[cgma-dev] r1405 - in cgm/trunk: . test
janehu at mcs.anl.gov
Fri Nov 16 13:40:16 CST 2007
Author: janehu
Date: 2007-11-16 13:40:16 -0600 (Fri, 16 Nov 2007)
New Revision: 1405
Added:
cgm/trunk/test/
cgm/trunk/test/Makefile.am
cgm/trunk/test/huge.sat
cgm/trunk/test/makept.cpp
cgm/trunk/test/merge.sat
cgm/trunk/test/model1.sat
cgm/trunk/test/model2.sat
cgm/trunk/test/model3.sat
cgm/trunk/test/model4.sat
cgm/trunk/test/model5.sat
cgm/trunk/test/model6.sat
cgm/trunk/test/model7.sat
cgm/trunk/test/webcut.cpp
Modified:
cgm/trunk/configure.in
Log:
make new directory for tests, move webcut test there, and add new OCC test
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2007-11-16 18:29:53 UTC (rev 1404)
+++ cgm/trunk/configure.in 2007-11-16 19:40:16 UTC (rev 1405)
@@ -1,4 +1,4 @@
# Standard Stuff
AC_INIT(CGMA, 10.2.2)
@@ -249,7 +249,7 @@
# if user specified option (other than --without-occ)
if test "x$occ_DIR" != "xno"; then
- OCC_LIBS="-lPTKernel -lTKMath -lTKTopTest -lTKXSBase -lTKAdvTools -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKPShape -lTKShapeSchema -lTKTopAlgo -lBinLPlugin -lBinPlugin -lBinXCAFPlugin -lFWOSPlugin -lmscmd -lPTKernel -lStdLPlugin -lStdPlugin -ltcl -lTKAdvTools -lTKBinL -lTKBin -lTKBinXCAF -lTKCAF -lTKCDF -lTKCDLFront -lTKCPPClient -lTKCPPExt -lTKCPPIntExt -lTKCPPJini -lTKCSFDBSchema -lTKDCAF -lTKDraw -lTKHLR -lTKIDLFront -lTKIGES -lTKjcas -lTKLCAF -lTKMesh -lTKMeshVS -lTKOpenGl -lTKPCAF -lTKPLCAF -lTKPLCAF -lTKPrim -lTKPShape -lTKService -ltk -lTKStdLSchema -lTKStdSchema -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTCPPExt -lTKTopAlgo -lTKV2d -lTKV3d -lTKViewerTest -lTKVRML -lTKWOK -lTKWOKTcl -lTKXCAFSchema -lTKXCAF -lTKXDEDRAW -lTKXDEIGES -lTKXDESTEP -lTKXmlL -lTKXml -lTKXmlXCAF -lTKXSBase -lTKXSDRAW -lwokcmd -lwokdeliverysteps -lwokdfltsteps -lwokobjssteps -lwokorbixsteps -lwoksteps -lwoktoolscmd -lwokutilscmd -lXCAFPlugin -lXmlLPlugin -lXmlPlugin -lXmlXCAFPlugin"
+ OCC_LIBS="-lPTKernel -lTKMath -lTKTopTest -lTKXSBase -lTKAdvTools -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKPShape -lTKShapeSchema -lTKTopAlgo -lBinLPlugin -lBinPlugin -lBinXCAFPlugin -lFWOSPlugin -lmscmd -lPTKernel -lStdLPlugin -lStdPlugin -lTKAdvTools -lTKBinL -lTKBin -lTKBinXCAF -lTKCAF -lTKCDF -lTKCDLFront -lTKCPPClient -lTKCPPExt -lTKCPPIntExt -lTKCPPJini -lTKCSFDBSchema -lTKDCAF -lTKDraw -lTKHLR -lTKIDLFront -lTKIGES -lTKjcas -lTKLCAF -lTKMesh -lTKMeshVS -lTKOpenGl -lTKPCAF -lTKPLCAF -lTKPLCAF -lTKPrim -lTKPShape -lTKService -lTKStdLSchema -lTKStdSchema -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTCPPExt -lTKTopAlgo -lTKV2d -lTKV3d -lTKViewerTest -lTKVRML -lTKWOK -lTKWOKTcl -lTKXCAFSchema -lTKXCAF -lTKXDEDRAW -lTKXDEIGES -lTKXDESTEP -lTKXmlL -lTKXml -lTKXmlXCAF -lTKXSBase -lTKXSDRAW -lwokcmd -lwokdeliverysteps -lwokdfltsteps -lwokobjssteps -lwokorbixsteps -lwoksteps -lwoktoolscmd -lwokutilscmd -lXCAFPlugin -lXmlLPlugin -lXmlPlugin -lXmlXCAFPlugin"
# Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
if test "x$occ_DIR" = "x"; then
@@ -280,8 +280,10 @@
[AC_MSG_ERROR([OpenCascade config error:Standard_Version.hxx not found])] )
# Check if libTKernel.so contains function 'create_mailbox'
+ old_LIBS="$LIBS"
AC_CHECK_LIB( [TKernel], [create_mailbox],,
[AC_MSG_ERROR([OpenCascade config error: libTKernel not found ])])
+ LIBS="$old_LIBS"
# Restore original values of variables
CPPFLAGS="$old_CPPFLAGS"
@@ -321,6 +323,7 @@
itaps/iGeom-Defs.inc
itaps/SIDL/Makefile
itaps/SIDL/iGeom-SIDL-Defs.inc
+ test/Makefile
AC_OUTPUT
Added: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am (rev 0)
+++ cgm/trunk/test/Makefile.am 2007-11-16 19:40:16 UTC (rev 1405)
@@ -0,0 +1,39 @@
+# Override default defines with the ones we want from the configure script
+DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM)
+INCLUDES = -I$(top_srcdir)/geom \
+ -I$(top_srcdir)/util \
+ -I$(top_srcdir)/geom/ACIS \
+ -I$(top_srcdir)/geom/virtual \
+ -I$(top_srcdir)/geom/facet \
+ -I$(top_srcdir)/geom/Cholla \
+ -I$(top_srcdir)/geom/OCC \
+ -I$(srcdir)
+TESTS = makept
+if build_ACIS
+ TESTS += webcut
+endif
+check_PROGRAMS = $(TESTS)
+webcut_SOURCES = webcut.cpp
+makept_SOURCES = makept.cpp
+opt_libs=
+LDADD = ../geom/virtual/libcubit_virtual.la \
+ ../geom/facetbool/libcubit_facetbool.la \
+ $(opt_libs) \
+ ../geom/Cholla/libcholla.la \
+ ../geom/facet/libcubit_facet.la \
+ ../geom/libcubit_geom.la \
+ ../util/libcubit_util.la
+if build_ACIS
+ opt_libs += ../geom/ACIS/libcubit_ACIS.la
+endif
+if WITH_OCC
+ opt_libs += ../geom/OCC/libcubit_OCC.la $(OCC_LIB_FLAG) $(OCC_LIBS)
+endif
Copied: cgm/trunk/test/huge.sat (from rev 1399, cgm/trunk/cgm_apps/examples/driverc++/huge.sat)
--- cgm/trunk/test/huge.sat (rev 0)
+++ cgm/trunk/test/huge.sat 2007-11-16 19:40:16 UTC (rev 1405)
@@ -0,0 +1,25686 @@
+1600 0 3 0
+10 Cubit 10.2 17 ACIS 16.0.1 Linux 24 Thu Aug 16 12:19:02 2007
+1 9.9999999999999995e-07 1e-10
+body $-1 -1 -1 $-1 $3 $-1 $4 T -50 -50 -50 50 50 50 #
+edge $-1 -1 -1 $-1 $5 -34.168762264076797 $6 37.942263245203002 $-1 $7 forward @7 unknown F #
+edge $-1 -1 -1 $-1 $8 -0.88675049056307642 $9 71.22427501871671 $-1 $10 forward @7 unknown F #
+lump $-1 -1 -1 $-1 $-1 $11 $0 T -50 -50 -50 50 50 50 #
+transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear #
+vertex $-1 -1 -1 $-1 $1 $12 #
+vertex $-1 -1 -1 $-1 $1 $13 #
+straight-curve $-1 -1 -1 $-1 -50 31.046580867343511 21.569871301015024 0 -0.55470019622522593 -0.83205029433784594 I I #
+vertex $-1 -1 -1 $-1 $2 $14 #
+vertex $-1 -1 -1 $-1 $2 $15 #
+straight-curve $-1 -1 -1 $-1 -50 9.262178993322765 -10.491880671118157 0 -0.83205029433784394 -0.5547001962252287 I I #
+shell $-1 -1 -1 $-1 $-1 $-1 $16 $-1 $3 T -50 -50 -50 50 50 50 #
+point $-1 -1 -1 $-1 -50 50 50 #
+point $-1 -1 -1 $-1 -50 10 -10 #
+point $-1 -1 -1 $-1 -50 -50 -50 #
+face $-1 -1 -1 $-1 $17 $18 $11 $-1 $19 reversed single T 29.999999999999996 -35 20.000000000000004 37.500000000000007 -30 35 F #
+face $-1 -1 -1 $-1 $20 $21 $11 $-1 $19 reversed single T 29.999999999999996 -35 5.0000000000000018 37.500000000000007 -30 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $22 $16 T 29.999999999999996 -35 20.000000000000004 37.500000000000007 -30 35 unknown #
+cone-surface $-1 -1 -1 $-1 35 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+face $-1 -1 -1 $-1 $23 $24 $11 $-1 $19 reversed single T 29.999999999999996 -35 -9.9999999999999982 37.5 -30 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $25 $17 T 29.999999999999996 -35 5.0000000000000018 37.500000000000007 -30 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $26 $27 $28 $29 reversed $18 $-1 #
+face $-1 -1 -1 $-1 $30 $31 $11 $-1 $19 reversed single T 29.999999999999996 -35 -24.999999999999996 37.500000000000007 -30 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $32 $20 T 29.999999999999996 -35 -9.9999999999999982 37.5 -30 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $33 $34 $35 $36 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $37 $22 $38 $39 reversed $18 $-1 #
+coedge $-1 -1 -1 $-1 $22 $40 $41 $42 reversed $18 $-1 #
+coedge $-1 -1 -1 $-1 $43 $44 $22 $29 forward $45 $-1 #
+edge $-1 -1 -1 $-1 $46 -1.5707963267948966 $47 6.1232339957367623e-17 $28 $48 forward @7 unknown T 29.999999999999996 -35 20.000000000000004 35 -30 25.000000000000007 #
+face $-1 -1 -1 $-1 $49 $50 $11 $-1 $19 reversed single T 29.999999999999996 -40 -24.999999999999996 37.500000000000014 -35 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $51 $23 T 29.999999999999996 -35 -24.999999999999996 37.500000000000007 -30 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $52 $53 $54 $55 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $56 $25 $57 $58 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $25 $59 $60 $61 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $62 $63 $25 $36 forward $64 $-1 #
+edge $-1 -1 -1 $-1 $65 -1.5707963267948966 $66 6.1232339957367673e-17 $35 $67 forward @7 unknown T 29.999999999999996 -35 5.0000000000000018 35 -30 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $68 $26 $69 $70 reversed $18 $-1 #
+coedge $-1 -1 -1 $-1 $71 $72 $26 $39 forward $73 $-1 #
+edge $-1 -1 -1 $-1 $74 -2.0943951023931966 $46 -1.5707963267948966 $38 $75 forward @7 unknown T 35 -30.669872981077809 20.000000000000004 37.500000000000007 -30 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $27 $68 $76 $77 reversed $18 $-1 #
+coedge $-1 -1 -1 $-1 $78 $79 $80 $42 forward $81 $-1 #
+edge $-1 -1 -1 $-1 $47 25 $82 30 $41 $83 forward @7 unknown T 29.999999999999996 -35 25 30 -35 30 #
+coedge $-1 -1 -1 $-1 $84 $28 $79 $85 reversed $45 $-1 #
+coedge $-1 -1 -1 $-1 $28 $84 $59 $86 forward $45 $-1 #
+loop $-1 -1 -1 $-1 $-1 $28 $87 T 25 -35 15 35 -30 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $86 $88 #
+vertex $-1 -1 -1 $-1 $89 $90 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $91 $92 $11 $-1 $19 reversed single T 29.999999999999996 -40 -9.9999999999999982 37.500000000000007 -35 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $93 $30 T 29.999999999999996 -40 -24.999999999999996 37.500000000000014 -35 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $94 $95 $96 $97 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $98 $32 $99 $100 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $32 $101 $102 $103 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $104 $105 $32 $55 forward $106 $-1 #
+edge $-1 -1 -1 $-1 $107 -1.5707963267948966 $108 6.1232339957367648e-17 $54 $109 forward @7 unknown T 29.999999999999996 -35 -9.9999999999999982 35 -30 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $110 $33 $111 $112 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $113 $114 $33 $58 forward $115 $-1 #
+edge $-1 -1 -1 $-1 $116 -2.0943951023931966 $65 -1.5707963267948966 $57 $117 forward @7 unknown T 35 -30.669872981077809 5.0000000000000018 37.500000000000007 -30 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $34 $110 $44 $86 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $118 $119 $120 $61 forward $121 $-1 #
+edge $-1 -1 -1 $-1 $66 10.000000000000002 $122 15 $60 $123 forward @7 unknown T 29.999999999999996 -35 10.000000000000002 30 -35 15 #
+coedge $-1 -1 -1 $-1 $124 $35 $119 $125 reversed $64 $-1 #
+coedge $-1 -1 -1 $-1 $35 $124 $101 $126 forward $64 $-1 #
+loop $-1 -1 -1 $-1 $-1 $35 $127 T 25 -35 1.7763568394002505e-15 35 -30 10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $126 $128 #
+vertex $-1 -1 -1 $-1 $129 $130 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $40 $37 $131 $132 reversed $18 $-1 #
+coedge $-1 -1 -1 $-1 $133 $134 $37 $70 forward $135 $-1 #
+edge $-1 -1 -1 $-1 $136 -32.5 $74 -22.500000000000011 $69 $137 forward @7 unknown T 37.5 -30.669872981077809 22.500000000000011 37.500000000000007 -30.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $138 $38 $110 $139 forward $73 $-1 #
+coedge $-1 -1 -1 $-1 $38 $138 $133 $140 reversed $73 $-1 #
+loop $-1 -1 -1 $-1 $-1 $38 $141 T 35 -30.669872981077809 17.500000000000007 40.000000000000007 -30 22.500000000000011 unknown #
+vertex $-1 -1 -1 $-1 $140 $142 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $143 $144 $40 $77 forward $145 $-1 #
+edge $-1 -1 -1 $-1 $82 -6.1232339957367648e-17 $146 1.5707963267948966 $76 $147 forward @7 unknown T 30 -35 30 35 -30 35 #
+coedge $-1 -1 -1 $-1 $148 $41 $144 $149 forward $81 $-1 #
+coedge $-1 -1 -1 $-1 $41 $150 $43 $85 forward $81 $-1 #
+coedge $-1 -1 -1 $-1 $151 $152 $153 $42 reversed $154 $-1 #
+loop $-1 -1 -1 $-1 $-1 $41 $155 T 22.499999999999993 -35 20 30 -30 35 unknown #
+vertex $-1 -1 -1 $-1 $149 $156 #
+straight-curve $-1 -1 -1 $-1 30 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $44 $43 $118 $157 reversed $45 $-1 #
+edge $-1 -1 -1 $-1 $158 1.5707963267948966 $47 3.1415926535897931 $79 $159 forward @7 unknown T 25 -35 20 29.999999999999996 -30 25 #
+edge $-1 -1 -1 $-1 $122 -6.1232339957367648e-17 $46 1.5707963267948966 $44 $160 forward @7 unknown T 29.999999999999996 -35 15 35 -30 20.000000000000004 #
+face $-1 -1 -1 $-1 $161 $45 $11 $-1 $162 reversed single T 25 -35 15 35 -30 25.000000000000007 F #
+point $-1 -1 -1 $-1 35 -30 20.000000000000004 #
+edge $-1 -1 -1 $-1 $47 3.1415926535897931 $163 4.7123889803846897 $151 $159 forward @7 unknown T 25 -40 20 29.999999999999996 -35 25 #
+point $-1 -1 -1 $-1 29.999999999999996 -35 25 #
+face $-1 -1 -1 $-1 $164 $165 $11 $-1 $19 reversed single T 29.999999999999996 -40 5.0000000000000018 37.500000000000007 -35 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $166 $49 T 29.999999999999996 -40 -9.9999999999999982 37.500000000000007 -35 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $167 $168 $169 $170 reversed $50 $-1 #
+coedge $-1 -1 -1 $-1 $171 $51 $172 $173 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $51 $174 $175 $176 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $177 $178 $51 $97 forward $179 $-1 #
+edge $-1 -1 -1 $-1 $180 -1.5707963267948966 $181 6.1232339957367648e-17 $96 $182 forward @7 unknown T 29.999999999999996 -35 -24.999999999999996 35 -30 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $183 $52 $184 $185 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $186 $187 $52 $100 forward $188 $-1 #
+edge $-1 -1 -1 $-1 $189 -2.0943951023931957 $107 -1.5707963267948966 $99 $190 forward @7 unknown T 35 -30.669872981077809 -9.9999999999999982 37.5 -30 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $53 $183 $63 $126 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $191 $192 $193 $103 forward $194 $-1 #
+edge $-1 -1 -1 $-1 $108 -4.9999999999999982 $195 1.7763568394002505e-15 $102 $196 forward @7 unknown T 29.999999999999996 -35 -4.9999999999999982 30 -35 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $197 $54 $192 $198 reversed $106 $-1 #
+coedge $-1 -1 -1 $-1 $54 $197 $174 $199 forward $106 $-1 #
+loop $-1 -1 -1 $-1 $-1 $54 $200 T 25 -35 -15 35 -30 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $199 $201 #
+vertex $-1 -1 -1 $-1 $202 $203 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $59 $56 $71 $139 reversed $21 $-1 #
+coedge $-1 -1 -1 $-1 $204 $205 $56 $112 forward $206 $-1 #
+edge $-1 -1 -1 $-1 $207 -17.500000000000007 $116 -7.5000000000000098 $111 $208 forward @7 unknown T 37.5 -30.669872981077809 7.5000000000000098 37.500000000000007 -30.669872981077805 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $209 $57 $183 $210 forward $115 $-1 #
+coedge $-1 -1 -1 $-1 $57 $209 $204 $211 reversed $115 $-1 #
+loop $-1 -1 -1 $-1 $-1 $57 $212 T 35 -30.669872981077809 2.5000000000000049 40.000000000000007 -30 7.5000000000000098 unknown #
+vertex $-1 -1 -1 $-1 $211 $213 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $214 $60 $84 $157 forward $121 $-1 #
+coedge $-1 -1 -1 $-1 $60 $215 $62 $125 forward $121 $-1 #
+coedge $-1 -1 -1 $-1 $216 $217 $218 $61 reversed $219 $-1 #
+loop $-1 -1 -1 $-1 $-1 $60 $220 T 22.499999999999993 -35 5.0000000000000018 30 -30 20 unknown #
+vertex $-1 -1 -1 $-1 $157 $221 #
+coedge $-1 -1 -1 $-1 $63 $62 $191 $222 reversed $64 $-1 #
+edge $-1 -1 -1 $-1 $223 1.570796326794897 $66 3.1415926535897931 $119 $224 forward @7 unknown T 25 -35 5.0000000000000018 29.999999999999996 -30 10.000000000000002 #
+edge $-1 -1 -1 $-1 $195 -6.1232339957367648e-17 $65 1.5707963267948966 $63 $225 forward @7 unknown T 29.999999999999996 -35 1.7763568394002505e-15 35 -30 5.0000000000000018 #
+face $-1 -1 -1 $-1 $226 $64 $11 $-1 $227 reversed single T 25 -35 1.7763568394002505e-15 35 -30 10.000000000000002 F #
+point $-1 -1 -1 $-1 35 -30 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $66 3.1415926535897931 $228 4.7123889803846897 $216 $224 forward @7 unknown T 24.999999999999996 -40 5.0000000000000018 29.999999999999996 -35 10.000000000000002 #
+point $-1 -1 -1 $-1 29.999999999999996 -35 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $229 $230 $68 $132 forward $231 $-1 #
+edge $-1 -1 -1 $-1 $146 1.5707963267948966 $136 2.0943951023931957 $131 $232 forward @7 unknown T 35 -30.669872981077809 32.5 37.500000000000007 -30 35 #
+coedge $-1 -1 -1 $-1 $233 $69 $72 $140 forward $135 $-1 #
+coedge $-1 -1 -1 $-1 $69 $234 $229 $235 forward $135 $-1 #
+loop $-1 -1 -1 $-1 $-1 $69 $236 T 37.5 -40 20.000000000000004 45 -30 35 unknown #
+vertex $-1 -1 -1 $-1 $70 $237 #
+straight-curve $-1 -1 -1 $-1 37.5 -30.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $72 $71 $205 $238 reversed $73 $-1 #
+edge $-1 -1 -1 $-1 $46 1.5707963267948966 $207 2.0943951023931948 $71 $239 forward @7 unknown T 35 -30.669872981077805 17.500000000000007 37.5 -30 20.000000000000004 #
+edge $-1 -1 -1 $-1 $74 4.1887902047863905 $240 4.7123889803846897 $133 $241 forward @7 unknown T 37.500000000000007 -30.669872981077809 20.000000000000004 40.000000000000007 -30 22.500000000000011 #
+face $-1 -1 -1 $-1 $242 $73 $11 $-1 $162 reversed single T 35 -30.669872981077809 17.500000000000007 40.000000000000007 -30 22.500000000000011 F #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077809 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $243 $76 $244 $245 forward $145 $-1 #
+coedge $-1 -1 -1 $-1 $76 $243 $78 $149 reversed $145 $-1 #
+loop $-1 -1 -1 $-1 $-1 $143 $246 T 25 -35 30 35 -30 40 unknown #
+vertex $-1 -1 -1 $-1 $77 $247 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $248 $78 $249 $250 forward $81 $-1 #
+edge $-1 -1 -1 $-1 $82 0 $251 1.5707963267948966 $78 $252 forward @7 unknown T 25 -35 30 30 -30 35 #
+coedge $-1 -1 -1 $-1 $79 $248 $253 $254 forward $81 $-1 #
+coedge $-1 -1 -1 $-1 $255 $80 $256 $89 forward $154 $-1 #
+coedge $-1 -1 -1 $-1 $80 $257 $258 $259 forward $154 $-1 #
+coedge $-1 -1 -1 $-1 $260 $261 $27 $42 forward $262 $-1 #
+loop $-1 -1 -1 $-1 $-1 $80 $263 T 22.499999999999993 -40 19.999999999999996 30 -35 35 unknown #
+face $-1 -1 -1 $-1 $264 $81 $11 $-1 $265 reversed single T 22.499999999999993 -35 20 30 -30 35 F #
+point $-1 -1 -1 $-1 30 -35 30 #
+edge $-1 -1 -1 $-1 $122 0 $158 1.5707963267948961 $118 $266 forward @7 unknown T 25 -35 15 29.999999999999996 -30 20 #
+vertex $-1 -1 -1 $-1 $267 $268 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $269 $270 $11 $-1 $162 reversed single T 25 -40 15 35 -35 25.000000000000007 F #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 -35 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $271 $272 #
+face $-1 -1 -1 $-1 $273 $262 $11 $-1 $19 reversed single T 29.999999999999996 -40 20.000000000000004 37.500000000000014 -35 35 F #
+loop $-1 -1 -1 $-1 $-1 $274 $91 T 29.999999999999996 -40 5.0000000000000018 37.500000000000007 -35 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $275 $276 $277 $278 reversed $92 $-1 #
+coedge $-1 -1 -1 $-1 $279 $93 $280 $281 reversed $50 $-1 #
+coedge $-1 -1 -1 $-1 $93 $282 $283 $284 reversed $50 $-1 #
+coedge $-1 -1 -1 $-1 $285 $286 $93 $170 forward $287 $-1 #
+edge $-1 -1 -1 $-1 $288 1.5707963267948966 $289 2.0943951023931966 $169 $290 forward @7 unknown T 35 -40 -24.999999999999996 37.500000000000014 -39.330127018922191 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $291 $94 $292 $293 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $294 $295 $94 $173 forward $296 $-1 #
+edge $-1 -1 -1 $-1 $297 -2.0943951023931966 $180 -1.5707963267948966 $172 $298 forward @7 unknown T 35 -30.669872981077809 -24.999999999999996 37.500000000000007 -30 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $95 $291 $105 $199 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $299 $300 $301 $176 forward $302 $-1 #
+edge $-1 -1 -1 $-1 $181 -20 $303 -14.999999999999998 $175 $304 forward @7 unknown T 29.999999999999996 -35 -20 30 -35 -14.999999999999998 #
+coedge $-1 -1 -1 $-1 $305 $96 $300 $306 reversed $179 $-1 #
+coedge $-1 -1 -1 $-1 $96 $305 $307 $308 forward $179 $-1 #
+loop $-1 -1 -1 $-1 $-1 $178 $309 T 25 -35 -30 35 -30 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $308 $310 #
+vertex $-1 -1 -1 $-1 $311 $312 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $101 $98 $113 $210 reversed $24 $-1 #
+coedge $-1 -1 -1 $-1 $313 $314 $98 $185 forward $315 $-1 #
+edge $-1 -1 -1 $-1 $316 -2.5000000000000049 $189 7.4999999999999947 $184 $317 forward @7 unknown T 37.5 -30.669872981077805 -7.4999999999999947 37.5 -30.669872981077805 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $318 $99 $291 $319 forward $188 $-1 #
+coedge $-1 -1 -1 $-1 $99 $318 $313 $320 reversed $188 $-1 #
+loop $-1 -1 -1 $-1 $-1 $186 $321 T 35 -30.669872981077809 -12.500000000000004 40 -30 -7.4999999999999947 unknown #
+vertex $-1 -1 -1 $-1 $320 $322 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $323 $102 $124 $222 forward $194 $-1 #
+coedge $-1 -1 -1 $-1 $102 $324 $104 $198 forward $194 $-1 #
+coedge $-1 -1 -1 $-1 $325 $326 $327 $103 reversed $328 $-1 #
+loop $-1 -1 -1 $-1 $-1 $102 $329 T 22.499999999999996 -35 -9.9999999999999982 30 -30 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $222 $330 #
+coedge $-1 -1 -1 $-1 $105 $104 $299 $331 reversed $106 $-1 #
+edge $-1 -1 -1 $-1 $332 1.570796326794897 $108 3.1415926535897931 $192 $333 forward @7 unknown T 25 -35 -9.9999999999999982 29.999999999999996 -30 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $303 -6.1232339957367648e-17 $107 1.5707963267948966 $105 $334 forward @7 unknown T 30 -35 -15 35 -30 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $335 $106 $11 $-1 $336 reversed single T 25 -35 -15 35 -30 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 -30 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $108 3.1415926535897931 $337 4.7123889803846897 $325 $333 forward @7 unknown T 24.999999999999996 -40 -9.9999999999999982 29.999999999999996 -35 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 -35 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $338 $111 $114 $211 forward $206 $-1 #
+coedge $-1 -1 -1 $-1 $111 $339 $138 $238 forward $206 $-1 #
+loop $-1 -1 -1 $-1 $-1 $111 $340 T 37.5 -40 5.0000000000000027 45.000000000000007 -30 20.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $112 $341 #
+coedge $-1 -1 -1 $-1 $114 $113 $314 $342 reversed $115 $-1 #
+edge $-1 -1 -1 $-1 $65 1.5707963267948966 $316 2.0943951023931948 $113 $343 forward @7 unknown T 35 -30.669872981077805 2.5000000000000049 37.5 -30 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $116 4.1887902047863905 $344 4.7123889803846897 $204 $345 forward @7 unknown T 37.500000000000007 -30.669872981077809 5.0000000000000027 40.000000000000007 -30 7.5000000000000098 #
+face $-1 -1 -1 $-1 $309 $115 $11 $-1 $227 reversed single T 35 -30.669872981077809 2.5000000000000049 40.000000000000007 -30 7.5000000000000098 F #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077809 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $346 $118 $347 $267 forward $121 $-1 #
+coedge $-1 -1 -1 $-1 $119 $346 $348 $349 forward $121 $-1 #
+coedge $-1 -1 -1 $-1 $350 $120 $351 $129 forward $219 $-1 #
+coedge $-1 -1 -1 $-1 $120 $352 $353 $354 forward $219 $-1 #
+coedge $-1 -1 -1 $-1 $355 $356 $34 $61 forward $165 $-1 #
+loop $-1 -1 -1 $-1 $-1 $120 $242 T 22.499999999999996 -40 4.9999999999999991 30 -35 20 unknown #
+face $-1 -1 -1 $-1 $357 $121 $11 $-1 $265 reversed single T 22.499999999999993 -35 5.0000000000000018 30 -30 20 F #
+point $-1 -1 -1 $-1 29.999999999999996 -35 15 #
+edge $-1 -1 -1 $-1 $195 0 $223 1.5707963267948961 $191 $358 forward @7 unknown T 25 -35 1.7763568394002505e-15 29.999999999999996 -30 5.0000000000000018 #
+vertex $-1 -1 -1 $-1 $359 $360 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -35 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $361 $362 $11 $-1 $227 reversed single T 24.999999999999996 -40 1.7763568394002505e-15 35 -35 10.000000000000002 F #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 -35 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $363 $364 #
+coedge $-1 -1 -1 $-1 $365 $131 $134 $235 reversed $231 $-1 #
+coedge $-1 -1 -1 $-1 $131 $365 $366 $367 forward $231 $-1 #
+loop $-1 -1 -1 $-1 $-1 $230 $368 T 35 -30.669872981077809 32.5 40 -30 37.500000000000007 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -35 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $369 $133 $370 $371 forward $135 $-1 #
+coedge $-1 -1 -1 $-1 $134 $372 $373 $374 forward $135 $-1 #
+edge $-1 -1 -1 $-1 $375 -1.5707963267948966 $136 -1.0471975511965983 $134 $376 forward @7 unknown T 37.5 -30.669872981077805 32.5 40 -30 35 #
+face $-1 -1 -1 $-1 $246 $135 $11 $-1 $377 reversed single T 37.5 -40 20.000000000000004 45 -30 35 F #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077805 32.5 #
+edge $-1 -1 -1 $-1 $240 -1.570796326794897 $207 -1.0471975511965987 $205 $378 forward @7 unknown T 37.5 -30.669872981077805 17.500000000000007 40 -30 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $238 $379 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $380 $219 $11 $-1 $265 reversed single T 22.499999999999996 -40 4.9999999999999991 30 -35 20 F #
+coedge $-1 -1 -1 $-1 $144 $143 $381 $382 reversed $145 $-1 #
+coedge $-1 -1 -1 $-1 $366 $383 $143 $245 reversed $384 $-1 #
+edge $-1 -1 -1 $-1 $146 -1.5707963267948966 $385 6.1232339957367648e-17 $143 $386 forward @7 unknown T 30 -35 35 35 -30 40 #
+face $-1 -1 -1 $-1 $387 $145 $11 $-1 $388 reversed single T 25 -35 30 35 -30 40 F #
+point $-1 -1 -1 $-1 35 -30 35 #
+coedge $-1 -1 -1 $-1 $150 $148 $389 $390 forward $81 $-1 #
+coedge $-1 -1 -1 $-1 $391 $392 $148 $250 reversed $393 $-1 #
+edge $-1 -1 -1 $-1 $251 -1.5707963267948966 $394 -1.0471975511965965 $148 $395 forward @7 unknown T 22.499999999999993 -30.669872981077809 32.499999999999993 25 -30 35 #
+vertex $-1 -1 -1 $-1 $250 $396 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $397 $347 $150 $254 reversed $398 $-1 #
+edge $-1 -1 -1 $-1 $399 4.1887902047863905 $158 4.7123889803846897 $150 $400 forward @7 unknown T 22.499999999999993 -30.669872981077809 20 25 -30 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $401 $151 $402 $403 forward $154 $-1 #
+coedge $-1 -1 -1 $-1 $404 $353 $151 $89 reversed $270 $-1 #
+coedge $-1 -1 -1 $-1 $152 $401 $405 $406 forward $154 $-1 #
+coedge $-1 -1 -1 $-1 $407 $408 $152 $259 reversed $409 $-1 #
+edge $-1 -1 -1 $-1 $410 -1.5707963267948966 $82 0 $152 $252 forward @7 unknown T 25 -40 30 30 -35 35 #
+coedge $-1 -1 -1 $-1 $411 $153 $408 $412 reversed $262 $-1 #
+coedge $-1 -1 -1 $-1 $153 $413 $404 $414 reversed $262 $-1 #
+loop $-1 -1 -1 $-1 $-1 $413 $164 T 29.999999999999996 -40 20.000000000000004 37.500000000000014 -35 35 unknown #
+face $-1 -1 -1 $-1 $415 $154 $11 $-1 $265 reversed single T 22.499999999999993 -40 19.999999999999996 30 -35 35 F #
+face $-1 -1 -1 $-1 $416 $417 $11 $-1 $388 reversed single T 10 -35 30 19.999999999999996 -30 40 F #
+cone-surface $-1 -1 -1 $-1 25 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $158 -1.5707963267948966 $418 -1.0471975511965974 $214 $419 forward @7 unknown T 22.5 -30.669872981077809 17.5 25 -30 20 #
+point $-1 -1 -1 $-1 25 -30 20 #
+face $-1 -1 -1 $-1 $141 $420 $11 $-1 $162 reversed single T 35 -40 17.500000000000004 40.000000000000007 -39.330127018922191 22.500000000000014 F #
+loop $-1 -1 -1 $-1 $-1 $404 $161 T 25 -40 15 35 -35 25.000000000000007 unknown #
+edge $-1 -1 -1 $-1 $421 1.047197551196597 $163 1.5707963267948966 $352 $419 forward @7 unknown T 22.5 -40 17.499999999999996 25 -39.330127018922184 20 #
+point $-1 -1 -1 $-1 25 -40 20 #
+face $-1 -1 -1 $-1 $422 $423 $11 $-1 $19 reversed single T 30 -40 35 37.500000000000007 -35 50 F #
+coedge $-1 -1 -1 $-1 $356 $424 $425 $426 reversed $165 $-1 #
+coedge $-1 -1 -1 $-1 $327 $166 $427 $428 reversed $92 $-1 #
+coedge $-1 -1 -1 $-1 $166 $429 $430 $431 reversed $92 $-1 #
+coedge $-1 -1 -1 $-1 $432 $433 $166 $278 forward $434 $-1 #
+edge $-1 -1 -1 $-1 $435 1.5707963267948966 $436 2.0943951023931957 $277 $437 forward @7 unknown T 35 -40 -9.9999999999999982 37.5 -39.330127018922191 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $438 $167 $95 $176 forward $50 $-1 #
+coedge $-1 -1 -1 $-1 $439 $440 $167 $281 forward $441 $-1 #
+edge $-1 -1 -1 $-1 $181 6.1232339957367648e-17 $288 1.5707963267948966 $280 $442 forward @7 unknown T 29.999999999999996 -40 -24.999999999999996 35 -35 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $168 $438 $433 $443 reversed $50 $-1 #
+coedge $-1 -1 -1 $-1 $444 $445 $168 $284 forward $446 $-1 #
+edge $-1 -1 -1 $-1 $289 -22.499999999999989 $447 -12.500000000000002 $283 $448 forward @7 unknown T 37.5 -39.330127018922198 -22.499999999999989 37.500000000000014 -39.330127018922191 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $449 $169 $445 $450 reversed $287 $-1 #
+coedge $-1 -1 -1 $-1 $169 $449 $451 $452 forward $287 $-1 #
+loop $-1 -1 -1 $-1 $-1 $286 $453 T 35 -40 -27.499999999999993 40.000000000000007 -39.330127018922191 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $454 $455 #
+vertex $-1 -1 -1 $-1 $284 $456 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $174 $171 $186 $319 reversed $31 $-1 #
+coedge $-1 -1 -1 $-1 $457 $458 $171 $293 forward $446 $-1 #
+edge $-1 -1 -1 $-1 $459 12.5 $297 22.499999999999989 $292 $460 forward @7 unknown T 37.5 -30.669872981077809 -22.499999999999989 37.500000000000007 -30.669872981077805 -12.5 #
+coedge $-1 -1 -1 $-1 $461 $172 $462 $463 forward $296 $-1 #
+coedge $-1 -1 -1 $-1 $172 $461 $457 $464 reversed $296 $-1 #
+loop $-1 -1 -1 $-1 $-1 $172 $465 T 35 -30.669872981077809 -27.499999999999993 40.000000000000007 -30 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $464 $466 #
+coedge $-1 -1 -1 $-1 $467 $175 $197 $331 forward $302 $-1 #
+coedge $-1 -1 -1 $-1 $175 $468 $177 $306 forward $302 $-1 #
+coedge $-1 -1 -1 $-1 $469 $470 $279 $176 reversed $471 $-1 #
+loop $-1 -1 -1 $-1 $-1 $175 $335 T 22.499999999999996 -35 -25 30 -30 -9.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $331 $472 #
+coedge $-1 -1 -1 $-1 $178 $177 $473 $474 reversed $179 $-1 #
+edge $-1 -1 -1 $-1 $475 1.5707963267948966 $181 3.1415926535897931 $300 $476 forward @7 unknown T 25 -35 -25 29.999999999999996 -30 -20 #
+coedge $-1 -1 -1 $-1 $477 $462 $178 $308 reversed $478 $-1 #
+edge $-1 -1 -1 $-1 $479 -6.1232339957367648e-17 $180 1.5707963267948966 $178 $480 forward @7 unknown T 29.999999999999996 -35 -30 35 -30 -24.999999999999996 #
+face $-1 -1 -1 $-1 $481 $179 $11 $-1 $482 reversed single T 25 -35 -30 35 -30 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 -30 -24.999999999999996 #
+edge $-1 -1 -1 $-1 $181 3.1415926535897931 $483 4.7123889803846897 $469 $476 forward @7 unknown T 25 -40 -25 29.999999999999996 -35 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 -35 -20 #
+coedge $-1 -1 -1 $-1 $484 $184 $187 $320 forward $315 $-1 #
+coedge $-1 -1 -1 $-1 $184 $485 $209 $342 forward $315 $-1 #
+loop $-1 -1 -1 $-1 $-1 $184 $486 T 37.5 -40 -9.9999999999999982 45.000000000000007 -30 5.0000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $185 $487 #
+coedge $-1 -1 -1 $-1 $187 $186 $458 $488 reversed $188 $-1 #
+edge $-1 -1 -1 $-1 $107 1.5707963267948966 $459 2.0943951023931966 $186 $489 forward @7 unknown T 35 -30.669872981077809 -12.500000000000004 37.500000000000007 -30 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $189 4.1887902047863905 $490 4.7123889803846897 $313 $491 forward @7 unknown T 37.5 -30.669872981077809 -9.9999999999999982 40 -30 -7.4999999999999947 #
+face $-1 -1 -1 $-1 $492 $188 $11 $-1 $336 reversed single T 35 -30.669872981077809 -12.500000000000004 40 -30 -7.4999999999999947 F #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $493 $191 $494 $359 forward $194 $-1 #
+coedge $-1 -1 -1 $-1 $192 $493 $495 $496 forward $194 $-1 #
+coedge $-1 -1 -1 $-1 $497 $193 $498 $202 forward $328 $-1 #
+coedge $-1 -1 -1 $-1 $193 $499 $500 $501 forward $328 $-1 #
+coedge $-1 -1 -1 $-1 $502 $275 $53 $103 forward $92 $-1 #
+loop $-1 -1 -1 $-1 $-1 $193 $503 T 22.499999999999996 -40 -9.9999999999999982 30 -35 5.0000000000000036 unknown #
+face $-1 -1 -1 $-1 $504 $194 $11 $-1 $265 reversed single T 22.499999999999996 -35 -9.9999999999999982 30 -30 5.0000000000000036 F #
+point $-1 -1 -1 $-1 29.999999999999996 -35 1.7763568394002505e-15 #
+edge $-1 -1 -1 $-1 $303 0 $332 1.5707963267948966 $299 $505 forward @7 unknown T 25 -35 -14.999999999999998 30 -30 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $506 $507 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 -9.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $508 $302 $11 $-1 $265 reversed single T 22.499999999999996 -35 -25 30 -30 -9.9999999999999964 F #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 -35 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $509 $510 #
+coedge $-1 -1 -1 $-1 $511 $204 $512 $513 forward $206 $-1 #
+coedge $-1 -1 -1 $-1 $205 $514 $515 $516 forward $206 $-1 #
+face $-1 -1 -1 $-1 $87 $206 $11 $-1 $377 reversed single T 37.5 -40 5.0000000000000027 45.000000000000007 -30 20.000000000000007 F #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 17.500000000000007 #
+edge $-1 -1 -1 $-1 $344 -1.570796326794897 $316 -1.0471975511965987 $314 $517 forward @7 unknown T 37.5 -30.669872981077805 2.5000000000000049 40 -30 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $342 $518 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $215 $214 $519 $520 forward $121 $-1 #
+coedge $-1 -1 -1 $-1 $253 $521 $214 $267 reversed $398 $-1 #
+coedge $-1 -1 -1 $-1 $522 $494 $215 $349 reversed $523 $-1 #
+edge $-1 -1 -1 $-1 $524 4.1887902047863896 $223 4.7123889803846897 $215 $525 forward @7 unknown T 22.499999999999993 -30.669872981077813 5.0000000000000018 25 -30 7.5000000000000071 #
+coedge $-1 -1 -1 $-1 $526 $216 $527 $528 forward $219 $-1 #
+coedge $-1 -1 -1 $-1 $529 $500 $216 $129 reversed $362 $-1 #
+coedge $-1 -1 -1 $-1 $217 $526 $530 $271 forward $219 $-1 #
+coedge $-1 -1 -1 $-1 $256 $531 $217 $354 reversed $270 $-1 #
+edge $-1 -1 -1 $-1 $163 -1.5707963267948961 $122 0 $217 $266 forward @7 unknown T 25 -40 15 29.999999999999996 -35 20 #
+coedge $-1 -1 -1 $-1 $532 $218 $531 $533 reversed $165 $-1 #
+coedge $-1 -1 -1 $-1 $218 $274 $529 $534 reversed $165 $-1 #
+face $-1 -1 -1 $-1 $535 $536 $11 $-1 $162 reversed single T 10 -35 15 19.999999999999996 -30 25 F #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $223 -1.570796326794897 $537 -1.0471975511965983 $323 $538 forward @7 unknown T 22.5 -30.669872981077805 2.5000000000000022 25 -30 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 -30 5.0000000000000018 #
+face $-1 -1 -1 $-1 $212 $539 $11 $-1 $227 reversed single T 35 -40 2.5000000000000053 40.000000000000007 -39.330127018922191 7.5000000000000044 F #
+loop $-1 -1 -1 $-1 $-1 $529 $226 T 24.999999999999996 -40 1.7763568394002505e-15 35 -35 10.000000000000002 unknown #
+edge $-1 -1 -1 $-1 $540 1.0471975511965979 $228 1.570796326794897 $499 $538 forward @7 unknown T 22.499999999999996 -40 2.5000000000000022 25 -39.330127018922191 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 -40 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $230 $229 $541 $542 reversed $231 $-1 #
+coedge $-1 -1 -1 $-1 $543 $244 $230 $367 reversed $384 $-1 #
+edge $-1 -1 -1 $-1 $544 -2.0943951023931957 $146 -1.5707963267948966 $230 $545 forward @7 unknown T 35 -30.669872981077809 35 37.5 -30 37.500000000000007 #
+face $-1 -1 -1 $-1 $263 $231 $11 $-1 $388 reversed single T 35 -30.669872981077809 32.5 40 -30 37.500000000000007 F #
+coedge $-1 -1 -1 $-1 $546 $233 $547 $548 forward $135 $-1 #
+coedge $-1 -1 -1 $-1 $515 $515 $233 $371 reversed $549 $-1 #
+edge $-1 -1 -1 $-1 $240 1.570796326794897 $550 4.7123889803846897 $233 $551 forward @7 unknown T 39.999999999999993 -40 20.000000000000004 44.999999999999993 -30 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $234 $546 $552 $553 forward $135 $-1 #
+coedge $-1 -1 -1 $-1 $554 $554 $234 $374 reversed $555 $-1 #
+edge $-1 -1 -1 $-1 $556 -1.5707963267948966 $375 1.5707963267948966 $234 $557 forward @7 unknown T 40 -40 30 45 -30 35 #
+vertex $-1 -1 -1 $-1 $235 $558 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+cone-surface $-1 -1 -1 $-1 40 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -30 20.000000000000004 #
+face $-1 -1 -1 $-1 $559 $560 $11 $-1 $377 reversed single T 37.5 -40 -40 45.000000000000007 -30 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $561 $562 $243 $382 forward $563 $-1 #
+edge $-1 -1 -1 $-1 $251 1.5707963267948966 $385 3.1415926535897931 $381 $564 forward @7 unknown T 25 -35 35 30 -30 40 #
+coedge $-1 -1 -1 $-1 $244 $565 $561 $566 reversed $384 $-1 #
+loop $-1 -1 -1 $-1 $-1 $543 $422 T 30 -35 35 37.5 -30 50 unknown #
+vertex $-1 -1 -1 $-1 $567 $568 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $569 $409 $11 $-1 $388 reversed single T 25 -40 30 35 -35 40 F #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 -35 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $570 $571 $248 $390 reversed $572 $-1 #
+edge $-1 -1 -1 $-1 $394 -32.499999999999993 $399 -22.500000000000004 $248 $573 forward @7 unknown T 22.499999999999993 -30.669872981077809 22.500000000000004 22.5 -30.669872981077805 32.499999999999993 #
+coedge $-1 -1 -1 $-1 $574 $249 $562 $575 reversed $393 $-1 #
+coedge $-1 -1 -1 $-1 $249 $574 $570 $576 forward $393 $-1 #
+loop $-1 -1 -1 $-1 $-1 $574 $577 T 19.999999999999996 -30.669872981077809 32.499999999999993 25 -30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $390 $578 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 25 -30 35 #
+coedge $-1 -1 -1 $-1 $521 $253 $571 $579 forward $398 $-1 #
+loop $-1 -1 -1 $-1 $-1 $397 $580 T 19.999999999999996 -30.669872981077809 17.5 25 -30 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $254 $581 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $257 $255 $582 $583 forward $154 $-1 #
+coedge $-1 -1 -1 $-1 $530 $584 $255 $403 reversed $585 $-1 #
+edge $-1 -1 -1 $-1 $163 1.5707963267948961 $586 2.0943951023931957 $255 $400 forward @7 unknown T 22.499999999999993 -40 19.999999999999996 25 -39.330127018922191 22.5 #
+coedge $-1 -1 -1 $-1 $531 $256 $261 $414 forward $270 $-1 #
+coedge $-1 -1 -1 $-1 $587 $588 $257 $406 reversed $589 $-1 #
+edge $-1 -1 -1 $-1 $590 1.0471975511965983 $410 1.5707963267948966 $257 $395 forward @7 unknown T 22.500000000000004 -40 32.5 25 -39.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $591 $258 $592 $567 reversed $409 $-1 #
+coedge $-1 -1 -1 $-1 $258 $591 $260 $412 forward $409 $-1 #
+loop $-1 -1 -1 $-1 $-1 $591 $387 T 25 -40 30 35 -35 40 unknown #
+vertex $-1 -1 -1 $-1 $406 $593 #
+coedge $-1 -1 -1 $-1 $594 $260 $595 $596 reversed $262 $-1 #
+edge $-1 -1 -1 $-1 $597 -1.5707963267948966 $82 -6.1232339957367648e-17 $408 $598 forward @7 unknown T 30 -40 30 35 -35 35 #
+coedge $-1 -1 -1 $-1 $261 $594 $599 $600 reversed $262 $-1 #
+edge $-1 -1 -1 $-1 $47 6.1232339957367623e-17 $601 1.5707963267948966 $404 $602 forward @7 unknown T 29.999999999999996 -40 20.000000000000004 35 -35 25.000000000000007 #
+face $-1 -1 -1 $-1 $603 $604 $11 $-1 $377 reversed single T 37.5 -40 -50 45 -30 -40 F #
+face $-1 -1 -1 $-1 $605 $606 $11 $-1 $388 reversed single T 10 -40 30 19.999999999999996 -35 40 F #
+loop $-1 -1 -1 $-1 $-1 $607 $264 T 10 -35 30 19.999999999999996 -30 40 unknown #
+vertex $-1 -1 -1 $-1 $520 $608 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+loop $-1 -1 -1 $-1 $-1 $599 $269 T 35 -40 17.500000000000004 40.000000000000007 -39.330127018922191 22.500000000000014 unknown #
+vertex $-1 -1 -1 $-1 $271 $609 #
+face $-1 -1 -1 $-1 $610 $384 $11 $-1 $19 reversed single T 30 -35 35 37.5 -30 50 F #
+loop $-1 -1 -1 $-1 $-1 $611 $273 T 30 -40 35 37.500000000000007 -35 50 unknown #
+coedge $-1 -1 -1 $-1 $274 $532 $612 $613 reversed $165 $-1 #
+coedge $-1 -1 -1 $-1 $614 $615 $274 $426 forward $539 $-1 #
+edge $-1 -1 -1 $-1 $616 1.5707963267948966 $617 2.0943951023931957 $425 $618 forward @7 unknown T 35 -40 5.0000000000000018 37.500000000000007 -39.330127018922191 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $619 $498 $275 $428 forward $620 $-1 #
+edge $-1 -1 -1 $-1 $108 6.1232339957367648e-17 $435 1.5707963267948966 $427 $621 forward @7 unknown T 29.999999999999996 -40 -9.9999999999999982 35 -35 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $276 $502 $615 $622 reversed $92 $-1 #
+coedge $-1 -1 -1 $-1 $623 $624 $276 $431 forward $315 $-1 #
+edge $-1 -1 -1 $-1 $436 -7.4999999999999964 $625 2.500000000000008 $430 $626 forward @7 unknown T 37.5 -39.330127018922198 -7.4999999999999964 37.500000000000007 -39.330127018922191 2.500000000000008 #
+coedge $-1 -1 -1 $-1 $627 $277 $624 $628 reversed $434 $-1 #
+coedge $-1 -1 -1 $-1 $277 $627 $282 $443 forward $434 $-1 #
+loop $-1 -1 -1 $-1 $-1 $433 $629 T 35 -40 -12.500000000000002 40 -39.330127018922191 -7.4999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $630 $631 #
+vertex $-1 -1 -1 $-1 $278 $632 #
+coedge $-1 -1 -1 $-1 $282 $279 $619 $630 reversed $50 $-1 #
+coedge $-1 -1 -1 $-1 $633 $280 $634 $454 forward $441 $-1 #
+coedge $-1 -1 -1 $-1 $280 $633 $469 $311 reversed $441 $-1 #
+loop $-1 -1 -1 $-1 $-1 $439 $481 T 25 -40 -30 35 -35 -19.999999999999996 unknown #
+edge $-1 -1 -1 $-1 $447 -2.0943951023931957 $435 -1.5707963267948966 $433 $635 forward @7 unknown T 35 -40 -12.500000000000002 37.500000000000007 -39.330127018922191 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $636 $283 $627 $637 forward $446 $-1 #
+coedge $-1 -1 -1 $-1 $283 $638 $285 $450 forward $446 $-1 #
+loop $-1 -1 -1 $-1 $-1 $292 $639 T 37.5 -40 -24.999999999999996 45 -30 -9.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $637 $640 #
+straight-curve $-1 -1 -1 $-1 37.5 -39.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $286 $285 $641 $642 reversed $287 $-1 #
+edge $-1 -1 -1 $-1 $643 1.570796326794897 $289 2.0943951023931948 $445 $644 forward @7 unknown T 37.500000000000014 -40 -24.999999999999996 40.000000000000007 -39.330127018922191 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $645 $634 $286 $452 reversed $646 $-1 #
+edge $-1 -1 -1 $-1 $647 -2.0943951023931948 $288 -1.5707963267948966 $286 $648 forward @7 unknown T 35 -40 -27.499999999999993 37.5 -39.330127018922191 -24.999999999999996 #
+face $-1 -1 -1 $-1 $465 $287 $11 $-1 $482 reversed single T 35 -40 -27.499999999999993 40.000000000000007 -39.330127018922191 -22.499999999999989 F #
+edge $-1 -1 -1 $-1 $288 -1.5707963267948966 $479 -6.1232339957367648e-17 $439 $649 forward @7 unknown T 29.999999999999996 -40 -30 35 -35 -24.999999999999996 #
+point $-1 -1 -1 $-1 35 -40 -24.999999999999996 #
+point $-1 -1 -1 $-1 37.500000000000014 -39.330127018922198 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $638 $292 $295 $464 forward $446 $-1 #
+coedge $-1 -1 -1 $-1 $292 $636 $318 $488 forward $446 $-1 #
+vertex $-1 -1 -1 $-1 $319 $650 #
+coedge $-1 -1 -1 $-1 $295 $294 $651 $652 reversed $296 $-1 #
+coedge $-1 -1 -1 $-1 $307 $653 $294 $463 reversed $478 $-1 #
+edge $-1 -1 -1 $-1 $180 1.5707963267948966 $654 2.0943951023931948 $294 $655 forward @7 unknown T 35 -30.669872981077805 -27.499999999999993 37.5 -30 -24.999999999999996 #
+edge $-1 -1 -1 $-1 $297 4.1887902047863905 $656 4.7123889803846897 $457 $644 forward @7 unknown T 37.500000000000007 -30.669872981077809 -24.999999999999996 40.000000000000007 -30 -22.499999999999989 #
+face $-1 -1 -1 $-1 $503 $296 $11 $-1 $482 reversed single T 35 -30.669872981077809 -27.499999999999993 40.000000000000007 -30 -22.499999999999989 F #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077809 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $657 $299 $658 $506 forward $302 $-1 #
+coedge $-1 -1 -1 $-1 $300 $657 $659 $660 forward $302 $-1 #
+coedge $-1 -1 -1 $-1 $661 $301 $440 $311 forward $471 $-1 #
+coedge $-1 -1 -1 $-1 $301 $662 $663 $664 forward $471 $-1 #
+loop $-1 -1 -1 $-1 $-1 $301 $665 T 22.499999999999993 -40 -25.000000000000004 30 -35 -9.9999999999999964 unknown #
+point $-1 -1 -1 $-1 30 -35 -14.999999999999998 #
+coedge $-1 -1 -1 $-1 $666 $667 $305 $474 forward $668 $-1 #
+edge $-1 -1 -1 $-1 $479 0 $475 1.5707963267948961 $473 $669 forward @7 unknown T 25 -35 -30 29.999999999999996 -30 -25 #
+vertex $-1 -1 -1 $-1 $670 $671 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $672 $307 $667 $673 reversed $478 $-1 #
+loop $-1 -1 -1 $-1 $-1 $477 $674 T 29.999999999999996 -35 -40 37.5 -30 -24.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $474 $675 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $453 $441 $11 $-1 $482 reversed single T 25 -40 -30 35 -35 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 -35 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $676 $677 #
+coedge $-1 -1 -1 $-1 $624 $313 $678 $679 forward $315 $-1 #
+coedge $-1 -1 -1 $-1 $314 $623 $680 $681 forward $315 $-1 #
+face $-1 -1 -1 $-1 $629 $315 $11 $-1 $377 reversed single T 37.5 -40 -9.9999999999999982 45.000000000000007 -30 5.0000000000000044 F #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 2.5000000000000049 #
+edge $-1 -1 -1 $-1 $490 -1.5707963267948966 $459 -1.0471975511965979 $458 $682 forward @7 unknown T 37.5 -30.669872981077809 -12.5 40 -30 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $488 $683 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -9.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $684 $685 $11 $-1 $336 reversed single T 19.999999999999996 -30.669872981077809 -12.5 25 -30 -7.4999999999999947 F #
+coedge $-1 -1 -1 $-1 $324 $323 $686 $687 forward $194 $-1 #
+coedge $-1 -1 -1 $-1 $348 $688 $323 $359 reversed $523 $-1 #
+coedge $-1 -1 -1 $-1 $689 $658 $324 $496 reversed $685 $-1 #
+edge $-1 -1 -1 $-1 $690 4.1887902047863905 $332 4.7123889803846897 $324 $691 forward @7 unknown T 22.499999999999996 -30.669872981077809 -9.9999999999999982 25 -30 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $692 $325 $693 $694 forward $328 $-1 #
+coedge $-1 -1 -1 $-1 $427 $663 $325 $202 reversed $620 $-1 #
+coedge $-1 -1 -1 $-1 $326 $692 $695 $363 forward $328 $-1 #
+coedge $-1 -1 -1 $-1 $351 $696 $326 $501 reversed $362 $-1 #
+edge $-1 -1 -1 $-1 $228 -1.5707963267948961 $195 0 $326 $358 forward @7 unknown T 25 -40 1.7763568394002505e-15 29.999999999999996 -35 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $429 $327 $696 $697 reversed $92 $-1 #
+face $-1 -1 -1 $-1 $486 $328 $11 $-1 $265 reversed single T 22.499999999999996 -40 -9.9999999999999982 30 -35 5.0000000000000036 F #
+face $-1 -1 -1 $-1 $698 $699 $11 $-1 $336 reversed single T 19.999999999999996 -40 -12.5 25 -39.330127018922184 -7.4999999999999938 F #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -9.9999999999999982 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $332 -1.570796326794897 $700 -1.0471975511965983 $467 $701 forward @7 unknown T 22.5 -30.669872981077805 -12.499999999999996 25 -30 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 -30 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $702 $703 $11 $-1 $704 reversed single T 29.999999999999996 -20 20.000000000000004 37.500000000000007 -15.000000000000004 35 F #
+edge $-1 -1 -1 $-1 $705 1.0471975511965979 $337 1.570796326794897 $662 $701 forward @7 unknown T 22.499999999999996 -40 -12.499999999999998 25 -39.330127018922191 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 -40 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $612 $338 $614 $706 forward $206 $-1 #
+coedge $-1 -1 -1 $-1 $680 $680 $338 $513 reversed $707 $-1 #
+edge $-1 -1 -1 $-1 $344 1.570796326794897 $708 4.7123889803846897 $338 $709 forward @7 unknown T 39.999999999999993 -40 5.0000000000000027 44.999999999999993 -30 10.000000000000004 #
+coedge $-1 -1 -1 $-1 $339 $612 $710 $711 forward $206 $-1 #
+coedge $-1 -1 -1 $-1 $370 $370 $339 $516 reversed $549 $-1 #
+edge $-1 -1 -1 $-1 $550 -1.570796326794897 $240 1.570796326794897 $339 $712 forward @7 unknown T 40 -40 15.000000000000004 45.000000000000007 -30 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 -30 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $713 $714 $346 $520 reversed $715 $-1 #
+edge $-1 -1 -1 $-1 $418 -17.5 $524 -7.5000000000000062 $346 $716 forward @7 unknown T 22.499999999999996 -30.669872981077813 7.5000000000000062 22.500000000000004 -30.669872981077809 17.5 #
+coedge $-1 -1 -1 $-1 $347 $397 $713 $717 forward $398 $-1 #
+coedge $-1 -1 -1 $-1 $688 $348 $714 $718 forward $523 $-1 #
+loop $-1 -1 -1 $-1 $-1 $522 $719 T 19.999999999999996 -30.669872981077813 2.5000000000000004 25 -30 7.5000000000000071 unknown #
+vertex $-1 -1 -1 $-1 $349 $720 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $352 $350 $721 $722 forward $219 $-1 #
+coedge $-1 -1 -1 $-1 $695 $723 $350 $528 reversed $724 $-1 #
+edge $-1 -1 -1 $-1 $228 1.5707963267948961 $725 2.0943951023931957 $350 $525 forward @7 unknown T 22.499999999999996 -40 4.9999999999999991 25 -39.330127018922191 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $696 $351 $356 $534 forward $362 $-1 #
+coedge $-1 -1 -1 $-1 $726 $402 $352 $271 reversed $585 $-1 #
+coedge $-1 -1 -1 $-1 $353 $404 $355 $533 forward $270 $-1 #
+coedge $-1 -1 -1 $-1 $424 $355 $727 $728 reversed $165 $-1 #
+edge $-1 -1 -1 $-1 $601 -1.5707963267948966 $122 -6.1232339957367648e-17 $531 $729 forward @7 unknown T 29.999999999999996 -40 15 35 -35 20.000000000000004 #
+edge $-1 -1 -1 $-1 $66 6.1232339957367673e-17 $616 1.5707963267948966 $529 $730 forward @7 unknown T 29.999999999999996 -40 5.0000000000000018 35 -35 10.000000000000002 #
+face $-1 -1 -1 $-1 $731 $732 $11 $-1 $162 reversed single T 10 -40 15 19.999999999999996 -35 25 F #
+loop $-1 -1 -1 $-1 $-1 $733 $357 T 10 -35 15 19.999999999999996 -30 25 unknown #
+vertex $-1 -1 -1 $-1 $687 $734 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $425 $361 T 35 -40 2.5000000000000053 40.000000000000007 -39.330127018922191 7.5000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $363 $735 #
+coedge $-1 -1 -1 $-1 $736 $737 $365 $542 forward $738 $-1 #
+edge $-1 -1 -1 $-1 $544 4.1887902047863905 $375 4.7123889803846897 $541 $739 forward @7 unknown T 37.5 -30.669872981077809 35 40 -30 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $565 $366 $737 $740 reversed $384 $-1 #
+vertex $-1 -1 -1 $-1 $542 $741 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $372 $369 $594 $742 forward $135 $-1 #
+coedge $-1 -1 -1 $-1 $710 $599 $369 $548 reversed $420 $-1 #
+edge $-1 -1 -1 $-1 $550 1.570796326794897 $743 2.0943951023931948 $369 $241 forward @7 unknown T 37.500000000000014 -40 20.000000000000004 40.000000000000007 -39.330127018922191 22.500000000000014 #
+loop $-1 -1 -1 $-1 $744 $515 $745 T 39.999999999999993 -40 15.000000000000004 45.000000000000007 -30 25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $711 $746 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $595 $747 $372 $553 reversed $748 $-1 #
+edge $-1 -1 -1 $-1 $749 1.0471975511966001 $556 1.5707963267948966 $372 $376 forward @7 unknown T 37.500000000000007 -40 32.500000000000007 40 -39.330127018922198 35 #
+coedge $-1 -1 -1 $-1 $373 $373 $736 $750 reversed $555 $-1 #
+loop $-1 -1 -1 $-1 $751 $373 $752 T 40 -40 30 45 -30 40 unknown #
+vertex $-1 -1 -1 $-1 $553 $753 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -30 35 #
+face $-1 -1 -1 $-1 $754 $755 $11 $-1 $756 reversed single T 25 -40 -45 35 -35 -35 F #
+loop $-1 -1 -1 $-1 $-1 $757 $380 T 37.5 -40 -40 45.000000000000007 -30 -24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $758 $381 $759 $566 forward $563 $-1 #
+coedge $-1 -1 -1 $-1 $381 $760 $391 $575 forward $563 $-1 #
+loop $-1 -1 -1 $-1 $-1 $561 $761 T 22.499999999999996 -35 35 30 -30 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $383 $543 $762 $763 reversed $384 $-1 #
+edge $-1 -1 -1 $-1 $385 40 $764 50 $561 $765 forward @7 unknown T 30 -35 40 30 -35 50 #
+edge $-1 -1 -1 $-1 $385 3.1415926535897931 $410 4.7123889803846897 $592 $564 forward @7 unknown T 25 -40 35 30 -35 40 #
+point $-1 -1 -1 $-1 30 -35 40 #
+face $-1 -1 -1 $-1 $368 $748 $11 $-1 $388 reversed single T 35 -40 32.500000000000007 40 -39.330127018922191 37.5 F #
+coedge $-1 -1 -1 $-1 $766 $389 $392 $576 reversed $572 $-1 #
+coedge $-1 -1 -1 $-1 $389 $767 $397 $579 reversed $572 $-1 #
+loop $-1 -1 -1 $-1 $-1 $767 $768 T 14.999999999999996 -35 20 22.5 -30 35 unknown #
+straight-curve $-1 -1 -1 $-1 22.5 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $392 $391 $769 $770 forward $393 $-1 #
+edge $-1 -1 -1 $-1 $771 4.1887902047863905 $251 4.7123889803846897 $562 $772 forward @7 unknown T 22.499999999999996 -30.669872981077809 35 25 -30 37.500000000000007 #
+edge $-1 -1 -1 $-1 $773 1.5707963267948966 $394 2.0943951023931957 $392 $774 forward @7 unknown T 19.999999999999996 -30.669872981077809 32.499999999999993 22.499999999999996 -30 35 #
+face $-1 -1 -1 $-1 $775 $393 $11 $-1 $388 reversed single T 19.999999999999996 -30.669872981077809 32.499999999999993 25 -30 37.500000000000007 F #
+point $-1 -1 -1 $-1 22.499999999999993 -30.669872981077805 32.499999999999993 #
+edge $-1 -1 -1 $-1 $399 -2.0943951023931957 $776 -1.5707963267948966 $397 $777 forward @7 unknown T 19.999999999999996 -30.669872981077809 20 22.499999999999996 -30 22.500000000000004 #
+face $-1 -1 -1 $-1 $778 $398 $11 $-1 $162 reversed single T 19.999999999999996 -30.669872981077809 17.5 25 -30 22.500000000000004 F #
+point $-1 -1 -1 $-1 22.499999999999996 -30.669872981077805 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $779 $780 $401 $583 reversed $781 $-1 #
+edge $-1 -1 -1 $-1 $586 22.499999999999996 $590 32.5 $401 $782 forward @7 unknown T 22.499999999999993 -39.330127018922198 22.499999999999996 22.500000000000004 -39.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $402 $726 $779 $783 forward $585 $-1 #
+loop $-1 -1 -1 $-1 $-1 $584 $731 T 19.999999999999996 -40 17.499999999999996 25 -39.330127018922184 22.5 unknown #
+vertex $-1 -1 -1 $-1 $783 $784 #
+coedge $-1 -1 -1 $-1 $785 $405 $780 $786 forward $589 $-1 #
+coedge $-1 -1 -1 $-1 $405 $785 $787 $788 reversed $589 $-1 #
+loop $-1 -1 -1 $-1 $-1 $785 $605 T 19.999999999999996 -40 32.5 25 -39.330127018922191 37.5 unknown #
+vertex $-1 -1 -1 $-1 $406 $789 #
+coedge $-1 -1 -1 $-1 $408 $407 $790 $791 forward $409 $-1 #
+coedge $-1 -1 -1 $-1 $787 $759 $407 $567 forward $792 $-1 #
+point $-1 -1 -1 $-1 25 -40 35 #
+coedge $-1 -1 -1 $-1 $413 $411 $546 $742 reversed $262 $-1 #
+coedge $-1 -1 -1 $-1 $793 $552 $411 $596 forward $748 $-1 #
+edge $-1 -1 -1 $-1 $749 -2.0943951023931939 $597 -1.5707963267948966 $595 $794 forward @7 unknown T 35 -40 32.500000000000007 37.500000000000007 -39.330127018922198 35 #
+vertex $-1 -1 -1 $-1 $412 $795 #
+coedge $-1 -1 -1 $-1 $547 $727 $413 $600 forward $420 $-1 #
+edge $-1 -1 -1 $-1 $601 1.5707963267948966 $743 2.0943951023931966 $599 $796 forward @7 unknown T 35 -40 20.000000000000004 37.500000000000014 -39.330127018922191 22.500000000000014 #
+vertex $-1 -1 -1 $-1 $533 $797 #
+face $-1 -1 -1 $-1 $340 $798 $11 $-1 $265 reversed single T 22.499999999999993 -35 -50 30 -30 -40 F #
+loop $-1 -1 -1 $-1 $-1 $799 $415 T 37.5 -40 -50 45 -30 -40 unknown #
+face $-1 -1 -1 $-1 $577 $589 $11 $-1 $388 reversed single T 19.999999999999996 -40 32.5 25 -39.330127018922191 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $800 $416 T 10 -40 30 19.999999999999996 -35 40 unknown #
+coedge $-1 -1 -1 $-1 $801 $802 $803 $804 forward $417 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 -30.669872981077809 17.5 #
+point $-1 -1 -1 $-1 22.500000000000004 -39.330127018922184 17.5 #
+face $-1 -1 -1 $-1 $674 $805 $11 $-1 $19 reversed single T 30 -35 -50 37.500000000000007 -30 -40 F #
+coedge $-1 -1 -1 $-1 $806 $790 $383 $566 forward $423 $-1 #
+coedge $-1 -1 -1 $-1 $514 $511 $424 $613 forward $206 $-1 #
+edge $-1 -1 -1 $-1 $617 7.5000000000000044 $807 17.500000000000011 $612 $808 forward @7 unknown T 37.5 -39.330127018922198 7.5000000000000044 37.500000000000007 -39.330127018922191 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $809 $425 $511 $706 reversed $539 $-1 #
+coedge $-1 -1 -1 $-1 $425 $809 $429 $622 forward $539 $-1 #
+vertex $-1 -1 -1 $-1 $697 $810 #
+vertex $-1 -1 -1 $-1 $426 $811 #
+coedge $-1 -1 -1 $-1 $663 $427 $438 $630 forward $620 $-1 #
+loop $-1 -1 -1 $-1 $-1 $427 $812 T 24.999999999999996 -40 -15 35 -35 -4.9999999999999982 unknown #
+edge $-1 -1 -1 $-1 $625 -2.0943951023931948 $616 -1.5707963267948966 $615 $813 forward @7 unknown T 35 -40 2.5000000000000053 37.500000000000007 -39.330127018922198 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $485 $430 $809 $814 forward $315 $-1 #
+coedge $-1 -1 -1 $-1 $430 $484 $432 $628 forward $315 $-1 #
+vertex $-1 -1 -1 $-1 $814 $815 #
+coedge $-1 -1 -1 $-1 $433 $432 $444 $637 reversed $434 $-1 #
+edge $-1 -1 -1 $-1 $816 1.5707963267948966 $436 2.0943951023931957 $624 $491 forward @7 unknown T 37.5 -40 -9.9999999999999982 40 -39.330127018922191 -7.4999999999999964 #
+face $-1 -1 -1 $-1 $812 $434 $11 $-1 $336 reversed single T 35 -40 -12.500000000000002 40 -39.330127018922191 -7.4999999999999964 F #
+edge $-1 -1 -1 $-1 $435 -1.5707963267948966 $303 -6.1232339957367648e-17 $619 $817 forward @7 unknown T 30 -40 -15 35 -35 -9.9999999999999982 #
+point $-1 -1 -1 $-1 35 -40 -9.9999999999999982 #
+point $-1 -1 -1 $-1 37.5 -39.330127018922191 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $440 $439 $818 $819 reversed $441 $-1 #
+coedge $-1 -1 -1 $-1 $451 $820 $439 $454 reversed $646 $-1 #
+coedge $-1 -1 -1 $-1 $458 $444 $821 $822 forward $446 $-1 #
+edge $-1 -1 -1 $-1 $447 1.0471975511965983 $816 1.5707963267948966 $444 $682 forward @7 unknown T 37.5 -40 -12.500000000000002 40 -39.330127018922198 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $445 $457 $823 $824 forward $446 $-1 #
+face $-1 -1 -1 $-1 $825 $446 $11 $-1 $377 reversed single T 37.5 -40 -24.999999999999996 45 -30 -9.9999999999999982 F #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $826 $757 $449 $642 forward $560 $-1 #
+edge $-1 -1 -1 $-1 $647 1.0471975511965992 $643 1.570796326794897 $641 $827 forward @7 unknown T 37.5 -40 -27.499999999999993 40 -39.330127018922198 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $642 $828 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $829 $451 $757 $830 reversed $646 $-1 #
+loop $-1 -1 -1 $-1 $-1 $829 $831 T 29.999999999999996 -40 -40 37.500000000000007 -35 -24.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $642 $832 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077809 -12.5 #
+coedge $-1 -1 -1 $-1 $833 $826 $461 $652 forward $560 $-1 #
+edge $-1 -1 -1 $-1 $656 -1.570796326794897 $654 -1.0471975511965987 $651 $827 forward @7 unknown T 37.5 -30.669872981077805 -27.499999999999993 40 -30 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $462 $834 $833 $835 reversed $478 $-1 #
+vertex $-1 -1 -1 $-1 $463 $836 #
+vertex $-1 -1 -1 $-1 $652 $837 #
+coedge $-1 -1 -1 $-1 $468 $467 $838 $839 forward $302 $-1 #
+coedge $-1 -1 -1 $-1 $495 $840 $467 $506 reversed $685 $-1 #
+coedge $-1 -1 -1 $-1 $841 $842 $468 $660 reversed $843 $-1 #
+edge $-1 -1 -1 $-1 $844 4.1887902047863914 $475 4.7123889803846897 $468 $845 forward @7 unknown T 22.499999999999996 -30.669872981077805 -25 25 -30 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $846 $469 $847 $848 forward $471 $-1 #
+coedge $-1 -1 -1 $-1 $470 $846 $849 $509 forward $471 $-1 #
+coedge $-1 -1 -1 $-1 $498 $619 $470 $664 reversed $620 $-1 #
+edge $-1 -1 -1 $-1 $337 -1.5707963267948966 $303 0 $470 $505 forward @7 unknown T 25 -40 -14.999999999999998 30 -35 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $639 $471 $11 $-1 $265 reversed single T 22.499999999999993 -40 -25.000000000000004 30 -35 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $850 $473 $842 $670 forward $668 $-1 #
+coedge $-1 -1 -1 $-1 $473 $851 $852 $673 forward $668 $-1 #
+loop $-1 -1 -1 $-1 $-1 $667 $853 T 22.5 -35 -40 30 -30 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $475 -1.5707963267948966 $854 -1.047197551196597 $666 $855 forward @7 unknown T 22.5 -30.669872981077809 -27.500000000000007 25 -30 -25 #
+point $-1 -1 -1 $-1 25 -30 -25 #
+coedge $-1 -1 -1 $-1 $834 $477 $856 $857 reversed $478 $-1 #
+edge $-1 -1 -1 $-1 $858 -35 $479 -30 $667 $859 forward @7 unknown T 29.999999999999996 -35 -35 30 -35 -30 #
+face $-1 -1 -1 $-1 $831 $478 $11 $-1 $19 reversed single T 29.999999999999996 -35 -40 37.5 -30 -24.999999999999996 F #
+point $-1 -1 -1 $-1 29.999999999999996 -35 -30 #
+edge $-1 -1 -1 $-1 $860 1.0471975511965961 $483 1.5707963267948966 $861 $855 forward @7 unknown T 22.499999999999996 -40 -27.500000000000007 25 -39.330127018922184 -25 #
+point $-1 -1 -1 $-1 25 -40 -25 #
+coedge $-1 -1 -1 $-1 $821 $821 $484 $679 reversed $862 $-1 #
+edge $-1 -1 -1 $-1 $490 1.5707963267948966 $816 4.7123889803846897 $484 $863 forward @7 unknown T 40 -40 -9.9999999999999982 45 -30 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $512 $512 $485 $681 reversed $707 $-1 #
+edge $-1 -1 -1 $-1 $708 -1.570796326794897 $344 1.570796326794897 $485 $864 forward @7 unknown T 40 -40 2.6645352591003757e-15 45.000000000000007 -30 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -9.9999999999999982 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 -30 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $865 $866 $11 $-1 $336 reversed single T 4.9999999999999982 -30.669872981077809 -12.500000000000002 10 -30 -7.4999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $840 $492 T 19.999999999999996 -30.669872981077809 -12.5 25 -30 -7.4999999999999947 unknown #
+coedge $-1 -1 -1 $-1 $867 $868 $493 $687 reversed $869 $-1 #
+edge $-1 -1 -1 $-1 $537 -2.5000000000000022 $690 7.4999999999999947 $493 $870 forward @7 unknown T 22.5 -30.669872981077809 -7.4999999999999947 22.5 -30.669872981077805 2.5000000000000022 #
+coedge $-1 -1 -1 $-1 $494 $522 $867 $871 forward $523 $-1 #
+coedge $-1 -1 -1 $-1 $840 $495 $868 $872 forward $685 $-1 #
+vertex $-1 -1 -1 $-1 $496 $873 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -9.9999999999999982 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $499 $497 $874 $875 forward $328 $-1 #
+coedge $-1 -1 -1 $-1 $849 $876 $497 $694 reversed $699 $-1 #
+edge $-1 -1 -1 $-1 $337 1.5707963267948966 $877 2.0943951023931966 $497 $691 forward @7 unknown T 22.499999999999996 -40 -9.9999999999999982 25 -39.330127018922184 -7.4999999999999938 #
+coedge $-1 -1 -1 $-1 $878 $527 $499 $363 reversed $724 $-1 #
+coedge $-1 -1 -1 $-1 $500 $529 $502 $697 forward $362 $-1 #
+edge $-1 -1 -1 $-1 $616 -1.5707963267948966 $195 -6.1232339957367648e-17 $696 $879 forward @7 unknown T 29.999999999999996 -40 1.7763568394002505e-15 35 -35 5.0000000000000018 #
+face $-1 -1 -1 $-1 $880 $881 $11 $-1 $336 reversed single T 10 -40 -15 19.999999999999996 -35 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $882 $504 T 19.999999999999996 -40 -12.5 25 -39.330127018922184 -7.4999999999999938 unknown #
+vertex $-1 -1 -1 $-1 $883 $884 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 -9.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $885 $886 $11 $-1 $704 reversed single T 29.999999999999996 -20 5.0000000000000018 37.500000000000007 -15.000000000000004 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $887 $508 T 29.999999999999996 -20 20.000000000000004 37.500000000000007 -15.000000000000004 35 unknown #
+cone-surface $-1 -1 -1 $-1 35 -20.000000000000004 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $509 $888 #
+edge $-1 -1 -1 $-1 $708 1.570796326794897 $617 2.0943951023931948 $511 $345 forward @7 unknown T 37.500000000000007 -40 5.0000000000000027 40.000000000000007 -39.330127018922198 7.5000000000000044 #
+loop $-1 -1 -1 $-1 $889 $680 $890 T 39.999999999999993 -40 2.6645352591003757e-15 45.000000000000007 -30 10.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $814 $891 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $727 $547 $514 $711 reversed $420 $-1 #
+edge $-1 -1 -1 $-1 $807 1.0471975511966001 $550 1.570796326794897 $514 $378 forward @7 unknown T 37.5 -40 17.500000000000011 40 -39.330127018922198 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $892 $519 $521 $717 reversed $715 $-1 #
+coedge $-1 -1 -1 $-1 $519 $893 $522 $718 reversed $715 $-1 #
+loop $-1 -1 -1 $-1 $-1 $893 $894 T 14.999999999999996 -35 5.0000000000000009 22.500000000000004 -30 20 unknown #
+edge $-1 -1 -1 $-1 $776 1.5707963267948966 $418 2.0943951023931957 $521 $895 forward @7 unknown T 19.999999999999996 -30.669872981077809 17.5 22.500000000000004 -30 20 #
+edge $-1 -1 -1 $-1 $524 -2.0943951023931966 $896 -1.5707963267948966 $522 $897 forward @7 unknown T 19.999999999999996 -30.669872981077813 5.0000000000000009 22.5 -30 7.5000000000000062 #
+face $-1 -1 -1 $-1 $898 $523 $11 $-1 $227 reversed single T 19.999999999999996 -30.669872981077813 2.5000000000000004 25 -30 7.5000000000000071 F #
+point $-1 -1 -1 $-1 22.499999999999996 -30.669872981077813 7.5000000000000062 #
+coedge $-1 -1 -1 $-1 $899 $900 $526 $722 reversed $901 $-1 #
+edge $-1 -1 -1 $-1 $725 7.5000000000000027 $421 17.5 $526 $902 forward @7 unknown T 22.499999999999996 -39.330127018922191 7.5000000000000027 22.500000000000004 -39.330127018922184 17.5 #
+coedge $-1 -1 -1 $-1 $527 $878 $899 $903 forward $724 $-1 #
+loop $-1 -1 -1 $-1 $-1 $723 $904 T 19.999999999999996 -40 2.5000000000000004 25 -39.330127018922191 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $903 $905 #
+coedge $-1 -1 -1 $-1 $584 $530 $900 $906 forward $585 $-1 #
+coedge $-1 -1 -1 $-1 $599 $710 $532 $728 forward $420 $-1 #
+edge $-1 -1 -1 $-1 $807 -2.0943951023931953 $601 -1.5707963267948966 $727 $907 forward @7 unknown T 35 -40 17.500000000000004 37.500000000000007 -39.330127018922191 20.000000000000004 #
+face $-1 -1 -1 $-1 $580 $585 $11 $-1 $162 reversed single T 19.999999999999996 -40 17.499999999999996 25 -39.330127018922184 22.5 F #
+loop $-1 -1 -1 $-1 $-1 $908 $535 T 10 -40 15 19.999999999999996 -35 25 unknown #
+coedge $-1 -1 -1 $-1 $909 $910 $767 $911 forward $536 $-1 #
+point $-1 -1 -1 $-1 22.5 -30.669872981077805 2.5000000000000022 #
+point $-1 -1 -1 $-1 22.5 -39.330127018922191 2.5000000000000022 #
+coedge $-1 -1 -1 $-1 $912 $541 $554 $750 forward $738 $-1 #
+coedge $-1 -1 -1 $-1 $541 $913 $543 $740 forward $738 $-1 #
+loop $-1 -1 -1 $-1 $-1 $737 $914 T 37.5 -40 35 45 -30 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $915 -50 $544 -37.500000000000007 $737 $916 forward @7 unknown T 37.5 -30.669872981077805 37.500000000000007 37.5 -30.669872981077805 50 #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 37.500000000000007 #
+edge $-1 -1 -1 $-1 $743 22.500000000000014 $749 32.500000000000007 $546 $917 forward @7 unknown T 37.5 -39.330127018922205 22.500000000000014 37.500000000000014 -39.330127018922191 32.500000000000007 #
+vertex $-1 -1 -1 $-1 $600 $918 #
+loop $-1 -1 -1 $-1 $-1 $919 $745 T 50 -40 15.000000000000004 50 -30 25.000000000000004 unknown #
+face $-1 -1 -1 $-1 $920 $549 $11 $-1 $162 reversed single T 39.999999999999993 -40 15.000000000000004 50 -30 25.000000000000004 F #
+point $-1 -1 -1 $-1 40 -40 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $552 $793 $912 $921 reversed $748 $-1 #
+loop $-1 -1 -1 $-1 $-1 $793 $569 T 35 -40 32.500000000000007 40 -39.330127018922191 37.5 unknown #
+vertex $-1 -1 -1 $-1 $553 $922 #
+edge $-1 -1 -1 $-1 $375 1.5707963267948966 $556 4.7123889803846897 $736 $923 forward @7 unknown T 40 -40 35 45 -30 40 #
+loop $-1 -1 -1 $-1 $-1 $924 $752 T 50 -40 30 50 -30 40 unknown #
+face $-1 -1 -1 $-1 $925 $555 $11 $-1 $388 reversed single T 40 -40 30 50 -30 40 F #
+point $-1 -1 -1 $-1 40 -40 35 #
+face $-1 -1 -1 $-1 $926 $927 $11 $-1 $756 reversed single T 25 -35 -45 35 -30 -35 F #
+loop $-1 -1 -1 $-1 $-1 $928 $559 T 25 -40 -45 35 -35 -35 unknown #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 -35 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $641 $929 $645 $830 forward $560 $-1 #
+coedge $-1 -1 -1 $-1 $760 $561 $930 $931 reversed $563 $-1 #
+coedge $-1 -1 -1 $-1 $592 $932 $611 $566 reversed $792 $-1 #
+coedge $-1 -1 -1 $-1 $562 $758 $933 $934 forward $563 $-1 #
+face $-1 -1 -1 $-1 $935 $563 $11 $-1 $265 reversed single T 22.499999999999996 -35 35 30 -30 50 F #
+coedge $-1 -1 -1 $-1 $936 $930 $565 $763 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $764 -1.5707963267948966 $915 0.5235987755982987 $762 $938 forward @7 unknown T 30 -35 50 37.5 -30 50 #
+vertex $-1 -1 -1 $-1 $939 $940 #
+straight-curve $-1 -1 -1 $-1 30 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $941 $570 $802 $942 reversed $572 $-1 #
+coedge $-1 -1 -1 $-1 $571 $941 $733 $911 reversed $572 $-1 #
+face $-1 -1 -1 $-1 $894 $572 $11 $-1 $943 reversed single T 14.999999999999996 -35 20 22.5 -30 35 F #
+coedge $-1 -1 -1 $-1 $933 $803 $574 $770 reversed $944 $-1 #
+edge $-1 -1 -1 $-1 $771 -2.0943951023931966 $773 -1.5707963267948966 $574 $945 forward @7 unknown T 19.999999999999996 -30.669872981077809 35 22.500000000000004 -30 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $575 $946 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $942 $947 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $948 $949 $11 $-1 $950 reversed single T 7.4999999999999982 -40 20 15 -35 35 F #
+vertex $-1 -1 -1 $-1 $951 $952 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $953 $954 $11 $-1 $950 reversed single T 7.4999999999999982 -40 5.0000000000000009 15 -35 20 F #
+coedge $-1 -1 -1 $-1 $955 $582 $584 $783 reversed $781 $-1 #
+coedge $-1 -1 -1 $-1 $582 $956 $587 $786 reversed $781 $-1 #
+loop $-1 -1 -1 $-1 $-1 $779 $957 T 14.999999999999996 -40 20 22.500000000000004 -35 35 unknown #
+straight-curve $-1 -1 -1 $-1 22.5 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $958 1.5707963267948966 $586 2.0943951023931948 $584 $959 forward @7 unknown T 19.999999999999996 -40 20 22.499999999999993 -39.330127018922191 22.499999999999996 #
+point $-1 -1 -1 $-1 22.499999999999993 -39.330127018922191 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $588 $587 $960 $961 forward $589 $-1 #
+edge $-1 -1 -1 $-1 $590 -2.0943951023931957 $962 -1.5707963267948966 $587 $963 forward @7 unknown T 19.999999999999996 -40 32.5 22.500000000000004 -39.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $964 $592 $588 $788 forward $792 $-1 #
+edge $-1 -1 -1 $-1 $410 1.5707963267948966 $965 2.0943951023931957 $787 $772 forward @7 unknown T 22.499999999999993 -40 35 25 -39.330127018922191 37.5 #
+point $-1 -1 -1 $-1 22.500000000000004 -39.330127018922198 32.5 #
+coedge $-1 -1 -1 $-1 $611 $966 $591 $791 reversed $423 $-1 #
+edge $-1 -1 -1 $-1 $385 6.1232339957367648e-17 $597 1.5707963267948966 $591 $967 forward @7 unknown T 30 -40 35 35 -35 40 #
+loop $-1 -1 -1 $-1 $-1 $759 $968 T 22.499999999999993 -40 35 30 -35 50 unknown #
+coedge $-1 -1 -1 $-1 $747 $595 $966 $969 forward $748 $-1 #
+point $-1 -1 -1 $-1 35 -40 35 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 35 -40 20.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $970 $603 T 22.499999999999993 -35 -50 30 -30 -40 unknown #
+coedge $-1 -1 -1 $-1 $971 $972 $973 $974 forward $604 $-1 #
+coedge $-1 -1 -1 $-1 $975 $976 $977 $978 forward $606 $-1 #
+coedge $-1 -1 -1 $-1 $979 $607 $980 $981 reversed $417 $-1 #
+coedge $-1 -1 -1 $-1 $607 $979 $766 $942 forward $417 $-1 #
+coedge $-1 -1 -1 $-1 $769 $982 $607 $804 reversed $944 $-1 #
+edge $-1 -1 -1 $-1 $773 -1.5707963267948966 $983 6.1232339957367648e-17 $607 $984 forward @7 unknown T 14.999999999999996 -35 35 19.999999999999996 -30 40 #
+loop $-1 -1 -1 $-1 $-1 $985 $610 T 30 -35 -50 37.500000000000007 -30 -40 unknown #
+coedge $-1 -1 -1 $-1 $986 $611 $987 $988 reversed $423 $-1 #
+vertex $-1 -1 -1 $-1 $711 $989 #
+coedge $-1 -1 -1 $-1 $615 $614 $623 $814 reversed $539 $-1 #
+point $-1 -1 -1 $-1 35 -40 5.0000000000000018 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 7.5000000000000044 #
+face $-1 -1 -1 $-1 $200 $620 $11 $-1 $336 reversed single T 24.999999999999996 -40 -15 35 -35 -4.9999999999999982 F #
+edge $-1 -1 -1 $-1 $625 1.0471975511965996 $708 1.570796326794897 $623 $517 forward @7 unknown T 37.5 -40 2.500000000000008 40 -39.330127018922198 5.0000000000000044 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 2.500000000000008 #
+vertex $-1 -1 -1 $-1 $637 $990 #
+coedge $-1 -1 -1 $-1 $852 $861 $633 $819 forward $991 $-1 #
+edge $-1 -1 -1 $-1 $483 -1.5707963267948961 $479 0 $818 $669 forward @7 unknown T 25 -40 -30 29.999999999999996 -35 -25 #
+coedge $-1 -1 -1 $-1 $634 $992 $477 $673 forward $646 $-1 #
+coedge $-1 -1 -1 $-1 $678 $678 $636 $822 reversed $862 $-1 #
+edge $-1 -1 -1 $-1 $816 -1.5707963267948966 $490 1.5707963267948966 $636 $993 forward @7 unknown T 40 -40 -14.999999999999998 45 -30 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $994 $994 $638 $824 reversed $995 $-1 #
+edge $-1 -1 -1 $-1 $656 1.570796326794897 $643 4.7123889803846897 $638 $996 forward @7 unknown T 39.999999999999993 -40 -24.999999999999996 44.999999999999993 -30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $997 $998 $11 $-1 $756 reversed single T 40 -40 -45 50 -30 -35 F #
+coedge $-1 -1 -1 $-1 $651 $641 $994 $999 forward $560 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -40 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $992 $645 $1000 $1001 reversed $646 $-1 #
+edge $-1 -1 -1 $-1 $1002 -37.500000000000007 $647 -27.499999999999993 $757 $1003 forward @7 unknown T 37.5 -39.330127018922198 -37.500000000000007 37.500000000000007 -39.330127018922191 -27.499999999999993 #
+face $-1 -1 -1 $-1 $1004 $646 $11 $-1 $19 reversed single T 29.999999999999996 -40 -40 37.500000000000007 -35 -24.999999999999996 F #
+point $-1 -1 -1 $-1 37.5 -39.330127018922198 -27.499999999999993 #
+coedge $-1 -1 -1 $-1 $1005 $651 $653 $835 forward $560 $-1 #
+coedge $-1 -1 -1 $-1 $653 $672 $1006 $1007 reversed $478 $-1 #
+edge $-1 -1 -1 $-1 $654 27.499999999999993 $1008 37.5 $833 $1009 forward @7 unknown T 37.5 -30.669872981077805 -37.5 37.5 -30.669872981077805 -27.499999999999993 #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 -27.499999999999993 #
+point $-1 -1 -1 $-1 40 -30 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $1010 $1011 $657 $839 reversed $1012 $-1 #
+edge $-1 -1 -1 $-1 $700 12.499999999999996 $844 22.500000000000004 $657 $1013 forward @7 unknown T 22.499999999999996 -30.669872981077809 -22.500000000000004 22.5 -30.669872981077805 -12.499999999999996 #
+coedge $-1 -1 -1 $-1 $658 $689 $1010 $883 forward $685 $-1 #
+coedge $-1 -1 -1 $-1 $1014 $659 $1011 $1015 forward $843 $-1 #
+coedge $-1 -1 -1 $-1 $659 $1014 $666 $670 reversed $843 $-1 #
+loop $-1 -1 -1 $-1 $-1 $841 $1016 T 19.999999999999993 -30.669872981077809 -27.500000000000007 25 -30 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $660 $1017 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -35 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $662 $661 $1018 $1019 forward $471 $-1 #
+coedge $-1 -1 -1 $-1 $1020 $1021 $661 $848 reversed $1022 $-1 #
+edge $-1 -1 -1 $-1 $483 1.5707963267948961 $1023 2.0943951023931957 $661 $845 forward @7 unknown T 22.499999999999993 -40 -25.000000000000004 25 -39.330127018922191 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $882 $693 $662 $509 reversed $699 $-1 #
+coedge $-1 -1 -1 $-1 $1024 $666 $1025 $1026 forward $668 $-1 #
+coedge $-1 -1 -1 $-1 $667 $1024 $1027 $1028 forward $668 $-1 #
+coedge $-1 -1 -1 $-1 $1029 $818 $820 $673 reversed $991 $-1 #
+face $-1 -1 -1 $-1 $127 $668 $11 $-1 $265 reversed single T 22.5 -35 -40 30 -30 -25 F #
+vertex $-1 -1 -1 $-1 $1030 $1031 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $1027 $1032 $672 $857 forward $927 $-1 #
+edge $-1 -1 -1 $-1 $1033 -1.5707963267948966 $858 6.1232339957367648e-17 $856 $1034 forward @7 unknown T 30 -35 -40 35 -30 -35 #
+vertex $-1 -1 -1 $-1 $1035 $1036 #
+vertex $-1 -1 -1 $-1 $676 $1037 #
+coedge $-1 -1 -1 $-1 $818 $1038 $1020 $676 forward $991 $-1 #
+loop $-1 -1 -1 $-1 $1039 $821 $1040 T 40 -40 -14.999999999999998 45 -30 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -9.9999999999999982 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 5.0000000000000027 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1041 $1042 $11 $-1 $336 reversed single T -10.000000000000002 -40 -12.500000000000004 -5 -39.330127018922191 -7.5 F #
+loop $-1 -1 -1 $-1 $-1 $1043 $684 T 4.9999999999999982 -30.669872981077809 -12.500000000000002 10 -30 -7.4999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $1044 $686 $688 $871 reversed $869 $-1 #
+coedge $-1 -1 -1 $-1 $686 $1045 $689 $872 reversed $869 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1045 $1046 T 14.999999999999996 -35 -9.9999999999999982 22.5 -30 5.0000000000000009 unknown #
+edge $-1 -1 -1 $-1 $896 1.5707963267948966 $537 2.0943951023931957 $688 $1047 forward @7 unknown T 19.999999999999996 -30.669872981077809 2.5000000000000004 22.5 -30 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $690 -2.0943951023931957 $1048 -1.5707963267948966 $689 $1049 forward @7 unknown T 19.999999999999996 -30.669872981077809 -9.9999999999999982 22.5 -30 -7.4999999999999947 #
+point $-1 -1 -1 $-1 22.5 -30.669872981077805 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $1050 $1051 $692 $875 reversed $1052 $-1 #
+edge $-1 -1 -1 $-1 $877 -7.4999999999999956 $540 2.5000000000000022 $692 $1053 forward @7 unknown T 22.499999999999996 -39.330127018922191 -7.4999999999999956 22.5 -39.330127018922184 2.5000000000000022 #
+coedge $-1 -1 -1 $-1 $693 $882 $1050 $1054 forward $699 $-1 #
+vertex $-1 -1 -1 $-1 $1054 $1055 #
+coedge $-1 -1 -1 $-1 $723 $695 $1051 $1056 forward $724 $-1 #
+face $-1 -1 -1 $-1 $1057 $1058 $11 $-1 $336 reversed single T 10 -35 -15 19.999999999999996 -30 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $1059 $698 T 10 -40 -15 19.999999999999996 -35 -4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $876 $849 $1060 $1061 forward $699 $-1 #
+edge $-1 -1 -1 $-1 $1048 1.5707963267948966 $700 2.0943951023931957 $840 $1062 forward @7 unknown T 19.999999999999996 -30.669872981077809 -12.5 22.5 -30 -9.9999999999999982 #
+point $-1 -1 -1 $-1 22.5 -30.669872981077805 -12.499999999999996 #
+face $-1 -1 -1 $-1 $1063 $1064 $11 $-1 $704 reversed single T 29.999999999999996 -20 -9.9999999999999982 37.5 -15.000000000000004 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $1065 $702 T 29.999999999999996 -20 5.0000000000000018 37.500000000000007 -15.000000000000004 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $1066 $1067 $1068 $1069 reversed $703 $-1 #
+point $-1 -1 -1 $-1 22.5 -39.330127018922191 -12.499999999999998 #
+loop $-1 -1 -1 $-1 $-1 $1070 $890 T 50 -40 2.6645352591003757e-15 50 -30 10.000000000000004 unknown #
+face $-1 -1 -1 $-1 $1071 $707 $11 $-1 $227 reversed single T 39.999999999999993 -40 2.6645352591003757e-15 50 -30 10.000000000000004 F #
+point $-1 -1 -1 $-1 40 -40 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $1072 $713 $910 $951 reversed $715 $-1 #
+coedge $-1 -1 -1 $-1 $714 $1072 $1073 $1074 reversed $715 $-1 #
+face $-1 -1 -1 $-1 $1046 $715 $11 $-1 $943 reversed single T 14.999999999999996 -35 5.0000000000000009 22.500000000000004 -30 20 F #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $1075 $1076 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1077 $1078 $11 $-1 $482 reversed single T 10 -35 -30 20 -30 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $1079 $721 $723 $903 reversed $901 $-1 #
+coedge $-1 -1 -1 $-1 $721 $1080 $726 $906 reversed $901 $-1 #
+loop $-1 -1 -1 $-1 $-1 $899 $1081 T 14.999999999999996 -40 5.0000000000000009 22.500000000000004 -35 20 unknown #
+edge $-1 -1 -1 $-1 $1082 1.5707963267948966 $725 2.0943951023931957 $723 $1083 forward @7 unknown T 19.999999999999996 -40 5.0000000000000009 22.499999999999996 -39.330127018922191 7.5000000000000027 #
+face $-1 -1 -1 $-1 $719 $724 $11 $-1 $227 reversed single T 19.999999999999996 -40 2.5000000000000004 25 -39.330127018922191 7.5000000000000027 F #
+point $-1 -1 -1 $-1 22.499999999999996 -39.330127018922191 7.5000000000000027 #
+edge $-1 -1 -1 $-1 $421 -2.0943951023931966 $958 -1.5707963267948966 $726 $1084 forward @7 unknown T 19.999999999999996 -40 17.499999999999996 22.500000000000004 -39.330127018922184 20 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1085 $1086 $955 $1087 forward $732 $-1 #
+coedge $-1 -1 -1 $-1 $1088 $733 $1089 $1090 reversed $536 $-1 #
+coedge $-1 -1 -1 $-1 $733 $1088 $892 $951 forward $536 $-1 #
+edge $-1 -1 -1 $-1 $776 -1.5707963267948966 $1091 6.1232339957367648e-17 $733 $1092 forward @7 unknown T 14.999999999999996 -35 20 19.999999999999996 -30 25 #
+coedge $-1 -1 -1 $-1 $1093 $736 $747 $921 forward $738 $-1 #
+coedge $-1 -1 -1 $-1 $737 $1093 $936 $1094 reversed $738 $-1 #
+face $-1 -1 -1 $-1 $968 $738 $11 $-1 $377 reversed single T 37.5 -40 35 45 -30 50 F #
+vertex $-1 -1 -1 $-1 $1094 $1095 #
+straight-curve $-1 -1 -1 $-1 37.5 -30.669872981077805 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 37.500000000000014 -39.330127018922198 22.500000000000014 #
+coedge $-1 -1 -1 $-1 $919 $919 $1096 $1097 reversed $744 $-1 #
+face $-1 -1 -1 $-1 $1098 $1099 $11 $-1 $162 reversed single T -10.000000000000002 -40 17.499999999999996 -5 -39.330127018922191 22.500000000000004 F #
+edge $-1 -1 -1 $-1 $556 1.5707963267948966 $1100 2.0943951023931939 $912 $739 forward @7 unknown T 37.500000000000007 -40 35 40 -39.330127018922198 37.5 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922205 32.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $924 $924 $1101 $1102 reversed $751 $-1 #
+face $-1 -1 -1 $-1 $1103 $1104 $11 $-1 $388 reversed single T -10.000000000000002 -40 32.5 -5 -39.330127018922191 37.500000000000007 F #
+face $-1 -1 -1 $-1 $1105 $1106 $11 $-1 $756 reversed single T 35 -30.669872981077809 -42.5 40 -30 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $1032 $754 T 25 -35 -45 35 -30 -35 unknown #
+coedge $-1 -1 -1 $-1 $1107 $1108 $1109 $1110 forward $755 $-1 #
+coedge $-1 -1 -1 $-1 $757 $1111 $1112 $1113 forward $560 $-1 #
+coedge $-1 -1 -1 $-1 $762 $1114 $758 $931 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $1115 -2.0943951023931957 $764 0 $930 $1116 forward @7 unknown T 22.5 -35 50 30 -30 50 #
+coedge $-1 -1 -1 $-1 $759 $964 $1117 $939 reversed $792 $-1 #
+coedge $-1 -1 -1 $-1 $1118 $769 $760 $934 reversed $944 $-1 #
+edge $-1 -1 -1 $-1 $1115 -50 $771 -37.500000000000007 $760 $1119 forward @7 unknown T 22.5 -30.669872981077809 37.500000000000007 22.500000000000004 -30.669872981077805 50 #
+face $-1 -1 -1 $-1 $155 $1120 $11 $-1 $950 reversed single T 7.4999999999999991 -40 35 15 -35 50 F #
+coedge $-1 -1 -1 $-1 $987 $762 $913 $1094 forward $937 $-1 #
+loop $-1 -1 -1 $-1 $1121 $762 $1122 T -45 -40 50 45 -30 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $764 0 $1123 2.0943951023931957 $1117 $1116 forward @7 unknown T 22.5 -40 50 30 -35 50 #
+point $-1 -1 -1 $-1 30 -35 50 #
+coedge $-1 -1 -1 $-1 $767 $766 $1124 $1125 reversed $572 $-1 #
+edge $-1 -1 -1 $-1 $1126 -6.1232339957367648e-17 $773 1.5707963267948966 $802 $1127 forward @7 unknown T 14.999999999999996 -35 30 19.999999999999996 -30 35 #
+cone-surface $-1 -1 -1 $-1 19.999999999999996 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+loop $-1 -1 -1 $-1 $-1 $933 $1128 T 14.999999999999996 -35 35 22.500000000000004 -30 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -30.669872981077805 37.500000000000007 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 35 #
+face $-1 -1 -1 $-1 $1129 $1130 $11 $-1 $265 reversed single T 22.5 -40 -50 30 -35 -40 F #
+loop $-1 -1 -1 $-1 $-1 $1131 $775 T 7.4999999999999982 -40 20 15 -35 35 unknown #
+cone-surface $-1 -1 -1 $-1 10 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $1132 -6.1232339957367648e-17 $776 1.5707963267948966 $910 $1133 forward @7 unknown T 14.999999999999996 -35 15 19.999999999999996 -30 20 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 20 #
+face $-1 -1 -1 $-1 $1134 $991 $11 $-1 $265 reversed single T 22.499999999999993 -40 -40 30 -35 -25 F #
+loop $-1 -1 -1 $-1 $-1 $1135 $778 T 7.4999999999999982 -40 5.0000000000000009 15 -35 20 unknown #
+coedge $-1 -1 -1 $-1 $1136 $779 $908 $1087 reversed $781 $-1 #
+coedge $-1 -1 -1 $-1 $780 $1136 $975 $1137 reversed $781 $-1 #
+face $-1 -1 -1 $-1 $1138 $781 $11 $-1 $943 reversed single T 14.999999999999996 -40 20 22.500000000000004 -35 35 F #
+vertex $-1 -1 -1 $-1 $1139 $1140 #
+coedge $-1 -1 -1 $-1 $977 $1141 $785 $961 reversed $1142 $-1 #
+edge $-1 -1 -1 $-1 $962 1.5707963267948966 $965 2.0943951023931948 $785 $1143 forward @7 unknown T 19.999999999999996 -40 35 22.499999999999993 -39.330127018922191 37.5 #
+vertex $-1 -1 -1 $-1 $1137 $1144 #
+coedge $-1 -1 -1 $-1 $932 $787 $1141 $1145 forward $792 $-1 #
+vertex $-1 -1 -1 $-1 $961 $1146 #
+coedge $-1 -1 -1 $-1 $790 $986 $793 $969 reversed $423 $-1 #
+face $-1 -1 -1 $-1 $236 $792 $11 $-1 $265 reversed single T 22.499999999999993 -40 35 30 -35 50 F #
+edge $-1 -1 -1 $-1 $597 1.5707963267948966 $1100 2.0943951023931957 $793 $1147 forward @7 unknown T 35 -40 35 37.500000000000007 -39.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $1148 $1149 $1150 $1151 forward $798 $-1 #
+coedge $-1 -1 -1 $-1 $1152 $799 $1153 $1154 forward $604 $-1 #
+coedge $-1 -1 -1 $-1 $799 $1155 $1156 $1157 reversed $604 $-1 #
+coedge $-1 -1 -1 $-1 $1158 $1159 $799 $974 reversed $1160 $-1 #
+edge $-1 -1 -1 $-1 $1161 -50 $1162 -42.500000000000014 $799 $1163 forward @7 unknown T 37.5 -39.330127018922205 -50 37.500000000000007 -39.330127018922191 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $1164 $800 $956 $1137 forward $606 $-1 #
+coedge $-1 -1 -1 $-1 $800 $1164 $1165 $1166 reversed $606 $-1 #
+coedge $-1 -1 -1 $-1 $1167 $960 $800 $978 reversed $1142 $-1 #
+edge $-1 -1 -1 $-1 $983 6.1232339957367648e-17 $962 1.5707963267948966 $800 $1168 forward @7 unknown T 14.999999999999996 -40 35 19.999999999999996 -35 40 #
+coedge $-1 -1 -1 $-1 $802 $801 $1169 $1170 reversed $417 $-1 #
+coedge $-1 -1 -1 $-1 $1171 $1172 $801 $981 forward $1173 $-1 #
+edge $-1 -1 -1 $-1 $1174 1.5707963267948966 $983 3.1415926535897931 $980 $1175 forward @7 unknown T 10 -35 35 15 -30 40 #
+coedge $-1 -1 -1 $-1 $803 $1118 $1171 $1176 reversed $944 $-1 #
+vertex $-1 -1 -1 $-1 $1166 $1177 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1178 $1179 $1155 $1180 reversed $805 $-1 #
+coedge $-1 -1 -1 $-1 $966 $806 $1093 $1181 reversed $423 $-1 #
+coedge $-1 -1 -1 $-1 $1117 $936 $806 $988 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $1182 2.617993877991494 $764 4.7123889803846897 $987 $1183 forward @7 unknown T 30 -40 50 37.5 -35 50 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 17.500000000000011 #
+point $-1 -1 -1 $-1 40 -40 -9.9999999999999982 #
+loop $-1 -1 -1 $-1 $-1 $852 $953 T 22.499999999999993 -40 -40 30 -35 -25 unknown #
+coedge $-1 -1 -1 $-1 $820 $829 $1108 $1184 reversed $646 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -9.9999999999999982 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $823 $823 $826 $999 reversed $995 $-1 #
+loop $-1 -1 -1 $-1 $1185 $994 $1186 T 39.999999999999993 -40 -29.999999999999996 45.000000000000007 -30 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -35 -24.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1187 $1188 $11 $-1 $756 reversed single T -10.000000000000002 -40 -42.500000000000007 -5 -39.330127018922191 -37.5 F #
+loop $-1 -1 -1 $-1 $1189 $1190 $825 T 40 -40 -45 45 -30 -35 unknown #
+edge $-1 -1 -1 $-1 $643 -1.570796326794897 $656 1.570796326794897 $826 $1191 forward @7 unknown T 40 -40 -29.999999999999996 45.000000000000007 -30 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $1112 $1192 $829 $1001 forward $1193 $-1 #
+edge $-1 -1 -1 $-1 $1194 1.5707963267948966 $1002 2.0943951023931953 $1000 $1195 forward @7 unknown T 35 -40 -40 37.500000000000007 -39.330127018922191 -37.5 #
+vertex $-1 -1 -1 $-1 $830 $1196 #
+face $-1 -1 -1 $-1 $914 $1160 $11 $-1 $19 reversed single T 30 -40 -50 37.500000000000007 -35 -40 F #
+coedge $-1 -1 -1 $-1 $1111 $833 $1197 $1198 forward $560 $-1 #
+coedge $-1 -1 -1 $-1 $1199 $1197 $834 $1007 forward $1106 $-1 #
+edge $-1 -1 -1 $-1 $1008 -2.0943951023931953 $1033 -1.5707963267948966 $1006 $1200 forward @7 unknown T 35 -30.669872981077809 -40 37.5 -30 -37.5 #
+vertex $-1 -1 -1 $-1 $1198 $1201 #
+coedge $-1 -1 -1 $-1 $1202 $838 $840 $883 reversed $1012 $-1 #
+coedge $-1 -1 -1 $-1 $838 $1203 $841 $1015 reversed $1012 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1203 $1204 T 14.999999999999996 -35 -25 22.5 -30 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $842 $841 $1205 $1030 forward $843 $-1 #
+edge $-1 -1 -1 $-1 $844 -2.0943951023931948 $1206 -1.5707963267948961 $841 $1207 forward @7 unknown T 19.999999999999993 -30.669872981077805 -25 22.499999999999996 -30 -22.5 #
+face $-1 -1 -1 $-1 $1208 $843 $11 $-1 $482 reversed single T 19.999999999999993 -30.669872981077809 -27.500000000000007 25 -30 -22.5 F #
+point $-1 -1 -1 $-1 22.499999999999996 -30.669872981077805 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $1209 $1060 $846 $1019 reversed $1210 $-1 #
+edge $-1 -1 -1 $-1 $1023 -22.499999999999996 $705 -12.499999999999998 $846 $1211 forward @7 unknown T 22.499999999999993 -39.330127018922191 -22.499999999999996 22.5 -39.330127018922191 -12.499999999999998 #
+coedge $-1 -1 -1 $-1 $1212 $847 $861 $676 reversed $1022 $-1 #
+coedge $-1 -1 -1 $-1 $847 $1212 $1209 $1213 forward $1022 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1212 $1214 T 19.999999999999993 -40 -27.500000000000007 25 -39.330127018922184 -22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $1019 $1215 #
+coedge $-1 -1 -1 $-1 $851 $850 $1216 $1217 forward $668 $-1 #
+coedge $-1 -1 -1 $-1 $1205 $1218 $850 $1026 reversed $1219 $-1 #
+edge $-1 -1 -1 $-1 $854 27.500000000000007 $1220 37.5 $850 $1221 forward @7 unknown T 22.5 -30.669872981077809 -37.5 22.500000000000004 -30.669872981077805 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $1222 $856 $851 $1028 reversed $927 $-1 #
+edge $-1 -1 -1 $-1 $1223 1.5707963267948966 $858 3.1415926535897931 $851 $1224 forward @7 unknown T 25 -35 -40 30 -30 -35 #
+coedge $-1 -1 -1 $-1 $1225 $852 $1226 $1035 forward $991 $-1 #
+edge $-1 -1 -1 $-1 $1206 1.570796326794897 $854 2.0943951023931966 $1014 $1227 forward @7 unknown T 19.999999999999996 -30.669872981077809 -27.500000000000007 22.500000000000004 -30 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 -30.669872981077809 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $856 $1222 $1228 $1229 forward $927 $-1 #
+vertex $-1 -1 -1 $-1 $1229 $1230 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $858 3.1415926535897931 $1231 4.7123889803846897 $1029 $1224 forward @7 unknown T 25 -40 -40 30 -35 -35 #
+point $-1 -1 -1 $-1 30 -35 -35 #
+point $-1 -1 -1 $-1 22.500000000000004 -39.330127018922184 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $861 $1225 $1232 $1233 forward $991 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1234 $1040 T 50 -40 -14.999999999999996 50 -30 -4.9999999999999964 unknown #
+face $-1 -1 -1 $-1 $321 $862 $11 $-1 $336 reversed single T 40 -40 -14.999999999999998 50 -30 -4.9999999999999964 F #
+face $-1 -1 -1 $-1 $1235 $1236 $11 $-1 $336 reversed single T -50 -40 -15.000000000000004 -40 -30 -5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $1237 $865 T -10.000000000000002 -40 -12.500000000000004 -5 -39.330127018922191 -7.5 unknown #
+coedge $-1 -1 -1 $-1 $1238 $1239 $1240 $1241 forward $866 $-1 #
+coedge $-1 -1 -1 $-1 $1242 $867 $1243 $1075 reversed $869 $-1 #
+coedge $-1 -1 -1 $-1 $868 $1242 $1244 $1245 reversed $869 $-1 #
+face $-1 -1 -1 $-1 $1204 $869 $11 $-1 $943 reversed single T 14.999999999999996 -35 -9.9999999999999982 22.5 -30 5.0000000000000009 F #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $1246 $1247 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1248 $874 $876 $1054 reversed $1052 $-1 #
+coedge $-1 -1 -1 $-1 $874 $1249 $878 $1056 reversed $1052 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1050 $1250 T 14.999999999999996 -40 -9.9999999999999982 22.5 -35 5.0000000000000009 unknown #
+edge $-1 -1 -1 $-1 $1251 1.5707963267948966 $877 2.0943951023931966 $876 $1252 forward @7 unknown T 19.999999999999996 -40 -9.9999999999999982 22.5 -39.330127018922184 -7.4999999999999938 #
+point $-1 -1 -1 $-1 22.499999999999996 -39.330127018922184 -7.4999999999999956 #
+edge $-1 -1 -1 $-1 $540 -2.0943951023931957 $1082 -1.5707963267948966 $878 $1253 forward @7 unknown T 19.999999999999996 -40 2.5000000000000004 22.5 -39.330127018922191 5.0000000000000009 #
+face $-1 -1 -1 $-1 $1254 $1255 $11 $-1 $950 reversed single T 7.4999999999999982 -35 -25 15 -30 -10 F #
+loop $-1 -1 -1 $-1 $-1 $1244 $880 T 10 -35 -15 19.999999999999996 -30 -4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $1256 $1257 $1248 $1258 forward $881 $-1 #
+coedge $-1 -1 -1 $-1 $1018 $1259 $882 $1061 reversed $1210 $-1 #
+edge $-1 -1 -1 $-1 $705 -2.0943951023931957 $1251 -1.5707963267948966 $882 $1260 forward @7 unknown T 19.999999999999996 -40 -12.5 22.5 -39.330127018922191 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1261 $1262 $11 $-1 $704 reversed single T 29.999999999999996 -20 -24.999999999999996 37.500000000000007 -15.000000000000004 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $1263 $885 T 29.999999999999996 -20 -9.9999999999999982 37.5 -15.000000000000004 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $1264 $1265 $1266 $1267 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $1268 $887 $1269 $1270 reversed $703 $-1 #
+coedge $-1 -1 -1 $-1 $887 $1271 $1272 $1273 reversed $703 $-1 #
+coedge $-1 -1 -1 $-1 $1274 $1275 $887 $1069 forward $1276 $-1 #
+edge $-1 -1 -1 $-1 $1277 -1.5707963267948966 $1278 -6.4931039580273245e-16 $1068 $1279 forward @7 unknown T 29.999999999999996 -20 20.000000000000004 35 -15.000000000000004 25.000000000000007 #
+coedge $-1 -1 -1 $-1 $1070 $1070 $1280 $1281 reversed $889 $-1 #
+face $-1 -1 -1 $-1 $1282 $1283 $11 $-1 $227 reversed single T -10.000000000000002 -40 2.4999999999999982 -5 -39.330127018922191 7.5000000000000027 F #
+coedge $-1 -1 -1 $-1 $893 $892 $1284 $1285 reversed $715 $-1 #
+coedge $-1 -1 -1 $-1 $1286 $1243 $893 $1074 forward $1287 $-1 #
+edge $-1 -1 -1 $-1 $896 -1.5707963267948966 $1288 6.1232339957367648e-17 $1073 $1289 forward @7 unknown T 14.999999999999996 -35 5.0000000000000009 19.999999999999996 -30 10 #
+edge $-1 -1 -1 $-1 $1290 -6.1232339957367623e-17 $896 1.5707963267948966 $1243 $1291 forward @7 unknown T 14.999999999999996 -35 -9.3734986416366032e-33 19.999999999999996 -30 5.0000000000000009 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 5.0000000000000009 #
+face $-1 -1 -1 $-1 $1214 $1292 $11 $-1 $482 reversed single T 10 -40 -30 20 -35 -19.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $1293 $898 T 10 -35 -30 20 -30 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $1294 $899 $1295 $1296 reversed $901 $-1 #
+coedge $-1 -1 -1 $-1 $900 $1294 $1085 $1139 reversed $901 $-1 #
+face $-1 -1 -1 $-1 $957 $901 $11 $-1 $943 reversed single T 14.999999999999996 -40 5.0000000000000009 22.500000000000004 -35 20 F #
+vertex $-1 -1 -1 $-1 $1297 $1298 #
+coedge $-1 -1 -1 $-1 $1299 $908 $1080 $1139 forward $732 $-1 #
+coedge $-1 -1 -1 $-1 $908 $1299 $1300 $1301 reversed $732 $-1 #
+edge $-1 -1 -1 $-1 $1091 6.1232339957367648e-17 $958 1.5707963267948966 $908 $1302 forward @7 unknown T 14.999999999999996 -40 20 19.999999999999996 -35 25 #
+coedge $-1 -1 -1 $-1 $910 $909 $1303 $1304 reversed $536 $-1 #
+coedge $-1 -1 -1 $-1 $1124 $1305 $909 $1090 forward $1306 $-1 #
+edge $-1 -1 -1 $-1 $1307 1.5707963267948966 $1091 3.1415926535897931 $1089 $1308 forward @7 unknown T 10 -35 20 15 -30 25 #
+vertex $-1 -1 -1 $-1 $1301 $1309 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $913 $912 $986 $1181 forward $738 $-1 #
+edge $-1 -1 -1 $-1 $915 -2.0943951023931948 $1182 2.0943951023931957 $936 $1310 forward @7 unknown T 37.5 -40 50 45 -30 50 #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $1096 $1096 $919 $1097 forward $1311 $-1 #
+edge $-1 -1 -1 $-1 $1312 0 $1312 6.2831853071795862 $1096 $1313 forward @7 unknown T 50 -40 15.000000000000004 50 -30 25.000000000000004 #
+face $-1 -1 -1 $-1 $1314 $1315 $11 $-1 $162 reversed single T -50 -40 14.999999999999996 -40 -30 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $1316 $920 T -10.000000000000002 -40 17.499999999999996 -5 -39.330127018922191 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $969 $1317 #
+coedge $-1 -1 -1 $-1 $1101 $1101 $924 $1102 forward $1318 $-1 #
+edge $-1 -1 -1 $-1 $1319 0 $1319 6.2831853071795862 $1101 $1320 forward @7 unknown T 50 -40 30 50 -30 40 #
+face $-1 -1 -1 $-1 $1321 $1322 $11 $-1 $388 reversed single T -50 -40 29.999999999999996 -40 -30 40 F #
+loop $-1 -1 -1 $-1 $-1 $1323 $925 T -10.000000000000002 -40 32.5 -5 -39.330127018922191 37.500000000000007 unknown #
+face $-1 -1 -1 $-1 $853 $1193 $11 $-1 $756 reversed single T 35 -40 -42.500000000000014 40 -39.330127018922191 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $1199 $926 T 35 -30.669872981077809 -42.5 40 -30 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $1226 $928 $1324 $1325 reversed $755 $-1 #
+coedge $-1 -1 -1 $-1 $928 $1226 $992 $1184 forward $755 $-1 #
+coedge $-1 -1 -1 $-1 $1159 $1326 $928 $1110 reversed $1160 $-1 #
+edge $-1 -1 -1 $-1 $1194 -1.5707963267948966 $1327 -6.1232339957367648e-17 $928 $1328 forward @7 unknown T 30 -40 -45 35 -35 -40 #
+coedge $-1 -1 -1 $-1 $929 $1005 $1329 $1330 forward $560 $-1 #
+coedge $-1 -1 -1 $-1 $1153 $1000 $929 $1113 reversed $1193 $-1 #
+edge $-1 -1 -1 $-1 $1331 1.5707963267948966 $1002 2.0943951023931939 $929 $1332 forward @7 unknown T 37.500000000000007 -40 -40 40 -39.330127018922198 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $930 $1333 $1118 $1334 forward $937 $-1 #
+vertex $-1 -1 -1 $-1 $931 $1335 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1336 $987 $932 $939 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $982 $933 $1114 $1334 reversed $944 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1337 $935 T 7.4999999999999991 -40 35 15 -35 50 unknown #
+loop $-1 -1 -1 $-1 $1338 $1339 $1122 T -45 -25.000000000000004 50 45 -14.999999999999996 50 unknown #
+face $-1 -1 -1 $-1 $1340 $937 $11 $-1 $1341 forward single T -50 -50 50 50 50 50 F #
+vertex $-1 -1 -1 $-1 $1145 $1342 #
+coedge $-1 -1 -1 $-1 $1169 $1089 $1131 $1125 forward $1306 $-1 #
+edge $-1 -1 -1 $-1 $1091 25 $1126 30 $1124 $1343 forward @7 unknown T 14.999999999999998 -35 25 15 -35 30 #
+vertex $-1 -1 -1 $-1 $1170 $1344 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1345 $944 $11 $-1 $943 reversed single T 14.999999999999996 -35 35 22.500000000000004 -30 50 F #
+face $-1 -1 -1 $-1 $220 $1346 $11 $-1 $950 reversed single T 7.4999999999999964 -35 -50 15 -30 -40 F #
+loop $-1 -1 -1 $-1 $-1 $1150 $948 T 22.5 -40 -50 30 -35 -40 unknown #
+coedge $-1 -1 -1 $-1 $1300 $1347 $1136 $1125 reversed $949 $-1 #
+vertex $-1 -1 -1 $-1 $1304 $1348 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1349 $1350 $11 $-1 $756 reversed single T 10 -40 -45 19.999999999999996 -35 -35 F #
+coedge $-1 -1 -1 $-1 $1351 $1352 $1294 $1285 reversed $954 $-1 #
+coedge $-1 -1 -1 $-1 $956 $955 $941 $1125 forward $781 $-1 #
+edge $-1 -1 -1 $-1 $962 -1.5707963267948966 $1126 -6.1232339957367648e-17 $975 $1353 forward @7 unknown T 14.999999999999996 -40 30 19.999999999999996 -35 35 #
+face $-1 -1 -1 $-1 $1128 $1142 $11 $-1 $943 reversed single T 14.999999999999996 -40 35 22.5 -35 50 F #
+edge $-1 -1 -1 $-1 $958 -1.5707963267948966 $1132 -6.1232339957367648e-17 $1085 $1354 forward @7 unknown T 14.999999999999996 -40 15 19.999999999999996 -35 20 #
+point $-1 -1 -1 $-1 19.999999999999996 -40 20 #
+coedge $-1 -1 -1 $-1 $960 $1355 $964 $1145 reversed $1142 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1167 $1138 T 14.999999999999996 -40 35 22.5 -35 50 unknown #
+point $-1 -1 -1 $-1 19.999999999999996 -40 35 #
+edge $-1 -1 -1 $-1 $965 37.5 $1123 50 $964 $1356 forward @7 unknown T 22.499999999999993 -39.330127018922191 37.5 22.5 -39.330127018922191 50 #
+point $-1 -1 -1 $-1 22.499999999999993 -39.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $1357 $970 $1222 $1358 forward $798 $-1 #
+coedge $-1 -1 -1 $-1 $970 $1359 $1360 $1361 reversed $798 $-1 #
+coedge $-1 -1 -1 $-1 $1362 $1324 $1326 $1151 reversed $1130 $-1 #
+edge $-1 -1 -1 $-1 $1363 -50 $1327 -45 $970 $1364 forward @7 unknown T 30 -35 -50 30 -35 -45 #
+coedge $-1 -1 -1 $-1 $1365 $971 $1190 $1366 forward $604 $-1 #
+coedge $-1 -1 -1 $-1 $1192 $1112 $971 $1154 reversed $1193 $-1 #
+edge $-1 -1 -1 $-1 $1162 1.0471975511965983 $1331 1.5707963267948966 $971 $1367 forward @7 unknown T 37.5 -40 -42.500000000000014 40 -39.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $972 $1365 $985 $1180 forward $604 $-1 #
+coedge $-1 -1 -1 $-1 $1368 $1369 $972 $1157 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $1161 -2.0943951023931957 $1371 2.0943951023931948 $1156 $1372 forward @7 unknown T 37.5 -40 -50 45 -30 -50 #
+coedge $-1 -1 -1 $-1 $1326 $973 $1369 $1373 reversed $1160 $-1 #
+coedge $-1 -1 -1 $-1 $973 $1109 $1192 $1374 reversed $1160 $-1 #
+loop $-1 -1 -1 $-1 $-1 $973 $1004 T 30 -40 -50 37.500000000000007 -35 -40 unknown #
+vertex $-1 -1 -1 $-1 $1157 $1375 #
+vertex $-1 -1 -1 $-1 $1154 $1376 #
+straight-curve $-1 -1 -1 $-1 37.5 -39.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $976 $975 $1347 $1377 reversed $606 $-1 #
+coedge $-1 -1 -1 $-1 $1378 $1337 $976 $1166 forward $1120 $-1 #
+edge $-1 -1 -1 $-1 $983 3.1415926535897931 $1379 4.7123889803846897 $1165 $1175 forward @7 unknown T 10 -40 35 15 -35 40 #
+coedge $-1 -1 -1 $-1 $1355 $977 $982 $1176 forward $1142 $-1 #
+coedge $-1 -1 -1 $-1 $1380 $1124 $979 $1170 forward $1306 $-1 #
+edge $-1 -1 -1 $-1 $1126 0 $1174 1.5707963267948966 $1169 $1381 forward @7 unknown T 10 -35 30 15 -30 35 #
+coedge $-1 -1 -1 $-1 $1382 $980 $1337 $1176 forward $1173 $-1 #
+coedge $-1 -1 -1 $-1 $980 $1383 $1384 $1385 forward $1173 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1171 $1386 T 7.4999999999999947 -35 35 15 -30 50 unknown #
+vertex $-1 -1 -1 $-1 $1387 $1388 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $983 40 $1389 50 $1171 $1390 forward @7 unknown T 14.999999999999998 -35 40 15 -35 50 #
+point $-1 -1 -1 $-1 15 -35 40 #
+coedge $-1 -1 -1 $-1 $1228 $985 $1199 $1391 reversed $805 $-1 #
+coedge $-1 -1 -1 $-1 $985 $1392 $1368 $1393 reversed $805 $-1 #
+edge $-1 -1 -1 $-1 $1394 42.5 $1371 50 $1155 $1395 forward @7 unknown T 37.5 -30.669872981077805 -50 37.500000000000007 -30.669872981077805 -42.5 #
+edge $-1 -1 -1 $-1 $1100 37.5 $1182 50 $1093 $1396 forward @7 unknown T 37.5 -39.330127018922198 37.5 37.500000000000007 -39.330127018922191 50 #
+vertex $-1 -1 -1 $-1 $1181 $1397 #
+edge $-1 -1 -1 $-1 $858 6.1232339957367648e-17 $1194 1.5707963267948966 $1108 $1398 forward @7 unknown T 30 -40 -40 35 -35 -35 #
+loop $-1 -1 -1 $-1 $-1 $1399 $1186 T 50 -40 -29.999999999999996 50 -30 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $1400 $995 $11 $-1 $482 reversed single T 39.999999999999993 -40 -29.999999999999996 50 -30 -19.999999999999996 F #
+face $-1 -1 -1 $-1 $1401 $1402 $11 $-1 $756 reversed single T -25.000000000000004 -30.669872981077809 -42.500000000000007 -20 -30 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $1403 $997 T -10.000000000000002 -40 -42.500000000000007 -5 -39.330127018922191 -37.5 unknown #
+loop $-1 -1 -1 $-1 $-1 $1404 $825 T 50 -40 -45 50 -30 -35 unknown #
+coedge $-1 -1 -1 $-1 $1329 $1329 $1152 $1366 reversed $998 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -35 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1000 $1153 $1159 $1374 forward $1193 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1192 $1105 T 35 -40 -42.500000000000014 40 -39.330127018922191 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $1110 $1405 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $1006 $1406 $1005 $1198 reversed $1106 $-1 #
+edge $-1 -1 -1 $-1 $1008 4.1887902047863914 $1407 4.7123889803846897 $1005 $1332 forward @7 unknown T 37.5 -30.669872981077805 -40 40 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $1406 $1006 $1178 $1391 forward $1106 $-1 #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 -37.5 #
+coedge $-1 -1 -1 $-1 $1408 $1010 $1409 $1246 reversed $1012 $-1 #
+coedge $-1 -1 -1 $-1 $1011 $1408 $1410 $1411 reversed $1012 $-1 #
+face $-1 -1 -1 $-1 $1412 $1012 $11 $-1 $943 reversed single T 14.999999999999996 -35 -25 22.5 -30 -9.9999999999999982 F #
+coedge $-1 -1 -1 $-1 $1413 $1025 $1014 $1030 reversed $1219 $-1 #
+vertex $-1 -1 -1 $-1 $1414 $1415 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $329 $1416 $11 $-1 $950 reversed single T 7.4999999999999991 -40 -10 15.000000000000004 -35 5.0000000000000009 F #
+coedge $-1 -1 -1 $-1 $1417 $1018 $1021 $1213 reversed $1210 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1209 $1412 T 14.999999999999996 -40 -25 22.5 -35 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $1021 $1020 $1418 $1419 forward $1022 $-1 #
+edge $-1 -1 -1 $-1 $1420 1.5707963267948961 $1023 2.0943951023931948 $1021 $1421 forward @7 unknown T 19.999999999999993 -40 -25 22.499999999999993 -39.330127018922191 -22.499999999999996 #
+face $-1 -1 -1 $-1 $1016 $1022 $11 $-1 $482 reversed single T 19.999999999999993 -40 -27.500000000000007 25 -39.330127018922184 -22.499999999999996 F #
+point $-1 -1 -1 $-1 22.499999999999993 -39.330127018922191 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $1422 $1423 $1024 $1217 reversed $1424 $-1 #
+edge $-1 -1 -1 $-1 $1220 4.1887902047863914 $1223 4.7123889803846897 $1024 $1425 forward @7 unknown T 22.500000000000004 -30.669872981077805 -40 25 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $1025 $1426 $1422 $1427 reversed $1219 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1428 $1429 T 14.999999999999996 -35 -40 22.500000000000004 -30 -25 unknown #
+vertex $-1 -1 -1 $-1 $1217 $1430 #
+coedge $-1 -1 -1 $-1 $1032 $1027 $1148 $1358 reversed $927 $-1 #
+vertex $-1 -1 -1 $-1 $1431 $1432 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1038 $1029 $1433 $1434 forward $991 $-1 #
+coedge $-1 -1 -1 $-1 $1108 $1107 $1029 $1035 reversed $755 $-1 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1392 $1178 $1032 $1229 reversed $805 $-1 #
+edge $-1 -1 -1 $-1 $1327 -6.1232339957367648e-17 $1033 1.5707963267948966 $1032 $1435 forward @7 unknown T 30 -35 -45 35 -30 -40 #
+point $-1 -1 -1 $-1 35 -30 -40 #
+vertex $-1 -1 -1 $-1 $1436 $1437 #
+coedge $-1 -1 -1 $-1 $1438 $1418 $1038 $1233 reversed $1439 $-1 #
+edge $-1 -1 -1 $-1 $1440 -37.499999999999986 $860 -27.500000000000007 $1038 $1441 forward @7 unknown T 22.499999999999993 -39.330127018922191 -37.499999999999986 22.500000000000004 -39.330127018922184 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $1234 $1234 $1442 $1443 reversed $1039 $-1 #
+face $-1 -1 -1 $-1 $1186 $1444 $11 $-1 $1445 reversed single T -7.5000000000000036 -35 -10 0 -30 5 F #
+loop $-1 -1 -1 $-1 $1446 $1447 $1041 T -45 -40 -15.000000000000002 -40 -30 -5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $1448 $1449 $1450 $1451 forward $1042 $-1 #
+coedge $-1 -1 -1 $-1 $1452 $1043 $1453 $1454 reversed $866 $-1 #
+coedge $-1 -1 -1 $-1 $1043 $1452 $1455 $1456 forward $866 $-1 #
+coedge $-1 -1 -1 $-1 $1457 $1458 $1043 $1241 reversed $1459 $-1 #
+edge $-1 -1 -1 $-1 $1460 1.5707963267948966 $1461 2.0943951023931957 $1043 $1462 forward @7 unknown T 4.9999999999999982 -30.669872981077809 -12.500000000000002 7.4999999999999991 -30 -10 #
+coedge $-1 -1 -1 $-1 $1045 $1044 $1463 $1464 reversed $869 $-1 #
+coedge $-1 -1 -1 $-1 $1073 $1465 $1044 $1075 forward $1287 $-1 #
+coedge $-1 -1 -1 $-1 $1466 $1409 $1045 $1245 forward $1058 $-1 #
+edge $-1 -1 -1 $-1 $1048 -1.5707963267948966 $1467 6.1232339957367648e-17 $1244 $1468 forward @7 unknown T 14.999999999999996 -35 -9.9999999999999982 19.999999999999996 -30 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $1469 -6.1232339957367648e-17 $1048 1.5707963267948966 $1409 $1470 forward @7 unknown T 14.999999999999996 -35 -15 19.999999999999996 -30 -9.9999999999999982 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $1471 $1050 $1059 $1258 reversed $1052 $-1 #
+coedge $-1 -1 -1 $-1 $1051 $1471 $1472 $1297 reversed $1052 $-1 #
+face $-1 -1 -1 $-1 $1081 $1052 $11 $-1 $943 reversed single T 14.999999999999996 -40 -9.9999999999999982 22.5 -35 5.0000000000000009 F #
+vertex $-1 -1 -1 $-1 $1473 $1474 #
+face $-1 -1 -1 $-1 $1475 $1476 $11 $-1 $1477 reversed single T 15 -20 20 22.500000000000004 -15 35 F #
+loop $-1 -1 -1 $-1 $-1 $1478 $1057 T 7.4999999999999982 -35 -25 15 -30 -10 unknown #
+coedge $-1 -1 -1 $-1 $1479 $1059 $1259 $1473 forward $881 $-1 #
+coedge $-1 -1 -1 $-1 $1059 $1479 $1480 $1481 reversed $881 $-1 #
+edge $-1 -1 -1 $-1 $1467 6.1232339957367648e-17 $1251 1.5707963267948966 $1059 $1482 forward @7 unknown T 14.999999999999996 -40 -9.9999999999999982 19.999999999999996 -35 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $1060 $1483 $1256 $1473 reversed $1210 $-1 #
+face $-1 -1 -1 $-1 $1484 $1485 $11 $-1 $704 reversed single T 29.999999999999996 -25.000000000000004 -24.999999999999996 37.500000000000007 -20 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $1486 $1063 T 29.999999999999996 -20 -24.999999999999996 37.500000000000007 -15.000000000000004 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $1487 $1488 $1489 $1490 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $1491 $1065 $1492 $1493 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $1065 $1494 $1495 $1496 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $1497 $1498 $1065 $1267 forward $1499 $-1 #
+edge $-1 -1 -1 $-1 $1500 -1.5707963267948966 $1501 -6.4931039580273206e-16 $1266 $1502 forward @7 unknown T 29.999999999999996 -20 5.0000000000000018 35 -15.000000000000004 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $1503 $1066 $1504 $1505 reversed $703 $-1 #
+coedge $-1 -1 -1 $-1 $1506 $1507 $1066 $1270 forward $1508 $-1 #
+edge $-1 -1 -1 $-1 $1509 -2.0943951023931966 $1277 -1.5707963267948966 $1269 $1510 forward @7 unknown T 35 -15.669872981077814 20.000000000000004 37.500000000000007 -15.000000000000004 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $1067 $1503 $1511 $1512 reversed $703 $-1 #
+coedge $-1 -1 -1 $-1 $1513 $1514 $1515 $1273 forward $1516 $-1 #
+edge $-1 -1 -1 $-1 $1278 25 $1517 30 $1272 $1518 forward @7 unknown T 29.999999999999996 -20 25 30 -20 30 #
+coedge $-1 -1 -1 $-1 $1519 $1068 $1514 $1520 reversed $1276 $-1 #
+coedge $-1 -1 -1 $-1 $1068 $1519 $1494 $1521 forward $1276 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1068 $1522 T 25 -20 15 35 -15 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $1521 $1523 #
+vertex $-1 -1 -1 $-1 $1524 $1525 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1280 $1280 $1070 $1281 forward $1526 $-1 #
+edge $-1 -1 -1 $-1 $1527 0 $1527 6.2831853071795862 $1280 $1528 forward @7 unknown T 50 -40 2.6645352591003757e-15 50 -30 10.000000000000004 #
+face $-1 -1 -1 $-1 $1529 $1530 $11 $-1 $227 reversed single T -50 -40 -3.5527136788005009e-15 -40 -30 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $1531 $1071 T -10.000000000000002 -40 2.4999999999999982 -5 -39.330127018922191 7.5000000000000027 unknown #
+coedge $-1 -1 -1 $-1 $1303 $1532 $1135 $1285 forward $1533 $-1 #
+edge $-1 -1 -1 $-1 $1288 10 $1132 15 $1284 $1534 forward @7 unknown T 14.999999999999996 -35 10 15 -35 15 #
+coedge $-1 -1 -1 $-1 $1465 $1073 $1532 $1535 reversed $1287 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1073 $1536 T 9.9999999999999982 -35 -9.3734986416366032e-33 19.999999999999996 -30 10 unknown #
+vertex $-1 -1 -1 $-1 $1537 $1538 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $1539 $1540 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $1541 $1077 T 10 -40 -30 20 -35 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $1410 $1542 $1413 $1414 forward $1078 $-1 #
+coedge $-1 -1 -1 $-1 $1080 $1079 $1072 $1285 forward $901 $-1 #
+coedge $-1 -1 -1 $-1 $1472 $1543 $1079 $1296 forward $1544 $-1 #
+edge $-1 -1 -1 $-1 $1288 6.1232339957367648e-17 $1082 1.5707963267948966 $1295 $1545 forward @7 unknown T 14.999999999999996 -40 5.0000000000000009 19.999999999999996 -35 10 #
+edge $-1 -1 -1 $-1 $1082 -1.5707963267948966 $1290 -6.1232339957367623e-17 $1472 $1546 forward @7 unknown T 14.999999999999996 -40 -9.3734986416366032e-33 19.999999999999996 -35 5.0000000000000009 #
+point $-1 -1 -1 $-1 19.999999999999996 -40 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $1086 $1085 $1352 $1547 reversed $732 $-1 #
+coedge $-1 -1 -1 $-1 $1548 $1131 $1086 $1301 forward $949 $-1 #
+edge $-1 -1 -1 $-1 $1091 3.1415926535897931 $1549 4.7123889803846897 $1300 $1308 forward @7 unknown T 10 -40 20 15 -35 25 #
+coedge $-1 -1 -1 $-1 $1550 $1284 $1088 $1304 forward $1533 $-1 #
+edge $-1 -1 -1 $-1 $1132 0 $1307 1.5707963267948966 $1303 $1551 forward @7 unknown T 10 -35 15 15 -30 20 #
+coedge $-1 -1 -1 $-1 $1089 $1552 $1553 $1554 forward $1306 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1124 $1555 T 7.4999999999999947 -35 20 15 -30 35 unknown #
+vertex $-1 -1 -1 $-1 $1556 $1557 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 15 -35 25 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 50 -0 -0 -1 5 0 0 1 I I #
+loop $-1 -1 -1 $-1 $1526 $1096 $1558 T 50 -40 15.000000000000004 50 -30 25.000000000000004 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1097 $1560 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $890 $1561 $11 $-1 $1445 reversed single T -7.5000000000000027 -35 20 0 -30 35 F #
+loop $-1 -1 -1 $-1 $1562 $1563 $1098 T -45 -40 14.999999999999996 -40 -30 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $1564 $1565 $1566 $1567 forward $1099 $-1 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922198 37.5 #
+loop $-1 -1 -1 $-1 $1311 $1101 $1558 T 50 -40 30 50 -30 40 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1102 $1568 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $745 $1569 $11 $-1 $1445 reversed single T -7.5000000000000018 -35 35 0 -30 50 F #
+loop $-1 -1 -1 $-1 $1570 $1571 $1103 T -45 -40 30 -40 -30 40 unknown #
+coedge $-1 -1 -1 $-1 $1572 $1573 $1574 $1575 forward $1104 $-1 #
+coedge $-1 -1 -1 $-1 $1150 $1576 $1107 $1325 forward $1130 $-1 #
+edge $-1 -1 -1 $-1 $1231 -1.5707963267948966 $1327 0 $1324 $1577 forward @7 unknown T 25 -40 -45 30 -35 -40 #
+coedge $-1 -1 -1 $-1 $1109 $1158 $1392 $1151 forward $1160 $-1 #
+vertex $-1 -1 -1 $-1 $1358 $1578 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1190 $1190 $1111 $1330 reversed $998 $-1 #
+edge $-1 -1 -1 $-1 $1407 1.5707963267948966 $1331 4.7123889803846897 $1111 $1579 forward @7 unknown T 40 -40 -40 45 -30 -35 #
+vertex $-1 -1 -1 $-1 $1154 $1580 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1114 $1581 $1382 $1582 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $1389 -1.5707963267948966 $1115 0.52359877559829959 $1114 $1583 forward @7 unknown T 14.999999999999996 -35 50 22.5 -30 50 #
+point $-1 -1 -1 $-1 22.5 -30.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $1584 $1117 $1355 $1585 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $1165 $1586 $1167 $1176 reversed $1120 $-1 #
+loop $-1 -1 -1 $-1 $1587 $1588 $1122 T -45 -10.000000000000002 50 45 2.6645352591003757e-15 50 unknown #
+coedge $-1 -1 -1 $-1 $1589 $1590 $1591 $1592 forward $1121 $-1 #
+face $-1 -1 -1 $-1 $1593 $1594 $11 $-1 $1595 reversed single T -22.500000000000004 -40 35 -15 -35 50 F #
+plane-surface $-1 -1 -1 $-1 0 0 50 0 0 1 1 0 0 forward_v I I I I #
+point $-1 -1 -1 $-1 22.5 -39.330127018922191 50 #
+straight-curve $-1 -1 -1 $-1 14.999999999999998 -35 0 0 0 1 I I #
+point $-1 -1 -1 $-1 15 -35 30 #
+face $-1 -1 -1 $-1 $1429 $1596 $11 $-1 $943 reversed single T 14.999999999999996 -35 -50 22.5 -30 -40 F #
+loop $-1 -1 -1 $-1 $-1 $1597 $1129 T 7.4999999999999964 -35 -50 15 -30 -40 unknown #
+coedge $-1 -1 -1 $-1 $1131 $1598 $1164 $1377 forward $949 $-1 #
+point $-1 -1 -1 $-1 15 -35 15 #
+face $-1 -1 -1 $-1 $1599 $1600 $11 $-1 $756 reversed single T 10 -35 -45 19.999999999999996 -30 -35 F #
+loop $-1 -1 -1 $-1 $-1 $1601 $1134 T 10 -40 -45 19.999999999999996 -35 -35 unknown #
+coedge $-1 -1 -1 $-1 $1602 $1135 $1543 $1537 forward $954 $-1 #
+coedge $-1 -1 -1 $-1 $1135 $1603 $1299 $1547 forward $954 $-1 #
+coedge $-1 -1 -1 $-1 $1141 $1167 $1336 $1585 reversed $1142 $-1 #
+coedge $-1 -1 -1 $-1 $1359 $1148 $1423 $1431 forward $798 $-1 #
+edge $-1 -1 -1 $-1 $1327 0 $1223 1.5707963267948966 $1148 $1577 forward @7 unknown T 25 -35 -45 30 -30 -40 #
+coedge $-1 -1 -1 $-1 $1149 $1357 $1604 $1605 forward $798 $-1 #
+coedge $-1 -1 -1 $-1 $1606 $1368 $1149 $1361 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $1363 0 $1607 2.0943951023931957 $1360 $1608 forward @7 unknown T 22.5 -35 -50 30 -30 -50 #
+coedge $-1 -1 -1 $-1 $1609 $1150 $1610 $1611 reversed $1130 $-1 #
+vertex $-1 -1 -1 $-1 $1361 $1612 #
+coedge $-1 -1 -1 $-1 $1155 $1152 $1406 $1613 forward $604 $-1 #
+edge $-1 -1 -1 $-1 $1331 -1.5707963267948966 $1407 1.5707963267948966 $1152 $1614 forward @7 unknown T 40 -40 -45 45 -30 -40 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1360 $1156 $1179 $1393 forward $1370 $-1 #
+coedge $-1 -1 -1 $-1 $1156 $1610 $1158 $1373 forward $1370 $-1 #
+loop $-1 -1 -1 $-1 $1615 $1369 $1616 T -45 -40 -50 45 -30 -50 unknown #
+vertex $-1 -1 -1 $-1 $1180 $1617 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -50 0 0 1 5 0 0 1 I I #
+edge $-1 -1 -1 $-1 $1363 1.5707963267948966 $1161 3.6651914291880923 $1369 $1618 forward @7 unknown T 30 -40 -50 37.5 -35 -50 #
+edge $-1 -1 -1 $-1 $1162 -2.0943951023931957 $1194 -1.5707963267948966 $1192 $1619 forward @7 unknown T 35 -40 -42.500000000000014 37.500000000000007 -39.330127018922191 -40 #
+point $-1 -1 -1 $-1 37.5 -39.330127018922191 -50 #
+point $-1 -1 -1 $-1 37.500000000000007 -39.330127018922205 -42.500000000000014 #
+edge $-1 -1 -1 $-1 $1379 -1.5707963267948966 $1126 0 $1347 $1381 forward @7 unknown T 10 -40 30 15 -35 35 #
+coedge $-1 -1 -1 $-1 $1620 $1165 $1621 $1622 forward $1120 $-1 #
+vertex $-1 -1 -1 $-1 $1623 $1624 #
+coedge $-1 -1 -1 $-1 $1552 $1169 $1625 $1387 forward $1306 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1383 $1171 $1333 $1582 reversed $1173 $-1 #
+coedge $-1 -1 -1 $-1 $1172 $1382 $1626 $1627 forward $1173 $-1 #
+coedge $-1 -1 -1 $-1 $1628 $1625 $1172 $1385 reversed $1629 $-1 #
+edge $-1 -1 -1 $-1 $1630 4.1887902047863896 $1174 4.7123889803846897 $1172 $1631 forward @7 unknown T 7.4999999999999947 -30.669872981077813 35 10 -30 37.500000000000007 #
+face $-1 -1 -1 $-1 $1632 $1173 $11 $-1 $950 reversed single T 7.4999999999999947 -35 35 15 -30 50 F #
+edge $-1 -1 -1 $-1 $1174 -1.5707963267948966 $1633 -1.0471975511965979 $1380 $1634 forward @7 unknown T 7.4999999999999982 -30.669872981077809 32.5 10 -30 35 #
+point $-1 -1 -1 $-1 10 -30 35 #
+vertex $-1 -1 -1 $-1 $1635 $1636 #
+edge $-1 -1 -1 $-1 $1033 1.5707963267948966 $1394 2.0943951023931957 $1199 $1637 forward @7 unknown T 35 -30.669872981077809 -42.5 37.500000000000007 -30 -40 #
+coedge $-1 -1 -1 $-1 $1179 $1228 $970 $1151 reversed $805 $-1 #
+edge $-1 -1 -1 $-1 $1371 -0.5235987755982987 $1363 1.5707963267948966 $1368 $1638 forward @7 unknown T 30 -35 -50 37.5 -30 -50 #
+vertex $-1 -1 -1 $-1 $1391 $1639 #
+point $-1 -1 -1 $-1 37.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $1399 $1399 $1640 $1641 reversed $1185 $-1 #
+face $-1 -1 -1 $-1 $1642 $1643 $11 $-1 $482 reversed single T -50 -40 -30.000000000000004 -40 -30 -20.000000000000004 F #
+face $-1 -1 -1 $-1 $1644 $1645 $11 $-1 $756 reversed single T -50 -40 -45 -40 -30 -35 F #
+loop $-1 -1 -1 $-1 $-1 $1646 $1187 T -25.000000000000004 -30.669872981077809 -42.500000000000007 -20 -30 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $1647 $1648 $1649 $1650 forward $1188 $-1 #
+coedge $-1 -1 -1 $-1 $1404 $1404 $1651 $1652 reversed $1189 $-1 #
+point $-1 -1 -1 $-1 35 -40 -40 #
+coedge $-1 -1 -1 $-1 $1197 $1199 $1365 $1613 reversed $1106 $-1 #
+vertex $-1 -1 -1 $-1 $1613 $1653 #
+coedge $-1 -1 -1 $-1 $1203 $1202 $1478 $1654 reversed $1012 $-1 #
+coedge $-1 -1 -1 $-1 $1244 $1655 $1202 $1246 forward $1058 $-1 #
+coedge $-1 -1 -1 $-1 $1656 $1293 $1203 $1411 forward $1078 $-1 #
+edge $-1 -1 -1 $-1 $1206 -1.570796326794897 $1657 6.1232339957367648e-17 $1410 $1658 forward @7 unknown T 14.999999999999996 -35 -25 20 -30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $1250 $1210 $11 $-1 $943 reversed single T 14.999999999999996 -40 -25 22.5 -35 -9.9999999999999982 F #
+coedge $-1 -1 -1 $-1 $1428 $1205 $1293 $1414 reversed $1219 $-1 #
+edge $-1 -1 -1 $-1 $1659 -6.1232339957367648e-17 $1206 1.5707963267948961 $1293 $1660 forward @7 unknown T 14.999999999999996 -35 -30 19.999999999999996 -30 -25 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 -25 #
+loop $-1 -1 -1 $-1 $-1 $1661 $1208 T 7.4999999999999991 -40 -10 15.000000000000004 -35 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $1483 $1209 $1662 $1663 reversed $1210 $-1 #
+coedge $-1 -1 -1 $-1 $1232 $1664 $1212 $1419 reversed $1439 $-1 #
+edge $-1 -1 -1 $-1 $860 -2.0943951023931975 $1420 -1.570796326794897 $1212 $1665 forward @7 unknown T 19.999999999999996 -40 -27.500000000000007 22.500000000000007 -39.330127018922184 -25 #
+vertex $-1 -1 -1 $-1 $1666 $1667 #
+coedge $-1 -1 -1 $-1 $1668 $1216 $1218 $1427 forward $1424 $-1 #
+coedge $-1 -1 -1 $-1 $1216 $1668 $1357 $1431 reversed $1424 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1668 $1599 T 19.999999999999996 -30.669872981077809 -42.5 25 -30 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1218 $1428 $1669 $1670 reversed $1219 $-1 #
+edge $-1 -1 -1 $-1 $1220 -2.0943951023931957 $1671 -1.5707963267948966 $1422 $1672 forward @7 unknown T 19.999999999999996 -30.669872981077809 -40 22.500000000000004 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $1426 $1413 $1673 $1674 reversed $1219 $-1 #
+face $-1 -1 -1 $-1 $1675 $1219 $11 $-1 $943 reversed single T 14.999999999999996 -35 -40 22.500000000000004 -30 -25 F #
+point $-1 -1 -1 $-1 22.500000000000004 -30.669872981077805 -37.5 #
+edge $-1 -1 -1 $-1 $1223 -1.5707963267948966 $1676 -1.047197551196597 $1357 $1677 forward @7 unknown T 22.499999999999993 -30.669872981077809 -42.5 25 -30 -40 #
+point $-1 -1 -1 $-1 25 -30 -40 #
+coedge $-1 -1 -1 $-1 $1678 $1679 $1225 $1434 reversed $1680 $-1 #
+edge $-1 -1 -1 $-1 $1231 1.5707963267948966 $1440 2.0943951023931975 $1225 $1425 forward @7 unknown T 22.499999999999993 -40 -40 25 -39.330127018922184 -37.499999999999986 #
+edge $-1 -1 -1 $-1 $1681 1.0471975511965979 $1231 1.5707963267948966 $1576 $1677 forward @7 unknown T 22.5 -40 -42.500000000000007 25 -39.330127018922191 -40 #
+point $-1 -1 -1 $-1 25 -40 -40 #
+coedge $-1 -1 -1 $-1 $1682 $1232 $1679 $1683 reversed $1439 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1438 $1675 T 14.999999999999996 -40 -40 22.500000000000007 -35 -25 unknown #
+vertex $-1 -1 -1 $-1 $1233 $1684 #
+coedge $-1 -1 -1 $-1 $1442 $1442 $1234 $1443 forward $1685 $-1 #
+edge $-1 -1 -1 $-1 $1686 0 $1686 6.2831853071795862 $1442 $1687 forward @7 unknown T 50 -40 -14.999999999999996 50 -30 -4.9999999999999964 #
+loop $-1 -1 -1 $-1 $-1 $1688 $1235 T -7.5000000000000036 -35 -10 0 -30 5 unknown #
+cone-surface $-1 -1 -1 $-1 -5 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+loop $-1 -1 -1 $-1 $-1 $1689 $1041 T -50 -40 -15.000000000000004 -50 -30 -5.0000000000000036 unknown #
+coedge $-1 -1 -1 $-1 $1690 $1690 $1691 $1692 forward $1236 $-1 #
+coedge $-1 -1 -1 $-1 $1693 $1237 $1694 $1695 reversed $1042 $-1 #
+coedge $-1 -1 -1 $-1 $1237 $1693 $1696 $1697 forward $1042 $-1 #
+coedge $-1 -1 -1 $-1 $1698 $1699 $1237 $1451 reversed $1700 $-1 #
+edge $-1 -1 -1 $-1 $1701 1.5707963267948966 $1702 2.0943951023931953 $1237 $1703 forward @7 unknown T -10.000000000000002 -40 -10 -7.5000000000000027 -39.330127018922191 -7.5 #
+coedge $-1 -1 -1 $-1 $1239 $1238 $1704 $1705 reversed $866 $-1 #
+coedge $-1 -1 -1 $-1 $1706 $1707 $1238 $1454 forward $1255 $-1 #
+edge $-1 -1 -1 $-1 $1708 -1.5707963267948966 $1461 -1.0471975511965974 $1453 $1709 forward @7 unknown T 7.4999999999999982 -30.669872981077809 -12.500000000000002 10 -30 -10 #
+coedge $-1 -1 -1 $-1 $1710 $1711 $1239 $1456 reversed $1712 $-1 #
+edge $-1 -1 -1 $-1 $1713 -2.0943951023931953 $1460 -1.5707963267948966 $1239 $1714 forward @7 unknown T 4.9999999999999982 -30.669872981077809 -10 7.4999999999999982 -30 -7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $1715 $1240 $1716 $1717 reversed $1459 $-1 #
+coedge $-1 -1 -1 $-1 $1240 $1718 $1706 $1719 reversed $1459 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1720 $1721 T -1.7763568394002505e-15 -35 -25 7.4999999999999991 -30 -10 unknown #
+vertex $-1 -1 -1 $-1 $1717 $1722 #
+vertex $-1 -1 -1 $-1 $1241 $1723 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1724 $1725 $1661 $1464 forward $1726 $-1 #
+edge $-1 -1 -1 $-1 $1467 -5 $1290 8.8817841970012523e-16 $1463 $1727 forward @7 unknown T 14.999999999999998 -35 -5 15.000000000000004 -35 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $1243 $1286 $1724 $1539 reversed $1287 $-1 #
+coedge $-1 -1 -1 $-1 $1655 $1244 $1725 $1728 reversed $1058 $-1 #
+vertex $-1 -1 -1 $-1 $1481 $1729 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $1730 $1731 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -9.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1249 $1248 $1242 $1464 forward $1052 $-1 #
+coedge $-1 -1 -1 $-1 $1732 $1295 $1249 $1297 forward $1544 $-1 #
+edge $-1 -1 -1 $-1 $1251 -1.5707963267948966 $1469 -6.1232339957367648e-17 $1256 $1733 forward @7 unknown T 14.999999999999996 -40 -15 19.999999999999996 -35 -9.9999999999999982 #
+point $-1 -1 -1 $-1 19.999999999999996 -40 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $1734 $1735 $11 $-1 $1477 reversed single T 14.999999999999996 -20 5.0000000000000009 22.500000000000004 -15 20 F #
+loop $-1 -1 -1 $-1 $-1 $1736 $1254 T 15 -20 20 22.500000000000004 -15 35 unknown #
+cone-surface $-1 -1 -1 $-1 20 -20 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $1707 $1737 $1738 $1654 forward $1255 $-1 #
+coedge $-1 -1 -1 $-1 $1257 $1256 $1739 $1740 reversed $881 $-1 #
+coedge $-1 -1 -1 $-1 $1741 $1661 $1257 $1481 forward $1416 $-1 #
+edge $-1 -1 -1 $-1 $1467 3.1415926535897931 $1742 4.7123889803846897 $1480 $1743 forward @7 unknown T 10 -40 -10 15 -35 -5 #
+coedge $-1 -1 -1 $-1 $1259 $1417 $1408 $1654 forward $1210 $-1 #
+face $-1 -1 -1 $-1 $1744 $1745 $11 $-1 $704 reversed single T 29.999999999999996 -25.000000000000004 -9.9999999999999982 37.500000000000007 -20 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $1746 $1261 T 29.999999999999996 -25.000000000000004 -24.999999999999996 37.500000000000007 -20 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $1747 $1748 $1749 $1750 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $1751 $1263 $1752 $1753 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $1263 $1754 $1755 $1756 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $1757 $1758 $1263 $1490 forward $1759 $-1 #
+edge $-1 -1 -1 $-1 $1760 -1.5707963267948966 $1761 -6.4931039580273226e-16 $1489 $1762 forward @7 unknown T 29.999999999999996 -20 -9.9999999999999982 35 -15.000000000000004 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $1763 $1264 $1764 $1765 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $1766 $1767 $1264 $1493 forward $1768 $-1 #
+edge $-1 -1 -1 $-1 $1769 -2.0943951023931966 $1500 -1.5707963267948966 $1492 $1770 forward @7 unknown T 35 -15.669872981077814 5.0000000000000018 37.500000000000007 -15.000000000000004 7.5000000000000107 #
+coedge $-1 -1 -1 $-1 $1265 $1763 $1275 $1521 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $1771 $1772 $1773 $1496 forward $1774 $-1 #
+edge $-1 -1 -1 $-1 $1501 10.000000000000002 $1775 15 $1495 $1776 forward @7 unknown T 29.999999999999996 -20 10.000000000000002 30 -20 15 #
+coedge $-1 -1 -1 $-1 $1777 $1266 $1772 $1778 reversed $1499 $-1 #
+coedge $-1 -1 -1 $-1 $1266 $1777 $1754 $1779 forward $1499 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1266 $1780 T 25 -20 1.7763568394002505e-15 35 -15 10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $1779 $1781 #
+vertex $-1 -1 -1 $-1 $1782 $1783 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $1271 $1268 $1784 $1785 reversed $703 $-1 #
+coedge $-1 -1 -1 $-1 $1786 $1787 $1268 $1505 forward $1788 $-1 #
+edge $-1 -1 -1 $-1 $1789 -32.499999999999993 $1509 -22.500000000000011 $1504 $1790 forward @7 unknown T 37.499999999999986 -15.669872981077814 22.500000000000011 37.500000000000007 -15.669872981077805 32.499999999999993 #
+coedge $-1 -1 -1 $-1 $1791 $1269 $1763 $1792 forward $1508 $-1 #
+coedge $-1 -1 -1 $-1 $1269 $1791 $1786 $1793 reversed $1508 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1269 $1794 T 35 -15.669872981077814 17.500000000000004 40.000000000000007 -15 22.500000000000011 unknown #
+vertex $-1 -1 -1 $-1 $1793 $1795 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1796 $1797 $1271 $1512 forward $1798 $-1 #
+edge $-1 -1 -1 $-1 $1517 6.4931039580273265e-16 $1799 1.5707963267948966 $1511 $1800 forward @7 unknown T 30 -20 30 35 -15.000000000000004 35 #
+coedge $-1 -1 -1 $-1 $1801 $1272 $1797 $1802 forward $1516 $-1 #
+coedge $-1 -1 -1 $-1 $1272 $1803 $1274 $1520 forward $1516 $-1 #
+coedge $-1 -1 -1 $-1 $1804 $1805 $1806 $1273 reversed $1807 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1272 $1808 T 22.499999999999996 -20 20 30 -15 35 unknown #
+vertex $-1 -1 -1 $-1 $1802 $1809 #
+straight-curve $-1 -1 -1 $-1 30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1275 $1274 $1771 $1810 reversed $1276 $-1 #
+edge $-1 -1 -1 $-1 $1811 1.5707963267948966 $1278 3.1415926535897931 $1514 $1812 forward @7 unknown T 25 -20 20 29.999999999999996 -15 25 #
+edge $-1 -1 -1 $-1 $1775 6.4931039580273206e-16 $1277 1.5707963267948966 $1275 $1813 forward @7 unknown T 29.999999999999996 -20 15 35 -15.000000000000004 20.000000000000004 #
+face $-1 -1 -1 $-1 $1814 $1276 $11 $-1 $1815 reversed single T 25 -20 15 35 -15 25.000000000000007 F #
+point $-1 -1 -1 $-1 35 -15.000000000000004 20.000000000000004 #
+edge $-1 -1 -1 $-1 $1278 3.1415926535897931 $1816 4.7123889803846897 $1804 $1812 forward @7 unknown T 25 -25 20 29.999999999999996 -20 25 #
+point $-1 -1 -1 $-1 29.999999999999996 -20 25 #
+loop $-1 -1 -1 $-1 $1685 $1280 $1558 T 50 -40 2.6645352591003757e-15 50 -30 10.000000000000004 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1281 $1817 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 5.0000000000000027 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $1040 $1818 $11 $-1 $1445 reversed single T -7.5000000000000036 -35 5 0 -30 20 F #
+loop $-1 -1 -1 $-1 $1819 $1820 $1282 T -45 -40 -3.5527136788005009e-15 -40 -30 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $1821 $1822 $1823 $1824 forward $1283 $-1 #
+coedge $-1 -1 -1 $-1 $1284 $1825 $1286 $1535 forward $1533 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1284 $1826 T 7.4999999999999956 -35 5.0000000000000009 15 -30 20 unknown #
+edge $-1 -1 -1 $-1 $1827 1.5707963267948966 $1288 3.1415926535897931 $1532 $1828 forward @7 unknown T 9.9999999999999982 -35 5.0000000000000009 14.999999999999996 -30 10 #
+face $-1 -1 -1 $-1 $1829 $1287 $11 $-1 $227 reversed single T 9.9999999999999982 -35 -9.3734986416366032e-33 19.999999999999996 -30 10 F #
+edge $-1 -1 -1 $-1 $1288 3.1415926535897931 $1830 4.7123889803846897 $1351 $1828 forward @7 unknown T 10 -40 5.0000000000000009 14.999999999999996 -35 10 #
+point $-1 -1 -1 $-1 14.999999999999996 -35 10 #
+edge $-1 -1 -1 $-1 $1290 0 $1827 1.5707963267948966 $1724 $1831 forward @7 unknown T 10 -35 8.8817841970012523e-16 15.000000000000004 -30 5.0000000000000009 #
+point $-1 -1 -1 $-1 15.000000000000004 -35 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $1832 $1662 $1664 $1666 forward $1292 $-1 #
+coedge $-1 -1 -1 $-1 $1293 $1656 $1833 $1834 reversed $1078 $-1 #
+coedge $-1 -1 -1 $-1 $1295 $1732 $1351 $1537 reversed $1544 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1295 $1829 T 10 -40 -9.3734986416366032e-33 19.999999999999996 -35 10 unknown #
+edge $-1 -1 -1 $-1 $1549 -1.5707963267948966 $1132 0 $1352 $1551 forward @7 unknown T 10 -40 15 15 -35 20 #
+coedge $-1 -1 -1 $-1 $1835 $1300 $1836 $1837 forward $949 $-1 #
+vertex $-1 -1 -1 $-1 $1838 $1839 #
+coedge $-1 -1 -1 $-1 $1840 $1303 $1841 $1556 forward $1533 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1305 $1380 $1842 $1843 forward $1306 $-1 #
+coedge $-1 -1 -1 $-1 $1844 $1841 $1305 $1554 reversed $1845 $-1 #
+edge $-1 -1 -1 $-1 $1846 4.1887902047863896 $1307 4.7123889803846897 $1305 $1847 forward @7 unknown T 7.4999999999999947 -30.669872981077813 20 10 -30 22.500000000000007 #
+face $-1 -1 -1 $-1 $1848 $1306 $11 $-1 $950 reversed single T 7.4999999999999947 -35 20 15 -30 35 F #
+edge $-1 -1 -1 $-1 $1307 -1.5707963267948966 $1849 -1.0471975511965974 $1550 $1850 forward @7 unknown T 7.4999999999999982 -30.669872981077809 17.499999999999996 10 -30 20 #
+point $-1 -1 -1 $-1 10 -30 20 #
+face $-1 -1 -1 $-1 $-1 $1318 $11 $-1 $1559 reversed single T 50 -50 -50 50 50 50 F #
+plane-surface $-1 -1 -1 $-1 50 0 0 -1 0 0 0 -0 1 forward_v I I I I #
+point $-1 -1 -1 $-1 50 -35 15.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $1851 $1314 T -7.5000000000000027 -35 20 0 -30 35 unknown #
+loop $-1 -1 -1 $-1 $-1 $1852 $1098 T -50 -40 14.999999999999996 -50 -30 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $1853 $1853 $1854 $1855 forward $1315 $-1 #
+coedge $-1 -1 -1 $-1 $1856 $1316 $1857 $1858 reversed $1099 $-1 #
+coedge $-1 -1 -1 $-1 $1316 $1856 $1859 $1860 forward $1099 $-1 #
+coedge $-1 -1 -1 $-1 $1861 $1862 $1316 $1567 reversed $1863 $-1 #
+edge $-1 -1 -1 $-1 $1864 1.5707963267948966 $1865 2.0943951023931948 $1316 $1866 forward @7 unknown T -10.000000000000002 -40 20 -7.5000000000000027 -39.330127018922191 22.500000000000004 #
+point $-1 -1 -1 $-1 50 -35 30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $1867 $1321 T -7.5000000000000018 -35 35 0 -30 50 unknown #
+loop $-1 -1 -1 $-1 $-1 $1868 $1103 T -50 -40 29.999999999999996 -50 -30 40 unknown #
+coedge $-1 -1 -1 $-1 $1869 $1869 $1870 $1871 forward $1322 $-1 #
+coedge $-1 -1 -1 $-1 $1872 $1323 $1873 $1874 reversed $1104 $-1 #
+coedge $-1 -1 -1 $-1 $1323 $1872 $1875 $1876 forward $1104 $-1 #
+coedge $-1 -1 -1 $-1 $1877 $1878 $1323 $1575 reversed $1879 $-1 #
+edge $-1 -1 -1 $-1 $1880 1.5707963267948966 $1881 2.0943951023931957 $1323 $1882 forward @7 unknown T -10.000000000000002 -40 35 -7.5000000000000009 -39.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $1324 $1609 $1678 $1436 forward $1130 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 30 -35 -45 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -40 -40 #
+coedge $-1 -1 -1 $-1 $1333 $1883 $1884 $1885 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $1886 -2.0943951023931957 $1389 0 $1333 $1887 forward @7 unknown T 7.4999999999999991 -35 50 15 -30 50 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $1888 $1336 $1586 $1635 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $1123 2.6179938779914931 $1389 4.7123889803846897 $1336 $1889 forward @7 unknown T 14.999999999999996 -40 50 22.5 -35 50 #
+coedge $-1 -1 -1 $-1 $1337 $1620 $1584 $1635 reversed $1120 $-1 #
+loop $-1 -1 -1 $-1 $1890 $1891 $1122 T -45 4.9999999999999982 50 45 15.000000000000002 50 unknown #
+coedge $-1 -1 -1 $-1 $1892 $1893 $1894 $1895 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $1896 $1339 $1897 $1898 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $1339 $1899 $1900 $1901 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $1902 $1903 $1339 $1592 reversed $1904 $-1 #
+edge $-1 -1 -1 $-1 $1905 -1.5707963267948957 $1906 0.5235987755982987 $1339 $1907 forward @7 unknown T 30 -20 50 37.5 -15.000000000000004 50 #
+face $-1 -1 -1 $-1 $1908 $1909 $11 $-1 $388 reversed single T -10.000000000000002 -30.669872981077813 32.5 -5 -30 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $1910 $1340 T -22.500000000000004 -40 35 -15 -35 50 unknown #
+cone-surface $-1 -1 -1 $-1 -20 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+loop $-1 -1 -1 $-1 $-1 $1604 $1345 T 14.999999999999996 -35 -50 22.5 -30 -40 unknown #
+coedge $-1 -1 -1 $-1 $1911 $1912 $1913 $1914 forward $1346 $-1 #
+coedge $-1 -1 -1 $-1 $1347 $1835 $1915 $1623 forward $949 $-1 #
+face $-1 -1 -1 $-1 $1916 $1424 $11 $-1 $756 reversed single T 19.999999999999996 -30.669872981077809 -42.5 25 -30 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $1917 $1349 T 10 -35 -45 19.999999999999996 -30 -35 unknown #
+coedge $-1 -1 -1 $-1 $1918 $1919 $1920 $1921 forward $1350 $-1 #
+coedge $-1 -1 -1 $-1 $1922 $1351 $1923 $1924 forward $954 $-1 #
+coedge $-1 -1 -1 $-1 $1352 $1922 $1925 $1838 forward $954 $-1 #
+coedge $-1 -1 -1 $-1 $1926 $1927 $1359 $1605 reversed $1596 $-1 #
+edge $-1 -1 -1 $-1 $1676 42.5 $1607 50 $1359 $1928 forward @7 unknown T 22.499999999999993 -30.669872981077809 -50 22.5 -30.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $1929 $1360 $1927 $1930 forward $1370 $-1 #
+vertex $-1 -1 -1 $-1 $1605 $1931 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1576 $1362 $1932 $1933 forward $1130 $-1 #
+coedge $-1 -1 -1 $-1 $1369 $1934 $1362 $1611 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $1935 -2.0943951023931957 $1363 0 $1610 $1608 forward @7 unknown T 22.5 -40 -50 30 -35 -50 #
+point $-1 -1 -1 $-1 30 -35 -50 #
+edge $-1 -1 -1 $-1 $1407 -1.5707963267948966 $1394 -1.0471975511965983 $1365 $1367 forward @7 unknown T 37.5 -30.669872981077805 -42.5 40 -30 -40 #
+ellipse-curve $-1 -1 -1 $-1 40 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $1936 $1937 $1616 T -45 -25.000000000000004 -50 45 -14.999999999999996 -50 unknown #
+face $-1 -1 -1 $-1 $1938 $1370 $11 $-1 $1939 reversed single T -50 -50 -50 50 50 -50 F #
+point $-1 -1 -1 $-1 37.5 -30.669872981077805 -50 #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1586 $1378 $1940 $1941 forward $1120 $-1 #
+coedge $-1 -1 -1 $-1 $1915 $1942 $1378 $1622 reversed $1943 $-1 #
+edge $-1 -1 -1 $-1 $1379 1.5707963267948966 $1944 2.0943951023931957 $1378 $1631 forward @7 unknown T 7.4999999999999991 -40 35 10 -39.330127018922191 37.500000000000007 #
+edge $-1 -1 -1 $-1 $1945 1.0471975511965979 $1379 1.5707963267948966 $1598 $1634 forward @7 unknown T 7.4999999999999982 -40 32.5 10 -39.330127018922191 35 #
+point $-1 -1 -1 $-1 10 -40 35 #
+coedge $-1 -1 -1 $-1 $1384 $1946 $1380 $1387 reversed $1629 $-1 #
+coedge $-1 -1 -1 $-1 $1884 $1947 $1383 $1627 reversed $1948 $-1 #
+edge $-1 -1 -1 $-1 $1886 -50 $1630 -37.500000000000007 $1383 $1949 forward @7 unknown T 7.4999999999999982 -30.669872981077813 37.500000000000007 7.4999999999999991 -30.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $1946 $1384 $1947 $1950 forward $1629 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1628 $1951 T 4.9999999999999982 -30.669872981077813 32.5 10 -30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $1385 $1952 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $1555 $1953 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 35 0 -35 50 F #
+vertex $-1 -1 -1 $-1 $1843 $1954 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $1389 0 $1955 2.0943951023931957 $1584 $1887 forward @7 unknown T 7.4999999999999991 -40 50 15 -35 50 #
+point $-1 -1 -1 $-1 14.999999999999998 -35 50 #
+point $-1 -1 -1 $-1 37.500000000000007 -30.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $1640 $1640 $1399 $1641 forward $1956 $-1 #
+edge $-1 -1 -1 $-1 $1957 0 $1957 6.2831853071795862 $1640 $1958 forward @7 unknown T 50 -40 -29.999999999999996 50 -30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $1959 $1960 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 -25 8.8817841970012523e-16 -35 -10 F #
+loop $-1 -1 -1 $-1 $1961 $1962 $1400 T -45 -40 -30.000000000000004 -40 -30 -20.000000000000004 unknown #
+face $-1 -1 -1 $-1 $1963 $1964 $11 $-1 $1965 reversed single T 40 -25 30 50 -15 40 F #
+loop $-1 -1 -1 $-1 $1966 $1967 $1401 T -45 -40 -45 -40 -30 -35 unknown #
+coedge $-1 -1 -1 $-1 $1968 $1969 $1970 $1971 forward $1402 $-1 #
+coedge $-1 -1 -1 $-1 $1972 $1403 $1973 $1974 reversed $1188 $-1 #
+coedge $-1 -1 -1 $-1 $1403 $1972 $1975 $1976 forward $1188 $-1 #
+coedge $-1 -1 -1 $-1 $1977 $1978 $1403 $1650 reversed $1979 $-1 #
+edge $-1 -1 -1 $-1 $1980 1.5707963267948966 $1981 2.0943951023931953 $1403 $1982 forward @7 unknown T -10.000000000000002 -40 -40 -7.5000000000000027 -39.330127018922191 -37.5 #
+coedge $-1 -1 -1 $-1 $1651 $1651 $1404 $1652 forward $1983 $-1 #
+edge $-1 -1 -1 $-1 $1984 0 $1984 6.2831853071795862 $1651 $1985 forward @7 unknown T 50 -40 -45 50 -30 -35 #
+point $-1 -1 -1 $-1 40 -30 -40 #
+edge $-1 -1 -1 $-1 $1657 -20 $1469 -15 $1478 $1986 forward @7 unknown T 14.999999999999998 -35 -20 15 -35 -15 #
+coedge $-1 -1 -1 $-1 $1409 $1466 $1707 $1730 reversed $1058 $-1 #
+coedge $-1 -1 -1 $-1 $1542 $1410 $1737 $1987 reversed $1078 $-1 #
+vertex $-1 -1 -1 $-1 $1988 $1989 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $1834 $1990 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1480 $1991 $1471 $1464 reversed $1416 $-1 #
+coedge $-1 -1 -1 $-1 $1541 $1992 $1417 $1663 forward $1292 $-1 #
+edge $-1 -1 -1 $-1 $1657 6.1232339957367648e-17 $1420 1.570796326794897 $1662 $1993 forward @7 unknown T 14.999999999999996 -40 -25 20 -35 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $1418 $1994 $1541 $1666 reversed $1439 $-1 #
+edge $-1 -1 -1 $-1 $1420 -1.5707963267948961 $1659 -6.1232339957367648e-17 $1541 $1995 forward @7 unknown T 14.999999999999996 -40 -30 19.999999999999996 -35 -25 #
+point $-1 -1 -1 $-1 19.999999999999996 -40 -25 #
+coedge $-1 -1 -1 $-1 $1423 $1422 $1926 $1996 forward $1424 $-1 #
+coedge $-1 -1 -1 $-1 $1997 $1917 $1426 $1670 forward $1600 $-1 #
+edge $-1 -1 -1 $-1 $1671 -1.5707963267948966 $1998 6.1232339957367648e-17 $1669 $1999 forward @7 unknown T 14.999999999999996 -35 -40 19.999999999999996 -30 -35 #
+vertex $-1 -1 -1 $-1 $2000 $2001 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1833 $2002 $2003 $1674 forward $2004 $-1 #
+edge $-1 -1 -1 $-1 $1998 -35 $1659 -30 $1673 $2005 forward @7 unknown T 14.999999999999998 -35 -35 15 -35 -30 #
+face $-1 -1 -1 $-1 $2006 $1439 $11 $-1 $943 reversed single T 14.999999999999996 -40 -40 22.500000000000007 -35 -25 F #
+vertex $-1 -1 -1 $-1 $1996 $2007 #
+ellipse-curve $-1 -1 -1 $-1 25 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2008 $1433 $1576 $1436 reversed $1680 $-1 #
+coedge $-1 -1 -1 $-1 $1433 $2008 $1438 $1683 forward $1680 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2008 $1916 T 19.999999999999996 -40 -42.500000000000007 25 -39.330127018922184 -37.499999999999986 unknown #
+vertex $-1 -1 -1 $-1 $1436 $2009 #
+coedge $-1 -1 -1 $-1 $1994 $1438 $1919 $2010 reversed $1439 $-1 #
+edge $-1 -1 -1 $-1 $2011 1.5707963267948966 $1440 2.0943951023931966 $1679 $2012 forward @7 unknown T 19.999999999999996 -40 -40 22.5 -39.330127018922191 -37.499999999999986 #
+point $-1 -1 -1 $-1 22.499999999999993 -39.330127018922191 -37.499999999999986 #
+loop $-1 -1 -1 $-1 $1956 $1442 $1558 T 50 -40 -14.999999999999996 50 -30 -4.9999999999999964 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1443 $2013 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 -9.9999999999999964 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $2014 $2015 $2016 $2017 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $1689 $1689 $2018 $2019 reversed $1446 $-1 #
+coedge $-1 -1 -1 $-1 $1447 $1447 $2020 $2021 forward $1236 $-1 #
+coedge $-1 -1 -1 $-1 $2022 $2023 $1447 $1692 reversed $2024 $-1 #
+edge $-1 -1 -1 $-1 $2025 -1.5707963267948966 $2026 1.5707963267948966 $1447 $2027 forward @7 unknown T -45 -40 -15.000000000000002 -40 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $1449 $1448 $2028 $2029 reversed $1042 $-1 #
+coedge $-1 -1 -1 $-1 $2030 $2031 $1448 $1695 forward $2032 $-1 #
+edge $-1 -1 -1 $-1 $2033 1.5707963267948966 $1702 2.0943951023931948 $1694 $2034 forward @7 unknown T -7.5000000000000027 -40 -10 -5 -39.330127018922198 -7.5 #
+coedge $-1 -1 -1 $-1 $2035 $2036 $1449 $1697 reversed $2037 $-1 #
+edge $-1 -1 -1 $-1 $2038 -2.0943951023931948 $1701 -1.5707963267948966 $1449 $2039 forward @7 unknown T -10.000000000000002 -40 -12.500000000000004 -7.5000000000000027 -39.330127018922198 -10 #
+coedge $-1 -1 -1 $-1 $2040 $1450 $2041 $2042 reversed $1700 $-1 #
+coedge $-1 -1 -1 $-1 $1450 $2043 $2030 $2044 reversed $1700 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1450 $2045 T -15.000000000000002 -40 -10 -7.5000000000000009 -35 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $2046 $2047 #
+vertex $-1 -1 -1 $-1 $1451 $2048 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1725 $2049 $1452 $1705 forward $1726 $-1 #
+edge $-1 -1 -1 $-1 $1713 4.1887902047863905 $1708 4.7123889803846897 $1704 $2050 forward @7 unknown T 7.4999999999999982 -30.669872981077809 -10 10 -30 -7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $2051 $1453 $1458 $1719 forward $1255 $-1 #
+coedge $-1 -1 -1 $-1 $1453 $1478 $1655 $1730 forward $1255 $-1 #
+vertex $-1 -1 -1 $-1 $1454 $2052 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -10 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2053 $1455 $2049 $2054 reversed $1712 $-1 #
+coedge $-1 -1 -1 $-1 $1455 $2055 $2056 $2057 reversed $1712 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1711 $2058 T -1.7763568394002505e-15 -35 -10 7.4999999999999991 -30 5 unknown #
+vertex $-1 -1 -1 $-1 $1705 $2059 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1720 $1457 $2060 $2061 reversed $1459 $-1 #
+coedge $-1 -1 -1 $-1 $2056 $2062 $1457 $1717 forward $2063 $-1 #
+edge $-1 -1 -1 $-1 $2064 -6.1232339957367648e-17 $1460 1.5707963267948966 $1716 $2065 forward @7 unknown T -1.7763568394002505e-15 -35 -15 4.9999999999999982 -30 -10 #
+coedge $-1 -1 -1 $-1 $1458 $1720 $2066 $2067 reversed $1459 $-1 #
+edge $-1 -1 -1 $-1 $1461 12.500000000000002 $2068 22.500000000000004 $1706 $2069 forward @7 unknown T 7.4999999999999982 -30.669872981077813 -22.500000000000004 7.4999999999999991 -30.669872981077805 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $1718 $1715 $2070 $2071 reversed $1459 $-1 #
+face $-1 -1 -1 $-1 $2072 $1459 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 -25 7.4999999999999991 -30 -10 F #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 -10 #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $2074 $1463 $1465 $1539 forward $1726 $-1 #
+coedge $-1 -1 -1 $-1 $1463 $1704 $1466 $1728 forward $1726 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1463 $2075 T 7.4999999999999973 -35 -10 15.000000000000004 -30 5.0000000000000009 unknown #
+edge $-1 -1 -1 $-1 $1708 1.5707963267948966 $1467 3.1415926535897931 $1725 $1743 forward @7 unknown T 10 -35 -10 15 -30 -5 #
+point $-1 -1 -1 $-1 15 -35 -5 #
+edge $-1 -1 -1 $-1 $1469 0 $1708 1.5707963267948966 $1707 $2076 forward @7 unknown T 10 -35 -15 15 -30 -10 #
+point $-1 -1 -1 $-1 15 -35 -15 #
+coedge $-1 -1 -1 $-1 $1543 $1472 $1991 $2077 reversed $1544 $-1 #
+face $-1 -1 -1 $-1 $2078 $2079 $11 $-1 $1477 reversed single T 15 -20 -9.9999999999999982 22.500000000000004 -15 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $2080 $1475 T 14.999999999999996 -20 5.0000000000000009 22.500000000000004 -15 20 unknown #
+coedge $-1 -1 -1 $-1 $2081 $2082 $2083 $2084 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $1478 $2051 $1656 $1987 forward $1255 $-1 #
+coedge $-1 -1 -1 $-1 $2085 $1739 $1483 $1654 reversed $2086 $-1 #
+coedge $-1 -1 -1 $-1 $1738 $2087 $1479 $1740 forward $2086 $-1 #
+edge $-1 -1 -1 $-1 $1742 -1.5707963267948966 $1469 0 $1739 $2076 forward @7 unknown T 10 -40 -15 15 -35 -10 #
+coedge $-1 -1 -1 $-1 $2088 $1480 $2089 $2090 forward $1416 $-1 #
+vertex $-1 -1 -1 $-1 $2091 $2092 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -10 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $2093 $2094 $11 $-1 $704 reversed single T 29.999999999999996 -25.000000000000004 5.0000000000000018 37.500000000000014 -20 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $2095 $1484 T 29.999999999999996 -25.000000000000004 -9.9999999999999982 37.500000000000007 -20 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $2096 $2097 $2098 $2099 reversed $1485 $-1 #
+coedge $-1 -1 -1 $-1 $2100 $1486 $2101 $2102 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $1486 $2103 $2104 $2105 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $2106 $2107 $1486 $1750 forward $2108 $-1 #
+edge $-1 -1 -1 $-1 $2109 -1.5707963267948966 $2110 -6.4931039580273265e-16 $1749 $2111 forward @7 unknown T 29.999999999999996 -20 -24.999999999999996 35 -15.000000000000004 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $2112 $1487 $2113 $2114 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $2115 $2116 $1487 $1753 forward $2117 $-1 #
+edge $-1 -1 -1 $-1 $2118 -2.0943951023931957 $1760 -1.5707963267948966 $1752 $2119 forward @7 unknown T 35 -15.669872981077813 -9.9999999999999982 37.5 -15.000000000000004 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $1488 $2112 $1498 $1779 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $2120 $2121 $2122 $1756 forward $2123 $-1 #
+edge $-1 -1 -1 $-1 $1761 -4.9999999999999982 $2124 1.7763568394002505e-15 $1755 $2125 forward @7 unknown T 29.999999999999996 -20 -4.9999999999999982 30 -20 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $2126 $1489 $2121 $2127 reversed $1759 $-1 #
+coedge $-1 -1 -1 $-1 $1489 $2126 $2103 $2128 forward $1759 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1489 $2129 T 25 -20 -15 35 -15 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $2128 $2130 #
+vertex $-1 -1 -1 $-1 $2131 $2132 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1494 $1491 $1506 $1792 reversed $886 $-1 #
+coedge $-1 -1 -1 $-1 $2133 $2134 $1491 $1765 forward $2135 $-1 #
+edge $-1 -1 -1 $-1 $2136 -17.500000000000007 $1769 -7.5000000000000107 $1764 $2137 forward @7 unknown T 37.499999999999986 -15.669872981077814 7.5000000000000107 37.500000000000007 -15.669872981077805 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $2138 $1492 $2112 $2139 forward $1768 $-1 #
+coedge $-1 -1 -1 $-1 $1492 $2138 $2133 $2140 reversed $1768 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1492 $2141 T 35 -15.669872981077814 2.5000000000000018 40.000000000000007 -15 7.5000000000000107 unknown #
+vertex $-1 -1 -1 $-1 $2140 $2142 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2143 $1495 $1519 $1810 forward $1774 $-1 #
+coedge $-1 -1 -1 $-1 $1495 $2144 $1497 $1778 forward $1774 $-1 #
+coedge $-1 -1 -1 $-1 $2145 $2146 $2147 $1496 reversed $2148 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1495 $2149 T 22.5 -20 5.0000000000000018 30 -15 20 unknown #
+vertex $-1 -1 -1 $-1 $1810 $2150 #
+coedge $-1 -1 -1 $-1 $1498 $1497 $2120 $2151 reversed $1499 $-1 #
+edge $-1 -1 -1 $-1 $2152 1.570796326794897 $1501 3.1415926535897931 $1772 $2153 forward @7 unknown T 25 -20 5.0000000000000018 29.999999999999996 -15 10.000000000000002 #
+edge $-1 -1 -1 $-1 $2124 6.4931039580273226e-16 $1500 1.5707963267948966 $1498 $2154 forward @7 unknown T 29.999999999999996 -20 1.7763568394002505e-15 35 -15.000000000000004 5.0000000000000018 #
+face $-1 -1 -1 $-1 $2155 $1499 $11 $-1 $2156 reversed single T 25 -20 1.7763568394002505e-15 35 -15 10.000000000000002 F #
+point $-1 -1 -1 $-1 35 -15.000000000000004 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $1501 3.1415926535897931 $2157 4.7123889803846897 $2145 $2153 forward @7 unknown T 24.999999999999996 -25 5.0000000000000018 29.999999999999996 -20 10.000000000000002 #
+point $-1 -1 -1 $-1 29.999999999999996 -20 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $2158 $2159 $1503 $1785 forward $2160 $-1 #
+edge $-1 -1 -1 $-1 $1799 1.5707963267948966 $1789 2.0943951023931939 $1784 $2161 forward @7 unknown T 35 -15.669872981077807 32.499999999999993 37.499999999999993 -15.000000000000004 35 #
+coedge $-1 -1 -1 $-1 $2162 $1504 $1507 $1793 forward $1788 $-1 #
+coedge $-1 -1 -1 $-1 $1504 $2163 $2158 $2164 forward $1788 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1504 $2165 T 37.499999999999986 -25 20.000000000000004 45 -15 35 unknown #
+vertex $-1 -1 -1 $-1 $1505 $2166 #
+straight-curve $-1 -1 -1 $-1 37.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $1507 $1506 $2134 $2167 reversed $1508 $-1 #
+edge $-1 -1 -1 $-1 $1277 1.5707963267948966 $2136 2.094395102393193 $1506 $2168 forward @7 unknown T 35 -15.669872981077805 17.500000000000007 37.499999999999986 -15.000000000000004 20.000000000000004 #
+edge $-1 -1 -1 $-1 $1509 4.1887902047863896 $2169 4.7123889803846897 $1786 $2170 forward @7 unknown T 37.5 -15.669872981077814 20.000000000000004 40.000000000000007 -15 22.500000000000011 #
+face $-1 -1 -1 $-1 $2171 $1508 $11 $-1 $1815 reversed single T 35 -15.669872981077814 17.500000000000004 40.000000000000007 -15 22.500000000000011 F #
+point $-1 -1 -1 $-1 37.500000000000007 -15.669872981077814 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $2172 $1511 $2173 $2174 forward $1798 $-1 #
+coedge $-1 -1 -1 $-1 $1511 $2172 $1513 $1802 reversed $1798 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1796 $2175 T 25 -20 30 35 -15 40 unknown #
+vertex $-1 -1 -1 $-1 $1512 $2176 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2177 $1513 $2178 $2179 forward $1516 $-1 #
+edge $-1 -1 -1 $-1 $1517 0 $2180 1.5707963267948966 $1513 $2181 forward @7 unknown T 25 -20 30 30 -15 35 #
+coedge $-1 -1 -1 $-1 $1514 $2177 $2182 $2183 forward $1516 $-1 #
+coedge $-1 -1 -1 $-1 $2184 $1515 $2185 $1524 forward $1807 $-1 #
+coedge $-1 -1 -1 $-1 $1515 $2186 $2187 $2188 forward $1807 $-1 #
+coedge $-1 -1 -1 $-1 $2189 $2190 $1067 $1273 forward $2191 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1515 $2192 T 22.499999999999993 -25 19.999999999999996 30 -20 35 unknown #
+face $-1 -1 -1 $-1 $2193 $1516 $11 $-1 $2194 reversed single T 22.499999999999996 -20 20 30 -15 35 F #
+point $-1 -1 -1 $-1 30 -20 30 #
+edge $-1 -1 -1 $-1 $1775 0 $1811 1.5707963267948961 $1771 $2195 forward @7 unknown T 25 -20 15 29.999999999999996 -15 20 #
+vertex $-1 -1 -1 $-1 $2196 $2197 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2198 $2199 $11 $-1 $1815 reversed single T 25 -25.000000000000004 15 35 -20 25.000000000000007 F #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 -20 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $2200 $2201 #
+point $-1 -1 -1 $-1 50 -35 3.0616169978683823e-15 #
+loop $-1 -1 -1 $-1 $-1 $2202 $1529 T -7.5000000000000036 -35 5 0 -30 20 unknown #
+loop $-1 -1 -1 $-1 $-1 $2203 $1282 T -50 -40 -3.0616169978683823e-15 -50 -30 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $2204 $2204 $2205 $2206 forward $1530 $-1 #
+coedge $-1 -1 -1 $-1 $2207 $1531 $2208 $2209 reversed $1283 $-1 #
+coedge $-1 -1 -1 $-1 $1531 $2207 $2043 $2210 forward $1283 $-1 #
+coedge $-1 -1 -1 $-1 $2211 $2212 $1531 $1824 reversed $2213 $-1 #
+edge $-1 -1 -1 $-1 $2214 1.5707963267948966 $2215 2.0943951023931948 $1531 $2216 forward @7 unknown T -10.000000000000002 -40 4.9999999999999991 -7.5000000000000027 -39.330127018922198 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $1532 $1840 $2217 $2218 forward $1533 $-1 #
+face $-1 -1 -1 $-1 $2219 $1533 $11 $-1 $950 reversed single T 7.4999999999999956 -35 5.0000000000000009 15 -30 20 F #
+vertex $-1 -1 -1 $-1 $2220 $2221 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -35 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $904 $1544 $11 $-1 $227 reversed single T 10 -40 -9.3734986416366032e-33 19.999999999999996 -35 10 F #
+vertex $-1 -1 -1 $-1 $2222 $2223 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -35 5.0000000000000009 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1992 $1541 $2224 $2225 reversed $1292 $-1 #
+coedge $-1 -1 -1 $-1 $2226 $1673 $1542 $1834 forward $2004 $-1 #
+edge $-1 -1 -1 $-1 $1659 0 $2227 1.5707963267948966 $1833 $2228 forward @7 unknown T 10 -35 -30 15 -30 -25 #
+coedge $-1 -1 -1 $-1 $1598 $1548 $2229 $2230 forward $949 $-1 #
+coedge $-1 -1 -1 $-1 $1925 $2231 $1548 $1837 reversed $2232 $-1 #
+edge $-1 -1 -1 $-1 $1549 1.5707963267948966 $2233 2.0943951023931948 $1548 $1847 forward @7 unknown T 7.5 -40 20 10 -39.330127018922191 22.500000000000004 #
+edge $-1 -1 -1 $-1 $2234 1.0471975511965974 $1549 1.5707963267948966 $1603 $1850 forward @7 unknown T 7.4999999999999982 -40 17.499999999999996 10 -39.330127018922191 20 #
+point $-1 -1 -1 $-1 10 -40 20 #
+coedge $-1 -1 -1 $-1 $1825 $1550 $2235 $2236 forward $1533 $-1 #
+coedge $-1 -1 -1 $-1 $1553 $2237 $1550 $1556 reversed $1845 $-1 #
+coedge $-1 -1 -1 $-1 $2238 $2239 $1552 $1843 reversed $2240 $-1 #
+edge $-1 -1 -1 $-1 $1633 -32.5 $1846 -22.500000000000004 $1552 $2241 forward @7 unknown T 7.4999999999999982 -30.669872981077813 22.500000000000004 7.4999999999999991 -30.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $2237 $1553 $2239 $2242 forward $1845 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1844 $2243 T 4.9999999999999982 -30.669872981077813 17.499999999999996 10 -30 22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $1554 $2244 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2245 $2246 $11 $-1 $388 reversed single T -5 -35 30 4.9999999999999982 -30 40 F #
+vertex $-1 -1 -1 $-1 $2236 $2247 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2248 $2249 $2250 $2251 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $1852 $1852 $2252 $2253 reversed $1562 $-1 #
+coedge $-1 -1 -1 $-1 $1563 $1563 $2254 $2255 forward $1315 $-1 #
+coedge $-1 -1 -1 $-1 $2256 $2257 $1563 $1855 reversed $2258 $-1 #
+edge $-1 -1 -1 $-1 $2259 -1.5707963267948966 $2260 1.5707963267948966 $1563 $2261 forward @7 unknown T -45 -40 14.999999999999996 -40 -30 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $1565 $1564 $2262 $2263 reversed $1099 $-1 #
+coedge $-1 -1 -1 $-1 $2264 $2265 $1564 $1858 forward $2266 $-1 #
+edge $-1 -1 -1 $-1 $2267 1.5707963267948966 $1865 2.0943951023931957 $1857 $2268 forward @7 unknown T -7.5000000000000027 -40 20 -5 -39.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $2212 $2269 $1565 $1860 reversed $2213 $-1 #
+edge $-1 -1 -1 $-1 $2270 -2.0943951023931948 $1864 -1.5707963267948966 $1565 $2271 forward @7 unknown T -10.000000000000002 -40 17.499999999999996 -7.5000000000000027 -39.330127018922191 20 #
+coedge $-1 -1 -1 $-1 $2272 $1566 $2273 $2274 reversed $1863 $-1 #
+coedge $-1 -1 -1 $-1 $1566 $1875 $2264 $2275 reversed $1863 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1566 $2276 T -15.000000000000002 -40 20 -7.5000000000000009 -35 35 unknown #
+vertex $-1 -1 -1 $-1 $2277 $2278 #
+vertex $-1 -1 -1 $-1 $1567 $2279 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2280 $2281 $2282 $2283 forward $1569 $-1 #
+coedge $-1 -1 -1 $-1 $1868 $1868 $2284 $2285 reversed $1570 $-1 #
+coedge $-1 -1 -1 $-1 $1571 $1571 $2286 $2287 forward $1322 $-1 #
+coedge $-1 -1 -1 $-1 $2288 $2289 $1571 $1871 reversed $2290 $-1 #
+edge $-1 -1 -1 $-1 $2291 -1.5707963267948966 $2292 1.5707963267948966 $1571 $2293 forward @7 unknown T -45 -40 30 -40 -30 35 #
+coedge $-1 -1 -1 $-1 $1573 $1572 $2294 $2295 reversed $1104 $-1 #
+coedge $-1 -1 -1 $-1 $2296 $2297 $1572 $1874 forward $1953 $-1 #
