[cgma-dev] r1315 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Fri Oct 19 13:18:57 CDT 2007
Author: janehu
Date: 2007-10-19 13:18:57 -0500 (Fri, 19 Oct 2007)
New Revision: 1315
Modified:
cgm/trunk/geom/OCC/OCCBody.hpp
cgm/trunk/geom/OCC/OCCCurve.hpp
cgm/trunk/geom/OCC/OCCLump.hpp
cgm/trunk/geom/OCC/OCCPoint.cpp
cgm/trunk/geom/OCC/OCCPoint.hpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.hpp
cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added entity-entity-distance and get-TopoDS-Shape-of_entity in Query functions, and make some small changes.
Modified: cgm/trunk/geom/OCC/OCCBody.hpp
--- cgm/trunk/geom/OCC/OCCBody.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCBody.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -62,6 +62,8 @@
//- This function returns a pointer to the geometric modeling engine
//- associated with the object.
+ TopoDS_Shape *get_TopoDS_Shape() {return myTopoDSShape; }
virtual void append_simple_attribute_virt(CubitSimpleAttrib*);
//R void
//I
Modified: cgm/trunk/geom/OCC/OCCCurve.hpp
--- cgm/trunk/geom/OCC/OCCCurve.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCCurve.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -339,8 +339,8 @@
void reset_length();
//- update the length of the facet curve
- TopoDS_Edge get_TopoDS_Edge( )
- { return *myTopoDSEdge; }
+ TopoDS_Edge *get_TopoDS_Edge( )
+ { return myTopoDSEdge; }
Point *start_point()
{ assert(0);return myStartPoint; }
Modified: cgm/trunk/geom/OCC/OCCLump.hpp
--- cgm/trunk/geom/OCC/OCCLump.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCLump.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -55,6 +55,8 @@
void add_body(BodySM* new_body)
{myBodyPtr = new_body;}
+ TopoDS_Solid *get_TopoDS_Solid(){ return myTopoDSSolid; }
//R void
//I
Modified: cgm/trunk/geom/OCC/OCCPoint.cpp
--- cgm/trunk/geom/OCC/OCCPoint.cpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCPoint.cpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -44,10 +44,26 @@
OCCPoint::OCCPoint( const CubitVector &location )
gp_Pnt pt = gp_Pnt( location.x(), location.y(), location.z());
- myPoint = BRepBuilderAPI_MakeVertex(pt);
+ TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(pt);
+ myTopoDSVertex = new TopoDS_Vertex(theVertex);
+// Purpose : The constructor with a gp_Pnt point
+// Special Notes :
+// Creator : Jane Hu
+// Creation Date : 10/19/07
+OCCPoint::OCCPoint( gp_Pnt& thePoint )
+ TopoDS_Vertex theVertex = BRepBuilderAPI_MakeVertex(thePoint);
// Purpose : The destructor.
// Special Notes :
@@ -133,16 +149,6 @@
{ return attribSet.restore_attributes(file_ptr, endian);
-TopoDS_Vertex OCCPoint::get_pnt()const
- return myPoint;
-void OCCPoint::set_pnt( TopoDS_Vertex &v_point)
- myPoint = v_point;
// Purpose : Returns the coordinates of this Point.
