if ( normal_axis.length() > CUBIT_RESABS )
+       //angle in degrees.
+       double angle = normal_axis.vector_angle( axis2, axis );
+       gme->get_gqe()->rotate(cutting_tool_ptr, normal_axis, angle);
+  gme->get_gqe()->translate(cutting_tool_ptr, center);
+  CubitStatus stat =
+    gme->webcut(webcut_body_list, cutting_tool_ptr, results_list, imprint) ;
+  // Delete the BodySM that was created to be used as a tool
+  gme->get_gqe()->delete_solid_model_entities(cutting_tool_ptr) ;
+  return stat;
 void GeometryModifyTool::do_attribute_setup(void)
   //save attribute settings
@@ -2002,19 +2097,48 @@
    assert(webcut_sm_list.size() == webcut_body_list.size());
    assert(curve_list.size() == refedge_list.size());
+   GeometryType surface_type = PLANE_SURFACE_TYPE;
+   CubitStatus stat;
+   //make copies of the curves.
+   DLIList<Curve*> copied_curves;
+   Curve* temp_curve = NULL;
+   for (int i = curve_list.size(); i--;)
+       temp_curve = gme->make_Curve(curve_list.get_and_step());
+       if(temp_curve != NULL)
+         copied_curves.append(temp_curve);
+   //make a face out of the curves
+   Surface * surf = gme->make_Surface(surface_type, copied_curves, NULL, false );
+   if (surf == NULL)
+       PRINT_ERROR("webcut tool surface is not created from acis.\n");
+   //get cutting tool BodySM.
+   BodySM* cutting_tool_ptr = gme->make_BodySM(surf);
+   assert(cutting_tool_ptr );
    do_attribute_setup();
    push_vg_attributes_before_modify(webcut_sm_list);
-   CubitStatus result_val = gme->webcut_with_curve_loop(
-                     webcut_sm_list, curve_list, result_sm_list, imprint) ;
+   stat = gme->webcut(
+                     webcut_sm_list, cutting_tool_ptr, result_sm_list, imprint) ;
    restore_vg_after_modify(result_sm_list, original_body_list);
-   result_val = finish_webcut( webcut_body_list, result_sm_list, CUBIT_FALSE,
-                               result_val, results_list );
+   stat = finish_webcut( webcut_body_list, result_sm_list, CUBIT_FALSE,
+                               stat, results_list );
    do_attribute_cleanup();
-   return result_val;
+   return stat;
@@ -2809,7 +2933,7 @@
 			Curve *facet_curve;
 			facet_curve=edge_list[ii]->get_curve_ptr();
 			int num_points;
-			int color = 2;
+			//int color = 2;
 			CubitStatus response;
 			GMem g_mem;
@@ -3115,7 +3239,7 @@
 				Curve *facet_curve;
 				facet_curve=surf_edge_list[ii]->get_curve_ptr();
 				int num_points;
-				int color = 2;
+				//int color = 2;
 				GMem g_mem;
@@ -3436,7 +3560,10 @@
                    width, height, depth );
       return CUBIT_FAILURE ;
+   BodySM *cutting_tool_ptr = NULL;
+   CubitBoolean is_sheet_body = CUBIT_FALSE;
+   CubitVector p1, p2, p3, p4;
    int wz = width < GEOMETRY_RESABS;
    int hz = height < GEOMETRY_RESABS;
    int dz = depth < GEOMETRY_RESABS;
@@ -3452,6 +3579,7 @@
       // Make a sheet body instead of a cuboid
+      is_sheet_body = CUBIT_TRUE;
       CubitVector sheet_axes[2];
       if( wz )
@@ -3471,8 +3599,13 @@
          sheet_axes[1] = axes[1];
-      return webcut_with_planar_sheet (webcut_body_list, center, sheet_axes,
-                          width, height, results_list, imprint, merge);
+      // Create the planar sheet to cut with
+      // Get the corners of the sheet
+      center.next_point( axes[0], width/2.0, p1 );
+      p1.next_point( axes[1], -height/2.0, p1 );
+      p1.next_point( axes[1], height, p2 );
+      p2.next_point( axes[0], -width, p3 );