+edge $-1 -1 -1 $-1 $2298 1.5707963267948966 $1881 2.0943951023931957 $1873 $2299 forward @7 unknown T -7.5000000000000027 -40 35 -5 -39.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $1862 $2300 $1573 $1876 reversed $1863 $-1 #
+edge $-1 -1 -1 $-1 $2301 -2.0943951023931953 $1880 -1.5707963267948966 $1573 $2302 forward @7 unknown T -10.000000000000002 -40 32.5 -7.5000000000000027 -39.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $2303 $1574 $2304 $2305 reversed $1879 $-1 #
+coedge $-1 -1 -1 $-1 $1574 $2306 $2296 $2307 reversed $1879 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1878 $2308 T -15.000000000000002 -40 35 -7.5000000000000009 -35 50 unknown #
+vertex $-1 -1 -1 $-1 $2309 $2310 #
+vertex $-1 -1 -1 $-1 $1575 $2311 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1581 $2312 $2280 $2313 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $2314 $1626 $1581 $1885 reversed $1948 $-1 #
+edge $-1 -1 -1 $-1 $2315 -1.5707963267948966 $1886 0.52359877559829937 $1581 $2316 forward @7 unknown T -1.7763568394002505e-15 -35 50 7.5 -30 50 #
+vertex $-1 -1 -1 $-1 $1582 $2317 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2318 $1584 $2319 $2320 forward $937 $-1 #
+loop $-1 -1 -1 $-1 $2321 $2322 $1122 T -45 19.999999999999996 50 45 30.000000000000004 50 unknown #
+coedge $-1 -1 -1 $-1 $2323 $2324 $2325 $2326 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $2327 $1588 $2328 $2329 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $1588 $2330 $2331 $2332 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $2333 $2334 $1588 $1895 reversed $2335 $-1 #
+edge $-1 -1 -1 $-1 $2336 -1.5707963267948966 $2337 0.5235987755982987 $1588 $2338 forward @7 unknown T 30 -5.0000000000000018 50 37.5 -1.7763568394002505e-15 50 #
+coedge $-1 -1 -1 $-1 $2339 $1589 $2340 $2341 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $2342 $2343 $1589 $1898 reversed $2344 $-1 #
+edge $-1 -1 -1 $-1 $1906 -2.0943951023931948 $2345 2.0943951023931948 $1589 $2346 forward @7 unknown T 37.5 -25 50 45 -15 50 #
+coedge $-1 -1 -1 $-1 $1590 $2347 $2348 $2349 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $2350 $2351 $1590 $1901 reversed $2352 $-1 #
+edge $-1 -1 -1 $-1 $2353 -2.0943951023931948 $1905 0 $1590 $2354 forward @7 unknown T 22.5 -20 50 30 -15 50 #
+coedge $-1 -1 -1 $-1 $2173 $1591 $2351 $2355 reversed $1904 $-1 #
+coedge $-1 -1 -1 $-1 $1591 $2356 $2342 $2357 reversed $1904 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1903 $2358 T 30 -20 35 37.5 -15.000000000000004 50 unknown #
+vertex $-1 -1 -1 $-1 $2359 $2360 #
+vertex $-1 -1 -1 $-1 $1898 $2361 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+face $-1 -1 -1 $-1 $2362 $2363 $11 $-1 $388 reversed single T -20 -35 30 -10.000000000000002 -30 40 F #
+loop $-1 -1 -1 $-1 $-1 $2364 $1593 T -10.000000000000002 -30.669872981077813 32.5 -5 -30 37.5 unknown #
+coedge $-1 -1 -1 $-1 $2365 $2366 $2303 $2367 reversed $1594 $-1 #
+coedge $-1 -1 -1 $-1 $2368 $1597 $2369 $2370 forward $1346 $-1 #
+coedge $-1 -1 -1 $-1 $1597 $2371 $1929 $2372 reversed $1346 $-1 #
+coedge $-1 -1 -1 $-1 $2373 $2374 $2375 $1914 reversed $2376 $-1 #
+edge $-1 -1 -1 $-1 $2377 -50 $2378 -45 $1597 $2379 forward @7 unknown T 14.999999999999998 -35 -50 15 -35 -45 #
+coedge $-1 -1 -1 $-1 $2380 $1621 $1598 $1623 reversed $1943 $-1 #
+face $-1 -1 -1 $-1 $2381 $1680 $11 $-1 $756 reversed single T 19.999999999999996 -40 -42.500000000000007 25 -39.330127018922184 -37.499999999999986 F #
+coedge $-1 -1 -1 $-1 $1669 $2369 $2382 $2000 forward $1600 $-1 #
+coedge $-1 -1 -1 $-1 $2383 $1601 $2374 $2384 reversed $1350 $-1 #
+coedge $-1 -1 -1 $-1 $1601 $2383 $1682 $2010 forward $1350 $-1 #
+coedge $-1 -1 -1 $-1 $2385 $2375 $1601 $1921 reversed $2386 $-1 #
+edge $-1 -1 -1 $-1 $2011 -1.5707963267948966 $2378 -6.1232339957367648e-17 $1601 $2387 forward @7 unknown T 14.999999999999996 -40 -45 19.999999999999996 -35 -40 #
+coedge $-1 -1 -1 $-1 $1603 $1602 $2388 $2389 forward $954 $-1 #
+coedge $-1 -1 -1 $-1 $2390 $2391 $1602 $1924 reversed $2392 $-1 #
+edge $-1 -1 -1 $-1 $1830 1.5707963267948966 $2393 2.0943951023931957 $1602 $2394 forward @7 unknown T 7.4999999999999982 -40 5.0000000000000009 10.000000000000002 -39.330127018922191 7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $2395 $1836 $1603 $1838 reversed $2232 $-1 #
+coedge $-1 -1 -1 $-1 $2382 $1604 $1668 $1996 reversed $1596 $-1 #
+coedge $-1 -1 -1 $-1 $1604 $2396 $1606 $1930 reversed $1596 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $2397 $1606 $1912 $2372 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $1607 -0.52359877559829959 $2377 1.5707963267948966 $1606 $2398 forward @7 unknown T 14.999999999999996 -35 -50 22.5 -30 -50 #
+point $-1 -1 -1 $-1 22.5 -30.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $2399 $2385 $1609 $1933 reversed $2386 $-1 #
+edge $-1 -1 -1 $-1 $1935 -50 $1681 -42.500000000000007 $1609 $2400 forward @7 unknown T 22.5 -39.330127018922198 -50 22.500000000000004 -39.330127018922191 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $1610 $2401 $2399 $2402 forward $1370 $-1 #
+vertex $-1 -1 -1 $-1 $1611 $2403 #
+loop $-1 -1 -1 $-1 $2404 $2405 $1616 T -45 -10.000000000000002 -50 45 2.6645352591003757e-15 -50 unknown #
+coedge $-1 -1 -1 $-1 $2406 $2407 $2408 $2409 forward $1615 $-1 #
+face $-1 -1 -1 $-1 $2410 $2411 $11 $-1 $2412 reversed single T -37.5 -40 -40 -30 -35 -25.000000000000004 F #
+plane-surface $-1 -1 -1 $-1 0 0 -50 0 0 1 1 0 0 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $2413 $2319 $1620 $1941 reversed $2414 $-1 #
+edge $-1 -1 -1 $-1 $1944 37.500000000000007 $1955 50 $1620 $2415 forward @7 unknown T 7.4999999999999991 -39.330127018922198 37.500000000000007 7.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $1621 $2380 $2413 $2416 forward $1943 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1942 $2417 T 4.9999999999999982 -40 32.5 10 -39.330127018922191 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $2416 $2418 #
+vertex $-1 -1 -1 $-1 $1623 $2419 #
+coedge $-1 -1 -1 $-1 $1625 $1628 $2238 $2420 forward $1629 $-1 #
+coedge $-1 -1 -1 $-1 $1626 $2421 $1628 $1950 reversed $1948 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1626 $2422 T -1.7763568394002505e-15 -35 35 7.5000000000000027 -30 50 unknown #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -30.669872981077809 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $1630 -2.0943951023931966 $2423 -1.5707963267948966 $1628 $2424 forward @7 unknown T 4.9999999999999982 -30.669872981077813 35 7.5000000000000027 -30 37.500000000000007 #
+face $-1 -1 -1 $-1 $2425 $1629 $11 $-1 $388 reversed single T 4.9999999999999982 -30.669872981077813 32.5 10 -30 37.500000000000007 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077813 37.500000000000007 #
+loop $-1 -1 -1 $-1 $-1 $2282 $1632 T -7.5000000000000027 -40 35 0 -35 50 unknown #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 32.5 #
+vertex $-1 -1 -1 $-1 $1941 $2426 #
+loop $-1 -1 -1 $-1 $1983 $1640 $1558 T 50 -40 -29.999999999999996 50 -30 -19.999999999999996 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1641 $2427 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 -24.999999999999996 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $665 $2086 $11 $-1 $950 reversed single T 7.4999999999999982 -40 -25 15 -35 -10 F #
+loop $-1 -1 -1 $-1 $-1 $2428 $1642 T -7.5000000000000027 -40 -25 8.8817841970012523e-16 -35 -10 unknown #
+loop $-1 -1 -1 $-1 $-1 $2429 $1400 T -50 -40 -30.000000000000004 -50 -30 -20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $2430 $2430 $2431 $2432 forward $1643 $-1 #
+face $-1 -1 -1 $-1 $2433 $2434 $11 $-1 $1965 reversed single T -10.000000000000002 -25 32.5 -5 -24.330127018922191 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $2435 $2436 $1644 T 40 -25 30 45 -15 40 unknown #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 -20 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+loop $-1 -1 -1 $-1 $-1 $2437 $1401 T -50 -40 -45 -50 -30 -35 unknown #
+coedge $-1 -1 -1 $-1 $2438 $2438 $2439 $2440 forward $1645 $-1 #
+coedge $-1 -1 -1 $-1 $2441 $1646 $2442 $2443 reversed $1402 $-1 #
+coedge $-1 -1 -1 $-1 $1646 $2441 $2444 $2445 forward $1402 $-1 #
+coedge $-1 -1 -1 $-1 $2446 $2447 $1646 $1971 reversed $2448 $-1 #
+edge $-1 -1 -1 $-1 $2449 1.5707963267948966 $2450 2.0943951023931957 $1646 $2451 forward @7 unknown T -25.000000000000004 -30.669872981077809 -42.500000000000007 -22.500000000000004 -30 -40 #
+coedge $-1 -1 -1 $-1 $1648 $1647 $2452 $2453 reversed $1188 $-1 #
+coedge $-1 -1 -1 $-1 $2454 $2455 $1647 $1974 forward $2456 $-1 #
+edge $-1 -1 -1 $-1 $2457 1.5707963267948966 $1981 2.0943951023931948 $1973 $2458 forward @7 unknown T -7.5000000000000027 -40 -40 -5 -39.330127018922191 -37.5 #
+coedge $-1 -1 -1 $-1 $2459 $2460 $1648 $1976 reversed $2461 $-1 #
+edge $-1 -1 -1 $-1 $2462 -2.0943951023931957 $1980 -1.5707963267948966 $1648 $2463 forward @7 unknown T -10.000000000000002 -40 -42.500000000000007 -7.5000000000000009 -39.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $2464 $1649 $2465 $2466 reversed $1979 $-1 #
+coedge $-1 -1 -1 $-1 $1649 $2467 $2454 $2468 reversed $1979 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1649 $2469 T -15.000000000000002 -40 -40 -7.5000000000000009 -35 -25 unknown #
+vertex $-1 -1 -1 $-1 $2470 $2471 #
+vertex $-1 -1 -1 $-1 $1650 $2472 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $2473 $1651 $1558 T 50 -40 -45 50 -30 -35 hole $1559 T #
+vertex $-1 -1 -1 $-1 $1652 $2474 #
+ellipse-curve $-1 -1 -1 $-1 50 -35 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+edge $-1 -1 -1 $-1 $2227 1.5707963267948966 $1657 3.1415926535897931 $1737 $2475 forward @7 unknown T 10 -35 -25 15 -30 -20 #
+edge $-1 -1 -1 $-1 $1657 3.1415926535897931 $2476 4.7123889803846897 $2085 $2475 forward @7 unknown T 10 -40 -25 15 -35 -20 #
+point $-1 -1 -1 $-1 15 -35 -20 #
+point $-1 -1 -1 $-1 15 -35 -30 #
+coedge $-1 -1 -1 $-1 $1661 $2477 $1732 $2077 forward $1416 $-1 #
+coedge $-1 -1 -1 $-1 $1662 $1832 $2085 $1988 reversed $1292 $-1 #
+coedge $-1 -1 -1 $-1 $1664 $1682 $1428 $1674 forward $1439 $-1 #
+edge $-1 -1 -1 $-1 $1671 1.5707963267948966 $1676 2.0943951023931948 $1668 $2478 forward @7 unknown T 19.999999999999996 -30.669872981077805 -42.5 22.499999999999993 -30 -40 #
+coedge $-1 -1 -1 $-1 $2369 $1669 $2002 $2479 reversed $1600 $-1 #
+vertex $-1 -1 -1 $-1 $2480 $2481 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2378 -6.1232339957367648e-17 $1671 1.5707963267948966 $1917 $2482 forward @7 unknown T 14.999999999999996 -35 -45 19.999999999999996 -30 -40 #
+point $-1 -1 -1 $-1 19.999999999999996 -30 -40 #
+coedge $-1 -1 -1 $-1 $1673 $2483 $1997 $2479 forward $2004 $-1 #
+coedge $-1 -1 -1 $-1 $2484 $2224 $1994 $1674 reversed $2485 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1673 $2381 T 7.4999999999999982 -35 -40 15 -30 -25 unknown #
+face $-1 -1 -1 $-1 $761 $2386 $11 $-1 $943 reversed single T 14.999999999999996 -40 -50 22.500000000000004 -35 -40 F #
+point $-1 -1 -1 $-1 22.499999999999993 -30.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $1679 $1678 $2385 $2486 forward $1680 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 -39.330127018922198 -42.500000000000007 #
+edge $-1 -1 -1 $-1 $1998 6.1232339957367648e-17 $2011 1.5707963267948966 $1919 $2487 forward @7 unknown T 14.999999999999996 -40 -40 19.999999999999996 -35 -35 #
+vertex $-1 -1 -1 $-1 $1921 $2488 #
+point $-1 -1 -1 $-1 50 -35 -14.999999999999996 #
+coedge $-1 -1 -1 $-1 $2489 $1688 $2490 $2491 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $1688 $2492 $2493 $2494 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $2031 $2495 $2496 $2017 reversed $2032 $-1 #
+edge $-1 -1 -1 $-1 $2497 -5 $2498 0 $1688 $2499 forward @7 unknown T -8.8817841970012523e-16 -35 -5 0 -35 0 #
+coedge $-1 -1 -1 $-1 $2018 $2018 $1689 $2019 forward $2500 $-1 #
+edge $-1 -1 -1 $-1 $2501 0 $2501 6.2831853071795862 $2018 $2502 forward @7 unknown T -50 -40 -15.000000000000004 -50 -30 -5.0000000000000036 #
+coedge $-1 -1 -1 $-1 $2503 $2504 $1690 $2021 reversed $2505 $-1 #
+edge $-1 -1 -1 $-1 $2026 -1.5707963267948966 $2025 1.5707963267948966 $1690 $2506 forward @7 unknown T -45 -40 -10.000000000000002 -40 -30 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $2507 $1691 $2508 $2509 reversed $2024 $-1 #
+coedge $-1 -1 -1 $-1 $1691 $2510 $2511 $2512 reversed $2024 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2513 $2514 T -45 -40 -25.000000000000004 -37.499999999999993 -30 -10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $1692 $2515 #
+vertex $-1 -1 -1 $-1 $1692 $2516 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -10.000000000000002 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2517 $2518 $1693 $2029 forward $1960 $-1 #
+edge $-1 -1 -1 $-1 $2038 1.0471975511965974 $2033 1.5707963267948966 $2028 $2519 forward @7 unknown T -7.5000000000000027 -40 -12.500000000000004 -5 -39.330127018922191 -10 #
+coedge $-1 -1 -1 $-1 $2520 $1694 $1699 $2044 forward $2032 $-1 #
+coedge $-1 -1 -1 $-1 $1694 $2016 $2521 $2522 forward $2032 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2016 $2523 T -7.5000000000000027 -40 -10 0 -35 5 unknown #
+vertex $-1 -1 -1 $-1 $2029 $2524 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -10 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2525 $1696 $2518 $2526 reversed $2037 $-1 #
+coedge $-1 -1 -1 $-1 $1696 $2527 $2528 $2046 reversed $2037 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2525 $2529 T -15.000000000000004 -40 -25 -7.5000000000000009 -35 -10 unknown #
+vertex $-1 -1 -1 $-1 $2029 $2530 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2531 $1698 $2532 $2533 forward $1700 $-1 #
+coedge $-1 -1 -1 $-1 $2528 $2534 $1698 $2042 forward $2535 $-1 #
+edge $-1 -1 -1 $-1 $2536 6.1232339957367648e-17 $1701 1.5707963267948966 $2041 $2537 forward @7 unknown T -15.000000000000002 -40 -10 -10.000000000000002 -35 -5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $1699 $2531 $1822 $2210 reversed $1700 $-1 #
+edge $-1 -1 -1 $-1 $1702 -7.5 $2538 2.4999999999999982 $2030 $2539 forward @7 unknown T -7.5000000000000027 -39.330127018922198 -7.5 -7.5000000000000009 -39.330127018922191 2.4999999999999982 #
+face $-1 -1 -1 $-1 $2540 $1700 $11 $-1 $2541 reversed single T -15.000000000000002 -40 -10 -7.5000000000000009 -35 4.9999999999999991 F #
+edge $-1 -1 -1 $-1 $1701 -1.5707963267948966 $2542 -6.1232339957367648e-17 $2528 $2543 forward @7 unknown T -15.000000000000004 -40 -15.000000000000002 -10.000000000000002 -35 -10 #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 -10 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -7.5 #
+coedge $-1 -1 -1 $-1 $1704 $2074 $1710 $2054 forward $1726 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -10 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1737 $1706 $2544 $2545 forward $1255 $-1 #
+point $-1 -1 -1 $-1 10 -30 -10 #
+coedge $-1 -1 -1 $-1 $2546 $1710 $2547 $2548 reversed $1712 $-1 #
+edge $-1 -1 -1 $-1 $2549 -2.4999999999999996 $1713 7.4999999999999982 $2049 $2550 forward @7 unknown T 7.4999999999999973 -30.669872981077809 -7.4999999999999982 7.4999999999999991 -30.669872981077805 2.4999999999999996 #
+coedge $-1 -1 -1 $-1 $1711 $2546 $1688 $2017 reversed $1712 $-1 #
+coedge $-1 -1 -1 $-1 $2493 $1716 $1711 $2057 forward $2063 $-1 #
+edge $-1 -1 -1 $-1 $1460 -1.5707963267948966 $2497 6.1232339957367648e-17 $2056 $2551 forward @7 unknown T -1.7763568394002505e-15 -35 -10 4.9999999999999982 -30 -5 #
+face $-1 -1 -1 $-1 $1721 $1712 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 -10 7.4999999999999991 -30 5 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 -7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $2552 $2553 $2428 $2061 forward $2554 $-1 #
+edge $-1 -1 -1 $-1 $2555 -20 $2064 -15 $2060 $2556 forward @7 unknown T -8.8817841970012523e-16 -35 -20 8.8817841970012523e-16 -35 -15 #
+coedge $-1 -1 -1 $-1 $1716 $2493 $2552 $2557 reversed $2063 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2056 $2558 T -5 -35 -15 4.9999999999999982 -30 -5 unknown #
+vertex $-1 -1 -1 $-1 $2557 $2559 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2560 $2544 $1718 $2067 forward $2561 $-1 #
+edge $-1 -1 -1 $-1 $2068 -2.0943951023931948 $2562 -1.5707963267948961 $2066 $2563 forward @7 unknown T 4.9999999999999956 -30.669872981077813 -25 7.4999999999999982 -30 -22.5 #
+vertex $-1 -1 -1 $-1 $2545 $2564 #
+coedge $-1 -1 -1 $-1 $2565 $2566 $1720 $2071 forward $2567 $-1 #
+edge $-1 -1 -1 $-1 $2562 -1.570796326794897 $2555 6.1232339957367648e-17 $2070 $2568 forward @7 unknown T -1.7763568394002505e-15 -35 -25 5 -30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $2569 $2570 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 -25 7.5 -35 -10 F #
+cone-surface $-1 -1 -1 $-1 4.9999999999999982 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $2049 $1724 $2571 $2220 forward $1726 $-1 #
+face $-1 -1 -1 $-1 $2572 $1726 $11 $-1 $950 reversed single T 7.4999999999999973 -35 -10 15.000000000000004 -30 5.0000000000000009 F #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -10 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $1830 -1.5707963267948966 $1290 0 $1991 $1831 forward @7 unknown T 10 -40 8.8817841970012523e-16 15.000000000000004 -35 5.0000000000000009 #
+face $-1 -1 -1 $-1 $2573 $2574 $11 $-1 $1477 reversed single T 15 -20 -25 22.5 -15 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $2575 $1734 T 15 -20 -9.9999999999999982 22.500000000000004 -15 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $2576 $2577 $2578 $2579 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $2580 $1736 $2581 $2582 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $1736 $2583 $2584 $2585 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $2586 $2587 $1736 $2084 forward $2588 $-1 #
+edge $-1 -1 -1 $-1 $2589 -1.5707963267948966 $2590 6.1232339957367673e-17 $2083 $2591 forward @7 unknown T 15 -20 20 20 -15 25 #
+coedge $-1 -1 -1 $-1 $2592 $1738 $1992 $1988 forward $2086 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1738 $1959 T 7.4999999999999982 -40 -25 15 -35 -10 unknown #
+coedge $-1 -1 -1 $-1 $1739 $2593 $2594 $2091 forward $2086 $-1 #
+coedge $-1 -1 -1 $-1 $2477 $1741 $2595 $2596 forward $1416 $-1 #
+coedge $-1 -1 -1 $-1 $2594 $2597 $1741 $2090 reversed $2598 $-1 #
+edge $-1 -1 -1 $-1 $1742 1.5707963267948966 $2599 2.0943951023931948 $1741 $2050 forward @7 unknown T 7.4999999999999991 -40 -10 10 -39.330127018922191 -7.4999999999999991 #
+edge $-1 -1 -1 $-1 $2600 1.0471975511965979 $1742 1.5707963267948966 $2087 $1709 forward @7 unknown T 7.4999999999999982 -40 -12.500000000000002 10 -39.330127018922191 -10 #
+point $-1 -1 -1 $-1 10 -40 -10 #
+face $-1 -1 -1 $-1 $2601 $2191 $11 $-1 $704 reversed single T 29.999999999999996 -25.000000000000004 20.000000000000004 37.500000000000007 -20 35 F #
+loop $-1 -1 -1 $-1 $-1 $2602 $1744 T 29.999999999999996 -25.000000000000004 5.0000000000000018 37.500000000000014 -20 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $2603 $2604 $2605 $2606 reversed $1745 $-1 #
+coedge $-1 -1 -1 $-1 $2607 $1746 $2608 $2609 reversed $1485 $-1 #
+coedge $-1 -1 -1 $-1 $1746 $2610 $2611 $2612 reversed $1485 $-1 #
+coedge $-1 -1 -1 $-1 $2613 $2614 $1746 $2099 forward $2615 $-1 #
+edge $-1 -1 -1 $-1 $2616 1.5707963267948966 $2617 2.0943951023931966 $2098 $2618 forward @7 unknown T 35 -25.000000000000004 -24.999999999999996 37.500000000000007 -24.330127018922187 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $2619 $1747 $2620 $2621 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $2622 $2623 $1747 $2102 forward $2624 $-1 #
+edge $-1 -1 -1 $-1 $2625 -2.0943951023931966 $2109 -1.5707963267948966 $2101 $2626 forward @7 unknown T 35 -15.669872981077814 -24.999999999999996 37.500000000000007 -15.000000000000004 -22.499999999999993 #
+coedge $-1 -1 -1 $-1 $1748 $2619 $1758 $2128 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $2627 $2628 $2629 $2105 forward $2630 $-1 #
+edge $-1 -1 -1 $-1 $2110 -20 $2631 -14.999999999999998 $2104 $2632 forward @7 unknown T 29.999999999999996 -20 -20 30 -20 -14.999999999999998 #
+coedge $-1 -1 -1 $-1 $2633 $1749 $2628 $2634 reversed $2108 $-1 #
+coedge $-1 -1 -1 $-1 $1749 $2633 $2635 $2636 forward $2108 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2107 $2637 T 25 -20 -30 35 -15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $2636 $2638 #
+vertex $-1 -1 -1 $-1 $2639 $2640 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1754 $1751 $1766 $2139 reversed $1064 $-1 #
+coedge $-1 -1 -1 $-1 $2641 $2642 $1751 $2114 forward $2643 $-1 #
+edge $-1 -1 -1 $-1 $2644 -2.5000000000000031 $2118 7.4999999999999947 $2113 $2645 forward @7 unknown T 37.499999999999986 -15.669872981077809 -7.4999999999999947 37.5 -15.669872981077805 2.5000000000000031 #
+coedge $-1 -1 -1 $-1 $2646 $1752 $2619 $2647 forward $2117 $-1 #
+coedge $-1 -1 -1 $-1 $1752 $2646 $2641 $2648 reversed $2117 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2115 $2649 T 35 -15.669872981077813 -12.500000000000004 40 -15 -7.4999999999999947 unknown #
+vertex $-1 -1 -1 $-1 $2648 $2650 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2651 $1755 $1777 $2151 forward $2123 $-1 #
+coedge $-1 -1 -1 $-1 $1755 $2652 $1757 $2127 forward $2123 $-1 #
+coedge $-1 -1 -1 $-1 $2653 $2654 $2655 $1756 reversed $2656 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1755 $2657 T 22.5 -20 -9.9999999999999982 30 -15 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $2151 $2658 #
+coedge $-1 -1 -1 $-1 $1758 $1757 $2627 $2659 reversed $1759 $-1 #
+edge $-1 -1 -1 $-1 $2660 1.570796326794897 $1761 3.1415926535897931 $2121 $2661 forward @7 unknown T 25 -20 -9.9999999999999982 29.999999999999996 -15 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $2631 6.4931039580273265e-16 $1760 1.5707963267948966 $1758 $2662 forward @7 unknown T 30 -20 -15 35 -15.000000000000004 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $2663 $1759 $11 $-1 $2664 reversed single T 25 -20 -15 35 -15 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 -15.000000000000004 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $1761 3.1415926535897931 $2665 4.7123889803846897 $2653 $2661 forward @7 unknown T 24.999999999999996 -25 -9.9999999999999982 29.999999999999996 -20 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 -20 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $2666 $1764 $1767 $2140 forward $2135 $-1 #
+coedge $-1 -1 -1 $-1 $1764 $2667 $1791 $2167 forward $2135 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1764 $2668 T 37.499999999999986 -25 5.0000000000000027 45.000000000000007 -15 20.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $1765 $2669 #
+coedge $-1 -1 -1 $-1 $1767 $1766 $2642 $2670 reversed $1768 $-1 #
+edge $-1 -1 -1 $-1 $1500 1.5707963267948966 $2644 2.094395102393193 $1766 $2671 forward @7 unknown T 35 -15.669872981077805 2.5000000000000031 37.499999999999986 -15.000000000000004 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $1769 4.1887902047863896 $2672 4.7123889803846897 $2133 $2673 forward @7 unknown T 37.5 -15.669872981077814 5.0000000000000027 40.000000000000007 -15 7.5000000000000107 #
+face $-1 -1 -1 $-1 $2637 $1768 $11 $-1 $2156 reversed single T 35 -15.669872981077814 2.5000000000000018 40.000000000000007 -15 7.5000000000000107 F #
+point $-1 -1 -1 $-1 37.500000000000007 -15.669872981077814 7.5000000000000107 #
+coedge $-1 -1 -1 $-1 $2674 $1771 $2675 $2196 forward $1774 $-1 #
+coedge $-1 -1 -1 $-1 $1772 $2674 $2676 $2677 forward $1774 $-1 #
+coedge $-1 -1 -1 $-1 $2678 $1773 $2679 $1782 forward $2148 $-1 #
+coedge $-1 -1 -1 $-1 $1773 $2680 $2681 $2682 forward $2148 $-1 #
+coedge $-1 -1 -1 $-1 $2683 $2684 $1265 $1496 forward $2094 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1773 $2171 T 22.499999999999996 -25 4.9999999999999991 30 -20 20 unknown #
+face $-1 -1 -1 $-1 $2685 $1774 $11 $-1 $2194 reversed single T 22.5 -20 5.0000000000000018 30 -15 20 F #
+point $-1 -1 -1 $-1 29.999999999999996 -20 15 #
+edge $-1 -1 -1 $-1 $2124 0 $2152 1.5707963267948961 $2120 $2686 forward @7 unknown T 25 -20 1.7763568394002505e-15 29.999999999999996 -15 5.0000000000000018 #
+vertex $-1 -1 -1 $-1 $2687 $2688 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2689 $2690 $11 $-1 $2156 reversed single T 24.999999999999996 -25.000000000000004 1.7763568394002505e-15 35 -20 10.000000000000002 F #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 -20 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $2691 $2692 #
+coedge $-1 -1 -1 $-1 $2693 $1784 $1787 $2164 reversed $2160 $-1 #
+coedge $-1 -1 -1 $-1 $1784 $2693 $2356 $2694 forward $2160 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2159 $2695 T 35 -15.669872981077813 32.499999999999993 40 -15 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $2696 $1786 $2697 $2698 forward $1788 $-1 #
+coedge $-1 -1 -1 $-1 $1787 $2699 $2436 $2700 forward $1788 $-1 #
+edge $-1 -1 -1 $-1 $2701 -1.5707963267948966 $1789 -1.0471975511965961 $1787 $2702 forward @7 unknown T 37.499999999999986 -15.669872981077813 32.499999999999993 40 -15 35 #
+face $-1 -1 -1 $-1 $2175 $1788 $11 $-1 $2703 reversed single T 37.499999999999986 -25 20.000000000000004 45 -15 35 F #
+point $-1 -1 -1 $-1 37.499999999999986 -15.669872981077805 32.499999999999993 #
+edge $-1 -1 -1 $-1 $2169 -1.570796326794897 $2136 -1.0471975511965974 $2134 $2704 forward @7 unknown T 37.499999999999986 -15.669872981077809 17.500000000000004 40 -15 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $2167 $2705 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2706 $2148 $11 $-1 $2194 reversed single T 22.499999999999996 -25 4.9999999999999991 30 -20 20 F #
+coedge $-1 -1 -1 $-1 $1797 $1796 $2707 $2708 reversed $1798 $-1 #
+coedge $-1 -1 -1 $-1 $2356 $1902 $1796 $2174 reversed $1904 $-1 #
+edge $-1 -1 -1 $-1 $1799 -1.5707963267948966 $2709 -6.4931039580273226e-16 $1796 $2710 forward @7 unknown T 30 -20 35 35 -15.000000000000004 40 #
+face $-1 -1 -1 $-1 $2711 $1798 $11 $-1 $1965 reversed single T 25 -20 30 35 -15 40 F #
+point $-1 -1 -1 $-1 35 -15.000000000000004 35 #
+coedge $-1 -1 -1 $-1 $1803 $1801 $2580 $2712 forward $1516 $-1 #
+coedge $-1 -1 -1 $-1 $2713 $2714 $1801 $2179 reversed $2715 $-1 #
+edge $-1 -1 -1 $-1 $2180 -1.5707963267948966 $2716 -1.0471975511965979 $1801 $2717 forward @7 unknown T 22.5 -15.669872981077809 32.5 25 -15 35 #
+vertex $-1 -1 -1 $-1 $2179 $2718 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2581 $2675 $1803 $2183 reversed $2719 $-1 #
+edge $-1 -1 -1 $-1 $2720 4.1887902047863914 $1811 4.7123889803846897 $1803 $2721 forward @7 unknown T 22.499999999999996 -15.669872981077805 20 25 -15 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $2722 $1804 $2723 $2724 forward $1807 $-1 #
+coedge $-1 -1 -1 $-1 $2725 $2681 $1804 $1524 reversed $2199 $-1 #
+coedge $-1 -1 -1 $-1 $1805 $2722 $2726 $2727 forward $1807 $-1 #
+coedge $-1 -1 -1 $-1 $2728 $2729 $1805 $2188 reversed $2730 $-1 #
+edge $-1 -1 -1 $-1 $2731 -1.5707963267948966 $1517 0 $1805 $2181 forward @7 unknown T 25 -25 30 30 -20 35 #
+coedge $-1 -1 -1 $-1 $2732 $1806 $2729 $2733 reversed $2191 $-1 #
+coedge $-1 -1 -1 $-1 $1806 $2734 $2725 $2735 reversed $2191 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2734 $2093 T 29.999999999999996 -25.000000000000004 20.000000000000004 37.500000000000007 -20 35 unknown #
+face $-1 -1 -1 $-1 $2736 $1807 $11 $-1 $2194 reversed single T 22.499999999999993 -25 19.999999999999996 30 -20 35 F #
+face $-1 -1 -1 $-1 $2737 $2738 $11 $-1 $1965 reversed single T 10 -20 30 20 -15 40 F #
+cone-surface $-1 -1 -1 $-1 25 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $1811 -1.5707963267948966 $2739 -1.0471975511965979 $2143 $2740 forward @7 unknown T 22.500000000000004 -15.669872981077807 17.5 25 -15 20 #
+point $-1 -1 -1 $-1 25 -15 20 #
+face $-1 -1 -1 $-1 $1794 $2741 $11 $-1 $1815 reversed single T 35 -25.000000000000004 17.500000000000007 40.000000000000007 -24.330127018922187 22.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $2725 $1814 T 25 -25.000000000000004 15 35 -20 25.000000000000007 unknown #
+edge $-1 -1 -1 $-1 $2742 1.0471975511965979 $1816 1.5707963267948966 $2680 $2740 forward @7 unknown T 22.500000000000004 -25 17.5 25 -24.330127018922191 20 #
+point $-1 -1 -1 $-1 25 -25 20 #
+coedge $-1 -1 -1 $-1 $2743 $2744 $2745 $2746 forward $1818 $-1 #
+coedge $-1 -1 -1 $-1 $2203 $2203 $2747 $2748 reversed $1819 $-1 #
+coedge $-1 -1 -1 $-1 $1820 $1820 $2749 $2750 forward $1530 $-1 #
+coedge $-1 -1 -1 $-1 $2751 $2752 $1820 $2206 reversed $2505 $-1 #
+edge $-1 -1 -1 $-1 $2753 -1.5707963267948966 $2754 1.5707963267948966 $1820 $2755 forward @7 unknown T -45 -40 -3.5527136788005009e-15 -40 -30 4.9999999999999973 #
+coedge $-1 -1 -1 $-1 $1822 $1821 $2520 $2756 reversed $1283 $-1 #
+coedge $-1 -1 -1 $-1 $2757 $2758 $1821 $2209 forward $2759 $-1 #
+edge $-1 -1 -1 $-1 $2760 1.5707963267948966 $2215 2.0943951023931957 $2208 $2761 forward @7 unknown T -7.5000000000000027 -40 5 -5 -39.330127018922191 7.5000000000000027 #
+edge $-1 -1 -1 $-1 $2538 -2.0943951023931948 $2214 -1.5707963267948966 $1822 $2762 forward @7 unknown T -10.000000000000002 -40 2.4999999999999982 -7.5000000000000027 -39.330127018922198 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $2763 $1823 $2764 $2765 reversed $2213 $-1 #
+coedge $-1 -1 -1 $-1 $1823 $1859 $2757 $2766 reversed $2213 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1823 $2540 T -15.000000000000002 -40 4.9999999999999991 -7.5000000000000009 -35 20 unknown #
+vertex $-1 -1 -1 $-1 $2767 $2768 #
+vertex $-1 -1 -1 $-1 $1824 $2769 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2770 $2571 $1825 $2218 reversed $2771 $-1 #
+edge $-1 -1 -1 $-1 $2772 4.1887902047863914 $1827 4.7123889803846897 $1825 $2394 forward @7 unknown T 7.4999999999999956 -30.669872981077805 5.0000000000000009 10 -30 7.5000000000000018 #
+face $-1 -1 -1 $-1 $2773 $2774 $11 $-1 $162 reversed single T -5 -35 15 4.9999999999999982 -30 25 F #
+edge $-1 -1 -1 $-1 $1827 -1.5707963267948966 $2549 -1.0471975511965974 $2074 $2775 forward @7 unknown T 7.4999999999999973 -30.669872981077809 2.4999999999999996 10 -30 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 -30 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $2776 1.0471975511965983 $1830 1.5707963267948966 $2477 $2775 forward @7 unknown T 7.4999999999999991 -40 2.5000000000000009 10 -39.330127018922198 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 -40 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $2003 $2777 $1832 $2225 forward $2485 $-1 #
+edge $-1 -1 -1 $-1 $2476 -1.5707963267948966 $1659 0 $2224 $2228 forward @7 unknown T 10 -40 -30 15 -35 -25 #
+coedge $-1 -1 -1 $-1 $2778 $1833 $2779 $2780 forward $2004 $-1 #
+vertex $-1 -1 -1 $-1 $2780 $2781 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2782 $2783 $1835 $2230 reversed $2784 $-1 #
+edge $-1 -1 -1 $-1 $2233 22.500000000000004 $1945 32.5 $1835 $2785 forward @7 unknown T 7.4999999999999982 -39.330127018922198 22.500000000000004 7.5 -39.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $1836 $2395 $2782 $2786 forward $2232 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2231 $2787 T 4.9999999999999982 -40 17.499999999999996 10 -39.330127018922191 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $2786 $2788 #
+vertex $-1 -1 -1 $-1 $1838 $2789 #
+coedge $-1 -1 -1 $-1 $2790 $2791 $1840 $2236 reversed $2792 $-1 #
+edge $-1 -1 -1 $-1 $1849 -17.499999999999996 $2772 -7.5000000000000018 $1840 $2793 forward @7 unknown T 7.4999999999999956 -30.669872981077809 7.5000000000000018 7.4999999999999991 -30.669872981077798 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $1841 $1844 $2790 $2794 forward $1845 $-1 #
+coedge $-1 -1 -1 $-1 $2795 $1842 $1946 $2420 reversed $2240 $-1 #
+coedge $-1 -1 -1 $-1 $1842 $2796 $1844 $2242 reversed $2240 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2796 $2797 T -1.7763568394002505e-15 -35 20 7.4999999999999991 -30 35 unknown #
+edge $-1 -1 -1 $-1 $1846 -2.0943951023931957 $2798 -1.5707963267948966 $1844 $2799 forward @7 unknown T 4.9999999999999982 -30.669872981077813 20 7.4999999999999991 -30 22.500000000000004 #
+face $-1 -1 -1 $-1 $2800 $1845 $11 $-1 $162 reversed single T 4.9999999999999982 -30.669872981077813 17.499999999999996 10 -30 22.500000000000007 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077813 22.500000000000004 #
+face $-1 -1 -1 $-1 $2417 $2801 $11 $-1 $388 reversed single T -5 -40 30 4.9999999999999982 -35 40 F #
+loop $-1 -1 -1 $-1 $-1 $2802 $1848 T -5 -35 30 4.9999999999999982 -30 40 unknown #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $2803 $1851 $2804 $2805 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $1851 $2806 $2807 $2808 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $2265 $2809 $2810 $2251 reversed $2266 $-1 #
+edge $-1 -1 -1 $-1 $2811 25 $2812 30 $1851 $2813 forward @7 unknown T -8.8817841970012523e-16 -35 25 0 -35 30 #
+coedge $-1 -1 -1 $-1 $2252 $2252 $1852 $2253 forward $2814 $-1 #
+edge $-1 -1 -1 $-1 $2815 0 $2815 6.2831853071795862 $2252 $2816 forward @7 unknown T -50 -40 14.999999999999996 -50 -30 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $2817 $2818 $1853 $2255 reversed $2290 $-1 #
+edge $-1 -1 -1 $-1 $2260 -1.5707963267948966 $2259 1.5707963267948966 $1853 $2819 forward @7 unknown T -45 -40 19.999999999999996 -40 -30 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $2820 $1854 $2821 $2822 reversed $2258 $-1 #
+coedge $-1 -1 -1 $-1 $1854 $2823 $2824 $2825 reversed $2258 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2826 $2827 T -45 -40 4.9999999999999973 -37.499999999999993 -30 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $1855 $2828 #
+vertex $-1 -1 -1 $-1 $1855 $2829 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2830 $2757 $1856 $2263 forward $2759 $-1 #
+edge $-1 -1 -1 $-1 $2270 1.0471975511965974 $2267 1.5707963267948966 $2262 $2831 forward @7 unknown T -7.5000000000000027 -40 17.499999999999996 -5 -39.330127018922191 20 #
+coedge $-1 -1 -1 $-1 $2294 $1857 $1862 $2275 forward $2266 $-1 #
+coedge $-1 -1 -1 $-1 $1857 $2250 $2832 $2833 forward $2266 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2250 $2425 T -7.5000000000000027 -40 20 0 -35 35 unknown #
+vertex $-1 -1 -1 $-1 $2263 $2834 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1859 $2763 $2835 $2277 reversed $2213 $-1 #
+vertex $-1 -1 -1 $-1 $2263 $2836 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2300 $1861 $2837 $2838 forward $1863 $-1 #
+coedge $-1 -1 -1 $-1 $2835 $2839 $1861 $2274 forward $2840 $-1 #
+edge $-1 -1 -1 $-1 $2841 6.1232339957367648e-17 $1864 1.5707963267948966 $2273 $2842 forward @7 unknown T -15.000000000000002 -40 20 -10.000000000000002 -35 25 #
+edge $-1 -1 -1 $-1 $1865 22.500000000000004 $2301 32.5 $2264 $2843 forward @7 unknown T -7.5000000000000027 -39.330127018922198 22.500000000000004 -7.5000000000000009 -39.330127018922191 32.5 #
+face $-1 -1 -1 $-1 $2308 $1863 $11 $-1 $2541 reversed single T -15.000000000000002 -40 20 -7.5000000000000009 -35 35 F #
+edge $-1 -1 -1 $-1 $1864 -1.5707963267948966 $2844 -6.1232339957367648e-17 $2835 $2845 forward @7 unknown T -15.000000000000002 -40 15 -10.000000000000002 -35 20 #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 20 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $2846 $1867 $1883 $2313 reversed $1569 $-1 #
+coedge $-1 -1 -1 $-1 $1867 $2847 $2848 $2849 forward $1569 $-1 #
+coedge $-1 -1 -1 $-1 $2297 $2850 $2851 $2283 reversed $1953 $-1 #
+edge $-1 -1 -1 $-1 $2852 40 $2315 50 $1867 $2853 forward @7 unknown T -8.8817841970012523e-16 -35 40 0 -35 50 #
+coedge $-1 -1 -1 $-1 $2284 $2284 $1868 $2285 forward $2854 $-1 #
+edge $-1 -1 -1 $-1 $2855 0 $2855 6.2831853071795862 $2284 $2856 forward @7 unknown T -50 -40 29.999999999999996 -50 -30 40 #
+coedge $-1 -1 -1 $-1 $2857 $2858 $1869 $2287 reversed $2859 $-1 #
+edge $-1 -1 -1 $-1 $2292 -1.5707963267948966 $2291 1.5707963267948966 $1869 $2860 forward @7 unknown T -45 -40 35 -40 -30 40 #
+coedge $-1 -1 -1 $-1 $2861 $1870 $2862 $2863 reversed $2290 $-1 #
+coedge $-1 -1 -1 $-1 $1870 $2864 $2865 $2866 reversed $2290 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2818 $2867 T -45 -40 19.999999999999996 -37.499999999999993 -30 35 unknown #
+vertex $-1 -1 -1 $-1 $1871 $2868 #
+vertex $-1 -1 -1 $-1 $1871 $2869 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2809 $2264 $1872 $2295 forward $2266 $-1 #
+edge $-1 -1 -1 $-1 $2301 1.0471975511965979 $2298 1.5707963267948966 $2294 $2870 forward @7 unknown T -7.5000000000000027 -40 32.5 -5 -39.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $2850 $1873 $1878 $2307 forward $1953 $-1 #
+coedge $-1 -1 -1 $-1 $1873 $2282 $2871 $2872 forward $1953 $-1 #
+vertex $-1 -1 -1 $-1 $2295 $2873 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $1875 $2272 $2874 $2309 reversed $1863 $-1 #
+vertex $-1 -1 -1 $-1 $2295 $2875 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2306 $1877 $2876 $2367 forward $1879 $-1 #
+coedge $-1 -1 -1 $-1 $2874 $2877 $1877 $2305 forward $2878 $-1 #
+edge $-1 -1 -1 $-1 $2879 6.1232339957367648e-17 $1880 1.5707963267948966 $2304 $2880 forward @7 unknown T -15.000000000000002 -40 35 -10.000000000000002 -35 40 #
+coedge $-1 -1 -1 $-1 $1878 $2303 $2881 $2882 reversed $1879 $-1 #
+edge $-1 -1 -1 $-1 $1881 37.500000000000007 $2883 50 $2296 $2884 forward @7 unknown T -7.5000000000000027 -39.330127018922198 37.500000000000007 -7.5000000000000009 -39.330127018922191 50 #
+face $-1 -1 -1 $-1 $2885 $1879 $11 $-1 $2541 reversed single T -15.000000000000002 -40 35 -7.5000000000000009 -35 50 F #
+edge $-1 -1 -1 $-1 $1880 -1.5707963267948966 $2886 -6.1232339957367648e-17 $2874 $2887 forward @7 unknown T -15.000000000000002 -40 30 -10.000000000000002 -35 35 #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 35 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $1883 $2888 $2889 $2890 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $2891 -2.0943951023931957 $2315 0 $1883 $2892 forward @7 unknown T -7.5000000000000009 -35 50 0 -30 50 #
+coedge $-1 -1 -1 $-1 $2421 $1884 $1867 $2283 reversed $1948 $-1 #
+vertex $-1 -1 -1 $-1 $2893 $2894 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+point $-1 -1 -1 $-1 7.4999999999999991 -30.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $2881 $1888 $2850 $2893 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $1940 $2851 $1888 $2320 reversed $2414 $-1 #
+edge $-1 -1 -1 $-1 $1955 2.617993877991494 $2315 4.7123889803846897 $1888 $2895 forward @7 unknown T -1.7763568394002505e-15 -40 50 7.4999999999999991 -35 50 #
+loop $-1 -1 -1 $-1 $2896 $2897 $1122 T -45 35 50 45 45 50 unknown #
+coedge $-1 -1 -1 $-1 $2898 $2899 $2900 $2901 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $2902 $1891 $2903 $2904 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $1891 $2905 $2906 $2907 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $2908 $2909 $1891 $2326 reversed $2910 $-1 #
+edge $-1 -1 -1 $-1 $2911 -1.5707963267948961 $2912 0.52359877559829893 $1891 $2913 forward @7 unknown T 30 10 50 37.5 14.999999999999998 50 #
+coedge $-1 -1 -1 $-1 $2914 $1892 $2915 $2916 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $2917 $2918 $1892 $2329 reversed $2919 $-1 #
+edge $-1 -1 -1 $-1 $2337 -2.0943951023931957 $2920 2.0943951023931948 $1892 $2921 forward @7 unknown T 37.5 -10 50 45 0 50 #
+coedge $-1 -1 -1 $-1 $1893 $2922 $2923 $2924 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $2925 $2926 $1893 $2332 reversed $2927 $-1 #
+edge $-1 -1 -1 $-1 $2928 -2.0943951023931957 $2336 1.7763568394002506e-16 $1893 $2929 forward @7 unknown T 22.5 -5.0000000000000009 50 30 0 50 #
+coedge $-1 -1 -1 $-1 $2930 $1894 $2926 $2931 reversed $2335 $-1 #
+coedge $-1 -1 -1 $-1 $1894 $2932 $2917 $2933 reversed $2335 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2334 $2934 T 30 -5.0000000000000018 35 37.500000000000007 -1.7763568394002505e-15 50 unknown #
+vertex $-1 -1 -1 $-1 $2935 $2936 #
+vertex $-1 -1 -1 $-1 $2329 $2937 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $2938 $1896 $2939 $2359 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $2940 $2941 $1896 $2341 reversed $2942 $-1 #
+edge $-1 -1 -1 $-1 $2345 2.617993877991494 $1905 4.7123889803846906 $1896 $2943 forward @7 unknown T 30 -25.000000000000004 50 37.5 -20 50 #
+coedge $-1 -1 -1 $-1 $2944 $1897 $1903 $2357 forward $2344 $-1 #
+coedge $-1 -1 -1 $-1 $1897 $2945 $2940 $2946 forward $2344 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2342 $2947 T 37.5 -25 35 45 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $2946 $2948 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1899 $2949 $2950 $2951 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $2952 $2953 $1899 $2349 reversed $2954 $-1 #
+edge $-1 -1 -1 $-1 $2955 -1.5707963267948966 $2353 0.5235987755982987 $1899 $2956 forward @7 unknown T 15 -20 50 22.5 -15 50 #
+coedge $-1 -1 -1 $-1 $2957 $1900 $2953 $2958 forward $2352 $-1 #
+coedge $-1 -1 -1 $-1 $1900 $2707 $2959 $2355 forward $2352 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2351 $2960 T 22.5 -20 35 30 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $1901 $2961 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 50 -0 -0 -1 5 0 0 1 I I #
+edge $-1 -1 -1 $-1 $2709 40 $1905 50 $2351 $2962 forward @7 unknown T 30 -20 40 30 -20 50 #
+coedge $-1 -1 -1 $-1 $1903 $2173 $2159 $2694 reversed $1904 $-1 #
+edge $-1 -1 -1 $-1 $1906 -50 $2963 -37.5 $2342 $2964 forward @7 unknown T 37.5 -15.669872981077809 37.5 37.5 -15.669872981077805 50 #
+face $-1 -1 -1 $-1 $2965 $1904 $11 $-1 $704 reversed single T 30 -20 35 37.5 -15.000000000000004 50 F #
+edge $-1 -1 -1 $-1 $1905 0 $2966 2.0943951023931948 $2339 $2354 forward @7 unknown T 22.5 -25 50 30 -20 50 #
+point $-1 -1 -1 $-1 30 -20 50 #
+point $-1 -1 -1 $-1 37.5 -15.669872981077805 50 #
+face $-1 -1 -1 $-1 $2967 $2878 $11 $-1 $388 reversed single T -20 -40 30 -10.000000000000002 -35 40 F #
+loop $-1 -1 -1 $-1 $-1 $2968 $1908 T -20 -35 30 -10.000000000000002 -30 40 unknown #
+coedge $-1 -1 -1 $-1 $2969 $2970 $2971 $2972 forward $1909 $-1 #
+coedge $-1 -1 -1 $-1 $2973 $1910 $2877 $2974 forward $1594 $-1 #
+coedge $-1 -1 -1 $-1 $1910 $2975 $2976 $2977 reversed $1594 $-1 #
+edge $-1 -1 -1 $-1 $2879 40 $2978 50 $2979 $2980 forward @7 unknown T -15 -35 40 -15 -35 50 #
+coedge $-1 -1 -1 $-1 $2371 $1911 $2981 $2982 forward $1346 $-1 #
+coedge $-1 -1 -1 $-1 $1917 $1997 $1911 $2370 reversed $1600 $-1 #
+edge $-1 -1 -1 $-1 $2378 0 $2983 1.5707963267948966 $1911 $2984 forward @7 unknown T 10 -35 -45 15 -30 -40 #
+coedge $-1 -1 -1 $-1 $1912 $2368 $2985 $2986 forward $1346 $-1 #
+edge $-1 -1 -1 $-1 $2377 0 $2987 2.0943951023931957 $1929 $2988 forward @7 unknown T 7.4999999999999991 -35 -50 15 -30 -50 #
+coedge $-1 -1 -1 $-1 $2989 $1913 $2401 $2990 reversed $2376 $-1 #
+coedge $-1 -1 -1 $-1 $1913 $2991 $1918 $2384 forward $2376 $-1 #
+coedge $-1 -1 -1 $-1 $1920 $2399 $2396 $1914 forward $2386 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1913 $2992 T 7.4999999999999982 -40 -50 15 -35 -40 unknown #
+vertex $-1 -1 -1 $-1 $2372 $2993 #
+vertex $-1 -1 -1 $-1 $2370 $2994 #
+straight-curve $-1 -1 -1 $-1 14.999999999999998 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1942 $1915 $2783 $2995 forward $1943 $-1 #
+face $-1 -1 -1 $-1 $1536 $2004 $11 $-1 $950 reversed single T 7.4999999999999982 -35 -40 15 -30 -25 F #
+coedge $-1 -1 -1 $-1 $2396 $1926 $1917 $2000 reversed $1596 $-1 #
+coedge $-1 -1 -1 $-1 $1919 $1918 $2484 $2480 reversed $1350 $-1 #
+edge $-1 -1 -1 $-1 $2996 -1.5707963267948966 $2378 0 $2374 $2984 forward @7 unknown T 10 -40 -45 15 -35 -40 #
+coedge $-1 -1 -1 $-1 $1932 $1920 $2008 $2486 reversed $2386 $-1 #
+loop $-1 -1 -1 $-1 $-1 $1932 $2006 T 14.999999999999996 -40 -50 22.500000000000004 -35 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2997 $2998 $1922 $2389 reversed $2999 $-1 #
+edge $-1 -1 -1 $-1 $2393 7.5000000000000036 $2234 17.499999999999996 $1922 $3000 forward @7 unknown T 7.4999999999999982 -39.330127018922198 7.5000000000000036 7.4999999999999991 -39.330127018922191 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $3001 $1923 $2477 $2222 reversed $2392 $-1 #
+coedge $-1 -1 -1 $-1 $1923 $3001 $2997 $3002 forward $2392 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2391 $3003 T 4.9999999999999982 -40 2.5000000000000009 10.000000000000002 -39.330127018922191 7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $3002 $3004 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -35 5.0000000000000009 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2231 $1925 $2998 $3005 forward $2232 $-1 #
+coedge $-1 -1 -1 $-1 $1927 $2382 $1597 $1914 reversed $1596 $-1 #
+coedge $-1 -1 -1 $-1 $3006 $1929 $3007 $3008 forward $1370 $-1 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $2375 $1932 $1934 $2402 reversed $2386 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -39.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $1934 $3009 $2373 $2990 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $2377 1.5707963267948966 $1935 3.6651914291880932 $1934 $3010 forward @7 unknown T 14.999999999999996 -40 -50 22.5 -35 -50 #
+point $-1 -1 -1 $-1 22.5 -39.330127018922191 -50 #
+loop $-1 -1 -1 $-1 $3011 $3012 $1616 T -45 4.9999999999999982 -50 45 15.000000000000002 -50 unknown #
+coedge $-1 -1 -1 $-1 $3013 $3014 $3015 $3016 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $3017 $1937 $3018 $3019 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $1937 $3020 $3021 $3022 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $3023 $3024 $1937 $2409 reversed $3025 $-1 #
+edge $-1 -1 -1 $-1 $3026 1.5707963267948957 $3027 3.6651914291880923 $1937 $3028 forward @7 unknown T 30 -25.000000000000004 -50 37.5 -20 -50 #
+face $-1 -1 -1 $-1 $3029 $3030 $11 $-1 $1595 reversed single T -22.500000000000004 -40 -50 -15 -35 -40 F #
+loop $-1 -1 -1 $-1 $-1 $3031 $1938 T -37.5 -40 -40 -30 -35 -25.000000000000004 unknown #
+cone-surface $-1 -1 -1 $-1 -35 -35 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $3032 $1940 $1942 $2416 reversed $2414 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2851 $3033 T -1.7763568394002505e-15 -40 35 7.5 -35 50 unknown #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3034 1.5707963267948966 $1944 2.0943951023931957 $1942 $3035 forward @7 unknown T 4.9999999999999982 -40 35 7.5 -39.330127018922191 37.500000000000007 #
+face $-1 -1 -1 $-1 $1951 $1943 $11 $-1 $388 reversed single T 4.9999999999999982 -40 32.5 10 -39.330127018922191 37.500000000000007 F #
+point $-1 -1 -1 $-1 7.5 -39.330127018922198 37.500000000000007 #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922198 32.5 #
+edge $-1 -1 -1 $-1 $2423 1.5707963267948966 $1633 2.0943951023931953 $1946 $3036 forward @7 unknown T 4.9999999999999982 -30.669872981077809 32.5 7.4999999999999982 -30 35 #
+coedge $-1 -1 -1 $-1 $1947 $2314 $2802 $3037 reversed $1948 $-1 #
+face $-1 -1 -1 $-1 $3038 $1948 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 35 7.5000000000000027 -30 50 F #
+vertex $-1 -1 -1 $-1 $3039 $3040 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2992 $2266 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 20 0 -35 35 F #
+point $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 50 #
+point $-1 -1 -1 $-1 50 -35 -29.999999999999996 #
+coedge $-1 -1 -1 $-1 $3041 $2517 $3042 $2061 reversed $1960 $-1 #
+coedge $-1 -1 -1 $-1 $2429 $2429 $3043 $3044 reversed $1961 $-1 #
+coedge $-1 -1 -1 $-1 $1962 $1962 $3045 $3046 forward $1643 $-1 #
+coedge $-1 -1 -1 $-1 $3047 $3048 $1962 $2432 reversed $3049 $-1 #
+edge $-1 -1 -1 $-1 $3050 -1.5707963267948966 $3051 1.5707963267948966 $1962 $3052 forward @7 unknown T -45 -40 -30.000000000000004 -40 -30 -25.000000000000004 #
+face $-1 -1 -1 $-1 $3053 $3054 $11 $-1 $1965 reversed single T -50 -25 29.999999999999996 -40 -14.999999999999996 40 F #
+loop $-1 -1 -1 $-1 $-1 $3055 $1963 T -10.000000000000002 -25 32.5 -5 -24.330127018922191 37.500000000000007 unknown #
+loop $-1 -1 -1 $-1 $-1 $3056 $1644 T 50 -25 30 50 -15 40 unknown #
+coedge $-1 -1 -1 $-1 $3057 $3057 $2163 $2700 reversed $1964 $-1 #
+coedge $-1 -1 -1 $-1 $2437 $2437 $3058 $3059 reversed $1966 $-1 #
+coedge $-1 -1 -1 $-1 $1967 $1967 $3060 $3061 forward $1645 $-1 #
+coedge $-1 -1 -1 $-1 $3062 $3063 $1967 $2440 reversed $3064 $-1 #
+edge $-1 -1 -1 $-1 $3065 -1.5707963267948966 $3066 1.5707963267948966 $1967 $3067 forward @7 unknown T -45 -40 -45 -40 -30 -40 #
+coedge $-1 -1 -1 $-1 $1969 $1968 $3068 $3069 reversed $1402 $-1 #
+coedge $-1 -1 -1 $-1 $3070 $3071 $1968 $2443 forward $3072 $-1 #
+edge $-1 -1 -1 $-1 $3073 -1.5707963267948966 $2450 -1.047197551196597 $2442 $3074 forward @7 unknown T -22.500000000000004 -30.669872981077809 -42.500000000000007 -20 -30 -40 #
+coedge $-1 -1 -1 $-1 $3075 $3076 $1969 $2445 reversed $3077 $-1 #
+edge $-1 -1 -1 $-1 $3078 -2.0943951023931953 $2449 -1.5707963267948966 $1969 $3079 forward @7 unknown T -25.000000000000004 -30.669872981077809 -40 -22.500000000000004 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $3080 $1970 $3081 $3082 reversed $2448 $-1 #
+coedge $-1 -1 -1 $-1 $1970 $3083 $3070 $3084 reversed $2448 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2447 $3085 T -30.000000000000004 -35 -50 -22.5 -30 -40 unknown #
+vertex $-1 -1 -1 $-1 $3082 $3086 #
+vertex $-1 -1 -1 $-1 $1971 $3087 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3088 $3089 $1972 $2453 forward $3090 $-1 #
+edge $-1 -1 -1 $-1 $2462 1.0471975511965974 $2457 1.5707963267948966 $2452 $3091 forward @7 unknown T -7.5000000000000027 -40 -42.500000000000007 -5 -39.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $3092 $1973 $1978 $2468 forward $2456 $-1 #
+coedge $-1 -1 -1 $-1 $1973 $3093 $3094 $3095 forward $2456 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3093 $3096 T -7.5000000000000027 -40 -40 0 -35 -25 unknown #
+vertex $-1 -1 -1 $-1 $2453 $3097 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3098 $1975 $3089 $3099 reversed $2461 $-1 #
+coedge $-1 -1 -1 $-1 $1975 $3100 $3101 $2470 reversed $2461 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2459 $3102 T -15.000000000000002 -40 -50 -7.5000000000000009 -35 -40 unknown #
+vertex $-1 -1 -1 $-1 $2453 $3103 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3104 $1977 $3105 $3106 forward $1979 $-1 #
+coedge $-1 -1 -1 $-1 $3101 $3107 $1977 $2466 forward $3108 $-1 #
+edge $-1 -1 -1 $-1 $3109 6.1232339957367648e-17 $1980 1.5707963267948966 $2465 $3110 forward @7 unknown T -15.000000000000002 -40 -40 -10.000000000000002 -35 -35 #
+coedge $-1 -1 -1 $-1 $1978 $3104 $3111 $3112 reversed $1979 $-1 #
+edge $-1 -1 -1 $-1 $1981 -37.5 $3113 -27.500000000000004 $2454 $3114 forward @7 unknown T -7.5000000000000027 -39.330127018922198 -37.5 -7.5000000000000009 -39.330127018922191 -27.500000000000004 #
+face $-1 -1 -1 $-1 $3102 $1979 $11 $-1 $2541 reversed single T -15.000000000000002 -40 -40 -7.5000000000000009 -35 -25 F #
+edge $-1 -1 -1 $-1 $1980 -1.5707963267948966 $3115 -6.1232339957367648e-17 $3101 $3116 forward @7 unknown T -15.000000000000002 -40 -45 -10.000000000000002 -35 -40 #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 -40 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -37.5 #
+loop $-1 -1 -1 $-1 $3117 $3118 $1558 T 50 -25 30 50 -15 40 hole $1559 T #
+point $-1 -1 -1 $-1 50 -35 -45 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $3119 $3120 #
+coedge $-1 -1 -1 $-1 $1991 $2088 $2390 $2222 forward $1416 $-1 #
+ellipse-curve $-1 -1 -1 $-1 19.999999999999996 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2983 1.5707963267948966 $1998 3.1415926535897931 $2002 $3121 forward @7 unknown T 10 -35 -40 15 -30 -35 #
+edge $-1 -1 -1 $-1 $1998 3.1415926535897931 $2996 4.7123889803846897 $2484 $3121 forward @7 unknown T 10 -40 -40 15 -35 -35 #
+point $-1 -1 -1 $-1 15 -35 -35 #
+coedge $-1 -1 -1 $-1 $2002 $2778 $3122 $3123 forward $2004 $-1 #
+coedge $-1 -1 -1 $-1 $3124 $2003 $2383 $2480 forward $2485 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2003 $3125 T 7.4999999999999982 -40 -40 15 -35 -25 unknown #
+edge $-1 -1 -1 $-1 $1681 -2.0943951023931957 $2011 -1.5707963267948966 $2008 $3126 forward @7 unknown T 19.999999999999996 -40 -42.500000000000007 22.500000000000004 -39.330127018922191 -40 #
+point $-1 -1 -1 $-1 19.999999999999996 -40 -40 #
+coedge $-1 -1 -1 $-1 $3127 $2014 $3128 $3129 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $3130 $3131 $2014 $2491 reversed $3132 $-1 #
+edge $-1 -1 -1 $-1 $2498 0 $3133 1.5707963267948966 $2014 $3134 forward @7 unknown T -5 -35 0 0 -30 5 #
+coedge $-1 -1 -1 $-1 $2015 $3127 $3135 $3136 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $2062 $2056 $2015 $2494 reversed $2063 $-1 #
+edge $-1 -1 -1 $-1 $3137 1.5707963267948966 $2497 3.1415926535897931 $2015 $3138 forward @7 unknown T -5 -35 -10 0 -30 -5 #
+coedge $-1 -1 -1 $-1 $2016 $2520 $3139 $3140 forward $2032 $-1 #
+coedge $-1 -1 -1 $-1 $3141 $3142 $2055 $2017 forward $3143 $-1 #
+vertex $-1 -1 -1 $-1 $2522 $3144 #
+vertex $-1 -1 -1 $-1 $2491 $3145 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $3146 $2018 $3147 T -50 -40 -15.000000000000004 -50 -30 -5.0000000000000036 hole $3148 T #
+vertex $-1 -1 -1 $-1 $2019 $3149 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 -10.000000000000004 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $3150 $2020 $3151 $3152 reversed $2505 $-1 #
+coedge $-1 -1 -1 $-1 $2020 $3153 $3154 $3155 reversed $2505 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2504 $3156 T -45 -40 -10.000000000000002 -37.5 -30 4.9999999999999973 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -10.000000000000002 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2513 $2022 $3157 $3158 reversed $2024 $-1 #
+coedge $-1 -1 -1 $-1 $3154 $3159 $2022 $2509 forward $3160 $-1 #
+edge $-1 -1 -1 $-1 $3161 -2.0943951023931957 $2025 -1.5707963267948966 $2508 $3162 forward @7 unknown T -40 -40 -12.500000000000004 -37.5 -39.330127018922191 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $2023 $3163 $3164 $3165 reversed $2024 $-1 #
+coedge $-1 -1 -1 $-1 $3166 $3151 $2023 $2512 forward $3167 $-1 #
+edge $-1 -1 -1 $-1 $2026 1.5707963267948966 $3168 2.0943951023931948 $2511 $3169 forward @7 unknown T -40 -30.669872981077805 -12.500000000000004 -37.5 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $3045 $2507 $3170 $3171 reversed $2024 $-1 #
+face $-1 -1 -1 $-1 $3156 $2024 $11 $-1 $3172 reversed single T -45 -40 -25.000000000000004 -37.499999999999993 -30 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -40 -40 -10.000000000000002 #
+point $-1 -1 -1 $-1 -40 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $2428 $2028 $3173 $3174 forward $1960 $-1 #
+coedge $-1 -1 -1 $-1 $2028 $3175 $2035 $2526 forward $1960 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -10 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2495 $2030 $2207 $2756 forward $2032 $-1 #
+coedge $-1 -1 -1 $-1 $3176 $3173 $2031 $2522 reversed $3177 $-1 #
+edge $-1 -1 -1 $-1 $2497 3.1415926535897931 $2033 4.7123889803846897 $2031 $3138 forward @7 unknown T -5 -40 -10 0 -35 -5 #
+face $-1 -1 -1 $-1 $2075 $2032 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 -10 0 -35 5 F #
+point $-1 -1 -1 $-1 -5 -40 -10 #
+coedge $-1 -1 -1 $-1 $3178 $2035 $3179 $3180 reversed $2037 $-1 #
+edge $-1 -1 -1 $-1 $3181 -22.500000000000004 $2038 -12.500000000000004 $2518 $3182 forward @7 unknown T -7.5000000000000027 -39.330127018922198 -22.500000000000004 -7.5000000000000009 -39.330127018922191 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $2036 $3178 $3183 $3184 forward $2037 $-1 #
+coedge $-1 -1 -1 $-1 $3185 $2041 $2036 $2046 forward $2535 $-1 #
+face $-1 -1 -1 $-1 $2045 $2037 $11 $-1 $2541 reversed single T -15.000000000000004 -40 -25 -7.5000000000000009 -35 -10 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $2043 $2040 $3186 $2767 reversed $1700 $-1 #
+coedge $-1 -1 -1 $-1 $3187 $3188 $3189 $2533 reversed $3190 $-1 #
+edge $-1 -1 -1 $-1 $2536 -5.0000000000000018 $3191 -8.8817841970012523e-16 $3189 $3192 forward @7 unknown T -15 -35 -5.0000000000000018 -14.999999999999996 -35 -8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $2041 $3185 $3193 $3194 reversed $2535 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2041 $3195 T -20 -40 -15.000000000000002 -10.000000000000002 -35 -5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $3194 $3196 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $2756 $3197 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -39.330127018922191 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $2276 $2213 $11 $-1 $2541 reversed single T -15.000000000000002 -40 4.9999999999999991 -7.5000000000000009 -35 20 F #
+cone-surface $-1 -1 -1 $-1 -10.000000000000002 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $3198 $3199 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2066 $2779 $2051 $2545 reversed $2561 $-1 #
+edge $-1 -1 -1 $-1 $2068 4.1887902047863905 $2227 4.7123889803846897 $2051 $3200 forward @7 unknown T 7.4999999999999982 -30.669872981077813 -25 10 -30 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $2055 $2053 $3130 $3201 reversed $1712 $-1 #
+coedge $-1 -1 -1 $-1 $2571 $2770 $2053 $2548 forward $2771 $-1 #
+edge $-1 -1 -1 $-1 $3202 1.5707963267948966 $2549 2.0943951023931948 $2547 $3203 forward @7 unknown T 4.9999999999999982 -30.669872981077805 2.4999999999999996 7.4999999999999973 -30 5 #
+vertex $-1 -1 -1 $-1 $2054 $3204 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3205 $2060 $2062 $2557 forward $2554 $-1 #
+coedge $-1 -1 -1 $-1 $2060 $3206 $2565 $3207 forward $2554 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2060 $3208 T -7.5000000000000053 -35 -25 8.8817841970012523e-16 -30 -10 unknown #
+vertex $-1 -1 -1 $-1 $3209 $3210 #
+edge $-1 -1 -1 $-1 $2064 0 $3137 1.5707963267948966 $2552 $3211 forward @7 unknown T -5 -35 -15 8.8817841970012523e-16 -30 -10 #
+face $-1 -1 -1 $-1 $3208 $2063 $11 $-1 $336 reversed single T -5 -35 -15 4.9999999999999982 -30 -5 F #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 -35 -15 #
+coedge $-1 -1 -1 $-1 $2779 $2066 $3212 $3213 forward $2561 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2066 $3214 T 4.9999999999999956 -30.669872981077813 -27.500000000000004 10 -30 -22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $3215 $3216 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077813 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $3217 $2070 $2553 $3207 reversed $2567 $-1 #
+coedge $-1 -1 -1 $-1 $2070 $3217 $3218 $3215 forward $2567 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2566 $3219 T -5 -35 -30 5 -30 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3220 $3143 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 -10 7.4999999999999991 -35 5 F #
+loop $-1 -1 -1 $-1 $-1 $3221 $2072 T -1.7763568394002505e-15 -40 -25 7.5 -35 -10 unknown #
+coedge $-1 -1 -1 $-1 $2217 $2547 $2074 $2220 reversed $2771 $-1 #
+face $-1 -1 -1 $-1 $3222 $2598 $11 $-1 $336 reversed single T 4.9999999999999982 -40 -12.500000000000002 10 -39.330127018922191 -7.4999999999999991 F #
+face $-1 -1 -1 $-1 $3223 $3224 $11 $-1 $1477 reversed single T 15 -25 -25 22.5 -20 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $3225 $2078 T 15 -20 -25 22.5 -15 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $3226 $3227 $3228 $3229 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $3230 $2080 $3231 $3232 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $2080 $3233 $3234 $3235 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $3236 $3237 $2080 $2579 forward $3238 $-1 #
+edge $-1 -1 -1 $-1 $3239 -1.5707963267948966 $3240 6.1232339957367673e-17 $2578 $3241 forward @7 unknown T 14.999999999999996 -20 5.0000000000000009 20 -15 10 #
+coedge $-1 -1 -1 $-1 $3242 $2081 $2177 $2712 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $3243 $2182 $2081 $2582 forward $2719 $-1 #
+edge $-1 -1 -1 $-1 $2720 -2.0943951023931939 $2589 -1.5707963267948966 $2581 $3244 forward @7 unknown T 20 -15.669872981077805 20 22.499999999999996 -15 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $2082 $3242 $3245 $3246 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $3247 $3248 $3249 $2585 forward $3250 $-1 #
+edge $-1 -1 -1 $-1 $2590 25 $3251 30 $2584 $3252 forward @7 unknown T 15 -20 25 15 -20 30 #
+coedge $-1 -1 -1 $-1 $3253 $2083 $3248 $3254 reversed $2588 $-1 #
+coedge $-1 -1 -1 $-1 $2083 $3253 $3233 $3255 forward $2588 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2083 $2685 T 10 -20 15 20 -15 25 unknown #
+vertex $-1 -1 -1 $-1 $3255 $3256 #
+vertex $-1 -1 -1 $-1 $3257 $3258 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2593 $2085 $3259 $3260 forward $2086 $-1 #
+coedge $-1 -1 -1 $-1 $2087 $2592 $3261 $3262 forward $2086 $-1 #
+coedge $-1 -1 -1 $-1 $3263 $2089 $2087 $2091 reversed $2598 $-1 #
+coedge $-1 -1 -1 $-1 $3264 $3265 $2088 $2596 reversed $3143 $-1 #
+edge $-1 -1 -1 $-1 $2599 -7.4999999999999991 $2776 2.5000000000000009 $2088 $3266 forward @7 unknown T 7.4999999999999991 -39.330127018922198 -7.4999999999999991 7.4999999999999991 -39.330127018922191 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $2089 $3263 $3264 $3267 forward $2598 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3263 $2572 T 4.9999999999999982 -40 -12.500000000000002 10 -39.330127018922191 -7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $3267 $3268 #
+vertex $-1 -1 -1 $-1 $2091 $3269 #
+face $-1 -1 -1 $-1 $2358 $2942 $11 $-1 $704 reversed single T 30 -25.000000000000004 35 37.5 -20 50 F #
+coedge $-1 -1 -1 $-1 $2684 $3270 $3271 $3272 reversed $2094 $-1 #
+coedge $-1 -1 -1 $-1 $2655 $2095 $3273 $3274 reversed $1745 $-1 #
+coedge $-1 -1 -1 $-1 $2095 $3275 $3276 $3277 reversed $1745 $-1 #
+coedge $-1 -1 -1 $-1 $3278 $3279 $2095 $2606 forward $3280 $-1 #
+edge $-1 -1 -1 $-1 $3281 1.5707963267948966 $3282 2.0943951023931948 $2605 $3283 forward @7 unknown T 35 -25.000000000000004 -9.9999999999999982 37.500000000000007 -24.330127018922198 -7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $3284 $2096 $1748 $2105 forward $1485 $-1 #
+coedge $-1 -1 -1 $-1 $3285 $3286 $2096 $2609 forward $3287 $-1 #
+edge $-1 -1 -1 $-1 $2110 -6.4931039580273265e-16 $2616 1.5707963267948966 $2608 $3288 forward @7 unknown T 29.999999999999996 -25.000000000000004 -24.999999999999996 35 -20 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $2097 $3284 $3279 $3289 reversed $1485 $-1 #
+coedge $-1 -1 -1 $-1 $3290 $3291 $2097 $2612 forward $3292 $-1 #
+edge $-1 -1 -1 $-1 $2617 -22.499999999999989 $3293 -12.499999999999995 $2611 $3294 forward @7 unknown T 37.5 -24.330127018922198 -22.499999999999989 37.5 -24.330127018922187 -12.499999999999995 #
+coedge $-1 -1 -1 $-1 $3295 $2098 $3291 $3296 reversed $2615 $-1 #
+coedge $-1 -1 -1 $-1 $2098 $3295 $3297 $3298 forward $2615 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2614 $3299 T 35 -25.000000000000004 -27.499999999999993 40.000000000000007 -24.330127018922187 -22.499999999999986 unknown #
+vertex $-1 -1 -1 $-1 $3300 $3301 #
+vertex $-1 -1 -1 $-1 $2612 $3302 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2103 $2100 $2115 $2647 reversed $1262 $-1 #
+coedge $-1 -1 -1 $-1 $3303 $3304 $2100 $2621 forward $3292 $-1 #
+edge $-1 -1 -1 $-1 $3305 12.500000000000002 $2625 22.499999999999996 $2620 $3306 forward @7 unknown T 37.499999999999993 -15.669872981077814 -22.499999999999996 37.500000000000007 -15.669872981077805 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $3307 $2101 $3308 $3309 forward $2624 $-1 #
+coedge $-1 -1 -1 $-1 $2101 $3307 $3303 $3310 reversed $2624 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2101 $3311 T 35 -15.669872981077814 -27.499999999999993 40.000000000000007 -15 -22.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $3310 $3312 #
+coedge $-1 -1 -1 $-1 $3313 $2104 $2126 $2659 forward $2630 $-1 #
+coedge $-1 -1 -1 $-1 $2104 $3314 $2106 $2634 forward $2630 $-1 #
+coedge $-1 -1 -1 $-1 $3315 $3316 $2607 $2105 reversed $3317 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2104 $2663 T 22.499999999999996 -20 -25 30 -15 -9.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $2659 $3318 #
+straight-curve $-1 -1 -1 $-1 30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2107 $2106 $3319 $3320 reversed $2108 $-1 #
+edge $-1 -1 -1 $-1 $3321 1.5707963267948966 $2110 3.1415926535897931 $2628 $3322 forward @7 unknown T 25 -20 -25 29.999999999999996 -15 -20 #
+coedge $-1 -1 -1 $-1 $3323 $3308 $2107 $2636 reversed $3324 $-1 #
+edge $-1 -1 -1 $-1 $3325 6.4931039580273206e-16 $2109 1.5707963267948966 $2107 $3326 forward @7 unknown T 29.999999999999996 -20 -30 35 -15.000000000000004 -24.999999999999996 #
+face $-1 -1 -1 $-1 $3327 $2108 $11 $-1 $3328 reversed single T 25 -20 -30 35 -15 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 -15.000000000000004 -24.999999999999996 #
+edge $-1 -1 -1 $-1 $2110 3.1415926535897931 $3329 4.7123889803846897 $3315 $3322 forward @7 unknown T 25 -25 -25 29.999999999999996 -20 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 -20 -20 #
+coedge $-1 -1 -1 $-1 $3330 $2113 $2116 $2648 forward $2643 $-1 #
+coedge $-1 -1 -1 $-1 $2113 $3331 $2138 $2670 forward $2643 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2113 $3332 T 37.499999999999986 -25 -9.9999999999999982 45.000000000000007 -15 5.0000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $2114 $3333 #
+straight-curve $-1 -1 -1 $-1 37.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $2116 $2115 $3304 $3334 reversed $2117 $-1 #
+edge $-1 -1 -1 $-1 $1760 1.5707963267948966 $3305 2.0943951023931948 $2115 $3335 forward @7 unknown T 35 -15.669872981077809 -12.500000000000002 37.5 -15.000000000000004 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $2118 4.1887902047863905 $3336 4.7123889803846897 $2641 $3337 forward @7 unknown T 37.5 -15.669872981077809 -9.9999999999999982 40 -15 -7.4999999999999947 #
+face $-1 -1 -1 $-1 $3338 $2117 $11 $-1 $2664 reversed single T 35 -15.669872981077813 -12.500000000000004 40 -15 -7.4999999999999947 F #
+point $-1 -1 -1 $-1 37.5 -15.669872981077809 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $3339 $2120 $3340 $2687 forward $2123 $-1 #
+coedge $-1 -1 -1 $-1 $2121 $3339 $3341 $3342 forward $2123 $-1 #
+coedge $-1 -1 -1 $-1 $3343 $2122 $3344 $2131 forward $2656 $-1 #
+coedge $-1 -1 -1 $-1 $2122 $3345 $3346 $3347 forward $2656 $-1 #
+coedge $-1 -1 -1 $-1 $3348 $2603 $1488 $1756 forward $1745 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2122 $3349 T 22.5 -25 -9.9999999999999982 30 -20 5.0000000000000036 unknown #
+face $-1 -1 -1 $-1 $3350 $2123 $11 $-1 $2194 reversed single T 22.5 -20 -9.9999999999999982 30 -15 5.0000000000000036 F #
+point $-1 -1 -1 $-1 29.999999999999996 -20 1.7763568394002505e-15 #
+edge $-1 -1 -1 $-1 $2631 0 $2660 1.5707963267948966 $2627 $3351 forward @7 unknown T 25 -20 -14.999999999999998 30 -15 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $3352 $3353 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 -9.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3354 $2630 $11 $-1 $2194 reversed single T 22.499999999999996 -20 -25 30 -15 -9.9999999999999964 F #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 -20 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $3355 $3356 #
+coedge $-1 -1 -1 $-1 $3357 $2133 $3358 $3359 forward $2135 $-1 #
+coedge $-1 -1 -1 $-1 $2134 $3360 $3361 $3362 forward $2135 $-1 #
+face $-1 -1 -1 $-1 $1522 $2135 $11 $-1 $2703 reversed single T 37.499999999999986 -25 5.0000000000000027 45.000000000000007 -15 20.000000000000007 F #
+point $-1 -1 -1 $-1 37.499999999999986 -15.669872981077805 17.500000000000007 #
+edge $-1 -1 -1 $-1 $2672 -1.570796326794897 $2644 -1.0471975511965974 $2642 $3363 forward @7 unknown T 37.499999999999986 -15.669872981077809 2.5000000000000018 40 -15 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $2670 $3364 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2144 $2143 $3230 $3365 forward $1774 $-1 #
+coedge $-1 -1 -1 $-1 $2182 $3243 $2143 $2196 reversed $2719 $-1 #
+coedge $-1 -1 -1 $-1 $3231 $3340 $2144 $2677 reversed $3366 $-1 #
+edge $-1 -1 -1 $-1 $3367 4.1887902047863914 $2152 4.7123889803846897 $2144 $3368 forward @7 unknown T 22.5 -15.669872981077807 5.0000000000000018 25 -15 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $3369 $2145 $3370 $3371 forward $2148 $-1 #
+coedge $-1 -1 -1 $-1 $3372 $3346 $2145 $1782 reversed $2690 $-1 #
+coedge $-1 -1 -1 $-1 $2146 $3369 $3373 $2200 forward $2148 $-1 #
+coedge $-1 -1 -1 $-1 $2185 $3374 $2146 $2682 reversed $2199 $-1 #
+edge $-1 -1 -1 $-1 $1816 -1.5707963267948961 $1775 0 $2146 $2195 forward @7 unknown T 25 -25 15 29.999999999999996 -20 20 #
+coedge $-1 -1 -1 $-1 $3375 $2147 $3374 $3376 reversed $2094 $-1 #
+coedge $-1 -1 -1 $-1 $2147 $2602 $3372 $3377 reversed $2094 $-1 #
+face $-1 -1 -1 $-1 $3378 $2588 $11 $-1 $1815 reversed single T 10 -20 15 20 -15 25 F #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2152 -1.570796326794897 $3379 -1.0471975511965983 $2651 $3380 forward @7 unknown T 22.5 -15.669872981077805 2.5000000000000036 25 -15 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 -15 5.0000000000000018 #
+face $-1 -1 -1 $-1 $2141 $3381 $11 $-1 $2156 reversed single T 35 -25.000000000000004 2.5000000000000053 40.000000000000007 -24.330127018922191 7.5000000000000062 F #
+loop $-1 -1 -1 $-1 $-1 $3372 $2155 T 24.999999999999996 -25.000000000000004 1.7763568394002505e-15 35 -20 10.000000000000002 unknown #
+edge $-1 -1 -1 $-1 $3382 1.0471975511965992 $2157 1.570796326794897 $3345 $3380 forward @7 unknown T 22.500000000000004 -25 2.5000000000000049 25 -24.330127018922195 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 -25 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $2159 $2158 $2944 $3383 reversed $2160 $-1 #
+edge $-1 -1 -1 $-1 $2963 -2.0943951023931953 $1799 -1.5707963267948966 $2159 $3384 forward @7 unknown T 35 -15.669872981077813 35 37.5 -15.000000000000004 37.5 #
+face $-1 -1 -1 $-1 $2192 $2160 $11 $-1 $1965 reversed single T 35 -15.669872981077813 32.499999999999993 40 -15 37.5 F #
+coedge $-1 -1 -1 $-1 $3385 $2162 $3386 $3387 forward $1788 $-1 #
+coedge $-1 -1 -1 $-1 $3361 $3361 $2162 $2698 reversed $3388 $-1 #
+edge $-1 -1 -1 $-1 $2169 1.570796326794897 $3389 4.7123889803846897 $2162 $3390 forward @7 unknown T 39.999999999999993 -25 20.000000000000004 44.999999999999993 -15 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $2163 $3385 $3391 $3392 forward $1788 $-1 #
+edge $-1 -1 -1 $-1 $3393 -1.5707963267948966 $2701 1.5707963267948966 $2163 $3394 forward @7 unknown T 40 -25 30 45 -15 35 #
+vertex $-1 -1 -1 $-1 $2164 $3395 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+cone-surface $-1 -1 -1 $-1 40 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -15 20.000000000000004 #
+face $-1 -1 -1 $-1 $3396 $3397 $11 $-1 $2703 reversed single T 37.499999999999986 -25 -40 45.000000000000007 -15 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $2351 $2957 $2172 $2708 forward $2352 $-1 #
+edge $-1 -1 -1 $-1 $2180 1.5707963267948966 $2709 3.1415926535897931 $2707 $3398 forward @7 unknown T 25 -20 35 30 -15 40 #
+vertex $-1 -1 -1 $-1 $3399 $3400 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $3401 $2730 $11 $-1 $1965 reversed single T 25 -25.000000000000004 30 35 -20 40 F #
+edge $-1 -1 -1 $-1 $2716 -32.5 $2720 -22.499999999999993 $2177 $3402 forward @7 unknown T 22.499999999999996 -15.669872981077809 22.499999999999993 22.500000000000004 -15.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $3403 $2178 $2957 $3404 reversed $2715 $-1 #
+coedge $-1 -1 -1 $-1 $2178 $3403 $3242 $3405 forward $2715 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3403 $3406 T 20 -15.669872981077809 32.5 25 -15 37.5 unknown #
+vertex $-1 -1 -1 $-1 $2712 $3407 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 25 -15 35 #
+loop $-1 -1 -1 $-1 $-1 $2581 $3408 T 20 -15.669872981077809 17.5 25 -15 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $2183 $3409 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2186 $2184 $3410 $3411 forward $1807 $-1 #
+coedge $-1 -1 -1 $-1 $3373 $3412 $2184 $2724 reversed $3413 $-1 #
+edge $-1 -1 -1 $-1 $1816 1.5707963267948961 $3414 2.0943951023931948 $2184 $2721 forward @7 unknown T 22.499999999999993 -25 19.999999999999996 25 -24.330127018922191 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $3374 $2185 $2190 $2735 forward $2199 $-1 #
+coedge $-1 -1 -1 $-1 $3415 $3416 $2186 $2727 reversed $3417 $-1 #
+edge $-1 -1 -1 $-1 $3418 1.0471975511965987 $2731 1.5707963267948966 $2186 $2717 forward @7 unknown T 22.500000000000004 -25 32.500000000000007 25 -24.330127018922195 35 #
+coedge $-1 -1 -1 $-1 $3419 $2187 $3420 $3399 reversed $2730 $-1 #
+coedge $-1 -1 -1 $-1 $2187 $3419 $2189 $2733 forward $2730 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3419 $2711 T 25 -25.000000000000004 30 35 -20 40 unknown #
+vertex $-1 -1 -1 $-1 $2727 $3421 #
+coedge $-1 -1 -1 $-1 $3422 $2189 $3423 $3424 reversed $2191 $-1 #
+edge $-1 -1 -1 $-1 $3425 -1.5707963267948966 $1517 6.4931039580273265e-16 $2729 $3426 forward @7 unknown T 30 -25.000000000000004 30 35 -20 35 #
+coedge $-1 -1 -1 $-1 $2190 $3422 $3427 $3428 reversed $2191 $-1 #
+edge $-1 -1 -1 $-1 $1278 -6.4931039580273245e-16 $3429 1.5707963267948966 $2725 $3430 forward @7 unknown T 29.999999999999996 -25.000000000000004 20.000000000000004 35 -20 25.000000000000007 #
+face $-1 -1 -1 $-1 $3431 $3432 $11 $-1 $2703 reversed single T 37.499999999999986 -25 -50 45 -15 -40 F #
+face $-1 -1 -1 $-1 $3433 $3434 $11 $-1 $1965 reversed single T 10 -25 30 20 -20 40 F #
+loop $-1 -1 -1 $-1 $-1 $3435 $2193 T 10 -20 30 20 -15 40 unknown #
+vertex $-1 -1 -1 $-1 $3365 $3436 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+loop $-1 -1 -1 $-1 $-1 $3427 $2198 T 35 -25.000000000000004 17.500000000000007 40.000000000000007 -24.330127018922187 22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $2200 $3437 #
+coedge $-1 -1 -1 $-1 $3438 $2202 $3439 $3440 forward $1818 $-1 #
+coedge $-1 -1 -1 $-1 $2202 $3441 $3131 $3442 forward $1818 $-1 #
+coedge $-1 -1 -1 $-1 $2758 $2830 $3443 $2746 reversed $2759 $-1 #
+edge $-1 -1 -1 $-1 $3444 10 $3445 15 $2202 $3446 forward @7 unknown T -8.8817841970012523e-16 -35 10 0 -35 15 #
+coedge $-1 -1 -1 $-1 $2747 $2747 $2203 $2748 forward $3447 $-1 #
+edge $-1 -1 -1 $-1 $3448 0 $3448 6.2831853071795862 $2747 $3449 forward @7 unknown T -50 -40 -3.0616169978683823e-15 -50 -30 9.9999999999999964 #
+coedge $-1 -1 -1 $-1 $3450 $2826 $2204 $2750 reversed $2258 $-1 #
+edge $-1 -1 -1 $-1 $2754 -1.5707963267948966 $2753 1.5707963267948966 $2204 $3451 forward @7 unknown T -45 -40 4.9999999999999973 -40 -30 9.9999999999999964 #
+coedge $-1 -1 -1 $-1 $3153 $2205 $3452 $3453 reversed $2505 $-1 #
+coedge $-1 -1 -1 $-1 $2205 $3150 $3454 $3455 reversed $2505 $-1 #
+vertex $-1 -1 -1 $-1 $2206 $3456 #
+vertex $-1 -1 -1 $-1 $2206 $3457 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 4.9999999999999973 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2538 1.0471975511965979 $2760 1.5707963267948966 $2520 $3458 forward @7 unknown T -7.5000000000000027 -40 2.4999999999999982 -5 -39.330127018922191 5 #
+coedge $-1 -1 -1 $-1 $2262 $2208 $2212 $2766 forward $2759 $-1 #
+coedge $-1 -1 -1 $-1 $2208 $2745 $3459 $3460 forward $2759 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2745 $2800 T -7.5000000000000027 -40 5 0 -35 20 unknown #
+vertex $-1 -1 -1 $-1 $2756 $3461 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 5 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2269 $2211 $3462 $3463 forward $2213 $-1 #
+coedge $-1 -1 -1 $-1 $3186 $3464 $2211 $2765 forward $3465 $-1 #
+edge $-1 -1 -1 $-1 $3466 6.1232339957367648e-17 $2214 1.5707963267948966 $2764 $3467 forward @7 unknown T -15.000000000000002 -40 4.9999999999999991 -10.000000000000002 -35 10 #
+edge $-1 -1 -1 $-1 $2215 7.5000000000000027 $2270 17.499999999999996 $2757 $3468 forward @7 unknown T -7.5000000000000027 -39.330127018922198 7.5000000000000027 -7.5000000000000009 -39.330127018922191 17.499999999999996 #
+edge $-1 -1 -1 $-1 $2214 -1.5707963267948966 $3191 -6.1232339957367648e-17 $3186 $3469 forward @7 unknown T -15.000000000000002 -40 -1.7763568394002505e-15 -10.000000000000002 -35 4.9999999999999991 #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 4.9999999999999991 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $2547 $2217 $2791 $3470 forward $2771 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2770 $3471 T 4.9999999999999982 -30.669872981077809 2.4999999999999996 10 -30 7.5000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $2218 $3472 #
+face $-1 -1 -1 $-1 $2787 $3473 $11 $-1 $162 reversed single T -5 -40 15 4.9999999999999982 -35 25 F #
+loop $-1 -1 -1 $-1 $-1 $3474 $2219 T -5 -35 15 4.9999999999999982 -30 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -35 5.0000000000000009 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $2222 $3475 #
+coedge $-1 -1 -1 $-1 $2224 $3476 $3477 $3119 forward $2485 $-1 #
+coedge $-1 -1 -1 $-1 $2483 $2226 $3478 $3479 forward $2004 $-1 #
+coedge $-1 -1 -1 $-1 $2544 $2560 $2226 $2780 reversed $2561 $-1 #
+edge $-1 -1 -1 $-1 $2227 -1.5707963267948966 $3480 -1.0471975511965974 $2226 $3481 forward @7 unknown T 7.4999999999999982 -30.669872981077809 -27.500000000000004 10 -30 -25 #
+point $-1 -1 -1 $-1 10 -30 -25 #
+coedge $-1 -1 -1 $-1 $3482 $2229 $2231 $2786 reversed $2784 $-1 #
+coedge $-1 -1 -1 $-1 $2229 $3483 $2380 $2995 reversed $2784 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2782 $3484 T -1.7763568394002505e-15 -40 20 7.5 -35 35 unknown #
+edge $-1 -1 -1 $-1 $3485 1.5707963267948966 $2233 2.0943951023931957 $2231 $3486 forward @7 unknown T 4.9999999999999982 -40 20 7.5 -39.330127018922191 22.500000000000004 #
+face $-1 -1 -1 $-1 $2243 $2232 $11 $-1 $162 reversed single T 4.9999999999999982 -40 17.499999999999996 10 -39.330127018922191 22.500000000000004 F #
+point $-1 -1 -1 $-1 7.5 -39.330127018922198 22.500000000000004 #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922198 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $3487 $2235 $2237 $2794 reversed $2792 $-1 #
+coedge $-1 -1 -1 $-1 $2235 $3488 $2770 $3470 reversed $2792 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3488 $3489 T -1.7763568394002505e-15 -35 5 7.4999999999999991 -30 20 unknown #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -30.669872981077809 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $2798 1.5707963267948966 $1849 2.0943951023931957 $2237 $3490 forward @7 unknown T 4.9999999999999982 -30.669872981077809 17.499999999999996 7.4999999999999991 -30 20 #
+coedge $-1 -1 -1 $-1 $3491 $2238 $3492 $3039 reversed $2240 $-1 #
+coedge $-1 -1 -1 $-1 $2239 $3491 $3474 $3493 reversed $2240 $-1 #
+face $-1 -1 -1 $-1 $3489 $2240 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 20 7.4999999999999991 -30 35 F #
+vertex $-1 -1 -1 $-1 $3494 $3495 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3125 $2759 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 5 0 -35 20 F #
+loop $-1 -1 -1 $-1 $-1 $3496 $2245 T -5 -40 30 4.9999999999999982 -35 40 unknown #
+coedge $-1 -1 -1 $-1 $2848 $3492 $2421 $3037 forward $2246 $-1 #
+coedge $-1 -1 -1 $-1 $3497 $2248 $3498 $3499 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $3492 $2848 $2248 $2805 reversed $2246 $-1 #
+edge $-1 -1 -1 $-1 $2812 0 $3500 1.5707963267948966 $2248 $3501 forward @7 unknown T -5 -35 30 0 -30 35 #
+coedge $-1 -1 -1 $-1 $2249 $3497 $3502 $3503 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $3439 $3474 $2249 $2808 reversed $2774 $-1 #
+edge $-1 -1 -1 $-1 $3504 1.5707963267948966 $2811 3.1415926535897931 $2249 $3505 forward @7 unknown T -5 -35 20 0 -30 25 #
+coedge $-1 -1 -1 $-1 $2250 $2294 $3506 $3507 forward $2266 $-1 #
+coedge $-1 -1 -1 $-1 $3483 $3482 $3491 $2251 forward $2784 $-1 #
+vertex $-1 -1 -1 $-1 $2833 $3508 #
+vertex $-1 -1 -1 $-1 $2805 $3509 #
+loop $-1 -1 -1 $-1 $3447 $2252 $3147 T -50 -40 14.999999999999996 -50 -30 24.999999999999996 hole $3148 T #
+vertex $-1 -1 -1 $-1 $2253 $3510 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 19.999999999999996 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $2864 $2254 $3511 $3512 reversed $2290 $-1 #
+coedge $-1 -1 -1 $-1 $2254 $2861 $3513 $3514 reversed $2290 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 19.999999999999996 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2826 $2256 $3515 $3516 reversed $2258 $-1 #
+coedge $-1 -1 -1 $-1 $3513 $3517 $2256 $2822 forward $3518 $-1 #
+edge $-1 -1 -1 $-1 $3519 -2.0943951023931966 $2259 -1.5707963267948966 $2821 $3520 forward @7 unknown T -40 -40 17.499999999999989 -37.499999999999993 -39.330127018922191 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $2257 $3450 $3521 $3522 reversed $2258 $-1 #
+coedge $-1 -1 -1 $-1 $3523 $3511 $2257 $2825 forward $3524 $-1 #
+edge $-1 -1 -1 $-1 $2260 1.5707963267948966 $3525 2.0943951023931957 $2824 $3526 forward @7 unknown T -40 -30.669872981077809 17.499999999999996 -37.5 -30 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $2749 $2820 $3527 $3528 reversed $2258 $-1 #
+face $-1 -1 -1 $-1 $2867 $2258 $11 $-1 $3172 reversed single T -45 -40 4.9999999999999973 -37.499999999999993 -30 19.999999999999996 F #
+point $-1 -1 -1 $-1 -40 -40 19.999999999999996 #
+point $-1 -1 -1 $-1 -40 -30 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $2745 $2262 $3529 $3530 forward $2759 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3531 $3529 $2265 $2833 reversed $3473 $-1 #
+edge $-1 -1 -1 $-1 $2811 3.1415926535897931 $2267 4.7123889803846897 $2265 $3505 forward @7 unknown T -5 -40 20 0 -35 25 #
+point $-1 -1 -1 $-1 -5 -40 20 #
+coedge $-1 -1 -1 $-1 $3532 $2273 $2269 $2277 forward $2840 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $3533 $3534 $3535 $2838 reversed $3536 $-1 #
+edge $-1 -1 -1 $-1 $2841 25 $2886 30 $3535 $3537 forward @7 unknown T -15 -35 25 -15 -35 30 #
+coedge $-1 -1 -1 $-1 $2273 $3532 $3538 $3539 reversed $2840 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2273 $3540 T -20 -40 15 -10.000000000000002 -35 25 unknown #
+vertex $-1 -1 -1 $-1 $3539 $3541 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $3542 $3543 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2847 $2280 $3544 $3545 forward $1569 $-1 #
+coedge $-1 -1 -1 $-1 $2281 $2846 $2970 $3546 forward $1569 $-1 #
+coedge $-1 -1 -1 $-1 $2804 $2802 $2281 $2849 reversed $2246 $-1 #
+edge $-1 -1 -1 $-1 $3500 1.5707963267948966 $2852 3.1415926535897931 $2281 $3547 forward @7 unknown T -5 -35 35 0 -30 40 #
+coedge $-1 -1 -1 $-1 $2282 $2296 $2318 $2893 reversed $1953 $-1 #
+coedge $-1 -1 -1 $-1 $2319 $3032 $2314 $2283 forward $2414 $-1 #
+vertex $-1 -1 -1 $-1 $2872 $3548 #
+loop $-1 -1 -1 $-1 $2814 $2284 $3147 T -50 -40 29.999999999999996 -50 -30 40 hole $3148 T #
+vertex $-1 -1 -1 $-1 $2285 $3549 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $3550 $2286 $3551 $3552 reversed $2859 $-1 #
+coedge $-1 -1 -1 $-1 $2286 $3553 $3554 $3555 reversed $2859 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3550 $3556 T -45 -40 35 -37.5 -30 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $2818 $2288 $3557 $3558 reversed $2290 $-1 #
+coedge $-1 -1 -1 $-1 $3554 $3559 $2288 $2863 forward $3560 $-1 #
+edge $-1 -1 -1 $-1 $3561 -2.0943951023931926 $2291 -1.5707963267948966 $2862 $3562 forward @7 unknown T -40 -40 32.500000000000007 -37.500000000000014 -39.330127018922198 35 #
+coedge $-1 -1 -1 $-1 $2289 $2817 $3563 $3564 reversed $2290 $-1 #
+coedge $-1 -1 -1 $-1 $3565 $3551 $2289 $2866 forward $3566 $-1 #
+edge $-1 -1 -1 $-1 $2292 1.5707963267948966 $3567 2.0943951023931948 $2865 $3568 forward @7 unknown T -40 -30.669872981077805 32.5 -37.5 -30 35 #
+face $-1 -1 -1 $-1 $3556 $2290 $11 $-1 $3172 reversed single T -45 -40 19.999999999999996 -37.499999999999993 -30 35 F #
+point $-1 -1 -1 $-1 -40 -40 35 #
+point $-1 -1 -1 $-1 -40 -30 35 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3496 $3506 $2297 $2872 reversed $2801 $-1 #
+edge $-1 -1 -1 $-1 $2852 3.1415926535897931 $2298 4.7123889803846897 $2297 $3547 forward @7 unknown T -5 -40 35 0 -35 40 #
+point $-1 -1 -1 $-1 -5 -40 35 #
+coedge $-1 -1 -1 $-1 $3569 $2304 $2300 $2309 forward $2878 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 32.5 #
+coedge $-1 -1 -1 $-1 $3570 $2889 $2979 $2367 reversed $3571 $-1 #
+coedge $-1 -1 -1 $-1 $2304 $3569 $2365 $2974 reversed $2878 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2304 $2362 T -20 -40 30 -10.000000000000002 -35 40 unknown #
+vertex $-1 -1 -1 $-1 $2974 $3572 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2976 $2318 $2306 $2882 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $2883 2.617993877991494 $2978 4.7123889803846897 $2881 $3573 forward @7 unknown T -15.000000000000002 -40 50 -7.5000000000000009 -35 50 #
+vertex $-1 -1 -1 $-1 $2307 $3574 #
+face $-1 -1 -1 $-1 $3575 $3576 $11 $-1 $2541 reversed single T -15.000000000000002 -35 -50 -7.4999999999999973 -30 -40 F #
+vertex $-1 -1 -1 $-1 $3577 $3578 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2312 $3579 $3580 $3581 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $2876 $3544 $2312 $2890 reversed $3571 $-1 #
+edge $-1 -1 -1 $-1 $2978 -1.5707963267948966 $2891 0.52359877559829937 $2312 $3582 forward @7 unknown T -15.000000000000002 -35 50 -7.5 -30 50 #
+vertex $-1 -1 -1 $-1 $2313 $3583 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 50 -0 -0 -1 5 0 0 1 I I #
+edge $-1 -1 -1 $-1 $2315 0 $2883 2.0943951023931957 $2318 $2892 forward @7 unknown T -7.5000000000000009 -40 50 0 -35 50 #
+point $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 50 #
+loop $-1 -1 -1 $-1 $-1 $3584 $1122 T -50 -50 50 50 50 50 unknown #
+coedge $-1 -1 -1 $-1 $3585 $3586 $3587 $3588 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $3589 $2322 $3590 $3591 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $2322 $3592 $3593 $3594 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $3595 $3596 $2322 $2901 reversed $3597 $-1 #
+edge $-1 -1 -1 $-1 $3598 -1.5707963267948957 $3599 0.5235987755982987 $2322 $3600 forward @7 unknown T 30 25 50 37.5 29.999999999999996 50 #
+coedge $-1 -1 -1 $-1 $3601 $2323 $3602 $3603 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $3604 $3605 $2323 $2904 reversed $3606 $-1 #
+edge $-1 -1 -1 $-1 $2912 -2.0943951023931948 $3607 2.0943951023931957 $2323 $3608 forward @7 unknown T 37.5 5 50 45 15 50 #
+coedge $-1 -1 -1 $-1 $2324 $3609 $3610 $3611 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $3612 $3613 $2324 $2907 reversed $3614 $-1 #
+edge $-1 -1 -1 $-1 $3615 -2.0943951023931948 $2911 0 $2324 $3616 forward @7 unknown T 22.5 10 50 30 15 50 #
+coedge $-1 -1 -1 $-1 $3617 $2325 $3613 $3618 reversed $2910 $-1 #
+coedge $-1 -1 -1 $-1 $2325 $3619 $3604 $3620 reversed $2910 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2909 $3621 T 30 10 35 37.5 14.999999999999998 50 unknown #
+vertex $-1 -1 -1 $-1 $3622 $3623 #
+vertex $-1 -1 -1 $-1 $2904 $3624 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $3625 $2327 $3626 $2935 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $3627 $3628 $2327 $2916 reversed $3629 $-1 #
+edge $-1 -1 -1 $-1 $2920 2.617993877991494 $2336 4.7123889803846897 $2327 $3630 forward @7 unknown T 30 -10.000000000000002 50 37.5 -5.0000000000000009 50 #
+coedge $-1 -1 -1 $-1 $3631 $2328 $2334 $2933 forward $2919 $-1 #
+coedge $-1 -1 -1 $-1 $2328 $3632 $3627 $3633 forward $2919 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2917 $3634 T 37.5 -10 35 45 0 50 unknown #
+vertex $-1 -1 -1 $-1 $3633 $3635 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2330 $3636 $3637 $3638 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $3639 $3640 $2330 $2924 reversed $3641 $-1 #
+edge $-1 -1 -1 $-1 $3642 -1.5707963267948966 $2928 0.5235987755982987 $2330 $3643 forward @7 unknown T 15 -5.0000000000000009 50 22.5 -8.8817841970012523e-16 50 #
+coedge $-1 -1 -1 $-1 $3644 $2331 $3640 $3645 forward $2927 $-1 #
+coedge $-1 -1 -1 $-1 $2331 $3646 $3647 $2931 forward $2927 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2926 $3648 T 22.499999999999996 -5.0000000000000009 35 30 0 50 unknown #
+vertex $-1 -1 -1 $-1 $2332 $3649 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2932 $2333 $3650 $3651 reversed $2335 $-1 #
+edge $-1 -1 -1 $-1 $3652 40 $2336 50 $2926 $3653 forward @7 unknown T 30 -5.0000000000000009 40 30 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $2334 $2930 $3654 $3655 reversed $2335 $-1 #
+edge $-1 -1 -1 $-1 $2337 -50 $3656 -37.500000000000007 $2917 $3657 forward @7 unknown T 37.5 -0.66987298107780902 37.500000000000007 37.500000000000007 -0.66987298107780724 50 #
+face $-1 -1 -1 $-1 $3658 $2335 $11 $-1 $3659 reversed single T 30 -5.0000000000000018 35 37.500000000000007 -1.7763568394002505e-15 50 F #
+edge $-1 -1 -1 $-1 $2336 1.7763568394002506e-16 $3660 2.0943951023931948 $2914 $2929 forward @7 unknown T 22.5 -10 50 30 -5.0000000000000009 50 #
+point $-1 -1 -1 $-1 30 -5.0000000000000009 50 #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780724 50 #
+coedge $-1 -1 -1 $-1 $3661 $2339 $3662 $3663 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $2959 $3664 $2339 $2359 reversed $3665 $-1 #
+coedge $-1 -1 -1 $-1 $3666 $2340 $2343 $2946 reversed $2942 $-1 #
+coedge $-1 -1 -1 $-1 $2340 $3667 $1902 $2355 forward $2942 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2941 $2601 T 30 -25.000000000000004 35 37.5 -20 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $3668 $2342 $2693 $3383 forward $2344 $-1 #
+coedge $-1 -1 -1 $-1 $2343 $3668 $3669 $3670 forward $2344 $-1 #
+edge $-1 -1 -1 $-1 $3671 37.5 $2345 50 $2343 $3672 forward @7 unknown T 37.5 -24.330127018922198 37.5 37.5 -24.330127018922195 50 #
+face $-1 -1 -1 $-1 $3673 $2344 $11 $-1 $2703 reversed single T 37.5 -25 35 45 -15 50 F #
+point $-1 -1 -1 $-1 37.5 -24.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $2347 $3674 $3675 $3676 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $3677 $3678 $2347 $2951 reversed $3679 $-1 #
+edge $-1 -1 -1 $-1 $3680 -2.0943951023931957 $2955 0 $2347 $3681 forward @7 unknown T 7.4999999999999991 -20 50 15 -15 50 #
+coedge $-1 -1 -1 $-1 $3682 $2348 $3678 $3683 reversed $2954 $-1 #
+coedge $-1 -1 -1 $-1 $2348 $3684 $2350 $2958 reversed $2954 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2953 $3685 T 15 -20 35 22.500000000000004 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $3686 $3687 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $2707 $2350 $2713 $3404 forward $2352 $-1 #
+edge $-1 -1 -1 $-1 $2353 -50 $3688 -37.499999999999993 $2350 $3689 forward @7 unknown T 22.5 -15.669872981077805 37.499999999999993 22.500000000000004 -15.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $3420 $2939 $2941 $2355 reversed $3665 $-1 #
+face $-1 -1 -1 $-1 $3690 $2352 $11 $-1 $2194 reversed single T 22.5 -20 35 30 -15 50 F #
+point $-1 -1 -1 $-1 22.5 -15.669872981077805 50 #
+vertex $-1 -1 -1 $-1 $3383 $3691 #
+face $-1 -1 -1 $-1 $3692 $3693 $11 $-1 $704 reversed single T 30 -20 -50 37.5 -15.000000000000004 -40 F #
+vertex $-1 -1 -1 $-1 $3694 $3695 #
+face $-1 -1 -1 $-1 $3696 $3697 $11 $-1 $1595 reversed single T -22.500000000000004 -40 20 -15 -35 35 F #
+coedge $-1 -1 -1 $-1 $3698 $3699 $3570 $3700 forward $2363 $-1 #
+coedge $-1 -1 -1 $-1 $3498 $2364 $3701 $3702 forward $1909 $-1 #
+coedge $-1 -1 -1 $-1 $2364 $3498 $2847 $3546 reversed $1909 $-1 #
+coedge $-1 -1 -1 $-1 $3544 $3570 $2364 $2972 reversed $3571 $-1 #
+edge $-1 -1 -1 $-1 $3703 -2.0943951023931953 $3704 -1.5707963267948966 $2364 $3705 forward @7 unknown T -10.000000000000002 -30.669872981077809 35 -7.5000000000000018 -30 37.5 #
+coedge $-1 -1 -1 $-1 $2975 $2365 $3706 $3707 forward $1594 $-1 #
+edge $-1 -1 -1 $-1 $2879 3.1415926535897931 $3708 4.7123889803846897 $2365 $3709 forward @7 unknown T -20 -40 35 -15 -35 40 #
+coedge $-1 -1 -1 $-1 $2366 $2973 $3710 $3711 forward $1594 $-1 #
+coedge $-1 -1 -1 $-1 $3712 $2881 $2366 $2977 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $2978 0 $3713 2.0943951023931957 $2976 $3714 forward @7 unknown T -22.5 -40 50 -15 -35 50 #
+vertex $-1 -1 -1 $-1 $2977 $3715 #
+coedge $-1 -1 -1 $-1 $3580 $3716 $1910 $2367 forward $3717 $-1 #
+straight-curve $-1 -1 -1 $-1 -15 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3122 $3718 $2368 $2982 reversed $3719 $-1 #
+edge $-1 -1 -1 $-1 $2983 -1.5707963267948966 $3720 -1.047197551196597 $2368 $3721 forward @7 unknown T 7.4999999999999964 -30.669872981077809 -42.500000000000007 10 -30 -40 #
+vertex $-1 -1 -1 $-1 $2982 $3722 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3723 $3007 $2371 $2986 reversed $3724 $-1 #
+edge $-1 -1 -1 $-1 $3720 42.500000000000007 $2987 50 $2371 $3725 forward @7 unknown T 7.4999999999999982 -30.669872981077809 -50 7.4999999999999991 -30.669872981077805 -42.500000000000007 #
+vertex $-1 -1 -1 $-1 $2986 $3726 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2991 $2373 $3727 $3728 forward $2376 $-1 #
+edge $-1 -1 -1 $-1 $3729 -2.0943951023931957 $2377 0 $2401 $2988 forward @7 unknown T 7.4999999999999991 -40 -50 15 -35 -50 #
+coedge $-1 -1 -1 $-1 $2374 $2989 $3730 $3731 forward $2376 $-1 #
+face $-1 -1 -1 $-1 $3732 $2376 $11 $-1 $950 reversed single T 7.4999999999999982 -40 -50 15 -35 -40 F #
+point $-1 -1 -1 $-1 14.999999999999998 -35 -50 #
+point $-1 -1 -1 $-1 15 -35 -45 #
+edge $-1 -1 -1 $-1 $1945 -2.0943951023931953 $3034 -1.5707963267948966 $2380 $3733 forward @7 unknown T 4.9999999999999982 -40 32.5 7.4999999999999982 -39.330127018922191 35 #
+vertex $-1 -1 -1 $-1 $3731 $3734 #
+coedge $-1 -1 -1 $-1 $3735 $2388 $2391 $3002 reversed $2999 $-1 #
+coedge $-1 -1 -1 $-1 $2388 $3736 $2395 $3005 reversed $2999 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2997 $3220 T -1.7763568394002505e-15 -40 5 7.4999999999999991 -35 20 unknown #
+coedge $-1 -1 -1 $-1 $2391 $2390 $3265 $3737 forward $2392 $-1 #
+edge $-1 -1 -1 $-1 $3738 1.5707963267948966 $2393 2.0943951023931957 $2391 $3739 forward @7 unknown T 4.9999999999999982 -40 5 7.4999999999999991 -39.330127018922191 7.5000000000000036 #
+face $-1 -1 -1 $-1 $3471 $2392 $11 $-1 $227 reversed single T 4.9999999999999982 -40 2.5000000000000009 10.000000000000002 -39.330127018922191 7.5000000000000036 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922191 7.5000000000000036 #
+edge $-1 -1 -1 $-1 $2234 -2.0943951023931948 $3485 -1.5707963267948966 $2395 $3740 forward @7 unknown T 4.9999999999999982 -40 17.499999999999996 7.4999999999999982 -39.330127018922191 20 #
+coedge $-1 -1 -1 $-1 $3741 $2397 $3742 $3743 forward $1370 $-1 #
+coedge $-1 -1 -1 $-1 $2985 $3744 $2397 $3008 reversed $3724 $-1 #
+edge $-1 -1 -1 $-1 $2987 -0.52359877559829937 $3745 1.5707963267948966 $2397 $3746 forward @7 unknown T -1.7763568394002505e-15 -35 -50 7.5 -30 -50 #
+coedge $-1 -1 -1 $-1 $2401 $3747 $3748 $3749 forward $1370 $-1 #
+loop $-1 -1 -1 $-1 $3750 $3751 $1616 T -45 19.999999999999996 -50 45 30.000000000000004 -50 unknown #
+coedge $-1 -1 -1 $-1 $3752 $3753 $3754 $3755 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $3756 $2405 $3757 $3758 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $2405 $3759 $3760 $3761 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $3762 $3763 $2405 $3016 reversed $3764 $-1 #
+edge $-1 -1 -1 $-1 $3765 1.5707963267948966 $3766 3.6651914291880923 $2405 $3767 forward @7 unknown T 30 -10.000000000000002 -50 37.5 -5.0000000000000009 -50 #
+coedge $-1 -1 -1 $-1 $3768 $2406 $3769 $3770 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $3771 $3772 $2406 $3019 reversed $3432 $-1 #
+edge $-1 -1 -1 $-1 $3027 -2.0943951023931948 $3773 2.0943951023931948 $2406 $3774 forward @7 unknown T 37.5 -25 -50 45 -15 -50 #
+coedge $-1 -1 -1 $-1 $2407 $3775 $3776 $3777 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $3778 $3779 $2407 $3022 reversed $3780 $-1 #
+edge $-1 -1 -1 $-1 $3781 -2.0943951023931948 $3026 0 $2407 $3782 forward @7 unknown T 22.5 -25 -50 30 -20 -50 #
+coedge $-1 -1 -1 $-1 $3783 $2408 $3784 $3785 forward $3025 $-1 #
+coedge $-1 -1 -1 $-1 $2408 $3786 $3771 $3787 reversed $3025 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3024 $3788 T 30 -25.000000000000004 -50 37.500000000000007 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $3789 $3790 #
+vertex $-1 -1 -1 $-1 $3019 $3791 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+face $-1 -1 -1 $-1 $3792 $3793 $11 $-1 $1595 reversed single T -22.500000000000004 -35 -40 -15 -30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $3794 $2410 T -22.500000000000004 -40 -50 -15 -35 -40 unknown #
+coedge $-1 -1 -1 $-1 $3795 $3796 $3797 $3798 reversed $2411 $-1 #
+coedge $-1 -1 -1 $-1 $2851 $2413 $3496 $3799 reversed $2414 $-1 #
+face $-1 -1 -1 $-1 $2422 $2414 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 35 7.5 -35 50 F #
+vertex $-1 -1 -1 $-1 $3800 $3801 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2423 -1.5707963267948966 $2852 6.1232339957367648e-17 $2802 $3802 forward @7 unknown T -1.7763568394002505e-15 -35 35 4.9999999999999982 -30 40 #
+face $-1 -1 -1 $-1 $3803 $3724 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 -50 7.5 -30 -40 F #
+edge $-1 -1 -1 $-1 $2812 -6.1232339957367648e-17 $2423 1.5707963267948966 $3492 $3804 forward @7 unknown T -1.7763568394002505e-15 -35 30 4.9999999999999982 -30 35 #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 35 #
+coedge $-1 -1 -1 $-1 $3175 $2428 $3805 $3209 forward $1960 $-1 #
+coedge $-1 -1 -1 $-1 $3806 $3807 $1715 $2061 forward $2570 $-1 #
+coedge $-1 -1 -1 $-1 $3043 $3043 $2429 $3044 forward $3146 $-1 #
+edge $-1 -1 -1 $-1 $3808 0 $3808 6.2831853071795862 $3043 $3809 forward @7 unknown T -50 -40 -30.000000000000004 -50 -30 -20.000000000000004 #
+coedge $-1 -1 -1 $-1 $3163 $2513 $2430 $3046 reversed $2024 $-1 #
+edge $-1 -1 -1 $-1 $3051 -1.5707963267948966 $3050 1.5707963267948966 $2430 $3810 forward @7 unknown T -45 -40 -25.000000000000004 -40 -30 -20.000000000000004 #
+coedge $-1 -1 -1 $-1 $3811 $2431 $3812 $3813 reversed $3049 $-1 #
+coedge $-1 -1 -1 $-1 $2431 $3814 $3815 $3816 reversed $3049 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3060 $3817 T -45 -40 -40 -37.5 -30 -25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $2432 $3818 #
+vertex $-1 -1 -1 $-1 $2432 $3819 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -25.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3820 $3821 $11 $-1 $3822 reversed single T -7.5000000000000027 -20 35 0 -15 50 F #
+loop $-1 -1 -1 $-1 $3823 $3824 $2433 T -45 -24.999999999999996 30 -40 -14.999999999999996 40 unknown #
+coedge $-1 -1 -1 $-1 $3825 $3826 $3827 $3828 forward $2434 $-1 #
+coedge $-1 -1 -1 $-1 $3056 $3056 $3118 $3829 reversed $2435 $-1 #
+coedge $-1 -1 -1 $-1 $2436 $2436 $3668 $3830 reversed $1964 $-1 #
+coedge $-1 -1 -1 $-1 $3058 $3058 $2437 $3059 forward $3831 $-1 #
+edge $-1 -1 -1 $-1 $3832 0 $3832 6.2831853071795862 $3058 $3833 forward @7 unknown T -50 -40 -45 -50 -30 -35 #
+coedge $-1 -1 -1 $-1 $3834 $3835 $2438 $3061 reversed $3049 $-1 #
+edge $-1 -1 -1 $-1 $3066 -1.5707963267948966 $3065 1.5707963267948966 $2438 $3836 forward @7 unknown T -45 -40 -40 -40 -30 -35 #
+coedge $-1 -1 -1 $-1 $3837 $2439 $3838 $3839 reversed $3064 $-1 #
+coedge $-1 -1 -1 $-1 $2439 $3840 $3841 $3842 reversed $3064 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3840 $3843 T -45 -40 -50 -37.5 -30 -40 unknown #
+vertex $-1 -1 -1 $-1 $2440 $3844 #
+vertex $-1 -1 -1 $-1 $2440 $3845 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3846 $3847 $2441 $3069 forward $3793 $-1 #
+edge $-1 -1 -1 $-1 $3078 4.1887902047863905 $3073 4.7123889803846897 $3068 $3848 forward @7 unknown T -22.500000000000004 -30.669872981077809 -40 -20 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $3849 $2442 $2447 $3084 forward $3072 $-1 #
+coedge $-1 -1 -1 $-1 $2442 $3850 $3851 $3852 forward $3072 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3850 $3853 T -22.500000000000004 -35 -50 -15 -30 -40 unknown #
+vertex $-1 -1 -1 $-1 $2443 $3854 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3855 $2444 $3847 $3856 reversed $3077 $-1 #
+coedge $-1 -1 -1 $-1 $2444 $3857 $3858 $3859 reversed $3077 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3857 $3860 T -30.000000000000007 -35 -40 -22.5 -30 -25 unknown #
+vertex $-1 -1 -1 $-1 $3069 $3861 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3083 $2446 $3862 $3863 reversed $2448 $-1 #
+coedge $-1 -1 -1 $-1 $3858 $3864 $2446 $3082 forward $3865 $-1 #
+edge $-1 -1 -1 $-1 $3866 -6.1232339957367648e-17 $2449 1.5707963267948966 $3081 $3867 forward @7 unknown T -30.000000000000004 -35 -45 -25.000000000000004 -30 -40 #
+coedge $-1 -1 -1 $-1 $2447 $3080 $3868 $3869 reversed $2448 $-1 #
+edge $-1 -1 -1 $-1 $2450 42.500000000000007 $3870 50 $3070 $3871 forward @7 unknown T -22.500000000000004 -30.669872981077809 -50 -22.5 -30.669872981077805 -42.500000000000007 #
+face $-1 -1 -1 $-1 $3860 $2448 $11 $-1 $3872 reversed single T -30.000000000000004 -35 -50 -22.5 -30 -40 F #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 -40 #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $3873 $2452 $3874 $3875 forward $3090 $-1 #
+coedge $-1 -1 -1 $-1 $2452 $3876 $2459 $3099 forward $3090 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3873 $3877 T -7.5000000000000027 -40 -50 0 -35 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3878 $2454 $3879 $3880 forward $2456 $-1 #
+coedge $-1 -1 -1 $-1 $2455 $3878 $3881 $3882 reversed $2456 $-1 #
+coedge $-1 -1 -1 $-1 $3883 $3874 $2455 $3095 reversed $3884 $-1 #
+edge $-1 -1 -1 $-1 $3885 3.1415926535897931 $2457 4.7123889803846897 $2455 $3886 forward @7 unknown T -5 -40 -40 0 -35 -35 #
+face $-1 -1 -1 $-1 $3887 $2456 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 -40 0 -35 -25 F #
+point $-1 -1 -1 $-1 -5 -40 -40 #
+coedge $-1 -1 -1 $-1 $3100 $2459 $3888 $3889 reversed $2461 $-1 #
+edge $-1 -1 -1 $-1 $3890 -50 $2462 -42.500000000000007 $3089 $3891 forward @7 unknown T -7.5000000000000027 -39.330127018922198 -50 -7.5000000000000009 -39.330127018922191 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $2460 $3098 $3892 $3893 forward $2461 $-1 #
+coedge $-1 -1 -1 $-1 $3894 $2465 $2460 $2470 forward $3108 $-1 #
+face $-1 -1 -1 $-1 $1122 $2461 $11 $-1 $2541 reversed single T -15.000000000000002 -40 -50 -7.5000000000000009 -35 -40 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $2467 $2464 $3895 $3896 reversed $1979 $-1 #
+coedge $-1 -1 -1 $-1 $3897 $3898 $3899 $3106 reversed $3900 $-1 #
+edge $-1 -1 -1 $-1 $3109 -35 $3901 -30 $3899 $3902 forward @7 unknown T -15 -35 -35 -15 -35 -30 #
+coedge $-1 -1 -1 $-1 $2465 $3894 $3903 $3904 reversed $3108 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3101 $3905 T -20 -40 -45 -10.000000000000002 -35 -35 unknown #
+vertex $-1 -1 -1 $-1 $3904 $3906 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3179 $3879 $2467 $3112 forward $3907 $-1 #
+edge $-1 -1 -1 $-1 $3113 -2.0943951023931957 $3908 -1.570796326794897 $3111 $3909 forward @7 unknown T -10.000000000000002 -40 -27.500000000000004 -7.5000000000000009 -39.330127018922191 -25 #
+vertex $-1 -1 -1 $-1 $3880 $3910 #
+vertex $-1 -1 -1 $-1 $3852 $3911 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $3912 $3913 $1558 T 50 -25 15.000000000000004 50 -15 25.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $3118 $3118 $3056 $3829 forward $2473 $-1 #
+edge $-1 -1 -1 $-1 $3914 1.0471975511965974 $2476 1.5707963267948966 $2777 $3481 forward @7 unknown T 7.4999999999999982 -40 -27.500000000000004 10 -39.330127018922191 -25 #
+point $-1 -1 -1 $-1 10 -40 -25 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3915 $2981 $2483 $3123 reversed $3719 $-1 #
+edge $-1 -1 -1 $-1 $3916 4.1887902047863905 $2983 4.7123889803846897 $2483 $3917 forward @7 unknown T 7.4999999999999982 -30.669872981077813 -40 10 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $3476 $2484 $3918 $3919 forward $2485 $-1 #
+face $-1 -1 -1 $-1 $3920 $2485 $11 $-1 $950 reversed single T 7.4999999999999982 -40 -40 15 -35 -25 F #
+coedge $-1 -1 -1 $-1 $2492 $2489 $3921 $3922 forward $1444 $-1 #
+coedge $-1 -1 -1 $-1 $3923 $3924 $2489 $3129 reversed $3925 $-1 #
+edge $-1 -1 -1 $-1 $3133 -1.5707963267948966 $3926 -1.047197551196597 $2489 $3458 forward @7 unknown T -7.5000000000000036 -30.669872981077813 2.4999999999999964 -5 -30 5 #
+coedge $-1 -1 -1 $-1 $3927 $2490 $2546 $3201 forward $3132 $-1 #
+coedge $-1 -1 -1 $-1 $2490 $3927 $2744 $3442 reversed $3132 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3927 $3928 T -5 -35 -9.3734986416366059e-33 4.9999999999999982 -30 10 unknown #
+vertex $-1 -1 -1 $-1 $3129 $3929 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 5 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3930 $3931 $2492 $3136 reversed $3932 $-1 #
+edge $-1 -1 -1 $-1 $3933 4.1887902047863914 $3137 4.7123889803846897 $2492 $2034 forward @7 unknown T -7.5000000000000018 -30.669872981077805 -10 -5 -30 -7.4999999999999956 #
+vertex $-1 -1 -1 $-1 $3934 $3935 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -10 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3459 $3936 $2495 $3140 reversed $3937 $-1 #
+edge $-1 -1 -1 $-1 $2760 -1.5707963267948966 $2498 0 $2495 $3134 forward @7 unknown T -5 -40 0 0 -35 5 #
+coedge $-1 -1 -1 $-1 $3265 $2496 $3936 $3938 reversed $3143 $-1 #
+coedge $-1 -1 -1 $-1 $2496 $3264 $3176 $3939 reversed $3143 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3264 $2569 T -1.7763568394002505e-15 -40 -10 7.4999999999999991 -35 5 unknown #
+point $-1 -1 -1 $-1 0 -35 -5 #
+point $-1 -1 -1 $-1 0 -35 0 #
+loop $-1 -1 -1 $-1 $3831 $3043 $3147 T -50 -40 -30.000000000000004 -50 -30 -20.000000000000004 hole $3148 T #
+face $-1 -1 -1 $-1 $3940 $2854 $11 $-1 $3148 reversed single T -50 -50 -50 -50 50 50 F #
+plane-surface $-1 -1 -1 $-1 -50 0 0 1 0 0 0 0 -1 forward_v I I I I #
+point $-1 -1 -1 $-1 -50 -35 -15.000000000000004 #
+coedge $-1 -1 -1 $-1 $2752 $2503 $3941 $3942 reversed $2505 $-1 #
+coedge $-1 -1 -1 $-1 $2511 $3943 $2503 $3152 forward $3167 $-1 #
+edge $-1 -1 -1 $-1 $3944 -2.0943951023931953 $2026 -1.5707963267948966 $3151 $3945 forward @7 unknown T -40 -30.669872981077813 -10.000000000000002 -37.5 -30 -7.5 #
+coedge $-1 -1 -1 $-1 $2504 $2751 $3946 $3947 reversed $2505 $-1 #
+coedge $-1 -1 -1 $-1 $3948 $2508 $2504 $3155 forward $3160 $-1 #
+edge $-1 -1 -1 $-1 $2025 1.5707963267948966 $3949 2.0943951023931939 $3154 $3950 forward @7 unknown T -40 -40 -10.000000000000002 -37.500000000000007 -39.330127018922198 -7.5000000000000036 #
+face $-1 -1 -1 $-1 $2827 $2505 $11 $-1 $3172 reversed single T -45 -40 -10.000000000000002 -37.5 -30 4.9999999999999973 F #
+coedge $-1 -1 -1 $-1 $3951 $3952 $2507 $3158 forward $3953 $-1 #
+edge $-1 -1 -1 $-1 $3954 -22.5 $3161 -12.500000000000004 $3157 $3955 forward @7 unknown T -37.5 -39.330127018922191 -22.5 -37.499999999999993 -39.330127018922184 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $2508 $3948 $3951 $3956 reversed $3160 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3154 $3957 T -40 -40 -12.500000000000004 -35 -39.330127018922191 -7.5000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $3956 $3958 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -10.000000000000002 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2510 $3045 $3959 $3960 reversed $2024 $-1 #
+coedge $-1 -1 -1 $-1 $3961 $3962 $2510 $3165 forward $3963 $-1 #
+edge $-1 -1 -1 $-1 $3168 12.500000000000004 $3964 22.500000000000007 $3164 $3965 forward @7 unknown T -37.5 -30.669872981077805 -22.500000000000007 -37.5 -30.669872981077802 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $3943 $2511 $3962 $3966 reversed $3167 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3151 $3967 T -40 -30.669872981077813 -12.500000000000004 -35 -30 -7.4999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $3165 $3968 #
+coedge $-1 -1 -1 $-1 $3969 $3812 $2513 $3171 forward $3970 $-1 #
+edge $-1 -1 -1 $-1 $3050 1.5707963267948966 $3954 2.0943951023931975 $3170 $3971 forward @7 unknown T -40 -40 -25.000000000000004 -37.499999999999993 -39.330127018922184 -22.499999999999993 #
+cone-surface $-1 -1 -1 $-1 -40 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $2521 $3972 $2517 $3174 reversed $3177 $-1 #
+edge $-1 -1 -1 $-1 $2033 -1.5707963267948966 $2064 0 $2517 $3211 forward @7 unknown T -5 -40 -15 8.8817841970012523e-16 -35 -10 #
+coedge $-1 -1 -1 $-1 $2518 $3041 $3973 $3974 forward $1960 $-1 #
+coedge $-1 -1 -1 $-1 $3972 $2521 $3142 $3939 forward $3177 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3176 $3222 T -5 -40 -15 4.9999999999999982 -35 -5 unknown #
+coedge $-1 -1 -1 $-1 $2527 $2525 $3975 $3976 reversed $2037 $-1 #
+coedge $-1 -1 -1 $-1 $3973 $3111 $2525 $3180 forward $3907 $-1 #
+edge $-1 -1 -1 $-1 $3908 1.5707963267948961 $3181 2.0943951023931944 $3179 $3977 forward @7 unknown T -10.000000000000004 -40 -25 -7.5000000000000027 -39.330127018922198 -22.5 #
+vertex $-1 -1 -1 $-1 $3180 $3978 #
+coedge $-1 -1 -1 $-1 $3979 $3980 $3981 $3184 reversed $3982 $-1 #
+edge $-1 -1 -1 $-1 $3983 -20 $2542 -15.000000000000002 $3981 $3984 forward @7 unknown T -15.000000000000004 -35 -20 -15 -35 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $2534 $2528 $3985 $3986 reversed $2535 $-1 #
+coedge $-1 -1 -1 $-1 $3987 $2764 $2531 $2767 forward $3465 $-1 #
+coedge $-1 -1 -1 $-1 $3988 $2532 $3989 $3990 reversed $3190 $-1 #
+coedge $-1 -1 -1 $-1 $2532 $3991 $3992 $3993 reversed $3190 $-1 #
+coedge $-1 -1 -1 $-1 $3994 $3995 $3996 $2533 forward $3997 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3187 $3998 T -15.000000000000002 -35 -10 -7.5000000000000009 -30 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $3999 $4000 #
+coedge $-1 -1 -1 $-1 $4001 $3996 $2534 $3194 forward $4002 $-1 #
+edge $-1 -1 -1 $-1 $2536 3.1415926535897931 $4003 4.7123889803846897 $3193 $4004 forward @7 unknown T -20 -40 -10.000000000000002 -14.999999999999996 -35 -5.0000000000000018 #
+face $-1 -1 -1 $-1 $3096 $2535 $11 $-1 $336 reversed single T -20 -40 -15.000000000000002 -10.000000000000002 -35 -5.0000000000000009 F #
+point $-1 -1 -1 $-1 -14.999999999999996 -35 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 2.4999999999999982 #
+edge $-1 -1 -1 $-1 $2542 0 $4005 1.5707963267948961 $4006 $4007 forward @7 unknown T -20 -35 -15.000000000000002 -15.000000000000004 -30 -10.000000000000002 #
+point $-1 -1 -1 $-1 -15.000000000000004 -35 -15.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2498 -6.1232339957367648e-17 $3202 1.5707963267948966 $3130 $4008 forward @7 unknown T -1.7763568394002505e-15 -35 -9.3734986416366059e-33 4.9999999999999982 -30 5 #
+vertex $-1 -1 -1 $-1 $3201 $4009 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 7.4999999999999973 -30.669872981077805 2.4999999999999996 #
+coedge $-1 -1 -1 $-1 $4010 $2552 $3931 $3934 forward $2554 $-1 #
+coedge $-1 -1 -1 $-1 $2553 $4010 $4011 $4012 forward $2554 $-1 #
+edge $-1 -1 -1 $-1 $4013 1.5707963267948966 $2555 3.1415926535897931 $2553 $4014 forward @7 unknown T -5 -35 -25 0 -30 -20 #
+face $-1 -1 -1 $-1 $4015 $2554 $11 $-1 $1445 reversed single T -7.5000000000000053 -35 -25 8.8817841970012523e-16 -30 -10 F #
+edge $-1 -1 -1 $-1 $2555 3.1415926535897931 $4016 4.7123889803846897 $3041 $4014 forward @7 unknown T -5 -40 -25 0 -35 -20 #
+point $-1 -1 -1 $-1 0 -35 -20 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -10 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3218 $3478 $2560 $3213 reversed $4017 $-1 #
+edge $-1 -1 -1 $-1 $2562 1.570796326794897 $3480 2.0943951023931957 $2560 $4018 forward @7 unknown T 4.9999999999999982 -30.669872981077809 -27.500000000000004 7.4999999999999991 -30 -25 #
+face $-1 -1 -1 $-1 $2523 $2561 $11 $-1 $482 reversed single T 4.9999999999999956 -30.669872981077813 -27.500000000000004 10 -30 -22.499999999999996 F #
+edge $-1 -1 -1 $-1 $4019 -6.1232339957367648e-17 $2562 1.5707963267948961 $2566 $4020 forward @7 unknown T -1.7763568394002505e-15 -35 -30 4.9999999999999982 -30 -25 #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 -25 #
+coedge $-1 -1 -1 $-1 $2566 $2565 $4021 $4022 reversed $2567 $-1 #
+coedge $-1 -1 -1 $-1 $4023 $3212 $2566 $3215 reversed $4017 $-1 #
+face $-1 -1 -1 $-1 $4024 $2567 $11 $-1 $482 reversed single T -5 -35 -30 5 -30 -19.999999999999996 F #
+face $-1 -1 -1 $-1 $3484 $2999 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 5 7.4999999999999991 -35 20 F #
+coedge $-1 -1 -1 $-1 $3807 $3261 $4025 $4026 reversed $2570 $-1 #
+face $-1 -1 -1 $-1 $2558 $3177 $11 $-1 $336 reversed single T -5 -40 -15 4.9999999999999982 -35 -5 F #
+face $-1 -1 -1 $-1 $4027 $4028 $11 $-1 $1477 reversed single T 15 -25 -9.9999999999999982 22.500000000000004 -20 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $4029 $2573 T 15 -25 -25 22.5 -20 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $4030 $4031 $4032 $4033 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $4034 $2575 $4035 $4036 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $2575 $4037 $4038 $4039 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $4040 $4041 $2575 $3229 forward $4042 $-1 #
+edge $-1 -1 -1 $-1 $4043 -1.5707963267948966 $4044 6.1232339957367648e-17 $3228 $4045 forward @7 unknown T 15 -20 -9.9999999999999982 20 -15 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $4046 $2576 $2674 $3365 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $4047 $2676 $2576 $3232 forward $3366 $-1 #
+edge $-1 -1 -1 $-1 $3367 -2.0943951023931957 $3239 -1.5707963267948966 $3231 $4048 forward @7 unknown T 20 -15.669872981077809 5.0000000000000009 22.500000000000004 -15 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $2577 $4046 $2587 $3255 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $4049 $4050 $4051 $3235 forward $4052 $-1 #
+edge $-1 -1 -1 $-1 $3240 10 $4053 15 $3234 $4054 forward @7 unknown T 14.999999999999996 -20 10 15 -20 15 #
+coedge $-1 -1 -1 $-1 $4055 $2578 $4050 $4056 reversed $3238 $-1 #
+coedge $-1 -1 -1 $-1 $2578 $4055 $4037 $4057 forward $3238 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2578 $4058 T 9.9999999999999982 -20 -9.3734986416366073e-33 20 -15 10 unknown #
+vertex $-1 -1 -1 $-1 $4057 $4059 #
+vertex $-1 -1 -1 $-1 $4060 $4061 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $2583 $2580 $2714 $3405 reversed $1476 $-1 #
+coedge $-1 -1 -1 $-1 $2675 $2581 $4046 $4062 forward $2719 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3435 $4063 $2583 $3246 forward $2738 $-1 #
+edge $-1 -1 -1 $-1 $3251 -6.1232339957367648e-17 $4064 1.5707963267948966 $3245 $4065 forward @7 unknown T 15 -20 30 20 -15 35 #
+coedge $-1 -1 -1 $-1 $4066 $2584 $4063 $4067 forward $3250 $-1 #
+coedge $-1 -1 -1 $-1 $2584 $4068 $2586 $3254 forward $3250 $-1 #
+coedge $-1 -1 -1 $-1 $4069 $4070 $4071 $2585 reversed $4072 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2584 $4073 T 7.4999999999999982 -20 20 15 -15 35 unknown #
+vertex $-1 -1 -1 $-1 $4067 $4074 #
+straight-curve $-1 -1 -1 $-1 15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2587 $2586 $4049 $4075 reversed $2588 $-1 #
+edge $-1 -1 -1 $-1 $4076 1.5707963267948966 $2590 3.1415926535897931 $3248 $4077 forward @7 unknown T 10 -20 20 15 -15 25 #
+edge $-1 -1 -1 $-1 $4053 -6.1232339957367648e-17 $2589 1.5707963267948966 $2587 $4078 forward @7 unknown T 15 -20 15 20 -15 20 #
+point $-1 -1 -1 $-1 20 -15 20 #
+edge $-1 -1 -1 $-1 $2590 3.1415926535897931 $4079 4.7123889803846897 $4069 $4077 forward @7 unknown T 10 -25 20 15 -20 25 #
+point $-1 -1 -1 $-1 15 -20 25 #
+coedge $-1 -1 -1 $-1 $3477 $4025 $2592 $3260 reversed $4080 $-1 #
+edge $-1 -1 -1 $-1 $2476 1.5707963267948966 $4081 2.0943951023931948 $2592 $3200 forward @7 unknown T 7.5 -40 -25 10 -39.330127018922191 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $3221 $4082 $2593 $3262 reversed $2570 $-1 #
+edge $-1 -1 -1 $-1 $4081 -22.500000000000004 $2600 -12.500000000000002 $2593 $4083 forward @7 unknown T 7.4999999999999982 -39.330127018922198 -22.500000000000004 7.5 -39.330127018922191 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $2597 $2594 $4082 $4084 forward $2598 $-1 #
+coedge $-1 -1 -1 $-1 $3142 $2595 $2597 $3267 reversed $3143 $-1 #
+coedge $-1 -1 -1 $-1 $2595 $3141 $3001 $3737 reversed $3143 $-1 #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $4085 1.5707963267948966 $2599 2.0943951023931948 $2597 $4086 forward @7 unknown T 4.9999999999999982 -40 -10 7.4999999999999991 -39.330127018922198 -7.4999999999999991 #
+point $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922198 -7.4999999999999991 #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922198 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $2602 $3375 $4087 $4088 reversed $2094 $-1 #
+coedge $-1 -1 -1 $-1 $4089 $4090 $2602 $3272 forward $3381 $-1 #
+edge $-1 -1 -1 $-1 $4091 1.5707963267948966 $4092 2.0943951023931966 $3271 $4093 forward @7 unknown T 35 -25.000000000000004 5.0000000000000018 37.500000000000014 -24.330127018922191 7.5000000000000062 #
+coedge $-1 -1 -1 $-1 $4094 $3344 $2603 $3274 forward $4095 $-1 #
+edge $-1 -1 -1 $-1 $1761 -6.4931039580273226e-16 $3281 1.5707963267948966 $3273 $4096 forward @7 unknown T 29.999999999999996 -25.000000000000004 -9.9999999999999982 35 -20 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $2604 $3348 $4090 $4097 reversed $1745 $-1 #
+coedge $-1 -1 -1 $-1 $4098 $4099 $2604 $3277 forward $2643 $-1 #
+edge $-1 -1 -1 $-1 $3282 -7.5000000000000053 $4100 2.500000000000008 $3276 $4101 forward @7 unknown T 37.499999999999993 -24.330127018922198 -7.5000000000000053 37.500000000000007 -24.330127018922195 2.500000000000008 #
+coedge $-1 -1 -1 $-1 $4102 $2605 $4099 $4103 reversed $3280 $-1 #
+coedge $-1 -1 -1 $-1 $2605 $4102 $2610 $3289 forward $3280 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3279 $4104 T 35 -25.000000000000004 -12.499999999999996 40 -24.330127018922195 -7.5000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $4105 $4106 #
+vertex $-1 -1 -1 $-1 $2606 $4107 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2610 $2607 $4094 $4105 reversed $1485 $-1 #
+coedge $-1 -1 -1 $-1 $4108 $2608 $4109 $3300 forward $3287 $-1 #
+coedge $-1 -1 -1 $-1 $2608 $4108 $3315 $2639 reversed $3287 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3285 $3327 T 25 -25.000000000000004 -30 35 -20 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $3293 -2.0943951023931948 $3281 -1.5707963267948966 $3279 $4110 forward @7 unknown T 35 -25.000000000000004 -12.499999999999995 37.5 -24.330127018922198 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $4111 $2611 $4102 $4112 forward $3292 $-1 #
+coedge $-1 -1 -1 $-1 $2611 $4113 $2613 $3296 forward $3292 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2620 $4114 T 37.499999999999993 -25 -24.999999999999996 45 -15 -9.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $4112 $4115 #
+straight-curve $-1 -1 -1 $-1 37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2614 $2613 $4116 $4117 reversed $2615 $-1 #
+edge $-1 -1 -1 $-1 $4118 1.570796326794897 $2617 2.0943951023931975 $3291 $4119 forward @7 unknown T 37.5 -25 -24.999999999999996 40.000000000000007 -24.330127018922187 -22.499999999999986 #
+coedge $-1 -1 -1 $-1 $4120 $4109 $2614 $3298 reversed $4121 $-1 #
+edge $-1 -1 -1 $-1 $4122 -2.0943951023931948 $2616 -1.5707963267948966 $2614 $4123 forward @7 unknown T 35 -25.000000000000004 -27.499999999999993 37.5 -24.330127018922195 -24.999999999999996 #
+face $-1 -1 -1 $-1 $3311 $2615 $11 $-1 $3328 reversed single T 35 -25.000000000000004 -27.499999999999993 40.000000000000007 -24.330127018922187 -22.499999999999986 F #
+edge $-1 -1 -1 $-1 $2616 -1.5707963267948966 $3325 6.4931039580273206e-16 $3285 $4124 forward @7 unknown T 29.999999999999996 -25.000000000000004 -30 35 -20 -24.999999999999996 #
+point $-1 -1 -1 $-1 35 -25.000000000000004 -24.999999999999996 #
+point $-1 -1 -1 $-1 37.5 -24.330127018922187 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $4113 $2620 $2623 $3310 forward $3292 $-1 #
+coedge $-1 -1 -1 $-1 $2620 $4111 $2646 $3334 forward $3292 $-1 #
+vertex $-1 -1 -1 $-1 $2647 $4125 #
+coedge $-1 -1 -1 $-1 $2623 $2622 $4126 $4127 reversed $2624 $-1 #
+coedge $-1 -1 -1 $-1 $2635 $4128 $2622 $3309 reversed $3324 $-1 #
+edge $-1 -1 -1 $-1 $2109 1.5707963267948966 $4129 2.0943951023931922 $2622 $4130 forward @7 unknown T 35 -15.669872981077804 -27.499999999999986 37.499999999999986 -15.000000000000004 -24.999999999999996 #
+edge $-1 -1 -1 $-1 $2625 4.1887902047863905 $4131 4.7123889803846897 $3303 $4119 forward @7 unknown T 37.500000000000007 -15.669872981077814 -24.999999999999996 40.000000000000007 -15 -22.499999999999993 #
+face $-1 -1 -1 $-1 $3349 $2624 $11 $-1 $3328 reversed single T 35 -15.669872981077814 -27.499999999999993 40.000000000000007 -15 -22.499999999999993 F #
+point $-1 -1 -1 $-1 37.500000000000007 -15.669872981077814 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $4132 $2627 $4133 $3352 forward $2630 $-1 #
+coedge $-1 -1 -1 $-1 $2628 $4132 $4134 $4135 forward $2630 $-1 #
+coedge $-1 -1 -1 $-1 $4136 $2629 $3286 $2639 forward $3317 $-1 #
+coedge $-1 -1 -1 $-1 $2629 $4137 $4138 $4139 forward $3317 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2629 $4140 T 22.499999999999993 -25 -25.000000000000004 30 -20 -9.9999999999999964 unknown #
+point $-1 -1 -1 $-1 30 -20 -14.999999999999998 #
+coedge $-1 -1 -1 $-1 $4141 $4142 $2633 $3320 forward $4143 $-1 #
+edge $-1 -1 -1 $-1 $3325 0 $3321 1.5707963267948961 $3319 $4144 forward @7 unknown T 25 -20 -30 29.999999999999996 -15 -25 #
+vertex $-1 -1 -1 $-1 $4145 $4146 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $4147 $2635 $4142 $4148 reversed $3324 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3323 $3692 T 29.999999999999996 -20 -40 37.5 -15.000000000000004 -24.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $3320 $4149 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3299 $3287 $11 $-1 $3328 reversed single T 25 -25.000000000000004 -30 35 -20 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 -20 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $4150 $4151 #
+coedge $-1 -1 -1 $-1 $4099 $2641 $4152 $4153 forward $2643 $-1 #
+coedge $-1 -1 -1 $-1 $2642 $4098 $4154 $4155 forward $2643 $-1 #
+face $-1 -1 -1 $-1 $4104 $2643 $11 $-1 $2703 reversed single T 37.499999999999986 -25 -9.9999999999999982 45.000000000000007 -15 5.0000000000000044 F #
+point $-1 -1 -1 $-1 37.499999999999986 -15.669872981077805 2.5000000000000031 #
+edge $-1 -1 -1 $-1 $3336 -1.5707963267948966 $3305 -1.0471975511965965 $3304 $4156 forward @7 unknown T 37.499999999999993 -15.669872981077811 -12.500000000000004 40 -15 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $3334 $4157 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -9.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $4158 $4159 $11 $-1 $2664 reversed single T 20 -15.669872981077809 -12.499999999999996 25 -15 -7.4999999999999973 F #
+coedge $-1 -1 -1 $-1 $2652 $2651 $4034 $4160 forward $2123 $-1 #
+coedge $-1 -1 -1 $-1 $2676 $4047 $2651 $2687 reversed $3366 $-1 #
+coedge $-1 -1 -1 $-1 $4035 $4133 $2652 $3342 reversed $4159 $-1 #
+edge $-1 -1 -1 $-1 $4161 4.1887902047863914 $2660 4.7123889803846897 $2652 $4162 forward @7 unknown T 22.5 -15.669872981077807 -9.9999999999999982 25 -15 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $4163 $2653 $4164 $4165 forward $2656 $-1 #
+coedge $-1 -1 -1 $-1 $3273 $4138 $2653 $2131 reversed $4095 $-1 #
+coedge $-1 -1 -1 $-1 $2654 $4163 $4166 $2691 forward $2656 $-1 #
+coedge $-1 -1 -1 $-1 $2679 $4167 $2654 $3347 reversed $2690 $-1 #
+edge $-1 -1 -1 $-1 $2157 -1.5707963267948961 $2124 0 $2654 $2686 forward @7 unknown T 25 -25 1.7763568394002505e-15 29.999999999999996 -20 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $3275 $2655 $4167 $4168 reversed $1745 $-1 #
+face $-1 -1 -1 $-1 $3332 $2656 $11 $-1 $2194 reversed single T 22.5 -25 -9.9999999999999982 30 -20 5.0000000000000036 F #
+face $-1 -1 -1 $-1 $4169 $4170 $11 $-1 $2664 reversed single T 20 -25 -12.499999999999998 25 -24.330127018922191 -7.4999999999999973 F #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -9.9999999999999982 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2660 -1.570796326794897 $4171 -1.0471975511965983 $3313 $4172 forward @7 unknown T 22.499999999999996 -15.669872981077805 -12.499999999999996 25 -15 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 -15 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $4173 $4174 $11 $-1 $3659 reversed single T 29.999999999999996 -5.0000000000000009 20.000000000000004 37.5 -1.7763568394002505e-15 35 F #
+edge $-1 -1 -1 $-1 $4175 1.0471975511965979 $2665 1.570796326794897 $4137 $4172 forward @7 unknown T 22.499999999999996 -25 -12.499999999999998 25 -24.330127018922191 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 -25 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $4087 $2666 $4089 $4176 forward $2135 $-1 #
+coedge $-1 -1 -1 $-1 $4154 $4154 $2666 $3359 reversed $4177 $-1 #
+edge $-1 -1 -1 $-1 $2672 1.570796326794897 $4178 4.7123889803846897 $2666 $4179 forward @7 unknown T 39.999999999999993 -25 5.0000000000000027 44.999999999999993 -15 10.000000000000004 #
+coedge $-1 -1 -1 $-1 $2667 $4087 $4180 $4181 forward $2135 $-1 #
+coedge $-1 -1 -1 $-1 $2697 $2697 $2667 $3362 reversed $3388 $-1 #
+edge $-1 -1 -1 $-1 $3389 -1.570796326794897 $2169 1.570796326794897 $2667 $4182 forward @7 unknown T 40 -25 15.000000000000004 45.000000000000007 -15 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 -15 5.0000000000000027 #
+edge $-1 -1 -1 $-1 $2739 -17.5 $3367 -7.5000000000000009 $2674 $4183 forward @7 unknown T 22.5 -15.669872981077807 7.5000000000000009 22.500000000000004 -15.669872981077805 17.5 #
+loop $-1 -1 -1 $-1 $-1 $3231 $4184 T 20 -15.669872981077809 2.5000000000000036 25 -15 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $2677 $4185 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2680 $2678 $4186 $4187 forward $2148 $-1 #
+coedge $-1 -1 -1 $-1 $4166 $4188 $2678 $3371 reversed $4189 $-1 #
+edge $-1 -1 -1 $-1 $2157 1.5707963267948961 $4190 2.0943951023931957 $2678 $3368 forward @7 unknown T 22.499999999999996 -25 4.9999999999999991 25 -24.330127018922191 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $4167 $2679 $2684 $3377 forward $2690 $-1 #
+coedge $-1 -1 -1 $-1 $4191 $2723 $2680 $2200 reversed $3413 $-1 #
+coedge $-1 -1 -1 $-1 $2681 $2725 $2683 $3376 forward $2199 $-1 #
+coedge $-1 -1 -1 $-1 $3270 $2683 $4192 $4193 reversed $2094 $-1 #
+edge $-1 -1 -1 $-1 $3429 -1.5707963267948966 $1775 6.4931039580273206e-16 $3374 $4194 forward @7 unknown T 29.999999999999996 -25.000000000000004 15 35 -20 20.000000000000004 #
+edge $-1 -1 -1 $-1 $1501 -6.4931039580273206e-16 $4091 1.5707963267948966 $3372 $4195 forward @7 unknown T 29.999999999999996 -25.000000000000004 5.0000000000000018 35 -20 10.000000000000002 #
+face $-1 -1 -1 $-1 $4196 $4197 $11 $-1 $1815 reversed single T 10 -25 15 20 -20 25 F #
+vertex $-1 -1 -1 $-1 $4160 $4198 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $3271 $2689 T 35 -25.000000000000004 2.5000000000000053 40.000000000000007 -24.330127018922191 7.5000000000000062 unknown #
+vertex $-1 -1 -1 $-1 $2691 $4199 #
+edge $-1 -1 -1 $-1 $2963 4.1887902047863905 $2701 4.7123889803846897 $2944 $4200 forward @7 unknown T 37.5 -15.669872981077809 35 40 -15 37.5 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2699 $2696 $3422 $4201 forward $1788 $-1 #
+coedge $-1 -1 -1 $-1 $4180 $3427 $2696 $3387 reversed $2741 $-1 #
+edge $-1 -1 -1 $-1 $3389 1.570796326794897 $4202 2.0943951023931966 $2696 $2170 forward @7 unknown T 37.5 -25 20.000000000000004 40.000000000000007 -24.330127018922187 22.500000000000007 #
+loop $-1 -1 -1 $-1 $4203 $3361 $3820 T 39.999999999999993 -25 15.000000000000004 45.000000000000007 -15 25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $4181 $4204 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3423 $3669 $2699 $3392 reversed $4205 $-1 #
+edge $-1 -1 -1 $-1 $4206 1.0471975511965992 $3393 1.5707963267948966 $2699 $2702 forward @7 unknown T 37.500000000000007 -25 32.500000000000007 40 -24.330127018922195 35 #
+vertex $-1 -1 -1 $-1 $3392 $4207 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -15 35 #
+face $-1 -1 -1 $-1 $4208 $4209 $11 $-1 $4210 reversed single T 25 -25.000000000000004 -45 35 -20 -35 F #
+loop $-1 -1 -1 $-1 $-1 $4211 $2706 T 37.499999999999986 -25 -40 45.000000000000007 -15 -24.999999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2709 3.1415926535897931 $2731 4.7123889803846897 $3420 $3398 forward @7 unknown T 25 -25 35 30 -20 40 #
+point $-1 -1 -1 $-1 30 -20 40 #
+face $-1 -1 -1 $-1 $2695 $4205 $11 $-1 $1965 reversed single T 35 -25.000000000000004 32.5 40 -24.330127018922195 37.5 F #
+straight-curve $-1 -1 -1 $-1 22.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $2714 $2713 $3684 $4212 forward $2715 $-1 #
+edge $-1 -1 -1 $-1 $3688 4.1887902047863923 $2180 4.7123889803846897 $2957 $4213 forward @7 unknown T 22.500000000000004 -15.669872981077805 35 25 -15 37.499999999999993 #
+edge $-1 -1 -1 $-1 $4064 1.5707963267948966 $2716 2.0943951023931957 $2714 $4214 forward @7 unknown T 20 -15.669872981077809 32.5 22.500000000000004 -15 35 #
+face $-1 -1 -1 $-1 $4215 $2715 $11 $-1 $1965 reversed single T 20 -15.669872981077809 32.5 25 -15 37.5 F #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077809 32.5 #
+face $-1 -1 -1 $-1 $4216 $2719 $11 $-1 $1815 reversed single T 20 -15.669872981077809 17.5 25 -15 22.499999999999996 F #
+point $-1 -1 -1 $-1 22.499999999999996 -15.669872981077805 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $4217 $4218 $2722 $3411 reversed $4219 $-1 #
+edge $-1 -1 -1 $-1 $3414 22.499999999999993 $3418 32.500000000000007 $2722 $4220 forward @7 unknown T 22.499999999999993 -24.330127018922195 22.499999999999993 22.500000000000004 -24.330127018922191 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $2723 $4191 $4217 $4221 forward $3413 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3412 $4196 T 20 -25 17.5 25 -24.330127018922191 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $4221 $4222 #
+coedge $-1 -1 -1 $-1 $4223 $2726 $4218 $4224 forward $3417 $-1 #
+coedge $-1 -1 -1 $-1 $2726 $4223 $4225 $4226 reversed $3417 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4223 $3433 T 20 -25 32.5 25 -24.330127018922191 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $2727 $4227 #
+coedge $-1 -1 -1 $-1 $2729 $2728 $3667 $4228 forward $2730 $-1 #
+coedge $-1 -1 -1 $-1 $4225 $2959 $2728 $3399 forward $3665 $-1 #
+point $-1 -1 -1 $-1 25 -25 35 #
+coedge $-1 -1 -1 $-1 $2734 $2732 $3385 $4201 reversed $2191 $-1 #
+coedge $-1 -1 -1 $-1 $4229 $3391 $2732 $3424 forward $4205 $-1 #
+edge $-1 -1 -1 $-1 $4206 -2.0943951023931957 $3425 -1.5707963267948966 $3423 $4230 forward @7 unknown T 35 -25.000000000000004 32.5 37.500000000000007 -24.330127018922195 35 #
+vertex $-1 -1 -1 $-1 $2733 $4231 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3386 $4192 $2734 $3428 forward $2741 $-1 #
+edge $-1 -1 -1 $-1 $3429 1.5707963267948966 $4202 2.0943951023931966 $3427 $4232 forward @7 unknown T 35 -25.000000000000004 20.000000000000004 37.500000000000007 -24.330127018922187 22.500000000000007 #
+vertex $-1 -1 -1 $-1 $3376 $4233 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $2668 $4234 $11 $-1 $2194 reversed single T 22.499999999999996 -20 -50 30 -15 -40 F #
+loop $-1 -1 -1 $-1 $-1 $3771 $2736 T 37.499999999999986 -25 -50 45 -15 -40 unknown #
+face $-1 -1 -1 $-1 $3406 $3417 $11 $-1 $1965 reversed single T 20 -25 32.5 25 -24.330127018922191 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $4235 $2737 T 10 -25 30 20 -20 40 unknown #
+coedge $-1 -1 -1 $-1 $4236 $3245 $3682 $4237 forward $2738 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077807 17.5 #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 17.5 #
+coedge $-1 -1 -1 $-1 $4238 $2743 $4239 $4240 forward $1818 $-1 #
+coedge $-1 -1 -1 $-1 $4241 $2807 $2743 $3440 reversed $2774 $-1 #
+edge $-1 -1 -1 $-1 $3445 0 $3504 1.5707963267948966 $2743 $4242 forward @7 unknown T -5 -35 15 0 -30 20 #
+coedge $-1 -1 -1 $-1 $2744 $4238 $3923 $4243 forward $1818 $-1 #
+edge $-1 -1 -1 $-1 $3133 1.5707963267948966 $3444 3.1415926535897931 $2744 $4244 forward @7 unknown T -5 -35 5 0 -30 10 #
+coedge $-1 -1 -1 $-1 $3736 $3735 $4245 $2746 forward $2999 $-1 #
+vertex $-1 -1 -1 $-1 $3460 $4246 #
+vertex $-1 -1 -1 $-1 $3440 $4247 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $2500 $2747 $3147 T -50 -40 -3.0616169978683823e-15 -50 -30 9.9999999999999964 hole $3148 T #
+vertex $-1 -1 -1 $-1 $2748 $4248 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 4.9999999999999973 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $2823 $2749 $4249 $4250 reversed $2258 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 4.9999999999999973 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $3527 $4251 $2751 $3453 forward $4252 $-1 #
+edge $-1 -1 -1 $-1 $4253 -2.0943951023931935 $2753 -1.5707963267948966 $3452 $4254 forward @7 unknown T -40 -40 2.4999999999999982 -37.500000000000007 -39.330127018922198 4.9999999999999973 #
+coedge $-1 -1 -1 $-1 $4255 $4249 $2752 $3455 forward $4256 $-1 #
+edge $-1 -1 -1 $-1 $2754 1.5707963267948966 $4257 2.0943951023931948 $3454 $4258 forward @7 unknown T -40 -30.669872981077805 2.4999999999999982 -37.5 -30 4.9999999999999973 #
+point $-1 -1 -1 $-1 -40 -40 4.9999999999999973 #
+point $-1 -1 -1 $-1 -40 -30 4.9999999999999973 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 5 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4259 $3139 $2758 $3460 reversed $3937 $-1 #
+edge $-1 -1 -1 $-1 $3444 3.1415926535897931 $2760 4.7123889803846897 $2758 $4244 forward @7 unknown T -5 -40 5 0 -35 10 #
+point $-1 -1 -1 $-1 -5 -40 5 #
+coedge $-1 -1 -1 $-1 $4260 $4261 $4262 $3463 reversed $4263 $-1 #
+edge $-1 -1 -1 $-1 $3466 10 $2844 15 $4262 $4264 forward @7 unknown T -15 -35 10 -15 -35 15 #
+coedge $-1 -1 -1 $-1 $2764 $3987 $4265 $4266 reversed $3465 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2764 $4267 T -20 -40 -1.7763568394002505e-15 -10.000000000000002 -35 10 unknown #
+vertex $-1 -1 -1 $-1 $4266 $4268 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -39.330127018922191 0 0 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $2772 -2.0943951023931944 $3202 -1.5707963267948966 $2770 $4269 forward @7 unknown T 4.9999999999999982 -30.669872981077805 5 7.4999999999999956 -30 7.5000000000000018 #
+face $-1 -1 -1 $-1 $3219 $2771 $11 $-1 $227 reversed single T 4.9999999999999982 -30.669872981077809 2.4999999999999996 10 -30 7.5000000000000018 F #
+point $-1 -1 -1 $-1 7.4999999999999956 -30.669872981077798 7.5000000000000018 #
+loop $-1 -1 -1 $-1 $-1 $3531 $2773 T -5 -40 15 4.9999999999999982 -35 25 unknown #
+coedge $-1 -1 -1 $-1 $2807 $4241 $2796 $3493 forward $2774 $-1 #
+point $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922198 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $2777 $3124 $4270 $4271 forward $2485 $-1 #
+coedge $-1 -1 -1 $-1 $4272 $3259 $2777 $3119 reversed $4080 $-1 #
+coedge $-1 -1 -1 $-1 $3212 $4273 $2778 $3479 reversed $4017 $-1 #
+edge $-1 -1 -1 $-1 $3480 27.500000000000004 $3916 37.500000000000007 $2778 $4274 forward @7 unknown T 7.4999999999999982 -30.669872981077813 -37.500000000000007 7.4999999999999991 -30.669872981077805 -27.500000000000004 #
+vertex $-1 -1 -1 $-1 $3213 $4275 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2810 $2782 $3531 $4276 reversed $2784 $-1 #
+coedge $-1 -1 -1 $-1 $2783 $2810 $4277 $3800 reversed $2784 $-1 #
+face $-1 -1 -1 $-1 $3033 $2784 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 20 7.5 -35 35 F #
+vertex $-1 -1 -1 $-1 $4278 $4279 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4245 $2790 $4241 $3494 reversed $2792 $-1 #
+coedge $-1 -1 -1 $-1 $2791 $4245 $3927 $4280 reversed $2792 $-1 #
+face $-1 -1 -1 $-1 $2058 $2792 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 5 7.4999999999999991 -30 20 F #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2796 $2795 $1851 $2251 reversed $2240 $-1 #
+coedge $-1 -1 -1 $-1 $2802 $2804 $2795 $3039 forward $2246 $-1 #
+edge $-1 -1 -1 $-1 $2798 -1.5707963267948966 $2811 6.1232339957367648e-17 $3474 $4281 forward @7 unknown T -1.7763568394002505e-15 -35 20 4.9999999999999982 -30 25 #
+edge $-1 -1 -1 $-1 $3445 -6.1232339957367648e-17 $2798 1.5707963267948966 $4241 $4282 forward @7 unknown T -1.7763568394002505e-15 -35 15 4.9999999999999982 -30 20 #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 20 #
+coedge $-1 -1 -1 $-1 $4277 $2871 $3032 $3799 forward $2801 $-1 #
+coedge $-1 -1 -1 $-1 $2806 $2803 $4283 $4284 forward $1561 $-1 #
+coedge $-1 -1 -1 $-1 $2970 $2969 $2803 $3499 reversed $1909 $-1 #
+edge $-1 -1 -1 $-1 $3500 -1.5707963267948966 $4285 -1.0471975511965974 $2803 $2870 forward @7 unknown T -7.5000000000000027 -30.669872981077813 32.5 -5 -30 35 #
+vertex $-1 -1 -1 $-1 $3499 $4286 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4287 $4239 $2806 $3503 reversed $4288 $-1 #
+edge $-1 -1 -1 $-1 $4289 4.1887902047863905 $3504 4.7123889803846897 $2806 $2268 forward @7 unknown T -7.5000000000000018 -30.669872981077809 20 -5 -30 22.500000000000004 #
+vertex $-1 -1 -1 $-1 $4240 $4290 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $2871 $4277 $2809 $3507 reversed $2801 $-1 #
+edge $-1 -1 -1 $-1 $2298 -1.5707963267948966 $2812 0 $2809 $3501 forward @7 unknown T -5 -40 30 0 -35 35 #
+point $-1 -1 -1 $-1 0 -35 25 #
+point $-1 -1 -1 $-1 0 -35 30 #
+point $-1 -1 -1 $-1 -50 -35 14.999999999999996 #
+coedge $-1 -1 -1 $-1 $2824 $4291 $2817 $3512 forward $3524 $-1 #
+edge $-1 -1 -1 $-1 $4292 -2.0943951023931948 $2260 -1.5707963267948966 $3511 $4293 forward @7 unknown T -40 -30.669872981077805 19.999999999999996 -37.5 -30 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $4294 $2821 $2818 $3514 forward $3518 $-1 #
+edge $-1 -1 -1 $-1 $2259 1.5707963267948966 $4295 2.0943951023931966 $3513 $4296 forward @7 unknown T -40 -40 19.999999999999996 -37.499999999999993 -39.330127018922184 22.5 #
+coedge $-1 -1 -1 $-1 $4297 $4298 $2820 $3516 forward $4299 $-1 #
+edge $-1 -1 -1 $-1 $4300 7.4999999999999982 $3519 17.499999999999989 $3515 $4301 forward @7 unknown T -37.500000000000007 -39.330127018922198 7.4999999999999982 -37.499999999999993 -39.330127018922191 17.499999999999989 #
+coedge $-1 -1 -1 $-1 $2821 $4294 $4297 $4302 reversed $3518 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3513 $4303 T -40 -40 17.499999999999989 -35 -39.330127018922184 22.5 unknown #
+vertex $-1 -1 -1 $-1 $4302 $4304 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 19.999999999999996 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $4305 $4306 $2823 $3522 forward $4307 $-1 #
+edge $-1 -1 -1 $-1 $3525 -17.499999999999996 $4308 -7.5000000000000027 $3521 $4309 forward @7 unknown T -37.500000000000007 -30.669872981077813 7.5000000000000027 -37.5 -30.669872981077805 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $4291 $2824 $4306 $4310 reversed $3524 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3511 $4311 T -40 -30.669872981077809 17.499999999999993 -35 -30 22.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $3522 $4312 #
+coedge $-1 -1 -1 $-1 $4313 $3452 $2826 $3528 forward $4252 $-1 #
+edge $-1 -1 -1 $-1 $2753 1.5707963267948966 $4300 2.0943951023931944 $3527 $4314 forward @7 unknown T -40 -40 4.9999999999999973 -37.500000000000007 -39.330127018922198 7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $2832 $4315 $2830 $3530 reversed $3473 $-1 #
+edge $-1 -1 -1 $-1 $2267 -1.5707963267948966 $3445 0 $2830 $4242 forward @7 unknown T -5 -40 15 0 -35 20 #
+coedge $-1 -1 -1 $-1 $4315 $2832 $3482 $4276 forward $3473 $-1 #
+coedge $-1 -1 -1 $-1 $2839 $2835 $4316 $4317 reversed $2840 $-1 #
+coedge $-1 -1 -1 $-1 $4318 $2837 $4319 $4320 reversed $3536 $-1 #
+coedge $-1 -1 -1 $-1 $2837 $3701 $3699 $4321 reversed $3536 $-1 #
+coedge $-1 -1 -1 $-1 $4322 $4323 $4324 $2838 forward $4325 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3533 $4326 T -15.000000000000002 -35 20 -7.5000000000000009 -30 35 unknown #
+coedge $-1 -1 -1 $-1 $4327 $4324 $2839 $3539 forward $3697 $-1 #
+edge $-1 -1 -1 $-1 $2841 3.1415926535897931 $4328 4.7123889803846897 $3538 $4329 forward @7 unknown T -20 -40 20 -15 -35 25 #
+face $-1 -1 -1 $-1 $4330 $2840 $11 $-1 $162 reversed single T -20 -40 15 -10.000000000000002 -35 25 F #
+point $-1 -1 -1 $-1 -15 -35 25 #
+edge $-1 -1 -1 $-1 $2844 0 $4331 1.5707963267948966 $4332 $4333 forward @7 unknown T -20 -35 15 -15 -30 20 #
+point $-1 -1 -1 $-1 -15 -35 15 #
+coedge $-1 -1 -1 $-1 $2889 $2971 $2846 $3545 reversed $3571 $-1 #
+edge $-1 -1 -1 $-1 $2891 -50 $3703 -37.5 $2846 $4334 forward @7 unknown T -7.5000000000000018 -30.669872981077809 37.5 -7.5000000000000009 -30.669872981077805 50 #
+edge $-1 -1 -1 $-1 $3703 4.1887902047863905 $3500 4.7123889803846897 $2847 $2299 forward @7 unknown T -7.5000000000000018 -30.669872981077809 35 -5 -30 37.5 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 0 -35 40 #
+point $-1 -1 -1 $-1 -50 -35 29.999999999999996 #
+coedge $-1 -1 -1 $-1 $4335 $2857 $4336 $4337 reversed $2859 $-1 #
+coedge $-1 -1 -1 $-1 $2865 $4338 $2857 $3552 forward $3566 $-1 #
+edge $-1 -1 -1 $-1 $4339 -2.0943951023931953 $2292 -1.5707963267948966 $3551 $4340 forward @7 unknown T -40 -30.669872981077809 35 -37.5 -30 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $2858 $4335 $4341 $4342 reversed $2859 $-1 #
+coedge $-1 -1 -1 $-1 $4343 $2862 $2858 $3555 forward $3560 $-1 #
+edge $-1 -1 -1 $-1 $2291 1.5707963267948966 $4344 2.0943951023931953 $3554 $4345 forward @7 unknown T -40 -40 35 -37.5 -39.330127018922191 37.5 #
+face $-1 -1 -1 $-1 $3843 $2859 $11 $-1 $3172 reversed single T -45 -40 35 -37.5 -30 50 F #
+coedge $-1 -1 -1 $-1 $4346 $4347 $2861 $3558 forward $4348 $-1 #
+edge $-1 -1 -1 $-1 $4295 22.499999999999996 $3561 32.500000000000007 $3557 $4349 forward @7 unknown T -37.500000000000014 -39.330127018922205 22.499999999999996 -37.499999999999993 -39.330127018922184 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $2862 $4343 $4346 $4350 reversed $3560 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3554 $4351 T -40 -40 32.5 -35 -39.330127018922191 37.5 unknown #
+vertex $-1 -1 -1 $-1 $4350 $4352 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 35 -0.70710678118654768 -0 -0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $4353 $4354 $2864 $3564 forward $4355 $-1 #
+edge $-1 -1 -1 $-1 $3567 -32.5 $4292 -22.499999999999993 $3563 $4356 forward @7 unknown T -37.5 -30.669872981077805 22.499999999999993 -37.5 -30.669872981077802 32.5 #
+coedge $-1 -1 -1 $-1 $4338 $2865 $4354 $4357 reversed $3566 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3551 $4358 T -40 -30.669872981077809 32.5 -35 -30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $3564 $4359 #
+coedge $-1 -1 -1 $-1 $2877 $2874 $4360 $4361 reversed $2878 $-1 #
+coedge $-1 -1 -1 $-1 $2971 $2876 $2968 $3700 reversed $3571 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3544 $4362 T -15.000000000000002 -35 35 -7.5 -30 50 unknown #
+point $-1 -1 -1 $-1 -15 -35 40 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000009 -39.330127018922191 50 #
+face $-1 -1 -1 $-1 $2469 $3900 $11 $-1 $2541 reversed single T -15.000000000000002 -35 -40 -7.4999999999999973 -30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $4363 $2885 T -15.000000000000002 -35 -50 -7.4999999999999973 -30 -40 unknown #
+edge $-1 -1 -1 $-1 $2886 0 $4364 1.5707963267948966 $4322 $4365 forward @7 unknown T -20 -35 30 -15 -30 35 #
+point $-1 -1 -1 $-1 -15 -35 30 #
+coedge $-1 -1 -1 $-1 $2888 $4366 $4367 $4368 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $4369 $2979 $2888 $3581 reversed $3717 $-1 #
+edge $-1 -1 -1 $-1 $4370 -2.0943951023931957 $2978 0 $2888 $3714 forward @7 unknown T -22.5 -35 50 -15 -30 50 #
+point $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $4371 $4372 $4373 $4374 forward $2896 $-1 #
+coedge $-1 -1 -1 $-1 $4375 $2897 $4376 $4377 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $2897 $4378 $4379 $4380 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $4381 $4382 $2897 $3588 reversed $4383 $-1 #
+edge $-1 -1 -1 $-1 $4384 -1.5707963267948966 $4385 0.52359877559829893 $2897 $4386 forward @7 unknown T 30 40 50 37.5 45 50 #
+coedge $-1 -1 -1 $-1 $4387 $2898 $4388 $4389 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $4390 $4391 $2898 $3591 reversed $4392 $-1 #
+edge $-1 -1 -1 $-1 $3599 -2.0943951023931948 $4393 2.0943951023931948 $2898 $4394 forward @7 unknown T 37.5 20 50 45 30 50 #
+coedge $-1 -1 -1 $-1 $2899 $4395 $4396 $4397 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $4398 $4399 $2899 $3594 reversed $4400 $-1 #
+edge $-1 -1 -1 $-1 $4401 -2.0943951023931948 $3598 0 $2899 $4402 forward @7 unknown T 22.5 25 50 30 30 50 #
+coedge $-1 -1 -1 $-1 $4403 $2900 $4399 $4404 reversed $3597 $-1 #
+coedge $-1 -1 -1 $-1 $2900 $4405 $4390 $4406 reversed $3597 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3596 $4407 T 30 25 35 37.5 29.999999999999996 50 unknown #
+vertex $-1 -1 -1 $-1 $4408 $4409 #
+vertex $-1 -1 -1 $-1 $3591 $4410 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4411 $2902 $4412 $3622 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $4413 $4414 $2902 $3603 reversed $4415 $-1 #
+edge $-1 -1 -1 $-1 $3607 2.617993877991494 $2911 4.7123889803846897 $2902 $4416 forward @7 unknown T 30 4.9999999999999982 50 37.5 10 50 #
+coedge $-1 -1 -1 $-1 $4417 $2903 $2909 $3620 forward $3606 $-1 #
+coedge $-1 -1 -1 $-1 $2903 $4418 $4413 $4419 forward $3606 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3604 $4420 T 37.5 5 35 45 15 50 unknown #
+vertex $-1 -1 -1 $-1 $4419 $4421 #
+ellipse-curve $-1 -1 -1 $-1 40 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $2905 $4422 $4423 $4424 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $4425 $4426 $2905 $3611 reversed $4427 $-1 #
+edge $-1 -1 -1 $-1 $4428 -1.5707963267948961 $3615 0.52359877559829893 $2905 $4429 forward @7 unknown T 15 10 50 22.5 14.999999999999998 50 #
+coedge $-1 -1 -1 $-1 $4430 $2906 $4426 $4431 forward $3614 $-1 #
+coedge $-1 -1 -1 $-1 $2906 $4432 $4433 $3618 forward $3614 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3613 $4434 T 22.499999999999996 10 35 30 15 50 unknown #
+vertex $-1 -1 -1 $-1 $2907 $4435 #
+ellipse-curve $-1 -1 -1 $-1 25 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3619 $2908 $4436 $4437 reversed $2910 $-1 #
+edge $-1 -1 -1 $-1 $4438 40 $2911 50 $3613 $4439 forward @7 unknown T 30 10 40 30 10 50 #
+coedge $-1 -1 -1 $-1 $2909 $3617 $4440 $4441 reversed $2910 $-1 #
+edge $-1 -1 -1 $-1 $2912 -50 $4442 -37.5 $3604 $4443 forward @7 unknown T 37.5 14.330127018922193 37.5 37.5 14.330127018922195 50 #
+face $-1 -1 -1 $-1 $4444 $2910 $11 $-1 $4445 reversed single T 30 10 35 37.5 14.999999999999998 50 F #
+edge $-1 -1 -1 $-1 $2911 0 $4446 2.0943951023931957 $3601 $3616 forward @7 unknown T 22.5 5 50 30 10 50 #
+point $-1 -1 -1 $-1 30 10 50 #
+point $-1 -1 -1 $-1 37.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $4447 $2914 $4448 $4449 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $3647 $4450 $2914 $2935 reversed $4451 $-1 #
+coedge $-1 -1 -1 $-1 $4452 $2915 $2918 $3633 reversed $3629 $-1 #
+coedge $-1 -1 -1 $-1 $2915 $4453 $2333 $2931 forward $3629 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3628 $4454 T 30 -10.000000000000002 35 37.5 -4.9999999999999991 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4455 $2917 $4456 $4457 forward $2919 $-1 #
+coedge $-1 -1 -1 $-1 $2918 $4455 $4458 $4459 forward $2919 $-1 #
+edge $-1 -1 -1 $-1 $4460 37.5 $2920 50 $2918 $4461 forward @7 unknown T 37.5 -9.3301270189221945 37.5 37.5 -9.3301270189221945 50 #
+face $-1 -1 -1 $-1 $4462 $2919 $11 $-1 $4463 reversed single T 37.5 -10 35 45 0 50 F #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221945 50 #
+coedge $-1 -1 -1 $-1 $2922 $4464 $4465 $4466 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $4467 $4468 $2922 $3638 reversed $4469 $-1 #
+edge $-1 -1 -1 $-1 $4470 -2.0943951023931957 $3642 0 $2922 $4471 forward @7 unknown T 7.4999999999999991 -5 50 15 0 50 #
+coedge $-1 -1 -1 $-1 $4472 $2923 $4468 $4473 reversed $3641 $-1 #
+coedge $-1 -1 -1 $-1 $2923 $4474 $2925 $3645 reversed $3641 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3640 $4475 T 15 -5.0000000000000009 35 22.500000000000004 -8.8817841970012523e-16 50 unknown #
+vertex $-1 -1 -1 $-1 $4476 $4477 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $3646 $2925 $4478 $4479 forward $2927 $-1 #
+edge $-1 -1 -1 $-1 $2928 -50 $4480 -37.500000000000007 $2925 $4481 forward @7 unknown T 22.5 -0.66987298107780902 37.500000000000007 22.500000000000004 -0.66987298107780635 50 #
+coedge $-1 -1 -1 $-1 $2926 $3644 $4482 $4483 forward $2927 $-1 #
+coedge $-1 -1 -1 $-1 $4484 $3626 $3628 $2931 reversed $4451 $-1 #
+face $-1 -1 -1 $-1 $4485 $2927 $11 $-1 $4486 reversed single T 22.499999999999996 -5.0000000000000009 35 30 0 50 F #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780635 50 #
+coedge $-1 -1 -1 $-1 $4482 $4487 $2930 $3651 forward $4488 $-1 #
+edge $-1 -1 -1 $-1 $4489 -1.5707963267948966 $3652 -4.7167471186270725e-16 $3650 $4490 forward @7 unknown T 30 -4.9999999999999991 35 35 -1.7763568394002505e-15 40 #
+vertex $-1 -1 -1 $-1 $4491 $4492 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4493 $4456 $2932 $3655 forward $4494 $-1 #
+edge $-1 -1 -1 $-1 $3656 -2.0943951023931966 $4489 -1.5707963267948966 $3654 $4495 forward @7 unknown T 35 -0.66987298107781257 35 37.500000000000007 -1.7763568394002505e-15 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $4457 $4496 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $4497 $4498 $11 $-1 $3659 reversed single T 30 -5.0000000000000018 -50 37.5 -1.7763568394002505e-15 -40 F #
+cone-surface $-1 -1 -1 $-1 35 -5.0000000000000018 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $4499 $4500 #
+coedge $-1 -1 -1 $-1 $4501 $2938 $4502 $3686 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $4503 $4504 $2938 $3663 reversed $4505 $-1 #
+edge $-1 -1 -1 $-1 $2966 2.617993877991494 $2955 4.7123889803846897 $2938 $4506 forward @7 unknown T 15 -25 50 22.5 -20 50 #
+coedge $-1 -1 -1 $-1 $2939 $4225 $4503 $3694 forward $3665 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2959 $3673 T 22.5 -25 35 30 -20 50 unknown #
+coedge $-1 -1 -1 $-1 $3667 $2940 $4229 $4507 reversed $2942 $-1 #
+coedge $-1 -1 -1 $-1 $2941 $3666 $3419 $4228 reversed $2942 $-1 #
+coedge $-1 -1 -1 $-1 $2945 $2944 $3057 $3830 forward $2344 $-1 #
+coedge $-1 -1 -1 $-1 $3391 $4229 $2945 $3670 reversed $4205 $-1 #
+edge $-1 -1 -1 $-1 $3393 1.5707963267948966 $3671 2.0943951023931948 $2945 $4200 forward @7 unknown T 37.5 -25 35 40 -24.330127018922195 37.5 #
+vertex $-1 -1 -1 $-1 $4507 $4508 #
+face $-1 -1 -1 $-1 $2165 $3665 $11 $-1 $2194 reversed single T 22.5 -25 35 30 -20 50 F #
+coedge $-1 -1 -1 $-1 $2949 $4509 $4510 $4511 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $4512 $4513 $2949 $3676 reversed $4514 $-1 #
+edge $-1 -1 -1 $-1 $4515 -1.5707963267948966 $3680 0.52359877559829893 $2949 $4516 forward @7 unknown T -8.8817841970012523e-16 -20 50 7.5 -15 50 #
+coedge $-1 -1 -1 $-1 $4517 $2950 $4513 $4518 forward $3679 $-1 #
+coedge $-1 -1 -1 $-1 $2950 $4519 $4520 $3683 forward $3679 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3678 $4521 T 7.4999999999999991 -20 35 15 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $2951 $4522 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3684 $2952 $3435 $4237 reversed $2954 $-1 #
+edge $-1 -1 -1 $-1 $4523 40 $2955 50 $3678 $4524 forward @7 unknown T 15 -20 40 15 -20 50 #
+coedge $-1 -1 -1 $-1 $2953 $3682 $3403 $4212 reversed $2954 $-1 #
+face $-1 -1 -1 $-1 $4525 $2954 $11 $-1 $1477 reversed single T 15 -20 35 22.500000000000004 -15 50 F #
+edge $-1 -1 -1 $-1 $2955 0 $4526 2.0943951023931957 $3661 $3681 forward @7 unknown T 7.4999999999999991 -25 50 15 -20 50 #
+point $-1 -1 -1 $-1 15 -20 50 #
+vertex $-1 -1 -1 $-1 $3404 $4527 #
+face $-1 -1 -1 $-1 $1808 $4528 $11 $-1 $4529 reversed single T 7.4999999999999991 -25 35 15 -20 50 F #
+point $-1 -1 -1 $-1 37.5 -15.669872981077809 37.5 #
+face $-1 -1 -1 $-1 $4530 $3324 $11 $-1 $704 reversed single T 29.999999999999996 -20 -40 37.5 -15.000000000000004 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $4531 $2965 T 30 -20 -50 37.5 -15.000000000000004 -40 unknown #
+edge $-1 -1 -1 $-1 $4532 37.500000000000007 $2966 50 $3664 $4533 forward @7 unknown T 22.5 -24.330127018922195 37.500000000000007 22.500000000000004 -24.330127018922195 50 #
+point $-1 -1 -1 $-1 22.5 -24.330127018922195 50 #
+face $-1 -1 -1 $-1 $4534 $4288 $11 $-1 $162 reversed single T -10.000000000000002 -30.669872981077813 17.499999999999996 -5 -30 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $4324 $2967 T -22.500000000000004 -40 20 -15 -35 35 unknown #
+coedge $-1 -1 -1 $-1 $4535 $2968 $3716 $4536 reversed $2363 $-1 #
+coedge $-1 -1 -1 $-1 $2968 $4535 $3534 $4321 forward $2363 $-1 #
+edge $-1 -1 -1 $-1 $3704 -1.5707963267948966 $2879 6.1232339957367648e-17 $2968 $4537 forward @7 unknown T -15.000000000000002 -35 35 -10.000000000000002 -30 40 #
+coedge $-1 -1 -1 $-1 $3534 $4283 $2969 $3702 reversed $3536 $-1 #
+edge $-1 -1 -1 $-1 $3704 1.5707963267948966 $4285 2.0943951023931944 $2969 $4538 forward @7 unknown T -10.000000000000002 -30.669872981077813 32.500000000000007 -7.5000000000000027 -30 35 #
+vertex $-1 -1 -1 $-1 $3546 $4539 #
+vertex $-1 -1 -1 $-1 $4321 $4540 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4541 $4542 $2973 $3707 reversed $4543 $-1 #
+edge $-1 -1 -1 $-1 $3708 1.5707963267948966 $4544 2.0943951023931957 $2973 $4545 forward @7 unknown T -22.500000000000004 -40 35 -20 -39.330127018922191 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $4546 $4547 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4548 $4549 $2975 $3711 reversed $4550 $-1 #
+edge $-1 -1 -1 $-1 $4544 37.500000000000007 $3713 50 $2975 $4551 forward @7 unknown T -22.500000000000004 -39.330127018922198 37.500000000000007 -22.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $4552 $2976 $4549 $4553 forward $937 $-1 #
+vertex $-1 -1 -1 $-1 $3711 $4554 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 50 -0 -0 -1 5 0 0 1 I I #
+point $-1 -1 -1 $-1 -15 -35 50 #
+coedge $-1 -1 -1 $-1 $2979 $4555 $3698 $4536 forward $3717 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2979 $4556 T -22.500000000000004 -35 35 -15 -30 50 unknown #
+coedge $-1 -1 -1 $-1 $2981 $3915 $3723 $4557 forward $3719 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3718 $4558 T 4.9999999999999982 -30.669872981077813 -42.500000000000007 10 -30 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $4557 $4559 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 -30 -40 #
+coedge $-1 -1 -1 $-1 $4560 $2985 $3718 $4557 reversed $3724 $-1 #
+loop $-1 -1 -1 $-1 $-1 $2985 $3038 T -1.7763568394002505e-15 -35 -50 7.5 -30 -40 unknown #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -30.669872981077809 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 7.4999999999999991 -30.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $3748 $4561 $2989 $3728 reversed $4562 $-1 #
+edge $-1 -1 -1 $-1 $3729 -50 $4563 -42.500000000000007 $2989 $4564 forward @7 unknown T 7.4999999999999982 -39.330127018922198 -50 7.4999999999999991 -39.330127018922191 -42.500000000000007 #
+vertex $-1 -1 -1 $-1 $2990 $4565 #
+coedge $-1 -1 -1 $-1 $4566 $3918 $2991 $3731 reversed $4567 $-1 #
+edge $-1 -1 -1 $-1 $4563 1.0471975511965974 $2996 1.5707963267948966 $2991 $3721 forward @7 unknown T 7.4999999999999982 -40 -42.500000000000007 10 -39.330127018922191 -40 #
+face $-1 -1 -1 $-1 $1826 $4568 $11 $-1 $1445 reversed single T -7.5000000000000089 -35 -50 0 -30 -40 F #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 -40 -40 #
+coedge $-1 -1 -1 $-1 $3443 $2997 $4259 $4569 reversed $2999 $-1 #
+coedge $-1 -1 -1 $-1 $2998 $3443 $4315 $4278 reversed $2999 $-1 #
+edge $-1 -1 -1 $-1 $2776 -2.0943951023931948 $3738 -1.5707963267948966 $3001 $4570 forward @7 unknown T 4.9999999999999982 -40 2.5000000000000009 7.4999999999999991 -39.330127018922198 5 #
+vertex $-1 -1 -1 $-1 $3938 $4571 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4572 $3006 $4573 $4574 forward $1370 $-1 #
+coedge $-1 -1 -1 $-1 $4575 $4576 $3006 $3743 reversed $4568 $-1 #
+edge $-1 -1 -1 $-1 $3745 0 $4577 2.0943951023931957 $3006 $4578 forward @7 unknown T -7.5000000000000009 -35 -50 0 -30 -50 #
+coedge $-1 -1 -1 $-1 $3007 $4560 $4575 $4579 reversed $3724 $-1 #
+vertex $-1 -1 -1 $-1 $3743 $4580 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $3009 $3888 $3876 $4581 forward $1370 $-1 #
+coedge $-1 -1 -1 $-1 $4582 $3727 $3009 $3749 reversed $4562 $-1 #
+edge $-1 -1 -1 $-1 $3745 1.5707963267948966 $3729 3.6651914291880923 $3009 $4583 forward @7 unknown T -1.7763568394002505e-15 -40 -50 7.4999999999999991 -35 -50 #
+loop $-1 -1 -1 $-1 $4584 $4585 $1616 T -45 35 -50 45 45 -50 unknown #
+coedge $-1 -1 -1 $-1 $4586 $4587 $4588 $4589 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $4590 $3012 $4591 $4592 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $3012 $4593 $4594 $4595 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $4596 $4597 $3012 $3755 reversed $4598 $-1 #
+edge $-1 -1 -1 $-1 $4599 1.5707963267948961 $4600 3.6651914291880923 $3012 $4601 forward @7 unknown T 30 4.9999999999999982 -50 37.5 10 -50 #
+coedge $-1 -1 -1 $-1 $4602 $3013 $4603 $4604 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $4605 $4606 $3013 $3758 reversed $4607 $-1 #
+edge $-1 -1 -1 $-1 $3766 -2.0943951023931948 $4608 2.0943951023931957 $3013 $4609 forward @7 unknown T 37.5 -10 -50 45 0 -50 #
+coedge $-1 -1 -1 $-1 $3014 $4610 $4611 $4612 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $4613 $4614 $3014 $3761 reversed $4615 $-1 #
+edge $-1 -1 -1 $-1 $4616 -2.0943951023931948 $3765 -1.7763568394002506e-16 $3014 $4617 forward @7 unknown T 22.5 -10 -50 30 -5.0000000000000009 -50 #
+coedge $-1 -1 -1 $-1 $4618 $3015 $4619 $4620 forward $3764 $-1 #
+coedge $-1 -1 -1 $-1 $3015 $4621 $4605 $4622 reversed $3764 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3763 $4623 T 30 -10.000000000000002 -50 37.500000000000007 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $4624 $4625 #
+vertex $-1 -1 -1 $-1 $3758 $4626 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4627 $3017 $4628 $3789 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $4531 $3784 $3017 $3770 reversed $3693 $-1 #
+edge $-1 -1 -1 $-1 $3773 -0.5235987755982987 $3026 1.5707963267948957 $3017 $4629 forward @7 unknown T 30 -20 -50 37.5 -15.000000000000004 -50 #
+coedge $-1 -1 -1 $-1 $4630 $3018 $3024 $3787 forward $3432 $-1 #
+coedge $-1 -1 -1 $-1 $3018 $4631 $4531 $4632 forward $3432 $-1 #
