[cgma-dev] r1342 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Oct 25 13:48:16 CDT 2007
Author: janehu
Date: 2007-10-25 13:48:16 -0500 (Thu, 25 Oct 2007)
New Revision: 1342
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added get_graphics for surfaces and modified bodies_overlap to check on lumps overlapping. This added bounding_box check for each lump, and make decision quicker.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2007-10-25 12:35:08 UTC (rev 1341)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2007-10-25 18:48:16 UTC (rev 1342)
@@ -12,8 +12,8 @@
 // Owner         : John Fowler
-#ifndef FACET_MODIFY_ENGINE_HPP
-#define FACET_MODIFY_ENGINE_HPP
+#ifndef OCC_MODIFY_ENGINE_HPP
+#define OCC_MODIFY_ENGINE_HPP
 #include "GeometryModifyEngine.hpp"
 #include <vector>
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-10-25 12:35:08 UTC (rev 1341)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2007-10-25 18:48:16 UTC (rev 1342)
@@ -21,8 +21,13 @@
 #include "Geom_Surface.hxx"
 #include "Geom_Curve.hxx"
 #include "BRepBuilderAPI_Transform.hxx"
+#include "TColgp_Array1OfPnt.hxx"
+#include "Poly_Array1OfTriangle.hxx"
+#include "Poly_Triangle.hxx"
+#include "Handle_Poly_Triangulation.hxx"
 #include "OCCQueryEngine.hpp"
 #include "OCCModifyEngine.hpp"
+#include "Poly_Triangulation.hxx"
 #include "TopologyEntity.hpp"
 #include "TopologyBridge.hpp"
 #include "RefEntity.hpp"
@@ -221,14 +226,68 @@
 // Date       :
 CubitStatus OCCQueryEngine::get_graphics( Surface* surface_ptr,
-                                                     int& number_triangles,
-                                                     int& number_points,
-                                                     int& number_facets,
-                                                     GMem* gMem,
-                                                     unsigned short ,
-                                                     double,
-                                                     double ) const
+                                          int& number_triangles,
+                                          int& number_points,
+                                          int& number_facets,
+                                          GMem* g_mem,
+                                          unsigned short normal_tolerance,
+                                          double distance_tolerance,
+                                          double max_edge_length) const
+    // Because this may be unnecessarily called twice,
+    // say there is one triangle.
+  if (!g_mem)
+    number_triangles = 1;
+    number_points = 3;
+    number_facets = 4;
+    return CUBIT_SUCCESS;
+  OCCSurface *occ_surface_ptr = CAST_TO(surface_ptr, OCCSurface);
+  TopoDS_Face * Topo_Face = occ_surface_ptr->get_TopoDS_Face();
+  if (!Topo_Face)
+    return CUBIT_FAILURE;
+  TopLoc_Location L;
+  Handle_Poly_Triangulation facets = BRep_Tool::Triangulation(*Topo_Face, L);
+  //if necessary, the face tolerance can be returned. now, no use.
+  //double tol = BRep_Tool::Tolerance(*Topo_Face);
+  number_points = facets->NbNodes();
+  number_triangles = facets->NbTriangles();
+  assert(number_points == 3 * number_triangles);
+  number_facets = 4 * number_triangles;
+  TColgp_Array1OfPnt points(0, number_points-1);
+  points.Assign(facets->Nodes());
+  GPoint *gPnts= new GPoint[number_points];
+  for (int i = 0; i < number_points; i ++)
+     gp_Pnt gp_pnt = points.Value(i);
+     GPoint gPnt;
+     gPnt.x = gp_pnt.X();
+     gPnt.y = gp_pnt.Y();
+     gPnt.z = gp_pnt.Z();
+     gPnts[i] = gPnt;
+  g_mem->replace_point_list( gPnts, number_points, number_points);
+  Poly_Array1OfTriangle triangles(0, number_facets-1);
+  triangles.Assign( facets->Triangles() );
+  int *facetList =  new int[number_facets];
+  for (int i = 0; i < triangles.Length(); i++)
+     Poly_Triangle triangle = triangles.Value( i );
+     int N1, N2, N3;
+     triangle.Get(N1, N2, N3);
+     facetList[4 * i] = 3;
+     facetList[4 * i + 1] = N1;
+     facetList[4 * i + 2] = N2;
+     facetList[4 * i + 3] = N3;
+  g_mem->replace_facet_list( facetList, number_facets, number_facets);
@@ -243,7 +302,7 @@
                                             double /*tolerance*/ ) const
   //  get the OCCCurve.
-  //OCCCurve *facet_curv_ptr = CAST_TO(curve_ptr,OCCCurve);
+  OCCCurve *occ_curv_ptr = CAST_TO(curve_ptr,OCCCurve);
@@ -1992,13 +2051,19 @@
   //BRepAlgoAPI_Section calculates intersection between faces only.
   TopExp_Explorer Ex1, Ex2;
-  for (Ex1.Init(*shape1, TopAbs_FACE); Ex1.More(); Ex1.Next())
+  for (Ex1.Init(*shape1, TopAbs_SOLID); Ex1.More(); Ex1.Next())
-    for (Ex2.Init(*shape2, TopAbs_FACE); Ex2.More(); Ex2.Next())
+    TopoDS_Solid *posolid1 =  new TopoDS_Solid;
+    *posolid1 = TopoDS::Solid(Ex1.Current());
+    OCCLump * lump1 = new OCCLump(posolid1);
+    for (Ex2.Init(*shape2, TopAbs_SOLID); Ex2.More(); Ex2.Next())
-        BRepAlgoAPI_Section section(Ex1.Current(), Ex2.Current());
-        if (section.HasGenerated())
-          return CUBIT_TRUE;
+       TopoDS_Solid *posolid2 =  new TopoDS_Solid;
+       *posolid2 = TopoDS::Solid(Ex2.Current());
+       OCCLump * lump2 = new OCCLump(posolid2);
+       CubitBoolean is_overlap = volumes_overlap(lump1, lump2);
+       if(is_overlap)
+	 return CUBIT_TRUE;
   return CUBIT_FALSE;
More information about the cgma-dev mailing list