+      p3.next_point( axes[1], -height, p4 );
    if (!okay_to_modify( webcut_body_list, "WEBCUT" ))
@@ -3493,9 +3626,20 @@
-      CubitStatus status = gme->webcut_with_brick (
-        engine_body_sms, center, axes, extension, result_sm_list, imprint );
+      // Create the brick to cut with
+      if (is_sheet_body)
+	cutting_tool_ptr = gme->planar_sheet(p1,p2,p3,p4);
+      else
+        cutting_tool_ptr = gme->brick( center, axes, extension );
+      CubitStatus status = gme->webcut (
+        engine_body_sms, cutting_tool_ptr, result_sm_list, imprint );
       status = finish_webcut( engine_bodies, result_sm_list, merge, status, results_list );
@@ -3545,9 +3689,26 @@
-      CubitStatus status = gme->webcut_with_planar_sheet (
-        engine_body_sms, center, axes, width, height, result_sm_list, imprint );
+      BodySM *cutting_tool_ptr = gme->planar_sheet(p1,p2,p3,p4);
@@ -4281,8 +4442,8 @@
                                          DLIList<Body*> &new_body_list,
                                          CubitBoolean keep_old )
-   if (get_group_imprint() == CUBIT_FALSE)
-     return imprint_singly( from_body_list, new_body_list, keep_old );
+   //if (get_group_imprint() == CUBIT_FALSE)
+   //  return imprint_singly( from_body_list, new_body_list, keep_old );
      // Check the GeometryEngine for each of the Body's; check to
      // make sure they're all the same
@@ -4429,7 +4590,7 @@
 CubitStatus GeometryModifyTool::imprint_singly( DLIList<Body*> &from_body_list,
@@ -4599,8 +4760,8 @@
    return CUBIT_SUCCESS;
 CubitStatus GeometryModifyTool::imprint( DLIList<Body*> &body_list,
                                          DLIList<RefEdge*> &ref_edge_list,
                                          DLIList<Body*>& new_body_list,
@@ -4829,8 +4990,6 @@
                                          new_sm_list, keep_old_body, &new_tbs,
                                             &att_tbs );
-   int i, j;
    if(process_composites)
       // Analyze the results and adjust virtual attributes as necessary.
@@ -5072,14 +5231,31 @@
+   //make the extended face
+   Surface * surf = gme->make_Surface(surf_ptr, true);
+   if (surf == NULL)
+   BodySM* cutting_tool_ptr = surf->bodysm();
    push_vg_attributes_before_modify(body_sm_list);
    //change sjs at cat 1/27/04
-   CubitStatus stat = gme->webcut_with_extended_surf ( //gmeList.get()->webcut_with_extended_surf (
-       body_sm_list, surf_ptr, new_sms, num_cut, imprint  );
+   CubitStatus stat = gme->webcut ( //gmeList.get()->webcut_with_extended_surf (
+       body_sm_list, cutting_tool_ptr, new_sms, imprint  );
+   num_cut = new_sms.size();
    restore_vg_after_modify(new_sms, original_body_list);
    CubitStatus ret = finish_webcut(webcut_body_list, new_sms, false, stat, new_bodies );
@@ -5132,14 +5308,23 @@
      stop_surface = stop_surf->get_surface_ptr();
+   BodySM* cutting_tool_ptr = NULL;
+   CubitStatus stat = prepare_surface_sweep(body_sm_list,surfaces_to_sweep,
+                           sweep_axis,false,false,false,
+                           up_to_next,stop_surface, NULL, cutting_tool_ptr, &point, &angle);
+   if(stat == CUBIT_FAILURE )
+        return stat;
-   CubitStatus stat = gme->webcut_with_sweep_surfaces_rotated(
-       body_sm_list, surfaces_to_sweep, point, sweep_axis, angle,
-       stop_surface, up_to_next, new_sms, imprint );
    stat = finish_webcut(webcut_body_list, new_sms, merge, stat, new_bodies );
@@ -5193,13 +5378,43 @@
+   //sweep the curves.