+vertex $-1 -1 -1 $-1 $4632 $4633 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3020 $4634 $4635 $4636 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $4637 $4638 $3020 $3777 reversed $4639 $-1 #
+edge $-1 -1 -1 $-1 $4640 1.5707963267948966 $3781 3.6651914291880923 $3020 $4641 forward @7 unknown T 15 -25 -50 22.5 -20 -50 #
+coedge $-1 -1 -1 $-1 $4642 $3021 $4638 $4643 forward $3780 $-1 #
+coedge $-1 -1 -1 $-1 $3021 $4644 $3023 $3785 reversed $3780 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3779 $4645 T 22.499999999999996 -25 -50 30 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $3022 $4646 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3786 $3023 $4647 $4648 reversed $3025 $-1 #
+coedge $-1 -1 -1 $-1 $3769 $4649 $4650 $3785 reversed $3693 $-1 #
+edge $-1 -1 -1 $-1 $3026 -50 $4651 -45 $4650 $4652 forward @7 unknown T 30 -20 -50 30 -20 -45 #
+coedge $-1 -1 -1 $-1 $3024 $3783 $4653 $4654 reversed $3025 $-1 #
+edge $-1 -1 -1 $-1 $3027 -50 $4655 -42.5 $3771 $4656 forward @7 unknown T 37.5 -24.330127018922198 -50 37.500000000000007 -24.330127018922195 -42.5 #
+face $-1 -1 -1 $-1 $2947 $3025 $11 $-1 $704 reversed single T 30 -25.000000000000004 -50 37.500000000000007 -20 -40 F #
+edge $-1 -1 -1 $-1 $3026 0 $4657 2.0943951023931948 $3768 $3782 forward @7 unknown T 22.5 -20 -50 30 -15 -50 #
+point $-1 -1 -1 $-1 30 -20 -50 #
+point $-1 -1 -1 $-1 37.5 -24.330127018922195 -50 #
+face $-1 -1 -1 $-1 $4658 $4659 $11 $-1 $756 reversed single T -25.000000000000004 -40 -42.500000000000007 -20 -39.330127018922191 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $3899 $3029 T -22.500000000000004 -35 -40 -15 -30 -25 unknown #
+coedge $-1 -1 -1 $-1 $4660 $4661 $3100 $3893 reversed $3030 $-1 #
+coedge $-1 -1 -1 $-1 $4662 $3031 $4663 $4664 forward $2411 $-1 #
+coedge $-1 -1 -1 $-1 $3031 $4665 $4666 $4667 forward $2411 $-1 #
+coedge $-1 -1 -1 $-1 $4668 $4669 $3857 $3798 forward $4670 $-1 #
+edge $-1 -1 -1 $-1 $4671 -35 $4672 -30.000000000000004 $4673 $4674 forward @7 unknown T -30.000000000000007 -35 -35 -30 -35 -30.000000000000004 #
+edge $-1 -1 -1 $-1 $2852 6.1232339957367648e-17 $3034 1.5707963267948966 $3496 $4675 forward @7 unknown T -1.7763568394002505e-15 -40 35 4.9999999999999982 -35 40 #
+edge $-1 -1 -1 $-1 $3034 -1.5707963267948966 $2812 -6.1232339957367648e-17 $4277 $4676 forward @7 unknown T -1.7763568394002505e-15 -40 30 4.9999999999999982 -35 35 #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 35 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $4677 $4017 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -35 -40 7.4999999999999991 -30 -25 F #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4678 $4679 $3041 $3209 reversed $4680 $-1 #
+coedge $-1 -1 -1 $-1 $4082 $3042 $3972 $4681 reversed $2570 $-1 #
+coedge $-1 -1 -1 $-1 $3042 $3221 $4678 $4682 reversed $2570 $-1 #
+vertex $-1 -1 -1 $-1 $3044 $4683 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 -25.000000000000004 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -25.000000000000004 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3835 $3047 $4684 $4685 reversed $3049 $-1 #
+coedge $-1 -1 -1 $-1 $3170 $4686 $3047 $3813 forward $3970 $-1 #
+edge $-1 -1 -1 $-1 $4687 -2.0943951023931957 $3050 -1.5707963267948966 $3812 $4688 forward @7 unknown T -40 -40 -27.500000000000007 -37.5 -39.330127018922191 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $3048 $3834 $4689 $4690 reversed $3049 $-1 #
+coedge $-1 -1 -1 $-1 $4691 $3959 $3048 $3816 forward $4692 $-1 #
+edge $-1 -1 -1 $-1 $3051 1.5707963267948966 $4693 2.0943951023931953 $3815 $4694 forward @7 unknown T -40 -30.669872981077809 -27.500000000000004 -37.5 -30 -25.000000000000004 #
+face $-1 -1 -1 $-1 $4695 $3049 $11 $-1 $3172 reversed single T -45 -40 -40 -37.5 -30 -25.000000000000004 F #
+point $-1 -1 -1 $-1 -40 -40 -25.000000000000004 #
+point $-1 -1 -1 $-1 -40 -30 -25.000000000000004 #
+face $-1 -1 -1 $-1 $4696 $3388 $11 $-1 $1815 reversed single T 39.999999999999993 -25 15.000000000000004 50 -15 25.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $4697 $3053 T -7.5000000000000027 -20 35 0 -15 50 unknown #
+cone-surface $-1 -1 -1 $-1 -5 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+loop $-1 -1 -1 $-1 $-1 $4698 $2433 T -50 -25 29.999999999999996 -50 -15 40 unknown #
+coedge $-1 -1 -1 $-1 $4699 $4699 $4700 $4701 forward $3054 $-1 #
+coedge $-1 -1 -1 $-1 $4702 $3055 $4703 $4704 reversed $2434 $-1 #
+coedge $-1 -1 -1 $-1 $3055 $4702 $4705 $4706 forward $2434 $-1 #
+coedge $-1 -1 -1 $-1 $4707 $4708 $3055 $3828 reversed $4709 $-1 #
+edge $-1 -1 -1 $-1 $4710 1.5707963267948966 $4711 2.0943951023931957 $3055 $4712 forward @7 unknown T -10.000000000000002 -25 35 -7.5000000000000009 -24.330127018922191 37.500000000000007 #
+edge $-1 -1 -1 $-1 $4713 0 $4713 6.2831853071795862 $3118 $4714 forward @7 unknown T 50 -25 30 50 -15 40 #
+edge $-1 -1 -1 $-1 $2701 1.5707963267948966 $3393 4.7123889803846897 $3668 $4715 forward @7 unknown T 40 -25 35 45 -15 40 #
+loop $-1 -1 -1 $-1 $4716 $3058 $3147 T -50 -40 -45 -50 -30 -35 hole $3148 T #
+vertex $-1 -1 -1 $-1 $3059 $4717 #
+ellipse-curve $-1 -1 -1 $-1 -50 -35 -40 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $3814 $3060 $4718 $4719 reversed $3049 $-1 #
+coedge $-1 -1 -1 $-1 $3060 $3811 $4720 $4721 reversed $3049 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4722 $3062 $4723 $4724 reversed $3064 $-1 #
+coedge $-1 -1 -1 $-1 $4720 $4725 $3062 $3839 forward $4726 $-1 #
+edge $-1 -1 -1 $-1 $4727 -2.0943951023931948 $3065 -1.5707963267948966 $3838 $4728 forward @7 unknown T -40 -40 -42.500000000000014 -37.5 -39.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $3063 $4722 $4729 $4730 reversed $3064 $-1 #
+coedge $-1 -1 -1 $-1 $4731 $4718 $3063 $3842 forward $4732 $-1 #
+edge $-1 -1 -1 $-1 $3066 1.5707963267948966 $4733 2.0943951023931953 $3841 $4734 forward @7 unknown T -40 -30.669872981077809 -42.5 -37.5 -30 -40 #
+face $-1 -1 -1 $-1 $3817 $3064 $11 $-1 $3172 reversed single T -45 -40 -50 -37.5 -30 -40 F #
+point $-1 -1 -1 $-1 -40 -40 -40 #
+point $-1 -1 -1 $-1 -40 -30 -40 #
+coedge $-1 -1 -1 $-1 $3899 $3068 $4735 $4736 forward $3793 $-1 #
+coedge $-1 -1 -1 $-1 $3068 $4737 $3075 $3856 forward $3793 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3850 $3070 $4572 $4738 reversed $3072 $-1 #
+coedge $-1 -1 -1 $-1 $3071 $3849 $3794 $3893 forward $3072 $-1 #
+coedge $-1 -1 -1 $-1 $4739 $4735 $3071 $3852 reversed $4740 $-1 #
+edge $-1 -1 -1 $-1 $3115 0 $3073 1.5707963267948966 $3071 $4741 forward @7 unknown T -20 -35 -45 -15 -30 -40 #
+face $-1 -1 -1 $-1 $4742 $3072 $11 $-1 $1595 reversed single T -22.500000000000004 -35 -50 -15 -30 -40 F #
+point $-1 -1 -1 $-1 -20 -30 -40 #
+coedge $-1 -1 -1 $-1 $4743 $3075 $4744 $4745 reversed $3077 $-1 #
+edge $-1 -1 -1 $-1 $4746 27.500000000000004 $3078 37.5 $3847 $4747 forward @7 unknown T -22.500000000000004 -30.669872981077809 -37.5 -22.5 -30.669872981077805 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $3076 $4743 $4673 $3798 reversed $3077 $-1 #
+coedge $-1 -1 -1 $-1 $4748 $3081 $3076 $3859 forward $3865 $-1 #
+edge $-1 -1 -1 $-1 $2449 -1.5707963267948966 $4671 6.1232339957367648e-17 $3858 $4749 forward @7 unknown T -30.000000000000004 -35 -40 -25.000000000000004 -30 -35 #
+face $-1 -1 -1 $-1 $4750 $3077 $11 $-1 $3872 reversed single T -30.000000000000007 -35 -40 -22.5 -30 -25 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 -37.5 #
+coedge $-1 -1 -1 $-1 $4751 $4752 $4753 $3863 forward $4754 $-1 #
+edge $-1 -1 -1 $-1 $4755 -50 $3866 -45 $3862 $4756 forward @7 unknown T -30 -35 -50 -30 -35 -45 #
+coedge $-1 -1 -1 $-1 $3081 $4748 $4751 $4757 reversed $3865 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3858 $4758 T -35 -35 -45 -25.000000000000004 -30 -35 unknown #
+vertex $-1 -1 -1 $-1 $4757 $4759 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4760 $4572 $3083 $3869 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $3870 -0.52359877559829959 $4755 1.5707963267948966 $3868 $4761 forward @7 unknown T -30.000000000000004 -35 -50 -22.5 -30 -50 #
+vertex $-1 -1 -1 $-1 $3869 $4762 #
+straight-curve $-1 -1 -1 $-1 -22.5 -30.669872981077809 0 -0 -0 -1 I I #
+cone-surface $-1 -1 -1 $-1 -25.000000000000004 -35 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $3876 $3088 $4582 $4579 reversed $3090 $-1 #
+coedge $-1 -1 -1 $-1 $3094 $4763 $3088 $3875 reversed $3884 $-1 #
+edge $-1 -1 -1 $-1 $2457 -1.5707963267948966 $4764 0 $3088 $4765 forward @7 unknown T -5 -40 -45 0 -35 -40 #
+coedge $-1 -1 -1 $-1 $3089 $3873 $3747 $4581 reversed $3090 $-1 #
+face $-1 -1 -1 $-1 $4766 $3090 $11 $-1 $1445 reversed single T -7.5000000000000027 -40 -50 0 -35 -40 F #
+coedge $-1 -1 -1 $-1 $3093 $3092 $4679 $4767 forward $2456 $-1 #
+coedge $-1 -1 -1 $-1 $3111 $3973 $3092 $3880 reversed $3907 $-1 #
+edge $-1 -1 -1 $-1 $3113 1.0471975511965974 $4016 1.5707963267948966 $3092 $4768 forward @7 unknown T -7.5000000000000027 -40 -27.500000000000004 -5 -39.330127018922191 -25 #
+coedge $-1 -1 -1 $-1 $4769 $4770 $4023 $3882 forward $4771 $-1 #
+edge $-1 -1 -1 $-1 $3885 -35 $4019 -30 $4772 $4773 forward @7 unknown T -8.8817841970012523e-16 -35 -35 0 -35 -30 #
+coedge $-1 -1 -1 $-1 $4763 $3094 $4770 $4774 forward $3884 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4763 $3920 T -5 -40 -45 4.9999999999999982 -35 -35 unknown #
+vertex $-1 -1 -1 $-1 $3095 $4775 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $3853 $4776 $11 $-1 $1595 reversed single T -22.500000000000004 -40 -25 -15 -35 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $3747 $4777 $3098 $3889 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $4778 1.5707963267948966 $3890 3.6651914291880923 $3888 $4779 forward @7 unknown T -15.000000000000002 -40 -50 -7.5000000000000009 -35 -50 #
+vertex $-1 -1 -1 $-1 $4581 $4780 #
+coedge $-1 -1 -1 $-1 $4573 $4781 $3850 $3893 reversed $3576 $-1 #
+edge $-1 -1 -1 $-1 $4778 -50 $3115 -45 $3850 $4782 forward @7 unknown T -15 -35 -50 -15 -35 -45 #
+coedge $-1 -1 -1 $-1 $3107 $3101 $4661 $4783 reversed $3108 $-1 #
+coedge $-1 -1 -1 $-1 $4784 $3975 $3104 $3896 forward $4785 $-1 #
+edge $-1 -1 -1 $-1 $3908 -1.5707963267948961 $3901 -6.1232339957367648e-17 $3895 $4786 forward @7 unknown T -15.000000000000002 -40 -30 -10.000000000000002 -35 -25 #
+coedge $-1 -1 -1 $-1 $4787 $3105 $4788 $4789 reversed $3900 $-1 #
+coedge $-1 -1 -1 $-1 $3105 $4790 $4791 $4792 reversed $3900 $-1 #
+coedge $-1 -1 -1 $-1 $4793 $3846 $4794 $3106 forward $3793 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3105 $3575 T -15.000000000000002 -35 -40 -7.4999999999999973 -30 -25 unknown #
+vertex $-1 -1 -1 $-1 $4795 $4796 #
+straight-curve $-1 -1 -1 $-1 -15 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4797 $4794 $3107 $3904 forward $4798 $-1 #
+edge $-1 -1 -1 $-1 $3109 3.1415926535897931 $4799 4.7123889803846897 $3903 $4800 forward @7 unknown T -20 -40 -40 -15 -35 -35 #
+face $-1 -1 -1 $-1 $4801 $3108 $11 $-1 $756 reversed single T -20 -40 -45 -10.000000000000002 -35 -35 F #
+point $-1 -1 -1 $-1 -15 -35 -35 #
+loop $-1 -1 -1 $-1 $-1 $3111 $4802 T -10.000000000000004 -40 -27.500000000000004 -5 -39.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $3896 $4803 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -27.500000000000004 #
+point $-1 -1 -1 $-1 -15 -35 -45 #
+loop $-1 -1 -1 $-1 $4804 $4805 $1558 T 50 -25 2.6645352591003757e-15 50 -15 10.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $3913 $3913 $4806 $4807 forward $3117 $-1 #
+vertex $-1 -1 -1 $-1 $3119 $4808 #
+coedge $-1 -1 -1 $-1 $3718 $3122 $4273 $4809 forward $3719 $-1 #
+vertex $-1 -1 -1 $-1 $3123 $4810 #
+ellipse-curve $-1 -1 -1 $-1 10 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3730 $4811 $3124 $3919 reversed $4567 $-1 #
+edge $-1 -1 -1 $-1 $2996 1.5707963267948966 $4812 2.0943951023931939 $3124 $3917 forward @7 unknown T 7.5 -40 -40 10 -39.330127018922198 -37.500000000000007 #
+face $-1 -1 -1 $-1 $4813 $3884 $11 $-1 $756 reversed single T -5 -40 -45 4.9999999999999982 -35 -35 F #
+coedge $-1 -1 -1 $-1 $3991 $3988 $3127 $3922 reversed $3190 $-1 #
+edge $-1 -1 -1 $-1 $3926 -2.5000000000000004 $3933 7.4999999999999956 $3127 $4814 forward @7 unknown T -7.5000000000000027 -30.669872981077813 -7.4999999999999956 -7.5000000000000009 -30.669872981077802 2.5000000000000004 #
+coedge $-1 -1 -1 $-1 $4815 $3128 $3441 $4243 reversed $3925 $-1 #
+coedge $-1 -1 -1 $-1 $3128 $4815 $3991 $4816 forward $3925 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4815 $4817 T -10.000000000000002 -30.669872981077813 2.4999999999999964 -5 -30 7.5 unknown #
+vertex $-1 -1 -1 $-1 $3922 $4818 #
+coedge $-1 -1 -1 $-1 $3131 $3130 $3488 $4280 forward $3132 $-1 #
+face $-1 -1 -1 $-1 $4819 $3132 $11 $-1 $227 reversed single T -5 -35 -9.3734986416366059e-33 4.9999999999999982 -30 10 F #
+point $-1 -1 -1 $-1 -5 -30 5 #
+coedge $-1 -1 -1 $-1 $4820 $3135 $3988 $4821 forward $3932 $-1 #
+coedge $-1 -1 -1 $-1 $3135 $4820 $3205 $3934 reversed $3932 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3930 $4766 T -10.000000000000002 -30.669872981077813 -12.500000000000005 -5 -30 -7.4999999999999956 unknown #
+vertex $-1 -1 -1 $-1 $3136 $4822 #
+edge $-1 -1 -1 $-1 $3137 -1.5707963267948966 $4823 -1.0471975511965965 $3205 $2519 forward @7 unknown T -7.5000000000000053 -30.669872981077813 -12.500000000000005 -5 -30 -10 #
+point $-1 -1 -1 $-1 -5 -30 -10 #
+coedge $-1 -1 -1 $-1 $3139 $4259 $3141 $3938 forward $3937 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4259 $4819 T -5 -40 -9.3734986416366059e-33 4.9999999999999982 -35 10 unknown #
+edge $-1 -1 -1 $-1 $3738 -1.5707963267948966 $2498 -6.1232339957367648e-17 $3936 $4824 forward @7 unknown T -1.7763568394002505e-15 -40 -9.3734986416366059e-33 4.9999999999999982 -35 5 #
+edge $-1 -1 -1 $-1 $2497 6.1232339957367648e-17 $4085 1.5707963267948966 $3176 $4825 forward @7 unknown T -1.7763568394002505e-15 -40 -10 4.9999999999999982 -35 -5 #
+face $-1 -1 -1 $-1 $1558 $4826 $11 $-1 $4827 reversed single T -50 50 -50 50 50 50 F #
+coedge $-1 -1 -1 $-1 $4828 $4829 $3150 $3942 forward $4830 $-1 #
+edge $-1 -1 -1 $-1 $4257 -2.4999999999999982 $3944 7.5 $3941 $4831 forward @7 unknown T -37.500000000000007 -30.669872981077813 -7.5 -37.5 -30.669872981077805 2.4999999999999982 #
+coedge $-1 -1 -1 $-1 $3151 $3166 $4828 $4832 reversed $3167 $-1 #
+vertex $-1 -1 -1 $-1 $4832 $4833 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -10.000000000000002 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4834 $4835 $3153 $3947 forward $4836 $-1 #
+edge $-1 -1 -1 $-1 $3949 -7.5000000000000036 $4253 2.4999999999999982 $3946 $4837 forward @7 unknown T -37.500000000000014 -39.330127018922205 -7.5000000000000036 -37.5 -39.330127018922191 2.4999999999999982 #
+coedge $-1 -1 -1 $-1 $3159 $3154 $4835 $4838 reversed $3160 $-1 #
+vertex $-1 -1 -1 $-1 $3155 $4839 #
+coedge $-1 -1 -1 $-1 $4840 $3157 $3159 $3956 forward $3953 $-1 #
+coedge $-1 -1 -1 $-1 $3157 $4841 $3969 $4842 forward $3953 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4843 $4844 T -37.500000000000007 -40 -25.000000000000007 -29.999999999999993 -35 -10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $3171 $4845 #
+straight-curve $-1 -1 -1 $-1 -37.5 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3161 1.0471975511965974 $4846 1.5707963267948966 $3951 $4847 forward @7 unknown T -37.5 -40 -12.500000000000004 -35 -39.330127018922191 -10.000000000000002 #
+face $-1 -1 -1 $-1 $3967 $3160 $11 $-1 $336 reversed single T -40 -40 -12.500000000000004 -35 -39.330127018922191 -7.5000000000000009 F #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922191 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $3815 $4848 $3163 $3960 forward $4692 $-1 #
+edge $-1 -1 -1 $-1 $3964 -2.0943951023931948 $3051 -1.5707963267948966 $3959 $4849 forward @7 unknown T -40 -30.669872981077805 -25.000000000000004 -37.5 -30 -22.500000000000007 #
+coedge $-1 -1 -1 $-1 $4850 $3164 $4848 $4851 forward $3963 $-1 #
+coedge $-1 -1 -1 $-1 $3164 $4852 $3166 $3966 forward $3963 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4853 $4854 T -37.5 -35 -25.000000000000007 -29.999999999999993 -30 -10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $4851 $4855 #
+straight-curve $-1 -1 -1 $-1 -37.5 -30.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $4856 -1.5707963267948966 $3168 -1.0471975511965979 $3962 $4847 forward @7 unknown T -37.5 -30.669872981077809 -12.500000000000004 -35 -30 -10.000000000000002 #
+face $-1 -1 -1 $-1 $4857 $3167 $11 $-1 $336 reversed single T -40 -30.669872981077813 -12.500000000000004 -35 -30 -7.4999999999999964 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077802 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $4686 $3170 $3952 $4842 reversed $3970 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3170 $4858 T -40 -40 -27.500000000000007 -35 -39.330127018922184 -22.499999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -25.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3173 $3176 $3806 $4681 forward $3177 $-1 #
+coedge $-1 -1 -1 $-1 $3879 $3179 $3175 $3974 reversed $3907 $-1 #
+edge $-1 -1 -1 $-1 $4016 1.5707963267948966 $3181 2.0943951023931948 $3175 $4859 forward @7 unknown T -7.5000000000000027 -40 -25 -5 -39.330127018922191 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $3895 $4860 $3178 $3976 forward $4785 $-1 #
+edge $-1 -1 -1 $-1 $3983 6.1232339957367648e-17 $3908 1.570796326794897 $3975 $4861 forward @7 unknown T -15.000000000000002 -40 -25 -10 -35 -19.999999999999996 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -39.330127018922198 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $4862 $3183 $4863 $4864 reversed $3982 $-1 #
+coedge $-1 -1 -1 $-1 $3183 $4865 $4866 $4867 reversed $3982 $-1 #
+coedge $-1 -1 -1 $-1 $4006 $4868 $4869 $3184 forward $4870 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3979 $4871 T -15.000000000000004 -35 -25 -7.5000000000000009 -30 -10 unknown #
+vertex $-1 -1 -1 $-1 $4872 $4873 #
+coedge $-1 -1 -1 $-1 $4869 $4874 $3185 $3986 forward $4776 $-1 #
+edge $-1 -1 -1 $-1 $4003 -1.5707963267948961 $2542 0 $3985 $4007 forward @7 unknown T -20 -40 -15.000000000000002 -15.000000000000004 -35 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $3464 $3186 $4875 $4876 reversed $3465 $-1 #
+coedge $-1 -1 -1 $-1 $3921 $3187 $3930 $4821 reversed $3190 $-1 #
+coedge $-1 -1 -1 $-1 $4877 $4866 $3187 $3990 forward $4878 $-1 #
+edge $-1 -1 -1 $-1 $4879 -1.5707963267948966 $2536 6.1232339957367648e-17 $3989 $4880 forward @7 unknown T -15.000000000000002 -35 -10 -10.000000000000002 -30 -5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $3188 $3921 $3924 $4816 reversed $3190 $-1 #
+coedge $-1 -1 -1 $-1 $4881 $4882 $3188 $3993 forward $4883 $-1 #
+edge $-1 -1 -1 $-1 $3191 -6.1232339957367648e-17 $4884 1.5707963267948966 $3992 $4885 forward @7 unknown T -15.000000000000002 -35 -1.7763568394002505e-15 -10.000000000000002 -30 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $4886 $3189 $4882 $3999 forward $3997 $-1 #
+coedge $-1 -1 -1 $-1 $3189 $4887 $4877 $4888 forward $3997 $-1 #
+coedge $-1 -1 -1 $-1 $3193 $4875 $2040 $2533 reversed $4002 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3189 $4889 T -22.500000000000007 -35 -10.000000000000004 -14.999999999999996 -30 4.9999999999999991 unknown #
+face $-1 -1 -1 $-1 $4871 $3190 $11 $-1 $2541 reversed single T -15.000000000000002 -35 -10 -7.5000000000000009 -30 4.9999999999999991 F #
+edge $-1 -1 -1 $-1 $3191 0 $4890 1.5707963267948966 $3994 $4891 forward @7 unknown T -20 -35 -8.8817841970012523e-16 -15 -30 4.9999999999999991 #
+point $-1 -1 -1 $-1 -15 -35 -8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $4892 $3193 $4893 $4894 forward $4002 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3996 $4895 T -22.500000000000004 -40 -10.000000000000004 -14.999999999999996 -35 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $4896 $4897 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 -35 -10.000000000000002 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $4898 $4899 #
+coedge $-1 -1 -1 $-1 $4900 $3981 $4901 $3198 forward $4870 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20.000000000000004 -35 -10.000000000000002 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 5 #
+coedge $-1 -1 -1 $-1 $3206 $3205 $4902 $4903 forward $2554 $-1 #
+coedge $-1 -1 -1 $-1 $4904 $4905 $3206 $4012 reversed $4906 $-1 #
+edge $-1 -1 -1 $-1 $4907 4.1887902047863905 $4013 4.7123889803846897 $3206 $4859 forward @7 unknown T -7.5000000000000018 -30.669872981077809 -25 -5 -30 -22.499999999999996 #
+vertex $-1 -1 -1 $-1 $4908 $4909 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $4910 $4911 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 20 7.5000000000000009 -15 35 F #
+vertex $-1 -1 -1 $-1 $3880 $4913 #
+loop $-1 -1 -1 $-1 $-1 $4023 $3803 T -1.7763568394002505e-15 -35 -40 7.4999999999999991 -30 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $4022 $4914 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4915 $4772 $3217 $4022 forward $4916 $-1 #
+edge $-1 -1 -1 $-1 $4019 0 $4013 1.5707963267948966 $4021 $4917 forward @7 unknown T -5 -35 -30 0 -30 -25 #
+coedge $-1 -1 -1 $-1 $4918 $3218 $4772 $3882 reversed $4017 $-1 #
+face $-1 -1 -1 $-1 $4919 $4680 $11 $-1 $482 reversed single T -5 -40 -30 5 -35 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $3259 $4272 $3221 $4026 forward $4080 $-1 #
+edge $-1 -1 -1 $-1 $4920 1.5707963267948961 $4081 2.0943951023931944 $4025 $4921 forward @7 unknown T 4.9999999999999956 -40 -25 7.5 -39.330127018922198 -22.5 #
+face $-1 -1 -1 $-1 $4922 $4923 $11 $-1 $1477 reversed single T 14.999999999999996 -25 5.0000000000000009 22.500000000000004 -20 20 F #
+loop $-1 -1 -1 $-1 $-1 $4924 $3223 T 15 -25 -9.9999999999999982 22.500000000000004 -20 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $4925 $4926 $4927 $4928 reversed $3224 $-1 #
+coedge $-1 -1 -1 $-1 $4929 $3225 $4930 $4931 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $3225 $4932 $4933 $4934 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $4935 $4936 $3225 $4033 forward $4937 $-1 #
+edge $-1 -1 -1 $-1 $4938 -1.570796326794897 $4939 6.1232339957367648e-17 $4032 $4940 forward @7 unknown T 15 -20 -25 20.000000000000004 -15 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $4941 $3226 $3339 $4160 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $4942 $3341 $3226 $4036 forward $4159 $-1 #
+edge $-1 -1 -1 $-1 $4161 -2.0943951023931957 $4043 -1.5707963267948966 $4035 $4943 forward @7 unknown T 20 -15.669872981077809 -9.9999999999999982 22.500000000000004 -15 -7.4999999999999973 #
+coedge $-1 -1 -1 $-1 $3227 $4941 $3237 $4057 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $4944 $4945 $4946 $4039 forward $4947 $-1 #
+edge $-1 -1 -1 $-1 $4044 -5 $4948 8.8817841970012523e-16 $4038 $4949 forward @7 unknown T 15 -20 -5 15.000000000000004 -20 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $4950 $3228 $4945 $4951 reversed $4042 $-1 #
+coedge $-1 -1 -1 $-1 $3228 $4950 $4932 $4952 forward $4042 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3228 $4953 T 10 -20 -15 20 -15 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $4952 $4954 #
+vertex $-1 -1 -1 $-1 $4955 $4956 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3233 $3230 $3243 $4062 reversed $1735 $-1 #
+coedge $-1 -1 -1 $-1 $3340 $3231 $4941 $4957 forward $3366 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4958 $3234 $3253 $4075 forward $4052 $-1 #
+coedge $-1 -1 -1 $-1 $3234 $4959 $3236 $4056 forward $4052 $-1 #
+coedge $-1 -1 -1 $-1 $4960 $4961 $4962 $3235 reversed $4963 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3234 $4964 T 7.4999999999999964 -20 5.0000000000000009 15 -15 20 unknown #
+vertex $-1 -1 -1 $-1 $4075 $4965 #
+straight-curve $-1 -1 -1 $-1 15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3237 $3236 $4944 $4966 reversed $3238 $-1 #
+edge $-1 -1 -1 $-1 $4967 1.5707963267948966 $3240 3.1415926535897931 $4050 $4968 forward @7 unknown T 9.9999999999999982 -20 5.0000000000000009 14.999999999999996 -15 10 #
+edge $-1 -1 -1 $-1 $4948 -6.1232339957367648e-17 $3239 1.5707963267948966 $3237 $4969 forward @7 unknown T 15 -20 -9.3734986416366073e-33 20 -15 5.0000000000000009 #
+face $-1 -1 -1 $-1 $4970 $3238 $11 $-1 $2156 reversed single T 9.9999999999999982 -20 -9.3734986416366073e-33 20 -15 10 F #
+point $-1 -1 -1 $-1 20 -15 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $3240 3.1415926535897931 $4971 4.7123889803846897 $4960 $4968 forward @7 unknown T 10 -25 5.0000000000000009 14.999999999999996 -20 10 #
+point $-1 -1 -1 $-1 14.999999999999996 -20 10 #
+edge $-1 -1 -1 $-1 $2589 1.5707963267948966 $2739 2.0943951023931957 $3243 $4972 forward @7 unknown T 20 -15.669872981077809 17.5 22.500000000000004 -15 20 #
+coedge $-1 -1 -1 $-1 $3245 $4236 $3247 $4067 reversed $2738 $-1 #
+vertex $-1 -1 -1 $-1 $3246 $4973 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4974 $3247 $4975 $4976 forward $3250 $-1 #
+edge $-1 -1 -1 $-1 $3251 0 $4977 1.5707963267948966 $3247 $4978 forward @7 unknown T 10 -20 30 15 -15 35 #
+coedge $-1 -1 -1 $-1 $3248 $4974 $4979 $4980 forward $3250 $-1 #
+coedge $-1 -1 -1 $-1 $4981 $3249 $4982 $3257 forward $4072 $-1 #
+coedge $-1 -1 -1 $-1 $3249 $4983 $4984 $4985 forward $4072 $-1 #
+coedge $-1 -1 -1 $-1 $4986 $4987 $2082 $2585 forward $4219 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3249 $4215 T 7.4999999999999991 -25 20 15 -20 35 unknown #
+face $-1 -1 -1 $-1 $4988 $3250 $11 $-1 $4529 reversed single T 7.4999999999999982 -20 20 15 -15 35 F #
+point $-1 -1 -1 $-1 15 -20 30 #
+edge $-1 -1 -1 $-1 $4053 0 $4076 1.5707963267948966 $4049 $4989 forward @7 unknown T 10 -20 15 15 -15 20 #
+vertex $-1 -1 -1 $-1 $4990 $4991 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $4992 $4993 #
+loop $-1 -1 -1 $-1 $-1 $4272 $4919 T 4.9999999999999956 -40 -27.500000000000004 10 -39.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $3262 $4994 #
+coedge $-1 -1 -1 $-1 $3261 $3806 $3263 $4084 reversed $2570 $-1 #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $2600 -2.0943951023931948 $4085 -1.5707963267948966 $3263 $4995 forward @7 unknown T 4.9999999999999982 -40 -12.500000000000002 7.4999999999999982 -39.330127018922191 -10 #
+vertex $-1 -1 -1 $-1 $4681 $4996 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3360 $3357 $3270 $4088 forward $2135 $-1 #
+edge $-1 -1 -1 $-1 $4092 7.5000000000000036 $4997 17.500000000000011 $4087 $4998 forward @7 unknown T 37.499999999999993 -24.330127018922195 7.5000000000000036 37.500000000000014 -24.330127018922195 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $4999 $3271 $3357 $4176 reversed $3381 $-1 #
+coedge $-1 -1 -1 $-1 $3271 $4999 $3275 $4097 forward $3381 $-1 #
+vertex $-1 -1 -1 $-1 $4168 $5000 #
+vertex $-1 -1 -1 $-1 $3272 $5001 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4138 $3273 $3284 $4105 forward $4095 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3273 $5002 T 24.999999999999996 -25.000000000000004 -15 35 -20 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4100 -2.0943951023931944 $4091 -1.5707963267948966 $4090 $5003 forward @7 unknown T 35 -25.000000000000004 2.5000000000000071 37.499999999999993 -24.330127018922195 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $3331 $3276 $4999 $5004 forward $2643 $-1 #
+coedge $-1 -1 -1 $-1 $3276 $3330 $3278 $4103 forward $2643 $-1 #
+vertex $-1 -1 -1 $-1 $5004 $5005 #
+straight-curve $-1 -1 -1 $-1 37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3279 $3278 $3290 $4112 reversed $3280 $-1 #
+edge $-1 -1 -1 $-1 $5006 1.5707963267948966 $3282 2.0943951023931939 $4099 $3337 forward @7 unknown T 37.500000000000007 -25 -9.9999999999999982 40 -24.330127018922195 -7.5000000000000053 #
+face $-1 -1 -1 $-1 $5002 $3280 $11 $-1 $2664 reversed single T 35 -25.000000000000004 -12.499999999999996 40 -24.330127018922195 -7.5000000000000018 F #
+edge $-1 -1 -1 $-1 $3281 -1.5707963267948966 $2631 6.4931039580273265e-16 $4094 $5007 forward @7 unknown T 30 -25.000000000000004 -15 35 -20 -9.9999999999999982 #
+point $-1 -1 -1 $-1 35 -25.000000000000004 -9.9999999999999982 #
+point $-1 -1 -1 $-1 37.500000000000007 -24.330127018922198 -7.5000000000000053 #
+coedge $-1 -1 -1 $-1 $3286 $3285 $5008 $5009 reversed $3287 $-1 #
+coedge $-1 -1 -1 $-1 $3297 $5010 $3285 $3300 reversed $4121 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3304 $3290 $5011 $5012 forward $3292 $-1 #
+edge $-1 -1 -1 $-1 $3293 1.0471975511965983 $5006 1.5707963267948966 $3290 $4156 forward @7 unknown T 37.5 -25 -12.499999999999996 40 -24.330127018922195 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $3291 $3303 $5013 $5014 forward $3292 $-1 #
+face $-1 -1 -1 $-1 $5015 $3292 $11 $-1 $2703 reversed single T 37.499999999999993 -25 -24.999999999999996 45 -15 -9.9999999999999982 F #
+point $-1 -1 -1 $-1 37.5 -24.330127018922198 -12.499999999999995 #
+coedge $-1 -1 -1 $-1 $5016 $4211 $3295 $4117 forward $3397 $-1 #
+edge $-1 -1 -1 $-1 $4122 1.0471975511965992 $4118 1.570796326794897 $4116 $5017 forward @7 unknown T 37.5 -25 -27.499999999999989 40 -24.330127018922195 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $4117 $5018 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5019 $3297 $4211 $5020 reversed $4121 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5019 $4530 T 29.999999999999996 -25.000000000000004 -40 37.5 -20 -24.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $4117 $5021 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.499999999999993 -15.669872981077809 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $5022 $5016 $3307 $4127 forward $3397 $-1 #
+edge $-1 -1 -1 $-1 $4131 -1.570796326794897 $4129 -1.0471975511965983 $4126 $5017 forward @7 unknown T 37.499999999999986 -15.669872981077805 -27.499999999999993 40 -15 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $3308 $5023 $5022 $5024 reversed $3324 $-1 #
+vertex $-1 -1 -1 $-1 $3309 $5025 #
+vertex $-1 -1 -1 $-1 $4127 $5026 #
+coedge $-1 -1 -1 $-1 $3314 $3313 $4929 $5027 forward $2630 $-1 #
+coedge $-1 -1 -1 $-1 $3341 $4942 $3313 $3352 reversed $4159 $-1 #
+coedge $-1 -1 -1 $-1 $4930 $5028 $3314 $4135 reversed $5029 $-1 #
+edge $-1 -1 -1 $-1 $5030 4.1887902047863914 $3321 4.7123889803846897 $3314 $5031 forward @7 unknown T 22.499999999999996 -15.669872981077805 -25 25 -15 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $5032 $3315 $5033 $5034 forward $3317 $-1 #
+coedge $-1 -1 -1 $-1 $3316 $5032 $5035 $3355 forward $3317 $-1 #
+coedge $-1 -1 -1 $-1 $3344 $4094 $3316 $4139 reversed $4095 $-1 #
+edge $-1 -1 -1 $-1 $2665 -1.5707963267948966 $2631 0 $3316 $3351 forward @7 unknown T 25 -25 -14.999999999999998 30 -20 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $4114 $3317 $11 $-1 $2194 reversed single T 22.499999999999993 -25 -25.000000000000004 30 -20 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $5036 $3319 $5028 $4145 forward $4143 $-1 #
+coedge $-1 -1 -1 $-1 $3319 $5037 $5038 $4148 forward $4143 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4142 $5039 T 22.5 -20 -40 30 -15 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $3321 -1.5707963267948966 $5040 -1.0471975511965974 $4141 $5041 forward @7 unknown T 22.5 -15.669872981077809 -27.500000000000004 25 -15 -25 #
+point $-1 -1 -1 $-1 25 -15 -25 #
+coedge $-1 -1 -1 $-1 $5023 $3323 $5042 $5043 reversed $3324 $-1 #
+edge $-1 -1 -1 $-1 $5044 -35 $3325 -30 $4142 $5045 forward @7 unknown T 29.999999999999996 -20 -35 30 -20 -30 #
+point $-1 -1 -1 $-1 29.999999999999996 -20 -30 #
+edge $-1 -1 -1 $-1 $5046 1.0471975511965974 $3329 1.5707963267948966 $5047 $5041 forward @7 unknown T 22.5 -25 -27.500000000000004 25 -24.330127018922191 -25 #
+point $-1 -1 -1 $-1 25 -25 -25 #
+coedge $-1 -1 -1 $-1 $5011 $5011 $3330 $4153 reversed $5048 $-1 #
+edge $-1 -1 -1 $-1 $3336 1.5707963267948966 $5006 4.7123889803846897 $3330 $5049 forward @7 unknown T 40 -25 -9.9999999999999982 45 -15 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $3358 $3358 $3331 $4155 reversed $4177 $-1 #
+edge $-1 -1 -1 $-1 $4178 -1.570796326794897 $2672 1.570796326794897 $3331 $5050 forward @7 unknown T 40 -25 2.6645352591003757e-15 45.000000000000007 -15 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -9.9999999999999982 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 -15 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $5051 $5052 $11 $-1 $2664 reversed single T 4.9999999999999991 -15.669872981077809 -12.500000000000004 10 -15 -7.4999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $4942 $3338 T 20 -15.669872981077809 -12.499999999999996 25 -15 -7.4999999999999973 unknown #
+edge $-1 -1 -1 $-1 $3379 -2.5000000000000036 $4161 7.4999999999999991 $3339 $5053 forward @7 unknown T 22.5 -15.669872981077807 -7.4999999999999991 22.500000000000004 -15.669872981077805 2.5000000000000036 #
+vertex $-1 -1 -1 $-1 $3342 $5054 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -9.9999999999999982 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3345 $3343 $5055 $5056 forward $2656 $-1 #
+coedge $-1 -1 -1 $-1 $5035 $5057 $3343 $4165 reversed $4170 $-1 #
+edge $-1 -1 -1 $-1 $2665 1.5707963267948966 $5058 2.0943951023931948 $3343 $4162 forward @7 unknown T 22.500000000000004 -25 -9.9999999999999982 25 -24.330127018922191 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $5059 $3370 $3345 $2691 reversed $4189 $-1 #
+coedge $-1 -1 -1 $-1 $3346 $3372 $3348 $4168 forward $2690 $-1 #
+edge $-1 -1 -1 $-1 $4091 -1.5707963267948966 $2124 6.4931039580273226e-16 $4167 $5060 forward @7 unknown T 29.999999999999996 -25.000000000000004 1.7763568394002505e-15 35 -20 5.0000000000000018 #
+face $-1 -1 -1 $-1 $4953 $5061 $11 $-1 $2664 reversed single T 10 -25 -15 20 -20 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $5062 $3350 T 20 -25 -12.499999999999998 25 -24.330127018922191 -7.4999999999999973 unknown #
+vertex $-1 -1 -1 $-1 $5063 $5064 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 -9.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5065 $5066 $11 $-1 $3659 reversed single T 29.999999999999996 -5.0000000000000009 5.0000000000000018 37.500000000000007 -8.8817841970012523e-16 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $5067 $3354 T 29.999999999999996 -5.0000000000000009 20.000000000000004 37.5 -1.7763568394002505e-15 35 unknown #
+vertex $-1 -1 -1 $-1 $3355 $5068 #
+edge $-1 -1 -1 $-1 $4178 1.570796326794897 $4092 2.0943951023931948 $3357 $2673 forward @7 unknown T 37.500000000000007 -25 5.0000000000000027 40.000000000000007 -24.330127018922195 7.5000000000000036 #
+loop $-1 -1 -1 $-1 $5069 $4154 $5070 T 39.999999999999993 -25 2.6645352591003757e-15 45.000000000000007 -15 10.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $5004 $5071 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $4192 $3386 $3360 $4181 reversed $2741 $-1 #
+edge $-1 -1 -1 $-1 $4997 1.0471975511965983 $3389 1.570796326794897 $3360 $2704 forward @7 unknown T 37.499999999999993 -25 17.500000000000007 40 -24.330127018922195 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 22.5 -15.669872981077805 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $5072 $3366 $11 $-1 $2156 reversed single T 20 -15.669872981077809 2.5000000000000036 25 -15 7.5000000000000027 F #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077807 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $5073 $5074 $3369 $4187 reversed $4923 $-1 #
+edge $-1 -1 -1 $-1 $4190 7.5 $2742 17.5 $3369 $5075 forward @7 unknown T 22.499999999999996 -24.330127018922195 7.5 22.500000000000004 -24.330127018922191 17.5 #
+coedge $-1 -1 -1 $-1 $3370 $5059 $5073 $5076 forward $4189 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4188 $5077 T 20 -25 2.5000000000000044 25 -24.330127018922191 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $5076 $5078 #
+coedge $-1 -1 -1 $-1 $3412 $3373 $5074 $5079 forward $3413 $-1 #
+coedge $-1 -1 -1 $-1 $3427 $4180 $3375 $4193 forward $2741 $-1 #
+edge $-1 -1 -1 $-1 $4997 -2.0943951023931944 $3429 -1.5707963267948966 $4192 $5080 forward @7 unknown T 35 -25.000000000000004 17.500000000000007 37.499999999999993 -24.330127018922195 20.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $3408 $3413 $11 $-1 $1815 reversed single T 20 -25 17.5 25 -24.330127018922191 22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $5081 $3378 T 10 -25 15 20 -20 25 unknown #
+point $-1 -1 -1 $-1 22.5 -15.669872981077805 2.5000000000000036 #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922198 2.5000000000000049 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4202 22.500000000000007 $4206 32.500000000000007 $3385 $5082 forward @7 unknown T 37.5 -24.330127018922198 22.500000000000007 37.500000000000007 -24.330127018922187 32.500000000000007 #
+vertex $-1 -1 -1 $-1 $3428 $5083 #
+loop $-1 -1 -1 $-1 $-1 $4806 $3820 T 50 -25 15.000000000000004 50 -15 25.000000000000004 unknown #
+point $-1 -1 -1 $-1 40 -25 20.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $4229 $3401 T 35 -25.000000000000004 32.5 40 -24.330127018922195 37.5 unknown #
+vertex $-1 -1 -1 $-1 $3392 $5084 #
+point $-1 -1 -1 $-1 40 -25 35 #
+face $-1 -1 -1 $-1 $5085 $5086 $11 $-1 $4210 reversed single T 25 -20 -45 35 -15 -35 F #
+loop $-1 -1 -1 $-1 $-1 $4647 $3396 T 25 -25.000000000000004 -45 35 -20 -35 unknown #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 -20 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $4116 $5087 $4120 $5020 forward $3397 $-1 #
+edge $-1 -1 -1 $-1 $3688 -2.0943951023931948 $4064 -1.5707963267948966 $3403 $5088 forward @7 unknown T 20 -15.669872981077805 35 22.500000000000004 -15 37.5 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $4645 $4072 $11 $-1 $4529 reversed single T 7.4999999999999991 -25 20 15 -20 35 F #
+face $-1 -1 -1 $-1 $5089 $4963 $11 $-1 $4529 reversed single T 7.5 -25 5.0000000000000009 15 -20 20 F #
+coedge $-1 -1 -1 $-1 $4987 $3410 $3412 $4221 reversed $4219 $-1 #
+coedge $-1 -1 -1 $-1 $3410 $4986 $3415 $4224 reversed $4219 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4217 $4922 T 15 -25 20 22.500000000000004 -20 35 unknown #
+straight-curve $-1 -1 -1 $-1 22.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $5090 1.5707963267948966 $3414 2.0943951023931939 $3412 $5091 forward @7 unknown T 20 -25 20 22.499999999999993 -24.330127018922191 22.499999999999993 #
+point $-1 -1 -1 $-1 22.499999999999993 -24.330127018922191 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $3416 $3415 $5092 $5093 forward $3417 $-1 #
+edge $-1 -1 -1 $-1 $3418 -2.0943951023931948 $5094 -1.5707963267948966 $3415 $5095 forward @7 unknown T 20 -25 32.5 22.500000000000004 -24.330127018922195 35 #
+coedge $-1 -1 -1 $-1 $3664 $3420 $3416 $4226 forward $3665 $-1 #
+edge $-1 -1 -1 $-1 $2731 1.5707963267948966 $4532 2.0943951023931957 $4225 $4213 forward @7 unknown T 22.5 -25 35 25 -24.330127018922191 37.500000000000007 #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 32.500000000000007 #
+edge $-1 -1 -1 $-1 $2709 -6.4931039580273226e-16 $3425 1.5707963267948966 $3419 $5096 forward @7 unknown T 30 -25.000000000000004 35 35 -20 40 #
+coedge $-1 -1 -1 $-1 $3669 $3423 $3666 $4507 forward $4205 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+point $-1 -1 -1 $-1 35 -25.000000000000004 35 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 35 -25.000000000000004 20.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $4650 $3431 T 22.499999999999996 -20 -50 30 -15 -40 unknown #
+coedge $-1 -1 -1 $-1 $5097 $5098 $5099 $5100 forward $3434 $-1 #
+coedge $-1 -1 -1 $-1 $4063 $3435 $4519 $5101 reversed $2738 $-1 #
+edge $-1 -1 -1 $-1 $4064 -1.5707963267948966 $4523 6.1232339957367648e-17 $3435 $5102 forward @7 unknown T 15 -20 35 20 -15 40 #
+coedge $-1 -1 -1 $-1 $3441 $3438 $5103 $5104 forward $1818 $-1 #
+coedge $-1 -1 -1 $-1 $3502 $5105 $3438 $4240 reversed $4288 $-1 #
+edge $-1 -1 -1 $-1 $3504 -1.5707963267948966 $5106 -1.047197551196597 $3438 $2831 forward @7 unknown T -7.5000000000000036 -30.669872981077813 17.499999999999996 -5 -30 20 #
+coedge $-1 -1 -1 $-1 $3474 $3439 $3487 $3494 forward $2774 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5107 4.1887902047863914 $3133 4.7123889803846897 $3441 $2761 forward @7 unknown T -7.5 -30.669872981077805 5 -5 -30 7.5 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 5 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3488 $3487 $2202 $2746 reversed $2792 $-1 #
+point $-1 -1 -1 $-1 0 -35 10 #
+point $-1 -1 -1 $-1 0 -35 15 #
+point $-1 -1 -1 $-1 -50 -35 -3.0616169978683823e-15 #
+coedge $-1 -1 -1 $-1 $3454 $5108 $3450 $4250 forward $4256 $-1 #
+edge $-1 -1 -1 $-1 $4308 -2.0943951023931953 $2754 -1.5707963267948966 $4249 $5109 forward @7 unknown T -40 -30.669872981077813 4.9999999999999973 -37.5 -30 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $3452 $4313 $4834 $5110 reversed $4252 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3527 $5111 T -40 -40 2.4999999999999973 -35 -39.330127018922191 7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $5110 $5112 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 4.9999999999999973 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $5108 $3454 $4829 $5113 reversed $4256 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4249 $5114 T -40 -30.669872981077813 2.4999999999999982 -35 -30 7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $3942 $5115 #
+coedge $-1 -1 -1 $-1 $3936 $3459 $3735 $4569 forward $3937 $-1 #
+coedge $-1 -1 -1 $-1 $5116 $3462 $4881 $5117 reversed $4263 $-1 #
+coedge $-1 -1 -1 $-1 $3462 $5118 $5119 $5120 reversed $4263 $-1 #
+coedge $-1 -1 -1 $-1 $4332 $5121 $5122 $3463 forward $5123 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4260 $5124 T -15.000000000000002 -35 4.9999999999999991 -7.5 -30 20 unknown #
+coedge $-1 -1 -1 $-1 $5125 $5122 $3464 $4266 forward $5126 $-1 #
+edge $-1 -1 -1 $-1 $3466 3.1415926535897931 $5127 4.7123889803846897 $4265 $5128 forward @7 unknown T -20 -40 4.9999999999999991 -15 -35 10 #
+face $-1 -1 -1 $-1 $4895 $3465 $11 $-1 $227 reversed single T -20 -40 -1.7763568394002505e-15 -10.000000000000002 -35 10 F #
+point $-1 -1 -1 $-1 -15 -35 10 #
+coedge $-1 -1 -1 $-1 $5129 $5130 $3476 $4271 reversed $4771 $-1 #
+edge $-1 -1 -1 $-1 $4812 -37.500000000000007 $3914 -27.500000000000004 $3476 $5131 forward @7 unknown T 7.4999999999999982 -39.330127018922198 -37.500000000000007 7.5 -39.330127018922191 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $4025 $3477 $5130 $5132 forward $4080 $-1 #
+coedge $-1 -1 -1 $-1 $3478 $4918 $3915 $4809 reversed $4017 $-1 #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $2811 6.1232339957367648e-17 $3485 1.5707963267948966 $3531 $5133 forward @7 unknown T -1.7763568394002505e-15 -40 20 4.9999999999999982 -35 25 #
+coedge $-1 -1 -1 $-1 $3506 $3496 $3483 $3800 forward $2801 $-1 #
+edge $-1 -1 -1 $-1 $3485 -1.5707963267948966 $3445 -6.1232339957367648e-17 $4315 $5134 forward @7 unknown T -1.7763568394002505e-15 -40 15 4.9999999999999982 -35 20 #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 20 #
+edge $-1 -1 -1 $-1 $3202 -1.5707963267948966 $3444 6.1232339957367648e-17 $3927 $5135 forward @7 unknown T -1.7763568394002505e-15 -35 5 4.9999999999999982 -30 10 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3701 $4318 $3497 $4284 reversed $3536 $-1 #
+edge $-1 -1 -1 $-1 $4285 -32.500000000000007 $4289 -22.500000000000004 $3497 $5136 forward @7 unknown T -7.5000000000000027 -30.669872981077813 22.500000000000004 -7.5000000000000009 -30.669872981077805 32.500000000000007 #
+vertex $-1 -1 -1 $-1 $4284 $5137 #
+point $-1 -1 -1 $-1 -5 -30 35 #
+coedge $-1 -1 -1 $-1 $5105 $3502 $4318 $5138 forward $4288 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4287 $3696 T -10.000000000000002 -30.669872981077813 17.499999999999996 -5 -30 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $3503 $5139 #
+point $-1 -1 -1 $-1 -5 -30 20 #
+coedge $-1 -1 -1 $-1 $3511 $3523 $4353 $5140 reversed $3524 $-1 #
+vertex $-1 -1 -1 $-1 $5140 $5141 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3517 $3513 $4347 $5142 reversed $3518 $-1 #
+vertex $-1 -1 -1 $-1 $3514 $5143 #
+coedge $-1 -1 -1 $-1 $5144 $3515 $3517 $4302 forward $4299 $-1 #
+coedge $-1 -1 -1 $-1 $3515 $5145 $4313 $5146 forward $4299 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5147 $5148 T -37.500000000000007 -40 4.9999999999999982 -30 -35 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $3528 $5149 #
+edge $-1 -1 -1 $-1 $3519 1.047197551196597 $5150 1.5707963267948957 $4297 $5151 forward @7 unknown T -37.5 -40 17.499999999999989 -35 -39.330127018922191 19.999999999999996 #
+face $-1 -1 -1 $-1 $4311 $3518 $11 $-1 $162 reversed single T -40 -40 17.499999999999989 -35 -39.330127018922184 22.5 F #
+point $-1 -1 -1 $-1 -37.499999999999993 -39.330127018922191 17.499999999999989 #
+coedge $-1 -1 -1 $-1 $5152 $3521 $5108 $5153 forward $4307 $-1 #
+coedge $-1 -1 -1 $-1 $3521 $5154 $3523 $4310 forward $4307 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5155 $5156 T -37.500000000000007 -35 4.9999999999999982 -30 -30 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $5153 $5157 #
+edge $-1 -1 -1 $-1 $5158 -1.5707963267948957 $3525 -1.047197551196597 $4306 $5151 forward @7 unknown T -37.5 -30.669872981077809 17.499999999999993 -35 -30 19.999999999999996 #
+face $-1 -1 -1 $-1 $5159 $3524 $11 $-1 $162 reversed single T -40 -30.669872981077809 17.499999999999993 -35 -30 22.499999999999993 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077809 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $4251 $3527 $4298 $5146 reversed $4252 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 4.9999999999999973 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3529 $3531 $3736 $4278 forward $3473 $-1 #
+coedge $-1 -1 -1 $-1 $5122 $5160 $3532 $4317 forward $5126 $-1 #
+edge $-1 -1 -1 $-1 $4328 -1.5707963267948966 $2844 0 $4316 $4333 forward @7 unknown T -20 -40 15 -15 -35 20 #
+coedge $-1 -1 -1 $-1 $4283 $3533 $4287 $5138 reversed $3536 $-1 #
+coedge $-1 -1 -1 $-1 $5161 $5119 $3533 $4320 forward $5162 $-1 #
+edge $-1 -1 -1 $-1 $5163 -1.5707963267948966 $2841 6.1232339957367648e-17 $4319 $5164 forward @7 unknown T -15.000000000000002 -35 20 -10.000000000000002 -30 25 #
+edge $-1 -1 -1 $-1 $2886 -6.1232339957367648e-17 $3704 1.5707963267948966 $3699 $5165 forward @7 unknown T -15.000000000000002 -35 30 -10.000000000000002 -30 35 #
+coedge $-1 -1 -1 $-1 $5166 $3535 $4535 $3577 forward $4325 $-1 #
+coedge $-1 -1 -1 $-1 $3535 $5167 $5161 $5168 forward $4325 $-1 #
+coedge $-1 -1 -1 $-1 $3538 $4360 $2272 $2838 reversed $3697 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3535 $5169 T -22.500000000000004 -35 20 -15 -30 35 unknown #
+face $-1 -1 -1 $-1 $5124 $3536 $11 $-1 $2541 reversed single T -15.000000000000002 -35 20 -7.5000000000000009 -30 35 F #
+coedge $-1 -1 -1 $-1 $5170 $3538 $5171 $5172 forward $3697 $-1 #
+vertex $-1 -1 -1 $-1 $5173 $5174 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $4817 $5126 $11 $-1 $1595 reversed single T -22.500000000000004 -40 4.9999999999999991 -15 -35 20 F #
+vertex $-1 -1 -1 $-1 $5175 $5176 #
+coedge $-1 -1 -1 $-1 $5177 $4262 $5178 $3542 forward $5123 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $3553 $3550 $5179 $5180 reversed $2859 $-1 #
+coedge $-1 -1 -1 $-1 $5181 $5182 $3550 $4337 forward $5183 $-1 #
+edge $-1 -1 -1 $-1 $5184 -50 $4339 -37.500000000000007 $4336 $5185 forward @7 unknown T -37.500000000000007 -30.669872981077805 37.500000000000007 -37.5 -30.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $3551 $3565 $5181 $5186 reversed $3566 $-1 #
+vertex $-1 -1 -1 $-1 $5186 $5187 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5188 $5189 $3553 $4342 forward $5190 $-1 #
+edge $-1 -1 -1 $-1 $4344 37.5 $5191 50 $4341 $5192 forward @7 unknown T -37.5 -39.330127018922198 37.5 -37.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $3559 $3554 $5189 $5193 reversed $3560 $-1 #
+vertex $-1 -1 -1 $-1 $3555 $5194 #
+coedge $-1 -1 -1 $-1 $5195 $3557 $3559 $4350 forward $4348 $-1 #
+coedge $-1 -1 -1 $-1 $3557 $5196 $4294 $5142 forward $4348 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5197 $5198 T -37.500000000000014 -40 19.999999999999993 -29.999999999999993 -35 35 unknown #
+edge $-1 -1 -1 $-1 $3561 1.0471975511965983 $5199 1.5707963267948966 $4346 $5200 forward @7 unknown T -37.500000000000014 -40 32.5 -35 -39.330127018922191 35 #
+face $-1 -1 -1 $-1 $4358 $3560 $11 $-1 $388 reversed single T -40 -40 32.5 -35 -39.330127018922191 37.5 F #
+point $-1 -1 -1 $-1 -37.500000000000014 -39.330127018922205 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $5201 $3563 $4291 $5140 forward $4355 $-1 #
+coedge $-1 -1 -1 $-1 $3563 $5202 $3565 $4357 forward $4355 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5203 $5204 T -37.5 -35 19.999999999999993 -29.999999999999993 -30 35 unknown #
+edge $-1 -1 -1 $-1 $5205 -1.5707963267948966 $3567 -1.0471975511965979 $4354 $5200 forward @7 unknown T -37.5 -30.669872981077809 32.5 -35 -30 35 #
+face $-1 -1 -1 $-1 $5156 $3566 $11 $-1 $388 reversed single T -40 -30.669872981077809 32.5 -35 -30 37.500000000000007 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $4324 $5206 $3569 $4361 forward $3697 $-1 #
+edge $-1 -1 -1 $-1 $3708 -1.5707963267948966 $2886 0 $4360 $4365 forward @7 unknown T -20 -40 30 -15 -35 35 #
+face $-1 -1 -1 $-1 $4326 $3571 $11 $-1 $2541 reversed single T -15.000000000000002 -35 35 -7.5 -30 50 F #
+coedge $-1 -1 -1 $-1 $5207 $4573 $4576 $5208 reversed $3576 $-1 #
+vertex $-1 -1 -1 $-1 $5209 $5210 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3579 $5179 $5182 $5211 forward $937 $-1 #
+coedge $-1 -1 -1 $-1 $5212 $5213 $3579 $4368 reversed $5214 $-1 #
+edge $-1 -1 -1 $-1 $5215 -1.5707963267948966 $4370 0.52359877559829959 $3579 $5216 forward @7 unknown T -30.000000000000004 -35 50 -22.5 -30 50 #
+coedge $-1 -1 -1 $-1 $4555 $3580 $5213 $5217 forward $3717 $-1 #
+vertex $-1 -1 -1 $-1 $3581 $5218 #
+coedge $-1 -1 -1 $-1 $5219 $3584 $5220 $5221 forward $2896 $-1 #
+coedge $-1 -1 -1 $-1 $3584 $5219 $5222 $5223 forward $2896 $-1 #
+coedge $-1 -1 -1 $-1 $5224 $5225 $3584 $4374 reversed $5226 $-1 #
+edge $-1 -1 -1 $-1 $5227 -50 $5228 50 $4373 $5229 forward @7 unknown T 50 -50 50 50 50 50 #
+coedge $-1 -1 -1 $-1 $5230 $3585 $5231 $5232 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $5233 $5234 $3585 $4377 reversed $5235 $-1 #
+edge $-1 -1 -1 $-1 $4385 -2.0943951023931957 $5236 2.0943951023931957 $3585 $5237 forward @7 unknown T 37.5 35 50 45 45 50 #
+coedge $-1 -1 -1 $-1 $3586 $5238 $5239 $5240 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $5241 $5242 $3586 $4380 reversed $5243 $-1 #
+edge $-1 -1 -1 $-1 $5244 -2.0943951023931957 $4384 0 $3586 $5245 forward @7 unknown T 22.5 40 50 30 45 50 #
+coedge $-1 -1 -1 $-1 $5246 $3587 $5242 $5247 reversed $4383 $-1 #
+coedge $-1 -1 -1 $-1 $3587 $5248 $5233 $5249 reversed $4383 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4382 $5250 T 30 40 35 37.5 45 50 unknown #
+vertex $-1 -1 -1 $-1 $5251 $5252 #
+vertex $-1 -1 -1 $-1 $4377 $5253 #
+ellipse-curve $-1 -1 -1 $-1 35 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5254 $3589 $5255 $4408 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $5256 $5257 $3589 $4389 reversed $5258 $-1 #
+edge $-1 -1 -1 $-1 $4393 2.617993877991494 $3598 4.7123889803846906 $3589 $5259 forward @7 unknown T 30 19.999999999999996 50 37.5 25 50 #
+coedge $-1 -1 -1 $-1 $5260 $3590 $3596 $4406 forward $4392 $-1 #
+coedge $-1 -1 -1 $-1 $3590 $5261 $5256 $5262 forward $4392 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4390 $5263 T 37.5 20 35 45 30 50 unknown #
+vertex $-1 -1 -1 $-1 $5262 $5264 #
+ellipse-curve $-1 -1 -1 $-1 40 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3592 $5265 $5266 $5267 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $5268 $5269 $3592 $4397 reversed $5270 $-1 #
+edge $-1 -1 -1 $-1 $5271 -1.5707963267948966 $4401 0.5235987755982987 $3592 $5272 forward @7 unknown T 15 25 50 22.5 30 50 #
+coedge $-1 -1 -1 $-1 $5273 $3593 $5269 $5274 forward $4400 $-1 #
+coedge $-1 -1 -1 $-1 $3593 $5275 $5276 $4404 forward $4400 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4399 $5277 T 22.499999999999996 25 35 30 30 50 unknown #
+vertex $-1 -1 -1 $-1 $3594 $5278 #
+ellipse-curve $-1 -1 -1 $-1 25 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4405 $3595 $5279 $5280 reversed $3597 $-1 #
+edge $-1 -1 -1 $-1 $5281 40 $3598 50 $4399 $5282 forward @7 unknown T 30 25 40 30 25 50 #
+coedge $-1 -1 -1 $-1 $3596 $4403 $5283 $5284 reversed $3597 $-1 #
+edge $-1 -1 -1 $-1 $3599 -50 $5285 -37.500000000000007 $4390 $5286 forward @7 unknown T 37.5 29.330127018922195 37.500000000000007 37.5 29.330127018922195 50 #
+face $-1 -1 -1 $-1 $5287 $3597 $11 $-1 $5288 reversed single T 30 25 35 37.5 29.999999999999996 50 F #
+edge $-1 -1 -1 $-1 $3598 0 $5289 2.0943951023931948 $4387 $4402 forward @7 unknown T 22.5 20 50 30 25 50 #
+point $-1 -1 -1 $-1 30 25 50 #
+point $-1 -1 -1 $-1 37.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $5290 $3601 $5291 $5292 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $4433 $5293 $3601 $3622 reversed $5294 $-1 #
+coedge $-1 -1 -1 $-1 $5295 $3602 $3605 $4419 reversed $4415 $-1 #
+coedge $-1 -1 -1 $-1 $3602 $5296 $2908 $3618 forward $4415 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4414 $5297 T 30 4.9999999999999982 35 37.5 10 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5298 $3604 $5299 $5300 forward $3606 $-1 #
+coedge $-1 -1 -1 $-1 $3605 $5298 $5301 $5302 forward $3606 $-1 #
+edge $-1 -1 -1 $-1 $5303 37.5 $3607 50 $3605 $5304 forward @7 unknown T 37.5 5.6698729810778055 37.5 37.5 5.6698729810778064 50 #
+face $-1 -1 -1 $-1 $5305 $3606 $11 $-1 $5306 reversed single T 37.5 5 35 45 15 50 F #
+point $-1 -1 -1 $-1 37.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $3609 $5307 $5308 $5309 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $5310 $5311 $3609 $4424 reversed $5312 $-1 #
+edge $-1 -1 -1 $-1 $5313 -2.0943951023931948 $4428 0 $3609 $5314 forward @7 unknown T 7.5 10 50 15 15 50 #
+coedge $-1 -1 -1 $-1 $5315 $3610 $5311 $5316 reversed $4427 $-1 #
+coedge $-1 -1 -1 $-1 $3610 $5317 $3612 $4431 reversed $4427 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4426 $5318 T 15 10 35 22.5 14.999999999999998 50 unknown #
+vertex $-1 -1 -1 $-1 $5319 $5320 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4432 $3612 $5321 $5322 forward $3614 $-1 #
+edge $-1 -1 -1 $-1 $3615 -50 $5323 -37.5 $3612 $5324 forward @7 unknown T 22.5 14.330127018922193 37.5 22.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $3613 $4430 $5325 $5326 forward $3614 $-1 #
+coedge $-1 -1 -1 $-1 $5327 $4412 $4414 $3618 reversed $5294 $-1 #
+face $-1 -1 -1 $-1 $5328 $3614 $11 $-1 $5329 reversed single T 22.499999999999996 10 35 30 15 50 F #
+point $-1 -1 -1 $-1 22.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $5325 $5330 $3617 $4437 forward $5331 $-1 #
+edge $-1 -1 -1 $-1 $5332 -1.5707963267948966 $4438 -2.9403902792268224e-16 $4436 $5333 forward @7 unknown T 30 10 35 35 14.999999999999998 40 #
+vertex $-1 -1 -1 $-1 $5334 $5335 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5336 $5299 $3619 $4441 forward $5337 $-1 #
+edge $-1 -1 -1 $-1 $4442 -2.0943951023931953 $5332 -1.5707963267948966 $4440 $5338 forward @7 unknown T 35 14.330127018922191 35 37.5 14.999999999999998 37.5 #
+vertex $-1 -1 -1 $-1 $5300 $5339 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $5340 $5341 $11 $-1 $4445 reversed single T 30 10 -50 37.5 14.999999999999998 -40 F #
+cone-surface $-1 -1 -1 $-1 35 9.9999999999999982 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $5342 $5343 #
+coedge $-1 -1 -1 $-1 $5344 $3625 $5345 $4476 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $5346 $5347 $3625 $4449 reversed $5348 $-1 #
+edge $-1 -1 -1 $-1 $3660 2.617993877991494 $3642 4.7123889803846897 $3625 $5349 forward @7 unknown T 15 -10 50 22.5 -5 50 #
+coedge $-1 -1 -1 $-1 $3626 $5350 $5346 $4499 forward $4451 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3647 $4462 T 22.5 -10 35 30 -4.9999999999999991 50 unknown #
+coedge $-1 -1 -1 $-1 $4453 $3627 $5351 $5352 reversed $3629 $-1 #
+coedge $-1 -1 -1 $-1 $3628 $4452 $5353 $5354 reversed $3629 $-1 #
+face $-1 -1 -1 $-1 $2934 $3629 $11 $-1 $3659 reversed single T 30 -10.000000000000002 35 37.5 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $3632 $3631 $5355 $5356 forward $2919 $-1 #
+coedge $-1 -1 -1 $-1 $3654 $5357 $3631 $4457 reversed $4494 $-1 #
+edge $-1 -1 -1 $-1 $3656 4.1887902047863905 $5358 4.7123889803846897 $3631 $5359 forward @7 unknown T 37.5 -0.66987298107780902 35 40 0 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $5360 $5351 $3632 $4459 reversed $5361 $-1 #
+edge $-1 -1 -1 $-1 $5362 1.5707963267948966 $4460 2.0943951023931948 $3632 $5359 forward @7 unknown T 37.5 -10 35 40 -9.3301270189221945 37.5 #
+vertex $-1 -1 -1 $-1 $5352 $5363 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $5364 $4451 $11 $-1 $4486 reversed single T 22.5 -10 35 30 -4.9999999999999991 50 F #
+cone-surface $-1 -1 -1 $-1 40 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $3636 $5365 $5366 $5367 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $5368 $5369 $3636 $4466 reversed $5370 $-1 #
+edge $-1 -1 -1 $-1 $5371 -1.5707963267948966 $4470 0.52359877559829893 $3636 $5372 forward @7 unknown T 0 -5 50 7.5 0 50 #
+coedge $-1 -1 -1 $-1 $5373 $3637 $5369 $5374 forward $4469 $-1 #
+coedge $-1 -1 -1 $-1 $3637 $5375 $5376 $4473 forward $4469 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4468 $5377 T 7.4999999999999991 -5 35 15 0 50 unknown #
+vertex $-1 -1 -1 $-1 $3638 $5378 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4474 $3639 $5379 $5380 reversed $3641 $-1 #
+edge $-1 -1 -1 $-1 $5381 40 $3642 50 $4468 $5382 forward @7 unknown T 15 -5 40 15 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $3640 $4472 $5383 $5384 reversed $3641 $-1 #
+face $-1 -1 -1 $-1 $5385 $3641 $11 $-1 $5386 reversed single T 15 -5.0000000000000009 35 22.500000000000004 -8.8817841970012523e-16 50 F #
+edge $-1 -1 -1 $-1 $3642 0 $5387 2.0943951023931948 $4447 $4471 forward @7 unknown T 7.5 -10 50 15 -5 50 #
+point $-1 -1 -1 $-1 15 -5 50 #
+coedge $-1 -1 -1 $-1 $5383 $5388 $3644 $4479 reversed $5389 $-1 #
+edge $-1 -1 -1 $-1 $4480 4.1887902047863905 $5390 4.7123889803846897 $3644 $5391 forward @7 unknown T 22.499999999999996 -0.66987298107780902 35 25 0 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $4479 $5392 #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $5393 $3650 $3646 $4483 reversed $4488 $-1 #
+edge $-1 -1 -1 $-1 $5390 1.5707963267948966 $3652 3.1415926535897931 $3646 $5394 forward @7 unknown T 25 -4.9999999999999991 35 30 0 40 #
+coedge $-1 -1 -1 $-1 $5350 $3647 $5395 $4491 forward $4451 $-1 #
+face $-1 -1 -1 $-1 $5396 $5397 $11 $-1 $5398 reversed single T 7.4999999999999991 -10 35 15 -4.9999999999999991 50 F #
+cone-surface $-1 -1 -1 $-1 25 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $3650 $5393 $5399 $5400 forward $4488 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3650 $5401 T 25 -5 30 35 0 40 unknown #
+vertex $-1 -1 -1 $-1 $5400 $5402 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+edge $-1 -1 -1 $-1 $3652 3.1415926535897931 $5403 4.7123889803846897 $4484 $5394 forward @7 unknown T 25 -10 35 30 -4.9999999999999991 40 #
+point $-1 -1 -1 $-1 30 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $5357 $3654 $5404 $5405 forward $4494 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3654 $5406 T 35 -0.66987298107781257 32.5 40 0 37.500000000000007 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 -0.66987298107780902 37.500000000000007 #
+face $-1 -1 -1 $-1 $5407 $5408 $11 $-1 $3659 reversed single T 29.999999999999996 -5.0000000000000009 -40 37.500000000000007 -1.7763568394002505e-15 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $5409 $3658 T 30 -5.0000000000000018 -50 37.5 -1.7763568394002505e-15 -40 unknown #
+edge $-1 -1 -1 $-1 $5410 37.5 $3660 50 $4450 $5411 forward @7 unknown T 22.5 -9.3301270189221963 37.5 22.500000000000004 -9.3301270189221945 50 #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221945 50 #
+coedge $-1 -1 -1 $-1 $5412 $3661 $5413 $5414 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $4520 $5415 $3661 $3686 reversed $4528 $-1 #
+coedge $-1 -1 -1 $-1 $5092 $3662 $3664 $3694 reversed $4505 $-1 #
+coedge $-1 -1 -1 $-1 $3662 $5099 $2952 $3683 forward $4505 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4504 $5416 T 15 -25 35 22.500000000000004 -20 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $3425 1.5707963267948966 $3671 2.0943951023931953 $4229 $5417 forward @7 unknown T 35 -25.000000000000004 35 37.5 -24.330127018922195 37.5 #
+point $-1 -1 -1 $-1 37.5 -24.330127018922198 37.5 #
+coedge $-1 -1 -1 $-1 $3674 $5418 $5419 $5420 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $5421 $4697 $3674 $4511 reversed $3821 $-1 #
+edge $-1 -1 -1 $-1 $5422 -2.0943951023931957 $4515 0 $3674 $5423 forward @7 unknown T -7.5000000000000009 -20 50 0 -15 50 #
+coedge $-1 -1 -1 $-1 $5424 $3675 $4697 $5425 reversed $4514 $-1 #
+coedge $-1 -1 -1 $-1 $3675 $5426 $3677 $4518 reversed $4514 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4513 $5427 T -8.8817841970012523e-16 -20 35 7.5000000000000009 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $5428 $5429 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4519 $3677 $5430 $5431 forward $3679 $-1 #
+edge $-1 -1 -1 $-1 $3680 -50 $5432 -37.499999999999993 $3677 $5433 forward @7 unknown T 7.5 -15.669872981077807 37.499999999999993 7.5000000000000009 -15.669872981077807 50 #
+coedge $-1 -1 -1 $-1 $3678 $4517 $4236 $5101 forward $3679 $-1 #
+coedge $-1 -1 -1 $-1 $5434 $4502 $4504 $3683 reversed $4528 $-1 #
+face $-1 -1 -1 $-1 $5435 $3679 $11 $-1 $4529 reversed single T 7.4999999999999991 -20 35 15 -15 50 F #
+point $-1 -1 -1 $-1 7.5 -15.669872981077807 50 #
+vertex $-1 -1 -1 $-1 $5436 $5437 #
+face $-1 -1 -1 $-1 $5438 $5439 $11 $-1 $1477 reversed single T 15 -20 -50 22.500000000000004 -15 -40 F #
+vertex $-1 -1 -1 $-1 $5440 $5441 #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077805 37.499999999999993 #
+loop $-1 -1 -1 $-1 $-1 $4520 $3690 T 7.4999999999999991 -25 35 15 -20 50 unknown #
+cone-surface $-1 -1 -1 $-1 10 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+face $-1 -1 -1 $-1 $3788 $4121 $11 $-1 $704 reversed single T 29.999999999999996 -25.000000000000004 -40 37.5 -20 -24.999999999999996 F #
+coedge $-1 -1 -1 $-1 $5442 $3769 $3772 $4632 reversed $3693 $-1 #
+vertex $-1 -1 -1 $-1 $5093 $5443 #
+face $-1 -1 -1 $-1 $3540 $5162 $11 $-1 $162 reversed single T -20 -35 15 -10.000000000000002 -30 25 F #
+coedge $-1 -1 -1 $-1 $3699 $3698 $4322 $3577 reversed $2363 $-1 #
+edge $-1 -1 -1 $-1 $4364 1.5707963267948966 $2879 3.1415926535897931 $3716 $3709 forward @7 unknown T -20 -35 35 -15 -30 40 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 -30.669872981077805 37.5 #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 35 #
+coedge $-1 -1 -1 $-1 $5444 $3706 $5206 $4546 reversed $4543 $-1 #
+coedge $-1 -1 -1 $-1 $3706 $5444 $4548 $5445 forward $4543 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4542 $5446 T -25.000000000000004 -40 32.5 -20 -39.330127018922191 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $5445 $5447 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5448 1.0471975511965979 $3708 1.5707963267948966 $5206 $5449 forward @7 unknown T -22.500000000000004 -40 32.5 -20 -39.330127018922191 35 #
+point $-1 -1 -1 $-1 -20 -40 35 #
+coedge $-1 -1 -1 $-1 $5450 $3710 $4542 $5445 reversed $4550 $-1 #
+coedge $-1 -1 -1 $-1 $3710 $5451 $3712 $4553 reversed $4550 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5451 $5452 T -30.000000000000004 -40 35 -22.5 -35 50 unknown #
+straight-curve $-1 -1 -1 $-1 -22.5 -39.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5179 $3712 $5188 $5453 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $3713 2.6179938779914931 $5215 4.7123889803846897 $3712 $5454 forward @7 unknown T -30.000000000000004 -40 50 -22.5 -35 50 #
+point $-1 -1 -1 $-1 -22.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $3716 $4369 $5455 $5456 forward $3717 $-1 #
+face $-1 -1 -1 $-1 $5457 $3717 $11 $-1 $1595 reversed single T -22.500000000000004 -35 35 -15 -30 50 F #
+edge $-1 -1 -1 $-1 $5458 1.5707963267948966 $3720 2.0943951023931957 $3718 $5459 forward @7 unknown T 4.9999999999999982 -30.669872981077809 -42.500000000000007 7.4999999999999991 -30 -40 #
+face $-1 -1 -1 $-1 $5460 $3719 $11 $-1 $756 reversed single T 4.9999999999999982 -30.669872981077813 -42.500000000000007 10 -30 -37.5 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077805 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $3744 $3723 $5461 $5462 reversed $3724 $-1 #
+coedge $-1 -1 -1 $-1 $3727 $5463 $4566 $5464 reversed $4562 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3727 $5465 T -1.7763568394002505e-15 -40 -50 7.4999999999999991 -35 -40 unknown #
+vertex $-1 -1 -1 $-1 $3731 $5466 #
+point $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $4811 $3730 $4561 $5464 forward $4567 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4566 $5460 T 4.9999999999999982 -40 -42.500000000000007 10 -39.330127018922191 -37.500000000000007 unknown #
+loop $-1 -1 -1 $-1 $-1 $4575 $3732 T -7.5000000000000089 -35 -50 0 -30 -40 unknown #
+edge $-1 -1 -1 $-1 $3444 6.1232339957367648e-17 $3738 1.5707963267948966 $4259 $5467 forward @7 unknown T -1.7763568394002505e-15 -40 5 4.9999999999999982 -35 10 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 5 #
+coedge $-1 -1 -1 $-1 $3868 $3741 $3849 $4738 forward $1370 $-1 #
+coedge $-1 -1 -1 $-1 $4363 $3892 $3741 $4574 reversed $3576 $-1 #
+edge $-1 -1 -1 $-1 $4577 -0.52359877559829937 $4778 1.5707963267948966 $3741 $5468 forward @7 unknown T -15.000000000000002 -35 -50 -7.5 -30 -50 #
+coedge $-1 -1 -1 $-1 $5469 $3742 $3873 $4579 forward $4568 $-1 #
+coedge $-1 -1 -1 $-1 $3742 $5470 $4363 $5208 forward $4568 $-1 #
+vertex $-1 -1 -1 $-1 $5208 $5471 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -50 0 0 1 5 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3745 -50 $4764 -45 $4575 $5472 forward @7 unknown T -8.8817841970012523e-16 -35 -50 0 -35 -45 #
+point $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 -50 #
+edge $-1 -1 -1 $-1 $3890 -2.0943951023931957 $3745 0 $3747 $4578 forward @7 unknown T -7.5000000000000009 -40 -50 0 -35 -50 #
+coedge $-1 -1 -1 $-1 $5463 $3748 $3744 $4579 forward $4562 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $5473 $1616 T -50 -50 -50 50 50 -50 unknown #
+coedge $-1 -1 -1 $-1 $5474 $5475 $5476 $5477 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $5478 $3751 $5479 $5480 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $3751 $5481 $5482 $5483 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $5484 $5485 $3751 $4589 reversed $5486 $-1 #
+edge $-1 -1 -1 $-1 $5487 1.5707963267948957 $5488 3.6651914291880923 $3751 $5489 forward @7 unknown T 30 19.999999999999996 -50 37.5 25 -50 #
+coedge $-1 -1 -1 $-1 $5490 $3752 $5491 $5492 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $5493 $5494 $3752 $4592 reversed $5495 $-1 #
+edge $-1 -1 -1 $-1 $4600 -2.0943951023931957 $5496 2.0943951023931948 $3752 $5497 forward @7 unknown T 37.5 5 -50 45 15 -50 #
+coedge $-1 -1 -1 $-1 $3753 $5498 $5499 $5500 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $5501 $5502 $3753 $4595 reversed $5503 $-1 #
+edge $-1 -1 -1 $-1 $5504 -2.0943951023931957 $4599 0 $3753 $5505 forward @7 unknown T 22.5 5 -50 30 10 -50 #
+coedge $-1 -1 -1 $-1 $5506 $3754 $5507 $5508 forward $4598 $-1 #
+coedge $-1 -1 -1 $-1 $3754 $5509 $5493 $5510 reversed $4598 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4597 $5511 T 30 4.9999999999999982 -50 37.500000000000007 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $5512 $5513 #
+vertex $-1 -1 -1 $-1 $4592 $5514 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5515 $3756 $5516 $4624 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $5409 $4619 $3756 $4604 reversed $4498 $-1 #
+edge $-1 -1 -1 $-1 $4608 -0.5235987755982987 $3765 1.5707963267948966 $3756 $5517 forward @7 unknown T 30 -5.0000000000000018 -50 37.5 -1.7763568394002505e-15 -50 #
+coedge $-1 -1 -1 $-1 $5518 $3757 $3763 $4622 forward $4607 $-1 #
+coedge $-1 -1 -1 $-1 $3757 $5519 $5409 $5520 forward $4607 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4605 $5521 T 37.5 -10 -50 45 0 -40 unknown #
+vertex $-1 -1 -1 $-1 $5520 $5522 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $3759 $5523 $5524 $5525 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $5526 $5527 $3759 $4612 reversed $5528 $-1 #
+edge $-1 -1 -1 $-1 $5529 1.5707963267948966 $4616 3.6651914291880923 $3759 $5530 forward @7 unknown T 15 -10 -50 22.5 -5 -50 #
+coedge $-1 -1 -1 $-1 $5531 $3760 $5527 $5532 forward $4615 $-1 #
+coedge $-1 -1 -1 $-1 $3760 $5533 $3762 $4620 reversed $4615 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4614 $5534 T 22.5 -10 -50 30 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $3761 $5535 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4621 $3762 $5536 $5537 reversed $3764 $-1 #
+coedge $-1 -1 -1 $-1 $4603 $5538 $5539 $4620 reversed $4498 $-1 #
+edge $-1 -1 -1 $-1 $3765 -50 $5540 -45 $5539 $5541 forward @7 unknown T 30 -5.0000000000000009 -50 30 -5 -45 #
+coedge $-1 -1 -1 $-1 $3763 $4618 $5542 $5543 reversed $3764 $-1 #
+edge $-1 -1 -1 $-1 $3766 -50 $5544 -42.5 $4605 $5545 forward @7 unknown T 37.5 -9.3301270189221945 -50 37.500000000000007 -9.3301270189221945 -42.5 #
+face $-1 -1 -1 $-1 $3634 $3764 $11 $-1 $3659 reversed single T 30 -10.000000000000002 -50 37.500000000000007 -5 -40 F #
+edge $-1 -1 -1 $-1 $3765 -1.7763568394002506e-16 $5546 2.0943951023931957 $4602 $4617 forward @7 unknown T 22.5 -5.0000000000000009 -50 30 0 -50 #
+point $-1 -1 -1 $-1 30 -5.0000000000000009 -50 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221945 -50 #
+coedge $-1 -1 -1 $-1 $5547 $3768 $5548 $5549 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $4650 $5550 $3768 $3789 reversed $4234 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5551 $3771 $5552 $5553 forward $3432 $-1 #
+coedge $-1 -1 -1 $-1 $3772 $5551 $5554 $5555 forward $3432 $-1 #
+edge $-1 -1 -1 $-1 $5556 42.5 $3773 50 $3772 $5557 forward @7 unknown T 37.499999999999986 -15.669872981077805 -50 37.5 -15.669872981077805 -42.5 #
+point $-1 -1 -1 $-1 37.5 -15.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $3775 $5558 $5559 $5560 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $5561 $5562 $3775 $4636 reversed $5563 $-1 #
+edge $-1 -1 -1 $-1 $5564 -2.0943951023931957 $4640 0 $3775 $5565 forward @7 unknown T 7.4999999999999991 -25 -50 15 -20 -50 #
+coedge $-1 -1 -1 $-1 $5566 $3776 $5567 $5568 forward $4639 $-1 #
+coedge $-1 -1 -1 $-1 $3776 $5569 $3778 $4643 reversed $4639 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4638 $5570 T 15 -25 -50 22.500000000000004 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $5571 $5572 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4644 $3778 $5573 $5574 forward $3780 $-1 #
+edge $-1 -1 -1 $-1 $3781 -50 $5575 -42.500000000000014 $3778 $5576 forward @7 unknown T 22.5 -24.330127018922195 -50 22.500000000000004 -24.330127018922195 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $3779 $4642 $5577 $5578 forward $3780 $-1 #
+face $-1 -1 -1 $-1 $5579 $3780 $11 $-1 $2194 reversed single T 22.499999999999996 -25 -50 30 -20 -40 F #
+point $-1 -1 -1 $-1 22.5 -24.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $5577 $5580 $3783 $4648 forward $4209 $-1 #
+edge $-1 -1 -1 $-1 $5581 -1.5707963267948966 $4651 6.4931039580273265e-16 $4647 $5582 forward @7 unknown T 30 -25.000000000000004 -45 35 -20 -40 #
+coedge $-1 -1 -1 $-1 $3784 $5442 $5583 $5584 reversed $3693 $-1 #
+coedge $-1 -1 -1 $-1 $5585 $4628 $3779 $3785 forward $4234 $-1 #
+vertex $-1 -1 -1 $-1 $5586 $5587 #
+straight-curve $-1 -1 -1 $-1 30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5588 $5552 $3786 $4654 forward $5589 $-1 #
+edge $-1 -1 -1 $-1 $4655 -2.0943951023931957 $5581 -1.5707963267948966 $4653 $5590 forward @7 unknown T 35 -25.000000000000004 -42.5 37.500000000000007 -24.330127018922195 -40 #
+vertex $-1 -1 -1 $-1 $5553 $5591 #
+vertex $-1 -1 -1 $-1 $5592 $5593 #
+face $-1 -1 -1 $-1 $4758 $5594 $11 $-1 $756 reversed single T -35 -40 -45 -25.000000000000004 -35 -35 F #
+loop $-1 -1 -1 $-1 $-1 $5595 $3792 T -25.000000000000004 -40 -42.500000000000007 -20 -39.330127018922191 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $5596 $3794 $4777 $5597 reversed $3030 $-1 #
+coedge $-1 -1 -1 $-1 $3794 $5598 $3894 $4783 forward $3030 $-1 #
+coedge $-1 -1 -1 $-1 $4684 $3795 $5599 $5600 forward $2411 $-1 #
+coedge $-1 -1 -1 $-1 $5601 $5602 $3795 $4664 reversed $5594 $-1 #
+edge $-1 -1 -1 $-1 $4671 3.1415926535897931 $5603 4.7123889803846897 $3795 $5604 forward @7 unknown T -35 -40 -40 -30 -35 -35 #
+coedge $-1 -1 -1 $-1 $3796 $4684 $4686 $5605 forward $2411 $-1 #
+coedge $-1 -1 -1 $-1 $5606 $5607 $3796 $4667 reversed $5608 $-1 #
+edge $-1 -1 -1 $-1 $5609 -1.5707963267948957 $4672 0 $3796 $5610 forward @7 unknown T -35 -40 -30.000000000000004 -30.000000000000007 -35 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $5611 $3797 $5607 $5612 reversed $4670 $-1 #
+coedge $-1 -1 -1 $-1 $3797 $5613 $5601 $5614 reversed $4670 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5613 $4750 T -30.000000000000007 -40 -40 -22.5 -35 -25 unknown #
+vertex $-1 -1 -1 $-1 $4664 $5615 #
+vertex $-1 -1 -1 $-1 $5616 $5617 #
+coedge $-1 -1 -1 $-1 $5618 $5619 $3031 $3798 forward $5620 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 -35 0 0 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5465 $4771 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 -40 7.5 -35 -25 F #
+coedge $-1 -1 -1 $-1 $5621 $3805 $3807 $4682 forward $4680 $-1 #
+coedge $-1 -1 -1 $-1 $3805 $5621 $3878 $4767 reversed $4680 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5621 $4024 T -5 -40 -30 5 -35 -19.999999999999996 unknown #
+edge $-1 -1 -1 $-1 $4085 -1.5707963267948966 $2064 -6.1232339957367648e-17 $3972 $5622 forward @7 unknown T -1.7763568394002505e-15 -40 -15 4.9999999999999982 -35 -10 #
+edge $-1 -1 -1 $-1 $2555 6.1232339957367648e-17 $4920 1.570796326794897 $4678 $5623 forward @7 unknown T -1.7763568394002505e-15 -40 -25 5 -35 -19.999999999999996 #
+point $-1 -1 -1 $-1 -50 -35 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $4665 $4662 $3811 $4685 forward $2411 $-1 #
+edge $-1 -1 -1 $-1 $5624 -37.500000000000007 $4687 -27.500000000000007 $4684 $5625 forward @7 unknown T -37.5 -39.330127018922198 -37.500000000000007 -37.5 -39.330127018922191 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $3812 $3969 $4665 $5605 reversed $3970 $-1 #
+vertex $-1 -1 -1 $-1 $5605 $5626 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -25.000000000000004 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5627 $5628 $3814 $4690 forward $5620 $-1 #
+edge $-1 -1 -1 $-1 $4693 27.500000000000004 $5629 37.5 $4689 $5630 forward @7 unknown T -37.500000000000007 -30.669872981077805 -37.5 -37.5 -30.669872981077805 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $4848 $3815 $5628 $5631 reversed $4692 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3959 $5632 T -40 -30.669872981077809 -27.500000000000007 -35 -30 -22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $4690 $5633 #
+face $-1 -1 -1 $-1 $5204 $5183 $11 $-1 $2412 reversed single T -37.500000000000007 -35 35 -30 -30 50 F #
+face $-1 -1 -1 $-1 $5634 $5635 $11 $-1 $1815 reversed single T -10.000000000000002 -25 17.499999999999996 -5 -24.330127018922191 22.500000000000004 F #
+coedge $-1 -1 -1 $-1 $4510 $5636 $5637 $5425 forward $3821 $-1 #
+coedge $-1 -1 -1 $-1 $4698 $4698 $5638 $5639 reversed $3823 $-1 #
+coedge $-1 -1 -1 $-1 $3824 $3824 $5640 $5641 forward $3054 $-1 #
+coedge $-1 -1 -1 $-1 $5642 $5643 $3824 $4701 reversed $5644 $-1 #
+edge $-1 -1 -1 $-1 $5645 -1.5707963267948966 $5646 1.5707963267948966 $3824 $5647 forward @7 unknown T -45 -24.999999999999996 30 -40 -14.999999999999996 35 #
+coedge $-1 -1 -1 $-1 $3826 $3825 $5648 $5649 reversed $2434 $-1 #
+coedge $-1 -1 -1 $-1 $5650 $5651 $3825 $4704 forward $5652 $-1 #
+edge $-1 -1 -1 $-1 $5653 1.5707963267948966 $4711 2.0943951023931957 $4703 $5654 forward @7 unknown T -7.5000000000000027 -25 35 -5 -24.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $5655 $5656 $3826 $4706 reversed $5657 $-1 #
+edge $-1 -1 -1 $-1 $5658 -2.0943951023931953 $4710 -1.5707963267948966 $3826 $5659 forward @7 unknown T -10.000000000000002 -25 32.5 -7.5000000000000027 -24.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $5660 $3827 $5661 $5662 reversed $4709 $-1 #
+coedge $-1 -1 -1 $-1 $3827 $5663 $5650 $5664 reversed $4709 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4708 $5665 T -15.000000000000002 -25 35 -7.5000000000000009 -20 50 unknown #
+vertex $-1 -1 -1 $-1 $5666 $5667 #
+vertex $-1 -1 -1 $-1 $3828 $5668 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $3829 $5669 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 40 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $5670 $5638 $3147 T -50 -25 29.999999999999996 -50 -15 40 hole $3148 T #
+point $-1 -1 -1 $-1 -50 -35 -45 #
+coedge $-1 -1 -1 $-1 $3841 $5671 $3834 $4719 forward $4732 $-1 #
+edge $-1 -1 -1 $-1 $5629 -2.0943951023931948 $3066 -1.5707963267948966 $4718 $5672 forward @7 unknown T -40 -30.669872981077805 -40 -37.5 -30 -37.5 #
+coedge $-1 -1 -1 $-1 $5599 $3838 $3835 $4721 forward $4726 $-1 #
+edge $-1 -1 -1 $-1 $3065 1.5707963267948966 $5624 2.0943951023931944 $4720 $5673 forward @7 unknown T -40 -40 -40 -37.5 -39.330127018922198 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $3840 $3837 $5674 $5675 reversed $3064 $-1 #
+coedge $-1 -1 -1 $-1 $5676 $5677 $3837 $4724 forward $5678 $-1 #
+edge $-1 -1 -1 $-1 $5679 -50 $4727 -42.500000000000014 $4723 $5680 forward @7 unknown T -37.500000000000014 -39.330127018922205 -50 -37.5 -39.330127018922191 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $3838 $5599 $5676 $5681 reversed $4726 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3838 $5682 T -40 -40 -42.500000000000014 -35 -39.330127018922191 -37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $5681 $5683 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4752 $5684 $3840 $4730 forward $4754 $-1 #
+edge $-1 -1 -1 $-1 $4733 42.5 $5685 50 $4729 $5686 forward @7 unknown T -37.5 -30.669872981077805 -50 -37.5 -30.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $5671 $3841 $5684 $5687 reversed $4732 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3841 $5688 T -40 -30.669872981077809 -42.5 -35 -30 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $3842 $5689 #
+coedge $-1 -1 -1 $-1 $3851 $4788 $3846 $4736 reversed $4740 $-1 #
+edge $-1 -1 -1 $-1 $3073 1.5707963267948966 $3109 3.1415926535897931 $3846 $4800 forward @7 unknown T -20 -35 -40 -15 -30 -35 #
+coedge $-1 -1 -1 $-1 $3847 $4793 $5690 $5691 forward $3793 $-1 #
+edge $-1 -1 -1 $-1 $4778 0 $3870 2.0943951023931957 $4572 $5692 forward @7 unknown T -22.5 -35 -50 -15 -30 -50 #
+coedge $-1 -1 -1 $-1 $4788 $3851 $4781 $5693 forward $4740 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4739 $5694 T -20 -35 -45 -10.000000000000002 -30 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5695 $4785 $11 $-1 $482 reversed single T -20 -40 -30 -10 -35 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $3857 $3855 $5696 $5697 reversed $3077 $-1 #
+coedge $-1 -1 -1 $-1 $5690 $5698 $3855 $4745 forward $5699 $-1 #
+edge $-1 -1 -1 $-1 $5700 1.570796326794897 $4746 2.0943951023931957 $4744 $5701 forward @7 unknown T -25.000000000000004 -30.669872981077809 -27.500000000000004 -22.500000000000004 -30 -25 #
+vertex $-1 -1 -1 $-1 $3856 $5702 #
+straight-curve $-1 -1 -1 $-1 -22.5 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $3864 $3858 $5619 $5703 reversed $3865 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5704 $4670 $11 $-1 $3872 reversed single T -30.000000000000007 -40 -40 -22.5 -35 -25 F #
+coedge $-1 -1 -1 $-1 $5684 $3862 $3864 $4757 forward $4754 $-1 #
+coedge $-1 -1 -1 $-1 $3862 $4729 $4760 $5705 reversed $4754 $-1 #
+coedge $-1 -1 -1 $-1 $5677 $5706 $5707 $3863 reversed $5678 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3862 $5708 T -37.5 -35 -50 -30 -30 -40 unknown #
+vertex $-1 -1 -1 $-1 $5705 $5709 #
+edge $-1 -1 -1 $-1 $3866 0 $5710 1.5707963267948966 $4751 $5711 forward @7 unknown T -35 -35 -45 -30 -30 -40 #
+face $-1 -1 -1 $-1 $5708 $3865 $11 $-1 $756 reversed single T -35 -35 -45 -25.000000000000004 -30 -35 F #
+point $-1 -1 -1 $-1 -30 -35 -45 #
+coedge $-1 -1 -1 $-1 $5674 $3868 $4752 $5705 forward $1370 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+point $-1 -1 -1 $-1 -22.5 -30.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $3874 $3883 $5463 $5712 forward $3884 $-1 #
+vertex $-1 -1 -1 $-1 $5713 $5714 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5715 $3932 $11 $-1 $336 reversed single T -10.000000000000002 -30.669872981077813 -12.500000000000005 -5 -30 -7.4999999999999956 F #
+edge $-1 -1 -1 $-1 $4016 -1.5707963267948966 $4019 0 $3878 $4917 forward @7 unknown T -5 -40 -30 0 -35 -25 #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5130 $3881 $5621 $5716 reversed $4771 $-1 #
+coedge $-1 -1 -1 $-1 $3881 $5129 $3883 $4774 reversed $4771 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5129 $4677 T -1.7763568394002505e-15 -40 -40 7.5 -35 -25 unknown #
+coedge $-1 -1 -1 $-1 $4021 $5717 $3093 $3882 forward $4916 $-1 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3885 6.1232339957367648e-17 $5718 1.5707963267948966 $3883 $5719 forward @7 unknown T -1.7763568394002505e-15 -40 -40 4.9999999999999982 -35 -35 #
+point $-1 -1 -1 $-1 0 -35 -35 #
+loop $-1 -1 -1 $-1 $-1 $4869 $3887 T -22.500000000000004 -40 -25 -15 -35 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $3888 $5720 $4660 $5597 forward $1370 $-1 #
+vertex $-1 -1 -1 $-1 $4738 $5721 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000009 -39.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $3892 $5207 $4739 $5693 reversed $3576 $-1 #
+straight-curve $-1 -1 -1 $-1 -15 -35 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $4799 -1.5707963267948966 $3115 0 $4661 $4741 forward @7 unknown T -20 -40 -45 -15 -35 -40 #
+coedge $-1 -1 -1 $-1 $4860 $3895 $5722 $5723 reversed $4785 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3975 $4742 T -20 -40 -30 -10 -35 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5724 $3897 $5725 $5726 reversed $3900 $-1 #
+coedge $-1 -1 -1 $-1 $4735 $4739 $3897 $4789 forward $4740 $-1 #
+edge $-1 -1 -1 $-1 $5727 -1.5707963267948966 $3109 6.1232339957367648e-17 $4788 $5728 forward @7 unknown T -15.000000000000002 -35 -40 -10.000000000000002 -30 -35 #
+coedge $-1 -1 -1 $-1 $3898 $5724 $5729 $5730 reversed $3900 $-1 #
+coedge $-1 -1 -1 $-1 $4863 $5731 $3898 $4792 forward $5732 $-1 #
+edge $-1 -1 -1 $-1 $3901 -6.1232339957367648e-17 $5733 1.5707963267948961 $4791 $5734 forward @7 unknown T -15.000000000000002 -35 -30 -10.000000000000002 -30 -25 #
+coedge $-1 -1 -1 $-1 $4737 $3899 $5731 $4795 forward $3793 $-1 #
+coedge $-1 -1 -1 $-1 $3903 $5722 $2464 $3106 reversed $4798 $-1 #
+edge $-1 -1 -1 $-1 $3901 0 $5735 1.5707963267948966 $4793 $5736 forward @7 unknown T -20 -35 -30 -15 -30 -25 #
+point $-1 -1 -1 $-1 -15 -35 -30 #
+coedge $-1 -1 -1 $-1 $5737 $3903 $5738 $5739 forward $4798 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4794 $4801 T -22.500000000000004 -40 -40 -15 -35 -25 unknown #
+vertex $-1 -1 -1 $-1 $5740 $5741 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5742 $4798 $11 $-1 $1595 reversed single T -22.500000000000004 -40 -40 -15 -35 -25 F #
+face $-1 -1 -1 $-1 $5743 $3907 $11 $-1 $482 reversed single T -10.000000000000004 -40 -27.500000000000004 -5 -39.330127018922191 -22.5 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -40 -25 #
+loop $-1 -1 -1 $-1 $5744 $5745 $1558 T 50 -25 -14.999999999999996 50 -15 -4.9999999999999964 hole $1559 T #
+coedge $-1 -1 -1 $-1 $4805 $4805 $5746 $5747 forward $3912 $-1 #
+coedge $-1 -1 -1 $-1 $4806 $4806 $3913 $4807 reversed $4203 $-1 #
+edge $-1 -1 -1 $-1 $5748 0 $5748 6.2831853071795862 $3913 $5749 forward @7 unknown T 50 -25 15.000000000000004 50 -15 25.000000000000004 #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922198 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $3916 -2.0943951023931948 $5458 -1.5707963267948966 $3915 $5750 forward @7 unknown T 4.9999999999999982 -30.669872981077813 -40 7.4999999999999982 -30 -37.5 #
+point $-1 -1 -1 $-1 7.4999999999999982 -30.669872981077813 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $3918 $4566 $5129 $5751 forward $4567 $-1 #
+vertex $-1 -1 -1 $-1 $4271 $5752 #
+face $-1 -1 -1 $-1 $4558 $5753 $11 $-1 $756 reversed single T -5 -35 -45 4.9999999999999982 -30 -35 F #
+coedge $-1 -1 -1 $-1 $3924 $3923 $5116 $5754 forward $3925 $-1 #
+edge $-1 -1 -1 $-1 $4884 1.5707963267948966 $3926 2.0943951023931953 $3924 $5755 forward @7 unknown T -10.000000000000002 -30.669872981077813 2.5000000000000004 -7.5000000000000027 -30 4.9999999999999991 #
+face $-1 -1 -1 $-1 $5756 $3925 $11 $-1 $227 reversed single T -10.000000000000002 -30.669872981077813 2.4999999999999964 -5 -30 7.5 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 2.5000000000000004 #
+face $-1 -1 -1 $-1 $3003 $3937 $11 $-1 $227 reversed single T -5 -40 -9.3734986416366059e-33 4.9999999999999982 -35 10 F #
+coedge $-1 -1 -1 $-1 $3931 $3930 $4865 $5757 forward $3932 $-1 #
+edge $-1 -1 -1 $-1 $3933 -2.0943951023931948 $4879 -1.5707963267948966 $3930 $5758 forward @7 unknown T -10.000000000000002 -30.669872981077805 -10 -7.5000000000000018 -30 -7.4999999999999956 #
+point $-1 -1 -1 $-1 -7.5000000000000018 -30.669872981077802 -7.4999999999999956 #
+vertex $-1 -1 -1 $-1 $4903 $5759 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $5760 $3940 T -50 50 -50 50 50 50 unknown #
+plane-surface $-1 -1 -1 $-1 0 50 0 0 -1 0 0 0 -1 forward_v I I I I #
+coedge $-1 -1 -1 $-1 $5761 $3941 $3943 $4832 forward $4830 $-1 #
+coedge $-1 -1 -1 $-1 $3941 $5762 $4255 $5113 forward $4830 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5763 $5159 T -37.500000000000007 -35 -10.000000000000002 -30 -30 4.9999999999999982 unknown #
+straight-curve $-1 -1 -1 $-1 -37.5 -30.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $3944 4.1887902047863896 $4856 4.7123889803846897 $4828 $5764 forward @7 unknown T -37.500000000000007 -30.669872981077813 -10.000000000000002 -35 -30 -7.4999999999999964 #
+point $-1 -1 -1 $-1 -37.500000000000007 -30.669872981077813 -7.5 #
+coedge $-1 -1 -1 $-1 $5765 $3946 $4251 $5110 forward $4836 $-1 #
+coedge $-1 -1 -1 $-1 $3946 $5766 $3948 $4838 forward $4836 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5767 $5768 T -37.500000000000014 -40 -10.000000000000002 -30 -35 4.9999999999999982 unknown #
+straight-curve $-1 -1 -1 $-1 -37.5 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $4846 1.5707963267948966 $3949 2.0943951023931957 $4835 $5764 forward @7 unknown T -37.500000000000007 -40 -10.000000000000002 -35 -39.330127018922191 -7.5000000000000009 #
+point $-1 -1 -1 $-1 -37.500000000000007 -39.330127018922198 -7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $4843 $3951 $5769 $5770 forward $3953 $-1 #
+coedge $-1 -1 -1 $-1 $3952 $4843 $5606 $5771 forward $3953 $-1 #
+edge $-1 -1 -1 $-1 $5609 1.5707963267948957 $3954 2.0943951023931957 $3952 $5772 forward @7 unknown T -37.500000000000007 -40 -25.000000000000007 -35 -39.330127018922184 -22.5 #
+coedge $-1 -1 -1 $-1 $4841 $4840 $5773 $5774 reversed $3953 $-1 #
+face $-1 -1 -1 $-1 $5775 $3953 $11 $-1 $2412 reversed single T -37.500000000000007 -40 -25.000000000000007 -29.999999999999993 -35 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -37.499999999999993 -39.330127018922184 -22.5 #
+vertex $-1 -1 -1 $-1 $3956 $5776 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -10.000000000000002 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3959 $4691 $3961 $4851 reversed $4692 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -25.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4853 $3961 $5777 $5778 forward $3963 $-1 #
+edge $-1 -1 -1 $-1 $3964 4.1887902047863923 $5779 4.7123889803846906 $3961 $5772 forward @7 unknown T -37.5 -30.669872981077805 -25.000000000000007 -35 -30 -22.500000000000007 #
+coedge $-1 -1 -1 $-1 $3962 $4853 $5780 $5781 forward $3963 $-1 #
+coedge $-1 -1 -1 $-1 $4852 $4850 $4843 $5774 forward $3963 $-1 #
+face $-1 -1 -1 $-1 $3957 $3963 $11 $-1 $2412 reversed single T -37.5 -35 -25.000000000000007 -29.999999999999993 -30 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077802 -22.500000000000007 #
+vertex $-1 -1 -1 $-1 $3966 $5782 #
+face $-1 -1 -1 $-1 $4858 $5620 $11 $-1 $2412 reversed single T -37.500000000000007 -35 -40 -30 -30 -25.000000000000004 F #
+face $-1 -1 -1 $-1 $5632 $3970 $11 $-1 $482 reversed single T -40 -40 -27.500000000000007 -35 -39.330127018922184 -22.499999999999993 F #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $3975 $4784 $5783 $4872 reversed $4785 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4902 $3979 $4904 $5784 reversed $3982 $-1 #
+coedge $-1 -1 -1 $-1 $5785 $4791 $3979 $4864 forward $5732 $-1 #
+edge $-1 -1 -1 $-1 $5733 -1.570796326794897 $3983 6.1232339957367648e-17 $4863 $5786 forward @7 unknown T -15.000000000000002 -35 -25 -10 -30 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $3980 $4902 $4820 $5757 reversed $3982 $-1 #
+coedge $-1 -1 -1 $-1 $3989 $4901 $3980 $4867 forward $4878 $-1 #
+edge $-1 -1 -1 $-1 $2542 -6.1232339957367648e-17 $4879 1.5707963267948966 $4866 $5787 forward @7 unknown T -15.000000000000004 -35 -15.000000000000002 -10.000000000000002 -30 -10 #
+coedge $-1 -1 -1 $-1 $3981 $5788 $5785 $5789 forward $4870 $-1 #
+coedge $-1 -1 -1 $-1 $5783 $3985 $2527 $3184 reversed $4776 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3981 $5790 T -22.500000000000004 -35 -25 -15 -30 -10.000000000000002 unknown #
+face $-1 -1 -1 $-1 $2529 $3982 $11 $-1 $2541 reversed single T -15.000000000000004 -35 -25 -7.5000000000000009 -30 -10 F #
+edge $-1 -1 -1 $-1 $3983 3.1415926535897931 $5791 4.7123889803846897 $5783 $5792 forward @7 unknown T -20 -40 -25 -15 -35 -20 #
+point $-1 -1 -1 $-1 -15 -35 -20 #
+coedge $-1 -1 -1 $-1 $3985 $5793 $5794 $4896 forward $4776 $-1 #
+coedge $-1 -1 -1 $-1 $3996 $5795 $3987 $4876 forward $4002 $-1 #
+edge $-1 -1 -1 $-1 $5127 -1.5707963267948966 $3191 0 $4875 $4891 forward @7 unknown T -20 -40 -8.8817841970012523e-16 -15 -35 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $4901 $3989 $3995 $4888 reversed $4878 $-1 #
+loop $-1 -1 -1 $-1 $-1 $3989 $5715 T -20 -35 -15.000000000000002 -10.000000000000002 -30 -5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $4867 $5796 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $5797 $3992 $4260 $5117 forward $4883 $-1 #
+coedge $-1 -1 -1 $-1 $3992 $5797 $3994 $3999 reversed $4883 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4881 $5756 T -20 -35 -1.7763568394002505e-15 -10.000000000000002 -30 10 unknown #
+vertex $-1 -1 -1 $-1 $3993 $5798 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5799 $3994 $5800 $5801 forward $3997 $-1 #
+coedge $-1 -1 -1 $-1 $3995 $5799 $5802 $5803 forward $3997 $-1 #
+edge $-1 -1 -1 $-1 $4005 1.5707963267948961 $2536 3.1415926535897931 $3995 $4004 forward @7 unknown T -20 -35 -10.000000000000004 -14.999999999999996 -30 -5.0000000000000018 #
+face $-1 -1 -1 $-1 $5804 $3997 $11 $-1 $1595 reversed single T -22.500000000000007 -35 -10.000000000000004 -14.999999999999996 -30 4.9999999999999991 F #
+vertex $-1 -1 -1 $-1 $5801 $5805 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 4.9999999999999991 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5795 $4001 $5806 $5807 forward $4002 $-1 #
+coedge $-1 -1 -1 $-1 $5794 $5808 $4001 $4894 reversed $5809 $-1 #
+edge $-1 -1 -1 $-1 $4003 1.5707963267948961 $5810 2.0943951023931948 $4001 $5811 forward @7 unknown T -22.500000000000004 -40 -10.000000000000004 -20 -39.330127018922191 -7.5000000000000036 #
+face $-1 -1 -1 $-1 $3877 $4002 $11 $-1 $1595 reversed single T -22.500000000000004 -40 -10.000000000000004 -14.999999999999996 -35 4.9999999999999991 F #
+edge $-1 -1 -1 $-1 $5812 1.0471975511965965 $4003 1.5707963267948961 $4874 $5813 forward @7 unknown T -22.500000000000004 -40 -12.500000000000007 -20 -39.330127018922191 -10.000000000000002 #
+point $-1 -1 -1 $-1 -20 -40 -10.000000000000002 #
+edge $-1 -1 -1 $-1 $4005 -1.5707963267948961 $5814 -1.0471975511965974 $4900 $5813 forward @7 unknown T -22.5 -30.669872981077809 -12.500000000000004 -20 -30 -10.000000000000002 #
+point $-1 -1 -1 $-1 -20 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $5815 $4006 $5816 $4898 forward $4870 $-1 #
+coedge $-1 -1 -1 $-1 $4866 $4877 $4006 $3198 reversed $4878 $-1 #
+coedge $-1 -1 -1 $-1 $4865 $4862 $4010 $4903 reversed $3982 $-1 #
+edge $-1 -1 -1 $-1 $4823 12.500000000000004 $4907 22.5 $4010 $5817 forward @7 unknown T -7.5000000000000027 -30.669872981077813 -22.5 -7.5000000000000009 -30.669872981077805 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $5729 $4011 $4862 $5784 forward $4906 $-1 #
+coedge $-1 -1 -1 $-1 $4011 $5729 $4915 $4908 reversed $4906 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5729 $5818 T -10.000000000000004 -30.669872981077813 -27.500000000000007 -5 -30 -22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $4012 $5819 #
+edge $-1 -1 -1 $-1 $4013 -1.5707963267948966 $5820 -1.0471975511965965 $4915 $4768 forward @7 unknown T -7.5000000000000053 -30.669872981077813 -27.500000000000007 -5 -30 -25 #
+point $-1 -1 -1 $-1 -5 -30 -25 #
+face $-1 -1 -1 $-1 $5821 $5822 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 5 7.5 -15 20 F #
+loop $-1 -1 -1 $-1 $-1 $5823 $4015 T -8.8817841970012523e-16 -20 20 7.5000000000000009 -15 35 unknown #
+cone-surface $-1 -1 -1 $-1 4.9999999999999991 -20 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+point $-1 -1 -1 $-1 -5 -40 -25 #
+point $-1 -1 -1 $-1 0 -35 -30 #
+coedge $-1 -1 -1 $-1 $5824 $4021 $4905 $4908 forward $4916 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4772 $5825 T -7.5000000000000053 -35 -40 0 -30 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -35 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4273 $4023 $5826 $5827 reversed $4017 $-1 #
+face $-1 -1 -1 $-1 $3214 $4080 $11 $-1 $482 reversed single T 4.9999999999999956 -40 -27.500000000000004 10 -39.330127018922191 -22.5 F #
+vertex $-1 -1 -1 $-1 $5716 $5828 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5416 $4219 $11 $-1 $1477 reversed single T 15 -25 20 22.500000000000004 -20 35 F #
+loop $-1 -1 -1 $-1 $-1 $5073 $4027 T 14.999999999999996 -25 5.0000000000000009 22.500000000000004 -20 20 unknown #
+coedge $-1 -1 -1 $-1 $5829 $5055 $5057 $5830 reversed $4028 $-1 #
+coedge $-1 -1 -1 $-1 $5831 $4029 $5832 $5833 reversed $3224 $-1 #
+coedge $-1 -1 -1 $-1 $4029 $5834 $5032 $5835 reversed $3224 $-1 #
+coedge $-1 -1 -1 $-1 $5033 $5836 $4029 $4928 forward $5837 $-1 #
+edge $-1 -1 -1 $-1 $5838 1.5707963267948961 $5839 2.0943951023931939 $4927 $5840 forward @7 unknown T 19.999999999999996 -25 -25 22.499999999999993 -24.330127018922191 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $5841 $4030 $4132 $5027 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $5842 $4134 $4030 $4931 forward $5029 $-1 #
+edge $-1 -1 -1 $-1 $5030 -2.0943951023931939 $4938 -1.5707963267948961 $4930 $5843 forward @7 unknown T 19.999999999999996 -15.669872981077805 -25 22.499999999999996 -15 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $4031 $5841 $4041 $4952 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $5844 $5845 $5846 $4934 forward $5847 $-1 #
+edge $-1 -1 -1 $-1 $4939 -20 $5848 -15 $4933 $5849 forward @7 unknown T 15 -20 -20 15 -20 -15 #
+coedge $-1 -1 -1 $-1 $5850 $4032 $5845 $5851 reversed $4937 $-1 #
+coedge $-1 -1 -1 $-1 $4032 $5850 $5852 $5853 forward $4937 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4936 $5072 T 10 -20 -30 20.000000000000004 -15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $5853 $5854 #
+vertex $-1 -1 -1 $-1 $5855 $5856 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4037 $4034 $4047 $4957 reversed $2079 $-1 #
+coedge $-1 -1 -1 $-1 $4133 $4035 $5841 $5063 forward $4159 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5857 $4038 $4055 $4966 forward $4947 $-1 #
+coedge $-1 -1 -1 $-1 $4038 $5858 $4040 $4951 forward $4947 $-1 #
+coedge $-1 -1 -1 $-1 $5859 $5860 $5861 $4039 reversed $5862 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4038 $5863 T 7.4999999999999982 -20 -10 15.000000000000004 -15 5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $4966 $5864 #
+straight-curve $-1 -1 -1 $-1 15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4041 $4040 $5844 $5865 reversed $4042 $-1 #
+edge $-1 -1 -1 $-1 $5866 1.5707963267948966 $4044 3.1415926535897931 $4945 $5867 forward @7 unknown T 10 -20 -10 15 -15 -5 #
+edge $-1 -1 -1 $-1 $5848 -6.1232339957367648e-17 $4043 1.5707963267948966 $4041 $5868 forward @7 unknown T 15 -20 -15 20 -15 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $5869 $4042 $11 $-1 $2664 reversed single T 10 -20 -15 20 -15 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 20 -15 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $4044 3.1415926535897931 $5870 4.7123889803846897 $5859 $5867 forward @7 unknown T 10 -25 -10 15 -20 -5 #
+point $-1 -1 -1 $-1 15 -20 -5 #
+edge $-1 -1 -1 $-1 $3239 1.5707963267948966 $3379 2.0943951023931948 $4047 $5871 forward @7 unknown T 20 -15.669872981077805 2.5000000000000036 22.5 -15 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $5872 $4049 $5873 $4990 forward $4052 $-1 #
+coedge $-1 -1 -1 $-1 $4050 $5872 $5874 $5875 forward $4052 $-1 #
+coedge $-1 -1 -1 $-1 $5876 $4051 $5877 $4060 forward $4963 $-1 #
+coedge $-1 -1 -1 $-1 $4051 $5878 $5879 $5880 forward $4963 $-1 #
+coedge $-1 -1 -1 $-1 $5881 $5882 $2577 $3235 forward $4923 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4051 $4216 T 7.5 -25 5.0000000000000009 15 -20 20 unknown #
+face $-1 -1 -1 $-1 $5883 $4052 $11 $-1 $4529 reversed single T 7.4999999999999964 -20 5.0000000000000009 15 -15 20 F #
+point $-1 -1 -1 $-1 15 -20 15 #
+edge $-1 -1 -1 $-1 $4948 0 $4967 1.5707963267948966 $4944 $5884 forward @7 unknown T 10 -20 8.8817841970012523e-16 15.000000000000004 -15 5.0000000000000009 #
+vertex $-1 -1 -1 $-1 $5885 $5886 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -20 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5077 $5887 $11 $-1 $2156 reversed single T 10 -25 -9.3734986416366073e-33 20 -20 10 F #
+vertex $-1 -1 -1 $-1 $5888 $5889 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 20 -15 35 #
+coedge $-1 -1 -1 $-1 $4068 $4066 $5890 $5891 forward $3250 $-1 #
+coedge $-1 -1 -1 $-1 $5430 $5892 $4066 $4976 reversed $5893 $-1 #
+edge $-1 -1 -1 $-1 $4977 -1.5707963267948966 $5894 -1.0471975511965974 $4066 $5895 forward @7 unknown T 7.4999999999999982 -15.669872981077809 32.5 10 -15 35 #
+vertex $-1 -1 -1 $-1 $4976 $5896 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5897 $5873 $4068 $4980 reversed $5898 $-1 #
+edge $-1 -1 -1 $-1 $5899 4.1887902047863914 $4076 4.7123889803846897 $4068 $5900 forward @7 unknown T 7.5000000000000009 -15.669872981077807 20 10 -15 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $5901 $4069 $5902 $5903 forward $4072 $-1 #
+coedge $-1 -1 -1 $-1 $5081 $5879 $4069 $3257 reversed $4197 $-1 #
+coedge $-1 -1 -1 $-1 $4070 $5901 $5904 $5905 forward $4072 $-1 #
+coedge $-1 -1 -1 $-1 $5098 $5097 $4070 $4985 reversed $3434 $-1 #
+edge $-1 -1 -1 $-1 $5906 -1.5707963267948966 $3251 0 $4070 $4978 forward @7 unknown T 10 -25 30 15 -20 35 #
+coedge $-1 -1 -1 $-1 $4218 $4071 $5097 $5907 reversed $4219 $-1 #
+coedge $-1 -1 -1 $-1 $4071 $4217 $5081 $5908 reversed $4219 $-1 #
+face $-1 -1 -1 $-1 $5909 $5910 $11 $-1 $1965 reversed single T -5 -20 30 4.9999999999999991 -15 40 F #
+ellipse-curve $-1 -1 -1 $-1 10 -20 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4076 -1.5707963267948966 $5911 -1.047197551196597 $4958 $5912 forward @7 unknown T 7.4999999999999964 -15.669872981077809 17.499999999999996 10 -15 20 #
+point $-1 -1 -1 $-1 10 -15 20 #
+edge $-1 -1 -1 $-1 $5913 1.0471975511965983 $4079 1.5707963267948966 $5878 $5912 forward @7 unknown T 7.5000000000000027 -25 17.500000000000004 10 -24.330127018922195 20 #
+point $-1 -1 -1 $-1 10 -25 20 #
+point $-1 -1 -1 $-1 7.5 -39.330127018922198 -22.500000000000004 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 -10 #
+vertex $-1 -1 -1 $-1 $4181 $5914 #
+straight-curve $-1 -1 -1 $-1 37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4090 $4089 $4098 $5004 reversed $3381 $-1 #
+point $-1 -1 -1 $-1 35 -25.000000000000004 5.0000000000000018 #
+point $-1 -1 -1 $-1 37.500000000000014 -24.330127018922195 7.5000000000000036 #
+face $-1 -1 -1 $-1 $2129 $4095 $11 $-1 $2664 reversed single T 24.999999999999996 -25.000000000000004 -15 35 -20 -4.9999999999999982 F #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $4100 1.0471975511965983 $4178 1.570796326794897 $4098 $3363 forward @7 unknown T 37.499999999999993 -25 2.5000000000000053 40 -24.330127018922195 5.0000000000000044 #
+point $-1 -1 -1 $-1 37.499999999999993 -24.330127018922195 2.500000000000008 #
+vertex $-1 -1 -1 $-1 $4112 $5915 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5038 $5047 $4108 $5009 forward $5916 $-1 #
+edge $-1 -1 -1 $-1 $3329 -1.5707963267948961 $3325 0 $5008 $4144 forward @7 unknown T 25 -25 -30 29.999999999999996 -20 -25 #
+coedge $-1 -1 -1 $-1 $4109 $5917 $3323 $4148 forward $4121 $-1 #
+coedge $-1 -1 -1 $-1 $4152 $4152 $4111 $5012 reversed $5048 $-1 #
+edge $-1 -1 -1 $-1 $5006 -1.5707963267948966 $3336 1.5707963267948966 $4111 $5918 forward @7 unknown T 40 -25 -14.999999999999998 45 -15 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $5919 $5919 $4113 $5014 reversed $5920 $-1 #
+edge $-1 -1 -1 $-1 $4131 1.570796326794897 $4118 4.7123889803846897 $4113 $5921 forward @7 unknown T 39.999999999999993 -25 -24.999999999999996 44.999999999999993 -15 -19.999999999999996 #
+face $-1 -1 -1 $-1 $5922 $5923 $11 $-1 $4210 reversed single T 40 -25 -45 50 -15 -35 F #
+coedge $-1 -1 -1 $-1 $4126 $4116 $5919 $5924 forward $3397 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -25 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $5917 $4120 $5588 $5925 reversed $4121 $-1 #
+edge $-1 -1 -1 $-1 $5926 -37.5 $4122 -27.499999999999989 $4211 $5927 forward @7 unknown T 37.5 -24.330127018922198 -37.5 37.5 -24.330127018922195 -27.499999999999989 #
+point $-1 -1 -1 $-1 37.5 -24.330127018922195 -27.499999999999989 #
+coedge $-1 -1 -1 $-1 $5928 $4126 $4128 $5024 forward $3397 $-1 #
+coedge $-1 -1 -1 $-1 $4128 $4147 $5929 $5930 reversed $3324 $-1 #
+edge $-1 -1 -1 $-1 $4129 27.499999999999986 $5931 37.5 $5022 $5932 forward @7 unknown T 37.499999999999986 -15.669872981077809 -37.5 37.5 -15.669872981077804 -27.499999999999986 #
+point $-1 -1 -1 $-1 37.499999999999986 -15.669872981077804 -27.499999999999986 #
+point $-1 -1 -1 $-1 40 -15 -24.999999999999996 #
+edge $-1 -1 -1 $-1 $4171 12.499999999999995 $5030 22.500000000000004 $4132 $5933 forward @7 unknown T 22.499999999999996 -15.669872981077805 -22.500000000000004 22.5 -15.669872981077804 -12.499999999999995 #
+coedge $-1 -1 -1 $-1 $4134 $5842 $4141 $4145 reversed $5029 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4930 $5934 T 19.999999999999996 -15.669872981077809 -27.500000000000004 25 -15 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $4135 $5935 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -20 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4137 $4136 $4926 $5835 forward $3317 $-1 #
+coedge $-1 -1 -1 $-1 $5936 $4927 $4136 $5034 reversed $5837 $-1 #
+edge $-1 -1 -1 $-1 $3329 1.5707963267948961 $5839 2.0943951023931957 $4136 $5031 forward @7 unknown T 22.499999999999993 -25 -25.000000000000004 25 -24.330127018922191 -22.5 #
+coedge $-1 -1 -1 $-1 $5062 $4164 $4137 $3355 reversed $4170 $-1 #
+coedge $-1 -1 -1 $-1 $5937 $4141 $5938 $5939 forward $4143 $-1 #
+coedge $-1 -1 -1 $-1 $4142 $5937 $5940 $5941 forward $4143 $-1 #
+coedge $-1 -1 -1 $-1 $5942 $5008 $5010 $4148 reversed $5916 $-1 #
+face $-1 -1 -1 $-1 $1780 $4143 $11 $-1 $2194 reversed single T 22.5 -20 -40 30 -15 -25 F #
+vertex $-1 -1 -1 $-1 $5943 $5944 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $5940 $5583 $4147 $5043 forward $5086 $-1 #
+edge $-1 -1 -1 $-1 $5945 -1.5707963267948966 $5044 -6.4931039580273265e-16 $5042 $5946 forward @7 unknown T 30 -20 -40 35 -15.000000000000004 -35 #
+vertex $-1 -1 -1 $-1 $5947 $5948 #
+vertex $-1 -1 -1 $-1 $4150 $5949 #
+coedge $-1 -1 -1 $-1 $5008 $5950 $5936 $4150 forward $5916 $-1 #
+loop $-1 -1 -1 $-1 $5951 $5011 $5952 T 40 -25 -14.999999999999998 45 -15 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -9.9999999999999982 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 5.0000000000000027 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5953 $5954 $11 $-1 $2664 reversed single T -10.000000000000002 -25 -12.500000000000004 -5 -24.330127018922191 -7.5 F #
+loop $-1 -1 -1 $-1 $-1 $5955 $4158 T 4.9999999999999991 -15.669872981077809 -12.500000000000004 10 -15 -7.4999999999999991 unknown #
+straight-curve $-1 -1 -1 $-1 22.5 -15.669872981077805 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077807 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $4924 $5956 $4163 $5056 reversed $4028 $-1 #
+edge $-1 -1 -1 $-1 $5058 -7.4999999999999991 $3382 2.5000000000000049 $4163 $5957 forward @7 unknown T 22.5 -24.330127018922198 -7.4999999999999991 22.500000000000004 -24.330127018922191 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $4164 $5062 $4924 $5830 forward $4170 $-1 #
+vertex $-1 -1 -1 $-1 $5830 $5958 #
+coedge $-1 -1 -1 $-1 $4188 $4166 $5956 $5959 forward $4189 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $5960 $4169 T 10 -25 -15 20 -20 -4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $5057 $5035 $5834 $5961 forward $4170 $-1 #
+edge $-1 -1 -1 $-1 $4043 1.5707963267948966 $4171 2.0943951023931948 $4942 $5962 forward @7 unknown T 20 -15.669872981077805 -12.499999999999995 22.499999999999996 -15 -9.9999999999999982 #
+point $-1 -1 -1 $-1 22.499999999999996 -15.669872981077804 -12.499999999999995 #
+face $-1 -1 -1 $-1 $5963 $5964 $11 $-1 $3659 reversed single T 29.999999999999996 -5.0000000000000009 -9.9999999999999982 37.5 -8.8817841970012523e-16 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $5965 $4173 T 29.999999999999996 -5.0000000000000009 5.0000000000000018 37.500000000000007 -8.8817841970012523e-16 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $5966 $5967 $5968 $5969 reversed $4174 $-1 #
+point $-1 -1 -1 $-1 22.5 -24.330127018922195 -12.499999999999998 #
+loop $-1 -1 -1 $-1 $-1 $5746 $5070 T 50 -25 2.6645352591003757e-15 50 -15 10.000000000000004 unknown #
+face $-1 -1 -1 $-1 $5970 $4177 $11 $-1 $2156 reversed single T 39.999999999999993 -25 2.6645352591003757e-15 50 -15 10.000000000000004 F #
+point $-1 -1 -1 $-1 40 -25 5.0000000000000027 #
+face $-1 -1 -1 $-1 $5971 $4937 $11 $-1 $3328 reversed single T 10 -20 -30 20.000000000000004 -15 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $5882 $4186 $4188 $5076 reversed $4923 $-1 #
+coedge $-1 -1 -1 $-1 $4186 $5881 $4191 $5079 reversed $4923 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $5972 1.5707963267948966 $4190 2.0943951023931948 $4188 $5973 forward @7 unknown T 20 -25 5.0000000000000009 22.499999999999996 -24.330127018922191 7.5 #
+face $-1 -1 -1 $-1 $4184 $4189 $11 $-1 $2156 reversed single T 20 -25 2.5000000000000044 25 -24.330127018922191 7.5000000000000027 F #
+point $-1 -1 -1 $-1 22.499999999999996 -24.330127018922191 7.5 #
+edge $-1 -1 -1 $-1 $2742 -2.0943951023931957 $5090 -1.5707963267948966 $4191 $5974 forward @7 unknown T 20 -25 17.5 22.500000000000004 -24.330127018922191 20 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5975 $4982 $4987 $5908 forward $4197 $-1 #
+point $-1 -1 -1 $-1 37.5 -24.330127018922187 22.500000000000007 #
+point $-1 -1 -1 $-1 37.500000000000007 -24.330127018922198 32.500000000000007 #
+face $-1 -1 -1 $-1 $5976 $5977 $11 $-1 $4210 reversed single T 35 -15.669872981077813 -42.500000000000007 40 -15 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $5583 $4208 T 25 -20 -45 35 -15 -35 unknown #
+coedge $-1 -1 -1 $-1 $4211 $5978 $5979 $5980 forward $3397 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5981 $5916 $11 $-1 $2194 reversed single T 22.5 -25 -40 30 -20 -25 F #
+vertex $-1 -1 -1 $-1 $5982 $5983 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5099 $4503 $4223 $5093 reversed $4505 $-1 #
+edge $-1 -1 -1 $-1 $5094 1.5707963267948966 $4532 2.0943951023931957 $4223 $5984 forward @7 unknown T 20 -25 35 22.500000000000004 -24.330127018922191 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $5907 $5985 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $4984 $4235 $4986 $5907 forward $3434 $-1 #
+coedge $-1 -1 -1 $-1 $4235 $4984 $5434 $5436 reversed $3434 $-1 #
+coedge $-1 -1 -1 $-1 $4504 $5092 $4235 $5100 reversed $4505 $-1 #
+edge $-1 -1 -1 $-1 $4523 6.1232339957367648e-17 $5094 1.5707963267948966 $4235 $5986 forward @7 unknown T 15 -25 35 20 -20 40 #
+edge $-1 -1 -1 $-1 $4977 1.5707963267948966 $4523 3.1415926535897931 $4519 $5987 forward @7 unknown T 10 -20 35 15 -15 40 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5118 $5116 $4238 $5104 reversed $4263 $-1 #
+edge $-1 -1 -1 $-1 $5106 -17.500000000000004 $5107 -7.5 $4238 $5988 forward @7 unknown T -7.5000000000000027 -30.669872981077813 7.5 -7.5 -30.669872981077802 17.500000000000004 #
+coedge $-1 -1 -1 $-1 $4239 $4287 $5118 $5989 forward $4288 $-1 #
+vertex $-1 -1 -1 $-1 $5104 $5990 #
+vertex $-1 -1 -1 $-1 $4243 $5991 #
+coedge $-1 -1 -1 $-1 $4249 $4255 $4305 $5153 reversed $4256 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 4.9999999999999973 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4253 1.0471975511965974 $5992 1.5707963267948966 $4834 $5993 forward @7 unknown T -37.500000000000014 -40 2.4999999999999973 -35 -39.330127018922191 4.9999999999999982 #
+face $-1 -1 -1 $-1 $5114 $4252 $11 $-1 $227 reversed single T -40 -40 2.4999999999999973 -35 -39.330127018922191 7.4999999999999991 F #
+point $-1 -1 -1 $-1 -37.500000000000014 -39.330127018922205 2.4999999999999982 #
+edge $-1 -1 -1 $-1 $5994 -1.5707963267948966 $4257 -1.0471975511965979 $4829 $5993 forward @7 unknown T -37.5 -30.669872981077809 2.4999999999999982 -35 -30 4.9999999999999982 #
+face $-1 -1 -1 $-1 $4854 $4256 $11 $-1 $227 reversed single T -40 -30.669872981077813 2.4999999999999982 -35 -30 7.5000000000000036 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 2.4999999999999982 #
+coedge $-1 -1 -1 $-1 $5103 $4260 $4815 $5754 reversed $4263 $-1 #
+edge $-1 -1 -1 $-1 $4884 -1.5707963267948966 $3466 6.1232339957367648e-17 $4881 $5995 forward @7 unknown T -15.000000000000002 -35 4.9999999999999991 -10.000000000000002 -30 10 #
+coedge $-1 -1 -1 $-1 $4261 $5103 $5105 $5989 reversed $4263 $-1 #
+coedge $-1 -1 -1 $-1 $4319 $5178 $4261 $5120 forward $5162 $-1 #
+edge $-1 -1 -1 $-1 $2844 -6.1232339957367648e-17 $5163 1.5707963267948966 $5119 $5996 forward @7 unknown T -15.000000000000002 -35 15 -10.000000000000002 -30 20 #
+coedge $-1 -1 -1 $-1 $4262 $5997 $5797 $5998 forward $5123 $-1 #
+coedge $-1 -1 -1 $-1 $4265 $4316 $2763 $3463 reversed $5126 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4262 $5999 T -22.500000000000004 -35 4.9999999999999991 -15 -30 20 unknown #
+face $-1 -1 -1 $-1 $3998 $4263 $11 $-1 $2541 reversed single T -15.000000000000002 -35 4.9999999999999991 -7.5 -30 20 F #
+coedge $-1 -1 -1 $-1 $6000 $4265 $6001 $6002 forward $5126 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5122 $4330 T -22.500000000000004 -40 4.9999999999999991 -15 -35 20 unknown #
+vertex $-1 -1 -1 $-1 $6003 $6004 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 4.9999999999999991 0.70710678118654757 0 -0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4770 $4270 $4811 $5751 reversed $4771 $-1 #
+coedge $-1 -1 -1 $-1 $4270 $4769 $4272 $5132 reversed $4771 $-1 #
+straight-curve $-1 -1 -1 $-1 7.4999999999999991 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3914 -2.0943951023931957 $4920 -1.570796326794897 $4272 $6005 forward @7 unknown T 4.9999999999999982 -40 -27.500000000000004 7.4999999999999991 -39.330127018922191 -25 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 5 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 32.500000000000007 #
+edge $-1 -1 -1 $-1 $4289 -2.0943951023931957 $5163 -1.5707963267948966 $4287 $6006 forward @7 unknown T -10.000000000000002 -30.669872981077809 20 -7.5000000000000009 -30 22.500000000000004 #
+point $-1 -1 -1 $-1 -7.5000000000000018 -30.669872981077805 22.500000000000004 #
+edge $-1 -1 -1 $-1 $4292 4.1887902047863923 $5158 4.7123889803846906 $4353 $6007 forward @7 unknown T -37.5 -30.669872981077805 19.999999999999993 -35 -30 22.499999999999993 #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077802 22.499999999999993 #
+edge $-1 -1 -1 $-1 $5150 1.5707963267948957 $4295 2.0943951023931948 $4347 $6007 forward @7 unknown T -37.5 -40 19.999999999999993 -35 -39.330127018922184 22.499999999999996 #
+point $-1 -1 -1 $-1 -37.499999999999993 -39.330127018922184 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $5147 $4297 $6008 $6009 forward $4299 $-1 #
+coedge $-1 -1 -1 $-1 $4298 $5147 $6010 $6011 forward $4299 $-1 #
+edge $-1 -1 -1 $-1 $5992 1.5707963267948966 $4300 2.0943951023931957 $4298 $6012 forward @7 unknown T -37.500000000000007 -40 4.9999999999999982 -35 -39.330127018922191 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $5145 $5144 $6013 $6014 reversed $4299 $-1 #
+face $-1 -1 -1 $-1 $4889 $4299 $11 $-1 $2412 reversed single T -37.500000000000007 -40 4.9999999999999982 -30 -35 19.999999999999996 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -39.330127018922198 7.4999999999999982 #
+vertex $-1 -1 -1 $-1 $4302 $6015 #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -35 19.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5155 $4305 $6016 $6017 forward $4307 $-1 #
+edge $-1 -1 -1 $-1 $4308 4.1887902047863896 $5994 4.7123889803846897 $4305 $6012 forward @7 unknown T -37.500000000000007 -30.669872981077813 4.9999999999999982 -35 -30 7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $4306 $5155 $6018 $6019 forward $4307 $-1 #
+coedge $-1 -1 -1 $-1 $5154 $5152 $5147 $6014 forward $4307 $-1 #
+face $-1 -1 -1 $-1 $4303 $4307 $11 $-1 $2412 reversed single T -37.500000000000007 -35 4.9999999999999982 -30 -30 19.999999999999996 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -30.669872981077813 7.5000000000000027 #
+vertex $-1 -1 -1 $-1 $4310 $6020 #
+face $-1 -1 -1 $-1 $5111 $4830 $11 $-1 $2412 reversed single T -37.500000000000007 -35 -10.000000000000002 -30 -30 4.9999999999999982 F #
+coedge $-1 -1 -1 $-1 $4316 $6000 $6021 $5173 forward $5126 $-1 #
+coedge $-1 -1 -1 $-1 $5178 $4319 $4323 $5168 reversed $5162 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4319 $4534 T -20 -35 15 -10.000000000000002 -30 25 unknown #
+vertex $-1 -1 -1 $-1 $5120 $6022 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6023 $4322 $6024 $5209 forward $4325 $-1 #
+coedge $-1 -1 -1 $-1 $4323 $6023 $6025 $6026 forward $4325 $-1 #
+edge $-1 -1 -1 $-1 $4331 1.5707963267948966 $2841 3.1415926535897931 $4323 $4329 forward @7 unknown T -20 -35 20 -15 -30 25 #
+face $-1 -1 -1 $-1 $6027 $4325 $11 $-1 $1595 reversed single T -22.500000000000004 -35 20 -15 -30 35 F #
+coedge $-1 -1 -1 $-1 $5206 $4327 $6028 $6029 forward $3697 $-1 #
+coedge $-1 -1 -1 $-1 $6021 $6030 $4327 $5172 reversed $6031 $-1 #
+edge $-1 -1 -1 $-1 $4328 1.5707963267948966 $6032 2.0943951023931957 $4327 $6033 forward @7 unknown T -22.500000000000004 -40 20 -20 -39.330127018922191 22.500000000000004 #
+edge $-1 -1 -1 $-1 $6034 1.0471975511965974 $4328 1.5707963267948966 $5160 $6035 forward @7 unknown T -22.500000000000004 -40 17.499999999999996 -20 -39.330127018922191 20 #
+point $-1 -1 -1 $-1 -20 -40 20 #
+edge $-1 -1 -1 $-1 $4331 -1.5707963267948966 $6036 -1.047197551196597 $5177 $6035 forward @7 unknown T -22.500000000000004 -30.669872981077809 17.499999999999996 -20 -30 20 #
+point $-1 -1 -1 $-1 -20 -30 20 #
+coedge $-1 -1 -1 $-1 $6037 $4332 $6038 $5175 forward $5123 $-1 #
+coedge $-1 -1 -1 $-1 $5119 $5161 $4332 $3542 reversed $5162 $-1 #
+coedge $-1 -1 -1 $-1 $4366 $4552 $4335 $5180 forward $937 $-1 #
+edge $-1 -1 -1 $-1 $5191 2.617993877991494 $5184 6.8067840827778845 $5179 $6039 forward @7 unknown T -45 -40 50 -37.5 -30 50 #
+coedge $-1 -1 -1 $-1 $6040 $4336 $4338 $5186 forward $5183 $-1 #
+coedge $-1 -1 -1 $-1 $4336 $6041 $4366 $5211 reversed $5183 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6041 $4695 T -37.500000000000007 -35 35 -30 -30 50 unknown #
+vertex $-1 -1 -1 $-1 $5211 $6042 #
+edge $-1 -1 -1 $-1 $4339 4.1887902047863896 $5205 4.7123889803846897 $5181 $6043 forward @7 unknown T -37.500000000000007 -30.669872981077809 35 -35 -30 37.500000000000007 #
+point $-1 -1 -1 $-1 -37.500000000000007 -30.669872981077805 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $6044 $4341 $4552 $5453 reversed $5190 $-1 #
+coedge $-1 -1 -1 $-1 $4341 $6045 $4343 $5193 forward $5190 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6044 $5457 T -37.5 -40 35 -30 -35 50 unknown #
+vertex $-1 -1 -1 $-1 $4342 $6046 #
+edge $-1 -1 -1 $-1 $5199 1.5707963267948966 $4344 2.0943951023931948 $5189 $6043 forward @7 unknown T -37.5 -40 35 -35 -39.330127018922191 37.5 #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922198 37.5 #
+coedge $-1 -1 -1 $-1 $5197 $4346 $6047 $6048 forward $4348 $-1 #
+coedge $-1 -1 -1 $-1 $4347 $5197 $6049 $6050 forward $4348 $-1 #
+coedge $-1 -1 -1 $-1 $5196 $5195 $6051 $6052 reversed $4348 $-1 #
+face $-1 -1 -1 $-1 $5999 $4348 $11 $-1 $2412 reversed single T -37.500000000000014 -40 19.999999999999993 -29.999999999999993 -35 35 F #
+vertex $-1 -1 -1 $-1 $4350 $6053 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5203 $4353 $6054 $6055 forward $4355 $-1 #
+coedge $-1 -1 -1 $-1 $4354 $5203 $6056 $6057 forward $4355 $-1 #
+coedge $-1 -1 -1 $-1 $5202 $5201 $5197 $6052 forward $4355 $-1 #
+face $-1 -1 -1 $-1 $4351 $4355 $11 $-1 $2412 reversed single T -37.5 -35 19.999999999999993 -29.999999999999993 -30 35 F #
+vertex $-1 -1 -1 $-1 $4357 $6058 #
+coedge $-1 -1 -1 $-1 $4360 $5170 $4541 $4546 forward $3697 $-1 #
+coedge $-1 -1 -1 $-1 $4781 $4363 $6059 $6060 reversed $3576 $-1 #
+edge $-1 -1 -1 $-1 $6061 42.500000000000014 $4577 50 $4576 $6062 forward @7 unknown T -7.5000000000000027 -30.669872981077813 -50 -7.5000000000000009 -30.669872981077809 -42.500000000000014 #
+edge $-1 -1 -1 $-1 $4364 -1.5707963267948966 $6063 -1.0471975511965974 $5166 $5449 forward @7 unknown T -22.500000000000004 -30.669872981077809 32.5 -20 -30 35 #
+point $-1 -1 -1 $-1 -20 -30 35 #
+edge $-1 -1 -1 $-1 $5184 -2.0943951023931948 $5215 0 $4366 $6064 forward @7 unknown T -37.5 -35 50 -30 -30 50 #
+coedge $-1 -1 -1 $-1 $6065 $4367 $6041 $6066 reversed $5214 $-1 #
+coedge $-1 -1 -1 $-1 $4367 $6067 $4369 $5217 reversed $5214 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5213 $6068 T -30.000000000000004 -35 35 -22.5 -30 50 unknown #
+vertex $-1 -1 -1 $-1 $5453 $6069 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $4370 -50 $6070 -37.500000000000007 $4369 $6071 forward @7 unknown T -22.500000000000004 -30.669872981077809 37.500000000000007 -22.5 -30.669872981077805 50 #
+point $-1 -1 -1 $-1 -22.5 -30.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $4372 $4371 $6072 $6073 forward $2896 $-1 #
+coedge $-1 -1 -1 $-1 $5760 $6074 $4371 $5221 reversed $4826 $-1 #
+edge $-1 -1 -1 $-1 $5228 -50 $6075 50 $5220 $6076 forward @7 unknown T -50 50 50 50 50 50 #
+coedge $-1 -1 -1 $-1 $6077 $6078 $4372 $5223 reversed $6079 $-1 #
+edge $-1 -1 -1 $-1 $6080 -50 $5227 50 $5222 $6081 forward @7 unknown T -50 -50 50 50 -50 50 #
+coedge $-1 -1 -1 $-1 $6082 $4373 $6078 $6083 forward $5226 $-1 #
+coedge $-1 -1 -1 $-1 $4373 $6082 $5760 $6084 reversed $5226 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5224 $1558 T 50 -50 -50 50 50 50 unknown #
+vertex $-1 -1 -1 $-1 $4374 $6085 #
+vertex $-1 -1 -1 $-1 $4374 $6086 #
+straight-curve $-1 -1 -1 $-1 50 0 50 0 1 0 I I #
+coedge $-1 -1 -1 $-1 $6087 $4375 $6088 $5251 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $6089 $6090 $4375 $5232 reversed $6091 $-1 #
+edge $-1 -1 -1 $-1 $5236 2.617993877991494 $4384 4.7123889803846897 $4375 $6092 forward @7 unknown T 30 35 50 37.5 40 50 #
+coedge $-1 -1 -1 $-1 $6093 $4376 $4382 $5249 forward $5235 $-1 #
+coedge $-1 -1 -1 $-1 $4376 $6094 $6089 $6095 forward $5235 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5233 $6096 T 37.5 35 35 45 45 50 unknown #
+vertex $-1 -1 -1 $-1 $6095 $6097 #
+ellipse-curve $-1 -1 -1 $-1 40 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4378 $6098 $6099 $6100 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $6101 $6102 $4378 $5240 reversed $6103 $-1 #
+edge $-1 -1 -1 $-1 $6104 -1.5707963267948966 $5244 0.52359877559829826 $4378 $6105 forward @7 unknown T 15.000000000000002 40 50 22.5 45 50 #
+coedge $-1 -1 -1 $-1 $6106 $4379 $6102 $6107 forward $5243 $-1 #
+coedge $-1 -1 -1 $-1 $4379 $6108 $6109 $5247 forward $5243 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5242 $6110 T 22.5 40 35 30 45 50 unknown #
+vertex $-1 -1 -1 $-1 $4380 $6111 #
+ellipse-curve $-1 -1 -1 $-1 25 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5248 $4381 $6112 $6113 reversed $4383 $-1 #
+edge $-1 -1 -1 $-1 $6114 40 $4384 50 $5242 $6115 forward @7 unknown T 30 40 40 30 40 50 #
+coedge $-1 -1 -1 $-1 $4382 $5246 $6116 $6117 reversed $4383 $-1 #
+edge $-1 -1 -1 $-1 $4385 -50 $6118 -37.500000000000007 $5233 $6119 forward @7 unknown T 37.5 44.330127018922191 37.500000000000007 37.5 44.330127018922191 50 #
+face $-1 -1 -1 $-1 $6120 $4383 $11 $-1 $6121 reversed single T 30 40 35 37.5 45 50 F #
+edge $-1 -1 -1 $-1 $4384 0 $6122 2.0943951023931957 $5230 $5245 forward @7 unknown T 22.5 35 50 30 40 50 #
+point $-1 -1 -1 $-1 30 40 50 #
+point $-1 -1 -1 $-1 37.5 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $6123 $4387 $6124 $6125 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $5276 $6126 $4387 $4408 reversed $6127 $-1 #
+coedge $-1 -1 -1 $-1 $6128 $4388 $4391 $5262 reversed $5258 $-1 #
+coedge $-1 -1 -1 $-1 $4388 $6129 $3595 $4404 forward $5258 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5257 $6130 T 30 19.999999999999996 35 37.5 25 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6131 $4390 $6132 $6133 forward $4392 $-1 #
+coedge $-1 -1 -1 $-1 $4391 $6131 $6134 $6135 forward $4392 $-1 #
+edge $-1 -1 -1 $-1 $6136 37.5 $4393 50 $4391 $6137 forward @7 unknown T 37.5 20.669872981077805 37.5 37.5 20.669872981077805 50 #
+face $-1 -1 -1 $-1 $6138 $4392 $11 $-1 $6139 reversed single T 37.5 20 35 45 30 50 F #
+point $-1 -1 -1 $-1 37.5 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $4395 $6140 $6141 $6142 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $6143 $6144 $4395 $5267 reversed $6145 $-1 #
+edge $-1 -1 -1 $-1 $6146 -2.0943951023931948 $5271 0 $4395 $6147 forward @7 unknown T 7.5000000000000009 25 50 15 30 50 #
+coedge $-1 -1 -1 $-1 $6148 $4396 $6144 $6149 reversed $5270 $-1 #
+coedge $-1 -1 -1 $-1 $4396 $6150 $4398 $5274 reversed $5270 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5269 $6151 T 15 25 35 22.500000000000004 30 50 unknown #
+vertex $-1 -1 -1 $-1 $6152 $6153 #
+ellipse-curve $-1 -1 -1 $-1 20 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5275 $4398 $6154 $6155 forward $4400 $-1 #
+edge $-1 -1 -1 $-1 $4401 -50 $6156 -37.500000000000007 $4398 $6157 forward @7 unknown T 22.5 29.330127018922195 37.500000000000007 22.500000000000004 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $4399 $5273 $6158 $6159 forward $4400 $-1 #
+coedge $-1 -1 -1 $-1 $6160 $5255 $5257 $4404 reversed $6127 $-1 #
+face $-1 -1 -1 $-1 $6161 $4400 $11 $-1 $6162 reversed single T 22.499999999999996 25 35 30 30 50 F #
+point $-1 -1 -1 $-1 22.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $6158 $6163 $4403 $5280 forward $6164 $-1 #
+edge $-1 -1 -1 $-1 $6165 -1.5707963267948966 $5281 -6.4931039580273226e-16 $5279 $6166 forward @7 unknown T 30 25 35 35 29.999999999999996 40 #
+vertex $-1 -1 -1 $-1 $6167 $6168 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6169 $6132 $4405 $5284 forward $6170 $-1 #
+edge $-1 -1 -1 $-1 $5285 -2.0943951023931957 $6165 -1.5707963267948966 $5283 $6171 forward @7 unknown T 35 29.330127018922187 35 37.5 29.999999999999996 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $6133 $6172 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $6173 $6174 $11 $-1 $5288 reversed single T 30 25 -50 37.5 29.999999999999996 -40 F #
+cone-surface $-1 -1 -1 $-1 35 24.999999999999996 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $6175 $6176 #
+coedge $-1 -1 -1 $-1 $6177 $4411 $6178 $5319 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $6179 $6180 $4411 $5292 reversed $6181 $-1 #
+edge $-1 -1 -1 $-1 $4446 2.617993877991494 $4428 4.7123889803846897 $4411 $6182 forward @7 unknown T 15 4.9999999999999982 50 22.5 10 50 #
+coedge $-1 -1 -1 $-1 $4412 $6183 $6179 $5342 forward $5294 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4433 $5305 T 22.5 5 35 30 10 50 unknown #
+coedge $-1 -1 -1 $-1 $5296 $4413 $6184 $6185 reversed $4415 $-1 #
+coedge $-1 -1 -1 $-1 $4414 $5295 $6186 $6187 reversed $4415 $-1 #
+face $-1 -1 -1 $-1 $3621 $4415 $11 $-1 $4445 reversed single T 30 4.9999999999999982 35 37.5 10 50 F #
+coedge $-1 -1 -1 $-1 $4418 $4417 $6188 $6189 forward $3606 $-1 #
+coedge $-1 -1 -1 $-1 $4440 $6190 $4417 $5300 reversed $5337 $-1 #
+edge $-1 -1 -1 $-1 $4442 4.1887902047863905 $6191 4.7123889803846897 $4417 $6192 forward @7 unknown T 37.5 14.330127018922191 35 40 15 37.5 #
+coedge $-1 -1 -1 $-1 $6193 $6184 $4418 $5302 reversed $6194 $-1 #
+edge $-1 -1 -1 $-1 $6195 1.5707963267948966 $5303 2.0943951023931948 $4418 $6192 forward @7 unknown T 37.5 5 35 40 5.6698729810778064 37.5 #
+vertex $-1 -1 -1 $-1 $6185 $6196 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $6197 $5294 $11 $-1 $5329 reversed single T 22.5 5 35 30 10 50 F #
+cone-surface $-1 -1 -1 $-1 40 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $4422 $6198 $6199 $6200 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $6201 $6202 $4422 $5309 reversed $6203 $-1 #
+edge $-1 -1 -1 $-1 $6204 -1.5707963267948966 $5313 0.52359877559829848 $4422 $6205 forward @7 unknown T 0 10 50 7.5 15 50 #
+coedge $-1 -1 -1 $-1 $6206 $4423 $6202 $6207 forward $5312 $-1 #
+coedge $-1 -1 -1 $-1 $4423 $6208 $6209 $5316 forward $5312 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5311 $6210 T 7.5 10 35 15 15 50 unknown #
+vertex $-1 -1 -1 $-1 $4424 $6211 #
+ellipse-curve $-1 -1 -1 $-1 10 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5317 $4425 $6212 $6213 reversed $4427 $-1 #
+edge $-1 -1 -1 $-1 $6214 40 $4428 50 $5311 $6215 forward @7 unknown T 15 10 40 15 10 50 #
+coedge $-1 -1 -1 $-1 $4426 $5315 $6216 $6217 reversed $4427 $-1 #
+face $-1 -1 -1 $-1 $6218 $4427 $11 $-1 $6219 reversed single T 15 10 35 22.5 14.999999999999998 50 F #
+edge $-1 -1 -1 $-1 $4428 0 $6220 2.0943951023931957 $5290 $5314 forward @7 unknown T 7.4999999999999991 5 50 15 10 50 #
+point $-1 -1 -1 $-1 15 10 50 #
+coedge $-1 -1 -1 $-1 $6216 $6221 $4430 $5322 reversed $6222 $-1 #
+edge $-1 -1 -1 $-1 $5323 4.1887902047863905 $6223 4.7123889803846897 $4430 $6224 forward @7 unknown T 22.499999999999996 14.330127018922191 35 25 15 37.5 #
+vertex $-1 -1 -1 $-1 $5322 $6225 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $6226 $4436 $4432 $5326 reversed $5331 $-1 #
+edge $-1 -1 -1 $-1 $6223 1.5707963267948966 $4438 3.1415926535897931 $4432 $6227 forward @7 unknown T 25 10 35 30 15 40 #
+coedge $-1 -1 -1 $-1 $6183 $4433 $6228 $5334 forward $5294 $-1 #
+face $-1 -1 -1 $-1 $6229 $6230 $11 $-1 $6231 reversed single T 7.4999999999999991 5 35 15 10 50 F #
+cone-surface $-1 -1 -1 $-1 25 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $4436 $6226 $6232 $6233 forward $5331 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4436 $6234 T 25 10 30 35 15 40 unknown #
+vertex $-1 -1 -1 $-1 $6233 $6235 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+edge $-1 -1 -1 $-1 $4438 3.1415926535897931 $6236 4.7123889803846897 $5327 $6227 forward @7 unknown T 25 5 35 30 10 40 #
+point $-1 -1 -1 $-1 30 10 40 #
+coedge $-1 -1 -1 $-1 $6190 $4440 $6237 $6238 forward $5337 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4440 $6239 T 35 14.330127018922191 32.5 40 15 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 14.330127018922193 37.5 #
+face $-1 -1 -1 $-1 $6240 $6241 $11 $-1 $4445 reversed single T 29.999999999999996 10 -40 37.5 14.999999999999998 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $6242 $4444 T 30 10 -50 37.5 14.999999999999998 -40 unknown #
+edge $-1 -1 -1 $-1 $6243 37.5 $4446 50 $5293 $6244 forward @7 unknown T 22.5 5.6698729810778055 37.5 22.500000000000007 5.6698729810778064 50 #
+point $-1 -1 -1 $-1 22.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $6245 $4447 $6246 $6247 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $5376 $6248 $4447 $4476 reversed $5397 $-1 #
+coedge $-1 -1 -1 $-1 $6249 $4448 $4450 $4499 reversed $5348 $-1 #
+coedge $-1 -1 -1 $-1 $4448 $6250 $3639 $4473 forward $5348 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5347 $6251 T 15 -10 35 22.500000000000004 -4.9999999999999991 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $4450 $4484 $6252 $6253 forward $4451 $-1 #
+coedge $-1 -1 -1 $-1 $4458 $6254 $4452 $5352 forward $5361 $-1 #
+edge $-1 -1 -1 $-1 $6255 1.5707963267948966 $4460 2.0943951023931957 $5351 $6256 forward @7 unknown T 35 -10.000000000000002 35 37.5 -9.3301270189221928 37.5 #
+coedge $-1 -1 -1 $-1 $6257 $5395 $4453 $5354 forward $6258 $-1 #
+edge $-1 -1 -1 $-1 $3652 -4.7167471186270725e-16 $6255 1.5707963267948966 $5353 $6259 forward @7 unknown T 30 -10.000000000000002 35 35 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $6260 $6260 $4455 $5356 reversed $6261 $-1 #
+edge $-1 -1 -1 $-1 $5358 1.5707963267948966 $5362 4.7123889803846897 $4455 $6262 forward @7 unknown T 40 -10 35 45 0 40 #
+coedge $-1 -1 -1 $-1 $4456 $4493 $6263 $6264 reversed $4494 $-1 #
+vertex $-1 -1 -1 $-1 $6264 $6265 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6254 $4458 $6266 $6267 reversed $5361 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5351 $6268 T 35 -10.000000000000002 32.5 40 -9.3301270189221928 37.5 unknown #
+vertex $-1 -1 -1 $-1 $6267 $6269 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221945 37.5 #
+face $-1 -1 -1 $-1 $5401 $6270 $11 $-1 $4463 reversed single T 37.5 -10 20.000000000000004 45 0 35 F #
+coedge $-1 -1 -1 $-1 $4464 $6271 $6272 $6273 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $6274 $6275 $4464 $5367 reversed $6276 $-1 #
+edge $-1 -1 -1 $-1 $6277 -2.0943951023931948 $5371 0 $4464 $6278 forward @7 unknown T -7.4999999999999991 -5 50 0 0 50 #
+coedge $-1 -1 -1 $-1 $6279 $4465 $6275 $6280 reversed $5370 $-1 #
+coedge $-1 -1 -1 $-1 $4465 $6281 $4467 $5374 reversed $5370 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5369 $6282 T 0 -5 35 7.5000000000000009 0 50 unknown #
+vertex $-1 -1 -1 $-1 $6283 $6284 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5375 $4467 $6285 $6286 forward $4469 $-1 #
+edge $-1 -1 -1 $-1 $4470 -50 $6287 -37.499999999999993 $4467 $6288 forward @7 unknown T 7.5 -0.66987298107780635 37.499999999999993 7.5000000000000009 -0.66987298107780624 50 #
+coedge $-1 -1 -1 $-1 $4468 $5373 $6289 $6290 forward $4469 $-1 #
+coedge $-1 -1 -1 $-1 $6291 $5345 $5347 $4473 reversed $5397 $-1 #
+face $-1 -1 -1 $-1 $6292 $4469 $11 $-1 $5398 reversed single T 7.4999999999999991 -5 35 15 0 50 F #
+point $-1 -1 -1 $-1 7.5 -0.66987298107780635 50 #
+coedge $-1 -1 -1 $-1 $6289 $6293 $4472 $5380 forward $6294 $-1 #
+edge $-1 -1 -1 $-1 $6295 -1.5707963267948966 $5381 -2.9403902792268234e-16 $5379 $6296 forward @7 unknown T 15 -4.9999999999999991 35 20 -8.8817841970012523e-16 40 #
+vertex $-1 -1 -1 $-1 $6297 $6298 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6299 $4478 $4474 $5384 forward $5389 $-1 #
+edge $-1 -1 -1 $-1 $4480 -2.0943951023931966 $6295 -1.5707963267948966 $5383 $6300 forward @7 unknown T 20 -0.66987298107781168 35 22.500000000000004 -8.8817841970012523e-16 37.500000000000007 #
+face $-1 -1 -1 $-1 $6301 $6302 $11 $-1 $5386 reversed single T 15 -5.0000000000000009 -50 22.5 -8.8817841970012523e-16 -40 F #
+cone-surface $-1 -1 -1 $-1 20 -5.0000000000000009 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $6303 $6304 #
+coedge $-1 -1 -1 $-1 $4478 $6299 $6305 $6306 reversed $5389 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5383 $6307 T 20 -0.66987298107781168 32.5 25 0 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $6306 $6308 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -0.66987298107780902 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $4487 $4482 $6309 $6310 reversed $4488 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5353 $6311 $4484 $4491 reversed $6258 $-1 #
+face $-1 -1 -1 $-1 $6312 $6313 $11 $-1 $4486 reversed single T 22.499999999999993 -5.0000000000000009 20 30 0 35 F #
+loop $-1 -1 -1 $-1 $-1 $5376 $4485 T 7.4999999999999991 -10 35 15 -4.9999999999999991 50 unknown #
+cone-surface $-1 -1 -1 $-1 10 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $5967 $5404 $4487 $5400 reversed $4174 $-1 #
+edge $-1 -1 -1 $-1 $6314 2.9403902792268234e-16 $4489 1.5707963267948966 $4487 $6315 forward @7 unknown T 30 -5 30 35 -1.7763568394002505e-15 35 #
+face $-1 -1 -1 $-1 $6316 $4488 $11 $-1 $6317 reversed single T 25 -5 30 35 0 40 F #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 35 #
+vertex $-1 -1 -1 $-1 $6318 $6319 #
+coedge $-1 -1 -1 $-1 $5399 $6320 $4493 $5405 reversed $4174 $-1 #
+edge $-1 -1 -1 $-1 $4489 1.5707963267948966 $6321 2.0943951023931957 $4493 $6322 forward @7 unknown T 35 -0.6698729810778099 32.5 37.5 -1.7763568394002505e-15 35 #
+face $-1 -1 -1 $-1 $6323 $4494 $11 $-1 $6317 reversed single T 35 -0.66987298107781257 32.5 40 0 37.500000000000007 F #
+face $-1 -1 -1 $-1 $4623 $6324 $11 $-1 $3659 reversed single T 29.999999999999996 -10.000000000000002 -40 37.5 -4.9999999999999991 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $6325 $4497 T 29.999999999999996 -5.0000000000000009 -40 37.500000000000007 -1.7763568394002505e-15 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $6326 $4603 $4606 $5520 reversed $4498 $-1 #
+vertex $-1 -1 -1 $-1 $6327 $6328 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6329 $4501 $6330 $5428 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $6331 $6332 $4501 $5414 reversed $6333 $-1 #
+edge $-1 -1 -1 $-1 $4526 2.617993877991494 $4515 4.7123889803846897 $4501 $6334 forward @7 unknown T -8.8817841970012523e-16 -25 50 7.5 -20 50 #
+coedge $-1 -1 -1 $-1 $4502 $6335 $6331 $5440 forward $4528 $-1 #
+face $-1 -1 -1 $-1 $3685 $4505 $11 $-1 $1477 reversed single T 15 -25 35 22.500000000000004 -20 50 F #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4509 $6336 $6337 $6338 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $6339 $6340 $4509 $5420 reversed $6341 $-1 #
+edge $-1 -1 -1 $-1 $6342 -1.5707963267948966 $5422 0.52359877559829893 $4509 $6343 forward @7 unknown T -15.000000000000002 -20 50 -7.5000000000000009 -15 50 #
+coedge $-1 -1 -1 $-1 $6344 $4510 $6340 $6345 forward $3821 $-1 #
+vertex $-1 -1 -1 $-1 $4511 $6346 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5426 $4512 $6347 $6348 reversed $4514 $-1 #
+edge $-1 -1 -1 $-1 $6349 40 $4515 50 $4697 $6350 forward @7 unknown T -8.8817841970012523e-16 -20 40 0 -20 50 #
+coedge $-1 -1 -1 $-1 $4513 $5424 $6351 $6352 reversed $4514 $-1 #
+face $-1 -1 -1 $-1 $6353 $4514 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 35 7.5000000000000009 -15 50 F #
+edge $-1 -1 -1 $-1 $4515 0 $6354 2.0943951023931957 $5412 $5423 forward @7 unknown T -7.5000000000000009 -25 50 0 -20 50 #
+point $-1 -1 -1 $-1 0 -20 50 #
+coedge $-1 -1 -1 $-1 $6351 $4975 $4517 $5431 reversed $5893 $-1 #
+edge $-1 -1 -1 $-1 $5432 4.1887902047863914 $4977 4.7123889803846897 $4517 $6355 forward @7 unknown T 7.5000000000000009 -15.669872981077807 35 10 -15 37.5 #
+vertex $-1 -1 -1 $-1 $5431 $6356 #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $6335 $4520 $5098 $5436 forward $4528 $-1 #
+face $-1 -1 -1 $-1 $4073 $5652 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 35 0 -20 50 F #
+edge $-1 -1 -1 $-1 $4523 3.1415926535897931 $5906 4.7123889803846897 $5434 $5987 forward @7 unknown T 10 -25 35 15 -20 40 #
+point $-1 -1 -1 $-1 15 -20 40 #
+face $-1 -1 -1 $-1 $6357 $6358 $11 $-1 $1477 reversed single T 15 -20 -40 22.500000000000004 -15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $6359 $4525 T 15 -20 -50 22.500000000000004 -15 -40 unknown #
+edge $-1 -1 -1 $-1 $6360 37.500000000000007 $4526 50 $5415 $6361 forward @7 unknown T 7.5 -24.330127018922191 37.500000000000007 7.5000000000000018 -24.330127018922191 50 #
+point $-1 -1 -1 $-1 7.5 -24.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $4649 $4531 $6362 $6363 reversed $3693 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $4542 $4541 $6364 $6365 forward $4543 $-1 #
+edge $-1 -1 -1 $-1 $6366 1.5707963267948966 $4544 2.0943951023931957 $4542 $6367 forward @7 unknown T -25.000000000000004 -40 35 -22.500000000000004 -39.330127018922191 37.500000000000007 #
+face $-1 -1 -1 $-1 $6368 $4543 $11 $-1 $388 reversed single T -25.000000000000004 -40 32.5 -20 -39.330127018922191 37.500000000000007 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $4546 $6369 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5451 $4548 $6370 $6371 reversed $4550 $-1 #
+coedge $-1 -1 -1 $-1 $4549 $5450 $5212 $6066 forward $4550 $-1 #
+face $-1 -1 -1 $-1 $6068 $4550 $11 $-1 $3872 reversed single T -30.000000000000004 -40 35 -22.5 -35 50 F #
+edge $-1 -1 -1 $-1 $5215 0 $5191 2.0943951023931957 $4552 $6064 forward @7 unknown T -37.5 -40 50 -30 -35 50 #
+coedge $-1 -1 -1 $-1 $6372 $6024 $4555 $5456 reversed $6373 $-1 #
+edge $-1 -1 -1 $-1 $6070 4.1887902047863905 $4364 4.7123889803846897 $4555 $4545 forward @7 unknown T -22.500000000000004 -30.669872981077809 35 -20 -30 37.500000000000007 #
+face $-1 -1 -1 $-1 $5169 $5190 $11 $-1 $2412 reversed single T -37.5 -40 35 -30 -35 50 F #
+vertex $-1 -1 -1 $-1 $5462 $6374 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5825 $4567 $11 $-1 $756 reversed single T 4.9999999999999982 -40 -42.500000000000007 10 -39.330127018922191 -37.500000000000007 F #
+coedge $-1 -1 -1 $-1 $5826 $6375 $4560 $5462 forward $5753 $-1 #
+edge $-1 -1 -1 $-1 $4764 -6.1232339957367648e-17 $5458 1.5707963267948966 $5461 $6376 forward @7 unknown T -1.7763568394002505e-15 -35 -45 4.9999999999999982 -30 -40 #
+coedge $-1 -1 -1 $-1 $4561 $4582 $4763 $5712 reversed $4562 $-1 #
+edge $-1 -1 -1 $-1 $4563 -2.0943951023931957 $5718 -1.5707963267948966 $4566 $6377 forward @7 unknown T 4.9999999999999982 -40 -42.500000000000007 7.4999999999999991 -39.330127018922191 -40 #
+face $-1 -1 -1 $-1 $1386 $4562 $11 $-1 $2073 reversed single T -1.7763568394002505e-15 -40 -50 7.4999999999999991 -35 -40 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -39.330127018922198 -42.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5470 $4575 $6375 $5713 forward $4568 $-1 #
+coedge $-1 -1 -1 $-1 $4576 $5469 $6378 $6379 forward $4568 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 -50 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6380 $6381 $6082 $6382 forward $4584 $-1 #
+coedge $-1 -1 -1 $-1 $6383 $4585 $6384 $6385 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $4585 $6386 $6387 $6388 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $6389 $6390 $4585 $5477 reversed $6391 $-1 #
+edge $-1 -1 -1 $-1 $6392 1.5707963267948966 $6393 3.6651914291880923 $4585 $6394 forward @7 unknown T 30 35 -50 37.5 40 -50 #
+coedge $-1 -1 -1 $-1 $6395 $4586 $6396 $6397 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $6398 $6399 $4586 $5480 reversed $6400 $-1 #
+edge $-1 -1 -1 $-1 $5488 -2.0943951023931948 $6401 2.0943951023931948 $4586 $6402 forward @7 unknown T 37.5 20 -50 45 30 -50 #
+coedge $-1 -1 -1 $-1 $4587 $6403 $6404 $6405 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $6406 $6407 $4587 $5483 reversed $6408 $-1 #
+edge $-1 -1 -1 $-1 $6409 -2.0943951023931948 $5487 0 $4587 $6410 forward @7 unknown T 22.5 20 -50 30 25 -50 #
+coedge $-1 -1 -1 $-1 $6411 $4588 $6412 $6413 forward $5486 $-1 #
+coedge $-1 -1 -1 $-1 $4588 $6414 $6398 $6415 reversed $5486 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5485 $6416 T 30 19.999999999999996 -50 37.500000000000007 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $6417 $6418 #
+vertex $-1 -1 -1 $-1 $5480 $6419 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6420 $4590 $6421 $5512 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $6242 $5507 $4590 $5492 reversed $5341 $-1 #
+edge $-1 -1 -1 $-1 $5496 -0.52359877559829893 $4599 1.5707963267948961 $4590 $6422 forward @7 unknown T 30 10 -50 37.5 14.999999999999998 -50 #
+coedge $-1 -1 -1 $-1 $6423 $4591 $4597 $5510 forward $5495 $-1 #
+coedge $-1 -1 -1 $-1 $4591 $6424 $6242 $6425 forward $5495 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5493 $6426 T 37.5 5 -50 45 15 -40 unknown #
+vertex $-1 -1 -1 $-1 $6425 $6427 #
+ellipse-curve $-1 -1 -1 $-1 40 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4593 $6428 $6429 $6430 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $6431 $6432 $4593 $5500 reversed $6433 $-1 #
+edge $-1 -1 -1 $-1 $6434 1.5707963267948961 $5504 3.6651914291880923 $4593 $6435 forward @7 unknown T 15 4.9999999999999982 -50 22.5 10 -50 #
+coedge $-1 -1 -1 $-1 $6436 $4594 $6432 $6437 forward $5503 $-1 #
+coedge $-1 -1 -1 $-1 $4594 $6438 $4596 $5508 reversed $5503 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5502 $6439 T 22.5 5 -50 30 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $4595 $6440 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5509 $4596 $6441 $6442 reversed $4598 $-1 #
+coedge $-1 -1 -1 $-1 $5491 $6443 $6444 $5508 reversed $5341 $-1 #
+edge $-1 -1 -1 $-1 $4599 -50 $6445 -45 $6444 $6446 forward @7 unknown T 30 10 -50 30 10 -45 #
+coedge $-1 -1 -1 $-1 $4597 $5506 $6447 $6448 reversed $4598 $-1 #
+edge $-1 -1 -1 $-1 $4600 -50 $6449 -42.5 $5493 $6450 forward @7 unknown T 37.5 5.6698729810778064 -50 37.500000000000007 5.6698729810778064 -42.5 #
+face $-1 -1 -1 $-1 $4420 $4598 $11 $-1 $4445 reversed single T 30 4.9999999999999982 -50 37.500000000000007 10 -40 F #
+edge $-1 -1 -1 $-1 $4599 0 $6451 2.0943951023931948 $5490 $5505 forward @7 unknown T 22.5 10 -50 30 15 -50 #
+point $-1 -1 -1 $-1 30 10 -50 #
+point $-1 -1 -1 $-1 37.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $6452 $4602 $6453 $6454 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $5539 $6455 $4602 $4624 reversed $6456 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6457 $4605 $6458 $6459 forward $4607 $-1 #
+coedge $-1 -1 -1 $-1 $4606 $6457 $6460 $6461 forward $4607 $-1 #
+edge $-1 -1 -1 $-1 $6462 42.5 $4608 50 $4606 $6463 forward @7 unknown T 37.5 -0.66987298107780924 -50 37.5 -0.66987298107780724 -42.5 #
+face $-1 -1 -1 $-1 $6464 $4607 $11 $-1 $4463 reversed single T 37.5 -10 -50 45 0 -40 F #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780724 -50 #
+coedge $-1 -1 -1 $-1 $4610 $6465 $6466 $6467 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $6468 $6469 $4610 $5525 reversed $6470 $-1 #
+edge $-1 -1 -1 $-1 $6471 -2.0943951023931948 $5529 0 $4610 $6472 forward @7 unknown T 7.5 -10 -50 15 -5 -50 #
+coedge $-1 -1 -1 $-1 $6473 $4611 $6474 $6475 forward $5528 $-1 #
+coedge $-1 -1 -1 $-1 $4611 $6476 $4613 $5532 reversed $5528 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5527 $6477 T 15 -10 -50 22.500000000000004 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $6478 $6479 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5533 $4613 $6480 $6481 forward $4615 $-1 #
+edge $-1 -1 -1 $-1 $4616 -50 $6482 -42.500000000000007 $4613 $6483 forward @7 unknown T 22.5 -9.3301270189221945 -50 22.500000000000004 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $4614 $5531 $6484 $6485 forward $4615 $-1 #
+face $-1 -1 -1 $-1 $6486 $4615 $11 $-1 $4486 reversed single T 22.5 -10 -50 30 -5 -40 F #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221945 -50 #
+coedge $-1 -1 -1 $-1 $6484 $6487 $4618 $5537 forward $6488 $-1 #
+edge $-1 -1 -1 $-1 $6489 -1.5707963267948966 $5540 2.9403902792268234e-16 $5536 $6490 forward @7 unknown T 30 -10.000000000000002 -45 35 -5 -40 #
+coedge $-1 -1 -1 $-1 $4619 $6326 $6491 $6492 reversed $4498 $-1 #
+coedge $-1 -1 -1 $-1 $6493 $5516 $4614 $4620 forward $6456 $-1 #
+vertex $-1 -1 -1 $-1 $6494 $6495 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6496 $6458 $4621 $5543 forward $6497 $-1 #
+edge $-1 -1 -1 $-1 $5544 -2.0943951023931957 $6489 -1.5707963267948966 $5542 $6498 forward @7 unknown T 35 -10.000000000000002 -42.5 37.500000000000007 -9.3301270189221928 -40 #
+vertex $-1 -1 -1 $-1 $6459 $6499 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $6500 $6501 #
+coedge $-1 -1 -1 $-1 $6502 $4627 $6503 $5571 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $6359 $5567 $4627 $5549 reversed $5439 $-1 #
+edge $-1 -1 -1 $-1 $4657 -0.5235987755982987 $4640 1.5707963267948966 $4627 $6504 forward @7 unknown T 15 -20 -50 22.5 -15 -50 #
+coedge $-1 -1 -1 $-1 $4628 $6505 $6359 $5592 forward $4234 $-1 #
+coedge $-1 -1 -1 $-1 $4631 $4630 $6506 $6507 forward $3432 $-1 #
+coedge $-1 -1 -1 $-1 $4653 $5979 $4630 $5553 reversed $5589 $-1 #
+edge $-1 -1 -1 $-1 $4655 1.0471975511965987 $6508 1.5707963267948966 $4630 $6509 forward @7 unknown T 37.500000000000007 -25 -42.5 40 -24.330127018922195 -40 #
+coedge $-1 -1 -1 $-1 $6510 $6362 $4631 $5555 reversed $5977 $-1 #
+edge $-1 -1 -1 $-1 $6511 -1.5707963267948966 $5556 -1.0471975511965965 $4631 $6509 forward @7 unknown T 37.499999999999986 -15.669872981077811 -42.500000000000007 40 -15 -40 #
+vertex $-1 -1 -1 $-1 $6363 $6512 #
+straight-curve $-1 -1 -1 $-1 37.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $4634 $6513 $6514 $6515 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $6516 $6517 $4634 $5560 reversed $6518 $-1 #
+edge $-1 -1 -1 $-1 $6519 1.5707963267948966 $5564 3.6651914291880923 $4634 $6520 forward @7 unknown T -8.8817841970012523e-16 -25 -50 7.5 -20 -50 #
+coedge $-1 -1 -1 $-1 $6521 $4635 $6517 $6522 forward $5563 $-1 #
+coedge $-1 -1 -1 $-1 $4635 $6523 $4637 $5568 reversed $5563 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5562 $6524 T 7.4999999999999964 -25 -50 15 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $4636 $6525 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5569 $4637 $6526 $6527 reversed $4639 $-1 #
+coedge $-1 -1 -1 $-1 $5548 $6528 $6529 $5568 reversed $5439 $-1 #
+edge $-1 -1 -1 $-1 $4640 -50 $6530 -45 $6529 $6531 forward @7 unknown T 15 -20 -50 15 -20 -45 #
+coedge $-1 -1 -1 $-1 $4638 $5566 $6532 $6533 reversed $4639 $-1 #
+face $-1 -1 -1 $-1 $2960 $4639 $11 $-1 $1477 reversed single T 15 -25 -50 22.500000000000004 -20 -40 F #
+edge $-1 -1 -1 $-1 $4640 0 $6534 2.0943951023931957 $5547 $5565 forward @7 unknown T 7.4999999999999991 -20 -50 15 -15 -50 #
+point $-1 -1 -1 $-1 15 -20 -50 #
+coedge $-1 -1 -1 $-1 $6532 $6535 $4642 $5574 reversed $6536 $-1 #
+edge $-1 -1 -1 $-1 $5575 1.047197551196597 $6537 1.5707963267948966 $4642 $6538 forward @7 unknown T 22.499999999999996 -25 -42.500000000000014 25 -24.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $5574 $6539 #
+coedge $-1 -1 -1 $-1 $6540 $4647 $4644 $5578 reversed $4209 $-1 #
+edge $-1 -1 -1 $-1 $6537 -1.5707963267948966 $4651 0 $4644 $6541 forward @7 unknown T 25 -25 -45 30 -20 -40 #
+face $-1 -1 -1 $-1 $2149 $6542 $11 $-1 $4529 reversed single T 7.4999999999999947 -20 -50 15 -15 -40 F #
+coedge $-1 -1 -1 $-1 $4647 $6540 $5917 $6543 forward $4209 $-1 #
+vertex $-1 -1 -1 $-1 $4648 $6544 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5042 $6545 $4649 $5584 forward $5086 $-1 #
+edge $-1 -1 -1 $-1 $4651 6.4931039580273265e-16 $5945 1.5707963267948966 $5583 $6546 forward @7 unknown T 30 -20 -45 35 -15.000000000000004 -40 #
+coedge $-1 -1 -1 $-1 $6505 $4650 $6545 $5586 forward $4234 $-1 #
+edge $-1 -1 -1 $-1 $4651 0 $6547 1.5707963267948966 $5585 $6541 forward @7 unknown T 25 -20 -45 30 -15 -40 #
+point $-1 -1 -1 $-1 30 -20 -45 #
+coedge $-1 -1 -1 $-1 $5979 $4653 $5019 $5925 forward $5589 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4653 $5976 T 35 -25.000000000000004 -42.5 40 -24.330127018922195 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 -24.330127018922198 -42.5 #
+edge $-1 -1 -1 $-1 $6548 42.500000000000007 $4657 50 $5550 $6549 forward @7 unknown T 22.5 -15.669872981077809 -50 22.500000000000004 -15.669872981077805 -42.500000000000007 #
+point $-1 -1 -1 $-1 22.5 -15.669872981077805 -50 #
+loop $-1 -1 -1 $-1 $-1 $5601 $4658 T -35 -40 -45 -25.000000000000004 -35 -35 unknown #
+coedge $-1 -1 -1 $-1 $6550 $6551 $6552 $6553 forward $4659 $-1 #
+coedge $-1 -1 -1 $-1 $5598 $4660 $6554 $6555 forward $3030 $-1 #
+edge $-1 -1 -1 $-1 $6556 -2.0943951023931957 $4778 0 $4777 $5692 forward @7 unknown T -22.5 -40 -50 -15 -35 -50 #
+coedge $-1 -1 -1 $-1 $4661 $5596 $6551 $5740 forward $3030 $-1 #
+coedge $-1 -1 -1 $-1 $4725 $4720 $4662 $5600 reversed $4726 $-1 #
+edge $-1 -1 -1 $-1 $5603 1.5707963267948966 $5624 2.0943951023931939 $4662 $6557 forward @7 unknown T -37.5 -40 -40 -35 -39.330127018922198 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $6558 $4663 $4669 $5614 forward $5594 $-1 #
+coedge $-1 -1 -1 $-1 $4663 $6558 $5706 $6559 reversed $5594 $-1 #
+vertex $-1 -1 -1 $-1 $5681 $6560 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4687 1.0471975511965965 $5609 1.5707963267948957 $4665 $6561 forward @7 unknown T -37.5 -40 -27.500000000000007 -35 -39.330127018922191 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $6562 $4666 $4841 $5771 reversed $5608 $-1 #
+coedge $-1 -1 -1 $-1 $4666 $6562 $4668 $5612 forward $5608 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6562 $6563 T -35 -40 -30.000000000000004 -25 -35 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $5605 $6564 #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -35 -25.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6565 $4668 $6566 $6567 reversed $4670 $-1 #
+edge $-1 -1 -1 $-1 $6568 -1.5707963267948961 $4672 -6.1232339957367648e-17 $5607 $6569 forward @7 unknown T -30.000000000000007 -40 -30.000000000000004 -25.000000000000004 -35 -25 #
+coedge $-1 -1 -1 $-1 $4669 $6565 $6550 $6570 reversed $4670 $-1 #
+edge $-1 -1 -1 $-1 $4671 6.1232339957367648e-17 $6571 1.5707963267948966 $5601 $6572 forward @7 unknown T -30.000000000000004 -40 -40 -25.000000000000004 -35 -35 #
+point $-1 -1 -1 $-1 -30 -35 -35 #
+edge $-1 -1 -1 $-1 $4672 0 $5779 1.5707963267948957 $5618 $5610 forward @7 unknown T -35 -35 -30.000000000000004 -30.000000000000007 -30 -25.000000000000004 #
+point $-1 -1 -1 $-1 -30.000000000000007 -35 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $5628 $4673 $6573 $5616 forward $5620 $-1 #
+coedge $-1 -1 -1 $-1 $4673 $5627 $4748 $5703 forward $5620 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4673 $4857 T -37.500000000000007 -35 -40 -30 -30 -25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $4679 $4678 $4769 $5716 forward $4680 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -10 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $4721 $6574 #
+straight-curve $-1 -1 -1 $-1 -37.5 -39.330127018922191 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922191 -27.500000000000007 #
+coedge $-1 -1 -1 $-1 $5619 $4689 $5671 $6575 forward $5620 $-1 #
+coedge $-1 -1 -1 $-1 $4689 $5618 $4691 $5631 forward $5620 $-1 #
+vertex $-1 -1 -1 $-1 $6575 $6576 #
+straight-curve $-1 -1 -1 $-1 -37.5 -30.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $5779 -1.5707963267948957 $4693 -1.047197551196597 $5628 $6561 forward @7 unknown T -37.5 -30.669872981077809 -27.500000000000007 -35 -30 -25.000000000000004 #
+face $-1 -1 -1 $-1 $5682 $4692 $11 $-1 $482 reversed single T -40 -30.669872981077809 -27.500000000000007 -35 -30 -22.500000000000007 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 -27.500000000000004 #
+face $-1 -1 -1 $-1 $6577 $6578 $11 $-1 $1815 reversed single T -50 -25 14.999999999999996 -40 -14.999999999999996 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $6579 $4696 T -10.000000000000002 -25 17.499999999999996 -5 -24.330127018922191 22.500000000000004 unknown #
+coedge $-1 -1 -1 $-1 $4697 $6344 $6580 $6581 forward $3821 $-1 #
+coedge $-1 -1 -1 $-1 $5651 $6330 $6332 $5425 reversed $5652 $-1 #
+coedge $-1 -1 -1 $-1 $5638 $5638 $4698 $5639 forward $4716 $-1 #
+edge $-1 -1 -1 $-1 $6582 0 $6582 6.2831853071795862 $5638 $6583 forward @7 unknown T -50 -25 29.999999999999996 -50 -15 40 #
+coedge $-1 -1 -1 $-1 $6584 $6585 $4699 $5641 reversed $6586 $-1 #
+edge $-1 -1 -1 $-1 $5646 -1.5707963267948966 $5645 1.5707963267948966 $4699 $6587 forward @7 unknown T -45 -24.999999999999996 35 -40 -14.999999999999996 40 #
+coedge $-1 -1 -1 $-1 $6588 $4700 $6589 $6590 reversed $5644 $-1 #
+coedge $-1 -1 -1 $-1 $4700 $6591 $6592 $6593 reversed $5644 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6594 $6595 T -45 -24.999999999999996 19.999999999999996 -37.5 -14.999999999999996 35 unknown #
+vertex $-1 -1 -1 $-1 $4701 $6596 #
+vertex $-1 -1 -1 $-1 $4701 $6597 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6598 $6599 $4702 $5649 forward $6600 $-1 #
+edge $-1 -1 -1 $-1 $5658 1.0471975511965974 $5653 1.5707963267948966 $5648 $6601 forward @7 unknown T -7.5000000000000027 -25 32.5 -5 -24.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $6330 $4703 $4708 $5664 forward $5652 $-1 #
+coedge $-1 -1 -1 $-1 $4703 $5637 $6602 $6603 forward $5652 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5637 $5435 T -7.5000000000000027 -25 35 0 -20 50 unknown #
+vertex $-1 -1 -1 $-1 $5649 $6604 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6605 $4705 $6599 $6606 reversed $5657 $-1 #
+coedge $-1 -1 -1 $-1 $4705 $6607 $6608 $5666 reversed $5657 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6605 $6609 T -15.000000000000002 -25 20 -7.5000000000000009 -20 35 unknown #
+vertex $-1 -1 -1 $-1 $5649 $6610 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5663 $4707 $6339 $6611 forward $4709 $-1 #
+coedge $-1 -1 -1 $-1 $6608 $6612 $4707 $5662 forward $6613 $-1 #
+edge $-1 -1 -1 $-1 $6614 6.1232339957367648e-17 $4710 1.5707963267948966 $5661 $6615 forward @7 unknown T -15.000000000000002 -25 35 -10.000000000000002 -20 40 #
+coedge $-1 -1 -1 $-1 $4708 $5660 $6329 $6616 reversed $4709 $-1 #
+edge $-1 -1 -1 $-1 $4711 37.500000000000007 $6354 50 $5650 $6617 forward @7 unknown T -7.5000000000000027 -24.330127018922195 37.500000000000007 -7.5000000000000009 -24.330127018922191 50 #
+face $-1 -1 -1 $-1 $6618 $4709 $11 $-1 $6619 reversed single T -15.000000000000002 -25 35 -7.5000000000000009 -20 50 F #
+edge $-1 -1 -1 $-1 $4710 -1.5707963267948966 $6620 -6.1232339957367648e-17 $6608 $6621 forward @7 unknown T -15.000000000000002 -25 30 -10.000000000000002 -20 35 #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 35 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 37.500000000000007 #
+point $-1 -1 -1 $-1 50 -20 30.000000000000004 #
+loop $-1 -1 -1 $-1 $6622 $6623 $3147 T -50 -25 14.999999999999996 -50 -15 24.999999999999996 hole $3148 T #
+coedge $-1 -1 -1 $-1 $4718 $4731 $5627 $6575 reversed $4732 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6624 $4760 $4722 $5675 forward $1370 $-1 #
+edge $-1 -1 -1 $-1 $5685 -0.5235987755982987 $5679 3.6651914291880923 $5674 $6625 forward @7 unknown T -45 -40 -50 -37.5 -30 -50 #
+coedge $-1 -1 -1 $-1 $5706 $4723 $4725 $5681 forward $5678 $-1 #
+coedge $-1 -1 -1 $-1 $4723 $4753 $6624 $6626 reversed $5678 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4753 $6627 T -37.500000000000014 -40 -50 -30 -35 -40 unknown #
+vertex $-1 -1 -1 $-1 $6626 $6628 #
+edge $-1 -1 -1 $-1 $4727 1.0471975511965965 $5603 1.5707963267948966 $5676 $6629 forward @7 unknown T -37.500000000000014 -40 -42.500000000000014 -35 -39.330127018922191 -40 #
+face $-1 -1 -1 $-1 $5688 $4726 $11 $-1 $756 reversed single T -40 -40 -42.500000000000014 -35 -39.330127018922191 -37.500000000000007 F #
+point $-1 -1 -1 $-1 -37.500000000000014 -39.330127018922205 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $4729 $4751 $4731 $5687 forward $4754 $-1 #
+vertex $-1 -1 -1 $-1 $4730 $6630 #
+edge $-1 -1 -1 $-1 $5710 -1.5707963267948966 $4733 -1.0471975511965979 $5684 $6629 forward @7 unknown T -37.5 -30.669872981077809 -42.5 -35 -30 -40 #
+face $-1 -1 -1 $-1 $6631 $4732 $11 $-1 $756 reversed single T -40 -30.669872981077809 -42.5 -35 -30 -37.5 F #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $6632 $4744 $4737 $5691 reversed $5699 $-1 #
+edge $-1 -1 -1 $-1 $5735 -1.5707963267948966 $4746 -1.047197551196597 $4737 $6633 forward @7 unknown T -22.500000000000004 -30.669872981077809 -27.500000000000004 -20 -30 -25 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -50 0 0 1 5 0 0 1 I I #
+edge $-1 -1 -1 $-1 $3115 -6.1232339957367648e-17 $5727 1.5707963267948966 $4739 $6634 forward @7 unknown T -15.000000000000002 -35 -45 -10.000000000000002 -30 -40 #
+face $-1 -1 -1 $-1 $3905 $4740 $11 $-1 $756 reversed single T -20 -35 -45 -10.000000000000002 -30 -35 F #
+face $-1 -1 -1 $-1 $5818 $5732 $11 $-1 $482 reversed single T -20 -35 -30 -10 -30 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $6635 $6573 $4743 $5697 forward $6636 $-1 #
+edge $-1 -1 -1 $-1 $4672 -6.1232339957367648e-17 $5700 1.5707963267948961 $5696 $6637 forward @7 unknown T -30.000000000000007 -35 -30.000000000000004 -25.000000000000004 -30 -25 #
+coedge $-1 -1 -1 $-1 $4744 $6632 $6638 $6639 forward $5699 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5698 $6640 T -25.000000000000007 -30.669872981077809 -27.500000000000004 -20 -30 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $5697 $6641 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $5710 1.5707963267948966 $4671 3.1415926535897931 $5619 $5604 forward @7 unknown T -35 -35 -40 -30 -30 -35 #
+face $-1 -1 -1 $-1 $4556 $6642 $11 $-1 $3872 reversed single T -30.000000000000004 -40 -50 -22.5 -35 -40 F #
+edge $-1 -1 -1 $-1 $4755 0 $5685 2.0943951023931948 $4760 $6643 forward @7 unknown T -37.5 -35 -50 -30 -30 -50 #
+coedge $-1 -1 -1 $-1 $4753 $5676 $5602 $6559 forward $5678 $-1 #
+coedge $-1 -1 -1 $-1 $6644 $6645 $3080 $3863 forward $6642 $-1 #