@@ -154,27 +160,29 @@
CubitVector OCCPoint::coordinates() const
- gp_Pnt pt = BRep_Tool::Pnt(myPoint);
+ gp_Pnt pt = BRep_Tool::Pnt(*myTopoDSVertex);
CubitVector p(pt.X(), pt.Y(), pt.Z());
return p;
-CubitBoolean OCCPoint::is_equal(const OCCPoint & other, double Tol)
+CubitBoolean OCCPoint::is_equal(OCCPoint & other, double Tol)
- return pt.IsEqual(BRep_Tool::Pnt(other.get_pnt()), Tol);
+ TopoDS_Vertex otherVertex = *(other.get_TopoDS_Vertex());
+ const gp_Pnt otherPnt = BRep_Tool::Pnt(otherVertex);
+ return pt.IsEqual(otherPnt, Tol);
-double OCCPoint::distance(const OCCPoint & other)
+double OCCPoint::distance(OCCPoint & other)
- return pt.Distance(BRep_Tool::Pnt(other.get_pnt()));
+ return pt.Distance(BRep_Tool::Pnt(*(other.get_TopoDS_Vertex())));
-double OCCPoint::SquareDistance (const OCCPoint & other)
+double OCCPoint::SquareDistance (OCCPoint & other)
- return pt.SquareDistance(BRep_Tool::Pnt(other.get_pnt()));
+ return pt.SquareDistance(BRep_Tool::Pnt(*(other.get_TopoDS_Vertex())));
// Purpose : Get geometry modeling engine: AcisGeometryEngine
Modified: cgm/trunk/geom/OCC/OCCPoint.hpp
--- cgm/trunk/geom/OCC/OCCPoint.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCPoint.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -35,7 +35,7 @@
private:
- TopoDS_Vertex myPoint;
+ TopoDS_Vertex *myTopoDSVertex;
OCCAttribSet attribSet;
@@ -47,13 +47,13 @@
//I- DLIList<Curve*> curves
//I- curves attaced to point
- OCCPoint(TopoDS_Vertex& thePoint ):myPoint(thePoint){};
+ OCCPoint(TopoDS_Vertex* thePoint ):myTopoDSVertex(thePoint){};
//I- gp_Pnt *thePoint
//I- pointer to the TopoDS_Vertex associated with OCCPoint
- OCCPoint(gp_Pnt& thePoint ):myPoint(BRepBuilderAPI_MakeVertex(thePoint)){};
+ OCCPoint(gp_Pnt& thePoint );
@@ -62,9 +62,7 @@
virtual ~OCCPoint();
//- The destructor
- TopoDS_Vertex get_pnt()const;
- void set_pnt( TopoDS_Vertex& gp_pnt);
- // - get/set the gp_Pnt associated with this object
+ TopoDS_Vertex *get_TopoDS_Vertex(){return myTopoDSVertex; }
#ifdef BOYD14
OCCPoint *copy();
@@ -116,10 +114,10 @@
//R- Contains the coordinate values {x y z} of this Point
//- Returns the spatial coordinates of this Point.
- CubitBoolean is_equal(const OCCPoint & other, double Tol);
+ CubitBoolean is_equal( OCCPoint & other, double Tol);
- double distance(const OCCPoint & other);
- double SquareDistance (const OCCPoint & other);
+ double distance( OCCPoint & other);
+ double SquareDistance ( OCCPoint & other);
virtual CubitBox bounding_box() const ;
// see comments in GeometryEntity.hpp
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -341,8 +341,9 @@
//currently, there's no effect on 'closest' argument or bounded.
- BRepExtrema_DistShapeShape distShapeShape(occ_curve1->get_TopoDS_Edge(),
- occ_curve2->get_TopoDS_Edge());
+ BRepExtrema_DistShapeShape distShapeShape(
+ *(occ_curve1->get_TopoDS_Edge()),
+ *(occ_curve2->get_TopoDS_Edge()));
distShapeShape.Perform();
if (!distShapeShape.IsDone())
@@ -351,7 +352,7 @@
return CUBIT_FAILURE;
- if (distShapeShape.Value() < 1e-6)
+ if (distShapeShape.Value() < get_sme_resabs_tolerance())
int numPnt = distShapeShape.NbSolution();
for (int i = 1; i <= numPnt; i++)
@@ -386,8 +387,8 @@
- BRepExtrema_DistShapeShape distShapeShape(occ_curve->get_TopoDS_Edge(),
- occ_surface->get_TopoDS_Face());
+ BRepExtrema_DistShapeShape distShapeShape(*(occ_curve->get_TopoDS_Edge()),
+ *(occ_surface->get_TopoDS_Face()));
@@ -396,7 +397,7 @@
@@ -430,19 +431,114 @@
// Description: Find distance between two entities and closest positions.