+   DLIList<GeometryEntity*> ref_ent_list;
+   for(int i = 0; i < curves_to_sweep.size(); i++)
+     ref_ent_list.append((GeometryEntity*)(curves_to_sweep.get_and_step()));
+   DLIList<BodySM*> swept_bodies;
+   CubitStatus stat = gme->sweep_rotational(ref_ent_list,swept_bodies,point,
+                                      sweep_axis,angle,0, 0.0, 0,false,false,
+                                      false,stop_surface);
+   if(stat == CUBIT_FAILURE  && swept_bodies.size() == 0)
+     return stat;
+   //stitch faces together
+   stat = gme->stitch_surfs(swept_bodies, cutting_tool_ptr);
+   if(stat == CUBIT_FAILURE)
+       //delete all swept faces
+       for(int i = 0; i < swept_bodies.size(); i++)
+         gme->get_gqe()->delete_solid_model_entities(swept_bodies.get_and_step()) ;
+       return stat;
-   CubitStatus stat = gme->webcut_with_sweep_curves_rotated(
-       body_sm_list, curves_to_sweep, point, sweep_axis, angle,
-       stop_surface, new_sms, imprint);
+       body_sm_list, cutting_tool_ptr, new_sms, imprint);
@@ -5258,6 +5473,22 @@
+   CubitVector tmp_sweep_vector = sweep_vector;
+   //get model bbox info...will scale sweep vector by its diagonal
+   //so that we go far enough
+   if( through_all || stop_surf )
+       CubitBox bounding_box = GeometryQueryTool::instance()->model_bounding_box();
+       tmp_sweep_vector.normalize();
+       tmp_sweep_vector*=(2*bounding_box.diagonal().length());
+   CubitStatus stat;
    Curve *curve_to_sweep_along = NULL;
    if( edge_to_sweep_along )
@@ -5271,15 +5502,49 @@
      curve_to_sweep_along = edge_to_sweep_along->get_curve_ptr();
+     DLIList<Curve*> curves_to_sweep_along;
+     curves_to_sweep_along.append(curve_to_sweep_along);
+     stat = gme->sweep_along_curve(ref_ent_list, swept_bodies,
+                              curves_to_sweep_along,0.0,0,false,stop_surface);
+     if (!stat && swept_bodies.size() == 0)
+       return stat;
+   else
+     stat = gme->sweep_translational(ref_ent_list, swept_bodies,
+                            tmp_sweep_vector,0.0,0, false, false, stop_surface);
+       return stat;
+       return stat;
-   CubitStatus stat = gme->webcut_with_sweep_curves(
-       body_sm_list, curves_to_sweep, sweep_vector, through_all,
-       stop_surface, curve_to_sweep_along, new_sms, imprint );
@@ -5356,10 +5621,19 @@
-   CubitStatus stat = gme->webcut_with_sweep_surfaces(
       body_sm_list, surfaces_to_sweep, sweep_vector, sweep_perp, through_all, outward,
-      up_to_next, stop_surface, curve_to_sweep_along, new_sms, imprint );
+      up_to_next, stop_surface, curve_to_sweep_along, cutting_tool_ptr );
+   if (stat == CUBIT_FAILURE)
+     return stat;
@@ -5517,7 +5791,7 @@
    BodySM* body_sm = body_ptr->get_body_sm_ptr();
    GeometryModifyEngine* gme = get_engine(body_sm);
    if (!gme) {
-      PRINT_ERROR("Volume does not have a modify engine.\n", body_ptr->id());
+      PRINT_ERROR("Volume %d does not have a modify engine.\n", body_ptr->id());
@@ -6787,7 +7061,7 @@
   if( ref_face1 == ref_face2 )
-    PRINT_ERROR("Cannot create midplane between the same surface.\n",
+    PRINT_ERROR("Cannot create midplane between the same surface.\n"
                 "       Surface %d was entered twice\n",  ref_face1->id() );
@@ -7054,7 +7328,7 @@
@@ -7099,7 +7373,7 @@
       PRINT_ERROR( "In GeometryModifyTool::get_mid_surface\n"
 		   "       Surfaces %d and %d do not have the same underlying geometry modeling engine.\n"
 		   "       For midsurface calculations, they must be the same\n",
-		   ref_face1->id(), ref_face2 );
+		   ref_face1->id(), ref_face2->id() );
@@ -8180,7 +8454,7 @@
               if(TopologyEntity* t = m->topology_entity())
                 entities_to_update.append(CAST_TO(t, RefEntity));
-                RefEntity *ref_ent = CAST_TO(t, RefEntity );
+                //RefEntity *ref_ent = CAST_TO(t, RefEntity );
@@ -9041,4 +9315,140 @@
   // Build strings for potential regularize solutions.