+face $-1 -1 -1 $-1 $6646 $4754 $11 $-1 $2412 reversed single T -37.5 -35 -50 -30 -30 -40 F #
+point $-1 -1 -1 $-1 -30 -35 -50 #
+vertex $-1 -1 -1 $-1 $5687 $6647 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5718 -1.5707963267948966 $4764 -6.1232339957367648e-17 $4763 $6648 forward @7 unknown T -1.7763568394002505e-15 -40 -45 4.9999999999999982 -35 -40 #
+edge $-1 -1 -1 $-1 $4764 0 $6649 1.5707963267948966 $5469 $4765 forward @7 unknown T -5 -35 -45 0 -30 -40 #
+point $-1 -1 -1 $-1 0 -35 -45 #
+face $-1 -1 -1 $-1 $3195 $4878 $11 $-1 $336 reversed single T -20 -35 -15.000000000000002 -10.000000000000002 -30 -5.0000000000000009 F #
+edge $-1 -1 -1 $-1 $4920 -1.5707963267948961 $4019 -6.1232339957367648e-17 $5621 $6650 forward @7 unknown T -1.7763568394002505e-15 -40 -30 4.9999999999999982 -35 -25 #
+coedge $-1 -1 -1 $-1 $4772 $6651 $6652 $6653 forward $4916 $-1 #
+vertex $-1 -1 -1 $-1 $5712 $6654 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4777 $6624 $6645 $6655 forward $1370 $-1 #
+point $-1 -1 -1 $-1 -15 -35 -50 #
+coedge $-1 -1 -1 $-1 $4794 $6656 $4784 $5723 forward $4798 $-1 #
+edge $-1 -1 -1 $-1 $5791 -1.5707963267948966 $3901 0 $5722 $5736 forward @7 unknown T -20 -40 -30 -15 -35 -25 #
+coedge $-1 -1 -1 $-1 $4790 $4787 $5824 $6657 reversed $3900 $-1 #
+coedge $-1 -1 -1 $-1 $6059 $6658 $4787 $5726 forward $6659 $-1 #
+edge $-1 -1 -1 $-1 $6660 -2.0943951023931953 $5727 -1.5707963267948966 $5725 $6661 forward @7 unknown T -10.000000000000002 -30.669872981077809 -40 -7.5000000000000018 -30 -37.5 #
+vertex $-1 -1 -1 $-1 $5693 $6662 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4905 $4904 $4790 $5730 forward $4906 $-1 #
+edge $-1 -1 -1 $-1 $5733 1.570796326794897 $5820 2.0943951023931966 $5729 $6663 forward @7 unknown T -10.000000000000002 -30.669872981077813 -27.500000000000004 -7.4999999999999973 -30 -25 #
+coedge $-1 -1 -1 $-1 $4791 $5785 $4793 $4795 reversed $5732 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4863 $5695 T -20 -35 -30 -10 -30 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $4792 $6664 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $5691 $6665 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6656 $4797 $6565 $6666 forward $4798 $-1 #
+coedge $-1 -1 -1 $-1 $6551 $6550 $4797 $5739 reversed $4659 $-1 #
+edge $-1 -1 -1 $-1 $4799 1.5707963267948966 $6667 2.0943951023931948 $4797 $3848 forward @7 unknown T -22.500000000000004 -40 -40 -20 -39.330127018922191 -37.5 #
+edge $-1 -1 -1 $-1 $6668 1.0471975511965974 $4799 1.5707963267948966 $5598 $3074 forward @7 unknown T -22.500000000000004 -40 -42.500000000000007 -20 -39.330127018922191 -40 #
+point $-1 -1 -1 $-1 -20 -40 -40 #
+face $-1 -1 -1 $-1 $6669 $6341 $11 $-1 $6619 reversed single T -15.000000000000002 -20 35 -7.5000000000000009 -15 50 F #
+face $-1 -1 -1 $-1 $5694 $6659 $11 $-1 $756 reversed single T -10.000000000000002 -30.669872981077813 -42.500000000000014 -5 -30 -37.5 F #
+loop $-1 -1 -1 $-1 $6670 $6671 $1558 T 50 -25 -29.999999999999996 50 -15 -19.999999999999996 hole $1559 T #
+coedge $-1 -1 -1 $-1 $5745 $5745 $6672 $6673 forward $4804 $-1 #
+coedge $-1 -1 -1 $-1 $5746 $5746 $4805 $5747 reversed $5069 $-1 #
+edge $-1 -1 -1 $-1 $6674 0 $6674 6.2831853071795862 $4805 $6675 forward @7 unknown T 50 -25 2.6645352591003757e-15 50 -15 10.000000000000004 #
+vertex $-1 -1 -1 $-1 $4807 $6676 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5718 1.5707963267948966 $4812 2.0943951023931944 $4811 $6677 forward @7 unknown T 4.9999999999999982 -40 -40 7.5 -39.330127018922198 -37.500000000000007 #
+point $-1 -1 -1 $-1 7.5 -39.330127018922198 -37.500000000000007 #
+loop $-1 -1 -1 $-1 $-1 $5461 $4813 T -5 -35 -45 4.9999999999999982 -30 -35 unknown #
+edge $-1 -1 -1 $-1 $5107 -2.0943951023931948 $4884 -1.5707963267948966 $4815 $6678 forward @7 unknown T -10.000000000000002 -30.669872981077805 4.9999999999999991 -7.5 -30 7.5 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $4267 $4883 $11 $-1 $227 reversed single T -20 -35 -1.7763568394002505e-15 -10.000000000000002 -30 10 F #
+edge $-1 -1 -1 $-1 $4879 1.5707963267948966 $4823 2.0943951023931957 $4820 $6679 forward @7 unknown T -10.000000000000002 -30.669872981077813 -12.500000000000004 -7.5000000000000009 -30 -10 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $6680 $5220 $5225 $6084 forward $4826 $-1 #
+coedge $-1 -1 -1 $-1 $5763 $4828 $6681 $6682 forward $4830 $-1 #
+coedge $-1 -1 -1 $-1 $4829 $5763 $6683 $6684 forward $4830 $-1 #
+coedge $-1 -1 -1 $-1 $5762 $5761 $5767 $6685 forward $4830 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -10.000000000000002 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5767 $4834 $6686 $6687 forward $4836 $-1 #
+coedge $-1 -1 -1 $-1 $4835 $5767 $6688 $6689 forward $4836 $-1 #
+coedge $-1 -1 -1 $-1 $5766 $5765 $6690 $6685 reversed $4836 $-1 #
+face $-1 -1 -1 $-1 $5790 $4836 $11 $-1 $2412 reversed single T -37.500000000000014 -40 -10.000000000000002 -30 -35 4.9999999999999982 F #
+coedge $-1 -1 -1 $-1 $6688 $6691 $4840 $5770 reversed $6692 $-1 #
+edge $-1 -1 -1 $-1 $4846 -1.5707963267948966 $6693 0 $4840 $6694 forward @7 unknown T -35 -40 -15.000000000000002 -30 -35 -10.000000000000002 #
+edge $-1 -1 -1 $-1 $6695 3.1415926535897931 $5609 4.7123889803846906 $4841 $6696 forward @7 unknown T -35 -40 -25.000000000000007 -29.999999999999993 -35 -20.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -35 -25.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6697 $6698 $6699 $5774 forward $6700 $-1 #
+edge $-1 -1 -1 $-1 $6695 -20.000000000000004 $6693 -15.000000000000002 $4853 $6701 forward @7 unknown T -30 -35 -20.000000000000004 -29.999999999999993 -35 -15.000000000000002 #
+face $-1 -1 -1 $-1 $6563 $6636 $11 $-1 $482 reversed single T -35 -35 -30.000000000000004 -25 -30 -19.999999999999996 F #
+point $-1 -1 -1 $-1 -35 -40 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $6573 $6635 $4850 $5778 reversed $6636 $-1 #
+edge $-1 -1 -1 $-1 $5779 1.5707963267948957 $6695 3.1415926535897931 $4850 $6696 forward @7 unknown T -35 -35 -25.000000000000007 -29.999999999999993 -30 -20.000000000000004 #
+vertex $-1 -1 -1 $-1 $5631 $6702 #
+coedge $-1 -1 -1 $-1 $6703 $6681 $4852 $5781 reversed $6704 $-1 #
+edge $-1 -1 -1 $-1 $6693 0 $4856 1.5707963267948966 $4852 $6694 forward @7 unknown T -35 -35 -15.000000000000002 -30 -30 -10.000000000000002 #
+point $-1 -1 -1 $-1 -35 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $6705 $4869 $4860 $4872 forward $4776 $-1 #
+edge $-1 -1 -1 $-1 $4907 -2.0943951023931948 $5733 -1.5707963267948961 $4904 $6706 forward @7 unknown T -10.000000000000004 -30.669872981077805 -25 -7.5000000000000018 -30 -22.5 #
+coedge $-1 -1 -1 $-1 $5731 $4863 $4868 $5789 reversed $5732 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4868 $5815 $6632 $6707 forward $4870 $-1 #
+edge $-1 -1 -1 $-1 $5735 1.5707963267948966 $3983 3.1415926535897931 $4868 $5792 forward @7 unknown T -20 -35 -25 -15 -30 -20 #
+face $-1 -1 -1 $-1 $6708 $4870 $11 $-1 $1595 reversed single T -22.500000000000004 -35 -25 -15 -30 -10.000000000000002 F #
+vertex $-1 -1 -1 $-1 $6709 $6710 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4874 $6705 $6711 $6712 forward $4776 $-1 #
+coedge $-1 -1 -1 $-1 $6713 $4893 $4874 $4896 reversed $5809 $-1 #
+coedge $-1 -1 -1 $-1 $4875 $4892 $6714 $6003 forward $4002 $-1 #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 -10 #
+coedge $-1 -1 -1 $-1 $4882 $4881 $5121 $5998 reversed $4883 $-1 #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $4887 $4886 $6715 $6716 forward $3997 $-1 #
+coedge $-1 -1 -1 $-1 $6717 $6718 $4886 $5801 reversed $6719 $-1 #
+edge $-1 -1 -1 $-1 $4890 -1.5707963267948966 $6720 -1.0471975511965974 $4886 $6721 forward @7 unknown T -22.500000000000004 -30.669872981077809 2.4999999999999969 -20 -30 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $6722 $5816 $4887 $5803 reversed $6723 $-1 #
+edge $-1 -1 -1 $-1 $6724 4.1887902047863896 $4005 4.7123889803846897 $4887 $5811 forward @7 unknown T -22.500000000000007 -30.669872981077813 -10.000000000000002 -20 -30 -7.4999999999999964 #
+face $-1 -1 -1 $-1 $6725 $6726 $11 $-1 $227 reversed single T -35 -35 -1.7763568394002505e-15 -25.000000000000004 -30 9.9999999999999982 F #
+point $-1 -1 -1 $-1 -20 -30 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $6727 $6728 $4892 $5807 reversed $6729 $-1 #
+edge $-1 -1 -1 $-1 $5810 -7.5000000000000036 $6730 2.4999999999999969 $4892 $6731 forward @7 unknown T -22.500000000000004 -39.330127018922198 -7.5000000000000036 -22.5 -39.330127018922191 2.4999999999999969 #
+coedge $-1 -1 -1 $-1 $4893 $6713 $6727 $6732 forward $5809 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5808 $6733 T -25.000000000000004 -40 -12.500000000000007 -20 -39.330127018922191 -7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $6732 $6734 #
+ellipse-curve $-1 -1 -1 $-1 -20.000000000000004 -35 -10.000000000000002 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $4896 $6735 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 -35 -10.000000000000002 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $6736 $6737 #
+coedge $-1 -1 -1 $-1 $5788 $4900 $6738 $6736 forward $4870 $-1 #
+coedge $-1 -1 -1 $-1 $5802 $6739 $4900 $4898 reversed $6723 $-1 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $4802 $4906 $11 $-1 $482 reversed single T -10.000000000000004 -30.669872981077813 -27.500000000000007 -5 -30 -22.499999999999996 F #
+point $-1 -1 -1 $-1 -7.5000000000000018 -30.669872981077805 -22.5 #
+vertex $-1 -1 -1 $-1 $5730 $6740 #
+face $-1 -1 -1 $-1 $6741 $6742 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 -10 7.5000000000000009 -15 5 F #
+loop $-1 -1 -1 $-1 $-1 $6743 $4910 T -8.8817841970012523e-16 -20 5 7.5 -15 20 unknown #
+coedge $-1 -1 -1 $-1 $6744 $6745 $6746 $6747 reversed $4911 $-1 #
+coedge $-1 -1 -1 $-1 $6651 $4915 $5724 $6657 forward $4916 $-1 #
+face $-1 -1 -1 $-1 $3928 $4916 $11 $-1 $1445 reversed single T -7.5000000000000053 -35 -40 0 -30 -25 F #
+coedge $-1 -1 -1 $-1 $6652 $5461 $4918 $5827 forward $5753 $-1 #
+edge $-1 -1 -1 $-1 $5458 -1.5707963267948966 $3885 6.1232339957367648e-17 $5826 $6748 forward @7 unknown T -1.7763568394002505e-15 -35 -40 4.9999999999999982 -30 -35 #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 -25 #
+coedge $-1 -1 -1 $-1 $5861 $4924 $5960 $6749 reversed $4028 $-1 #
+edge $-1 -1 -1 $-1 $6750 1.5707963267948966 $5058 2.0943951023931957 $5057 $6751 forward @7 unknown T 20 -25 -9.9999999999999982 22.500000000000004 -24.330127018922191 -7.4999999999999973 #
+coedge $-1 -1 -1 $-1 $6752 $4925 $4031 $4934 forward $3224 $-1 #
+coedge $-1 -1 -1 $-1 $6753 $6754 $4925 $5833 forward $6755 $-1 #
+edge $-1 -1 -1 $-1 $4939 6.1232339957367648e-17 $5838 1.570796326794897 $5832 $6756 forward @7 unknown T 15 -25 -25 20.000000000000004 -20 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $4926 $6752 $5062 $5961 reversed $3224 $-1 #
+edge $-1 -1 -1 $-1 $5839 -22.500000000000004 $4175 -12.499999999999998 $5032 $6757 forward @7 unknown T 22.499999999999993 -24.330127018922195 -22.500000000000004 22.5 -24.330127018922191 -12.499999999999998 #
+coedge $-1 -1 -1 $-1 $4927 $5936 $6758 $6759 forward $5837 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5836 $6760 T 19.999999999999996 -25 -27.500000000000004 25 -24.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $6761 $6762 #
+vertex $-1 -1 -1 $-1 $5835 $6763 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4932 $4929 $4942 $5063 reversed $2574 $-1 #
+coedge $-1 -1 -1 $-1 $5028 $4930 $6764 $5943 forward $5029 $-1 #
+coedge $-1 -1 -1 $-1 $6765 $4933 $4950 $5865 forward $5847 $-1 #
+coedge $-1 -1 -1 $-1 $4933 $6766 $4935 $5851 forward $5847 $-1 #
+coedge $-1 -1 -1 $-1 $6767 $6768 $5831 $4934 reversed $6769 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4933 $5869 T 7.4999999999999973 -20 -25 15 -15 -10 unknown #
+vertex $-1 -1 -1 $-1 $5865 $6770 #
+straight-curve $-1 -1 -1 $-1 15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $4936 $4935 $6771 $6772 reversed $4937 $-1 #
+edge $-1 -1 -1 $-1 $6773 1.5707963267948966 $4939 3.1415926535897931 $5845 $6774 forward @7 unknown T 10 -20 -25 15 -15 -20 #
+coedge $-1 -1 -1 $-1 $6775 $6764 $4936 $5853 reversed $6358 $-1 #
+edge $-1 -1 -1 $-1 $6776 -6.1232339957367648e-17 $4938 1.5707963267948961 $4936 $6777 forward @7 unknown T 15 -20 -30 20 -15 -25 #
+point $-1 -1 -1 $-1 20 -15 -25 #
+edge $-1 -1 -1 $-1 $4939 3.1415926535897931 $6778 4.7123889803846897 $6767 $6774 forward @7 unknown T 10 -25 -25 15 -20 -20 #
+point $-1 -1 -1 $-1 15 -20 -20 #
+coedge $-1 -1 -1 $-1 $6779 $4944 $6780 $5885 forward $4947 $-1 #
+coedge $-1 -1 -1 $-1 $4945 $6779 $6781 $6782 forward $4947 $-1 #
+coedge $-1 -1 -1 $-1 $6783 $4946 $6784 $4955 forward $5862 $-1 #
+coedge $-1 -1 -1 $-1 $4946 $6785 $6786 $6787 forward $5862 $-1 #
+coedge $-1 -1 -1 $-1 $6788 $5829 $3227 $4039 forward $4028 $-1 #
+loop $-1 -1 -1 $-1 $-1 $4946 $6789 T 7.4999999999999991 -25 -10 15.000000000000004 -20 5.0000000000000009 unknown #
+face $-1 -1 -1 $-1 $6790 $4947 $11 $-1 $4529 reversed single T 7.4999999999999982 -20 -10 15.000000000000004 -15 5.0000000000000009 F #
+point $-1 -1 -1 $-1 15.000000000000004 -20 8.8817841970012523e-16 #
+edge $-1 -1 -1 $-1 $5848 0 $5866 1.5707963267948966 $5844 $6791 forward @7 unknown T 10 -20 -15 15 -15 -10 #
+vertex $-1 -1 -1 $-1 $6792 $6793 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -10 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6794 $5847 $11 $-1 $4529 reversed single T 7.4999999999999973 -20 -25 15 -15 -10 F #
+vertex $-1 -1 -1 $-1 $6795 $6796 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $4959 $4958 $6797 $6798 forward $4052 $-1 #
+coedge $-1 -1 -1 $-1 $4979 $6799 $4958 $4990 reversed $5898 $-1 #
+coedge $-1 -1 -1 $-1 $6800 $6780 $4959 $5875 reversed $6801 $-1 #
+edge $-1 -1 -1 $-1 $6802 4.1887902047863905 $4967 4.7123889803846897 $4959 $6803 forward @7 unknown T 7.4999999999999973 -15.669872981077807 5.0000000000000009 10 -15 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $6804 $4960 $6805 $6806 forward $4963 $-1 #
+coedge $-1 -1 -1 $-1 $6807 $6786 $4960 $4060 reversed $5887 $-1 #
+coedge $-1 -1 -1 $-1 $4961 $6804 $6808 $4992 forward $4963 $-1 #
+coedge $-1 -1 -1 $-1 $4982 $5975 $4961 $5880 reversed $4197 $-1 #
+edge $-1 -1 -1 $-1 $4079 -1.5707963267948966 $4053 0 $4961 $4989 forward @7 unknown T 10 -25 15 15 -20 20 #
+coedge $-1 -1 -1 $-1 $5074 $4962 $5975 $5982 reversed $4923 $-1 #
+coedge $-1 -1 -1 $-1 $4962 $5073 $6807 $6809 reversed $4923 $-1 #
+face $-1 -1 -1 $-1 $6810 $6811 $11 $-1 $1815 reversed single T -5 -20 15 4.9999999999999991 -15 25 F #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -20 5.0000000000000009 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4967 -1.5707963267948966 $6812 -1.0471975511965974 $5857 $6813 forward @7 unknown T 7.4999999999999982 -15.669872981077809 2.5 10 -15 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 -15 5.0000000000000009 #
+loop $-1 -1 -1 $-1 $-1 $6807 $4970 T 10 -25 -9.3734986416366073e-33 20 -20 10 unknown #
+edge $-1 -1 -1 $-1 $6814 1.0471975511965979 $4971 1.5707963267948966 $6785 $6813 forward @7 unknown T 7.4999999999999991 -25 2.5000000000000009 10 -24.330127018922191 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 -25 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $6815 $6744 $4974 $5891 reversed $4911 $-1 #
+edge $-1 -1 -1 $-1 $5894 -32.5 $5899 -22.499999999999996 $4974 $6816 forward @7 unknown T 7.4999999999999982 -15.669872981077809 22.499999999999996 7.5000000000000009 -15.669872981077807 32.5 #
+coedge $-1 -1 -1 $-1 $4975 $6351 $6815 $6817 forward $5893 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6351 $6818 T 4.9999999999999991 -15.669872981077809 32.5 10 -15 37.5 unknown #
+vertex $-1 -1 -1 $-1 $5891 $6819 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 -15 35 #
+coedge $-1 -1 -1 $-1 $6799 $4979 $6744 $6820 forward $5898 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5897 $6821 T 4.9999999999999991 -15.669872981077809 17.499999999999996 10 -15 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $4980 $6822 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $4983 $4981 $6823 $6824 forward $4072 $-1 #
+coedge $-1 -1 -1 $-1 $6808 $6825 $4981 $5903 reversed $6826 $-1 #
+edge $-1 -1 -1 $-1 $4079 1.5707963267948966 $6827 2.0943951023931957 $4981 $5900 forward @7 unknown T 7.4999999999999991 -25 20 10 -24.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $6828 $6829 $4983 $5905 reversed $6830 $-1 #
+edge $-1 -1 -1 $-1 $6831 1.0471975511965987 $5906 1.5707963267948966 $4983 $5895 forward @7 unknown T 7.5000000000000027 -25 32.500000000000007 10 -24.330127018922195 35 #
+vertex $-1 -1 -1 $-1 $5905 $6832 #
+edge $-1 -1 -1 $-1 $5094 -1.5707963267948966 $3251 -6.1232339957367648e-17 $5097 $6833 forward @7 unknown T 15 -25 30 20 -20 35 #
+edge $-1 -1 -1 $-1 $2590 6.1232339957367673e-17 $5090 1.5707963267948966 $5081 $6834 forward @7 unknown T 15 -25 20 20 -20 25 #
+face $-1 -1 -1 $-1 $6835 $6836 $11 $-1 $1965 reversed single T -5 -25 30 4.9999999999999991 -20 40 F #
+loop $-1 -1 -1 $-1 $-1 $6347 $4988 T -5 -20 30 4.9999999999999991 -15 40 unknown #
+vertex $-1 -1 -1 $-1 $6798 $6837 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $4992 $6838 #
+point $-1 -1 -1 $-1 37.499999999999993 -24.330127018922195 17.500000000000011 #
+point $-1 -1 -1 $-1 40 -25 -9.9999999999999982 #
+loop $-1 -1 -1 $-1 $-1 $5038 $5089 T 22.5 -25 -40 30 -20 -25 unknown #
+coedge $-1 -1 -1 $-1 $5010 $5019 $5580 $6543 reversed $4121 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -9.9999999999999982 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5013 $5013 $5016 $5924 reversed $5920 $-1 #
+loop $-1 -1 -1 $-1 $6839 $5919 $6840 T 39.999999999999993 -25 -29.999999999999996 45.000000000000007 -15 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -20 -24.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6841 $6842 $11 $-1 $4210 reversed single T -10.000000000000002 -25 -42.500000000000007 -5 -24.330127018922191 -37.5 F #
+loop $-1 -1 -1 $-1 $6843 $6506 $5015 T 40 -25 -45 45 -15 -35 unknown #
+edge $-1 -1 -1 $-1 $4118 -1.570796326794897 $4131 1.570796326794897 $5016 $6844 forward @7 unknown T 40 -25 -29.999999999999996 45.000000000000007 -15 -24.999999999999993 #
+edge $-1 -1 -1 $-1 $5581 1.5707963267948966 $5926 2.0943951023931953 $5588 $6845 forward @7 unknown T 35 -25.000000000000004 -40 37.5 -24.330127018922195 -37.5 #
+vertex $-1 -1 -1 $-1 $5020 $6846 #
+straight-curve $-1 -1 -1 $-1 37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5978 $5022 $6510 $6847 forward $3397 $-1 #
+coedge $-1 -1 -1 $-1 $6362 $6510 $5023 $5930 forward $5977 $-1 #
+edge $-1 -1 -1 $-1 $5931 -2.0943951023931953 $5945 -1.5707963267948966 $5929 $6848 forward @7 unknown T 35 -15.669872981077813 -40 37.5 -15.000000000000004 -37.5 #
+vertex $-1 -1 -1 $-1 $6847 $6849 #
+straight-curve $-1 -1 -1 $-1 22.5 -15.669872981077805 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $6789 $5029 $11 $-1 $3328 reversed single T 19.999999999999996 -15.669872981077809 -27.500000000000004 25 -15 -22.500000000000004 F #
+point $-1 -1 -1 $-1 22.499999999999996 -15.669872981077805 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $5836 $5033 $5047 $4150 reversed $5837 $-1 #
+coedge $-1 -1 -1 $-1 $5037 $5036 $6850 $6851 forward $4143 $-1 #
+coedge $-1 -1 -1 $-1 $6764 $6852 $5036 $5939 reversed $6358 $-1 #
+edge $-1 -1 -1 $-1 $5040 27.500000000000004 $6853 37.5 $5036 $6854 forward @7 unknown T 22.5 -15.669872981077807 -37.5 22.500000000000004 -15.669872981077805 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $6545 $5042 $5037 $5941 reversed $5086 $-1 #
+edge $-1 -1 -1 $-1 $6547 1.5707963267948966 $5044 3.1415926535897931 $5037 $6855 forward @7 unknown T 25 -20 -40 30 -15 -35 #
+coedge $-1 -1 -1 $-1 $6856 $5038 $6540 $5947 forward $5916 $-1 #
+edge $-1 -1 -1 $-1 $4938 1.570796326794897 $5040 2.0943951023931957 $5842 $6857 forward @7 unknown T 20 -15.669872981077809 -27.500000000000004 22.500000000000004 -15 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077807 -27.500000000000004 #
+vertex $-1 -1 -1 $-1 $5584 $6858 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5044 3.1415926535897931 $6537 4.7123889803846897 $5942 $6855 forward @7 unknown T 25 -25 -40 30 -20 -35 #
+point $-1 -1 -1 $-1 30 -20 -35 #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $5047 $6856 $6859 $6860 forward $5916 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6672 $5952 T 50 -25 -14.999999999999996 50 -15 -4.9999999999999964 unknown #
+face $-1 -1 -1 $-1 $2649 $5048 $11 $-1 $2664 reversed single T 40 -25 -14.999999999999998 50 -15 -4.9999999999999964 F #
+face $-1 -1 -1 $-1 $6861 $6862 $11 $-1 $2664 reversed single T -50 -25 -15.000000000000004 -40 -14.999999999999996 -5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $6863 $5051 T -10.000000000000002 -25 -12.500000000000004 -5 -24.330127018922191 -7.5 unknown #
+coedge $-1 -1 -1 $-1 $6864 $6865 $6866 $6867 forward $5052 $-1 #
+coedge $-1 -1 -1 $-1 $5055 $6788 $5059 $5959 reversed $4028 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -24.330127018922195 0 0 0 1 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922191 -7.4999999999999991 #
+edge $-1 -1 -1 $-1 $3382 -2.0943951023931948 $5972 -1.5707963267948966 $5059 $6868 forward @7 unknown T 20 -25 2.5000000000000044 22.500000000000004 -24.330127018922195 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $6869 $6784 $5829 $6749 forward $5061 $-1 #
+edge $-1 -1 -1 $-1 $4175 -2.0943951023931953 $6750 -1.5707963267948966 $5062 $6870 forward @7 unknown T 20 -25 -12.499999999999998 22.5 -24.330127018922191 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6871 $6872 $11 $-1 $3659 reversed single T 29.999999999999996 -5.0000000000000009 -24.999999999999996 37.5 -1.7763568394002505e-15 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $6873 $5065 T 29.999999999999996 -5.0000000000000009 -9.9999999999999982 37.5 -8.8817841970012523e-16 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $6874 $6875 $6876 $6877 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $6320 $5067 $6878 $6879 reversed $4174 $-1 #
+coedge $-1 -1 -1 $-1 $5067 $5399 $6880 $6881 reversed $4174 $-1 #
+coedge $-1 -1 -1 $-1 $6882 $6883 $5067 $5969 forward $6884 $-1 #
+edge $-1 -1 -1 $-1 $6885 -1.5707963267948966 $6886 -4.7167471186270745e-16 $5968 $6887 forward @7 unknown T 29.999999999999996 -4.9999999999999991 20.000000000000004 35 -1.7763568394002505e-15 25.000000000000007 #
+face $-1 -1 -1 $-1 $6888 $6889 $11 $-1 $2156 reversed single T -10.000000000000002 -25 2.4999999999999982 -5 -24.330127018922191 7.5000000000000027 F #
+face $-1 -1 -1 $-1 $6760 $6755 $11 $-1 $3328 reversed single T 10 -25 -30 20.000000000000004 -20 -19.999999999999996 F #
+vertex $-1 -1 -1 $-1 $6890 $6891 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $5879 $5081 $5881 $5982 forward $4197 $-1 #
+face $-1 -1 -1 $-1 $5039 $5589 $11 $-1 $4210 reversed single T 35 -25.000000000000004 -42.5 40 -24.330127018922195 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $6362 $5085 T 35 -15.669872981077813 -42.500000000000007 40 -15 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $5087 $5928 $6892 $6893 forward $3397 $-1 #
+coedge $-1 -1 -1 $-1 $5552 $5588 $5087 $5980 reversed $5589 $-1 #
+edge $-1 -1 -1 $-1 $6508 1.5707963267948966 $5926 2.0943951023931948 $5087 $6894 forward @7 unknown T 37.5 -25 -40 40 -24.330127018922195 -37.5 #
+face $-1 -1 -1 $-1 $6895 $6896 $11 $-1 $4210 reversed single T 10 -25 -45 20 -20 -35 F #
+edge $-1 -1 -1 $-1 $5090 -1.5707963267948966 $4053 -6.1232339957367648e-17 $5975 $6897 forward @7 unknown T 15 -25 15 20 -20 20 #
+point $-1 -1 -1 $-1 20 -25 20 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 -25 35 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 10 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5163 1.5707963267948966 $5106 2.0943951023931953 $5105 $6898 forward @7 unknown T -10.000000000000002 -30.669872981077813 17.5 -7.5000000000000027 -30 20 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 17.500000000000004 #
+point $-1 -1 -1 $-1 -7.5 -30.669872981077802 7.5 #
+vertex $-1 -1 -1 $-1 $5110 $6899 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 4.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $5113 $6900 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5121 $6037 $6717 $6901 forward $5123 $-1 #
+edge $-1 -1 -1 $-1 $4890 1.5707963267948966 $3466 3.1415926535897931 $5121 $5128 forward @7 unknown T -20 -35 4.9999999999999991 -15 -30 10 #
+face $-1 -1 -1 $-1 $6902 $5123 $11 $-1 $1595 reversed single T -22.500000000000004 -35 4.9999999999999991 -15 -30 20 F #
+coedge $-1 -1 -1 $-1 $5160 $5125 $6903 $6904 forward $5126 $-1 #
+coedge $-1 -1 -1 $-1 $6714 $6905 $5125 $6002 reversed $6906 $-1 #
+edge $-1 -1 -1 $-1 $5127 1.5707963267948966 $6907 2.0943951023931966 $5125 $6908 forward @7 unknown T -22.500000000000004 -40 4.9999999999999991 -20 -39.330127018922184 7.5000000000000036 #
+edge $-1 -1 -1 $-1 $6730 1.0471975511965979 $5127 1.5707963267948966 $5795 $6721 forward @7 unknown T -22.500000000000004 -40 2.4999999999999969 -20 -39.330127018922191 4.9999999999999991 #
+point $-1 -1 -1 $-1 -20 -40 4.9999999999999991 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -35 19.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6049 $6909 $5144 $6009 reversed $6910 $-1 #
+edge $-1 -1 -1 $-1 $5150 -1.5707963267948957 $6911 0 $5144 $6912 forward @7 unknown T -35 -40 14.999999999999996 -30.000000000000007 -35 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $6913 $6686 $5145 $6011 reversed $6914 $-1 #
+edge $-1 -1 -1 $-1 $6915 3.1415926535897931 $5992 4.7123889803846897 $5145 $6916 forward @7 unknown T -35 -40 4.9999999999999982 -30 -35 9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 4.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6917 $6918 $6919 $6014 forward $6920 $-1 #
+edge $-1 -1 -1 $-1 $6915 9.9999999999999982 $6911 14.999999999999996 $5155 $6921 forward @7 unknown T -30.000000000000007 -35 9.9999999999999982 -30 -35 14.999999999999996 #
+point $-1 -1 -1 $-1 -35 -40 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $6683 $6922 $5152 $6017 reversed $6726 $-1 #
+edge $-1 -1 -1 $-1 $5994 1.5707963267948966 $6915 3.1415926535897931 $5152 $6916 forward @7 unknown T -35 -35 4.9999999999999982 -30 -30 9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $6923 $6054 $5154 $6019 reversed $6924 $-1 #
+edge $-1 -1 -1 $-1 $6911 0 $5158 1.5707963267948957 $5154 $6912 forward @7 unknown T -35 -35 14.999999999999996 -30.000000000000007 -30 19.999999999999996 #
+point $-1 -1 -1 $-1 -35 -30 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $6925 $5171 $5160 $5173 reversed $6031 $-1 #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 20 #
+coedge $-1 -1 -1 $-1 $5167 $5166 $6926 $6927 forward $4325 $-1 #
+coedge $-1 -1 -1 $-1 $5455 $6928 $5166 $5209 reversed $6373 $-1 #
+coedge $-1 -1 -1 $-1 $6929 $6038 $5167 $6026 reversed $6930 $-1 #
+edge $-1 -1 -1 $-1 $6931 4.1887902047863905 $4331 4.7123889803846897 $5167 $6033 forward @7 unknown T -22.500000000000004 -30.669872981077809 20 -20 -30 22.500000000000004 #
+face $-1 -1 -1 $-1 $6932 $6933 $11 $-1 $388 reversed single T -35 -35 30 -25.000000000000004 -30 40 F #
+coedge $-1 -1 -1 $-1 $6934 $6364 $5170 $6029 reversed $6935 $-1 #
+edge $-1 -1 -1 $-1 $6032 22.500000000000004 $5448 32.5 $5170 $6936 forward @7 unknown T -22.500000000000004 -39.330127018922198 22.500000000000004 -22.5 -39.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $5171 $6925 $6934 $6937 forward $6031 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6030 $6938 T -25.000000000000004 -40 17.499999999999996 -20 -39.330127018922191 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $6937 $6939 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $5173 $6940 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $6941 $6942 #
+coedge $-1 -1 -1 $-1 $5997 $5177 $6943 $6941 forward $5123 $-1 #
+coedge $-1 -1 -1 $-1 $6025 $6944 $5177 $5175 reversed $6930 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6041 $5181 $6945 $6946 forward $5183 $-1 #
+coedge $-1 -1 -1 $-1 $5182 $6040 $6044 $6066 forward $5183 $-1 #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 50 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6045 $5188 $5451 $6066 reversed $5190 $-1 #
+coedge $-1 -1 -1 $-1 $5189 $6044 $6947 $6948 forward $5190 $-1 #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $6947 $6949 $5195 $6048 reversed $6950 $-1 #
+edge $-1 -1 -1 $-1 $5199 -1.5707963267948966 $6951 0 $5195 $6952 forward @7 unknown T -35 -40 30 -30 -35 35 #
+coedge $-1 -1 -1 $-1 $6953 $6008 $5196 $6050 reversed $6910 $-1 #
+edge $-1 -1 -1 $-1 $6954 3.1415926535897931 $5150 4.7123889803846906 $5196 $6955 forward @7 unknown T -35 -40 19.999999999999993 -29.999999999999993 -35 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $6956 $6957 $6958 $6052 forward $6935 $-1 #
+edge $-1 -1 -1 $-1 $6954 24.999999999999996 $6951 30 $5203 $6959 forward @7 unknown T -30 -35 24.999999999999996 -29.999999999999993 -35 30 #
+point $-1 -1 -1 $-1 -35 -40 35 #
+coedge $-1 -1 -1 $-1 $6018 $6960 $5201 $6055 reversed $6924 $-1 #
+edge $-1 -1 -1 $-1 $5158 1.5707963267948957 $6954 3.1415926535897931 $5201 $6955 forward @7 unknown T -35 -35 19.999999999999993 -29.999999999999993 -30 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $6961 $6945 $5202 $6057 reversed $6933 $-1 #
+edge $-1 -1 -1 $-1 $6951 0 $5205 1.5707963267948966 $5202 $6952 forward @7 unknown T -35 -35 30 -30 -30 35 #
+point $-1 -1 -1 $-1 -35 -30 35 #
+coedge $-1 -1 -1 $-1 $6378 $5725 $5207 $6060 forward $6659 $-1 #
+edge $-1 -1 -1 $-1 $5727 1.5707963267948966 $6061 2.0943951023931966 $6059 $6962 forward @7 unknown T -10.000000000000002 -30.669872981077813 -42.500000000000014 -7.4999999999999973 -30 -40 #
+vertex $-1 -1 -1 $-1 $6060 $6963 #
+vertex $-1 -1 -1 $-1 $6927 $6964 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6067 $5212 $6965 $6966 reversed $5214 $-1 #
+edge $-1 -1 -1 $-1 $6967 40 $5215 50 $6041 $6968 forward @7 unknown T -30 -35 40 -30 -35 50 #
+coedge $-1 -1 -1 $-1 $5213 $6065 $6372 $6969 reversed $5214 $-1 #
+face $-1 -1 -1 $-1 $3085 $5214 $11 $-1 $3872 reversed single T -30.000000000000004 -35 35 -22.5 -30 50 F #
+point $-1 -1 -1 $-1 -30 -35 50 #
+vertex $-1 -1 -1 $-1 $5456 $6970 #
+straight-curve $-1 -1 -1 $-1 -22.5 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $6971 $6972 $5219 $6073 reversed $6973 $-1 #
+edge $-1 -1 -1 $-1 $6075 -50 $6080 50 $6072 $6974 forward @7 unknown T -50 -50 50 -50 50 50 #
+coedge $-1 -1 -1 $-1 $5220 $6680 $6971 $6975 reversed $4826 $-1 #
+vertex $-1 -1 -1 $-1 $5221 $6976 #
+straight-curve $-1 -1 -1 $-1 0 50 50 -1 0 0 I I #
+coedge $-1 -1 -1 $-1 $6977 $5222 $6972 $6978 forward $6079 $-1 #
+coedge $-1 -1 -1 $-1 $5222 $6977 $5224 $6083 reversed $6079 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6077 $6979 T -50 -50 -50 50 -50 50 unknown #
+vertex $-1 -1 -1 $-1 $6073 $6980 #
+straight-curve $-1 -1 -1 $-1 0 -50 50 1 0 0 I I #
+coedge $-1 -1 -1 $-1 $5225 $5224 $5473 $6382 reversed $5226 $-1 #
+edge $-1 -1 -1 $-1 $5227 -50 $6981 50 $5224 $6982 forward @7 unknown T 50 -50 -50 50 -50 50 #
+edge $-1 -1 -1 $-1 $5228 -50 $6983 50 $5225 $6984 forward @7 unknown T 50 50 -50 50 50 50 #
+point $-1 -1 -1 $-1 50 -50 50 #
+point $-1 -1 -1 $-1 50 50 50 #
+coedge $-1 -1 -1 $-1 $6985 $5230 $6986 $6987 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $6109 $6988 $5230 $5251 reversed $6989 $-1 #
+coedge $-1 -1 -1 $-1 $6990 $5231 $5234 $6095 reversed $6091 $-1 #
+coedge $-1 -1 -1 $-1 $5231 $6991 $4381 $5247 forward $6091 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6090 $6992 T 30 35 35 37.500000000000007 40 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6993 $5233 $6994 $6995 forward $5235 $-1 #
+coedge $-1 -1 -1 $-1 $5234 $6993 $6996 $6997 forward $5235 $-1 #
+edge $-1 -1 -1 $-1 $6998 37.5 $5236 50 $5234 $6999 forward @7 unknown T 37.5 35.669872981077809 37.5 37.500000000000007 35.669872981077809 50 #
+face $-1 -1 -1 $-1 $7000 $5235 $11 $-1 $7001 reversed single T 37.5 35 35 45 45 50 F #
+point $-1 -1 -1 $-1 37.5 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $5238 $7002 $7003 $7004 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $7005 $7006 $5238 $6100 reversed $7007 $-1 #
+edge $-1 -1 -1 $-1 $7008 -2.0943951023931957 $6104 0 $5238 $7009 forward @7 unknown T 7.4999999999999991 40 50 15.000000000000002 45 50 #
+coedge $-1 -1 -1 $-1 $7010 $5239 $7006 $7011 reversed $6103 $-1 #
+coedge $-1 -1 -1 $-1 $5239 $7012 $5241 $6107 reversed $6103 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6102 $7013 T 15 40 35 22.500000000000007 45 50 unknown #
+vertex $-1 -1 -1 $-1 $7014 $7015 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6108 $5241 $7016 $7017 forward $5243 $-1 #
+edge $-1 -1 -1 $-1 $5244 -50 $7018 -37.5 $5241 $7019 forward @7 unknown T 22.5 44.330127018922191 37.5 22.500000000000007 44.330127018922205 50 #
+coedge $-1 -1 -1 $-1 $5242 $6106 $7020 $7021 forward $5243 $-1 #
+coedge $-1 -1 -1 $-1 $7022 $6088 $6090 $5247 reversed $6989 $-1 #
+face $-1 -1 -1 $-1 $7023 $5243 $11 $-1 $7024 reversed single T 22.5 40 35 30 45 50 F #
+point $-1 -1 -1 $-1 22.5 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $7020 $7025 $5246 $6113 forward $7026 $-1 #
+edge $-1 -1 -1 $-1 $7027 -1.5707963267948966 $6114 6.1232339957367648e-17 $6112 $7028 forward @7 unknown T 30 40 35 35 45 40 #
+vertex $-1 -1 -1 $-1 $7029 $7030 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7031 $6994 $5248 $6117 forward $7032 $-1 #
+edge $-1 -1 -1 $-1 $6118 -2.0943951023931957 $7027 -1.5707963267948966 $6116 $7033 forward @7 unknown T 35 44.330127018922191 35 37.5 45 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $6995 $7034 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $7035 $7036 $11 $-1 $6121 reversed single T 30 40 -50 37.500000000000007 45 -40 F #
+cone-surface $-1 -1 -1 $-1 35 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $7037 $7038 #
+coedge $-1 -1 -1 $-1 $7039 $5254 $7040 $6152 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $7041 $7042 $5254 $6125 reversed $7043 $-1 #
+edge $-1 -1 -1 $-1 $5289 2.617993877991494 $5271 4.7123889803846897 $5254 $7044 forward @7 unknown T 15 20 50 22.5 25 50 #
+coedge $-1 -1 -1 $-1 $5255 $7045 $7041 $6175 forward $6127 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5276 $6138 T 22.5 20 35 30 25 50 unknown #
+coedge $-1 -1 -1 $-1 $6129 $5256 $7046 $7047 reversed $5258 $-1 #
+coedge $-1 -1 -1 $-1 $5257 $6128 $7048 $7049 reversed $5258 $-1 #
+face $-1 -1 -1 $-1 $4407 $5258 $11 $-1 $5288 reversed single T 30 19.999999999999996 35 37.5 25 50 F #
+coedge $-1 -1 -1 $-1 $5261 $5260 $7050 $7051 forward $4392 $-1 #
+coedge $-1 -1 -1 $-1 $5283 $7052 $5260 $6133 reversed $6170 $-1 #
+edge $-1 -1 -1 $-1 $5285 4.1887902047863905 $7053 4.7123889803846897 $5260 $7054 forward @7 unknown T 37.5 29.330127018922191 35 40 30 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $7055 $7046 $5261 $6135 reversed $7056 $-1 #
+edge $-1 -1 -1 $-1 $7057 1.5707963267948966 $6136 2.0943951023931948 $5261 $7054 forward @7 unknown T 37.5 20 35 40 20.669872981077805 37.5 #
+vertex $-1 -1 -1 $-1 $7047 $7058 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $7059 $6127 $11 $-1 $6162 reversed single T 22.5 20 35 30 25 50 F #
+cone-surface $-1 -1 -1 $-1 40 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $5265 $7060 $7061 $7062 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $7063 $7064 $5265 $6142 reversed $7065 $-1 #
+edge $-1 -1 -1 $-1 $7066 -1.5707963267948966 $6146 0.52359877559829826 $5265 $7067 forward @7 unknown T 8.8817841970012523e-16 25 50 7.5000000000000009 30 50 #
+coedge $-1 -1 -1 $-1 $7068 $5266 $7064 $7069 forward $6145 $-1 #
+coedge $-1 -1 -1 $-1 $5266 $7070 $7071 $6149 forward $6145 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6144 $7072 T 7.5000000000000009 25 35 15 30 50 unknown #
+vertex $-1 -1 -1 $-1 $5267 $7073 #
+ellipse-curve $-1 -1 -1 $-1 10 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6150 $5268 $7074 $7075 reversed $5270 $-1 #
+edge $-1 -1 -1 $-1 $7076 40 $5271 50 $6144 $7077 forward @7 unknown T 15 25 40 15 25 50 #
+coedge $-1 -1 -1 $-1 $5269 $6148 $7078 $7079 reversed $5270 $-1 #
+face $-1 -1 -1 $-1 $7080 $5270 $11 $-1 $7081 reversed single T 15 25 35 22.500000000000004 30 50 F #
+edge $-1 -1 -1 $-1 $5271 0 $7082 2.0943951023931948 $6123 $6147 forward @7 unknown T 7.5000000000000009 20 50 15 25 50 #
+point $-1 -1 -1 $-1 15 25 50 #
+coedge $-1 -1 -1 $-1 $7078 $7083 $5273 $6155 reversed $7084 $-1 #
+edge $-1 -1 -1 $-1 $6156 4.1887902047863905 $7085 4.7123889803846897 $5273 $7086 forward @7 unknown T 22.499999999999996 29.330127018922191 35 25 30 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $6155 $7087 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $7088 $5279 $5275 $6159 reversed $6164 $-1 #
+edge $-1 -1 -1 $-1 $7085 1.5707963267948966 $5281 3.1415926535897931 $5275 $7089 forward @7 unknown T 25 25 35 30 30 40 #
+coedge $-1 -1 -1 $-1 $7045 $5276 $7090 $6167 forward $6127 $-1 #
+face $-1 -1 -1 $-1 $7091 $7092 $11 $-1 $7093 reversed single T 7.4999999999999956 20 35 15 25 50 F #
+cone-surface $-1 -1 -1 $-1 25 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $5279 $7088 $7094 $7095 forward $6164 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5279 $7096 T 25 25 30 35 30 40 unknown #
+vertex $-1 -1 -1 $-1 $7095 $7097 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+edge $-1 -1 -1 $-1 $5281 3.1415926535897931 $7098 4.7123889803846897 $6160 $7089 forward @7 unknown T 25 20 35 30 25 40 #
+point $-1 -1 -1 $-1 30 25 40 #
+coedge $-1 -1 -1 $-1 $7052 $5283 $7099 $7100 forward $6170 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5283 $7101 T 35 29.330127018922184 32.499999999999986 40 30 37.500000000000007 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 29.330127018922195 37.500000000000007 #
+face $-1 -1 -1 $-1 $7102 $7103 $11 $-1 $5288 reversed single T 29.999999999999996 25 -40 37.5 29.999999999999996 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $7104 $5287 T 30 25 -50 37.5 29.999999999999996 -40 unknown #
+edge $-1 -1 -1 $-1 $7105 37.5 $5289 50 $6126 $7106 forward @7 unknown T 22.5 20.669872981077805 37.5 22.5 20.669872981077805 50 #
+point $-1 -1 -1 $-1 22.5 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $7107 $5290 $7108 $7109 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $6209 $7110 $5290 $5319 reversed $6230 $-1 #
+coedge $-1 -1 -1 $-1 $7111 $5291 $5293 $5342 reversed $6181 $-1 #
+coedge $-1 -1 -1 $-1 $5291 $7112 $4425 $5316 forward $6181 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6180 $7113 T 15 4.9999999999999982 35 22.500000000000007 10 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5293 $5327 $7114 $7115 forward $5294 $-1 #
+coedge $-1 -1 -1 $-1 $5301 $7116 $5295 $6185 forward $6194 $-1 #
+edge $-1 -1 -1 $-1 $7117 1.5707963267948966 $5303 2.0943951023931957 $6184 $7118 forward @7 unknown T 35 4.9999999999999982 35 37.5 5.6698729810778072 37.5 #
+coedge $-1 -1 -1 $-1 $7119 $6228 $5296 $6187 forward $7120 $-1 #
+edge $-1 -1 -1 $-1 $4438 -2.9403902792268224e-16 $7117 1.5707963267948966 $6186 $7121 forward @7 unknown T 30 4.9999999999999982 35 35 10 40 #
+coedge $-1 -1 -1 $-1 $7122 $7122 $5298 $6189 reversed $7123 $-1 #
+edge $-1 -1 -1 $-1 $6191 1.5707963267948966 $6195 4.7123889803846897 $5298 $7124 forward @7 unknown T 40 5 35 45 15 40 #
+coedge $-1 -1 -1 $-1 $5299 $5336 $7125 $7126 reversed $5337 $-1 #
+vertex $-1 -1 -1 $-1 $7126 $7127 #
+ellipse-curve $-1 -1 -1 $-1 40 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7116 $5301 $7128 $7129 reversed $6194 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6184 $7130 T 35 4.9999999999999982 32.5 40 5.669872981077809 37.5 unknown #
+vertex $-1 -1 -1 $-1 $7129 $7131 #
+point $-1 -1 -1 $-1 37.5 5.6698729810778055 37.5 #
+face $-1 -1 -1 $-1 $6234 $7132 $11 $-1 $5306 reversed single T 37.499999999999993 5 20.000000000000004 45 15 35 F #
+coedge $-1 -1 -1 $-1 $5307 $7133 $7134 $7135 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $7136 $7137 $5307 $6200 reversed $7138 $-1 #
+edge $-1 -1 -1 $-1 $7139 -2.0943951023931948 $6204 0 $5307 $7140 forward @7 unknown T -7.5 10 50 0 15 50 #
+coedge $-1 -1 -1 $-1 $7141 $5308 $7137 $7142 reversed $6203 $-1 #
+coedge $-1 -1 -1 $-1 $5308 $7143 $5310 $6207 reversed $6203 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6202 $7144 T 0 10 35 7.5000000000000009 15 50 unknown #
+vertex $-1 -1 -1 $-1 $7145 $7146 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6208 $5310 $7147 $7148 forward $5312 $-1 #
+edge $-1 -1 -1 $-1 $5313 -50 $7149 -37.499999999999993 $5310 $7150 forward @7 unknown T 7.5 14.330127018922195 37.499999999999993 7.5000000000000009 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $5311 $6206 $7151 $7152 forward $5312 $-1 #
+coedge $-1 -1 -1 $-1 $7153 $6178 $6180 $5316 reversed $6230 $-1 #
+face $-1 -1 -1 $-1 $7154 $5312 $11 $-1 $6231 reversed single T 7.5 10 35 15 15 50 F #
+point $-1 -1 -1 $-1 7.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $7151 $7155 $5315 $6213 forward $7156 $-1 #
+edge $-1 -1 -1 $-1 $7157 -1.5707963267948966 $6214 -2.9403902792268234e-16 $6212 $7158 forward @7 unknown T 15 10 35 20 14.999999999999998 40 #
+vertex $-1 -1 -1 $-1 $7159 $7160 #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7161 $5321 $5317 $6217 forward $6222 $-1 #
+edge $-1 -1 -1 $-1 $5323 -2.0943951023931953 $7157 -1.5707963267948966 $6216 $7162 forward @7 unknown T 20 14.330127018922191 35 22.5 14.999999999999998 37.5 #
+face $-1 -1 -1 $-1 $7163 $7164 $11 $-1 $6219 reversed single T 15 10 -50 22.500000000000004 14.999999999999998 -40 F #
+cone-surface $-1 -1 -1 $-1 20 9.9999999999999982 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $7165 $7166 #
+coedge $-1 -1 -1 $-1 $5321 $7161 $7167 $7168 reversed $6222 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6216 $7169 T 20 14.330127018922189 32.5 25 15 37.5 unknown #
+vertex $-1 -1 -1 $-1 $7168 $7170 #
+ellipse-curve $-1 -1 -1 $-1 25 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.5 14.330127018922193 37.5 #
+coedge $-1 -1 -1 $-1 $5330 $5325 $7171 $7172 reversed $5331 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6186 $7173 $5327 $5334 reversed $7120 $-1 #
+face $-1 -1 -1 $-1 $7174 $7175 $11 $-1 $5329 reversed single T 22.499999999999996 10 20 30 15 35 F #
+loop $-1 -1 -1 $-1 $-1 $6209 $5328 T 7.4999999999999991 5 35 15 10 50 unknown #
+cone-surface $-1 -1 -1 $-1 10 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $7176 $6237 $5330 $6233 reversed $7177 $-1 #
+edge $-1 -1 -1 $-1 $7178 2.9403902792268234e-16 $5332 1.5707963267948966 $5330 $7179 forward @7 unknown T 30 10 30 35 14.999999999999998 35 #
+face $-1 -1 -1 $-1 $7180 $5331 $11 $-1 $7181 reversed single T 25 10 30 35 15 40 F #
+point $-1 -1 -1 $-1 35 14.999999999999998 35 #
+vertex $-1 -1 -1 $-1 $7182 $7183 #
+coedge $-1 -1 -1 $-1 $6232 $7184 $5336 $6238 reversed $7177 $-1 #
+edge $-1 -1 -1 $-1 $5332 1.5707963267948966 $7185 2.0943951023931957 $5336 $7186 forward @7 unknown T 35 14.330127018922191 32.5 37.5 14.999999999999998 35 #
+face $-1 -1 -1 $-1 $7187 $5337 $11 $-1 $7181 reversed single T 35 14.330127018922191 32.5 40 15 37.5 F #
+face $-1 -1 -1 $-1 $5511 $7188 $11 $-1 $4445 reversed single T 29.999999999999996 4.9999999999999982 -40 37.500000000000007 10 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $7189 $5340 T 29.999999999999996 10 -40 37.5 14.999999999999998 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $7190 $5491 $5494 $6425 reversed $5341 $-1 #
+vertex $-1 -1 -1 $-1 $7191 $7192 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7193 $5344 $7194 $6283 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $7195 $7196 $5344 $6247 reversed $7197 $-1 #
+edge $-1 -1 -1 $-1 $5387 2.617993877991494 $5371 4.7123889803846897 $5344 $7198 forward @7 unknown T 0 -10 50 7.5000000000000009 -5 50 #
+coedge $-1 -1 -1 $-1 $5345 $7199 $7195 $6303 forward $5397 $-1 #
+coedge $-1 -1 -1 $-1 $6250 $5346 $7200 $6327 reversed $5348 $-1 #
+coedge $-1 -1 -1 $-1 $5347 $6249 $7201 $7202 reversed $5348 $-1 #
+face $-1 -1 -1 $-1 $4475 $5348 $11 $-1 $5386 reversed single T 15 -10 35 22.500000000000004 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $7203 $7200 $5350 $6253 reversed $7204 $-1 #
+edge $-1 -1 -1 $-1 $5403 1.5707963267948966 $5410 2.0943951023931948 $5350 $5391 forward @7 unknown T 22.500000000000004 -10 35 25 -9.3301270189221945 37.5 #
+coedge $-1 -1 -1 $-1 $5351 $5360 $7205 $7206 forward $5361 $-1 #
+vertex $-1 -1 -1 $-1 $7207 $7208 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6311 $5353 $7209 $7207 forward $6258 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5353 $6316 T 25 -10.000000000000002 30 35 -4.9999999999999991 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $5355 $5355 $7210 $7211 reversed $6261 $-1 #
+loop $-1 -1 -1 $-1 $7212 $6260 $7213 T 40 -10 30 45 0 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7214 $7210 $5357 $6264 forward $6270 $-1 #
+edge $-1 -1 -1 $-1 $5358 -1.5707963267948966 $6321 -1.0471975511965974 $6263 $7215 forward @7 unknown T 37.5 -0.66987298107780924 32.5 40 0 35 #
+point $-1 -1 -1 $-1 40 0 35 #
+coedge $-1 -1 -1 $-1 $7210 $7216 $5360 $6267 forward $6270 $-1 #
+edge $-1 -1 -1 $-1 $7217 1.0471975511965983 $5362 1.5707963267948966 $6266 $7215 forward @7 unknown T 37.5 -10 32.5 40 -9.3301270189221945 35 #
+face $-1 -1 -1 $-1 $5406 $5361 $11 $-1 $6317 reversed single T 35 -10.000000000000002 32.5 40 -9.3301270189221928 37.5 F #
+point $-1 -1 -1 $-1 40 -10 35 #
+loop $-1 -1 -1 $-1 $-1 $7214 $5364 T 37.5 -10 20.000000000000004 45 0 35 unknown #
+coedge $-1 -1 -1 $-1 $5365 $7218 $7219 $7220 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $7221 $7222 $5365 $6273 reversed $7223 $-1 #
+edge $-1 -1 -1 $-1 $7224 -1.5707963267948966 $6277 0.52359877559829893 $5365 $7225 forward @7 unknown T -15 -5 50 -7.4999999999999991 8.8817841970012523e-16 50 #
+coedge $-1 -1 -1 $-1 $7226 $5366 $7222 $7227 forward $6276 $-1 #
+coedge $-1 -1 -1 $-1 $5366 $7228 $7229 $6280 forward $6276 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6275 $7230 T -7.5000000000000018 -5 35 0 0 50 unknown #
+vertex $-1 -1 -1 $-1 $5367 $7231 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6281 $5368 $7232 $7233 reversed $5370 $-1 #
+edge $-1 -1 -1 $-1 $7234 40 $5371 50 $6275 $7235 forward @7 unknown T 0 -5 40 0 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $5369 $6279 $7236 $7237 reversed $5370 $-1 #
+face $-1 -1 -1 $-1 $7238 $5370 $11 $-1 $7239 reversed single T 0 -5 35 7.5000000000000009 0 50 F #
+edge $-1 -1 -1 $-1 $5371 0 $7240 2.0943951023931957 $6245 $6278 forward @7 unknown T -7.5000000000000009 -10 50 0 -5 50 #
+point $-1 -1 -1 $-1 0 -5 50 #
+coedge $-1 -1 -1 $-1 $7236 $7241 $5373 $6286 reversed $7242 $-1 #
+edge $-1 -1 -1 $-1 $6287 4.1887902047863914 $7243 4.7123889803846897 $5373 $7244 forward @7 unknown T 7.5000000000000009 -0.66987298107780635 35 10 0 37.5 #
+vertex $-1 -1 -1 $-1 $6286 $7245 #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $7246 $5379 $5375 $6290 reversed $6294 $-1 #
+edge $-1 -1 -1 $-1 $7243 1.5707963267948966 $5381 3.1415926535897931 $5375 $7247 forward @7 unknown T 10 -4.9999999999999991 35 15 0 40 #
+coedge $-1 -1 -1 $-1 $7199 $5376 $7248 $6297 forward $5397 $-1 #
+face $-1 -1 -1 $-1 $7249 $7250 $11 $-1 $7251 reversed single T -7.5000000000000009 -10 35 0 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $5379 $7246 $7252 $7253 forward $6294 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5379 $6312 T 10 -5 30 20 0 40 unknown #
+vertex $-1 -1 -1 $-1 $7253 $7254 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5381 3.1415926535897931 $7255 4.7123889803846897 $6291 $7247 forward @7 unknown T 10 -10 35 15 -4.9999999999999991 40 #
+point $-1 -1 -1 $-1 15 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $5388 $5383 $7256 $7257 forward $5389 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7258 $7259 $11 $-1 $5386 reversed single T 15 -5 -40 22.500000000000004 -8.8817841970012523e-16 -25 F #
+loop $-1 -1 -1 $-1 $-1 $7260 $5385 T 15 -5.0000000000000009 -50 22.5 -8.8817841970012523e-16 -40 unknown #
+edge $-1 -1 -1 $-1 $7261 37.500000000000007 $5387 50 $6248 $7262 forward @7 unknown T 7.5 -9.3301270189221945 37.500000000000007 7.5000000000000018 -9.3301270189221945 50 #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 50 #
+coedge $-1 -1 -1 $-1 $7263 $6309 $5388 $6306 forward $6313 $-1 #
+edge $-1 -1 -1 $-1 $5390 -1.5707963267948966 $7264 -1.0471975511965974 $6305 $7265 forward @7 unknown T 22.5 -0.66987298107780902 32.5 25 0 35 #
+face $-1 -1 -1 $-1 $7266 $5389 $11 $-1 $6317 reversed single T 20 -0.66987298107781168 32.5 25 0 37.500000000000007 F #
+point $-1 -1 -1 $-1 25 0 35 #
+coedge $-1 -1 -1 $-1 $6305 $6880 $5393 $6310 forward $6313 $-1 #
+edge $-1 -1 -1 $-1 $6314 0 $5390 1.5707963267948966 $6309 $7267 forward @7 unknown T 25 -5 30 30 0 35 #
+coedge $-1 -1 -1 $-1 $5395 $6257 $7268 $7269 reversed $6258 $-1 #
+face $-1 -1 -1 $-1 $7270 $6294 $11 $-1 $6317 reversed single T 10 -5 30 20 0 40 F #
+loop $-1 -1 -1 $-1 $-1 $6880 $5396 T 22.499999999999993 -5.0000000000000009 20 30 0 35 unknown #
+vertex $-1 -1 -1 $-1 $6310 $7271 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6268 $6258 $11 $-1 $6317 reversed single T 25 -10.000000000000002 30 35 -4.9999999999999991 40 F #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 -5 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $7272 1.0471975511965987 $5403 1.5707963267948966 $7273 $7265 forward @7 unknown T 22.500000000000004 -10 32.500000000000007 25 -9.3301270189221945 35 #
+point $-1 -1 -1 $-1 25 -10 35 #
+coedge $-1 -1 -1 $-1 $5404 $5966 $7214 $7274 reversed $4174 $-1 #
+vertex $-1 -1 -1 $-1 $7274 $7275 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $5521 $7276 $11 $-1 $4486 reversed single T 22.5 -10 19.999999999999996 30 -4.9999999999999991 35 F #
+loop $-1 -1 -1 $-1 $-1 $7277 $5407 T 29.999999999999996 -10.000000000000002 -40 37.5 -4.9999999999999991 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $7278 $7279 $7280 $7281 reversed $5408 $-1 #
+coedge $-1 -1 -1 $-1 $5538 $5409 $7282 $7283 reversed $4498 $-1 #
+edge $-1 -1 -1 $-1 $7284 1.5707963267948966 $5410 2.0943951023931957 $7200 $7285 forward @7 unknown T 20 -10 35 22.500000000000004 -9.330127018922191 37.5 #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221963 37.5 #
+coedge $-1 -1 -1 $-1 $7286 $5412 $5663 $6616 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $5637 $5650 $5412 $5428 reversed $5652 $-1 #
+coedge $-1 -1 -1 $-1 $7287 $5413 $5415 $5440 reversed $6333 $-1 #
+coedge $-1 -1 -1 $-1 $5413 $7288 $4512 $5425 forward $6333 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6332 $7289 T -8.8817841970012523e-16 -25 35 7.5000000000000036 -20 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5415 $5434 $6829 $7290 forward $4528 $-1 #
+coedge $-1 -1 -1 $-1 $5418 $7291 $7292 $7293 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $7294 $7295 $5418 $6338 reversed $7296 $-1 #
+edge $-1 -1 -1 $-1 $7297 -2.0943951023931948 $6342 0 $5418 $7298 forward @7 unknown T -22.5 -20 50 -15 -15 50 #
+coedge $-1 -1 -1 $-1 $7299 $5419 $7295 $6611 reversed $6341 $-1 #
+coedge $-1 -1 -1 $-1 $5419 $7300 $5421 $6345 reversed $6341 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6340 $5742 T -15.000000000000002 -20 35 -7.5000000000000009 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $7301 $7302 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5636 $5421 $7303 $7304 forward $3821 $-1 #
+edge $-1 -1 -1 $-1 $5422 -50 $7305 -37.5 $5421 $7306 forward @7 unknown T -7.5000000000000027 -15.669872981077809 37.5 -7.5000000000000009 -15.669872981077807 50 #
+point $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 50 #
+coedge $-1 -1 -1 $-1 $6580 $7307 $5424 $6348 forward $5910 $-1 #
+edge $-1 -1 -1 $-1 $7308 -1.5707963267948966 $6349 6.1232339957367648e-17 $6347 $7309 forward @7 unknown T -8.8817841970012523e-16 -20 35 4.9999999999999991 -15 40 #
+vertex $-1 -1 -1 $-1 $6603 $7310 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5892 $5430 $5426 $6352 forward $5893 $-1 #
+edge $-1 -1 -1 $-1 $5432 -2.0943951023931948 $7308 -1.5707963267948966 $6351 $7311 forward @7 unknown T 4.9999999999999991 -15.669872981077807 35 7.5000000000000009 -15 37.5 #
+face $-1 -1 -1 $-1 $7312 $7313 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 -50 7.5 -15 -40 F #
+vertex $-1 -1 -1 $-1 $5664 $7314 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000009 -15.669872981077807 37.499999999999993 #
+face $-1 -1 -1 $-1 $5570 $7315 $11 $-1 $1477 reversed single T 15 -25 -40 22.500000000000004 -20 -25 F #
+loop $-1 -1 -1 $-1 $-1 $6775 $5438 T 15 -20 -40 22.500000000000004 -15 -25 unknown #
+coedge $-1 -1 -1 $-1 $7316 $5548 $5550 $5592 reversed $5439 $-1 #
+vertex $-1 -1 -1 $-1 $7317 $7318 #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5554 $5929 $5442 $6363 forward $5977 $-1 #
+edge $-1 -1 -1 $-1 $5945 1.5707963267948966 $5556 2.0943951023931939 $6362 $7319 forward @7 unknown T 35 -15.669872981077809 -42.5 37.499999999999993 -15.000000000000004 -40 #
+coedge $-1 -1 -1 $-1 $6028 $6956 $5444 $6365 reversed $6935 $-1 #
+edge $-1 -1 -1 $-1 $5448 -2.0943951023931953 $6366 -1.5707963267948966 $5444 $7320 forward @7 unknown T -25.000000000000004 -40 32.5 -22.500000000000004 -39.330127018922191 35 #
+vertex $-1 -1 -1 $-1 $7321 $7322 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5198 $6373 $11 $-1 $388 reversed single T -25.000000000000004 -30.669872981077809 32.5 -20 -30 37.500000000000007 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 32.5 #
+coedge $-1 -1 -1 $-1 $6949 $6947 $5450 $6371 forward $6950 $-1 #
+edge $-1 -1 -1 $-1 $6967 6.1232339957367648e-17 $6366 1.5707963267948966 $6370 $7323 forward @7 unknown T -30.000000000000004 -40 35 -25.000000000000004 -35 40 #
+coedge $-1 -1 -1 $-1 $6928 $5455 $6067 $6969 forward $6373 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6372 $6368 T -25.000000000000004 -30.669872981077809 32.5 -20 -30 37.500000000000007 unknown #
+point $-1 -1 -1 $-1 4.9999999999999982 -30 -40 #
+coedge $-1 -1 -1 $-1 $5461 $6652 $5469 $5713 reversed $5753 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6658 $6059 $5470 $6379 reversed $6659 $-1 #
+edge $-1 -1 -1 $-1 $6649 -1.5707963267948966 $6061 -1.0471975511965956 $5470 $3091 forward @7 unknown T -7.5000000000000089 -30.669872981077813 -42.500000000000014 -5 -30 -40 #
+coedge $-1 -1 -1 $-1 $7324 $5473 $6977 $7325 forward $4584 $-1 #
+coedge $-1 -1 -1 $-1 $5473 $7324 $6680 $7326 forward $4584 $-1 #
+edge $-1 -1 -1 $-1 $6983 -50 $6981 50 $6082 $7327 forward @7 unknown T 50 -50 -50 50 50 -50 #
+coedge $-1 -1 -1 $-1 $7328 $5474 $7329 $7330 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $7331 $7332 $5474 $6385 reversed $7333 $-1 #
+edge $-1 -1 -1 $-1 $6393 -2.0943951023931957 $7334 2.0943951023931957 $5474 $7335 forward @7 unknown T 37.5 35 -50 45 45 -50 #
+coedge $-1 -1 -1 $-1 $5475 $7336 $7337 $7338 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $7339 $7340 $5475 $6388 reversed $7341 $-1 #
+edge $-1 -1 -1 $-1 $7342 -2.0943951023931957 $6392 0 $5475 $7343 forward @7 unknown T 22.5 35 -50 30 40 -50 #
+coedge $-1 -1 -1 $-1 $7344 $5476 $7345 $7346 forward $6391 $-1 #
+coedge $-1 -1 -1 $-1 $5476 $7347 $7331 $7348 reversed $6391 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6390 $7349 T 30 35 -50 37.500000000000014 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $7350 $7351 #
+vertex $-1 -1 -1 $-1 $6385 $7352 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7353 $5478 $7354 $6417 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $7104 $6412 $5478 $6397 reversed $6174 $-1 #
+edge $-1 -1 -1 $-1 $6401 -0.5235987755982987 $5487 1.5707963267948957 $5478 $7355 forward @7 unknown T 30 25 -50 37.5 29.999999999999996 -50 #
+coedge $-1 -1 -1 $-1 $7356 $5479 $5485 $6415 forward $6400 $-1 #
+coedge $-1 -1 -1 $-1 $5479 $7357 $7104 $7358 forward $6400 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6398 $7359 T 37.499999999999986 20 -50 45 30 -40 unknown #
+vertex $-1 -1 -1 $-1 $7358 $7360 #
+ellipse-curve $-1 -1 -1 $-1 40 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $5481 $7361 $7362 $7363 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $7364 $7365 $5481 $6405 reversed $7366 $-1 #
+edge $-1 -1 -1 $-1 $7367 1.5707963267948966 $6409 3.6651914291880923 $5481 $7368 forward @7 unknown T 15 20 -50 22.5 25 -50 #
+coedge $-1 -1 -1 $-1 $7369 $5482 $7365 $7370 forward $6408 $-1 #
+coedge $-1 -1 -1 $-1 $5482 $7371 $5484 $6413 reversed $6408 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6407 $7372 T 22.499999999999993 20 -50 30 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $5483 $7373 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6414 $5484 $7374 $7375 reversed $5486 $-1 #
+coedge $-1 -1 -1 $-1 $6396 $7376 $7377 $6413 reversed $6174 $-1 #
+edge $-1 -1 -1 $-1 $5487 -50 $7378 -45 $7377 $7379 forward @7 unknown T 30 25 -50 30 25 -45 #
+coedge $-1 -1 -1 $-1 $5485 $6411 $7380 $7381 reversed $5486 $-1 #
+edge $-1 -1 -1 $-1 $5488 -50 $7382 -42.5 $6398 $7383 forward @7 unknown T 37.5 20.669872981077805 -50 37.500000000000007 20.669872981077805 -42.5 #
+face $-1 -1 -1 $-1 $5263 $5486 $11 $-1 $5288 reversed single T 30 19.999999999999996 -50 37.500000000000007 25 -40 F #
+edge $-1 -1 -1 $-1 $5487 0 $7384 2.0943951023931948 $6395 $6410 forward @7 unknown T 22.5 25 -50 30 30 -50 #
+point $-1 -1 -1 $-1 30 25 -50 #
+point $-1 -1 -1 $-1 37.5 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $7385 $5490 $7386 $7387 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $6444 $7388 $5490 $5512 reversed $7389 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7390 $5493 $7391 $7392 forward $5495 $-1 #
+coedge $-1 -1 -1 $-1 $5494 $7390 $7393 $7394 forward $5495 $-1 #
+edge $-1 -1 -1 $-1 $7395 42.500000000000007 $5496 50 $5494 $7396 forward @7 unknown T 37.5 14.330127018922193 -50 37.5 14.330127018922195 -42.500000000000007 #
+face $-1 -1 -1 $-1 $7397 $5495 $11 $-1 $5306 reversed single T 37.5 5 -50 45 15 -40 F #
+point $-1 -1 -1 $-1 37.5 14.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $5498 $7398 $7399 $7400 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $7401 $7402 $5498 $6430 reversed $7403 $-1 #
+edge $-1 -1 -1 $-1 $7404 -2.0943951023931957 $6434 0 $5498 $7405 forward @7 unknown T 7.4999999999999991 5 -50 15 10 -50 #
+coedge $-1 -1 -1 $-1 $7406 $5499 $7407 $7408 forward $6433 $-1 #
+coedge $-1 -1 -1 $-1 $5499 $7409 $5501 $6437 reversed $6433 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6432 $7410 T 15 4.9999999999999982 -50 22.500000000000004 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $7411 $7412 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6438 $5501 $7413 $7414 forward $5503 $-1 #
+edge $-1 -1 -1 $-1 $5504 -50 $7415 -42.5 $5501 $7416 forward @7 unknown T 22.5 5.6698729810778064 -50 22.500000000000004 5.6698729810778064 -42.5 #
+coedge $-1 -1 -1 $-1 $5502 $6436 $7417 $7418 forward $5503 $-1 #
+face $-1 -1 -1 $-1 $7419 $5503 $11 $-1 $5329 reversed single T 22.5 5 -50 30 10 -40 F #
+point $-1 -1 -1 $-1 22.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $7417 $7420 $5506 $6442 forward $7421 $-1 #
+edge $-1 -1 -1 $-1 $7422 -1.5707963267948966 $6445 2.9403902792268234e-16 $6441 $7423 forward @7 unknown T 30 4.9999999999999982 -45 35 10 -40 #
+coedge $-1 -1 -1 $-1 $5507 $7190 $7424 $7425 reversed $5341 $-1 #
+coedge $-1 -1 -1 $-1 $7426 $6421 $5502 $5508 forward $7389 $-1 #
+vertex $-1 -1 -1 $-1 $7427 $7428 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7429 $7391 $5509 $6448 forward $7430 $-1 #
+edge $-1 -1 -1 $-1 $6449 -2.0943951023931957 $7422 -1.5707963267948966 $6447 $7431 forward @7 unknown T 35 4.9999999999999982 -42.5 37.500000000000007 5.6698729810778072 -40 #
+vertex $-1 -1 -1 $-1 $7392 $7432 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $7433 $7434 #
+coedge $-1 -1 -1 $-1 $7435 $5515 $7436 $6478 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $7260 $6474 $5515 $6454 reversed $6302 $-1 #
+edge $-1 -1 -1 $-1 $5546 -0.5235987755982987 $5529 1.5707963267948966 $5515 $7437 forward @7 unknown T 15 -5.0000000000000009 -50 22.5 -8.8817841970012523e-16 -50 #
+coedge $-1 -1 -1 $-1 $5516 $7438 $7260 $6500 forward $6456 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5539 $6464 T 22.499999999999996 -5.0000000000000009 -50 30 0 -40 unknown #
+coedge $-1 -1 -1 $-1 $5519 $5518 $7439 $7440 forward $4607 $-1 #
+coedge $-1 -1 -1 $-1 $5542 $7441 $5518 $6459 reversed $6497 $-1 #
+edge $-1 -1 -1 $-1 $5544 1.0471975511965983 $7442 1.5707963267948966 $5518 $7443 forward @7 unknown T 37.5 -10 -42.5 40 -9.3301270189221945 -40 #
+coedge $-1 -1 -1 $-1 $7444 $7282 $5519 $6461 reversed $7445 $-1 #
+edge $-1 -1 -1 $-1 $7446 -1.5707963267948966 $6462 -1.0471975511965974 $5519 $7443 forward @7 unknown T 37.5 -0.66987298107780924 -42.5 40 0 -40 #
+vertex $-1 -1 -1 $-1 $7283 $7447 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $7448 $6456 $11 $-1 $4486 reversed single T 22.499999999999996 -5.0000000000000009 -50 30 0 -40 F #
+coedge $-1 -1 -1 $-1 $5523 $7449 $7450 $7451 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $7452 $7453 $5523 $6467 reversed $7454 $-1 #
+edge $-1 -1 -1 $-1 $7455 1.5707963267948966 $6471 3.6651914291880923 $5523 $7456 forward @7 unknown T 0 -10 -50 7.5 -5 -50 #
+coedge $-1 -1 -1 $-1 $7457 $5524 $7453 $7458 forward $6470 $-1 #
+coedge $-1 -1 -1 $-1 $5524 $7459 $5526 $6475 reversed $6470 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6469 $7460 T 7.4999999999999964 -10 -50 15 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $5525 $7461 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6476 $5526 $7462 $7463 reversed $5528 $-1 #
+coedge $-1 -1 -1 $-1 $6453 $7464 $7465 $6475 reversed $6302 $-1 #
+edge $-1 -1 -1 $-1 $5529 -50 $7466 -45 $7465 $7467 forward @7 unknown T 15 -5 -50 15 -5 -45 #
+coedge $-1 -1 -1 $-1 $5527 $6473 $7468 $7469 reversed $5528 $-1 #
+face $-1 -1 -1 $-1 $3648 $5528 $11 $-1 $5386 reversed single T 15 -10 -50 22.500000000000004 -5 -40 F #
+edge $-1 -1 -1 $-1 $5529 0 $7470 2.0943951023931957 $6452 $6472 forward @7 unknown T 7.4999999999999991 -5 -50 15 0 -50 #
+point $-1 -1 -1 $-1 15 -5 -50 #
+coedge $-1 -1 -1 $-1 $7468 $7471 $5531 $6481 reversed $7472 $-1 #
+edge $-1 -1 -1 $-1 $6482 1.0471975511965974 $7473 1.5707963267948966 $5531 $7474 forward @7 unknown T 22.5 -10 -42.500000000000007 25 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $6481 $7475 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7476 $5536 $5533 $6485 reversed $6488 $-1 #
+edge $-1 -1 -1 $-1 $7473 -1.5707963267948966 $5540 0 $5533 $7477 forward @7 unknown T 25 -10 -45 30 -5 -40 #
+face $-1 -1 -1 $-1 $7478 $7479 $11 $-1 $5398 reversed single T 7.4999999999999991 -5 -50 15 0 -40 F #
+coedge $-1 -1 -1 $-1 $5536 $7476 $7480 $7481 forward $6488 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5536 $7482 T 25 -10.000000000000002 -45 35 -4.9999999999999991 -35 unknown #
+vertex $-1 -1 -1 $-1 $5537 $7483 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7484 $7485 $5538 $6492 forward $7486 $-1 #
+edge $-1 -1 -1 $-1 $5540 2.9403902792268234e-16 $7487 1.5707963267948966 $6491 $7488 forward @7 unknown T 30 -5 -45 35 -1.7763568394002505e-15 -40 #
+coedge $-1 -1 -1 $-1 $7438 $5539 $7485 $6494 forward $6456 $-1 #
+edge $-1 -1 -1 $-1 $5540 0 $7489 1.5707963267948966 $6493 $7477 forward @7 unknown T 25 -5 -45 30 0 -40 #
+point $-1 -1 -1 $-1 30 -5 -45 #
+coedge $-1 -1 -1 $-1 $7441 $5542 $7277 $7490 forward $6497 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5542 $7491 T 35 -10.000000000000002 -42.5 40 -9.3301270189221928 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 -9.3301270189221945 -42.5 #
+edge $-1 -1 -1 $-1 $7492 42.500000000000007 $5546 50 $6455 $7493 forward @7 unknown T 22.5 -0.66987298107780857 -50 22.5 -0.66987298107780635 -42.500000000000007 #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780635 -50 #
+coedge $-1 -1 -1 $-1 $7494 $5547 $7495 $7496 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $6529 $7497 $5547 $5571 reversed $6542 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $5550 $5585 $7498 $7499 forward $4234 $-1 #
+coedge $-1 -1 -1 $-1 $6892 $6892 $5551 $6507 reversed $5923 $-1 #
+edge $-1 -1 -1 $-1 $6508 -1.5707963267948966 $6511 1.5707963267948966 $5551 $7500 forward @7 unknown T 40 -25 -45 45 -15 -40 #
+vertex $-1 -1 -1 $-1 $5553 $7501 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5929 $5554 $5928 $6847 reversed $5977 $-1 #
+vertex $-1 -1 -1 $-1 $5555 $7502 #
+point $-1 -1 -1 $-1 37.499999999999986 -15.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $5558 $7503 $7504 $7505 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $7506 $7507 $5558 $6515 reversed $7508 $-1 #
+edge $-1 -1 -1 $-1 $7509 -2.0943951023931957 $6519 0 $5558 $7510 forward @7 unknown T -7.5000000000000009 -25 -50 0 -20 -50 #
+coedge $-1 -1 -1 $-1 $7511 $5559 $7512 $7513 forward $6518 $-1 #
+coedge $-1 -1 -1 $-1 $5559 $7514 $5561 $6522 reversed $6518 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6517 $7515 T -8.8817841970012523e-16 -25 -50 7.5000000000000036 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $7516 $7517 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6523 $5561 $7518 $7519 forward $5563 $-1 #
+edge $-1 -1 -1 $-1 $5564 -50 $7520 -42.500000000000014 $5561 $7521 forward @7 unknown T 7.5 -24.330127018922195 -50 7.5000000000000027 -24.330127018922191 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $5562 $6521 $7522 $7523 forward $5563 $-1 #
+face $-1 -1 -1 $-1 $7524 $5563 $11 $-1 $4529 reversed single T 7.4999999999999964 -25 -50 15 -20 -40 F #
+point $-1 -1 -1 $-1 7.5 -24.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $7522 $7525 $5566 $6527 forward $6896 $-1 #
+edge $-1 -1 -1 $-1 $7526 -1.5707963267948966 $6530 -6.1232339957367648e-17 $6526 $7527 forward @7 unknown T 15 -25 -45 20 -20 -40 #
+coedge $-1 -1 -1 $-1 $5567 $7316 $7528 $7529 reversed $5439 $-1 #
+coedge $-1 -1 -1 $-1 $7530 $6503 $5562 $5568 forward $6542 $-1 #
+vertex $-1 -1 -1 $-1 $7531 $7532 #
+coedge $-1 -1 -1 $-1 $7533 $5573 $5569 $6533 forward $6536 $-1 #
+edge $-1 -1 -1 $-1 $5575 -2.0943951023931966 $7526 -1.5707963267948966 $6532 $7534 forward @7 unknown T 20 -25 -42.500000000000014 22.500000000000004 -24.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $7535 $7536 #
+coedge $-1 -1 -1 $-1 $5573 $7533 $6856 $7537 reversed $6536 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6532 $7538 T 20 -25 -42.500000000000014 25 -24.330127018922191 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $5574 $7539 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $5580 $5577 $5942 $5947 reversed $4209 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $6529 $5579 T 7.4999999999999947 -20 -50 15 -15 -40 unknown #
+edge $-1 -1 -1 $-1 $5044 -6.4931039580273265e-16 $5581 1.5707963267948966 $5580 $7540 forward @7 unknown T 30 -25.000000000000004 -40 35 -20 -35 #
+point $-1 -1 -1 $-1 35 -25.000000000000004 -40 #
+coedge $-1 -1 -1 $-1 $5583 $5940 $5585 $5586 reversed $5086 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $7499 $7541 #
+vertex $-1 -1 -1 $-1 $7542 $7543 #
+coedge $-1 -1 -1 $-1 $5738 $5595 $5613 $6570 forward $4659 $-1 #
+coedge $-1 -1 -1 $-1 $5595 $5738 $5598 $5740 reversed $4659 $-1 #
+coedge $-1 -1 -1 $-1 $6554 $6644 $5595 $6553 reversed $6642 $-1 #
+edge $-1 -1 -1 $-1 $6668 -2.0943951023931957 $6571 -1.5707963267948966 $5595 $7544 forward @7 unknown T -25.000000000000004 -40 -42.500000000000007 -22.500000000000004 -39.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $6645 $6552 $5596 $6555 reversed $6642 $-1 #
+edge $-1 -1 -1 $-1 $6556 -50 $6668 -42.500000000000007 $5596 $7545 forward @7 unknown T -22.500000000000004 -39.330127018922198 -50 -22.5 -39.330127018922191 -42.500000000000007 #
+vertex $-1 -1 -1 $-1 $5597 $7546 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5602 $5601 $6644 $7547 forward $5594 $-1 #
+edge $-1 -1 -1 $-1 $5603 -1.5707963267948966 $3866 0 $5706 $5711 forward @7 unknown T -35 -40 -45 -30 -35 -40 #
+point $-1 -1 -1 $-1 -35 -40 -40 #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -35 -25.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5607 $5606 $6698 $7548 forward $5608 $-1 #
+face $-1 -1 -1 $-1 $7549 $5608 $11 $-1 $482 reversed single T -35 -40 -30.000000000000004 -25 -35 -19.999999999999996 F #
+point $-1 -1 -1 $-1 -35 -40 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $5613 $5611 $5737 $6666 reversed $4670 $-1 #
+coedge $-1 -1 -1 $-1 $7550 $7551 $5611 $6567 forward $7552 $-1 #
+edge $-1 -1 -1 $-1 $7553 -2.0943951023931957 $6568 -1.570796326794897 $6566 $7554 forward @7 unknown T -25.000000000000004 -40 -27.500000000000004 -22.500000000000004 -39.330127018922191 -25 #
+vertex $-1 -1 -1 $-1 $5612 $7555 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6571 1.5707963267948966 $6667 2.0943951023931953 $6550 $7556 forward @7 unknown T -25.000000000000004 -40 -40 -22.500000000000004 -39.330127018922191 -37.5 #
+vertex $-1 -1 -1 $-1 $7547 $7557 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5696 $5777 $5618 $5616 reversed $6636 $-1 #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922198 -37.500000000000007 #
+edge $-1 -1 -1 $-1 $5629 4.1887902047863905 $5710 4.7123889803846897 $5627 $6557 forward @7 unknown T -37.500000000000007 -30.669872981077809 -40 -35 -30 -37.5 #
+point $-1 -1 -1 $-1 -37.500000000000007 -30.669872981077805 -37.5 #
+face $-1 -1 -1 $-1 $5070 $7558 $11 $-1 $3822 reversed single T -7.5000000000000053 -20 20 0 -15 35 F #
+loop $-1 -1 -1 $-1 $7559 $7560 $5634 T -45 -24.999999999999996 14.999999999999996 -40 -14.999999999999996 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $7561 $7562 $6605 $7563 forward $5635 $-1 #
+coedge $-1 -1 -1 $-1 $7564 $6347 $5636 $6581 reversed $5910 $-1 #
+edge $-1 -1 -1 $-1 $7565 1.5707963267948966 $6349 3.1415926535897931 $5636 $7566 forward @7 unknown T -5 -20 35 0 -15 40 #
+vertex $-1 -1 -1 $-1 $5639 $7567 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $7568 $5640 $7569 $7570 reversed $6586 $-1 #
+coedge $-1 -1 -1 $-1 $5640 $7571 $7572 $7573 reversed $6586 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7568 $7574 T -45 -24.999999999999996 35 -37.499999999999993 -14.999999999999996 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $6594 $5642 $7575 $7576 reversed $5644 $-1 #
+coedge $-1 -1 -1 $-1 $7572 $7577 $5642 $6590 forward $7578 $-1 #
+edge $-1 -1 -1 $-1 $7579 -2.0943951023931957 $5645 -1.5707963267948966 $6589 $7580 forward @7 unknown T -40 -24.999999999999996 32.499999999999993 -37.5 -24.330127018922187 35 #
+coedge $-1 -1 -1 $-1 $5643 $7581 $7582 $7583 reversed $5644 $-1 #
+coedge $-1 -1 -1 $-1 $7584 $7569 $5643 $6593 forward $7585 $-1 #
+edge $-1 -1 -1 $-1 $5646 1.5707963267948966 $7586 2.0943951023931953 $6592 $7587 forward @7 unknown T -40 -15.669872981077805 32.5 -37.5 -14.999999999999996 35 #
+coedge $-1 -1 -1 $-1 $7588 $6588 $7589 $7590 reversed $5644 $-1 #
+face $-1 -1 -1 $-1 $7574 $5644 $11 $-1 $7591 reversed single T -45 -24.999999999999996 19.999999999999996 -37.5 -14.999999999999996 35 F #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 35 #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 35 #
+coedge $-1 -1 -1 $-1 $7592 $5648 $7593 $7594 forward $6600 $-1 #
+coedge $-1 -1 -1 $-1 $5648 $7595 $5655 $6606 forward $6600 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7592 $7596 T -7.5000000000000027 -25 20 0 -20 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7597 $7593 $5651 $6603 reversed $6836 $-1 #
+edge $-1 -1 -1 $-1 $6349 3.1415926535897931 $5653 4.7123889803846897 $5651 $7566 forward @7 unknown T -5 -25 35 0 -20 40 #
+point $-1 -1 -1 $-1 -5 -25 35 #
+coedge $-1 -1 -1 $-1 $7598 $5655 $6579 $7563 reversed $5657 $-1 #
+edge $-1 -1 -1 $-1 $7599 22.500000000000004 $5658 32.5 $6599 $7600 forward @7 unknown T -7.5000000000000027 -24.330127018922195 22.500000000000004 -7.5000000000000009 -24.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $5656 $7598 $7601 $7602 forward $5657 $-1 #
+coedge $-1 -1 -1 $-1 $7603 $5661 $5656 $5666 forward $6613 $-1 #
+face $-1 -1 -1 $-1 $5665 $5657 $11 $-1 $6619 reversed single T -15.000000000000002 -25 20 -7.5000000000000009 -20 35 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 32.5 #
+edge $-1 -1 -1 $-1 $6614 40 $6342 50 $7295 $7604 forward @7 unknown T -15 -20 40 -15 -20 50 #
+coedge $-1 -1 -1 $-1 $5661 $7603 $7605 $7606 reversed $6613 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5661 $7607 T -20 -25 30 -10.000000000000002 -20 40 unknown #
+vertex $-1 -1 -1 $-1 $7606 $7608 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6354 2.617993877991494 $6342 4.7123889803846897 $6329 $7609 forward @7 unknown T -15.000000000000002 -25 50 -7.5000000000000009 -20 50 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $7610 $7611 $11 $-1 $6619 reversed single T -15.000000000000002 -20 -50 -7.5000000000000009 -15 -40 F #
+cone-surface $-1 -1 -1 $-1 -10.000000000000002 -20 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $7612 $7613 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $7614 $7615 $3147 T -50 -25 -3.0616169978683823e-15 -50 -15 9.9999999999999964 hole $3148 T #
+coedge $-1 -1 -1 $-1 $6623 $6623 $7616 $7617 forward $5670 $-1 #
+coedge $-1 -1 -1 $-1 $5720 $5674 $5677 $6626 forward $1370 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $5679 -2.0943951023931957 $4755 0 $6624 $6643 forward @7 unknown T -37.5 -40 -50 -30 -35 -50 #
+face $-1 -1 -1 $-1 $7618 $5678 $11 $-1 $2412 reversed single T -37.500000000000014 -40 -50 -30 -35 -40 F #
+point $-1 -1 -1 $-1 -37.5 -39.330127018922191 -50 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 -30.669872981077805 -50 #
+face $-1 -1 -1 $-1 $7619 $7620 $11 $-1 $7591 reversed single T -45 -24.999999999999996 -25.000000000000004 -37.5 -14.999999999999996 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $5698 $5690 $5788 $6707 reversed $5699 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5777 $5696 $7621 $7622 forward $6636 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6635 $5775 T -35 -35 -30.000000000000004 -25 -30 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $6738 $7621 $5698 $6639 reversed $7623 $-1 #
+edge $-1 -1 -1 $-1 $7624 -2.0943951023931948 $5700 -1.5707963267948961 $5698 $7625 forward @7 unknown T -25.000000000000007 -30.669872981077805 -25 -22.500000000000004 -30 -22.5 #
+face $-1 -1 -1 $-1 $1616 $5699 $11 $-1 $482 reversed single T -25.000000000000007 -30.669872981077809 -27.500000000000004 -20 -30 -22.5 F #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 -25 #
+loop $-1 -1 -1 $-1 $-1 $6554 $5704 T -30.000000000000004 -40 -50 -22.5 -35 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6552 $5707 $6558 $7547 reversed $6642 $-1 #
+coedge $-1 -1 -1 $-1 $5707 $6554 $5720 $6655 reversed $6642 $-1 #
+face $-1 -1 -1 $-1 $7626 $7627 $11 $-1 $7628 reversed single T -30 -20 20 -22.499999999999993 -15 35 F #
+point $-1 -1 -1 $-1 -35 -30 -40 #
+vertex $-1 -1 -1 $-1 $6379 $7629 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5717 $5824 $6658 $7630 forward $4916 $-1 #
+coedge $-1 -1 -1 $-1 $6375 $5826 $5717 $6653 reversed $5753 $-1 #
+edge $-1 -1 -1 $-1 $6649 1.5707963267948966 $3885 3.1415926535897931 $5717 $3886 forward @7 unknown T -5 -35 -40 0 -30 -35 #
+point $-1 -1 -1 $-1 4.9999999999999982 -40 -40 #
+edge $-1 -1 -1 $-1 $4755 1.5707963267948966 $6556 3.6651914291880932 $5720 $7631 forward @7 unknown T -30.000000000000004 -40 -50 -22.5 -35 -50 #
+coedge $-1 -1 -1 $-1 $5722 $5737 $7551 $6709 forward $4798 $-1 #
+edge $-1 -1 -1 $-1 $5820 27.500000000000004 $6660 37.5 $5824 $7632 forward @7 unknown T -7.5000000000000027 -30.669872981077813 -37.5 -7.5000000000000009 -30.669872981077805 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $5725 $6378 $6651 $7630 reversed $6659 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5725 $5743 T -10.000000000000002 -30.669872981077813 -42.500000000000014 -5 -30 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $7630 $7633 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 -40 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -10.000000000000002 -30 -25 #
+point $-1 -1 -1 $-1 -20 -30 -25 #
+edge $-1 -1 -1 $-1 $6667 -37.5 $7553 -27.500000000000004 $5737 $7634 forward @7 unknown T -22.500000000000004 -39.330127018922198 -37.5 -22.5 -39.330127018922191 -27.500000000000004 #
+vertex $-1 -1 -1 $-1 $6570 $7635 #
+vertex $-1 -1 -1 $-1 $5740 $7636 #
+face $-1 -1 -1 $-1 $7637 $7638 $11 $-1 $6619 reversed single T -15.000000000000002 -20 20 -7.5000000000000009 -15 35 F #
+loop $-1 -1 -1 $-1 $7639 $7640 $1558 T 50 -25 -45 50 -15 -35 hole $1559 T #
+coedge $-1 -1 -1 $-1 $6671 $6671 $7641 $7642 forward $5744 $-1 #
+coedge $-1 -1 -1 $-1 $6672 $6672 $5745 $6673 reversed $5951 $-1 #
+edge $-1 -1 -1 $-1 $7643 0 $7643 6.2831853071795862 $5745 $7644 forward @7 unknown T 50 -25 -14.999999999999996 50 -15 -4.9999999999999964 #
+vertex $-1 -1 -1 $-1 $5747 $7645 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 5.0000000000000027 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -20 15.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $6074 $5760 $6381 $7326 reversed $4826 $-1 #
+coedge $-1 -1 -1 $-1 $5780 $7646 $5761 $6682 reversed $6704 $-1 #
+edge $-1 -1 -1 $-1 $4856 1.5707963267948966 $7647 3.1415926535897931 $5761 $7648 forward @7 unknown T -35 -35 -10.000000000000002 -30 -30 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $7649 $6016 $5762 $6684 reversed $6726 $-1 #
+edge $-1 -1 -1 $-1 $7650 0 $5994 1.5707963267948966 $5762 $7651 forward @7 unknown T -35 -35 -1.7763568394002505e-15 -30 -30 4.9999999999999982 #
+edge $-1 -1 -1 $-1 $7647 -5.0000000000000018 $7650 -1.7763568394002505e-15 $5763 $7652 forward @7 unknown T -30 -35 -5.0000000000000018 -30 -35 -1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $6010 $7653 $5765 $6687 reversed $6914 $-1 #
+edge $-1 -1 -1 $-1 $5992 -1.5707963267948966 $7650 0 $5765 $7651 forward @7 unknown T -35 -40 -1.7763568394002505e-15 -30 -35 4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $7654 $5769 $5766 $6689 reversed $6692 $-1 #
+edge $-1 -1 -1 $-1 $7647 3.1415926535897931 $4846 4.7123889803846897 $5766 $7648 forward @7 unknown T -35 -40 -10.000000000000002 -30 -35 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $7655 $7656 $7657 $6685 forward $6729 $-1 #
+coedge $-1 -1 -1 $-1 $5769 $7654 $6697 $7658 forward $6692 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7654 $7659 T -35 -40 -15.000000000000004 -25.000000000000004 -35 -5.0000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $5781 $7660 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -10.000000000000002 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $5771 $7661 #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -35 -25.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7662 $5773 $6691 $7658 reversed $6700 $-1 #
+coedge $-1 -1 -1 $-1 $5773 $7663 $6562 $7548 reversed $6700 $-1 #
+coedge $-1 -1 -1 $-1 $7621 $7664 $4853 $5774 reversed $7623 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7663 $7665 T -30.000000000000004 -40 -25 -22.5 -35 -10.000000000000002 unknown #
+straight-curve $-1 -1 -1 $-1 -30 -35 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -35 -30 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $7646 $5780 $7664 $7666 forward $6704 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7646 $6708 T -35 -35 -15.000000000000004 -25.000000000000004 -30 -5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $5793 $5783 $7667 $7668 forward $4776 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7624 4.1887902047863914 $5735 4.7123889803846897 $5788 $7669 forward @7 unknown T -22.500000000000004 -30.669872981077805 -25 -20 -30 -22.500000000000004 #
+face $-1 -1 -1 $-1 $7659 $6704 $11 $-1 $336 reversed single T -35 -35 -15.000000000000004 -25.000000000000004 -30 -5.0000000000000018 F #
+edge $-1 -1 -1 $-1 $7553 1.0471975511965974 $5791 1.5707963267948966 $6656 $6633 forward @7 unknown T -22.500000000000004 -40 -27.500000000000004 -20 -39.330127018922191 -25 #
+point $-1 -1 -1 $-1 -20 -40 -25 #
+coedge $-1 -1 -1 $-1 $7663 $7662 $5793 $6712 reversed $6700 $-1 #
+edge $-1 -1 -1 $-1 $7670 -22.500000000000004 $5812 -12.500000000000005 $5793 $7671 forward @7 unknown T -22.500000000000004 -39.330127018922198 -22.500000000000004 -22.5 -39.330127018922191 -12.500000000000005 #
+coedge $-1 -1 -1 $-1 $5808 $5794 $7662 $7672 forward $5809 $-1 #
+coedge $-1 -1 -1 $-1 $7673 $6001 $5795 $6003 reversed $6906 $-1 #
+coedge $-1 -1 -1 $-1 $7674 $7675 $5799 $6716 reversed $7676 $-1 #
+edge $-1 -1 -1 $-1 $6720 -2.4999999999999969 $6724 7.4999999999999991 $5799 $7677 forward @7 unknown T -22.500000000000007 -30.669872981077813 -7.4999999999999991 -22.5 -30.669872981077805 2.4999999999999969 #
+coedge $-1 -1 -1 $-1 $7678 $5800 $5997 $6901 reversed $6719 $-1 #
+coedge $-1 -1 -1 $-1 $5800 $7678 $7674 $7679 forward $6719 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7678 $7680 T -25.000000000000004 -30.669872981077809 2.4999999999999969 -20 -30 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $6716 $7681 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 4.9999999999999991 -0.70710678118654757 -0 0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6739 $5802 $7675 $7682 forward $6723 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6722 $7683 T -25.000000000000004 -30.669872981077813 -12.500000000000004 -20 -30 -7.4999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $5803 $7684 #
+face $-1 -1 -1 $-1 $7685 $6914 $11 $-1 $227 reversed single T -35 -40 -1.7763568394002505e-15 -25.000000000000004 -35 9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $6922 $5804 T -35 -35 -1.7763568394002505e-15 -25.000000000000004 -30 9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $7656 $5806 $5808 $6732 reversed $6729 $-1 #
+coedge $-1 -1 -1 $-1 $5806 $7655 $7673 $7686 reversed $6729 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6727 $7687 T -30.000000000000004 -40 -10.000000000000002 -22.5 -35 4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $6003 $7688 #
+straight-curve $-1 -1 -1 $-1 -22.5 -39.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $7689 1.5707963267948966 $5810 2.0943951023931948 $5808 $7690 forward @7 unknown T -25.000000000000004 -40 -10.000000000000002 -22.500000000000004 -39.330127018922198 -7.5000000000000036 #
+face $-1 -1 -1 $-1 $7683 $5809 $11 $-1 $336 reversed single T -25.000000000000004 -40 -12.500000000000007 -20 -39.330127018922191 -7.5000000000000036 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 -7.5000000000000036 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922191 -12.500000000000005 #
+edge $-1 -1 -1 $-1 $5814 12.500000000000004 $7624 22.500000000000004 $5815 $7691 forward @7 unknown T -22.500000000000004 -30.669872981077809 -22.500000000000004 -22.5 -30.669872981077802 -12.500000000000004 #
+point $-1 -1 -1 $-1 -22.5 -30.669872981077802 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $7692 $6638 $5815 $6736 reversed $7623 $-1 #
+coedge $-1 -1 -1 $-1 $5816 $6722 $7692 $7693 forward $6723 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 -27.500000000000004 #
+face $-1 -1 -1 $-1 $7694 $7695 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 -25 7.5000000000000009 -15 -10 F #
+loop $-1 -1 -1 $-1 $-1 $7696 $5821 T -8.8817841970012523e-16 -20 -10 7.5000000000000009 -15 5 unknown #
+coedge $-1 -1 -1 $-1 $7697 $7698 $7699 $7700 reversed $5822 $-1 #
+coedge $-1 -1 -1 $-1 $5890 $5823 $5897 $6820 reversed $4911 $-1 #
+coedge $-1 -1 -1 $-1 $5823 $7701 $7702 $7703 reversed $4911 $-1 #
+coedge $-1 -1 -1 $-1 $7704 $7705 $5823 $6747 forward $6811 $-1 #
+edge $-1 -1 -1 $-1 $7706 -1.5707963267948966 $7707 6.1232339957367648e-17 $6746 $7708 forward @7 unknown T -8.8817841970012523e-16 -20 20 4.9999999999999991 -15 25 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999982 -35 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $4044 6.1232339957367648e-17 $6750 1.5707963267948966 $5960 $7709 forward @7 unknown T 15 -25 -9.9999999999999982 20 -20 -4.9999999999999982 #
+vertex $-1 -1 -1 $-1 $7710 $7711 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5834 $5831 $6869 $7710 reversed $3224 $-1 #
+coedge $-1 -1 -1 $-1 $7712 $5832 $7713 $6761 forward $6755 $-1 #
+coedge $-1 -1 -1 $-1 $5832 $7712 $6767 $5855 reversed $6755 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6753 $5971 T 10 -25 -30 20.000000000000004 -20 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 22.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6859 $7713 $5836 $6759 reversed $7315 $-1 #
+edge $-1 -1 -1 $-1 $5046 -2.0943951023931957 $5838 -1.570796326794897 $5836 $7714 forward @7 unknown T 20 -25 -27.500000000000004 22.500000000000004 -24.330127018922191 -25 #
+face $-1 -1 -1 $-1 $5934 $5837 $11 $-1 $3328 reversed single T 19.999999999999996 -25 -27.500000000000004 25 -24.330127018922191 -22.5 F #
+edge $-1 -1 -1 $-1 $5838 -1.5707963267948961 $6776 -6.1232339957367648e-17 $6753 $7715 forward @7 unknown T 15 -25 -30 20 -20 -25 #
+point $-1 -1 -1 $-1 20 -25 -25 #
+point $-1 -1 -1 $-1 22.499999999999993 -24.330127018922191 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $5852 $5938 $5842 $5943 reversed $6358 $-1 #
+coedge $-1 -1 -1 $-1 $7716 $5844 $6864 $6792 forward $5847 $-1 #
+coedge $-1 -1 -1 $-1 $5845 $7716 $7717 $7718 forward $5847 $-1 #
+coedge $-1 -1 -1 $-1 $7719 $5846 $6754 $5855 forward $6769 $-1 #
+coedge $-1 -1 -1 $-1 $5846 $7720 $7721 $7722 forward $6769 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5846 $7723 T 7.4999999999999982 -25 -25 15 -20 -10 unknown #
+point $-1 -1 -1 $-1 15 -20 -15 #
+coedge $-1 -1 -1 $-1 $7724 $7725 $5850 $6772 forward $7726 $-1 #
+edge $-1 -1 -1 $-1 $6776 0 $6773 1.5707963267948966 $6771 $7727 forward @7 unknown T 10 -20 -30 15 -15 -25 #
+vertex $-1 -1 -1 $-1 $7728 $7729 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7730 $5852 $7725 $7731 reversed $6358 $-1 #
+vertex $-1 -1 -1 $-1 $6772 $7732 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $7733 $7734 #
+coedge $-1 -1 -1 $-1 $5858 $5857 $7735 $7736 forward $4947 $-1 #
+coedge $-1 -1 -1 $-1 $5874 $7737 $5857 $5885 reversed $6801 $-1 #
+coedge $-1 -1 -1 $-1 $6865 $6864 $5858 $6782 reversed $5052 $-1 #
+edge $-1 -1 -1 $-1 $7738 4.1887902047863914 $5866 4.7123889803846897 $5858 $7739 forward @7 unknown T 7.5000000000000009 -15.669872981077807 -10 10 -15 -7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $7740 $5859 $7741 $7742 forward $5862 $-1 #
+coedge $-1 -1 -1 $-1 $5960 $7721 $5859 $4955 reversed $5061 $-1 #
+coedge $-1 -1 -1 $-1 $5860 $7740 $7743 $5888 forward $5862 $-1 #
+coedge $-1 -1 -1 $-1 $5877 $7744 $5860 $6787 reversed $5887 $-1 #
+edge $-1 -1 -1 $-1 $4971 -1.5707963267948966 $4948 0 $5860 $5884 forward @7 unknown T 10 -25 8.8817841970012523e-16 15.000000000000004 -20 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $5956 $5861 $7744 $6890 reversed $4028 $-1 #
+face $-1 -1 -1 $-1 $2657 $5862 $11 $-1 $4529 reversed single T 7.4999999999999991 -25 -10 15.000000000000004 -20 5.0000000000000009 F #
+face $-1 -1 -1 $-1 $7745 $7746 $11 $-1 $2664 reversed single T 4.9999999999999991 -25 -12.500000000000002 10 -24.330127018922191 -7.4999999999999991 F #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -10 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $5866 -1.5707963267948966 $7747 -1.047197551196597 $6765 $7748 forward @7 unknown T 7.4999999999999973 -15.669872981077809 -12.500000000000004 10 -15 -10 #
+point $-1 -1 -1 $-1 10 -15 -10 #
+face $-1 -1 -1 $-1 $7749 $7750 $11 $-1 $5386 reversed single T 15 -5 20 22.5 -8.8817841970012523e-16 35 F #
+edge $-1 -1 -1 $-1 $7751 1.0471975511965974 $5870 1.5707963267948966 $7720 $7748 forward @7 unknown T 7.4999999999999982 -25 -12.500000000000002 10 -24.330127018922191 -10 #
+point $-1 -1 -1 $-1 10 -25 -10 #
+coedge $-1 -1 -1 $-1 $7752 $7697 $5872 $6798 reversed $5822 $-1 #
+edge $-1 -1 -1 $-1 $5911 -17.499999999999996 $6802 -7.5000000000000044 $5872 $7753 forward @7 unknown T 7.4999999999999973 -15.669872981077809 7.5000000000000044 7.5 -15.669872981077807 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $5873 $5897 $7752 $7754 forward $5898 $-1 #
+coedge $-1 -1 -1 $-1 $7737 $5874 $7697 $7755 forward $6801 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6800 $7756 T 4.9999999999999991 -15.669872981077809 2.5 10 -15 7.5000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $5875 $7757 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -20 5.0000000000000009 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5878 $5876 $7758 $7759 forward $4963 $-1 #
+coedge $-1 -1 -1 $-1 $7743 $7760 $5876 $6806 reversed $7761 $-1 #
+edge $-1 -1 -1 $-1 $4971 1.5707963267948966 $7762 2.0943951023931957 $5876 $6803 forward @7 unknown T 7.5 -25 5.0000000000000009 10.000000000000002 -24.330127018922191 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $7744 $5877 $5882 $6809 forward $5887 $-1 #
+coedge $-1 -1 -1 $-1 $7763 $5902 $5878 $4992 reversed $6826 $-1 #
+edge $-1 -1 -1 $-1 $3240 6.1232339957367673e-17 $5972 1.5707963267948966 $6807 $7764 forward @7 unknown T 14.999999999999996 -25 5.0000000000000009 20 -20 10 #
+face $-1 -1 -1 $-1 $7765 $7766 $11 $-1 $1815 reversed single T -5 -25 15 4.9999999999999991 -20 25 F #
+loop $-1 -1 -1 $-1 $-1 $6746 $5883 T -5 -20 15 4.9999999999999991 -15 25 unknown #
+vertex $-1 -1 -1 $-1 $7736 $7767 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -20 5.0000000000000009 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $5888 $7768 #
+coedge $-1 -1 -1 $-1 $7701 $5890 $5892 $6817 reversed $4911 $-1 #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $7308 1.5707963267948966 $5894 2.0943951023931957 $5892 $7769 forward @7 unknown T 4.9999999999999991 -15.669872981077809 32.5 7.5 -15 35 #
+face $-1 -1 -1 $-1 $7596 $5893 $11 $-1 $1965 reversed single T 4.9999999999999991 -15.669872981077809 32.5 10 -15 37.5 F #
+point $-1 -1 -1 $-1 7.4999999999999982 -15.669872981077809 32.5 #
+edge $-1 -1 -1 $-1 $5899 -2.0943951023931948 $7706 -1.5707963267948966 $5897 $7770 forward @7 unknown T 4.9999999999999991 -15.669872981077807 20 7.5000000000000009 -15 22.499999999999996 #
+face $-1 -1 -1 $-1 $7771 $5898 $11 $-1 $1815 reversed single T 4.9999999999999991 -15.669872981077809 17.499999999999996 10 -15 22.499999999999996 F #
+point $-1 -1 -1 $-1 7.5000000000000009 -15.669872981077807 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $7772 $7773 $5901 $6824 reversed $7774 $-1 #
+edge $-1 -1 -1 $-1 $6827 22.500000000000004 $6831 32.500000000000007 $5901 $7775 forward @7 unknown T 7.5 -24.330127018922195 22.500000000000004 7.5000000000000027 -24.330127018922191 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $5902 $7763 $7772 $7776 forward $6826 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6825 $7765 T 4.9999999999999991 -25 17.500000000000004 10 -24.330127018922191 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $7776 $7777 #
+coedge $-1 -1 -1 $-1 $7778 $5904 $7773 $7779 forward $6830 $-1 #
+coedge $-1 -1 -1 $-1 $5904 $7778 $6335 $7290 reversed $6830 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7778 $6835 T 4.9999999999999991 -25 32.5 10 -24.330127018922191 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $5905 $7780 #
+point $-1 -1 -1 $-1 10 -25 35 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $6818 $6830 $11 $-1 $1965 reversed single T 4.9999999999999991 -25 32.5 10 -24.330127018922191 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $7597 $5909 T -5 -25 30 4.9999999999999991 -20 40 unknown #
+point $-1 -1 -1 $-1 7.4999999999999982 -15.669872981077809 17.499999999999996 #
+point $-1 -1 -1 $-1 7.5000000000000027 -24.330127018922195 17.500000000000004 #
+loop $-1 -1 -1 $-1 $-1 $7641 $6840 T 50 -25 -29.999999999999996 50 -15 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $7781 $5920 $11 $-1 $3328 reversed single T 39.999999999999993 -25 -29.999999999999996 50 -15 -19.999999999999996 F #
+face $-1 -1 -1 $-1 $7782 $7783 $11 $-1 $4210 reversed single T -25 -15.669872981077811 -42.500000000000007 -20 -15 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $7784 $5922 T -10.000000000000002 -25 -42.500000000000007 -5 -24.330127018922191 -37.5 unknown #
+loop $-1 -1 -1 $-1 $-1 $7785 $5015 T 50 -25 -45 50 -15 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -20 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 -24.330127018922198 -37.5 #
+edge $-1 -1 -1 $-1 $5931 4.1887902047863905 $6511 4.7123889803846897 $5928 $6894 forward @7 unknown T 37.5 -15.669872981077809 -40 40 -15 -37.5 #
+point $-1 -1 -1 $-1 37.5 -15.669872981077809 -37.5 #
+coedge $-1 -1 -1 $-1 $7786 $7498 $5937 $6851 reversed $7787 $-1 #
+edge $-1 -1 -1 $-1 $6853 4.1887902047863914 $6547 4.7123889803846897 $5937 $7788 forward @7 unknown T 22.500000000000004 -15.669872981077805 -40 25 -15 -37.5 #
+coedge $-1 -1 -1 $-1 $5938 $7730 $7786 $7789 reversed $6358 $-1 #
+vertex $-1 -1 -1 $-1 $6851 $7790 #
+straight-curve $-1 -1 -1 $-1 22.5 -15.669872981077805 0 -0 -0 -1 I I #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $5950 $5942 $6535 $7537 forward $5916 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 35 -15.000000000000004 -40 #
+coedge $-1 -1 -1 $-1 $7791 $6758 $5950 $6860 reversed $7315 $-1 #
+edge $-1 -1 -1 $-1 $7792 -37.5 $5046 -27.500000000000004 $5950 $7793 forward @7 unknown T 22.5 -24.330127018922195 -37.5 22.500000000000004 -24.330127018922195 -27.500000000000004 #
+face $-1 -1 -1 $-1 $6840 $7794 $11 $-1 $3822 reversed single T -7.5000000000000044 -20 -10 0 -15 5 F #
+loop $-1 -1 -1 $-1 $7795 $7796 $5953 T -45 -24.999999999999996 -15.000000000000002 -40 -14.999999999999996 -5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $7797 $7798 $7799 $7800 forward $5954 $-1 #
+coedge $-1 -1 -1 $-1 $6781 $5955 $6765 $6792 reversed $5052 $-1 #
+coedge $-1 -1 -1 $-1 $5955 $6781 $7801 $7802 forward $5052 $-1 #
+coedge $-1 -1 -1 $-1 $7803 $7804 $5955 $6867 reversed $7695 $-1 #
+edge $-1 -1 -1 $-1 $7805 1.5707963267948966 $7747 2.0943951023931957 $5955 $7806 forward @7 unknown T 4.9999999999999991 -15.669872981077809 -12.500000000000002 7.5 -15 -10 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $7721 $5960 $6752 $7710 forward $5061 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7807 $7808 $11 $-1 $3659 reversed single T 29.999999999999996 -10.000000000000002 -24.999999999999996 37.500000000000007 -4.9999999999999991 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $7809 $5963 T 29.999999999999996 -5.0000000000000009 -24.999999999999996 37.5 -1.7763568394002505e-15 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $7810 $7811 $7812 $7813 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $7814 $5965 $7815 $7816 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $5965 $7817 $7818 $7819 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $7820 $7821 $5965 $6877 forward $7822 $-1 #
+edge $-1 -1 -1 $-1 $7823 -1.5707963267948966 $7824 -4.7167471186270725e-16 $6876 $7825 forward @7 unknown T 29.999999999999996 -4.9999999999999991 5.0000000000000018 35 -8.8817841970012523e-16 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $7826 $7827 $5966 $6879 forward $7828 $-1 #
+edge $-1 -1 -1 $-1 $7829 -2.0943951023931957 $6885 -1.5707963267948966 $6878 $7830 forward @7 unknown T 35 -0.66987298107781124 20.000000000000004 37.5 -1.7763568394002505e-15 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $6309 $7831 $7832 $6881 forward $6313 $-1 #
+edge $-1 -1 -1 $-1 $6886 25 $6314 30 $6880 $7833 forward @7 unknown T 29.999999999999996 -5.0000000000000009 25 30 -4.9999999999999991 30 #
+coedge $-1 -1 -1 $-1 $7834 $5968 $7831 $7835 reversed $6884 $-1 #
+coedge $-1 -1 -1 $-1 $5968 $7834 $7817 $7836 forward $6884 $-1 #
+loop $-1 -1 -1 $-1 $-1 $5968 $7837 T 25 -5 15 35 0 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $7836 $7838 #
+vertex $-1 -1 -1 $-1 $7839 $7840 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7841 $7842 $11 $-1 $2156 reversed single T -50 -25 -3.5527136788005009e-15 -40 -14.999999999999996 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $7843 $5970 T -10.000000000000002 -25 2.4999999999999982 -5 -24.330127018922191 7.5000000000000027 unknown #
+edge $-1 -1 -1 $-1 $5972 -1.5707963267948966 $4948 -6.1232339957367648e-17 $7744 $7844 forward @7 unknown T 15 -25 -9.3734986416366073e-33 20 -20 5.0000000000000009 #
+point $-1 -1 -1 $-1 20 -25 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $6506 $6506 $5978 $6893 reversed $5923 $-1 #
+edge $-1 -1 -1 $-1 $6511 1.5707963267948966 $6508 4.7123889803846897 $5978 $7845 forward @7 unknown T 40 -25 -40 45 -15 -35 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7846 $7847 $11 $-1 $4210 reversed single T 10 -20 -45 20 -15 -35 F #
+loop $-1 -1 -1 $-1 $-1 $6526 $5981 T 10 -25 -45 20 -20 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -35 -40 4.9999999999999982 #
+point $-1 -1 -1 $-1 -35 -30 4.9999999999999982 #
+edge $-1 -1 -1 $-1 $7848 4.1887902047863905 $4890 4.7123889803846897 $5997 $6908 forward @7 unknown T -22.500000000000004 -30.669872981077809 4.9999999999999991 -20 -30 7.5000000000000027 #
+face $-1 -1 -1 $-1 $7849 $6924 $11 $-1 $162 reversed single T -35 -35 14.999999999999996 -25.000000000000004 -30 25 F #
+coedge $-1 -1 -1 $-1 $7850 $7851 $6000 $6904 reversed $6920 $-1 #
+edge $-1 -1 -1 $-1 $6907 7.5000000000000018 $6034 17.499999999999996 $6000 $7852 forward @7 unknown T -22.500000000000004 -39.330127018922198 7.5000000000000018 -22.5 -39.330127018922184 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $6001 $7673 $7850 $7853 forward $6906 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6905 $7685 T -25.000000000000004 -40 2.4999999999999969 -20 -39.330127018922184 7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $7853 $7854 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 4.9999999999999991 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6008 $6953 $6917 $7855 forward $6910 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6953 $7849 T -35 -40 14.999999999999996 -25.000000000000004 -35 25 unknown #
+vertex $-1 -1 -1 $-1 $6019 $7856 #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -35 19.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7653 $6010 $6918 $7857 forward $6914 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6913 $6725 T -35 -40 -1.7763568394002505e-15 -25.000000000000004 -35 9.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $6011 $7858 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 4.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7851 $6013 $6909 $7855 reversed $6920 $-1 #
+coedge $-1 -1 -1 $-1 $6013 $7850 $6913 $7857 reversed $6920 $-1 #
+coedge $-1 -1 -1 $-1 $7859 $7860 $5155 $6014 reversed $7861 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7850 $7862 T -30.000000000000007 -40 4.9999999999999982 -22.5 -35 20 unknown #
+coedge $-1 -1 -1 $-1 $6016 $7649 $7859 $7863 forward $6726 $-1 #
+coedge $-1 -1 -1 $-1 $6960 $6018 $7860 $7864 forward $6924 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6960 $6902 T -35 -35 14.999999999999996 -25.000000000000004 -30 25 unknown #
+coedge $-1 -1 -1 $-1 $6030 $6021 $7851 $7865 forward $6031 $-1 #
+coedge $-1 -1 -1 $-1 $7866 $7867 $6023 $6927 reversed $7868 $-1 #
+edge $-1 -1 -1 $-1 $6063 -32.5 $6931 -22.500000000000004 $6023 $7869 forward @7 unknown T -22.500000000000004 -30.669872981077809 22.500000000000004 -22.5 -30.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $6024 $6372 $7866 $7870 forward $6373 $-1 #
+coedge $-1 -1 -1 $-1 $6944 $6025 $7867 $7871 forward $6930 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6929 $7872 T -25.000000000000004 -30.669872981077809 17.499999999999996 -20 -30 22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $6026 $7873 #
+face $-1 -1 -1 $-1 $5446 $6950 $11 $-1 $388 reversed single T -35 -40 30 -25.000000000000004 -35 40 F #
+loop $-1 -1 -1 $-1 $-1 $6965 $6027 T -35 -35 30 -25.000000000000004 -30 40 unknown #
+coedge $-1 -1 -1 $-1 $6957 $6028 $6030 $6937 reversed $6935 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6934 $7874 T -30.000000000000004 -40 20 -22.5 -35 35 unknown #
+edge $-1 -1 -1 $-1 $7875 1.5707963267948966 $6032 2.0943951023931948 $6030 $7876 forward @7 unknown T -25.000000000000004 -40 20 -22.500000000000004 -39.330127018922191 22.500000000000004 #
+face $-1 -1 -1 $-1 $7872 $6031 $11 $-1 $162 reversed single T -25.000000000000004 -40 17.499999999999996 -20 -39.330127018922191 22.500000000000004 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 22.500000000000004 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 17.499999999999996 #
+edge $-1 -1 -1 $-1 $6036 -17.499999999999996 $7848 -7.5000000000000027 $6037 $7877 forward @7 unknown T -22.500000000000004 -30.669872981077809 7.5000000000000027 -22.5 -30.669872981077805 17.499999999999996 #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $7878 $7879 $6037 $6941 reversed $7861 $-1 #
+coedge $-1 -1 -1 $-1 $6038 $6929 $7878 $7880 forward $6930 $-1 #
+coedge $-1 -1 -1 $-1 $6056 $6965 $6040 $6946 reversed $6933 $-1 #
+edge $-1 -1 -1 $-1 $5205 1.5707963267948966 $6967 3.1415926535897931 $6040 $7881 forward @7 unknown T -35 -35 35 -30 -30 40 #
+coedge $-1 -1 -1 $-1 $6370 $6047 $6045 $6948 reversed $6950 $-1 #
+edge $-1 -1 -1 $-1 $6967 3.1415926535897931 $5199 4.7123889803846897 $6045 $7881 forward @7 unknown T -35 -40 35 -30 -35 40 #
+coedge $-1 -1 -1 $-1 $6047 $6370 $6956 $7321 forward $6950 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6370 $6932 T -35 -40 30 -25.000000000000004 -35 40 unknown #
+vertex $-1 -1 -1 $-1 $6057 $7882 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6909 $6049 $6957 $7883 forward $6910 $-1 #
+vertex $-1 -1 -1 $-1 $6050 $7884 #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -35 19.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6364 $6051 $6949 $7321 reversed $6935 $-1 #
+coedge $-1 -1 -1 $-1 $6051 $6934 $6953 $7883 reversed $6935 $-1 #
+coedge $-1 -1 -1 $-1 $7885 $7886 $5203 $6052 reversed $7868 $-1 #
+coedge $-1 -1 -1 $-1 $6054 $6923 $7885 $7887 forward $6924 $-1 #
+coedge $-1 -1 -1 $-1 $6965 $6056 $7886 $7888 forward $6933 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -30.669872981077813 -42.500000000000014 #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $6945 $6961 $6065 $6966 forward $6933 $-1 #
+edge $-1 -1 -1 $-1 $7889 -1.5707963267948966 $6967 6.1232339957367648e-17 $6965 $7890 forward @7 unknown T -30.000000000000004 -35 35 -25.000000000000004 -30 40 #
+vertex $-1 -1 -1 $-1 $6948 $7891 #
+edge $-1 -1 -1 $-1 $6070 -2.0943951023931957 $7889 -1.5707963267948966 $6372 $7892 forward @7 unknown T -25.000000000000004 -30.669872981077809 35 -22.500000000000004 -30 37.500000000000007 #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $7893 $6072 $6074 $6975 forward $6973 $-1 #
+coedge $-1 -1 -1 $-1 $6072 $7893 $6077 $6978 reversed $6973 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6971 $3147 T -50 -50 -50 -50 50 50 unknown #
+straight-curve $-1 -1 -1 $-1 -50 0 50 0 -1 0 I I #
+edge $-1 -1 -1 $-1 $6075 -50 $7894 50 $6074 $7895 forward @7 unknown T -50 50 -50 -50 50 50 #
+point $-1 -1 -1 $-1 -50 50 50 #
+coedge $-1 -1 -1 $-1 $6078 $6077 $6380 $7325 reversed $6079 $-1 #
+edge $-1 -1 -1 $-1 $6080 -50 $7896 50 $6972 $7897 forward @7 unknown T -50 -50 -50 -50 -50 50 #
+face $-1 -1 -1 $-1 $3147 $6079 $11 $-1 $7898 reversed single T -50 -50 -50 50 -50 50 F #
+point $-1 -1 -1 $-1 -50 -50 50 #
+vertex $-1 -1 -1 $-1 $6083 $7899 #
+straight-curve $-1 -1 -1 $-1 50 -50 0 0 0 -1 I I #
+vertex $-1 -1 -1 $-1 $6382 $7900 #
+straight-curve $-1 -1 -1 $-1 50 50 0 0 0 -1 I I #
+coedge $-1 -1 -1 $-1 $7901 $6087 $7902 $7014 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $7903 $7904 $6087 $6987 reversed $7905 $-1 #
+edge $-1 -1 -1 $-1 $6122 2.6179938779914949 $6104 4.7123889803846897 $6087 $7906 forward @7 unknown T 15.000000000000002 35 50 22.5 40 50 #
+coedge $-1 -1 -1 $-1 $6088 $7907 $7903 $7037 forward $6989 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6109 $7000 T 22.5 35 35 30 40 50 unknown #
+coedge $-1 -1 -1 $-1 $6991 $6089 $7908 $7909 reversed $6091 $-1 #
+coedge $-1 -1 -1 $-1 $6090 $6990 $7910 $7911 reversed $6091 $-1 #
+face $-1 -1 -1 $-1 $5250 $6091 $11 $-1 $6121 reversed single T 30 35 35 37.500000000000007 40 50 F #
+coedge $-1 -1 -1 $-1 $6094 $6093 $7912 $7913 forward $5235 $-1 #
+coedge $-1 -1 -1 $-1 $6116 $7914 $6093 $6995 reversed $7032 $-1 #
+edge $-1 -1 -1 $-1 $6118 4.1887902047863905 $7915 4.7123889803846897 $6093 $7916 forward @7 unknown T 37.5 44.330127018922191 35 40 45 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $7917 $7908 $6094 $6997 reversed $7918 $-1 #
+edge $-1 -1 -1 $-1 $7919 1.5707963267948966 $6998 2.0943951023931948 $6094 $7916 forward @7 unknown T 37.5 35 35 40 35.669872981077809 37.5 #
+vertex $-1 -1 -1 $-1 $7909 $7920 #
+straight-curve $-1 -1 -1 $-1 37.5 35.669872981077809 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $7921 $6989 $11 $-1 $7024 reversed single T 22.5 35 35 30 40 50 F #
+cone-surface $-1 -1 -1 $-1 40 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $6098 $7922 $7923 $7924 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $7925 $7926 $6098 $7004 reversed $7927 $-1 #
+edge $-1 -1 -1 $-1 $7928 -1.5707963267948966 $7008 0.52359877559829893 $6098 $7929 forward @7 unknown T 1.7763568394002505e-15 40 50 7.5000000000000027 45 50 #
+coedge $-1 -1 -1 $-1 $7930 $6099 $7926 $7931 forward $7007 $-1 #
+coedge $-1 -1 -1 $-1 $6099 $7932 $7933 $7011 forward $7007 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7006 $7934 T 7.4999999999999991 40 35 15.000000000000002 45 50 unknown #
+vertex $-1 -1 -1 $-1 $6100 $7935 #
+ellipse-curve $-1 -1 -1 $-1 10 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7012 $6101 $7936 $7937 reversed $6103 $-1 #
+edge $-1 -1 -1 $-1 $7938 40 $6104 50 $7006 $7939 forward @7 unknown T 15 40 40 15.000000000000002 40 50 #
+coedge $-1 -1 -1 $-1 $6102 $7010 $7940 $7941 reversed $6103 $-1 #
+face $-1 -1 -1 $-1 $7942 $6103 $11 $-1 $7943 reversed single T 15 40 35 22.500000000000007 45 50 F #
+edge $-1 -1 -1 $-1 $6104 0 $7944 2.0943951023931957 $6985 $7009 forward @7 unknown T 7.4999999999999991 35 50 15.000000000000002 40 50 #
+point $-1 -1 -1 $-1 15.000000000000002 40 50 #
+coedge $-1 -1 -1 $-1 $7940 $7945 $6106 $7017 reversed $7946 $-1 #
+edge $-1 -1 -1 $-1 $7018 4.1887902047863932 $7947 4.7123889803846897 $6106 $7948 forward @7 unknown T 22.500000000000007 44.330127018922198 35 25 45 37.5 #
+vertex $-1 -1 -1 $-1 $7017 $7949 #
+straight-curve $-1 -1 -1 $-1 22.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $7950 $6112 $6108 $7021 reversed $7026 $-1 #
+edge $-1 -1 -1 $-1 $7947 1.5707963267948966 $6114 3.1415926535897931 $6108 $7951 forward @7 unknown T 25 40 35 30 45 40 #
+coedge $-1 -1 -1 $-1 $7907 $6109 $7952 $7029 forward $6989 $-1 #
+face $-1 -1 -1 $-1 $7953 $7954 $11 $-1 $7955 reversed single T 7.4999999999999991 35 35 15.000000000000002 40 50 F #
+cone-surface $-1 -1 -1 $-1 25 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $6112 $7950 $7956 $7957 forward $7026 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6112 $7958 T 25 40 30 35 45 40 unknown #
+vertex $-1 -1 -1 $-1 $7957 $7959 #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+edge $-1 -1 -1 $-1 $6114 3.1415926535897931 $7960 4.7123889803846897 $7022 $7951 forward @7 unknown T 25 35 35 30 40 40 #
+point $-1 -1 -1 $-1 30 40 40 #
+coedge $-1 -1 -1 $-1 $7914 $6116 $7961 $7962 forward $7032 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6116 $7963 T 35 44.330127018922191 32.5 40 45 37.500000000000007 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 44.330127018922191 37.500000000000007 #
+face $-1 -1 -1 $-1 $7964 $7965 $11 $-1 $6121 reversed single T 29.999999999999996 40 -40 37.5 45 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $7966 $6120 T 30 40 -50 37.500000000000007 45 -40 unknown #
+edge $-1 -1 -1 $-1 $7967 37.5 $6122 50 $6988 $7968 forward @7 unknown T 22.5 35.669872981077802 37.5 22.500000000000007 35.669872981077809 50 #
+point $-1 -1 -1 $-1 22.5 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $7969 $6123 $7970 $7971 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $7071 $7972 $6123 $6152 reversed $7092 $-1 #
+coedge $-1 -1 -1 $-1 $7973 $6124 $6126 $6175 reversed $7043 $-1 #
+coedge $-1 -1 -1 $-1 $6124 $7974 $5268 $6149 forward $7043 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7042 $7975 T 15 20 35 22.5 25 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6126 $6160 $7976 $7977 forward $6127 $-1 #
+coedge $-1 -1 -1 $-1 $6134 $7978 $6128 $7047 forward $7056 $-1 #
+edge $-1 -1 -1 $-1 $7979 1.5707963267948966 $6136 2.0943951023931957 $7046 $7980 forward @7 unknown T 35 19.999999999999996 35 37.5 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $7981 $7090 $6129 $7049 forward $7982 $-1 #
+edge $-1 -1 -1 $-1 $5281 -6.4931039580273226e-16 $7979 1.5707963267948966 $7048 $7983 forward @7 unknown T 30 19.999999999999996 35 35 25 40 #
+coedge $-1 -1 -1 $-1 $7984 $7984 $6131 $7051 reversed $7985 $-1 #
+edge $-1 -1 -1 $-1 $7053 1.5707963267948966 $7057 4.7123889803846897 $6131 $7986 forward @7 unknown T 40 20 35 45 30 40 #
+coedge $-1 -1 -1 $-1 $6132 $6169 $7987 $7988 reversed $6170 $-1 #
+vertex $-1 -1 -1 $-1 $7988 $7989 #
+ellipse-curve $-1 -1 -1 $-1 40 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7978 $6134 $7990 $7991 reversed $7056 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7046 $7992 T 35 19.999999999999996 32.5 40 20.669872981077805 37.5 unknown #
+vertex $-1 -1 -1 $-1 $7991 $7993 #
+point $-1 -1 -1 $-1 37.5 20.669872981077805 37.5 #
+face $-1 -1 -1 $-1 $7096 $7994 $11 $-1 $6139 reversed single T 37.499999999999986 20 20.000000000000004 45 30 35 F #
+coedge $-1 -1 -1 $-1 $6140 $7995 $7996 $7997 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $7998 $7999 $6140 $7062 reversed $8000 $-1 #
+edge $-1 -1 -1 $-1 $8001 -2.0943951023931948 $7066 0 $6140 $8002 forward @7 unknown T -7.4999999999999991 25 50 8.8817841970012523e-16 30 50 #
+coedge $-1 -1 -1 $-1 $8003 $6141 $7999 $8004 reversed $7065 $-1 #
+coedge $-1 -1 -1 $-1 $6141 $8005 $6143 $7069 reversed $7065 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7064 $8006 T 0 25 35 7.5000000000000027 30 50 unknown #
+vertex $-1 -1 -1 $-1 $8007 $8008 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7070 $6143 $8009 $8010 forward $6145 $-1 #
+edge $-1 -1 -1 $-1 $6146 -50 $8011 -37.500000000000007 $6143 $8012 forward @7 unknown T 7.5000000000000009 29.330127018922195 37.500000000000007 7.5000000000000027 29.330127018922202 50 #
+coedge $-1 -1 -1 $-1 $6144 $7068 $8013 $8014 forward $6145 $-1 #
+coedge $-1 -1 -1 $-1 $8015 $7040 $7042 $6149 reversed $7092 $-1 #
+face $-1 -1 -1 $-1 $8016 $6145 $11 $-1 $7093 reversed single T 7.5000000000000009 25 35 15 30 50 F #
+point $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $8013 $8017 $6148 $7075 forward $8018 $-1 #
+edge $-1 -1 -1 $-1 $8019 -1.5707963267948966 $7076 6.1232339957367648e-17 $7074 $8020 forward @7 unknown T 15 25 35 20 30 40 #
+vertex $-1 -1 -1 $-1 $8021 $8022 #
+straight-curve $-1 -1 -1 $-1 15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8023 $6154 $6150 $7079 forward $7084 $-1 #
+edge $-1 -1 -1 $-1 $6156 -2.0943951023931957 $8019 -1.5707963267948966 $7078 $8024 forward @7 unknown T 20 29.330127018922191 35 22.500000000000004 30 37.500000000000007 #
+face $-1 -1 -1 $-1 $8025 $8026 $11 $-1 $7081 reversed single T 15 25 -50 22.5 30 -40 F #
+cone-surface $-1 -1 -1 $-1 20 25 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $8027 $8028 #
+coedge $-1 -1 -1 $-1 $6154 $8023 $8029 $8030 reversed $7084 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7078 $8031 T 20 29.330127018922191 32.5 25 30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $8030 $8032 #
+ellipse-curve $-1 -1 -1 $-1 25 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 29.330127018922195 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $6163 $6158 $8033 $8034 reversed $6164 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7048 $8035 $6160 $6167 reversed $7982 $-1 #
+face $-1 -1 -1 $-1 $8036 $8037 $11 $-1 $6162 reversed single T 22.5 25 20 30 30 35 F #
+loop $-1 -1 -1 $-1 $-1 $7071 $6161 T 7.4999999999999956 20 35 15 25 50 unknown #
+cone-surface $-1 -1 -1 $-1 10 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8038 $7099 $6163 $7095 reversed $8039 $-1 #
+edge $-1 -1 -1 $-1 $8040 6.4931039580273265e-16 $6165 1.5707963267948966 $6163 $8041 forward @7 unknown T 30 25 30 35 29.999999999999996 35 #
+face $-1 -1 -1 $-1 $8042 $6164 $11 $-1 $8043 reversed single T 25 25 30 35 30 40 F #
+point $-1 -1 -1 $-1 35 29.999999999999996 35 #
+vertex $-1 -1 -1 $-1 $8044 $8045 #
+coedge $-1 -1 -1 $-1 $7094 $8046 $6169 $7100 reversed $8039 $-1 #
+edge $-1 -1 -1 $-1 $6165 1.5707963267948966 $8047 2.0943951023931948 $6169 $8048 forward @7 unknown T 35 29.330127018922187 32.499999999999993 37.5 29.999999999999996 35 #
+face $-1 -1 -1 $-1 $8049 $6170 $11 $-1 $8043 reversed single T 35 29.330127018922184 32.499999999999986 40 30 37.500000000000007 F #
+face $-1 -1 -1 $-1 $6416 $8050 $11 $-1 $5288 reversed single T 29.999999999999996 19.999999999999996 -40 37.5 25 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $8051 $6173 T 29.999999999999996 25 -40 37.5 29.999999999999996 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $8052 $6396 $6399 $7358 reversed $6174 $-1 #
+vertex $-1 -1 -1 $-1 $8053 $8054 #
+straight-curve $-1 -1 -1 $-1 22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8055 $6177 $8056 $7145 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $8057 $8058 $6177 $7109 reversed $8059 $-1 #
+edge $-1 -1 -1 $-1 $6220 2.617993877991494 $6204 4.7123889803846897 $6177 $8060 forward @7 unknown T 0 5 50 7.5000000000000018 10 50 #
+coedge $-1 -1 -1 $-1 $6178 $8061 $8057 $7165 forward $6230 $-1 #
+coedge $-1 -1 -1 $-1 $7112 $6179 $8062 $7191 reversed $6181 $-1 #
+coedge $-1 -1 -1 $-1 $6180 $7111 $8063 $8064 reversed $6181 $-1 #
+face $-1 -1 -1 $-1 $5318 $6181 $11 $-1 $6219 reversed single T 15 4.9999999999999982 35 22.500000000000007 10 50 F #
+coedge $-1 -1 -1 $-1 $8065 $8062 $6183 $7115 reversed $8066 $-1 #
+edge $-1 -1 -1 $-1 $6236 1.5707963267948966 $6243 2.0943951023931948 $6183 $6224 forward @7 unknown T 22.500000000000004 5 35 25 5.6698729810778064 37.5 #
+coedge $-1 -1 -1 $-1 $6184 $6193 $8067 $8068 forward $6194 $-1 #
+vertex $-1 -1 -1 $-1 $8069 $8070 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7173 $6186 $8071 $8069 forward $7120 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6186 $7180 T 25 4.9999999999999982 30 35 10 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $6188 $6188 $8072 $8073 reversed $7123 $-1 #
+loop $-1 -1 -1 $-1 $8074 $7122 $8075 T 40 5 30 45 15 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8076 $8072 $6190 $7126 forward $7132 $-1 #
+edge $-1 -1 -1 $-1 $6191 -1.5707963267948966 $7185 -1.0471975511965974 $7125 $8077 forward @7 unknown T 37.5 14.330127018922191 32.5 40 15 35 #
+point $-1 -1 -1 $-1 40 15 35 #
+coedge $-1 -1 -1 $-1 $8072 $8078 $6193 $7129 forward $7132 $-1 #
+edge $-1 -1 -1 $-1 $8079 1.0471975511965983 $6195 1.5707963267948966 $7128 $8077 forward @7 unknown T 37.5 5 32.5 40 5.6698729810778064 35 #
+face $-1 -1 -1 $-1 $6239 $6194 $11 $-1 $7181 reversed single T 35 4.9999999999999982 32.5 40 5.669872981077809 37.5 F #
+point $-1 -1 -1 $-1 40 5 35 #
+loop $-1 -1 -1 $-1 $-1 $8076 $6197 T 37.499999999999993 5 20.000000000000004 45 15 35 unknown #
+coedge $-1 -1 -1 $-1 $6198 $8080 $8081 $8082 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $8083 $8084 $6198 $7135 reversed $8085 $-1 #
+edge $-1 -1 -1 $-1 $8086 -1.5707963267948966 $7139 0.5235987755982987 $6198 $8087 forward @7 unknown T -15 10 50 -7.5 15 50 #
+coedge $-1 -1 -1 $-1 $8088 $6199 $8084 $8089 forward $7138 $-1 #
+coedge $-1 -1 -1 $-1 $6199 $8090 $8091 $7142 forward $7138 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7137 $8092 T -7.5 10 35 8.8817841970012523e-16 15 50 unknown #
+vertex $-1 -1 -1 $-1 $6200 $8093 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7143 $6201 $8094 $8095 reversed $6203 $-1 #
+edge $-1 -1 -1 $-1 $8096 40 $6204 50 $7137 $8097 forward @7 unknown T 0 10 40 8.8817841970012523e-16 10 50 #
+coedge $-1 -1 -1 $-1 $6202 $7141 $8098 $8099 reversed $6203 $-1 #
+face $-1 -1 -1 $-1 $8100 $6203 $11 $-1 $8101 reversed single T 0 10 35 7.5000000000000009 15 50 F #
+edge $-1 -1 -1 $-1 $6204 0 $8102 2.0943951023931957 $7107 $7140 forward @7 unknown T -7.5000000000000009 5 50 0 10 50 #
+point $-1 -1 -1 $-1 0 10 50 #
+coedge $-1 -1 -1 $-1 $8098 $8103 $6206 $7148 reversed $8104 $-1 #
+edge $-1 -1 -1 $-1 $7149 4.1887902047863914 $8105 4.7123889803846897 $6206 $8106 forward @7 unknown T 7.5000000000000009 14.330127018922195 35 10 15 37.5 #
+vertex $-1 -1 -1 $-1 $7148 $8107 #
+straight-curve $-1 -1 -1 $-1 7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $8108 $6212 $6208 $7152 reversed $7156 $-1 #
+edge $-1 -1 -1 $-1 $8105 1.5707963267948966 $6214 3.1415926535897931 $6208 $8109 forward @7 unknown T 10 10 35 15 15 40 #
+coedge $-1 -1 -1 $-1 $8061 $6209 $8110 $7159 forward $6230 $-1 #
+face $-1 -1 -1 $-1 $8111 $8112 $11 $-1 $8113 reversed single T -7.5000000000000009 5 35 8.8817841970012523e-16 10 50 F #
+coedge $-1 -1 -1 $-1 $6212 $8108 $8114 $8115 forward $7156 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6212 $7174 T 10 10 30 20 15 40 unknown #
+vertex $-1 -1 -1 $-1 $8115 $8116 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6214 3.1415926535897931 $8117 4.7123889803846897 $7153 $8109 forward @7 unknown T 10 5 35 15 10 40 #
+point $-1 -1 -1 $-1 15 10 40 #
+coedge $-1 -1 -1 $-1 $6221 $6216 $8118 $8119 forward $6222 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8120 $8121 $11 $-1 $6219 reversed single T 15 10 -40 22.500000000000004 14.999999999999998 -25 F #
+loop $-1 -1 -1 $-1 $-1 $8122 $6218 T 15 10 -50 22.500000000000004 14.999999999999998 -40 unknown #
+edge $-1 -1 -1 $-1 $8123 37.500000000000007 $6220 50 $7110 $8124 forward @7 unknown T 7.5 5.6698729810778064 37.500000000000007 7.5000000000000018 5.6698729810778072 50 #
+point $-1 -1 -1 $-1 7.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $8125 $7171 $6221 $7168 forward $7175 $-1 #
+edge $-1 -1 -1 $-1 $6223 -1.5707963267948966 $8126 -1.0471975511965979 $7167 $8127 forward @7 unknown T 22.5 14.330127018922191 32.5 25 15 35 #
+face $-1 -1 -1 $-1 $8128 $6222 $11 $-1 $7181 reversed single T 20 14.330127018922189 32.5 25 15 37.5 F #
+point $-1 -1 -1 $-1 25 15 35 #
+coedge $-1 -1 -1 $-1 $7167 $8129 $6226 $7172 forward $7175 $-1 #
+edge $-1 -1 -1 $-1 $7178 0 $6223 1.5707963267948966 $7171 $8130 forward @7 unknown T 25 10 30 30 15 35 #
+coedge $-1 -1 -1 $-1 $6228 $7119 $8131 $8132 reversed $7120 $-1 #
+face $-1 -1 -1 $-1 $8133 $7156 $11 $-1 $7181 reversed single T 10 10 30 20 15 40 F #
+loop $-1 -1 -1 $-1 $-1 $8129 $6229 T 22.499999999999996 10 20 30 15 35 unknown #
+coedge $-1 -1 -1 $-1 $8134 $6232 $8129 $8135 reversed $7177 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8134 $8136 T 29.999999999999996 10 20.000000000000004 37.5 14.999999999999998 35 unknown #
+vertex $-1 -1 -1 $-1 $7172 $8137 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7130 $7120 $11 $-1 $7181 reversed single T 25 4.9999999999999982 30 35 10 40 F #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 10 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $8138 1.0471975511965979 $6236 1.5707963267948966 $8139 $8127 forward @7 unknown T 22.5 5 32.5 25 5.6698729810778081 35 #
+point $-1 -1 -1 $-1 25 5 35 #
+coedge $-1 -1 -1 $-1 $6237 $8140 $8076 $8141 reversed $7177 $-1 #
+vertex $-1 -1 -1 $-1 $8141 $8142 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $6426 $8143 $11 $-1 $5329 reversed single T 22.5 5 19.999999999999996 30 10 35 F #
+loop $-1 -1 -1 $-1 $-1 $8144 $6240 T 29.999999999999996 4.9999999999999982 -40 37.500000000000007 10 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $8145 $8146 $8147 $8148 reversed $6241 $-1 #
+coedge $-1 -1 -1 $-1 $6443 $6242 $8149 $8150 reversed $5341 $-1 #
+edge $-1 -1 -1 $-1 $8151 1.5707963267948966 $6243 2.0943951023931957 $8062 $8152 forward @7 unknown T 20 4.9999999999999982 35 22.500000000000007 5.6698729810778072 37.5 #
+point $-1 -1 -1 $-1 22.500000000000007 5.6698729810778055 37.5 #
+coedge $-1 -1 -1 $-1 $8153 $6245 $8154 $8155 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $7229 $8156 $6245 $6283 reversed $7250 $-1 #
+coedge $-1 -1 -1 $-1 $8157 $6246 $6248 $6303 reversed $7197 $-1 #
+coedge $-1 -1 -1 $-1 $6246 $8158 $5368 $6280 forward $7197 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7196 $8159 T -4.686749320818303e-33 -10 35 7.5000000000000018 -4.9999999999999991 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 5 -5 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6248 $6291 $8160 $8161 forward $5397 $-1 #
+coedge $-1 -1 -1 $-1 $6252 $8162 $6249 $6327 forward $7204 $-1 #
+coedge $-1 -1 -1 $-1 $8163 $7248 $6250 $7202 forward $8164 $-1 #
+edge $-1 -1 -1 $-1 $5381 -2.9403902792268234e-16 $7284 1.5707963267948966 $7201 $8165 forward @7 unknown T 15 -10 35 20 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $8162 $6252 $7273 $6318 reversed $7204 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7200 $8166 T 20 -10 32.5 25 -9.330127018922191 37.5 unknown #
+coedge $-1 -1 -1 $-1 $8167 $7209 $6254 $7206 reversed $8168 $-1 #
+edge $-1 -1 -1 $-1 $7217 -2.0943951023931957 $6255 -1.5707963267948966 $6254 $8169 forward @7 unknown T 35 -10.000000000000002 32.5 37.500000000000007 -9.3301270189221945 35 #
+edge $-1 -1 -1 $-1 $6255 -1.5707963267948966 $6314 2.9403902792268234e-16 $6257 $8170 forward @7 unknown T 30 -10.000000000000002 30 35 -5 35 #
+point $-1 -1 -1 $-1 35 -10.000000000000002 35 #
+coedge $-1 -1 -1 $-1 $7205 $8171 $6257 $7207 reversed $8168 $-1 #
+coedge $-1 -1 -1 $-1 $6263 $6266 $6260 $7211 forward $6270 $-1 #
+edge $-1 -1 -1 $-1 $5362 -1.5707963267948966 $5358 1.5707963267948966 $7210 $8172 forward @7 unknown T 40 -10 30 45 0 35 #
+loop $-1 -1 -1 $-1 $-1 $8173 $7213 T 50 -10 30 50 0 40 unknown #
+face $-1 -1 -1 $-1 $8174 $6261 $11 $-1 $6317 reversed single T 40 -10 30 50 0 40 F #
+coedge $-1 -1 -1 $-1 $8175 $6263 $6320 $7274 forward $6270 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6266 $8176 $8167 $8177 forward $6270 $-1 #
+vertex $-1 -1 -1 $-1 $6267 $8178 #
+coedge $-1 -1 -1 $-1 $6271 $8179 $8180 $8181 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $8182 $8183 $6271 $7220 reversed $8184 $-1 #
+edge $-1 -1 -1 $-1 $8185 -2.0943951023931948 $7224 0 $6271 $8186 forward @7 unknown T -22.5 -5 50 -15 0 50 #
+coedge $-1 -1 -1 $-1 $8187 $6272 $8183 $8188 reversed $7223 $-1 #
+coedge $-1 -1 -1 $-1 $6272 $8189 $6274 $7227 reversed $7223 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7222 $8190 T -15 -5 35 -7.4999999999999991 8.8817841970012523e-16 50 unknown #
+vertex $-1 -1 -1 $-1 $8191 $8192 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7228 $6274 $8193 $8194 forward $6276 $-1 #
+edge $-1 -1 -1 $-1 $6277 -50 $8195 -37.500000000000007 $6274 $8196 forward @7 unknown T -7.4999999999999991 -0.66987298107780657 37.500000000000007 -7.4999999999999991 -0.66987298107780635 50 #
+coedge $-1 -1 -1 $-1 $6275 $7226 $8197 $8198 forward $6276 $-1 #
+coedge $-1 -1 -1 $-1 $8199 $7194 $7196 $6280 reversed $7250 $-1 #
+face $-1 -1 -1 $-1 $8200 $6276 $11 $-1 $7251 reversed single T -7.5000000000000018 -5 35 0 0 50 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 50 #
+coedge $-1 -1 -1 $-1 $8197 $8201 $6279 $7233 forward $8202 $-1 #
+edge $-1 -1 -1 $-1 $8203 -1.5707963267948966 $7234 -1.1640334398265738e-16 $7232 $8204 forward @7 unknown T 0 -4.9999999999999991 35 5 0 40 #
+vertex $-1 -1 -1 $-1 $8205 $8206 #
+straight-curve $-1 -1 -1 $-1 0 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8207 $6285 $6281 $7237 forward $7242 $-1 #
+edge $-1 -1 -1 $-1 $6287 -2.0943951023931948 $8203 -1.5707963267948966 $7236 $8208 forward @7 unknown T 5 -0.66987298107780635 35 7.5000000000000009 0 37.5 #
+face $-1 -1 -1 $-1 $8209 $8210 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 -50 7.5000000000000018 0 -40 F #
+cone-surface $-1 -1 -1 $-1 5 -5 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $8211 $8212 #
+coedge $-1 -1 -1 $-1 $6285 $8207 $8213 $8214 reversed $7242 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7236 $8215 T 5 -0.66987298107780902 32.5 10 0 37.5 unknown #
+vertex $-1 -1 -1 $-1 $8214 $8216 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000009 -0.66987298107780624 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $6293 $6289 $8217 $8218 reversed $6294 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7201 $8219 $6291 $6297 reversed $8164 $-1 #
+face $-1 -1 -1 $-1 $8220 $8221 $11 $-1 $5398 reversed single T 7.5 -5 20 15 0 35 F #
+loop $-1 -1 -1 $-1 $-1 $7229 $6292 T -7.5000000000000009 -10 35 0 -4.9999999999999991 50 unknown #
+cone-surface $-1 -1 -1 $-1 -5 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8222 $7256 $6293 $7253 reversed $7750 $-1 #
+edge $-1 -1 -1 $-1 $8223 1.1640334398265738e-16 $6295 1.5707963267948966 $6293 $8224 forward @7 unknown T 15 -5 30 20 -8.8817841970012523e-16 35 #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 35 #
+vertex $-1 -1 -1 $-1 $8225 $8226 #
+coedge $-1 -1 -1 $-1 $7252 $8227 $6299 $7257 reversed $7750 $-1 #
+edge $-1 -1 -1 $-1 $6295 1.5707963267948966 $7264 2.0943951023931957 $6299 $8228 forward @7 unknown T 20 -0.6698729810778099 32.5 22.5 -8.8817841970012523e-16 35 #
+face $-1 -1 -1 $-1 $6477 $8229 $11 $-1 $5386 reversed single T 15 -10 -40 22.500000000000004 -4.9999999999999991 -25 F #
+loop $-1 -1 -1 $-1 $-1 $8230 $6301 T 15 -5 -40 22.500000000000004 -8.8817841970012523e-16 -25 unknown #
+coedge $-1 -1 -1 $-1 $8231 $6453 $6455 $6500 reversed $6302 $-1 #
+vertex $-1 -1 -1 $-1 $8232 $8233 #
+straight-curve $-1 -1 -1 $-1 7.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8234 $6305 $8227 $8235 forward $6313 $-1 #
+vertex $-1 -1 -1 $-1 $8235 $8236 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $5534 $8237 $11 $-1 $5398 reversed single T 7.4999999999999991 -10 20 15 -4.9999999999999991 35 F #
+ellipse-curve $-1 -1 -1 $-1 25 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7832 $7273 $6311 $7269 forward $7276 $-1 #
+edge $-1 -1 -1 $-1 $5403 -1.5707963267948966 $6314 0 $7268 $7267 forward @7 unknown T 25 -10 30 30 -5 35 #
+face $-1 -1 -1 $-1 $8166 $8164 $11 $-1 $6317 reversed single T 10 -10 30 20 -4.9999999999999991 40 F #
+point $-1 -1 -1 $-1 30 -5 30 #
+vertex $-1 -1 -1 $-1 $6318 $8238 #
+coedge $-1 -1 -1 $-1 $7268 $8239 $7203 $6318 forward $7276 $-1 #
+edge $-1 -1 -1 $-1 $6321 -32.5 $7829 -22.500000000000011 $7214 $8240 forward @7 unknown T 37.5 -0.66987298107781124 22.500000000000011 37.5 -0.66987298107780724 32.5 #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780924 32.5 #
+loop $-1 -1 -1 $-1 $-1 $7832 $6323 T 22.5 -10 19.999999999999996 30 -4.9999999999999991 35 unknown #
+coedge $-1 -1 -1 $-1 $7480 $8241 $6496 $7490 reversed $6324 $-1 #
+coedge $-1 -1 -1 $-1 $8242 $6325 $7484 $8243 reversed $5408 $-1 #
+coedge $-1 -1 -1 $-1 $6325 $8244 $8245 $8246 reversed $5408 $-1 #
+coedge $-1 -1 -1 $-1 $8247 $8248 $8249 $7281 forward $8250 $-1 #
+edge $-1 -1 -1 $-1 $8251 -35 $8252 -30 $7280 $8253 forward @7 unknown T 29.999999999999996 -5.0000000000000009 -35 30 -4.9999999999999991 -30 #
+coedge $-1 -1 -1 $-1 $6460 $8254 $6326 $7283 forward $7445 $-1 #
+edge $-1 -1 -1 $-1 $7487 1.5707963267948966 $6462 2.0943951023931957 $7282 $8255 forward @7 unknown T 35 -0.66987298107781079 -42.5 37.5 -1.7763568394002505e-15 -40 #
+vertex $-1 -1 -1 $-1 $8256 $8257 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8258 $6329 $8259 $7301 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $7288 $6331 $7778 $7317 reversed $6333 $-1 #
+coedge $-1 -1 -1 $-1 $6332 $7287 $7597 $8260 reversed $6333 $-1 #
+face $-1 -1 -1 $-1 $5427 $6333 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 35 7.5000000000000036 -20 50 F #
+edge $-1 -1 -1 $-1 $5906 1.5707963267948966 $6360 2.0943951023931957 $6335 $6355 forward @7 unknown T 7.4999999999999991 -25 35 10 -24.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $6336 $8261 $8262 $8263 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $8264 $8265 $6336 $7293 reversed $8266 $-1 #
+edge $-1 -1 -1 $-1 $8267 -1.5707963267948966 $7297 0.5235987755982987 $6336 $8268 forward @7 unknown T -30 -20 50 -22.5 -15 50 #
+coedge $-1 -1 -1 $-1 $8269 $6337 $8265 $8270 forward $7296 $-1 #
+coedge $-1 -1 -1 $-1 $6337 $8271 $8272 $6611 forward $7296 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7295 $8273 T -22.5 -20 35 -15 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $6338 $8274 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7300 $6339 $8275 $8276 reversed $6341 $-1 #
+coedge $-1 -1 -1 $-1 $6340 $7299 $8277 $8278 reversed $6341 $-1 #
+edge $-1 -1 -1 $-1 $6342 0 $8279 2.0943951023931948 $7286 $7298 forward @7 unknown T -22.5 -25 50 -15 -20 50 #
+point $-1 -1 -1 $-1 -15 -20 50 #
+coedge $-1 -1 -1 $-1 $8277 $8280 $6344 $7304 reversed $8281 $-1 #
+edge $-1 -1 -1 $-1 $7305 4.1887902047863905 $7565 4.7123889803846897 $6344 $5654 forward @7 unknown T -7.5000000000000027 -15.669872981077809 35 -5 -15 37.5 #
+vertex $-1 -1 -1 $-1 $7304 $8282 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $6347 $7564 $7701 $8283 forward $5910 $-1 #
+vertex $-1 -1 -1 $-1 $8283 $8284 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 0 -20 40 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8285 $8286 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -20 -40 7.5000000000000009 -15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $8287 $6353 T -8.8817841970012523e-16 -20 -50 7.5 -15 -40 unknown #
+point $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 50 #
+loop $-1 -1 -1 $-1 $-1 $7791 $6357 T 15 -25 -40 22.500000000000004 -20 -25 unknown #
+coedge $-1 -1 -1 $-1 $6528 $6359 $8288 $7542 reversed $5439 $-1 #
+edge $-1 -1 -1 $-1 $8289 1.5707963267948966 $6360 2.0943951023931966 $7778 $8290 forward @7 unknown T 4.9999999999999991 -25 35 7.5000000000000036 -24.330127018922191 37.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000018 -24.330127018922191 37.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6366 -1.5707963267948966 $6951 -6.1232339957367648e-17 $6949 $8291 forward @7 unknown T -30.000000000000004 -40 30 -25.000000000000004 -35 35 #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 35 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6381 $6380 $7893 $8292 forward $4584 $-1 #
+edge $-1 -1 -1 $-1 $6981 -50 $7896 50 $6977 $8293 forward @7 unknown T -50 -50 -50 50 -50 -50 #
+edge $-1 -1 -1 $-1 $7894 -50 $6983 50 $6680 $8294 forward @7 unknown T -50 50 -50 50 50 -50 #
+straight-curve $-1 -1 -1 $-1 50 0 -50 0 -1 0 I I #
+coedge $-1 -1 -1 $-1 $8295 $6383 $8296 $7350 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $7966 $7345 $6383 $7330 reversed $7036 $-1 #
+edge $-1 -1 -1 $-1 $7334 -0.52359877559829893 $6392 1.5707963267948966 $6383 $8297 forward @7 unknown T 30 40 -50 37.5 45 -50 #
+coedge $-1 -1 -1 $-1 $8298 $6384 $6390 $7348 forward $7333 $-1 #
+coedge $-1 -1 -1 $-1 $6384 $8299 $7966 $8300 forward $7333 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7331 $8301 T 37.499999999999993 35 -50 45 45 -40 unknown #
+vertex $-1 -1 -1 $-1 $8300 $8302 #
+ellipse-curve $-1 -1 -1 $-1 40 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6386 $8303 $8304 $8305 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $8306 $8307 $6386 $7338 reversed $8308 $-1 #
+edge $-1 -1 -1 $-1 $8309 1.5707963267948966 $7342 3.6651914291880914 $6386 $8310 forward @7 unknown T 15.000000000000002 35 -50 22.5 40 -50 #
+coedge $-1 -1 -1 $-1 $8311 $6387 $8307 $8312 forward $7341 $-1 #
+coedge $-1 -1 -1 $-1 $6387 $8313 $6389 $7346 reversed $7341 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7340 $8314 T 22.5 35 -50 30 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $6388 $8315 #
+ellipse-curve $-1 -1 -1 $-1 25 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7347 $6389 $8316 $8317 reversed $6391 $-1 #
+coedge $-1 -1 -1 $-1 $7329 $8318 $8319 $7346 reversed $7036 $-1 #
+edge $-1 -1 -1 $-1 $6392 -50 $8320 -45 $8319 $8321 forward @7 unknown T 30 40 -50 30 40 -45 #
+coedge $-1 -1 -1 $-1 $6390 $7344 $8322 $8323 reversed $6391 $-1 #
+edge $-1 -1 -1 $-1 $6393 -50 $8324 -42.500000000000014 $7331 $8325 forward @7 unknown T 37.5 35.669872981077809 -50 37.500000000000007 35.669872981077816 -42.500000000000014 #
+face $-1 -1 -1 $-1 $6096 $6391 $11 $-1 $6121 reversed single T 30 35 -50 37.500000000000014 40 -40 F #
+edge $-1 -1 -1 $-1 $6392 0 $8326 2.0943951023931957 $7328 $7343 forward @7 unknown T 22.5 40 -50 30 45 -50 #
+point $-1 -1 -1 $-1 30 40 -50 #
+point $-1 -1 -1 $-1 37.5 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $8327 $6395 $8328 $8329 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $7377 $8330 $6395 $6417 reversed $8331 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8332 $6398 $8333 $8334 forward $6400 $-1 #
+coedge $-1 -1 -1 $-1 $6399 $8332 $8335 $8336 forward $6400 $-1 #
+edge $-1 -1 -1 $-1 $8337 42.5 $6401 50 $6399 $8338 forward @7 unknown T 37.499999999999986 29.330127018922187 -50 37.5 29.330127018922195 -42.5 #
+face $-1 -1 -1 $-1 $8339 $6400 $11 $-1 $6139 reversed single T 37.499999999999986 20 -50 45 30 -40 F #
+point $-1 -1 -1 $-1 37.5 29.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $6403 $8340 $8341 $8342 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $8343 $8344 $6403 $7363 reversed $8345 $-1 #
+edge $-1 -1 -1 $-1 $8346 -2.0943951023931948 $7367 0 $6403 $8347 forward @7 unknown T 7.5000000000000009 20 -50 15 25 -50 #
+coedge $-1 -1 -1 $-1 $8348 $6404 $8349 $8350 forward $7366 $-1 #
+coedge $-1 -1 -1 $-1 $6404 $8351 $6406 $7370 reversed $7366 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7365 $8352 T 15 20 -50 22.500000000000007 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $8353 $8354 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7371 $6406 $8355 $8356 forward $6408 $-1 #
+edge $-1 -1 -1 $-1 $6409 -50 $8357 -42.500000000000014 $6406 $8358 forward @7 unknown T 22.5 20.669872981077805 -50 22.500000000000004 20.669872981077813 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $6407 $7369 $8359 $8360 forward $6408 $-1 #
+face $-1 -1 -1 $-1 $8361 $6408 $11 $-1 $6162 reversed single T 22.499999999999993 20 -50 30 25 -40 F #
+point $-1 -1 -1 $-1 22.5 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $8359 $8362 $6411 $7375 forward $8363 $-1 #
+edge $-1 -1 -1 $-1 $8364 -1.5707963267948966 $7378 6.4931039580273265e-16 $7374 $8365 forward @7 unknown T 30 19.999999999999996 -45 35 25 -40 #
+coedge $-1 -1 -1 $-1 $6412 $8052 $8366 $8367 reversed $6174 $-1 #
+coedge $-1 -1 -1 $-1 $8368 $7354 $6407 $6413 forward $8331 $-1 #
+vertex $-1 -1 -1 $-1 $8369 $8370 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8371 $8333 $6414 $7381 forward $8372 $-1 #
+edge $-1 -1 -1 $-1 $7382 -2.0943951023931957 $8364 -1.5707963267948966 $7380 $8373 forward @7 unknown T 35 19.999999999999996 -42.5 37.500000000000007 20.669872981077805 -40 #
+vertex $-1 -1 -1 $-1 $8334 $8374 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $8375 $8376 #
+coedge $-1 -1 -1 $-1 $8377 $6420 $8378 $7411 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $8122 $7407 $6420 $7387 reversed $7164 $-1 #
+edge $-1 -1 -1 $-1 $6451 -0.52359877559829893 $6434 1.5707963267948961 $6420 $8379 forward @7 unknown T 15 10 -50 22.5 14.999999999999998 -50 #
+coedge $-1 -1 -1 $-1 $6421 $8380 $8122 $7433 forward $7389 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6444 $7397 T 22.5 10 -50 30 15 -40 unknown #
+coedge $-1 -1 -1 $-1 $6424 $6423 $8381 $8382 forward $5495 $-1 #
+coedge $-1 -1 -1 $-1 $6447 $8383 $6423 $7392 reversed $7430 $-1 #
+edge $-1 -1 -1 $-1 $6449 1.0471975511965983 $8384 1.5707963267948966 $6423 $8385 forward @7 unknown T 37.5 5 -42.5 40 5.6698729810778064 -40 #
+coedge $-1 -1 -1 $-1 $8386 $8149 $6424 $7394 reversed $8387 $-1 #
+edge $-1 -1 -1 $-1 $8388 -1.5707963267948966 $7395 -1.047197551196597 $6424 $8385 forward @7 unknown T 37.5 14.330127018922191 -42.500000000000007 40 15 -40 #
+vertex $-1 -1 -1 $-1 $8150 $8389 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $8390 $7389 $11 $-1 $5329 reversed single T 22.5 10 -50 30 15 -40 F #
+coedge $-1 -1 -1 $-1 $6428 $8391 $8392 $8393 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $8394 $8395 $6428 $7400 reversed $8396 $-1 #
+edge $-1 -1 -1 $-1 $8397 1.5707963267948966 $7404 3.6651914291880923 $6428 $8398 forward @7 unknown T 8.8817841970012523e-16 5 -50 7.5000000000000009 10 -50 #
+coedge $-1 -1 -1 $-1 $8399 $6429 $8395 $8400 forward $7403 $-1 #
+coedge $-1 -1 -1 $-1 $6429 $8401 $6431 $7408 reversed $7403 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7402 $8402 T 7.4999999999999991 5 -50 15 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $6430 $8403 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7409 $6431 $8404 $8405 reversed $6433 $-1 #
+coedge $-1 -1 -1 $-1 $7386 $8406 $8407 $7408 reversed $7164 $-1 #
+edge $-1 -1 -1 $-1 $6434 -50 $8408 -45 $8407 $8409 forward @7 unknown T 15 10 -50 15 10 -45 #
+coedge $-1 -1 -1 $-1 $6432 $7406 $8410 $8411 reversed $6433 $-1 #
+face $-1 -1 -1 $-1 $4434 $6433 $11 $-1 $6219 reversed single T 15 4.9999999999999982 -50 22.500000000000004 10 -40 F #
+edge $-1 -1 -1 $-1 $6434 0 $8412 2.0943951023931948 $7385 $7405 forward @7 unknown T 7.5 10 -50 15 15 -50 #
+point $-1 -1 -1 $-1 15 10 -50 #
+coedge $-1 -1 -1 $-1 $8410 $8413 $6436 $7414 reversed $8414 $-1 #
+edge $-1 -1 -1 $-1 $7415 1.0471975511965979 $8415 1.5707963267948966 $6436 $8416 forward @7 unknown T 22.5 5 -42.5 25 5.6698729810778081 -40 #
+vertex $-1 -1 -1 $-1 $7414 $8417 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8418 $6441 $6438 $7418 reversed $7421 $-1 #
+edge $-1 -1 -1 $-1 $8415 -1.5707963267948966 $6445 0 $6438 $8419 forward @7 unknown T 25 5 -45 30 10 -40 #
+face $-1 -1 -1 $-1 $8420 $8421 $11 $-1 $6231 reversed single T 7.4999999999999964 10 -50 15 15 -40 F #
+coedge $-1 -1 -1 $-1 $6441 $8418 $8422 $8423 forward $7421 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6441 $8424 T 25 4.9999999999999982 -45 35 10 -35 unknown #
+vertex $-1 -1 -1 $-1 $6442 $8425 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8426 $8427 $6443 $7425 forward $8428 $-1 #
+edge $-1 -1 -1 $-1 $6445 2.9403902792268234e-16 $8429 1.5707963267948966 $7424 $8430 forward @7 unknown T 30 10 -45 35 14.999999999999998 -40 #
+coedge $-1 -1 -1 $-1 $8380 $6444 $8427 $7427 forward $7389 $-1 #
+edge $-1 -1 -1 $-1 $6445 0 $8431 1.5707963267948966 $7426 $8419 forward @7 unknown T 25 10 -45 30 15 -40 #
+point $-1 -1 -1 $-1 30 10 -45 #
+coedge $-1 -1 -1 $-1 $8383 $6447 $8144 $8432 forward $7430 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6447 $8433 T 35 4.9999999999999982 -42.5 40 5.6698729810778072 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778064 -42.5 #
+edge $-1 -1 -1 $-1 $8434 42.500000000000007 $6451 50 $7388 $8435 forward @7 unknown T 22.5 14.330127018922193 -50 22.500000000000004 14.330127018922195 -42.500000000000007 #
+point $-1 -1 -1 $-1 22.5 14.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $8436 $6452 $8437 $8438 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $7465 $8439 $6452 $6478 reversed $7479 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6455 $6493 $8440 $8441 forward $6456 $-1 #
+coedge $-1 -1 -1 $-1 $8442 $8442 $6457 $7440 reversed $8443 $-1 #
+edge $-1 -1 -1 $-1 $7442 -1.5707963267948966 $7446 1.5707963267948966 $6457 $8444 forward @7 unknown T 40 -10 -45 45 0 -40 #
+coedge $-1 -1 -1 $-1 $6458 $6496 $8445 $8446 reversed $6497 $-1 #
+vertex $-1 -1 -1 $-1 $6459 $8447 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8254 $6460 $8448 $8449 reversed $7445 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7282 $8450 T 35 -0.66987298107781079 -42.5 40 0 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $6461 $8451 #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780924 -42.5 #
+face $-1 -1 -1 $-1 $7837 $8452 $11 $-1 $4463 reversed single T 37.499999999999993 -10 5.0000000000000027 45.000000000000007 8.8817841970012523e-16 20.000000000000007 F #
+coedge $-1 -1 -1 $-1 $6465 $8453 $8454 $8455 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $8456 $8457 $6465 $7451 reversed $8458 $-1 #
+edge $-1 -1 -1 $-1 $8459 -2.0943951023931957 $7455 0 $6465 $8460 forward @7 unknown T -7.5000000000000009 -10 -50 0 -5 -50 #
+coedge $-1 -1 -1 $-1 $8461 $6466 $8462 $8463 forward $7454 $-1 #
+coedge $-1 -1 -1 $-1 $6466 $8464 $6468 $7458 reversed $7454 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7453 $8465 T -9.3734986416366059e-33 -10 -50 7.5000000000000009 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $8466 $8467 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7459 $6468 $8468 $8469 forward $6470 $-1 #
+edge $-1 -1 -1 $-1 $6471 -50 $8470 -42.500000000000007 $6468 $8471 forward @7 unknown T 7.5 -9.3301270189221945 -50 7.5 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $6469 $7457 $8472 $8473 forward $6470 $-1 #
+face $-1 -1 -1 $-1 $8474 $6470 $11 $-1 $5398 reversed single T 7.4999999999999964 -10 -50 15 -5 -40 F #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 -50 #
+coedge $-1 -1 -1 $-1 $8472 $8475 $6473 $7463 forward $8476 $-1 #
+edge $-1 -1 -1 $-1 $8477 -1.5707963267948966 $7466 1.1640334398265738e-16 $7462 $8478 forward @7 unknown T 15 -10 -45 20 -5 -40 #
+coedge $-1 -1 -1 $-1 $6474 $8231 $8479 $8480 reversed $6302 $-1 #
+coedge $-1 -1 -1 $-1 $8481 $7436 $6469 $6475 forward $7479 $-1 #
+vertex $-1 -1 -1 $-1 $8482 $8483 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8484 $6480 $6476 $7469 forward $7472 $-1 #
+edge $-1 -1 -1 $-1 $6482 -2.0943951023931966 $8477 -1.5707963267948966 $7468 $8485 forward @7 unknown T 20 -10 -42.500000000000007 22.500000000000004 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $8486 $8487 #
+coedge $-1 -1 -1 $-1 $6480 $8484 $8488 $8489 reversed $7472 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7468 $8490 T 20 -10 -42.500000000000007 25 -9.330127018922191 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $6481 $8491 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $6487 $6484 $8492 $8493 reversed $6488 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8494 $8495 $11 $-1 $4486 reversed single T 22.499999999999996 -5.0000000000000009 5.0000000000000018 30 0 20 F #
+loop $-1 -1 -1 $-1 $-1 $7465 $6486 T 7.4999999999999991 -5 -50 15 0 -40 unknown #
+coedge $-1 -1 -1 $-1 $8496 $7277 $6487 $7481 reversed $6324 $-1 #
+edge $-1 -1 -1 $-1 $8251 -4.7167471186270745e-16 $6489 1.5707963267948966 $6487 $8497 forward @7 unknown T 30 -10.000000000000002 -40 35 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $8498 $6488 $11 $-1 $8499 reversed single T 25 -10.000000000000002 -45 35 -4.9999999999999991 -35 F #
+point $-1 -1 -1 $-1 35 -10.000000000000002 -40 #
+coedge $-1 -1 -1 $-1 $8500 $6491 $7278 $8243 forward $7486 $-1 #
+coedge $-1 -1 -1 $-1 $6491 $8500 $6493 $6494 reversed $7486 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6491 $8498 T 25 -5 -45 35 0 -35 unknown #
+vertex $-1 -1 -1 $-1 $6492 $8501 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $8441 $8502 #
+edge $-1 -1 -1 $-1 $6489 1.5707963267948966 $8503 2.0943951023931957 $6496 $8504 forward @7 unknown T 35 -10.000000000000002 -40 37.5 -9.3301270189221928 -37.5 #
+face $-1 -1 -1 $-1 $8505 $6497 $11 $-1 $8499 reversed single T 35 -10.000000000000002 -42.5 40 -9.3301270189221928 -37.5 F #
+vertex $-1 -1 -1 $-1 $8506 $8507 #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $8508 $6502 $8509 $7516 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $8287 $7512 $6502 $7496 reversed $7313 $-1 #
+edge $-1 -1 -1 $-1 $6534 -0.52359877559829893 $6519 1.5707963267948966 $6502 $8510 forward @7 unknown T -8.8817841970012523e-16 -20 -50 7.5 -15 -50 #
+coedge $-1 -1 -1 $-1 $6503 $8511 $8287 $7535 forward $6542 $-1 #
+coedge $-1 -1 -1 $-1 $6850 $8288 $6505 $7499 reversed $7787 $-1 #
+edge $-1 -1 -1 $-1 $6547 -1.5707963267948966 $6548 -1.047197551196597 $6505 $6538 forward @7 unknown T 22.499999999999996 -15.669872981077809 -42.500000000000007 25 -15 -40 #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -25 -40 #
+point $-1 -1 -1 $-1 40 -15 -40 #
+coedge $-1 -1 -1 $-1 $6513 $8512 $8513 $8514 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $8515 $8516 $6513 $7505 reversed $8517 $-1 #
+edge $-1 -1 -1 $-1 $8518 1.5707963267948966 $7509 3.6651914291880923 $6513 $8519 forward @7 unknown T -15.000000000000002 -25 -50 -7.5000000000000009 -20 -50 #
+coedge $-1 -1 -1 $-1 $8520 $6514 $8516 $8521 forward $7508 $-1 #
+coedge $-1 -1 -1 $-1 $6514 $8522 $6516 $7513 reversed $7508 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7507 $8523 T -7.5000000000000036 -25 -50 0 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $6515 $8524 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7514 $6516 $8525 $8526 reversed $6518 $-1 #
+coedge $-1 -1 -1 $-1 $7495 $8527 $8528 $7513 reversed $7313 $-1 #
+edge $-1 -1 -1 $-1 $6519 -50 $8529 -45 $8528 $8530 forward @7 unknown T -8.8817841970012523e-16 -20 -50 0 -20 -45 #
+coedge $-1 -1 -1 $-1 $6517 $7511 $8531 $8532 reversed $6518 $-1 #
+face $-1 -1 -1 $-1 $4521 $6518 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 -50 7.5000000000000036 -20 -40 F #
+edge $-1 -1 -1 $-1 $6519 0 $8533 2.0943951023931957 $7494 $7510 forward @7 unknown T -7.5000000000000009 -20 -50 0 -15 -50 #
+point $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 -50 #
+coedge $-1 -1 -1 $-1 $8531 $8534 $6521 $7519 reversed $8535 $-1 #
+edge $-1 -1 -1 $-1 $7520 1.047197551196597 $8536 1.5707963267948966 $6521 $8537 forward @7 unknown T 7.4999999999999964 -25 -42.500000000000014 10 -24.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $7519 $8538 #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8539 $6526 $6523 $7523 reversed $6896 $-1 #
+edge $-1 -1 -1 $-1 $8536 -1.5707963267948966 $6530 0 $6523 $8540 forward @7 unknown T 10 -25 -45 15 -20 -40 #
+face $-1 -1 -1 $-1 $4964 $8541 $11 $-1 $3822 reversed single T -7.5000000000000053 -20 -50 0 -15 -40 F #
+coedge $-1 -1 -1 $-1 $6526 $8539 $8542 $8543 forward $6896 $-1 #
+vertex $-1 -1 -1 $-1 $6527 $8544 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8545 $8546 $6528 $7529 forward $7847 $-1 #
+edge $-1 -1 -1 $-1 $6530 -6.1232339957367648e-17 $8547 1.5707963267948966 $7528 $8548 forward @7 unknown T 15 -20 -45 20 -15 -40 #
+coedge $-1 -1 -1 $-1 $8511 $6529 $8546 $7531 forward $6542 $-1 #
+edge $-1 -1 -1 $-1 $6530 0 $8549 1.5707963267948966 $7530 $8540 forward @7 unknown T 10 -20 -45 15 -15 -40 #
+point $-1 -1 -1 $-1 15 -20 -45 #
+coedge $-1 -1 -1 $-1 $6535 $6532 $7791 $8550 forward $6536 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8551 42.500000000000007 $6534 50 $7497 $8552 forward @7 unknown T 7.4999999999999982 -15.669872981077809 -50 7.5 -15.669872981077807 -42.500000000000007 #
+point $-1 -1 -1 $-1 7.5 -15.669872981077807 -50 #
+edge $-1 -1 -1 $-1 $6537 1.5707963267948966 $7792 2.0943951023931948 $6856 $7788 forward @7 unknown T 22.500000000000004 -25 -40 25 -24.330127018922195 -37.5 #
+face $-1 -1 -1 $-1 $8553 $6536 $11 $-1 $4210 reversed single T 20 -25 -42.500000000000014 25 -24.330127018922191 -37.5 F #
+point $-1 -1 -1 $-1 25 -25 -40 #
+ellipse-curve $-1 -1 -1 $-1 35 -20.000000000000004 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 25 -15 -40 #
+edge $-1 -1 -1 $-1 $8547 1.5707963267948966 $6548 2.0943951023931966 $8288 $8554 forward @7 unknown T 20 -15.669872981077811 -42.500000000000007 22.500000000000004 -15 -40 #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077809 -42.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 -22.5 -39.330127018922191 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -22.5 -39.330127018922191 -50 #
+edge $-1 -1 -1 $-1 $6571 -1.5707963267948966 $3866 -6.1232339957367648e-17 $6558 $8555 forward @7 unknown T -30.000000000000004 -40 -45 -25.000000000000004 -35 -40 #
+edge $-1 -1 -1 $-1 $6695 6.1232339957367648e-17 $6568 1.570796326794897 $6562 $8556 forward @7 unknown T -30.000000000000004 -40 -25 -25 -35 -19.999999999999996 #
+face $-1 -1 -1 $-1 $6640 $7552 $11 $-1 $482 reversed single T -25.000000000000007 -40 -27.500000000000004 -20 -39.330127018922191 -22.5 F #
+coedge $-1 -1 -1 $-1 $7667 $6566 $7663 $8557 forward $7552 $-1 #
+coedge $-1 -1 -1 $-1 $6566 $7667 $6656 $6709 reversed $7552 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7550 $7549 T -25.000000000000007 -40 -27.500000000000004 -20 -39.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $6709 $8558 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 -25 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 -40 #
+loop $-1 -1 -1 $-1 $-1 $7702 $6577 T -7.5000000000000053 -20 20 0 -15 35 unknown #
+loop $-1 -1 -1 $-1 $-1 $7616 $5634 T -50 -25 14.999999999999996 -50 -15 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $8559 $8559 $8560 $8561 forward $6578 $-1 #
+coedge $-1 -1 -1 $-1 $8562 $6579 $7595 $8563 reversed $5635 $-1 #
+coedge $-1 -1 -1 $-1 $6579 $8562 $8564 $8565 forward $5635 $-1 #
+edge $-1 -1 -1 $-1 $8566 1.5707963267948966 $7599 2.0943951023931957 $6579 $8567 forward @7 unknown T -10.000000000000002 -25 20 -7.5000000000000009 -24.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $7307 $6580 $8568 $8569 reversed $5910 $-1 #
+vertex $-1 -1 -1 $-1 $8570 $8571 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -50 -20 29.999999999999996 #
+coedge $-1 -1 -1 $-1 $8572 $6584 $8573 $8574 reversed $6586 $-1 #
+coedge $-1 -1 -1 $-1 $6592 $8575 $6584 $7570 forward $7585 $-1 #
+edge $-1 -1 -1 $-1 $8576 -2.0943951023931957 $5646 -1.5707963267948966 $7569 $8577 forward @7 unknown T -40 -15.669872981077805 35 -37.499999999999993 -14.999999999999996 37.5 #
+coedge $-1 -1 -1 $-1 $6585 $8572 $8578 $8579 reversed $6586 $-1 #
+coedge $-1 -1 -1 $-1 $8580 $6589 $6585 $7573 forward $7578 $-1 #
+edge $-1 -1 -1 $-1 $5645 1.5707963267948966 $8581 2.0943951023931957 $7572 $8582 forward @7 unknown T -40 -24.999999999999996 35 -37.5 -24.330127018922187 37.5 #
+face $-1 -1 -1 $-1 $8583 $6586 $11 $-1 $7591 reversed single T -45 -24.999999999999996 35 -37.499999999999993 -14.999999999999996 50 F #
+coedge $-1 -1 -1 $-1 $8584 $8585 $6588 $7576 forward $8586 $-1 #
+edge $-1 -1 -1 $-1 $8587 22.5 $7579 32.499999999999993 $7575 $8588 forward @7 unknown T -37.500000000000007 -24.330127018922198 22.5 -37.5 -24.330127018922187 32.499999999999993 #
+coedge $-1 -1 -1 $-1 $6589 $8580 $8584 $8589 reversed $7578 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7572 $8590 T -40 -25 32.499999999999993 -35 -24.330127018922187 37.5 unknown #
+vertex $-1 -1 -1 $-1 $8589 $8591 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 35 -0.70710678118654768 -0 -0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $6591 $7588 $8592 $8593 reversed $5644 $-1 #
+coedge $-1 -1 -1 $-1 $8594 $8595 $6591 $7583 forward $8596 $-1 #
+edge $-1 -1 -1 $-1 $7586 -32.5 $8597 -22.499999999999993 $7582 $8598 forward @7 unknown T -37.500000000000007 -15.669872981077805 22.499999999999993 -37.5 -15.669872981077804 32.5 #
+coedge $-1 -1 -1 $-1 $8575 $6592 $8595 $8599 reversed $7585 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7569 $8600 T -40 -15.669872981077809 32.5 -35 -14.999999999999996 37.5 unknown #
+vertex $-1 -1 -1 $-1 $7583 $8601 #
+coedge $-1 -1 -1 $-1 $7581 $6594 $8559 $8602 reversed $5644 $-1 #
+coedge $-1 -1 -1 $-1 $8603 $8604 $6594 $7590 forward $8605 $-1 #
+edge $-1 -1 -1 $-1 $8606 1.5707963267948966 $8587 2.0943951023931944 $7589 $8607 forward @7 unknown T -40 -24.999999999999996 19.999999999999996 -37.500000000000007 -24.330127018922191 22.5 #
+cone-surface $-1 -1 -1 $-1 -40 -19.999999999999996 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8608 $6598 $8609 $7703 reversed $6600 $-1 #
+coedge $-1 -1 -1 $-1 $6602 $8610 $6598 $7594 reversed $6836 $-1 #
+edge $-1 -1 -1 $-1 $5653 -1.5707963267948966 $8611 0 $6598 $8612 forward @7 unknown T -5 -25 30 0 -20 35 #
+coedge $-1 -1 -1 $-1 $6599 $8608 $7561 $8563 forward $6600 $-1 #
+face $-1 -1 -1 $-1 $6524 $6600 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 20 0 -20 35 F #
+coedge $-1 -1 -1 $-1 $8610 $6602 $7288 $8260 forward $6836 $-1 #
+coedge $-1 -1 -1 $-1 $6607 $6605 $8613 $8614 reversed $5657 $-1 #
+vertex $-1 -1 -1 $-1 $7563 $8615 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8616 $8617 $8618 $7602 reversed $7638 $-1 #
+edge $-1 -1 -1 $-1 $8619 25 $6620 30 $8618 $8620 forward @7 unknown T -15 -20 25 -15 -20 30 #
+coedge $-1 -1 -1 $-1 $6612 $6608 $8621 $8622 reversed $6613 $-1 #
+straight-curve $-1 -1 -1 $-1 -15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8623 $8272 $6612 $7606 forward $8624 $-1 #
+edge $-1 -1 -1 $-1 $6614 3.1415926535897931 $8625 4.7123889803846897 $7605 $8626 forward @7 unknown T -20 -25 35 -15 -20 40 #
+face $-1 -1 -1 $-1 $8627 $6613 $11 $-1 $1965 reversed single T -20 -25 30 -10.000000000000002 -20 40 F #
+point $-1 -1 -1 $-1 -15 -20 40 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+face $-1 -1 -1 $-1 $8628 $8629 $11 $-1 $6619 reversed single T -15.000000000000002 -20 -40 -7.5000000000000009 -15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $8630 $6618 T -15.000000000000002 -20 -50 -7.5000000000000009 -15 -40 unknown #
+edge $-1 -1 -1 $-1 $6620 0 $8631 1.5707963267948966 $8632 $8633 forward @7 unknown T -20 -20 30 -15 -15 35 #
+point $-1 -1 -1 $-1 -15 -20 30 #
+loop $-1 -1 -1 $-1 $8634 $8635 $3147 T -50 -25 -15.000000000000004 -50 -15 -5.0000000000000036 hole $3148 T #
+coedge $-1 -1 -1 $-1 $7615 $7615 $8636 $8637 forward $6622 $-1 #
+coedge $-1 -1 -1 $-1 $7616 $7616 $6623 $7617 reversed $7559 $-1 #
+edge $-1 -1 -1 $-1 $8638 0 $8638 6.2831853071795862 $6623 $8639 forward @7 unknown T -50 -25 14.999999999999996 -50 -15 24.999999999999996 #
+face $-1 -1 -1 $-1 $8640 $8641 $11 $-1 $8642 reversed single T -37.5 -25 -50 -30 -20 -40 F #
+face $-1 -1 -1 $-1 $8643 $8644 $11 $-1 $7591 reversed single T -45 -24.999999999999996 -10.000000000000002 -37.499999999999993 -14.999999999999996 4.9999999999999973 F #
+loop $-1 -1 -1 $-1 $-1 $8645 $6631 T -45 -24.999999999999996 -25.000000000000004 -37.5 -14.999999999999996 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $6638 $6699 $6635 $7622 reversed $7623 $-1 #
+edge $-1 -1 -1 $-1 $5700 -1.570796326794897 $6695 6.1232339957367648e-17 $6635 $8646 forward @7 unknown T -30.000000000000004 -35 -25 -25 -30 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $7621 $8647 T -30.000000000000004 -35 -25 -22.5 -30 -10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $6707 $8648 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8649 $8650 $11 $-1 $7628 reversed single T -30.000000000000007 -20 4.9999999999999982 -22.499999999999993 -15 20 F #
+loop $-1 -1 -1 $-1 $-1 $8651 $6646 T -30 -20 20 -22.499999999999993 -15 35 unknown #
+cone-surface $-1 -1 -1 $-1 -25 -20 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+point $-1 -1 -1 $-1 -5 -30 -40 #
+edge $-1 -1 -1 $-1 $6660 4.1887902047863905 $6649 4.7123889803846897 $6651 $2458 forward @7 unknown T -7.5000000000000018 -30.669872981077809 -40 -5 -30 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -30.669872981077809 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 -30.669872981077805 -37.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 -37.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 -42.500000000000007 #
+face $-1 -1 -1 $-1 $8652 $8653 $11 $-1 $6619 reversed single T -15.000000000000002 -20 4.9999999999999991 -7.5000000000000009 -15 20 F #
+loop $-1 -1 -1 $-1 $-1 $8616 $6669 T -15.000000000000002 -20 20 -7.5000000000000009 -15 35 unknown #
+loop $-1 -1 -1 $-1 $8654 $8655 $1558 T 50 -10 30 50 0 40 hole $1559 T #
+coedge $-1 -1 -1 $-1 $7640 $7640 $7785 $8656 forward $6670 $-1 #
+coedge $-1 -1 -1 $-1 $7641 $7641 $6671 $7642 reversed $6839 $-1 #
+edge $-1 -1 -1 $-1 $8657 0 $8657 6.2831853071795862 $6671 $8658 forward @7 unknown T 50 -25 -29.999999999999996 50 -15 -19.999999999999996 #
+vertex $-1 -1 -1 $-1 $6673 $8659 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 -9.9999999999999964 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -20 3.0616169978683823e-15 #
+coedge $-1 -1 -1 $-1 $6681 $6703 $8660 $8661 forward $6704 $-1 #
+vertex $-1 -1 -1 $-1 $6689 $8662 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 -10.000000000000002 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6922 $6683 $8663 $8664 forward $6726 $-1 #
+vertex $-1 -1 -1 $-1 $6684 $8665 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 4.9999999999999982 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 -30 -35 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6686 $6913 $7655 $8666 forward $6914 $-1 #
+coedge $-1 -1 -1 $-1 $6691 $6688 $7656 $8667 forward $6692 $-1 #
+coedge $-1 -1 -1 $-1 $6728 $6690 $7653 $8666 reversed $6729 $-1 #
+coedge $-1 -1 -1 $-1 $6690 $6727 $7654 $8667 reversed $6729 $-1 #
+coedge $-1 -1 -1 $-1 $8660 $8663 $5763 $6685 reversed $7676 $-1 #
+edge $-1 -1 -1 $-1 $7689 -1.5707963267948966 $6693 -6.1232339957367648e-17 $6691 $8668 forward @7 unknown T -30.000000000000004 -40 -15.000000000000004 -25.000000000000004 -35 -10.000000000000002 #
+face $-1 -1 -1 $-1 $6733 $6692 $11 $-1 $336 reversed single T -35 -40 -15.000000000000004 -25.000000000000004 -35 -5.0000000000000018 F #
+point $-1 -1 -1 $-1 -30 -35 -15.000000000000002 #
+point $-1 -1 -1 $-1 -29.999999999999993 -35 -20.000000000000004 #
+coedge $-1 -1 -1 $-1 $6711 $6697 $6713 $7672 reversed $6700 $-1 #
+coedge $-1 -1 -1 $-1 $6698 $6711 $7550 $8557 reversed $6700 $-1 #
+coedge $-1 -1 -1 $-1 $6699 $7692 $6703 $7666 reversed $7623 $-1 #
+face $-1 -1 -1 $-1 $7687 $6700 $11 $-1 $3872 reversed single T -30.000000000000004 -40 -25 -22.5 -35 -10.000000000000002 F #
+edge $-1 -1 -1 $-1 $6693 -6.1232339957367648e-17 $8669 1.5707963267948966 $6703 $8670 forward @7 unknown T -30.000000000000004 -35 -15.000000000000004 -25.000000000000004 -30 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $7551 $7550 $6705 $7668 reversed $7552 $-1 #
+edge $-1 -1 -1 $-1 $5791 1.5707963267948966 $7670 2.0943951023931948 $6705 $7669 forward @7 unknown T -22.500000000000004 -40 -25 -20 -39.330127018922191 -22.500000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -20 -35 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $8557 $8671 #
+edge $-1 -1 -1 $-1 $5812 -2.0943951023931957 $7689 -1.5707963267948966 $6713 $8672 forward @7 unknown T -25.000000000000004 -40 -12.500000000000005 -22.500000000000004 -39.330127018922191 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $6905 $6714 $6728 $7686 forward $6906 $-1 #