-// Author :
-// Date :
+// Author : Jane Hu
+// Date : 10/19/07
CubitStatus
-OCCQueryEngine::entity_entity_distance( GeometryEntity *,
- GeometryEntity *,
- CubitVector &, CubitVector &,
- double & )
+OCCQueryEngine::entity_entity_distance( GeometryEntity *entity1,
+ GeometryEntity *entity2,
+ CubitVector &pos1, CubitVector &pos2,
+ double &distance )
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ TopoDS_Shape * shape1;
+ TopoDS_Shape * shape2;
+ if ((shape1 = get_TopoDS_Shape_of_entity(entity1)) == NULL)
+ PRINT_ERROR( "problem occured getting OCC entity.\n"
+ " Aborting.\n" );
+ return CUBIT_FAILURE;
+ if( (shape2 = get_TopoDS_Shape_of_entity( entity2 )) == NULL )
+ " Aborting.\n");
+ BRepExtrema_DistShapeShape distShapeShape(*shape1, *shape2);
+ distShapeShape.Perform();
+ if (!distShapeShape.IsDone())
+ PRINT_ERROR( "problem occured getting distance between OCC entities.\n"
+ " Aborting.\n");
+ distance = distShapeShape.Value();
+ gp_Pnt pnt1 = distShapeShape.PointOnShape1(1);
+ gp_Pnt pnt2 = distShapeShape.PointOnShape2(2);
+ pos1 = CubitVector(pnt1.X(), pnt1.Y(), pnt1.Z());
+ pos2 = CubitVector(pnt2.X(), pnt2.Y(), pnt2.Z());
+ return CUBIT_SUCCESS;
+TopoDS_Shape* OCCQueryEngine::get_TopoDS_Shape_of_entity(TopologyBridge *entity_ptr)
+ if (OCCBody *body_ptr = CAST_TO( entity_ptr, OCCBody))
+ TopoDS_Shape* theShape = body_ptr->get_TopoDS_Shape();
+ if (!theShape)
+ PRINT_ERROR("OCCBody without TopoDS_Shape at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return theShape;
+ else if (OCCLump * lump_ptr = CAST_TO( entity_ptr,OCCLump))
+ TopoDS_Solid * theSolid = lump_ptr->get_TopoDS_Solid();
+ if(theSolid)
+ return (TopoDS_Shape*) theSolid;
+ else
+ PRINT_ERROR("OCCLump without TopoDS_Solid at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ else if( OCCSurface *surface_ptr = CAST_TO( entity_ptr, OCCSurface))
+ TopoDS_Face *theFace = surface_ptr->get_TopoDS_Face();
+ if(!theFace)
+ PRINT_ERROR("OCCSurface without TopoDS_Face at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) theFace;
+ else if( OCCCurve *curve_ptr = CAST_TO( entity_ptr, OCCCurve))
+ TopoDS_Edge *theEdge = curve_ptr->get_TopoDS_Edge();
+ if (!theEdge)
+ PRINT_ERROR("OCCCurve without TopoDS_Edge at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) theEdge;
+ else if( OCCPoint *point_ptr = CAST_TO( entity_ptr, OCCPoint))
+ TopoDS_Vertex *thePoint = point_ptr->get_TopoDS_Vertex();
+ if (!thePoint)
+ PRINT_ERROR("OCCPoint without TopoDS_Point at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) thePoint;
+ PRINT_ERROR("Non-OCC TopologyBridge at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
//Function Name: save_temp_geom_file
//Member Type: PUBLIC
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -108,6 +108,7 @@
const char* modeler_type()
{ return "OCC"; }
+ TopoDS_Shape *get_TopoDS_Shape_of_entity( TopologyBridge * entity);
int get_major_version();
int get_minor_version();
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp 2007-10-18 19:37:21 UTC (rev 1314)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp 2007-10-19 18:18:57 UTC (rev 1315)
@@ -340,7 +340,7 @@
//- Determines the u and v derivitives from the given parameter
//- values.
- TopoDS_Face get_TopoDS_Face(){return *myTopoDSFace;}
+ TopoDS_Face *get_TopoDS_Face(){return myTopoDSFace;}
virtual CubitBoolean is_parametric();
//R CubitBoolean
More information about the cgma-dev