+CubitStatus GeometryModifyTool::prepare_surface_sweep(
+                              DLIList<BodySM*> &blank_bodies,
+                              DLIList<Surface*> &surfaces,
+                              const CubitVector& sweep_vector,
+                              bool sweep_perp,
+                              bool through_all,
+                              bool outward,
+                              bool up_to_next,
+                              Surface *stop_surf,
+                              Curve *curve_to_sweep_along,
+                              BodySM* &cutting_tool_ptr ,
+                              const CubitVector* point,
+                              double *angle)
+  GeometryModifyEngine* gme = get_engine(blank_bodies.get());
+  if(surfaces.size() == 0 )
+  Surface * temp_face = NULL;
+  for(int i = 0; i < surfaces.size(); i++)
+      //copy the faces before sweep
+      temp_face = gme->make_Surface(surfaces.get_and_step());
+      if (temp_face)
+        ref_ent_list.append((GeometryEntity*)temp_face);
+  BodySM* to_body = NULL;
+  CubitStatus stat = CUBIT_SUCCESS;
+  if(up_to_next && blank_bodies.size() > 1) //unite all bland_bodies
+       DLIList<BodySM*> newBodies;
+       DLIList<BodySM*> copied_bodies;
+       for(int i = 0; i < blank_bodies.size(); i++)
+         copied_bodies.append(gme->copy_body(blank_bodies.get_and_step()));
+       stat = gme->unite(copied_bodies, newBodies);
+           PRINT_ERROR("Cannot use 'up_to_next' option with specified geometry\n");
+           PRINT_INFO("Try the 'stop surface <id>' option instead\n");
+           return stat;
+       to_body = newBodies.get();
+  else if(up_to_next && blank_bodies.size() == 1)
+    to_body = gme->copy_body(blank_bodies.get());
+  if (point && angle) //sweep_surface_rotated
+    stat = gme->sweep_rotational(ref_ent_list,swept_bodies,*point,
+                           sweep_vector, *angle,0, 0.0,0,false,false,
+                           false,stop_surf, to_body);
+  else
+    if( through_all || stop_surf || up_to_next)
+    //see if we're sweeping along a specified curve
+    if( curve_to_sweep_along )
+                                 curves_to_sweep_along, 0.0,0,false,stop_surf,
+                                 to_body);
+    else if (sweep_perp )
+      stat = gme->sweep_perpendicular(ref_ent_list, swept_bodies,
+                                 tmp_sweep_vector.length(),0.0,0,outward,false,
+                                 stop_surf, to_body);
+    else
+                                 tmp_sweep_vector,0.0,0, false, false, stop_surf,
+                                 to_body);
+       //delete copied faces
+       GeometryEntity * temp_entity = NULL;
+       for(int i = ref_ent_list.size();i--;)
+            temp_entity = ref_ent_list.get_and_step();
+            if (temp_entity)
+              gme->get_gqe()->delete_solid_model_entities( (Surface*)temp_entity);
+       return stat;
+  //if there are more than 1, unite them all
+  if (swept_bodies.size() > 1)
+     stat = gme->unite(swept_bodies, newBodies);
+  else
+     newBodies = swept_bodies;
+  if(stat == CUBIT_FAILURE || newBodies.size()!= 1)
+       PRINT_ERROR("webcut tool body is not created from acis.\n");
+       //delete the swept_bodies
+       BodySM* tmp_body = NULL;
+       for (int i = swept_bodies.size(); i--;)
+           tmp_body= swept_bodies.get_and_step();
+           if (tmp_body)
+             gme->get_gqe()->delete_solid_model_entities(tmp_body);
+            if (temp_entity)
+    cutting_tool_ptr = newBodies.get();
+    return stat;
Modified: cgm/trunk/geom/GeometryModifyTool.hpp
--- cgm/trunk/geom/GeometryModifyTool.hpp	2007-09-26 17:10:31 UTC (rev 1295)
+++ cgm/trunk/geom/GeometryModifyTool.hpp	2007-09-27 14:18:44 UTC (rev 1296)
@@ -1594,6 +1594,32 @@
     *   only be called after webcutting. (Checks sepAfterWebcut flag.)
+  CubitStatus webcut_w_cylinder(
+                                double radius,
+                                bool imprint = false) ;
+  //- webcuts a body using a cylinder given the input parameters.
+  CubitStatus prepare_surface_sweep(
+                              bool sweep_perp,
+                              bool through_all,
+                              bool outward,
+                              bool up_to_next,
+                              const CubitVector* point = NULL,
+                              double *angle = NULL);
+  // prepare for webcut with swept_surfaces. if point and angle is known,
+  // do surface sweep rotated; or if curve_to_sweep_along is known, do
+  // sweep along curve; then if sweep_perp is true, do perpendicular sweep
+  // of the surfaces; lastly do sweep along vector.
   bool contains_intermediate_geom(DLIList<Body*>& list) const;
   bool contains_intermediate_geom(DLIList<TopologyBridge*>& list) const;
   bool contains_composites(DLIList<TopologyBridge*>& bridge_list ) const;
More information about the cgma-dev mailing list