+coedge $-1 -1 -1 $-1 $8663 $6715 $6718 $7679 reversed $7676 $-1 #
+coedge $-1 -1 -1 $-1 $6715 $8660 $6722 $7682 reversed $7676 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8660 $8673 T -30.000000000000004 -35 -10.000000000000002 -22.5 -30 4.9999999999999982 unknown #
+straight-curve $-1 -1 -1 $-1 -22.5 -30.669872981077809 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $6718 $6717 $7879 $8674 forward $6719 $-1 #
+edge $-1 -1 -1 $-1 $8675 1.5707963267948966 $6720 2.0943951023931948 $6718 $8676 forward @7 unknown T -25.000000000000004 -30.669872981077805 2.4999999999999969 -22.500000000000004 -30 4.9999999999999982 #
+face $-1 -1 -1 $-1 $5768 $6719 $11 $-1 $227 reversed single T -25.000000000000004 -30.669872981077809 2.4999999999999969 -20 -30 7.5000000000000027 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 2.4999999999999969 #
+edge $-1 -1 -1 $-1 $6724 -2.0943951023931953 $8669 -1.5707963267948966 $6722 $8677 forward @7 unknown T -25.000000000000004 -30.669872981077813 -10.000000000000002 -22.500000000000004 -30 -7.4999999999999991 #
+face $-1 -1 -1 $-1 $4844 $6723 $11 $-1 $336 reversed single T -25.000000000000004 -30.669872981077813 -12.500000000000004 -20 -30 -7.4999999999999964 F #
+point $-1 -1 -1 $-1 -22.500000000000007 -30.669872981077813 -7.4999999999999991 #
+face $-1 -1 -1 $-1 $7680 $6906 $11 $-1 $227 reversed single T -25.000000000000004 -40 2.4999999999999969 -20 -39.330127018922184 7.5000000000000036 F #
+edge $-1 -1 -1 $-1 $6730 -2.0943951023931948 $8678 -1.5707963267948966 $7673 $8679 forward @7 unknown T -25.000000000000004 -40 2.4999999999999969 -22.500000000000004 -39.330127018922198 4.9999999999999982 #
+face $-1 -1 -1 $-1 $7862 $6729 $11 $-1 $3872 reversed single T -30.000000000000004 -40 -10.000000000000002 -22.5 -35 4.9999999999999982 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 2.4999999999999969 #
+vertex $-1 -1 -1 $-1 $7658 $8680 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -10.000000000000002 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7664 $6738 $6739 $7693 reversed $7623 $-1 #
+edge $-1 -1 -1 $-1 $8669 1.5707963267948966 $5814 2.0943951023931957 $6739 $8681 forward @7 unknown T -25.000000000000004 -30.669872981077809 -12.500000000000004 -22.5 -30 -10.000000000000002 #
+face $-1 -1 -1 $-1 $8682 $8683 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 -25 7.5000000000000018 -20 -10 F #
+loop $-1 -1 -1 $-1 $-1 $8684 $6741 T -8.8817841970012523e-16 -20 -25 7.5000000000000009 -15 -10 unknown #
+coedge $-1 -1 -1 $-1 $7801 $8685 $8686 $8687 reversed $6742 $-1 #
+coedge $-1 -1 -1 $-1 $6797 $6743 $6800 $7755 reversed $5822 $-1 #
+coedge $-1 -1 -1 $-1 $6743 $8688 $8689 $8690 reversed $5822 $-1 #
+coedge $-1 -1 -1 $-1 $8691 $8692 $6743 $7700 forward $8693 $-1 #
+edge $-1 -1 -1 $-1 $8694 -1.5707963267948966 $8695 6.1232339957367648e-17 $7699 $8696 forward @7 unknown T -8.8817841970012523e-16 -20 5 4.9999999999999991 -15 10 #
+coedge $-1 -1 -1 $-1 $6745 $6815 $7307 $8283 reversed $4911 $-1 #
+coedge $-1 -1 -1 $-1 $8568 $8697 $7592 $7703 forward $7558 $-1 #
+edge $-1 -1 -1 $-1 $7707 25 $8611 30 $7702 $8698 forward @7 unknown T -8.8817841970012523e-16 -20 25 0 -20 30 #
+coedge $-1 -1 -1 $-1 $8699 $6746 $8697 $8700 reversed $6811 $-1 #
+coedge $-1 -1 -1 $-1 $6746 $8699 $8688 $8701 forward $6811 $-1 #
+vertex $-1 -1 -1 $-1 $8701 $8702 #
+vertex $-1 -1 -1 $-1 $8703 $8704 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6750 -1.5707963267948966 $5848 -6.1232339957367648e-17 $6869 $8705 forward @7 unknown T 15 -25 -15 20 -20 -9.9999999999999982 #
+point $-1 -1 -1 $-1 20 -25 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $6754 $6753 $8706 $8707 reversed $6755 $-1 #
+coedge $-1 -1 -1 $-1 $6758 $8708 $6753 $6761 reversed $7315 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6766 $6765 $7804 $8709 forward $5847 $-1 #
+coedge $-1 -1 -1 $-1 $8710 $8711 $6766 $7718 reversed $8712 $-1 #
+edge $-1 -1 -1 $-1 $8713 4.1887902047863914 $6773 4.7123889803846897 $6766 $8714 forward @7 unknown T 7.5000000000000009 -15.669872981077807 -25 10 -15 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $8715 $6767 $8716 $8717 forward $6769 $-1 #
+coedge $-1 -1 -1 $-1 $6768 $8715 $8718 $6795 forward $6769 $-1 #
+coedge $-1 -1 -1 $-1 $6784 $6869 $6768 $7722 reversed $5061 $-1 #
+edge $-1 -1 -1 $-1 $5870 -1.5707963267948966 $5848 0 $6768 $6791 forward @7 unknown T 10 -25 -15 15 -20 -10 #
+face $-1 -1 -1 $-1 $4140 $6769 $11 $-1 $4529 reversed single T 7.4999999999999982 -25 -25 15 -20 -10 F #
+coedge $-1 -1 -1 $-1 $8719 $6771 $8711 $7728 forward $7726 $-1 #
+coedge $-1 -1 -1 $-1 $6771 $8720 $8721 $7731 forward $7726 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7725 $8553 T 7.4999999999999964 -20 -40 15 -15 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6773 -1.5707963267948966 $8722 -1.047197551196597 $7724 $8723 forward @7 unknown T 7.4999999999999964 -15.669872981077809 -27.500000000000004 10 -15 -25 #
+point $-1 -1 -1 $-1 10 -15 -25 #
+coedge $-1 -1 -1 $-1 $6852 $6775 $8545 $8724 reversed $6358 $-1 #
+edge $-1 -1 -1 $-1 $8725 -35 $6776 -30 $7725 $8726 forward @7 unknown T 15 -20 -35 15 -20 -30 #
+point $-1 -1 -1 $-1 15 -20 -30 #
+edge $-1 -1 -1 $-1 $8727 1.0471975511965979 $6778 1.5707963267948966 $8728 $8723 forward @7 unknown T 7.5 -25 -27.500000000000004 10 -24.330127018922191 -25 #
+point $-1 -1 -1 $-1 10 -25 -25 #
+coedge $-1 -1 -1 $-1 $8729 $7801 $6779 $7736 reversed $6742 $-1 #
+edge $-1 -1 -1 $-1 $6812 -2.5000000000000009 $7738 7.5000000000000009 $6779 $8730 forward @7 unknown T 7.4999999999999991 -15.669872981077809 -7.5000000000000009 7.5000000000000009 -15.669872981077807 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $6780 $6800 $8729 $8731 forward $6801 $-1 #
+vertex $-1 -1 -1 $-1 $6782 $8732 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -10 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6785 $6783 $8733 $8734 forward $5862 $-1 #
+coedge $-1 -1 -1 $-1 $8718 $8735 $6783 $7742 reversed $7746 $-1 #
+edge $-1 -1 -1 $-1 $5870 1.5707963267948966 $8736 2.0943951023931957 $6783 $7739 forward @7 unknown T 7.4999999999999991 -25 -10 10 -24.330127018922191 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $8737 $6805 $6785 $5888 reversed $7761 $-1 #
+coedge $-1 -1 -1 $-1 $6786 $6807 $6788 $6890 forward $5887 $-1 #
+face $-1 -1 -1 $-1 $8738 $8739 $11 $-1 $2664 reversed single T -5 -25 -15 4.9999999999999991 -20 -5 F #
+loop $-1 -1 -1 $-1 $-1 $8740 $6790 T 4.9999999999999991 -25 -12.500000000000002 10 -24.330127018922191 -7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $6867 $8741 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -10 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8742 $8743 $11 $-1 $5386 reversed single T 14.999999999999996 -5 5.0000000000000009 22.5 0 20 F #
+loop $-1 -1 -1 $-1 $-1 $8744 $6794 T 15 -5 20 22.5 -8.8817841970012523e-16 35 unknown #
+vertex $-1 -1 -1 $-1 $6795 $8745 #
+coedge $-1 -1 -1 $-1 $8688 $6797 $6799 $7754 reversed $5822 $-1 #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $7706 1.5707963267948966 $5911 2.0943951023931957 $6799 $8746 forward @7 unknown T 4.9999999999999991 -15.669872981077809 17.499999999999996 7.5 -15 20 #
+edge $-1 -1 -1 $-1 $6802 -2.0943951023931957 $8694 -1.5707963267948966 $6800 $8747 forward @7 unknown T 4.9999999999999991 -15.669872981077809 5 7.5 -15 7.5000000000000044 #
+face $-1 -1 -1 $-1 $8748 $6801 $11 $-1 $2156 reversed single T 4.9999999999999991 -15.669872981077809 2.5 10 -15 7.5000000000000044 F #
+point $-1 -1 -1 $-1 7.4999999999999973 -15.669872981077807 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $8749 $8750 $6804 $7759 reversed $8751 $-1 #
+edge $-1 -1 -1 $-1 $7762 7.5000000000000027 $5913 17.500000000000004 $6804 $8752 forward @7 unknown T 7.5 -24.330127018922195 7.5000000000000027 7.5000000000000027 -24.330127018922191 17.500000000000004 #
+coedge $-1 -1 -1 $-1 $6805 $8737 $8749 $8753 forward $7761 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7760 $8754 T 4.9999999999999991 -25 2.5000000000000009 10.000000000000002 -24.330127018922191 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $8753 $8755 #
+coedge $-1 -1 -1 $-1 $6825 $6808 $8750 $8756 forward $6826 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $6821 $6826 $11 $-1 $1815 reversed single T 4.9999999999999991 -25 17.500000000000004 10 -24.330127018922191 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $8757 $6810 T -5 -25 15 4.9999999999999991 -20 25 unknown #
+point $-1 -1 -1 $-1 7.4999999999999991 -15.669872981077809 2.5000000000000009 #
+point $-1 -1 -1 $-1 7.4999999999999991 -24.330127018922195 2.5000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8758 $8759 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 5 0 -20 20 F #
+coedge $-1 -1 -1 $-1 $8760 $6823 $6825 $7776 reversed $7774 $-1 #
+coedge $-1 -1 -1 $-1 $6823 $8761 $6828 $7779 reversed $7774 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7772 $8762 T -8.8817841970012523e-16 -25 20 7.5000000000000027 -20 35 unknown #
+edge $-1 -1 -1 $-1 $8763 1.5707963267948966 $6827 2.0943951023931957 $6825 $8764 forward @7 unknown T 4.9999999999999991 -25 20 7.5000000000000018 -24.330127018922191 22.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 -24.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $6829 $6828 $7287 $7317 forward $6830 $-1 #
+edge $-1 -1 -1 $-1 $6831 -2.0943951023931948 $8289 -1.5707963267948966 $6828 $8765 forward @7 unknown T 4.9999999999999991 -25 32.5 7.5000000000000027 -24.330127018922195 35 #
+point $-1 -1 -1 $-1 7.5000000000000027 -24.330127018922195 32.500000000000007 #
+face $-1 -1 -1 $-1 $8766 $8767 $11 $-1 $3328 reversed single T -50 -25 -30.000000000000004 -40 -14.999999999999996 -20.000000000000004 F #
+face $-1 -1 -1 $-1 $7213 $8768 $11 $-1 $4210 reversed single T -50 -25 -45 -40 -14.999999999999996 -35 F #
+loop $-1 -1 -1 $-1 $-1 $8769 $6841 T -25 -15.669872981077811 -42.500000000000007 -20 -15 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $8770 $8771 $8772 $8773 forward $6842 $-1 #
+coedge $-1 -1 -1 $-1 $7785 $7785 $7640 $8656 reversed $6843 $-1 #
+coedge $-1 -1 -1 $-1 $8288 $6850 $6852 $7789 forward $7787 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8288 $7846 T 20 -15.669872981077811 -42.500000000000007 25 -15 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6853 -2.0943951023931957 $8547 -1.5707963267948966 $7786 $8774 forward @7 unknown T 20 -15.669872981077809 -40 22.500000000000004 -15 -37.5 #
+point $-1 -1 -1 $-1 22.500000000000004 -15.669872981077805 -37.5 #
+coedge $-1 -1 -1 $-1 $8542 $6859 $7533 $8550 reversed $7315 $-1 #
+vertex $-1 -1 -1 $-1 $6860 $8775 #
+straight-curve $-1 -1 -1 $-1 22.5 -24.330127018922195 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $8776 $6861 T -7.5000000000000044 -20 -10 0 -15 5 unknown #
+loop $-1 -1 -1 $-1 $-1 $8777 $5953 T -50 -25 -15.000000000000004 -50 -15 -5.0000000000000036 unknown #
+coedge $-1 -1 -1 $-1 $8778 $8778 $8779 $8780 forward $6862 $-1 #
+coedge $-1 -1 -1 $-1 $8781 $6863 $8782 $8783 reversed $5954 $-1 #
+coedge $-1 -1 -1 $-1 $6863 $8781 $8784 $8785 forward $5954 $-1 #
+coedge $-1 -1 -1 $-1 $8786 $8787 $6863 $7800 reversed $8788 $-1 #
+edge $-1 -1 -1 $-1 $8789 1.5707963267948966 $8790 2.0943951023931953 $6863 $8791 forward @7 unknown T -10.000000000000002 -25 -10 -7.5000000000000027 -24.330127018922191 -7.5 #
+coedge $-1 -1 -1 $-1 $7735 $7696 $6865 $7802 reversed $6742 $-1 #
+edge $-1 -1 -1 $-1 $7738 -2.0943951023931957 $7805 -1.5707963267948966 $6865 $8792 forward @7 unknown T 4.9999999999999991 -15.669872981077809 -10 7.5000000000000009 -15 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $8793 $6866 $8794 $8795 reversed $7695 $-1 #
+coedge $-1 -1 -1 $-1 $6866 $8796 $7716 $8709 reversed $7695 $-1 #
+vertex $-1 -1 -1 $-1 $8795 $8797 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8798 $8799 $11 $-1 $3659 reversed single T 29.999999999999996 -10.000000000000004 -9.9999999999999982 37.500000000000007 -4.9999999999999991 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $8800 $6871 T 29.999999999999996 -10.000000000000002 -24.999999999999996 37.500000000000007 -4.9999999999999991 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $8801 $8802 $8803 $8804 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $8805 $6873 $8806 $8807 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $6873 $8808 $8809 $8810 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $8811 $8812 $6873 $7813 forward $8813 $-1 #
+edge $-1 -1 -1 $-1 $8814 -1.5707963267948966 $8815 -4.7167471186270725e-16 $7812 $8816 forward @7 unknown T 29.999999999999996 -4.9999999999999991 -9.9999999999999982 35 -1.7763568394002505e-15 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $8817 $6874 $8818 $8819 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $8820 $8821 $6874 $7816 forward $8822 $-1 #
+edge $-1 -1 -1 $-1 $8823 -2.0943951023931966 $7823 -1.5707963267948966 $7815 $8824 forward @7 unknown T 35 -0.66987298107781257 5.0000000000000018 37.500000000000007 -1.7763568394002505e-15 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $6875 $8817 $6883 $7836 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $8825 $8826 $8827 $7819 forward $8495 $-1 #
+edge $-1 -1 -1 $-1 $7824 10.000000000000002 $8828 15 $7818 $8829 forward @7 unknown T 29.999999999999996 -5.0000000000000009 10.000000000000002 30 -4.9999999999999991 15 #
+coedge $-1 -1 -1 $-1 $8830 $6876 $8826 $8831 reversed $7822 $-1 #
+coedge $-1 -1 -1 $-1 $6876 $8830 $8808 $8832 forward $7822 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6876 $8833 T 25 -5 1.7763568394002505e-15 35 0 10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $8832 $8834 #
+vertex $-1 -1 -1 $-1 $8835 $8836 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $8837 $6878 $8817 $8838 forward $7828 $-1 #
+coedge $-1 -1 -1 $-1 $6878 $8837 $8175 $8839 reversed $7828 $-1 #
+loop $-1 -1 -1 $-1 $-1 $6878 $8840 T 35 -0.66987298107781124 17.500000000000004 40.000000000000007 0 22.500000000000011 unknown #
+vertex $-1 -1 -1 $-1 $8839 $8841 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6880 $8234 $6882 $7835 forward $6313 $-1 #
+coedge $-1 -1 -1 $-1 $8842 $7268 $8171 $6881 reversed $7276 $-1 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $6883 $6882 $8825 $8843 reversed $6884 $-1 #
+edge $-1 -1 -1 $-1 $8844 1.5707963267948966 $6886 3.1415926535897931 $7831 $8845 forward @7 unknown T 25 -4.9999999999999991 20 29.999999999999996 0 25 #
+edge $-1 -1 -1 $-1 $8828 2.9403902792268214e-16 $6885 1.5707963267948966 $6883 $8846 forward @7 unknown T 29.999999999999996 -5 15 35 -1.7763568394002505e-15 20.000000000000004 #
+face $-1 -1 -1 $-1 $8847 $6884 $11 $-1 $8848 reversed single T 25 -5 15 35 0 25.000000000000007 F #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 20.000000000000004 #
+edge $-1 -1 -1 $-1 $6886 3.1415926535897931 $8849 4.7123889803846897 $8842 $8845 forward @7 unknown T 25 -10 20 29.999999999999996 -4.9999999999999991 25 #
+point $-1 -1 -1 $-1 29.999999999999996 -4.9999999999999991 25 #
+face $-1 -1 -1 $-1 $5952 $8850 $11 $-1 $3822 reversed single T -7.5000000000000036 -20 5 0 -15 20 F #
+loop $-1 -1 -1 $-1 $8851 $8852 $6888 T -45 -24.999999999999996 -3.5527136788005009e-15 -40 -14.999999999999996 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $8853 $8854 $8855 $8856 forward $6889 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 40 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7538 $7787 $11 $-1 $4210 reversed single T 20 -15.669872981077811 -42.500000000000007 25 -15 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $7528 $6895 T 10 -20 -45 20 -15 -35 unknown #
+vertex $-1 -1 -1 $-1 $6901 $8857 #
+face $-1 -1 -1 $-1 $6938 $6910 $11 $-1 $162 reversed single T -35 -40 14.999999999999996 -25.000000000000004 -35 25 F #
+coedge $-1 -1 -1 $-1 $6918 $6903 $6905 $7853 reversed $6920 $-1 #
+coedge $-1 -1 -1 $-1 $6903 $6917 $6925 $7865 reversed $6920 $-1 #
+edge $-1 -1 -1 $-1 $8678 1.5707963267948966 $6907 2.0943951023931966 $6905 $8858 forward @7 unknown T -25.000000000000004 -40 4.9999999999999982 -22.5 -39.330127018922184 7.5000000000000027 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922184 7.5000000000000018 #
+edge $-1 -1 -1 $-1 $7875 -1.5707963267948966 $6911 -6.1232339957367648e-17 $6909 $8859 forward @7 unknown T -30.000000000000007 -40 14.999999999999996 -25.000000000000004 -35 20 #
+point $-1 -1 -1 $-1 -30.000000000000007 -35 14.999999999999996 #
+edge $-1 -1 -1 $-1 $6915 6.1232339957367673e-17 $8678 1.5707963267948966 $6913 $8860 forward @7 unknown T -30.000000000000004 -40 4.9999999999999982 -25.000000000000004 -35 9.9999999999999982 #
+point $-1 -1 -1 $-1 -30 -35 9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $7879 $6919 $6922 $7863 reversed $7861 $-1 #
+coedge $-1 -1 -1 $-1 $6919 $7878 $6923 $7864 reversed $7861 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7859 $8861 T -30.000000000000007 -35 4.9999999999999982 -22.5 -30 20 unknown #
+face $-1 -1 -1 $-1 $7874 $6920 $11 $-1 $3872 reversed single T -30.000000000000007 -40 4.9999999999999982 -22.5 -35 20 F #
+edge $-1 -1 -1 $-1 $8675 -1.5707963267948966 $6915 6.1232339957367673e-17 $6922 $8862 forward @7 unknown T -30.000000000000004 -35 4.9999999999999982 -25.000000000000004 -30 9.9999999999999982 #
+edge $-1 -1 -1 $-1 $6911 -6.1232339957367648e-17 $8863 1.5707963267948966 $6923 $8864 forward @7 unknown T -30.000000000000007 -35 14.999999999999996 -25.000000000000004 -30 20 #
+edge $-1 -1 -1 $-1 $6034 -2.0943951023931948 $7875 -1.5707963267948966 $6925 $8865 forward @7 unknown T -25.000000000000004 -40 17.499999999999996 -22.500000000000004 -39.330127018922198 20 #
+coedge $-1 -1 -1 $-1 $7886 $6926 $6928 $7870 reversed $7868 $-1 #
+coedge $-1 -1 -1 $-1 $6926 $7885 $6929 $7871 reversed $7868 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7885 $8866 T -30.000000000000004 -35 20 -22.5 -30 35 unknown #
+edge $-1 -1 -1 $-1 $7889 1.5707963267948966 $6063 2.0943951023931953 $6928 $8867 forward @7 unknown T -25.000000000000004 -30.669872981077809 32.5 -22.500000000000004 -30 35 #
+edge $-1 -1 -1 $-1 $6931 -2.0943951023931957 $8863 -1.5707963267948966 $6929 $8868 forward @7 unknown T -25.000000000000004 -30.669872981077809 20 -22.500000000000004 -30 22.500000000000004 #
+face $-1 -1 -1 $-1 $5148 $6930 $11 $-1 $162 reversed single T -25.000000000000004 -30.669872981077809 17.499999999999996 -20 -30 22.500000000000004 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 22.500000000000004 #
+face $-1 -1 -1 $-1 $5452 $6935 $11 $-1 $3872 reversed single T -30.000000000000004 -40 20 -22.5 -35 35 F #
+vertex $-1 -1 -1 $-1 $7855 $8869 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7860 $6943 $6944 $7880 reversed $7861 $-1 #
+coedge $-1 -1 -1 $-1 $6943 $7859 $7678 $8674 reversed $7861 $-1 #
+edge $-1 -1 -1 $-1 $8863 1.5707963267948966 $6036 2.0943951023931957 $6944 $8870 forward @7 unknown T -25.000000000000004 -30.669872981077809 17.499999999999996 -22.500000000000004 -30 20 #
+ellipse-curve $-1 -1 -1 $-1 -35 -35 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -30 -35 30 #
+edge $-1 -1 -1 $-1 $6954 6.1232339957367623e-17 $7875 1.5707963267948966 $6953 $8871 forward @7 unknown T -30.000000000000004 -40 20 -25.000000000000004 -35 25 #
+point $-1 -1 -1 $-1 -29.999999999999993 -35 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $7867 $6958 $6960 $7887 reversed $7868 $-1 #
+coedge $-1 -1 -1 $-1 $6958 $7866 $6961 $7888 reversed $7868 $-1 #
+edge $-1 -1 -1 $-1 $8863 -1.5707963267948966 $6954 6.1232339957367623e-17 $6960 $8872 forward @7 unknown T -30.000000000000004 -35 20 -25.000000000000004 -30 25 #
+edge $-1 -1 -1 $-1 $6951 -6.1232339957367648e-17 $7889 1.5707963267948966 $6961 $8873 forward @7 unknown T -30.000000000000004 -35 30 -25.000000000000004 -30 35 #
+vertex $-1 -1 -1 $-1 $7888 $8874 #
+point $-1 -1 -1 $-1 -30 -35 40 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $6972 $6971 $7324 $8292 reversed $6973 $-1 #
+vertex $-1 -1 -1 $-1 $7326 $8875 #
+straight-curve $-1 -1 -1 $-1 -50 50 0 0 0 -1 I I #
+vertex $-1 -1 -1 $-1 $8292 $8876 #
+straight-curve $-1 -1 -1 $-1 -50 -50 0 0 0 -1 I I #
+plane-surface $-1 -1 -1 $-1 0 -50 0 0 1 -0 -0 0 1 forward_v I I I I #
+point $-1 -1 -1 $-1 50 -50 -50 #
+point $-1 -1 -1 $-1 50 50 -50 #
+coedge $-1 -1 -1 $-1 $8877 $6985 $8878 $8879 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $7933 $8880 $6985 $7014 reversed $7954 $-1 #
+coedge $-1 -1 -1 $-1 $8881 $6986 $6988 $7037 reversed $7905 $-1 #
+coedge $-1 -1 -1 $-1 $6986 $8882 $6101 $7011 forward $7905 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7904 $8883 T 15 35 35 22.500000000000007 40 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $6988 $7022 $8884 $8885 forward $6989 $-1 #
+coedge $-1 -1 -1 $-1 $6996 $8886 $6990 $7909 forward $7918 $-1 #
+edge $-1 -1 -1 $-1 $8887 1.5707963267948966 $6998 2.0943951023931957 $7908 $8888 forward @7 unknown T 35 35 35 37.500000000000007 35.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $8889 $7952 $6991 $7911 forward $8890 $-1 #
+edge $-1 -1 -1 $-1 $6114 6.1232339957367648e-17 $8887 1.5707963267948966 $7910 $8891 forward @7 unknown T 30 35 35 35 40 40 #
+coedge $-1 -1 -1 $-1 $8892 $8892 $6993 $7913 reversed $8893 $-1 #
+edge $-1 -1 -1 $-1 $7915 1.5707963267948966 $7919 4.7123889803846897 $6993 $8894 forward @7 unknown T 40 35 35 45 45 40 #
+coedge $-1 -1 -1 $-1 $6994 $7031 $8895 $8896 reversed $7032 $-1 #
+vertex $-1 -1 -1 $-1 $8896 $8897 #
+ellipse-curve $-1 -1 -1 $-1 40 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8886 $6996 $8898 $8899 reversed $7918 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7908 $8900 T 35 35 32.5 40 35.669872981077816 37.5 unknown #
+vertex $-1 -1 -1 $-1 $8899 $8901 #
+point $-1 -1 -1 $-1 37.500000000000007 35.669872981077809 37.5 #
+face $-1 -1 -1 $-1 $7958 $8902 $11 $-1 $7001 reversed single T 37.5 35 20.000000000000004 45 45 35 F #
+coedge $-1 -1 -1 $-1 $7002 $8903 $8904 $8905 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $8906 $8907 $7002 $7924 reversed $8908 $-1 #
+edge $-1 -1 -1 $-1 $8909 -2.0943951023931957 $7928 0 $7002 $8910 forward @7 unknown T -7.5000000000000009 40 50 1.7763568394002505e-15 45 50 #
+coedge $-1 -1 -1 $-1 $8911 $7003 $8907 $8912 reversed $7927 $-1 #
+coedge $-1 -1 -1 $-1 $7003 $8913 $7005 $7931 reversed $7927 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7926 $8914 T 0 40 35 7.5000000000000027 45 50 unknown #
+vertex $-1 -1 -1 $-1 $8915 $8916 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7932 $7005 $8917 $8918 forward $7007 $-1 #
+edge $-1 -1 -1 $-1 $7008 -50 $8919 -37.500000000000007 $7005 $8920 forward @7 unknown T 7.5000000000000018 44.330127018922191 37.500000000000007 7.5000000000000027 44.330127018922205 50 #
+coedge $-1 -1 -1 $-1 $7006 $7930 $8921 $8922 forward $7007 $-1 #
+coedge $-1 -1 -1 $-1 $8923 $7902 $7904 $7011 reversed $7954 $-1 #
+face $-1 -1 -1 $-1 $8924 $7007 $11 $-1 $7955 reversed single T 7.4999999999999991 40 35 15.000000000000002 45 50 F #
+point $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $8921 $8925 $7010 $7937 forward $8926 $-1 #
+edge $-1 -1 -1 $-1 $8927 -1.5707963267948966 $7938 6.1232339957367648e-17 $7936 $8928 forward @7 unknown T 15 40 35 20.000000000000004 45 40 #
+vertex $-1 -1 -1 $-1 $8929 $8930 #
+straight-curve $-1 -1 -1 $-1 15.000000000000002 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8931 $7016 $7012 $7941 forward $7946 $-1 #
+edge $-1 -1 -1 $-1 $7018 -2.0943951023931939 $8927 -1.5707963267948966 $7940 $8932 forward @7 unknown T 20.000000000000004 44.330127018922198 35 22.500000000000007 45 37.5 #
+face $-1 -1 -1 $-1 $8933 $8934 $11 $-1 $7943 reversed single T 15 40 -50 22.500000000000004 45 -40 F #
+cone-surface $-1 -1 -1 $-1 20.000000000000004 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $8935 $8936 #
+coedge $-1 -1 -1 $-1 $7016 $8931 $8937 $8938 reversed $7946 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7940 $8939 T 20.000000000000004 44.330127018922184 32.499999999999993 25 45 37.5 unknown #
+vertex $-1 -1 -1 $-1 $8938 $8940 #
+ellipse-curve $-1 -1 -1 $-1 25 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000007 44.330127018922205 37.5 #
+coedge $-1 -1 -1 $-1 $7025 $7020 $8941 $8942 reversed $7026 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7910 $8943 $7022 $7029 reversed $8890 $-1 #
+face $-1 -1 -1 $-1 $8944 $8945 $11 $-1 $7024 reversed single T 22.499999999999993 40 20 30 45 35 F #
+loop $-1 -1 -1 $-1 $-1 $7933 $7023 T 7.4999999999999991 35 35 15.000000000000002 40 50 unknown #
+cone-surface $-1 -1 -1 $-1 10 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8946 $7961 $7025 $7957 reversed $8947 $-1 #
+edge $-1 -1 -1 $-1 $8948 -6.1232339957367648e-17 $7027 1.5707963267948966 $7025 $8949 forward @7 unknown T 30 40 30 35 45 35 #
+face $-1 -1 -1 $-1 $8950 $7026 $11 $-1 $8951 reversed single T 25 40 30 35 45 40 F #
+point $-1 -1 -1 $-1 35 45 35 #
+vertex $-1 -1 -1 $-1 $8952 $8953 #
+coedge $-1 -1 -1 $-1 $7956 $8954 $7031 $7962 reversed $8947 $-1 #
+edge $-1 -1 -1 $-1 $7027 1.5707963267948966 $8955 2.0943951023931966 $7031 $8956 forward @7 unknown T 35 44.330127018922191 32.5 37.500000000000007 45 35 #
+face $-1 -1 -1 $-1 $8957 $7032 $11 $-1 $8951 reversed single T 35 44.330127018922191 32.5 40 45 37.500000000000007 F #
+face $-1 -1 -1 $-1 $7349 $8958 $11 $-1 $6121 reversed single T 29.999999999999996 35 -40 37.500000000000007 40 -24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $8959 $7035 T 29.999999999999996 40 -40 37.5 45 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $8960 $7329 $7332 $8300 reversed $7036 $-1 #
+vertex $-1 -1 -1 $-1 $8961 $8962 #
+straight-curve $-1 -1 -1 $-1 22.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8963 $7039 $8964 $8007 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $8965 $8966 $7039 $7971 reversed $8967 $-1 #
+edge $-1 -1 -1 $-1 $7082 2.6179938779914949 $7066 4.7123889803846897 $7039 $8968 forward @7 unknown T 8.8817841970012523e-16 20 50 7.5000000000000009 25 50 #
+coedge $-1 -1 -1 $-1 $7040 $8969 $8965 $8027 forward $7092 $-1 #
+coedge $-1 -1 -1 $-1 $7974 $7041 $8970 $8053 reversed $7043 $-1 #
+coedge $-1 -1 -1 $-1 $7042 $7973 $8971 $8972 reversed $7043 $-1 #
+face $-1 -1 -1 $-1 $6151 $7043 $11 $-1 $7081 reversed single T 15 20 35 22.5 25 50 F #
+coedge $-1 -1 -1 $-1 $8973 $8970 $7045 $7977 reversed $8974 $-1 #
+edge $-1 -1 -1 $-1 $7098 1.5707963267948966 $7105 2.0943951023931948 $7045 $7086 forward @7 unknown T 22.5 20 35 25 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $7046 $7055 $8975 $8976 forward $7056 $-1 #
+vertex $-1 -1 -1 $-1 $8977 $8978 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8035 $7048 $8979 $8977 forward $7982 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7048 $8042 T 25 19.999999999999996 30 35 25 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $7050 $7050 $8980 $8981 reversed $7985 $-1 #
+loop $-1 -1 -1 $-1 $8982 $7984 $8983 T 40 20 30 45 30 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8984 $8980 $7052 $7988 forward $7994 $-1 #
+edge $-1 -1 -1 $-1 $7053 -1.5707963267948966 $8047 -1.0471975511965952 $7987 $8985 forward @7 unknown T 37.499999999999986 29.330127018922184 32.499999999999986 40 30 35 #
+point $-1 -1 -1 $-1 40 30 35 #
+coedge $-1 -1 -1 $-1 $8980 $8986 $7055 $7991 forward $7994 $-1 #
+edge $-1 -1 -1 $-1 $8987 1.0471975511965992 $7057 1.5707963267948966 $7990 $8985 forward @7 unknown T 37.500000000000007 20 32.500000000000007 40 20.669872981077805 35 #
+face $-1 -1 -1 $-1 $7101 $7056 $11 $-1 $8043 reversed single T 35 19.999999999999996 32.5 40 20.669872981077805 37.5 F #
+point $-1 -1 -1 $-1 40 20 35 #
+loop $-1 -1 -1 $-1 $-1 $8984 $7059 T 37.499999999999986 20 20.000000000000004 45 30 35 unknown #
+coedge $-1 -1 -1 $-1 $7060 $8988 $8989 $8990 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $8991 $8992 $7060 $7997 reversed $8993 $-1 #
+edge $-1 -1 -1 $-1 $8994 -1.5707963267948966 $8001 0.52359877559829826 $7060 $8995 forward @7 unknown T -15 25 50 -7.4999999999999991 30 50 #
+coedge $-1 -1 -1 $-1 $8996 $7061 $8992 $8997 forward $8000 $-1 #
+coedge $-1 -1 -1 $-1 $7061 $8998 $8999 $8004 forward $8000 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7999 $9000 T -7.4999999999999991 25 35 8.8817841970012523e-16 30 50 unknown #
+vertex $-1 -1 -1 $-1 $7062 $9001 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8005 $7063 $9002 $9003 reversed $7065 $-1 #
+edge $-1 -1 -1 $-1 $9004 40 $7066 50 $7999 $9005 forward @7 unknown T 0 25 40 8.8817841970012523e-16 25 50 #
+coedge $-1 -1 -1 $-1 $7064 $8003 $9006 $9007 reversed $7065 $-1 #
+face $-1 -1 -1 $-1 $9008 $7065 $11 $-1 $9009 reversed single T 0 25 35 7.5000000000000027 30 50 F #
+edge $-1 -1 -1 $-1 $7066 0 $9010 2.0943951023931948 $7969 $8002 forward @7 unknown T -7.4999999999999991 20 50 8.8817841970012523e-16 25 50 #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 25 50 #
+coedge $-1 -1 -1 $-1 $9006 $9011 $7068 $8010 reversed $9012 $-1 #
+edge $-1 -1 -1 $-1 $8011 4.1887902047863914 $9013 4.7123889803846897 $7068 $9014 forward @7 unknown T 7.5000000000000018 29.330127018922195 35 10 30 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $8010 $9015 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9016 $7074 $7070 $8014 reversed $8018 $-1 #
+edge $-1 -1 -1 $-1 $9013 1.5707963267948966 $7076 3.1415926535897931 $7070 $9017 forward @7 unknown T 10 25 35 15 30 40 #
+coedge $-1 -1 -1 $-1 $8969 $7071 $9018 $8021 forward $7092 $-1 #
+face $-1 -1 -1 $-1 $9019 $9020 $11 $-1 $9021 reversed single T -7.5 20 35 8.8817841970012523e-16 25 50 F #
+coedge $-1 -1 -1 $-1 $7074 $9016 $9022 $9023 forward $8018 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7074 $8036 T 10 25 30 20 30 40 unknown #
+vertex $-1 -1 -1 $-1 $9023 $9024 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7076 3.1415926535897931 $9025 4.7123889803846897 $8015 $9017 forward @7 unknown T 10 20 35 15 25 40 #
+point $-1 -1 -1 $-1 15 25 40 #
+coedge $-1 -1 -1 $-1 $7083 $7078 $9026 $9027 forward $7084 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9028 $9029 $11 $-1 $7081 reversed single T 15 25 -40 22.500000000000004 30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9030 $7080 T 15 25 -50 22.5 30 -40 unknown #
+edge $-1 -1 -1 $-1 $9031 37.500000000000007 $7082 50 $7972 $9032 forward @7 unknown T 7.5 20.669872981077805 37.500000000000007 7.5000000000000009 20.669872981077813 50 #
+point $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $9033 $8033 $7083 $8030 forward $8037 $-1 #
+edge $-1 -1 -1 $-1 $7085 -1.5707963267948966 $9034 -1.0471975511965974 $8029 $9035 forward @7 unknown T 22.5 29.330127018922191 32.5 25 30 35 #
+face $-1 -1 -1 $-1 $9036 $7084 $11 $-1 $8043 reversed single T 20 29.330127018922191 32.5 25 30 37.500000000000007 F #
+point $-1 -1 -1 $-1 25 30 35 #
+coedge $-1 -1 -1 $-1 $8029 $9037 $7088 $8034 forward $8037 $-1 #
+edge $-1 -1 -1 $-1 $8040 0 $7085 1.5707963267948966 $8033 $9038 forward @7 unknown T 25 25 30 30 30 35 #
+coedge $-1 -1 -1 $-1 $7090 $7981 $9039 $9040 reversed $7982 $-1 #
+face $-1 -1 -1 $-1 $9041 $8018 $11 $-1 $8043 reversed single T 10 25 30 20 30 40 F #
+loop $-1 -1 -1 $-1 $-1 $9037 $7091 T 22.5 25 20 30 30 35 unknown #
+coedge $-1 -1 -1 $-1 $9042 $7094 $9037 $9043 reversed $8039 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9042 $9044 T 29.999999999999996 25 20.000000000000004 37.500000000000007 29.999999999999996 35 unknown #
+vertex $-1 -1 -1 $-1 $8034 $9045 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7992 $7982 $11 $-1 $8043 reversed single T 25 19.999999999999996 30 35 25 40 F #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 25 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $9046 1.0471975511965979 $7098 1.5707963267948966 $9047 $9035 forward @7 unknown T 22.5 20 32.5 25 20.669872981077813 35 #
+point $-1 -1 -1 $-1 25 20 35 #
+coedge $-1 -1 -1 $-1 $7099 $9048 $8984 $9049 reversed $8039 $-1 #
+vertex $-1 -1 -1 $-1 $9049 $9050 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $7359 $9051 $11 $-1 $6162 reversed single T 22.499999999999993 20 19.999999999999996 30 25 35 F #
+loop $-1 -1 -1 $-1 $-1 $9052 $7102 T 29.999999999999996 19.999999999999996 -40 37.5 25 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $9053 $9054 $9055 $9056 reversed $7103 $-1 #
+coedge $-1 -1 -1 $-1 $7376 $7104 $9057 $9058 reversed $6174 $-1 #
+edge $-1 -1 -1 $-1 $9059 1.5707963267948966 $7105 2.0943951023931953 $8970 $9060 forward @7 unknown T 20 20 35 22.5 20.669872981077809 37.5 #
+point $-1 -1 -1 $-1 22.5 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $9061 $7107 $9062 $9063 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $8091 $9064 $7107 $7145 reversed $8112 $-1 #
+coedge $-1 -1 -1 $-1 $9065 $7108 $7110 $7165 reversed $8059 $-1 #
+coedge $-1 -1 -1 $-1 $7108 $9066 $6201 $7142 forward $8059 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8058 $9067 T 0 4.9999999999999991 35 7.5000000000000018 10 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7110 $7153 $9068 $9069 forward $6230 $-1 #
+coedge $-1 -1 -1 $-1 $7114 $9070 $7111 $7191 forward $8066 $-1 #
+coedge $-1 -1 -1 $-1 $9071 $8110 $7112 $8064 forward $9072 $-1 #
+edge $-1 -1 -1 $-1 $6214 -2.9403902792268234e-16 $8151 1.5707963267948966 $8063 $9073 forward @7 unknown T 15 4.9999999999999982 35 20 10 40 #
+coedge $-1 -1 -1 $-1 $9070 $7114 $8139 $7182 reversed $8066 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8062 $9074 T 20 4.9999999999999982 32.5 25 5.6698729810778081 37.5 unknown #
+coedge $-1 -1 -1 $-1 $9075 $8071 $7116 $8068 reversed $9076 $-1 #
+edge $-1 -1 -1 $-1 $8079 -2.0943951023931966 $7117 -1.5707963267948966 $7116 $9077 forward @7 unknown T 35 4.9999999999999982 32.5 37.500000000000007 5.669872981077809 35 #
+edge $-1 -1 -1 $-1 $7117 -1.5707963267948966 $7178 2.9403902792268234e-16 $7119 $9078 forward @7 unknown T 30 4.9999999999999982 30 35 10 35 #
+point $-1 -1 -1 $-1 35 4.9999999999999982 35 #
+coedge $-1 -1 -1 $-1 $8067 $9079 $7119 $8069 reversed $9076 $-1 #
+coedge $-1 -1 -1 $-1 $7125 $7128 $7122 $8073 forward $7132 $-1 #
+edge $-1 -1 -1 $-1 $6195 -1.5707963267948966 $6191 1.5707963267948966 $8072 $9080 forward @7 unknown T 40 5 30 45 15 35 #
+loop $-1 -1 -1 $-1 $-1 $9081 $8075 T 50 5 30 50 15 40 unknown #
+face $-1 -1 -1 $-1 $9082 $7123 $11 $-1 $7181 reversed single T 40 5 30 50 15 40 F #
+coedge $-1 -1 -1 $-1 $9083 $7125 $7184 $8141 forward $7132 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7128 $9084 $9075 $9085 forward $7132 $-1 #
+vertex $-1 -1 -1 $-1 $7129 $9086 #
+coedge $-1 -1 -1 $-1 $7133 $9087 $9088 $9089 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $9090 $9091 $7133 $8082 reversed $9092 $-1 #
+edge $-1 -1 -1 $-1 $9093 -2.0943951023931948 $8086 0 $7133 $9094 forward @7 unknown T -22.5 10 50 -15 15 50 #
+coedge $-1 -1 -1 $-1 $9095 $7134 $9091 $9096 reversed $8085 $-1 #
+coedge $-1 -1 -1 $-1 $7134 $9097 $7136 $8089 reversed $8085 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8084 $9098 T -15 10 35 -7.4999999999999982 15 50 unknown #
+vertex $-1 -1 -1 $-1 $9099 $9100 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8090 $7136 $9101 $9102 forward $7138 $-1 #
+edge $-1 -1 -1 $-1 $7139 -50 $9103 -37.499999999999993 $7136 $9104 forward @7 unknown T -7.5 14.330127018922193 37.499999999999993 -7.4999999999999982 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $7137 $8088 $9105 $9106 forward $7138 $-1 #
+coedge $-1 -1 -1 $-1 $9107 $8056 $8058 $7142 reversed $8112 $-1 #
+face $-1 -1 -1 $-1 $9108 $7138 $11 $-1 $8113 reversed single T -7.5 10 35 8.8817841970012523e-16 15 50 F #
+point $-1 -1 -1 $-1 -7.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $9105 $9109 $7141 $8095 forward $9110 $-1 #
+edge $-1 -1 -1 $-1 $9111 -1.5707963267948966 $8096 6.1232339957367648e-17 $8094 $9112 forward @7 unknown T 0 10 35 5.0000000000000009 15 40 #
+vertex $-1 -1 -1 $-1 $9113 $9114 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9115 $7147 $7143 $8099 forward $8104 $-1 #
+edge $-1 -1 -1 $-1 $7149 -2.0943951023931944 $9111 -1.5707963267948966 $8098 $9116 forward @7 unknown T 5.0000000000000009 14.330127018922195 35 7.5000000000000009 15 37.499999999999993 #
+face $-1 -1 -1 $-1 $9117 $9118 $11 $-1 $8101 reversed single T 0 10 -50 7.5000000000000053 15 -40 F #
+cone-surface $-1 -1 -1 $-1 5.0000000000000009 10 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $9119 $9120 #
+coedge $-1 -1 -1 $-1 $7147 $9115 $9121 $9122 reversed $8104 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8098 $9123 T 5.0000000000000009 14.330127018922195 32.5 10 15 37.5 unknown #
+vertex $-1 -1 -1 $-1 $9122 $9124 #
+ellipse-curve $-1 -1 -1 $-1 10 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000009 14.330127018922195 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $7155 $7151 $9125 $9126 reversed $7156 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8063 $9127 $7153 $7159 reversed $9072 $-1 #
+face $-1 -1 -1 $-1 $9128 $9129 $11 $-1 $6231 reversed single T 7.5 10 20 15 15 35 F #
+loop $-1 -1 -1 $-1 $-1 $8091 $7154 T -7.5000000000000009 5 35 8.8817841970012523e-16 10 50 unknown #
+cone-surface $-1 -1 -1 $-1 -5 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $9130 $8118 $7155 $8115 reversed $9131 $-1 #
+edge $-1 -1 -1 $-1 $9132 2.9403902792268234e-16 $7157 1.5707963267948966 $7155 $9133 forward @7 unknown T 15 10 30 20 14.999999999999998 35 #
+point $-1 -1 -1 $-1 20 14.999999999999998 35 #
+vertex $-1 -1 -1 $-1 $9134 $9135 #
+coedge $-1 -1 -1 $-1 $8114 $9136 $7161 $8119 reversed $9131 $-1 #
+edge $-1 -1 -1 $-1 $7157 1.5707963267948966 $8126 2.0943951023931957 $7161 $9137 forward @7 unknown T 20 14.330127018922189 32.5 22.500000000000004 14.999999999999998 35 #
+face $-1 -1 -1 $-1 $7410 $9138 $11 $-1 $6219 reversed single T 15 4.9999999999999982 -40 22.500000000000007 10 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9139 $7163 T 15 10 -40 22.500000000000004 14.999999999999998 -25 unknown #
+coedge $-1 -1 -1 $-1 $9140 $7386 $7388 $7433 reversed $7164 $-1 #
+vertex $-1 -1 -1 $-1 $9141 $9142 #
+straight-curve $-1 -1 -1 $-1 7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9143 $7167 $9136 $9144 forward $7175 $-1 #
+vertex $-1 -1 -1 $-1 $9144 $9145 #
+ellipse-curve $-1 -1 -1 $-1 25 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6439 $9146 $11 $-1 $6231 reversed single T 7.4999999999999991 5 20 15 10 35 F #
+coedge $-1 -1 -1 $-1 $7171 $9147 $9148 $8135 forward $7175 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9148 $8139 $7173 $8132 forward $8143 $-1 #
+edge $-1 -1 -1 $-1 $6236 -1.5707963267948966 $7178 0 $8131 $8130 forward @7 unknown T 25 5 30 30 10 35 #
+face $-1 -1 -1 $-1 $9074 $9072 $11 $-1 $7181 reversed single T 10 4.9999999999999982 30 20 10 40 F #
+coedge $-1 -1 -1 $-1 $8140 $7176 $9149 $9150 reversed $7177 $-1 #
+edge $-1 -1 -1 $-1 $9151 25 $7178 30 $8129 $9152 forward @7 unknown T 29.999999999999996 10 25 30 10 30 #
+face $-1 -1 -1 $-1 $9153 $7177 $11 $-1 $4445 reversed single T 29.999999999999996 10 20.000000000000004 37.5 14.999999999999998 35 F #
+point $-1 -1 -1 $-1 30 10 30 #
+vertex $-1 -1 -1 $-1 $7182 $9154 #
+coedge $-1 -1 -1 $-1 $8131 $9155 $8065 $7182 forward $8143 $-1 #
+coedge $-1 -1 -1 $-1 $7184 $8134 $9156 $9157 reversed $7177 $-1 #
+edge $-1 -1 -1 $-1 $7185 -32.5 $9158 -22.500000000000007 $8076 $9159 forward @7 unknown T 37.499999999999993 14.330127018922186 22.500000000000007 37.5 14.330127018922195 32.5 #
+point $-1 -1 -1 $-1 37.5 14.330127018922193 32.5 #
+loop $-1 -1 -1 $-1 $-1 $9148 $7187 T 22.5 5 19.999999999999996 30 10 35 unknown #
+coedge $-1 -1 -1 $-1 $8422 $9160 $7429 $8432 reversed $7188 $-1 #
+coedge $-1 -1 -1 $-1 $9161 $7189 $8426 $9162 reversed $6241 $-1 #
+coedge $-1 -1 -1 $-1 $7189 $9163 $9164 $9165 reversed $6241 $-1 #
+coedge $-1 -1 -1 $-1 $9166 $9167 $9168 $8148 forward $9169 $-1 #
+edge $-1 -1 -1 $-1 $9170 -35 $9171 -30 $8147 $9172 forward @7 unknown T 29.999999999999996 10 -35 30 10 -30 #
+coedge $-1 -1 -1 $-1 $7393 $9173 $7190 $8150 forward $8387 $-1 #
+edge $-1 -1 -1 $-1 $8429 1.5707963267948966 $7395 2.0943951023931957 $8149 $9174 forward @7 unknown T 35 14.330127018922189 -42.500000000000007 37.5 14.999999999999998 -40 #
+vertex $-1 -1 -1 $-1 $9175 $9176 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9177 $7193 $9178 $8191 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $9179 $9180 $7193 $8155 reversed $9181 $-1 #
+edge $-1 -1 -1 $-1 $7240 2.6179938779914949 $7224 4.7123889803846897 $7193 $9182 forward @7 unknown T -15 -10 50 -7.5000000000000009 -5 50 #
+coedge $-1 -1 -1 $-1 $7194 $9183 $9179 $8211 forward $7250 $-1 #
+coedge $-1 -1 -1 $-1 $8158 $7195 $9184 $8232 reversed $7197 $-1 #
+coedge $-1 -1 -1 $-1 $7196 $8157 $9185 $9186 reversed $7197 $-1 #
+face $-1 -1 -1 $-1 $6282 $7197 $11 $-1 $7239 reversed single T -4.686749320818303e-33 -10 35 7.5000000000000018 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $9187 $9184 $7199 $8161 reversed $9188 $-1 #
+edge $-1 -1 -1 $-1 $7255 1.5707963267948966 $7261 2.0943951023931957 $7199 $7244 forward @7 unknown T 7.4999999999999991 -10 35 10 -9.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $7200 $7203 $9189 $9190 forward $7204 $-1 #
+coedge $-1 -1 -1 $-1 $8219 $7201 $9191 $8256 forward $8164 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7201 $7270 T 10 -10 30 20 -4.9999999999999991 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $6307 $7204 $11 $-1 $6317 reversed single T 20 -10 32.5 25 -9.330127018922191 37.5 F #
+coedge $-1 -1 -1 $-1 $9192 $7205 $7216 $8177 reversed $8168 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9192 $9193 T 29.999999999999996 -10.000000000000002 20.000000000000004 37.500000000000007 -4.9999999999999991 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7209 $9194 $5967 $6881 forward $8168 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8173 $8173 $8655 $9195 reversed $7212 $-1 #
+face $-1 -1 -1 $-1 $9196 $9197 $11 $-1 $6317 reversed single T -10 -10 32.5 -5 -9.330127018922191 37.5 F #
+coedge $-1 -1 -1 $-1 $9198 $7214 $7827 $8839 forward $6270 $-1 #
+coedge $-1 -1 -1 $-1 $7216 $9198 $9199 $9200 forward $6270 $-1 #
+edge $-1 -1 -1 $-1 $9201 22.500000000000007 $7217 32.5 $7216 $9202 forward @7 unknown T 37.5 -9.3301270189221945 22.500000000000007 37.500000000000007 -9.3301270189221892 32.5 #
+point $-1 -1 -1 $-1 37.500000000000007 -9.3301270189221945 32.5 #
+coedge $-1 -1 -1 $-1 $7218 $9203 $9204 $9205 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $9206 $9207 $7218 $8181 reversed $9208 $-1 #
+edge $-1 -1 -1 $-1 $9209 -1.5707963267948966 $8185 0.52359877559829893 $7218 $9210 forward @7 unknown T -30 -4.9999999999999991 50 -22.5 1.7763568394002505e-15 50 #
+coedge $-1 -1 -1 $-1 $9211 $7219 $9207 $9212 forward $8184 $-1 #
+coedge $-1 -1 -1 $-1 $7219 $9213 $9214 $8188 forward $8184 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8183 $9215 T -22.500000000000004 -5 35 -15 0 50 unknown #
+vertex $-1 -1 -1 $-1 $7220 $9216 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8189 $7221 $9217 $9218 reversed $7223 $-1 #
+edge $-1 -1 -1 $-1 $9219 40 $7224 50 $8183 $9220 forward @7 unknown T -15 -5 40 -15 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $7222 $8187 $9221 $9222 reversed $7223 $-1 #
+face $-1 -1 -1 $-1 $9223 $7223 $11 $-1 $9224 reversed single T -15 -5 35 -7.4999999999999991 8.8817841970012523e-16 50 F #
+edge $-1 -1 -1 $-1 $7224 0 $9225 2.0943951023931957 $8153 $8186 forward @7 unknown T -22.5 -10 50 -15 -5 50 #
+point $-1 -1 -1 $-1 -15 -5 50 #
+coedge $-1 -1 -1 $-1 $9221 $9226 $7226 $8194 reversed $9227 $-1 #
+edge $-1 -1 -1 $-1 $8195 4.1887902047863905 $9228 4.7123889803846897 $7226 $9229 forward @7 unknown T -7.5000000000000018 -0.66987298107780902 35 -5 0 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $8194 $9230 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9231 $7232 $7228 $8198 reversed $8202 $-1 #
+edge $-1 -1 -1 $-1 $9228 1.5707963267948966 $7234 3.1415926535897931 $7228 $9232 forward @7 unknown T -5 -4.9999999999999991 35 0 0 40 #
+coedge $-1 -1 -1 $-1 $9183 $7229 $9233 $8205 forward $7250 $-1 #
+face $-1 -1 -1 $-1 $9234 $9235 $11 $-1 $8848 reversed single T 39.999999999999993 -10 15.000000000000004 50 0 25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $7232 $9231 $9236 $9237 forward $8202 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7232 $8220 T -5 -5 30 5 0 40 unknown #
+vertex $-1 -1 -1 $-1 $9237 $9238 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7234 3.1415926535897931 $9239 4.7123889803846897 $8199 $9232 forward @7 unknown T -5 -10 35 0 -4.9999999999999991 40 #
+point $-1 -1 -1 $-1 0 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $7241 $7236 $9240 $9241 forward $7242 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9242 $9243 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 -40 7.5000000000000018 0 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9244 $7238 T -9.3734986416366059e-33 -5 -50 7.5000000000000018 0 -40 unknown #
+edge $-1 -1 -1 $-1 $9245 37.5 $7240 50 $8156 $9246 forward @7 unknown T -7.5000000000000009 -9.3301270189221945 37.5 -7.5 -9.3301270189221928 50 #
+point $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 50 #
+coedge $-1 -1 -1 $-1 $9247 $8217 $7241 $8214 forward $8221 $-1 #
+edge $-1 -1 -1 $-1 $7243 -1.5707963267948966 $9248 -1.0471975511965979 $8213 $9249 forward @7 unknown T 7.5 -0.66987298107780813 32.5 10 0 35 #
+face $-1 -1 -1 $-1 $9250 $7242 $11 $-1 $6317 reversed single T 5 -0.66987298107780902 32.5 10 0 37.5 F #
+point $-1 -1 -1 $-1 10 0 35 #
+coedge $-1 -1 -1 $-1 $8213 $9251 $7246 $8218 forward $8221 $-1 #
+edge $-1 -1 -1 $-1 $8223 0 $7243 1.5707963267948966 $8217 $9252 forward @7 unknown T 10 -5 30 15 0 35 #
+coedge $-1 -1 -1 $-1 $7248 $8163 $9253 $9254 reversed $8164 $-1 #
+face $-1 -1 -1 $-1 $9255 $8202 $11 $-1 $6317 reversed single T -5 -5 30 5 0 40 F #
+loop $-1 -1 -1 $-1 $-1 $9251 $7249 T 7.5 -5 20 15 0 35 unknown #
+coedge $-1 -1 -1 $-1 $8744 $7252 $9251 $9256 reversed $7750 $-1 #
+vertex $-1 -1 -1 $-1 $8218 $9257 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9258 1.0471975511965983 $7255 1.5707963267948966 $9259 $9249 forward @7 unknown T 7.5 -10 32.5 10 -9.3301270189221945 35 #
+point $-1 -1 -1 $-1 10 -10 35 #
+coedge $-1 -1 -1 $-1 $7256 $9260 $7263 $8235 reversed $7750 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $9261 $7258 T 15 -10 -40 22.500000000000004 -4.9999999999999991 -25 unknown #
+coedge $-1 -1 -1 $-1 $9262 $9263 $9264 $9265 reversed $7259 $-1 #
+coedge $-1 -1 -1 $-1 $7464 $7260 $9266 $8506 reversed $6302 $-1 #
+edge $-1 -1 -1 $-1 $9267 1.5707963267948966 $7261 2.0943951023931957 $9184 $9268 forward @7 unknown T 5 -10 35 7.5000000000000018 -9.330127018922191 37.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000018 -9.3301270189221945 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $7831 $7263 $9269 $9270 forward $6313 $-1 #
+edge $-1 -1 -1 $-1 $7264 -32.5 $9271 -22.5 $7263 $9272 forward @7 unknown T 22.499999999999993 -0.66987298107780857 22.5 22.5 -0.66987298107780635 32.5 #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780857 32.5 #
+loop $-1 -1 -1 $-1 $-1 $9273 $7266 T 7.4999999999999991 -10 20 15 -4.9999999999999991 35 unknown #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221945 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $7273 $9274 $9275 $9276 forward $7276 $-1 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $7277 $9277 $9278 $9279 reversed $6324 $-1 #
+coedge $-1 -1 -1 $-1 $9280 $7278 $8254 $9281 reversed $5408 $-1 #
+edge $-1 -1 -1 $-1 $7487 -1.5707963267948966 $8251 -4.7167471186270745e-16 $7484 $9282 forward @7 unknown T 30 -4.9999999999999991 -40 35 -1.7763568394002505e-15 -35 #
+coedge $-1 -1 -1 $-1 $7279 $9280 $9283 $9284 reversed $5408 $-1 #
+coedge $-1 -1 -1 $-1 $8803 $9285 $7279 $8246 forward $9286 $-1 #
+edge $-1 -1 -1 $-1 $8252 2.9403902792268214e-16 $9287 1.5707963267948966 $8245 $9288 forward @7 unknown T 29.999999999999996 -5 -30 35 -1.7763568394002505e-15 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $9289 $7280 $9285 $9290 forward $8250 $-1 #
+coedge $-1 -1 -1 $-1 $7280 $9291 $8500 $9292 forward $8250 $-1 #
+coedge $-1 -1 -1 $-1 $8492 $9293 $8496 $7281 reversed $9294 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7280 $8505 T 22.5 -5.0000000000000009 -40 30 0 -25 unknown #
+vertex $-1 -1 -1 $-1 $8493 $9295 #
+vertex $-1 -1 -1 $-1 $9290 $9296 #
+coedge $-1 -1 -1 $-1 $7282 $7444 $8242 $9281 forward $7445 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7284 -1.5707963267948966 $8223 1.1640334398265738e-16 $8163 $9297 forward @7 unknown T 15 -10 30 20 -5 35 #
+point $-1 -1 -1 $-1 20 -10 35 #
+coedge $-1 -1 -1 $-1 $9298 $7286 $9299 $9300 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $8272 $9301 $7286 $7301 reversed $8624 $-1 #
+edge $-1 -1 -1 $-1 $6349 6.1232339957367648e-17 $8289 1.5707963267948966 $7597 $9302 forward @7 unknown T -8.8817841970012523e-16 -25 35 4.9999999999999991 -20 40 #
+coedge $-1 -1 -1 $-1 $7291 $9298 $8572 $9303 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $8573 $9304 $7291 $8263 reversed $9305 $-1 #
+edge $-1 -1 -1 $-1 $9306 -2.0943951023931948 $8267 0 $7291 $9307 forward @7 unknown T -37.5 -20 50 -30 -15 50 #
+coedge $-1 -1 -1 $-1 $9308 $7292 $9304 $9309 reversed $8266 $-1 #
+coedge $-1 -1 -1 $-1 $7292 $9310 $7294 $8270 reversed $8266 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8265 $9311 T -30 -20 35 -22.499999999999993 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $9312 $9313 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8271 $7294 $9314 $9315 forward $7296 $-1 #
+edge $-1 -1 -1 $-1 $7297 -50 $9316 -37.499999999999993 $7294 $9317 forward @7 unknown T -22.5 -15.669872981077805 37.499999999999993 -22.499999999999993 -15.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $7295 $8269 $9318 $9319 forward $7296 $-1 #
+coedge $-1 -1 -1 $-1 $7605 $8259 $5660 $6611 reversed $8624 $-1 #
+face $-1 -1 -1 $-1 $9320 $7296 $11 $-1 $9321 reversed single T -22.5 -20 35 -15 -15 50 F #
+point $-1 -1 -1 $-1 -22.5 -15.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $9318 $9322 $7299 $8276 forward $9323 $-1 #
+edge $-1 -1 -1 $-1 $9324 -1.5707963267948966 $6614 6.1232339957367648e-17 $8275 $9325 forward @7 unknown T -15.000000000000002 -20 35 -10.000000000000002 -15 40 #
+coedge $-1 -1 -1 $-1 $9326 $7303 $7300 $8278 forward $8281 $-1 #
+edge $-1 -1 -1 $-1 $7305 -2.0943951023931953 $9324 -1.5707963267948966 $8277 $9327 forward @7 unknown T -10.000000000000002 -15.669872981077809 35 -7.5000000000000027 -15 37.5 #
+vertex $-1 -1 -1 $-1 $9328 $9329 #
+coedge $-1 -1 -1 $-1 $7303 $9326 $9330 $8570 reversed $8281 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8277 $9331 T -10.000000000000002 -15.669872981077809 32.5 -5 -15 37.5 unknown #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 37.5 #
+edge $-1 -1 -1 $-1 $8611 -6.1232339957367648e-17 $7308 1.5707963267948966 $7307 $9332 forward @7 unknown T -8.8817841970012523e-16 -20 30 4.9999999999999991 -15 35 #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 35 #
+face $-1 -1 -1 $-1 $7515 $9333 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 -40 7.5000000000000027 -20 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9334 $7312 T -8.8817841970012523e-16 -20 -40 7.5000000000000009 -15 -25 unknown #
+coedge $-1 -1 -1 $-1 $9335 $7495 $7497 $7535 reversed $7313 $-1 #
+coedge $-1 -1 -1 $-1 $7498 $7786 $7316 $7542 forward $7787 $-1 #
+vertex $-1 -1 -1 $-1 $9336 $9337 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7896 -50 $7894 50 $7893 $9338 forward @7 unknown T -50 -50 -50 -50 50 -50 #
+straight-curve $-1 -1 -1 $-1 0 -50 -50 -1 0 0 I I #
+straight-curve $-1 -1 -1 $-1 0 50 -50 1 0 0 I I #
+coedge $-1 -1 -1 $-1 $9339 $7328 $9340 $9341 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $8319 $9342 $7328 $7350 reversed $9343 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9344 $7331 $9345 $9346 forward $7333 $-1 #
+coedge $-1 -1 -1 $-1 $7332 $9344 $9347 $9348 forward $7333 $-1 #
+edge $-1 -1 -1 $-1 $9349 42.5 $7334 50 $7332 $9350 forward @7 unknown T 37.5 44.330127018922191 -50 37.500000000000007 44.330127018922191 -42.5 #
+face $-1 -1 -1 $-1 $9351 $7333 $11 $-1 $7001 reversed single T 37.499999999999993 35 -50 45 45 -40 F #
+point $-1 -1 -1 $-1 37.5 44.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $7336 $9352 $9353 $9354 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $9355 $9356 $7336 $8305 reversed $9357 $-1 #
+edge $-1 -1 -1 $-1 $9358 -2.0943951023931957 $8309 0 $7336 $9359 forward @7 unknown T 7.4999999999999991 35 -50 15.000000000000002 40 -50 #
+coedge $-1 -1 -1 $-1 $9360 $7337 $9361 $9362 forward $8308 $-1 #
+coedge $-1 -1 -1 $-1 $7337 $9363 $7339 $8312 reversed $8308 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8307 $9364 T 15 35 -50 22.5 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $9365 $9366 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8313 $7339 $9367 $9368 forward $7341 $-1 #
+edge $-1 -1 -1 $-1 $7342 -50 $9369 -42.5 $7339 $9370 forward @7 unknown T 22.5 35.669872981077809 -50 22.5 35.669872981077809 -42.5 #
+coedge $-1 -1 -1 $-1 $7340 $8311 $9371 $9372 forward $7341 $-1 #
+face $-1 -1 -1 $-1 $9373 $7341 $11 $-1 $7024 reversed single T 22.5 35 -50 30 40 -40 F #
+point $-1 -1 -1 $-1 22.5 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $9371 $9374 $7344 $8317 forward $9375 $-1 #
+edge $-1 -1 -1 $-1 $9376 -1.5707963267948966 $8320 -6.1232339957367648e-17 $8316 $9377 forward @7 unknown T 30 35 -45 35 40 -40 #
+coedge $-1 -1 -1 $-1 $7345 $8960 $9378 $9379 reversed $7036 $-1 #
+coedge $-1 -1 -1 $-1 $9380 $8296 $7340 $7346 forward $9343 $-1 #
+vertex $-1 -1 -1 $-1 $9381 $9382 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9383 $9345 $7347 $8323 forward $9384 $-1 #
+edge $-1 -1 -1 $-1 $8324 -2.0943951023931984 $9376 -1.5707963267948966 $8322 $9385 forward @7 unknown T 35 35 -42.500000000000014 37.500000000000014 35.669872981077816 -40 #
+vertex $-1 -1 -1 $-1 $9346 $9386 #
+straight-curve $-1 -1 -1 $-1 37.5 35.669872981077809 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $9387 $9388 #
+coedge $-1 -1 -1 $-1 $9389 $7353 $9390 $8353 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $9030 $8349 $7353 $8329 reversed $8026 $-1 #
+edge $-1 -1 -1 $-1 $7384 -0.5235987755982987 $7367 1.5707963267948966 $7353 $9391 forward @7 unknown T 15 25 -50 22.5 30 -50 #
+coedge $-1 -1 -1 $-1 $7354 $9392 $9030 $8375 forward $8331 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7377 $8339 T 22.5 25 -50 30 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $7357 $7356 $9393 $9394 forward $6400 $-1 #
+coedge $-1 -1 -1 $-1 $7380 $9395 $7356 $8334 reversed $8372 $-1 #
+edge $-1 -1 -1 $-1 $7382 1.0471975511965983 $9396 1.5707963267948966 $7356 $9397 forward @7 unknown T 37.5 20 -42.5 40 20.669872981077805 -40 #
+coedge $-1 -1 -1 $-1 $9398 $9057 $7357 $8336 reversed $9399 $-1 #
+edge $-1 -1 -1 $-1 $9400 -1.5707963267948966 $8337 -1.0471975511965956 $7357 $9397 forward @7 unknown T 37.499999999999986 29.330127018922187 -42.500000000000007 40 30 -40 #
+vertex $-1 -1 -1 $-1 $9058 $9401 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $9402 $8331 $11 $-1 $6162 reversed single T 22.5 25 -50 30 30 -40 F #
+coedge $-1 -1 -1 $-1 $7361 $9403 $9404 $9405 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $9406 $9407 $7361 $8342 reversed $9408 $-1 #
+edge $-1 -1 -1 $-1 $9409 1.5707963267948966 $8346 3.6651914291880914 $7361 $9410 forward @7 unknown T 8.8817841970012523e-16 20 -50 7.5000000000000009 25 -50 #
+coedge $-1 -1 -1 $-1 $9411 $7362 $9407 $9412 forward $8345 $-1 #
+coedge $-1 -1 -1 $-1 $7362 $9413 $7364 $8350 reversed $8345 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8344 $9414 T 7.5 20 -50 15 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $7363 $9415 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8351 $7364 $9416 $9417 reversed $7366 $-1 #
+coedge $-1 -1 -1 $-1 $8328 $9418 $9419 $8350 reversed $8026 $-1 #
+edge $-1 -1 -1 $-1 $7367 -50 $9420 -45 $9419 $9421 forward @7 unknown T 15 25 -50 15 25 -45 #
+coedge $-1 -1 -1 $-1 $7365 $8348 $9422 $9423 reversed $7366 $-1 #
+face $-1 -1 -1 $-1 $5277 $7366 $11 $-1 $7081 reversed single T 15 20 -50 22.500000000000007 25 -40 F #
+edge $-1 -1 -1 $-1 $7367 0 $9424 2.0943951023931948 $8327 $8347 forward @7 unknown T 7.5000000000000009 25 -50 15 30 -50 #
+point $-1 -1 -1 $-1 15 25 -50 #
+coedge $-1 -1 -1 $-1 $9422 $9425 $7369 $8356 reversed $9426 $-1 #
+edge $-1 -1 -1 $-1 $8357 1.0471975511965961 $9427 1.5707963267948966 $7369 $9428 forward @7 unknown T 22.499999999999993 20 -42.500000000000014 25 20.669872981077813 -40 #
+vertex $-1 -1 -1 $-1 $8356 $9429 #
+straight-curve $-1 -1 -1 $-1 22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9430 $7374 $7371 $8360 reversed $8363 $-1 #
+edge $-1 -1 -1 $-1 $9427 -1.5707963267948966 $7378 0 $7371 $9431 forward @7 unknown T 25 20 -45 30 25 -40 #
+face $-1 -1 -1 $-1 $9432 $9433 $11 $-1 $7093 reversed single T 7.4999999999999991 25 -50 15 30 -40 F #
+coedge $-1 -1 -1 $-1 $7374 $9430 $9434 $9435 forward $8363 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7374 $9436 T 25 19.999999999999996 -45 35 25 -35 unknown #
+vertex $-1 -1 -1 $-1 $7375 $9437 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9438 $9439 $7376 $8367 forward $9440 $-1 #
+edge $-1 -1 -1 $-1 $7378 6.4931039580273265e-16 $9441 1.5707963267948966 $8366 $9442 forward @7 unknown T 30 25 -45 35 29.999999999999996 -40 #
+coedge $-1 -1 -1 $-1 $9392 $7377 $9439 $8369 forward $8331 $-1 #
+edge $-1 -1 -1 $-1 $7378 0 $9443 1.5707963267948966 $8368 $9431 forward @7 unknown T 25 25 -45 30 30 -40 #
+point $-1 -1 -1 $-1 30 25 -45 #
+coedge $-1 -1 -1 $-1 $9395 $7380 $9052 $9444 forward $8372 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7380 $9445 T 35 19.999999999999996 -42.5 40 20.669872981077805 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 20.669872981077805 -42.5 #
+edge $-1 -1 -1 $-1 $9446 42.5 $7384 50 $8330 $9447 forward @7 unknown T 22.5 29.330127018922191 -50 22.5 29.330127018922195 -42.5 #
+point $-1 -1 -1 $-1 22.5 29.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $9448 $7385 $9449 $9450 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $8407 $9451 $7385 $7411 reversed $8421 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7388 $7426 $9452 $9453 forward $7389 $-1 #
+coedge $-1 -1 -1 $-1 $9454 $9454 $7390 $8382 reversed $9455 $-1 #
+edge $-1 -1 -1 $-1 $8384 -1.5707963267948966 $8388 1.5707963267948966 $7390 $9456 forward @7 unknown T 40 5 -45 45 15 -40 #
+coedge $-1 -1 -1 $-1 $7391 $7429 $9457 $9458 reversed $7430 $-1 #
+vertex $-1 -1 -1 $-1 $7392 $9459 #
+ellipse-curve $-1 -1 -1 $-1 40 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9173 $7393 $9460 $9461 reversed $8387 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8149 $9462 T 35 14.330127018922189 -42.500000000000007 40 15 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $7394 $9463 #
+point $-1 -1 -1 $-1 37.5 14.330127018922193 -42.500000000000007 #
+face $-1 -1 -1 $-1 $9464 $9465 $11 $-1 $5306 reversed single T 37.5 4.9999999999999991 5.0000000000000027 45.000000000000007 15 20.000000000000007 F #
+coedge $-1 -1 -1 $-1 $7398 $9466 $9467 $9468 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $9469 $9470 $7398 $8393 reversed $9471 $-1 #
+edge $-1 -1 -1 $-1 $9472 -2.0943951023931957 $8397 0 $7398 $9473 forward @7 unknown T -7.5000000000000009 5 -50 8.8817841970012523e-16 10 -50 #
+coedge $-1 -1 -1 $-1 $9474 $7399 $9475 $9476 forward $8396 $-1 #
+coedge $-1 -1 -1 $-1 $7399 $9477 $7401 $8400 reversed $8396 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8395 $9478 T 0 4.9999999999999991 -50 7.5000000000000018 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $9479 $9480 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8401 $7401 $9481 $9482 forward $7403 $-1 #
+edge $-1 -1 -1 $-1 $7404 -50 $9483 -42.5 $7401 $9484 forward @7 unknown T 7.5 5.6698729810778064 -50 7.5000000000000018 5.6698729810778072 -42.5 #
+coedge $-1 -1 -1 $-1 $7402 $8399 $9485 $9486 forward $7403 $-1 #
+face $-1 -1 -1 $-1 $9487 $7403 $11 $-1 $6231 reversed single T 7.4999999999999991 5 -50 15 10 -40 F #
+point $-1 -1 -1 $-1 7.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $9485 $9488 $7406 $8405 forward $9489 $-1 #
+edge $-1 -1 -1 $-1 $9490 -1.5707963267948966 $8408 2.9403902792268234e-16 $8404 $9491 forward @7 unknown T 15 4.9999999999999982 -45 20 10 -40 #
+coedge $-1 -1 -1 $-1 $7407 $9140 $9492 $9493 reversed $7164 $-1 #
+coedge $-1 -1 -1 $-1 $9494 $8378 $7402 $7408 forward $8421 $-1 #
+vertex $-1 -1 -1 $-1 $9495 $9496 #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9497 $7413 $7409 $8411 forward $8414 $-1 #
+edge $-1 -1 -1 $-1 $7415 -2.0943951023931957 $9490 -1.5707963267948966 $8410 $9498 forward @7 unknown T 20 4.9999999999999982 -42.5 22.500000000000004 5.6698729810778072 -40 #
+vertex $-1 -1 -1 $-1 $9499 $9500 #
+coedge $-1 -1 -1 $-1 $7413 $9497 $9501 $9502 reversed $8414 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8410 $9503 T 20 4.9999999999999982 -42.5 25 5.6698729810778081 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $7414 $9504 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 5.6698729810778064 -42.5 #
+coedge $-1 -1 -1 $-1 $7420 $7417 $9505 $9506 reversed $7421 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9507 $9508 $11 $-1 $5329 reversed single T 22.5 10 5.0000000000000018 30 15 20 F #
+loop $-1 -1 -1 $-1 $-1 $8407 $7419 T 7.4999999999999964 10 -50 15 15 -40 unknown #
+coedge $-1 -1 -1 $-1 $9509 $8144 $7420 $8423 reversed $7188 $-1 #
+edge $-1 -1 -1 $-1 $9170 -2.9403902792268234e-16 $7422 1.5707963267948966 $7420 $9510 forward @7 unknown T 30 4.9999999999999982 -40 35 10 -35 #
+face $-1 -1 -1 $-1 $9511 $7421 $11 $-1 $9512 reversed single T 25 4.9999999999999982 -45 35 10 -35 F #
+point $-1 -1 -1 $-1 35 4.9999999999999982 -40 #
+coedge $-1 -1 -1 $-1 $9513 $7424 $8145 $9162 forward $8428 $-1 #
+coedge $-1 -1 -1 $-1 $7424 $9513 $7426 $7427 reversed $8428 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7424 $9511 T 25 10 -45 35 15 -35 unknown #
+vertex $-1 -1 -1 $-1 $7425 $9514 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $9453 $9515 #
+edge $-1 -1 -1 $-1 $7422 1.5707963267948966 $9516 2.0943951023931957 $7429 $9517 forward @7 unknown T 35 4.9999999999999982 -40 37.5 5.6698729810778072 -37.5 #
+face $-1 -1 -1 $-1 $9518 $7430 $11 $-1 $9512 reversed single T 35 4.9999999999999982 -42.5 40 5.6698729810778072 -37.5 F #
+vertex $-1 -1 -1 $-1 $9519 $9520 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9521 $7435 $9522 $8466 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $9244 $8462 $7435 $8438 reversed $8210 $-1 #
+edge $-1 -1 -1 $-1 $7470 -0.52359877559829893 $7455 1.5707963267948966 $7435 $9523 forward @7 unknown T 0 -5 -50 7.5 0 -50 #
+coedge $-1 -1 -1 $-1 $7436 $9524 $9244 $8486 forward $7479 $-1 #
+coedge $-1 -1 -1 $-1 $9525 $9266 $7438 $8441 reversed $9526 $-1 #
+edge $-1 -1 -1 $-1 $7489 -1.5707963267948966 $7492 -1.047197551196597 $7438 $7474 forward @7 unknown T 22.499999999999996 -0.6698729810778099 -42.500000000000007 25 0 -40 #
+coedge $-1 -1 -1 $-1 $7439 $7439 $9527 $9528 reversed $8443 $-1 #
+loop $-1 -1 -1 $-1 $9529 $7439 $9530 T 40 -10 -45 45 0 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9278 $9527 $7441 $8446 forward $9531 $-1 #
+edge $-1 -1 -1 $-1 $7442 1.5707963267948966 $8503 2.0943951023931948 $8445 $9532 forward @7 unknown T 37.5 -10 -40 40 -9.3301270189221945 -37.5 #
+point $-1 -1 -1 $-1 40 -10 -40 #
+coedge $-1 -1 -1 $-1 $9527 $9533 $7444 $8449 forward $9531 $-1 #
+edge $-1 -1 -1 $-1 $9534 4.1887902047863923 $7446 4.7123889803846897 $8448 $9532 forward @7 unknown T 37.500000000000007 -0.66987298107780902 -40 40 0 -37.500000000000007 #
+face $-1 -1 -1 $-1 $7491 $7445 $11 $-1 $8499 reversed single T 35 -0.66987298107781079 -42.5 40 0 -37.5 F #
+point $-1 -1 -1 $-1 40 0 -40 #
+loop $-1 -1 -1 $-1 $-1 $8818 $7448 T 37.499999999999993 -10 5.0000000000000027 45.000000000000007 8.8817841970012523e-16 20.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $7449 $9535 $9536 $9537 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $9538 $9539 $7449 $8455 reversed $9540 $-1 #
+edge $-1 -1 -1 $-1 $9541 1.5707963267948966 $8459 3.6651914291880914 $7449 $9542 forward @7 unknown T -15 -10 -50 -7.5000000000000009 -4.9999999999999991 -50 #
+coedge $-1 -1 -1 $-1 $9543 $7450 $9539 $9544 forward $8458 $-1 #
+coedge $-1 -1 -1 $-1 $7450 $9545 $7452 $8463 reversed $8458 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8457 $9546 T -7.5000000000000036 -10 -50 0 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $7451 $9547 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8464 $7452 $9548 $9549 reversed $7454 $-1 #
+coedge $-1 -1 -1 $-1 $8437 $9550 $9551 $8463 reversed $8210 $-1 #
+edge $-1 -1 -1 $-1 $7455 -50 $9552 -45 $9551 $9553 forward @7 unknown T 0 -5 -50 0 -5 -45 #
+coedge $-1 -1 -1 $-1 $7453 $8461 $9554 $9555 reversed $7454 $-1 #
+face $-1 -1 -1 $-1 $5377 $7454 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 -50 7.5000000000000009 -5 -40 F #
+edge $-1 -1 -1 $-1 $7455 0 $9556 2.0943951023931948 $8436 $8460 forward @7 unknown T -7.4999999999999991 -5 -50 0 0 -50 #
+point $-1 -1 -1 $-1 0 -5 -50 #
+coedge $-1 -1 -1 $-1 $9554 $9557 $7457 $8469 reversed $9558 $-1 #
+edge $-1 -1 -1 $-1 $8470 1.047197551196597 $9559 1.5707963267948966 $7457 $9560 forward @7 unknown T 7.4999999999999964 -10 -42.500000000000007 10 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $8469 $9561 #
+straight-curve $-1 -1 -1 $-1 7.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9562 $7462 $7459 $8473 reversed $8476 $-1 #
+edge $-1 -1 -1 $-1 $9559 -1.5707963267948966 $7466 0 $7459 $9563 forward @7 unknown T 10 -10 -45 15 -5 -40 #
+face $-1 -1 -1 $-1 $9564 $9565 $11 $-1 $7251 reversed single T -7.5000000000000009 -5 -50 0 0 -40 F #
+coedge $-1 -1 -1 $-1 $7462 $9562 $9566 $9567 forward $8476 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7462 $9568 T 10 -10 -45 20 -4.9999999999999991 -35 unknown #
+vertex $-1 -1 -1 $-1 $7463 $9569 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9570 $9571 $7464 $8480 forward $9572 $-1 #
+edge $-1 -1 -1 $-1 $7466 1.1640334398265738e-16 $9573 1.5707963267948966 $8479 $9574 forward @7 unknown T 15 -5 -45 20 -8.8817841970012523e-16 -40 #
+coedge $-1 -1 -1 $-1 $9524 $7465 $9571 $8482 forward $7479 $-1 #
+edge $-1 -1 -1 $-1 $7466 0 $9575 1.5707963267948966 $8481 $9563 forward @7 unknown T 10 -5 -45 15 0 -40 #
+point $-1 -1 -1 $-1 15 -5 -45 #
+coedge $-1 -1 -1 $-1 $7471 $7468 $9261 $9576 forward $7472 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9577 42.5 $7470 50 $8439 $9578 forward @7 unknown T 7.5 -0.66987298107780746 -50 7.5000000000000018 -0.66987298107780635 -42.5 #
+point $-1 -1 -1 $-1 7.5 -0.66987298107780635 -50 #
+coedge $-1 -1 -1 $-1 $9579 $8492 $7471 $8489 forward $9294 $-1 #
+edge $-1 -1 -1 $-1 $7473 1.5707963267948966 $9580 2.0943951023931948 $8488 $9581 forward @7 unknown T 22.500000000000004 -10 -40 25 -9.3301270189221945 -37.5 #
+face $-1 -1 -1 $-1 $9582 $7472 $11 $-1 $8499 reversed single T 20 -10 -42.500000000000007 25 -9.330127018922191 -37.5 F #
+point $-1 -1 -1 $-1 25 -10 -40 #
+coedge $-1 -1 -1 $-1 $8488 $8249 $7476 $8493 forward $9294 $-1 #
+edge $-1 -1 -1 $-1 $8251 3.1415926535897931 $7473 4.7123889803846897 $8492 $9583 forward @7 unknown T 25 -10 -40 30 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $9584 $9585 $11 $-1 $8848 reversed single T 10 -5 15 20 0 25 F #
+loop $-1 -1 -1 $-1 $-1 $7818 $7478 T 22.499999999999996 -5.0000000000000009 5.0000000000000018 30 0 20 unknown #
+coedge $-1 -1 -1 $-1 $9586 $7480 $6325 $7281 forward $6324 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8450 $7486 $11 $-1 $8499 reversed single T 25 -5 -45 35 0 -35 F #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 -5 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $7485 $7484 $8248 $9292 reversed $7486 $-1 #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 -40 #
+point $-1 -1 -1 $-1 25 0 -40 #
+vertex $-1 -1 -1 $-1 $9279 $9587 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8833 $8250 $11 $-1 $4486 reversed single T 22.5 -5.0000000000000009 -40 30 0 -25 F #
+edge $-1 -1 -1 $-1 $9573 1.5707963267948966 $7492 2.0943951023931957 $9266 $9588 forward @7 unknown T 20 -0.6698729810778099 -42.500000000000007 22.5 -8.8817841970012523e-16 -40 #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780857 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $9589 $7494 $9590 $9591 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $8528 $9592 $7494 $7516 reversed $8541 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7497 $7530 $9593 $9594 forward $6542 $-1 #
+coedge $-1 -1 -1 $-1 $7503 $9595 $9596 $9597 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $9598 $9599 $7503 $8514 reversed $9600 $-1 #
+edge $-1 -1 -1 $-1 $9601 -2.0943951023931948 $8518 0 $7503 $9602 forward @7 unknown T -22.5 -25 -50 -15 -20 -50 #
+coedge $-1 -1 -1 $-1 $9603 $7504 $9604 $9605 forward $8517 $-1 #
+coedge $-1 -1 -1 $-1 $7504 $9606 $7506 $8521 reversed $8517 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8516 $9607 T -15.000000000000002 -25 -50 -7.5000000000000009 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $9608 $9609 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8522 $7506 $9610 $9611 forward $7508 $-1 #
+edge $-1 -1 -1 $-1 $7509 -50 $9612 -42.500000000000007 $7506 $9613 forward @7 unknown T -7.5000000000000027 -24.330127018922195 -50 -7.5000000000000009 -24.330127018922191 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $7507 $8520 $9614 $9615 forward $7508 $-1 #
+face $-1 -1 -1 $-1 $9616 $7508 $11 $-1 $3822 reversed single T -7.5000000000000036 -25 -50 0 -20 -40 F #
+point $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $9614 $9617 $7511 $8526 forward $9618 $-1 #
+edge $-1 -1 -1 $-1 $9619 -1.5707963267948966 $8529 -6.1232339957367648e-17 $8525 $9620 forward @7 unknown T -8.8817841970012523e-16 -25 -45 4.9999999999999991 -20 -40 #
+coedge $-1 -1 -1 $-1 $7512 $9335 $9621 $9622 reversed $7313 $-1 #
+coedge $-1 -1 -1 $-1 $9623 $8509 $7507 $7513 forward $8541 $-1 #
+vertex $-1 -1 -1 $-1 $9624 $9625 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9626 $7518 $7514 $8532 forward $8535 $-1 #
+edge $-1 -1 -1 $-1 $7520 -2.0943951023931966 $9619 -1.5707963267948966 $8531 $9627 forward @7 unknown T 4.9999999999999991 -25 -42.500000000000014 7.5000000000000036 -24.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $9628 $9629 #
+coedge $-1 -1 -1 $-1 $7518 $9626 $9630 $9631 reversed $8535 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8531 $9632 T 4.9999999999999991 -25 -42.500000000000014 10 -24.330127018922191 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $7519 $9633 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000027 -24.330127018922195 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $7525 $7522 $9634 $9635 reversed $6896 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $8528 $7524 T -7.5000000000000053 -20 -50 0 -15 -40 unknown #
+coedge $-1 -1 -1 $-1 $8708 $7791 $7525 $8543 reversed $7315 $-1 #
+edge $-1 -1 -1 $-1 $8725 6.1232339957367648e-17 $7526 1.5707963267948966 $7525 $9636 forward @7 unknown T 15 -25 -40 20 -20 -35 #
+point $-1 -1 -1 $-1 20 -25 -40 #
+coedge $-1 -1 -1 $-1 $9637 $7528 $7730 $8724 forward $7847 $-1 #
+coedge $-1 -1 -1 $-1 $7528 $9637 $7530 $7531 reversed $7847 $-1 #
+vertex $-1 -1 -1 $-1 $7529 $9638 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $9594 $9639 #
+edge $-1 -1 -1 $-1 $7526 1.5707963267948966 $7792 2.0943951023931957 $7533 $9640 forward @7 unknown T 20 -25 -40 22.500000000000004 -24.330127018922191 -37.5 #
+vertex $-1 -1 -1 $-1 $9641 $9642 #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $4058 $7726 $11 $-1 $4529 reversed single T 7.4999999999999964 -20 -40 15 -15 -25 F #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $6568 1.5707963267948961 $7670 2.0943951023931944 $7550 $9643 forward @7 unknown T -25.000000000000007 -40 -25 -22.500000000000004 -39.330127018922198 -22.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $7560 $7560 $7588 $8602 forward $6578 $-1 #
+coedge $-1 -1 -1 $-1 $9644 $9645 $7560 $8561 reversed $9646 $-1 #
+edge $-1 -1 -1 $-1 $8606 -1.5707963267948966 $9647 1.5707963267948966 $7560 $9648 forward @7 unknown T -45 -24.999999999999996 14.999999999999996 -40 -14.999999999999996 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $7562 $7561 $9649 $9650 reversed $5635 $-1 #
+edge $-1 -1 -1 $-1 $9651 1.5707963267948966 $7599 2.0943951023931957 $7595 $9652 forward @7 unknown T -7.5000000000000027 -25 20 -5 -24.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $9653 $9654 $7562 $8565 reversed $9655 $-1 #
+edge $-1 -1 -1 $-1 $9656 -2.0943951023931957 $8566 -1.5707963267948966 $7562 $9657 forward @7 unknown T -10.000000000000002 -25 17.499999999999996 -7.5000000000000009 -24.330127018922191 20 #
+vertex $-1 -1 -1 $-1 $9658 $9659 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9330 $7702 $7564 $8569 forward $7558 $-1 #
+edge $-1 -1 -1 $-1 $8611 0 $7565 1.5707963267948966 $8568 $8612 forward @7 unknown T -5 -20 30 0 -15 35 #
+edge $-1 -1 -1 $-1 $7565 -1.5707963267948966 $9660 -1.047197551196597 $9330 $6601 forward @7 unknown T -7.5000000000000036 -15.669872981077809 32.5 -5 -15 35 #
+point $-1 -1 -1 $-1 -5 -15 35 #
+coedge $-1 -1 -1 $-1 $7571 $7568 $8261 $9303 reversed $6586 $-1 #
+coedge $-1 -1 -1 $-1 $9661 $8262 $7568 $8574 forward $9305 $-1 #
+edge $-1 -1 -1 $-1 $9306 -50 $8576 -37.499999999999993 $8573 $9662 forward @7 unknown T -37.5 -15.669872981077805 37.499999999999993 -37.499999999999993 -15.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $7569 $7584 $9661 $9663 reversed $7585 $-1 #
+vertex $-1 -1 -1 $-1 $9663 $9664 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9665 $9666 $7571 $8579 forward $9667 $-1 #
+edge $-1 -1 -1 $-1 $8581 37.5 $9668 50 $8578 $9669 forward @7 unknown T -37.5 -24.330127018922195 37.5 -37.5 -24.330127018922187 50 #
+coedge $-1 -1 -1 $-1 $7577 $7572 $9666 $9670 reversed $7578 $-1 #
+vertex $-1 -1 -1 $-1 $7573 $9671 #
+face $-1 -1 -1 $-1 $9672 $9673 $11 $-1 $7591 reversed single T -45 -24.999999999999996 -50 -37.5 -14.999999999999996 -40 F #
+coedge $-1 -1 -1 $-1 $9674 $7575 $7577 $8589 forward $8586 $-1 #
+coedge $-1 -1 -1 $-1 $7575 $9675 $8603 $9676 forward $8586 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9677 $9678 T -37.500000000000007 -25 19.999999999999993 -29.999999999999993 -20 35 unknown #
+vertex $-1 -1 -1 $-1 $7590 $9679 #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $7579 1.0471975511965965 $9680 1.5707963267948966 $8584 $9681 forward @7 unknown T -37.500000000000007 -25 32.499999999999993 -35 -24.330127018922187 35 #
+face $-1 -1 -1 $-1 $8600 $7578 $11 $-1 $1965 reversed single T -40 -25 32.499999999999993 -35 -24.330127018922187 37.5 F #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 32.499999999999993 #
+coedge $-1 -1 -1 $-1 $9682 $9683 $7581 $8593 forward $9684 $-1 #
+edge $-1 -1 -1 $-1 $8597 -2.0943951023931939 $9647 -1.5707963267948966 $8592 $9685 forward @7 unknown T -40 -15.669872981077804 19.999999999999996 -37.500000000000007 -14.999999999999996 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $9686 $7582 $9683 $9687 forward $8596 $-1 #
+coedge $-1 -1 -1 $-1 $7582 $9688 $7584 $8599 forward $8596 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9689 $9690 T -37.500000000000007 -20 19.999999999999993 -29.999999999999993 -15 35 unknown #
+vertex $-1 -1 -1 $-1 $9687 $9691 #
+straight-curve $-1 -1 -1 $-1 -37.5 -15.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $9692 -1.5707963267948966 $7586 -1.0471975511965979 $8595 $9681 forward @7 unknown T -37.5 -15.669872981077809 32.5 -35 -15 35 #
+face $-1 -1 -1 $-1 $9693 $7585 $11 $-1 $1965 reversed single T -40 -15.669872981077809 32.5 -35 -14.999999999999996 37.5 F #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077805 32.5 #
+edge $-1 -1 -1 $-1 $9647 -1.5707963267948966 $8606 1.5707963267948966 $8559 $9694 forward @7 unknown T -45 -24.999999999999996 19.999999999999996 -40 -14.999999999999996 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $9695 $7589 $8585 $9676 reversed $8605 $-1 #
+coedge $-1 -1 -1 $-1 $7589 $9695 $9644 $9696 forward $8605 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7589 $9697 T -40 -25 17.499999999999989 -35 -24.330127018922187 22.5 unknown #
+vertex $-1 -1 -1 $-1 $8561 $9698 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7595 $7592 $9699 $8703 forward $6600 $-1 #
+coedge $-1 -1 -1 $-1 $8761 $8760 $6745 $7703 forward $7774 $-1 #
+coedge $-1 -1 -1 $-1 $7593 $7597 $8761 $9336 forward $6836 $-1 #
+vertex $-1 -1 -1 $-1 $8569 $9700 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9701 $9702 $7598 $8614 forward $9703 $-1 #
+edge $-1 -1 -1 $-1 $8619 6.1232339957367648e-17 $8566 1.5707963267948966 $8613 $9704 forward @7 unknown T -15.000000000000002 -25 20 -10.000000000000002 -20 25 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $9705 $7601 $9706 $9707 reversed $7638 $-1 #
+coedge $-1 -1 -1 $-1 $7601 $9708 $9322 $9709 reversed $7638 $-1 #
+coedge $-1 -1 -1 $-1 $8632 $9710 $9711 $7602 forward $9712 $-1 #
+vertex $-1 -1 -1 $-1 $9713 $9714 #
+straight-curve $-1 -1 -1 $-1 -15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9711 $9715 $7603 $8622 forward $9716 $-1 #
+edge $-1 -1 -1 $-1 $8625 -1.5707963267948966 $6620 0 $8621 $8633 forward @7 unknown T -20 -25 30 -15 -20 35 #
+coedge $-1 -1 -1 $-1 $9301 $7605 $9717 $9718 forward $8624 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8272 $9719 T -22.500000000000004 -25 35 -15 -20 50 unknown #
+vertex $-1 -1 -1 $-1 $9720 $9721 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9722 $9716 $11 $-1 $9321 reversed single T -22.500000000000004 -25 20 -15 -20 35 F #
+face $-1 -1 -1 $-1 $9607 $9723 $11 $-1 $6619 reversed single T -15.000000000000002 -25 -40 -7.5000000000000009 -20 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9724 $7610 T -15.000000000000002 -20 -40 -7.5000000000000009 -15 -25 unknown #
+coedge $-1 -1 -1 $-1 $9725 $9590 $9592 $9628 reversed $7611 $-1 #
+vertex $-1 -1 -1 $-1 $9726 $9727 #
+coedge $-1 -1 -1 $-1 $9728 $8618 $9729 $7612 forward $9712 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $9730 $9731 $3147 T -50 -25 -30.000000000000004 -50 -15 -20.000000000000004 hole $3148 T #
+coedge $-1 -1 -1 $-1 $8635 $8635 $8777 $9732 forward $7614 $-1 #
+coedge $-1 -1 -1 $-1 $8636 $8636 $7615 $8637 reversed $8851 $-1 #
+edge $-1 -1 -1 $-1 $9733 0 $9733 6.2831853071795862 $7615 $9734 forward @7 unknown T -50 -25 -3.0616169978683823e-15 -50 -15 9.9999999999999964 #
+vertex $-1 -1 -1 $-1 $7617 $9735 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 19.999999999999996 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $9736 $9737 $11 $-1 $9738 reversed single T -37.5 -10 -50 -30 -4.9999999999999991 -40 F #
+loop $-1 -1 -1 $-1 $-1 $9739 $7618 T -37.5 -25 -50 -30 -20 -40 unknown #
+cone-surface $-1 -1 -1 $-1 -35 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+face $-1 -1 -1 $-1 $6595 $9646 $11 $-1 $7591 reversed single T -45 -24.999999999999996 4.9999999999999973 -37.499999999999993 -14.999999999999996 19.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $9740 $7619 T -45 -24.999999999999996 -10.000000000000002 -37.499999999999993 -14.999999999999996 4.9999999999999973 unknown #
+coedge $-1 -1 -1 $-1 $9741 $9742 $9743 $9744 reversed $7620 $-1 #
+face $-1 -1 -1 $-1 $7665 $7623 $11 $-1 $3872 reversed single T -30.000000000000004 -35 -25 -22.5 -30 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 -22.500000000000004 #
+face $-1 -1 -1 $-1 $9745 $9746 $11 $-1 $7628 reversed single T -30 -20 -10.000000000000002 -22.5 -15 4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $9747 $7626 T -30.000000000000007 -20 4.9999999999999982 -22.499999999999993 -15 20 unknown #
+coedge $-1 -1 -1 $-1 $9748 $9749 $9750 $9751 reversed $7627 $-1 #
+face $-1 -1 -1 $-1 $9752 $9753 $11 $-1 $6619 reversed single T -15.000000000000002 -20 -10 -7.5000000000000009 -15 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $9754 $7637 T -15.000000000000002 -20 4.9999999999999991 -7.5000000000000009 -15 20 unknown #
+loop $-1 -1 -1 $-1 $9755 $9756 $1558 T 50 -10 15.000000000000004 50 0 25.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $8655 $8655 $8173 $9195 forward $7639 $-1 #
+edge $-1 -1 -1 $-1 $9757 0 $9757 6.2831853071795862 $7640 $9758 forward @7 unknown T 50 -25 -45 50 -15 -35 #
+vertex $-1 -1 -1 $-1 $7642 $9759 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 -24.999999999999996 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -20 -14.999999999999996 #
+coedge $-1 -1 -1 $-1 $7675 $7657 $7646 $8661 reversed $7676 $-1 #
+edge $-1 -1 -1 $-1 $8669 -1.5707963267948966 $7647 6.1232339957367648e-17 $7646 $9760 forward @7 unknown T -30.000000000000004 -35 -10.000000000000002 -25.000000000000004 -30 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -30 -35 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $7657 $7674 $7649 $8664 reversed $7676 $-1 #
+edge $-1 -1 -1 $-1 $7650 -6.1232339957367648e-17 $8675 1.5707963267948966 $7649 $9761 forward @7 unknown T -30.000000000000004 -35 -1.7763568394002505e-15 -25.000000000000004 -30 4.9999999999999982 #
+point $-1 -1 -1 $-1 -30 -35 -1.7763568394002505e-15 #
+edge $-1 -1 -1 $-1 $8678 -1.5707963267948966 $7650 -6.1232339957367648e-17 $7653 $9762 forward @7 unknown T -30.000000000000004 -40 -1.7763568394002505e-15 -25.000000000000004 -35 4.9999999999999982 #
+edge $-1 -1 -1 $-1 $7647 6.1232339957367648e-17 $7689 1.5707963267948966 $7654 $9763 forward @7 unknown T -30.000000000000004 -40 -10.000000000000002 -25.000000000000004 -35 -5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -10.000000000000002 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $7666 $9764 #
+point $-1 -1 -1 $-1 -22.500000000000004 -39.330127018922198 -22.500000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -10.000000000000002 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8647 $7676 $11 $-1 $3872 reversed single T -30.000000000000004 -35 -10.000000000000002 -22.5 -30 4.9999999999999982 F #
+edge $-1 -1 -1 $-1 $7848 -2.0943951023931957 $8675 -1.5707963267948966 $7678 $9765 forward @7 unknown T -25.000000000000004 -30.669872981077809 4.9999999999999982 -22.500000000000004 -30 7.5000000000000027 #
+vertex $-1 -1 -1 $-1 $8664 $9766 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 4.9999999999999982 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -10.000000000000002 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $8666 $9767 #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 -10.000000000000002 #
+face $-1 -1 -1 $-1 $9768 $9769 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 -10 7.5 -20 5 F #
+loop $-1 -1 -1 $-1 $-1 $9770 $7694 T -8.8817841970012523e-16 -25 -25 7.5000000000000018 -20 -10 unknown #
+coedge $-1 -1 -1 $-1 $8796 $8793 $9771 $9772 reversed $7695 $-1 #
+coedge $-1 -1 -1 $-1 $7696 $9773 $8776 $9774 reversed $6742 $-1 #
+coedge $-1 -1 -1 $-1 $9775 $8794 $7696 $8687 forward $9776 $-1 #
+edge $-1 -1 -1 $-1 $7805 -1.5707963267948966 $9777 6.1232339957367648e-17 $8686 $9778 forward @7 unknown T -8.8817841970012523e-16 -20 -10 4.9999999999999991 -15 -5 #
+coedge $-1 -1 -1 $-1 $7698 $7752 $7705 $8701 reversed $5822 $-1 #
+coedge $-1 -1 -1 $-1 $9779 $9780 $9781 $8690 forward $8850 $-1 #
+edge $-1 -1 -1 $-1 $8695 10 $9782 15 $8689 $9783 forward @7 unknown T -8.8817841970012523e-16 -20 10 0 -20 15 #
+coedge $-1 -1 -1 $-1 $9784 $7699 $9780 $9785 reversed $8693 $-1 #
+coedge $-1 -1 -1 $-1 $7699 $9784 $9773 $9786 forward $8693 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7699 $9787 T -5 -20 0 4.9999999999999991 -15 10 unknown #
+vertex $-1 -1 -1 $-1 $9786 $9788 #
+vertex $-1 -1 -1 $-1 $9789 $9790 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 0.70710678118654735 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $7702 $9791 $7704 $8700 forward $7558 $-1 #
+coedge $-1 -1 -1 $-1 $7705 $7704 $9779 $9792 reversed $6811 $-1 #
+edge $-1 -1 -1 $-1 $9793 1.5707963267948966 $7707 3.1415926535897931 $8697 $9794 forward @7 unknown T -5 -20 20 0 -15 25 #
+edge $-1 -1 -1 $-1 $9782 -6.1232339957367648e-17 $7706 1.5707963267948966 $7705 $9795 forward @7 unknown T -8.8817841970012523e-16 -20 15 4.9999999999999991 -15 20 #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 20 #
+edge $-1 -1 -1 $-1 $7707 3.1415926535897931 $9651 4.7123889803846897 $8608 $9794 forward @7 unknown T -5 -25 20 0 -20 25 #
+point $-1 -1 -1 $-1 0 -20 25 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -9.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8721 $8728 $7712 $8707 forward $9796 $-1 #
+edge $-1 -1 -1 $-1 $6778 -1.5707963267948966 $6776 0 $8706 $7727 forward @7 unknown T 10 -25 -30 15 -20 -25 #
+coedge $-1 -1 -1 $-1 $7713 $8542 $6775 $7731 forward $7315 $-1 #
+edge $-1 -1 -1 $-1 $7747 12.500000000000002 $8713 22.500000000000004 $7716 $9797 forward @7 unknown T 7.4999999999999973 -15.669872981077809 -22.500000000000004 7.5000000000000009 -15.669872981077807 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $9798 $7717 $8796 $9799 forward $8712 $-1 #
+coedge $-1 -1 -1 $-1 $7717 $9798 $7724 $7728 reversed $8712 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8710 $9800 T 4.9999999999999991 -15.669872981077809 -27.500000000000004 10 -15 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $7718 $9801 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7720 $7719 $9802 $9803 forward $6769 $-1 #
+coedge $-1 -1 -1 $-1 $9804 $9805 $7719 $8717 reversed $9806 $-1 #
+edge $-1 -1 -1 $-1 $6778 1.5707963267948966 $9807 2.0943951023931948 $7719 $8714 forward @7 unknown T 7.5000000000000018 -25 -25 10 -24.330127018922191 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $8740 $7741 $7720 $6795 reversed $7746 $-1 #
+coedge $-1 -1 -1 $-1 $9808 $7724 $9809 $9810 forward $7726 $-1 #
+coedge $-1 -1 -1 $-1 $7725 $9808 $9637 $9811 forward $7726 $-1 #
+coedge $-1 -1 -1 $-1 $9634 $8706 $8708 $7731 reversed $9796 $-1 #
+vertex $-1 -1 -1 $-1 $9812 $9813 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8547 -1.5707963267948966 $8725 6.1232339957367648e-17 $8545 $9814 forward @7 unknown T 15 -20 -40 20 -15 -35 #
+vertex $-1 -1 -1 $-1 $9635 $9815 #
+straight-curve $-1 -1 -1 $-1 15 -20 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $7733 $9816 #
+coedge $-1 -1 -1 $-1 $8706 $9817 $9804 $7733 forward $9796 $-1 #
+coedge $-1 -1 -1 $-1 $9773 $7735 $7737 $8731 reversed $6742 $-1 #
+edge $-1 -1 -1 $-1 $8694 1.5707963267948966 $6812 2.0943951023931957 $7737 $9818 forward @7 unknown T 4.9999999999999991 -15.669872981077809 2.5 7.5 -15 5 #
+point $-1 -1 -1 $-1 7.5000000000000009 -15.669872981077807 -7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $9819 $9820 $7740 $8734 reversed $9769 $-1 #
+edge $-1 -1 -1 $-1 $8736 -7.4999999999999991 $6814 2.5000000000000009 $7740 $9821 forward @7 unknown T 7.4999999999999991 -24.330127018922195 -7.4999999999999991 7.5 -24.330127018922191 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $7741 $8740 $9819 $9822 forward $7746 $-1 #
+vertex $-1 -1 -1 $-1 $9822 $9823 #
+coedge $-1 -1 -1 $-1 $7760 $7743 $9820 $9824 forward $7761 $-1 #
+face $-1 -1 -1 $-1 $9825 $9776 $11 $-1 $2664 reversed single T -5 -20 -15 4.9999999999999991 -15 -5 F #
+loop $-1 -1 -1 $-1 $-1 $9826 $7745 T -5 -25 -15 4.9999999999999991 -20 -5 unknown #
+coedge $-1 -1 -1 $-1 $8735 $8718 $9827 $9828 forward $7746 $-1 #
+point $-1 -1 -1 $-1 7.4999999999999973 -15.669872981077809 -12.500000000000002 #
+face $-1 -1 -1 $-1 $9829 $9830 $11 $-1 $5386 reversed single T 15 -5 -9.9999999999999982 22.500000000000004 0 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $9831 $7749 T 14.999999999999996 -5 5.0000000000000009 22.5 0 20 unknown #
+coedge $-1 -1 -1 $-1 $9260 $8222 $9832 $9833 reversed $7750 $-1 #
+point $-1 -1 -1 $-1 7.4999999999999982 -24.330127018922195 -12.500000000000002 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $9834 $9835 $11 $-1 $3328 reversed single T -5 -20 -30 4.9999999999999991 -15 -20 F #
+coedge $-1 -1 -1 $-1 $9836 $7758 $7760 $8753 reversed $8751 $-1 #
+coedge $-1 -1 -1 $-1 $7758 $9837 $7763 $8756 reversed $8751 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8749 $9768 T -8.8817841970012523e-16 -25 5 7.5000000000000027 -20 20 unknown #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $9838 1.5707963267948966 $7762 2.0943951023931957 $7760 $9839 forward @7 unknown T 4.9999999999999991 -25 5 7.5 -24.330127018922191 7.5000000000000027 #
+face $-1 -1 -1 $-1 $7756 $7761 $11 $-1 $2156 reversed single T 4.9999999999999991 -25 2.5000000000000009 10.000000000000002 -24.330127018922191 7.5000000000000027 F #
+point $-1 -1 -1 $-1 7.5 -24.330127018922195 7.5000000000000027 #
+edge $-1 -1 -1 $-1 $5913 -2.0943951023931948 $8763 -1.5707963267948966 $7763 $9840 forward @7 unknown T 4.9999999999999991 -25 17.500000000000004 7.5000000000000027 -24.330127018922195 20 #
+coedge $-1 -1 -1 $-1 $9841 $9699 $8760 $9842 forward $7766 $-1 #
+face $-1 -1 -1 $-1 $9843 $9796 $11 $-1 $4529 reversed single T 7.5 -25 -40 15 -20 -25 F #
+loop $-1 -1 -1 $-1 $-1 $9781 $7771 T -7.5000000000000027 -25 5 0 -20 20 unknown #
+coedge $-1 -1 -1 $-1 $8609 $7772 $8757 $9842 reversed $7774 $-1 #
+coedge $-1 -1 -1 $-1 $7773 $8609 $8610 $9336 reversed $7774 $-1 #
+face $-1 -1 -1 $-1 $7289 $7774 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 20 7.5000000000000027 -20 35 F #
+vertex $-1 -1 -1 $-1 $9844 $9845 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $7723 $9846 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 -25 8.8817841970012523e-16 -20 -10 F #
+loop $-1 -1 -1 $-1 $9847 $9848 $7781 T -45 -24.999999999999996 -30.000000000000004 -40 -14.999999999999996 -20.000000000000004 unknown #
+loop $-1 -1 -1 $-1 $9849 $9850 $7782 T -45 -24.999999999999996 -45 -40 -14.999999999999996 -35 unknown #
+coedge $-1 -1 -1 $-1 $9851 $9852 $9853 $9854 forward $7783 $-1 #
+coedge $-1 -1 -1 $-1 $9610 $7784 $9855 $9856 reversed $6842 $-1 #
+coedge $-1 -1 -1 $-1 $7784 $9610 $9606 $9857 forward $6842 $-1 #
+coedge $-1 -1 -1 $-1 $9858 $9859 $7784 $8773 reversed $9723 $-1 #
+edge $-1 -1 -1 $-1 $9860 1.5707963267948966 $9861 2.0943951023931953 $7784 $9862 forward @7 unknown T -10.000000000000002 -25 -40 -7.5000000000000027 -24.330127018922191 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -24.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $9863 $9864 $9865 $9774 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $8777 $8777 $8635 $9732 reversed $7795 $-1 #
+coedge $-1 -1 -1 $-1 $7796 $7796 $9866 $9867 forward $6862 $-1 #
+coedge $-1 -1 -1 $-1 $9868 $9869 $7796 $8780 reversed $7620 $-1 #
+edge $-1 -1 -1 $-1 $9870 -1.5707963267948966 $9871 1.5707963267948966 $7796 $9872 forward @7 unknown T -45 -24.999999999999996 -15.000000000000002 -40 -14.999999999999996 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $7798 $7797 $9873 $9874 reversed $5954 $-1 #
+coedge $-1 -1 -1 $-1 $9875 $9876 $7797 $8783 forward $9877 $-1 #
+edge $-1 -1 -1 $-1 $9878 1.5707963267948966 $8790 2.0943951023931948 $8782 $9879 forward @7 unknown T -7.5000000000000027 -25 -10 -5 -24.330127018922195 -7.5 #
+coedge $-1 -1 -1 $-1 $9880 $9881 $7798 $8785 reversed $9882 $-1 #
+edge $-1 -1 -1 $-1 $9883 -2.0943951023931957 $8789 -1.5707963267948966 $7798 $9884 forward @7 unknown T -10.000000000000002 -25 -12.500000000000004 -7.5000000000000009 -24.330127018922191 -10 #
+coedge $-1 -1 -1 $-1 $9885 $7799 $9886 $9887 reversed $8788 $-1 #
+coedge $-1 -1 -1 $-1 $7799 $9888 $9875 $9889 reversed $8788 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7799 $9890 T -15.000000000000002 -25 -10 -7.5000000000000009 -20 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $9891 $9892 #
+vertex $-1 -1 -1 $-1 $7800 $9893 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8684 $7803 $9894 $9895 reversed $7695 $-1 #
+coedge $-1 -1 -1 $-1 $8686 $9896 $7803 $8795 forward $9776 $-1 #
+edge $-1 -1 -1 $-1 $9897 -6.1232339957367648e-17 $7805 1.5707963267948966 $8794 $9898 forward @7 unknown T -8.8817841970012523e-16 -20 -15 4.9999999999999991 -15 -10 #
+coedge $-1 -1 -1 $-1 $7804 $8684 $8710 $9799 reversed $7695 $-1 #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 -10 #
+face $-1 -1 -1 $-1 $9193 $9899 $11 $-1 $3659 reversed single T 29.999999999999996 -10.000000000000004 5.0000000000000018 37.500000000000007 -4.9999999999999991 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $9900 $7807 T 29.999999999999996 -10.000000000000004 -9.9999999999999982 37.500000000000007 -4.9999999999999991 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $9901 $9902 $9903 $9904 reversed $7808 $-1 #
+coedge $-1 -1 -1 $-1 $9905 $7809 $9906 $9907 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $7809 $9908 $9909 $9910 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $9911 $8245 $7809 $8804 forward $9286 $-1 #
+edge $-1 -1 -1 $-1 $9287 -1.5707963267948966 $9912 -4.7167471186270745e-16 $8803 $9913 forward @7 unknown T 29.999999999999996 -4.9999999999999991 -24.999999999999996 35 -1.7763568394002505e-15 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $9914 $7810 $9915 $9916 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $9917 $9918 $7810 $8807 forward $9919 $-1 #
+edge $-1 -1 -1 $-1 $9920 -2.0943951023931957 $8814 -1.5707963267948966 $8806 $9921 forward @7 unknown T 35 -0.6698729810778099 -9.9999999999999982 37.5 -1.7763568394002505e-15 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $7811 $9914 $7821 $8832 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $9922 $9923 $9924 $8810 forward $9925 $-1 #
+edge $-1 -1 -1 $-1 $8815 -4.9999999999999982 $9926 1.7763568394002505e-15 $8809 $9927 forward @7 unknown T 29.999999999999996 -5.0000000000000009 -4.9999999999999982 30 -4.9999999999999991 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $9928 $7812 $9923 $9929 reversed $8813 $-1 #
+coedge $-1 -1 -1 $-1 $7812 $9928 $9908 $9930 forward $8813 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7812 $9931 T 25 -5 -15 35 8.8817841970012523e-16 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $9930 $9932 #
+vertex $-1 -1 -1 $-1 $9933 $9934 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7817 $7814 $7826 $8838 reversed $5066 $-1 #
+coedge $-1 -1 -1 $-1 $9935 $9936 $7814 $8819 forward $8452 $-1 #
+edge $-1 -1 -1 $-1 $9937 -17.500000000000007 $8823 -7.5000000000000098 $8818 $9938 forward @7 unknown T 37.499999999999993 -0.66987298107780979 7.5000000000000098 37.500000000000007 -0.66987298107780613 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $9939 $7815 $9914 $9940 forward $8822 $-1 #
+coedge $-1 -1 -1 $-1 $7815 $9939 $9935 $9941 reversed $8822 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7815 $9942 T 35 -0.66987298107781257 2.5000000000000053 40.000000000000007 8.8817841970012523e-16 7.5000000000000098 unknown #
+vertex $-1 -1 -1 $-1 $9941 $9943 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9944 $7818 $7834 $8843 forward $8495 $-1 #
+coedge $-1 -1 -1 $-1 $7818 $9945 $7820 $8831 forward $8495 $-1 #
+coedge $-1 -1 -1 $-1 $9946 $9947 $9948 $7819 reversed $9949 $-1 #
+vertex $-1 -1 -1 $-1 $8843 $9950 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $7821 $7820 $9922 $9951 reversed $7822 $-1 #
+edge $-1 -1 -1 $-1 $9952 1.570796326794897 $7824 3.1415926535897931 $8826 $9953 forward @7 unknown T 25 -4.9999999999999991 5.0000000000000018 29.999999999999996 0 10.000000000000002 #
+edge $-1 -1 -1 $-1 $9926 2.9403902792268224e-16 $7823 1.5707963267948966 $7821 $9954 forward @7 unknown T 29.999999999999996 -5 1.7763568394002505e-15 35 -1.7763568394002505e-15 5.0000000000000018 #
+face $-1 -1 -1 $-1 $9955 $7822 $11 $-1 $9956 reversed single T 25 -5 1.7763568394002505e-15 35 0 10.000000000000002 F #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $7824 3.1415926535897931 $9957 4.7123889803846897 $9946 $9953 forward @7 unknown T 24.999999999999996 -10 5.0000000000000018 29.999999999999996 -4.9999999999999991 10.000000000000002 #
+point $-1 -1 -1 $-1 29.999999999999996 -4.9999999999999991 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $7827 $7826 $9936 $9958 reversed $7828 $-1 #
+edge $-1 -1 -1 $-1 $6885 1.5707963267948966 $9937 2.0943951023931939 $7826 $9959 forward @7 unknown T 35 -0.66987298107780613 17.500000000000007 37.499999999999993 -1.7763568394002505e-15 20.000000000000004 #
+edge $-1 -1 -1 $-1 $7829 4.1887902047863896 $9960 4.7123889803846897 $8175 $9961 forward @7 unknown T 37.5 -0.66987298107781124 20.000000000000004 40.000000000000007 0 22.500000000000011 #
+face $-1 -1 -1 $-1 $9962 $7828 $11 $-1 $8848 reversed single T 35 -0.66987298107781124 17.500000000000004 40.000000000000007 0 22.500000000000011 F #
+point $-1 -1 -1 $-1 37.5 -0.66987298107781124 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $9274 $7832 $9963 $7839 forward $7276 $-1 #
+edge $-1 -1 -1 $-1 $8828 0 $8844 1.5707963267948961 $8825 $9964 forward @7 unknown T 25 -5 15 29.999999999999996 0 20 #
+vertex $-1 -1 -1 $-1 $9965 $9966 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9967 $9968 $11 $-1 $8848 reversed single T 25 -10.000000000000002 15 35 -4.9999999999999991 25.000000000000007 F #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 -5 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $9969 $9970 #
+loop $-1 -1 -1 $-1 $-1 $8689 $7841 T -7.5000000000000036 -20 5 0 -15 20 unknown #
+loop $-1 -1 -1 $-1 $-1 $8636 $6888 T -50 -25 -3.0616169978683823e-15 -50 -15 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $9971 $9971 $9972 $9973 forward $7842 $-1 #
+coedge $-1 -1 -1 $-1 $9974 $7843 $9975 $9976 reversed $6889 $-1 #
+coedge $-1 -1 -1 $-1 $7843 $9974 $9888 $9977 forward $6889 $-1 #
+coedge $-1 -1 -1 $-1 $9978 $9653 $7843 $8856 reversed $9655 $-1 #
+edge $-1 -1 -1 $-1 $9979 1.5707963267948966 $9980 2.0943951023931957 $7843 $9981 forward @7 unknown T -10.000000000000002 -25 4.9999999999999991 -7.5000000000000009 -24.330127018922191 7.5000000000000027 #
+point $-1 -1 -1 $-1 -22.500000000000004 -30.669872981077805 7.5000000000000027 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 4.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 4.9999999999999982 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8673 $7861 $11 $-1 $3872 reversed single T -30.000000000000007 -35 4.9999999999999982 -22.5 -30 20 F #
+vertex $-1 -1 -1 $-1 $7864 $9982 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 20 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8861 $7868 $11 $-1 $3872 reversed single T -30.000000000000004 -35 20 -22.5 -30 35 F #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 20 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 20 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 35 #
+point $-1 -1 -1 $-1 -50 50 -50 #
+point $-1 -1 -1 $-1 -50 -50 -50 #
+coedge $-1 -1 -1 $-1 $9983 $7901 $9984 $8915 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $9985 $9986 $7901 $8879 reversed $9987 $-1 #
+edge $-1 -1 -1 $-1 $7944 2.617993877991494 $7928 4.7123889803846897 $7901 $9988 forward @7 unknown T 1.7763568394002505e-15 35 50 7.5000000000000036 40 50 #
+coedge $-1 -1 -1 $-1 $7902 $9989 $9985 $8935 forward $7954 $-1 #
+coedge $-1 -1 -1 $-1 $8882 $7903 $9990 $8961 reversed $7905 $-1 #
+coedge $-1 -1 -1 $-1 $7904 $8881 $9991 $9992 reversed $7905 $-1 #
+face $-1 -1 -1 $-1 $7013 $7905 $11 $-1 $7943 reversed single T 15 35 35 22.500000000000007 40 50 F #
+coedge $-1 -1 -1 $-1 $9993 $9990 $7907 $8885 reversed $9994 $-1 #
+edge $-1 -1 -1 $-1 $7960 1.5707963267948966 $7967 2.0943951023931939 $7907 $7948 forward @7 unknown T 22.500000000000007 35 35 25 35.669872981077802 37.5 #
+coedge $-1 -1 -1 $-1 $7908 $7917 $9995 $9996 forward $7918 $-1 #
+vertex $-1 -1 -1 $-1 $9997 $9998 #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8943 $7910 $9999 $9997 forward $8890 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7910 $8950 T 25 35 30 35 40 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 0.70710678118654724 0 0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+coedge $-1 -1 -1 $-1 $7912 $7912 $10000 $10001 reversed $8893 $-1 #
+loop $-1 -1 -1 $-1 $10002 $8892 $10003 T 40 35 30 45 45 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10004 $10000 $7914 $8896 forward $8902 $-1 #
+edge $-1 -1 -1 $-1 $7915 -1.5707963267948966 $8955 -1.0471975511965979 $8895 $10005 forward @7 unknown T 37.5 44.330127018922191 32.5 40 45 35 #
+point $-1 -1 -1 $-1 40 45 35 #
+coedge $-1 -1 -1 $-1 $10000 $10006 $7917 $8899 forward $8902 $-1 #
+edge $-1 -1 -1 $-1 $10007 1.0471975511965979 $7919 1.5707963267948966 $8898 $10005 forward @7 unknown T 37.5 35 32.5 40 35.669872981077816 35 #
+face $-1 -1 -1 $-1 $7963 $7918 $11 $-1 $8951 reversed single T 35 35 32.5 40 35.669872981077816 37.5 F #
+point $-1 -1 -1 $-1 40 35 35 #
+loop $-1 -1 -1 $-1 $-1 $10004 $7921 T 37.5 35 20.000000000000004 45 45 35 unknown #
+coedge $-1 -1 -1 $-1 $7922 $10008 $10009 $10010 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $10011 $10012 $7922 $8905 reversed $10013 $-1 #
+edge $-1 -1 -1 $-1 $10014 -1.5707963267948966 $8909 0.52359877559829893 $7922 $10015 forward @7 unknown T -15 40 50 -7.4999999999999982 45 50 #
+coedge $-1 -1 -1 $-1 $10016 $7923 $10012 $10017 forward $8908 $-1 #
+coedge $-1 -1 -1 $-1 $7923 $10018 $10019 $8912 forward $8908 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8907 $10020 T -7.5000000000000018 40 35 1.7763568394002505e-15 45 50 unknown #
+vertex $-1 -1 -1 $-1 $7924 $10021 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8913 $7925 $10022 $10023 reversed $7927 $-1 #
+edge $-1 -1 -1 $-1 $10024 40 $7928 50 $8907 $10025 forward @7 unknown T 0 40 40 1.7763568394002505e-15 40 50 #
+coedge $-1 -1 -1 $-1 $7926 $8911 $10026 $10027 reversed $7927 $-1 #
+face $-1 -1 -1 $-1 $10028 $7927 $11 $-1 $10029 reversed single T 0 40 35 7.5000000000000027 45 50 F #
+edge $-1 -1 -1 $-1 $7928 0 $10030 2.0943951023931957 $8877 $8910 forward @7 unknown T -7.5000000000000009 35 50 1.7763568394002505e-15 40 50 #
+point $-1 -1 -1 $-1 1.7763568394002505e-15 40 50 #
+coedge $-1 -1 -1 $-1 $10026 $10031 $7930 $8918 reversed $10032 $-1 #
+edge $-1 -1 -1 $-1 $8919 4.1887902047863914 $10033 4.7123889803846897 $7930 $10034 forward @7 unknown T 7.5000000000000018 44.330127018922191 35 10 45 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $8918 $10035 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10036 $7936 $7932 $8922 reversed $8926 $-1 #
+edge $-1 -1 -1 $-1 $10033 1.5707963267948966 $7938 3.1415926535897931 $7932 $10037 forward @7 unknown T 10 40 35 15 45 40 #
+coedge $-1 -1 -1 $-1 $9989 $7933 $10038 $8929 forward $7954 $-1 #
+face $-1 -1 -1 $-1 $10039 $10040 $11 $-1 $10041 reversed single T -7.5000000000000009 35 35 1.7763568394002505e-15 40 50 F #
+coedge $-1 -1 -1 $-1 $7936 $10036 $10042 $10043 forward $8926 $-1 #
+loop $-1 -1 -1 $-1 $-1 $7936 $8944 T 10 40 30 20.000000000000004 45 40 unknown #
+vertex $-1 -1 -1 $-1 $10043 $10044 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $7938 3.1415926535897931 $10045 4.7123889803846897 $8923 $10037 forward @7 unknown T 10 35 35 15 40 40 #
+point $-1 -1 -1 $-1 15 40 40 #
+coedge $-1 -1 -1 $-1 $7945 $7940 $10046 $10047 forward $7946 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10048 $10049 $11 $-1 $7943 reversed single T 15 40 -40 22.500000000000011 45 -25 F #
+loop $-1 -1 -1 $-1 $-1 $10050 $7942 T 15 40 -50 22.500000000000004 45 -40 unknown #
+edge $-1 -1 -1 $-1 $10051 37.500000000000007 $7944 50 $8880 $10052 forward @7 unknown T 7.5000000000000018 35.669872981077809 37.500000000000007 7.5000000000000018 35.669872981077809 50 #
+point $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $10053 $8941 $7945 $8938 forward $8945 $-1 #
+edge $-1 -1 -1 $-1 $7947 -1.5707963267948966 $10054 -1.0471975511965965 $8937 $10055 forward @7 unknown T 22.499999999999993 44.330127018922184 32.499999999999993 25 45 35 #
+face $-1 -1 -1 $-1 $10056 $7946 $11 $-1 $8951 reversed single T 20.000000000000004 44.330127018922184 32.499999999999993 25 45 37.5 F #
+point $-1 -1 -1 $-1 25 45 35 #
+coedge $-1 -1 -1 $-1 $8937 $10057 $7950 $8942 forward $8945 $-1 #
+edge $-1 -1 -1 $-1 $8948 0 $7947 1.5707963267948966 $8941 $10058 forward @7 unknown T 25 40 30 30 45 35 #
+coedge $-1 -1 -1 $-1 $7952 $8889 $10059 $10060 reversed $8890 $-1 #
+face $-1 -1 -1 $-1 $10061 $8926 $11 $-1 $8951 reversed single T 10 40 30 20.000000000000004 45 40 F #
+loop $-1 -1 -1 $-1 $-1 $10057 $7953 T 22.499999999999993 40 20 30 45 35 unknown #
+coedge $-1 -1 -1 $-1 $10062 $7956 $10057 $10063 reversed $8947 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10062 $10064 T 29.999999999999996 40 20.000000000000004 37.500000000000007 45 35 unknown #
+vertex $-1 -1 -1 $-1 $8942 $10065 #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8900 $8890 $11 $-1 $8951 reversed single T 25 35 30 35 40 40 F #
+cone-surface $-1 -1 -1 $-1 -2.1431318985078679e-15 40 35 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $10066 1.0471975511965974 $7960 1.5707963267948966 $10067 $10055 forward @7 unknown T 22.5 35 32.5 25 35.669872981077809 35 #
+point $-1 -1 -1 $-1 25 35 35 #
+coedge $-1 -1 -1 $-1 $7961 $10068 $10004 $10069 reversed $8947 $-1 #
+vertex $-1 -1 -1 $-1 $10069 $10070 #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+face $-1 -1 -1 $-1 $8301 $10071 $11 $-1 $7024 reversed single T 22.499999999999993 35 19.999999999999996 30 40 35 F #
+loop $-1 -1 -1 $-1 $-1 $10072 $7964 T 29.999999999999996 35 -40 37.500000000000007 40 -24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $10073 $10074 $10075 $10076 reversed $7965 $-1 #
+coedge $-1 -1 -1 $-1 $8318 $7966 $10077 $10078 reversed $7036 $-1 #
+edge $-1 -1 -1 $-1 $10079 1.5707963267948966 $7967 2.0943951023931948 $9990 $10080 forward @7 unknown T 20.000000000000004 35 35 22.500000000000007 35.669872981077809 37.5 #
+point $-1 -1 -1 $-1 22.500000000000007 35.669872981077802 37.5 #
+coedge $-1 -1 -1 $-1 $10081 $7969 $10082 $10083 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $8999 $10084 $7969 $8007 reversed $9020 $-1 #
+coedge $-1 -1 -1 $-1 $10085 $7970 $7972 $8027 reversed $8967 $-1 #
+coedge $-1 -1 -1 $-1 $7970 $10086 $7063 $8004 forward $8967 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8966 $10087 T 0 20 35 7.5000000000000062 25 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $7972 $8015 $10088 $10089 forward $7092 $-1 #
+coedge $-1 -1 -1 $-1 $7976 $10090 $7973 $8053 forward $8974 $-1 #
+coedge $-1 -1 -1 $-1 $10091 $9018 $7974 $8972 forward $10092 $-1 #
+edge $-1 -1 -1 $-1 $7076 6.1232339957367648e-17 $9059 1.5707963267948966 $8971 $10093 forward @7 unknown T 15 20 35 20 25 40 #
+coedge $-1 -1 -1 $-1 $10090 $7976 $9047 $8044 reversed $8974 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8970 $10094 T 20 20 32.5 25 20.669872981077813 37.5 unknown #
+coedge $-1 -1 -1 $-1 $10095 $8979 $7978 $8976 reversed $10096 $-1 #
+edge $-1 -1 -1 $-1 $8987 -2.0943951023931957 $7979 -1.5707963267948966 $7978 $10097 forward @7 unknown T 35 19.999999999999996 32.5 37.500000000000007 20.669872981077805 35 #
+edge $-1 -1 -1 $-1 $7979 -1.5707963267948966 $8040 6.4931039580273265e-16 $7981 $10098 forward @7 unknown T 30 19.999999999999996 30 35 25 35 #
+point $-1 -1 -1 $-1 35 19.999999999999996 35 #
+coedge $-1 -1 -1 $-1 $8975 $10099 $7981 $8977 reversed $10096 $-1 #
+coedge $-1 -1 -1 $-1 $7987 $7990 $7984 $8981 forward $7994 $-1 #
+edge $-1 -1 -1 $-1 $7057 -1.5707963267948966 $7053 1.5707963267948966 $8980 $10100 forward @7 unknown T 40 20 30 45 30 35 #
+loop $-1 -1 -1 $-1 $-1 $10101 $8983 T 50 20 30 50 30 40 unknown #
+face $-1 -1 -1 $-1 $10102 $7985 $11 $-1 $8043 reversed single T 40 20 30 50 30 40 F #
+coedge $-1 -1 -1 $-1 $10103 $7987 $8046 $9049 forward $7994 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $7990 $10104 $10095 $10105 forward $7994 $-1 #
+vertex $-1 -1 -1 $-1 $7991 $10106 #
+coedge $-1 -1 -1 $-1 $7995 $10107 $10108 $10109 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $10110 $10111 $7995 $8990 reversed $10112 $-1 #
+edge $-1 -1 -1 $-1 $10113 -2.0943951023931948 $8994 0 $7995 $10114 forward @7 unknown T -22.5 25 50 -15 30 50 #
+coedge $-1 -1 -1 $-1 $10115 $7996 $10111 $10116 reversed $8993 $-1 #
+coedge $-1 -1 -1 $-1 $7996 $10117 $7998 $8997 reversed $8993 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8992 $10118 T -15 25 35 -7.4999999999999964 30 50 unknown #
+vertex $-1 -1 -1 $-1 $10119 $10120 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8998 $7998 $10121 $10122 forward $8000 $-1 #
+edge $-1 -1 -1 $-1 $8001 -50 $10123 -37.5 $7998 $10124 forward @7 unknown T -7.4999999999999991 29.330127018922191 37.5 -7.4999999999999964 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $7999 $8996 $10125 $10126 forward $8000 $-1 #
+coedge $-1 -1 -1 $-1 $10127 $8964 $8966 $8004 reversed $9020 $-1 #
+face $-1 -1 -1 $-1 $10128 $8000 $11 $-1 $9021 reversed single T -7.4999999999999991 25 35 8.8817841970012523e-16 30 50 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $10125 $10129 $8003 $9003 forward $10130 $-1 #
+edge $-1 -1 -1 $-1 $10131 -1.5707963267948966 $9004 6.1232339957367648e-17 $9002 $10132 forward @7 unknown T 0 25 35 5.0000000000000018 30 40 #
+vertex $-1 -1 -1 $-1 $10133 $10134 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10135 $8009 $8005 $9007 forward $9012 $-1 #
+edge $-1 -1 -1 $-1 $8011 -2.0943951023931948 $10131 -1.5707963267948966 $9006 $10136 forward @7 unknown T 5.0000000000000018 29.330127018922195 35 7.5000000000000027 30 37.500000000000007 #
+face $-1 -1 -1 $-1 $10137 $10138 $11 $-1 $9009 reversed single T 0 25 -50 7.5000000000000009 30 -40 F #
+cone-surface $-1 -1 -1 $-1 5.0000000000000018 25 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $10139 $10140 #
+coedge $-1 -1 -1 $-1 $8009 $10135 $10141 $10142 reversed $9012 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9006 $10143 T 5.0000000000000018 29.330127018922191 32.5 10 30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $10142 $10144 #
+ellipse-curve $-1 -1 -1 $-1 10 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000027 29.330127018922202 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $8017 $8013 $10145 $10146 reversed $8018 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8971 $10147 $8015 $8021 reversed $10092 $-1 #
+face $-1 -1 -1 $-1 $10148 $10149 $11 $-1 $7093 reversed single T 7.4999999999999991 25 20 15 30 35 F #
+loop $-1 -1 -1 $-1 $-1 $8999 $8016 T -7.5 20 35 8.8817841970012523e-16 25 50 unknown #
+cone-surface $-1 -1 -1 $-1 -5 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $10150 $9026 $8017 $9023 reversed $10151 $-1 #
+edge $-1 -1 -1 $-1 $10152 -6.1232339957367648e-17 $8019 1.5707963267948966 $8017 $10153 forward @7 unknown T 15 25 30 20 30 35 #
+point $-1 -1 -1 $-1 20 30 35 #
+vertex $-1 -1 -1 $-1 $10154 $10155 #
+coedge $-1 -1 -1 $-1 $9022 $10156 $8023 $9027 reversed $10151 $-1 #
+edge $-1 -1 -1 $-1 $8019 1.5707963267948966 $9034 2.0943951023931957 $8023 $10157 forward @7 unknown T 20 29.330127018922191 32.5 22.5 30 35 #
+face $-1 -1 -1 $-1 $8352 $10158 $11 $-1 $7081 reversed single T 15 20 -40 22.500000000000004 25 -25 F #
+loop $-1 -1 -1 $-1 $-1 $10159 $8025 T 15 25 -40 22.500000000000004 30 -25 unknown #
+coedge $-1 -1 -1 $-1 $10160 $8328 $8330 $8375 reversed $8026 $-1 #
+vertex $-1 -1 -1 $-1 $10161 $10162 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10163 $8029 $10156 $10164 forward $8037 $-1 #
+vertex $-1 -1 -1 $-1 $10164 $10165 #
+ellipse-curve $-1 -1 -1 $-1 25 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7372 $10166 $11 $-1 $7093 reversed single T 7.4999999999999956 20 20 15 25 35 F #
+coedge $-1 -1 -1 $-1 $8033 $10167 $10168 $9043 forward $8037 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10168 $9047 $8035 $9040 forward $9051 $-1 #
+edge $-1 -1 -1 $-1 $7098 -1.5707963267948966 $8040 0 $9039 $9038 forward @7 unknown T 25 20 30 30 25 35 #
+face $-1 -1 -1 $-1 $10094 $10092 $11 $-1 $8043 reversed single T 10 20 30 20 25 40 F #
+coedge $-1 -1 -1 $-1 $9048 $8038 $10169 $10170 reversed $8039 $-1 #
+edge $-1 -1 -1 $-1 $10171 25 $8040 30 $9037 $10172 forward @7 unknown T 29.999999999999996 25 25 30 25 30 #
+face $-1 -1 -1 $-1 $10173 $8039 $11 $-1 $5288 reversed single T 29.999999999999996 25 20.000000000000004 37.500000000000007 29.999999999999996 35 F #
+point $-1 -1 -1 $-1 30 25 30 #
+vertex $-1 -1 -1 $-1 $8044 $10174 #
+coedge $-1 -1 -1 $-1 $9039 $10175 $8973 $8044 forward $9051 $-1 #
+coedge $-1 -1 -1 $-1 $8046 $9042 $10176 $10177 reversed $8039 $-1 #
+edge $-1 -1 -1 $-1 $8047 -32.499999999999993 $10178 -22.500000000000011 $8984 $10179 forward @7 unknown T 37.499999999999986 29.330127018922187 22.500000000000011 37.500000000000007 29.330127018922195 32.499999999999993 #
+point $-1 -1 -1 $-1 37.499999999999986 29.330127018922187 32.499999999999993 #
+loop $-1 -1 -1 $-1 $-1 $10168 $8049 T 22.499999999999993 20 19.999999999999996 30 25 35 unknown #
+coedge $-1 -1 -1 $-1 $9434 $10180 $8371 $9444 reversed $8050 $-1 #
+coedge $-1 -1 -1 $-1 $10181 $8051 $9438 $10182 reversed $7103 $-1 #
+coedge $-1 -1 -1 $-1 $8051 $10183 $10184 $10185 reversed $7103 $-1 #
+coedge $-1 -1 -1 $-1 $10186 $10187 $10188 $9056 forward $10189 $-1 #
+edge $-1 -1 -1 $-1 $10190 -35 $10191 -30 $9055 $10192 forward @7 unknown T 29.999999999999996 25 -35 30 25 -30 #
+coedge $-1 -1 -1 $-1 $8335 $10193 $8052 $9058 forward $9399 $-1 #
+edge $-1 -1 -1 $-1 $9441 1.5707963267948966 $8337 2.0943951023931939 $9057 $10194 forward @7 unknown T 35 29.330127018922187 -42.5 37.499999999999993 29.999999999999996 -40 #
+vertex $-1 -1 -1 $-1 $10195 $10196 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10197 $8055 $10198 $9099 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $10199 $10200 $8055 $9063 reversed $10201 $-1 #
+edge $-1 -1 -1 $-1 $8102 2.617993877991494 $8086 4.7123889803846897 $8055 $10202 forward @7 unknown T -15 5 50 -7.4999999999999991 10 50 #
+coedge $-1 -1 -1 $-1 $8056 $10203 $10199 $9119 forward $8112 $-1 #
+coedge $-1 -1 -1 $-1 $9066 $8057 $10204 $9141 reversed $8059 $-1 #
+coedge $-1 -1 -1 $-1 $8058 $9065 $10205 $10206 reversed $8059 $-1 #
+face $-1 -1 -1 $-1 $7144 $8059 $11 $-1 $8101 reversed single T 0 4.9999999999999991 35 7.5000000000000018 10 50 F #
+coedge $-1 -1 -1 $-1 $10207 $10204 $8061 $9069 reversed $10208 $-1 #
+edge $-1 -1 -1 $-1 $8117 1.5707963267948966 $8123 2.0943951023931957 $8061 $8106 forward @7 unknown T 7.4999999999999991 5 35 10 5.669872981077809 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $8062 $8065 $10209 $10210 forward $8066 $-1 #
+coedge $-1 -1 -1 $-1 $9127 $8063 $10211 $9175 forward $9072 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8063 $8133 T 10 4.9999999999999982 30 20 10 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7169 $8066 $11 $-1 $7181 reversed single T 20 4.9999999999999982 32.5 25 5.6698729810778081 37.5 F #
+coedge $-1 -1 -1 $-1 $10212 $8067 $8078 $9085 reversed $9076 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10212 $10213 T 29.999999999999996 4.9999999999999982 20.000000000000004 37.500000000000007 10 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8071 $10214 $7176 $8135 forward $9076 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9081 $9081 $10215 $10216 reversed $8074 $-1 #
+face $-1 -1 -1 $-1 $10217 $10218 $11 $-1 $7181 reversed single T -10 5 32.5 -5 5.669872981077809 37.5 F #
+coedge $-1 -1 -1 $-1 $10219 $8076 $10220 $10221 forward $7132 $-1 #
+coedge $-1 -1 -1 $-1 $8078 $10219 $10222 $10223 forward $7132 $-1 #
+edge $-1 -1 -1 $-1 $10224 22.500000000000007 $8079 32.5 $8078 $10225 forward @7 unknown T 37.5 5.6698729810778064 22.500000000000007 37.500000000000007 5.6698729810778081 32.5 #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778064 32.5 #
+coedge $-1 -1 -1 $-1 $8080 $10226 $10227 $10228 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $10229 $10230 $8080 $9089 reversed $10231 $-1 #
+edge $-1 -1 -1 $-1 $10232 -1.570796326794897 $9093 0.52359877559829893 $8080 $10233 forward @7 unknown T -30 10 50 -22.5 15.000000000000002 50 #
+coedge $-1 -1 -1 $-1 $10234 $8081 $10230 $10235 forward $9092 $-1 #
+coedge $-1 -1 -1 $-1 $8081 $10236 $10237 $9096 forward $9092 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9091 $10238 T -22.5 10 35 -15 15 50 unknown #
+vertex $-1 -1 -1 $-1 $8082 $10239 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9097 $8083 $10240 $10241 reversed $8085 $-1 #
+edge $-1 -1 -1 $-1 $10242 40 $8086 50 $9091 $10243 forward @7 unknown T -15 10 40 -15 10 50 #
+coedge $-1 -1 -1 $-1 $8084 $9095 $10244 $10245 reversed $8085 $-1 #
+face $-1 -1 -1 $-1 $10246 $8085 $11 $-1 $10247 reversed single T -15 10 35 -7.4999999999999982 15 50 F #
+edge $-1 -1 -1 $-1 $8086 0 $10248 2.0943951023931957 $9061 $9094 forward @7 unknown T -22.5 5 50 -15 10 50 #
+point $-1 -1 -1 $-1 -15 10 50 #
+coedge $-1 -1 -1 $-1 $10244 $10249 $8088 $9102 reversed $10250 $-1 #
+edge $-1 -1 -1 $-1 $9103 4.1887902047863914 $10251 4.7123889803846897 $8088 $10252 forward @7 unknown T -7.4999999999999982 14.330127018922193 35 -5 15 37.5 #
+vertex $-1 -1 -1 $-1 $9102 $10253 #
+straight-curve $-1 -1 -1 $-1 -7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10254 $8094 $8090 $9106 reversed $9110 $-1 #
+edge $-1 -1 -1 $-1 $10251 1.5707963267948966 $8096 3.1415926535897931 $8090 $10255 forward @7 unknown T -5 10 35 0 15 40 #
+coedge $-1 -1 -1 $-1 $10203 $8091 $10256 $9113 forward $8112 $-1 #
+face $-1 -1 -1 $-1 $10257 $10258 $11 $-1 $10259 reversed single T 39.999999999999993 5 15.000000000000004 50 15 25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $8094 $10254 $10260 $10261 forward $9110 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8094 $9128 T -5 10 30 5.0000000000000009 15 40 unknown #
+vertex $-1 -1 -1 $-1 $10261 $10262 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8096 3.1415926535897931 $10263 4.7123889803846897 $9107 $10255 forward @7 unknown T -5 5 35 0 10 40 #
+point $-1 -1 -1 $-1 0 10 40 #
+coedge $-1 -1 -1 $-1 $8103 $8098 $10264 $10265 forward $8104 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10266 $10267 $11 $-1 $8101 reversed single T 0 10 -40 7.5000000000000027 15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $10268 $8100 T 0 10 -50 7.5000000000000053 15 -40 unknown #
+edge $-1 -1 -1 $-1 $10269 37.5 $8102 50 $9064 $10270 forward @7 unknown T -7.5 5.6698729810778064 37.5 -7.5 5.6698729810778072 50 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $10271 $9125 $8103 $9122 forward $9129 $-1 #
+edge $-1 -1 -1 $-1 $8105 -1.5707963267948966 $10272 -1.0471975511965987 $9121 $10273 forward @7 unknown T 7.5000000000000027 14.330127018922195 32.500000000000007 10 15 35 #
+face $-1 -1 -1 $-1 $10274 $8104 $11 $-1 $7181 reversed single T 5.0000000000000009 14.330127018922195 32.5 10 15 37.5 F #
+point $-1 -1 -1 $-1 10 15 35 #
+coedge $-1 -1 -1 $-1 $9121 $10275 $8108 $9126 forward $9129 $-1 #
+edge $-1 -1 -1 $-1 $9132 0 $8105 1.5707963267948966 $9125 $10276 forward @7 unknown T 10 10 30 15 15 35 #
+coedge $-1 -1 -1 $-1 $8110 $9071 $10277 $10278 reversed $9072 $-1 #
+face $-1 -1 -1 $-1 $10279 $9110 $11 $-1 $7181 reversed single T -5 10 30 5.0000000000000009 15 40 F #
+loop $-1 -1 -1 $-1 $-1 $10275 $8111 T 7.5 10 20 15 15 35 unknown #
+coedge $-1 -1 -1 $-1 $10280 $8114 $10275 $10281 reversed $9131 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10280 $10282 T 15 10 20 22.500000000000004 14.999999999999998 35 unknown #
+vertex $-1 -1 -1 $-1 $9126 $10283 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10284 1.0471975511965979 $8117 1.5707963267948966 $10285 $10273 forward @7 unknown T 7.5 5 32.5 10 5.6698729810778081 35 #
+point $-1 -1 -1 $-1 10 5 35 #
+coedge $-1 -1 -1 $-1 $8118 $10286 $8125 $9144 reversed $9131 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $10287 $8120 T 15 4.9999999999999982 -40 22.500000000000007 10 -25 unknown #
+coedge $-1 -1 -1 $-1 $10288 $10289 $10290 $10291 reversed $8121 $-1 #
+coedge $-1 -1 -1 $-1 $8406 $8122 $10292 $9519 reversed $7164 $-1 #
+edge $-1 -1 -1 $-1 $10293 1.5707963267948966 $8123 2.0943951023931957 $10204 $10294 forward @7 unknown T 5.0000000000000009 4.9999999999999991 35 7.5000000000000018 5.6698729810778072 37.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $9147 $8125 $10295 $10296 forward $7175 $-1 #
+edge $-1 -1 -1 $-1 $8126 -32.5 $10297 -22.499999999999993 $8125 $10298 forward @7 unknown T 22.499999999999996 14.330127018922193 22.499999999999993 22.500000000000004 14.330127018922195 32.5 #
+point $-1 -1 -1 $-1 22.500000000000004 14.330127018922193 32.5 #
+loop $-1 -1 -1 $-1 $-1 $10299 $8128 T 7.4999999999999991 5 20 15 10 35 unknown #
+coedge $-1 -1 -1 $-1 $8129 $9143 $10300 $10301 forward $7175 $-1 #
+coedge $-1 -1 -1 $-1 $10302 $8131 $9079 $8135 reversed $8143 $-1 #
+coedge $-1 -1 -1 $-1 $10300 $10303 $8134 $9150 forward $10304 $-1 #
+edge $-1 -1 -1 $-1 $10305 -1.5707963267948966 $9151 -2.9403902792268244e-16 $9149 $10306 forward @7 unknown T 29.999999999999996 10 20.000000000000004 35 14.999999999999998 25.000000000000007 #
+vertex $-1 -1 -1 $-1 $10307 $10308 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $10309 $10310 $11 $-1 $4445 reversed single T 29.999999999999996 10 5.0000000000000018 37.500000000000007 15 20.000000000000004 F #
+point $-1 -1 -1 $-1 22.500000000000004 5.6698729810778064 32.5 #
+coedge $-1 -1 -1 $-1 $8139 $10311 $10312 $10313 forward $8143 $-1 #
+coedge $-1 -1 -1 $-1 $10314 $10220 $8140 $9157 forward $10315 $-1 #
+edge $-1 -1 -1 $-1 $9158 -2.0943951023931953 $10305 -1.5707963267948966 $9156 $10316 forward @7 unknown T 35 14.330127018922186 20.000000000000004 37.5 14.999999999999998 22.500000000000007 #
+vertex $-1 -1 -1 $-1 $10221 $10317 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $8144 $10318 $10319 $10320 reversed $7188 $-1 #
+coedge $-1 -1 -1 $-1 $10321 $8145 $9173 $10322 reversed $6241 $-1 #
+edge $-1 -1 -1 $-1 $8429 -1.5707963267948966 $9170 -2.9403902792268234e-16 $8426 $10323 forward @7 unknown T 30 10 -40 35 14.999999999999998 -35 #
+coedge $-1 -1 -1 $-1 $8146 $10321 $10324 $10325 reversed $6241 $-1 #
+coedge $-1 -1 -1 $-1 $10326 $10327 $8146 $9165 forward $10328 $-1 #
+edge $-1 -1 -1 $-1 $9171 2.9403902792268214e-16 $10329 1.5707963267948966 $9164 $10330 forward @7 unknown T 29.999999999999996 10 -30 35 14.999999999999998 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $10331 $8147 $10327 $10332 forward $9169 $-1 #
+coedge $-1 -1 -1 $-1 $8147 $10333 $9513 $10334 forward $9169 $-1 #
+coedge $-1 -1 -1 $-1 $9505 $10335 $9509 $8148 reversed $10336 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8147 $9518 T 22.499999999999996 10 -40 30 15 -25 unknown #
+vertex $-1 -1 -1 $-1 $9506 $10337 #
+vertex $-1 -1 -1 $-1 $10332 $10338 #
+coedge $-1 -1 -1 $-1 $8149 $8386 $9161 $10322 forward $8387 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8151 -1.5707963267948966 $9132 2.9403902792268234e-16 $9071 $10339 forward @7 unknown T 15 4.9999999999999982 30 20 10 35 #
+point $-1 -1 -1 $-1 20 4.9999999999999982 35 #
+coedge $-1 -1 -1 $-1 $10340 $8153 $10341 $10342 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $9214 $10343 $8153 $8191 reversed $10344 $-1 #
+coedge $-1 -1 -1 $-1 $10345 $8154 $8156 $8211 reversed $9181 $-1 #
+coedge $-1 -1 -1 $-1 $8154 $10346 $7221 $8188 forward $9181 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9179 $10347 T -15 -10 35 -7.5 -4.9999999999999991 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8156 $8199 $10348 $10349 forward $7250 $-1 #
+coedge $-1 -1 -1 $-1 $8160 $10350 $8157 $8232 forward $9188 $-1 #
+coedge $-1 -1 -1 $-1 $10351 $9233 $8158 $9186 forward $10352 $-1 #
+edge $-1 -1 -1 $-1 $7234 -1.1640334398265738e-16 $9267 1.5707963267948966 $9185 $10353 forward @7 unknown T -4.686749320818303e-33 -10 35 5 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $10350 $8160 $9259 $8225 reversed $9188 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9184 $10354 T 5 -10 32.5 10 -9.330127018922191 37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $9275 $9191 $8162 $9190 reversed $10355 $-1 #
+edge $-1 -1 -1 $-1 $7272 -2.0943951023931948 $7284 -1.5707963267948966 $8162 $10356 forward @7 unknown T 20 -10 32.5 22.500000000000004 -9.3301270189221945 35 #
+coedge $-1 -1 -1 $-1 $9189 $10357 $8163 $8256 reversed $10355 $-1 #
+coedge $-1 -1 -1 $-1 $9194 $8167 $10358 $10359 reversed $8168 $-1 #
+face $-1 -1 -1 $-1 $4454 $8168 $11 $-1 $3659 reversed single T 29.999999999999996 -10.000000000000002 20.000000000000004 37.500000000000007 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $8171 $9192 $10360 $10361 reversed $8168 $-1 #
+edge $-1 -1 -1 $-1 $10362 0 $10362 6.2831853071795862 $8655 $10363 forward @7 unknown T 50 -10 30 50 0 40 #
+face $-1 -1 -1 $-1 $7230 $10364 $11 $-1 $6317 reversed single T -50 -10 29.999999999999996 -40 2.6645352591003757e-15 40 F #
+loop $-1 -1 -1 $-1 $-1 $10365 $8174 T -10 -10 32.5 -5 -9.330127018922191 37.5 unknown #
+coedge $-1 -1 -1 $-1 $8176 $8175 $10366 $10367 forward $6270 $-1 #
+coedge $-1 -1 -1 $-1 $10368 $10358 $8176 $9200 reversed $10369 $-1 #
+edge $-1 -1 -1 $-1 $10370 1.570796326794897 $9201 2.0943951023931966 $8176 $9961 forward @7 unknown T 37.5 -10 20.000000000000004 40.000000000000007 -9.3301270189221892 22.500000000000007 #
+vertex $-1 -1 -1 $-1 $10359 $10371 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8179 $10340 $10372 $10373 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $10374 $10375 $8179 $9205 reversed $10376 $-1 #
+edge $-1 -1 -1 $-1 $10377 -2.0943951023931948 $9209 -1.7763568394002506e-16 $8179 $10378 forward @7 unknown T -37.5 -4.9999999999999991 50 -30 0 50 #
+coedge $-1 -1 -1 $-1 $10379 $8180 $10375 $10380 reversed $9208 $-1 #
+coedge $-1 -1 -1 $-1 $8180 $10381 $8182 $9212 reversed $9208 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9207 $10382 T -30 -4.9999999999999991 35 -22.5 1.7763568394002505e-15 50 unknown #
+vertex $-1 -1 -1 $-1 $10383 $10384 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9213 $8182 $10385 $10386 forward $8184 $-1 #
+edge $-1 -1 -1 $-1 $8185 -50 $10387 -37.500000000000007 $8182 $10388 forward @7 unknown T -22.5 -0.66987298107780657 37.500000000000007 -22.5 -0.66987298107780546 50 #
+coedge $-1 -1 -1 $-1 $8183 $9211 $10389 $10390 forward $8184 $-1 #
+coedge $-1 -1 -1 $-1 $10391 $9178 $9180 $8188 reversed $10344 $-1 #
+face $-1 -1 -1 $-1 $10392 $8184 $11 $-1 $10393 reversed single T -22.500000000000004 -5 35 -15 0 50 F #
+point $-1 -1 -1 $-1 -22.5 -0.66987298107780546 50 #
+coedge $-1 -1 -1 $-1 $10389 $10394 $8187 $9218 forward $10395 $-1 #
+edge $-1 -1 -1 $-1 $10396 -1.5707963267948966 $9219 6.1232339957367648e-17 $9217 $10397 forward @7 unknown T -15 -4.9999999999999991 35 -10 8.8817841970012523e-16 40 #
+vertex $-1 -1 -1 $-1 $10398 $10399 #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10400 $8193 $8189 $9222 forward $9227 $-1 #
+edge $-1 -1 -1 $-1 $8195 -2.0943951023931957 $10396 -1.5707963267948966 $9221 $10401 forward @7 unknown T -10 -0.66987298107780813 35 -7.4999999999999991 8.8817841970012523e-16 37.500000000000007 #
+face $-1 -1 -1 $-1 $10402 $10403 $11 $-1 $9224 reversed single T -15 -5 20 -7.4999999999999991 8.8817841970012523e-16 35 F #
+cone-surface $-1 -1 -1 $-1 -10 -4.9999999999999991 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $10404 $10405 #
+coedge $-1 -1 -1 $-1 $8193 $10400 $10406 $10407 reversed $9227 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9221 $10408 T -10 -0.66987298107780902 32.5 -5 8.8817841970012523e-16 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $10407 $10409 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780657 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $8201 $8197 $10410 $10411 reversed $8202 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9185 $10412 $8199 $8205 reversed $10352 $-1 #
+face $-1 -1 -1 $-1 $10413 $10414 $11 $-1 $8848 reversed single T -10 -10 17.499999999999996 -5 -9.330127018922191 22.5 F #
+loop $-1 -1 -1 $-1 $10415 $10416 $8200 T 39.999999999999993 -10 15.000000000000004 45.000000000000007 0 25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $10417 $9240 $8201 $9237 reversed $10418 $-1 #
+edge $-1 -1 -1 $-1 $10419 -6.1232339957367648e-17 $8203 1.5707963267948966 $8201 $10420 forward @7 unknown T -9.3734986416366059e-33 -5 30 5 0 35 #
+point $-1 -1 -1 $-1 5 0 35 #
+vertex $-1 -1 -1 $-1 $10421 $10422 #
+coedge $-1 -1 -1 $-1 $9236 $10423 $8207 $9241 reversed $10418 $-1 #
+edge $-1 -1 -1 $-1 $8203 1.5707963267948966 $9248 2.0943951023931957 $8207 $10424 forward @7 unknown T 5 -0.66987298107780902 32.5 7.5000000000000018 0 35 #
+face $-1 -1 -1 $-1 $8465 $10425 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 -40 7.5000000000000018 -4.9999999999999991 -25 F #
+loop $-1 -1 -1 $-1 $-1 $10426 $8209 T -9.3734986416366059e-33 -5 -40 7.5000000000000018 0 -25 unknown #
+coedge $-1 -1 -1 $-1 $10427 $8437 $8439 $8486 reversed $8210 $-1 #
+vertex $-1 -1 -1 $-1 $10428 $10429 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10430 $8213 $10423 $10431 forward $8221 $-1 #
+vertex $-1 -1 -1 $-1 $10431 $10432 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $7460 $10433 $11 $-1 $7251 reversed single T -7.5000000000000018 -10 20 0 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $8217 $10434 $9273 $9256 forward $8221 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9273 $9259 $8219 $9254 forward $8237 $-1 #
+edge $-1 -1 -1 $-1 $7255 -1.5707963267948966 $8223 0 $9253 $9252 forward @7 unknown T 10 -10 30 15 -5 35 #
+face $-1 -1 -1 $-1 $10354 $10352 $11 $-1 $6317 reversed single T -5 -10 30 5 -4.9999999999999991 40 F #
+edge $-1 -1 -1 $-1 $10435 25 $8223 30 $9251 $10436 forward @7 unknown T 15 -5 25 15 -4.9999999999999991 30 #
+point $-1 -1 -1 $-1 15 -5 30 #
+vertex $-1 -1 -1 $-1 $8225 $10437 #
+coedge $-1 -1 -1 $-1 $9253 $10438 $9187 $8225 forward $8237 $-1 #
+coedge $-1 -1 -1 $-1 $8227 $8744 $10439 $10440 reversed $7750 $-1 #
+coedge $-1 -1 -1 $-1 $9566 $10441 $8484 $9576 reversed $8229 $-1 #
+coedge $-1 -1 -1 $-1 $10442 $8230 $9570 $10443 reversed $7259 $-1 #
+coedge $-1 -1 -1 $-1 $8230 $10444 $10445 $10446 reversed $7259 $-1 #
+coedge $-1 -1 -1 $-1 $10447 $10448 $10449 $9265 forward $10450 $-1 #
+edge $-1 -1 -1 $-1 $10451 -35 $10452 -30 $9264 $10453 forward @7 unknown T 15 -5 -35 15 -4.9999999999999991 -30 #
+coedge $-1 -1 -1 $-1 $8440 $10454 $8231 $8506 forward $9526 $-1 #
+vertex $-1 -1 -1 $-1 $10455 $10456 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10439 $10457 $8234 $9270 reversed $10458 $-1 #
+edge $-1 -1 -1 $-1 $9271 4.1887902047863905 $8844 4.7123889803846897 $8234 $10459 forward @7 unknown T 22.499999999999993 -0.66987298107780902 20 25 0 22.500000000000004 #
+vertex $-1 -1 -1 $-1 $9270 $10460 #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10461 $9253 $10357 $9256 reversed $8237 $-1 #
+coedge $-1 -1 -1 $-1 $8239 $8842 $10462 $10463 forward $7276 $-1 #
+coedge $-1 -1 -1 $-1 $10464 $9189 $8239 $9276 reversed $10355 $-1 #
+edge $-1 -1 -1 $-1 $10465 22.499999999999993 $7272 32.500000000000007 $8239 $10466 forward @7 unknown T 22.5 -9.3301270189221945 22.499999999999993 22.500000000000004 -9.3301270189221928 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $8241 $9586 $10467 $10468 reversed $6324 $-1 #
+coedge $-1 -1 -1 $-1 $10469 $8445 $8241 $9279 forward $9531 $-1 #
+edge $-1 -1 -1 $-1 $8503 -37.5 $10470 -27.499999999999986 $9278 $10471 forward @7 unknown T 37.5 -9.3301270189221963 -37.5 37.5 -9.3301270189221945 -27.499999999999986 #
+coedge $-1 -1 -1 $-1 $8244 $8242 $9533 $10472 reversed $5408 $-1 #
+edge $-1 -1 -1 $-1 $9534 -2.0943951023931957 $7487 -1.5707963267948966 $8254 $10473 forward @7 unknown T 35 -0.66987298107781079 -40 37.500000000000007 -1.7763568394002505e-15 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10474 $9906 $8244 $9284 forward $10475 $-1 #
+edge $-1 -1 -1 $-1 $9287 1.5707963267948966 $10476 2.0943951023931948 $9283 $10477 forward @7 unknown T 35 -0.66987298107780813 -27.499999999999993 37.5 -1.7763568394002505e-15 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $8245 $9911 $8247 $9290 reversed $9286 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8245 $10478 T 25 -5 -30 35 0 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $8246 $10479 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10480 $8247 $10481 $10482 forward $8250 $-1 #
+edge $-1 -1 -1 $-1 $8252 0 $10483 1.5707963267948961 $8247 $10484 forward @7 unknown T 25 -5 -30 29.999999999999996 0 -25 #
+coedge $-1 -1 -1 $-1 $8248 $10480 $9525 $10485 forward $8250 $-1 #
+edge $-1 -1 -1 $-1 $7489 1.5707963267948966 $8251 3.1415926535897931 $8248 $9583 forward @7 unknown T 25 -4.9999999999999991 -40 30 0 -35 #
+coedge $-1 -1 -1 $-1 $8249 $10486 $10487 $10488 forward $9294 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8249 $10489 T 22.5 -10 -40 30 -4.9999999999999991 -25 unknown #
+point $-1 -1 -1 $-1 30 -4.9999999999999991 -35 #
+point $-1 -1 -1 $-1 29.999999999999996 -5 -30 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8261 $8258 $9665 $9312 forward $1121 $-1 #
+coedge $-1 -1 -1 $-1 $10490 $10491 $8258 $9300 reversed $10492 $-1 #
+edge $-1 -1 -1 $-1 $8279 2.617993877991494 $8267 4.7123889803846897 $8258 $10493 forward @7 unknown T -30 -25 50 -22.5 -20 50 #
+coedge $-1 -1 -1 $-1 $8259 $8623 $10490 $9328 forward $8624 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $9668 2.617993877991494 $9306 6.8067840827778854 $8261 $10494 forward @7 unknown T -45 -24.999999999999996 50 -37.5 -14.999999999999996 50 #
+coedge $-1 -1 -1 $-1 $8262 $10495 $10496 $9309 forward $9305 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9304 $10497 T -37.5 -20 35 -30 -15 50 unknown #
+vertex $-1 -1 -1 $-1 $8263 $10498 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9310 $8264 $10499 $10500 reversed $8266 $-1 #
+edge $-1 -1 -1 $-1 $10501 40 $8267 50 $9304 $10502 forward @7 unknown T -30 -20 40 -30 -20 50 #
+coedge $-1 -1 -1 $-1 $8265 $9308 $10503 $10504 reversed $8266 $-1 #
+face $-1 -1 -1 $-1 $10505 $8266 $11 $-1 $7628 reversed single T -30 -20 35 -22.499999999999993 -15 50 F #
+edge $-1 -1 -1 $-1 $8267 0 $9668 2.0943951023931948 $9298 $9307 forward @7 unknown T -37.5 -25 50 -30 -20 50 #
+point $-1 -1 -1 $-1 -30 -20 50 #
+coedge $-1 -1 -1 $-1 $10503 $10506 $8269 $9315 reversed $10507 $-1 #
+edge $-1 -1 -1 $-1 $9316 4.1887902047863923 $8631 4.7123889803846897 $8269 $10508 forward @7 unknown T -22.499999999999993 -15.669872981077805 35 -20 -15 37.499999999999993 #
+vertex $-1 -1 -1 $-1 $9315 $10509 #
+straight-curve $-1 -1 -1 $-1 -22.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9729 $8275 $8271 $9319 reversed $9323 $-1 #
+edge $-1 -1 -1 $-1 $8631 1.5707963267948966 $6614 3.1415926535897931 $8271 $8626 forward @7 unknown T -20 -20 35 -15 -15 40 #
+face $-1 -1 -1 $-1 $10510 $9667 $11 $-1 $8642 reversed single T -37.5 -25 35 -30 -20 50 F #
+cone-surface $-1 -1 -1 $-1 -20 -20 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8275 $9729 $8617 $9709 forward $9323 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8275 $10511 T -20 -20 30 -10.000000000000002 -15 40 unknown #
+vertex $-1 -1 -1 $-1 $9709 $10512 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8280 $8277 $9708 $10513 forward $8281 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10514 37.500000000000007 $8279 50 $9301 $10515 forward @7 unknown T -22.500000000000004 -24.330127018922195 37.500000000000007 -22.5 -24.330127018922195 50 #
+point $-1 -1 -1 $-1 -22.5 -24.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $10516 $8568 $8280 $8570 forward $7558 $-1 #
+face $-1 -1 -1 $-1 $10511 $8281 $11 $-1 $1965 reversed single T -10.000000000000002 -15.669872981077809 32.5 -5 -15 37.5 F #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+loop $-1 -1 -1 $-1 $-1 $10517 $8285 T -8.8817841970012523e-16 -25 -40 7.5000000000000027 -20 -25 unknown #
+coedge $-1 -1 -1 $-1 $10518 $10519 $10520 $10521 reversed $8286 $-1 #
+coedge $-1 -1 -1 $-1 $8527 $8287 $10522 $9641 reversed $7313 $-1 #
+edge $-1 -1 -1 $-1 $8289 -1.5707963267948966 $8611 -6.1232339957367648e-17 $8610 $10523 forward @7 unknown T -8.8817841970012523e-16 -25 30 4.9999999999999991 -20 35 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 35 #
+straight-curve $-1 -1 -1 $-1 -50 0 -50 0 1 0 I I #
+coedge $-1 -1 -1 $-1 $10524 $8295 $10525 $9365 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $10050 $9361 $8295 $9341 reversed $8934 $-1 #
+edge $-1 -1 -1 $-1 $8326 -0.52359877559829826 $8309 1.5707963267948966 $8295 $10526 forward @7 unknown T 15.000000000000002 40 -50 22.5 45 -50 #
+coedge $-1 -1 -1 $-1 $8296 $10527 $10050 $9387 forward $9343 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8319 $9351 T 22.499999999999993 40 -50 30 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $8299 $8298 $10528 $10529 forward $7333 $-1 #
+coedge $-1 -1 -1 $-1 $8322 $10530 $8298 $9346 reversed $9384 $-1 #
+edge $-1 -1 -1 $-1 $8324 1.0471975511965961 $10531 1.5707963267948966 $8298 $10532 forward @7 unknown T 37.499999999999993 35 -42.500000000000014 40 35.669872981077816 -40 #
+coedge $-1 -1 -1 $-1 $10533 $10077 $8299 $9348 reversed $10534 $-1 #
+edge $-1 -1 -1 $-1 $10535 -1.5707963267948966 $9349 -1.0471975511965979 $8299 $10532 forward @7 unknown T 37.5 44.330127018922191 -42.5 40 45 -40 #
+vertex $-1 -1 -1 $-1 $10078 $10536 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $10537 $9343 $11 $-1 $7024 reversed single T 22.499999999999993 40 -50 30 45 -40 F #
+coedge $-1 -1 -1 $-1 $8303 $10538 $10539 $10540 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $10541 $10542 $8303 $9354 reversed $10543 $-1 #
+edge $-1 -1 -1 $-1 $10544 1.5707963267948966 $9358 3.6651914291880923 $8303 $10545 forward @7 unknown T 8.8817841970012523e-16 35 -50 7.5000000000000027 40 -50 #
+coedge $-1 -1 -1 $-1 $10546 $8304 $10542 $10547 forward $9357 $-1 #
+coedge $-1 -1 -1 $-1 $8304 $10548 $8306 $9362 reversed $9357 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9356 $10549 T 7.4999999999999991 35 -50 15.000000000000002 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $8305 $10550 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9363 $8306 $10551 $10552 reversed $8308 $-1 #
+coedge $-1 -1 -1 $-1 $9340 $10553 $10554 $9362 reversed $8934 $-1 #
+edge $-1 -1 -1 $-1 $8309 -50 $10555 -45 $10554 $10556 forward @7 unknown T 15 40 -50 15.000000000000002 40 -45 #
+coedge $-1 -1 -1 $-1 $8307 $9360 $10557 $10558 reversed $8308 $-1 #
+face $-1 -1 -1 $-1 $6110 $8308 $11 $-1 $7943 reversed single T 15 35 -50 22.5 40 -40 F #
+edge $-1 -1 -1 $-1 $8309 0 $10559 2.0943951023931957 $9339 $9359 forward @7 unknown T 7.4999999999999991 40 -50 15.000000000000002 45 -50 #
+point $-1 -1 -1 $-1 15.000000000000002 40 -50 #
+coedge $-1 -1 -1 $-1 $10557 $10560 $8311 $9368 reversed $10561 $-1 #
+edge $-1 -1 -1 $-1 $9369 1.0471975511965974 $10562 1.5707963267948966 $8311 $10563 forward @7 unknown T 22.5 35 -42.5 25 35.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $9368 $10564 #
+straight-curve $-1 -1 -1 $-1 22.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10565 $8316 $8313 $9372 reversed $9375 $-1 #
+edge $-1 -1 -1 $-1 $10562 -1.5707963267948966 $8320 0 $8313 $10566 forward @7 unknown T 25 35 -45 30 40 -40 #
+face $-1 -1 -1 $-1 $10567 $10568 $11 $-1 $7955 reversed single T 7.4999999999999991 40 -50 15.000000000000002 45 -40 F #
+coedge $-1 -1 -1 $-1 $8316 $10565 $10569 $10570 forward $9375 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8316 $10571 T 25 35 -45 35 40 -35 unknown #
+vertex $-1 -1 -1 $-1 $8317 $10572 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10573 $10574 $8318 $9379 forward $10575 $-1 #
+edge $-1 -1 -1 $-1 $8320 -6.1232339957367648e-17 $10576 1.5707963267948966 $9378 $10577 forward @7 unknown T 30 40 -45 35 45 -40 #
+coedge $-1 -1 -1 $-1 $10527 $8319 $10574 $9381 forward $9343 $-1 #
+edge $-1 -1 -1 $-1 $8320 0 $10578 1.5707963267948966 $9380 $10566 forward @7 unknown T 25 40 -45 30 45 -40 #
+point $-1 -1 -1 $-1 30 40 -45 #
+coedge $-1 -1 -1 $-1 $10530 $8322 $10072 $10579 forward $9384 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8322 $10580 T 35 35 -42.500000000000014 40 35.669872981077816 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 35.669872981077816 -42.500000000000014 #
+edge $-1 -1 -1 $-1 $10581 42.5 $8326 50 $9342 $10582 forward @7 unknown T 22.5 44.330127018922184 -50 22.5 44.330127018922191 -42.5 #
+point $-1 -1 -1 $-1 22.5 44.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $10583 $8327 $10584 $10585 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $9419 $10586 $8327 $8353 reversed $9433 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8330 $8368 $10587 $10588 forward $8331 $-1 #
+coedge $-1 -1 -1 $-1 $10589 $10589 $8332 $9394 reversed $10590 $-1 #
+edge $-1 -1 -1 $-1 $9396 -1.5707963267948966 $9400 1.5707963267948966 $8332 $10591 forward @7 unknown T 40 20 -45 45 30 -40 #
+coedge $-1 -1 -1 $-1 $8333 $8371 $10592 $10593 reversed $8372 $-1 #
+vertex $-1 -1 -1 $-1 $8334 $10594 #
+ellipse-curve $-1 -1 -1 $-1 40 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10193 $8335 $10595 $10596 reversed $9399 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9057 $10597 T 35 29.330127018922187 -42.500000000000007 40 30 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $8336 $10598 #
+point $-1 -1 -1 $-1 37.499999999999986 29.330127018922187 -42.5 #
+face $-1 -1 -1 $-1 $10599 $10600 $11 $-1 $6139 reversed single T 37.499999999999993 20 5.0000000000000027 45.000000000000007 30 20.000000000000007 F #
+coedge $-1 -1 -1 $-1 $8340 $10601 $10602 $10603 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $10604 $10605 $8340 $9405 reversed $10606 $-1 #
+edge $-1 -1 -1 $-1 $10607 -2.0943951023931948 $9409 0 $8340 $10608 forward @7 unknown T -7.4999999999999991 20 -50 8.8817841970012523e-16 25 -50 #
+coedge $-1 -1 -1 $-1 $10609 $8341 $10610 $10611 forward $9408 $-1 #
+coedge $-1 -1 -1 $-1 $8341 $10612 $8343 $9412 reversed $9408 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9407 $10613 T 0 20 -50 7.5000000000000009 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $10614 $10615 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9413 $8343 $10616 $10617 forward $8345 $-1 #
+edge $-1 -1 -1 $-1 $8346 -50 $10618 -42.5 $8343 $10619 forward @7 unknown T 7.5 20.669872981077805 -50 7.5000000000000009 20.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $8344 $9411 $10620 $10621 forward $8345 $-1 #
+face $-1 -1 -1 $-1 $10622 $8345 $11 $-1 $7093 reversed single T 7.5 20 -50 15 25 -40 F #
+point $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $10620 $10623 $8348 $9417 forward $10624 $-1 #
+edge $-1 -1 -1 $-1 $10625 -1.5707963267948966 $9420 -6.1232339957367648e-17 $9416 $10626 forward @7 unknown T 15 20 -45 20 25 -40 #
+coedge $-1 -1 -1 $-1 $8349 $10160 $10627 $10628 reversed $8026 $-1 #
+coedge $-1 -1 -1 $-1 $10629 $9390 $8344 $8350 forward $9433 $-1 #
+vertex $-1 -1 -1 $-1 $10630 $10631 #
+straight-curve $-1 -1 -1 $-1 15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10632 $8355 $8351 $9423 forward $9426 $-1 #
+edge $-1 -1 -1 $-1 $8357 -2.0943951023931975 $10625 -1.5707963267948966 $9422 $10633 forward @7 unknown T 20 20 -42.500000000000014 22.500000000000007 20.669872981077813 -40 #
+vertex $-1 -1 -1 $-1 $10634 $10635 #
+coedge $-1 -1 -1 $-1 $8355 $10632 $10636 $10637 reversed $9426 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9422 $10638 T 20 20 -42.500000000000014 25 20.669872981077813 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $8356 $10639 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.500000000000004 20.669872981077813 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $8362 $8359 $10640 $10641 reversed $8363 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10642 $10643 $11 $-1 $6162 reversed single T 22.5 25 5.0000000000000018 30 30 20 F #
+loop $-1 -1 -1 $-1 $-1 $9419 $8361 T 7.4999999999999991 25 -50 15 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $10644 $9052 $8362 $9435 reversed $8050 $-1 #
+edge $-1 -1 -1 $-1 $10190 -6.4931039580273265e-16 $8364 1.5707963267948966 $8362 $10645 forward @7 unknown T 30 19.999999999999996 -40 35 25 -35 #
+face $-1 -1 -1 $-1 $10646 $8363 $11 $-1 $10647 reversed single T 25 19.999999999999996 -45 35 25 -35 F #
+point $-1 -1 -1 $-1 35 19.999999999999996 -40 #
+coedge $-1 -1 -1 $-1 $10648 $8366 $9053 $10182 forward $9440 $-1 #
+coedge $-1 -1 -1 $-1 $8366 $10648 $8368 $8369 reversed $9440 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8366 $10646 T 25 25 -45 35 30 -35 unknown #
+vertex $-1 -1 -1 $-1 $8367 $10649 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $10588 $10650 #
+edge $-1 -1 -1 $-1 $8364 1.5707963267948966 $10651 2.0943951023931957 $8371 $10652 forward @7 unknown T 35 19.999999999999996 -40 37.5 20.669872981077805 -37.5 #
+face $-1 -1 -1 $-1 $10653 $8372 $11 $-1 $10647 reversed single T 35 19.999999999999996 -42.5 40 20.669872981077805 -37.5 F #
+vertex $-1 -1 -1 $-1 $10654 $10655 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10656 $8377 $10657 $9479 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $10268 $9475 $8377 $9450 reversed $9118 $-1 #
+edge $-1 -1 -1 $-1 $8412 -0.52359877559829848 $8397 1.5707963267948966 $8377 $10658 forward @7 unknown T 8.8817841970012523e-16 10 -50 7.5 15 -50 #
+coedge $-1 -1 -1 $-1 $8378 $10659 $10268 $9499 forward $8421 $-1 #
+coedge $-1 -1 -1 $-1 $10660 $10292 $8380 $9453 reversed $10661 $-1 #
+edge $-1 -1 -1 $-1 $8431 -1.5707963267948966 $8434 -1.0471975511965974 $8380 $8416 forward @7 unknown T 22.5 14.330127018922191 -42.500000000000007 25 15 -40 #
+coedge $-1 -1 -1 $-1 $8381 $8381 $10662 $10663 reversed $9455 $-1 #
+loop $-1 -1 -1 $-1 $10664 $8381 $10665 T 40 5 -45 45 15 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10319 $10662 $8383 $9458 forward $10666 $-1 #
+edge $-1 -1 -1 $-1 $8384 1.5707963267948966 $9516 2.0943951023931948 $9457 $10667 forward @7 unknown T 37.5 5 -40 40 5.6698729810778064 -37.5 #
+point $-1 -1 -1 $-1 40 5 -40 #
+coedge $-1 -1 -1 $-1 $10662 $10668 $8386 $9461 forward $10666 $-1 #
+edge $-1 -1 -1 $-1 $10669 4.1887902047863905 $8388 4.7123889803846897 $9460 $10667 forward @7 unknown T 37.5 14.330127018922191 -40 40 15 -37.5 #
+face $-1 -1 -1 $-1 $8433 $8387 $11 $-1 $9512 reversed single T 35 14.330127018922189 -42.500000000000007 40 15 -37.5 F #
+point $-1 -1 -1 $-1 40 15 -40 #
+face $-1 -1 -1 $-1 $10670 $10304 $11 $-1 $10259 reversed single T 25 10 15 35 15 25.000000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $10671 $8390 T 37.5 4.9999999999999991 5.0000000000000027 45.000000000000007 15 20.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $8391 $10672 $10673 $10674 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $10675 $10676 $8391 $9468 reversed $10677 $-1 #
+edge $-1 -1 -1 $-1 $10678 1.5707963267948966 $9472 3.6651914291880923 $8391 $10679 forward @7 unknown T -15 5 -50 -7.5 10 -50 #
+coedge $-1 -1 -1 $-1 $10680 $8392 $10676 $10681 forward $9471 $-1 #
+coedge $-1 -1 -1 $-1 $8392 $10682 $8394 $9476 reversed $9471 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9470 $10683 T -7.5000000000000036 5 -50 8.8817841970012523e-16 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $8393 $10684 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9477 $8394 $10685 $10686 reversed $8396 $-1 #
+coedge $-1 -1 -1 $-1 $9449 $10687 $10688 $9476 reversed $9118 $-1 #
+edge $-1 -1 -1 $-1 $8397 -50 $10689 -45 $10688 $10690 forward @7 unknown T 0 10 -50 8.8817841970012523e-16 10 -45 #
+coedge $-1 -1 -1 $-1 $8395 $9474 $10691 $10692 reversed $8396 $-1 #
+face $-1 -1 -1 $-1 $6210 $8396 $11 $-1 $8101 reversed single T 0 4.9999999999999991 -50 7.5000000000000018 10 -40 F #
+edge $-1 -1 -1 $-1 $8397 0 $10693 2.0943951023931948 $9448 $9473 forward @7 unknown T -7.5 10 -50 8.8817841970012523e-16 15 -50 #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 10 -50 #
+coedge $-1 -1 -1 $-1 $10691 $10694 $8399 $9482 reversed $10695 $-1 #
+edge $-1 -1 -1 $-1 $9483 1.0471975511965979 $10696 1.5707963267948966 $8399 $10697 forward @7 unknown T 7.5 5 -42.5 10 5.6698729810778081 -40 #
+vertex $-1 -1 -1 $-1 $9482 $10698 #
+straight-curve $-1 -1 -1 $-1 7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10699 $8404 $8401 $9486 reversed $9489 $-1 #
+edge $-1 -1 -1 $-1 $10696 -1.5707963267948966 $8408 0 $8401 $10700 forward @7 unknown T 10 5 -45 15 10 -40 #
+face $-1 -1 -1 $-1 $10701 $10702 $11 $-1 $8113 reversed single T -7.5000000000000009 10 -50 8.8817841970012523e-16 15 -40 F #
+coedge $-1 -1 -1 $-1 $8404 $10699 $10703 $10704 forward $9489 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8404 $10705 T 10 4.9999999999999982 -45 20 10 -35 unknown #
+vertex $-1 -1 -1 $-1 $8405 $10706 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10707 $10708 $8406 $9493 forward $10709 $-1 #
+edge $-1 -1 -1 $-1 $8408 2.9403902792268234e-16 $10710 1.5707963267948966 $9492 $10711 forward @7 unknown T 15 10 -45 20 14.999999999999998 -40 #
+coedge $-1 -1 -1 $-1 $10659 $8407 $10708 $9495 forward $8421 $-1 #
+edge $-1 -1 -1 $-1 $8408 0 $10712 1.5707963267948966 $9494 $10700 forward @7 unknown T 10 10 -45 15 15 -40 #
+point $-1 -1 -1 $-1 15 10 -45 #
+coedge $-1 -1 -1 $-1 $8413 $8410 $10287 $10713 forward $8414 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10714 42.500000000000014 $8412 50 $9451 $10715 forward @7 unknown T 7.5 14.330127018922195 -50 7.5000000000000027 14.330127018922195 -42.500000000000014 #
+point $-1 -1 -1 $-1 7.5 14.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $10716 $9505 $8413 $9502 forward $10336 $-1 #
+edge $-1 -1 -1 $-1 $8415 1.5707963267948966 $10717 2.0943951023931948 $9501 $10718 forward @7 unknown T 22.500000000000004 5 -40 25 5.6698729810778064 -37.5 #
+face $-1 -1 -1 $-1 $10719 $8414 $11 $-1 $9512 reversed single T 20 4.9999999999999982 -42.5 25 5.6698729810778081 -37.5 F #
+point $-1 -1 -1 $-1 25 5 -40 #
+coedge $-1 -1 -1 $-1 $9501 $9168 $8418 $9506 forward $10336 $-1 #
+edge $-1 -1 -1 $-1 $9170 3.1415926535897931 $8415 4.7123889803846897 $9505 $10720 forward @7 unknown T 25 5 -40 30 10 -35 #
+face $-1 -1 -1 $-1 $10721 $10722 $11 $-1 $10259 reversed single T 10 10 15 20 15 25 F #
+loop $-1 -1 -1 $-1 $-1 $10723 $8420 T 22.5 10 5.0000000000000018 30 15 20 unknown #
+coedge $-1 -1 -1 $-1 $10724 $8422 $7189 $8148 forward $7188 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9462 $8428 $11 $-1 $9512 reversed single T 25 10 -45 35 15 -35 F #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 10 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $8427 $8426 $9167 $10334 reversed $8428 $-1 #
+point $-1 -1 -1 $-1 35 14.999999999999998 -40 #
+point $-1 -1 -1 $-1 25 15 -40 #
+vertex $-1 -1 -1 $-1 $10320 $10725 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10726 $9169 $11 $-1 $5329 reversed single T 22.499999999999996 10 -40 30 15 -25 F #
+edge $-1 -1 -1 $-1 $10710 1.5707963267948966 $8434 2.0943951023931957 $10292 $10727 forward @7 unknown T 20 14.330127018922189 -42.500000000000007 22.500000000000004 14.999999999999998 -40 #
+point $-1 -1 -1 $-1 22.500000000000004 14.330127018922193 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $10728 $8436 $10729 $10730 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $9551 $10731 $8436 $8466 reversed $9565 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8439 $8481 $10732 $10733 forward $7479 $-1 #
+coedge $-1 -1 -1 $-1 $10454 $8440 $9291 $10485 reversed $9526 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9266 $10734 T 20 -0.6698729810778099 -42.500000000000007 25 0 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $8445 $8448 $8442 $9528 forward $9531 $-1 #
+edge $-1 -1 -1 $-1 $7446 1.5707963267948966 $7442 4.7123889803846897 $9527 $10735 forward @7 unknown T 40 -10 -40 45 0 -35 #
+loop $-1 -1 -1 $-1 $-1 $10736 $9530 T 50 -10 -45 50 0 -35 unknown #
+face $-1 -1 -1 $-1 $10737 $8443 $11 $-1 $8499 reversed single T 40 -10 -45 50 0 -35 F #
+loop $-1 -1 -1 $-1 $-1 $9278 $10738 T 37.5 -10 -40 45.000000000000007 0 -24.999999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8448 $10739 $9280 $10472 forward $9531 $-1 #
+vertex $-1 -1 -1 $-1 $8449 $10740 #
+coedge $-1 -1 -1 $-1 $8453 $10741 $10742 $10743 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $10744 $10745 $8453 $9537 reversed $10746 $-1 #
+edge $-1 -1 -1 $-1 $10747 -2.0943951023931957 $9541 0 $8453 $10748 forward @7 unknown T -22.5 -10 -50 -15 -5 -50 #
+coedge $-1 -1 -1 $-1 $10749 $8454 $10750 $10751 forward $9540 $-1 #
+coedge $-1 -1 -1 $-1 $8454 $10752 $8456 $9544 reversed $9540 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9539 $10753 T -15 -10 -50 -7.4999999999999991 -4.9999999999999991 -40 unknown #
+vertex $-1 -1 -1 $-1 $10754 $10755 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9545 $8456 $10756 $10757 forward $8458 $-1 #
+edge $-1 -1 -1 $-1 $8459 -50 $10758 -42.500000000000007 $8456 $10759 forward @7 unknown T -7.5000000000000018 -9.3301270189221945 -50 -7.5000000000000009 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $8457 $9543 $10760 $10761 forward $8458 $-1 #
+face $-1 -1 -1 $-1 $10762 $8458 $11 $-1 $7251 reversed single T -7.5000000000000036 -10 -50 0 -5 -40 F #
+point $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 -50 #
+coedge $-1 -1 -1 $-1 $10760 $10763 $8461 $9549 forward $10764 $-1 #
+edge $-1 -1 -1 $-1 $10765 -1.5707963267948966 $9552 -6.1232339957367648e-17 $9548 $10766 forward @7 unknown T -9.3734986416366059e-33 -10 -45 5 -5 -40 #
+coedge $-1 -1 -1 $-1 $8462 $10427 $10767 $10768 reversed $8210 $-1 #
+coedge $-1 -1 -1 $-1 $10769 $9522 $8457 $8463 forward $9565 $-1 #
+vertex $-1 -1 -1 $-1 $10770 $10771 #
+straight-curve $-1 -1 -1 $-1 0 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10772 $8468 $8464 $9555 forward $9558 $-1 #
+edge $-1 -1 -1 $-1 $8470 -2.0943951023931957 $10765 -1.5707963267948966 $9554 $10773 forward @7 unknown T 5 -10 -42.500000000000007 7.5000000000000009 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $10774 $10775 #
+coedge $-1 -1 -1 $-1 $8468 $10772 $10776 $10777 reversed $9558 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9554 $10778 T 5 -10 -42.500000000000007 10 -9.330127018922191 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $8469 $10779 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $8475 $8472 $10780 $10781 reversed $8476 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10782 $10783 $11 $-1 $5398 reversed single T 7.4999999999999956 -5 5.0000000000000009 15 8.8817841970012523e-16 20 F #
+loop $-1 -1 -1 $-1 $-1 $9551 $8474 T -7.5000000000000009 -5 -50 0 0 -40 unknown #
+coedge $-1 -1 -1 $-1 $10784 $9261 $8475 $9567 reversed $8229 $-1 #
+edge $-1 -1 -1 $-1 $10451 -2.9403902792268234e-16 $8477 1.5707963267948966 $8475 $10785 forward @7 unknown T 15 -10 -40 20 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $10786 $8476 $11 $-1 $8499 reversed single T 10 -10 -45 20 -4.9999999999999991 -35 F #
+point $-1 -1 -1 $-1 20 -10 -40 #
+coedge $-1 -1 -1 $-1 $10787 $8479 $9262 $10443 forward $9572 $-1 #
+coedge $-1 -1 -1 $-1 $8479 $10787 $8481 $8482 reversed $9572 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8479 $10786 T 10 -5 -45 20 0 -35 unknown #
+vertex $-1 -1 -1 $-1 $8480 $10788 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $10733 $10789 #
+edge $-1 -1 -1 $-1 $8477 1.5707963267948966 $9580 2.0943951023931957 $8484 $10790 forward @7 unknown T 20 -10 -40 22.500000000000004 -9.330127018922191 -37.5 #
+vertex $-1 -1 -1 $-1 $10791 $10792 #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10486 $8488 $10441 $10793 forward $9294 $-1 #
+vertex $-1 -1 -1 $-1 $10793 $10794 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10795 $10450 $11 $-1 $5398 reversed single T 7.5 -5 -40 15 0 -25 F #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10796 $10797 $11 $-1 $8848 reversed single T 10 -10 15 20 -4.9999999999999991 25 F #
+loop $-1 -1 -1 $-1 $-1 $9832 $8494 T 10 -5 15 20 0 25 unknown #
+coedge $-1 -1 -1 $-1 $9277 $8496 $10798 $10799 reversed $6324 $-1 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221945 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10800 $8508 $10801 $9608 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $8630 $9604 $8508 $9591 reversed $7611 $-1 #
+edge $-1 -1 -1 $-1 $8533 -0.52359877559829893 $8518 1.5707963267948966 $8508 $10802 forward @7 unknown T -15.000000000000002 -20 -50 -7.5000000000000009 -15 -50 #
+coedge $-1 -1 -1 $-1 $8509 $10803 $8630 $9628 forward $8541 $-1 #
+coedge $-1 -1 -1 $-1 $10804 $10522 $8511 $9594 reversed $10805 $-1 #
+edge $-1 -1 -1 $-1 $8549 -1.5707963267948966 $8551 -1.0471975511965965 $8511 $8537 forward @7 unknown T 7.4999999999999947 -15.669872981077811 -42.500000000000007 10 -15 -40 #
+coedge $-1 -1 -1 $-1 $8512 $10806 $10807 $10808 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $10809 $10810 $8512 $9597 reversed $10811 $-1 #
+edge $-1 -1 -1 $-1 $10812 1.5707963267948966 $9601 3.6651914291880923 $8512 $10813 forward @7 unknown T -30 -25 -50 -22.5 -20 -50 #
+coedge $-1 -1 -1 $-1 $10814 $8513 $10810 $10815 forward $9600 $-1 #
+coedge $-1 -1 -1 $-1 $8513 $10816 $8515 $9605 reversed $9600 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9599 $10817 T -22.500000000000007 -25 -50 -15 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $8514 $10818 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9606 $8515 $10819 $10820 reversed $8517 $-1 #
+coedge $-1 -1 -1 $-1 $9590 $10821 $10822 $9605 reversed $7611 $-1 #
+edge $-1 -1 -1 $-1 $8518 -50 $10823 -45 $10822 $10824 forward @7 unknown T -15 -20 -50 -15 -20 -45 #
+coedge $-1 -1 -1 $-1 $8516 $9603 $8771 $9857 reversed $8517 $-1 #
+face $-1 -1 -1 $-1 $9719 $8517 $11 $-1 $6619 reversed single T -15.000000000000002 -25 -50 -7.5000000000000009 -20 -40 F #
+edge $-1 -1 -1 $-1 $8518 0 $10825 2.0943951023931948 $9589 $9602 forward @7 unknown T -22.5 -20 -50 -15 -15 -50 #
+point $-1 -1 -1 $-1 -15 -20 -50 #
+coedge $-1 -1 -1 $-1 $8771 $8770 $8520 $9611 reversed $6842 $-1 #
+edge $-1 -1 -1 $-1 $9612 1.047197551196597 $10826 1.5707963267948966 $8520 $10827 forward @7 unknown T -7.5000000000000036 -25 -42.500000000000007 -5 -24.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $9611 $10828 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10829 $8525 $8522 $9615 reversed $9618 $-1 #
+edge $-1 -1 -1 $-1 $10826 -1.5707963267948966 $8529 0 $8522 $10830 forward @7 unknown T -5 -25 -45 0 -20 -40 #
+face $-1 -1 -1 $-1 $10831 $10832 $11 $-1 $2664 reversed single T -10.000000000000002 -15.669872981077809 -12.500000000000004 -5 -15 -7.4999999999999956 F #
+coedge $-1 -1 -1 $-1 $8525 $10829 $10833 $10834 forward $9618 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8525 $9843 T -5 -25 -45 4.9999999999999991 -20 -35 unknown #
+vertex $-1 -1 -1 $-1 $8526 $10835 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10836 $10837 $8527 $9622 forward $10838 $-1 #
+edge $-1 -1 -1 $-1 $8529 -6.1232339957367648e-17 $10839 1.5707963267948966 $9621 $10840 forward @7 unknown T -8.8817841970012523e-16 -20 -45 4.9999999999999991 -15 -40 #
+coedge $-1 -1 -1 $-1 $10803 $8528 $10837 $9624 forward $8541 $-1 #
+edge $-1 -1 -1 $-1 $8529 0 $10841 1.5707963267948966 $9623 $10830 forward @7 unknown T -5 -20 -45 0 -15 -40 #
+point $-1 -1 -1 $-1 0 -20 -45 #
+coedge $-1 -1 -1 $-1 $8534 $8531 $10517 $10842 forward $8535 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $10843 42.500000000000007 $8533 50 $9592 $10844 forward @7 unknown T -7.5000000000000027 -15.669872981077809 -50 -7.5000000000000009 -15.669872981077807 -42.500000000000007 #
+point $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 -50 #
+coedge $-1 -1 -1 $-1 $9817 $9634 $8534 $9631 forward $9796 $-1 #
+edge $-1 -1 -1 $-1 $8536 1.5707963267948966 $10845 2.0943951023931948 $9630 $10846 forward @7 unknown T 7.5000000000000018 -25 -40 10 -24.330127018922191 -37.5 #
+face $-1 -1 -1 $-1 $10847 $8535 $11 $-1 $4210 reversed single T 4.9999999999999991 -25 -42.500000000000014 10 -24.330127018922191 -37.5 F #
+point $-1 -1 -1 $-1 10 -25 -40 #
+coedge $-1 -1 -1 $-1 $9630 $8721 $8539 $9635 forward $9796 $-1 #
+edge $-1 -1 -1 $-1 $8725 3.1415926535897931 $8536 4.7123889803846897 $9634 $10848 forward @7 unknown T 10 -25 -40 15 -20 -35 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8546 $8545 $8720 $9811 reversed $7847 $-1 #
+point $-1 -1 -1 $-1 20 -15 -40 #
+point $-1 -1 -1 $-1 10 -15 -40 #
+ellipse-curve $-1 -1 -1 $-1 20 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10839 1.5707963267948966 $8551 2.0943951023931957 $10522 $10849 forward @7 unknown T 4.9999999999999991 -15.669872981077809 -42.500000000000007 7.5 -15 -40 #
+point $-1 -1 -1 $-1 7.4999999999999982 -15.669872981077809 -42.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10850 $8560 $8604 $9696 reversed $9646 $-1 #
+coedge $-1 -1 -1 $-1 $8560 $10851 $9682 $10852 reversed $9646 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10853 $8643 T -45 -24.999999999999996 4.9999999999999973 -37.499999999999993 -14.999999999999996 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $8561 $10854 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10855 $10856 $8562 $9650 forward $8759 $-1 #
+edge $-1 -1 -1 $-1 $9656 1.0471975511965974 $9651 1.5707963267948966 $9649 $10857 forward @7 unknown T -7.5000000000000027 -25 17.499999999999996 -5 -24.330127018922191 20 #
+vertex $-1 -1 -1 $-1 $9650 $10858 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8855 $8564 $10856 $10859 reversed $9655 $-1 #
+coedge $-1 -1 -1 $-1 $8564 $10860 $9701 $9658 reversed $9655 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8855 $10861 T -15.000000000000002 -25 4.9999999999999991 -7.5000000000000009 -20 20 unknown #
+vertex $-1 -1 -1 $-1 $9650 $10862 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8566 -1.5707963267948966 $10863 -6.1232339957367648e-17 $9701 $10864 forward @7 unknown T -15.000000000000002 -25 15 -10.000000000000002 -20 20 #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 20 #
+vertex $-1 -1 -1 $-1 $10865 $10866 #
+coedge $-1 -1 -1 $-1 $10495 $8573 $8575 $9663 forward $9305 $-1 #
+straight-curve $-1 -1 -1 $-1 -37.5 -15.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $8576 4.1887902047863923 $9692 4.7123889803846897 $9661 $10867 forward @7 unknown T -37.499999999999993 -15.669872981077805 35 -35 -15 37.499999999999993 #
+point $-1 -1 -1 $-1 -37.499999999999993 -15.669872981077805 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $10496 $8578 $9298 $9312 reversed $9667 $-1 #
+coedge $-1 -1 -1 $-1 $8578 $10868 $8580 $9670 forward $9667 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10496 $9320 T -37.5 -25 35 -30 -20 50 unknown #
+vertex $-1 -1 -1 $-1 $8579 $10869 #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $9680 1.5707963267948966 $8581 2.0943951023931957 $9666 $10867 forward @7 unknown T -37.5 -25 35 -35 -24.330127018922187 37.5 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 37.5 #
+face $-1 -1 -1 $-1 $10497 $10870 $11 $-1 $7591 reversed single T -45 -24.999999999999996 -40 -37.499999999999993 -14.999999999999996 -25.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $10871 $8583 T -45 -24.999999999999996 -50 -37.5 -14.999999999999996 -40 unknown #
+coedge $-1 -1 -1 $-1 $9677 $8584 $10872 $10873 forward $8586 $-1 #
+coedge $-1 -1 -1 $-1 $8585 $9677 $10874 $10875 forward $8586 $-1 #
+edge $-1 -1 -1 $-1 $10876 1.5707963267948957 $8587 2.0943951023931948 $8585 $10877 forward @7 unknown T -37.500000000000007 -25 19.999999999999993 -35 -24.330127018922195 22.5 #
+coedge $-1 -1 -1 $-1 $9675 $9674 $10878 $10879 reversed $8586 $-1 #
+face $-1 -1 -1 $-1 $10880 $8586 $11 $-1 $8642 reversed single T -37.500000000000007 -25 19.999999999999993 -29.999999999999993 -20 35 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -24.330127018922198 22.5 #
+vertex $-1 -1 -1 $-1 $8589 $10881 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10882 $8592 $9645 $10852 forward $9684 $-1 #
+coedge $-1 -1 -1 $-1 $8592 $10882 $8594 $9687 reversed $9684 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8592 $10883 T -40 -15.669872981077809 17.499999999999996 -35 -14.999999999999996 22.499999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9689 $8594 $10884 $10885 forward $8596 $-1 #
+edge $-1 -1 -1 $-1 $8597 4.1887902047863914 $10886 4.7123889803846906 $8594 $10877 forward @7 unknown T -37.500000000000007 -15.669872981077805 19.999999999999993 -35 -15 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $8595 $9689 $10887 $10888 forward $8596 $-1 #
+coedge $-1 -1 -1 $-1 $9688 $9686 $9677 $10879 forward $8596 $-1 #
+face $-1 -1 -1 $-1 $8590 $8596 $11 $-1 $8642 reversed single T -37.500000000000007 -20 19.999999999999993 -29.999999999999993 -15 35 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -15.669872981077804 22.499999999999993 #
+vertex $-1 -1 -1 $-1 $8599 $10889 #
+face $-1 -1 -1 $-1 $9697 $10890 $11 $-1 $8642 reversed single T -37.5 -20 4.9999999999999982 -30 -15 19.999999999999996 F #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $8604 $8603 $10891 $10892 reversed $8605 $-1 #
+edge $-1 -1 -1 $-1 $10893 -2.0943951023931957 $8606 -1.5707963267948966 $8604 $10894 forward @7 unknown T -40 -24.999999999999996 17.499999999999993 -37.5 -24.330127018922187 19.999999999999996 #
+face $-1 -1 -1 $-1 $10883 $8605 $11 $-1 $1815 reversed single T -40 -25 17.499999999999989 -35 -24.330127018922187 22.5 F #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $8757 $10895 $8608 $8703 reversed $7766 $-1 #
+point $-1 -1 -1 $-1 0 -20 30 #
+coedge $-1 -1 -1 $-1 $10896 $8613 $9654 $9658 forward $9703 $-1 #
+coedge $-1 -1 -1 $-1 $8613 $10896 $10897 $9713 reversed $9703 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8613 $10898 T -20 -25 15 -10.000000000000002 -20 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10899 $8616 $10900 $10901 reversed $7638 $-1 #
+coedge $-1 -1 -1 $-1 $10902 $10903 $8616 $9707 forward $10904 $-1 #
+edge $-1 -1 -1 $-1 $10905 -1.5707963267948966 $8619 6.1232339957367648e-17 $9706 $10906 forward @7 unknown T -15.000000000000002 -20 20 -10.000000000000002 -15 25 #
+coedge $-1 -1 -1 $-1 $8617 $10899 $9326 $10513 reversed $7638 $-1 #
+edge $-1 -1 -1 $-1 $6620 -6.1232339957367648e-17 $9324 1.5707963267948966 $9322 $10907 forward @7 unknown T -15.000000000000002 -20 30 -10.000000000000002 -15 35 #
+coedge $-1 -1 -1 $-1 $8618 $10908 $10902 $10909 forward $9712 $-1 #
+coedge $-1 -1 -1 $-1 $10897 $8621 $6607 $7602 reversed $9716 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8618 $10510 T -22.500000000000004 -20 20 -15 -15 35 unknown #
+edge $-1 -1 -1 $-1 $8619 3.1415926535897931 $10910 4.7123889803846897 $10897 $10911 forward @7 unknown T -20 -25 20 -15 -20 25 #
+point $-1 -1 -1 $-1 -15 -20 25 #
+coedge $-1 -1 -1 $-1 $8621 $10912 $10913 $9720 forward $9716 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9711 $8627 T -22.500000000000004 -25 20 -15 -20 35 unknown #
+coedge $-1 -1 -1 $-1 $10913 $10914 $8623 $9718 reversed $10915 $-1 #
+edge $-1 -1 -1 $-1 $8625 1.5707963267948966 $10514 2.0943951023931957 $8623 $10508 forward @7 unknown T -22.500000000000004 -25 35 -20 -24.330127018922191 37.500000000000007 #
+face $-1 -1 -1 $-1 $9331 $8624 $11 $-1 $9321 reversed single T -22.500000000000004 -25 35 -15 -20 50 F #
+edge $-1 -1 -1 $-1 $10916 1.0471975511965979 $8625 1.5707963267948966 $9715 $10917 forward @7 unknown T -22.500000000000004 -25 32.5 -20 -24.330127018922191 35 #
+point $-1 -1 -1 $-1 -20 -25 35 #
+face $-1 -1 -1 $-1 $10918 $10919 $11 $-1 $1815 reversed single T -10.000000000000002 -15.669872981077811 17.499999999999996 -5 -15 22.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $8772 $8628 T -15.000000000000002 -25 -40 -7.5000000000000009 -20 -25 unknown #
+coedge $-1 -1 -1 $-1 $10920 $10921 $10922 $10923 reversed $8629 $-1 #
+coedge $-1 -1 -1 $-1 $10821 $8630 $10924 $10925 reversed $7611 $-1 #
+edge $-1 -1 -1 $-1 $8631 -1.5707963267948966 $10926 -1.047197551196597 $9728 $10917 forward @7 unknown T -22.500000000000004 -15.669872981077809 32.5 -20 -15 35 #
+point $-1 -1 -1 $-1 -20 -15 35 #
+coedge $-1 -1 -1 $-1 $10927 $8632 $10506 $9726 forward $9712 $-1 #
+coedge $-1 -1 -1 $-1 $9322 $9318 $8632 $7612 reversed $9323 $-1 #
+loop $-1 -1 -1 $-1 $10928 $10929 $3147 T -50 -25 -45 -50 -15 -35 hole $3148 T #
+coedge $-1 -1 -1 $-1 $9731 $9731 $10930 $10931 forward $8634 $-1 #
+edge $-1 -1 -1 $-1 $10932 0 $10932 6.2831853071795862 $8635 $10933 forward @7 unknown T -50 -25 -15.000000000000004 -50 -15 -5.0000000000000036 #
+vertex $-1 -1 -1 $-1 $8637 $10934 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 4.9999999999999973 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -20 14.999999999999996 #
+face $-1 -1 -1 $-1 $10935 $10936 $11 $-1 $10937 reversed single T -37.5 5 -50 -30 10 -40 F #
+loop $-1 -1 -1 $-1 $-1 $10938 $8640 T -37.5 -10 -50 -30 -4.9999999999999991 -40 unknown #
+cone-surface $-1 -1 -1 $-1 -35 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $10807 $10939 $10809 $10940 reversed $8641 $-1 #
+coedge $-1 -1 -1 $-1 $9866 $10941 $10942 $10943 reversed $8644 $-1 #
+coedge $-1 -1 -1 $-1 $10944 $8645 $10945 $10946 reversed $7620 $-1 #
+coedge $-1 -1 -1 $-1 $8645 $9868 $10947 $10948 reversed $7620 $-1 #
+coedge $-1 -1 -1 $-1 $10949 $10950 $8645 $9744 forward $10951 $-1 #
+edge $-1 -1 -1 $-1 $10952 1.5707963267948966 $10953 2.0943951023931944 $9743 $10954 forward @7 unknown T -40 -24.999999999999996 -25.000000000000004 -37.500000000000007 -24.330127018922191 -22.5 #
+face $-1 -1 -1 $-1 $10955 $10956 $11 $-1 $7628 reversed single T -30 -20 -25 -22.499999999999993 -15 -10.000000000000002 F #
+loop $-1 -1 -1 $-1 $-1 $10957 $8649 T -30 -20 -10.000000000000002 -22.5 -15 4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $10958 $10959 $10960 $10961 reversed $8650 $-1 #
+coedge $-1 -1 -1 $-1 $10962 $8651 $10963 $10964 reversed $7627 $-1 #
+coedge $-1 -1 -1 $-1 $8651 $10965 $9689 $10879 reversed $7627 $-1 #
+coedge $-1 -1 -1 $-1 $10884 $10966 $8651 $9751 forward $10967 $-1 #
+edge $-1 -1 -1 $-1 $10968 -1.5707963267948966 $10969 6.1232339957367623e-17 $9750 $10970 forward @7 unknown T -30 -20 20 -25 -15 25 #
+face $-1 -1 -1 $-1 $10971 $10972 $11 $-1 $6619 reversed single T -15.000000000000004 -20 -25 -7.5000000000000009 -15 -10 F #
+loop $-1 -1 -1 $-1 $-1 $10973 $8652 T -15.000000000000002 -20 -10 -7.5000000000000009 -15 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $10974 $10975 $10976 $10977 reversed $8653 $-1 #
+loop $-1 -1 -1 $-1 $10978 $10979 $1558 T 50 -10 2.6645352591003757e-15 50 0 10.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $9756 $9756 $10980 $10981 forward $8654 $-1 #
+vertex $-1 -1 -1 $-1 $8656 $10982 #
+ellipse-curve $-1 -1 -1 $-1 50 -20 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -20 -29.999999999999996 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 -10.000000000000002 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 4.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 -10.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 -25.000000000000004 -35 4.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 4.9999999999999982 #
+point $-1 -1 -1 $-1 -25.000000000000004 -40 4.9999999999999982 #
+face $-1 -1 -1 $-1 $8762 $8751 $11 $-1 $4912 reversed single T -8.8817841970012523e-16 -25 5 7.5000000000000027 -20 20 F #
+loop $-1 -1 -1 $-1 $-1 $9819 $8682 T -8.8817841970012523e-16 -25 -10 7.5 -20 5 unknown #
+coedge $-1 -1 -1 $-1 $10983 $9802 $9805 $10984 reversed $8683 $-1 #
+coedge $-1 -1 -1 $-1 $10985 $10986 $8684 $9772 forward $9835 $-1 #
+edge $-1 -1 -1 $-1 $10987 -1.5707963267948966 $10988 6.1232339957367648e-17 $9771 $10989 forward @7 unknown T -8.8817841970012523e-16 -20 -25 4.9999999999999991 -15 -20 #
+coedge $-1 -1 -1 $-1 $8685 $8729 $8692 $9786 reversed $6742 $-1 #
+edge $-1 -1 -1 $-1 $9777 -5 $10990 0 $8776 $10991 forward @7 unknown T -8.8817841970012523e-16 -20 -5 0 -20 0 #
+coedge $-1 -1 -1 $-1 $9896 $8686 $9864 $10992 reversed $9776 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8686 $8738 T -5 -20 -15 4.9999999999999991 -15 -5 unknown #
+vertex $-1 -1 -1 $-1 $10993 $10994 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10995 $8689 $8699 $9792 forward $8850 $-1 #
+coedge $-1 -1 -1 $-1 $8689 $10996 $8691 $9785 forward $8850 $-1 #
+coedge $-1 -1 -1 $-1 $10997 $10855 $10998 $8690 reversed $8759 $-1 #
+vertex $-1 -1 -1 $-1 $9792 $10999 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8692 $8691 $9863 $11000 reversed $8693 $-1 #
+edge $-1 -1 -1 $-1 $11001 1.5707963267948966 $8695 3.1415926535897931 $9780 $11002 forward @7 unknown T -5 -20 5 0 -15 10 #
+edge $-1 -1 -1 $-1 $10990 -6.1232339957367648e-17 $8694 1.5707963267948966 $8692 $11003 forward @7 unknown T -8.8817841970012523e-16 -20 0 4.9999999999999991 -15 5 #
+face $-1 -1 -1 $-1 $11004 $8693 $11 $-1 $2156 reversed single T -5 -20 0 4.9999999999999991 -15 10 F #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 5 #
+edge $-1 -1 -1 $-1 $8695 3.1415926535897931 $11005 4.7123889803846897 $10997 $11002 forward @7 unknown T -5 -25 5 0 -20 10 #
+point $-1 -1 -1 $-1 0 -20 10 #
+coedge $-1 -1 -1 $-1 $8697 $10516 $11006 $11007 forward $7558 $-1 #
+edge $-1 -1 -1 $-1 $9782 0 $9793 1.5707963267948966 $9779 $11008 forward @7 unknown T -5 -20 15 0 -15 20 #
+vertex $-1 -1 -1 $-1 $11009 $11010 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+loop $-1 -1 -1 $-1 $-1 $8721 $8758 T 7.5 -25 -40 15 -20 -25 unknown #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $8711 $8710 $11011 $9812 forward $8712 $-1 #
+edge $-1 -1 -1 $-1 $8713 -2.0943951023931948 $10987 -1.5707963267948966 $8710 $11012 forward @7 unknown T 4.9999999999999991 -15.669872981077807 -25 7.5000000000000009 -15 -22.500000000000004 #
+face $-1 -1 -1 $-1 $11013 $8712 $11 $-1 $3328 reversed single T 4.9999999999999991 -15.669872981077809 -27.500000000000004 10 -15 -22.500000000000004 F #
+point $-1 -1 -1 $-1 7.5000000000000009 -15.669872981077807 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $9770 $9827 $8715 $9803 reversed $8683 $-1 #
+edge $-1 -1 -1 $-1 $9807 -22.500000000000004 $7751 -12.500000000000002 $8715 $11014 forward @7 unknown T 7.4999999999999982 -24.330127018922195 -22.500000000000004 7.5000000000000018 -24.330127018922191 -12.500000000000002 #
+coedge $-1 -1 -1 $-1 $11015 $8716 $8728 $7733 reversed $9806 $-1 #
+coedge $-1 -1 -1 $-1 $8716 $11015 $9770 $10984 forward $9806 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11015 $11016 T 4.9999999999999991 -25 -27.500000000000004 10 -24.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $9803 $11017 #
+coedge $-1 -1 -1 $-1 $8720 $8719 $10804 $11018 forward $7726 $-1 #
+coedge $-1 -1 -1 $-1 $11011 $11019 $8719 $9810 reversed $8286 $-1 #
+edge $-1 -1 -1 $-1 $8722 27.500000000000004 $11020 37.5 $8719 $11021 forward @7 unknown T 7.4999999999999982 -15.669872981077809 -37.5 7.5000000000000009 -15.669872981077807 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $8549 1.5707963267948966 $8725 3.1415926535897931 $8720 $10848 forward @7 unknown T 10 -20 -40 15 -15 -35 #
+edge $-1 -1 -1 $-1 $10987 1.5707963267948966 $8722 2.0943951023931957 $9798 $11022 forward @7 unknown T 4.9999999999999991 -15.669872981077809 -27.500000000000004 7.5 -15 -25 #
+point $-1 -1 -1 $-1 7.4999999999999982 -15.669872981077809 -27.500000000000004 #
+point $-1 -1 -1 $-1 15 -20 -35 #
+point $-1 -1 -1 $-1 7.5000000000000027 -24.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $8728 $9630 $11023 $11024 forward $9796 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 -0.70710678118654735 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $11025 $8733 $8735 $9822 reversed $9769 $-1 #
+coedge $-1 -1 -1 $-1 $8733 $11026 $8737 $9824 reversed $9769 $-1 #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $11027 1.5707963267948966 $8736 2.0943951023931957 $8735 $11028 forward @7 unknown T 4.9999999999999991 -25 -10 7.5 -24.330127018922191 -7.4999999999999991 #
+point $-1 -1 -1 $-1 7.4999999999999991 -24.330127018922195 -7.4999999999999991 #
+edge $-1 -1 -1 $-1 $6814 -2.0943951023931948 $9838 -1.5707963267948966 $8737 $11029 forward @7 unknown T 4.9999999999999991 -25 2.5000000000000009 7.4999999999999991 -24.330127018922195 5 #
+face $-1 -1 -1 $-1 $11030 $11031 $11 $-1 $3822 reversed single T -7.5000000000000036 -20 -25 8.8817841970012523e-16 -15 -10 F #
+coedge $-1 -1 -1 $-1 $11032 $11033 $11025 $11034 forward $8739 $-1 #
+coedge $-1 -1 -1 $-1 $9802 $11035 $8740 $9828 reversed $8683 $-1 #
+edge $-1 -1 -1 $-1 $7751 -2.0943951023931957 $11027 -1.5707963267948966 $8740 $11036 forward @7 unknown T 4.9999999999999991 -25 -12.500000000000002 7.5 -24.330127018922191 -10 #
+face $-1 -1 -1 $-1 $11037 $11038 $11 $-1 $5386 reversed single T 15 -5 -25 22.5 -8.8817841970012523e-16 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $11039 $8742 T 15 -5 -9.9999999999999982 22.500000000000004 0 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $11040 $11041 $11042 $11043 reversed $8743 $-1 #
+coedge $-1 -1 -1 $-1 $11044 $11045 $8744 $9833 forward $9585 $-1 #
+edge $-1 -1 -1 $-1 $11046 -1.5707963267948966 $10435 -2.9403902792268244e-16 $9832 $11047 forward @7 unknown T 15 -4.9999999999999991 20 20 -8.8817841970012523e-16 25 #
+face $-1 -1 -1 $-1 $11016 $11048 $11 $-1 $3328 reversed single T -5 -25 -30 4.9999999999999991 -20 -20 F #
+loop $-1 -1 -1 $-1 $-1 $10986 $8748 T -5 -20 -30 4.9999999999999991 -15 -20 unknown #
+coedge $-1 -1 -1 $-1 $10998 $8749 $11049 $11050 reversed $8751 $-1 #
+coedge $-1 -1 -1 $-1 $8750 $10998 $9841 $9844 reversed $8751 $-1 #
+vertex $-1 -1 -1 $-1 $11051 $11052 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10895 $8757 $9837 $9844 forward $7766 $-1 #
+edge $-1 -1 -1 $-1 $7707 6.1232339957367648e-17 $8763 1.5707963267948966 $8757 $11053 forward @7 unknown T -8.8817841970012523e-16 -25 20 4.9999999999999991 -20 25 #
+face $-1 -1 -1 $-1 $11054 $9618 $11 $-1 $4210 reversed single T -5 -25 -45 4.9999999999999991 -20 -35 F #
+edge $-1 -1 -1 $-1 $8763 -1.5707963267948966 $9782 -6.1232339957367648e-17 $9841 $11055 forward @7 unknown T -8.8817841970012523e-16 -25 15 4.9999999999999991 -20 20 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 20 #
+loop $-1 -1 -1 $-1 $-1 $11056 $8766 T -7.5000000000000027 -25 -25 8.8817841970012523e-16 -20 -10 unknown #
+loop $-1 -1 -1 $-1 $-1 $10930 $7781 T -50 -25 -30.000000000000004 -50 -15 -20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $10945 $10945 $11057 $11058 forward $8767 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11059 $7782 T -50 -25 -45 -50 -15 -35 unknown #
+coedge $-1 -1 -1 $-1 $11060 $11060 $11061 $11062 forward $8768 $-1 #
+coedge $-1 -1 -1 $-1 $11063 $8769 $11064 $11065 reversed $7783 $-1 #
+coedge $-1 -1 -1 $-1 $8769 $11063 $11066 $11067 forward $7783 $-1 #
+coedge $-1 -1 -1 $-1 $11068 $11069 $8769 $9854 reversed $11070 $-1 #
+edge $-1 -1 -1 $-1 $11071 1.5707963267948966 $11072 2.0943951023931957 $8769 $11073 forward @7 unknown T -25 -15.669872981077809 -42.500000000000007 -22.5 -15 -40 #
+coedge $-1 -1 -1 $-1 $11074 $11075 $8770 $9856 forward $11076 $-1 #
+edge $-1 -1 -1 $-1 $10826 1.5707963267948966 $9861 2.0943951023931957 $9855 $11077 forward @7 unknown T -7.5000000000000027 -25 -40 -5 -24.330127018922191 -37.5 #
+edge $-1 -1 -1 $-1 $9612 -2.0943951023931957 $9860 -1.5707963267948966 $8771 $11078 forward @7 unknown T -10.000000000000002 -25 -42.500000000000007 -7.5000000000000009 -24.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $11079 $8772 $11080 $11081 reversed $9723 $-1 #
+coedge $-1 -1 -1 $-1 $8772 $11082 $11074 $11083 reversed $9723 $-1 #
+vertex $-1 -1 -1 $-1 $10820 $11084 #
+vertex $-1 -1 -1 $-1 $8773 $11085 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11086 $8776 $9784 $11000 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $8776 $11087 $9775 $10992 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $9876 $11088 $11089 $9774 reversed $9877 $-1 #
+coedge $-1 -1 -1 $-1 $11090 $9740 $8778 $9867 reversed $8644 $-1 #
+edge $-1 -1 -1 $-1 $9871 -1.5707963267948966 $9870 1.5707963267948966 $8778 $11091 forward @7 unknown T -45 -24.999999999999996 -10.000000000000002 -40 -14.999999999999996 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $9742 $8779 $11092 $11093 reversed $7620 $-1 #
+coedge $-1 -1 -1 $-1 $8779 $11094 $11095 $11096 reversed $7620 $-1 #
+vertex $-1 -1 -1 $-1 $8780 $11097 #
+vertex $-1 -1 -1 $-1 $8780 $11098 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -10.000000000000002 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11099 $11100 $8781 $9874 forward $9846 $-1 #
+edge $-1 -1 -1 $-1 $9883 1.0471975511965974 $9878 1.5707963267948966 $9873 $11101 forward @7 unknown T -7.5000000000000027 -25 -12.500000000000004 -5 -24.330127018922191 -10 #
+coedge $-1 -1 -1 $-1 $11102 $8782 $8787 $9889 forward $9877 $-1 #
+coedge $-1 -1 -1 $-1 $8782 $9865 $11033 $10993 forward $9877 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9865 $11013 T -7.5000000000000027 -25 -10 0 -20 5 unknown #
+vertex $-1 -1 -1 $-1 $9874 $11103 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -10 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11104 $8784 $11100 $11105 reversed $9882 $-1 #
+coedge $-1 -1 -1 $-1 $8784 $11106 $11107 $9891 reversed $9882 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11104 $10971 T -15.000000000000004 -25 -25 -7.5000000000000009 -20 -10 unknown #
+vertex $-1 -1 -1 $-1 $9874 $11108 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $11109 $8786 $11110 $11111 forward $8788 $-1 #
+coedge $-1 -1 -1 $-1 $11107 $11112 $8786 $9887 forward $11113 $-1 #
+edge $-1 -1 -1 $-1 $11114 6.1232339957367648e-17 $8789 1.5707963267948966 $9886 $11115 forward @7 unknown T -15.000000000000002 -25 -10 -10.000000000000002 -20 -5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $8787 $11109 $8854 $9977 reversed $8788 $-1 #
+edge $-1 -1 -1 $-1 $8790 -7.5 $11116 2.4999999999999982 $9875 $11117 forward @7 unknown T -7.5000000000000027 -24.330127018922198 -7.5 -7.5000000000000009 -24.330127018922191 2.4999999999999982 #
+face $-1 -1 -1 $-1 $10861 $8788 $11 $-1 $6619 reversed single T -15.000000000000002 -25 -10 -7.5000000000000009 -20 4.9999999999999991 F #
+edge $-1 -1 -1 $-1 $8789 -1.5707963267948966 $11118 -6.1232339957367648e-17 $11107 $11119 forward @7 unknown T -15.000000000000004 -25 -15.000000000000002 -10.000000000000002 -20 -10 #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 -10 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922198 -7.5 #
+coedge $-1 -1 -1 $-1 $11120 $11121 $11056 $9895 forward $11031 $-1 #
+edge $-1 -1 -1 $-1 $10988 -20 $9897 -15 $9894 $11122 forward @7 unknown T -8.8817841970012523e-16 -20 -20 8.8817841970012523e-16 -20 -15 #
+coedge $-1 -1 -1 $-1 $8794 $9775 $11120 $11123 reversed $9776 $-1 #
+vertex $-1 -1 -1 $-1 $11123 $11124 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $11125 $8798 T 29.999999999999996 -10.000000000000004 5.0000000000000018 37.500000000000007 -4.9999999999999991 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $11126 $11127 $11128 $11129 reversed $8799 $-1 #
+coedge $-1 -1 -1 $-1 $11130 $8800 $11131 $11132 reversed $7808 $-1 #
+coedge $-1 -1 -1 $-1 $8800 $11133 $11134 $11135 reversed $7808 $-1 #
+coedge $-1 -1 -1 $-1 $11136 $10467 $8800 $9904 forward $11137 $-1 #
+edge $-1 -1 -1 $-1 $11138 1.5707963267948966 $11139 2.0943951023931966 $9903 $11140 forward @7 unknown T 35 -10.000000000000002 -24.999999999999996 37.500000000000007 -9.3301270189221892 -22.499999999999986 #
+coedge $-1 -1 -1 $-1 $11141 $8801 $11142 $11143 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $9283 $11144 $8801 $9907 forward $10475 $-1 #
+edge $-1 -1 -1 $-1 $11145 -2.0943951023931957 $9287 -1.5707963267948966 $9906 $11146 forward @7 unknown T 35 -0.66987298107781124 -24.999999999999996 37.5 -1.7763568394002505e-15 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $8802 $11141 $8812 $9930 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $11147 $11148 $11149 $9910 forward $11150 $-1 #
+edge $-1 -1 -1 $-1 $9912 -20 $11151 -14.999999999999998 $9909 $11152 forward @7 unknown T 29.999999999999996 -5.0000000000000009 -20 30 -4.9999999999999991 -14.999999999999998 #
+coedge $-1 -1 -1 $-1 $9285 $8803 $11148 $11153 reversed $9286 $-1 #
+vertex $-1 -1 -1 $-1 $11154 $11155 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8808 $8805 $8820 $9940 reversed $5964 $-1 #
+coedge $-1 -1 -1 $-1 $11156 $11157 $8805 $9916 forward $11158 $-1 #
+edge $-1 -1 -1 $-1 $11159 -2.5000000000000053 $9920 7.4999999999999947 $9915 $11160 forward @7 unknown T 37.5 -0.6698729810778089 -7.4999999999999947 37.5 -0.66987298107780502 2.5000000000000053 #
+coedge $-1 -1 -1 $-1 $11161 $8806 $11141 $11162 forward $9919 $-1 #
+coedge $-1 -1 -1 $-1 $8806 $11161 $11156 $11163 reversed $9919 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9917 $11164 T 35 -0.66987298107781079 -12.5 40 0 -7.4999999999999947 unknown #
+vertex $-1 -1 -1 $-1 $11163 $11165 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11166 $8809 $8830 $9951 forward $9925 $-1 #
+coedge $-1 -1 -1 $-1 $8809 $11167 $8811 $9929 forward $9925 $-1 #
+coedge $-1 -1 -1 $-1 $11168 $11169 $11170 $8810 reversed $11171 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8809 $11172 T 22.5 -5.0000000000000009 -9.9999999999999982 30 8.8817841970012523e-16 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $9951 $11173 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $8812 $8811 $11147 $11174 reversed $8813 $-1 #
+edge $-1 -1 -1 $-1 $11175 1.570796326794897 $8815 3.1415926535897931 $9923 $11176 forward @7 unknown T 25 -4.9999999999999991 -9.9999999999999982 29.999999999999996 0 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $11151 2.9403902792268244e-16 $8814 1.5707963267948966 $8812 $11177 forward @7 unknown T 30 -5 -15 35 -1.7763568394002505e-15 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $11178 $8813 $11 $-1 $11179 reversed single T 25 -5 -15 35 8.8817841970012523e-16 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $8815 3.1415926535897931 $11180 4.7123889803846897 $11168 $11176 forward @7 unknown T 24.999999999999996 -10 -9.9999999999999982 29.999999999999996 -4.9999999999999991 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 -4.9999999999999991 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $11181 $8818 $8821 $9941 forward $8452 $-1 #
+coedge $-1 -1 -1 $-1 $8818 $11182 $8837 $9958 forward $8452 $-1 #
+vertex $-1 -1 -1 $-1 $8819 $11183 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $8821 $8820 $11157 $11184 reversed $8822 $-1 #
+edge $-1 -1 -1 $-1 $7823 1.5707963267948966 $11159 2.0943951023931948 $8820 $11185 forward @7 unknown T 35 -0.66987298107780724 2.5000000000000053 37.5 -8.8817841970012523e-16 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $8823 4.1887902047863905 $11186 4.7123889803846897 $9935 $11187 forward @7 unknown T 37.500000000000007 -0.66987298107780979 5.0000000000000027 40.000000000000007 8.8817841970012523e-16 7.5000000000000098 #
+face $-1 -1 -1 $-1 $10478 $8822 $11 $-1 $9956 reversed single T 35 -0.66987298107781257 2.5000000000000053 40.000000000000007 8.8817841970012523e-16 7.5000000000000098 F #
+point $-1 -1 -1 $-1 37.500000000000007 -0.66987298107780979 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $11188 $8825 $10457 $9965 forward $8495 $-1 #
+coedge $-1 -1 -1 $-1 $8826 $11188 $11189 $11190 forward $8495 $-1 #
+coedge $-1 -1 -1 $-1 $11191 $8827 $11192 $8835 forward $9949 $-1 #
+coedge $-1 -1 -1 $-1 $8827 $11193 $11194 $11195 forward $9949 $-1 #
+coedge $-1 -1 -1 $-1 $11196 $11197 $6875 $7819 forward $9899 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8827 $9962 T 22.499999999999996 -10 4.9999999999999991 30 -4.9999999999999991 20 unknown #
+point $-1 -1 -1 $-1 29.999999999999996 -5 15 #
+edge $-1 -1 -1 $-1 $9926 0 $9952 1.5707963267948961 $9922 $11198 forward @7 unknown T 25 -5 1.7763568394002505e-15 29.999999999999996 0 5.0000000000000018 #
+vertex $-1 -1 -1 $-1 $11199 $11200 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11201 $11202 $11 $-1 $9956 reversed single T 24.999999999999996 -10.000000000000004 1.7763568394002505e-15 35 -4.9999999999999991 10.000000000000002 F #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 -5 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $11203 $11204 #
+edge $-1 -1 -1 $-1 $9960 -1.570796326794897 $9937 -1.0471975511965979 $9936 $11205 forward @7 unknown T 37.499999999999993 -0.66987298107780813 17.500000000000004 40 0 20.000000000000007 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $9958 $11206 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10738 $9949 $11 $-1 $4486 reversed single T 22.499999999999996 -10 4.9999999999999991 30 -4.9999999999999991 20 F #
+coedge $-1 -1 -1 $-1 $10360 $11194 $8842 $7839 reversed $9968 $-1 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $8844 -1.5707963267948966 $11207 -1.047197551196597 $9944 $11208 forward @7 unknown T 22.5 -0.66987298107780902 17.499999999999996 25 0 20 #
+point $-1 -1 -1 $-1 25 0 20 #
+face $-1 -1 -1 $-1 $8840 $10369 $11 $-1 $8848 reversed single T 35 -10.000000000000002 17.500000000000007 40.000000000000007 -9.3301270189221892 22.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $10360 $8847 T 25 -10.000000000000002 15 35 -4.9999999999999991 25.000000000000007 unknown #
+edge $-1 -1 -1 $-1 $11209 1.0471975511965979 $8849 1.5707963267948966 $11193 $11208 forward @7 unknown T 22.500000000000004 -10 17.5 25 -9.3301270189221928 20 #
+point $-1 -1 -1 $-1 25 -10 20 #
+coedge $-1 -1 -1 $-1 $8852 $8852 $11210 $11211 forward $7842 $-1 #
+coedge $-1 -1 -1 $-1 $11212 $11213 $8852 $9973 reversed $8644 $-1 #
+edge $-1 -1 -1 $-1 $11214 -1.5707963267948966 $11215 1.5707963267948966 $8852 $11216 forward @7 unknown T -45 -24.999999999999996 -3.5527136788005009e-15 -40 -14.999999999999996 4.9999999999999973 #
+coedge $-1 -1 -1 $-1 $8854 $8853 $11102 $11217 reversed $6889 $-1 #
+coedge $-1 -1 -1 $-1 $10856 $10997 $8853 $9976 forward $8759 $-1 #
+edge $-1 -1 -1 $-1 $11005 1.5707963267948966 $9980 2.0943951023931957 $9975 $11218 forward @7 unknown T -7.5000000000000027 -25 5 -5 -24.330127018922191 7.5000000000000027 #
+edge $-1 -1 -1 $-1 $11116 -2.0943951023931948 $9979 -1.5707963267948966 $8854 $11219 forward @7 unknown T -10.000000000000002 -25 2.4999999999999982 -7.5000000000000027 -24.330127018922195 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $10860 $8855 $11220 $11221 reversed $9655 $-1 #
+vertex $-1 -1 -1 $-1 $11222 $11223 #
+vertex $-1 -1 -1 $-1 $8856 $11224 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25.000000000000004 -30 20 #
+coedge $-1 -1 -1 $-1 $11225 $8877 $11226 $11227 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $10019 $11228 $8877 $8915 reversed $10040 $-1 #
+coedge $-1 -1 -1 $-1 $11229 $8878 $8880 $8935 reversed $9987 $-1 #
+coedge $-1 -1 -1 $-1 $8878 $11230 $7925 $8912 forward $9987 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9986 $11231 T 0 35 35 7.5000000000000036 40 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $8880 $8923 $11232 $11233 forward $7954 $-1 #
+coedge $-1 -1 -1 $-1 $8884 $11234 $8881 $8961 forward $9994 $-1 #
+coedge $-1 -1 -1 $-1 $11235 $10038 $8882 $9992 forward $11236 $-1 #
+edge $-1 -1 -1 $-1 $7938 6.1232339957367648e-17 $10079 1.5707963267948966 $9991 $11237 forward @7 unknown T 15 35 35 20.000000000000004 40 40 #
+coedge $-1 -1 -1 $-1 $11234 $8884 $10067 $8952 reversed $9994 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9990 $11238 T 20.000000000000004 35 32.5 25 35.669872981077809 37.5 unknown #
+coedge $-1 -1 -1 $-1 $11239 $9999 $8886 $9996 reversed $11240 $-1 #
+edge $-1 -1 -1 $-1 $10007 -2.0943951023931966 $8887 -1.5707963267948966 $8886 $11241 forward @7 unknown T 35 35 32.5 37.500000000000007 35.669872981077816 35 #
+edge $-1 -1 -1 $-1 $8887 -1.5707963267948966 $8948 -6.1232339957367648e-17 $8889 $11242 forward @7 unknown T 30 35 30 35 40 35 #
+point $-1 -1 -1 $-1 35 35 35 #
+coedge $-1 -1 -1 $-1 $9995 $11243 $8889 $9997 reversed $11240 $-1 #
+coedge $-1 -1 -1 $-1 $8895 $8898 $8892 $10001 forward $8902 $-1 #
+edge $-1 -1 -1 $-1 $7919 -1.5707963267948966 $7915 1.5707963267948966 $10000 $11244 forward @7 unknown T 40 35 30 45 45 35 #
+loop $-1 -1 -1 $-1 $-1 $11245 $10003 T 50 35 30 50 45 40 unknown #
+face $-1 -1 -1 $-1 $11246 $8893 $11 $-1 $8951 reversed single T 40 35 30 50 45 40 F #
+coedge $-1 -1 -1 $-1 $11247 $8895 $8954 $10069 forward $8902 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 40 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8898 $11248 $11239 $11249 forward $8902 $-1 #
+vertex $-1 -1 -1 $-1 $8899 $11250 #
+coedge $-1 -1 -1 $-1 $8903 $11251 $11252 $11253 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $11254 $11255 $8903 $10010 reversed $11256 $-1 #
+edge $-1 -1 -1 $-1 $11257 -2.0943951023931957 $10014 0 $8903 $11258 forward @7 unknown T -22.5 40 50 -15 45 50 #
+coedge $-1 -1 -1 $-1 $11259 $8904 $11255 $11260 reversed $10013 $-1 #
+coedge $-1 -1 -1 $-1 $8904 $11261 $8906 $10017 reversed $10013 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10012 $11262 T -15 40 35 -7.4999999999999982 45 50 unknown #
+vertex $-1 -1 -1 $-1 $11263 $11264 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10018 $8906 $11265 $11266 forward $8908 $-1 #
+edge $-1 -1 -1 $-1 $8909 -50 $11267 -37.5 $8906 $11268 forward @7 unknown T -7.5000000000000018 44.330127018922191 37.5 -7.4999999999999991 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $8907 $10016 $11269 $11270 forward $8908 $-1 #
+coedge $-1 -1 -1 $-1 $11271 $9984 $9986 $8912 reversed $10040 $-1 #
+face $-1 -1 -1 $-1 $11272 $8908 $11 $-1 $10041 reversed single T -7.5000000000000018 40 35 1.7763568394002505e-15 45 50 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $11269 $11273 $8911 $10023 forward $11274 $-1 #
+edge $-1 -1 -1 $-1 $11275 -1.5707963267948966 $10024 6.1232339957367673e-17 $10022 $11276 forward @7 unknown T 0 40 35 5.0000000000000027 45 40 #
+vertex $-1 -1 -1 $-1 $11277 $11278 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11279 $8917 $8913 $10027 forward $10032 $-1 #
+edge $-1 -1 -1 $-1 $8919 -2.0943951023931948 $11275 -1.5707963267948966 $10026 $11280 forward @7 unknown T 5.0000000000000027 44.330127018922198 35 7.5000000000000027 45 37.500000000000007 #
+face $-1 -1 -1 $-1 $11281 $11282 $11 $-1 $10029 reversed single T 0 40 -50 7.5000000000000027 45 -40 F #
+cone-surface $-1 -1 -1 $-1 5.0000000000000027 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $11283 $11284 #
+coedge $-1 -1 -1 $-1 $8917 $11279 $11285 $11286 reversed $10032 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10026 $11287 T 5.0000000000000027 44.330127018922191 32.5 10 45 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $11286 $11288 #
+ellipse-curve $-1 -1 -1 $-1 10 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000027 44.330127018922205 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $8925 $8921 $11289 $11290 reversed $8926 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9991 $11291 $8923 $8929 reversed $11236 $-1 #
+face $-1 -1 -1 $-1 $11292 $11293 $11 $-1 $7955 reversed single T 7.4999999999999991 40 20 15.000000000000002 45 35 F #
+loop $-1 -1 -1 $-1 $-1 $10019 $8924 T -7.5000000000000009 35 35 1.7763568394002505e-15 40 50 unknown #
+cone-surface $-1 -1 -1 $-1 -5 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $11294 $10046 $8925 $10043 reversed $11295 $-1 #
+edge $-1 -1 -1 $-1 $11296 -6.1232339957367648e-17 $8927 1.5707963267948966 $8925 $11297 forward @7 unknown T 15 40 30 20.000000000000004 45 35 #
+point $-1 -1 -1 $-1 20.000000000000004 45 35 #
+vertex $-1 -1 -1 $-1 $11298 $11299 #
+coedge $-1 -1 -1 $-1 $10042 $11300 $8931 $10047 reversed $11295 $-1 #
+edge $-1 -1 -1 $-1 $8927 1.5707963267948966 $10054 2.0943951023931953 $8931 $11301 forward @7 unknown T 20.000000000000004 44.330127018922184 32.5 22.500000000000004 45 35 #
+face $-1 -1 -1 $-1 $9364 $11302 $11 $-1 $7943 reversed single T 15 35 -40 22.500000000000007 40 -25 F #
+loop $-1 -1 -1 $-1 $-1 $11303 $8933 T 15 40 -40 22.500000000000011 45 -25 unknown #
+coedge $-1 -1 -1 $-1 $11304 $9340 $9342 $9387 reversed $8934 $-1 #
+vertex $-1 -1 -1 $-1 $11305 $11306 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11307 $8937 $11300 $11308 forward $8945 $-1 #
+vertex $-1 -1 -1 $-1 $11308 $11309 #
+ellipse-curve $-1 -1 -1 $-1 25 40 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8314 $11310 $11 $-1 $7955 reversed single T 7.4999999999999991 35 20 15.000000000000002 40 35 F #
+coedge $-1 -1 -1 $-1 $8941 $11311 $11312 $10063 forward $8945 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 40 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11312 $10067 $8943 $10060 forward $10071 $-1 #
+edge $-1 -1 -1 $-1 $7960 -1.5707963267948966 $8948 0 $10059 $10058 forward @7 unknown T 25 35 30 30 40 35 #
+face $-1 -1 -1 $-1 $11238 $11236 $11 $-1 $8951 reversed single T 10 35 30 20.000000000000004 40 40 F #
+coedge $-1 -1 -1 $-1 $10068 $8946 $11313 $11314 reversed $8947 $-1 #
+edge $-1 -1 -1 $-1 $11315 25 $8948 30 $10057 $11316 forward @7 unknown T 29.999999999999996 40 25 30 40 30 #
+face $-1 -1 -1 $-1 $11317 $8947 $11 $-1 $6121 reversed single T 29.999999999999996 40 20.000000000000004 37.500000000000007 45 35 F #
+point $-1 -1 -1 $-1 30 40 30 #
+vertex $-1 -1 -1 $-1 $8952 $11318 #
+coedge $-1 -1 -1 $-1 $10059 $11319 $9993 $8952 forward $10071 $-1 #
+coedge $-1 -1 -1 $-1 $8954 $10062 $11320 $11321 reversed $8947 $-1 #
+edge $-1 -1 -1 $-1 $8955 -32.5 $11322 -22.500000000000011 $10004 $11323 forward @7 unknown T 37.5 44.330127018922191 22.500000000000011 37.500000000000007 44.330127018922198 32.5 #
+point $-1 -1 -1 $-1 37.500000000000007 44.330127018922191 32.5 #
+loop $-1 -1 -1 $-1 $-1 $11312 $8957 T 22.499999999999993 35 19.999999999999996 30 40 35 unknown #
+coedge $-1 -1 -1 $-1 $10569 $11324 $9383 $10579 reversed $8958 $-1 #
+coedge $-1 -1 -1 $-1 $11325 $8959 $10573 $11326 reversed $7965 $-1 #
+coedge $-1 -1 -1 $-1 $8959 $11327 $11328 $11329 reversed $7965 $-1 #
+coedge $-1 -1 -1 $-1 $11330 $11331 $11332 $10076 forward $11333 $-1 #
+edge $-1 -1 -1 $-1 $11334 -35 $11335 -30 $10075 $11336 forward @7 unknown T 29.999999999999996 40 -35 30 40 -30 #
+coedge $-1 -1 -1 $-1 $9347 $11337 $8960 $10078 forward $10534 $-1 #
+edge $-1 -1 -1 $-1 $10576 1.5707963267948966 $9349 2.0943951023931957 $10077 $11338 forward @7 unknown T 35 44.330127018922191 -42.5 37.500000000000007 45 -40 #
+vertex $-1 -1 -1 $-1 $11339 $11340 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11341 $8963 $11342 $10119 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $11343 $11344 $8963 $10083 reversed $11345 $-1 #
+edge $-1 -1 -1 $-1 $9010 2.6179938779914949 $8994 4.7123889803846897 $8963 $11346 forward @7 unknown T -15 20 50 -7.4999999999999991 25 50 #
+coedge $-1 -1 -1 $-1 $8964 $11347 $11343 $10139 forward $9020 $-1 #
+coedge $-1 -1 -1 $-1 $10086 $8965 $11348 $10161 reversed $8967 $-1 #
+coedge $-1 -1 -1 $-1 $8966 $10085 $11349 $11350 reversed $8967 $-1 #
+face $-1 -1 -1 $-1 $8006 $8967 $11 $-1 $9009 reversed single T 0 20 35 7.5000000000000062 25 50 F #
+coedge $-1 -1 -1 $-1 $11351 $11348 $8969 $10089 reversed $11352 $-1 #
+edge $-1 -1 -1 $-1 $9025 1.5707963267948966 $9031 2.0943951023931966 $8969 $9014 forward @7 unknown T 7.4999999999999956 20 35 10 20.669872981077813 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $8970 $8973 $11353 $11354 forward $8974 $-1 #
+coedge $-1 -1 -1 $-1 $10147 $8971 $11355 $10195 forward $10092 $-1 #
+loop $-1 -1 -1 $-1 $-1 $8971 $9041 T 10 20 30 20 25 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8031 $8974 $11 $-1 $8043 reversed single T 20 20 32.5 25 20.669872981077813 37.5 F #
+coedge $-1 -1 -1 $-1 $11356 $8975 $8986 $10105 reversed $10096 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11356 $11357 T 29.999999999999996 19.999999999999996 20.000000000000004 37.500000000000007 25 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $8979 $11358 $8038 $9043 forward $10096 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10101 $10101 $11359 $11360 reversed $8982 $-1 #
+face $-1 -1 -1 $-1 $11361 $11362 $11 $-1 $8043 reversed single T -9.9999999999999982 20 32.5 -5 20.669872981077805 37.5 F #
+coedge $-1 -1 -1 $-1 $11363 $8984 $11364 $11365 forward $7994 $-1 #
+coedge $-1 -1 -1 $-1 $8986 $11363 $11366 $11367 forward $7994 $-1 #
+edge $-1 -1 -1 $-1 $11368 22.500000000000007 $8987 32.500000000000007 $8986 $11369 forward @7 unknown T 37.5 20.669872981077802 22.500000000000007 37.500000000000007 20.669872981077805 32.500000000000007 #
+point $-1 -1 -1 $-1 37.500000000000007 20.669872981077805 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $8988 $11370 $11371 $11372 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $11373 $11374 $8988 $10109 reversed $11375 $-1 #
+edge $-1 -1 -1 $-1 $11376 -1.5707963267948966 $10113 0.5235987755982987 $8988 $11377 forward @7 unknown T -30 25 50 -22.5 30 50 #
+coedge $-1 -1 -1 $-1 $11378 $8989 $11374 $11379 forward $10112 $-1 #
+coedge $-1 -1 -1 $-1 $8989 $11380 $11381 $10116 forward $10112 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10111 $11382 T -22.500000000000004 25 35 -15 30 50 unknown #
+vertex $-1 -1 -1 $-1 $8990 $11383 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10117 $8991 $11384 $11385 reversed $8993 $-1 #
+edge $-1 -1 -1 $-1 $11386 40 $8994 50 $10111 $11387 forward @7 unknown T -15 25 40 -15 25 50 #
+coedge $-1 -1 -1 $-1 $8992 $10115 $11388 $11389 reversed $8993 $-1 #
+face $-1 -1 -1 $-1 $11390 $8993 $11 $-1 $11391 reversed single T -15 25 35 -7.4999999999999964 30 50 F #
+edge $-1 -1 -1 $-1 $8994 0 $11392 2.0943951023931948 $10081 $10114 forward @7 unknown T -22.5 20 50 -15 25 50 #
+point $-1 -1 -1 $-1 -15 25 50 #
+coedge $-1 -1 -1 $-1 $11388 $11393 $8996 $10122 reversed $11394 $-1 #
+edge $-1 -1 -1 $-1 $10123 4.1887902047863914 $11395 4.7123889803846897 $8996 $11396 forward @7 unknown T -7.4999999999999982 29.330127018922191 35 -5 30 37.5 #
+vertex $-1 -1 -1 $-1 $10122 $11397 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11398 $9002 $8998 $10126 reversed $10130 $-1 #
+edge $-1 -1 -1 $-1 $11395 1.5707963267948966 $9004 3.1415926535897931 $8998 $11399 forward @7 unknown T -5 25 35 0 30 40 #
+coedge $-1 -1 -1 $-1 $11347 $8999 $11400 $10133 forward $9020 $-1 #
+face $-1 -1 -1 $-1 $11401 $11402 $11 $-1 $11403 reversed single T 39.999999999999993 20 15.000000000000004 50 30 25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $9002 $11398 $11404 $11405 forward $10130 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9002 $10148 T -5 25 30 5.0000000000000018 30 40 unknown #
+vertex $-1 -1 -1 $-1 $11405 $11406 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9004 3.1415926535897931 $11407 4.7123889803846897 $10127 $11399 forward @7 unknown T -5 20 35 0 25 40 #
+point $-1 -1 -1 $-1 0 25 40 #
+coedge $-1 -1 -1 $-1 $9011 $9006 $11408 $11409 forward $9012 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11410 $11411 $11 $-1 $9009 reversed single T 0 25 -40 7.5000000000000027 30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $11412 $9008 T 0 25 -50 7.5000000000000009 30 -40 unknown #
+edge $-1 -1 -1 $-1 $11413 37.5 $9010 50 $10084 $11414 forward @7 unknown T -7.5 20.669872981077805 37.5 -7.4999999999999991 20.669872981077805 50 #
+point $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $11415 $10145 $9011 $10142 forward $10149 $-1 #
+edge $-1 -1 -1 $-1 $9013 -1.5707963267948966 $11416 -1.0471975511965974 $10141 $11417 forward @7 unknown T 7.4999999999999991 29.330127018922191 32.5 10 30 35 #
+face $-1 -1 -1 $-1 $11418 $9012 $11 $-1 $8043 reversed single T 5.0000000000000018 29.330127018922191 32.5 10 30 37.500000000000007 F #
+point $-1 -1 -1 $-1 10 30 35 #
+coedge $-1 -1 -1 $-1 $10141 $11419 $9016 $10146 forward $10149 $-1 #
+edge $-1 -1 -1 $-1 $10152 0 $9013 1.5707963267948966 $10145 $11420 forward @7 unknown T 10 25 30 15 30 35 #
+coedge $-1 -1 -1 $-1 $9018 $10091 $11421 $11422 reversed $10092 $-1 #
+face $-1 -1 -1 $-1 $11423 $10130 $11 $-1 $8043 reversed single T -5 25 30 5.0000000000000018 30 40 F #
+loop $-1 -1 -1 $-1 $-1 $11419 $9019 T 7.4999999999999991 25 20 15 30 35 unknown #
+coedge $-1 -1 -1 $-1 $11424 $9022 $11419 $11425 reversed $10151 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11424 $11426 T 15 25 20 22.5 30 35 unknown #
+vertex $-1 -1 -1 $-1 $10146 $11427 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11428 1.0471975511965979 $9025 1.5707963267948966 $11429 $11417 forward @7 unknown T 7.5 20 32.5 10 20.669872981077809 35 #
+point $-1 -1 -1 $-1 10 20 35 #
+coedge $-1 -1 -1 $-1 $9026 $11430 $9033 $10164 reversed $10151 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $11431 $9028 T 15 20 -40 22.500000000000004 25 -25 unknown #
+coedge $-1 -1 -1 $-1 $11432 $11433 $11434 $11435 reversed $9029 $-1 #
+coedge $-1 -1 -1 $-1 $9418 $9030 $11436 $10654 reversed $8026 $-1 #
+edge $-1 -1 -1 $-1 $11437 1.5707963267948966 $9031 2.0943951023931966 $11348 $11438 forward @7 unknown T 5.0000000000000018 20 35 7.5000000000000062 20.669872981077813 37.500000000000007 #
+point $-1 -1 -1 $-1 7.5 20.669872981077813 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $10167 $9033 $11439 $11440 forward $8037 $-1 #
+edge $-1 -1 -1 $-1 $9034 -32.5 $11441 -22.5 $9033 $11442 forward @7 unknown T 22.5 29.330127018922191 22.5 22.5 29.330127018922195 32.5 #
+point $-1 -1 -1 $-1 22.5 29.330127018922191 32.5 #
+loop $-1 -1 -1 $-1 $-1 $11443 $9036 T 7.4999999999999956 20 20 15 25 35 unknown #
+coedge $-1 -1 -1 $-1 $9037 $10163 $11444 $11445 forward $8037 $-1 #
+coedge $-1 -1 -1 $-1 $11446 $9039 $10099 $9043 reversed $9051 $-1 #
+coedge $-1 -1 -1 $-1 $11444 $11447 $9042 $10170 forward $11448 $-1 #
+edge $-1 -1 -1 $-1 $11449 -1.5707963267948966 $10171 -6.4931039580273245e-16 $10169 $11450 forward @7 unknown T 29.999999999999996 25 20.000000000000004 35 29.999999999999996 25.000000000000007 #
+vertex $-1 -1 -1 $-1 $11451 $11452 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $11453 $11454 $11 $-1 $5288 reversed single T 29.999999999999996 25 5.0000000000000018 37.500000000000007 29.999999999999996 20.000000000000004 F #
+point $-1 -1 -1 $-1 22.500000000000004 20.669872981077813 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $9047 $11455 $11456 $11457 forward $9051 $-1 #
+coedge $-1 -1 -1 $-1 $11458 $11364 $9048 $10177 forward $11459 $-1 #
+edge $-1 -1 -1 $-1 $10178 -2.0943951023931957 $11449 -1.5707963267948966 $10176 $11460 forward @7 unknown T 35 29.330127018922187 20.000000000000004 37.500000000000007 29.999999999999996 22.500000000000011 #
+vertex $-1 -1 -1 $-1 $11365 $11461 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9052 $11462 $11463 $11464 reversed $8050 $-1 #
+coedge $-1 -1 -1 $-1 $11465 $9053 $10193 $11466 reversed $7103 $-1 #
+edge $-1 -1 -1 $-1 $9441 -1.5707963267948966 $10190 -6.4931039580273265e-16 $9438 $11467 forward @7 unknown T 30 25 -40 35 29.999999999999996 -35 #
+coedge $-1 -1 -1 $-1 $9054 $11465 $11468 $11469 reversed $7103 $-1 #
+coedge $-1 -1 -1 $-1 $11470 $11471 $9054 $10185 forward $11472 $-1 #
+edge $-1 -1 -1 $-1 $10191 6.4931039580273206e-16 $11473 1.5707963267948966 $10184 $11474 forward @7 unknown T 29.999999999999996 25 -30 35 29.999999999999996 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $11475 $9055 $11471 $11476 forward $10189 $-1 #
+coedge $-1 -1 -1 $-1 $9055 $11477 $10648 $11478 forward $10189 $-1 #
+coedge $-1 -1 -1 $-1 $10640 $11479 $10644 $9056 reversed $11480 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9055 $10653 T 22.5 25 -40 30 30 -25 unknown #
+vertex $-1 -1 -1 $-1 $10641 $11481 #
+vertex $-1 -1 -1 $-1 $11476 $11482 #
+coedge $-1 -1 -1 $-1 $9057 $9398 $10181 $11466 forward $9399 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9059 -1.5707963267948966 $10152 -6.1232339957367648e-17 $10091 $11483 forward @7 unknown T 15 20 30 20 25 35 #
+point $-1 -1 -1 $-1 20 20 35 #
+coedge $-1 -1 -1 $-1 $11484 $9061 $11485 $11486 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $10237 $11487 $9061 $9099 reversed $11488 $-1 #
+coedge $-1 -1 -1 $-1 $11489 $9062 $9064 $9119 reversed $10201 $-1 #
+coedge $-1 -1 -1 $-1 $9062 $11490 $8083 $9096 forward $10201 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10199 $11491 T -15 5 35 -7.4999999999999991 10 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9064 $9107 $11492 $11493 forward $8112 $-1 #
+coedge $-1 -1 -1 $-1 $9068 $11494 $9065 $9141 forward $10208 $-1 #
+coedge $-1 -1 -1 $-1 $11495 $10256 $9066 $10206 forward $11496 $-1 #
+edge $-1 -1 -1 $-1 $8096 6.1232339957367648e-17 $10293 1.5707963267948966 $10205 $11497 forward @7 unknown T 0 4.9999999999999991 35 5.0000000000000009 10 40 #
+coedge $-1 -1 -1 $-1 $11494 $9068 $10285 $9134 reversed $10208 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10204 $11498 T 5.0000000000000009 4.9999999999999991 32.5 10 5.669872981077809 37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $10312 $10211 $9070 $10210 reversed $11499 $-1 #
+edge $-1 -1 -1 $-1 $8138 -2.0943951023931957 $8151 -1.5707963267948966 $9070 $11500 forward @7 unknown T 20 4.9999999999999982 32.5 22.500000000000004 5.6698729810778072 35 #
+coedge $-1 -1 -1 $-1 $10209 $11501 $9071 $9175 reversed $11499 $-1 #
+coedge $-1 -1 -1 $-1 $10214 $9075 $11502 $11503 reversed $9076 $-1 #
+face $-1 -1 -1 $-1 $5297 $9076 $11 $-1 $4445 reversed single T 29.999999999999996 4.9999999999999982 20.000000000000004 37.500000000000007 10 35 F #
+coedge $-1 -1 -1 $-1 $9079 $10212 $11504 $11505 reversed $9076 $-1 #
+coedge $-1 -1 -1 $-1 $10215 $10215 $9081 $10216 forward $11506 $-1 #
+edge $-1 -1 -1 $-1 $11507 0 $11507 6.2831853071795862 $10215 $11508 forward @7 unknown T 50 5 30 50 15 40 #
+face $-1 -1 -1 $-1 $8092 $11509 $11 $-1 $7181 reversed single T -50 5 29.999999999999996 -40 15.000000000000002 40 F #
+loop $-1 -1 -1 $-1 $-1 $11510 $9082 T -10 5 32.5 -5 5.669872981077809 37.5 unknown #
+coedge $-1 -1 -1 $-1 $9084 $9083 $11511 $11512 forward $7132 $-1 #
+coedge $-1 -1 -1 $-1 $9156 $11513 $9083 $10221 reversed $10315 $-1 #
+edge $-1 -1 -1 $-1 $9158 4.1887902047863887 $11514 4.7123889803846897 $9083 $11515 forward @7 unknown T 37.499999999999993 14.330127018922186 20.000000000000004 40.000000000000007 15 22.500000000000014 #
+coedge $-1 -1 -1 $-1 $11516 $11502 $9084 $10223 reversed $11517 $-1 #
+edge $-1 -1 -1 $-1 $11518 1.570796326794897 $10224 2.0943951023931957 $9084 $11515 forward @7 unknown T 37.500000000000007 5 20.000000000000004 40.000000000000007 5.669872981077809 22.500000000000007 #
+vertex $-1 -1 -1 $-1 $11503 $11519 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9087 $11484 $11520 $11521 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $11522 $11523 $9087 $10228 reversed $11524 $-1 #
+edge $-1 -1 -1 $-1 $11525 -2.0943951023931948 $10232 0 $9087 $11526 forward @7 unknown T -37.5 10 50 -30 15 50 #
+coedge $-1 -1 -1 $-1 $11527 $9088 $11523 $11528 reversed $10231 $-1 #
+coedge $-1 -1 -1 $-1 $9088 $11529 $9090 $10235 reversed $10231 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10230 $11530 T -30 10 35 -22.499999999999993 15.000000000000002 50 unknown #
+vertex $-1 -1 -1 $-1 $11531 $11532 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10236 $9090 $11533 $11534 forward $9092 $-1 #
+edge $-1 -1 -1 $-1 $9093 -50 $11535 -37.499999999999993 $9090 $11536 forward @7 unknown T -22.5 14.330127018922193 37.499999999999993 -22.499999999999993 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $9091 $10234 $11537 $11538 forward $9092 $-1 #
+coedge $-1 -1 -1 $-1 $11539 $10198 $10200 $9096 reversed $11488 $-1 #
+face $-1 -1 -1 $-1 $11540 $9092 $11 $-1 $11541 reversed single T -22.5 10 35 -15 15 50 F #
+point $-1 -1 -1 $-1 -22.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $11537 $11542 $9095 $10241 forward $11543 $-1 #
+edge $-1 -1 -1 $-1 $11544 -1.5707963267948966 $10242 6.1232339957367648e-17 $10240 $11545 forward @7 unknown T -15 10 35 -10 15 40 #
+vertex $-1 -1 -1 $-1 $11546 $11547 #
+straight-curve $-1 -1 -1 $-1 -15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11548 $9101 $9097 $10245 forward $10250 $-1 #
+edge $-1 -1 -1 $-1 $9103 -2.0943951023931948 $11544 -1.5707963267948966 $10244 $11549 forward @7 unknown T -10 14.330127018922193 35 -7.4999999999999982 15 37.5 #
+face $-1 -1 -1 $-1 $11550 $11551 $11 $-1 $10247 reversed single T -15 10 20 -7.4999999999999982 15 35 F #
+cone-surface $-1 -1 -1 $-1 -10 10 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $11552 $11553 #
+coedge $-1 -1 -1 $-1 $9101 $11548 $11554 $11555 reversed $10250 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10244 $11556 T -10 14.330127018922191 32.5 -5 15 37.5 unknown #
+vertex $-1 -1 -1 $-1 $11555 $11557 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999982 14.330127018922193 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $9109 $9105 $11558 $11559 reversed $9110 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10205 $11560 $9107 $9113 reversed $11496 $-1 #
+face $-1 -1 -1 $-1 $11561 $11562 $11 $-1 $10259 reversed single T -10 5 17.5 -5 5.669872981077809 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $11563 $11564 $9108 T 39.999999999999993 5 15.000000000000004 45.000000000000007 15 25.000000000000004 unknown #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 10 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $11565 $10264 $9109 $10261 reversed $11566 $-1 #
+edge $-1 -1 -1 $-1 $11567 -6.1232339957367648e-17 $9111 1.5707963267948966 $9109 $11568 forward @7 unknown T 0 10 30 5.0000000000000009 15 35 #
+point $-1 -1 -1 $-1 5.0000000000000009 15 35 #
+vertex $-1 -1 -1 $-1 $11569 $11570 #
+coedge $-1 -1 -1 $-1 $10260 $11571 $9115 $10265 reversed $11566 $-1 #
+edge $-1 -1 -1 $-1 $9111 1.5707963267948966 $10272 2.0943951023931948 $9115 $11572 forward @7 unknown T 5.0000000000000009 14.330127018922195 32.5 7.5000000000000027 15 35 #
+face $-1 -1 -1 $-1 $9478 $11573 $11 $-1 $8101 reversed single T 0 4.9999999999999991 -40 7.5000000000000018 10 -25 F #
+loop $-1 -1 -1 $-1 $-1 $11574 $9117 T 0 10 -40 7.5000000000000027 15 -25 unknown #
+coedge $-1 -1 -1 $-1 $11575 $9449 $9451 $9499 reversed $9118 $-1 #
+vertex $-1 -1 -1 $-1 $11576 $11577 #
+straight-curve $-1 -1 -1 $-1 -7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11578 $9121 $11571 $11579 forward $9129 $-1 #
+vertex $-1 -1 -1 $-1 $11579 $11580 #
+ellipse-curve $-1 -1 -1 $-1 10 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8402 $11581 $11 $-1 $8113 reversed single T -7.5000000000000009 5 20 8.8817841970012523e-16 10 35 F #
+coedge $-1 -1 -1 $-1 $9125 $11582 $10299 $10281 forward $9129 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10299 $10285 $9127 $10278 forward $9146 $-1 #
+edge $-1 -1 -1 $-1 $8117 -1.5707963267948966 $9132 0 $10277 $10276 forward @7 unknown T 10 5 30 15 10 35 #
+face $-1 -1 -1 $-1 $11498 $11496 $11 $-1 $7181 reversed single T -5 4.9999999999999991 30 5.0000000000000009 10 40 F #
+coedge $-1 -1 -1 $-1 $10286 $9130 $11583 $11584 reversed $9131 $-1 #
+edge $-1 -1 -1 $-1 $11585 25 $9132 30 $10275 $11586 forward @7 unknown T 15 10 25 15 10 30 #
+face $-1 -1 -1 $-1 $11587 $9131 $11 $-1 $6219 reversed single T 15 10 20 22.500000000000004 14.999999999999998 35 F #
+point $-1 -1 -1 $-1 15 10 30 #
+vertex $-1 -1 -1 $-1 $9134 $11588 #
+coedge $-1 -1 -1 $-1 $10277 $11589 $10207 $9134 forward $9146 $-1 #
+coedge $-1 -1 -1 $-1 $9136 $10280 $11590 $11591 reversed $9131 $-1 #
+coedge $-1 -1 -1 $-1 $10703 $11592 $9497 $10713 reversed $9138 $-1 #
+coedge $-1 -1 -1 $-1 $11593 $9139 $10707 $11594 reversed $8121 $-1 #
+coedge $-1 -1 -1 $-1 $9139 $11595 $11596 $11597 reversed $8121 $-1 #
+coedge $-1 -1 -1 $-1 $11598 $11599 $11600 $10291 forward $11601 $-1 #
+edge $-1 -1 -1 $-1 $11602 -35 $11603 -30 $10290 $11604 forward @7 unknown T 15 10 -35 15 10 -30 #
+coedge $-1 -1 -1 $-1 $9452 $11605 $9140 $9519 forward $10661 $-1 #
+vertex $-1 -1 -1 $-1 $11606 $11607 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11590 $11608 $9143 $10296 reversed $11609 $-1 #
+edge $-1 -1 -1 $-1 $10297 4.1887902047863914 $11610 4.7123889803846897 $9143 $11611 forward @7 unknown T 22.499999999999996 14.330127018922193 20 25 15 22.499999999999996 #
+vertex $-1 -1 -1 $-1 $10296 $11612 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11613 $10277 $11501 $10281 reversed $9146 $-1 #
+coedge $-1 -1 -1 $-1 $11614 $9149 $9147 $10301 reversed $10304 $-1 #
+edge $-1 -1 -1 $-1 $11610 1.5707963267948966 $9151 3.1415926535897931 $9147 $11615 forward @7 unknown T 25 10 20 29.999999999999996 15 25 #
+coedge $-1 -1 -1 $-1 $10311 $9148 $11616 $10307 forward $8143 $-1 #
+coedge $-1 -1 -1 $-1 $9149 $11614 $11617 $11618 forward $10304 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9149 $9464 T 25 10 15 35 15 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $11618 $11619 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9151 3.1415926535897931 $11620 4.7123889803846897 $10302 $11615 forward @7 unknown T 25 5 20 29.999999999999996 10 25 #
+point $-1 -1 -1 $-1 29.999999999999996 10 25 #
+face $-1 -1 -1 $-1 $11621 $11622 $11 $-1 $4445 reversed single T 29.999999999999996 10 -9.9999999999999982 37.5 15 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $11623 $9153 T 29.999999999999996 10 5.0000000000000018 37.500000000000007 15 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $9155 $10302 $11624 $11625 forward $8143 $-1 #
+coedge $-1 -1 -1 $-1 $11626 $10209 $9155 $10313 reversed $11499 $-1 #
+edge $-1 -1 -1 $-1 $11627 22.5 $8138 32.5 $9155 $11628 forward @7 unknown T 22.5 5.6698729810778055 22.5 22.500000000000004 5.6698729810778064 32.5 #
+coedge $-1 -1 -1 $-1 $11513 $9156 $11629 $11630 forward $10315 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9156 $11631 T 35 14.330127018922186 17.500000000000011 40.000000000000007 15 22.500000000000014 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.499999999999993 14.330127018922186 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $9160 $10724 $11632 $11633 reversed $7188 $-1 #
+coedge $-1 -1 -1 $-1 $11634 $9457 $9160 $10320 forward $10666 $-1 #
+edge $-1 -1 -1 $-1 $9516 -37.5 $11635 -27.499999999999993 $10319 $11636 forward @7 unknown T 37.5 5.6698729810778046 -37.5 37.500000000000007 5.6698729810778064 -27.499999999999993 #
+coedge $-1 -1 -1 $-1 $9163 $9161 $10668 $11637 reversed $6241 $-1 #
+edge $-1 -1 -1 $-1 $10669 -2.0943951023931953 $8429 -1.5707963267948966 $9173 $11638 forward @7 unknown T 35 14.330127018922191 -40 37.5 14.999999999999998 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11639 $11640 $9163 $10325 forward $11641 $-1 #
+edge $-1 -1 -1 $-1 $10329 1.5707963267948966 $11642 2.0943951023931944 $10324 $11643 forward @7 unknown T 35 14.330127018922193 -27.499999999999993 37.5 14.999999999999998 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $11644 $9164 $11645 $11646 forward $10328 $-1 #
+coedge $-1 -1 -1 $-1 $9164 $11644 $9166 $10332 reversed $10328 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9164 $11647 T 25 10 -30 35 15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $9165 $11648 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11649 $9166 $11650 $11651 forward $9169 $-1 #
+edge $-1 -1 -1 $-1 $9171 0 $11652 1.5707963267948961 $9166 $11653 forward @7 unknown T 25 10 -30 29.999999999999996 15 -25 #
+coedge $-1 -1 -1 $-1 $9167 $11649 $10660 $11654 forward $9169 $-1 #
+edge $-1 -1 -1 $-1 $8431 1.5707963267948966 $9170 3.1415926535897931 $9167 $10720 forward @7 unknown T 25 10 -40 30 15 -35 #
+coedge $-1 -1 -1 $-1 $9168 $11655 $11656 $11657 forward $10336 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9168 $11658 T 22.5 5 -40 30 10 -25 unknown #
+point $-1 -1 -1 $-1 30 10 -35 #
+point $-1 -1 -1 $-1 29.999999999999996 10 -30 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9203 $9177 $11659 $10383 forward $1338 $-1 #
+coedge $-1 -1 -1 $-1 $11660 $11661 $9177 $10342 reversed $11662 $-1 #
+edge $-1 -1 -1 $-1 $9225 2.617993877991494 $9209 4.7123889803846897 $9177 $11663 forward @7 unknown T -30 -9.9999999999999982 50 -22.5 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $9178 $11664 $11660 $10404 forward $10344 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9214 $11665 T -22.5 -10 35 -15 -4.9999999999999991 50 unknown #
+coedge $-1 -1 -1 $-1 $10346 $9179 $10365 $10428 reversed $9181 $-1 #
+coedge $-1 -1 -1 $-1 $9180 $10345 $11666 $11667 reversed $9181 $-1 #
+face $-1 -1 -1 $-1 $11668 $9181 $11 $-1 $9224 reversed single T -15 -10 35 -7.5 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $11669 $10365 $9183 $10349 reversed $9197 $-1 #
+edge $-1 -1 -1 $-1 $9239 1.5707963267948966 $9245 2.0943951023931957 $9183 $9229 forward @7 unknown T -7.5000000000000009 -10 35 -5 -9.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $9184 $9187 $11670 $11671 forward $9188 $-1 #
+coedge $-1 -1 -1 $-1 $10412 $9185 $11672 $10455 forward $10352 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9185 $9255 T -5 -10 30 5 -4.9999999999999991 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8215 $9188 $11 $-1 $6317 reversed single T 5 -10 32.5 10 -9.330127018922191 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $10464 $11673 T 15 -10 20 22.500000000000004 -4.9999999999999991 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9191 $11674 $8222 $9256 forward $10355 $-1 #
+coedge $-1 -1 -1 $-1 $9199 $11675 $9192 $10359 forward $10369 $-1 #
+edge $-1 -1 -1 $-1 $11676 1.5707963267948966 $9201 2.0943951023931966 $10358 $11677 forward @7 unknown T 35 -10.000000000000002 20.000000000000004 37.500000000000007 -9.3301270189221892 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $11678 $9963 $9194 $10361 forward $9968 $-1 #
+edge $-1 -1 -1 $-1 $6886 -4.7167471186270745e-16 $11676 1.5707963267948966 $10360 $11679 forward @7 unknown T 29.999999999999996 -10.000000000000002 20.000000000000004 35 -4.9999999999999991 25.000000000000007 #
+vertex $-1 -1 -1 $-1 $9195 $11680 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $11681 $11682 $9196 T -45 -9.9999999999999964 30 -40 2.6645352591003757e-15 40 unknown #
+coedge $-1 -1 -1 $-1 $10348 $11683 $10345 $10428 forward $9197 $-1 #
+coedge $-1 -1 -1 $-1 $10416 $10416 $9198 $10367 reversed $9235 $-1 #
+edge $-1 -1 -1 $-1 $9960 1.570796326794897 $10370 4.7123889803846897 $9198 $11684 forward @7 unknown T 39.999999999999993 -10 20.000000000000004 44.999999999999993 0 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $11675 $9199 $11685 $11686 reversed $10369 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10358 $9967 T 35 -10.000000000000002 17.500000000000007 40.000000000000007 -9.3301270189221892 22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $11686 $11687 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221892 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $11688 $11689 $9203 $10373 reversed $11690 $-1 #
+edge $-1 -1 -1 $-1 $11691 2.617993877991494 $10377 6.8067840827778854 $9203 $11692 forward @7 unknown T -45 -9.9999999999999964 50 -37.5 2.6645352591003757e-15 50 #
+coedge $-1 -1 -1 $-1 $11693 $9204 $11689 $11694 forward $10376 $-1 #
+coedge $-1 -1 -1 $-1 $9204 $11695 $11696 $10380 forward $10376 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10375 $11697 T -37.500000000000007 -4.9999999999999991 35 -30 0 50 unknown #
+vertex $-1 -1 -1 $-1 $9205 $11698 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10381 $9206 $11699 $11700 reversed $9208 $-1 #
+edge $-1 -1 -1 $-1 $11701 40 $9209 50 $10375 $11702 forward @7 unknown T -30 -4.9999999999999991 40 -30 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $9207 $10379 $11703 $11704 reversed $9208 $-1 #
+face $-1 -1 -1 $-1 $11705 $9208 $11 $-1 $11706 reversed single T -30 -4.9999999999999991 35 -22.5 1.7763568394002505e-15 50 F #
+edge $-1 -1 -1 $-1 $9209 -1.7763568394002506e-16 $11691 2.0943951023931957 $10340 $10378 forward @7 unknown T -37.5 -10 50 -30 -4.9999999999999991 50 #
+point $-1 -1 -1 $-1 -30 -4.9999999999999991 50 #
+coedge $-1 -1 -1 $-1 $11703 $11707 $9211 $10386 reversed $11708 $-1 #
+edge $-1 -1 -1 $-1 $10387 4.1887902047863905 $11709 4.7123889803846897 $9211 $11710 forward @7 unknown T -22.500000000000004 -0.66987298107780902 35 -20 0 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $10386 $11711 #
+straight-curve $-1 -1 -1 $-1 -22.5 -0.66987298107780546 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11712 $9217 $9213 $10390 reversed $10395 $-1 #
+edge $-1 -1 -1 $-1 $11709 1.5707963267948966 $9219 3.1415926535897931 $9213 $11713 forward @7 unknown T -20 -4.9999999999999991 35 -15 0 40 #
+coedge $-1 -1 -1 $-1 $11664 $9214 $11714 $10398 forward $10344 $-1 #
+face $-1 -1 -1 $-1 $11715 $11716 $11 $-1 $9738 reversed single T -37.5 -10 35 -30 -4.9999999999999991 50 F #
+cone-surface $-1 -1 -1 $-1 -20 -5 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $9217 $11712 $11717 $11718 forward $10395 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9217 $11719 T -20 -5 30 -10 8.8817841970012523e-16 40 unknown #
+vertex $-1 -1 -1 $-1 $11718 $11720 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9219 3.1415926535897931 $11721 4.7123889803846897 $10391 $11713 forward @7 unknown T -20 -10 35 -15 -4.9999999999999991 40 #
+point $-1 -1 -1 $-1 -15 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $9226 $9221 $11722 $11723 forward $9227 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11724 $11725 $11 $-1 $9224 reversed single T -15 -5 4.9999999999999991 -7.4999999999999991 1.7763568394002505e-15 20 F #
+loop $-1 -1 -1 $-1 $-1 $11726 $9223 T -15 -5 20 -7.4999999999999991 8.8817841970012523e-16 35 unknown #
+edge $-1 -1 -1 $-1 $11727 37.5 $9225 50 $10343 $11728 forward @7 unknown T -22.5 -9.3301270189221928 37.5 -22.5 -9.3301270189221928 50 #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221928 50 #
+coedge $-1 -1 -1 $-1 $11729 $10410 $9226 $10407 forward $11730 $-1 #
+edge $-1 -1 -1 $-1 $9228 -1.5707963267948966 $11731 -1.0471975511965974 $10406 $11732 forward @7 unknown T -7.5000000000000009 -0.66987298107780902 32.5 -5 0 35 #
+face $-1 -1 -1 $-1 $11719 $9227 $11 $-1 $6317 reversed single T -10 -0.66987298107780902 32.5 -5 8.8817841970012523e-16 37.500000000000007 F #
+point $-1 -1 -1 $-1 -5 0 35 #
+coedge $-1 -1 -1 $-1 $10406 $11733 $9231 $10411 forward $11730 $-1 #
+edge $-1 -1 -1 $-1 $10419 0 $9228 1.5707963267948966 $10410 $11734 forward @7 unknown T -5 -5 30 0 0 35 #
+coedge $-1 -1 -1 $-1 $9233 $10351 $11735 $11736 reversed $10352 $-1 #
+face $-1 -1 -1 $-1 $11737 $11738 $11 $-1 $8848 reversed single T -50 -10 14.999999999999996 -40 2.6645352591003757e-15 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $11739 $9234 T -10 -10 17.499999999999996 -5 -9.330127018922191 22.5 unknown #
+loop $-1 -1 -1 $-1 $-1 $10980 $8200 T 50 -10 15.000000000000004 50 0 25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $10366 $10366 $11182 $11740 reversed $9235 $-1 #
+coedge $-1 -1 -1 $-1 $11741 $9236 $11733 $11742 reversed $10418 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11741 $11030 T -9.3734986416366059e-33 -5 20 7.5000000000000018 0 35 unknown #
+vertex $-1 -1 -1 $-1 $10411 $11743 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11744 1.0471975511965979 $9239 1.5707963267948966 $11745 $11732 forward @7 unknown T -7.5000000000000018 -10 32.5 -5 -9.330127018922191 35 #
+point $-1 -1 -1 $-1 -5 -10 35 #
+coedge $-1 -1 -1 $-1 $9240 $11746 $9247 $10431 reversed $10418 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $11747 $9242 T -9.3734986416366059e-33 -10 -40 7.5000000000000018 -4.9999999999999991 -25 unknown #
+coedge $-1 -1 -1 $-1 $11748 $11749 $11750 $11751 reversed $9243 $-1 #
+coedge $-1 -1 -1 $-1 $9550 $9244 $11752 $10791 reversed $8210 $-1 #
+edge $-1 -1 -1 $-1 $11753 1.5707963267948966 $9245 2.0943951023931953 $10365 $11754 forward @7 unknown T -10 -10 35 -7.5 -9.330127018922191 37.5 #
+point $-1 -1 -1 $-1 -7.5 -9.3301270189221928 37.5 #
+coedge $-1 -1 -1 $-1 $10434 $9247 $11755 $11756 forward $8221 $-1 #
+edge $-1 -1 -1 $-1 $9248 -32.5 $11757 -22.499999999999993 $9247 $11758 forward @7 unknown T 7.5 -0.66987298107780746 22.499999999999993 7.5000000000000018 -0.66987298107780624 32.5 #
+point $-1 -1 -1 $-1 7.5000000000000018 -0.66987298107780746 32.5 #
+loop $-1 -1 -1 $-1 $-1 $11759 $9250 T -7.5000000000000018 -10 20 0 -4.9999999999999991 35 unknown #
+coedge $-1 -1 -1 $-1 $9251 $10430 $11044 $11760 forward $8221 $-1 #
+vertex $-1 -1 -1 $-1 $11761 $11762 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $9259 $11763 $11764 $11765 forward $8237 $-1 #
+coedge $-1 -1 -1 $-1 $11766 $9269 $9260 $10440 forward $10458 $-1 #
+edge $-1 -1 -1 $-1 $9271 -2.0943951023931948 $11046 -1.5707963267948966 $10439 $11767 forward @7 unknown T 20 -0.66987298107780724 20 22.499999999999996 -8.8817841970012523e-16 22.5 #
+coedge $-1 -1 -1 $-1 $9261 $11768 $9579 $10793 reversed $8229 $-1 #
+coedge $-1 -1 -1 $-1 $11769 $9262 $10454 $11770 reversed $7259 $-1 #
+edge $-1 -1 -1 $-1 $9573 -1.5707963267948966 $10451 -2.9403902792268234e-16 $9570 $11771 forward @7 unknown T 15 -4.9999999999999991 -40 20 -8.8817841970012523e-16 -35 #
+coedge $-1 -1 -1 $-1 $9263 $11769 $11772 $11773 reversed $7259 $-1 #
+coedge $-1 -1 -1 $-1 $11774 $11775 $9263 $10446 forward $11776 $-1 #
+edge $-1 -1 -1 $-1 $10452 1.1640334398265733e-16 $11777 1.5707963267948961 $10445 $11778 forward @7 unknown T 15 -5 -30 20 -8.8817841970012523e-16 -25 #
+coedge $-1 -1 -1 $-1 $11779 $9264 $11775 $11780 forward $10450 $-1 #
+coedge $-1 -1 -1 $-1 $9264 $11781 $10787 $11782 forward $10450 $-1 #
+coedge $-1 -1 -1 $-1 $10780 $11783 $10784 $9265 reversed $11784 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9264 $9582 T 7.5 -5 -40 15 0 -25 unknown #
+vertex $-1 -1 -1 $-1 $10781 $11785 #
+vertex $-1 -1 -1 $-1 $11780 $11786 #
+coedge $-1 -1 -1 $-1 $9266 $9525 $10442 $11770 forward $9526 $-1 #
+edge $-1 -1 -1 $-1 $9267 -1.5707963267948966 $10419 -6.1232339957367648e-17 $10351 $11787 forward @7 unknown T -9.3734986416366059e-33 -10 30 5 -5 35 #
+point $-1 -1 -1 $-1 5 -10 35 #
+coedge $-1 -1 -1 $-1 $9269 $11766 $9944 $9965 reversed $10458 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10439 $11788 T 20 -0.66987298107780902 17.499999999999996 25 0 22.500000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.499999999999993 -0.66987298107780691 22.5 #
+coedge $-1 -1 -1 $-1 $11763 $9273 $11789 $11761 forward $8237 $-1 #
+coedge $-1 -1 -1 $-1 $11790 $11791 $9274 $10463 reversed $11792 $-1 #
+edge $-1 -1 -1 $-1 $8849 1.5707963267948961 $10465 2.0943951023931939 $9274 $10459 forward @7 unknown T 22.5 -10 19.999999999999996 25 -9.3301270189221928 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $11674 $9275 $11791 $11793 reversed $10355 $-1 #
+vertex $-1 -1 -1 $-1 $11793 $11794 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9903 $11795 $9277 $10468 forward $11137 $-1 #
+edge $-1 -1 -1 $-1 $10470 -2.0943951023931939 $11138 -1.5707963267948966 $10467 $11796 forward @7 unknown T 35 -10.000000000000002 -27.499999999999989 37.5 -9.3301270189221963 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $11797 $9278 $11795 $11798 forward $9531 $-1 #
+vertex $-1 -1 -1 $-1 $11798 $11799 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $10476 27.499999999999993 $9534 37.500000000000007 $9533 $11800 forward @7 unknown T 37.5 -0.66987298107780902 -37.500000000000007 37.500000000000007 -0.66987298107780613 -27.499999999999993 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11144 $9283 $10739 $11801 reversed $10475 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9906 $11802 T 35 -0.66987298107781124 -27.499999999999993 40.000000000000007 0 -22.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $9284 $11803 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11804 $9286 $11 $-1 $11805 reversed single T 25 -5 -30 35 0 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 -1.7763568394002505e-15 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $9291 $9289 $11769 $11806 forward $8250 $-1 #
+coedge $-1 -1 -1 $-1 $11807 $11772 $9289 $10482 reversed $11808 $-1 #
+edge $-1 -1 -1 $-1 $10483 -1.5707963267948966 $11809 -1.047197551196597 $9289 $11810 forward @7 unknown T 22.5 -0.66987298107780902 -27.500000000000004 25 0 -25 #
+vertex $-1 -1 -1 $-1 $10482 $11811 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11812 4.1887902047863914 $7489 4.7123889803846897 $9291 $9581 forward @7 unknown T 22.500000000000004 -0.66987298107780902 -40 25 0 -37.5 #
+coedge $-1 -1 -1 $-1 $9293 $9579 $11813 $11814 forward $9294 $-1 #
+coedge $-1 -1 -1 $-1 $11815 $10798 $9293 $10488 reversed $11816 $-1 #
+edge $-1 -1 -1 $-1 $11817 -1.5707963267948961 $8252 0 $9293 $10484 forward @7 unknown T 25 -10 -30 29.999999999999996 -5 -25 #
+face $-1 -1 -1 $-1 $9568 $9294 $11 $-1 $4486 reversed single T 22.5 -10 -40 30 -4.9999999999999991 -25 F #
+coedge $-1 -1 -1 $-1 $11818 $9299 $9301 $9328 reversed $10492 $-1 #
+coedge $-1 -1 -1 $-1 $9299 $11819 $8264 $9309 forward $10492 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10491 $11820 T -30 -25 35 -22.5 -20 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9304 $9661 $11821 $11822 forward $9305 $-1 #
+coedge $-1 -1 -1 $-1 $10868 $9665 $10491 $9309 reversed $9667 $-1 #
+face $-1 -1 -1 $-1 $9690 $9305 $11 $-1 $8642 reversed single T -37.5 -20 35 -30 -15 50 F #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $11821 $11823 $9308 $10500 forward $11824 $-1 #
+edge $-1 -1 -1 $-1 $11825 -1.5707963267948966 $10501 6.1232339957367648e-17 $10499 $11826 forward @7 unknown T -30 -20 35 -25 -15 40 #
+vertex $-1 -1 -1 $-1 $11827 $11828 #
+straight-curve $-1 -1 -1 $-1 -30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11829 $9314 $9310 $10504 forward $10507 $-1 #
+edge $-1 -1 -1 $-1 $9316 -2.0943951023931953 $11825 -1.5707963267948966 $10503 $11830 forward @7 unknown T -25 -15.669872981077809 35 -22.499999999999993 -15 37.5 #
+face $-1 -1 -1 $-1 $11831 $11070 $11 $-1 $7628 reversed single T -30 -20 -50 -22.5 -15 -40 F #
+coedge $-1 -1 -1 $-1 $9314 $11829 $9728 $9726 reversed $10507 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10503 $11832 T -25 -15.669872981077809 32.5 -20 -15 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.499999999999993 -15.669872981077805 37.499999999999993 #
+face $-1 -1 -1 $-1 $11833 $9712 $11 $-1 $9321 reversed single T -22.500000000000004 -20 20 -15 -15 35 F #
+face $-1 -1 -1 $-1 $7607 $9323 $11 $-1 $1965 reversed single T -20 -20 30 -10.000000000000002 -15 40 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 35 #
+edge $-1 -1 -1 $-1 $9324 1.5707963267948966 $9660 2.0943951023931953 $9326 $11834 forward @7 unknown T -10.000000000000002 -15.669872981077809 32.5 -7.5000000000000027 -15 35 #
+vertex $-1 -1 -1 $-1 $11835 $11836 #
+straight-curve $-1 -1 -1 $-1 -22.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9791 $9330 $10899 $10865 forward $7558 $-1 #
+coedge $-1 -1 -1 $-1 $10833 $11023 $9626 $10842 reversed $9333 $-1 #
+coedge $-1 -1 -1 $-1 $11019 $9334 $10836 $11837 reversed $8286 $-1 #
+coedge $-1 -1 -1 $-1 $9334 $11011 $10986 $11838 reversed $8286 $-1 #
+coedge $-1 -1 -1 $-1 $11839 $11840 $11841 $10521 forward $11842 $-1 #
+edge $-1 -1 -1 $-1 $11843 -35 $11844 -30 $10520 $11845 forward @7 unknown T -8.8817841970012523e-16 -20 -35 0 -20 -30 #
+coedge $-1 -1 -1 $-1 $9593 $11846 $9335 $9641 forward $10805 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 35 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $11847 $9339 $11848 $11849 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $10554 $11850 $9339 $9365 reversed $10568 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9342 $9380 $11851 $11852 forward $9343 $-1 #
+coedge $-1 -1 -1 $-1 $11853 $11853 $9344 $10529 reversed $11854 $-1 #
+edge $-1 -1 -1 $-1 $10531 -1.5707963267948966 $10535 1.5707963267948966 $9344 $11855 forward @7 unknown T 40 35 -45 45 45 -40 #
+coedge $-1 -1 -1 $-1 $9345 $9383 $11856 $11857 reversed $9384 $-1 #
+vertex $-1 -1 -1 $-1 $9346 $11858 #
+ellipse-curve $-1 -1 -1 $-1 40 40 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11337 $9347 $11859 $11860 reversed $10534 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10077 $11861 T 35 44.330127018922191 -42.5 40 45 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $9348 $11862 #
+point $-1 -1 -1 $-1 37.500000000000007 44.330127018922191 -42.5 #
+face $-1 -1 -1 $-1 $11863 $11864 $11 $-1 $7001 reversed single T 37.499999999999993 35 5.0000000000000027 45.000000000000007 45 20.000000000000007 F #
+coedge $-1 -1 -1 $-1 $9352 $11865 $11866 $11867 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $11868 $11869 $9352 $10540 reversed $11870 $-1 #
+edge $-1 -1 -1 $-1 $11871 -2.0943951023931957 $10544 0 $9352 $11872 forward @7 unknown T -7.5000000000000009 35 -50 8.8817841970012523e-16 40 -50 #
+coedge $-1 -1 -1 $-1 $11873 $9353 $11874 $11875 forward $10543 $-1 #
+coedge $-1 -1 -1 $-1 $9353 $11876 $9355 $10547 reversed $10543 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10542 $11877 T 0 35 -50 7.5000000000000027 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $11878 $11879 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10548 $9355 $11880 $11881 forward $9357 $-1 #
+edge $-1 -1 -1 $-1 $9358 -50 $11882 -42.5 $9355 $11883 forward @7 unknown T 7.5 35.669872981077809 -50 7.5000000000000018 35.669872981077809 -42.5 #
+coedge $-1 -1 -1 $-1 $9356 $10546 $11884 $11885 forward $9357 $-1 #
+face $-1 -1 -1 $-1 $11886 $9357 $11 $-1 $7955 reversed single T 7.4999999999999991 35 -50 15.000000000000002 40 -40 F #
+point $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $11884 $11887 $9360 $10552 forward $11888 $-1 #
+edge $-1 -1 -1 $-1 $11889 -1.5707963267948966 $10555 -6.1232339957367648e-17 $10551 $11890 forward @7 unknown T 15 35 -45 20.000000000000004 40 -40 #
+coedge $-1 -1 -1 $-1 $9361 $11304 $11891 $11892 reversed $8934 $-1 #
+coedge $-1 -1 -1 $-1 $11893 $10525 $9356 $9362 forward $10568 $-1 #
+vertex $-1 -1 -1 $-1 $11894 $11895 #
+straight-curve $-1 -1 -1 $-1 15.000000000000002 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11896 $9367 $9363 $10558 forward $10561 $-1 #
+edge $-1 -1 -1 $-1 $9369 -2.0943951023931948 $11889 -1.5707963267948966 $10557 $11897 forward @7 unknown T 20.000000000000004 35 -42.5 22.5 35.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $11898 $11899 #
+coedge $-1 -1 -1 $-1 $9367 $11896 $11900 $11901 reversed $10561 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10557 $11902 T 20.000000000000004 35 -42.5 25 35.669872981077809 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $9368 $11903 #
+ellipse-curve $-1 -1 -1 $-1 25 40 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.5 35.669872981077809 -42.5 #
+coedge $-1 -1 -1 $-1 $9374 $9371 $11904 $11905 reversed $9375 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11906 $11907 $11 $-1 $7024 reversed single T 22.5 40 5.0000000000000018 30 45 20 F #
+loop $-1 -1 -1 $-1 $-1 $10554 $9373 T 7.4999999999999991 40 -50 15.000000000000002 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $11908 $10072 $9374 $10570 reversed $8958 $-1 #
+edge $-1 -1 -1 $-1 $11334 6.1232339957367648e-17 $9376 1.5707963267948966 $9374 $11909 forward @7 unknown T 30 35 -40 35 40 -35 #
+face $-1 -1 -1 $-1 $11910 $9375 $11 $-1 $11911 reversed single T 25 35 -45 35 40 -35 F #
+point $-1 -1 -1 $-1 35 35 -40 #
+coedge $-1 -1 -1 $-1 $11912 $9378 $10073 $11326 forward $10575 $-1 #
+coedge $-1 -1 -1 $-1 $9378 $11912 $9380 $9381 reversed $10575 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9378 $11910 T 25 40 -45 35 45 -35 unknown #
+vertex $-1 -1 -1 $-1 $9379 $11913 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $11852 $11914 #
+edge $-1 -1 -1 $-1 $9376 1.5707963267948966 $11915 2.0943951023931957 $9383 $11916 forward @7 unknown T 35 35 -40 37.500000000000007 35.669872981077809 -37.5 #
+face $-1 -1 -1 $-1 $11917 $9384 $11 $-1 $11911 reversed single T 35 35 -42.500000000000014 40 35.669872981077816 -37.5 F #
+vertex $-1 -1 -1 $-1 $11918 $11919 #
+straight-curve $-1 -1 -1 $-1 22.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11920 $9389 $11921 $10614 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $11412 $10610 $9389 $10585 reversed $10138 $-1 #
+edge $-1 -1 -1 $-1 $9424 -0.52359877559829826 $9409 1.5707963267948966 $9389 $11922 forward @7 unknown T 8.8817841970012523e-16 25 -50 7.5000000000000009 30 -50 #
+coedge $-1 -1 -1 $-1 $9390 $11923 $11412 $10634 forward $9433 $-1 #
+coedge $-1 -1 -1 $-1 $11924 $11436 $9392 $10588 reversed $11925 $-1 #
+edge $-1 -1 -1 $-1 $9443 -1.5707963267948966 $9446 -1.0471975511965974 $9392 $9428 forward @7 unknown T 22.5 29.330127018922191 -42.5 25 30 -40 #
+coedge $-1 -1 -1 $-1 $9393 $9393 $11926 $11927 reversed $10590 $-1 #
+loop $-1 -1 -1 $-1 $11928 $9393 $11929 T 40 20 -45 45 30 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11463 $11926 $9395 $10593 forward $11930 $-1 #
+edge $-1 -1 -1 $-1 $9396 1.5707963267948966 $10651 2.0943951023931948 $10592 $11931 forward @7 unknown T 37.5 20 -40 40 20.669872981077805 -37.5 #
+point $-1 -1 -1 $-1 40 20 -40 #
+coedge $-1 -1 -1 $-1 $11926 $11932 $9398 $10596 forward $11930 $-1 #
+edge $-1 -1 -1 $-1 $11933 4.1887902047863914 $9400 4.7123889803846897 $10595 $11931 forward @7 unknown T 37.5 29.330127018922195 -40 40 30 -37.5 #
+face $-1 -1 -1 $-1 $9445 $9399 $11 $-1 $10647 reversed single T 35 29.330127018922187 -42.500000000000007 40 30 -37.5 F #
+point $-1 -1 -1 $-1 40 30 -40 #
+face $-1 -1 -1 $-1 $11934 $11448 $11 $-1 $11403 reversed single T 25 25 15 35 30 25.000000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $11935 $9402 T 37.499999999999993 20 5.0000000000000027 45.000000000000007 30 20.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $9403 $11936 $11937 $11938 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $11939 $11940 $9403 $10603 reversed $11941 $-1 #
+edge $-1 -1 -1 $-1 $11942 1.5707963267948966 $10607 3.6651914291880914 $9403 $11943 forward @7 unknown T -15 20 -50 -7.4999999999999991 25 -50 #
+coedge $-1 -1 -1 $-1 $11944 $9404 $11940 $11945 forward $10606 $-1 #
+coedge $-1 -1 -1 $-1 $9404 $11946 $9406 $10611 reversed $10606 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10605 $11947 T -7.4999999999999991 20 -50 8.8817841970012523e-16 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $9405 $11948 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10612 $9406 $11949 $11950 reversed $9408 $-1 #
+coedge $-1 -1 -1 $-1 $10584 $11951 $11952 $10611 reversed $10138 $-1 #
+edge $-1 -1 -1 $-1 $9409 -50 $11953 -45 $11952 $11954 forward @7 unknown T 0 25 -50 8.8817841970012523e-16 25 -45 #
+coedge $-1 -1 -1 $-1 $9407 $10609 $11955 $11956 reversed $9408 $-1 #
+face $-1 -1 -1 $-1 $7072 $9408 $11 $-1 $9009 reversed single T 0 20 -50 7.5000000000000009 25 -40 F #
+edge $-1 -1 -1 $-1 $9409 0 $11957 2.0943951023931948 $10583 $10608 forward @7 unknown T -7.4999999999999991 25 -50 8.8817841970012523e-16 30 -50 #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 25 -50 #
+coedge $-1 -1 -1 $-1 $11955 $11958 $9411 $10617 reversed $11959 $-1 #
+edge $-1 -1 -1 $-1 $10618 1.0471975511965979 $11960 1.5707963267948966 $9411 $11961 forward @7 unknown T 7.5 20 -42.5 10 20.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $10617 $11962 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11963 $9416 $9413 $10621 reversed $10624 $-1 #
+edge $-1 -1 -1 $-1 $11960 -1.5707963267948966 $9420 0 $9413 $11964 forward @7 unknown T 10 20 -45 15 25 -40 #
+face $-1 -1 -1 $-1 $11965 $11966 $11 $-1 $9021 reversed single T -7.5000000000000009 25 -50 8.8817841970012523e-16 30 -40 F #
+coedge $-1 -1 -1 $-1 $9416 $11963 $11967 $11968 forward $10624 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9416 $11969 T 10 20 -45 20 25 -35 unknown #
+vertex $-1 -1 -1 $-1 $9417 $11970 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11971 $11972 $9418 $10628 forward $11973 $-1 #
+edge $-1 -1 -1 $-1 $9420 -6.1232339957367648e-17 $11974 1.5707963267948966 $10627 $11975 forward @7 unknown T 15 25 -45 20 30 -40 #
+coedge $-1 -1 -1 $-1 $11923 $9419 $11972 $10630 forward $9433 $-1 #
+edge $-1 -1 -1 $-1 $9420 0 $11976 1.5707963267948966 $10629 $11964 forward @7 unknown T 10 25 -45 15 30 -40 #
+point $-1 -1 -1 $-1 15 25 -45 #
+coedge $-1 -1 -1 $-1 $9425 $9422 $11431 $11977 forward $9426 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11978 42.5 $9424 50 $10586 $11979 forward @7 unknown T 7.5 29.330127018922191 -50 7.5000000000000009 29.330127018922195 -42.5 #
+point $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $11980 $10640 $9425 $10637 forward $11480 $-1 #
+edge $-1 -1 -1 $-1 $9427 1.5707963267948966 $11981 2.0943951023931948 $10636 $11982 forward @7 unknown T 22.5 20 -40 25 20.669872981077805 -37.5 #
+face $-1 -1 -1 $-1 $11983 $9426 $11 $-1 $10647 reversed single T 20 20 -42.500000000000014 25 20.669872981077813 -37.5 F #
+point $-1 -1 -1 $-1 25 20 -40 #
+coedge $-1 -1 -1 $-1 $10636 $10188 $9430 $10641 forward $11480 $-1 #
+edge $-1 -1 -1 $-1 $10190 3.1415926535897931 $9427 4.7123889803846897 $10640 $11984 forward @7 unknown T 25 20 -40 30 25 -35 #
+face $-1 -1 -1 $-1 $11985 $11986 $11 $-1 $11403 reversed single T 10 25 15 20 30 25 F #
+loop $-1 -1 -1 $-1 $-1 $11987 $9432 T 22.5 25 5.0000000000000018 30 30 20 unknown #
+coedge $-1 -1 -1 $-1 $11988 $9434 $8051 $9056 forward $8050 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10597 $9440 $11 $-1 $10647 reversed single T 25 25 -45 35 30 -35 F #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 25 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $9439 $9438 $10187 $11478 reversed $9440 $-1 #
+point $-1 -1 -1 $-1 35 29.999999999999996 -40 #
+point $-1 -1 -1 $-1 25 30 -40 #
+vertex $-1 -1 -1 $-1 $11464 $11989 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11990 $10189 $11 $-1 $6162 reversed single T 22.5 25 -40 30 30 -25 F #
+edge $-1 -1 -1 $-1 $11974 1.5707963267948966 $9446 2.0943951023931957 $11436 $11991 forward @7 unknown T 20 29.330127018922191 -42.5 22.5 30 -40 #
+point $-1 -1 -1 $-1 22.5 29.330127018922191 -42.5 #
+coedge $-1 -1 -1 $-1 $11992 $9448 $11993 $11994 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $10688 $11995 $9448 $9479 reversed $10702 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9451 $9494 $11996 $11997 forward $8421 $-1 #
+coedge $-1 -1 -1 $-1 $11605 $9452 $10333 $11654 reversed $10661 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10292 $11998 T 20 14.330127018922189 -42.500000000000007 25 15 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $9457 $9460 $9454 $10663 forward $10666 $-1 #
+edge $-1 -1 -1 $-1 $8388 1.5707963267948966 $8384 4.7123889803846897 $10662 $11999 forward @7 unknown T 40 5 -40 45 15 -35 #
+loop $-1 -1 -1 $-1 $-1 $12000 $10665 T 50 5 -45 50 15 -35 unknown #
+face $-1 -1 -1 $-1 $12001 $9455 $11 $-1 $9512 reversed single T 40 5 -45 50 15 -35 F #
+loop $-1 -1 -1 $-1 $-1 $10319 $12002 T 37.5 5 -40 45.000000000000007 15 -24.999999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 10 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9460 $12003 $10321 $11637 forward $10666 $-1 #
+vertex $-1 -1 -1 $-1 $9461 $12004 #
+face $-1 -1 -1 $-1 $12005 $12006 $11 $-1 $10259 reversed single T 25 4.9999999999999982 15 35 10 25.000000000000007 F #
+coedge $-1 -1 -1 $-1 $12007 $12008 $12009 $12010 forward $9465 $-1 #
+coedge $-1 -1 -1 $-1 $9466 $12011 $12012 $12013 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $12014 $12015 $9466 $10674 reversed $12016 $-1 #
+edge $-1 -1 -1 $-1 $12017 -2.0943951023931957 $10678 0 $9466 $12018 forward @7 unknown T -22.5 5 -50 -15 10 -50 #
+coedge $-1 -1 -1 $-1 $12019 $9467 $12020 $12021 forward $10677 $-1 #
+coedge $-1 -1 -1 $-1 $9467 $12022 $9469 $10681 reversed $10677 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10676 $12023 T -15 5 -50 -7.4999999999999991 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $12024 $12025 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10682 $9469 $12026 $12027 forward $9471 $-1 #
+edge $-1 -1 -1 $-1 $9472 -50 $12028 -42.500000000000007 $9469 $12029 forward @7 unknown T -7.5 5.6698729810778064 -50 -7.5 5.6698729810778072 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $9470 $10680 $12030 $12031 forward $9471 $-1 #
+face $-1 -1 -1 $-1 $12032 $9471 $11 $-1 $8113 reversed single T -7.5000000000000036 5 -50 8.8817841970012523e-16 10 -40 F #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $12030 $12033 $9474 $10686 forward $12034 $-1 #
+edge $-1 -1 -1 $-1 $12035 -1.5707963267948966 $10689 -6.1232339957367648e-17 $10685 $12036 forward @7 unknown T 0 4.9999999999999991 -45 5.0000000000000009 10 -40 #
+coedge $-1 -1 -1 $-1 $9475 $11575 $12037 $12038 reversed $9118 $-1 #
+coedge $-1 -1 -1 $-1 $12039 $10657 $9470 $9476 forward $10702 $-1 #
+vertex $-1 -1 -1 $-1 $12040 $12041 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12042 $9481 $9477 $10692 forward $10695 $-1 #
+edge $-1 -1 -1 $-1 $9483 -2.0943951023931957 $12035 -1.5707963267948966 $10691 $12043 forward @7 unknown T 5.0000000000000009 4.9999999999999991 -42.5 7.5000000000000018 5.6698729810778072 -40 #
+vertex $-1 -1 -1 $-1 $12044 $12045 #
+coedge $-1 -1 -1 $-1 $9481 $12042 $12046 $12047 reversed $10695 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10691 $12048 T 5.0000000000000009 4.9999999999999991 -42.5 10 5.6698729810778081 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $9482 $12049 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 -42.5 #
+coedge $-1 -1 -1 $-1 $9488 $9485 $12050 $12051 reversed $9489 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12052 $12053 $11 $-1 $6231 reversed single T 7.5 10 5.0000000000000009 15 15 20 F #
+loop $-1 -1 -1 $-1 $-1 $10688 $9487 T -7.5000000000000009 10 -50 8.8817841970012523e-16 15 -40 unknown #
+coedge $-1 -1 -1 $-1 $12054 $10287 $9488 $10704 reversed $9138 $-1 #
+edge $-1 -1 -1 $-1 $11602 -2.9403902792268234e-16 $9490 1.5707963267948966 $9488 $12055 forward @7 unknown T 15 4.9999999999999982 -40 20 10 -35 #
+face $-1 -1 -1 $-1 $12056 $9489 $11 $-1 $9512 reversed single T 10 4.9999999999999982 -45 20 10 -35 F #
+point $-1 -1 -1 $-1 20 4.9999999999999982 -40 #
+coedge $-1 -1 -1 $-1 $12057 $9492 $10288 $11594 forward $10709 $-1 #
+coedge $-1 -1 -1 $-1 $9492 $12057 $9494 $9495 reversed $10709 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9492 $12056 T 10 10 -45 20 15 -35 unknown #
+vertex $-1 -1 -1 $-1 $9493 $12058 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $11997 $12059 #
+edge $-1 -1 -1 $-1 $9490 1.5707963267948966 $10717 2.0943951023931957 $9497 $12060 forward @7 unknown T 20 4.9999999999999982 -40 22.500000000000007 5.6698729810778072 -37.5 #
+vertex $-1 -1 -1 $-1 $12061 $12062 #
+straight-curve $-1 -1 -1 $-1 7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11655 $9501 $11592 $12063 forward $10336 $-1 #
+vertex $-1 -1 -1 $-1 $12063 $12064 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12065 $11601 $11 $-1 $6231 reversed single T 7.5 10 -40 15 15 -25 F #
+ellipse-curve $-1 -1 -1 $-1 25 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12066 $12067 $11 $-1 $10259 reversed single T 10 4.9999999999999982 15 20 10 25 F #
+loop $-1 -1 -1 $-1 $-1 $11583 $9507 T 10 10 15 20 15 25 unknown #
+coedge $-1 -1 -1 $-1 $12068 $12069 $12070 $12071 forward $9508 $-1 #
+coedge $-1 -1 -1 $-1 $10318 $9509 $12072 $12073 reversed $7188 $-1 #
+point $-1 -1 -1 $-1 37.5 5.6698729810778055 -37.5 #
+face $-1 -1 -1 $-1 $12074 $12075 $11 $-1 $12076 reversed single T 25 10 1.7763568394002505e-15 35 15 10.000000000000002 F #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12077 $9521 $12078 $10754 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $12079 $10750 $9521 $10730 reversed $12080 $-1 #
+edge $-1 -1 -1 $-1 $9556 -0.52359877559829893 $9541 1.5707963267948966 $9521 $12081 forward @7 unknown T -15 -5 -50 -7.4999999999999991 8.8817841970012523e-16 -50 #
+coedge $-1 -1 -1 $-1 $9522 $12082 $12079 $10774 forward $9565 $-1 #
+coedge $-1 -1 -1 $-1 $12083 $11752 $9524 $10733 reversed $12084 $-1 #
+edge $-1 -1 -1 $-1 $9575 -1.5707963267948966 $9577 -1.0471975511965979 $9524 $9560 forward @7 unknown T 7.5 -0.66987298107780813 -42.5 10 0 -40 #
+face $-1 -1 -1 $-1 $8490 $9526 $11 $-1 $8499 reversed single T 20 -0.6698729810778099 -42.500000000000007 25 0 -37.5 F #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10736 $10736 $12085 $12086 reversed $9529 $-1 #
+face $-1 -1 -1 $-1 $12087 $12088 $11 $-1 $8499 reversed single T -10 -10 -42.500000000000007 -5 -9.330127018922191 -37.499999999999993 F #
+face $-1 -1 -1 $-1 $7482 $9531 $11 $-1 $4463 reversed single T 37.5 -10 -40 45.000000000000007 0 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $9533 $11797 $10474 $11801 forward $9531 $-1 #
+point $-1 -1 -1 $-1 37.500000000000007 -0.66987298107780902 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $9535 $12089 $12090 $12091 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $12092 $12093 $9535 $10743 reversed $12094 $-1 #
+edge $-1 -1 -1 $-1 $12095 1.5707963267948966 $10747 3.6651914291880923 $9535 $12096 forward @7 unknown T -30 -9.9999999999999982 -50 -22.5 -4.9999999999999982 -50 #
+coedge $-1 -1 -1 $-1 $12097 $9536 $12093 $12098 forward $10746 $-1 #
+coedge $-1 -1 -1 $-1 $9536 $12099 $9538 $10751 reversed $10746 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10745 $12100 T -22.500000000000004 -10 -50 -15 -5 -40 unknown #
+vertex $-1 -1 -1 $-1 $9537 $12101 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10752 $9538 $12102 $12103 reversed $9540 $-1 #
+coedge $-1 -1 -1 $-1 $10729 $12104 $12105 $10751 reversed $12080 $-1 #
+edge $-1 -1 -1 $-1 $9541 -50 $12106 -45 $12105 $12107 forward @7 unknown T -15 -5 -50 -15 -5 -45 #
+coedge $-1 -1 -1 $-1 $9539 $10749 $12108 $12109 reversed $9540 $-1 #
+face $-1 -1 -1 $-1 $11665 $9540 $11 $-1 $9224 reversed single T -15 -10 -50 -7.4999999999999991 -4.9999999999999991 -40 F #
+edge $-1 -1 -1 $-1 $9541 0 $12110 2.0943951023931948 $10728 $10748 forward @7 unknown T -22.5 -5 -50 -15 0 -50 #
+point $-1 -1 -1 $-1 -15 -5 -50 #
+coedge $-1 -1 -1 $-1 $12108 $12111 $9543 $10757 reversed $12088 $-1 #
+edge $-1 -1 -1 $-1 $10758 1.047197551196597 $12112 1.5707963267948966 $9543 $12113 forward @7 unknown T -7.5000000000000036 -10 -42.500000000000007 -5 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $10757 $12114 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12115 $9548 $9545 $10761 reversed $10764 $-1 #
+edge $-1 -1 -1 $-1 $12112 -1.5707963267948966 $9552 0 $9545 $12116 forward @7 unknown T -5 -10 -45 0 -5 -40 #
+face $-1 -1 -1 $-1 $12117 $12118 $11 $-1 $11179 reversed single T -10 -0.66987298107780902 -12.5 -5 8.8817841970012523e-16 -7.5000000000000009 F #
+coedge $-1 -1 -1 $-1 $9548 $12115 $12119 $12120 forward $10764 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9548 $12121 T -5 -10 -45 5 -4.9999999999999991 -35 unknown #
+vertex $-1 -1 -1 $-1 $9549 $12122 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12123 $12124 $9550 $10768 forward $12125 $-1 #
+edge $-1 -1 -1 $-1 $9552 -6.1232339957367648e-17 $12126 1.5707963267948966 $10767 $12127 forward @7 unknown T -9.3734986416366059e-33 -5 -45 5 0 -40 #
+coedge $-1 -1 -1 $-1 $12082 $9551 $12124 $10770 forward $9565 $-1 #
+edge $-1 -1 -1 $-1 $9552 0 $12128 1.5707963267948966 $10769 $12116 forward @7 unknown T -5 -5 -45 0 0 -40 #
+point $-1 -1 -1 $-1 0 -5 -45 #
+coedge $-1 -1 -1 $-1 $9557 $9554 $11747 $12129 forward $9558 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12130 42.5 $9556 50 $10731 $12131 forward @7 unknown T -7.5 -0.66987298107780746 -50 -7.4999999999999991 -0.66987298107780635 -42.5 #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 -50 #
+coedge $-1 -1 -1 $-1 $12132 $10780 $9557 $10777 forward $11784 $-1 #
+edge $-1 -1 -1 $-1 $9559 1.5707963267948966 $12133 2.0943951023931948 $10776 $12134 forward @7 unknown T 7.5000000000000018 -10 -40 10 -9.3301270189221945 -37.5 #
+face $-1 -1 -1 $-1 $12135 $9558 $11 $-1 $8499 reversed single T 5 -10 -42.500000000000007 10 -9.330127018922191 -37.5 F #
+point $-1 -1 -1 $-1 10 -10 -40 #
+coedge $-1 -1 -1 $-1 $10776 $10449 $9562 $10781 forward $11784 $-1 #
+edge $-1 -1 -1 $-1 $10451 3.1415926535897931 $9559 4.7123889803846897 $10780 $12136 forward @7 unknown T 10 -10 -40 15 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $12137 $12138 $11 $-1 $8848 reversed single T -5 -5 15 5 0 25 F #
+loop $-1 -1 -1 $-1 $-1 $12139 $9564 T 7.4999999999999956 -5 5.0000000000000009 15 8.8817841970012523e-16 20 unknown #
+coedge $-1 -1 -1 $-1 $12140 $9566 $8230 $9265 forward $8229 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10734 $9572 $11 $-1 $8499 reversed single T 10 -5 -45 20 0 -35 F #
+coedge $-1 -1 -1 $-1 $9571 $9570 $10448 $11782 reversed $9572 $-1 #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 -40 #
+point $-1 -1 -1 $-1 10 0 -40 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12126 1.5707963267948966 $9577 2.0943951023931957 $11752 $12141 forward @7 unknown T 5 -0.66987298107780902 -42.5 7.5000000000000018 0 -40 #
+point $-1 -1 -1 $-1 7.5000000000000018 -0.66987298107780746 -42.5 #
+edge $-1 -1 -1 $-1 $9580 -37.5 $12142 -27.500000000000004 $9579 $12143 forward @7 unknown T 22.5 -9.3301270189221963 -37.5 22.500000000000004 -9.3301270189221945 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221963 -37.5 #
+face $-1 -1 -1 $-1 $12144 $12145 $11 $-1 $9956 reversed single T 9.9999999999999982 -5 1.7819122827301222e-32 20 8.8817841970012523e-16 10 F #
+face $-1 -1 -1 $-1 $11788 $11792 $11 $-1 $8848 reversed single T 20 -10 17.5 25 -9.3301270189221928 22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $12146 $9584 T 10 -10 15 20 -4.9999999999999991 25 unknown #
+coedge $-1 -1 -1 $-1 $10487 $11131 $9586 $10799 forward $11816 $-1 #
+edge $-1 -1 -1 $-1 $11138 -1.5707963267948966 $8252 2.9403902792268214e-16 $10798 $12147 forward @7 unknown T 29.999999999999996 -10.000000000000002 -30 35 -5 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $12148 $9589 $12149 $12150 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $10822 $12151 $9589 $9608 reversed $12152 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $9592 $9623 $12153 $12154 forward $8541 $-1 #
+coedge $-1 -1 -1 $-1 $11846 $9593 $9808 $11018 reversed $10805 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10522 $12155 T 4.9999999999999991 -15.669872981077811 -42.500000000000007 10 -15 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $9595 $12148 $12156 $12157 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $12158 $9739 $9595 $10808 reversed $8641 $-1 #
+edge $-1 -1 -1 $-1 $12159 -2.0943951023931948 $10812 0 $9595 $12160 forward @7 unknown T -37.5 -25 -50 -30 -20 -50 #
+coedge $-1 -1 -1 $-1 $12161 $9596 $12162 $10940 forward $10811 $-1 #
+coedge $-1 -1 -1 $-1 $9596 $12163 $9598 $10815 reversed $10811 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10810 $12164 T -30 -25 -50 -22.5 -20 -40 unknown #
+vertex $-1 -1 -1 $-1 $12165 $12166 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10816 $9598 $12167 $12168 forward $9600 $-1 #
+edge $-1 -1 -1 $-1 $9601 -50 $12169 -42.500000000000014 $9598 $12170 forward @7 unknown T -22.500000000000004 -24.330127018922195 -50 -22.5 -24.330127018922195 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $9599 $10814 $12171 $12172 forward $9600 $-1 #
+face $-1 -1 -1 $-1 $12173 $9600 $11 $-1 $9321 reversed single T -22.500000000000007 -25 -50 -15 -20 -40 F #
+point $-1 -1 -1 $-1 -22.5 -24.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $12171 $11080 $9603 $10820 forward $12174 $-1 #
+edge $-1 -1 -1 $-1 $9860 -1.5707963267948966 $10823 -6.1232339957367648e-17 $10819 $12175 forward @7 unknown T -15.000000000000002 -25 -45 -10.000000000000002 -20 -40 #
+coedge $-1 -1 -1 $-1 $9604 $9725 $12176 $12177 reversed $7611 $-1 #
+coedge $-1 -1 -1 $-1 $12178 $10801 $9599 $9605 forward $12152 $-1 #
+vertex $-1 -1 -1 $-1 $12179 $12180 #
+straight-curve $-1 -1 -1 $-1 -15 -20 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $12150 $12181 #
+vertex $-1 -1 -1 $-1 $9611 $12182 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $9617 $9614 $11075 $12183 reversed $9618 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12184 $12185 $11 $-1 $2664 reversed single T -20 -20 -15.000000000000002 -10.000000000000002 -15 -5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $12186 $9616 T -10.000000000000002 -15.669872981077809 -12.500000000000004 -5 -15 -7.4999999999999956 unknown #
+coedge $-1 -1 -1 $-1 $12187 $10517 $9617 $10834 reversed $9333 $-1 #
+edge $-1 -1 -1 $-1 $11843 6.1232339957367648e-17 $9619 1.5707963267948966 $9617 $12188 forward @7 unknown T -8.8817841970012523e-16 -25 -40 4.9999999999999991 -20 -35 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 -40 #
+coedge $-1 -1 -1 $-1 $12189 $9621 $10518 $11837 forward $10838 $-1 #
+coedge $-1 -1 -1 $-1 $9621 $12189 $9623 $9624 reversed $10838 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9621 $11054 T -5 -20 -45 4.9999999999999991 -15 -35 unknown #
+vertex $-1 -1 -1 $-1 $9622 $12190 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $12154 $12191 #
+edge $-1 -1 -1 $-1 $9619 1.5707963267948966 $10845 2.0943951023931948 $9626 $12192 forward @7 unknown T 4.9999999999999991 -25 -40 7.5000000000000018 -24.330127018922191 -37.5 #
+vertex $-1 -1 -1 $-1 $10925 $12193 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 0 -0 -0 -1 I I #
+vertex $-1 -1 -1 $-1 $11024 $12194 #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9787 $11842 $11 $-1 $3822 reversed single T -7.5000000000000036 -20 -40 0 -15 -25 F #
+ellipse-curve $-1 -1 -1 $-1 10 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10853 $9644 $12195 $12196 reversed $9646 $-1 #
+coedge $-1 -1 -1 $-1 $9645 $12197 $12198 $12199 reversed $9646 $-1 #
+edge $-1 -1 -1 $-1 $9647 1.5707963267948966 $12200 2.0943951023931957 $9682 $12201 forward @7 unknown T -40 -15.669872981077805 17.499999999999996 -37.499999999999993 -14.999999999999996 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $11210 $10850 $12202 $12203 reversed $9646 $-1 #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $9781 $9649 $10895 $12204 forward $8759 $-1 #
+coedge $-1 -1 -1 $-1 $9649 $9975 $9653 $10859 forward $8759 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 -25 20 #
+edge $-1 -1 -1 $-1 $9980 7.5000000000000027 $9656 17.499999999999996 $10856 $12205 forward @7 unknown T -7.5000000000000027 -24.330127018922195 7.5000000000000027 -7.5000000000000009 -24.330127018922191 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $9654 $9978 $10975 $12206 forward $9655 $-1 #
+face $-1 -1 -1 $-1 $6609 $9655 $11 $-1 $6619 reversed single T -15.000000000000002 -25 4.9999999999999991 -7.5000000000000009 -20 20 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 17.499999999999996 #
+vertex $-1 -1 -1 $-1 $12207 $12208 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9660 -32.5 $12209 -22.500000000000007 $10516 $12210 forward @7 unknown T -7.5000000000000027 -15.669872981077809 22.500000000000007 -7.5000000000000009 -15.669872981077807 32.5 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 32.5 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9666 $10496 $12211 $11827 forward $9667 $-1 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922195 50 #
+loop $-1 -1 -1 $-1 $-1 $12212 $9672 T -45 -24.999999999999996 -40 -37.499999999999993 -14.999999999999996 -25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $12213 $12156 $12214 $12215 reversed $9673 $-1 #
+coedge $-1 -1 -1 $-1 $12211 $12216 $9674 $10873 reversed $12217 $-1 #
+edge $-1 -1 -1 $-1 $9680 -1.5707963267948966 $12218 0 $9674 $12219 forward @7 unknown T -35 -25 30 -30 -20 35 #
+coedge $-1 -1 -1 $-1 $12220 $12221 $9675 $10875 reversed $12222 $-1 #
+edge $-1 -1 -1 $-1 $10969 3.1415926535897931 $10876 4.7123889803846906 $9675 $12223 forward @7 unknown T -35 -25 19.999999999999993 -29.999999999999993 -20 24.999999999999996 #
+vertex $-1 -1 -1 $-1 $10892 $12224 #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -20 19.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12225 $12226 $9749 $10879 forward $12227 $-1 #
+edge $-1 -1 -1 $-1 $10969 24.999999999999996 $12218 30 $9689 $12228 forward @7 unknown T -30 -20 24.999999999999996 -29.999999999999993 -20 30 #
+face $-1 -1 -1 $-1 $12229 $12230 $11 $-1 $9321 reversed single T -22.500000000000004 -20 4.9999999999999991 -15 -15 20 F #
+point $-1 -1 -1 $-1 -35 -25 35 #
+coedge $-1 -1 -1 $-1 $9683 $9682 $12231 $12232 reversed $9684 $-1 #
+face $-1 -1 -1 $-1 $12233 $9684 $11 $-1 $1815 reversed single T -40 -15.669872981077809 17.499999999999996 -35 -14.999999999999996 22.499999999999993 F #
+coedge $-1 -1 -1 $-1 $12234 $9750 $9686 $10885 reversed $10967 $-1 #
+edge $-1 -1 -1 $-1 $10886 1.5707963267948957 $10969 3.1415926535897931 $9686 $12223 forward @7 unknown T -35 -20 19.999999999999993 -29.999999999999993 -15 24.999999999999996 #
+vertex $-1 -1 -1 $-1 $12232 $12235 #
+coedge $-1 -1 -1 $-1 $11823 $11821 $9688 $10888 reversed $11824 $-1 #
+edge $-1 -1 -1 $-1 $12218 0 $9692 1.5707963267948966 $9688 $12219 forward @7 unknown T -35 -20 30 -30 -15 35 #
+point $-1 -1 -1 $-1 -35 -15 35 #
+loop $-1 -1 -1 $-1 $-1 $12236 $9693 T -37.5 -20 4.9999999999999982 -30 -15 19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $12237 $12195 $9695 $10892 forward $12238 $-1 #
+edge $-1 -1 -1 $-1 $10893 1.0471975511965961 $10876 1.5707963267948957 $10891 $12239 forward @7 unknown T -37.5 -25 17.499999999999989 -35 -24.330127018922187 19.999999999999996 #
+vertex $-1 -1 -1 $-1 $10892 $12240 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $9699 $9841 $10855 $12204 reversed $7766 $-1 #
+coedge $-1 -1 -1 $-1 $9702 $9701 $12241 $12242 reversed $9703 $-1 #
+coedge $-1 -1 -1 $-1 $12243 $9711 $9702 $9713 forward $9716 $-1 #
+face $-1 -1 -1 $-1 $12244 $9703 $11 $-1 $1815 reversed single T -20 -25 15 -10.000000000000002 -20 25 F #
+coedge $-1 -1 -1 $-1 $9708 $9705 $10516 $10865 reversed $7638 $-1 #
+coedge $-1 -1 -1 $-1 $12245 $11006 $9705 $10901 forward $10919 $-1 #
+edge $-1 -1 -1 $-1 $12209 -2.0943951023931957 $10905 -1.5707963267948966 $10900 $12246 forward @7 unknown T -10.000000000000002 -15.669872981077809 20 -7.5000000000000009 -15 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $12247 $9706 $9710 $10909 reversed $10904 $-1 #
+coedge $-1 -1 -1 $-1 $9706 $12247 $12248 $12249 forward $10904 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9706 $10918 T -20 -20 15 -10.000000000000002 -15 25 unknown #
+vertex $-1 -1 -1 $-1 $12249 $12250 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9710 $10927 $12251 $12252 forward $9712 $-1 #
+edge $-1 -1 -1 $-1 $12253 1.5707963267948966 $8619 3.1415926535897931 $9710 $10911 forward @7 unknown T -20 -20 20 -15 -15 25 #
+vertex $-1 -1 -1 $-1 $12254 $12255 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9715 $12243 $12256 $12257 forward $9716 $-1 #
+coedge $-1 -1 -1 $-1 $12258 $9717 $9715 $9720 reversed $10915 $-1 #
+coedge $-1 -1 -1 $-1 $9717 $12258 $11818 $11835 forward $10915 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10914 $12259 T -25 -25 32.5 -20 -24.330127018922191 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $9720 $12260 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10898 $10904 $11 $-1 $1815 reversed single T -20 -20 15 -10.000000000000002 -15 25 F #
+loop $-1 -1 -1 $-1 $-1 $10900 $9722 T -10.000000000000002 -15.669872981077811 17.499999999999996 -5 -15 22.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $12261 $9724 $12262 $12263 reversed $8629 $-1 #
+coedge $-1 -1 -1 $-1 $9724 $12264 $12265 $12266 reversed $8629 $-1 #
+coedge $-1 -1 -1 $-1 $12267 $12268 $12269 $10923 forward $12270 $-1 #
+edge $-1 -1 -1 $-1 $12271 -35 $12272 -30 $10922 $12273 forward @7 unknown T -15 -20 -35 -15 -20 -30 #
+coedge $-1 -1 -1 $-1 $12153 $12274 $9725 $10925 forward $12275 $-1 #
+edge $-1 -1 -1 $-1 $12276 1.5707963267948966 $10843 2.0943951023931957 $10924 $12277 forward @7 unknown T -10.000000000000002 -15.669872981077809 -42.500000000000007 -7.5000000000000009 -15 -40 #
+vertex $-1 -1 -1 $-1 $12278 $12279 #
+coedge $-1 -1 -1 $-1 $10908 $9728 $10962 $12278 forward $9712 $-1 #
+loop $-1 -1 -1 $-1 $12280 $12281 $3147 T -50 -10 29.999999999999996 -50 0 40 hole $3148 T #
+coedge $-1 -1 -1 $-1 $10929 $10929 $11059 $12282 forward $9730 $-1 #
+coedge $-1 -1 -1 $-1 $10930 $10930 $9731 $10931 reversed $9847 $-1 #
+edge $-1 -1 -1 $-1 $12283 0 $12283 6.2831853071795862 $9731 $12284 forward @7 unknown T -50 -25 -30.000000000000004 -50 -15 -20.000000000000004 #
+vertex $-1 -1 -1 $-1 $9732 $12285 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 -10.000000000000004 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -20 -3.0616169978683823e-15 #
+face $-1 -1 -1 $-1 $12286 $12287 $11 $-1 $12288 reversed single T -37.500000000000007 20 -50 -30 25 -40 F #
+loop $-1 -1 -1 $-1 $-1 $12289 $9736 T -37.5 5 -50 -30 10 -40 unknown #
+cone-surface $-1 -1 -1 $-1 -35 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $12090 $12290 $12092 $12291 reversed $9737 $-1 #
+coedge $-1 -1 -1 $-1 $9739 $12292 $12293 $12294 forward $8641 $-1 #
+edge $-1 -1 -1 $-1 $10812 -50 $12295 -45 $12296 $12297 forward @7 unknown T -30 -20 -50 -30 -20 -45 #
+coedge $-1 -1 -1 $-1 $9740 $11212 $12298 $12299 reversed $8644 $-1 #
+coedge $-1 -1 -1 $-1 $12300 $11092 $9740 $10943 forward $12301 $-1 #
+edge $-1 -1 -1 $-1 $9870 1.5707963267948966 $12302 2.0943951023931948 $10942 $12303 forward @7 unknown T -40 -24.999999999999996 -10.000000000000002 -37.5 -24.330127018922191 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $11094 $9741 $12304 $12305 reversed $7620 $-1 #
+coedge $-1 -1 -1 $-1 $9848 $9848 $9741 $10946 forward $8767 $-1 #
+edge $-1 -1 -1 $-1 $12306 -1.5707963267948966 $10952 1.5707963267948966 $10945 $12307 forward @7 unknown T -45 -24.999999999999996 -25.000000000000004 -40 -14.999999999999996 -20.000000000000004 #
+coedge $-1 -1 -1 $-1 $12308 $12309 $9742 $10948 forward $12310 $-1 #
+edge $-1 -1 -1 $-1 $10953 -22.5 $12311 -12.500000000000005 $10947 $12312 forward @7 unknown T -37.500000000000007 -24.330127018922198 -22.5 -37.5 -24.330127018922195 -12.500000000000005 #
+coedge $-1 -1 -1 $-1 $12313 $9743 $12309 $12314 reversed $10951 $-1 #
+coedge $-1 -1 -1 $-1 $9743 $12313 $12315 $12316 forward $10951 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9743 $12317 T -40 -25 -27.500000000000007 -35 -24.330127018922187 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $11058 $12318 #
+vertex $-1 -1 -1 $-1 $9744 $12319 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12320 $12321 $11 $-1 $7628 reversed single T -30 -25 -25 -22.5 -20 -10.000000000000002 F #
+loop $-1 -1 -1 $-1 $-1 $12322 $9745 T -30 -20 -25 -22.499999999999993 -15 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $12323 $12324 $12325 $12326 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $12327 $9747 $12328 $12329 reversed $8650 $-1 #
+coedge $-1 -1 -1 $-1 $9747 $12330 $12236 $12331 reversed $8650 $-1 #
+coedge $-1 -1 -1 $-1 $12332 $12333 $9747 $10961 forward $12334 $-1 #
+edge $-1 -1 -1 $-1 $12335 -1.5707963267948966 $12336 6.1232339957367648e-17 $10960 $12337 forward @7 unknown T -30 -20 4.9999999999999982 -25 -15 9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $12338 $9748 $10927 $12278 reversed $7627 $-1 #
+coedge $-1 -1 -1 $-1 $12339 $12251 $9748 $10964 forward $12340 $-1 #
+edge $-1 -1 -1 $-1 $12341 -2.0943951023931953 $10968 -1.5707963267948966 $10963 $12342 forward @7 unknown T -25 -15.669872981077809 20 -22.499999999999993 -15 22.5 #
+coedge $-1 -1 -1 $-1 $9749 $12338 $11823 $12343 reversed $7627 $-1 #
+coedge $-1 -1 -1 $-1 $9750 $12234 $12330 $12344 forward $10967 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9750 $12229 T -35 -20 14.999999999999996 -25 -15 25 unknown #
+vertex $-1 -1 -1 $-1 $12344 $12345 #
+vertex $-1 -1 -1 $-1 $10875 $12346 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9890 $9882 $11 $-1 $6619 reversed single T -15.000000000000004 -25 -25 -7.5000000000000009 -20 -10 F #
+loop $-1 -1 -1 $-1 $-1 $12347 $9752 T -15.000000000000004 -20 -25 -7.5000000000000009 -15 -10 unknown #
+coedge $-1 -1 -1 $-1 $12348 $11110 $12349 $12350 reversed $9753 $-1 #
+coedge $-1 -1 -1 $-1 $12351 $9754 $12352 $12353 reversed $8653 $-1 #
+coedge $-1 -1 -1 $-1 $9754 $12248 $12354 $12206 reversed $8653 $-1 #
+coedge $-1 -1 -1 $-1 $12355 $12356 $9754 $10977 forward $12357 $-1 #
+edge $-1 -1 -1 $-1 $12358 -1.5707963267948966 $12359 6.1232339957367648e-17 $10976 $12360 forward @7 unknown T -15.000000000000002 -20 4.9999999999999991 -10.000000000000002 -15 10 #
+loop $-1 -1 -1 $-1 $12361 $12362 $1558 T 50 -10 -14.999999999999996 50 0 -4.9999999999999964 hole $1559 T #
+coedge $-1 -1 -1 $-1 $10979 $10979 $12363 $12364 forward $9755 $-1 #
+coedge $-1 -1 -1 $-1 $10980 $10980 $9756 $10981 reversed $10415 $-1 #
+edge $-1 -1 -1 $-1 $12365 0 $12365 6.2831853071795862 $9756 $12366 forward @7 unknown T 50 -10 15.000000000000004 50 0 25.000000000000004 #
+point $-1 -1 -1 $-1 50 -20 -45 #
+coedge $-1 -1 -1 $-1 $12367 $9770 $12368 $12369 reversed $8683 $-1 #
+edge $-1 -1 -1 $-1 $12370 1.5707963267948966 $9807 2.0943951023931957 $9805 $12371 forward @7 unknown T 4.9999999999999991 -25 -25 7.5000000000000018 -24.330127018922191 -22.5 #
+coedge $-1 -1 -1 $-1 $12372 $9771 $11121 $12373 reversed $9835 $-1 #
+coedge $-1 -1 -1 $-1 $9771 $12372 $10519 $11838 forward $9835 $-1 #
+vertex $-1 -1 -1 $-1 $11838 $12374 #
+vertex $-1 -1 -1 $-1 $12375 $12376 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $11000 $12377 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $12378 1.5707963267948966 $9777 3.1415926535897931 $9864 $12379 forward @7 unknown T -5 -20 -10 0 -15 -5 #
+edge $-1 -1 -1 $-1 $9777 3.1415926535897931 $9878 4.7123889803846897 $9876 $12379 forward @7 unknown T -5 -25 -10 0 -20 -5 #
+point $-1 -1 -1 $-1 0 -20 -5 #
+coedge $-1 -1 -1 $-1 $12380 $9779 $12381 $11009 forward $8850 $-1 #
+coedge $-1 -1 -1 $-1 $9780 $12380 $12382 $12383 forward $8850 $-1 #
+coedge $-1 -1 -1 $-1 $9975 $9781 $12384 $9789 forward $8759 $-1 #
+coedge $-1 -1 -1 $-1 $9837 $9836 $7698 $8690 forward $8751 $-1 #
+point $-1 -1 -1 $-1 0 -20 15 #
+edge $-1 -1 -1 $-1 $10990 0 $11001 1.5707963267948966 $9863 $12385 forward @7 unknown T -5 -20 0 0 -15 5 #
+vertex $-1 -1 -1 $-1 $12386 $12387 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 5 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $8754 $12388 $11 $-1 $2156 reversed single T -5 -25 0 4.9999999999999991 -20 10 F #
+vertex $-1 -1 -1 $-1 $11217 $12389 #
+coedge $-1 -1 -1 $-1 $10900 $12381 $9791 $11007 reversed $10919 $-1 #
+edge $-1 -1 -1 $-1 $12209 4.1887902047863896 $9793 4.7123889803846897 $9791 $9652 forward @7 unknown T -7.5000000000000053 -15.669872981077811 20 -5 -15 22.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9793 -1.5707963267948966 $12390 -1.047197551196597 $10995 $10857 forward @7 unknown T -7.5000000000000036 -15.669872981077809 17.499999999999996 -5 -15 20 #
+point $-1 -1 -1 $-1 -5 -15 20 #
+coedge $-1 -1 -1 $-1 $10519 $9809 $9798 $9812 reversed $8286 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $5863 $9877 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 -10 0 -20 5 F #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $9805 $9804 $12391 $12392 forward $9806 $-1 #
+face $-1 -1 -1 $-1 $9800 $9806 $11 $-1 $3328 reversed single T 4.9999999999999991 -25 -27.500000000000004 10 -24.330127018922191 -22.5 F #
+point $-1 -1 -1 $-1 7.5000000000000018 -24.330127018922191 -22.500000000000004 #
+edge $-1 -1 -1 $-1 $11020 4.1887902047863914 $8549 4.7123889803846897 $9808 $10846 forward @7 unknown T 7.5000000000000009 -15.669872981077807 -40 10 -15 -37.5 #
+coedge $-1 -1 -1 $-1 $9809 $10518 $11846 $12393 reversed $8286 $-1 #
+vertex $-1 -1 -1 $-1 $11018 $12394 #
+straight-curve $-1 -1 -1 $-1 7.5 -15.669872981077807 0 -0 -0 -1 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10517 $12391 $9817 $11024 reversed $9333 $-1 #
+edge $-1 -1 -1 $-1 $10845 -37.500000000000007 $8727 -27.500000000000004 $9817 $12395 forward @7 unknown T 7.5 -24.330127018922195 -37.500000000000007 7.5000000000000027 -24.330127018922191 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $11089 $9819 $9826 $11034 reversed $9769 $-1 #
+coedge $-1 -1 -1 $-1 $9820 $11089 $12396 $11051 reversed $9769 $-1 #
+vertex $-1 -1 -1 $-1 $12397 $12398 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 -0.70710678118654735 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $12399 $10418 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 20 7.5000000000000018 0 35 F #
+loop $-1 -1 -1 $-1 $-1 $9894 $9825 T -7.5000000000000036 -20 -25 8.8817841970012523e-16 -15 -10 unknown #
+coedge $-1 -1 -1 $-1 $12400 $9826 $11035 $12397 forward $8739 $-1 #
+coedge $-1 -1 -1 $-1 $9826 $12400 $9876 $10993 reversed $8739 $-1 #
+edge $-1 -1 -1 $-1 $9777 6.1232339957367648e-17 $11027 1.5707963267948966 $9826 $12401 forward @7 unknown T -8.8817841970012523e-16 -25 -10 4.9999999999999991 -20 -5 #
+coedge $-1 -1 -1 $-1 $9827 $12367 $11032 $12397 reversed $8683 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $12402 $12403 $11 $-1 $5386 reversed single T 15 -10 -25 22.500000000000004 -4.9999999999999991 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $12404 $9829 T 15 -5 -25 22.5 -8.8817841970012523e-16 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $12405 $12406 $12407 $12408 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $12409 $9831 $12410 $12411 reversed $8743 $-1 #
+coedge $-1 -1 -1 $-1 $9831 $12412 $12139 $12413 reversed $8743 $-1 #
+coedge $-1 -1 -1 $-1 $12414 $12415 $9831 $11043 forward $12145 $-1 #
+edge $-1 -1 -1 $-1 $12416 -1.5707963267948966 $12417 -2.9403902792268234e-16 $11042 $12418 forward @7 unknown T 14.999999999999996 -4.9999999999999991 5.0000000000000009 20 0 10 #
+coedge $-1 -1 -1 $-1 $12419 $9832 $10434 $11760 reversed $9585 $-1 #
+coedge $-1 -1 -1 $-1 $9832 $12419 $12412 $12420 forward $9585 $-1 #
+vertex $-1 -1 -1 $-1 $12420 $12421 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+loop $-1 -1 -1 $-1 $-1 $12422 $9834 T -5 -25 -30 4.9999999999999991 -20 -20 unknown #
+coedge $-1 -1 -1 $-1 $12396 $12384 $9836 $11050 forward $12388 $-1 #
+edge $-1 -1 -1 $-1 $8695 6.1232339957367648e-17 $9838 1.5707963267948966 $11049 $12423 forward @7 unknown T -8.8817841970012523e-16 -25 5 4.9999999999999991 -20 10 #
+edge $-1 -1 -1 $-1 $9838 -1.5707963267948966 $10990 -6.1232339957367648e-17 $12396 $12424 forward @7 unknown T -8.8817841970012523e-16 -25 0 4.9999999999999991 -20 5 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 5 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $12155 $10838 $11 $-1 $4210 reversed single T -5 -20 -45 4.9999999999999991 -15 -35 F #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 20 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $12425 $11099 $12367 $9895 reversed $9846 $-1 #
+coedge $-1 -1 -1 $-1 $12315 $12426 $9848 $11058 reversed $10870 $-1 #
+edge $-1 -1 -1 $-1 $10952 -1.5707963267948966 $12306 1.5707963267948966 $9848 $12427 forward @7 unknown T -45 -24.999999999999996 -30.000000000000004 -40 -14.999999999999996 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $11059 $11059 $10929 $12282 reversed $9849 $-1 #
+coedge $-1 -1 -1 $-1 $9850 $9850 $12212 $12428 forward $8768 $-1 #
+coedge $-1 -1 -1 $-1 $12429 $12213 $9850 $11062 reversed $9673 $-1 #
+edge $-1 -1 -1 $-1 $12430 -1.5707963267948966 $12431 1.5707963267948966 $9850 $12432 forward @7 unknown T -45 -24.999999999999996 -45 -40 -14.999999999999996 -40 #
+coedge $-1 -1 -1 $-1 $9852 $9851 $12433 $12434 reversed $7783 $-1 #
+coedge $-1 -1 -1 $-1 $12151 $12178 $9851 $11065 forward $12152 $-1 #
+edge $-1 -1 -1 $-1 $12435 -1.5707963267948966 $11072 -1.0471975511965965 $11064 $12436 forward @7 unknown T -22.500000000000007 -15.669872981077811 -42.500000000000007 -20 -15 -40 #
+coedge $-1 -1 -1 $-1 $12437 $12438 $9852 $11067 reversed $12439 $-1 #
+edge $-1 -1 -1 $-1 $12440 -2.0943951023931957 $11071 -1.5707963267948966 $9852 $12441 forward @7 unknown T -25 -15.669872981077809 -40 -22.499999999999993 -15 -37.5 #
+coedge $-1 -1 -1 $-1 $12162 $9853 $12442 $12443 reversed $11070 $-1 #
+coedge $-1 -1 -1 $-1 $9853 $12149 $12151 $12444 reversed $11070 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11069 $10505 T -30 -20 -50 -22.5 -15 -40 unknown #
+vertex $-1 -1 -1 $-1 $12443 $12445 #
+vertex $-1 -1 -1 $-1 $9854 $12446 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12447 $9855 $9859 $11083 forward $11076 $-1 #
+coedge $-1 -1 -1 $-1 $9855 $11841 $10829 $12183 forward $11076 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11841 $12448 T -7.5000000000000027 -25 -40 0 -20 -25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12449 $9858 $9724 $10923 forward $9723 $-1 #
+coedge $-1 -1 -1 $-1 $10819 $12450 $9858 $11081 forward $12174 $-1 #
+edge $-1 -1 -1 $-1 $12271 6.1232339957367648e-17 $9860 1.5707963267948966 $11080 $12451 forward @7 unknown T -15.000000000000002 -25 -40 -10.000000000000002 -20 -35 #
+coedge $-1 -1 -1 $-1 $9859 $12449 $12452 $12453 reversed $9723 $-1 #
+edge $-1 -1 -1 $-1 $9861 -37.5 $12454 -27.500000000000004 $11074 $12455 forward @7 unknown T -7.5000000000000027 -24.330127018922195 -37.5 -7.5000000000000009 -24.330127018922191 -27.500000000000004 #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 -40 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $12456 $9863 $12457 $12386 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $9864 $12456 $12458 $12459 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $9865 $11102 $12460 $12461 forward $9877 $-1 #
+coedge $-1 -1 -1 $-1 $11026 $11025 $8685 $9774 forward $9769 $-1 #
+coedge $-1 -1 -1 $-1 $12462 $9866 $12463 $12464 reversed $8644 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -10.000000000000002 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10942 $12465 $9868 $11093 forward $12301 $-1 #
+edge $-1 -1 -1 $-1 $12311 -2.0943951023931948 $9870 -1.5707963267948966 $11092 $12466 forward @7 unknown T -40 -24.999999999999996 -12.500000000000005 -37.5 -24.330127018922191 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $9869 $10944 $12467 $12468 reversed $7620 $-1 #
+coedge $-1 -1 -1 $-1 $12469 $12463 $9869 $11096 forward $12470 $-1 #
+edge $-1 -1 -1 $-1 $9871 1.5707963267948966 $12471 2.0943951023931953 $11095 $12472 forward @7 unknown T -40 -15.669872981077809 -12.500000000000004 -37.5 -14.999999999999996 -10.000000000000002 #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 -10.000000000000002 #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $11056 $9873 $12400 $12473 forward $9846 $-1 #
+coedge $-1 -1 -1 $-1 $9873 $12474 $9880 $11105 forward $9846 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -10 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11088 $9875 $9974 $11217 forward $9877 $-1 #
+point $-1 -1 -1 $-1 -5 -25 -10 #
+coedge $-1 -1 -1 $-1 $12475 $9880 $12476 $12477 reversed $9882 $-1 #
+edge $-1 -1 -1 $-1 $12478 -22.500000000000004 $9883 -12.500000000000004 $11100 $12479 forward @7 unknown T -7.5000000000000027 -24.330127018922195 -22.500000000000004 -7.5000000000000009 -24.330127018922191 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $9881 $12475 $12480 $12481 forward $9882 $-1 #
+coedge $-1 -1 -1 $-1 $12482 $9886 $9881 $9891 forward $11113 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $9888 $9885 $12483 $11222 reversed $8788 $-1 #
+coedge $-1 -1 -1 $-1 $10973 $12484 $12485 $11111 reversed $9753 $-1 #
+edge $-1 -1 -1 $-1 $11114 -5.0000000000000018 $12486 -8.8817841970012523e-16 $12485 $12487 forward @7 unknown T -15 -20 -5.0000000000000018 -14.999999999999996 -20 -8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $9886 $12482 $12488 $12489 reversed $11113 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9886 $12184 T -20 -25 -15.000000000000002 -10.000000000000002 -20 -5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $12489 $12490 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $11217 $12491 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $12492 $12493 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12494 $9894 $9896 $11123 forward $11031 $-1 #
+coedge $-1 -1 -1 $-1 $9894 $12495 $10985 $12373 forward $11031 $-1 #
+edge $-1 -1 -1 $-1 $9897 0 $12378 1.5707963267948966 $11120 $12496 forward @7 unknown T -5 -20 -15 8.8817841970012523e-16 -15 -10 #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 -20 -15 #
+coedge $-1 -1 -1 $-1 $11197 $12497 $12498 $12499 reversed $9899 $-1 #
+coedge $-1 -1 -1 $-1 $11170 $9900 $12500 $12501 reversed $8799 $-1 #
+coedge $-1 -1 -1 $-1 $9900 $12502 $12503 $12504 reversed $8799 $-1 #
+coedge $-1 -1 -1 $-1 $12505 $12506 $9900 $11129 forward $12507 $-1 #
+edge $-1 -1 -1 $-1 $12508 1.5707963267948966 $12509 2.0943951023931957 $11128 $12510 forward @7 unknown T 35 -10.000000000000002 -9.9999999999999982 37.500000000000007 -9.3301270189221945 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $12511 $9901 $8802 $9910 forward $7808 $-1 #
+coedge $-1 -1 -1 $-1 $10798 $11815 $9901 $11132 forward $11816 $-1 #
+edge $-1 -1 -1 $-1 $9912 -4.7167471186270745e-16 $11138 1.5707963267948966 $11131 $12512 forward @7 unknown T 29.999999999999996 -10.000000000000002 -24.999999999999996 35 -4.9999999999999991 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $9902 $12511 $12506 $12513 reversed $7808 $-1 #
+coedge $-1 -1 -1 $-1 $12514 $12515 $9902 $11135 forward $12516 $-1 #
+edge $-1 -1 -1 $-1 $11139 -22.499999999999986 $12517 -12.499999999999996 $11134 $12518 forward @7 unknown T 37.5 -9.3301270189221945 -22.499999999999986 37.500000000000007 -9.3301270189221892 -12.499999999999996 #
+coedge $-1 -1 -1 $-1 $11795 $9903 $12515 $12519 reversed $11137 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10467 $12520 T 35 -10.000000000000002 -27.499999999999989 40.000000000000007 -9.3301270189221874 -22.499999999999986 unknown #
+vertex $-1 -1 -1 $-1 $10799 $12521 #
+vertex $-1 -1 -1 $-1 $11135 $12522 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9908 $9905 $9917 $11162 reversed $6872 $-1 #
+coedge $-1 -1 -1 $-1 $12523 $12524 $9905 $11143 forward $12516 $-1 #
+edge $-1 -1 -1 $-1 $12525 12.5 $11145 22.499999999999996 $11142 $12526 forward @7 unknown T 37.5 -0.66987298107781124 -22.499999999999996 37.5 -0.66987298107780724 -12.5 #
+coedge $-1 -1 -1 $-1 $9906 $10474 $12523 $12527 reversed $10475 $-1 #
+vertex $-1 -1 -1 $-1 $12527 $12528 #
+coedge $-1 -1 -1 $-1 $12529 $9909 $9928 $11174 forward $11150 $-1 #
+coedge $-1 -1 -1 $-1 $9909 $12530 $9911 $11153 forward $11150 $-1 #
+coedge $-1 -1 -1 $-1 $12531 $12532 $11130 $9910 reversed $12533 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9909 $11178 T 22.499999999999993 -5.0000000000000009 -25 30 8.8817841970012523e-16 -9.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $11174 $12534 #
+straight-curve $-1 -1 -1 $-1 30 -5.0000000000000009 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $10483 1.5707963267948966 $9912 3.1415926535897931 $11148 $12535 forward @7 unknown T 25 -4.9999999999999991 -25 29.999999999999996 0 -20 #
+edge $-1 -1 -1 $-1 $9912 3.1415926535897931 $11817 4.7123889803846897 $12531 $12535 forward @7 unknown T 25 -10 -25 29.999999999999996 -4.9999999999999991 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 -4.9999999999999991 -20 #
+coedge $-1 -1 -1 $-1 $12536 $9915 $9918 $11163 forward $11158 $-1 #
+coedge $-1 -1 -1 $-1 $9915 $12537 $9939 $11184 forward $11158 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9915 $12538 T 37.499999999999993 -10 -9.9999999999999982 45.000000000000007 8.8817841970012523e-16 5.0000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $9916 $12539 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $9918 $9917 $12524 $12540 reversed $9919 $-1 #
+edge $-1 -1 -1 $-1 $8814 1.5707963267948966 $12525 2.0943951023931957 $9917 $12541 forward @7 unknown T 35 -0.66987298107781079 -12.5 37.5 -1.7763568394002505e-15 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $9920 4.1887902047863905 $12542 4.7123889803846897 $11156 $12543 forward @7 unknown T 37.5 -0.66987298107780902 -9.9999999999999982 40 0 -7.4999999999999947 #
+face $-1 -1 -1 $-1 $12544 $9919 $11 $-1 $11179 reversed single T 35 -0.66987298107781079 -12.5 40 0 -7.4999999999999947 F #
+point $-1 -1 -1 $-1 37.5 -0.6698729810778089 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $12545 $9922 $12546 $11199 forward $9925 $-1 #
+coedge $-1 -1 -1 $-1 $9923 $12545 $12547 $12548 forward $9925 $-1 #
+coedge $-1 -1 -1 $-1 $12549 $9924 $12550 $9933 forward $11171 $-1 #
+coedge $-1 -1 -1 $-1 $9924 $12551 $12552 $12553 forward $11171 $-1 #
+coedge $-1 -1 -1 $-1 $12554 $11126 $7811 $8810 forward $8799 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9924 $12555 T 22.5 -10 -9.9999999999999982 30 -4.9999999999999991 5.0000000000000036 unknown #
+face $-1 -1 -1 $-1 $12556 $9925 $11 $-1 $4486 reversed single T 22.5 -5.0000000000000009 -9.9999999999999982 30 8.8817841970012523e-16 5.0000000000000036 F #
+point $-1 -1 -1 $-1 29.999999999999996 -5 1.7763568394002505e-15 #
+edge $-1 -1 -1 $-1 $11151 0 $11175 1.5707963267948966 $11147 $12557 forward @7 unknown T 25 -5 -14.999999999999998 30 8.8817841970012523e-16 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $12558 $12559 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 -9.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8136 $11150 $11 $-1 $4486 reversed single T 22.499999999999993 -5.0000000000000009 -25 30 8.8817841970012523e-16 -9.9999999999999964 F #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 -5 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $12560 $12561 #
+coedge $-1 -1 -1 $-1 $12562 $9935 $12563 $12564 forward $8452 $-1 #
+coedge $-1 -1 -1 $-1 $9936 $11685 $10416 $11740 forward $8452 $-1 #
+point $-1 -1 -1 $-1 37.499999999999993 -0.66987298107780613 17.500000000000007 #
+edge $-1 -1 -1 $-1 $11186 -1.570796326794897 $11159 -1.0471975511965987 $11157 $12565 forward @7 unknown T 37.5 -0.66987298107780502 2.5000000000000053 40 0 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $11184 $12566 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9945 $9944 $12409 $12567 forward $8495 $-1 #
+coedge $-1 -1 -1 $-1 $12410 $12546 $9945 $11190 reversed $12568 $-1 #
+edge $-1 -1 -1 $-1 $12569 4.1887902047863914 $9952 4.7123889803846897 $9945 $12570 forward @7 unknown T 22.499999999999996 -0.66987298107780635 5.0000000000000018 25 0 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $12571 $9946 $12572 $12573 forward $9949 $-1 #
+coedge $-1 -1 -1 $-1 $12574 $12552 $9946 $8835 reversed $11202 $-1 #
+coedge $-1 -1 -1 $-1 $9947 $12571 $11790 $9969 forward $9949 $-1 #
+coedge $-1 -1 -1 $-1 $9963 $11678 $9947 $11195 reversed $9968 $-1 #
+edge $-1 -1 -1 $-1 $8849 -1.5707963267948961 $8828 0 $9947 $9964 forward @7 unknown T 25 -10 15 29.999999999999996 -5 20 #
+coedge $-1 -1 -1 $-1 $12575 $9948 $11678 $12576 reversed $9899 $-1 #
+coedge $-1 -1 -1 $-1 $9948 $11125 $12574 $12577 reversed $9899 $-1 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $9952 -1.570796326794897 $12578 -1.0471975511965983 $11166 $12579 forward @7 unknown T 22.5 -0.66987298107780768 2.5000000000000036 25 0 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 0 5.0000000000000018 #
+face $-1 -1 -1 $-1 $9942 $12580 $11 $-1 $9956 reversed single T 35 -10.000000000000004 2.5000000000000031 40.000000000000007 -9.330127018922191 7.500000000000008 F #
+loop $-1 -1 -1 $-1 $-1 $12574 $9955 T 24.999999999999996 -10.000000000000004 1.7763568394002505e-15 35 -4.9999999999999991 10.000000000000002 unknown #
+edge $-1 -1 -1 $-1 $12581 1.0471975511965983 $9957 1.570796326794897 $12551 $12579 forward @7 unknown T 22.5 -10 2.5000000000000044 25 -9.3301270189221945 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 -10 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 0 20.000000000000004 #
+vertex $-1 -1 -1 $-1 $12567 $12582 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+vertex $-1 -1 -1 $-1 $9969 $12583 #
+coedge $-1 -1 -1 $-1 $12197 $10853 $9971 $11211 reversed $9646 $-1 #
+edge $-1 -1 -1 $-1 $11215 -1.5707963267948966 $11214 1.5707963267948966 $9971 $12584 forward @7 unknown T -45 -24.999999999999996 4.9999999999999973 -40 -14.999999999999996 9.9999999999999964 #
+coedge $-1 -1 -1 $-1 $10941 $9972 $12585 $12586 reversed $8644 $-1 #
+coedge $-1 -1 -1 $-1 $9972 $12462 $12587 $12588 reversed $8644 $-1 #
+vertex $-1 -1 -1 $-1 $9973 $12589 #
+vertex $-1 -1 -1 $-1 $9973 $12590 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 4.9999999999999973 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11116 1.0471975511965974 $11005 1.5707963267948966 $11102 $12591 forward @7 unknown T -7.5000000000000027 -25 2.4999999999999982 -5 -24.330127018922191 5 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 5 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $12483 $12592 $9978 $11221 forward $12593 $-1 #
+edge $-1 -1 -1 $-1 $12359 6.1232339957367648e-17 $9979 1.5707963267948966 $11220 $12594 forward @7 unknown T -15.000000000000002 -25 4.9999999999999991 -10.000000000000002 -20 10 #
+edge $-1 -1 -1 $-1 $9979 -1.5707963267948966 $12486 -6.1232339957367648e-17 $12483 $12595 forward @7 unknown T -15.000000000000002 -25 -1.7763568394002505e-15 -10.000000000000002 -20 4.9999999999999991 #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 4.9999999999999991 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $12596 $9983 $12597 $11263 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $12598 $12599 $9983 $11227 reversed $12600 $-1 #
+edge $-1 -1 -1 $-1 $10030 2.617993877991494 $10014 4.7123889803846897 $9983 $12601 forward @7 unknown T -15 35 50 -7.4999999999999973 40 50 #
+coedge $-1 -1 -1 $-1 $9984 $12602 $12598 $11283 forward $10040 $-1 #
+coedge $-1 -1 -1 $-1 $11230 $9985 $12603 $11305 reversed $9987 $-1 #
+coedge $-1 -1 -1 $-1 $9986 $11229 $12604 $12605 reversed $9987 $-1 #
+face $-1 -1 -1 $-1 $8914 $9987 $11 $-1 $10029 reversed single T 0 35 35 7.5000000000000036 40 50 F #
+coedge $-1 -1 -1 $-1 $12606 $12603 $9989 $11233 reversed $12607 $-1 #
+edge $-1 -1 -1 $-1 $10045 1.5707963267948966 $10051 2.0943951023931957 $9989 $10034 forward @7 unknown T 7.4999999999999991 35 35 10 35.669872981077809 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $9990 $9993 $12608 $12609 forward $9994 $-1 #
+coedge $-1 -1 -1 $-1 $11291 $9991 $12610 $11339 forward $11236 $-1 #
+loop $-1 -1 -1 $-1 $-1 $9991 $10061 T 10 35 30 20.000000000000004 40 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8939 $9994 $11 $-1 $8951 reversed single T 20.000000000000004 35 32.5 25 35.669872981077809 37.5 F #
+coedge $-1 -1 -1 $-1 $12611 $9995 $10006 $11249 reversed $11240 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12611 $12612 T 29.999999999999996 35 20.000000000000004 37.500000000000014 40 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 -0.70710678118654724 -0 -0.70710678118654779 -5 3.0616169978683826e-16 4.9999999999999956 0.70710678118654791 I I #
+ellipse-curve $-1 -1 -1 $-1 35 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $9999 $12613 $8946 $10063 forward $11240 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40 40 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11245 $11245 $12614 $12615 reversed $10002 $-1 #
+face $-1 -1 -1 $-1 $12616 $12617 $11 $-1 $8951 reversed single T -9.9999999999999982 35 32.5 -5 35.669872981077816 37.5 F #
+coedge $-1 -1 -1 $-1 $12618 $10004 $12619 $12620 forward $8902 $-1 #
+coedge $-1 -1 -1 $-1 $10006 $12618 $12621 $12622 forward $8902 $-1 #
+edge $-1 -1 -1 $-1 $12623 22.500000000000014 $10007 32.500000000000007 $10006 $12624 forward @7 unknown T 37.5 35.669872981077809 22.500000000000014 37.500000000000014 35.669872981077816 32.500000000000007 #
+point $-1 -1 -1 $-1 37.500000000000007 35.669872981077816 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $10008 $12625 $12626 $12627 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $12628 $12629 $10008 $11253 reversed $12630 $-1 #
+edge $-1 -1 -1 $-1 $12631 -1.5707963267948966 $11257 0.52359877559829826 $10008 $12632 forward @7 unknown T -30 40 50 -22.5 45 50 #
+coedge $-1 -1 -1 $-1 $12633 $10009 $12629 $12634 forward $11256 $-1 #
+coedge $-1 -1 -1 $-1 $10009 $12635 $12636 $11260 forward $11256 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11255 $12637 T -22.5 40 35 -15 45 50 unknown #
+vertex $-1 -1 -1 $-1 $10010 $12638 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11261 $10011 $12639 $12640 reversed $10013 $-1 #
+edge $-1 -1 -1 $-1 $12641 40 $10014 50 $11255 $12642 forward @7 unknown T -15 40 40 -15 40 50 #
+coedge $-1 -1 -1 $-1 $10012 $11259 $12643 $12644 reversed $10013 $-1 #
+face $-1 -1 -1 $-1 $12645 $10013 $11 $-1 $12646 reversed single T -15 40 35 -7.4999999999999982 45 50 F #
+edge $-1 -1 -1 $-1 $10014 0 $12647 2.0943951023931957 $11225 $11258 forward @7 unknown T -22.5 35 50 -15 40 50 #
+point $-1 -1 -1 $-1 -15 40 50 #
+coedge $-1 -1 -1 $-1 $12643 $12648 $10016 $11266 reversed $12649 $-1 #
+edge $-1 -1 -1 $-1 $11267 4.1887902047863905 $12650 4.7123889803846897 $10016 $12651 forward @7 unknown T -7.5000000000000018 44.330127018922191 35 -5 45 37.5 #
+vertex $-1 -1 -1 $-1 $11266 $12652 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $12653 $10022 $10018 $11270 reversed $11274 $-1 #
+edge $-1 -1 -1 $-1 $12650 1.5707963267948966 $10024 3.1415926535897931 $10018 $12654 forward @7 unknown T -5 40 35 0 45 40 #
+coedge $-1 -1 -1 $-1 $12602 $10019 $12655 $11277 forward $10040 $-1 #
+face $-1 -1 -1 $-1 $12656 $12657 $11 $-1 $12658 reversed single T 39.999999999999993 35 15.000000000000004 50 45 25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $10022 $12653 $12659 $12660 forward $11274 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10022 $11292 T -5 40 30 5.0000000000000027 45 40 unknown #
+vertex $-1 -1 -1 $-1 $12660 $12661 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10024 3.1415926535897931 $12662 4.7123889803846897 $11271 $12654 forward @7 unknown T -5 35 35 0 40 40 #
+point $-1 -1 -1 $-1 0 40 40 #
+coedge $-1 -1 -1 $-1 $10031 $10026 $12663 $12664 forward $10032 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12665 $12666 $11 $-1 $10029 reversed single T 0 40 -40 7.5000000000000027 45 -25 F #
+loop $-1 -1 -1 $-1 $-1 $12667 $10028 T 0 40 -50 7.5000000000000027 45 -40 unknown #
+edge $-1 -1 -1 $-1 $12668 37.5 $10030 50 $11228 $12669 forward @7 unknown T -7.5 35.669872981077809 37.5 -7.4999999999999991 35.669872981077809 50 #
+point $-1 -1 -1 $-1 -7.4999999999999991 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $12670 $11289 $10031 $11286 forward $11293 $-1 #
+edge $-1 -1 -1 $-1 $10033 -1.5707963267948966 $12671 -1.0471975511965974 $11285 $12672 forward @7 unknown T 7.4999999999999991 44.330127018922191 32.5 10 45 35 #
+face $-1 -1 -1 $-1 $12673 $10032 $11 $-1 $8951 reversed single T 5.0000000000000027 44.330127018922191 32.5 10 45 37.500000000000007 F #
+point $-1 -1 -1 $-1 10 45 35 #
+coedge $-1 -1 -1 $-1 $11285 $12674 $10036 $11290 forward $11293 $-1 #
+edge $-1 -1 -1 $-1 $11296 0 $10033 1.5707963267948966 $11289 $12675 forward @7 unknown T 10 40 30 15 45 35 #
+coedge $-1 -1 -1 $-1 $10038 $11235 $12676 $12677 reversed $11236 $-1 #
+face $-1 -1 -1 $-1 $12678 $11274 $11 $-1 $8951 reversed single T -5 40 30 5.0000000000000027 45 40 F #
+loop $-1 -1 -1 $-1 $-1 $12674 $10039 T 7.4999999999999991 40 20 15.000000000000002 45 35 unknown #
+coedge $-1 -1 -1 $-1 $12679 $10042 $12674 $12680 reversed $11295 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12679 $12681 T 15 40 20 22.500000000000004 45 35 unknown #
+vertex $-1 -1 -1 $-1 $11290 $12682 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12683 1.0471975511965974 $10045 1.5707963267948966 $12684 $12672 forward @7 unknown T 7.4999999999999991 35 32.5 10 35.669872981077809 35 #
+point $-1 -1 -1 $-1 10 35 35 #
+coedge $-1 -1 -1 $-1 $10046 $12685 $10053 $11308 reversed $11295 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $12686 $10048 T 15 35 -40 22.500000000000007 40 -25 unknown #
+coedge $-1 -1 -1 $-1 $12687 $12688 $12689 $12690 reversed $10049 $-1 #
+coedge $-1 -1 -1 $-1 $10553 $10050 $12691 $11918 reversed $8934 $-1 #
+edge $-1 -1 -1 $-1 $12692 1.5707963267948966 $10051 2.0943951023931957 $12603 $12693 forward @7 unknown T 5.0000000000000027 35 35 7.5000000000000036 35.669872981077809 37.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $11311 $10053 $12694 $12695 forward $8945 $-1 #
+edge $-1 -1 -1 $-1 $10054 -32.5 $12696 -22.5 $10053 $12697 forward @7 unknown T 22.5 44.330127018922184 22.5 22.5 44.330127018922205 32.5 #
+point $-1 -1 -1 $-1 22.5 44.330127018922184 32.5 #
+loop $-1 -1 -1 $-1 $-1 $12698 $10056 T 7.4999999999999991 35 20 15.000000000000002 40 35 unknown #
+coedge $-1 -1 -1 $-1 $10057 $11307 $12699 $12700 forward $8945 $-1 #
+coedge $-1 -1 -1 $-1 $12701 $10059 $11243 $10063 reversed $10071 $-1 #
+coedge $-1 -1 -1 $-1 $12699 $12702 $10062 $11314 forward $12703 $-1 #
+edge $-1 -1 -1 $-1 $12704 -1.5707963267948966 $11315 6.1232339957367623e-17 $11313 $12705 forward @7 unknown T 29.999999999999996 40 20.000000000000004 35 45 25.000000000000007 #
+vertex $-1 -1 -1 $-1 $12706 $12707 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $12708 $12709 $11 $-1 $6121 reversed single T 29.999999999999996 40 5.0000000000000018 37.500000000000007 45 20.000000000000004 F #
+point $-1 -1 -1 $-1 22.5 35.669872981077809 32.5 #
+coedge $-1 -1 -1 $-1 $10067 $12710 $12711 $12712 forward $10071 $-1 #
+coedge $-1 -1 -1 $-1 $12713 $12619 $10068 $11321 forward $12714 $-1 #
+edge $-1 -1 -1 $-1 $11322 -2.0943951023931957 $12704 -1.5707963267948966 $11320 $12715 forward @7 unknown T 35 44.330127018922191 20.000000000000004 37.500000000000007 45 22.500000000000011 #
+vertex $-1 -1 -1 $-1 $12620 $12716 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $10072 $12717 $12718 $12719 reversed $8958 $-1 #
+coedge $-1 -1 -1 $-1 $12720 $10073 $11337 $12721 reversed $7965 $-1 #
+edge $-1 -1 -1 $-1 $10576 -1.5707963267948966 $11334 6.1232339957367648e-17 $10573 $12722 forward @7 unknown T 30 40 -40 35 45 -35 #
+coedge $-1 -1 -1 $-1 $10074 $12720 $12723 $12724 reversed $7965 $-1 #
+coedge $-1 -1 -1 $-1 $12725 $12726 $10074 $11329 forward $12727 $-1 #
+edge $-1 -1 -1 $-1 $11335 -6.1232339957367648e-17 $12728 1.5707963267948966 $11328 $12729 forward @7 unknown T 29.999999999999996 40 -30 35 45 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $12730 $10075 $12726 $12731 forward $11333 $-1 #
+coedge $-1 -1 -1 $-1 $10075 $12732 $11912 $12733 forward $11333 $-1 #
+coedge $-1 -1 -1 $-1 $11904 $12734 $11908 $10076 reversed $12735 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10075 $11917 T 22.5 40 -40 30 45 -25 unknown #
+vertex $-1 -1 -1 $-1 $11905 $12736 #
+vertex $-1 -1 -1 $-1 $12731 $12737 #
+coedge $-1 -1 -1 $-1 $10077 $10533 $11325 $12721 forward $10534 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10079 -1.5707963267948966 $11296 -6.1232339957367648e-17 $11235 $12738 forward @7 unknown T 15 35 30 20.000000000000004 40 35 #
+point $-1 -1 -1 $-1 20.000000000000004 35 35 #
+coedge $-1 -1 -1 $-1 $12739 $10081 $12740 $12741 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $11381 $12742 $10081 $10119 reversed $12743 $-1 #
+coedge $-1 -1 -1 $-1 $12744 $10082 $10084 $10139 reversed $11345 $-1 #
+coedge $-1 -1 -1 $-1 $10082 $12745 $8991 $10116 forward $11345 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11343 $12746 T -15 20 35 -7.4999999999999991 25 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10084 $10127 $12747 $12748 forward $9020 $-1 #
+coedge $-1 -1 -1 $-1 $10088 $12749 $10085 $10161 forward $11352 $-1 #
+coedge $-1 -1 -1 $-1 $12750 $11400 $10086 $11350 forward $12751 $-1 #
+edge $-1 -1 -1 $-1 $9004 6.1232339957367648e-17 $11437 1.5707963267948966 $11349 $12752 forward @7 unknown T 0 20 35 5.0000000000000018 25 40 #
+coedge $-1 -1 -1 $-1 $12749 $10088 $11429 $10154 reversed $11352 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11348 $12753 T 5.0000000000000018 20 32.5 10 20.669872981077813 37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $11456 $11355 $10090 $11354 reversed $12754 $-1 #
+edge $-1 -1 -1 $-1 $9046 -2.0943951023931953 $9059 -1.5707963267948966 $10090 $12755 forward @7 unknown T 20 20 32.5 22.500000000000004 20.669872981077813 35 #
+coedge $-1 -1 -1 $-1 $11353 $12756 $10091 $10195 reversed $12754 $-1 #
+coedge $-1 -1 -1 $-1 $11358 $10095 $12757 $12758 reversed $10096 $-1 #
+face $-1 -1 -1 $-1 $6130 $10096 $11 $-1 $5288 reversed single T 29.999999999999996 19.999999999999996 20.000000000000004 37.500000000000007 25 35 F #
+coedge $-1 -1 -1 $-1 $10099 $11356 $12759 $12760 reversed $10096 $-1 #
+coedge $-1 -1 -1 $-1 $11359 $11359 $10101 $11360 forward $12761 $-1 #
+edge $-1 -1 -1 $-1 $12762 0 $12762 6.2831853071795862 $11359 $12763 forward @7 unknown T 50 20 30 50 30 40 #
+face $-1 -1 -1 $-1 $9000 $12764 $11 $-1 $8043 reversed single T -50 20 29.999999999999996 -40 30.000000000000004 40 F #
+loop $-1 -1 -1 $-1 $-1 $12765 $10102 T -9.9999999999999982 20 32.5 -5 20.669872981077805 37.5 unknown #
+coedge $-1 -1 -1 $-1 $10104 $10103 $12766 $12767 forward $7994 $-1 #
+coedge $-1 -1 -1 $-1 $10176 $12768 $10103 $11365 reversed $11459 $-1 #
+edge $-1 -1 -1 $-1 $10178 4.1887902047863905 $12769 4.7123889803846897 $10103 $12770 forward @7 unknown T 37.500000000000007 29.330127018922191 20.000000000000004 40.000000000000007 30 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $12771 $12757 $10104 $11367 reversed $12772 $-1 #
+edge $-1 -1 -1 $-1 $12773 1.570796326794897 $11368 2.0943951023931957 $10104 $12770 forward @7 unknown T 37.5 20 20.000000000000004 40.000000000000007 20.669872981077809 22.500000000000007 #
+vertex $-1 -1 -1 $-1 $12758 $12774 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10107 $12739 $12775 $12776 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $12777 $12778 $10107 $11372 reversed $12779 $-1 #
+edge $-1 -1 -1 $-1 $12780 -2.0943951023931948 $11376 0 $10107 $12781 forward @7 unknown T -37.5 25 50 -30 30 50 #
+coedge $-1 -1 -1 $-1 $12782 $10108 $12778 $12783 reversed $11375 $-1 #
+coedge $-1 -1 -1 $-1 $10108 $12784 $10110 $11379 reversed $11375 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11374 $12785 T -30 25 35 -22.5 30 50 unknown #
+vertex $-1 -1 -1 $-1 $12786 $12787 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11380 $10110 $12788 $12789 forward $10112 $-1 #
+edge $-1 -1 -1 $-1 $10113 -50 $12790 -37.500000000000007 $10110 $12791 forward @7 unknown T -22.500000000000004 29.330127018922195 37.500000000000007 -22.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $10111 $11378 $12792 $12793 forward $10112 $-1 #
+coedge $-1 -1 -1 $-1 $12794 $11342 $11344 $10116 reversed $12743 $-1 #
+face $-1 -1 -1 $-1 $12795 $10112 $11 $-1 $12796 reversed single T -22.500000000000004 25 35 -15 30 50 F #
+point $-1 -1 -1 $-1 -22.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $12792 $12797 $10115 $11385 forward $12798 $-1 #
+edge $-1 -1 -1 $-1 $12799 -1.5707963267948966 $11386 6.1232339957367648e-17 $11384 $12800 forward @7 unknown T -15 25 35 -9.9999999999999982 30 40 #
+vertex $-1 -1 -1 $-1 $12801 $12802 #
+straight-curve $-1 -1 -1 $-1 -15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12803 $10121 $10117 $11389 forward $11394 $-1 #
+edge $-1 -1 -1 $-1 $10123 -2.0943951023931957 $12799 -1.5707963267948966 $11388 $12804 forward @7 unknown T -9.9999999999999982 29.330127018922191 35 -7.4999999999999964 30 37.5 #
+face $-1 -1 -1 $-1 $12805 $12806 $11 $-1 $11391 reversed single T -15 25 20 -7.4999999999999964 30 35 F #
+cone-surface $-1 -1 -1 $-1 -9.9999999999999982 25 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $12807 $12808 #
+coedge $-1 -1 -1 $-1 $10121 $12803 $12809 $12810 reversed $11394 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11388 $12811 T -9.9999999999999982 29.330127018922191 32.5 -5 30 37.5 unknown #
+vertex $-1 -1 -1 $-1 $12810 $12812 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999964 29.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $10129 $10125 $12813 $12814 reversed $10130 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11349 $12815 $10127 $10133 reversed $12751 $-1 #
+face $-1 -1 -1 $-1 $12816 $12817 $11 $-1 $11403 reversed single T -9.9999999999999982 20 17.5 -5 20.669872981077809 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $12818 $12819 $10128 T 39.999999999999993 20 15.000000000000004 45.000000000000007 30 25.000000000000004 unknown #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 25 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $12820 $11408 $10129 $11405 reversed $12821 $-1 #
+edge $-1 -1 -1 $-1 $12822 -6.1232339957367648e-17 $10131 1.5707963267948966 $10129 $12823 forward @7 unknown T 0 25 30 5.0000000000000018 30 35 #
+point $-1 -1 -1 $-1 5.0000000000000018 30 35 #
+vertex $-1 -1 -1 $-1 $12824 $12825 #
+coedge $-1 -1 -1 $-1 $11404 $12826 $10135 $11409 reversed $12821 $-1 #
+edge $-1 -1 -1 $-1 $10131 1.5707963267948966 $11416 2.0943951023931953 $10135 $12827 forward @7 unknown T 5.0000000000000018 29.330127018922191 32.5 7.5000000000000009 30 35 #
+face $-1 -1 -1 $-1 $10613 $12828 $11 $-1 $9009 reversed single T 0 20 -40 7.5000000000000009 25 -25 F #
+loop $-1 -1 -1 $-1 $-1 $12829 $10137 T 0 25 -40 7.5000000000000027 30 -25 unknown #
+coedge $-1 -1 -1 $-1 $12830 $10584 $10586 $10634 reversed $10138 $-1 #
+vertex $-1 -1 -1 $-1 $12831 $12832 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12833 $10141 $12826 $12834 forward $10149 $-1 #
+vertex $-1 -1 -1 $-1 $12834 $12835 #
+ellipse-curve $-1 -1 -1 $-1 10 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9414 $12836 $11 $-1 $9021 reversed single T -7.5000000000000009 20 20 8.8817841970012523e-16 25 35 F #
+coedge $-1 -1 -1 $-1 $10145 $12837 $11443 $11425 forward $10149 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11443 $11429 $10147 $11422 forward $10166 $-1 #
+edge $-1 -1 -1 $-1 $9025 -1.5707963267948966 $10152 0 $11421 $11420 forward @7 unknown T 10 20 30 15 25 35 #
+face $-1 -1 -1 $-1 $12753 $12751 $11 $-1 $8043 reversed single T -5 20 30 5.0000000000000018 25 40 F #
+coedge $-1 -1 -1 $-1 $11430 $10150 $12838 $12839 reversed $10151 $-1 #
+edge $-1 -1 -1 $-1 $12840 25 $10152 30 $11419 $12841 forward @7 unknown T 15 25 25 15 25 30 #
+face $-1 -1 -1 $-1 $12842 $10151 $11 $-1 $7081 reversed single T 15 25 20 22.5 30 35 F #
+point $-1 -1 -1 $-1 15 25 30 #
+vertex $-1 -1 -1 $-1 $10154 $12843 #
+coedge $-1 -1 -1 $-1 $11421 $12844 $11351 $10154 forward $10166 $-1 #
+coedge $-1 -1 -1 $-1 $10156 $11424 $12845 $12846 reversed $10151 $-1 #
+coedge $-1 -1 -1 $-1 $11967 $12847 $10632 $11977 reversed $10158 $-1 #
+coedge $-1 -1 -1 $-1 $12848 $10159 $11971 $12849 reversed $9029 $-1 #
+coedge $-1 -1 -1 $-1 $10159 $12850 $12851 $12852 reversed $9029 $-1 #
+coedge $-1 -1 -1 $-1 $12853 $12854 $12855 $11435 forward $12856 $-1 #
+edge $-1 -1 -1 $-1 $12857 -35 $12858 -30 $11434 $12859 forward @7 unknown T 15 25 -35 15 25 -30 #
+coedge $-1 -1 -1 $-1 $10587 $12860 $10160 $10654 forward $11925 $-1 #
+vertex $-1 -1 -1 $-1 $12861 $12862 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12845 $12863 $10163 $11440 reversed $12864 $-1 #
+edge $-1 -1 -1 $-1 $11441 4.1887902047863914 $12865 4.7123889803846897 $10163 $12866 forward @7 unknown T 22.5 29.330127018922195 20 25 30 22.5 #
+vertex $-1 -1 -1 $-1 $11440 $12867 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $12868 $11421 $12756 $11425 reversed $10166 $-1 #
+coedge $-1 -1 -1 $-1 $12869 $10169 $10167 $11445 reversed $11448 $-1 #
+edge $-1 -1 -1 $-1 $12865 1.5707963267948966 $10171 3.1415926535897931 $10167 $12870 forward @7 unknown T 25 25 20 29.999999999999996 30 25 #
+coedge $-1 -1 -1 $-1 $11455 $10168 $12871 $11451 forward $9051 $-1 #
+coedge $-1 -1 -1 $-1 $10169 $12869 $12872 $12873 forward $11448 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10169 $10599 T 25 25 15 35 30 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $12873 $12874 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10171 3.1415926535897931 $12875 4.7123889803846897 $11446 $12870 forward @7 unknown T 25 20 20 29.999999999999996 25 25 #
+point $-1 -1 -1 $-1 29.999999999999996 25 25 #
+face $-1 -1 -1 $-1 $12876 $12877 $11 $-1 $5288 reversed single T 29.999999999999996 25 -9.9999999999999982 37.5 29.999999999999996 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $12878 $10173 T 29.999999999999996 25 5.0000000000000018 37.500000000000007 29.999999999999996 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $10175 $11446 $12879 $12880 forward $9051 $-1 #
+coedge $-1 -1 -1 $-1 $12881 $11353 $10175 $11457 reversed $12754 $-1 #
+edge $-1 -1 -1 $-1 $12882 22.499999999999996 $9046 32.500000000000007 $10175 $12883 forward @7 unknown T 22.499999999999993 20.669872981077802 22.499999999999996 22.500000000000004 20.669872981077813 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $12768 $10176 $12884 $12885 forward $11459 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10176 $12886 T 35 29.330127018922187 17.500000000000007 40.000000000000007 30 22.500000000000011 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 29.330127018922195 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $10180 $11988 $12887 $12888 reversed $8050 $-1 #
+coedge $-1 -1 -1 $-1 $12889 $10592 $10180 $11464 forward $11930 $-1 #
+edge $-1 -1 -1 $-1 $10651 -37.5 $12890 -27.499999999999986 $11463 $12891 forward @7 unknown T 37.5 20.669872981077802 -37.5 37.5 20.669872981077805 -27.499999999999986 #
+coedge $-1 -1 -1 $-1 $10183 $10181 $11932 $12892 reversed $7103 $-1 #
+edge $-1 -1 -1 $-1 $11933 -2.0943951023931953 $9441 -1.5707963267948966 $10193 $12893 forward @7 unknown T 35 29.330127018922187 -40 37.5 29.999999999999996 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12894 $12895 $10183 $11469 forward $12896 $-1 #
+edge $-1 -1 -1 $-1 $11473 1.5707963267948966 $12897 2.0943951023931953 $11468 $12898 forward @7 unknown T 35 29.330127018922187 -27.499999999999996 37.5 29.999999999999996 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $12899 $10184 $12900 $12901 forward $11472 $-1 #
+coedge $-1 -1 -1 $-1 $10184 $12899 $10186 $11476 reversed $11472 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10184 $12902 T 25 25 -30 35 30 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $10185 $12903 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12904 $10186 $12905 $12906 forward $10189 $-1 #
+edge $-1 -1 -1 $-1 $10191 0 $12907 1.5707963267948961 $10186 $12908 forward @7 unknown T 25 25 -30 29.999999999999996 30 -25 #
+coedge $-1 -1 -1 $-1 $10187 $12904 $11924 $12909 forward $10189 $-1 #
+edge $-1 -1 -1 $-1 $9443 1.5707963267948966 $10190 3.1415926535897931 $10187 $11984 forward @7 unknown T 25 25 -40 30 30 -35 #
+coedge $-1 -1 -1 $-1 $10188 $12910 $12911 $12912 forward $11480 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10188 $12913 T 22.5 20 -40 30 25 -25 unknown #
+point $-1 -1 -1 $-1 30 25 -35 #
+point $-1 -1 -1 $-1 29.999999999999996 25 -30 #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10226 $10197 $12914 $11531 forward $1587 $-1 #
+coedge $-1 -1 -1 $-1 $12915 $12916 $10197 $11486 reversed $12917 $-1 #
+edge $-1 -1 -1 $-1 $10248 2.617993877991494 $10232 4.7123889803846897 $10197 $12918 forward @7 unknown T -30 5.0000000000000018 50 -22.5 10 50 #
+coedge $-1 -1 -1 $-1 $10198 $12919 $12915 $11552 forward $11488 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10237 $12920 T -22.5 5 35 -15 10 50 unknown #
+coedge $-1 -1 -1 $-1 $11490 $10199 $11510 $11576 reversed $10201 $-1 #
+coedge $-1 -1 -1 $-1 $10200 $11489 $12921 $12922 reversed $10201 $-1 #
+face $-1 -1 -1 $-1 $12923 $10201 $11 $-1 $10247 reversed single T -15 5 35 -7.4999999999999991 10 50 F #
+coedge $-1 -1 -1 $-1 $12924 $11510 $10203 $11493 reversed $10218 $-1 #
+edge $-1 -1 -1 $-1 $10263 1.5707963267948966 $10269 2.0943951023931957 $10203 $10252 forward @7 unknown T -7.5000000000000009 5 35 -5 5.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $10204 $10207 $12925 $12926 forward $10208 $-1 #
+coedge $-1 -1 -1 $-1 $11560 $10205 $12927 $11606 forward $11496 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10205 $10279 T -5 4.9999999999999991 30 5.0000000000000009 10 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $9123 $10208 $11 $-1 $7181 reversed single T 5.0000000000000009 4.9999999999999991 32.5 10 5.669872981077809 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $11626 $12928 T 15 4.9999999999999982 20 22.500000000000004 10 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10211 $12929 $9130 $10281 forward $11499 $-1 #
+coedge $-1 -1 -1 $-1 $10222 $12930 $10212 $11503 forward $11517 $-1 #
+edge $-1 -1 -1 $-1 $12931 1.5707963267948966 $10224 2.0943951023931966 $11502 $12932 forward @7 unknown T 35 4.9999999999999982 20.000000000000004 37.500000000000007 5.669872981077809 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $12933 $11616 $10214 $11505 forward $12006 $-1 #
+edge $-1 -1 -1 $-1 $9151 -2.9403902792268244e-16 $12931 1.5707963267948966 $11504 $12934 forward @7 unknown T 29.999999999999996 4.9999999999999982 20.000000000000004 35 10 25.000000000000007 #
+loop $-1 -1 -1 $-1 $12935 $10215 $1558 T 50 5 30 50 15 40 hole $1559 T #
+vertex $-1 -1 -1 $-1 $10216 $12936 #
+ellipse-curve $-1 -1 -1 $-1 50 10 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $12937 $12938 $10217 T -45 5.0000000000000018 30 -40 15.000000000000002 40 unknown #
+coedge $-1 -1 -1 $-1 $11492 $12939 $11489 $11576 forward $10218 $-1 #
+coedge $-1 -1 -1 $-1 $11564 $11564 $10219 $11512 reversed $10258 $-1 #
+edge $-1 -1 -1 $-1 $11514 1.570796326794897 $11518 4.7123889803846897 $10219 $12940 forward @7 unknown T 39.999999999999993 5 20.000000000000004 44.999999999999993 15 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $10220 $10314 $12008 $12941 reversed $10315 $-1 #
+vertex $-1 -1 -1 $-1 $12941 $12942 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12930 $10222 $12943 $12944 reversed $11517 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11502 $12005 T 35 4.9999999999999982 17.500000000000007 40.000000000000007 5.669872981077809 22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $12944 $12945 #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778081 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $12946 $12947 $10226 $11521 reversed $12948 $-1 #
+edge $-1 -1 -1 $-1 $12949 2.617993877991494 $11525 6.8067840827778854 $10226 $12950 forward @7 unknown T -45 5.0000000000000018 50 -37.5 15.000000000000002 50 #
+coedge $-1 -1 -1 $-1 $12951 $10227 $12947 $12952 forward $11524 $-1 #
+coedge $-1 -1 -1 $-1 $10227 $12953 $12954 $11528 forward $11524 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11523 $12955 T -37.5 10 35 -30 15 50 unknown #
+vertex $-1 -1 -1 $-1 $10228 $12956 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11529 $10229 $12957 $12958 reversed $10231 $-1 #
+edge $-1 -1 -1 $-1 $12959 40 $10232 50 $11523 $12960 forward @7 unknown T -30 10 40 -30 10 50 #
+coedge $-1 -1 -1 $-1 $10230 $11527 $12961 $12962 reversed $10231 $-1 #
+face $-1 -1 -1 $-1 $12963 $10231 $11 $-1 $12964 reversed single T -30 10 35 -22.499999999999993 15.000000000000002 50 F #
+edge $-1 -1 -1 $-1 $10232 0 $12949 2.0943951023931957 $11484 $11526 forward @7 unknown T -37.5 5 50 -30 10 50 #
+point $-1 -1 -1 $-1 -30 10 50 #
+coedge $-1 -1 -1 $-1 $12961 $12965 $10234 $11534 reversed $12966 $-1 #
+edge $-1 -1 -1 $-1 $11535 4.1887902047863923 $12967 4.7123889803846897 $10234 $12968 forward @7 unknown T -22.499999999999993 14.330127018922193 35 -20 15 37.499999999999993 #
+vertex $-1 -1 -1 $-1 $11534 $12969 #
+straight-curve $-1 -1 -1 $-1 -22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $12970 $10240 $10236 $11538 reversed $11543 $-1 #
+edge $-1 -1 -1 $-1 $12967 1.5707963267948966 $10242 3.1415926535897931 $10236 $12971 forward @7 unknown T -20 10 35 -15 15 40 #
+coedge $-1 -1 -1 $-1 $12919 $10237 $12972 $11546 forward $11488 $-1 #
+face $-1 -1 -1 $-1 $12973 $12974 $11 $-1 $10937 reversed single T -37.5 5 35 -30 10 50 F #
+cone-surface $-1 -1 -1 $-1 -20 10 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $10240 $12970 $12975 $12976 forward $11543 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10240 $12977 T -20 10 30 -10 15 40 unknown #
+vertex $-1 -1 -1 $-1 $12976 $12978 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10242 3.1415926535897931 $12979 4.7123889803846897 $11539 $12971 forward @7 unknown T -20 5 35 -15 10 40 #
+point $-1 -1 -1 $-1 -15 10 40 #
+coedge $-1 -1 -1 $-1 $10249 $10244 $12980 $12981 forward $10250 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12982 $12983 $11 $-1 $10247 reversed single T -15 10 4.9999999999999991 -7.4999999999999991 15 20 F #
+loop $-1 -1 -1 $-1 $-1 $12984 $10246 T -15 10 20 -7.4999999999999982 15 35 unknown #
+edge $-1 -1 -1 $-1 $12985 37.5 $10248 50 $11487 $12986 forward @7 unknown T -22.5 5.6698729810778064 37.5 -22.5 5.6698729810778081 50 #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $12987 $11558 $10249 $11555 forward $12988 $-1 #
+edge $-1 -1 -1 $-1 $10251 -1.5707963267948966 $12989 -1.0471975511965974 $11554 $12990 forward @7 unknown T -7.5000000000000009 14.330127018922191 32.5 -5 15 35 #
+face $-1 -1 -1 $-1 $12977 $10250 $11 $-1 $7181 reversed single T -10 14.330127018922191 32.5 -5 15 37.5 F #
+point $-1 -1 -1 $-1 -5 15 35 #
+coedge $-1 -1 -1 $-1 $11554 $12991 $10254 $11559 forward $12988 $-1 #
+edge $-1 -1 -1 $-1 $11567 0 $10251 1.5707963267948966 $11558 $12992 forward @7 unknown T -5 10 30 0 15 35 #
+coedge $-1 -1 -1 $-1 $10256 $11495 $12993 $12994 reversed $11496 $-1 #
+face $-1 -1 -1 $-1 $12995 $12996 $11 $-1 $10259 reversed single T -50 5 14.999999999999996 -40 15.000000000000002 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $12997 $10257 T -10 5 17.5 -5 5.669872981077809 22.500000000000004 unknown #
+loop $-1 -1 -1 $-1 $-1 $12998 $9108 T 50 5 15.000000000000004 50 15 25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $11511 $11511 $12999 $13000 reversed $10258 $-1 #
+coedge $-1 -1 -1 $-1 $13001 $10260 $12991 $13002 reversed $11566 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13001 $13003 T 0 10 20 7.5000000000000027 15 35 unknown #
+vertex $-1 -1 -1 $-1 $11559 $13004 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13005 1.0471975511965974 $10263 1.5707963267948966 $13006 $12990 forward @7 unknown T -7.5000000000000009 5 32.5 -5 5.669872981077809 35 #
+point $-1 -1 -1 $-1 -5 5 35 #
+coedge $-1 -1 -1 $-1 $10264 $13007 $10271 $11579 reversed $11566 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $13008 $10266 T 0 4.9999999999999991 -40 7.5000000000000018 10 -25 unknown #
+coedge $-1 -1 -1 $-1 $13009 $13010 $13011 $13012 reversed $10267 $-1 #
+coedge $-1 -1 -1 $-1 $10687 $10268 $13013 $12061 reversed $9118 $-1 #
+edge $-1 -1 -1 $-1 $13014 1.5707963267948966 $10269 2.0943951023931957 $11510 $13015 forward @7 unknown T -10 5 35 -7.4999999999999991 5.669872981077809 37.5 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 37.5 #
+coedge $-1 -1 -1 $-1 $11582 $10271 $13016 $13017 forward $9129 $-1 #
+edge $-1 -1 -1 $-1 $10272 -32.500000000000007 $13018 -22.499999999999996 $10271 $13019 forward @7 unknown T 7.5 14.330127018922195 22.499999999999996 7.5000000000000027 14.330127018922195 32.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000027 14.330127018922195 32.500000000000007 #
+loop $-1 -1 -1 $-1 $-1 $13020 $10274 T -7.5000000000000009 5 20 8.8817841970012523e-16 10 35 unknown #
+coedge $-1 -1 -1 $-1 $10275 $11578 $13021 $13022 forward $9129 $-1 #
+coedge $-1 -1 -1 $-1 $13021 $13023 $10280 $11584 forward $10722 $-1 #
+edge $-1 -1 -1 $-1 $13024 -1.5707963267948966 $11585 -2.9403902792268244e-16 $11583 $13025 forward @7 unknown T 15 10 20 20 14.999999999999998 25 #
+vertex $-1 -1 -1 $-1 $13026 $13027 #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $13028 $13029 $11 $-1 $6219 reversed single T 14.999999999999996 10 5.0000000000000009 22.500000000000004 15 20 F #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 32.5 #
+coedge $-1 -1 -1 $-1 $10285 $13030 $13031 $13032 forward $9146 $-1 #
+coedge $-1 -1 -1 $-1 $13033 $10295 $10286 $11591 forward $11609 $-1 #
+edge $-1 -1 -1 $-1 $10297 -2.0943951023931939 $13024 -1.5707963267948966 $11590 $13034 forward @7 unknown T 20 14.330127018922193 20 22.499999999999996 14.999999999999998 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $10287 $13035 $10716 $12063 reversed $9138 $-1 #
+coedge $-1 -1 -1 $-1 $13036 $10288 $11605 $13037 reversed $8121 $-1 #
+edge $-1 -1 -1 $-1 $10710 -1.5707963267948966 $11602 -2.9403902792268234e-16 $10707 $13038 forward @7 unknown T 15 10 -40 20 14.999999999999998 -35 #
+coedge $-1 -1 -1 $-1 $10289 $13036 $13039 $13040 reversed $8121 $-1 #
+coedge $-1 -1 -1 $-1 $13041 $13042 $10289 $11597 forward $13043 $-1 #
+edge $-1 -1 -1 $-1 $11603 2.9403902792268224e-16 $13044 1.5707963267948961 $11596 $13045 forward @7 unknown T 15 10 -30 20 14.999999999999998 -25 #
+coedge $-1 -1 -1 $-1 $13046 $10290 $13042 $13047 forward $11601 $-1 #
+coedge $-1 -1 -1 $-1 $10290 $13048 $12057 $13049 forward $11601 $-1 #
+coedge $-1 -1 -1 $-1 $12050 $13050 $12054 $10291 reversed $13051 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10290 $10719 T 7.5 10 -40 15 15 -25 unknown #
+vertex $-1 -1 -1 $-1 $12051 $13052 #
+vertex $-1 -1 -1 $-1 $13047 $13053 #
+coedge $-1 -1 -1 $-1 $10292 $10660 $11593 $13037 forward $10661 $-1 #
+edge $-1 -1 -1 $-1 $10293 -1.5707963267948966 $11567 -6.1232339957367648e-17 $11495 $13054 forward @7 unknown T 0 4.9999999999999991 30 5.0000000000000009 10 35 #
+point $-1 -1 -1 $-1 5.0000000000000009 5 35 #
+coedge $-1 -1 -1 $-1 $10295 $13033 $13055 $13056 reversed $11609 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11590 $13057 T 20 14.330127018922191 17.5 25 15 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $13056 $13058 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.499999999999996 14.330127018922193 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $13030 $10299 $13059 $13026 forward $9146 $-1 #
+coedge $-1 -1 -1 $-1 $10303 $10300 $12068 $13060 reversed $10304 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 10 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $11504 $13061 $10302 $10307 reversed $12006 $-1 #
+coedge $-1 -1 -1 $-1 $13062 $11629 $10303 $11618 reversed $10310 $-1 #
+edge $-1 -1 -1 $-1 $13063 2.9403902792268214e-16 $10305 1.5707963267948966 $10303 $13064 forward @7 unknown T 29.999999999999996 10 15 35 14.999999999999998 20.000000000000004 #
+point $-1 -1 -1 $-1 35 14.999999999999998 20.000000000000004 #
+vertex $-1 -1 -1 $-1 $13065 $13066 #
+face $-1 -1 -1 $-1 $13067 $13068 $11 $-1 $4445 reversed single T 29.999999999999996 10 -24.999999999999996 37.5 14.999999999999998 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $13069 $10309 T 29.999999999999996 10 -9.9999999999999982 37.5 15 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $13070 $13062 $13071 $13072 reversed $10310 $-1 #
+coedge $-1 -1 -1 $-1 $13073 $13074 $10311 $11625 reversed $13075 $-1 #
+edge $-1 -1 -1 $-1 $11620 1.5707963267948961 $11627 2.0943951023931948 $10311 $11611 forward @7 unknown T 22.5 5 19.999999999999996 25 5.6698729810778064 22.5 #
+coedge $-1 -1 -1 $-1 $12929 $10312 $13074 $13076 reversed $11499 $-1 #
+vertex $-1 -1 -1 $-1 $13076 $13077 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11617 $12009 $10314 $11630 reversed $10310 $-1 #
+edge $-1 -1 -1 $-1 $10305 1.5707963267948966 $13078 2.0943951023931939 $10314 $13079 forward @7 unknown T 35 14.330127018922195 17.500000000000011 37.5 14.999999999999998 20.000000000000004 #
+face $-1 -1 -1 $-1 $13080 $10315 $11 $-1 $10259 reversed single T 35 14.330127018922186 17.500000000000011 40.000000000000007 15 22.500000000000014 F #
+coedge $-1 -1 -1 $-1 $13081 $13082 $10318 $11633 forward $13083 $-1 #
+edge $-1 -1 -1 $-1 $11635 -2.0943951023931957 $13084 -1.5707963267948966 $11632 $13085 forward @7 unknown T 35 4.9999999999999982 -27.499999999999996 37.500000000000007 5.6698729810778072 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $13086 $10319 $13082 $13087 forward $10666 $-1 #
+vertex $-1 -1 -1 $-1 $13087 $13088 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $11642 27.499999999999989 $10669 37.5 $10668 $13089 forward @7 unknown T 37.5 14.330127018922193 -37.5 37.5 14.330127018922196 -27.499999999999989 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13090 $10324 $12003 $13091 reversed $11641 $-1 #
+coedge $-1 -1 -1 $-1 $10324 $13090 $13092 $13093 forward $11641 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11640 $13094 T 35 14.330127018922186 -27.499999999999993 40.000000000000007 15 -22.499999999999986 unknown #
+vertex $-1 -1 -1 $-1 $10325 $13095 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10327 $10326 $13096 $13097 reversed $10328 $-1 #
+coedge $-1 -1 -1 $-1 $13092 $13098 $10326 $11646 reversed $13068 $-1 #
+edge $-1 -1 -1 $-1 $10329 -1.5707963267948966 $13099 -2.9403902792268234e-16 $10326 $13100 forward @7 unknown T 29.999999999999996 10 -24.999999999999996 35 14.999999999999998 -19.999999999999996 #
+face $-1 -1 -1 $-1 $13101 $10328 $11 $-1 $13102 reversed single T 25 10 -30 35 15 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 14.999999999999998 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $10333 $10331 $13036 $13103 forward $9169 $-1 #
+coedge $-1 -1 -1 $-1 $13104 $13039 $10331 $11651 reversed $13105 $-1 #
+edge $-1 -1 -1 $-1 $11652 -1.5707963267948966 $13106 -1.047197551196597 $10331 $13107 forward @7 unknown T 22.5 14.330127018922191 -27.500000000000004 25 15 -25 #
+vertex $-1 -1 -1 $-1 $11651 $13108 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13109 4.1887902047863905 $8431 4.7123889803846897 $10333 $10718 forward @7 unknown T 22.499999999999996 14.330127018922191 -40 25 15 -37.5 #
+coedge $-1 -1 -1 $-1 $10335 $10716 $13110 $13111 forward $10336 $-1 #
+coedge $-1 -1 -1 $-1 $13112 $12072 $10335 $11657 reversed $13113 $-1 #
+edge $-1 -1 -1 $-1 $13114 -1.5707963267948961 $9171 0 $10335 $11653 forward @7 unknown T 25 5 -30 29.999999999999996 10 -25 #
+face $-1 -1 -1 $-1 $10705 $10336 $11 $-1 $5329 reversed single T 22.5 5 -40 30 10 -25 F #
+coedge $-1 -1 -1 $-1 $11696 $13115 $10340 $10383 reversed $11716 $-1 #
+coedge $-1 -1 -1 $-1 $13116 $10341 $10343 $10404 reversed $11662 $-1 #
+coedge $-1 -1 -1 $-1 $10341 $13117 $9206 $10380 forward $11662 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11661 $13118 T -30 -9.9999999999999982 35 -22.5 -4.9999999999999991 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10343 $10391 $13119 $13120 forward $10344 $-1 #
+face $-1 -1 -1 $-1 $10408 $10344 $11 $-1 $10393 reversed single T -22.5 -10 35 -15 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $13121 $11714 $10346 $11667 forward $13122 $-1 #
+edge $-1 -1 -1 $-1 $9219 6.1232339957367648e-17 $11753 1.5707963267948966 $11666 $13123 forward @7 unknown T -15 -10 35 -10 -4.9999999999999991 40 #
+face $-1 -1 -1 $-1 $13124 $12080 $11 $-1 $9224 reversed single T -15 -5 -50 -7.4999999999999991 8.8817841970012523e-16 -40 F #
+coedge $-1 -1 -1 $-1 $11683 $10348 $11745 $10421 reversed $9197 $-1 #
+coedge $-1 -1 -1 $-1 $11764 $11672 $10350 $11671 reversed $13125 $-1 #
+edge $-1 -1 -1 $-1 $9258 -2.0943951023931948 $9267 -1.5707963267948966 $10350 $13126 forward @7 unknown T 5 -10 32.5 7.5 -9.3301270189221945 35 #
+coedge $-1 -1 -1 $-1 $11670 $13127 $10351 $10455 reversed $13125 $-1 #
+face $-1 -1 -1 $-1 $6251 $10355 $11 $-1 $5386 reversed single T 15 -10 20 22.500000000000004 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $10357 $10464 $12146 $13128 reversed $10355 $-1 #
+coedge $-1 -1 -1 $-1 $10358 $10368 $12575 $13129 forward $10369 $-1 #
+vertex $-1 -1 -1 $-1 $12576 $13130 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11194 $10360 $11196 $12576 forward $9968 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 50 -5 30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $13131 $9196 T -50 -10 29.999999999999996 -50 0 40 unknown #
+coedge $-1 -1 -1 $-1 $13132 $13132 $13133 $13134 forward $10364 $-1 #
+coedge $-1 -1 -1 $-1 $10365 $11669 $13135 $13136 forward $9197 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11182 $13137 $10368 $11686 forward $8452 $-1 #
+edge $-1 -1 -1 $-1 $13138 1.0471975511965987 $10370 1.570796326794897 $11685 $11205 forward @7 unknown T 37.499999999999993 -10 17.500000000000007 40 -9.3301270189221945 20.000000000000007 #
+point $-1 -1 -1 $-1 40 -10 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $13139 $10372 $13115 $13140 reversed $11690 $-1 #
+coedge $-1 -1 -1 $-1 $10372 $13141 $10374 $11694 reversed $11690 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11689 $13142 T -45 -9.9999999999999964 35 -37.5 2.6645352591003757e-15 50 unknown #
+vertex $-1 -1 -1 $-1 $13140 $13143 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11695 $10374 $13144 $13145 forward $10376 $-1 #
+edge $-1 -1 -1 $-1 $10377 -50 $13146 -37.500000000000007 $10374 $13147 forward @7 unknown T -37.500000000000007 -0.66987298107780657 37.500000000000007 -37.5 -0.66987298107780457 50 #
+coedge $-1 -1 -1 $-1 $10375 $11693 $13148 $13149 forward $10376 $-1 #
+coedge $-1 -1 -1 $-1 $13150 $11659 $11661 $10380 reversed $11716 $-1 #
+face $-1 -1 -1 $-1 $13151 $10376 $11 $-1 $9738 reversed single T -37.500000000000007 -4.9999999999999991 35 -30 0 50 F #
+point $-1 -1 -1 $-1 -37.5 -0.66987298107780457 50 #
+coedge $-1 -1 -1 $-1 $13148 $13152 $10379 $11700 forward $13153 $-1 #
+edge $-1 -1 -1 $-1 $13154 -1.5707963267948966 $11701 2.3886802389739268e-16 $11699 $13155 forward @7 unknown T -30 -4.9999999999999991 35 -25 1.7763568394002505e-15 40 #
+vertex $-1 -1 -1 $-1 $13156 $13157 #
+straight-curve $-1 -1 -1 $-1 -30 -4.9999999999999991 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13158 $10385 $10381 $11704 forward $11708 $-1 #
+edge $-1 -1 -1 $-1 $10387 -2.0943951023931957 $13154 -1.5707963267948966 $11703 $13159 forward @7 unknown T -25 -0.66987298107780724 35 -22.5 1.7763568394002505e-15 37.500000000000007 #
+face $-1 -1 -1 $-1 $13160 $13161 $11 $-1 $11706 reversed single T -30 -5 -50 -22.5 1.7763568394002505e-15 -40 F #
+cone-surface $-1 -1 -1 $-1 -25 -4.9999999999999982 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $10385 $13158 $13162 $13163 reversed $11708 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11703 $13164 T -25 -0.66987298107780902 32.5 -20 1.7763568394002505e-15 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $13163 $13165 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 -0.66987298107780657 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $10394 $10389 $13166 $13167 reversed $10395 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11666 $13168 $10391 $10398 reversed $13122 $-1 #
+face $-1 -1 -1 $-1 $13169 $13170 $11 $-1 $10393 reversed single T -22.500000000000004 -5 20 -15 0 35 F #
+loop $-1 -1 -1 $-1 $-1 $11696 $10392 T -37.5 -10 35 -30 -4.9999999999999991 50 unknown #
+coedge $-1 -1 -1 $-1 $13171 $11722 $10394 $11718 reversed $10403 $-1 #
+edge $-1 -1 -1 $-1 $13172 -2.3886802389739268e-16 $10396 1.5707963267948966 $10394 $13173 forward @7 unknown T -15 -5 30 -10 8.8817841970012523e-16 35 #
+face $-1 -1 -1 $-1 $13174 $10395 $11 $-1 $6317 reversed single T -20 -5 30 -10 8.8817841970012523e-16 40 F #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 35 #
+vertex $-1 -1 -1 $-1 $13175 $13176 #
+coedge $-1 -1 -1 $-1 $11717 $13177 $10400 $11723 reversed $10403 $-1 #
+edge $-1 -1 -1 $-1 $10396 1.5707963267948966 $11731 2.0943951023931957 $10400 $13178 forward @7 unknown T -10 -0.66987298107780813 32.5 -7.4999999999999991 8.8817841970012523e-16 35 #
+face $-1 -1 -1 $-1 $13179 $13180 $11 $-1 $9224 reversed single T -15 -5 -10 -7.4999999999999982 1.7763568394002505e-15 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $13181 $10402 T -15 -5 4.9999999999999991 -7.4999999999999991 1.7763568394002505e-15 20 unknown #
+coedge $-1 -1 -1 $-1 $13182 $13171 $13183 $13184 reversed $10403 $-1 #
+vertex $-1 -1 -1 $-1 $13185 $13186 #
+straight-curve $-1 -1 -1 $-1 -22.5 -9.3301270189221928 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13187 $10406 $13177 $13188 forward $11730 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11733 $11737 T -7.5000000000000009 -5 20 0 0 35 unknown #
+vertex $-1 -1 -1 $-1 $13188 $13189 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10410 $13190 $11759 $11742 forward $11730 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11759 $11745 $10412 $11736 forward $10433 $-1 #
+edge $-1 -1 -1 $-1 $9239 -1.5707963267948966 $10419 0 $11735 $11734 forward @7 unknown T -5 -10 30 0 -5 35 #
+face $-1 -1 -1 $-1 $13191 $11730 $11 $-1 $7251 reversed single T -7.5000000000000009 -5 20 0 0 35 F #
+loop $-1 -1 -1 $-1 $13192 $13193 $10413 T -45 -9.9999999999999964 14.999999999999996 -40 2.6645352591003757e-15 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $13194 $13195 $13196 $13197 forward $10414 $-1 #
+edge $-1 -1 -1 $-1 $10370 -1.570796326794897 $9960 1.570796326794897 $11182 $13198 forward @7 unknown T 40 -10 15.000000000000004 45.000000000000007 0 20.000000000000007 #
+coedge $-1 -1 -1 $-1 $11746 $10417 $13199 $13200 reversed $10418 $-1 #
+edge $-1 -1 -1 $-1 $13201 25 $10419 30 $11733 $13202 forward @7 unknown T 0 -5 25 0 -4.9999999999999991 30 #
+point $-1 -1 -1 $-1 0 -5 30 #
+vertex $-1 -1 -1 $-1 $10421 $13203 #
+coedge $-1 -1 -1 $-1 $11735 $13204 $11669 $10421 forward $10433 $-1 #
+coedge $-1 -1 -1 $-1 $10423 $11741 $13205 $13206 reversed $10418 $-1 #
+coedge $-1 -1 -1 $-1 $12119 $13207 $10772 $12129 reversed $10425 $-1 #
+coedge $-1 -1 -1 $-1 $13208 $10426 $12123 $13209 reversed $9243 $-1 #
+coedge $-1 -1 -1 $-1 $10426 $13210 $13211 $13212 reversed $9243 $-1 #
+coedge $-1 -1 -1 $-1 $13213 $13214 $13215 $11751 forward $13216 $-1 #
+edge $-1 -1 -1 $-1 $13217 -35 $13218 -30 $11750 $13219 forward @7 unknown T 0 -5 -35 0 -4.9999999999999991 -30 #
+coedge $-1 -1 -1 $-1 $10732 $13220 $10427 $10791 forward $12084 $-1 #
+vertex $-1 -1 -1 $-1 $13221 $13222 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13205 $13223 $10430 $11756 reversed $13224 $-1 #
+edge $-1 -1 -1 $-1 $11757 4.1887902047863914 $13225 4.7123889803846897 $10430 $13226 forward @7 unknown T 7.5000000000000009 -0.66987298107780635 20 10 0 22.499999999999996 #
+vertex $-1 -1 -1 $-1 $11756 $13227 #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $13228 $11735 $13127 $11742 reversed $10433 $-1 #
+edge $-1 -1 -1 $-1 $13225 1.5707963267948966 $10435 3.1415926535897931 $10434 $13229 forward @7 unknown T 10 -4.9999999999999991 20 15 0 25 #
+edge $-1 -1 -1 $-1 $10435 3.1415926535897931 $13230 4.7123889803846897 $10461 $13229 forward @7 unknown T 10 -10 20 15 -4.9999999999999991 25 #
+point $-1 -1 -1 $-1 15 -4.9999999999999991 25 #
+coedge $-1 -1 -1 $-1 $10438 $10461 $13231 $13232 forward $8237 $-1 #
+coedge $-1 -1 -1 $-1 $13233 $11670 $10438 $11765 reversed $13125 $-1 #
+edge $-1 -1 -1 $-1 $13234 22.500000000000004 $9258 32.500000000000007 $10438 $13235 forward @7 unknown T 7.5 -9.3301270189221945 22.500000000000004 7.5000000000000018 -9.3301270189221945 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $10457 $10439 $13236 $13237 forward $10458 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10441 $12140 $13238 $13239 reversed $8229 $-1 #
+coedge $-1 -1 -1 $-1 $10444 $10442 $10480 $11806 reversed $7259 $-1 #
+edge $-1 -1 -1 $-1 $11812 -2.0943951023931948 $9573 -1.5707963267948966 $10454 $13240 forward @7 unknown T 20 -0.66987298107780902 -40 22.500000000000004 -8.8817841970012523e-16 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10481 $13241 $10444 $11773 forward $11808 $-1 #
+edge $-1 -1 -1 $-1 $11777 1.570796326794897 $11809 2.0943951023931957 $11772 $13242 forward @7 unknown T 20 -0.6698729810778099 -27.500000000000004 22.5 -8.8817841970012523e-16 -25 #
+coedge $-1 -1 -1 $-1 $13243 $10445 $12404 $13244 forward $11776 $-1 #
+coedge $-1 -1 -1 $-1 $10445 $13243 $10447 $11780 reversed $11776 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10445 $13245 T 10 -5 -30 20.000000000000004 0 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $10446 $13246 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13247 $10447 $13248 $13249 forward $10450 $-1 #
+edge $-1 -1 -1 $-1 $10452 0 $13250 1.5707963267948966 $10447 $13251 forward @7 unknown T 10 -5 -30 15 0 -25 #
+coedge $-1 -1 -1 $-1 $10448 $13247 $12083 $13252 forward $10450 $-1 #
+edge $-1 -1 -1 $-1 $9575 1.5707963267948966 $10451 3.1415926535897931 $10448 $12136 forward @7 unknown T 10 -4.9999999999999991 -40 15 0 -35 #
+coedge $-1 -1 -1 $-1 $10449 $13253 $13254 $13255 forward $11784 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10449 $13256 T 7.4999999999999991 -10 -40 15 -4.9999999999999991 -25 unknown #
+point $-1 -1 -1 $-1 15 -4.9999999999999991 -35 #
+point $-1 -1 -1 $-1 15 -5 -30 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13257 $10458 $11 $-1 $8848 reversed single T 20 -0.66987298107780902 17.499999999999996 25 0 22.500000000000004 F #
+coedge $-1 -1 -1 $-1 $12146 $13258 $10461 $11761 reversed $10797 $-1 #
+coedge $-1 -1 -1 $-1 $13259 $10462 $11193 $9969 reversed $11792 $-1 #
+coedge $-1 -1 -1 $-1 $10462 $13259 $10464 $11793 forward $11792 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11791 $10796 T 20 -10 17.5 25 -9.3301270189221928 22.499999999999996 unknown #
+edge $-1 -1 -1 $-1 $13260 1.5707963267948966 $10465 2.0943951023931948 $11791 $13261 forward @7 unknown T 20 -10 20 22.5 -9.3301270189221928 22.499999999999996 #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221928 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $10467 $11136 $10469 $11798 reversed $11137 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10739 $10469 $13262 $13263 forward $9531 $-1 #
+edge $-1 -1 -1 $-1 $10470 1.0471975511965996 $13264 1.570796326794897 $10469 $13265 forward @7 unknown T 37.5 -10 -27.499999999999989 40 -9.3301270189221963 -24.999999999999993 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221963 -27.499999999999986 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $13266 -1.570796326794897 $10476 -1.0471975511965987 $10739 $13265 forward @7 unknown T 37.5 -0.66987298107780613 -27.499999999999993 40 0 -24.999999999999993 #
+face $-1 -1 -1 $-1 $12555 $10475 $11 $-1 $11805 reversed single T 35 -0.66987298107781124 -27.499999999999993 40.000000000000007 0 -22.499999999999993 F #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780613 -27.499999999999993 #
+face $-1 -1 -1 $-1 $12520 $11816 $11 $-1 $11805 reversed single T 25 -10.000000000000002 -30 35 -4.9999999999999991 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 -5 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $11809 27.500000000000004 $11812 37.500000000000007 $10480 $13267 forward @7 unknown T 22.5 -0.66987298107780902 -37.500000000000007 22.500000000000004 -0.66987298107780635 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $13241 $10481 $12530 $13268 reversed $11808 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13241 $13269 T 19.999999999999996 -0.6698729810778099 -27.500000000000004 25 0 -22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $11773 $13270 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+point $-1 -1 -1 $-1 25 0 -25 #
+vertex $-1 -1 -1 $-1 $10485 $13271 #
+coedge $-1 -1 -1 $-1 $13238 $13272 $10486 $11814 reversed $13273 $-1 #
+edge $-1 -1 -1 $-1 $12142 1.0471975511965974 $11817 1.5707963267948966 $10486 $11810 forward @7 unknown T 22.5 -10 -27.500000000000004 25 -9.330127018922191 -25 #
+coedge $-1 -1 -1 $-1 $11131 $10487 $12531 $11154 reversed $11816 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10798 $11804 T 25 -10.000000000000002 -30 35 -4.9999999999999991 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $11814 $13274 #
+coedge $-1 -1 -1 $-1 $11819 $10490 $10914 $11835 reversed $10492 $-1 #
+coedge $-1 -1 -1 $-1 $10491 $11818 $13275 $13276 reversed $10492 $-1 #
+face $-1 -1 -1 $-1 $9311 $10492 $11 $-1 $7628 reversed single T -30 -25 35 -22.5 -20 50 F #
+coedge $-1 -1 -1 $-1 $10887 $10499 $10495 $11822 reversed $11824 $-1 #
+edge $-1 -1 -1 $-1 $9692 1.5707963267948966 $10501 3.1415926535897931 $10495 $13277 forward @7 unknown T -35 -20 35 -30 -15 40 #
+coedge $-1 -1 -1 $-1 $10499 $10887 $10965 $12343 forward $11824 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10499 $11833 T -35 -20 30 -25 -15 40 unknown #
+vertex $-1 -1 -1 $-1 $12343 $13278 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10501 3.1415926535897931 $9680 4.7123889803846897 $10868 $13277 forward @7 unknown T -35 -25 35 -30 -20 40 #
+point $-1 -1 -1 $-1 -30 -20 40 #
+coedge $-1 -1 -1 $-1 $10506 $10503 $12338 $13279 forward $10507 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13280 $12439 $11 $-1 $7628 reversed single T -30.000000000000007 -20 -40 -22.499999999999993 -15 -25 F #
+face $-1 -1 -1 $-1 $9678 $10507 $11 $-1 $1965 reversed single T -25 -15.669872981077809 32.5 -20 -15 37.5 F #
+face $-1 -1 -1 $-1 $13281 $11824 $11 $-1 $1965 reversed single T -35 -20 30 -25 -15 40 F #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13282 1.5707963267948966 $10514 2.0943951023931957 $10914 $13283 forward @7 unknown T -25 -25 35 -22.5 -24.330127018922191 37.500000000000007 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 37.500000000000007 #
+edge $-1 -1 -1 $-1 $10839 -1.5707963267948966 $11843 6.1232339957367648e-17 $10836 $13284 forward @7 unknown T -8.8817841970012523e-16 -20 -40 4.9999999999999991 -15 -35 #
+edge $-1 -1 -1 $-1 $11844 -6.1232339957367648e-17 $10987 1.5707963267948966 $10986 $13285 forward @7 unknown T -8.8817841970012523e-16 -20 -30 4.9999999999999991 -15 -25 #
+coedge $-1 -1 -1 $-1 $13286 $10520 $12372 $13287 forward $11842 $-1 #
+coedge $-1 -1 -1 $-1 $10520 $13288 $12189 $13289 forward $11842 $-1 #
+coedge $-1 -1 -1 $-1 $11075 $13290 $12187 $10521 reversed $11076 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10520 $10847 T -7.5000000000000036 -20 -40 0 -15 -25 unknown #
+vertex $-1 -1 -1 $-1 $12183 $13291 #
+vertex $-1 -1 -1 $-1 $13287 $13292 #
+straight-curve $-1 -1 -1 $-1 -8.8817841970012523e-16 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10522 $10804 $11019 $12393 forward $10805 $-1 #
+coedge $-1 -1 -1 $-1 $13293 $10524 $13294 $11878 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $12667 $11874 $10524 $11849 reversed $11282 $-1 #
+edge $-1 -1 -1 $-1 $10559 -0.52359877559829893 $10544 1.5707963267948966 $10524 $13295 forward @7 unknown T 8.8817841970012523e-16 40 -50 7.5000000000000027 45 -50 #
+coedge $-1 -1 -1 $-1 $10525 $13296 $12667 $11898 forward $10568 $-1 #
+coedge $-1 -1 -1 $-1 $13297 $12691 $10527 $11852 reversed $13298 $-1 #
+edge $-1 -1 -1 $-1 $10578 -1.5707963267948966 $10581 -1.0471975511965965 $10527 $10563 forward @7 unknown T 22.499999999999993 44.330127018922184 -42.500000000000007 25 45 -40 #
+coedge $-1 -1 -1 $-1 $10528 $10528 $13299 $13300 reversed $11854 $-1 #
+loop $-1 -1 -1 $-1 $13301 $10528 $13302 T 40 35 -45 45 45 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12718 $13299 $10530 $11857 forward $13303 $-1 #
+edge $-1 -1 -1 $-1 $10531 1.5707963267948966 $11915 2.0943951023931939 $11856 $13304 forward @7 unknown T 37.500000000000007 35 -40 40 35.669872981077809 -37.500000000000007 #
+point $-1 -1 -1 $-1 40 35 -40 #
+coedge $-1 -1 -1 $-1 $13299 $13305 $10533 $11860 forward $13303 $-1 #
+edge $-1 -1 -1 $-1 $13306 4.1887902047863905 $10535 4.7123889803846897 $11859 $13304 forward @7 unknown T 37.5 44.330127018922191 -40 40 45 -37.5 #
+face $-1 -1 -1 $-1 $10580 $10534 $11 $-1 $11911 reversed single T 35 44.330127018922191 -42.5 40 45 -37.5 F #
+point $-1 -1 -1 $-1 40 45 -40 #
+face $-1 -1 -1 $-1 $13307 $12703 $11 $-1 $12658 reversed single T 25 40 15 35 45 25.000000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $13308 $10537 T 37.499999999999993 35 5.0000000000000027 45.000000000000007 45 20.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $10538 $13309 $13310 $13311 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $13312 $13313 $10538 $11867 reversed $13314 $-1 #
+edge $-1 -1 -1 $-1 $13315 1.5707963267948966 $11871 3.6651914291880923 $10538 $13316 forward @7 unknown T -15 35 -50 -7.4999999999999982 40 -50 #
+coedge $-1 -1 -1 $-1 $13317 $10539 $13313 $13318 forward $11870 $-1 #
+coedge $-1 -1 -1 $-1 $10539 $13319 $10541 $11875 reversed $11870 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11869 $13320 T -7.5000000000000107 35 -50 8.8817841970012523e-16 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $10540 $13321 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11876 $10541 $13322 $13323 reversed $10543 $-1 #
+coedge $-1 -1 -1 $-1 $11848 $13324 $13325 $11875 reversed $11282 $-1 #
+edge $-1 -1 -1 $-1 $10544 -50 $13326 -45 $13325 $13327 forward @7 unknown T 0 40 -50 8.8817841970012523e-16 40 -45 #
+coedge $-1 -1 -1 $-1 $10542 $11873 $13328 $13329 reversed $10543 $-1 #
+face $-1 -1 -1 $-1 $7934 $10543 $11 $-1 $10029 reversed single T 0 35 -50 7.5000000000000027 40 -40 F #
+edge $-1 -1 -1 $-1 $10544 0 $13330 2.0943951023931957 $11847 $11872 forward @7 unknown T -7.5000000000000009 40 -50 8.8817841970012523e-16 45 -50 #
+point $-1 -1 -1 $-1 8.8817841970012523e-16 40 -50 #
+coedge $-1 -1 -1 $-1 $13328 $13331 $10546 $11881 reversed $13332 $-1 #
+edge $-1 -1 -1 $-1 $11882 1.0471975511965974 $13333 1.5707963267948966 $10546 $13334 forward @7 unknown T 7.4999999999999991 35 -42.5 10 35.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $11881 $13335 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13336 $10551 $10548 $11885 reversed $11888 $-1 #
+edge $-1 -1 -1 $-1 $13333 -1.5707963267948966 $10555 0 $10548 $13337 forward @7 unknown T 10 35 -45 15 40 -40 #
+face $-1 -1 -1 $-1 $13338 $13339 $11 $-1 $10041 reversed single T -7.5000000000000009 40 -50 8.8817841970012523e-16 45 -40 F #
+coedge $-1 -1 -1 $-1 $10551 $13336 $13340 $13341 forward $11888 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10551 $13342 T 10 35 -45 20.000000000000004 40 -35 unknown #
+vertex $-1 -1 -1 $-1 $10552 $13343 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13344 $13345 $10553 $11892 forward $13346 $-1 #
+edge $-1 -1 -1 $-1 $10555 -6.1232339957367648e-17 $13347 1.5707963267948966 $11891 $13348 forward @7 unknown T 15 40 -45 20.000000000000004 45 -40 #
+coedge $-1 -1 -1 $-1 $13296 $10554 $13345 $11894 forward $10568 $-1 #
+edge $-1 -1 -1 $-1 $10555 0 $13349 1.5707963267948966 $11893 $13337 forward @7 unknown T 10 40 -45 15 45 -40 #
+point $-1 -1 -1 $-1 15 40 -45 #
+coedge $-1 -1 -1 $-1 $10560 $10557 $12686 $13350 forward $10561 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13351 42.5 $10559 50 $11850 $13352 forward @7 unknown T 7.5 44.330127018922191 -50 7.5000000000000018 44.330127018922191 -42.5 #
+point $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $13353 $11904 $10560 $11901 forward $12735 $-1 #
+edge $-1 -1 -1 $-1 $10562 1.5707963267948966 $13354 2.0943951023931939 $11900 $13355 forward @7 unknown T 22.500000000000007 35 -40 25 35.669872981077802 -37.5 #
+face $-1 -1 -1 $-1 $13356 $10561 $11 $-1 $11911 reversed single T 20.000000000000004 35 -42.5 25 35.669872981077809 -37.5 F #
+point $-1 -1 -1 $-1 25 35 -40 #
+coedge $-1 -1 -1 $-1 $11900 $11332 $10565 $11905 forward $12735 $-1 #
+edge $-1 -1 -1 $-1 $11334 3.1415926535897931 $10562 4.7123889803846897 $11904 $13357 forward @7 unknown T 25 35 -40 30 40 -35 #
+face $-1 -1 -1 $-1 $13358 $13359 $11 $-1 $12658 reversed single T 10 40 15 20.000000000000004 45 25 F #
+loop $-1 -1 -1 $-1 $-1 $13360 $10567 T 22.5 40 5.0000000000000018 30 45 20 unknown #
+coedge $-1 -1 -1 $-1 $13361 $10569 $8959 $10076 forward $8958 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11861 $10575 $11 $-1 $11911 reversed single T 25 40 -45 35 45 -35 F #
+cone-surface $-1 -1 -1 $-1 2.4492935982947061e-15 40 -40 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $10574 $10573 $11331 $12733 reversed $10575 $-1 #
+point $-1 -1 -1 $-1 35 45 -40 #
+point $-1 -1 -1 $-1 25 45 -40 #
+vertex $-1 -1 -1 $-1 $12719 $13362 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13363 $11333 $11 $-1 $7024 reversed single T 22.5 40 -40 30 45 -25 F #
+edge $-1 -1 -1 $-1 $13347 1.5707963267948966 $10581 2.0943951023931953 $12691 $13364 forward @7 unknown T 20.000000000000004 44.330127018922184 -42.5 22.500000000000004 45 -40 #
+point $-1 -1 -1 $-1 22.5 44.330127018922184 -42.5 #
+coedge $-1 -1 -1 $-1 $13365 $10583 $13366 $13367 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $11952 $13368 $10583 $10614 reversed $11966 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10586 $10629 $13369 $13370 forward $9433 $-1 #
+coedge $-1 -1 -1 $-1 $12860 $10587 $11477 $12909 reversed $11925 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11436 $13371 T 20 29.330127018922191 -42.5 25 30 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $10592 $10595 $10589 $11927 forward $11930 $-1 #
+edge $-1 -1 -1 $-1 $9400 1.5707963267948966 $9396 4.7123889803846897 $11926 $13372 forward @7 unknown T 40 20 -40 45 30 -35 #
+loop $-1 -1 -1 $-1 $-1 $13373 $11929 T 50 20 -45 50 30 -35 unknown #
+face $-1 -1 -1 $-1 $13374 $10590 $11 $-1 $10647 reversed single T 40 20 -45 50 30 -35 F #
+loop $-1 -1 -1 $-1 $-1 $11463 $13375 T 37.5 20 -40 45.000000000000007 30 -24.999999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 25 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10595 $13376 $11465 $12892 forward $11930 $-1 #
+vertex $-1 -1 -1 $-1 $10596 $13377 #
+face $-1 -1 -1 $-1 $13378 $13379 $11 $-1 $11403 reversed single T 25 19.999999999999996 15 35 25 25.000000000000007 F #
+coedge $-1 -1 -1 $-1 $13380 $13381 $13382 $13383 forward $10600 $-1 #
+coedge $-1 -1 -1 $-1 $10601 $13384 $13385 $13386 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $13387 $13388 $10601 $11938 reversed $13389 $-1 #
+edge $-1 -1 -1 $-1 $13390 -2.0943951023931948 $11942 0 $10601 $13391 forward @7 unknown T -22.5 20 -50 -15 25 -50 #
+coedge $-1 -1 -1 $-1 $13392 $10602 $13393 $13394 forward $11941 $-1 #
+coedge $-1 -1 -1 $-1 $10602 $13395 $10604 $11945 reversed $11941 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11940 $13396 T -15 20 -50 -7.4999999999999964 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $13397 $13398 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11946 $10604 $13399 $13400 forward $10606 $-1 #
+edge $-1 -1 -1 $-1 $10607 -50 $13401 -42.5 $10604 $13402 forward @7 unknown T -7.4999999999999991 20.669872981077802 -50 -7.4999999999999964 20.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $10605 $11944 $13403 $13404 forward $10606 $-1 #
+face $-1 -1 -1 $-1 $13405 $10606 $11 $-1 $9021 reversed single T -7.4999999999999991 20 -50 8.8817841970012523e-16 25 -40 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $13403 $13406 $10609 $11950 forward $13407 $-1 #
+edge $-1 -1 -1 $-1 $13408 -1.5707963267948966 $11953 -6.1232339957367648e-17 $11949 $13409 forward @7 unknown T 0 20 -45 5.0000000000000018 25 -40 #
+coedge $-1 -1 -1 $-1 $10610 $12830 $13410 $13411 reversed $10138 $-1 #
+coedge $-1 -1 -1 $-1 $13412 $11921 $10605 $10611 forward $11966 $-1 #
+vertex $-1 -1 -1 $-1 $13413 $13414 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13415 $10616 $10612 $11956 forward $11959 $-1 #
+edge $-1 -1 -1 $-1 $10618 -2.0943951023931948 $13408 -1.5707963267948966 $11955 $13416 forward @7 unknown T 5.0000000000000018 20 -42.5 7.5 20.669872981077805 -40 #
+vertex $-1 -1 -1 $-1 $13417 $13418 #
+coedge $-1 -1 -1 $-1 $10616 $13415 $13419 $13420 reversed $11959 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11955 $13421 T 5.0000000000000018 20 -42.5 10 20.669872981077813 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $10617 $13422 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5 20.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $10623 $10620 $13423 $13424 reversed $10624 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13425 $13426 $11 $-1 $7093 reversed single T 7.4999999999999956 25 5.0000000000000009 15 30 20 F #
+loop $-1 -1 -1 $-1 $-1 $11952 $10622 T -7.5000000000000009 25 -50 8.8817841970012523e-16 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $13427 $11431 $10623 $11968 reversed $10158 $-1 #
+edge $-1 -1 -1 $-1 $12857 6.1232339957367648e-17 $10625 1.5707963267948966 $10623 $13428 forward @7 unknown T 15 20 -40 20 25 -35 #
+face $-1 -1 -1 $-1 $13429 $10624 $11 $-1 $10647 reversed single T 10 20 -45 20 25 -35 F #
+point $-1 -1 -1 $-1 20 20 -40 #
+coedge $-1 -1 -1 $-1 $13430 $10627 $11432 $12849 forward $11973 $-1 #
+coedge $-1 -1 -1 $-1 $10627 $13430 $10629 $10630 reversed $11973 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10627 $13429 T 10 25 -45 20 30 -35 unknown #
+vertex $-1 -1 -1 $-1 $10628 $13431 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13370 $13432 #
+edge $-1 -1 -1 $-1 $10625 1.5707963267948966 $11981 2.0943951023931948 $10632 $13433 forward @7 unknown T 20 20 -40 22.5 20.669872981077805 -37.5 #
+vertex $-1 -1 -1 $-1 $13434 $13435 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $12910 $10636 $12847 $13436 forward $11480 $-1 #
+vertex $-1 -1 -1 $-1 $13436 $13437 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13438 $12856 $11 $-1 $7093 reversed single T 7.5 25 -40 15 30 -25 F #
+ellipse-curve $-1 -1 -1 $-1 25 25 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13439 $13440 $11 $-1 $11403 reversed single T 10 20 15 20 25 25 F #
+loop $-1 -1 -1 $-1 $-1 $12838 $10642 T 10 25 15 20 30 25 unknown #
+coedge $-1 -1 -1 $-1 $13441 $13442 $13443 $13444 forward $10643 $-1 #
+coedge $-1 -1 -1 $-1 $11462 $10644 $13445 $13446 reversed $8050 $-1 #
+point $-1 -1 -1 $-1 37.5 20.669872981077805 -37.5 #
+face $-1 -1 -1 $-1 $13447 $13448 $11 $-1 $13449 reversed single T 25 25 1.7763568394002505e-15 35 30 10.000000000000002 F #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13450 $10656 $13451 $12024 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $13452 $12020 $10656 $11994 reversed $13453 $-1 #
+edge $-1 -1 -1 $-1 $10693 -0.5235987755982987 $10678 1.5707963267948966 $10656 $13454 forward @7 unknown T -15 10 -50 -7.5 15 -50 #
+coedge $-1 -1 -1 $-1 $10657 $13455 $13452 $12044 forward $10702 $-1 #
+coedge $-1 -1 -1 $-1 $13456 $13013 $10659 $11997 reversed $13457 $-1 #
+edge $-1 -1 -1 $-1 $10712 -1.5707963267948966 $10714 -1.047197551196597 $10659 $10697 forward @7 unknown T 7.4999999999999964 14.330127018922191 -42.500000000000014 10 15 -40 #
+face $-1 -1 -1 $-1 $9503 $10661 $11 $-1 $9512 reversed single T 20 14.330127018922189 -42.500000000000007 25 15 -37.5 F #
+ellipse-curve $-1 -1 -1 $-1 40 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12000 $12000 $13458 $13459 reversed $10664 $-1 #
+face $-1 -1 -1 $-1 $13460 $13461 $11 $-1 $9512 reversed single T -10 5 -42.500000000000007 -5 5.6698729810778099 -37.5 F #
+face $-1 -1 -1 $-1 $8424 $10666 $11 $-1 $5306 reversed single T 37.5 5 -40 45.000000000000007 15 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $10668 $13086 $11639 $13091 forward $10666 $-1 #
+point $-1 -1 -1 $-1 37.5 14.330127018922193 -37.5 #
+face $-1 -1 -1 $-1 $11631 $11517 $11 $-1 $10259 reversed single T 35 4.9999999999999982 17.500000000000007 40.000000000000007 5.669872981077809 22.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $11504 $10670 T 25 4.9999999999999982 15 35 10 25.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $13462 $10671 $13463 $13464 forward $9465 $-1 #
+coedge $-1 -1 -1 $-1 $10671 $12999 $11513 $12941 forward $9465 $-1 #
+coedge $-1 -1 -1 $-1 $11629 $13070 $10671 $12010 reversed $10310 $-1 #
+edge $-1 -1 -1 $-1 $13078 -17.500000000000011 $13465 -7.5000000000000107 $10671 $13466 forward @7 unknown T 37.5 14.330127018922191 7.5000000000000107 37.500000000000007 14.330127018922195 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $10672 $13467 $13468 $13469 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $13470 $13471 $10672 $12013 reversed $13472 $-1 #
+edge $-1 -1 -1 $-1 $13473 1.570796326794897 $12017 3.6651914291880923 $10672 $13474 forward @7 unknown T -30 5.0000000000000018 -50 -22.5 10 -50 #
+coedge $-1 -1 -1 $-1 $13475 $10673 $13471 $13476 forward $12016 $-1 #
+coedge $-1 -1 -1 $-1 $10673 $13477 $10675 $12021 reversed $12016 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12015 $13478 T -22.5 5 -50 -15 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $10674 $13479 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12022 $10675 $13480 $13481 reversed $10677 $-1 #
+coedge $-1 -1 -1 $-1 $11993 $13482 $13483 $12021 reversed $13453 $-1 #
+edge $-1 -1 -1 $-1 $10678 -50 $13484 -45 $13483 $13485 forward @7 unknown T -15 10 -50 -15 10 -45 #
+coedge $-1 -1 -1 $-1 $10676 $12019 $13486 $13487 reversed $10677 $-1 #
+face $-1 -1 -1 $-1 $12920 $10677 $11 $-1 $10247 reversed single T -15 5 -50 -7.4999999999999991 10 -40 F #
+edge $-1 -1 -1 $-1 $10678 0 $13488 2.0943951023931948 $11992 $12018 forward @7 unknown T -22.5 10 -50 -15 15 -50 #
+point $-1 -1 -1 $-1 -15 10 -50 #
+coedge $-1 -1 -1 $-1 $13486 $13489 $10680 $12027 reversed $13461 $-1 #
+edge $-1 -1 -1 $-1 $12028 1.047197551196597 $13490 1.5707963267948966 $10680 $13491 forward @7 unknown T -7.5000000000000036 5 -42.500000000000007 -5 5.6698729810778099 -40 #
+vertex $-1 -1 -1 $-1 $12027 $13492 #
+straight-curve $-1 -1 -1 $-1 -7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13493 $10685 $10682 $12031 reversed $12034 $-1 #
+edge $-1 -1 -1 $-1 $13490 -1.5707963267948966 $10689 0 $10682 $13494 forward @7 unknown T -5 5 -45 0 10 -40 #
+face $-1 -1 -1 $-1 $13495 $13496 $11 $-1 $13497 reversed single T -10 14.330127018922191 -12.5 -5 15 -7.4999999999999991 F #
+coedge $-1 -1 -1 $-1 $10685 $13493 $13498 $13499 forward $12034 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10685 $13500 T -5 4.9999999999999991 -45 5.0000000000000009 10 -35 unknown #
+vertex $-1 -1 -1 $-1 $10686 $13501 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13502 $13503 $10687 $12038 forward $13504 $-1 #
+edge $-1 -1 -1 $-1 $10689 -6.1232339957367648e-17 $13505 1.5707963267948966 $12037 $13506 forward @7 unknown T 0 10 -45 5.0000000000000009 15 -40 #
+coedge $-1 -1 -1 $-1 $13455 $10688 $13503 $12040 forward $10702 $-1 #
+edge $-1 -1 -1 $-1 $10689 0 $13507 1.5707963267948966 $12039 $13494 forward @7 unknown T -5 10 -45 0 15 -40 #
+point $-1 -1 -1 $-1 0 10 -45 #
+coedge $-1 -1 -1 $-1 $10694 $10691 $13008 $13508 forward $10695 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13509 42.5 $10693 50 $11995 $13510 forward @7 unknown T -7.5 14.330127018922193 -50 -7.5 14.330127018922195 -42.5 #
+point $-1 -1 -1 $-1 -7.5 14.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $13511 $12050 $10694 $12047 forward $13051 $-1 #
+edge $-1 -1 -1 $-1 $10696 1.5707963267948966 $13512 2.0943951023931948 $12046 $13513 forward @7 unknown T 7.5000000000000018 5 -40 10 5.6698729810778072 -37.5 #
+face $-1 -1 -1 $-1 $13514 $10695 $11 $-1 $9512 reversed single T 5.0000000000000009 4.9999999999999991 -42.5 10 5.6698729810778081 -37.5 F #
+point $-1 -1 -1 $-1 10 5 -40 #
+coedge $-1 -1 -1 $-1 $12046 $11600 $10699 $12051 forward $13051 $-1 #
+edge $-1 -1 -1 $-1 $11602 3.1415926535897931 $10696 4.7123889803846897 $12050 $13515 forward @7 unknown T 10 5 -40 15 10 -35 #
+face $-1 -1 -1 $-1 $13516 $13517 $11 $-1 $10259 reversed single T -5 10 15 5.0000000000000009 15 25 F #
+loop $-1 -1 -1 $-1 $-1 $13518 $10701 T 7.5 10 5.0000000000000009 15 15 20 unknown #
+coedge $-1 -1 -1 $-1 $13519 $10703 $9139 $10291 forward $9138 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11998 $10709 $11 $-1 $9512 reversed single T 10 10 -45 20 15 -35 F #
+coedge $-1 -1 -1 $-1 $10708 $10707 $11599 $13049 reversed $10709 $-1 #
+point $-1 -1 -1 $-1 20 14.999999999999998 -40 #
+point $-1 -1 -1 $-1 10 15 -40 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13505 1.5707963267948966 $10714 2.0943951023931966 $13013 $13520 forward @7 unknown T 5.0000000000000009 14.330127018922191 -42.500000000000014 7.5000000000000053 15 -40 #
+point $-1 -1 -1 $-1 7.5000000000000027 14.330127018922195 -42.500000000000014 #
+edge $-1 -1 -1 $-1 $10717 -37.5 $13521 -27.500000000000004 $10716 $13522 forward @7 unknown T 22.5 5.6698729810778055 -37.5 22.500000000000007 5.6698729810778072 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000007 5.6698729810778055 -37.5 #
+face $-1 -1 -1 $-1 $13523 $13524 $11 $-1 $12076 reversed single T 9.9999999999999982 10 4.501174429623904e-32 20 15 10 F #
+face $-1 -1 -1 $-1 $13057 $13075 $11 $-1 $10259 reversed single T 20 4.9999999999999982 17.5 25 5.6698729810778072 22.5 F #
+loop $-1 -1 -1 $-1 $-1 $13525 $10721 T 10 4.9999999999999982 15 20 10 25 unknown #
+coedge $-1 -1 -1 $-1 $13055 $10723 $11614 $13060 forward $9508 $-1 #
+coedge $-1 -1 -1 $-1 $10723 $13526 $13527 $13528 forward $9508 $-1 #
+coedge $-1 -1 -1 $-1 $13529 $13530 $13531 $12071 reversed $13532 $-1 #
+edge $-1 -1 -1 $-1 $13533 10.000000000000002 $13063 15 $10723 $13534 forward @7 unknown T 29.999999999999996 10 10.000000000000002 30 10 15 #
+coedge $-1 -1 -1 $-1 $11656 $13535 $10724 $12073 forward $13113 $-1 #
+edge $-1 -1 -1 $-1 $13084 -1.5707963267948966 $9171 2.9403902792268214e-16 $12072 $13536 forward @7 unknown T 29.999999999999996 4.9999999999999982 -30 35 10 -24.999999999999996 #
+face $-1 -1 -1 $-1 $13537 $13538 $11 $-1 $12076 reversed single T 24.999999999999996 4.9999999999999973 1.7763568394002505e-15 35 10 10.000000000000002 F #
+loop $-1 -1 -1 $-1 $-1 $13071 $10726 T 25 10 1.7763568394002505e-15 35 15 10.000000000000002 unknown #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 10 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $13539 $10728 $13540 $13541 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $12105 $13542 $10728 $10754 reversed $13543 $-1 #
+coedge $-1 -1 -1 $-1 $13544 $10729 $10731 $10774 reversed $12080 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12079 $11668 T -15 -5 -50 -7.4999999999999991 8.8817841970012523e-16 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $10731 $10769 $13545 $13546 forward $9565 $-1 #
+coedge $-1 -1 -1 $-1 $13220 $10732 $11781 $13252 reversed $12084 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11752 $13547 T 5 -0.66987298107780902 -42.5 10 0 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $12085 $12085 $10736 $12086 forward $13548 $-1 #
+edge $-1 -1 -1 $-1 $13549 0 $13549 6.2831853071795862 $12085 $13550 forward @7 unknown T 50 -10 -45 50 0 -35 #
+face $-1 -1 -1 $-1 $13551 $13552 $11 $-1 $8499 reversed single T -25 -0.66987298107780902 -42.5 -20 1.7763568394002505e-15 -37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $13553 $10737 T -10 -10 -42.500000000000007 -5 -9.330127018922191 -37.499999999999993 unknown #
+coedge $-1 -1 -1 $-1 $10741 $13539 $13554 $13555 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $13556 $10938 $10741 $12091 reversed $9737 $-1 #
+edge $-1 -1 -1 $-1 $13557 -2.0943951023931957 $12095 1.7763568394002506e-16 $10741 $13558 forward @7 unknown T -37.5 -10 -50 -30 -4.9999999999999991 -50 #
+coedge $-1 -1 -1 $-1 $13559 $10742 $13560 $12291 forward $12094 $-1 #
+coedge $-1 -1 -1 $-1 $10742 $13561 $10744 $12098 reversed $12094 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12093 $13562 T -30 -9.9999999999999982 -50 -22.5 -4.9999999999999982 -40 unknown #
+vertex $-1 -1 -1 $-1 $13563 $13564 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $12099 $10744 $13565 $13566 forward $10746 $-1 #
+edge $-1 -1 -1 $-1 $10747 -50 $13567 -42.500000000000007 $10744 $13568 forward @7 unknown T -22.5 -9.3301270189221945 -50 -22.5 -9.3301270189221928 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $10745 $12097 $13569 $13570 forward $10746 $-1 #
+face $-1 -1 -1 $-1 $13571 $10746 $11 $-1 $10393 reversed single T -22.500000000000004 -10 -50 -15 -5 -40 F #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221928 -50 #
+coedge $-1 -1 -1 $-1 $13569 $13572 $10749 $12103 forward $13573 $-1 #
+edge $-1 -1 -1 $-1 $13574 -1.5707963267948966 $12106 -2.3886802389739258e-16 $12102 $13575 forward @7 unknown T -15 -10 -45 -10 -5 -40 #
+coedge $-1 -1 -1 $-1 $10750 $13544 $13576 $13577 reversed $12080 $-1 #
+coedge $-1 -1 -1 $-1 $13578 $12078 $10745 $10751 forward $13543 $-1 #
+vertex $-1 -1 -1 $-1 $13579 $13580 #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13553 $10756 $10752 $12109 forward $12088 $-1 #
+edge $-1 -1 -1 $-1 $10758 -2.0943951023931957 $13574 -1.5707963267948966 $12108 $13581 forward @7 unknown T -10 -10 -42.500000000000007 -7.4999999999999991 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $13541 $13582 #
+coedge $-1 -1 -1 $-1 $10756 $13553 $13583 $13584 reversed $12088 $-1 #
+vertex $-1 -1 -1 $-1 $10757 $13585 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $10763 $10760 $13586 $13587 reversed $10764 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13588 $13589 $11 $-1 $11179 reversed single T -20 -5 -15.000000000000002 -10 8.8817841970012523e-16 -5 F #
+loop $-1 -1 -1 $-1 $-1 $13590 $10762 T -10 -0.66987298107780902 -12.5 -5 8.8817841970012523e-16 -7.5000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $13591 $11747 $10763 $12120 reversed $10425 $-1 #
+edge $-1 -1 -1 $-1 $13217 -1.1640334398265738e-16 $10765 1.5707963267948966 $10763 $13592 forward @7 unknown T -4.686749320818303e-33 -10 -40 5 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $13593 $10764 $11 $-1 $8499 reversed single T -5 -10 -45 5 -4.9999999999999991 -35 F #
+point $-1 -1 -1 $-1 5 -10 -40 #
+coedge $-1 -1 -1 $-1 $13594 $10767 $11748 $13209 forward $12125 $-1 #
+coedge $-1 -1 -1 $-1 $10767 $13594 $10769 $10770 reversed $12125 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10767 $13593 T -5 -5 -45 5 0 -35 unknown #
+vertex $-1 -1 -1 $-1 $10768 $13595 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13546 $13596 #
+edge $-1 -1 -1 $-1 $10765 1.5707963267948966 $12133 2.0943951023931948 $10772 $13597 forward @7 unknown T 5 -10 -40 7.5000000000000018 -9.3301270189221945 -37.5 #
+vertex $-1 -1 -1 $-1 $13598 $13599 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $13253 $10776 $13207 $13600 forward $11784 $-1 #
+vertex $-1 -1 -1 $-1 $13600 $13601 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13602 $13216 $11 $-1 $7251 reversed single T -7.5000000000000009 -5 -40 0 0 -25 F #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13603 $13604 $11 $-1 $8848 reversed single T -5 -10 15 5 -4.9999999999999991 25 F #
+loop $-1 -1 -1 $-1 $-1 $13199 $10782 T -5 -5 15 5 0 25 unknown #
+coedge $-1 -1 -1 $-1 $13605 $13606 $13607 $12413 forward $10783 $-1 #
+coedge $-1 -1 -1 $-1 $11768 $10784 $13608 $13609 reversed $8229 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $11814 $13610 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $13611 $13612 $11 $-1 $9956 reversed single T 10 -10.000000000000002 -4.6867493208183037e-33 20 -4.9999999999999991 10 F #
+loop $-1 -1 -1 $-1 $-1 $11042 $10795 T 9.9999999999999982 -5 1.7819122827301222e-32 20 8.8817841970012523e-16 10 unknown #
+coedge $-1 -1 -1 $-1 $13613 $11789 $11674 $13128 forward $10797 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10806 $10800 $13614 $12165 forward $1615 $-1 #
+coedge $-1 -1 -1 $-1 $11069 $12162 $10800 $12150 reversed $11070 $-1 #
+edge $-1 -1 -1 $-1 $10825 -0.5235987755982987 $10812 1.5707963267948966 $10800 $13615 forward @7 unknown T -30 -20 -50 -22.5 -15 -50 #
+coedge $-1 -1 -1 $-1 $10801 $11064 $11069 $12444 forward $12152 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10822 $13616 T -22.500000000000007 -20 -50 -15 -15 -40 unknown #
+coedge $-1 -1 -1 $-1 $13617 $10924 $10803 $12154 reversed $12275 $-1 #
+edge $-1 -1 -1 $-1 $10841 -1.5707963267948966 $10843 -1.0471975511965965 $10803 $10827 forward @7 unknown T -7.5000000000000053 -15.669872981077811 -42.500000000000007 -5 -15 -40 #
+face $-1 -1 -1 $-1 $9632 $10805 $11 $-1 $4210 reversed single T 4.9999999999999991 -15.669872981077811 -42.500000000000007 10 -15 -37.5 F #
+coedge $-1 -1 -1 $-1 $10871 $13618 $10806 $12157 reversed $9673 $-1 #
+edge $-1 -1 -1 $-1 $13619 -0.52359877559829893 $12159 3.6651914291880923 $10806 $13620 forward @7 unknown T -45 -24.999999999999996 -50 -37.5 -14.999999999999996 -50 #
+coedge $-1 -1 -1 $-1 $12292 $10807 $13618 $13621 forward $8641 $-1 #
+vertex $-1 -1 -1 $-1 $10808 $13622 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12163 $10809 $13623 $13624 reversed $10811 $-1 #
+coedge $-1 -1 -1 $-1 $12149 $11068 $12296 $10940 reversed $11070 $-1 #
+coedge $-1 -1 -1 $-1 $10810 $12161 $13625 $13626 reversed $10811 $-1 #
+face $-1 -1 -1 $-1 $8273 $10811 $11 $-1 $7628 reversed single T -30 -25 -50 -22.5 -20 -40 F #
+edge $-1 -1 -1 $-1 $10812 0 $13619 2.0943951023931948 $12148 $12160 forward @7 unknown T -37.5 -20 -50 -30 -15 -50 #
+point $-1 -1 -1 $-1 -30 -20 -50 #
+coedge $-1 -1 -1 $-1 $13625 $13627 $10814 $12168 reversed $13628 $-1 #
+edge $-1 -1 -1 $-1 $12169 1.0471975511965961 $13629 1.5707963267948966 $10814 $12436 forward @7 unknown T -22.500000000000007 -25 -42.500000000000014 -20 -24.330127018922187 -40 #
+vertex $-1 -1 -1 $-1 $12168 $13630 #
+straight-curve $-1 -1 -1 $-1 -22.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12450 $10819 $10816 $12172 reversed $12174 $-1 #
+edge $-1 -1 -1 $-1 $13629 -1.5707963267948966 $10823 0 $10816 $13631 forward @7 unknown T -20 -25 -45 -15 -20 -40 #
+face $-1 -1 -1 $-1 $13632 $12270 $11 $-1 $9321 reversed single T -22.500000000000004 -20 -40 -15 -15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $10819 $13633 T -20 -25 -45 -10.000000000000002 -20 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12262 $13634 $10821 $12177 forward $13635 $-1 #
+edge $-1 -1 -1 $-1 $10823 -6.1232339957367648e-17 $12276 1.5707963267948966 $12176 $13636 forward @7 unknown T -15.000000000000002 -20 -45 -10.000000000000002 -15 -40 #
+coedge $-1 -1 -1 $-1 $11064 $10822 $13634 $12179 forward $12152 $-1 #
+edge $-1 -1 -1 $-1 $10823 0 $12435 1.5707963267948966 $12178 $13631 forward @7 unknown T -20 -20 -45 -15 -15 -40 #
+point $-1 -1 -1 $-1 -15 -20 -45 #
+point $-1 -1 -1 $-1 -22.5 -15.669872981077805 -50 #
+point $-1 -1 -1 $-1 -5 -25 -40 #
+edge $-1 -1 -1 $-1 $11843 3.1415926535897931 $10826 4.7123889803846897 $11075 $13637 forward @7 unknown T -5 -25 -40 0 -20 -35 #
+face $-1 -1 -1 $-1 $12448 $11113 $11 $-1 $2664 reversed single T -20 -25 -15.000000000000002 -10.000000000000002 -20 -5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $12349 $10831 T -20 -20 -15.000000000000002 -10.000000000000002 -15 -5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $13638 $12458 $12348 $13639 forward $10832 $-1 #
+coedge $-1 -1 -1 $-1 $13640 $10833 $9334 $10521 forward $9333 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10837 $10836 $11840 $13289 reversed $10838 $-1 #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 -40 #
+point $-1 -1 -1 $-1 -5 -15 -40 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 -42.500000000000007 #
+point $-1 -1 -1 $-1 7.5000000000000018 -24.330127018922191 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $10891 $13641 $10850 $12196 forward $12238 $-1 #
+edge $-1 -1 -1 $-1 $13642 7.5000000000000009 $10893 17.499999999999993 $12195 $13643 forward @7 unknown T -37.5 -24.330127018922195 7.5000000000000009 -37.5 -24.330127018922187 17.499999999999993 #
+coedge $-1 -1 -1 $-1 $10851 $11210 $13644 $13645 reversed $9646 $-1 #
+coedge $-1 -1 -1 $-1 $13646 $12231 $10851 $12199 forward $10890 $-1 #
+edge $-1 -1 -1 $-1 $12200 -17.499999999999996 $13647 -7.4999999999999982 $12198 $13648 forward @7 unknown T -37.5 -15.669872981077807 7.4999999999999982 -37.499999999999993 -15.669872981077805 17.499999999999996 #
+vertex $-1 -1 -1 $-1 $12199 $13649 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 19.999999999999996 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $13650 $12585 $10853 $12203 forward $13651 $-1 #
+edge $-1 -1 -1 $-1 $11214 1.5707963267948966 $13642 2.0943951023931948 $12202 $13652 forward @7 unknown T -40 -24.999999999999996 4.9999999999999973 -37.5 -24.330127018922191 7.5000000000000009 #
+edge $-1 -1 -1 $-1 $9651 -1.5707963267948966 $9782 0 $10855 $11008 forward @7 unknown T -5 -25 15 0 -20 20 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -24.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $12359 10 $10863 15 $12354 $13653 forward @7 unknown T -15 -20 10 -15 -20 15 #
+edge $-1 -1 -1 $-1 $10863 0 $12253 1.5707963267948966 $13654 $13655 forward @7 unknown T -20 -20 15 -15 -15 20 #
+point $-1 -1 -1 $-1 -15 -20 15 #
+vertex $-1 -1 -1 $-1 $11007 $13656 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $13275 $10872 $10868 $11827 reversed $12217 $-1 #
+coedge $-1 -1 -1 $-1 $13657 $13658 $11060 $12428 reversed $10870 $-1 #
+coedge $-1 -1 -1 $-1 $11061 $10871 $13659 $13660 reversed $9673 $-1 #
+coedge $-1 -1 -1 $-1 $13614 $13661 $10871 $12215 forward $13662 $-1 #
+edge $-1 -1 -1 $-1 $13663 42.5 $13619 50 $12214 $13664 forward @7 unknown T -37.5 -15.669872981077805 -50 -37.5 -15.669872981077805 -42.5 #
+coedge $-1 -1 -1 $-1 $10872 $13275 $12225 $13665 forward $12217 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13275 $13281 T -35 -25 30 -25 -20 40 unknown #
+vertex $-1 -1 -1 $-1 $10888 $13666 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13667 $10874 $12226 $13668 forward $12222 $-1 #
+coedge $-1 -1 -1 $-1 $10874 $13667 $12237 $13669 reversed $12222 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12220 $13670 T -35 -25 14.999999999999996 -25 -20 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -20 19.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -35 -25 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $13671 $10878 $12216 $13665 reversed $12227 $-1 #
+coedge $-1 -1 -1 $-1 $10878 $13672 $12220 $13668 reversed $12227 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13672 $13673 T -30 -25 20 -22.5 -20 35 unknown #
+straight-curve $-1 -1 -1 $-1 -30 -20 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $13670 $10967 $11 $-1 $1815 reversed single T -35 -20 14.999999999999996 -25 -15 25 F #
+loop $-1 -1 -1 $-1 $-1 $12354 $10880 T -22.500000000000004 -20 4.9999999999999991 -15 -15 20 unknown #
+coedge $-1 -1 -1 $-1 $12198 $13674 $10882 $12232 forward $10890 $-1 #
+edge $-1 -1 -1 $-1 $10886 -1.5707963267948957 $12200 -1.0471975511965979 $12231 $12239 forward @7 unknown T -37.499999999999993 -15.669872981077809 17.499999999999996 -35 -15 19.999999999999996 #
+face $-1 -1 -1 $-1 $13675 $13676 $11 $-1 $8642 reversed single T -37.5 -20 -10.000000000000002 -30 -15 4.9999999999999982 F #
+coedge $-1 -1 -1 $-1 $10966 $10884 $13674 $13677 reversed $10967 $-1 #
+point $-1 -1 -1 $-1 -35 -15 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $13674 $13678 $13679 $12331 forward $10890 $-1 #
+coedge $-1 -1 -1 $-1 $13679 $10891 $12221 $13669 forward $12238 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13679 $13680 T -37.5 -25 4.9999999999999982 -30 -20 19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -20 19.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 17.499999999999993 #
+coedge $-1 -1 -1 $-1 $13681 $13682 $10896 $12242 forward $13683 $-1 #
+edge $-1 -1 -1 $-1 $10910 -1.5707963267948966 $10863 0 $12241 $13655 forward @7 unknown T -20 -25 15 -15 -20 20 #
+coedge $-1 -1 -1 $-1 $10912 $10897 $13684 $13685 forward $9716 $-1 #
+face $-1 -1 -1 $-1 $13686 $13683 $11 $-1 $9321 reversed single T -22.500000000000004 -25 4.9999999999999991 -15 -20 20 F #
+coedge $-1 -1 -1 $-1 $12381 $10900 $13687 $13688 forward $10919 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10903 $10902 $13654 $12207 reversed $10904 $-1 #
+coedge $-1 -1 -1 $-1 $10975 $13687 $10903 $12249 reversed $8653 $-1 #
+edge $-1 -1 -1 $-1 $10863 -6.1232339957367648e-17 $10905 1.5707963267948966 $10903 $13689 forward @7 unknown T -15.000000000000002 -20 15 -10.000000000000002 -15 20 #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 20 #
+coedge $-1 -1 -1 $-1 $10963 $13690 $10908 $12252 reversed $12340 $-1 #
+edge $-1 -1 -1 $-1 $12341 4.1887902047863923 $12253 4.7123889803846897 $10908 $13691 forward @7 unknown T -22.499999999999993 -15.669872981077805 20 -20 -15 22.499999999999993 #
+vertex $-1 -1 -1 $-1 $13692 $13693 #
+edge $-1 -1 -1 $-1 $13694 1.0471975511965979 $10910 1.5707963267948966 $13682 $13695 forward @7 unknown T -22.500000000000004 -25 17.5 -20 -24.330127018922191 20 #
+point $-1 -1 -1 $-1 -20 -25 20 #
+coedge $-1 -1 -1 $-1 $13672 $13671 $10912 $12257 reversed $12227 $-1 #
+edge $-1 -1 -1 $-1 $13696 22.500000000000004 $10916 32.500000000000007 $10912 $13697 forward @7 unknown T -22.500000000000004 -24.330127018922195 22.500000000000004 -22.5 -24.330127018922195 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $10914 $10913 $13671 $13698 forward $10915 $-1 #
+face $-1 -1 -1 $-1 $11832 $10915 $11 $-1 $1965 reversed single T -25 -25 32.5 -20 -24.330127018922191 37.500000000000007 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $13699 $10920 $12274 $13700 reversed $8629 $-1 #
+coedge $-1 -1 -1 $-1 $13701 $12176 $10920 $12263 forward $13635 $-1 #
+edge $-1 -1 -1 $-1 $12276 -1.5707963267948966 $12271 6.1232339957367648e-17 $12262 $13702 forward @7 unknown T -15.000000000000002 -20 -40 -10.000000000000002 -15 -35 #
+coedge $-1 -1 -1 $-1 $10921 $13699 $13703 $13704 reversed $8629 $-1 #
+coedge $-1 -1 -1 $-1 $13705 $13706 $10921 $12266 forward $13707 $-1 #
+edge $-1 -1 -1 $-1 $12272 -6.1232339957367648e-17 $13708 1.5707963267948961 $12265 $13709 forward @7 unknown T -15.000000000000002 -20 -30 -10.000000000000002 -15 -25 #
+coedge $-1 -1 -1 $-1 $13710 $10922 $13706 $13711 forward $12270 $-1 #
+coedge $-1 -1 -1 $-1 $10922 $12433 $13701 $13712 forward $12270 $-1 #
+coedge $-1 -1 -1 $-1 $13713 $13714 $11079 $10923 reversed $13715 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10922 $12173 T -22.500000000000004 -20 -40 -15 -15 -25 unknown #
+vertex $-1 -1 -1 $-1 $13716 $13717 #
+vertex $-1 -1 -1 $-1 $13711 $13718 #
+straight-curve $-1 -1 -1 $-1 -15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10924 $13617 $12261 $13700 forward $12275 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12274 $13719 T -10.000000000000002 -15.669872981077811 -42.500000000000007 -5 -15 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $12177 $13720 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $10926 -32.5 $12341 -22.499999999999993 $10927 $13721 forward @7 unknown T -22.500000000000004 -15.669872981077809 22.499999999999993 -22.499999999999993 -15.669872981077805 32.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077809 32.5 #
+loop $-1 -1 -1 $-1 $13722 $13723 $3147 T -50 -10 14.999999999999996 -50 0 24.999999999999996 hole $3148 T #
+coedge $-1 -1 -1 $-1 $12281 $12281 $13131 $13724 forward $10928 $-1 #
+edge $-1 -1 -1 $-1 $13725 0 $13725 6.2831853071795862 $10929 $13726 forward @7 unknown T -50 -25 -45 -50 -15 -35 #
+vertex $-1 -1 -1 $-1 $10931 $13727 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 -25.000000000000004 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -20 -15.000000000000004 #
+face $-1 -1 -1 $-1 $6979 $13728 $11 $-1 $13729 reversed single T -37.500000000000014 35 -50 -30 40 -40 F #
+loop $-1 -1 -1 $-1 $-1 $13730 $10935 T -37.500000000000007 20 -50 -30 25 -40 unknown #
+cone-surface $-1 -1 -1 $-1 -35 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $13468 $13731 $13470 $13732 reversed $10936 $-1 #
+coedge $-1 -1 -1 $-1 $10938 $13733 $13734 $13735 forward $9737 $-1 #
+edge $-1 -1 -1 $-1 $12095 -50 $13736 -45 $13737 $13738 forward @7 unknown T -30 -5 -50 -30 -4.9999999999999991 -45 #
+coedge $-1 -1 -1 $-1 $10939 $12158 $13739 $13740 forward $8641 $-1 #
+coedge $-1 -1 -1 $-1 $13741 $13623 $10939 $12294 reversed $13742 $-1 #
+edge $-1 -1 -1 $-1 $13743 -1.5707963267948966 $12295 0 $10939 $13744 forward @7 unknown T -35 -25 -45 -30 -20 -40 #
+vertex $-1 -1 -1 $-1 $13745 $13746 #
+coedge $-1 -1 -1 $-1 $13747 $13614 $9739 $10940 forward $13662 $-1 #
+coedge $-1 -1 -1 $-1 $13748 $13749 $10941 $12299 forward $13750 $-1 #
+edge $-1 -1 -1 $-1 $12302 -7.4999999999999991 $13751 2.4999999999999942 $12298 $13752 forward @7 unknown T -37.5 -24.330127018922195 -7.4999999999999991 -37.5 -24.330127018922187 2.4999999999999942 #
+coedge $-1 -1 -1 $-1 $12465 $10942 $13749 $13753 reversed $12301 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10942 $13754 T -40 -25 -12.500000000000005 -35 -24.330127018922191 -7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $10943 $13755 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -10.000000000000002 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13756 $13757 $10944 $12305 forward $13758 $-1 #
+edge $-1 -1 -1 $-1 $13759 -2.094395102393193 $12306 -1.5707963267948966 $12304 $13760 forward @7 unknown T -40 -15.669872981077804 -25.000000000000004 -37.500000000000007 -14.999999999999996 -22.500000000000014 #
+vertex $-1 -1 -1 $-1 $11058 $13761 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13762 $10947 $12465 $13763 forward $12310 $-1 #
+coedge $-1 -1 -1 $-1 $10947 $13764 $10949 $12314 forward $12310 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13765 $13766 T -37.500000000000007 -25 -25.000000000000007 -29.999999999999993 -20 -10.000000000000002 unknown #
+vertex $-1 -1 -1 $-1 $13763 $13767 #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $10950 $10949 $13768 $13769 reversed $10951 $-1 #
+edge $-1 -1 -1 $-1 $13770 1.5707963267948957 $10953 2.0943951023931948 $12309 $13771 forward @7 unknown T -37.500000000000007 -25 -25.000000000000007 -35 -24.330127018922195 -22.5 #
+coedge $-1 -1 -1 $-1 $13772 $11057 $10950 $12316 reversed $10870 $-1 #
+edge $-1 -1 -1 $-1 $13773 -2.0943951023931953 $10952 -1.5707963267948966 $10950 $13774 forward @7 unknown T -40 -24.999999999999996 -27.500000000000004 -37.5 -24.330127018922187 -25.000000000000004 #
+face $-1 -1 -1 $-1 $13775 $10951 $11 $-1 $3328 reversed single T -40 -25 -27.500000000000007 -35 -24.330127018922187 -22.5 F #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 -25.000000000000004 #
+point $-1 -1 -1 $-1 -37.500000000000007 -24.330127018922198 -22.5 #
+face $-1 -1 -1 $-1 $13776 $13777 $11 $-1 $7628 reversed single T -30 -25 -10.000000000000002 -22.5 -20 4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $13778 $10955 T -30 -25 -25 -22.5 -20 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $13779 $13780 $13781 $13782 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $13783 $10957 $13784 $13785 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $10957 $13786 $13787 $13788 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $13789 $13790 $10957 $12326 forward $13791 $-1 #
+edge $-1 -1 -1 $-1 $13792 -1.5707963267948966 $13793 6.1232339957367648e-17 $12325 $13794 forward @7 unknown T -30 -20 -10.000000000000002 -25 -15 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $13795 $10958 $13796 $13797 reversed $8650 $-1 #
+coedge $-1 -1 -1 $-1 $13798 $13799 $10958 $12329 forward $13800 $-1 #
+edge $-1 -1 -1 $-1 $13801 -2.0943951023931957 $12335 -1.5707963267948966 $12328 $13802 forward @7 unknown T -25 -15.669872981077809 4.9999999999999982 -22.499999999999993 -15 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $10959 $13795 $10966 $12344 reversed $8650 $-1 #
+edge $-1 -1 -1 $-1 $12336 9.9999999999999982 $13803 14.999999999999996 $12236 $13804 forward @7 unknown T -30.000000000000007 -20 9.9999999999999982 -30 -20 14.999999999999996 #
+coedge $-1 -1 -1 $-1 $13805 $10960 $13678 $13806 reversed $12334 $-1 #
+coedge $-1 -1 -1 $-1 $10960 $13805 $13786 $13807 forward $12334 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10960 $13808 T -35 -20 -1.7763568394002505e-15 -25 -15 9.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $13807 $13809 #
+vertex $-1 -1 -1 $-1 $13810 $13811 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10965 $10962 $11829 $13279 reversed $7627 $-1 #
+coedge $-1 -1 -1 $-1 $13690 $10963 $13795 $13812 forward $12340 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10963 $13813 T -25 -15.669872981077809 17.499999999999996 -20 -15 22.5 unknown #
+vertex $-1 -1 -1 $-1 $12252 $13814 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12218 -6.1232339957367648e-17 $11825 1.5707963267948966 $11823 $13815 forward @7 unknown T -30 -20 30 -25 -15 35 #
+edge $-1 -1 -1 $-1 $13803 -6.1232339957367648e-17 $10968 1.5707963267948966 $10966 $13816 forward @7 unknown T -30.000000000000007 -20 14.999999999999996 -25 -15 20 #
+point $-1 -1 -1 $-1 -25 -15 20 #
+point $-1 -1 -1 $-1 -29.999999999999993 -20 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $13817 $12480 $13705 $13818 reversed $10972 $-1 #
+coedge $-1 -1 -1 $-1 $13819 $10973 $12186 $13639 reversed $9753 $-1 #
+coedge $-1 -1 -1 $-1 $13820 $13821 $10973 $12350 forward $12185 $-1 #
+edge $-1 -1 -1 $-1 $13822 -1.5707963267948966 $11114 6.1232339957367648e-17 $12349 $13823 forward @7 unknown T -15.000000000000002 -20 -10 -10.000000000000002 -15 -5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $13687 $10974 $12380 $13824 reversed $8653 $-1 #
+coedge $-1 -1 -1 $-1 $13825 $12382 $10974 $12353 forward $13826 $-1 #
+edge $-1 -1 -1 $-1 $13827 -2.0943951023931957 $12358 -1.5707963267948966 $12352 $13828 forward @7 unknown T -10.000000000000002 -15.669872981077809 4.9999999999999991 -7.5000000000000009 -15 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $13654 $13829 $13681 $12206 forward $12230 $-1 #
+coedge $-1 -1 -1 $-1 $13830 $10976 $13829 $13831 reversed $12357 $-1 #
+coedge $-1 -1 -1 $-1 $10976 $13830 $12484 $13832 forward $12357 $-1 #
+loop $-1 -1 -1 $-1 $-1 $10976 $13833 T -20 -20 -1.7763568394002505e-15 -10.000000000000002 -15 10 unknown #
+vertex $-1 -1 -1 $-1 $13832 $13834 #
+vertex $-1 -1 -1 $-1 $13835 $13836 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+loop $-1 -1 -1 $-1 $13548 $13837 $1558 T 50 -10 -29.999999999999996 50 0 -19.999999999999996 hole $1559 T #
+coedge $-1 -1 -1 $-1 $12362 $12362 $13838 $13839 forward $10978 $-1 #
+coedge $-1 -1 -1 $-1 $12363 $12363 $10979 $12364 reversed $13840 $-1 #
+edge $-1 -1 -1 $-1 $13841 0 $13841 6.2831853071795862 $10979 $13842 forward @7 unknown T 50 -10 2.6645352591003757e-15 50 0 10.000000000000004 #
+vertex $-1 -1 -1 $-1 $10981 $13843 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $11035 $10983 $8793 $9895 forward $8683 $-1 #
+coedge $-1 -1 -1 $-1 $12422 $13844 $10983 $12369 forward $11048 $-1 #
+edge $-1 -1 -1 $-1 $10988 6.1232339957367648e-17 $12370 1.5707963267948966 $12368 $13845 forward @7 unknown T -8.8817841970012523e-16 -25 -25 4.9999999999999991 -20 -20 #
+vertex $-1 -1 -1 $-1 $13846 $13847 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $10986 $10985 $11839 $13287 reversed $9835 $-1 #
+edge $-1 -1 -1 $-1 $13848 1.5707963267948966 $10988 3.1415926535897931 $11121 $13849 forward @7 unknown T -5 -20 -25 0 -15 -20 #
+point $-1 -1 -1 $-1 4.9999999999999991 -15 -25 #
+edge $-1 -1 -1 $-1 $10988 3.1415926535897931 $13850 4.7123889803846897 $12425 $13849 forward @7 unknown T -5 -25 -25 0 -20 -20 #
+point $-1 -1 -1 $-1 0 -20 -20 #
+point $-1 -1 -1 $-1 0 -20 0 #
+vertex $-1 -1 -1 $-1 $13851 $13852 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -10 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $10996 $10995 $12351 $13824 forward $8850 $-1 #
+coedge $-1 -1 -1 $-1 $11006 $12245 $10995 $11009 reversed $10919 $-1 #
+coedge $-1 -1 -1 $-1 $12352 $12457 $10996 $12383 reversed $13826 $-1 #
+edge $-1 -1 -1 $-1 $13827 4.1887902047863905 $11001 4.7123889803846897 $10996 $11218 forward @7 unknown T -7.5000000000000027 -15.669872981077809 5 -5 -15 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $11049 $12460 $10997 $9789 reversed $12388 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 5 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11001 -1.5707963267948966 $13853 -1.047197551196597 $11086 $12591 forward @7 unknown T -7.5000000000000036 -15.669872981077809 2.4999999999999964 -5 -15 5 #
+point $-1 -1 -1 $-1 -5 -15 5 #
+loop $-1 -1 -1 $-1 $-1 $11049 $11004 T -5 -25 0 4.9999999999999991 -20 10 unknown #
+point $-1 -1 -1 $-1 -5 -25 5 #
+vertex $-1 -1 -1 $-1 $13824 $13854 #
+coedge $-1 -1 -1 $-1 $11023 $13640 $11015 $12392 reversed $9333 $-1 #
+edge $-1 -1 -1 $-1 $8727 -2.0943951023931957 $12370 -1.5707963267948966 $11015 $13855 forward @7 unknown T 4.9999999999999991 -25 -27.500000000000004 7.5000000000000027 -24.330127018922191 -25 #
+edge $-1 -1 -1 $-1 $11020 -2.0943951023931957 $10839 -1.5707963267948966 $11846 $13856 forward @7 unknown T 4.9999999999999991 -15.669872981077809 -40 7.5000000000000009 -15 -37.5 #
+point $-1 -1 -1 $-1 7.5000000000000009 -15.669872981077807 -37.5 #
+straight-curve $-1 -1 -1 $-1 7.5 -24.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12460 $11049 $11026 $11051 forward $12388 $-1 #
+edge $-1 -1 -1 $-1 $11027 -1.5707963267948966 $9897 -6.1232339957367648e-17 $11032 $13857 forward @7 unknown T -8.8817841970012523e-16 -25 -15 4.9999999999999991 -20 -10 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 -10 #
+face $-1 -1 -1 $-1 $13858 $13859 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 5 7.5000000000000018 8.8817841970012523e-16 20 F #
+coedge $-1 -1 -1 $-1 $11033 $11032 $11099 $12473 reversed $8739 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $13860 $13861 $11 $-1 $5386 reversed single T 15 -10.000000000000002 -9.9999999999999982 22.5 -4.9999999999999991 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $13862 $11037 T 15 -10 -25 22.500000000000004 -4.9999999999999991 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $13863 $13864 $11774 $13244 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $13865 $11039 $13866 $13867 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $11039 $13868 $13869 $13870 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $13871 $13872 $11039 $12408 forward $13873 $-1 #
+edge $-1 -1 -1 $-1 $13874 -1.5707963267948966 $13875 -2.9403902792268244e-16 $12407 $13876 forward @7 unknown T 15 -4.9999999999999991 -9.9999999999999982 20 -8.8817841970012523e-16 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $13236 $11040 $11188 $12567 reversed $8743 $-1 #
+coedge $-1 -1 -1 $-1 $13877 $11189 $11040 $12411 forward $12568 $-1 #
+edge $-1 -1 -1 $-1 $12569 -2.0943951023931948 $12416 -1.5707963267948966 $12410 $13878 forward @7 unknown T 20 -0.66987298107780635 5.0000000000000009 22.499999999999996 -8.8817841970012523e-16 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $11041 $13236 $11045 $12420 reversed $8743 $-1 #
+edge $-1 -1 -1 $-1 $12417 10 $13879 15 $12139 $13880 forward @7 unknown T 14.999999999999996 -5 10 15 -4.9999999999999991 15 #
+coedge $-1 -1 -1 $-1 $13881 $11042 $13606 $13882 reversed $12145 $-1 #
+coedge $-1 -1 -1 $-1 $11042 $13881 $13868 $13883 forward $12145 $-1 #
+vertex $-1 -1 -1 $-1 $13883 $13884 #
+vertex $-1 -1 -1 $-1 $13885 $13886 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $11045 $11044 $13605 $13887 reversed $9585 $-1 #
+edge $-1 -1 -1 $-1 $13879 1.1640334398265738e-16 $11046 1.5707963267948966 $11045 $13888 forward @7 unknown T 15 -5 15 20 -8.8817841970012523e-16 20 #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 20 #
+coedge $-1 -1 -1 $-1 $13889 $12368 $13640 $13846 forward $11048 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 0.70710678118654735 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 5 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $12474 $11056 $13844 $12375 forward $9846 $-1 #
+coedge $-1 -1 -1 $-1 $11057 $13890 $13756 $13891 reversed $10870 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12431 -1.5707963267948966 $12430 1.5707963267948966 $11060 $13892 forward @7 unknown T -45 -24.999999999999996 -40 -40 -14.999999999999996 -35 #
+coedge $-1 -1 -1 $-1 $13618 $11061 $13893 $13894 reversed $9673 $-1 #
+vertex $-1 -1 -1 $-1 $11062 $13895 #
+vertex $-1 -1 -1 $-1 $11062 $13896 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12268 $13897 $11063 $12434 forward $12270 $-1 #
+edge $-1 -1 -1 $-1 $12440 4.1887902047863914 $12435 4.7123889803846897 $12433 $13898 forward @7 unknown T -22.499999999999996 -15.669872981077805 -40 -20 -15 -37.5 #
+vertex $-1 -1 -1 $-1 $11065 $13899 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13900 $11066 $13897 $13901 reversed $12439 $-1 #
+coedge $-1 -1 -1 $-1 $11066 $13902 $13903 $13904 reversed $12439 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13902 $11831 T -30.000000000000007 -20 -40 -22.499999999999993 -15 -25 unknown #
+vertex $-1 -1 -1 $-1 $12434 $13905 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13903 $13906 $11068 $12443 forward $13907 $-1 #
+edge $-1 -1 -1 $-1 $12295 -6.1232339957367648e-17 $11071 1.5707963267948966 $12442 $13908 forward @7 unknown T -30 -20 -45 -25 -15 -40 #
+edge $-1 -1 -1 $-1 $11072 42.500000000000007 $10825 50 $12151 $13909 forward @7 unknown T -22.500000000000004 -15.669872981077809 -50 -22.5 -15.669872981077805 -42.500000000000007 #
+point $-1 -1 -1 $-1 -25 -15 -40 #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077809 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $13290 $11074 $13910 $13911 forward $11076 $-1 #
+face $-1 -1 -1 $-1 $13912 $11076 $11 $-1 $3822 reversed single T -7.5000000000000027 -25 -40 0 -20 -25 F #
+coedge $-1 -1 -1 $-1 $11082 $11079 $13913 $13914 reversed $9723 $-1 #
+coedge $-1 -1 -1 $-1 $11080 $12171 $13713 $13716 reversed $12174 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12476 $13910 $11082 $12453 forward $13915 $-1 #
+edge $-1 -1 -1 $-1 $12454 -2.0943951023931957 $13916 -1.570796326794897 $12452 $13917 forward @7 unknown T -10.000000000000002 -25 -27.500000000000004 -7.5000000000000009 -24.330127018922191 -25 #
+vertex $-1 -1 -1 $-1 $13911 $13918 #
+coedge $-1 -1 -1 $-1 $11087 $11086 $13819 $13919 forward $7794 $-1 #
+coedge $-1 -1 -1 $-1 $12382 $13825 $11086 $12386 reversed $13826 $-1 #
+coedge $-1 -1 -1 $-1 $12186 $13920 $11087 $12459 reversed $10832 $-1 #
+edge $-1 -1 -1 $-1 $13921 4.1887902047863905 $12378 4.7123889803846897 $11087 $9879 forward @7 unknown T -7.5000000000000044 -15.669872981077807 -10 -5 -15 -7.4999999999999956 #
+coedge $-1 -1 -1 $-1 $12384 $12396 $11088 $12461 reversed $12388 $-1 #
+edge $-1 -1 -1 $-1 $11005 -1.5707963267948966 $10990 0 $11088 $12385 forward @7 unknown T -5 -25 0 0 -20 5 #
+coedge $-1 -1 -1 $-1 $11213 $11090 $13922 $13923 reversed $8644 $-1 #
+coedge $-1 -1 -1 $-1 $11095 $13924 $11090 $12464 forward $12470 $-1 #
+edge $-1 -1 -1 $-1 $13925 -2.0943951023931966 $9871 -1.5707963267948966 $12463 $13926 forward @7 unknown T -40 -15.669872981077807 -10.000000000000002 -37.499999999999993 -14.999999999999996 -7.4999999999999973 #
+coedge $-1 -1 -1 $-1 $11092 $12300 $12308 $13763 reversed $12301 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -10.000000000000002 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13927 $13928 $11094 $12468 forward $13929 $-1 #
+edge $-1 -1 -1 $-1 $12471 12.500000000000004 $13759 22.500000000000018 $12467 $13930 forward @7 unknown T -37.500000000000007 -15.669872981077809 -22.500000000000018 -37.5 -15.669872981077804 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $13924 $11095 $13928 $13931 reversed $12470 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12463 $13932 T -40 -15.669872981077811 -12.500000000000007 -35 -14.999999999999996 -7.4999999999999973 unknown #
+vertex $-1 -1 -1 $-1 $12468 $13933 #
+edge $-1 -1 -1 $-1 $9878 -1.5707963267948966 $9897 0 $11099 $12496 forward @7 unknown T -5 -25 -15 8.8817841970012523e-16 -20 -10 #
+coedge $-1 -1 -1 $-1 $11100 $12425 $13934 $13935 forward $9846 $-1 #
+coedge $-1 -1 -1 $-1 $11106 $11104 $13936 $13937 reversed $9882 $-1 #
+coedge $-1 -1 -1 $-1 $13934 $12452 $11104 $12477 forward $13915 $-1 #
+edge $-1 -1 -1 $-1 $13916 1.5707963267948961 $12478 2.0943951023931948 $12476 $13938 forward @7 unknown T -10.000000000000004 -25 -25 -7.5000000000000027 -24.330127018922195 -22.5 #
+vertex $-1 -1 -1 $-1 $12477 $13939 #
+coedge $-1 -1 -1 $-1 $12347 $13940 $13941 $12481 reversed $10972 $-1 #
+edge $-1 -1 -1 $-1 $13942 -20 $11118 -15.000000000000002 $13941 $13943 forward @7 unknown T -15.000000000000004 -20 -20 -15 -20 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $11112 $11107 $13944 $13945 reversed $11113 $-1 #
+coedge $-1 -1 -1 $-1 $13946 $11220 $11109 $11222 forward $12593 $-1 #
+coedge $-1 -1 -1 $-1 $11110 $13947 $12356 $13832 reversed $9753 $-1 #
+coedge $-1 -1 -1 $-1 $13948 $13949 $13950 $11111 forward $13951 $-1 #
+vertex $-1 -1 -1 $-1 $13952 $13953 #
+coedge $-1 -1 -1 $-1 $13954 $13950 $11112 $12489 forward $13955 $-1 #
+edge $-1 -1 -1 $-1 $11114 3.1415926535897931 $13956 4.7123889803846897 $12488 $13957 forward @7 unknown T -20 -25 -10.000000000000002 -14.999999999999996 -20 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -14.999999999999996 -20 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 2.4999999999999982 #
+edge $-1 -1 -1 $-1 $11118 0 $13958 1.5707963267948961 $13959 $13960 forward @7 unknown T -20 -20 -15.000000000000002 -15.000000000000004 -15 -10.000000000000002 #
+point $-1 -1 -1 $-1 -15.000000000000004 -20 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $13961 $11120 $13920 $13851 forward $11031 $-1 #
+coedge $-1 -1 -1 $-1 $11121 $13961 $13962 $13963 forward $11031 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -10 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11125 $12575 $13137 $13964 reversed $9899 $-1 #
+coedge $-1 -1 -1 $-1 $13965 $13966 $11125 $12499 forward $12580 $-1 #
+edge $-1 -1 -1 $-1 $13967 1.5707963267948966 $13968 2.0943951023931966 $12498 $13969 forward @7 unknown T 35 -10.000000000000002 5.0000000000000018 37.500000000000007 -9.330127018922191 7.500000000000008 #
+coedge $-1 -1 -1 $-1 $13970 $12550 $11126 $12501 forward $13971 $-1 #
+edge $-1 -1 -1 $-1 $8815 -4.7167471186270725e-16 $12508 1.5707963267948966 $12500 $13972 forward @7 unknown T 29.999999999999996 -10.000000000000002 -9.9999999999999982 35 -4.9999999999999991 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $11127 $12554 $13966 $13973 reversed $8799 $-1 #
+coedge $-1 -1 -1 $-1 $13974 $13975 $11127 $12504 forward $11158 $-1 #
+edge $-1 -1 -1 $-1 $12509 -7.4999999999999982 $13976 2.5000000000000071 $12503 $13977 forward @7 unknown T 37.499999999999993 -9.3301270189221945 -7.4999999999999982 37.500000000000007 -9.3301270189221945 2.5000000000000071 #
+coedge $-1 -1 -1 $-1 $13978 $11128 $13975 $13979 reversed $12507 $-1 #
+coedge $-1 -1 -1 $-1 $11128 $13978 $11133 $12513 forward $12507 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12506 $13980 T 35 -10.000000000000002 -12.5 40 -9.3301270189221928 -7.4999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $13981 $13982 #
+vertex $-1 -1 -1 $-1 $11129 $13983 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11133 $11130 $13970 $13981 reversed $7808 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12517 -2.0943951023931957 $12508 -1.5707963267948966 $12506 $13984 forward @7 unknown T 35 -10.000000000000002 -12.5 37.500000000000007 -9.3301270189221928 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $13985 $11134 $13978 $13986 forward $12516 $-1 #
+coedge $-1 -1 -1 $-1 $11134 $13987 $11136 $12519 forward $12516 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11142 $13988 T 37.5 -10 -24.999999999999996 45 0 -9.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $13986 $13989 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $13264 1.570796326794897 $11139 2.0943951023931975 $12515 $13990 forward @7 unknown T 37.5 -10 -24.999999999999996 40.000000000000007 -9.3301270189221874 -22.499999999999986 #
+face $-1 -1 -1 $-1 $11802 $11137 $11 $-1 $11805 reversed single T 35 -10.000000000000002 -27.499999999999989 40.000000000000007 -9.3301270189221874 -22.499999999999986 F #
+point $-1 -1 -1 $-1 35 -10.000000000000002 -24.999999999999996 #
+point $-1 -1 -1 $-1 37.5 -9.3301270189221892 -22.499999999999986 #
+coedge $-1 -1 -1 $-1 $13987 $11142 $11144 $12527 forward $12516 $-1 #
+coedge $-1 -1 -1 $-1 $11142 $13985 $11161 $12540 forward $12516 $-1 #
+vertex $-1 -1 -1 $-1 $11162 $13991 #
+straight-curve $-1 -1 -1 $-1 37.5 -0.66987298107780724 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $11145 4.1887902047863896 $13266 4.7123889803846897 $12523 $13990 forward @7 unknown T 37.5 -0.66987298107781124 -24.999999999999996 40.000000000000007 0 -22.499999999999993 #
+point $-1 -1 -1 $-1 37.5 -0.66987298107781124 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $13992 $11147 $13993 $12558 forward $11150 $-1 #
+coedge $-1 -1 -1 $-1 $11148 $13992 $11807 $13268 forward $11150 $-1 #
+coedge $-1 -1 -1 $-1 $13994 $11149 $11815 $11154 forward $12533 $-1 #
+coedge $-1 -1 -1 $-1 $11149 $13995 $13996 $13997 forward $12533 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11149 $13998 T 22.5 -10 -25.000000000000004 30 -4.9999999999999991 -9.9999999999999964 unknown #
+point $-1 -1 -1 $-1 30 -5 -14.999999999999998 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $13975 $11156 $13999 $14000 forward $11158 $-1 #
+coedge $-1 -1 -1 $-1 $11157 $13974 $14001 $14002 forward $11158 $-1 #
+face $-1 -1 -1 $-1 $13980 $11158 $11 $-1 $4463 reversed single T 37.499999999999993 -10 -9.9999999999999982 45.000000000000007 8.8817841970012523e-16 5.0000000000000044 F #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780502 2.5000000000000053 #
+edge $-1 -1 -1 $-1 $12542 -1.5707963267948966 $12525 -1.0471975511965974 $12524 $14003 forward @7 unknown T 37.5 -0.66987298107780813 -12.5 40 0 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $12540 $14004 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -9.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14005 $14006 $11 $-1 $11179 reversed single T 20 -0.6698729810778099 -12.499999999999996 25 8.8817841970012523e-16 -7.4999999999999964 F #
+coedge $-1 -1 -1 $-1 $11167 $11166 $13865 $14007 forward $9925 $-1 #
+coedge $-1 -1 -1 $-1 $11189 $13877 $11166 $11199 reversed $12568 $-1 #
+coedge $-1 -1 -1 $-1 $13866 $13993 $11167 $12548 reversed $14006 $-1 #
+edge $-1 -1 -1 $-1 $14008 4.1887902047863914 $11175 4.7123889803846897 $11167 $14009 forward @7 unknown T 22.5 -0.66987298107780735 -9.9999999999999982 25 8.8817841970012523e-16 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $14010 $11168 $14011 $14012 forward $11171 $-1 #
+coedge $-1 -1 -1 $-1 $12500 $13996 $11168 $9933 reversed $13971 $-1 #
+coedge $-1 -1 -1 $-1 $11169 $14010 $14013 $11203 forward $11171 $-1 #
+coedge $-1 -1 -1 $-1 $11192 $14014 $11169 $12553 reversed $11202 $-1 #
+edge $-1 -1 -1 $-1 $9957 -1.5707963267948961 $9926 0 $11169 $11198 forward @7 unknown T 25 -10 1.7763568394002505e-15 29.999999999999996 -5 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $12502 $11170 $14014 $14015 reversed $8799 $-1 #
+face $-1 -1 -1 $-1 $12538 $11171 $11 $-1 $4486 reversed single T 22.5 -10 -9.9999999999999982 30 -4.9999999999999991 5.0000000000000036 F #
+face $-1 -1 -1 $-1 $14016 $14017 $11 $-1 $11179 reversed single T 20 -10 -12.499999999999996 25 -9.3301270189221928 -7.4999999999999982 F #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -9.9999999999999982 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11175 -1.570796326794897 $14018 -1.0471975511965983 $12529 $14019 forward @7 unknown T 22.5 -0.66987298107780768 -12.499999999999996 25 0 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 0 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $14020 1.0471975511965987 $11180 1.570796326794897 $13995 $14019 forward @7 unknown T 22.5 -10 -12.499999999999996 25 -9.3301270189221945 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 -10 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $13137 $11181 $13965 $14021 forward $8452 $-1 #
+coedge $-1 -1 -1 $-1 $14001 $14001 $11181 $12564 reversed $14022 $-1 #
+edge $-1 -1 -1 $-1 $11186 1.570796326794897 $14023 4.7123889803846897 $11181 $14024 forward @7 unknown T 39.999999999999993 -10 5.0000000000000027 44.999999999999993 0 10.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 0 5.0000000000000027 #
+edge $-1 -1 -1 $-1 $11207 -17.499999999999996 $12569 -7.5000000000000009 $11188 $14025 forward @7 unknown T 22.499999999999996 -0.66987298107780868 7.5000000000000009 22.5 -0.66987298107780624 17.499999999999996 #
+loop $-1 -1 -1 $-1 $-1 $12410 $14026 T 20 -0.66987298107780768 2.5000000000000036 25 0 7.5000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $11190 $14027 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11193 $11191 $14028 $14029 forward $9949 $-1 #
+coedge $-1 -1 -1 $-1 $14013 $14030 $11191 $12573 reversed $14031 $-1 #
+edge $-1 -1 -1 $-1 $9957 1.5707963267948961 $14032 2.0943951023931948 $11191 $12570 forward @7 unknown T 22.499999999999996 -10 4.9999999999999991 25 -9.3301270189221928 7.5 #
+coedge $-1 -1 -1 $-1 $14014 $11192 $11197 $12577 forward $11202 $-1 #
+coedge $-1 -1 -1 $-1 $12497 $11196 $11675 $13129 reversed $9899 $-1 #
+edge $-1 -1 -1 $-1 $11676 -1.5707963267948966 $8828 2.9403902792268214e-16 $11678 $14033 forward @7 unknown T 29.999999999999996 -10.000000000000002 15 35 -5 20.000000000000004 #
+edge $-1 -1 -1 $-1 $7824 -4.7167471186270725e-16 $13967 1.5707963267948966 $12574 $14034 forward @7 unknown T 29.999999999999996 -10.000000000000004 5.0000000000000018 35 -4.9999999999999991 10.000000000000002 #
+vertex $-1 -1 -1 $-1 $14007 $14035 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $12498 $11201 T 35 -10.000000000000004 2.5000000000000031 40.000000000000007 -9.330127018922191 7.500000000000008 unknown #
+vertex $-1 -1 -1 $-1 $11203 $14036 #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780868 17.499999999999996 #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221945 17.5 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 4.9999999999999973 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $12202 $14037 $11212 $12586 forward $13651 $-1 #
+edge $-1 -1 -1 $-1 $13751 -2.0943951023931957 $11214 -1.5707963267948966 $12585 $14038 forward @7 unknown T -40 -24.999999999999996 2.4999999999999942 -37.5 -24.330127018922187 4.9999999999999973 #
+coedge $-1 -1 -1 $-1 $14039 $13644 $11213 $12588 forward $14040 $-1 #
+edge $-1 -1 -1 $-1 $11215 1.5707963267948966 $14041 2.0943951023931948 $12587 $14042 forward @7 unknown T -40 -15.669872981077805 2.5000000000000009 -37.5 -14.999999999999996 4.9999999999999973 #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 4.9999999999999973 #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 4.9999999999999973 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 5 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11220 $13946 $14043 $13835 reversed $12593 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11220 $14044 T -20 -25 -1.7763568394002505e-15 -10.000000000000002 -20 10 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14045 $11225 $14046 $14047 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $12636 $14048 $11225 $11263 reversed $14049 $-1 #
+coedge $-1 -1 -1 $-1 $14050 $11226 $11228 $11283 reversed $12600 $-1 #
+coedge $-1 -1 -1 $-1 $11226 $14051 $10011 $11260 forward $12600 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12598 $14052 T -15 35 35 -7.4999999999999973 40 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11228 $11271 $14053 $14054 forward $10040 $-1 #
+coedge $-1 -1 -1 $-1 $11232 $14055 $11229 $11305 forward $12607 $-1 #
+coedge $-1 -1 -1 $-1 $14056 $12655 $11230 $12605 forward $14057 $-1 #
+edge $-1 -1 -1 $-1 $10024 6.1232339957367673e-17 $12692 1.5707963267948966 $12604 $14058 forward @7 unknown T 0 35 35 5.0000000000000027 40 40 #
+coedge $-1 -1 -1 $-1 $14055 $11232 $12684 $11298 reversed $12607 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12603 $14059 T 5.0000000000000027 35 32.5 10 35.669872981077809 37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $12711 $12610 $11234 $12609 reversed $14060 $-1 #
+edge $-1 -1 -1 $-1 $10066 -2.0943951023931948 $10079 -1.5707963267948966 $11234 $14061 forward @7 unknown T 20.000000000000004 35 32.5 22.5 35.669872981077809 35 #
+coedge $-1 -1 -1 $-1 $12608 $14062 $11235 $11339 reversed $14060 $-1 #
+coedge $-1 -1 -1 $-1 $12613 $11239 $14063 $14064 reversed $11240 $-1 #
+face $-1 -1 -1 $-1 $6992 $11240 $11 $-1 $6121 reversed single T 29.999999999999996 35 20.000000000000004 37.500000000000014 40 35 F #
+coedge $-1 -1 -1 $-1 $11243 $12611 $14065 $14066 reversed $11240 $-1 #
+coedge $-1 -1 -1 $-1 $12614 $12614 $11245 $12615 forward $14067 $-1 #
+edge $-1 -1 -1 $-1 $14068 0 $14068 6.2831853071795862 $12614 $14069 forward @7 unknown T 50 35 30 50 45 40 #
+face $-1 -1 -1 $-1 $10020 $14070 $11 $-1 $8951 reversed single T -50 35 29.999999999999996 -40 45 40 F #
+loop $-1 -1 -1 $-1 $-1 $14071 $11246 T -9.9999999999999982 35 32.5 -5 35.669872981077816 37.5 unknown #
+coedge $-1 -1 -1 $-1 $11248 $11247 $14072 $14073 forward $8902 $-1 #
+coedge $-1 -1 -1 $-1 $11320 $14074 $11247 $12620 reversed $12714 $-1 #
+edge $-1 -1 -1 $-1 $11322 4.1887902047863905 $14075 4.7123889803846897 $11247 $14076 forward @7 unknown T 37.500000000000007 44.330127018922191 20.000000000000004 40.000000000000007 45 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $14077 $14063 $11248 $12622 reversed $14078 $-1 #
+edge $-1 -1 -1 $-1 $14079 1.570796326794897 $12623 2.0943951023931966 $11248 $14076 forward @7 unknown T 37.5 35 20.000000000000004 40.000000000000007 35.669872981077816 22.500000000000014 #
+vertex $-1 -1 -1 $-1 $14064 $14080 #
+straight-curve $-1 -1 -1 $-1 37.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $11251 $14045 $14081 $14082 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $14083 $14084 $11251 $12627 reversed $14085 $-1 #
+edge $-1 -1 -1 $-1 $14086 -2.0943951023931957 $12631 0 $11251 $14087 forward @7 unknown T -37.5 40 50 -30 45 50 #
+coedge $-1 -1 -1 $-1 $14088 $11252 $14084 $14089 reversed $12630 $-1 #
+coedge $-1 -1 -1 $-1 $11252 $14090 $11254 $12634 reversed $12630 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12629 $14091 T -30 40 35 -22.5 45 50 unknown #
+vertex $-1 -1 -1 $-1 $14092 $14093 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $12635 $11254 $14094 $14095 forward $11256 $-1 #
+edge $-1 -1 -1 $-1 $11257 -50 $14096 -37.5 $11254 $14097 forward @7 unknown T -22.5 44.330127018922191 37.5 -22.5 44.330127018922205 50 #
+coedge $-1 -1 -1 $-1 $11255 $12633 $14098 $14099 forward $11256 $-1 #
+coedge $-1 -1 -1 $-1 $14100 $12597 $12599 $11260 reversed $14049 $-1 #
+face $-1 -1 -1 $-1 $14101 $11256 $11 $-1 $14102 reversed single T -22.5 40 35 -15 45 50 F #
+point $-1 -1 -1 $-1 -22.5 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $14098 $14103 $11259 $12640 forward $14104 $-1 #
+edge $-1 -1 -1 $-1 $14105 -1.5707963267948966 $12641 6.1232339957367648e-17 $12639 $14106 forward @7 unknown T -15 40 35 -9.9999999999999982 45 40 #
+vertex $-1 -1 -1 $-1 $14107 $14108 #
+straight-curve $-1 -1 -1 $-1 -15 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14109 $11265 $11261 $12644 forward $12649 $-1 #
+edge $-1 -1 -1 $-1 $11267 -2.0943951023931948 $14105 -1.5707963267948966 $12643 $14110 forward @7 unknown T -9.9999999999999982 44.330127018922191 35 -7.5000000000000018 45 37.5 #
+face $-1 -1 -1 $-1 $14111 $14112 $11 $-1 $12646 reversed single T -15 40 20 -7.4999999999999973 45 35 F #
+cone-surface $-1 -1 -1 $-1 -9.9999999999999982 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+vertex $-1 -1 -1 $-1 $14113 $14114 #
+coedge $-1 -1 -1 $-1 $11265 $14109 $14115 $14116 reversed $12649 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12643 $14117 T -9.9999999999999982 44.330127018922191 32.5 -5 45 37.5 unknown #
+vertex $-1 -1 -1 $-1 $14116 $14118 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 44.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $11273 $11269 $14119 $14120 reversed $11274 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12604 $14121 $11271 $11277 reversed $14057 $-1 #
+face $-1 -1 -1 $-1 $14122 $14123 $11 $-1 $12658 reversed single T -9.9999999999999982 35 17.499999999999996 -5 35.669872981077816 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $14124 $14125 $11272 T 39.999999999999993 35 15.000000000000004 45.000000000000007 45 25.000000000000004 unknown #
+cone-surface $-1 -1 -1 $-1 -1.2246467991473531e-15 40 20 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $14126 $12663 $11273 $12660 reversed $14127 $-1 #
+edge $-1 -1 -1 $-1 $14128 -6.1232339957367673e-17 $11275 1.5707963267948966 $11273 $14129 forward @7 unknown T 0 40 30 5.0000000000000027 45 35 #
+point $-1 -1 -1 $-1 5.0000000000000027 45 35 #
+vertex $-1 -1 -1 $-1 $14130 $14131 #
+coedge $-1 -1 -1 $-1 $12659 $14132 $11279 $12664 reversed $14127 $-1 #
+edge $-1 -1 -1 $-1 $11275 1.5707963267948966 $12671 2.0943951023931948 $11279 $14133 forward @7 unknown T 5.0000000000000027 44.330127018922191 32.5 7.5 45 35 #
+face $-1 -1 -1 $-1 $11877 $14134 $11 $-1 $10029 reversed single T 0 35 -40 7.5000000000000018 40 -25 F #
+loop $-1 -1 -1 $-1 $-1 $14135 $11281 T 0 40 -40 7.5000000000000027 45 -25 unknown #
+coedge $-1 -1 -1 $-1 $14136 $11848 $11850 $11898 reversed $11282 $-1 #
+vertex $-1 -1 -1 $-1 $14137 $14138 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14139 $11285 $14132 $14140 forward $11293 $-1 #
+vertex $-1 -1 -1 $-1 $14140 $14141 #
+ellipse-curve $-1 -1 -1 $-1 10 40 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10549 $14142 $11 $-1 $10041 reversed single T -7.5000000000000036 35 20 8.8817841970012523e-16 40 35 F #
+coedge $-1 -1 -1 $-1 $11289 $14143 $12698 $12680 forward $11293 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 40 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12698 $12684 $11291 $12677 forward $11310 $-1 #
+edge $-1 -1 -1 $-1 $10045 -1.5707963267948966 $11296 0 $12676 $12675 forward @7 unknown T 10 35 30 15 40 35 #
+face $-1 -1 -1 $-1 $14059 $14057 $11 $-1 $8951 reversed single T -5 35 30 5.0000000000000027 40 40 F #
+coedge $-1 -1 -1 $-1 $12685 $11294 $14144 $14145 reversed $11295 $-1 #
+edge $-1 -1 -1 $-1 $14146 25 $11296 30 $12674 $14147 forward @7 unknown T 15 40 25 15.000000000000002 40 30 #
+face $-1 -1 -1 $-1 $14148 $11295 $11 $-1 $7943 reversed single T 15 40 20 22.500000000000004 45 35 F #
+point $-1 -1 -1 $-1 15 40 30 #
+vertex $-1 -1 -1 $-1 $11298 $14149 #
+coedge $-1 -1 -1 $-1 $12676 $14150 $12606 $11298 forward $11310 $-1 #
+coedge $-1 -1 -1 $-1 $11300 $12679 $14151 $14152 reversed $11295 $-1 #
+coedge $-1 -1 -1 $-1 $13340 $14153 $11896 $13350 reversed $11302 $-1 #
+coedge $-1 -1 -1 $-1 $14154 $11303 $13344 $14155 reversed $10049 $-1 #
+coedge $-1 -1 -1 $-1 $11303 $14156 $14157 $14158 reversed $10049 $-1 #
+coedge $-1 -1 -1 $-1 $14159 $14160 $14161 $12690 forward $14162 $-1 #
+edge $-1 -1 -1 $-1 $14163 -35 $14164 -30 $12689 $14165 forward @7 unknown T 15 40 -35 15.000000000000002 40 -30 #
+coedge $-1 -1 -1 $-1 $11851 $14166 $11304 $11918 forward $13298 $-1 #
+vertex $-1 -1 -1 $-1 $14167 $14168 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14151 $14169 $11307 $12695 reversed $14170 $-1 #
+edge $-1 -1 -1 $-1 $12696 4.1887902047863923 $14171 4.7123889803846897 $11307 $14172 forward @7 unknown T 22.5 44.330127018922198 20 25 45 22.5 #
+vertex $-1 -1 -1 $-1 $12695 $14173 #
+straight-curve $-1 -1 -1 $-1 22.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14174 $12676 $14062 $12680 reversed $11310 $-1 #
+coedge $-1 -1 -1 $-1 $14175 $11313 $11311 $12700 reversed $12703 $-1 #
+edge $-1 -1 -1 $-1 $14171 1.5707963267948966 $11315 3.1415926535897931 $11311 $14176 forward @7 unknown T 25 40 20 29.999999999999996 45 25 #
+coedge $-1 -1 -1 $-1 $12710 $11312 $14177 $12706 forward $10071 $-1 #
+coedge $-1 -1 -1 $-1 $11313 $14175 $14178 $14179 forward $12703 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11313 $11863 T 25 40 15 35 45 25.000000000000007 unknown #
+vertex $-1 -1 -1 $-1 $14179 $14180 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11315 3.1415926535897931 $14181 4.7123889803846897 $12701 $14176 forward @7 unknown T 25 35 20 29.999999999999996 40 25 #
+point $-1 -1 -1 $-1 29.999999999999996 40 25 #
+face $-1 -1 -1 $-1 $14182 $14183 $11 $-1 $6121 reversed single T 29.999999999999996 40 -9.9999999999999982 37.500000000000007 45 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $14184 $11317 T 29.999999999999996 40 5.0000000000000018 37.500000000000007 45 20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $11319 $12701 $14185 $14186 forward $10071 $-1 #
+coedge $-1 -1 -1 $-1 $14187 $12608 $11319 $12712 reversed $14060 $-1 #
+edge $-1 -1 -1 $-1 $14188 22.499999999999993 $10066 32.5 $11319 $14189 forward @7 unknown T 22.499999999999993 35.669872981077802 22.499999999999993 22.5 35.669872981077809 32.5 #
+coedge $-1 -1 -1 $-1 $14074 $11320 $14190 $14191 forward $12714 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11320 $14192 T 35 44.330127018922191 17.500000000000004 40.000000000000007 45 22.500000000000011 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 44.330127018922198 22.500000000000011 #
+coedge $-1 -1 -1 $-1 $11324 $13361 $14193 $14194 reversed $8958 $-1 #
+coedge $-1 -1 -1 $-1 $14195 $11856 $11324 $12719 forward $13303 $-1 #
+edge $-1 -1 -1 $-1 $11915 -37.500000000000007 $14196 -27.499999999999993 $12718 $14197 forward @7 unknown T 37.5 35.669872981077802 -37.500000000000007 37.500000000000007 35.669872981077809 -27.499999999999993 #
+coedge $-1 -1 -1 $-1 $11327 $11325 $13305 $14198 reversed $7965 $-1 #
+edge $-1 -1 -1 $-1 $13306 -2.0943951023931957 $10576 -1.5707963267948966 $11337 $14199 forward @7 unknown T 35 44.330127018922191 -40 37.5 45 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14200 $14201 $11327 $12724 forward $14202 $-1 #
+edge $-1 -1 -1 $-1 $12728 1.5707963267948966 $14203 2.0943951023931944 $12723 $14204 forward @7 unknown T 35 44.330127018922198 -27.499999999999993 37.5 45 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $14205 $11328 $14206 $14207 forward $12727 $-1 #
+coedge $-1 -1 -1 $-1 $11328 $14205 $11330 $12731 reversed $12727 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11328 $14208 T 25 40 -30 35 45 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $11329 $14209 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14210 $11330 $14211 $14212 forward $11333 $-1 #
+edge $-1 -1 -1 $-1 $11335 0 $14213 1.5707963267948961 $11330 $14214 forward @7 unknown T 25 40 -30 29.999999999999996 45 -25 #
+coedge $-1 -1 -1 $-1 $11331 $14210 $13297 $14215 forward $11333 $-1 #
+edge $-1 -1 -1 $-1 $10578 1.5707963267948966 $11334 3.1415926535897931 $11331 $13357 forward @7 unknown T 25 40 -40 30 45 -35 #
+coedge $-1 -1 -1 $-1 $11332 $14216 $14217 $14218 forward $12735 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11332 $14219 T 22.5 35 -40 30 40 -25 unknown #
+point $-1 -1 -1 $-1 30 40 -35 #
+point $-1 -1 -1 $-1 29.999999999999996 40 -30 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11370 $11341 $14220 $12786 forward $1890 $-1 #
+coedge $-1 -1 -1 $-1 $14221 $14222 $11341 $12741 reversed $14223 $-1 #
+edge $-1 -1 -1 $-1 $11392 2.617993877991494 $11376 4.7123889803846897 $11341 $14224 forward @7 unknown T -30 20 50 -22.5 25 50 #
+coedge $-1 -1 -1 $-1 $11342 $14225 $14221 $12807 forward $12743 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11381 $14226 T -22.500000000000004 20 35 -15 25 50 unknown #
+coedge $-1 -1 -1 $-1 $12745 $11343 $12765 $12831 reversed $11345 $-1 #
+coedge $-1 -1 -1 $-1 $11344 $12744 $14227 $14228 reversed $11345 $-1 #
+face $-1 -1 -1 $-1 $14229 $11345 $11 $-1 $11391 reversed single T -15 20 35 -7.4999999999999991 25 50 F #
+coedge $-1 -1 -1 $-1 $14230 $12765 $11347 $12748 reversed $11362 $-1 #
+edge $-1 -1 -1 $-1 $11407 1.5707963267948966 $11413 2.0943951023931948 $11347 $11396 forward @7 unknown T -7.5 20 35 -5 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $11348 $11351 $14231 $14232 forward $11352 $-1 #
+coedge $-1 -1 -1 $-1 $12815 $11349 $14233 $12861 forward $12751 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11349 $11423 T -5 20 30 5.0000000000000018 25 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10143 $11352 $11 $-1 $8043 reversed single T 5.0000000000000018 20 32.5 10 20.669872981077813 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $12881 $14234 T 15 20 20 22.500000000000004 25 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11355 $14235 $10150 $11425 forward $12754 $-1 #
+coedge $-1 -1 -1 $-1 $11366 $14236 $11356 $12758 forward $12772 $-1 #
+edge $-1 -1 -1 $-1 $14237 1.5707963267948966 $11368 2.0943951023931957 $12757 $14238 forward @7 unknown T 35 19.999999999999996 20.000000000000004 37.5 20.669872981077805 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $14239 $12871 $11358 $12760 forward $13379 $-1 #
+edge $-1 -1 -1 $-1 $10171 -6.4931039580273245e-16 $14237 1.5707963267948966 $12759 $14240 forward @7 unknown T 29.999999999999996 19.999999999999996 20.000000000000004 35 25 25.000000000000007 #
+loop $-1 -1 -1 $-1 $14241 $11359 $1558 T 50 20 30 50 30 40 hole $1559 T #
+vertex $-1 -1 -1 $-1 $11360 $14242 #
+ellipse-curve $-1 -1 -1 $-1 50 25 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $14243 $14244 $11361 T -45 20.000000000000004 30 -40 30.000000000000004 40 unknown #
+coedge $-1 -1 -1 $-1 $12747 $14245 $12744 $12831 forward $11362 $-1 #
+coedge $-1 -1 -1 $-1 $12819 $12819 $11363 $12767 reversed $11402 $-1 #
+edge $-1 -1 -1 $-1 $12769 1.570796326794897 $12773 4.7123889803846897 $11363 $14246 forward @7 unknown T 39.999999999999993 20 20.000000000000004 44.999999999999993 30 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $11364 $11458 $13381 $14247 reversed $11459 $-1 #
+vertex $-1 -1 -1 $-1 $14247 $14248 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14236 $11366 $14249 $14250 reversed $12772 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12757 $13378 T 35 19.999999999999996 17.500000000000007 40.000000000000007 20.669872981077809 22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $14250 $14251 #
+point $-1 -1 -1 $-1 37.5 20.669872981077802 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $14252 $14253 $11370 $12776 reversed $14254 $-1 #
+edge $-1 -1 -1 $-1 $14255 2.617993877991494 $12780 6.8067840827778854 $11370 $14256 forward @7 unknown T -45 20.000000000000004 50 -37.5 30.000000000000004 50 #
+coedge $-1 -1 -1 $-1 $14257 $11371 $14253 $14258 forward $12779 $-1 #
+coedge $-1 -1 -1 $-1 $11371 $14259 $14260 $12783 forward $12779 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12778 $14261 T -37.5 25 35 -30 30 50 unknown #
+vertex $-1 -1 -1 $-1 $11372 $14262 #
+ellipse-curve $-1 -1 -1 $-1 -35 25 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12784 $11373 $14263 $14264 reversed $11375 $-1 #
+edge $-1 -1 -1 $-1 $14265 40 $11376 50 $12778 $14266 forward @7 unknown T -30 25 40 -30 25 50 #
+coedge $-1 -1 -1 $-1 $11374 $12782 $14267 $14268 reversed $11375 $-1 #
+face $-1 -1 -1 $-1 $14269 $11375 $11 $-1 $14270 reversed single T -30 25 35 -22.5 30 50 F #
+edge $-1 -1 -1 $-1 $11376 0 $14255 2.0943951023931948 $12739 $12781 forward @7 unknown T -37.5 20 50 -30 25 50 #
+point $-1 -1 -1 $-1 -30 25 50 #
+coedge $-1 -1 -1 $-1 $14267 $14271 $11378 $12789 reversed $14272 $-1 #
+edge $-1 -1 -1 $-1 $12790 4.1887902047863905 $14273 4.7123889803846897 $11378 $14274 forward @7 unknown T -22.500000000000004 29.330127018922191 35 -20 30 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $12789 $14275 #
+straight-curve $-1 -1 -1 $-1 -22.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14276 $11384 $11380 $12793 reversed $12798 $-1 #
+edge $-1 -1 -1 $-1 $14273 1.5707963267948966 $11386 3.1415926535897931 $11380 $14277 forward @7 unknown T -20 25 35 -15 30 40 #
+coedge $-1 -1 -1 $-1 $14225 $11381 $14278 $12801 forward $12743 $-1 #
+face $-1 -1 -1 $-1 $14279 $14280 $11 $-1 $12288 reversed single T -37.5 20 35 -30 25 50 F #
+cone-surface $-1 -1 -1 $-1 -20 25 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $11384 $14276 $14281 $14282 forward $12798 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11384 $14283 T -20 25 30 -9.9999999999999982 30 40 unknown #
+vertex $-1 -1 -1 $-1 $14282 $14284 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11386 3.1415926535897931 $14285 4.7123889803846897 $12794 $14277 forward @7 unknown T -20 20 35 -15 25 40 #
+point $-1 -1 -1 $-1 -15 25 40 #
+coedge $-1 -1 -1 $-1 $11393 $11388 $14286 $14287 forward $11394 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14288 $14289 $11 $-1 $11391 reversed single T -15 25 4.9999999999999991 -7.4999999999999964 30 20 F #
+loop $-1 -1 -1 $-1 $-1 $14290 $11390 T -15 25 20 -7.4999999999999964 30 35 unknown #
+edge $-1 -1 -1 $-1 $14291 37.5 $11392 50 $12742 $14292 forward @7 unknown T -22.500000000000004 20.669872981077805 37.5 -22.5 20.669872981077805 50 #
+point $-1 -1 -1 $-1 -22.5 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $14293 $12813 $11393 $12810 forward $14294 $-1 #
+edge $-1 -1 -1 $-1 $11395 -1.5707963267948966 $14295 -1.0471975511965974 $12809 $14296 forward @7 unknown T -7.5000000000000009 29.330127018922191 32.5 -5 30 35 #
+face $-1 -1 -1 $-1 $14283 $11394 $11 $-1 $8043 reversed single T -9.9999999999999982 29.330127018922191 32.5 -5 30 37.5 F #
+point $-1 -1 -1 $-1 -5 30 35 #
+coedge $-1 -1 -1 $-1 $12809 $14297 $11398 $12814 forward $14294 $-1 #
+edge $-1 -1 -1 $-1 $12822 0 $11395 1.5707963267948966 $12813 $14298 forward @7 unknown T -5 25 30 0 30 35 #
+coedge $-1 -1 -1 $-1 $11400 $12750 $14299 $14300 reversed $12751 $-1 #
+face $-1 -1 -1 $-1 $14301 $14302 $11 $-1 $11403 reversed single T -50 20 14.999999999999996 -40 30.000000000000004 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $14303 $11401 T -9.9999999999999982 20 17.5 -5 20.669872981077809 22.500000000000004 unknown #
+loop $-1 -1 -1 $-1 $-1 $14304 $10128 T 50 20 15.000000000000004 50 30 25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $12766 $12766 $14305 $14306 reversed $11402 $-1 #
+coedge $-1 -1 -1 $-1 $14307 $11404 $14297 $14308 reversed $12821 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14307 $14309 T 0 25 20 7.5000000000000027 30 35 unknown #
+vertex $-1 -1 -1 $-1 $12814 $14310 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14311 1.0471975511965983 $11407 1.5707963267948966 $14312 $14296 forward @7 unknown T -7.4999999999999973 20 32.5 -5 20.669872981077805 35 #
+point $-1 -1 -1 $-1 -5 20 35 #
+coedge $-1 -1 -1 $-1 $11408 $14313 $11415 $12834 reversed $12821 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $14314 $11410 T 0 20 -40 7.5000000000000009 25 -25 unknown #
+coedge $-1 -1 -1 $-1 $14315 $14316 $14317 $14318 reversed $11411 $-1 #
+coedge $-1 -1 -1 $-1 $11951 $11412 $14319 $13434 reversed $10138 $-1 #
+edge $-1 -1 -1 $-1 $14320 1.5707963267948966 $11413 2.0943951023931948 $12765 $14321 forward @7 unknown T -9.9999999999999982 20 35 -7.5 20.669872981077805 37.5 #
+point $-1 -1 -1 $-1 -7.5 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $12837 $11415 $14322 $14323 forward $10149 $-1 #
+edge $-1 -1 -1 $-1 $11416 -32.5 $14324 -22.5 $11415 $14325 forward @7 unknown T 7.5 29.330127018922191 22.5 7.5000000000000027 29.330127018922202 32.5 #
+point $-1 -1 -1 $-1 7.5 29.330127018922191 32.5 #
+loop $-1 -1 -1 $-1 $-1 $14326 $11418 T -7.5000000000000009 20 20 8.8817841970012523e-16 25 35 unknown #
+coedge $-1 -1 -1 $-1 $11419 $12833 $14327 $14328 forward $10149 $-1 #
+coedge $-1 -1 -1 $-1 $14327 $14329 $11424 $12839 forward $11986 $-1 #
+edge $-1 -1 -1 $-1 $14330 -1.5707963267948966 $12840 6.1232339957367673e-17 $12838 $14331 forward @7 unknown T 15 25 20 20 30 25 #
+vertex $-1 -1 -1 $-1 $14332 $14333 #
+straight-curve $-1 -1 -1 $-1 15 25 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $14334 $14335 $11 $-1 $7081 reversed single T 14.999999999999996 25 5.0000000000000009 22.500000000000007 30 20 F #
+point $-1 -1 -1 $-1 7.5 20.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $11429 $14336 $14337 $14338 forward $10166 $-1 #
+coedge $-1 -1 -1 $-1 $14339 $11439 $11430 $12846 forward $12864 $-1 #
+edge $-1 -1 -1 $-1 $11441 -2.0943951023931953 $14330 -1.5707963267948966 $12845 $14340 forward @7 unknown T 20 29.330127018922191 20 22.5 30 22.5 #
+coedge $-1 -1 -1 $-1 $11431 $14341 $11980 $13436 reversed $10158 $-1 #
+coedge $-1 -1 -1 $-1 $14342 $11432 $12860 $14343 reversed $9029 $-1 #
+edge $-1 -1 -1 $-1 $11974 -1.5707963267948966 $12857 6.1232339957367648e-17 $11971 $14344 forward @7 unknown T 15 25 -40 20 30 -35 #
+coedge $-1 -1 -1 $-1 $11433 $14342 $14345 $14346 reversed $9029 $-1 #
+coedge $-1 -1 -1 $-1 $14347 $14348 $11433 $12852 forward $14349 $-1 #
+edge $-1 -1 -1 $-1 $12858 -6.1232339957367648e-17 $14350 1.5707963267948961 $12851 $14351 forward @7 unknown T 15 25 -30 20 30 -25 #
+coedge $-1 -1 -1 $-1 $14352 $11434 $14348 $14353 forward $12856 $-1 #
+coedge $-1 -1 -1 $-1 $11434 $14354 $13430 $14355 forward $12856 $-1 #
+coedge $-1 -1 -1 $-1 $13423 $14356 $13427 $11435 reversed $14357 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11434 $11983 T 7.5 25 -40 15 30 -25 unknown #
+vertex $-1 -1 -1 $-1 $13424 $14358 #
+vertex $-1 -1 -1 $-1 $14353 $14359 #
+coedge $-1 -1 -1 $-1 $11436 $11924 $12848 $14343 forward $11925 $-1 #
+edge $-1 -1 -1 $-1 $11437 -1.5707963267948966 $12822 -6.1232339957367648e-17 $12750 $14360 forward @7 unknown T 0 20 30 5.0000000000000018 25 35 #
+point $-1 -1 -1 $-1 5.0000000000000018 20 35 #
+coedge $-1 -1 -1 $-1 $11439 $14339 $14361 $14362 reversed $12864 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12845 $14363 T 20 29.330127018922191 17.5 25 30 22.5 unknown #
+vertex $-1 -1 -1 $-1 $14362 $14364 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.5 29.330127018922195 22.5 #
+coedge $-1 -1 -1 $-1 $14336 $11443 $14365 $14332 forward $10166 $-1 #
+coedge $-1 -1 -1 $-1 $11447 $11444 $13441 $14366 reversed $11448 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 25 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $12759 $14367 $11446 $11451 reversed $13379 $-1 #
+coedge $-1 -1 -1 $-1 $14368 $12884 $11447 $12873 reversed $11454 $-1 #
+edge $-1 -1 -1 $-1 $14369 6.4931039580273206e-16 $11449 1.5707963267948966 $11447 $14370 forward @7 unknown T 29.999999999999996 25 15 35 29.999999999999996 20.000000000000004 #
+point $-1 -1 -1 $-1 35 29.999999999999996 20.000000000000004 #
+vertex $-1 -1 -1 $-1 $14371 $14372 #
+face $-1 -1 -1 $-1 $14373 $14374 $11 $-1 $5288 reversed single T 29.999999999999996 25 -24.999999999999996 37.500000000000007 29.999999999999996 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $14375 $11453 T 29.999999999999996 25 -9.9999999999999982 37.5 29.999999999999996 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $14376 $14368 $14377 $14378 reversed $11454 $-1 #
+coedge $-1 -1 -1 $-1 $14379 $14380 $11455 $12880 reversed $14381 $-1 #
+edge $-1 -1 -1 $-1 $12875 1.5707963267948961 $12882 2.0943951023931948 $11455 $12866 forward @7 unknown T 22.499999999999993 20 19.999999999999996 25 20.669872981077805 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $14235 $11456 $14380 $14382 reversed $12754 $-1 #
+vertex $-1 -1 -1 $-1 $14382 $14383 #
+straight-curve $-1 -1 -1 $-1 22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12872 $13382 $11458 $12885 reversed $11454 $-1 #
+edge $-1 -1 -1 $-1 $11449 1.5707963267948966 $14384 2.0943951023931948 $11458 $14385 forward @7 unknown T 35 29.330127018922191 17.500000000000007 37.5 29.999999999999996 20.000000000000004 #
+face $-1 -1 -1 $-1 $14386 $11459 $11 $-1 $11403 reversed single T 35 29.330127018922187 17.500000000000007 40.000000000000007 30 22.500000000000011 F #
+coedge $-1 -1 -1 $-1 $14387 $14388 $11462 $12888 forward $14389 $-1 #
+edge $-1 -1 -1 $-1 $12890 -2.0943951023931939 $14390 -1.5707963267948966 $12887 $14391 forward @7 unknown T 35 19.999999999999996 -27.499999999999989 37.5 20.669872981077802 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $14392 $11463 $14388 $14393 forward $11930 $-1 #
+vertex $-1 -1 -1 $-1 $14393 $14394 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $12897 27.499999999999996 $11933 37.5 $11932 $14395 forward @7 unknown T 37.5 29.330127018922195 -37.5 37.5 29.330127018922198 -27.499999999999996 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14396 $11468 $13376 $14397 reversed $12896 $-1 #
+coedge $-1 -1 -1 $-1 $11468 $14396 $14398 $14399 forward $12896 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12895 $14400 T 35 29.330127018922187 -27.499999999999996 40.000000000000007 30 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $11469 $14401 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11471 $11470 $14402 $14403 reversed $11472 $-1 #
+coedge $-1 -1 -1 $-1 $14398 $14404 $11470 $12901 reversed $14374 $-1 #
+edge $-1 -1 -1 $-1 $11473 -1.5707963267948966 $14405 -6.4931039580273265e-16 $11470 $14406 forward @7 unknown T 29.999999999999996 25 -24.999999999999996 35 29.999999999999996 -19.999999999999996 #
+face $-1 -1 -1 $-1 $14407 $11472 $11 $-1 $14408 reversed single T 25 25 -30 35 30 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 29.999999999999996 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $11477 $11475 $14342 $14409 forward $10189 $-1 #
+coedge $-1 -1 -1 $-1 $14410 $14345 $11475 $12906 reversed $14411 $-1 #
+edge $-1 -1 -1 $-1 $12907 -1.5707963267948966 $14412 -1.047197551196597 $11475 $14413 forward @7 unknown T 22.5 29.330127018922191 -27.500000000000004 25 30 -25 #
+vertex $-1 -1 -1 $-1 $12906 $14414 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14415 4.1887902047863914 $9443 4.7123889803846897 $11477 $11982 forward @7 unknown T 22.500000000000004 29.330127018922195 -40 25 30 -37.5 #
+coedge $-1 -1 -1 $-1 $11479 $11980 $14416 $14417 forward $11480 $-1 #
+coedge $-1 -1 -1 $-1 $14418 $13445 $11479 $12912 reversed $14419 $-1 #
+edge $-1 -1 -1 $-1 $14420 -1.5707963267948961 $10191 0 $11479 $12908 forward @7 unknown T 25 20 -30 29.999999999999996 25 -25 #
+face $-1 -1 -1 $-1 $11969 $11480 $11 $-1 $6162 reversed single T 22.5 20 -40 30 25 -25 F #
+coedge $-1 -1 -1 $-1 $12954 $14421 $11484 $11531 reversed $12974 $-1 #
+coedge $-1 -1 -1 $-1 $14422 $11485 $11487 $11552 reversed $12917 $-1 #
+coedge $-1 -1 -1 $-1 $11485 $14423 $10229 $11528 forward $12917 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12916 $14424 T -30 5.0000000000000018 35 -22.5 10 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11487 $11539 $14425 $14426 forward $11488 $-1 #
+face $-1 -1 -1 $-1 $11556 $11488 $11 $-1 $11541 reversed single T -22.5 5 35 -15 10 50 F #
+coedge $-1 -1 -1 $-1 $14427 $12972 $11490 $12922 forward $14428 $-1 #
+edge $-1 -1 -1 $-1 $10242 6.1232339957367648e-17 $13014 1.5707963267948966 $12921 $14429 forward @7 unknown T -15 5 35 -10 10 40 #
+face $-1 -1 -1 $-1 $14430 $13453 $11 $-1 $10247 reversed single T -15 10 -50 -7.4999999999999991 15 -40 F #
+coedge $-1 -1 -1 $-1 $12939 $11492 $13006 $11569 reversed $10218 $-1 #
+coedge $-1 -1 -1 $-1 $13031 $12927 $11494 $12926 reversed $14431 $-1 #
+edge $-1 -1 -1 $-1 $10284 -2.0943951023931957 $10293 -1.5707963267948966 $11494 $14432 forward @7 unknown T 5.0000000000000009 4.9999999999999991 32.5 7.5000000000000018 5.6698729810778072 35 #
+coedge $-1 -1 -1 $-1 $12925 $14433 $11495 $11606 reversed $14431 $-1 #
+face $-1 -1 -1 $-1 $7113 $11499 $11 $-1 $6219 reversed single T 15 4.9999999999999982 20 22.500000000000004 10 35 F #
+coedge $-1 -1 -1 $-1 $11501 $11626 $13525 $14434 reversed $11499 $-1 #
+coedge $-1 -1 -1 $-1 $11502 $11516 $14435 $14436 forward $11517 $-1 #
+vertex $-1 -1 -1 $-1 $14437 $14438 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13061 $11504 $14439 $14437 forward $12006 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $14440 $14441 $1558 T 50 5 15.000000000000004 50 15 25.000000000000004 hole $1559 T #
+point $-1 -1 -1 $-1 50 10 30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $14442 $10217 T -50 5 29.999999999999996 -50 15 40 unknown #
+coedge $-1 -1 -1 $-1 $14443 $14443 $14444 $14445 forward $11509 $-1 #
+coedge $-1 -1 -1 $-1 $11510 $12924 $14446 $14447 forward $10218 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11514 -1.570796326794897 $13078 -1.0471975511965992 $12008 $14448 forward @7 unknown T 37.5 14.330127018922195 17.500000000000011 40 15 20.000000000000007 #
+point $-1 -1 -1 $-1 40 15 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $12999 $14449 $11516 $12944 forward $9465 $-1 #
+edge $-1 -1 -1 $-1 $14450 1.0471975511965992 $11518 1.570796326794897 $12943 $14448 forward @7 unknown T 37.5 5 17.500000000000011 40 5.6698729810778046 20.000000000000007 #
+point $-1 -1 -1 $-1 40 5 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $14451 $11520 $14421 $14452 reversed $12948 $-1 #
+coedge $-1 -1 -1 $-1 $11520 $14453 $11522 $12952 reversed $12948 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12947 $14454 T -45 5.0000000000000018 35 -37.499999999999993 15.000000000000002 50 unknown #
+vertex $-1 -1 -1 $-1 $14452 $14455 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $12953 $11522 $14456 $14457 forward $11524 $-1 #
+edge $-1 -1 -1 $-1 $11525 -50 $14458 -37.499999999999993 $11522 $14459 forward @7 unknown T -37.5 14.330127018922193 37.499999999999993 -37.499999999999993 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $11523 $12951 $14460 $14461 forward $11524 $-1 #
+coedge $-1 -1 -1 $-1 $14462 $12914 $12916 $11528 reversed $12974 $-1 #
+face $-1 -1 -1 $-1 $14463 $11524 $11 $-1 $10937 reversed single T -37.5 10 35 -30 15 50 F #
+point $-1 -1 -1 $-1 -37.5 14.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $14460 $14464 $11527 $12958 forward $14465 $-1 #
+edge $-1 -1 -1 $-1 $14466 -1.5707963267948966 $12959 4.1650370783741769e-16 $12957 $14467 forward @7 unknown T -30 10 35 -25 15.000000000000002 40 #
+vertex $-1 -1 -1 $-1 $14468 $14469 #
+straight-curve $-1 -1 -1 $-1 -30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14470 $11533 $11529 $12962 forward $12966 $-1 #
+edge $-1 -1 -1 $-1 $11535 -2.0943951023931957 $14466 -1.5707963267948966 $12961 $14471 forward @7 unknown T -25 14.330127018922193 35 -22.499999999999993 15.000000000000002 37.5 #
+face $-1 -1 -1 $-1 $14472 $14473 $11 $-1 $12964 reversed single T -30 10 -50 -22.5 15.000000000000002 -40 F #
+cone-surface $-1 -1 -1 $-1 -25 10.000000000000002 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $11533 $14470 $14474 $14475 reversed $12966 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12961 $14476 T -25 14.330127018922191 32.5 -20 15.000000000000002 37.5 unknown #
+vertex $-1 -1 -1 $-1 $14475 $14477 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.499999999999993 14.330127018922193 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $11542 $11537 $14478 $14479 reversed $11543 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12921 $14480 $11539 $11546 reversed $14428 $-1 #
+face $-1 -1 -1 $-1 $14481 $14482 $11 $-1 $11541 reversed single T -22.500000000000004 10 20 -15 15 35 F #
+loop $-1 -1 -1 $-1 $-1 $12954 $11540 T -37.5 5 35 -30 10 50 unknown #
+coedge $-1 -1 -1 $-1 $14483 $12980 $11542 $12976 reversed $11551 $-1 #
+edge $-1 -1 -1 $-1 $14484 -6.1232339957367648e-17 $11544 1.5707963267948966 $11542 $14485 forward @7 unknown T -15 10 30 -10 15 35 #
+face $-1 -1 -1 $-1 $14486 $11543 $11 $-1 $7181 reversed single T -20 10 30 -10 15 40 F #
+point $-1 -1 -1 $-1 -10 15 35 #
+vertex $-1 -1 -1 $-1 $14487 $14488 #
+coedge $-1 -1 -1 $-1 $12975 $14489 $11548 $12981 reversed $11551 $-1 #
+edge $-1 -1 -1 $-1 $11544 1.5707963267948966 $12989 2.0943951023931957 $11548 $14490 forward @7 unknown T -10 14.330127018922191 32.5 -7.4999999999999991 15 35 #
+face $-1 -1 -1 $-1 $14491 $14492 $11 $-1 $10247 reversed single T -15 10 -10 -7.4999999999999982 15 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $14493 $11550 T -15 10 4.9999999999999991 -7.4999999999999991 15 20 unknown #
+coedge $-1 -1 -1 $-1 $14494 $14483 $14495 $14496 reversed $11551 $-1 #
+vertex $-1 -1 -1 $-1 $14497 $14498 #
+straight-curve $-1 -1 -1 $-1 -22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14499 $11554 $14489 $14500 forward $12988 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12991 $12995 T -7.5000000000000009 10 20 8.8817841970012523e-16 15 35 unknown #
+vertex $-1 -1 -1 $-1 $14500 $14501 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11558 $14502 $13020 $13002 forward $12988 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13020 $13006 $11560 $12994 forward $11581 $-1 #
+edge $-1 -1 -1 $-1 $10263 -1.5707963267948966 $11567 0 $12993 $12992 forward @7 unknown T -5 5 30 0 10 35 #
+face $-1 -1 -1 $-1 $14503 $12988 $11 $-1 $8113 reversed single T -7.5000000000000009 10 20 8.8817841970012523e-16 15 35 F #
+loop $-1 -1 -1 $-1 $14504 $14505 $11561 T -45 5.0000000000000018 14.999999999999996 -40 15.000000000000002 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $14506 $14507 $14508 $14509 forward $11562 $-1 #
+coedge $-1 -1 -1 $-1 $12998 $12998 $14441 $14510 reversed $11563 $-1 #
+coedge $-1 -1 -1 $-1 $12008 $12943 $11564 $13000 forward $9465 $-1 #
+edge $-1 -1 -1 $-1 $11518 -1.570796326794897 $11514 1.570796326794897 $12999 $14511 forward @7 unknown T 40 5 15.000000000000004 45.000000000000007 15 20.000000000000007 #
+coedge $-1 -1 -1 $-1 $13007 $11565 $14512 $14513 reversed $11566 $-1 #
+edge $-1 -1 -1 $-1 $14514 25 $11567 30 $12991 $14515 forward @7 unknown T 0 10 25 8.8817841970012523e-16 10 30 #
+face $-1 -1 -1 $-1 $14516 $11566 $11 $-1 $8101 reversed single T 0 10 20 7.5000000000000027 15 35 F #
+point $-1 -1 -1 $-1 0 10 30 #
+vertex $-1 -1 -1 $-1 $11569 $14517 #
+coedge $-1 -1 -1 $-1 $12993 $14518 $12924 $11569 forward $11581 $-1 #
+coedge $-1 -1 -1 $-1 $11571 $13001 $14519 $14520 reversed $11566 $-1 #
+coedge $-1 -1 -1 $-1 $13498 $14521 $12042 $13508 reversed $11573 $-1 #
+coedge $-1 -1 -1 $-1 $14522 $11574 $13502 $14523 reversed $10267 $-1 #
+coedge $-1 -1 -1 $-1 $11574 $14524 $14525 $14526 reversed $10267 $-1 #
+coedge $-1 -1 -1 $-1 $14527 $14528 $14529 $13012 forward $14530 $-1 #
+edge $-1 -1 -1 $-1 $14531 -35 $14532 -30 $13011 $14533 forward @7 unknown T 0 10 -35 8.8817841970012523e-16 10 -30 #
+coedge $-1 -1 -1 $-1 $11996 $14534 $11575 $12061 forward $13457 $-1 #
+vertex $-1 -1 -1 $-1 $14535 $14536 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14519 $14537 $11578 $13017 reversed $14538 $-1 #
+edge $-1 -1 -1 $-1 $13018 4.1887902047863914 $14539 4.7123889803846897 $11578 $14540 forward @7 unknown T 7.5000000000000009 14.330127018922195 20 10 15 22.499999999999996 #
+vertex $-1 -1 -1 $-1 $13017 $14541 #
+straight-curve $-1 -1 -1 $-1 7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14542 $12993 $14433 $13002 reversed $11581 $-1 #
+coedge $-1 -1 -1 $-1 $14543 $11583 $11582 $13022 reversed $10722 $-1 #
+edge $-1 -1 -1 $-1 $14539 1.5707963267948966 $11585 3.1415926535897931 $11582 $14544 forward @7 unknown T 10 10 20 15 15 25 #
+coedge $-1 -1 -1 $-1 $11583 $14543 $14545 $14546 forward $10722 $-1 #
+vertex $-1 -1 -1 $-1 $14546 $14547 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $11585 3.1415926535897931 $14548 4.7123889803846897 $11613 $14544 forward @7 unknown T 10 5 20 15 10 25 #
+point $-1 -1 -1 $-1 15 10 25 #
+face $-1 -1 -1 $-1 $14549 $14550 $11 $-1 $6219 reversed single T 15 10 -9.9999999999999982 22.5 15 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $14551 $11587 T 14.999999999999996 10 5.0000000000000009 22.500000000000004 15 20 unknown #
+coedge $-1 -1 -1 $-1 $11589 $11613 $14552 $14553 forward $9146 $-1 #
+coedge $-1 -1 -1 $-1 $14554 $12925 $11589 $13032 reversed $14431 $-1 #
+edge $-1 -1 -1 $-1 $14555 22.500000000000004 $10284 32.5 $11589 $14556 forward @7 unknown T 7.5 5.6698729810778064 22.500000000000004 7.5000000000000018 5.6698729810778072 32.5 #
+coedge $-1 -1 -1 $-1 $11608 $11590 $14557 $14558 forward $11609 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11592 $13519 $14559 $14560 reversed $9138 $-1 #
+coedge $-1 -1 -1 $-1 $11595 $11593 $11649 $13103 reversed $8121 $-1 #
+edge $-1 -1 -1 $-1 $13109 -2.0943951023931953 $10710 -1.5707963267948966 $11605 $14561 forward @7 unknown T 20 14.330127018922191 -40 22.5 14.999999999999998 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11650 $14562 $11595 $13040 forward $13105 $-1 #
+edge $-1 -1 -1 $-1 $13044 1.570796326794897 $13106 2.0943951023931957 $13039 $14563 forward @7 unknown T 20 14.330127018922189 -27.500000000000004 22.500000000000004 14.999999999999998 -25 #
+coedge $-1 -1 -1 $-1 $14564 $11596 $14565 $14566 forward $13043 $-1 #
+coedge $-1 -1 -1 $-1 $11596 $14564 $11598 $13047 reversed $13043 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11596 $14567 T 10 10 -30 20.000000000000004 15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $11597 $14568 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14569 $11598 $14570 $14571 forward $11601 $-1 #
+edge $-1 -1 -1 $-1 $11603 0 $14572 1.5707963267948966 $11598 $14573 forward @7 unknown T 10 10 -30 15 15 -25 #
+coedge $-1 -1 -1 $-1 $11599 $14569 $13456 $14574 forward $11601 $-1 #
+edge $-1 -1 -1 $-1 $10712 1.5707963267948966 $11602 3.1415926535897931 $11599 $13515 forward @7 unknown T 10 10 -40 15 15 -35 #
+coedge $-1 -1 -1 $-1 $11600 $14575 $14576 $14577 forward $13051 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11600 $14578 T 7.5 5 -40 15 10 -25 unknown #
+point $-1 -1 -1 $-1 15 10 -35 #
+point $-1 -1 -1 $-1 15 10 -30 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14579 $12068 $11608 $13056 forward $9508 $-1 #
+edge $-1 -1 -1 $-1 $11610 -1.5707963267948966 $14580 -1.0471975511965974 $13055 $14581 forward @7 unknown T 22.5 14.330127018922191 17.5 25 15 20 #
+face $-1 -1 -1 $-1 $14582 $11609 $11 $-1 $10259 reversed single T 20 14.330127018922191 17.5 25 15 22.499999999999996 F #
+point $-1 -1 -1 $-1 25 15 20 #
+coedge $-1 -1 -1 $-1 $13525 $14583 $11613 $13026 reversed $12067 $-1 #
+edge $-1 -1 -1 $-1 $13063 0 $11610 1.5707963267948961 $12068 $14584 forward @7 unknown T 25 10 15 29.999999999999996 15 20 #
+coedge $-1 -1 -1 $-1 $11616 $12933 $13530 $14585 reversed $12006 $-1 #
+coedge $-1 -1 -1 $-1 $11623 $11617 $10723 $12071 reversed $10310 $-1 #
+vertex $-1 -1 -1 $-1 $13060 $14586 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14587 1.0471975511965979 $11620 1.5707963267948966 $14588 $14581 forward @7 unknown T 22.500000000000004 5 17.5 25 5.6698729810778072 20 #
+point $-1 -1 -1 $-1 25 5 20 #
+face $-1 -1 -1 $-1 $14589 $14590 $11 $-1 $4445 reversed single T 29.999999999999996 4.9999999999999982 -24.999999999999996 37.500000000000007 10 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $11645 $11621 T 29.999999999999996 10 -24.999999999999996 37.5 14.999999999999998 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $14591 $14592 $14593 $14594 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $12009 $11623 $14595 $14596 reversed $10310 $-1 #
+coedge $-1 -1 -1 $-1 $13527 $14597 $11623 $13072 forward $12075 $-1 #
+edge $-1 -1 -1 $-1 $14598 -1.5707963267948966 $13533 -2.9403902792268224e-16 $13071 $14599 forward @7 unknown T 29.999999999999996 10 5.0000000000000018 35 15 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $14600 $11624 $14588 $13065 reversed $13075 $-1 #
+coedge $-1 -1 -1 $-1 $11624 $14600 $11626 $13076 forward $13075 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13074 $12066 T 20 4.9999999999999982 17.5 25 5.6698729810778072 22.5 unknown #
+edge $-1 -1 -1 $-1 $14601 1.5707963267948966 $11627 2.0943951023931957 $13074 $14602 forward @7 unknown T 20 4.9999999999999982 20 22.5 5.6698729810778072 22.5 #
+point $-1 -1 -1 $-1 22.5 5.6698729810778055 22.5 #
+vertex $-1 -1 -1 $-1 $12010 $14603 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $12002 $13532 $11 $-1 $5329 reversed single T 22.5 5 4.9999999999999991 30 10 20 F #
+coedge $-1 -1 -1 $-1 $14604 $11632 $14605 $14606 forward $13083 $-1 #
+coedge $-1 -1 -1 $-1 $11632 $14604 $11634 $13087 reversed $13083 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11632 $14607 T 35 4.9999999999999982 -27.499999999999996 40.000000000000007 5.669872981077809 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $12073 $14608 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12003 $11634 $14609 $14610 forward $10666 $-1 #
+edge $-1 -1 -1 $-1 $11635 1.0471975511965992 $14611 1.570796326794897 $11634 $14612 forward @7 unknown T 37.5 5 -27.499999999999993 40 5.6698729810778046 -24.999999999999993 #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778046 -27.499999999999993 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $11640 $11639 $14613 $14614 reversed $11641 $-1 #
+edge $-1 -1 -1 $-1 $14615 -1.570796326794897 $11642 -1.0471975511965992 $12003 $14612 forward @7 unknown T 37.5 14.330127018922195 -27.499999999999989 40 15 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $14616 $11645 $11640 $13093 reversed $13068 $-1 #
+edge $-1 -1 -1 $-1 $14617 -2.0943951023931957 $10329 -1.5707963267948966 $11640 $14618 forward @7 unknown T 35 14.330127018922186 -24.999999999999996 37.5 14.999999999999998 -22.499999999999989 #
+face $-1 -1 -1 $-1 $14619 $11641 $11 $-1 $13102 reversed single T 35 14.330127018922186 -27.499999999999993 40.000000000000007 15 -22.499999999999986 F #
+point $-1 -1 -1 $-1 37.5 14.330127018922196 -27.499999999999989 #
+coedge $-1 -1 -1 $-1 $14620 $14621 $11644 $13097 forward $14622 $-1 #
+edge $-1 -1 -1 $-1 $11652 1.5707963267948966 $13099 3.1415926535897931 $13096 $14623 forward @7 unknown T 25 10 -25 29.999999999999996 15 -20 #
+coedge $-1 -1 -1 $-1 $11645 $14624 $14620 $14625 reversed $13068 $-1 #
+vertex $-1 -1 -1 $-1 $14626 $14627 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14607 $13113 $11 $-1 $13102 reversed single T 25 4.9999999999999982 -30 35 10 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 10 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $13106 27.500000000000004 $13109 37.5 $11649 $14628 forward @7 unknown T 22.5 14.330127018922191 -37.5 22.500000000000004 14.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $14562 $11650 $14621 $14629 reversed $13105 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14562 $14630 T 19.999999999999996 14.330127018922189 -27.500000000000004 25 15 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $13040 $14631 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+point $-1 -1 -1 $-1 25 15 -25 #
+vertex $-1 -1 -1 $-1 $11654 $14632 #
+coedge $-1 -1 -1 $-1 $14559 $14633 $11655 $13111 reversed $14634 $-1 #
+edge $-1 -1 -1 $-1 $13521 1.0471975511965974 $13114 1.5707963267948966 $11655 $13107 forward @7 unknown T 22.5 5 -27.500000000000004 25 5.6698729810778081 -25 #
+coedge $-1 -1 -1 $-1 $13535 $11656 $14635 $14626 reversed $13113 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12072 $13101 T 25 4.9999999999999982 -30 35 10 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $13111 $14636 #
+coedge $-1 -1 -1 $-1 $11659 $14637 $11688 $13140 forward $11716 $-1 #
+coedge $-1 -1 -1 $-1 $13117 $11660 $14638 $13185 reversed $11662 $-1 #
+coedge $-1 -1 -1 $-1 $11661 $13116 $14639 $14640 reversed $11662 $-1 #
+face $-1 -1 -1 $-1 $10382 $11662 $11 $-1 $11706 reversed single T -30 -9.9999999999999982 35 -22.5 -4.9999999999999991 50 F #
+coedge $-1 -1 -1 $-1 $14641 $14638 $11664 $13120 reversed $14642 $-1 #
+edge $-1 -1 -1 $-1 $11721 1.5707963267948966 $11727 2.0943951023931957 $11664 $11710 forward @7 unknown T -22.5 -10 35 -20 -9.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $13168 $11666 $14643 $13221 forward $13122 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11666 $13174 T -20 -10 30 -10 -4.9999999999999991 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14644 $14645 $11 $-1 $9224 reversed single T -15 -5 -40 -7.4999999999999991 8.8817841970012523e-16 -25 F #
+loop $-1 -1 -1 $-1 $-1 $13233 $14646 T -9.3734986416366059e-33 -10 20 7.5000000000000018 -4.9999999999999991 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 5 -5 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11672 $14647 $10417 $11742 forward $13125 $-1 #
+edge $-1 -1 -1 $-1 $10435 -2.9403902792268244e-16 $13260 1.5707963267948966 $12146 $14648 forward @7 unknown T 15 -10 20 20 -4.9999999999999991 25 #
+edge $-1 -1 -1 $-1 $13138 -2.0943951023931939 $11676 -1.5707963267948966 $11675 $14649 forward @7 unknown T 35 -10.000000000000002 17.500000000000011 37.499999999999993 -9.3301270189221963 20.000000000000004 #
+point $-1 -1 -1 $-1 35 -10.000000000000002 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $13131 $13131 $12281 $13724 reversed $11681 $-1 #
+coedge $-1 -1 -1 $-1 $11682 $11682 $14650 $14651 forward $10364 $-1 #
+coedge $-1 -1 -1 $-1 $14652 $14653 $11682 $13134 reversed $14654 $-1 #
+edge $-1 -1 -1 $-1 $14655 -1.5707963267948966 $14656 1.5707963267948966 $11682 $14657 forward @7 unknown T -45 -9.9999999999999964 30 -40 2.6645352591003757e-15 35 #
+coedge $-1 -1 -1 $-1 $14658 $14643 $11683 $13136 reversed $14659 $-1 #
+edge $-1 -1 -1 $-1 $11744 -2.0943951023931948 $11753 -1.5707963267948966 $11683 $14660 forward @7 unknown T -10 -10 32.5 -7.5000000000000018 -9.3301270189221928 35 #
+coedge $-1 -1 -1 $-1 $11685 $12562 $12497 $13964 forward $8452 $-1 #
+vertex $-1 -1 -1 $-1 $11686 $14661 #
+coedge $-1 -1 -1 $-1 $14650 $11688 $14662 $14663 reversed $11690 $-1 #
+edge $-1 -1 -1 $-1 $14664 37.5 $11691 50 $13115 $14665 forward @7 unknown T -37.5 -9.3301270189221928 37.5 -37.5 -9.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $11689 $14650 $14666 $14667 reversed $11690 $-1 #
+face $-1 -1 -1 $-1 $14668 $11690 $11 $-1 $14669 reversed single T -45 -9.9999999999999964 35 -37.5 2.6645352591003757e-15 50 F #
+point $-1 -1 -1 $-1 -37.5 -9.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $14666 $14670 $11693 $13145 reversed $14671 $-1 #
+edge $-1 -1 -1 $-1 $13146 4.1887902047863896 $14672 4.7123889803846897 $11693 $14673 forward @7 unknown T -37.500000000000007 -0.66987298107781079 35 -35 0 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $13145 $14674 #
+straight-curve $-1 -1 -1 $-1 -37.5 -0.66987298107780457 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14675 $11699 $11695 $13149 reversed $13153 $-1 #
+edge $-1 -1 -1 $-1 $14672 1.5707963267948966 $11701 3.1415926535897931 $11695 $14676 forward @7 unknown T -35 -4.9999999999999991 35 -30 0 40 #
+coedge $-1 -1 -1 $-1 $14637 $11696 $14677 $13156 forward $11716 $-1 #
+face $-1 -1 -1 $-1 $14678 $14679 $11 $-1 $9738 reversed single T -37.500000000000007 -5 19.999999999999993 -29.999999999999993 0 35 F #
+coedge $-1 -1 -1 $-1 $11699 $14675 $14680 $14681 forward $13153 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11699 $13169 T -35 -5 30 -25 1.7763568394002505e-15 40 unknown #
+vertex $-1 -1 -1 $-1 $14681 $14682 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11701 3.1415926535897931 $14683 4.7123889803846897 $13150 $14676 forward @7 unknown T -35 -10 35 -30 -4.9999999999999991 40 #
+point $-1 -1 -1 $-1 -30 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $11707 $11703 $14684 $14685 forward $11708 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14686 $14687 $11 $-1 $11706 reversed single T -30.000000000000007 -5 -40 -22.5 1.7763568394002505e-15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $14688 $11705 T -30 -5 -50 -22.5 1.7763568394002505e-15 -40 unknown #
+coedge $-1 -1 -1 $-1 $14689 $13166 $11707 $13163 forward $13170 $-1 #
+edge $-1 -1 -1 $-1 $11709 -1.5707963267948966 $14690 -1.0471975511965974 $13162 $14691 forward @7 unknown T -22.500000000000004 -0.66987298107780902 32.5 -20 0 35 #
+face $-1 -1 -1 $-1 $14692 $11708 $11 $-1 $6317 reversed single T -25 -0.66987298107780902 32.5 -20 1.7763568394002505e-15 37.500000000000007 F #
+point $-1 -1 -1 $-1 -20 0 35 #
+coedge $-1 -1 -1 $-1 $13162 $14693 $11712 $13167 forward $13170 $-1 #
+edge $-1 -1 -1 $-1 $13172 0 $11709 1.5707963267948966 $13166 $14694 forward @7 unknown T -20 -5 30 -15 0 35 #
+coedge $-1 -1 -1 $-1 $11714 $13121 $14695 $14696 reversed $13122 $-1 #
+face $-1 -1 -1 $-1 $14697 $13153 $11 $-1 $6317 reversed single T -35 -5 30 -25 1.7763568394002505e-15 40 F #
+loop $-1 -1 -1 $-1 $-1 $14693 $11715 T -22.500000000000004 -5 20 -15 0 35 unknown #
+coedge $-1 -1 -1 $-1 $11726 $11717 $14693 $14698 reversed $10403 $-1 #
+vertex $-1 -1 -1 $-1 $13167 $14699 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14700 $13122 $11 $-1 $6317 reversed single T -20 -10 30 -10 -4.9999999999999991 40 F #
+edge $-1 -1 -1 $-1 $14701 1.0471975511965979 $11721 1.5707963267948966 $14702 $14691 forward @7 unknown T -22.5 -10 32.5 -20 -9.330127018922191 35 #
+point $-1 -1 -1 $-1 -20 -10 35 #
+coedge $-1 -1 -1 $-1 $11722 $13182 $11729 $13188 reversed $10403 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14703 $14704 $11 $-1 $9224 reversed single T -15.000000000000004 -5 -25 -7.4999999999999991 8.8817841970012523e-16 -10 F #
+loop $-1 -1 -1 $-1 $-1 $14705 $11724 T -15 -5 -10 -7.4999999999999982 1.7763568394002505e-15 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $14706 $14707 $14708 $14709 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $13177 $11726 $14710 $14711 reversed $10403 $-1 #
+coedge $-1 -1 -1 $-1 $14712 $14713 $11726 $13184 forward $14714 $-1 #
+edge $-1 -1 -1 $-1 $14715 -1.5707963267948966 $14716 6.1232339957367648e-17 $13183 $14717 forward @7 unknown T -15 -4.9999999999999991 20 -10 8.8817841970012523e-16 25 #
+edge $-1 -1 -1 $-1 $14718 1.5707963267948966 $11727 2.0943951023931953 $14638 $14719 forward @7 unknown T -25 -9.9999999999999982 35 -22.5 -9.330127018922191 37.5 #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221928 37.5 #
+coedge $-1 -1 -1 $-1 $13190 $11729 $14720 $14721 forward $11730 $-1 #
+edge $-1 -1 -1 $-1 $11731 -32.5 $14722 -22.5 $11729 $14723 forward @7 unknown T -7.5 -0.66987298107780746 22.5 -7.4999999999999991 -0.66987298107780635 32.5 #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 32.5 #
+coedge $-1 -1 -1 $-1 $11733 $13187 $14724 $14725 forward $11730 $-1 #
+face $-1 -1 -1 $-1 $14726 $14022 $11 $-1 $9956 reversed single T 39.999999999999993 -10 2.6645352591003757e-15 50 8.8817841970012523e-16 10.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $14727 $10413 T -50 -10 14.999999999999996 -50 0 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $14728 $14728 $14729 $14730 forward $11738 $-1 #
+coedge $-1 -1 -1 $-1 $14731 $11739 $14732 $14733 reversed $10414 $-1 #
+coedge $-1 -1 -1 $-1 $11739 $14731 $14734 $14735 forward $10414 $-1 #
+coedge $-1 -1 -1 $-1 $14736 $14658 $11739 $13197 reversed $14659 $-1 #
+edge $-1 -1 -1 $-1 $14737 1.5707963267948966 $14738 2.0943951023931953 $11739 $14739 forward @7 unknown T -10 -10 20 -7.5 -9.330127018922191 22.5 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14724 $14740 $11741 $13200 forward $12138 $-1 #
+edge $-1 -1 -1 $-1 $14741 -1.5707963267948966 $13201 -1.1640334398265738e-16 $13199 $14742 forward @7 unknown T 0 -4.9999999999999991 20 5 0 25 #
+vertex $-1 -1 -1 $-1 $14743 $14744 #
+straight-curve $-1 -1 -1 $-1 0 -5 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 -9.3301270189221945 32.5 #
+coedge $-1 -1 -1 $-1 $11745 $14732 $14658 $14745 forward $10433 $-1 #
+coedge $-1 -1 -1 $-1 $14746 $11755 $11746 $13206 forward $13224 $-1 #
+edge $-1 -1 -1 $-1 $11757 -2.0943951023931948 $14741 -1.5707963267948966 $13205 $14747 forward @7 unknown T 5 -0.66987298107780635 20 7.5000000000000009 0 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $11747 $14748 $12132 $13600 reversed $10425 $-1 #
+coedge $-1 -1 -1 $-1 $14749 $11748 $13220 $14750 reversed $9243 $-1 #
+edge $-1 -1 -1 $-1 $12126 -1.5707963267948966 $13217 -1.1640334398265738e-16 $12123 $14751 forward @7 unknown T 0 -4.9999999999999991 -40 5 0 -35 #
+coedge $-1 -1 -1 $-1 $11749 $14749 $14752 $14753 reversed $9243 $-1 #
+coedge $-1 -1 -1 $-1 $14754 $14755 $11749 $13212 forward $14756 $-1 #
+edge $-1 -1 -1 $-1 $13218 -6.1232339957367648e-17 $14757 1.5707963267948961 $13211 $14758 forward @7 unknown T -9.3734986416366059e-33 -5 -30 5 0 -25 #
+coedge $-1 -1 -1 $-1 $14759 $11750 $14755 $14760 forward $13216 $-1 #
+coedge $-1 -1 -1 $-1 $11750 $14761 $13594 $14762 forward $13216 $-1 #
+coedge $-1 -1 -1 $-1 $13586 $14763 $13591 $11751 reversed $14764 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11750 $12135 T -7.5000000000000009 -5 -40 0 0 -25 unknown #
+vertex $-1 -1 -1 $-1 $13587 $14765 #
+vertex $-1 -1 -1 $-1 $14760 $14766 #
+coedge $-1 -1 -1 $-1 $11752 $12083 $13208 $14750 forward $12084 $-1 #
+edge $-1 -1 -1 $-1 $11753 -1.5707963267948966 $13172 -2.3886802389739268e-16 $13121 $14767 forward @7 unknown T -15 -10 30 -10 -5 35 #
+point $-1 -1 -1 $-1 -10 -10 35 #
+coedge $-1 -1 -1 $-1 $11755 $14746 $14768 $14769 reversed $13224 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13205 $14770 T 5 -0.66987298107780902 17.5 10 0 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $14769 $14771 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000009 -0.66987298107780624 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $14732 $11759 $14772 $14743 forward $10433 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $14773 $14774 #
+coedge $-1 -1 -1 $-1 $14775 $14776 $11763 $13232 reversed $14777 $-1 #
+edge $-1 -1 -1 $-1 $13230 1.5707963267948966 $13234 2.0943951023931957 $11763 $13226 forward @7 unknown T 7.4999999999999991 -10 20 10 -9.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $14647 $11764 $14776 $14778 reversed $13125 $-1 #
+vertex $-1 -1 -1 $-1 $14778 $14779 #
+straight-curve $-1 -1 -1 $-1 7.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12412 $12409 $11766 $13237 reversed $8743 $-1 #
+edge $-1 -1 -1 $-1 $11046 1.5707963267948966 $11207 2.0943951023931957 $11766 $14780 forward @7 unknown T 20 -0.66987298107780902 17.499999999999996 22.5 -8.8817841970012523e-16 20 #
+coedge $-1 -1 -1 $-1 $14781 $11813 $11768 $13239 forward $13273 $-1 #
+edge $-1 -1 -1 $-1 $12142 -2.0943951023931966 $14782 -1.570796326794897 $13238 $14783 forward @7 unknown T 20 -10 -27.500000000000004 22.500000000000004 -9.330127018922191 -25 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11772 $11807 $13863 $14784 forward $11808 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11775 $11774 $14785 $14786 reversed $11776 $-1 #
+edge $-1 -1 -1 $-1 $11777 -1.570796326794897 $14787 -2.9403902792268254e-16 $11774 $14788 forward @7 unknown T 15 -4.9999999999999991 -25 20.000000000000004 -8.8817841970012523e-16 -19.999999999999996 #
+face $-1 -1 -1 $-1 $14789 $11776 $11 $-1 $11805 reversed single T 10 -5 -30 20.000000000000004 0 -19.999999999999996 F #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 -25 #
+coedge $-1 -1 -1 $-1 $11781 $11779 $14749 $14790 forward $10450 $-1 #
+coedge $-1 -1 -1 $-1 $14791 $14752 $11779 $13249 reversed $14792 $-1 #
+edge $-1 -1 -1 $-1 $13250 -1.5707963267948966 $14793 -1.0471975511965979 $11779 $14794 forward @7 unknown T 7.5 -0.66987298107780813 -27.5 10 0 -25 #
+vertex $-1 -1 -1 $-1 $13249 $14795 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14796 4.1887902047863914 $9575 4.7123889803846897 $11781 $12134 forward @7 unknown T 7.5000000000000009 -0.66987298107780635 -40 10 0 -37.5 #
+coedge $-1 -1 -1 $-1 $11783 $12132 $14797 $14798 forward $11784 $-1 #
+coedge $-1 -1 -1 $-1 $14799 $13608 $11783 $13255 reversed $14800 $-1 #
+edge $-1 -1 -1 $-1 $14801 -1.5707963267948966 $10452 0 $11783 $13251 forward @7 unknown T 10 -10 -30 15 -5 -25 #
+face $-1 -1 -1 $-1 $12121 $11784 $11 $-1 $5398 reversed single T 7.4999999999999991 -10 -40 15 -4.9999999999999991 -25 F #
+face $-1 -1 -1 $-1 $10489 $14802 $11 $-1 $5398 reversed single T 7.5 -10 5.0000000000000009 15 -4.9999999999999991 20 F #
+coedge $-1 -1 -1 $-1 $11789 $13613 $14803 $14804 reversed $10797 $-1 #
+coedge $-1 -1 -1 $-1 $11791 $11790 $14805 $14806 forward $11792 $-1 #
+vertex $-1 -1 -1 $-1 $14807 $14808 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14809 $14809 $11797 $13263 reversed $14810 $-1 #
+edge $-1 -1 -1 $-1 $13264 -1.570796326794897 $13266 1.570796326794897 $11797 $14811 forward @7 unknown T 40 -10 -29.999999999999996 45.000000000000007 0 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $11798 $14812 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $11801 $14813 #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $14814 4.1887902047863905 $10483 4.7123889803846897 $12530 $14815 forward @7 unknown T 22.499999999999993 -0.66987298107780902 -25 25 0 -22.499999999999996 #
+face $-1 -1 -1 $-1 $14816 $11808 $11 $-1 $11805 reversed single T 19.999999999999996 -0.6698729810778099 -27.500000000000004 25 0 -22.499999999999996 F #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780868 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000004 -0.66987298107780902 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $11813 $14781 $13994 $14817 reversed $13273 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13238 $14818 T 19.999999999999996 -10 -27.500000000000004 25 -9.330127018922191 -22.5 unknown #
+point $-1 -1 -1 $-1 25 -10 -25 #
+coedge $-1 -1 -1 $-1 $12216 $12211 $11819 $13276 forward $12217 $-1 #
+edge $-1 -1 -1 $-1 $10501 6.1232339957367648e-17 $13282 1.5707963267948966 $13275 $14819 forward @7 unknown T -30 -25 35 -25 -20 40 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25 -15 35 #
+edge $-1 -1 -1 $-1 $11825 1.5707963267948966 $10926 2.0943951023931948 $11829 $14820 forward @7 unknown T -25 -15.669872981077809 32.5 -22.500000000000004 -15 35 #
+face $-1 -1 -1 $-1 $12164 $14821 $11 $-1 $7628 reversed single T -30.000000000000007 -25 -40 -22.5 -20 -25 F #
+face $-1 -1 -1 $-1 $12259 $12217 $11 $-1 $1965 reversed single T -35 -25 30 -25 -20 40 F #
+vertex $-1 -1 -1 $-1 $13665 $14822 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $14823 $11839 $14824 $14825 forward $11842 $-1 #
+edge $-1 -1 -1 $-1 $11844 0 $13848 1.5707963267948966 $11839 $14826 forward @7 unknown T -5 -20 -30 0 -15 -25 #
+coedge $-1 -1 -1 $-1 $11840 $14823 $13617 $14827 forward $11842 $-1 #
+edge $-1 -1 -1 $-1 $10841 1.5707963267948966 $11843 3.1415926535897931 $11840 $13637 forward @7 unknown T -5 -20 -40 0 -15 -35 #
+coedge $-1 -1 -1 $-1 $11841 $12447 $13889 $14828 forward $11076 $-1 #
+point $-1 -1 -1 $-1 0 -20 -35 #
+point $-1 -1 -1 $-1 0 -20 -30 #
+coedge $-1 -1 -1 $-1 $14829 $11847 $14830 $14831 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $13325 $14832 $11847 $11878 reversed $13339 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11850 $11893 $14833 $14834 forward $10568 $-1 #
+coedge $-1 -1 -1 $-1 $14166 $11851 $12732 $14215 reversed $13298 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12691 $14835 T 20.000000000000004 44.330127018922184 -42.500000000000007 25 45 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $11856 $11859 $11853 $13300 forward $13303 $-1 #
+edge $-1 -1 -1 $-1 $10535 1.5707963267948966 $10531 4.7123889803846897 $13299 $14836 forward @7 unknown T 40 35 -40 45 45 -35 #
+loop $-1 -1 -1 $-1 $-1 $14837 $13302 T 50 35 -45 50 45 -35 unknown #
+face $-1 -1 -1 $-1 $14838 $11854 $11 $-1 $11911 reversed single T 40 35 -45 50 45 -35 F #
+loop $-1 -1 -1 $-1 $-1 $12718 $14839 T 37.5 35 -40 45.000000000000007 45 -24.999999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 40 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $11859 $14840 $12720 $14198 forward $13303 $-1 #
+vertex $-1 -1 -1 $-1 $11860 $14841 #
+face $-1 -1 -1 $-1 $14842 $14843 $11 $-1 $12658 reversed single T 25 35 15 35 40 25.000000000000007 F #
+coedge $-1 -1 -1 $-1 $14844 $14845 $14846 $14847 forward $11864 $-1 #
+coedge $-1 -1 -1 $-1 $11865 $14848 $14849 $14850 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $14851 $14852 $11865 $13311 reversed $14853 $-1 #
+edge $-1 -1 -1 $-1 $14854 -2.0943951023931957 $13315 0 $11865 $14855 forward @7 unknown T -22.5 35 -50 -15 40 -50 #
+coedge $-1 -1 -1 $-1 $14856 $11866 $14857 $14858 forward $13314 $-1 #
+coedge $-1 -1 -1 $-1 $11866 $14859 $11868 $13318 reversed $13314 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13313 $14860 T -15 35 -50 -7.4999999999999893 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $14861 $14862 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $13319 $11868 $14863 $14864 forward $11870 $-1 #
+edge $-1 -1 -1 $-1 $11871 -50 $14865 -42.500000000000014 $11868 $14866 forward @7 unknown T -7.5000000000000027 35.669872981077809 -50 -7.4999999999999991 35.669872981077816 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $11869 $13317 $14867 $14868 forward $11870 $-1 #
+face $-1 -1 -1 $-1 $14869 $11870 $11 $-1 $10041 reversed single T -7.5000000000000107 35 -50 8.8817841970012523e-16 40 -40 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $14867 $14870 $11873 $13323 forward $14871 $-1 #
+edge $-1 -1 -1 $-1 $14872 -1.5707963267948966 $13326 -6.1232339957367648e-17 $13322 $14873 forward @7 unknown T 0 35 -45 5.0000000000000027 40 -40 #
+coedge $-1 -1 -1 $-1 $11874 $14136 $14874 $14875 reversed $11282 $-1 #
+coedge $-1 -1 -1 $-1 $14876 $13294 $11869 $11875 forward $13339 $-1 #
+vertex $-1 -1 -1 $-1 $14877 $14878 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14879 $11880 $11876 $13329 forward $13332 $-1 #
+edge $-1 -1 -1 $-1 $11882 -2.0943951023931953 $14872 -1.5707963267948966 $13328 $14880 forward @7 unknown T 5.0000000000000027 35 -42.5 7.5000000000000018 35.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $14881 $14882 #
+coedge $-1 -1 -1 $-1 $11880 $14879 $14883 $14884 reversed $13332 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13328 $14885 T 5.0000000000000027 35 -42.5 10 35.669872981077809 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $11881 $14886 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5 35.669872981077809 -42.5 #
+coedge $-1 -1 -1 $-1 $11887 $11884 $14887 $14888 reversed $11888 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14889 $14890 $11 $-1 $7955 reversed single T 7.4999999999999991 40 5.0000000000000009 15.000000000000002 45 20 F #
+loop $-1 -1 -1 $-1 $-1 $13325 $11886 T -7.5000000000000009 40 -50 8.8817841970012523e-16 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $14891 $12686 $11887 $13341 reversed $11302 $-1 #
+edge $-1 -1 -1 $-1 $14163 6.1232339957367648e-17 $11889 1.5707963267948966 $11887 $14892 forward @7 unknown T 15 35 -40 20.000000000000004 40 -35 #
+face $-1 -1 -1 $-1 $14893 $11888 $11 $-1 $11911 reversed single T 10 35 -45 20.000000000000004 40 -35 F #
+point $-1 -1 -1 $-1 20.000000000000004 35 -40 #
+coedge $-1 -1 -1 $-1 $14894 $11891 $12687 $14155 forward $13346 $-1 #
+coedge $-1 -1 -1 $-1 $11891 $14894 $11893 $11894 reversed $13346 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11891 $14893 T 10 40 -45 20.000000000000004 45 -35 unknown #
+vertex $-1 -1 -1 $-1 $11892 $14895 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $14834 $14896 #
+edge $-1 -1 -1 $-1 $11889 1.5707963267948966 $13354 2.0943951023931948 $11896 $14897 forward @7 unknown T 20.000000000000004 35 -40 22.500000000000007 35.669872981077809 -37.5 #
+vertex $-1 -1 -1 $-1 $14898 $14899 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14216 $11900 $14153 $14900 forward $12735 $-1 #
+vertex $-1 -1 -1 $-1 $14900 $14901 #
+ellipse-curve $-1 -1 -1 $-1 25 40 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14902 $14162 $11 $-1 $7955 reversed single T 7.5 40 -40 15.000000000000002 45 -25 F #
+ellipse-curve $-1 -1 -1 $-1 25 40 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14903 $14904 $11 $-1 $12658 reversed single T 10 35 15 20.000000000000004 40 25 F #
+loop $-1 -1 -1 $-1 $-1 $14144 $11906 T 10 40 15 20.000000000000004 45 25 unknown #
+coedge $-1 -1 -1 $-1 $14905 $14906 $14907 $14908 forward $11907 $-1 #
+coedge $-1 -1 -1 $-1 $12717 $11908 $14909 $14910 reversed $8958 $-1 #
+point $-1 -1 -1 $-1 37.500000000000007 35.669872981077809 -37.500000000000007 #
+face $-1 -1 -1 $-1 $14911 $14912 $11 $-1 $14913 reversed single T 25 40 1.7763568394002505e-15 35 45 10.000000000000002 F #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14914 $11920 $14915 $13397 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $14916 $13393 $11920 $13367 reversed $14917 $-1 #
+edge $-1 -1 -1 $-1 $11957 -0.52359877559829826 $11942 1.5707963267948966 $11920 $14918 forward @7 unknown T -15 25 -50 -7.4999999999999991 30 -50 #
+coedge $-1 -1 -1 $-1 $11921 $14919 $14916 $13417 forward $11966 $-1 #
+coedge $-1 -1 -1 $-1 $14920 $14319 $11923 $13370 reversed $14921 $-1 #
+edge $-1 -1 -1 $-1 $11976 -1.5707963267948966 $11978 -1.0471975511965974 $11923 $11961 forward @7 unknown T 7.4999999999999991 29.330127018922191 -42.5 10 30 -40 #
+face $-1 -1 -1 $-1 $10638 $11925 $11 $-1 $10647 reversed single T 20 29.330127018922191 -42.5 25 30 -37.5 F #
+ellipse-curve $-1 -1 -1 $-1 40 25 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13373 $13373 $14922 $14923 reversed $11928 $-1 #
+face $-1 -1 -1 $-1 $14924 $14925 $11 $-1 $10647 reversed single T -9.9999999999999982 20 -42.5 -5 20.669872981077805 -37.5 F #
+face $-1 -1 -1 $-1 $9436 $11930 $11 $-1 $6139 reversed single T 37.5 20 -40 45.000000000000007 30 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $11932 $14392 $12894 $14397 forward $11930 $-1 #
+point $-1 -1 -1 $-1 37.5 29.330127018922195 -37.5 #
+face $-1 -1 -1 $-1 $12886 $12772 $11 $-1 $11403 reversed single T 35 19.999999999999996 17.500000000000007 40.000000000000007 20.669872981077809 22.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $12759 $11934 T 25 19.999999999999996 15 35 25 25.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $14926 $11935 $14927 $14928 forward $10600 $-1 #
+coedge $-1 -1 -1 $-1 $11935 $14305 $12768 $14247 forward $10600 $-1 #
+coedge $-1 -1 -1 $-1 $12884 $14376 $11935 $13383 reversed $11454 $-1 #
+edge $-1 -1 -1 $-1 $14384 -17.500000000000007 $14929 -7.5000000000000098 $11935 $14930 forward @7 unknown T 37.5 29.330127018922191 7.5000000000000098 37.500000000000007 29.330127018922195 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $11936 $14931 $14932 $14933 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $14934 $14935 $11936 $13386 reversed $14936 $-1 #
+edge $-1 -1 -1 $-1 $14937 1.5707963267948966 $13390 3.6651914291880923 $11936 $14938 forward @7 unknown T -30 20 -50 -22.5 25 -50 #
+coedge $-1 -1 -1 $-1 $14939 $11937 $14935 $14940 forward $13389 $-1 #
+coedge $-1 -1 -1 $-1 $11937 $14941 $11939 $13394 reversed $13389 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13388 $14942 T -22.500000000000007 20 -50 -15 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $11938 $14943 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13395 $11939 $14944 $14945 reversed $11941 $-1 #
+coedge $-1 -1 -1 $-1 $13366 $14946 $14947 $13394 reversed $14917 $-1 #
+edge $-1 -1 -1 $-1 $11942 -50 $14948 -45 $14947 $14949 forward @7 unknown T -15 25 -50 -15 25 -45 #
+coedge $-1 -1 -1 $-1 $11940 $13392 $14950 $14951 reversed $11941 $-1 #
+face $-1 -1 -1 $-1 $14226 $11941 $11 $-1 $11391 reversed single T -15 20 -50 -7.4999999999999964 25 -40 F #
+edge $-1 -1 -1 $-1 $11942 0 $14952 2.0943951023931948 $13365 $13391 forward @7 unknown T -22.5 25 -50 -15 30 -50 #
+point $-1 -1 -1 $-1 -15 25 -50 #
+coedge $-1 -1 -1 $-1 $14950 $14953 $11944 $13400 reversed $14925 $-1 #
+edge $-1 -1 -1 $-1 $13401 1.0471975511965983 $14954 1.5707963267948966 $11944 $14955 forward @7 unknown T -7.4999999999999973 20 -42.5 -5 20.669872981077805 -40 #
+vertex $-1 -1 -1 $-1 $13400 $14956 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14957 $11949 $11946 $13404 reversed $13407 $-1 #
+edge $-1 -1 -1 $-1 $14954 -1.5707963267948966 $11953 0 $11946 $14958 forward @7 unknown T -5 20 -45 0 25 -40 #
+face $-1 -1 -1 $-1 $14959 $14960 $11 $-1 $14961 reversed single T -9.9999999999999982 29.330127018922184 -12.5 -5 30 -7.4999999999999947 F #
+coedge $-1 -1 -1 $-1 $11949 $14957 $14962 $14963 forward $13407 $-1 #
+loop $-1 -1 -1 $-1 $-1 $11949 $14964 T -5 20 -45 5.0000000000000018 25 -35 unknown #
+vertex $-1 -1 -1 $-1 $11950 $14965 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14966 $14967 $11951 $13411 forward $14968 $-1 #
+edge $-1 -1 -1 $-1 $11953 -6.1232339957367648e-17 $14969 1.5707963267948966 $13410 $14970 forward @7 unknown T 0 25 -45 5.0000000000000018 30 -40 #
+coedge $-1 -1 -1 $-1 $14919 $11952 $14967 $13413 forward $11966 $-1 #
+edge $-1 -1 -1 $-1 $11953 0 $14971 1.5707963267948966 $13412 $14958 forward @7 unknown T -5 25 -45 0 30 -40 #
+point $-1 -1 -1 $-1 0 25 -45 #
+coedge $-1 -1 -1 $-1 $11958 $11955 $14314 $14972 forward $11959 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14973 42.5 $11957 50 $13368 $14974 forward @7 unknown T -7.5 29.330127018922191 -50 -7.4999999999999991 29.330127018922195 -42.5 #
+point $-1 -1 -1 $-1 -7.4999999999999991 29.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $14975 $13423 $11958 $13420 forward $14357 $-1 #
+edge $-1 -1 -1 $-1 $11960 1.5707963267948966 $14976 2.0943951023931948 $13419 $14977 forward @7 unknown T 7.5 20 -40 10 20.669872981077813 -37.5 #
+face $-1 -1 -1 $-1 $14978 $11959 $11 $-1 $10647 reversed single T 5.0000000000000018 20 -42.5 10 20.669872981077813 -37.5 F #
+point $-1 -1 -1 $-1 10 20 -40 #
+coedge $-1 -1 -1 $-1 $13419 $12855 $11963 $13424 forward $14357 $-1 #
+edge $-1 -1 -1 $-1 $12857 3.1415926535897931 $11960 4.7123889803846897 $13423 $14979 forward @7 unknown T 10 20 -40 15 25 -35 #
+face $-1 -1 -1 $-1 $14980 $14981 $11 $-1 $11403 reversed single T -5 25 15 5.0000000000000018 30 25 F #
+loop $-1 -1 -1 $-1 $-1 $14982 $11965 T 7.4999999999999956 25 5.0000000000000009 15 30 20 unknown #
+coedge $-1 -1 -1 $-1 $14983 $11967 $10159 $11435 forward $10158 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13371 $11973 $11 $-1 $10647 reversed single T 10 25 -45 20 30 -35 F #
+coedge $-1 -1 -1 $-1 $11972 $11971 $12854 $14355 reversed $11973 $-1 #
+point $-1 -1 -1 $-1 20 30 -40 #
+point $-1 -1 -1 $-1 10 30 -40 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14969 1.5707963267948966 $11978 2.0943951023931953 $14319 $14984 forward @7 unknown T 5.0000000000000018 29.330127018922191 -42.5 7.5000000000000009 30 -40 #
+point $-1 -1 -1 $-1 7.5 29.330127018922191 -42.5 #
+edge $-1 -1 -1 $-1 $11981 -37.500000000000007 $14985 -27.500000000000004 $11980 $14986 forward @7 unknown T 22.5 20.669872981077805 -37.500000000000007 22.500000000000004 20.669872981077805 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.5 20.669872981077805 -37.500000000000007 #
+face $-1 -1 -1 $-1 $14987 $14988 $11 $-1 $13449 reversed single T 9.9999999999999982 25 -9.3734986416366073e-33 20 30 10 F #
+face $-1 -1 -1 $-1 $14363 $14381 $11 $-1 $11403 reversed single T 20 20 17.5 25 20.669872981077809 22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $14989 $11985 T 10 20 15 20 25 25 unknown #
+coedge $-1 -1 -1 $-1 $14361 $11987 $12869 $14366 forward $10643 $-1 #
+coedge $-1 -1 -1 $-1 $11987 $14990 $14991 $14992 forward $10643 $-1 #
+coedge $-1 -1 -1 $-1 $14993 $14994 $14995 $13444 reversed $14996 $-1 #
+edge $-1 -1 -1 $-1 $14997 10.000000000000002 $14369 15 $11987 $14998 forward @7 unknown T 29.999999999999996 25 10.000000000000002 30 25 15 #
+coedge $-1 -1 -1 $-1 $12911 $14999 $11988 $13446 forward $14419 $-1 #
+edge $-1 -1 -1 $-1 $14390 -1.5707963267948966 $10191 6.4931039580273206e-16 $13445 $15000 forward @7 unknown T 29.999999999999996 19.999999999999996 -30 35 25 -24.999999999999996 #
+face $-1 -1 -1 $-1 $15001 $15002 $11 $-1 $13449 reversed single T 24.999999999999996 19.999999999999996 1.7763568394002505e-15 35 25 10.000000000000002 F #
+loop $-1 -1 -1 $-1 $-1 $14377 $11990 T 25 25 1.7763568394002505e-15 35 30 10.000000000000002 unknown #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 25 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $15003 $11992 $15004 $15005 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $13483 $15006 $11992 $12024 reversed $15007 $-1 #
+coedge $-1 -1 -1 $-1 $15008 $11993 $11995 $12044 reversed $13453 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13452 $12923 T -15 10 -50 -7.4999999999999991 15 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $11995 $12039 $15009 $15010 forward $10702 $-1 #
+coedge $-1 -1 -1 $-1 $14534 $11996 $13048 $14574 reversed $13457 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13013 $15011 T 5.0000000000000009 14.330127018922191 -42.500000000000014 10 15 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $13458 $13458 $12000 $13459 forward $15012 $-1 #
+edge $-1 -1 -1 $-1 $15013 0 $15013 6.2831853071795862 $13458 $15014 forward @7 unknown T 50 5 -45 50 15 -35 #
+face $-1 -1 -1 $-1 $15015 $15016 $11 $-1 $9512 reversed single T -25 14.330127018922191 -42.5 -20 15.000000000000002 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $15017 $12001 T -10 5 -42.500000000000007 -5 5.6698729810778099 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $15018 $12007 $15019 $15020 forward $9465 $-1 #
+coedge $-1 -1 -1 $-1 $14595 $15021 $12007 $13464 reversed $15022 $-1 #
+edge $-1 -1 -1 $-1 $13465 4.1887902047863905 $15023 4.7123889803846897 $12007 $15024 forward @7 unknown T 37.500000000000007 14.330127018922191 5.0000000000000027 40.000000000000007 15 7.5000000000000107 #
+vertex $-1 -1 -1 $-1 $13464 $15025 #
+coedge $-1 -1 -1 $-1 $12011 $15003 $15026 $15027 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $15028 $12289 $12011 $13469 reversed $10936 $-1 #
+edge $-1 -1 -1 $-1 $15029 -2.0943951023931957 $13473 0 $12011 $15030 forward @7 unknown T -37.5 5 -50 -30 10 -50 #
+coedge $-1 -1 -1 $-1 $15031 $12012 $15032 $13732 forward $13472 $-1 #
+coedge $-1 -1 -1 $-1 $12012 $15033 $12014 $13476 reversed $13472 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13471 $15034 T -30 5.0000000000000018 -50 -22.5 10 -40 unknown #
+vertex $-1 -1 -1 $-1 $15035 $15036 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $13477 $12014 $15037 $15038 forward $12016 $-1 #
+edge $-1 -1 -1 $-1 $12017 -50 $15039 -42.5 $12014 $15040 forward @7 unknown T -22.5 5.6698729810778064 -50 -22.5 5.6698729810778081 -42.5 #
+coedge $-1 -1 -1 $-1 $12015 $13475 $15041 $15042 forward $12016 $-1 #
+face $-1 -1 -1 $-1 $15043 $12016 $11 $-1 $11541 reversed single T -22.5 5 -50 -15 10 -40 F #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $15041 $15044 $12019 $13481 forward $15045 $-1 #
+edge $-1 -1 -1 $-1 $15046 -1.5707963267948966 $13484 -6.1232339957367648e-17 $13480 $15047 forward @7 unknown T -15 5 -45 -10 10 -40 #
+coedge $-1 -1 -1 $-1 $12020 $15008 $15048 $15049 reversed $13453 $-1 #
+coedge $-1 -1 -1 $-1 $15050 $13451 $12015 $12021 forward $15007 $-1 #
+vertex $-1 -1 -1 $-1 $15051 $15052 #
+straight-curve $-1 -1 -1 $-1 -15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15017 $12026 $12022 $13487 forward $13461 $-1 #
+edge $-1 -1 -1 $-1 $12028 -2.0943951023931957 $15046 -1.5707963267948966 $13486 $15053 forward @7 unknown T -10 5 -42.500000000000007 -7.4999999999999991 5.6698729810778081 -40 #
+vertex $-1 -1 -1 $-1 $15005 $15054 #
+coedge $-1 -1 -1 $-1 $12026 $15017 $15055 $15056 reversed $13461 $-1 #
+vertex $-1 -1 -1 $-1 $12027 $15057 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $12033 $12030 $15058 $15059 reversed $12034 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15060 $15061 $11 $-1 $13497 reversed single T -20 10 -15.000000000000002 -10 15 -5 F #
+loop $-1 -1 -1 $-1 $-1 $15062 $12032 T -10 14.330127018922191 -12.5 -5 15 -7.4999999999999991 unknown #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 10 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $15063 $13008 $12033 $13499 reversed $11573 $-1 #
+edge $-1 -1 -1 $-1 $14531 6.1232339957367648e-17 $12035 1.5707963267948966 $12033 $15064 forward @7 unknown T 0 4.9999999999999991 -40 5.0000000000000009 10 -35 #
+face $-1 -1 -1 $-1 $15065 $12034 $11 $-1 $9512 reversed single T -5 4.9999999999999991 -45 5.0000000000000009 10 -35 F #
+point $-1 -1 -1 $-1 5.0000000000000009 5 -40 #
+coedge $-1 -1 -1 $-1 $15066 $12037 $13009 $14523 forward $13504 $-1 #
+coedge $-1 -1 -1 $-1 $12037 $15066 $12039 $12040 reversed $13504 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12037 $15065 T -5 10 -45 5.0000000000000009 15 -35 unknown #
+vertex $-1 -1 -1 $-1 $12038 $15067 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $15010 $15068 #
+edge $-1 -1 -1 $-1 $12035 1.5707963267948966 $13512 2.0943951023931948 $12042 $15069 forward @7 unknown T 5.0000000000000009 4.9999999999999991 -40 7.5000000000000018 5.6698729810778072 -37.5 #
+vertex $-1 -1 -1 $-1 $15070 $15071 #
+straight-curve $-1 -1 -1 $-1 -7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14575 $12046 $14521 $15072 forward $13051 $-1 #
+vertex $-1 -1 -1 $-1 $15072 $15073 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15074 $14530 $11 $-1 $8113 reversed single T -7.5 10 -40 8.8817841970012523e-16 15 -25 F #
+ellipse-curve $-1 -1 -1 $-1 10 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15075 $15076 $11 $-1 $10259 reversed single T -5 4.9999999999999991 15 5.0000000000000009 10 25 F #
+loop $-1 -1 -1 $-1 $-1 $14512 $12052 T -5 10 15 5.0000000000000009 15 25 unknown #
+coedge $-1 -1 -1 $-1 $15077 $15078 $15079 $15080 forward $12053 $-1 #
+coedge $-1 -1 -1 $-1 $13035 $12054 $15081 $15082 reversed $9138 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13111 $15083 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $15084 $15085 $11 $-1 $12076 reversed single T 10 4.9999999999999973 -4.6867493208183037e-33 20 10 10 F #
+loop $-1 -1 -1 $-1 $-1 $15086 $12065 T 9.9999999999999982 10 4.501174429623904e-32 20 15 10 unknown #
+coedge $-1 -1 -1 $-1 $15087 $13059 $12929 $14434 forward $12067 $-1 #
+coedge $-1 -1 -1 $-1 $12069 $14579 $15088 $15089 forward $9508 $-1 #
+coedge $-1 -1 -1 $-1 $15090 $13071 $12069 $13528 reversed $12075 $-1 #
+edge $-1 -1 -1 $-1 $15091 1.570796326794897 $13533 3.1415926535897931 $12069 $15092 forward @7 unknown T 25 10 5.0000000000000018 29.999999999999996 15 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $15093 $12070 $15094 $15095 forward $13532 $-1 #
+coedge $-1 -1 -1 $-1 $12070 $14588 $13061 $14585 forward $13532 $-1 #
+coedge $-1 -1 -1 $-1 $14439 $15096 $13062 $12071 forward $15097 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12070 $13080 T 22.5 5 4.9999999999999991 30 10 20 unknown #
+vertex $-1 -1 -1 $-1 $15095 $15098 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12072 $13112 $15099 $15100 forward $13113 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15101 $15102 $11 $-1 $12076 reversed single T 35 4.9999999999999973 2.5000000000000053 40.000000000000007 5.669872981077809 7.5000000000000062 F #
+loop $-1 -1 -1 $-1 $-1 $15103 $12074 T 24.999999999999996 4.9999999999999973 1.7763568394002505e-15 35 10 10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $12089 $12077 $15104 $13563 forward $1936 $-1 #
+coedge $-1 -1 -1 $-1 $14688 $13560 $12077 $13541 reversed $13161 $-1 #
+edge $-1 -1 -1 $-1 $12110 -0.52359877559829893 $12095 1.5707963267948966 $12077 $15105 forward @7 unknown T -30 -4.9999999999999991 -50 -22.5 1.7763568394002505e-15 -50 #
+coedge $-1 -1 -1 $-1 $12078 $15106 $14688 $15107 forward $13543 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12105 $15108 T -22.500000000000004 -5 -50 -15 0 -40 unknown #
+coedge $-1 -1 -1 $-1 $12104 $12079 $15109 $13598 reversed $12080 $-1 #
+coedge $-1 -1 -1 $-1 $15110 $15109 $12082 $13546 reversed $15111 $-1 #
+edge $-1 -1 -1 $-1 $12128 -1.5707963267948966 $12130 -1.0471975511965974 $12082 $12113 forward @7 unknown T -7.5000000000000009 -0.66987298107780902 -42.5 -5 0 -40 #
+face $-1 -1 -1 $-1 $10778 $12084 $11 $-1 $8499 reversed single T 5 -0.66987298107780902 -42.5 10 0 -37.5 F #
+loop $-1 -1 -1 $-1 $11506 $12085 $1558 T 50 -10 -45 50 0 -35 hole $1559 T #
+vertex $-1 -1 -1 $-1 $12086 $15112 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $8075 $15113 $11 $-1 $8499 reversed single T -50 -10 -45 -40 2.6645352591003757e-15 -35 F #
+loop $-1 -1 -1 $-1 $-1 $15114 $12087 T -25 -0.66987298107780902 -42.5 -20 1.7763568394002505e-15 -37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $12111 $12108 $15115 $15116 forward $12088 $-1 #
+coedge $-1 -1 -1 $-1 $15117 $15118 $12089 $13555 reversed $15119 $-1 #
+edge $-1 -1 -1 $-1 $15120 -0.52359877559829893 $13557 3.6651914291880923 $12089 $15121 forward @7 unknown T -45 -9.9999999999999964 -50 -37.5 2.6645352591003757e-15 -50 #
+coedge $-1 -1 -1 $-1 $13733 $12090 $15118 $15122 forward $9737 $-1 #
+vertex $-1 -1 -1 $-1 $12091 $15123 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13561 $12092 $15124 $15125 reversed $12094 $-1 #
+coedge $-1 -1 -1 $-1 $13540 $15126 $13737 $12291 reversed $13161 $-1 #
+coedge $-1 -1 -1 $-1 $12093 $13559 $15127 $15128 reversed $12094 $-1 #
+face $-1 -1 -1 $-1 $9215 $12094 $11 $-1 $11706 reversed single T -30 -9.9999999999999982 -50 -22.5 -4.9999999999999982 -40 F #
+edge $-1 -1 -1 $-1 $12095 1.7763568394002506e-16 $15120 2.0943951023931948 $13539 $13558 forward @7 unknown T -37.5 -4.9999999999999991 -50 -30 0 -50 #
+point $-1 -1 -1 $-1 -30 -4.9999999999999991 -50 #
+coedge $-1 -1 -1 $-1 $15127 $15129 $12097 $13566 reversed $15130 $-1 #
+edge $-1 -1 -1 $-1 $13567 1.047197551196597 $15131 1.5707963267948966 $12097 $15132 forward @7 unknown T -22.500000000000004 -10 -42.500000000000007 -20 -9.330127018922191 -40 #
+vertex $-1 -1 -1 $-1 $13566 $15133 #
+straight-curve $-1 -1 -1 $-1 -22.5 -9.3301270189221928 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15134 $12102 $12099 $13570 reversed $13573 $-1 #
+edge $-1 -1 -1 $-1 $15131 -1.5707963267948966 $12106 0 $12099 $15135 forward @7 unknown T -20 -10 -45 -15 -5 -40 #
+face $-1 -1 -1 $-1 $15136 $15137 $11 $-1 $10393 reversed single T -22.500000000000004 -5 -40 -15 0 -25 F #
+coedge $-1 -1 -1 $-1 $12102 $15134 $15138 $15139 forward $13573 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12102 $15140 T -20 -10 -45 -10 -4.9999999999999991 -35 unknown #
+vertex $-1 -1 -1 $-1 $12103 $15141 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $15142 $15143 $12104 $13577 forward $15144 $-1 #
+edge $-1 -1 -1 $-1 $12106 -2.3886802389739258e-16 $15145 1.5707963267948966 $13576 $15146 forward @7 unknown T -15 -5 -45 -10 8.8817841970012523e-16 -40 #
+coedge $-1 -1 -1 $-1 $15106 $12105 $15143 $13579 forward $13543 $-1 #
+edge $-1 -1 -1 $-1 $12106 0 $15147 1.5707963267948966 $13578 $15135 forward @7 unknown T -20 -5 -45 -15 0 -40 #
+point $-1 -1 -1 $-1 -15 -5 -45 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -22.5 -0.66987298107780546 -50 #
+coedge $-1 -1 -1 $-1 $15148 $13586 $12111 $13584 forward $14764 $-1 #
+edge $-1 -1 -1 $-1 $12112 1.5707963267948966 $15149 2.0943951023931957 $13583 $15150 forward @7 unknown T -7.5000000000000009 -10 -40 -5 -9.330127018922191 -37.499999999999993 #
+point $-1 -1 -1 $-1 -5 -10 -40 #
+coedge $-1 -1 -1 $-1 $13583 $13215 $12115 $13587 forward $14764 $-1 #
+edge $-1 -1 -1 $-1 $13217 3.1415926535897931 $12112 4.7123889803846897 $13586 $15151 forward @7 unknown T -5 -10 -40 0 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $15152 $15153 $11 $-1 $11179 reversed single T -20 -10 -15.000000000000002 -10 -4.9999999999999991 -5 F #
+loop $-1 -1 -1 $-1 $-1 $15154 $12117 T -20 -5 -15.000000000000002 -10 8.8817841970012523e-16 -5 unknown #
+coedge $-1 -1 -1 $-1 $15155 $15156 $15157 $15158 forward $12118 $-1 #
+coedge $-1 -1 -1 $-1 $15159 $12119 $10426 $11751 forward $10425 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13547 $12125 $11 $-1 $8499 reversed single T -5 -5 -45 5 0 -35 F #
+coedge $-1 -1 -1 $-1 $12124 $12123 $13214 $14762 reversed $12125 $-1 #
+point $-1 -1 -1 $-1 5 0 -40 #
+point $-1 -1 -1 $-1 -5 0 -40 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15145 1.5707963267948966 $12130 2.0943951023931957 $15109 $15160 forward @7 unknown T -10 -0.66987298107780746 -42.5 -7.4999999999999991 8.8817841970012523e-16 -40 #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 -42.5 #
+edge $-1 -1 -1 $-1 $12133 -37.500000000000007 $15161 -27.500000000000004 $12132 $15162 forward @7 unknown T 7.5 -9.3301270189221945 -37.500000000000007 7.5000000000000018 -9.3301270189221945 -27.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 -9.3301270189221945 -37.500000000000007 #
+face $-1 -1 -1 $-1 $15163 $15164 $11 $-1 $9956 reversed single T -5 -5 -9.3734986416366059e-33 5 8.8817841970012523e-16 10 F #
+face $-1 -1 -1 $-1 $14770 $14777 $11 $-1 $8848 reversed single T 5 -10 17.5 10 -9.330127018922191 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $15165 $12137 T -5 -10 15 5 -4.9999999999999991 25 unknown #
+coedge $-1 -1 -1 $-1 $14768 $12139 $12419 $13887 forward $10783 $-1 #
+coedge $-1 -1 -1 $-1 $12139 $15166 $12414 $13882 forward $10783 $-1 #
+coedge $-1 -1 -1 $-1 $15167 $14803 $15168 $12413 reversed $14802 $-1 #
+coedge $-1 -1 -1 $-1 $13254 $15169 $12140 $13609 forward $14800 $-1 #
+edge $-1 -1 -1 $-1 $14782 -1.5707963267948961 $10452 1.1640334398265733e-16 $13608 $15170 forward @7 unknown T 15 -10 -30 20 -5 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221945 -27.500000000000004 #
+face $-1 -1 -1 $-1 $14026 $14031 $11 $-1 $9956 reversed single T 20 -10.000000000000002 2.5000000000000044 25 -9.3301270189221928 7.5 F #
+loop $-1 -1 -1 $-1 $-1 $15171 $12144 T 10 -10.000000000000002 -4.6867493208183037e-33 20 -4.9999999999999991 10 unknown #
+coedge $-1 -1 -1 $-1 $13258 $12146 $15172 $14807 forward $10797 $-1 #
+coedge $-1 -1 -1 $-1 $12296 $12214 $12148 $12165 reversed $13662 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+face $-1 -1 -1 $-1 $15173 $12152 $11 $-1 $9321 reversed single T -22.500000000000007 -20 -50 -15 -15 -40 F #
+coedge $-1 -1 -1 $-1 $12274 $12153 $13288 $14827 reversed $12275 $-1 #
+coedge $-1 -1 -1 $-1 $12156 $12429 $12158 $13621 reversed $9673 $-1 #
+vertex $-1 -1 -1 $-1 $12215 $15174 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $12159 -50 $15175 -42.5 $12158 $15176 forward @7 unknown T -37.5 -24.330127018922195 -50 -37.5 -24.330127018922187 -42.5 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $12293 $15177 $12161 $13624 forward $13742 $-1 #
+edge $-1 -1 -1 $-1 $15178 -1.5707963267948966 $12295 -6.1232339957367648e-17 $13623 $15179 forward @7 unknown T -30 -25 -45 -25 -20 -40 #
+coedge $-1 -1 -1 $-1 $15180 $12167 $12163 $13626 forward $13628 $-1 #
+edge $-1 -1 -1 $-1 $12169 -2.0943951023931957 $15178 -1.5707963267948966 $13625 $15181 forward @7 unknown T -25 -25 -42.500000000000014 -22.5 -24.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $12167 $15180 $15182 $15183 reversed $13628 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13625 $13632 T -25 -25 -42.500000000000014 -20 -24.330127018922187 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $12168 $15184 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 -42.500000000000014 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15185 $13628 $11 $-1 $4210 reversed single T -25 -25 -42.500000000000014 -20 -24.330127018922187 -37.5 F #
+face $-1 -1 -1 $-1 $15186 $12174 $11 $-1 $4210 reversed single T -20 -25 -45 -10.000000000000002 -20 -35 F #
+coedge $-1 -1 -1 $-1 $12176 $13701 $12178 $12179 reversed $13635 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12176 $15187 T -20 -20 -45 -10.000000000000002 -15 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13920 $12186 $15188 $15189 forward $10832 $-1 #
+edge $-1 -1 -1 $-1 $13921 -2.0943951023931957 $13822 -1.5707963267948966 $12186 $15190 forward @7 unknown T -10.000000000000002 -15.669872981077809 -10 -7.5000000000000009 -15 -7.4999999999999956 #
+coedge $-1 -1 -1 $-1 $12391 $12187 $12422 $13846 reversed $9333 $-1 #
+coedge $-1 -1 -1 $-1 $12195 $15191 $13650 $15192 forward $12238 $-1 #
+vertex $-1 -1 -1 $-1 $12203 $15193 #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12587 $15194 $12197 $13645 forward $14040 $-1 #
+edge $-1 -1 -1 $-1 $13647 -2.0943951023931957 $11215 -1.5707963267948966 $13644 $15195 forward @7 unknown T -40 -15.669872981077807 4.9999999999999973 -37.5 -14.999999999999996 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $13678 $12198 $15194 $15196 forward $10890 $-1 #
+vertex $-1 -1 -1 $-1 $15196 $15197 #
+straight-curve $-1 -1 -1 $-1 -37.5 -15.669872981077805 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -37.499999999999993 -15.669872981077805 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $14037 $12202 $13641 $15192 reversed $13651 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12202 $13675 T -40 -25 2.4999999999999929 -35 -24.330127018922187 7.5000000000000009 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 4.9999999999999973 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 -15 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15198 $12354 $12247 $12207 forward $12230 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 22.500000000000007 #
+coedge $-1 -1 -1 $-1 $13890 $12212 $15199 $15200 reversed $10870 $-1 #
+coedge $-1 -1 -1 $-1 $12212 $13772 $15201 $15202 reversed $10870 $-1 #
+coedge $-1 -1 -1 $-1 $15203 $15199 $12213 $13660 forward $15204 $-1 #
+edge $-1 -1 -1 $-1 $12431 1.5707963267948966 $13663 2.0943951023931957 $13659 $15205 forward @7 unknown T -40 -15.669872981077805 -42.5 -37.5 -14.999999999999996 -40 #
+coedge $-1 -1 -1 $-1 $12214 $13747 $15203 $15206 forward $13662 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12296 $15207 T -37.5 -20 -50 -30 -15 -40 unknown #
+vertex $-1 -1 -1 $-1 $13660 $15208 #
+edge $-1 -1 -1 $-1 $13282 -1.5707963267948966 $12218 -6.1232339957367648e-17 $12216 $15209 forward @7 unknown T -30 -25 30 -25 -20 35 #
+point $-1 -1 -1 $-1 -30 -20 30 #
+coedge $-1 -1 -1 $-1 $12221 $12220 $15210 $15211 forward $12222 $-1 #
+edge $-1 -1 -1 $-1 $10969 6.1232339957367623e-17 $15212 1.5707963267948966 $12220 $15213 forward @7 unknown T -30 -25 20 -25 -20 25 #
+edge $-1 -1 -1 $-1 $10876 -1.5707963267948957 $13803 0 $12237 $15214 forward @7 unknown T -35 -25 14.999999999999996 -30.000000000000007 -20 19.999999999999996 #
+face $-1 -1 -1 $-1 $15215 $12222 $11 $-1 $1815 reversed single T -35 -25 14.999999999999996 -25 -20 25 F #
+coedge $-1 -1 -1 $-1 $12256 $12225 $12258 $13698 reversed $12227 $-1 #
+coedge $-1 -1 -1 $-1 $12226 $12256 $15216 $15217 reversed $12227 $-1 #
+face $-1 -1 -1 $-1 $11820 $12227 $11 $-1 $7628 reversed single T -30 -25 20 -22.5 -20 35 F #
+coedge $-1 -1 -1 $-1 $12231 $12236 $12234 $13677 forward $10890 $-1 #
+face $-1 -1 -1 $-1 $15218 $13651 $11 $-1 $2156 reversed single T -40 -25 2.4999999999999929 -35 -24.330127018922187 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $13787 $12233 T -37.5 -20 -10.000000000000002 -30 -15 4.9999999999999982 unknown #
+edge $-1 -1 -1 $-1 $13803 0 $10886 1.5707963267948957 $13674 $15214 forward @7 unknown T -35 -20 14.999999999999996 -30.000000000000007 -15 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $12236 $13646 $12332 $13806 forward $10890 $-1 #
+coedge $-1 -1 -1 $-1 $15191 $12237 $15219 $12331 reversed $12238 $-1 #
+face $-1 -1 -1 $-1 $15220 $12238 $11 $-1 $8642 reversed single T -37.5 -25 4.9999999999999982 -30 -20 19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $14043 $12241 $10860 $12206 reversed $13683 $-1 #
+coedge $-1 -1 -1 $-1 $12241 $15221 $15222 $12254 forward $13683 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13681 $12244 T -22.500000000000004 -25 4.9999999999999991 -15 -20 20 unknown #
+coedge $-1 -1 -1 $-1 $15222 $15216 $12243 $13685 reversed $15223 $-1 #
+edge $-1 -1 -1 $-1 $10910 1.5707963267948966 $13696 2.0943951023931957 $12243 $13691 forward @7 unknown T -22.500000000000004 -25 20 -20 -24.330127018922191 22.500000000000004 #
+face $-1 -1 -1 $-1 $13833 $13826 $11 $-1 $2156 reversed single T -10.000000000000002 -15.669872981077809 2.4999999999999964 -5 -15 7.5000000000000027 F #
+coedge $-1 -1 -1 $-1 $12248 $12351 $12245 $13688 reversed $8653 $-1 #
+edge $-1 -1 -1 $-1 $10905 1.5707963267948966 $12390 2.0943951023931957 $12245 $15224 forward @7 unknown T -10.000000000000002 -15.669872981077809 17.499999999999996 -7.5000000000000009 -15 20 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12251 $12339 $15198 $13692 reversed $12340 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12253 -1.5707963267948966 $15225 -1.047197551196597 $15198 $13695 forward @7 unknown T -22.500000000000004 -15.669872981077809 17.499999999999996 -20 -15 20 #
+point $-1 -1 -1 $-1 -20 -15 20 #
+vertex $-1 -1 -1 $-1 $12254 $15226 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $15217 $15227 #
+straight-curve $-1 -1 -1 $-1 -22.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $10916 -2.0943951023931939 $13282 -1.5707963267948966 $12258 $15228 forward @7 unknown T -25 -25 32.500000000000007 -22.500000000000004 -24.330127018922195 35 #
+coedge $-1 -1 -1 $-1 $12264 $12261 $14823 $15229 reversed $8629 $-1 #
+edge $-1 -1 -1 $-1 $15230 -2.0943951023931953 $12276 -1.5707963267948966 $12274 $15231 forward @7 unknown T -10.000000000000002 -15.669872981077809 -40 -7.5000000000000027 -15 -37.5 #
+coedge $-1 -1 -1 $-1 $13634 $12262 $12268 $13712 reversed $13635 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14824 $15232 $12264 $13704 forward $15233 $-1 #
+edge $-1 -1 -1 $-1 $13708 1.570796326794897 $15234 2.0943951023931957 $13703 $15235 forward @7 unknown T -10.000000000000002 -15.669872981077809 -27.500000000000004 -7.5000000000000009 -15 -25 #
+coedge $-1 -1 -1 $-1 $15236 $12265 $12347 $13818 forward $13707 $-1 #
+coedge $-1 -1 -1 $-1 $12265 $15236 $12267 $13711 reversed $13707 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13705 $15237 T -20 -20 -30 -10 -15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $12266 $15238 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13897 $12267 $15239 $15240 forward $12270 $-1 #
+edge $-1 -1 -1 $-1 $12272 0 $15241 1.5707963267948966 $12267 $15242 forward @7 unknown T -20 -20 -30 -15 -15 -25 #
+edge $-1 -1 -1 $-1 $12435 1.5707963267948966 $12271 3.1415926535897931 $12268 $15243 forward @7 unknown T -20 -20 -40 -15 -15 -35 #
+coedge $-1 -1 -1 $-1 $15182 $12269 $12450 $13716 forward $13715 $-1 #
+coedge $-1 -1 -1 $-1 $12269 $15244 $15245 $15246 forward $13715 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12269 $15186 T -22.500000000000004 -25 -40 -15 -20 -25 unknown #
+edge $-1 -1 -1 $-1 $12271 3.1415926535897931 $13629 4.7123889803846897 $13713 $15243 forward @7 unknown T -20 -25 -40 -15 -20 -35 #
+point $-1 -1 -1 $-1 -15 -20 -35 #
+point $-1 -1 -1 $-1 -15 -20 -30 #
+face $-1 -1 -1 $-1 $15187 $12275 $11 $-1 $4210 reversed single T -10.000000000000002 -15.669872981077811 -42.500000000000007 -5 -15 -37.5 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 -40 #
+straight-curve $-1 -1 -1 $-1 -22.5 -15.669872981077805 0 -0 -0 -1 I I #
+loop $-1 -1 -1 $-1 $15247 $15248 $3147 T -50 -10 -3.0616169978683823e-15 -50 0 9.9999999999999964 hole $3148 T #
+coedge $-1 -1 -1 $-1 $13723 $13723 $14727 $15249 forward $12280 $-1 #
+edge $-1 -1 -1 $-1 $15250 0 $15250 6.2831853071795862 $12281 $15251 forward @7 unknown T -50 -10 29.999999999999996 -50 0 40 #
+vertex $-1 -1 -1 $-1 $12282 $15252 #
+ellipse-curve $-1 -1 -1 $-1 -50 -20 -40 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -20 -30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $15253 $12286 T -37.500000000000014 35 -50 -30 40 -40 unknown #
+cone-surface $-1 -1 -1 $-1 -35 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $14932 $15254 $14934 $15255 reversed $12287 $-1 #
+coedge $-1 -1 -1 $-1 $12289 $15256 $15257 $15258 forward $10936 $-1 #
+edge $-1 -1 -1 $-1 $13473 -50 $15259 -45 $15260 $15261 forward @7 unknown T -30 10 -50 -30 10 -45 #
+coedge $-1 -1 -1 $-1 $12290 $13556 $15262 $15263 forward $9737 $-1 #
+coedge $-1 -1 -1 $-1 $15264 $15124 $12290 $13735 reversed $15265 $-1 #
+edge $-1 -1 -1 $-1 $15266 -1.5707963267948966 $13736 0 $12290 $15267 forward @7 unknown T -35 -10 -45 -30 -5 -40 #
+vertex $-1 -1 -1 $-1 $15268 $15269 #
+coedge $-1 -1 -1 $-1 $15270 $15104 $10938 $12291 forward $15271 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 -4.9999999999999991 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13893 $15272 $12292 $13740 reversed $15273 $-1 #
+edge $-1 -1 -1 $-1 $15175 1.047197551196597 $13743 1.5707963267948966 $12292 $15274 forward @7 unknown T -37.5 -25 -42.5 -35 -24.330127018922187 -40 #
+coedge $-1 -1 -1 $-1 $15177 $12293 $15275 $15276 reversed $13742 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15177 $15185 T -35 -25 -45 -25 -20 -35 unknown #
+vertex $-1 -1 -1 $-1 $13740 $15277 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12295 0 $15278 1.5707963267948966 $13747 $13744 forward @7 unknown T -35 -20 -45 -30 -15 -40 #
+point $-1 -1 -1 $-1 -30 -20 -45 #
+coedge $-1 -1 -1 $-1 $13661 $12296 $13906 $13745 forward $13662 $-1 #
+coedge $-1 -1 -1 $-1 $15279 $12298 $14037 $15280 forward $13750 $-1 #
+coedge $-1 -1 -1 $-1 $12298 $15281 $12300 $13753 forward $13750 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15282 $15283 T -37.500000000000007 -25 -10.000000000000002 -30 -20 4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $15280 $15284 #
+edge $-1 -1 -1 $-1 $15285 1.5707963267948966 $12302 2.0943951023931957 $13749 $15286 forward @7 unknown T -37.5 -25 -10.000000000000002 -35 -24.330127018922191 -7.4999999999999991 #
+face $-1 -1 -1 $-1 $13932 $12301 $11 $-1 $2664 reversed single T -40 -25 -12.500000000000005 -35 -24.330127018922191 -7.4999999999999991 F #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922195 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $15287 $12304 $12426 $13891 forward $13758 $-1 #
+coedge $-1 -1 -1 $-1 $12304 $15287 $13927 $15288 reversed $13758 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12304 $13775 T -40 -15.669872981077809 -27.500000000000004 -35 -14.999999999999996 -22.500000000000011 unknown #
+vertex $-1 -1 -1 $-1 $15288 $15289 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $13765 $12308 $15290 $15291 forward $12310 $-1 #
+edge $-1 -1 -1 $-1 $12311 1.047197551196597 $15285 1.5707963267948966 $12308 $15292 forward @7 unknown T -37.500000000000007 -25 -12.500000000000005 -35 -24.330127018922191 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $12309 $13765 $15293 $15294 forward $12310 $-1 #
+coedge $-1 -1 -1 $-1 $13764 $13762 $15295 $15296 reversed $12310 $-1 #
+face $-1 -1 -1 $-1 $15297 $12310 $11 $-1 $8642 reversed single T -37.500000000000007 -25 -25.000000000000007 -29.999999999999993 -20 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -24.330127018922195 -12.500000000000005 #
+coedge $-1 -1 -1 $-1 $15298 $15299 $12313 $13769 forward $15300 $-1 #
+edge $-1 -1 -1 $-1 $13773 1.047197551196597 $13770 1.5707963267948957 $13768 $15301 forward @7 unknown T -37.5 -25 -27.500000000000007 -35 -24.330127018922191 -25.000000000000004 #
+vertex $-1 -1 -1 $-1 $13769 $15302 #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -20 -25.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13658 $12315 $15299 $15303 reversed $10870 $-1 #
+vertex $-1 -1 -1 $-1 $13769 $15304 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15305 $13758 $11 $-1 $3328 reversed single T -40 -15.669872981077809 -27.500000000000004 -35 -14.999999999999996 -22.500000000000011 F #
+face $-1 -1 -1 $-1 $13673 $15306 $11 $-1 $7628 reversed single T -30.000000000000007 -25 4.9999999999999982 -22.5 -20 20 F #
+loop $-1 -1 -1 $-1 $-1 $15307 $12320 T -30 -25 -10.000000000000002 -22.5 -20 4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $15308 $15309 $15310 $15311 reversed $12321 $-1 #
+coedge $-1 -1 -1 $-1 $15312 $12322 $15313 $15314 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $12322 $15315 $15316 $15296 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $15317 $15318 $12322 $13782 forward $15319 $-1 #
+edge $-1 -1 -1 $-1 $15320 -1.570796326794897 $15321 6.1232339957367648e-17 $13781 $15322 forward @7 unknown T -30 -20 -25 -24.999999999999996 -15 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $15323 $12323 $15324 $15325 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $15326 $15327 $12323 $13785 forward $15328 $-1 #
+edge $-1 -1 -1 $-1 $15329 -2.0943951023931948 $13792 -1.5707963267948966 $13784 $15330 forward @7 unknown T -25 -15.669872981077807 -10.000000000000002 -22.500000000000004 -15 -7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $12324 $15323 $12333 $13807 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $15331 $15332 $15282 $13788 forward $13676 $-1 #
+edge $-1 -1 -1 $-1 $13793 -5.0000000000000018 $15333 -1.7763568394002505e-15 $13787 $15334 forward @7 unknown T -30 -20 -5.0000000000000018 -30 -20 -1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $15335 $12325 $15332 $15336 reversed $13791 $-1 #
+coedge $-1 -1 -1 $-1 $12325 $15335 $15315 $15337 forward $13791 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12325 $15338 T -35 -20 -15.000000000000004 -25 -15 -5.0000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $15337 $15339 #
+vertex $-1 -1 -1 $-1 $15340 $15341 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12330 $12327 $12339 $13812 reversed $8650 $-1 #
+coedge $-1 -1 -1 $-1 $15342 $15198 $12327 $13797 forward $12230 $-1 #
+edge $-1 -1 -1 $-1 $15225 -17.499999999999996 $13801 -7.4999999999999982 $13796 $15343 forward @7 unknown T -22.500000000000004 -15.669872981077809 7.4999999999999982 -22.499999999999993 -15.669872981077805 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $15344 $12328 $15323 $15345 forward $13800 $-1 #
+coedge $-1 -1 -1 $-1 $12328 $15344 $15342 $15346 reversed $13800 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12328 $15347 T -25 -15.669872981077809 2.4999999999999956 -20 -15 7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $15346 $15348 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13677 $15349 #
+straight-curve $-1 -1 -1 $-1 -30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12333 $12332 $15331 $15350 reversed $12334 $-1 #
+edge $-1 -1 -1 $-1 $15351 1.5707963267948966 $12336 3.1415926535897931 $13678 $15352 forward @7 unknown T -35 -20 4.9999999999999982 -30 -15 9.9999999999999982 #
+edge $-1 -1 -1 $-1 $15333 -6.1232339957367648e-17 $12335 1.5707963267948966 $12333 $15353 forward @7 unknown T -30 -20 -1.7763568394002505e-15 -25 -15 4.9999999999999982 #
+face $-1 -1 -1 $-1 $15354 $12334 $11 $-1 $2156 reversed single T -35 -20 -1.7763568394002505e-15 -25 -15 9.9999999999999982 F #
+point $-1 -1 -1 $-1 -25 -15 4.9999999999999982 #
+edge $-1 -1 -1 $-1 $12336 3.1415926535897931 $15355 4.7123889803846897 $15191 $15352 forward @7 unknown T -35 -25 4.9999999999999982 -30 -20 9.9999999999999982 #
+point $-1 -1 -1 $-1 -30 -20 9.9999999999999982 #
+edge $-1 -1 -1 $-1 $10968 1.5707963267948966 $15225 2.0943951023931953 $12339 $15356 forward @7 unknown T -25 -15.669872981077809 17.499999999999996 -22.5 -15 20 #
+face $-1 -1 -1 $-1 $13680 $12340 $11 $-1 $1815 reversed single T -25 -15.669872981077809 17.499999999999996 -20 -15 22.5 F #
+point $-1 -1 -1 $-1 -22.499999999999993 -15.669872981077805 22.499999999999993 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15357 $12347 $15232 $15358 reversed $10972 $-1 #
+edge $-1 -1 -1 $-1 $13708 -1.570796326794897 $13942 6.1232339957367648e-17 $13705 $15359 forward @7 unknown T -15.000000000000002 -20 -25 -10 -15 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $13947 $12348 $12456 $13919 reversed $9753 $-1 #
+coedge $-1 -1 -1 $-1 $15360 $12349 $13949 $15361 reversed $12185 $-1 #
+coedge $-1 -1 -1 $-1 $12349 $15360 $13940 $15362 forward $12185 $-1 #
+vertex $-1 -1 -1 $-1 $15362 $15363 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $12390 -17.499999999999996 $13827 -7.5000000000000027 $12380 $15364 forward @7 unknown T -7.5000000000000027 -15.669872981077809 7.5000000000000027 -7.5000000000000009 -15.669872981077807 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $12457 $12352 $13947 $15365 forward $13826 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12352 $13686 T -10.000000000000002 -15.669872981077809 2.4999999999999964 -5 -15 7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $12383 $15366 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12354 $15342 $12355 $13831 forward $12230 $-1 #
+coedge $-1 -1 -1 $-1 $12356 $12355 $13948 $13952 reversed $12357 $-1 #
+edge $-1 -1 -1 $-1 $15367 1.5707963267948966 $12359 3.1415926535897931 $13829 $15368 forward @7 unknown T -20 -20 4.9999999999999991 -15 -15 10 #
+edge $-1 -1 -1 $-1 $12486 -6.1232339957367648e-17 $12358 1.5707963267948966 $12356 $15369 forward @7 unknown T -15.000000000000002 -20 -1.7763568394002505e-15 -10.000000000000002 -15 4.9999999999999991 #
+face $-1 -1 -1 $-1 $14044 $12357 $11 $-1 $2156 reversed single T -20 -20 -1.7763568394002505e-15 -10.000000000000002 -15 10 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $12359 3.1415926535897931 $15370 4.7123889803846897 $14043 $15368 forward @7 unknown T -20 -25 4.9999999999999991 -15 -20 10 #
+point $-1 -1 -1 $-1 -15 -20 10 #
+coedge $-1 -1 -1 $-1 $13837 $13837 $15371 $15372 forward $12361 $-1 #
+coedge $-1 -1 -1 $-1 $13838 $13838 $12362 $13839 reversed $15373 $-1 #
+edge $-1 -1 -1 $-1 $15374 0 $15374 6.2831853071795862 $12362 $15375 forward @7 unknown T 50 -10 -14.999999999999996 50 0 -4.9999999999999964 #
+loop $-1 -1 -1 $-1 $-1 $12363 $13191 T 50 -10 2.6645352591003757e-15 50 0 10.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $12364 $15376 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 5.0000000000000027 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -5 15.000000000000004 #
+coedge $-1 -1 -1 $-1 $12368 $13889 $12425 $12375 reversed $11048 $-1 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $12370 -1.5707963267948966 $11844 -6.1232339957367648e-17 $12422 $15377 forward @7 unknown T -8.8817841970012523e-16 -25 -30 4.9999999999999991 -20 -25 #
+point $-1 -1 -1 $-1 4.9999999999999991 -25 -25 #
+vertex $-1 -1 -1 $-1 $14825 $15378 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13911 $15379 #
+edge $-1 -1 -1 $-1 $12378 -1.5707963267948966 $15380 -1.047197551196597 $12494 $11101 forward @7 unknown T -7.5000000000000036 -15.669872981077809 -12.500000000000004 -5 -15 -10 #
+point $-1 -1 -1 $-1 -5 -15 -10 #
+vertex $-1 -1 -1 $-1 $13919 $15381 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 17.499999999999996 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15382 $15383 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 -10 7.5000000000000009 8.8817841970012523e-16 5 F #
+loop $-1 -1 -1 $-1 $-1 $15384 $12399 T -9.3734986416366059e-33 -5 5 7.5000000000000018 8.8817841970012523e-16 20 unknown #
+face $-1 -1 -1 $-1 $11673 $15385 $11 $-1 $5386 reversed single T 14.999999999999996 -10.000000000000002 5.0000000000000009 22.500000000000004 -4.9999999999999991 20 F #
+loop $-1 -1 -1 $-1 $-1 $15386 $12402 T 15 -10.000000000000002 -9.9999999999999982 22.5 -4.9999999999999991 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $15387 $15388 $14781 $15389 reversed $12403 $-1 #
+coedge $-1 -1 -1 $-1 $15390 $12404 $13241 $14784 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $12404 $15391 $15392 $15393 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $15394 $12405 $12545 $14007 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $15395 $12547 $12405 $13867 forward $14006 $-1 #
+edge $-1 -1 -1 $-1 $14008 -2.0943951023931957 $13874 -1.5707963267948966 $13866 $15396 forward @7 unknown T 20 -0.6698729810778099 -9.9999999999999982 22.500000000000004 -8.8817841970012523e-16 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $12406 $15394 $12415 $13883 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $15397 $15398 $15399 $13870 forward $15400 $-1 #
+edge $-1 -1 -1 $-1 $13875 -5 $15401 8.8817841970012523e-16 $13869 $15402 forward @7 unknown T 15 -5 -5 15.000000000000004 -4.9999999999999991 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $15403 $12407 $15398 $15404 reversed $13873 $-1 #
+coedge $-1 -1 -1 $-1 $12407 $15403 $15391 $15405 forward $13873 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12407 $15406 T 10 -5 -15 20 0 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $15405 $15407 #
+vertex $-1 -1 -1 $-1 $15408 $15409 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12546 $12410 $15394 $15410 forward $12568 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13887 $15411 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12415 $12414 $15397 $15412 reversed $12145 $-1 #
+edge $-1 -1 -1 $-1 $15413 1.5707963267948966 $12417 3.1415926535897931 $13606 $15414 forward @7 unknown T 9.9999999999999982 -4.9999999999999991 5.0000000000000009 14.999999999999996 0 10 #
+edge $-1 -1 -1 $-1 $15401 1.1640334398265748e-16 $12416 1.5707963267948966 $12415 $15415 forward @7 unknown T 15 -5 1.7819122827301222e-32 20 -8.8817841970012523e-16 5.0000000000000009 #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $12417 3.1415926535897931 $15416 4.7123889803846897 $15167 $15414 forward @7 unknown T 10 -10 5.0000000000000009 14.999999999999996 -4.9999999999999991 10 #
+point $-1 -1 -1 $-1 14.999999999999996 -4.9999999999999991 10 #
+edge $-1 -1 -1 $-1 $13879 0 $13225 1.5707963267948966 $13605 $15417 forward @7 unknown T 10 -5 15 15 0 20 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13844 $12422 $13290 $14828 reversed $11048 $-1 #
+coedge $-1 -1 -1 $-1 $12426 $13657 $15418 $15419 reversed $10870 $-1 #
+edge $-1 -1 -1 $-1 $12306 1.5707963267948966 $15420 2.0943951023931957 $13756 $15421 forward @7 unknown T -40 -15.669872981077805 -27.500000000000004 -37.499999999999993 -14.999999999999996 -25.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15201 $13739 $12429 $13894 forward $15273 $-1 #
+edge $-1 -1 -1 $-1 $15175 -2.0943951023931957 $12430 -1.5707963267948966 $13893 $15422 forward @7 unknown T -40 -24.999999999999996 -42.5 -37.5 -24.330127018922187 -40 #
+point $-1 -1 -1 $-1 -40 -24.999999999999996 -40 #
+point $-1 -1 -1 $-1 -40 -14.999999999999996 -40 #
+coedge $-1 -1 -1 $-1 $12433 $13710 $12437 $13901 forward $12270 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -20 -15 -40 #
+coedge $-1 -1 -1 $-1 $15423 $12437 $15424 $15425 reversed $12439 $-1 #
+edge $-1 -1 -1 $-1 $15426 27.500000000000004 $12440 37.5 $13897 $15427 forward @7 unknown T -22.500000000000004 -15.669872981077809 -37.5 -22.499999999999993 -15.669872981077805 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $12438 $15423 $15428 $15429 reversed $12439 $-1 #
+coedge $-1 -1 -1 $-1 $15430 $12442 $12438 $13904 forward $13907 $-1 #
+edge $-1 -1 -1 $-1 $11071 -1.5707963267948966 $15431 6.1232339957367648e-17 $13903 $15432 forward @7 unknown T -30 -20 -40 -25 -15 -35 #
+point $-1 -1 -1 $-1 -22.499999999999993 -15.669872981077805 -37.5 #
+coedge $-1 -1 -1 $-1 $12442 $15430 $13747 $13745 reversed $13907 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13903 $15433 T -35 -20 -45 -25 -15 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12452 $13934 $12447 $13911 reversed $13915 $-1 #
+edge $-1 -1 -1 $-1 $12454 1.0471975511965974 $13850 1.5707963267948966 $12447 $15434 forward @7 unknown T -7.5000000000000027 -25 -27.500000000000004 -5 -24.330127018922191 -25 #
+face $-1 -1 -1 $-1 $13616 $15435 $11 $-1 $9321 reversed single T -22.500000000000004 -25 -25 -15 -20 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $15245 $13936 $12449 $13914 forward $15436 $-1 #
+edge $-1 -1 -1 $-1 $13916 -1.5707963267948961 $12272 -6.1232339957367648e-17 $13913 $15437 forward @7 unknown T -15.000000000000002 -25 -30 -10.000000000000002 -20 -25 #
+loop $-1 -1 -1 $-1 $-1 $12452 $15438 T -10.000000000000004 -25 -27.500000000000004 -5 -24.330127018922191 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $13914 $15439 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $13853 -2.4999999999999982 $13921 7.4999999999999956 $12456 $15440 forward @7 unknown T -7.5000000000000044 -15.669872981077809 -7.4999999999999956 -7.5000000000000009 -15.669872981077807 2.4999999999999982 #
+coedge $-1 -1 -1 $-1 $12458 $13638 $12494 $13851 reversed $10832 $-1 #
+vertex $-1 -1 -1 $-1 $12459 $15441 #
+coedge $-1 -1 -1 $-1 $15442 $15443 $12462 $13923 forward $13676 $-1 #
+edge $-1 -1 -1 $-1 $14041 -2.5000000000000013 $13925 7.5000000000000018 $13922 $15444 forward @7 unknown T -37.5 -15.669872981077807 -7.5000000000000018 -37.499999999999993 -15.669872981077805 2.5000000000000013 #
+coedge $-1 -1 -1 $-1 $12463 $12469 $15442 $15445 reversed $12470 $-1 #
+vertex $-1 -1 -1 $-1 $15445 $15446 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -10.000000000000002 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15447 $12467 $13757 $15288 forward $13929 $-1 #
+coedge $-1 -1 -1 $-1 $12467 $15448 $12469 $13931 forward $13929 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15316 $15449 T -37.500000000000007 -20 -25.000000000000007 -29.999999999999993 -15 -10.000000000000002 unknown #
+edge $-1 -1 -1 $-1 $15450 -1.5707963267948966 $12471 -1.0471975511965965 $13928 $15292 forward @7 unknown T -37.500000000000007 -15.669872981077811 -12.500000000000007 -35 -15 -10.000000000000002 #
+face $-1 -1 -1 $-1 $15451 $12470 $11 $-1 $2664 reversed single T -40 -15.669872981077811 -12.500000000000007 -35 -14.999999999999996 -7.4999999999999973 F #
+point $-1 -1 -1 $-1 -37.500000000000007 -15.669872981077809 -12.500000000000004 #
+coedge $-1 -1 -1 $-1 $13910 $12476 $12474 $13935 reversed $13915 $-1 #
+edge $-1 -1 -1 $-1 $13850 1.5707963267948966 $12478 2.0943951023931948 $12474 $15452 forward @7 unknown T -7.5000000000000027 -25 -25 -5 -24.330127018922195 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $13913 $15453 $12475 $13937 forward $15436 $-1 #
+edge $-1 -1 -1 $-1 $13942 6.1232339957367648e-17 $13916 1.570796326794897 $13936 $15454 forward @7 unknown T -15.000000000000002 -25 -25 -10 -20 -19.999999999999996 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -24.330127018922195 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $12480 $15188 $13821 $15362 reversed $10972 $-1 #
+coedge $-1 -1 -1 $-1 $13959 $15455 $15456 $12481 forward $15457 $-1 #
+vertex $-1 -1 -1 $-1 $15458 $15459 #
+coedge $-1 -1 -1 $-1 $15456 $15460 $12482 $13945 forward $15435 $-1 #
+edge $-1 -1 -1 $-1 $13956 -1.5707963267948961 $11118 0 $13944 $13960 forward @7 unknown T -20 -25 -15.000000000000002 -15.000000000000004 -20 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $12592 $12483 $15461 $15462 reversed $12593 $-1 #
+coedge $-1 -1 -1 $-1 $12484 $13819 $13825 $15365 reversed $9753 $-1 #
+coedge $-1 -1 -1 $-1 $15463 $12485 $13830 $13952 forward $13951 $-1 #
+coedge $-1 -1 -1 $-1 $12485 $15464 $13820 $15361 forward $13951 $-1 #
+coedge $-1 -1 -1 $-1 $12488 $15461 $9885 $11111 reversed $13955 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12485 $15220 T -22.500000000000004 -20 -10.000000000000004 -14.999999999999996 -15 4.9999999999999991 unknown #
+edge $-1 -1 -1 $-1 $12486 0 $15367 1.5707963267948966 $13948 $15465 forward @7 unknown T -20 -20 -8.8817841970012523e-16 -15 -15 4.9999999999999991 #
+point $-1 -1 -1 $-1 -15 -20 -8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $15466 $12488 $15467 $15468 forward $13955 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13950 $15469 T -22.500000000000004 -25 -10.000000000000004 -14.999999999999996 -20 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $15470 $15471 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 -20 -10.000000000000002 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $15472 $15473 #
+coedge $-1 -1 -1 $-1 $15474 $13941 $15360 $12492 forward $15457 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20.000000000000004 -20 -10.000000000000002 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12495 $12494 $15357 $15475 forward $11031 $-1 #
+coedge $-1 -1 -1 $-1 $15232 $14824 $12495 $13963 reversed $15233 $-1 #
+edge $-1 -1 -1 $-1 $15476 4.1887902047863905 $13848 4.7123889803846897 $12495 $15452 forward @7 unknown T -7.5000000000000027 -15.669872981077809 -25 -5 -15 -22.499999999999996 #
+edge $-1 -1 -1 $-1 $13968 7.500000000000008 $13138 17.500000000000011 $13137 $15477 forward @7 unknown T 37.499999999999993 -9.3301270189221963 7.500000000000008 37.500000000000007 -9.3301270189221928 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $15478 $12498 $12562 $14021 reversed $12580 $-1 #
+coedge $-1 -1 -1 $-1 $12498 $15478 $12502 $13973 forward $12580 $-1 #
+vertex $-1 -1 -1 $-1 $14015 $15479 #
+vertex $-1 -1 -1 $-1 $12499 $15480 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13996 $12500 $12511 $13981 forward $13971 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12500 $15481 T 24.999999999999996 -10.000000000000002 -15 35 -4.9999999999999991 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13976 -2.0943951023931939 $13967 -1.5707963267948966 $13966 $15482 forward @7 unknown T 35 -10.000000000000004 2.5000000000000071 37.499999999999993 -9.3301270189221945 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $12537 $12503 $15478 $15483 forward $11158 $-1 #
+coedge $-1 -1 -1 $-1 $12503 $12536 $12505 $13979 forward $11158 $-1 #
+vertex $-1 -1 -1 $-1 $15483 $15484 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $12506 $12505 $12514 $13986 reversed $12507 $-1 #
+edge $-1 -1 -1 $-1 $15485 1.5707963267948966 $12509 2.0943951023931948 $13975 $12543 forward @7 unknown T 37.5 -10 -9.9999999999999982 40 -9.3301270189221945 -7.4999999999999982 #
+face $-1 -1 -1 $-1 $15481 $12507 $11 $-1 $11179 reversed single T 35 -10.000000000000002 -12.5 40 -9.3301270189221928 -7.4999999999999964 F #
+edge $-1 -1 -1 $-1 $12508 -1.5707963267948966 $11151 2.9403902792268244e-16 $13970 $15486 forward @7 unknown T 30 -10.000000000000002 -15 35 -5 -9.9999999999999982 #
+point $-1 -1 -1 $-1 35 -10.000000000000002 -9.9999999999999982 #
+point $-1 -1 -1 $-1 37.500000000000007 -9.3301270189221945 -7.4999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12524 $12514 $15487 $15488 forward $12516 $-1 #
+edge $-1 -1 -1 $-1 $12517 1.0471975511965983 $15485 1.5707963267948966 $12514 $14003 forward @7 unknown T 37.5 -10 -12.499999999999996 40 -9.3301270189221945 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $12515 $12523 $14809 $15489 forward $12516 $-1 #
+face $-1 -1 -1 $-1 $9530 $12516 $11 $-1 $4463 reversed single T 37.5 -10 -24.999999999999996 45 0 -9.9999999999999982 F #
+point $-1 -1 -1 $-1 37.500000000000007 -9.3301270189221945 -12.499999999999996 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 -0.66987298107780768 -12.5 #
+coedge $-1 -1 -1 $-1 $12530 $12529 $15390 $15490 forward $11150 $-1 #
+coedge $-1 -1 -1 $-1 $12547 $15395 $12529 $12558 reversed $14006 $-1 #
+coedge $-1 -1 -1 $-1 $15491 $12531 $13272 $14817 forward $12533 $-1 #
+coedge $-1 -1 -1 $-1 $12532 $15491 $15492 $12560 forward $12533 $-1 #
+coedge $-1 -1 -1 $-1 $12550 $13970 $12532 $13997 reversed $13971 $-1 #
+edge $-1 -1 -1 $-1 $11180 -1.5707963267948966 $11151 0 $12532 $12557 forward @7 unknown T 25 -10 -14.999999999999998 30 -5 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $13988 $12533 $11 $-1 $4486 reversed single T 22.5 -10 -25.000000000000004 30 -4.9999999999999991 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $15487 $15487 $12536 $14000 reversed $15493 $-1 #
+edge $-1 -1 -1 $-1 $12542 1.5707963267948966 $15485 4.7123889803846897 $12536 $15494 forward @7 unknown T 40 -10 -9.9999999999999982 45 0 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $12563 $12563 $12537 $14002 reversed $14022 $-1 #
+edge $-1 -1 -1 $-1 $14023 -1.570796326794897 $11186 1.570796326794897 $12537 $15495 forward @7 unknown T 40 -10 2.6645352591003757e-15 45.000000000000007 8.8817841970012523e-16 5.0000000000000044 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -9.9999999999999982 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 40 0 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $15496 $15497 $11 $-1 $11179 reversed single T 5 -0.66987298107780902 -12.5 10 0 -7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $15395 $12544 T 20 -0.6698729810778099 -12.499999999999996 25 8.8817841970012523e-16 -7.4999999999999964 unknown #
+edge $-1 -1 -1 $-1 $12578 -2.5000000000000036 $14008 7.4999999999999964 $12545 $15498 forward @7 unknown T 22.5 -0.66987298107780768 -7.4999999999999964 22.500000000000004 -0.66987298107780635 2.5000000000000036 #
+vertex $-1 -1 -1 $-1 $12548 $15499 #
+ellipse-curve $-1 -1 -1 $-1 25 -5 -9.9999999999999982 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12551 $12549 $15500 $15501 forward $11171 $-1 #
+coedge $-1 -1 -1 $-1 $15492 $15502 $12549 $14012 reversed $14017 $-1 #
+edge $-1 -1 -1 $-1 $11180 1.5707963267948966 $15503 2.0943951023931948 $12549 $14009 forward @7 unknown T 22.5 -10 -9.9999999999999982 25 -9.3301270189221945 -7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $15504 $12572 $12551 $11203 reversed $14031 $-1 #
+coedge $-1 -1 -1 $-1 $12552 $12574 $12554 $14015 forward $11202 $-1 #
+edge $-1 -1 -1 $-1 $13967 -1.5707963267948966 $9926 2.9403902792268224e-16 $14014 $15505 forward @7 unknown T 29.999999999999996 -10.000000000000002 1.7763568394002505e-15 35 -5 5.0000000000000018 #
+face $-1 -1 -1 $-1 $15406 $15506 $11 $-1 $11179 reversed single T 10 -10 -15 20 -4.9999999999999991 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $15507 $12556 T 20 -10 -12.499999999999996 25 -9.3301270189221928 -7.4999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $15508 $15509 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 -9.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $12560 $15510 #
+edge $-1 -1 -1 $-1 $14023 1.570796326794897 $13968 2.0943951023931957 $12562 $11187 forward @7 unknown T 37.500000000000007 -10 5.0000000000000027 40.000000000000007 -9.3301270189221928 7.500000000000008 #
+loop $-1 -1 -1 $-1 $13840 $14001 $13191 T 39.999999999999993 -10 2.6645352591003757e-15 45.000000000000007 8.8817841970012523e-16 10.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $15483 $15511 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $13245 $12568 $11 $-1 $9956 reversed single T 20 -0.66987298107780768 2.5000000000000036 25 0 7.5000000000000009 F #
+point $-1 -1 -1 $-1 22.499999999999996 -0.66987298107780624 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $15512 $14805 $12571 $14029 reversed $15385 $-1 #
+edge $-1 -1 -1 $-1 $14032 7.5 $11209 17.5 $12571 $15513 forward @7 unknown T 22.499999999999996 -9.3301270189221945 7.5 22.500000000000004 -9.3301270189221928 17.5 #
+coedge $-1 -1 -1 $-1 $12572 $15504 $15512 $15514 forward $14031 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14030 $13611 T 20 -10.000000000000002 2.5000000000000044 25 -9.3301270189221928 7.5 unknown #
+vertex $-1 -1 -1 $-1 $15514 $15515 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780768 2.5000000000000036 #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221945 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $12585 $13650 $13748 $15280 reversed $13651 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 4.9999999999999973 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $15194 $12587 $15443 $15516 reversed $14040 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13644 $15218 T -40 -15.669872981077809 2.4999999999999987 -35 -14.999999999999996 7.5 unknown #
+vertex $-1 -1 -1 $-1 $13923 $15517 #
+coedge $-1 -1 -1 $-1 $15518 $13681 $12592 $13835 forward $13683 $-1 #
+face $-1 -1 -1 $-1 $15469 $12593 $11 $-1 $2156 reversed single T -20 -25 -1.7763568394002505e-15 -10.000000000000002 -20 10 F #
+coedge $-1 -1 -1 $-1 $12625 $12596 $15519 $14092 forward $2321 $-1 #
+coedge $-1 -1 -1 $-1 $15520 $15521 $12596 $14047 reversed $15522 $-1 #
+edge $-1 -1 -1 $-1 $12647 2.6179938779914949 $12631 4.7123889803846897 $12596 $15523 forward @7 unknown T -30 35 50 -22.5 40 50 #
+coedge $-1 -1 -1 $-1 $12597 $15524 $15520 $14113 forward $14049 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12636 $15525 T -22.5 35 35 -15 40 50 unknown #
+coedge $-1 -1 -1 $-1 $14051 $12598 $14071 $14137 reversed $12600 $-1 #
+coedge $-1 -1 -1 $-1 $12599 $14050 $15526 $15527 reversed $12600 $-1 #
+face $-1 -1 -1 $-1 $15528 $12600 $11 $-1 $12646 reversed single T -15 35 35 -7.4999999999999973 40 50 F #
+coedge $-1 -1 -1 $-1 $15529 $14071 $12602 $14054 reversed $12617 $-1 #
+edge $-1 -1 -1 $-1 $12662 1.5707963267948966 $12668 2.0943951023931957 $12602 $12651 forward @7 unknown T -7.5000000000000009 35 35 -5 35.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $12603 $12606 $15530 $15531 forward $12607 $-1 #
+coedge $-1 -1 -1 $-1 $14121 $12604 $15532 $14167 forward $14057 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12604 $12678 T -5 35 30 5.0000000000000027 40 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11287 $12607 $11 $-1 $8951 reversed single T 5.0000000000000027 35 32.5 10 35.669872981077809 37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $14187 $15533 T 15 35 20 22.5 40 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12610 $15534 $11294 $12680 forward $14060 $-1 #
+coedge $-1 -1 -1 $-1 $12621 $15535 $12611 $14064 forward $14078 $-1 #
+edge $-1 -1 -1 $-1 $15536 1.5707963267948966 $12623 2.0943951023931984 $14063 $15537 forward @7 unknown T 35 35 20.000000000000004 37.500000000000014 35.669872981077816 22.500000000000014 #
+coedge $-1 -1 -1 $-1 $15538 $14177 $12613 $14066 forward $14843 $-1 #
+edge $-1 -1 -1 $-1 $11315 6.1232339957367623e-17 $15536 1.5707963267948966 $14065 $15539 forward @7 unknown T 29.999999999999996 35 20.000000000000004 35 40 25.000000000000007 #
+loop $-1 -1 -1 $-1 $15540 $12614 $1558 T 50 35 30 50 45 40 hole $1559 T #
+vertex $-1 -1 -1 $-1 $12615 $15541 #
+ellipse-curve $-1 -1 -1 $-1 50 40 35 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $15542 $15543 $12616 T -45 35 30 -40 45 40 unknown #
+coedge $-1 -1 -1 $-1 $14053 $15544 $14050 $14137 forward $12617 $-1 #
+coedge $-1 -1 -1 $-1 $14125 $14125 $12618 $14073 reversed $12657 $-1 #
+edge $-1 -1 -1 $-1 $14075 1.570796326794897 $14079 4.7123889803846897 $12618 $15545 forward @7 unknown T 39.999999999999993 35 20.000000000000004 44.999999999999993 45 25.000000000000004 #
+coedge $-1 -1 -1 $-1 $12619 $12713 $14845 $15546 reversed $12714 $-1 #
+vertex $-1 -1 -1 $-1 $15546 $15547 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 40 20.000000000000004 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15535 $12621 $15548 $15549 reversed $14078 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14063 $14842 T 35 35 17.500000000000007 40.000000000000007 35.669872981077816 22.500000000000014 unknown #
+vertex $-1 -1 -1 $-1 $15549 $15550 #
+point $-1 -1 -1 $-1 37.500000000000014 35.669872981077816 22.500000000000014 #
+coedge $-1 -1 -1 $-1 $15551 $15552 $12625 $14082 reversed $15553 $-1 #
+edge $-1 -1 -1 $-1 $15554 2.617993877991494 $14086 6.8067840827778854 $12625 $15555 forward @7 unknown T -45 35 50 -37.5 45 50 #
+coedge $-1 -1 -1 $-1 $15556 $12626 $15552 $15557 forward $14085 $-1 #
+coedge $-1 -1 -1 $-1 $12626 $15558 $15559 $14089 forward $14085 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14084 $15560 T -37.500000000000007 40 35 -30 45 50 unknown #
+vertex $-1 -1 -1 $-1 $12627 $15561 #
+ellipse-curve $-1 -1 -1 $-1 -35 40 50 -0 -0 -1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14090 $12628 $15562 $15563 reversed $12630 $-1 #
+edge $-1 -1 -1 $-1 $15564 40 $12631 50 $14084 $15565 forward @7 unknown T -30 40 40 -30 40 50 #
+coedge $-1 -1 -1 $-1 $12629 $14088 $15566 $15567 reversed $12630 $-1 #
+face $-1 -1 -1 $-1 $15568 $12630 $11 $-1 $15569 reversed single T -30 40 35 -22.5 45 50 F #
+edge $-1 -1 -1 $-1 $12631 0 $15554 2.0943951023931957 $14045 $14087 forward @7 unknown T -37.5 35 50 -30 40 50 #
+point $-1 -1 -1 $-1 -30 40 50 #
+coedge $-1 -1 -1 $-1 $15566 $15570 $12633 $14095 reversed $15571 $-1 #
+edge $-1 -1 -1 $-1 $14096 4.1887902047863923 $15572 4.7123889803846897 $12633 $15573 forward @7 unknown T -22.5 44.330127018922198 35 -20 45 37.5 #
+vertex $-1 -1 -1 $-1 $14095 $15574 #
+straight-curve $-1 -1 -1 $-1 -22.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $15575 $12639 $12635 $14099 reversed $14104 $-1 #
+edge $-1 -1 -1 $-1 $15572 1.5707963267948966 $12641 3.1415926535897931 $12635 $15576 forward @7 unknown T -20 40 35 -15 45 40 #
+coedge $-1 -1 -1 $-1 $15524 $12636 $15577 $14107 forward $14049 $-1 #
+face $-1 -1 -1 $-1 $15578 $15579 $11 $-1 $13729 reversed single T -37.5 35 35 -30 40 50 F #
+cone-surface $-1 -1 -1 $-1 -20 40 0 0 0 1 5 0 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $12639 $15575 $15580 $15581 forward $14104 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12639 $15582 T -20 40 30 -9.9999999999999982 45 40 unknown #
+vertex $-1 -1 -1 $-1 $15581 $15583 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12641 3.1415926535897931 $15584 4.7123889803846897 $14100 $15576 forward @7 unknown T -20 35 35 -15 40 40 #
+point $-1 -1 -1 $-1 -15 40 40 #
+coedge $-1 -1 -1 $-1 $12648 $12643 $15585 $15586 forward $12649 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15587 $15588 $11 $-1 $12646 reversed single T -15 40 4.9999999999999991 -7.4999999999999991 45 20 F #
+loop $-1 -1 -1 $-1 $-1 $15589 $12645 T -15 40 20 -7.4999999999999973 45 35 unknown #
+edge $-1 -1 -1 $-1 $15590 37.5 $12647 50 $14048 $15591 forward @7 unknown T -22.5 35.669872981077802 37.5 -22.5 35.669872981077809 50 #
+point $-1 -1 -1 $-1 -22.5 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $15592 $14119 $12648 $14116 forward $15593 $-1 #
+edge $-1 -1 -1 $-1 $12650 -1.5707963267948966 $15594 -1.0471975511965974 $14115 $15595 forward @7 unknown T -7.5000000000000009 44.330127018922191 32.5 -5 45 35 #
+face $-1 -1 -1 $-1 $15582 $12649 $11 $-1 $8951 reversed single T -9.9999999999999982 44.330127018922191 32.5 -5 45 37.5 F #
+point $-1 -1 -1 $-1 -5 45 35 #
+coedge $-1 -1 -1 $-1 $14115 $15596 $12653 $14120 forward $15593 $-1 #
+edge $-1 -1 -1 $-1 $14128 0 $12650 1.5707963267948966 $14119 $15597 forward @7 unknown T -5 40 30 0 45 35 #
+coedge $-1 -1 -1 $-1 $12655 $14056 $15598 $15599 reversed $14057 $-1 #
+face $-1 -1 -1 $-1 $15600 $15601 $11 $-1 $12658 reversed single T -50 35 14.999999999999996 -40 45 24.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $15602 $12656 T -9.9999999999999982 35 17.499999999999996 -5 35.669872981077816 22.500000000000004 unknown #
+loop $-1 -1 -1 $-1 $-1 $15603 $11272 T 50 35 15.000000000000004 50 45 25.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $14072 $14072 $15604 $15605 reversed $12657 $-1 #
+coedge $-1 -1 -1 $-1 $15606 $12659 $15596 $15607 reversed $14127 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15606 $15608 T 0 40 20 7.5000000000000027 45 35 unknown #
+vertex $-1 -1 -1 $-1 $14120 $15609 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15610 1.047197551196597 $12662 1.5707963267948966 $15611 $15595 forward @7 unknown T -7.5000000000000036 35 32.5 -5 35.669872981077816 35 #
+point $-1 -1 -1 $-1 -5 35 35 #
+coedge $-1 -1 -1 $-1 $12663 $15612 $12670 $14140 reversed $14127 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $15613 $12665 T 0 35 -40 7.5000000000000018 40 -25 unknown #
+coedge $-1 -1 -1 $-1 $15614 $15615 $15616 $15617 reversed $12666 $-1 #
+coedge $-1 -1 -1 $-1 $13324 $12667 $15618 $14898 reversed $11282 $-1 #
+edge $-1 -1 -1 $-1 $15619 1.5707963267948966 $12668 2.0943951023931953 $14071 $15620 forward @7 unknown T -9.9999999999999982 35 35 -7.4999999999999991 35.669872981077809 37.5 #
+point $-1 -1 -1 $-1 -7.5 35.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $14143 $12670 $15621 $15622 forward $11293 $-1 #
+edge $-1 -1 -1 $-1 $12671 -32.5 $15623 -22.5 $12670 $15624 forward @7 unknown T 7.5 44.330127018922191 22.5 7.5000000000000027 44.330127018922205 32.5 #
+point $-1 -1 -1 $-1 7.5 44.330127018922191 32.5 #
+loop $-1 -1 -1 $-1 $-1 $15625 $12673 T -7.5000000000000036 35 20 8.8817841970012523e-16 40 35 unknown #
+coedge $-1 -1 -1 $-1 $12674 $14139 $15626 $15627 forward $11293 $-1 #
+coedge $-1 -1 -1 $-1 $15626 $15628 $12679 $14145 forward $13359 $-1 #
+edge $-1 -1 -1 $-1 $15629 -1.5707963267948966 $14146 6.1232339957367648e-17 $14144 $15630 forward @7 unknown T 15 40 20 20.000000000000004 45 25 #
+vertex $-1 -1 -1 $-1 $15631 $15632 #
+straight-curve $-1 -1 -1 $-1 15.000000000000002 40 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $15633 $15634 $11 $-1 $7943 reversed single T 14.999999999999996 40 5.0000000000000009 22.500000000000011 45 20 F #
+point $-1 -1 -1 $-1 7.5 35.669872981077809 32.5 #
+coedge $-1 -1 -1 $-1 $12684 $15635 $15636 $15637 forward $11310 $-1 #
+coedge $-1 -1 -1 $-1 $15638 $12694 $12685 $14152 forward $14170 $-1 #
+edge $-1 -1 -1 $-1 $12696 -2.0943951023931944 $15629 -1.5707963267948966 $14151 $15639 forward @7 unknown T 20.000000000000004 44.330127018922198 20 22.5 45 22.5 #
+coedge $-1 -1 -1 $-1 $12686 $15640 $13353 $14900 reversed $11302 $-1 #
+coedge $-1 -1 -1 $-1 $15641 $12687 $14166 $15642 reversed $10049 $-1 #
+edge $-1 -1 -1 $-1 $13347 -1.5707963267948966 $14163 6.1232339957367648e-17 $13344 $15643 forward @7 unknown T 15 40 -40 20.000000000000004 45 -35 #
+coedge $-1 -1 -1 $-1 $12688 $15641 $15644 $15645 reversed $10049 $-1 #
+coedge $-1 -1 -1 $-1 $15646 $15647 $12688 $14158 forward $15648 $-1 #
+edge $-1 -1 -1 $-1 $14164 -6.1232339957367648e-17 $15649 1.5707963267948961 $14157 $15650 forward @7 unknown T 15 40 -30 20.000000000000004 45 -25 #
+coedge $-1 -1 -1 $-1 $15651 $12689 $15647 $15652 forward $14162 $-1 #
+coedge $-1 -1 -1 $-1 $12689 $15653 $14894 $15654 forward $14162 $-1 #
+coedge $-1 -1 -1 $-1 $14887 $15655 $14891 $12690 reversed $15656 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12689 $13356 T 7.5 40 -40 15.000000000000002 45 -25 unknown #
+vertex $-1 -1 -1 $-1 $14888 $15657 #
+vertex $-1 -1 -1 $-1 $15652 $15658 #
+coedge $-1 -1 -1 $-1 $12691 $13297 $14154 $15642 forward $13298 $-1 #
+edge $-1 -1 -1 $-1 $12692 -1.5707963267948966 $14128 -6.1232339957367673e-17 $14056 $15659 forward @7 unknown T 0 35 30 5.0000000000000027 40 35 #
+point $-1 -1 -1 $-1 5.0000000000000027 35 35 #
+coedge $-1 -1 -1 $-1 $12694 $15638 $15660 $15661 reversed $14170 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14151 $15662 T 20.000000000000004 44.330127018922198 17.500000000000004 25 45 22.5 unknown #
+vertex $-1 -1 -1 $-1 $15661 $15663 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 22.5 44.330127018922205 22.5 #
+coedge $-1 -1 -1 $-1 $15635 $12698 $15664 $15631 forward $11310 $-1 #
+coedge $-1 -1 -1 $-1 $12702 $12699 $14905 $15665 reversed $12703 $-1 #
+ellipse-curve $-1 -1 -1 $-1 25 40 20 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $14065 $15666 $12701 $12706 reversed $14843 $-1 #
+coedge $-1 -1 -1 $-1 $15667 $14190 $12702 $14179 reversed $12709 $-1 #
+edge $-1 -1 -1 $-1 $15668 -6.1232339957367648e-17 $12704 1.5707963267948966 $12702 $15669 forward @7 unknown T 29.999999999999996 40 15 35 45 20.000000000000004 #
+point $-1 -1 -1 $-1 35 45 20.000000000000004 #
+vertex $-1 -1 -1 $-1 $15670 $15671 #
+face $-1 -1 -1 $-1 $15672 $15673 $11 $-1 $6121 reversed single T 29.999999999999996 40 -24.999999999999996 37.500000000000007 45 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $15674 $12708 T 29.999999999999996 40 -9.9999999999999982 37.500000000000007 45 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $15675 $15667 $15676 $15677 reversed $12709 $-1 #
+coedge $-1 -1 -1 $-1 $15678 $15679 $12710 $14186 reversed $15680 $-1 #
+edge $-1 -1 -1 $-1 $14181 1.5707963267948961 $14188 2.0943951023931948 $12710 $14172 forward @7 unknown T 22.499999999999993 35 19.999999999999996 25 35.669872981077809 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $15534 $12711 $15679 $15681 reversed $14060 $-1 #
+vertex $-1 -1 -1 $-1 $15681 $15682 #
+straight-curve $-1 -1 -1 $-1 22.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14178 $14846 $12713 $14191 reversed $12709 $-1 #
+edge $-1 -1 -1 $-1 $12704 1.5707963267948966 $15683 2.0943951023931944 $12713 $15684 forward @7 unknown T 35 44.330127018922191 17.500000000000007 37.499999999999993 45 20.000000000000004 #
+face $-1 -1 -1 $-1 $15685 $12714 $11 $-1 $12658 reversed single T 35 44.330127018922191 17.500000000000004 40.000000000000007 45 22.500000000000011 F #
+coedge $-1 -1 -1 $-1 $15686 $15687 $12717 $14194 forward $15688 $-1 #
+edge $-1 -1 -1 $-1 $14196 -2.0943951023931948 $15689 -1.5707963267948966 $14193 $15690 forward @7 unknown T 35 35 -27.499999999999993 37.5 35.669872981077809 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $15691 $12718 $15687 $15692 forward $13303 $-1 #
+vertex $-1 -1 -1 $-1 $15692 $15693 #
+straight-curve $-1 -1 -1 $-1 37.5 35.669872981077809 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $14203 27.499999999999993 $13306 37.5 $13305 $15694 forward @7 unknown T 37.5 44.330127018922191 -37.5 37.5 44.330127018922205 -27.499999999999993 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15695 $12723 $14840 $15696 reversed $14202 $-1 #
+coedge $-1 -1 -1 $-1 $12723 $15695 $15697 $15698 forward $14202 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14201 $15699 T 35 44.330127018922191 -27.499999999999993 40.000000000000007 45 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $12724 $15700 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12726 $12725 $15701 $15702 reversed $12727 $-1 #
+coedge $-1 -1 -1 $-1 $15697 $15703 $12725 $14207 reversed $15673 $-1 #
+edge $-1 -1 -1 $-1 $12728 -1.5707963267948966 $15704 6.1232339957367648e-17 $12725 $15705 forward @7 unknown T 29.999999999999996 40 -24.999999999999996 35 45 -19.999999999999996 #
+face $-1 -1 -1 $-1 $15706 $12727 $11 $-1 $15707 reversed single T 25 40 -30 35 45 -19.999999999999996 F #
+point $-1 -1 -1 $-1 35 45 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $12732 $12730 $15641 $15708 forward $11333 $-1 #
+coedge $-1 -1 -1 $-1 $15709 $15644 $12730 $14212 reversed $15710 $-1 #
+edge $-1 -1 -1 $-1 $14213 -1.5707963267948966 $15711 -1.0471975511965992 $12730 $15712 forward @7 unknown T 22.500000000000007 44.330127018922198 -27.500000000000004 25 45 -25 #
+vertex $-1 -1 -1 $-1 $14212 $15713 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15714 4.1887902047863932 $10578 4.7123889803846897 $12732 $13355 forward @7 unknown T 22.500000000000007 44.330127018922198 -40 25 45 -37.5 #
+coedge $-1 -1 -1 $-1 $12734 $13353 $15715 $15716 forward $12735 $-1 #
+coedge $-1 -1 -1 $-1 $15717 $14909 $12734 $14218 reversed $15718 $-1 #
+edge $-1 -1 -1 $-1 $15719 -1.5707963267948961 $11335 0 $12734 $14214 forward @7 unknown T 25 35 -30 29.999999999999996 40 -25 #
+face $-1 -1 -1 $-1 $13342 $12735 $11 $-1 $7024 reversed single T 22.5 35 -40 30 40 -25 F #
+coedge $-1 -1 -1 $-1 $14260 $15720 $12739 $12786 reversed $14280 $-1 #
+coedge $-1 -1 -1 $-1 $15721 $12740 $12742 $12807 reversed $14223 $-1 #
+coedge $-1 -1 -1 $-1 $12740 $15722 $11373 $12783 forward $14223 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14222 $15723 T -30 20 35 -22.5 25 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 25 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $12742 $12794 $15724 $15725 forward $12743 $-1 #
+face $-1 -1 -1 $-1 $12811 $12743 $11 $-1 $12796 reversed single T -22.500000000000004 20 35 -15 25 50 F #
+coedge $-1 -1 -1 $-1 $15726 $14278 $12745 $14228 forward $15727 $-1 #
+edge $-1 -1 -1 $-1 $11386 6.1232339957367648e-17 $14320 1.5707963267948966 $14227 $15728 forward @7 unknown T -15 20 35 -9.9999999999999982 25 40 #
+face $-1 -1 -1 $-1 $15729 $14917 $11 $-1 $11391 reversed single T -15 25 -50 -7.4999999999999991 30 -40 F #
+coedge $-1 -1 -1 $-1 $14245 $12747 $14312 $12824 reversed $11362 $-1 #
+coedge $-1 -1 -1 $-1 $14337 $14233 $12749 $14232 reversed $15730 $-1 #
+edge $-1 -1 -1 $-1 $11428 -2.0943951023931948 $11437 -1.5707963267948966 $12749 $15731 forward @7 unknown T 5.0000000000000018 20 32.5 7.5 20.669872981077805 35 #
+coedge $-1 -1 -1 $-1 $14231 $15732 $12750 $12861 reversed $15730 $-1 #
+face $-1 -1 -1 $-1 $7975 $12754 $11 $-1 $7081 reversed single T 15 20 20 22.500000000000004 25 35 F #
+coedge $-1 -1 -1 $-1 $12756 $12881 $14989 $15733 reversed $12754 $-1 #
+coedge $-1 -1 -1 $-1 $12757 $12771 $15734 $15735 forward $12772 $-1 #
+vertex $-1 -1 -1 $-1 $15736 $15737 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14367 $12759 $15738 $15736 forward $13379 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $15739 $15740 $1558 T 50 20 15.000000000000004 50 30 25.000000000000004 hole $1559 T #
+point $-1 -1 -1 $-1 50 25 30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $15741 $11361 T -50 20 29.999999999999996 -50 30 40 unknown #
+coedge $-1 -1 -1 $-1 $15742 $15742 $15743 $15744 forward $12764 $-1 #
+coedge $-1 -1 -1 $-1 $12765 $14230 $15745 $15746 forward $11362 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12769 -1.570796326794897 $14384 -1.0471975511965983 $13381 $15747 forward @7 unknown T 37.499999999999993 29.330127018922191 17.500000000000007 40 30 20.000000000000007 #
+point $-1 -1 -1 $-1 40 30 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $14305 $15748 $12771 $14250 forward $10600 $-1 #
+edge $-1 -1 -1 $-1 $15749 1.0471975511965987 $12773 1.570796326794897 $14249 $15747 forward @7 unknown T 37.499999999999993 20 17.500000000000007 40 20.669872981077805 20.000000000000007 #
+point $-1 -1 -1 $-1 40 20 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $15750 $12775 $15720 $15751 reversed $14254 $-1 #
+coedge $-1 -1 -1 $-1 $12775 $15752 $12777 $14258 reversed $14254 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14253 $15753 T -45 20.000000000000004 35 -37.5 30.000000000000004 50 unknown #
+vertex $-1 -1 -1 $-1 $15751 $15754 #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $14259 $12777 $15755 $15756 forward $12779 $-1 #
+edge $-1 -1 -1 $-1 $12780 -50 $15757 -37.5 $12777 $15758 forward @7 unknown T -37.5 29.330127018922195 37.5 -37.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $12778 $14257 $15759 $15760 forward $12779 $-1 #
+coedge $-1 -1 -1 $-1 $15761 $14220 $14222 $12783 reversed $14280 $-1 #
+face $-1 -1 -1 $-1 $15762 $12779 $11 $-1 $12288 reversed single T -37.5 25 35 -30 30 50 F #
+point $-1 -1 -1 $-1 -37.5 29.330127018922195 50 #
+coedge $-1 -1 -1 $-1 $15759 $15763 $12782 $14264 forward $15764 $-1 #
+edge $-1 -1 -1 $-1 $15765 -1.5707963267948966 $14265 6.1232339957367648e-17 $14263 $15766 forward @7 unknown T -30 25 35 -25 30 40 #
+vertex $-1 -1 -1 $-1 $15767 $15768 #
+straight-curve $-1 -1 -1 $-1 -30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15769 $12788 $12784 $14268 forward $14272 $-1 #
+edge $-1 -1 -1 $-1 $12790 -2.0943951023931957 $15765 -1.5707963267948966 $14267 $15770 forward @7 unknown T -25 29.330127018922191 35 -22.5 30 37.500000000000007 #
+face $-1 -1 -1 $-1 $15771 $15772 $11 $-1 $14270 reversed single T -30 25 -50 -22.5 30 -40 F #
+cone-surface $-1 -1 -1 $-1 -25 25 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $12788 $15769 $15773 $15774 reversed $14272 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14267 $15775 T -25 29.330127018922191 32.5 -20 30 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $15774 $15776 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 29.330127018922195 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $12797 $12792 $15777 $15778 reversed $12798 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14227 $15779 $12794 $12801 reversed $15727 $-1 #
+face $-1 -1 -1 $-1 $15780 $15781 $11 $-1 $12796 reversed single T -22.500000000000004 25 20 -15 30 35 F #
+loop $-1 -1 -1 $-1 $-1 $14260 $12795 T -37.5 20 35 -30 25 50 unknown #
+coedge $-1 -1 -1 $-1 $15782 $14286 $12797 $14282 reversed $12806 $-1 #
+edge $-1 -1 -1 $-1 $15783 -6.1232339957367648e-17 $12799 1.5707963267948966 $12797 $15784 forward @7 unknown T -15 25 30 -9.9999999999999982 30 35 #
+face $-1 -1 -1 $-1 $15785 $12798 $11 $-1 $8043 reversed single T -20 25 30 -9.9999999999999982 30 40 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 30 35 #
+vertex $-1 -1 -1 $-1 $15786 $15787 #
+coedge $-1 -1 -1 $-1 $14281 $15788 $12803 $14287 reversed $12806 $-1 #
+edge $-1 -1 -1 $-1 $12799 1.5707963267948966 $14295 2.0943951023931953 $12803 $15789 forward @7 unknown T -9.9999999999999982 29.330127018922191 32.5 -7.4999999999999991 30 35 #
+face $-1 -1 -1 $-1 $15790 $15791 $11 $-1 $11391 reversed single T -15 25 -10 -7.4999999999999964 30 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $15792 $12805 T -15 25 4.9999999999999991 -7.4999999999999964 30 20 unknown #
+coedge $-1 -1 -1 $-1 $15793 $15782 $15794 $15795 reversed $12806 $-1 #
+vertex $-1 -1 -1 $-1 $15796 $15797 #
+straight-curve $-1 -1 -1 $-1 -22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15798 $12809 $15788 $15799 forward $14294 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14297 $14301 T -7.5000000000000009 25 20 8.8817841970012523e-16 30 35 unknown #
+vertex $-1 -1 -1 $-1 $15799 $15800 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12813 $15801 $14326 $14308 forward $14294 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14326 $14312 $12815 $14300 forward $12836 $-1 #
+edge $-1 -1 -1 $-1 $11407 -1.5707963267948966 $12822 0 $14299 $14298 forward @7 unknown T -5 20 30 0 25 35 #
+face $-1 -1 -1 $-1 $15802 $14294 $11 $-1 $9021 reversed single T -7.5000000000000009 25 20 8.8817841970012523e-16 30 35 F #
+loop $-1 -1 -1 $-1 $15803 $15804 $12816 T -45 20.000000000000004 14.999999999999996 -40 30.000000000000004 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $15805 $15806 $15807 $15808 forward $12817 $-1 #
+coedge $-1 -1 -1 $-1 $14304 $14304 $15740 $15809 reversed $12818 $-1 #
+coedge $-1 -1 -1 $-1 $13381 $14249 $12819 $14306 forward $10600 $-1 #
+edge $-1 -1 -1 $-1 $12773 -1.570796326794897 $12769 1.570796326794897 $14305 $15810 forward @7 unknown T 40 20 15.000000000000004 45.000000000000007 30 20.000000000000007 #
+coedge $-1 -1 -1 $-1 $14313 $12820 $15811 $15812 reversed $12821 $-1 #
+edge $-1 -1 -1 $-1 $15813 25 $12822 30 $14297 $15814 forward @7 unknown T 0 25 25 8.8817841970012523e-16 25 30 #
+face $-1 -1 -1 $-1 $15815 $12821 $11 $-1 $9009 reversed single T 0 25 20 7.5000000000000027 30 35 F #
+point $-1 -1 -1 $-1 0 25 30 #
+vertex $-1 -1 -1 $-1 $12824 $15816 #
+coedge $-1 -1 -1 $-1 $14299 $15817 $14230 $12824 forward $12836 $-1 #
+coedge $-1 -1 -1 $-1 $12826 $14307 $15818 $15819 reversed $12821 $-1 #
+coedge $-1 -1 -1 $-1 $14962 $15820 $13415 $14972 reversed $12828 $-1 #
+coedge $-1 -1 -1 $-1 $15821 $12829 $14966 $15822 reversed $11411 $-1 #
+coedge $-1 -1 -1 $-1 $12829 $15823 $15824 $15825 reversed $11411 $-1 #
+coedge $-1 -1 -1 $-1 $15826 $15827 $15828 $14318 forward $15829 $-1 #
+edge $-1 -1 -1 $-1 $15830 -35 $15831 -30 $14317 $15832 forward @7 unknown T 0 25 -35 8.8817841970012523e-16 25 -30 #
+coedge $-1 -1 -1 $-1 $13369 $15833 $12830 $13434 forward $14921 $-1 #
+vertex $-1 -1 -1 $-1 $15834 $15835 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15818 $15836 $12833 $14323 reversed $15837 $-1 #
+edge $-1 -1 -1 $-1 $14324 4.1887902047863923 $15838 4.7123889803846897 $12833 $15839 forward @7 unknown T 7.5000000000000027 29.330127018922195 20 10 30 22.5 #
+vertex $-1 -1 -1 $-1 $14323 $15840 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $15841 $14299 $15732 $14308 reversed $12836 $-1 #
+coedge $-1 -1 -1 $-1 $15842 $12838 $12837 $14328 reversed $11986 $-1 #
+edge $-1 -1 -1 $-1 $15838 1.5707963267948966 $12840 3.1415926535897931 $12837 $15843 forward @7 unknown T 10 25 20 15 30 25 #
+coedge $-1 -1 -1 $-1 $12838 $15842 $15844 $15845 forward $11986 $-1 #
+vertex $-1 -1 -1 $-1 $15845 $15846 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $12840 3.1415926535897931 $15847 4.7123889803846897 $12868 $15843 forward @7 unknown T 10 20 20 15 25 25 #
+point $-1 -1 -1 $-1 15 25 25 #
+face $-1 -1 -1 $-1 $15848 $15849 $11 $-1 $7081 reversed single T 15 25 -9.9999999999999982 22.500000000000004 30 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $15850 $12842 T 14.999999999999996 25 5.0000000000000009 22.500000000000007 30 20 unknown #
+coedge $-1 -1 -1 $-1 $12844 $12868 $15851 $15852 forward $10166 $-1 #
+coedge $-1 -1 -1 $-1 $15853 $14231 $12844 $14338 reversed $15730 $-1 #
+edge $-1 -1 -1 $-1 $15854 22.500000000000004 $11428 32.5 $12844 $15855 forward @7 unknown T 7.5 20.669872981077805 22.500000000000004 7.5000000000000009 20.669872981077813 32.5 #
+coedge $-1 -1 -1 $-1 $12863 $12845 $15856 $15857 forward $12864 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12847 $14983 $15858 $15859 reversed $10158 $-1 #
+coedge $-1 -1 -1 $-1 $12850 $12848 $12904 $14409 reversed $9029 $-1 #
+edge $-1 -1 -1 $-1 $14415 -2.0943951023931957 $11974 -1.5707963267948966 $12860 $15860 forward @7 unknown T 20 29.330127018922191 -40 22.500000000000004 30 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12905 $15861 $12850 $14346 forward $14411 $-1 #
+edge $-1 -1 -1 $-1 $14350 1.570796326794897 $14412 2.0943951023931966 $14345 $15862 forward @7 unknown T 20 29.330127018922191 -27.500000000000004 22.500000000000004 30 -25 #
+coedge $-1 -1 -1 $-1 $15863 $12851 $15864 $15865 forward $14349 $-1 #
+coedge $-1 -1 -1 $-1 $12851 $15863 $12853 $14353 reversed $14349 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12851 $15866 T 10 25 -30 20.000000000000004 30 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $12852 $15867 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15868 $12853 $15869 $15870 forward $12856 $-1 #
+edge $-1 -1 -1 $-1 $12858 0 $15871 1.5707963267948966 $12853 $15872 forward @7 unknown T 10 25 -30 15 30 -25 #
+coedge $-1 -1 -1 $-1 $12854 $15868 $14920 $15873 forward $12856 $-1 #
+edge $-1 -1 -1 $-1 $11976 1.5707963267948966 $12857 3.1415926535897931 $12854 $14979 forward @7 unknown T 10 25 -40 15 30 -35 #
+coedge $-1 -1 -1 $-1 $12855 $15874 $15875 $15876 forward $14357 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12855 $15877 T 7.5 20 -40 15 25 -25 unknown #
+point $-1 -1 -1 $-1 15 25 -35 #
+point $-1 -1 -1 $-1 15 25 -30 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15878 $13441 $12863 $14362 forward $10643 $-1 #
+edge $-1 -1 -1 $-1 $12865 -1.5707963267948966 $15879 -1.0471975511965974 $14361 $15880 forward @7 unknown T 22.5 29.330127018922191 17.5 25 30 20 #
+face $-1 -1 -1 $-1 $15881 $12864 $11 $-1 $11403 reversed single T 20 29.330127018922191 17.5 25 30 22.5 F #
+point $-1 -1 -1 $-1 25 30 20 #
+coedge $-1 -1 -1 $-1 $14989 $15882 $12868 $14332 reversed $13440 $-1 #
+edge $-1 -1 -1 $-1 $14369 0 $12865 1.5707963267948961 $13441 $15883 forward @7 unknown T 25 25 15 29.999999999999996 30 20 #
+coedge $-1 -1 -1 $-1 $12871 $14239 $14994 $15884 reversed $13379 $-1 #
+coedge $-1 -1 -1 $-1 $12878 $12872 $11987 $13444 reversed $11454 $-1 #
+vertex $-1 -1 -1 $-1 $14366 $15885 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15886 1.0471975511965979 $12875 1.5707963267948966 $15887 $15880 forward @7 unknown T 22.500000000000004 20 17.5 25 20.669872981077809 20 #
+point $-1 -1 -1 $-1 25 20 20 #
+face $-1 -1 -1 $-1 $15888 $15889 $11 $-1 $5288 reversed single T 29.999999999999996 19.999999999999996 -24.999999999999996 37.5 25 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $12900 $12876 T 29.999999999999996 25 -24.999999999999996 37.500000000000007 29.999999999999996 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $15890 $15891 $15892 $15893 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $13382 $12878 $15894 $15895 reversed $11454 $-1 #
+coedge $-1 -1 -1 $-1 $14991 $15896 $12878 $14378 forward $13448 $-1 #
+edge $-1 -1 -1 $-1 $15897 -1.5707963267948966 $14997 -6.4931039580273206e-16 $14377 $15898 forward @7 unknown T 29.999999999999996 25 5.0000000000000018 35 29.999999999999996 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $15899 $12879 $15887 $14371 reversed $14381 $-1 #
+coedge $-1 -1 -1 $-1 $12879 $15899 $12881 $14382 forward $14381 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14380 $13439 T 20 20 17.5 25 20.669872981077809 22.499999999999996 unknown #
+edge $-1 -1 -1 $-1 $15900 1.5707963267948966 $12882 2.0943951023931939 $14380 $15901 forward @7 unknown T 20 20 20 22.499999999999993 20.669872981077805 22.499999999999996 #
+point $-1 -1 -1 $-1 22.499999999999993 20.669872981077802 22.499999999999996 #
+vertex $-1 -1 -1 $-1 $13383 $15902 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13375 $14996 $11 $-1 $6162 reversed single T 22.499999999999996 20 4.9999999999999991 30 25 20 F #
+coedge $-1 -1 -1 $-1 $15903 $12887 $15904 $15905 forward $14389 $-1 #
+coedge $-1 -1 -1 $-1 $12887 $15903 $12889 $14393 reversed $14389 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12887 $15906 T 35 19.999999999999996 -27.499999999999989 40.000000000000007 20.669872981077809 -22.499999999999989 unknown #
+vertex $-1 -1 -1 $-1 $13446 $15907 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13376 $12889 $15908 $15909 forward $11930 $-1 #
+edge $-1 -1 -1 $-1 $12890 1.0471975511965996 $15910 1.570796326794897 $12889 $15911 forward @7 unknown T 37.5 20 -27.499999999999989 40 20.669872981077802 -24.999999999999993 #
+point $-1 -1 -1 $-1 37.5 20.669872981077802 -27.499999999999986 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $12895 $12894 $15912 $15913 reversed $12896 $-1 #
+edge $-1 -1 -1 $-1 $15914 -1.570796326794897 $12897 -1.0471975511965987 $13376 $15911 forward @7 unknown T 37.5 29.330127018922195 -27.499999999999996 40 30 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $15915 $12900 $12895 $14399 reversed $14374 $-1 #
+edge $-1 -1 -1 $-1 $15916 -2.0943951023931957 $11473 -1.5707963267948966 $12895 $15917 forward @7 unknown T 35 29.330127018922187 -24.999999999999996 37.500000000000007 29.999999999999996 -22.499999999999989 #
+face $-1 -1 -1 $-1 $15918 $12896 $11 $-1 $14408 reversed single T 35 29.330127018922187 -27.499999999999996 40.000000000000007 30 -22.499999999999989 F #
+point $-1 -1 -1 $-1 37.5 29.330127018922198 -27.499999999999996 #
+coedge $-1 -1 -1 $-1 $15919 $15920 $12899 $14403 forward $15921 $-1 #
+edge $-1 -1 -1 $-1 $12907 1.5707963267948966 $14405 3.1415926535897931 $14402 $15922 forward @7 unknown T 25 25 -25 29.999999999999996 30 -20 #
+coedge $-1 -1 -1 $-1 $12900 $15923 $15919 $15924 reversed $14374 $-1 #
+vertex $-1 -1 -1 $-1 $15925 $15926 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15906 $14419 $11 $-1 $14408 reversed single T 25 19.999999999999996 -30 35 25 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 25 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $14412 27.500000000000004 $14415 37.5 $12904 $15927 forward @7 unknown T 22.5 29.330127018922191 -37.5 22.500000000000004 29.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $15861 $12905 $15920 $15928 reversed $14411 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15861 $15929 T 19.999999999999996 29.330127018922191 -27.500000000000004 25 30 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $14346 $15930 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+point $-1 -1 -1 $-1 25 30 -25 #
+vertex $-1 -1 -1 $-1 $12909 $15931 #
+coedge $-1 -1 -1 $-1 $15858 $15932 $12910 $14417 reversed $15933 $-1 #
+edge $-1 -1 -1 $-1 $14985 1.0471975511965974 $14420 1.5707963267948966 $12910 $14413 forward @7 unknown T 22.5 20 -27.500000000000004 25 20.669872981077809 -25 #
+coedge $-1 -1 -1 $-1 $14999 $12911 $15934 $15925 reversed $14419 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13445 $14407 T 25 19.999999999999996 -30 35 25 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $14417 $15935 #
+coedge $-1 -1 -1 $-1 $12914 $15936 $12946 $14452 forward $12974 $-1 #
+coedge $-1 -1 -1 $-1 $14423 $12915 $15937 $14497 reversed $12917 $-1 #
+coedge $-1 -1 -1 $-1 $12916 $14422 $15938 $15939 reversed $12917 $-1 #
+face $-1 -1 -1 $-1 $11530 $12917 $11 $-1 $12964 reversed single T -30 5.0000000000000018 35 -22.5 10 50 F #
+coedge $-1 -1 -1 $-1 $15940 $15937 $12919 $14426 reversed $15941 $-1 #
+edge $-1 -1 -1 $-1 $12979 1.5707963267948966 $12985 2.0943951023931957 $12919 $12968 forward @7 unknown T -22.5 5 35 -20 5.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $14480 $12921 $15942 $14535 forward $14428 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12921 $14486 T -20 5 30 -10 10 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15943 $15944 $11 $-1 $10247 reversed single T -15 10 -40 -7.4999999999999982 15 -25 F #
+loop $-1 -1 -1 $-1 $-1 $14554 $15945 T 0 4.9999999999999991 20 7.5000000000000018 10 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 35 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12927 $15946 $11565 $13002 forward $14431 $-1 #
+edge $-1 -1 -1 $-1 $11585 -2.9403902792268244e-16 $14601 1.5707963267948966 $13525 $15947 forward @7 unknown T 15 4.9999999999999982 20 20 10 25 #
+coedge $-1 -1 -1 $-1 $15948 $14439 $12930 $14436 reversed $15097 $-1 #
+edge $-1 -1 -1 $-1 $14450 -2.0943951023931948 $12931 -1.5707963267948966 $12930 $15949 forward @7 unknown T 35 4.9999999999999982 17.500000000000007 37.5 5.6698729810778046 20.000000000000004 #
+edge $-1 -1 -1 $-1 $12931 -1.5707963267948966 $13063 2.9403902792268214e-16 $12933 $15950 forward @7 unknown T 29.999999999999996 4.9999999999999982 15 35 10 20.000000000000004 #
+point $-1 -1 -1 $-1 35 4.9999999999999982 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $14435 $13531 $12933 $14437 reversed $15097 $-1 #
+loop $-1 -1 -1 $-1 $15951 $15952 $1558 T 50 5 2.6645352591003757e-15 50 15 10.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $14441 $14441 $12998 $14510 forward $12935 $-1 #
+coedge $-1 -1 -1 $-1 $14442 $14442 $15953 $15954 reversed $12937 $-1 #
+coedge $-1 -1 -1 $-1 $12938 $12938 $15955 $15956 forward $11509 $-1 #
+coedge $-1 -1 -1 $-1 $15957 $15958 $12938 $14445 reversed $15959 $-1 #
+edge $-1 -1 -1 $-1 $15960 -1.5707963267948966 $15961 1.5707963267948966 $12938 $15962 forward @7 unknown T -45 5.0000000000000018 30 -40 15.000000000000002 35 #
+coedge $-1 -1 -1 $-1 $15963 $15942 $12939 $14447 reversed $15964 $-1 #
+edge $-1 -1 -1 $-1 $13005 -2.0943951023931957 $13014 -1.5707963267948966 $12939 $15965 forward @7 unknown T -10 5 32.5 -7.4999999999999991 5.669872981077809 35 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $12943 $15018 $15948 $15966 forward $9465 $-1 #
+vertex $-1 -1 -1 $-1 $12944 $15967 #
+coedge $-1 -1 -1 $-1 $15955 $12946 $15968 $15969 reversed $12948 $-1 #
+edge $-1 -1 -1 $-1 $15970 37.5 $12949 50 $14421 $15971 forward @7 unknown T -37.5 5.6698729810778064 37.5 -37.5 5.6698729810778081 50 #
+coedge $-1 -1 -1 $-1 $12947 $15955 $15972 $15973 reversed $12948 $-1 #
+face $-1 -1 -1 $-1 $15974 $12948 $11 $-1 $15975 reversed single T -45 5.0000000000000018 35 -37.499999999999993 15.000000000000002 50 F #
+point $-1 -1 -1 $-1 -37.5 5.6698729810778064 50 #
+coedge $-1 -1 -1 $-1 $15972 $15976 $12951 $14457 reversed $15977 $-1 #
+edge $-1 -1 -1 $-1 $14458 4.1887902047863923 $15978 4.7123889803846897 $12951 $15979 forward @7 unknown T -37.499999999999993 14.330127018922193 35 -35 15 37.499999999999993 #
+vertex $-1 -1 -1 $-1 $14457 $15980 #
+straight-curve $-1 -1 -1 $-1 -37.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $15981 $12957 $12953 $14461 reversed $14465 $-1 #
+edge $-1 -1 -1 $-1 $15978 1.5707963267948966 $12959 3.1415926535897931 $12953 $15982 forward @7 unknown T -35 10 35 -30 15 40 #
+coedge $-1 -1 -1 $-1 $15936 $12954 $15983 $14468 forward $12974 $-1 #
+face $-1 -1 -1 $-1 $15984 $15985 $11 $-1 $10937 reversed single T -37.5 10 19.999999999999993 -29.999999999999993 15 35 F #
+coedge $-1 -1 -1 $-1 $12957 $15981 $15986 $15987 forward $14465 $-1 #
+loop $-1 -1 -1 $-1 $-1 $12957 $14481 T -35 10 30 -25 15.000000000000002 40 unknown #
+vertex $-1 -1 -1 $-1 $15987 $15988 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12959 3.1415926535897931 $15989 4.7123889803846897 $14462 $15982 forward @7 unknown T -35 5 35 -30 10 40 #
+point $-1 -1 -1 $-1 -30 10 40 #
+coedge $-1 -1 -1 $-1 $12965 $12961 $15990 $15991 forward $12966 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15992 $15993 $11 $-1 $12964 reversed single T -30.000000000000007 10 -40 -22.499999999999993 15.000000000000002 -25 F #
+loop $-1 -1 -1 $-1 $-1 $15994 $12963 T -30 10 -50 -22.5 15.000000000000002 -40 unknown #
+coedge $-1 -1 -1 $-1 $15995 $14478 $12965 $14475 forward $14482 $-1 #
+edge $-1 -1 -1 $-1 $12967 -1.5707963267948966 $15996 -1.0471975511965974 $14474 $15997 forward @7 unknown T -22.500000000000004 14.330127018922191 32.5 -20 15 35 #
+face $-1 -1 -1 $-1 $15998 $12966 $11 $-1 $7181 reversed single T -25 14.330127018922191 32.5 -20 15.000000000000002 37.5 F #
+point $-1 -1 -1 $-1 -20 15 35 #
+coedge $-1 -1 -1 $-1 $14474 $15999 $12970 $14479 forward $14482 $-1 #
+edge $-1 -1 -1 $-1 $14484 0 $12967 1.5707963267948966 $14478 $16000 forward @7 unknown T -20 10 30 -15 15 35 #
+coedge $-1 -1 -1 $-1 $12972 $14427 $16001 $16002 reversed $14428 $-1 #
+face $-1 -1 -1 $-1 $16003 $14465 $11 $-1 $7181 reversed single T -35 10 30 -25 15.000000000000002 40 F #
+loop $-1 -1 -1 $-1 $-1 $15999 $12973 T -22.500000000000004 10 20 -15 15 35 unknown #
+coedge $-1 -1 -1 $-1 $12984 $12975 $15999 $16004 reversed $11551 $-1 #
+vertex $-1 -1 -1 $-1 $14479 $16005 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16006 $14428 $11 $-1 $7181 reversed single T -20 5 30 -10 10 40 F #
+edge $-1 -1 -1 $-1 $16007 1.0471975511965974 $12979 1.5707963267948966 $16008 $15997 forward @7 unknown T -22.5 5 32.5 -20 5.669872981077809 35 #
+point $-1 -1 -1 $-1 -20 5 35 #
+coedge $-1 -1 -1 $-1 $12980 $14494 $12987 $14500 reversed $11551 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16009 $16010 $11 $-1 $10247 reversed single T -15.000000000000004 10 -25 -7.4999999999999982 15 -10 F #
+loop $-1 -1 -1 $-1 $-1 $16011 $12982 T -15 10 -10 -7.4999999999999982 15 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $16012 $16013 $16014 $16015 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $14489 $12984 $16016 $16017 reversed $11551 $-1 #
+coedge $-1 -1 -1 $-1 $16018 $16019 $12984 $14496 forward $16020 $-1 #
+edge $-1 -1 -1 $-1 $16021 -1.5707963267948966 $16022 6.1232339957367648e-17 $14495 $16023 forward @7 unknown T -15 10 20 -10 15 25 #
+edge $-1 -1 -1 $-1 $16024 1.5707963267948966 $12985 2.0943951023931953 $15937 $16025 forward @7 unknown T -25 5.0000000000000018 35 -22.5 5.6698729810778099 37.5 #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778081 37.5 #
+coedge $-1 -1 -1 $-1 $14502 $12987 $16026 $16027 forward $12988 $-1 #
+edge $-1 -1 -1 $-1 $12989 -32.5 $16028 -22.499999999999996 $12987 $16029 forward @7 unknown T -7.5 14.330127018922193 22.499999999999996 -7.4999999999999982 14.330127018922195 32.5 #
+point $-1 -1 -1 $-1 -7.5 14.330127018922193 32.5 #
+coedge $-1 -1 -1 $-1 $12991 $14499 $16030 $16031 forward $12988 $-1 #
+face $-1 -1 -1 $-1 $16032 $16033 $11 $-1 $12076 reversed single T 39.999999999999993 4.9999999999999991 2.6645352591003757e-15 50 15 10.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $16034 $11561 T -50 5 14.999999999999996 -50 15 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $16035 $16035 $16036 $16037 forward $12996 $-1 #
+coedge $-1 -1 -1 $-1 $16038 $12997 $16039 $16040 reversed $11562 $-1 #
+coedge $-1 -1 -1 $-1 $12997 $16038 $16041 $16042 forward $11562 $-1 #
+coedge $-1 -1 -1 $-1 $16043 $15963 $12997 $14509 reversed $15964 $-1 #
+edge $-1 -1 -1 $-1 $16044 1.5707963267948966 $16045 2.0943951023931957 $12997 $16046 forward @7 unknown T -10 5 20 -7.4999999999999991 5.669872981077809 22.500000000000004 #
+edge $-1 -1 -1 $-1 $16047 0 $16047 6.2831853071795862 $14441 $16048 forward @7 unknown T 50 5 15.000000000000004 50 15 25.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16030 $16049 $13001 $14513 forward $13517 $-1 #
+edge $-1 -1 -1 $-1 $16050 -1.5707963267948966 $14514 6.1232339957367648e-17 $14512 $16051 forward @7 unknown T 0 10 20 5.0000000000000009 15 25 #
+vertex $-1 -1 -1 $-1 $16052 $16053 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 10 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $16054 $16055 $11 $-1 $8101 reversed single T 0 10 5 7.5000000000000027 15 20 F #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 32.5 #
+coedge $-1 -1 -1 $-1 $13006 $16039 $15963 $16056 forward $11581 $-1 #
+coedge $-1 -1 -1 $-1 $16057 $13016 $13007 $14520 forward $14538 $-1 #
+edge $-1 -1 -1 $-1 $13018 -2.0943951023931948 $16050 -1.5707963267948966 $14519 $16058 forward @7 unknown T 5.0000000000000009 14.330127018922195 20 7.5000000000000009 15 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $13008 $16059 $13511 $15072 reversed $11573 $-1 #
+coedge $-1 -1 -1 $-1 $16060 $13009 $14534 $16061 reversed $10267 $-1 #
+edge $-1 -1 -1 $-1 $13505 -1.5707963267948966 $14531 6.1232339957367648e-17 $13502 $16062 forward @7 unknown T 0 10 -40 5.0000000000000009 15 -35 #
+coedge $-1 -1 -1 $-1 $13010 $16060 $16063 $16064 reversed $10267 $-1 #
+coedge $-1 -1 -1 $-1 $16065 $16066 $13010 $14526 forward $16067 $-1 #
+edge $-1 -1 -1 $-1 $14532 -6.1232339957367648e-17 $16068 1.5707963267948966 $14525 $16069 forward @7 unknown T 0 10 -30 5.0000000000000009 15 -25 #
+coedge $-1 -1 -1 $-1 $16070 $13011 $16066 $16071 forward $14530 $-1 #
+coedge $-1 -1 -1 $-1 $13011 $16072 $15066 $16073 forward $14530 $-1 #
+coedge $-1 -1 -1 $-1 $15058 $16074 $15063 $13012 reversed $16075 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13011 $13514 T -7.5 10 -40 8.8817841970012523e-16 15 -25 unknown #
+vertex $-1 -1 -1 $-1 $15059 $16076 #
+vertex $-1 -1 -1 $-1 $16071 $16077 #
+coedge $-1 -1 -1 $-1 $13013 $13456 $14522 $16061 forward $13457 $-1 #
+edge $-1 -1 -1 $-1 $13014 -1.5707963267948966 $14484 -6.1232339957367648e-17 $14427 $16078 forward @7 unknown T -15 5 30 -10 10 35 #
+point $-1 -1 -1 $-1 -10 5 35 #
+coedge $-1 -1 -1 $-1 $13016 $16057 $16079 $16080 reversed $14538 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14519 $16081 T 5.0000000000000009 14.330127018922195 17.500000000000004 10 15 22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $16080 $16082 #
+ellipse-curve $-1 -1 -1 $-1 10 10 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000009 14.330127018922195 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $16039 $13020 $16083 $16052 forward $11581 $-1 #
+coedge $-1 -1 -1 $-1 $13023 $13021 $15077 $16084 reversed $10722 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 10 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16085 $14557 $13023 $14546 reversed $13029 $-1 #
+edge $-1 -1 -1 $-1 $16086 2.9403902792268234e-16 $13024 1.5707963267948966 $13023 $16087 forward @7 unknown T 15 10 15 20 14.999999999999998 20 #
+point $-1 -1 -1 $-1 20 14.999999999999998 20 #
+vertex $-1 -1 -1 $-1 $16088 $16089 #
+face $-1 -1 -1 $-1 $16090 $16091 $11 $-1 $6219 reversed single T 15 10 -25 22.5 14.999999999999998 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $16092 $13028 T 15 10 -9.9999999999999982 22.5 15 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $16093 $16085 $15086 $16094 reversed $13029 $-1 #
+coedge $-1 -1 -1 $-1 $16095 $16096 $13030 $14553 reversed $16097 $-1 #
+edge $-1 -1 -1 $-1 $14548 1.5707963267948966 $14555 2.0943951023931957 $13030 $14540 forward @7 unknown T 7.4999999999999991 5 20 10 5.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $15946 $13031 $16096 $16098 reversed $14431 $-1 #
+vertex $-1 -1 -1 $-1 $16098 $16099 #
+straight-curve $-1 -1 -1 $-1 7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14545 $16100 $13033 $14558 reversed $13029 $-1 #
+edge $-1 -1 -1 $-1 $13024 1.5707963267948966 $14580 2.0943951023931957 $13033 $16101 forward @7 unknown T 20 14.330127018922191 17.5 22.500000000000004 14.999999999999998 20 #
+coedge $-1 -1 -1 $-1 $16102 $13110 $13035 $14560 forward $14634 $-1 #
+edge $-1 -1 -1 $-1 $13521 -2.0943951023931966 $16103 -1.570796326794897 $14559 $16104 forward @7 unknown T 20 4.9999999999999982 -27.500000000000004 22.500000000000004 5.669872981077809 -25 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13039 $13104 $16105 $16106 forward $13105 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13042 $13041 $16107 $16108 reversed $13043 $-1 #
+coedge $-1 -1 -1 $-1 $16105 $16109 $13041 $14566 reversed $16091 $-1 #
+edge $-1 -1 -1 $-1 $13044 -1.570796326794897 $16110 -2.9403902792268254e-16 $13041 $16111 forward @7 unknown T 15 10 -25 20.000000000000004 14.999999999999998 -19.999999999999996 #
+face $-1 -1 -1 $-1 $16112 $13043 $11 $-1 $13102 reversed single T 10 10 -30 20.000000000000004 15 -19.999999999999996 F #
+point $-1 -1 -1 $-1 20 14.999999999999998 -25 #
+coedge $-1 -1 -1 $-1 $13048 $13046 $16060 $16113 forward $11601 $-1 #
+coedge $-1 -1 -1 $-1 $16114 $16063 $13046 $14571 reversed $16115 $-1 #
+edge $-1 -1 -1 $-1 $14572 -1.5707963267948966 $16116 -1.0471975511965979 $13046 $16117 forward @7 unknown T 7.5 14.330127018922191 -27.500000000000004 10 15 -25 #
+vertex $-1 -1 -1 $-1 $14571 $16118 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16119 4.1887902047863914 $10712 4.7123889803846897 $13048 $13513 forward @7 unknown T 7.5000000000000009 14.330127018922195 -40 10 15 -37.5 #
+coedge $-1 -1 -1 $-1 $13050 $13511 $16120 $16121 forward $13051 $-1 #
+coedge $-1 -1 -1 $-1 $16122 $15081 $13050 $14577 reversed $16123 $-1 #
+edge $-1 -1 -1 $-1 $16124 -1.5707963267948966 $11603 0 $13050 $14573 forward @7 unknown T 10 5 -30 15 10 -25 #
+face $-1 -1 -1 $-1 $13500 $13051 $11 $-1 $6231 reversed single T 7.5 5 -40 15 10 -25 F #
+coedge $-1 -1 -1 $-1 $13526 $13055 $16100 $16125 forward $9508 $-1 #
+vertex $-1 -1 -1 $-1 $16125 $16126 #
+ellipse-curve $-1 -1 -1 $-1 25 10 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+face $-1 -1 -1 $-1 $11658 $16127 $11 $-1 $6231 reversed single T 7.5 4.9999999999999991 5.0000000000000009 15 10 20 F #
+coedge $-1 -1 -1 $-1 $13059 $15087 $16128 $16129 reversed $12067 $-1 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $11620 -1.5707963267948961 $13063 0 $13530 $14584 forward @7 unknown T 25 5 15 29.999999999999996 10 20 #
+point $-1 -1 -1 $-1 29.999999999999996 10 15 #
+vertex $-1 -1 -1 $-1 $13065 $16130 #
+coedge $-1 -1 -1 $-1 $13530 $16131 $13073 $13065 forward $13532 $-1 #
+face $-1 -1 -1 $-1 $16132 $16133 $11 $-1 $4445 reversed single T 29.999999999999996 4.9999999999999973 -9.9999999999999982 37.5 10 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $14605 $13067 T 29.999999999999996 4.9999999999999982 -24.999999999999996 37.500000000000007 10 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $16134 $13069 $16135 $16136 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $13069 $16137 $16138 $16139 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $16140 $16141 $13069 $14594 forward $16142 $-1 #
+edge $-1 -1 -1 $-1 $16143 -1.5707963267948966 $16144 -2.9403902792268224e-16 $14593 $16145 forward @7 unknown T 29.999999999999996 10 -9.9999999999999982 35 14.999999999999998 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $16146 $13463 $13070 $14596 forward $15022 $-1 #
+edge $-1 -1 -1 $-1 $13465 -2.0943951023931966 $14598 -1.5707963267948966 $14595 $16147 forward @7 unknown T 35 14.330127018922187 5.0000000000000018 37.500000000000007 14.999999999999998 7.5000000000000107 #
+coedge $-1 -1 -1 $-1 $13071 $15090 $16137 $16148 forward $12075 $-1 #
+vertex $-1 -1 -1 $-1 $16148 $16149 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $13074 $13073 $16150 $16151 forward $13075 $-1 #
+vertex $-1 -1 -1 $-1 $16152 $16153 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 14.330127018922195 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $13082 $13081 $16154 $16155 reversed $13083 $-1 #
+coedge $-1 -1 -1 $-1 $15099 $16156 $13081 $14606 reversed $14590 $-1 #
+edge $-1 -1 -1 $-1 $13084 1.5707963267948966 $16157 2.0943951023931966 $13081 $16158 forward @7 unknown T 35 4.9999999999999982 -24.999999999999996 37.500000000000007 5.669872981077809 -22.499999999999989 #
+face $-1 -1 -1 $-1 $13094 $13083 $11 $-1 $13102 reversed single T 35 4.9999999999999982 -27.499999999999996 40.000000000000007 5.669872981077809 -22.499999999999989 F #
+point $-1 -1 -1 $-1 35 4.9999999999999982 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $16159 $16159 $13086 $14610 reversed $16160 $-1 #
+edge $-1 -1 -1 $-1 $14611 -1.570796326794897 $14615 1.570796326794897 $13086 $16161 forward @7 unknown T 40 5 -29.999999999999996 45.000000000000007 15 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $13087 $16162 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16163 $16164 $13090 $14614 forward $16165 $-1 #
+edge $-1 -1 -1 $-1 $14617 4.1887902047863887 $14615 4.7123889803846897 $14613 $16166 forward @7 unknown T 37.499999999999993 14.330127018922186 -24.999999999999996 40.000000000000007 15 -22.499999999999986 #
+vertex $-1 -1 -1 $-1 $13091 $16167 #
+coedge $-1 -1 -1 $-1 $16168 $13092 $16164 $16169 reversed $13068 $-1 #
+vertex $-1 -1 -1 $-1 $14614 $16170 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16171 $16172 $11 $-1 $5329 reversed single T 22.5 4.9999999999999991 -9.9999999999999982 30 10 5.0000000000000036 F #
+coedge $-1 -1 -1 $-1 $16173 $13096 $16174 $14625 forward $14622 $-1 #
+coedge $-1 -1 -1 $-1 $13096 $16175 $13104 $14629 forward $14622 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14620 $16176 T 22.499999999999996 10 -25 30 15 -9.9999999999999964 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 10 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $13098 $16168 $16141 $16177 reversed $13068 $-1 #
+edge $-1 -1 -1 $-1 $13099 -20 $16178 -14.999999999999998 $14620 $16179 forward @7 unknown T 29.999999999999996 10 -20 30 10 -14.999999999999998 #
+edge $-1 -1 -1 $-1 $13099 3.1415926535897931 $13114 4.7123889803846897 $14635 $14623 forward @7 unknown T 25 5 -25 29.999999999999996 10 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 10 -20 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $16180 4.1887902047863914 $11652 4.7123889803846897 $14621 $16181 forward @7 unknown T 22.499999999999996 14.330127018922193 -25 25 15 -22.500000000000004 #
+face $-1 -1 -1 $-1 $16182 $13105 $11 $-1 $13102 reversed single T 19.999999999999996 14.330127018922189 -27.500000000000004 25 15 -22.500000000000004 F #
+point $-1 -1 -1 $-1 22.500000000000004 14.330127018922191 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.5 14.330127018922193 -37.5 #
+coedge $-1 -1 -1 $-1 $13110 $16102 $16183 $16184 reversed $14634 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14559 $16185 T 19.999999999999996 4.9999999999999982 -27.500000000000004 25 5.669872981077809 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $16183 $16174 $13112 $14626 forward $16186 $-1 #
+point $-1 -1 -1 $-1 25 5 -25 #
+coedge $-1 -1 -1 $-1 $13115 $13150 $16187 $16188 forward $11716 $-1 #
+coedge $-1 -1 -1 $-1 $13119 $16189 $13116 $13185 forward $14642 $-1 #
+coedge $-1 -1 -1 $-1 $16190 $14677 $13117 $14640 forward $16191 $-1 #
+edge $-1 -1 -1 $-1 $11701 2.3886802389739268e-16 $14718 1.5707963267948966 $14639 $16192 forward @7 unknown T -30 -9.9999999999999982 35 -25 -4.9999999999999991 40 #
+coedge $-1 -1 -1 $-1 $16189 $13119 $14702 $13175 reversed $14642 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14638 $16193 T -25 -10 32.5 -20 -9.330127018922191 37.5 unknown #
+coedge $-1 -1 -1 $-1 $13135 $16194 $13121 $13221 reversed $14659 $-1 #
+face $-1 -1 -1 $-1 $10753 $16195 $11 $-1 $9224 reversed single T -15 -10 -40 -7.4999999999999991 -4.9999999999999991 -25 F #
+loop $-1 -1 -1 $-1 $-1 $16196 $13124 T -15 -5 -40 -7.4999999999999991 8.8817841970012523e-16 -25 unknown #
+face $-1 -1 -1 $-1 $8159 $13125 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 20 7.5000000000000018 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $13127 $13233 $15165 $16197 reversed $13125 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13141 $13139 $13132 $14651 reversed $11690 $-1 #
+edge $-1 -1 -1 $-1 $14656 -1.5707963267948966 $14655 1.5707963267948966 $13132 $16198 forward @7 unknown T -45 -9.9999999999999964 35 -40 2.6645352591003757e-15 40 #
+coedge $-1 -1 -1 $-1 $16199 $13133 $16200 $16201 reversed $14654 $-1 #
+coedge $-1 -1 -1 $-1 $13133 $16202 $16203 $16204 reversed $14654 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16205 $16206 T -45 -9.9999999999999964 19.999999999999996 -37.5 2.6645352591003757e-15 35 unknown #
+vertex $-1 -1 -1 $-1 $13134 $16207 #
+vertex $-1 -1 -1 $-1 $13134 $16208 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13196 $13135 $13204 $14745 reversed $14659 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13196 $16209 T -15 -10 20 -7.5 -4.9999999999999991 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.499999999999993 -9.3301270189221963 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $16187 $16200 $13139 $14663 forward $16210 $-1 #
+edge $-1 -1 -1 $-1 $14655 1.5707963267948966 $14664 2.0943951023931953 $14662 $16211 forward @7 unknown T -40 -9.9999999999999964 35 -37.5 -9.3301270189221892 37.5 #
+vertex $-1 -1 -1 $-1 $14663 $16212 #
+straight-curve $-1 -1 -1 $-1 -37.5 -9.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16203 $13144 $13141 $14667 forward $14671 $-1 #
+edge $-1 -1 -1 $-1 $13146 -2.0943951023931957 $14656 -1.5707963267948966 $14666 $16213 forward @7 unknown T -40 -0.66987298107780657 35 -37.5 2.6645352591003757e-15 37.500000000000007 #
+face $-1 -1 -1 $-1 $16214 $15119 $11 $-1 $14669 reversed single T -45 -9.9999999999999964 -50 -37.5 2.6645352591003757e-15 -40 F #
+cone-surface $-1 -1 -1 $-1 -40 -4.9999999999999973 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $13144 $16203 $16215 $16216 reversed $14671 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14666 $16217 T -40 -0.66987298107781079 32.5 -35 2.6645352591003757e-15 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $16216 $16218 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.500000000000007 -0.66987298107780657 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $13152 $13148 $16219 $16220 reversed $13153 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14639 $16221 $13150 $13156 reversed $16191 $-1 #
+face $-1 -1 -1 $-1 $16217 $16210 $11 $-1 $6317 reversed single T -40 -10 32.5 -35 -9.3301270189221892 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $16222 $13151 T -37.500000000000007 -5 19.999999999999993 -29.999999999999993 0 35 unknown #
+coedge $-1 -1 -1 $-1 $16223 $14684 $13152 $14681 reversed $16224 $-1 #
+edge $-1 -1 -1 $-1 $16225 -4.1650370783741769e-16 $13154 1.5707963267948966 $13152 $16226 forward @7 unknown T -30 -5 30 -25 1.7763568394002505e-15 35 #
+point $-1 -1 -1 $-1 -25 1.7763568394002505e-15 35 #
+vertex $-1 -1 -1 $-1 $16227 $16228 #
+coedge $-1 -1 -1 $-1 $14680 $16229 $13158 $14685 reversed $16224 $-1 #
+edge $-1 -1 -1 $-1 $13154 1.5707963267948966 $14690 2.0943951023931948 $13158 $16230 forward @7 unknown T -25 -0.66987298107780746 32.5 -22.500000000000004 1.7763568394002505e-15 35 #
+face $-1 -1 -1 $-1 $13562 $16231 $11 $-1 $11706 reversed single T -30.000000000000007 -9.9999999999999982 -40 -22.5 -4.9999999999999991 -25 F #
+loop $-1 -1 -1 $-1 $-1 $16232 $13160 T -30.000000000000007 -5 -40 -22.5 1.7763568394002505e-15 -25 unknown #
+coedge $-1 -1 -1 $-1 $16233 $13540 $13542 $15107 reversed $13161 $-1 #
+coedge $-1 -1 -1 $-1 $16234 $13162 $16229 $16235 forward $13170 $-1 #
+vertex $-1 -1 -1 $-1 $16235 $16236 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16237 $16238 $11 $-1 $9738 reversed single T -37.500000000000007 -10 19.999999999999993 -29.999999999999993 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $13166 $16239 $16240 $14698 forward $13170 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16240 $14702 $13168 $14696 forward $16241 $-1 #
+edge $-1 -1 -1 $-1 $11721 -1.5707963267948966 $13172 0 $14695 $14694 forward @7 unknown T -20 -10 30 -15 -5 35 #
+face $-1 -1 -1 $-1 $16193 $16191 $11 $-1 $6317 reversed single T -35 -10 30 -25 -4.9999999999999991 40 F #
+edge $-1 -1 -1 $-1 $14716 25 $13172 30 $14693 $16242 forward @7 unknown T -15 -5 25 -15 -4.9999999999999991 30 #
+point $-1 -1 -1 $-1 -15 -5 30 #
+face $-1 -1 -1 $-1 $16243 $16241 $11 $-1 $10393 reversed single T -22.5 -10 20 -15 -4.9999999999999991 35 F #
+vertex $-1 -1 -1 $-1 $13175 $16244 #
+coedge $-1 -1 -1 $-1 $14695 $16245 $14641 $13175 forward $16241 $-1 #
+face $-1 -1 -1 $-1 $16246 $16247 $11 $-1 $9224 reversed single T -15.000000000000004 -10 -25 -7.5 -4.9999999999999991 -10 F #
+loop $-1 -1 -1 $-1 $-1 $16248 $13179 T -15.000000000000004 -5 -25 -7.4999999999999991 8.8817841970012523e-16 -10 unknown #
+coedge $-1 -1 -1 $-1 $15157 $16249 $15154 $16250 reversed $13180 $-1 #
+coedge $-1 -1 -1 $-1 $16251 $13181 $16252 $16253 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $13181 $16254 $16255 $16256 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $16257 $16258 $13181 $14709 forward $16259 $-1 #
+edge $-1 -1 -1 $-1 $16260 -1.5707963267948966 $16261 6.1232339957367648e-17 $14708 $16262 forward @7 unknown T -15 -4.9999999999999991 4.9999999999999991 -10 1.7763568394002505e-15 10 #
+coedge $-1 -1 -1 $-1 $16263 $14720 $13182 $14711 forward $16264 $-1 #
+edge $-1 -1 -1 $-1 $14722 -2.0943951023931957 $14715 -1.5707963267948966 $14710 $16265 forward @7 unknown T -10 -0.66987298107780813 20 -7.4999999999999991 8.8817841970012523e-16 22.5 #
+coedge $-1 -1 -1 $-1 $16266 $13183 $16239 $16267 reversed $14714 $-1 #
+coedge $-1 -1 -1 $-1 $13183 $16266 $16254 $16268 forward $14714 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13183 $16269 T -20 -5 15 -10 8.8817841970012523e-16 25 unknown #
+vertex $-1 -1 -1 $-1 $16268 $16270 #
+vertex $-1 -1 -1 $-1 $16271 $16272 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $16273 $16274 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14710 $16275 $13187 $14721 reversed $16264 $-1 #
+edge $-1 -1 -1 $-1 $14722 4.1887902047863914 $16276 4.7123889803846897 $13187 $16277 forward @7 unknown T -7.4999999999999991 -0.66987298107780657 20 -5 0 22.5 #
+vertex $-1 -1 -1 $-1 $14721 $16278 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $16279 $13199 $13190 $14725 reversed $12138 $-1 #
+edge $-1 -1 -1 $-1 $16276 1.5707963267948966 $13201 3.1415926535897931 $13190 $16280 forward @7 unknown T -5 -4.9999999999999991 20 0 0 25 #
+face $-1 -1 -1 $-1 $16281 $16282 $11 $-1 $9956 reversed single T -10 -10 2.4999999999999982 -5 -9.330127018922191 7.5000000000000009 F #
+coedge $-1 -1 -1 $-1 $14727 $14727 $13723 $15249 reversed $13192 $-1 #
+coedge $-1 -1 -1 $-1 $13193 $13193 $16283 $16284 forward $11738 $-1 #
+coedge $-1 -1 -1 $-1 $16285 $16286 $13193 $14730 reversed $16287 $-1 #
+edge $-1 -1 -1 $-1 $16288 -1.5707963267948966 $16289 1.5707963267948966 $13193 $16290 forward @7 unknown T -45 -9.9999999999999964 14.999999999999996 -40 2.6645352591003757e-15 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $13195 $13194 $16291 $16292 reversed $10414 $-1 #
+coedge $-1 -1 -1 $-1 $13204 $13228 $13194 $14733 forward $10433 $-1 #
+edge $-1 -1 -1 $-1 $16293 1.5707963267948966 $14738 2.0943951023931957 $14732 $16277 forward @7 unknown T -7.5000000000000009 -10 20 -5 -9.330127018922191 22.5 #
+coedge $-1 -1 -1 $-1 $16294 $16295 $13195 $14735 reversed $16296 $-1 #
+edge $-1 -1 -1 $-1 $16297 -2.0943951023931948 $14737 -1.5707963267948966 $13195 $16298 forward @7 unknown T -10 -10 17.499999999999996 -7.5000000000000018 -9.3301270189221928 20 #
+coedge $-1 -1 -1 $-1 $16194 $13196 $16299 $16300 reversed $14659 $-1 #
+vertex $-1 -1 -1 $-1 $16301 $16302 #
+vertex $-1 -1 -1 $-1 $13197 $16303 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13199 $16279 $16304 $16305 forward $12138 $-1 #
+vertex $-1 -1 -1 $-1 $16305 $16306 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13201 3.1415926535897931 $16293 4.7123889803846897 $13228 $16280 forward @7 unknown T -5 -10 20 0 -4.9999999999999991 25 #
+point $-1 -1 -1 $-1 0 -4.9999999999999991 25 #
+edge $-1 -1 -1 $-1 $14738 22.5 $11744 32.5 $13204 $16307 forward @7 unknown T -7.5000000000000018 -9.3301270189221945 22.5 -7.5 -9.3301270189221928 32.5 #
+coedge $-1 -1 -1 $-1 $13223 $13205 $16308 $16309 forward $13224 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13207 $15159 $16310 $16311 reversed $10425 $-1 #
+coedge $-1 -1 -1 $-1 $13210 $13208 $13247 $14790 reversed $9243 $-1 #
+edge $-1 -1 -1 $-1 $14796 -2.0943951023931953 $12126 -1.5707963267948966 $13220 $16312 forward @7 unknown T 5 -0.66987298107780813 -40 7.5000000000000009 0 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13248 $16313 $13210 $14753 forward $14792 $-1 #
+edge $-1 -1 -1 $-1 $14757 1.570796326794897 $14793 2.0943951023931957 $14752 $16314 forward @7 unknown T 5 -0.66987298107780902 -27.5 7.5000000000000018 0 -25 #
+coedge $-1 -1 -1 $-1 $16315 $13211 $16316 $16317 forward $14756 $-1 #
+coedge $-1 -1 -1 $-1 $13211 $16315 $13213 $14760 reversed $14756 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13211 $16318 T -5 -5 -30 5.0000000000000018 0 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $13212 $16319 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16320 $13213 $16321 $16322 forward $13216 $-1 #
+edge $-1 -1 -1 $-1 $13218 0 $16323 1.5707963267948966 $13213 $16324 forward @7 unknown T -5 -5 -30 0 0 -25 #
+coedge $-1 -1 -1 $-1 $13214 $16320 $15110 $16325 forward $13216 $-1 #
+edge $-1 -1 -1 $-1 $12128 1.5707963267948966 $13217 3.1415926535897931 $13214 $15151 forward @7 unknown T -5 -4.9999999999999991 -40 0 0 -35 #
+coedge $-1 -1 -1 $-1 $13215 $16326 $16327 $16328 forward $14764 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13215 $15152 T -7.5000000000000018 -10 -40 0 -4.9999999999999991 -25 unknown #
+point $-1 -1 -1 $-1 0 -4.9999999999999991 -35 #
+point $-1 -1 -1 $-1 0 -5 -30 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16329 $13605 $13223 $14769 forward $10783 $-1 #
+edge $-1 -1 -1 $-1 $13225 -1.5707963267948966 $16330 -1.0471975511965979 $14768 $16331 forward @7 unknown T 7.5 -0.66987298107780813 17.5 10 0 20 #
+face $-1 -1 -1 $-1 $16332 $13224 $11 $-1 $8848 reversed single T 5 -0.66987298107780902 17.5 10 0 22.499999999999996 F #
+point $-1 -1 -1 $-1 10 0 20 #
+coedge $-1 -1 -1 $-1 $15165 $16333 $13228 $14743 reversed $13604 $-1 #
+edge $-1 -1 -1 $-1 $16334 1.0471975511965979 $13230 1.5707963267948966 $16335 $16331 forward @7 unknown T 7.5 -10 17.5 10 -9.330127018922191 20 #
+point $-1 -1 -1 $-1 10 -10 20 #
+coedge $-1 -1 -1 $-1 $16336 $13231 $16335 $14773 reversed $14777 $-1 #
+coedge $-1 -1 -1 $-1 $13231 $16336 $13233 $14778 forward $14777 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14776 $13603 T 5 -10 17.5 10 -9.330127018922191 22.500000000000004 unknown #
+edge $-1 -1 -1 $-1 $16337 1.5707963267948966 $13234 2.0943951023931957 $14776 $16338 forward @7 unknown T 5 -10 20 7.5000000000000018 -9.330127018922191 22.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 -9.3301270189221945 22.500000000000004 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $13272 $13238 $13862 $15389 forward $13273 $-1 #
+vertex $-1 -1 -1 $-1 $13609 $16339 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14814 -2.0943951023931939 $11777 -1.5707963267948961 $13241 $16340 forward @7 unknown T 19.999999999999996 -0.66987298107780691 -25 22.499999999999993 -8.8817841970012523e-16 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $15392 $16341 $13243 $14786 forward $16342 $-1 #
+edge $-1 -1 -1 $-1 $13250 1.5707963267948966 $14787 3.1415926535897931 $14785 $16343 forward @7 unknown T 10 -4.9999999999999991 -25 15 0 -20 #
+vertex $-1 -1 -1 $-1 $16344 $16345 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14818 $14800 $11 $-1 $11805 reversed single T 10 -10 -30 20.000000000000004 -4.9999999999999991 -19.999999999999996 F #
+edge $-1 -1 -1 $-1 $14793 27.5 $14796 37.5 $13247 $16346 forward @7 unknown T 7.5 -0.66987298107780746 -37.5 7.5000000000000018 -0.66987298107780624 -27.5 #
+coedge $-1 -1 -1 $-1 $16313 $13248 $16341 $16347 reversed $14792 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16313 $16348 T 4.9999999999999973 -0.66987298107780902 -27.5 10 0 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $14753 $16349 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 0 -25 #
+vertex $-1 -1 -1 $-1 $13252 $16350 #
+coedge $-1 -1 -1 $-1 $16310 $16351 $13253 $14798 reversed $16352 $-1 #
+edge $-1 -1 -1 $-1 $15161 1.0471975511965974 $14801 1.5707963267948966 $13253 $14794 forward @7 unknown T 7.4999999999999991 -10 -27.500000000000004 10 -9.330127018922191 -25 #
+coedge $-1 -1 -1 $-1 $15169 $13254 $16353 $16344 reversed $14800 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13608 $14789 T 10 -10 -30 20.000000000000004 -4.9999999999999991 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $14798 $16354 #
+loop $-1 -1 -1 $-1 $-1 $13607 $13257 T 7.5 -10 5.0000000000000009 15 -4.9999999999999991 20 unknown #
+coedge $-1 -1 -1 $-1 $13607 $16335 $13258 $14804 forward $14802 $-1 #
+edge $-1 -1 -1 $-1 $13230 -1.5707963267948966 $13879 0 $14803 $15417 forward @7 unknown T 10 -10 15 15 -5 20 #
+coedge $-1 -1 -1 $-1 $14028 $15172 $13259 $14806 reversed $15385 $-1 #
+edge $-1 -1 -1 $-1 $11209 -2.0943951023931957 $13260 -1.5707963267948966 $13259 $16355 forward @7 unknown T 20 -10 17.5 22.500000000000004 -9.3301270189221928 20 #
+edge $-1 -1 -1 $-1 $13260 -1.5707963267948966 $13879 1.1640334398265738e-16 $13613 $16356 forward @7 unknown T 15 -10 15 20 -5 20 #
+point $-1 -1 -1 $-1 20 -10 20 #
+coedge $-1 -1 -1 $-1 $13262 $13262 $13987 $15489 reversed $14810 $-1 #
+loop $-1 -1 -1 $-1 $16357 $13262 $16358 T 39.999999999999993 -10 -29.999999999999996 45.000000000000007 0 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 -10 -24.999999999999996 #
+point $-1 -1 -1 $-1 40 0 -24.999999999999996 #
+vertex $-1 -1 -1 $-1 $13268 $16359 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 -5 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11172 $16360 $11 $-1 $5398 reversed single T 7.4999999999999991 -10 -10 15.000000000000004 -4.9999999999999991 5.0000000000000009 F #
+edge $-1 -1 -1 $-1 $11817 1.5707963267948961 $16361 2.0943951023931948 $13994 $14815 forward @7 unknown T 22.5 -10 -25.000000000000004 25 -9.3301270189221928 -22.500000000000004 #
+face $-1 -1 -1 $-1 $13269 $13273 $11 $-1 $11805 reversed single T 19.999999999999996 -10 -27.500000000000004 25 -9.330127018922191 -22.5 F #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $16362 $13280 T -30.000000000000007 -25 -40 -22.5 -20 -25 unknown #
+point $-1 -1 -1 $-1 -25 -25 35 #
+coedge $-1 -1 -1 $-1 $13288 $13286 $13699 $15229 forward $11842 $-1 #
+coedge $-1 -1 -1 $-1 $13962 $13703 $13286 $14825 reversed $15233 $-1 #
+edge $-1 -1 -1 $-1 $13848 -1.5707963267948966 $15234 -1.047197551196597 $13286 $15434 forward @7 unknown T -7.5000000000000036 -15.669872981077809 -27.500000000000004 -5 -15 -25 #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15230 4.1887902047863905 $10841 4.7123889803846897 $13288 $11077 forward @7 unknown T -7.5000000000000027 -15.669872981077809 -40 -5 -15 -37.5 #
+edge $-1 -1 -1 $-1 $13850 -1.5707963267948966 $11844 0 $13290 $14826 forward @7 unknown T -5 -25 -30 0 -20 -25 #
+coedge $-1 -1 -1 $-1 $16363 $13293 $16364 $14861 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $16365 $14857 $13293 $14831 reversed $16366 $-1 #
+edge $-1 -1 -1 $-1 $13330 -0.52359877559829893 $13315 1.5707963267948966 $13293 $16367 forward @7 unknown T -15 40 -50 -7.4999999999999982 45 -50 #
+coedge $-1 -1 -1 $-1 $13294 $16368 $16365 $14881 forward $13339 $-1 #
+coedge $-1 -1 -1 $-1 $16369 $15618 $13296 $14834 reversed $16370 $-1 #
+edge $-1 -1 -1 $-1 $13349 -1.5707963267948966 $13351 -1.0471975511965974 $13296 $13334 forward @7 unknown T 7.4999999999999991 44.330127018922191 -42.5 10 45 -40 #
+face $-1 -1 -1 $-1 $11902 $13298 $11 $-1 $11911 reversed single T 20.000000000000004 44.330127018922184 -42.500000000000007 25 45 -37.5 F #
+ellipse-curve $-1 -1 -1 $-1 40 40 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14837 $14837 $16371 $16372 reversed $13301 $-1 #
+face $-1 -1 -1 $-1 $16373 $16374 $11 $-1 $11911 reversed single T -9.9999999999999982 35 -42.500000000000014 -5 35.669872981077816 -37.5 F #
+face $-1 -1 -1 $-1 $10571 $13303 $11 $-1 $7001 reversed single T 37.5 35 -40 45.000000000000007 45 -24.999999999999993 F #
+coedge $-1 -1 -1 $-1 $13305 $15691 $14200 $15696 forward $13303 $-1 #
+point $-1 -1 -1 $-1 37.5 44.330127018922191 -37.5 #
+face $-1 -1 -1 $-1 $14192 $14078 $11 $-1 $12658 reversed single T 35 35 17.500000000000007 40.000000000000007 35.669872981077816 22.500000000000014 F #
+loop $-1 -1 -1 $-1 $-1 $14065 $13307 T 25 35 15 35 40 25.000000000000007 unknown #
+coedge $-1 -1 -1 $-1 $16375 $13308 $16376 $16377 forward $11864 $-1 #
+coedge $-1 -1 -1 $-1 $13308 $15604 $14074 $15546 forward $11864 $-1 #
+coedge $-1 -1 -1 $-1 $14190 $15675 $13308 $14847 reversed $12709 $-1 #
+edge $-1 -1 -1 $-1 $15683 -17.500000000000007 $16378 -7.5000000000000098 $13308 $16379 forward @7 unknown T 37.499999999999993 44.330127018922191 7.5000000000000098 37.500000000000007 44.330127018922198 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $13309 $16380 $16381 $16382 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $16383 $16384 $13309 $14850 reversed $16385 $-1 #
+edge $-1 -1 -1 $-1 $16386 1.5707963267948966 $14854 3.6651914291880914 $13309 $16387 forward @7 unknown T -30 35 -50 -22.5 40 -50 #
+coedge $-1 -1 -1 $-1 $16388 $13310 $16384 $16389 forward $14853 $-1 #
+coedge $-1 -1 -1 $-1 $13310 $16390 $13312 $14858 reversed $14853 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14852 $16391 T -22.5 35 -50 -15 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $13311 $16392 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14859 $13312 $16393 $16394 reversed $13314 $-1 #
+coedge $-1 -1 -1 $-1 $14830 $16395 $16396 $14858 reversed $16366 $-1 #
+edge $-1 -1 -1 $-1 $13315 -50 $16397 -45 $16396 $16398 forward @7 unknown T -15 40 -50 -15 40 -45 #
+coedge $-1 -1 -1 $-1 $13313 $14856 $16399 $16400 reversed $13314 $-1 #
+face $-1 -1 -1 $-1 $15525 $13314 $11 $-1 $12646 reversed single T -15 35 -50 -7.4999999999999893 40 -40 F #
+edge $-1 -1 -1 $-1 $13315 0 $16401 2.0943951023931957 $14829 $14855 forward @7 unknown T -22.5 40 -50 -15 45 -50 #
+point $-1 -1 -1 $-1 -15 40 -50 #
+coedge $-1 -1 -1 $-1 $16399 $16402 $13317 $14864 reversed $16374 $-1 #
+edge $-1 -1 -1 $-1 $14865 1.0471975511965952 $16403 1.5707963267948966 $13317 $16404 forward @7 unknown T -7.5000000000000107 35 -42.500000000000014 -5 35.669872981077816 -40 #
+vertex $-1 -1 -1 $-1 $14864 $16405 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16406 $13322 $13319 $14868 reversed $14871 $-1 #
+edge $-1 -1 -1 $-1 $16403 -1.5707963267948966 $13326 0 $13319 $16407 forward @7 unknown T -5 35 -45 0 40 -40 #
+face $-1 -1 -1 $-1 $16408 $16409 $11 $-1 $16410 reversed single T -9.9999999999999982 44.330127018922184 -12.5 -5 45 -7.4999999999999947 F #
+coedge $-1 -1 -1 $-1 $13322 $16406 $16411 $16412 forward $14871 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13322 $16413 T -5 35 -45 5.0000000000000027 40 -35 unknown #
+vertex $-1 -1 -1 $-1 $13323 $16414 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $16415 $16416 $13324 $14875 forward $16417 $-1 #
+edge $-1 -1 -1 $-1 $13326 -6.1232339957367648e-17 $16418 1.5707963267948966 $14874 $16419 forward @7 unknown T 0 40 -45 5.0000000000000027 45 -40 #
+coedge $-1 -1 -1 $-1 $16368 $13325 $16416 $14877 forward $13339 $-1 #
+edge $-1 -1 -1 $-1 $13326 0 $16420 1.5707963267948966 $14876 $16407 forward @7 unknown T -5 40 -45 0 45 -40 #
+point $-1 -1 -1 $-1 0 40 -45 #
+coedge $-1 -1 -1 $-1 $13331 $13328 $15613 $16421 forward $13332 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $16422 42.5 $13330 50 $14832 $16423 forward @7 unknown T -7.5 44.330127018922191 -50 -7.4999999999999991 44.330127018922191 -42.5 #
+point $-1 -1 -1 $-1 -7.4999999999999991 44.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $16424 $14887 $13331 $14884 forward $15656 $-1 #
+edge $-1 -1 -1 $-1 $13333 1.5707963267948966 $16425 2.0943951023931948 $14883 $16426 forward @7 unknown T 7.5000000000000018 35 -40 10 35.669872981077809 -37.5 #
+face $-1 -1 -1 $-1 $16427 $13332 $11 $-1 $11911 reversed single T 5.0000000000000027 35 -42.5 10 35.669872981077809 -37.5 F #
+point $-1 -1 -1 $-1 10 35 -40 #
+coedge $-1 -1 -1 $-1 $14883 $14161 $13336 $14888 forward $15656 $-1 #
+edge $-1 -1 -1 $-1 $14163 3.1415926535897931 $13333 4.7123889803846897 $14887 $16428 forward @7 unknown T 10 35 -40 15 40 -35 #
+face $-1 -1 -1 $-1 $16429 $16430 $11 $-1 $12658 reversed single T -5 40 15 5.0000000000000027 45 25 F #
+loop $-1 -1 -1 $-1 $-1 $16431 $13338 T 7.4999999999999991 40 5.0000000000000009 15.000000000000002 45 20 unknown #
+coedge $-1 -1 -1 $-1 $16432 $13340 $11303 $12690 forward $11302 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14835 $13346 $11 $-1 $11911 reversed single T 10 40 -45 20.000000000000004 45 -35 F #
+coedge $-1 -1 -1 $-1 $13345 $13344 $14160 $15654 reversed $13346 $-1 #
+point $-1 -1 -1 $-1 20.000000000000004 45 -40 #
+point $-1 -1 -1 $-1 10 45 -40 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16418 1.5707963267948966 $13351 2.0943951023931948 $15618 $16433 forward @7 unknown T 5.0000000000000027 44.330127018922191 -42.5 7.5 45 -40 #
+point $-1 -1 -1 $-1 7.5 44.330127018922191 -42.5 #
+edge $-1 -1 -1 $-1 $13354 -37.5 $16434 -27.500000000000004 $13353 $16435 forward @7 unknown T 22.5 35.669872981077802 -37.5 22.500000000000007 35.669872981077809 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000007 35.669872981077802 -37.5 #
+face $-1 -1 -1 $-1 $16436 $16437 $11 $-1 $14913 reversed single T 9.9999999999999982 40 -9.3734986416366073e-33 20.000000000000004 45 10 F #
+face $-1 -1 -1 $-1 $15662 $15680 $11 $-1 $12658 reversed single T 20.000000000000004 35 17.5 25 35.669872981077809 22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $16438 $13358 T 10 35 15 20.000000000000004 40 25 unknown #
+coedge $-1 -1 -1 $-1 $15660 $13360 $14175 $15665 forward $11907 $-1 #
+coedge $-1 -1 -1 $-1 $13360 $16439 $16440 $16441 forward $11907 $-1 #
+coedge $-1 -1 -1 $-1 $16442 $16443 $16444 $14908 reversed $16445 $-1 #
+edge $-1 -1 -1 $-1 $16446 10.000000000000002 $15668 15 $13360 $16447 forward @7 unknown T 29.999999999999996 40 10.000000000000002 30 40 15 #
+coedge $-1 -1 -1 $-1 $14217 $16448 $13361 $14910 forward $15718 $-1 #
+edge $-1 -1 -1 $-1 $15689 -1.5707963267948966 $11335 -6.1232339957367648e-17 $14909 $16449 forward @7 unknown T 29.999999999999996 35 -30 35 40 -24.999999999999996 #
+face $-1 -1 -1 $-1 $16450 $16451 $11 $-1 $14913 reversed single T 24.999999999999996 35 1.7763568394002505e-15 35 40 10.000000000000002 F #
+loop $-1 -1 -1 $-1 $-1 $15676 $13363 T 25 40 1.7763568394002505e-15 35 45 10.000000000000002 unknown #
+cone-surface $-1 -1 -1 $-1 -3.0616169978683826e-16 40 5 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $16452 $13365 $16453 $16454 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $14947 $16455 $13365 $13397 reversed $16456 $-1 #
+coedge $-1 -1 -1 $-1 $16457 $13366 $13368 $13417 reversed $14917 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14916 $14229 T -15 25 -50 -7.4999999999999991 30 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $13368 $13412 $16458 $16459 forward $11966 $-1 #
+coedge $-1 -1 -1 $-1 $15833 $13369 $14354 $15873 reversed $14921 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14319 $16460 T 5.0000000000000018 29.330127018922191 -42.5 10 30 -37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $14922 $14922 $13373 $14923 forward $16461 $-1 #
+edge $-1 -1 -1 $-1 $16462 0 $16462 6.2831853071795862 $14922 $16463 forward @7 unknown T 50 20 -45 50 30 -35 #
+face $-1 -1 -1 $-1 $16464 $16465 $11 $-1 $10647 reversed single T -25 29.330127018922191 -42.5 -20 30 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $16466 $13374 T -9.9999999999999982 20 -42.5 -5 20.669872981077805 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $16467 $13380 $16468 $16469 forward $10600 $-1 #
+coedge $-1 -1 -1 $-1 $15894 $16470 $13380 $14928 reversed $16471 $-1 #
+edge $-1 -1 -1 $-1 $14929 4.1887902047863905 $16472 4.7123889803846897 $13380 $16473 forward @7 unknown T 37.500000000000007 29.330127018922191 5.0000000000000027 40.000000000000007 30 7.5000000000000098 #
+vertex $-1 -1 -1 $-1 $14928 $16474 #
+coedge $-1 -1 -1 $-1 $13384 $16452 $16475 $16476 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $16477 $13730 $13384 $14933 reversed $12287 $-1 #
+edge $-1 -1 -1 $-1 $16478 -2.0943951023931948 $14937 0 $13384 $16479 forward @7 unknown T -37.5 20 -50 -30 25 -50 #
+coedge $-1 -1 -1 $-1 $16480 $13385 $16481 $15255 forward $14936 $-1 #
+coedge $-1 -1 -1 $-1 $13385 $16482 $13387 $14940 reversed $14936 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14935 $16483 T -30 20 -50 -22.499999999999996 25 -40 unknown #
+vertex $-1 -1 -1 $-1 $16484 $16485 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $14941 $13387 $16486 $16487 forward $13389 $-1 #
+edge $-1 -1 -1 $-1 $13390 -50 $16488 -42.500000000000014 $13387 $16489 forward @7 unknown T -22.500000000000004 20.669872981077805 -50 -22.5 20.669872981077813 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $13388 $14939 $16490 $16491 forward $13389 $-1 #
+face $-1 -1 -1 $-1 $16492 $13389 $11 $-1 $12796 reversed single T -22.500000000000007 20 -50 -15 25 -40 F #
+point $-1 -1 -1 $-1 -22.5 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $16490 $16493 $13392 $14945 forward $16494 $-1 #
+edge $-1 -1 -1 $-1 $16495 -1.5707963267948966 $14948 -6.1232339957367648e-17 $14944 $16496 forward @7 unknown T -15 20 -45 -9.9999999999999982 25 -40 #
+coedge $-1 -1 -1 $-1 $13393 $16457 $16497 $16498 reversed $14917 $-1 #
+coedge $-1 -1 -1 $-1 $16499 $14915 $13388 $13394 forward $16456 $-1 #
+vertex $-1 -1 -1 $-1 $16500 $16501 #
+straight-curve $-1 -1 -1 $-1 -15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16466 $13399 $13395 $14951 forward $14925 $-1 #
+edge $-1 -1 -1 $-1 $13401 -2.0943951023931948 $16495 -1.5707963267948966 $14950 $16502 forward @7 unknown T -9.9999999999999982 20 -42.5 -7.4999999999999964 20.669872981077805 -40 #
+vertex $-1 -1 -1 $-1 $16454 $16503 #
+coedge $-1 -1 -1 $-1 $13399 $16466 $16504 $16505 reversed $14925 $-1 #
+vertex $-1 -1 -1 $-1 $13400 $16506 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999964 20.669872981077802 -42.5 #
+coedge $-1 -1 -1 $-1 $13406 $13403 $16507 $16508 reversed $13407 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16509 $16510 $11 $-1 $14961 reversed single T -20 25 -15.000000000000002 -9.9999999999999982 30 -5 F #
+loop $-1 -1 -1 $-1 $-1 $16511 $13405 T -9.9999999999999982 29.330127018922184 -12.5 -5 30 -7.4999999999999947 unknown #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 25 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $16512 $14314 $13406 $14963 reversed $12828 $-1 #
+edge $-1 -1 -1 $-1 $15830 6.1232339957367648e-17 $13408 1.5707963267948966 $13406 $16513 forward @7 unknown T 0 20 -40 5.0000000000000018 25 -35 #
+face $-1 -1 -1 $-1 $16514 $13407 $11 $-1 $10647 reversed single T -5 20 -45 5.0000000000000018 25 -35 F #
+point $-1 -1 -1 $-1 5.0000000000000018 20 -40 #
+coedge $-1 -1 -1 $-1 $16515 $13410 $14315 $15822 forward $14968 $-1 #
+coedge $-1 -1 -1 $-1 $13410 $16515 $13412 $13413 reversed $14968 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13410 $16514 T -5 25 -45 5.0000000000000018 30 -35 unknown #
+vertex $-1 -1 -1 $-1 $13411 $16516 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $16459 $16517 #
+edge $-1 -1 -1 $-1 $13408 1.5707963267948966 $14976 2.0943951023931944 $13415 $16518 forward @7 unknown T 5.0000000000000018 20 -40 7.5 20.669872981077813 -37.500000000000007 #
+vertex $-1 -1 -1 $-1 $16519 $16520 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $15874 $13419 $15820 $16521 forward $14357 $-1 #
+vertex $-1 -1 -1 $-1 $16521 $16522 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16523 $15829 $11 $-1 $9021 reversed single T -7.5 25 -40 8.8817841970012523e-16 30 -25 F #
+ellipse-curve $-1 -1 -1 $-1 10 25 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16524 $16525 $11 $-1 $11403 reversed single T -5 20 15 5.0000000000000018 25 25 F #
+loop $-1 -1 -1 $-1 $-1 $15811 $13425 T -5 25 15 5.0000000000000018 30 25 unknown #
+coedge $-1 -1 -1 $-1 $16526 $16527 $16528 $16529 forward $13426 $-1 #
+coedge $-1 -1 -1 $-1 $14341 $13427 $16530 $16531 reversed $10158 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $14417 $16532 #
+straight-curve $-1 -1 -1 $-1 22.5 20.669872981077805 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $16533 $16534 $11 $-1 $13449 reversed single T 10 20 -9.3734986416366073e-33 20 25 10 F #
+loop $-1 -1 -1 $-1 $-1 $16535 $13438 T 9.9999999999999982 25 -9.3734986416366073e-33 20 30 10 unknown #
+coedge $-1 -1 -1 $-1 $16536 $14365 $14235 $15733 forward $13440 $-1 #
+coedge $-1 -1 -1 $-1 $13442 $15878 $16537 $16538 forward $10643 $-1 #
+coedge $-1 -1 -1 $-1 $16539 $14377 $13442 $14992 reversed $13448 $-1 #
+edge $-1 -1 -1 $-1 $16540 1.570796326794897 $14997 3.1415926535897931 $13442 $16541 forward @7 unknown T 25 25 5.0000000000000018 29.999999999999996 30 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $16542 $13443 $16543 $16544 forward $14996 $-1 #
+coedge $-1 -1 -1 $-1 $13443 $15887 $14367 $15884 forward $14996 $-1 #
+coedge $-1 -1 -1 $-1 $15738 $16545 $14368 $13444 forward $16546 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13443 $14386 T 22.499999999999996 20 4.9999999999999991 30 25 20 unknown #
+vertex $-1 -1 -1 $-1 $16544 $16547 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13445 $14418 $16548 $16549 forward $14419 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16550 $16551 $11 $-1 $13449 reversed single T 35 19.999999999999996 2.5000000000000071 40.000000000000007 20.669872981077813 7.5000000000000107 F #
+loop $-1 -1 -1 $-1 $-1 $16552 $13447 T 24.999999999999996 19.999999999999996 1.7763568394002505e-15 35 25 10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $13467 $13450 $16553 $15035 forward $2404 $-1 #
+coedge $-1 -1 -1 $-1 $15994 $15032 $13450 $15005 reversed $14473 $-1 #
+edge $-1 -1 -1 $-1 $13488 -0.52359877559829893 $13473 1.570796326794897 $13450 $16554 forward @7 unknown T -30 10 -50 -22.5 15.000000000000002 -50 #
+coedge $-1 -1 -1 $-1 $13451 $16555 $15994 $16556 forward $15007 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13483 $16557 T -22.500000000000004 10 -50 -15 15 -40 unknown #
+coedge $-1 -1 -1 $-1 $13482 $13452 $16558 $15070 reversed $13453 $-1 #
+coedge $-1 -1 -1 $-1 $16559 $16558 $13455 $15010 reversed $16560 $-1 #
+edge $-1 -1 -1 $-1 $13507 -1.5707963267948966 $13509 -1.0471975511965974 $13455 $13491 forward @7 unknown T -7.5000000000000009 14.330127018922191 -42.5 -5 15 -40 #
+face $-1 -1 -1 $-1 $12048 $13457 $11 $-1 $9512 reversed single T 5.0000000000000009 14.330127018922191 -42.500000000000014 10 15 -37.5 F #
+loop $-1 -1 -1 $-1 $12761 $13458 $1558 T 50 5 -45 50 15 -35 hole $1559 T #
+vertex $-1 -1 -1 $-1 $13459 $16561 #
+ellipse-curve $-1 -1 -1 $-1 50 10 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $8983 $16562 $11 $-1 $9512 reversed single T -50 5 -45 -40 15.000000000000002 -35 F #
+loop $-1 -1 -1 $-1 $-1 $16563 $13460 T -25 14.330127018922191 -42.5 -20 15.000000000000002 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $13489 $13486 $16564 $16565 forward $13461 $-1 #
+coedge $-1 -1 -1 $-1 $14449 $13462 $16566 $16567 forward $9465 $-1 #
+coedge $-1 -1 -1 $-1 $16568 $16568 $13462 $15020 reversed $16033 $-1 #
+edge $-1 -1 -1 $-1 $15023 1.570796326794897 $16569 4.7123889803846897 $13462 $16570 forward @7 unknown T 39.999999999999993 5 5.0000000000000027 44.999999999999993 15 10.000000000000004 #
+coedge $-1 -1 -1 $-1 $13463 $16146 $16571 $16572 reversed $15022 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14595 $15101 T 35 14.330127018922187 2.5000000000000053 40.000000000000007 15 7.5000000000000107 unknown #
+vertex $-1 -1 -1 $-1 $16572 $16573 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 14.330127018922191 7.5000000000000107 #
+coedge $-1 -1 -1 $-1 $16574 $16575 $13467 $15027 reversed $16576 $-1 #
+edge $-1 -1 -1 $-1 $16577 -0.52359877559829893 $15029 3.6651914291880923 $13467 $16578 forward @7 unknown T -45 5.0000000000000018 -50 -37.5 15.000000000000002 -50 #
+coedge $-1 -1 -1 $-1 $15256 $13468 $16575 $16579 forward $10936 $-1 #
+vertex $-1 -1 -1 $-1 $13469 $16580 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15033 $13470 $16581 $16582 reversed $13472 $-1 #
+coedge $-1 -1 -1 $-1 $15004 $16583 $15260 $13732 reversed $14473 $-1 #
+coedge $-1 -1 -1 $-1 $13471 $15031 $16584 $16585 reversed $13472 $-1 #
+face $-1 -1 -1 $-1 $10238 $13472 $11 $-1 $12964 reversed single T -30 5.0000000000000018 -50 -22.5 10 -40 F #
+edge $-1 -1 -1 $-1 $13473 0 $16577 2.0943951023931948 $15003 $15030 forward @7 unknown T -37.5 10 -50 -30 15 -50 #
+point $-1 -1 -1 $-1 -30 10 -50 #
+coedge $-1 -1 -1 $-1 $16584 $16586 $13475 $15038 reversed $16587 $-1 #
+edge $-1 -1 -1 $-1 $15039 1.0471975511965974 $16588 1.5707963267948966 $13475 $16589 forward @7 unknown T -22.5 5 -42.5 -20 5.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $15038 $16590 #
+straight-curve $-1 -1 -1 $-1 -22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16591 $13480 $13477 $15042 reversed $15045 $-1 #
+edge $-1 -1 -1 $-1 $16588 -1.5707963267948966 $13484 0 $13477 $16592 forward @7 unknown T -20 5 -45 -15 10 -40 #
+face $-1 -1 -1 $-1 $16593 $16594 $11 $-1 $11541 reversed single T -22.500000000000004 10 -40 -15 15 -25 F #
+coedge $-1 -1 -1 $-1 $13480 $16591 $16595 $16596 forward $15045 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13480 $16597 T -20 5 -45 -10 10 -35 unknown #
+vertex $-1 -1 -1 $-1 $13481 $16598 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $16599 $16600 $13482 $15049 forward $16601 $-1 #
+edge $-1 -1 -1 $-1 $13484 -6.1232339957367648e-17 $16602 1.5707963267948966 $15048 $16603 forward @7 unknown T -15 10 -45 -10 15 -40 #
+coedge $-1 -1 -1 $-1 $16555 $13483 $16600 $15051 forward $15007 $-1 #
+edge $-1 -1 -1 $-1 $13484 0 $16604 1.5707963267948966 $15050 $16592 forward @7 unknown T -20 10 -45 -15 15 -40 #
+point $-1 -1 -1 $-1 -15 10 -45 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -22.5 14.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $16605 $15058 $13489 $15056 forward $16075 $-1 #
+edge $-1 -1 -1 $-1 $13490 1.5707963267948966 $16606 2.0943951023931957 $15055 $16607 forward @7 unknown T -7.5000000000000009 5 -40 -5 5.669872981077809 -37.5 #
+point $-1 -1 -1 $-1 -5 5 -40 #
+coedge $-1 -1 -1 $-1 $15055 $14529 $13493 $15059 forward $16075 $-1 #
+edge $-1 -1 -1 $-1 $14531 3.1415926535897931 $13490 4.7123889803846897 $15058 $16608 forward @7 unknown T -5 5 -40 0 10 -35 #
+face $-1 -1 -1 $-1 $16609 $16610 $11 $-1 $13497 reversed single T -20 5 -15.000000000000002 -10 10 -5 F #
+loop $-1 -1 -1 $-1 $-1 $16611 $13495 T -20 10 -15.000000000000002 -10 15 -5 unknown #
+coedge $-1 -1 -1 $-1 $16612 $16613 $16614 $16615 forward $13496 $-1 #
+coedge $-1 -1 -1 $-1 $16616 $13498 $11574 $13012 forward $11573 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15011 $13504 $11 $-1 $9512 reversed single T -5 10 -45 5.0000000000000009 15 -35 F #
+coedge $-1 -1 -1 $-1 $13503 $13502 $14528 $16073 reversed $13504 $-1 #
+point $-1 -1 -1 $-1 5.0000000000000009 15 -40 #
+point $-1 -1 -1 $-1 -5 15 -40 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16602 1.5707963267948966 $13509 2.0943951023931957 $16558 $16617 forward @7 unknown T -10 14.330127018922191 -42.5 -7.4999999999999991 15 -40 #
+point $-1 -1 -1 $-1 -7.5 14.330127018922193 -42.5 #
+edge $-1 -1 -1 $-1 $13512 -37.500000000000007 $16618 -27.5 $13511 $16619 forward @7 unknown T 7.5 5.6698729810778064 -37.500000000000007 7.5000000000000018 5.6698729810778072 -27.5 #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 -37.500000000000007 #
+face $-1 -1 -1 $-1 $16620 $16621 $11 $-1 $12076 reversed single T -5 10 -8.8817841970012523e-16 5.0000000000000009 15 10 F #
+face $-1 -1 -1 $-1 $16081 $16097 $11 $-1 $10259 reversed single T 5.0000000000000009 4.9999999999999991 17.5 10 5.669872981077809 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $16622 $13516 T -5 4.9999999999999991 15 5.0000000000000009 10 25 unknown #
+coedge $-1 -1 -1 $-1 $16079 $13518 $14543 $16084 forward $12053 $-1 #
+coedge $-1 -1 -1 $-1 $13518 $16623 $16624 $16625 forward $12053 $-1 #
+coedge $-1 -1 -1 $-1 $16626 $16128 $16627 $15080 reversed $16127 $-1 #
+edge $-1 -1 -1 $-1 $16628 10 $16086 15 $13518 $16629 forward @7 unknown T 14.999999999999996 10 10 15 10 15 #
+coedge $-1 -1 -1 $-1 $14576 $16630 $13519 $15082 forward $16123 $-1 #
+edge $-1 -1 -1 $-1 $16103 -1.5707963267948961 $11603 2.9403902792268224e-16 $15081 $16631 forward @7 unknown T 15 4.9999999999999982 -30 20 10 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 5.6698729810778072 -27.500000000000004 #
+face $-1 -1 -1 $-1 $16632 $16633 $11 $-1 $12076 reversed single T 20 4.9999999999999973 2.5000000000000044 25 5.6698729810778064 7.5000000000000027 F #
+loop $-1 -1 -1 $-1 $-1 $16634 $13523 T 10 4.9999999999999973 -4.6867493208183037e-33 20 10 10 unknown #
+coedge $-1 -1 -1 $-1 $16624 $16635 $14551 $16094 forward $13524 $-1 #
+coedge $-1 -1 -1 $-1 $14583 $13525 $16636 $16152 forward $12067 $-1 #
+coedge $-1 -1 -1 $-1 $16637 $16638 $13526 $15089 reversed $16639 $-1 #
+edge $-1 -1 -1 $-1 $16640 4.1887902047863923 $15091 4.7123889803846897 $13526 $16641 forward @7 unknown T 22.500000000000004 14.330127018922195 5.0000000000000018 25 15 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $14597 $13527 $16642 $16643 reversed $12075 $-1 #
+vertex $-1 -1 -1 $-1 $16644 $16645 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16131 $13529 $16646 $16647 forward $13532 $-1 #
+coedge $-1 -1 -1 $-1 $15103 $16648 $13529 $15095 reversed $13538 $-1 #
+edge $-1 -1 -1 $-1 $13533 3.1415926535897931 $16649 4.7123889803846897 $13529 $15092 forward @7 unknown T 24.999999999999996 5 5.0000000000000018 29.999999999999996 10 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $13531 $16650 $15103 $16651 reversed $15097 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16650 $16132 T 29.999999999999996 4.9999999999999973 5.0000000000000018 37.500000000000014 10 20.000000000000004 unknown #
+point $-1 -1 -1 $-1 29.999999999999996 10 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $16652 $14605 $13535 $15100 reversed $14590 $-1 #
+edge $-1 -1 -1 $-1 $13099 -2.9403902792268234e-16 $13084 1.5707963267948966 $13535 $16653 forward @7 unknown T 29.999999999999996 4.9999999999999982 -24.999999999999996 35 10 -19.999999999999996 #
+face $-1 -1 -1 $-1 $11647 $15022 $11 $-1 $12076 reversed single T 35 14.330127018922187 2.5000000000000053 40.000000000000007 15 7.5000000000000107 F #
+loop $-1 -1 -1 $-1 $-1 $16654 $13537 T 35 4.9999999999999973 2.5000000000000053 40.000000000000007 5.669872981077809 7.5000000000000062 unknown #
+coedge $-1 -1 -1 $-1 $16655 $15094 $15096 $16651 forward $13538 $-1 #
+coedge $-1 -1 -1 $-1 $13737 $16656 $13539 $13563 reversed $15271 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $13542 $13578 $16657 $16658 forward $13543 $-1 #
+edge $-1 -1 -1 $-1 $16659 42.5 $12110 50 $13542 $16660 forward @7 unknown T -22.500000000000004 -0.66987298107780746 -50 -22.5 -0.66987298107780546 -42.5 #
+face $-1 -1 -1 $-1 $16661 $13543 $11 $-1 $10393 reversed single T -22.500000000000004 -5 -50 -15 0 -40 F #
+coedge $-1 -1 -1 $-1 $13545 $16662 $13544 $13598 forward $15111 $-1 #
+coedge $-1 -1 -1 $-1 $16662 $13545 $14761 $16325 reversed $15111 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16662 $16663 T -10 -0.66987298107780902 -42.5 -5 8.8817841970012523e-16 -37.500000000000007 unknown #
+point $-1 -1 -1 $-1 50 -5 -45 #
+loop $-1 -1 -1 $-1 $16664 $16665 $13551 T -45 -9.9999999999999964 -45 -40 2.6645352591003757e-15 -35 unknown #
+coedge $-1 -1 -1 $-1 $16657 $16666 $16233 $16667 forward $13552 $-1 #
+coedge $-1 -1 -1 $-1 $15138 $16668 $13553 $15116 reversed $16195 $-1 #
+edge $-1 -1 -1 $-1 $13574 1.5707963267948966 $15149 2.0943951023931957 $13553 $16669 forward @7 unknown T -10 -10 -40 -7.4999999999999991 -9.330127018922191 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $16670 $13554 $16656 $16671 reversed $15119 $-1 #
+coedge $-1 -1 -1 $-1 $13554 $16672 $13556 $15122 reversed $15119 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15117 $14668 T -45 -9.9999999999999964 -50 -37.5 2.6645352591003757e-15 -40 unknown #
+vertex $-1 -1 -1 $-1 $16671 $16673 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $13557 -50 $16674 -42.500000000000007 $13556 $16675 forward @7 unknown T -37.5 -9.3301270189221945 -50 -37.5 -9.330127018922191 -42.500000000000007 #
+point $-1 -1 -1 $-1 -37.5 -9.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $13734 $16676 $13559 $15125 forward $15265 $-1 #
+edge $-1 -1 -1 $-1 $16677 -1.5707963267948966 $13736 -4.1650370783741769e-16 $15124 $16678 forward @7 unknown T -30 -9.9999999999999982 -45 -25 -5 -40 #
+coedge $-1 -1 -1 $-1 $13560 $16233 $16679 $16680 reversed $13161 $-1 #
+coedge $-1 -1 -1 $-1 $16681 $13565 $13561 $15128 forward $15130 $-1 #
+edge $-1 -1 -1 $-1 $13567 -2.0943951023931957 $16677 -1.5707963267948966 $15127 $16682 forward @7 unknown T -25 -9.9999999999999982 -42.500000000000007 -22.5 -9.3301270189221892 -40 #
+coedge $-1 -1 -1 $-1 $13565 $16681 $16683 $16684 reversed $15130 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15127 $15136 T -25 -10 -42.500000000000007 -20 -9.3301270189221892 -37.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $13566 $16685 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $13572 $13569 $16686 $16687 reversed $13573 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16688 $15130 $11 $-1 $8499 reversed single T -25 -10 -42.500000000000007 -20 -9.3301270189221892 -37.499999999999993 F #
+loop $-1 -1 -1 $-1 $-1 $16689 $13571 T -22.500000000000004 -5 -40 -15 0 -25 unknown #
+coedge $-1 -1 -1 $-1 $16690 $15115 $13572 $15139 reversed $16195 $-1 #
+edge $-1 -1 -1 $-1 $16691 6.1232339957367648e-17 $13574 1.5707963267948966 $13572 $16692 forward @7 unknown T -15 -10 -40 -10 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $16693 $13573 $11 $-1 $8499 reversed single T -20 -10 -45 -10 -4.9999999999999991 -35 F #
+point $-1 -1 -1 $-1 -10 -10 -40 #
+coedge $-1 -1 -1 $-1 $16694 $13576 $16695 $16696 forward $15144 $-1 #
+coedge $-1 -1 -1 $-1 $13576 $16694 $13578 $13579 reversed $15144 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13576 $16697 T -20 -5 -45 -10 8.8817841970012523e-16 -35 unknown #
+vertex $-1 -1 -1 $-1 $13577 $16698 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $16658 $16699 #
+coedge $-1 -1 -1 $-1 $16326 $13583 $16668 $16700 forward $14764 $-1 #
+vertex $-1 -1 -1 $-1 $15116 $16701 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16702 $14764 $11 $-1 $7251 reversed single T -7.5000000000000018 -10 -40 0 -4.9999999999999991 -25 F #
+loop $-1 -1 -1 $-1 $-1 $16703 $13588 T -20 -10 -15.000000000000002 -10 -4.9999999999999991 -5 unknown #
+coedge $-1 -1 -1 $-1 $16704 $16705 $14705 $16250 forward $13589 $-1 #
+coedge $-1 -1 -1 $-1 $16706 $13590 $16707 $16708 forward $12118 $-1 #
+coedge $-1 -1 -1 $-1 $13590 $16706 $16709 $16710 reversed $12118 $-1 #
+coedge $-1 -1 -1 $-1 $16711 $14705 $13590 $15158 reversed $13180 $-1 #
+edge $-1 -1 -1 $-1 $16712 -2.0943951023931948 $16713 -1.5707963267948966 $13590 $16714 forward @7 unknown T -10 -0.66987298107780546 -10 -7.4999999999999982 8.8817841970012523e-16 -7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $14748 $13591 $16715 $16716 reversed $10425 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $14798 $16717 #
+straight-curve $-1 -1 -1 $-1 7.5 -9.3301270189221945 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $16718 $16719 $11 $-1 $9956 reversed single T -5 -10 -9.3734986416366059e-33 5 -4.9999999999999991 10 F #
+loop $-1 -1 -1 $-1 $-1 $16720 $13602 T -5 -5 -9.3734986416366059e-33 5 8.8817841970012523e-16 10 unknown #
+coedge $-1 -1 -1 $-1 $16721 $14772 $14647 $16197 forward $13604 $-1 #
+coedge $-1 -1 -1 $-1 $13606 $16329 $16722 $16723 forward $10783 $-1 #
+coedge $-1 -1 -1 $-1 $16724 $13607 $16725 $13885 forward $14802 $-1 #
+coedge $-1 -1 -1 $-1 $15172 $16726 $11041 $12413 forward $15385 $-1 #
+coedge $-1 -1 -1 $-1 $13608 $14799 $15387 $16727 forward $14800 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16728 $16725 $16726 $16729 forward $13612 $-1 #
+coedge $-1 -1 -1 $-1 $14805 $15168 $13613 $14807 reversed $15385 $-1 #
+face $-1 -1 -1 $-1 $15237 $15436 $11 $-1 $3328 reversed single T -20 -25 -30 -10 -20 -19.999999999999996 F #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077805 -50 #
+vertex $-1 -1 -1 $-1 $13740 $16730 #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13623 $13741 $16731 $16732 forward $13742 $-1 #
+vertex $-1 -1 -1 $-1 $13624 $16733 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13627 $13625 $16362 $16734 forward $13628 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16735 $13713 $13627 $15183 forward $13715 $-1 #
+edge $-1 -1 -1 $-1 $13629 1.5707963267948966 $16736 2.0943951023931957 $15182 $13898 forward @7 unknown T -22.500000000000004 -25 -40 -20 -24.330127018922191 -37.5 #
+point $-1 -1 -1 $-1 -20 -25 -40 #
+face $-1 -1 -1 $-1 $15433 $13742 $11 $-1 $4210 reversed single T -35 -25 -45 -25 -20 -35 F #
+face $-1 -1 -1 $-1 $8190 $13715 $11 $-1 $9321 reversed single T -22.500000000000004 -25 -40 -15 -20 -25 F #
+face $-1 -1 -1 $-1 $13633 $13635 $11 $-1 $4210 reversed single T -20 -20 -45 -10.000000000000002 -15 -35 F #
+coedge $-1 -1 -1 $-1 $13940 $15357 $13638 $15189 reversed $10972 $-1 #
+edge $-1 -1 -1 $-1 $13822 1.5707963267948966 $15380 2.0943951023931957 $13638 $16737 forward @7 unknown T -10.000000000000002 -15.669872981077809 -12.500000000000004 -7.5000000000000009 -15 -10 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13641 $13679 $16738 $13810 forward $12238 $-1 #
+edge $-1 -1 -1 $-1 $15355 1.5707963267948966 $13642 2.0943951023931957 $13641 $16739 forward @7 unknown T -37.5 -25 4.9999999999999982 -35 -24.330127018922191 7.5000000000000009 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922195 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $13644 $14039 $13646 $15196 reversed $14040 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 4.9999999999999973 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13647 4.1887902047863905 $15351 4.7123889803846897 $13646 $16739 forward @7 unknown T -37.5 -15.669872981077809 4.9999999999999982 -35 -15 7.5 #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077807 7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $13796 $13654 $13690 $13692 forward $12230 $-1 #
+coedge $-1 -1 -1 $-1 $13659 $16740 $13657 $15200 forward $15204 $-1 #
+edge $-1 -1 -1 $-1 $16741 -2.0943951023931957 $12431 -1.5707963267948966 $15199 $16742 forward @7 unknown T -40 -15.669872981077805 -40 -37.499999999999993 -14.999999999999996 -37.5 #
+coedge $-1 -1 -1 $-1 $15272 $13893 $13658 $15202 forward $15273 $-1 #
+edge $-1 -1 -1 $-1 $12430 1.5707963267948966 $16743 2.0943951023931966 $15201 $16744 forward @7 unknown T -40 -24.999999999999996 -40 -37.499999999999993 -24.330127018922184 -37.499999999999986 #
+coedge $-1 -1 -1 $-1 $16740 $13659 $13661 $15206 reversed $15204 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13659 $16745 T -40 -15.669872981077809 -42.5 -35 -14.999999999999996 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15278 -1.5707963267948966 $13663 -1.0471975511965979 $13661 $15274 forward @7 unknown T -37.5 -15.669872981077809 -42.5 -35 -15 -40 #
+face $-1 -1 -1 $-1 $16746 $13662 $11 $-1 $8642 reversed single T -37.5 -20 -50 -30 -15 -40 F #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077805 -42.5 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16747 $15219 $13667 $15211 reversed $15306 $-1 #
+edge $-1 -1 -1 $-1 $15212 -1.5707963267948966 $13803 -6.1232339957367648e-17 $13667 $16748 forward @7 unknown T -30.000000000000007 -25 14.999999999999996 -25 -20 20 #
+vertex $-1 -1 -1 $-1 $15211 $16749 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -20 19.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13813 $15223 $11 $-1 $1815 reversed single T -25 -25 17.5 -20 -24.330127018922191 22.500000000000004 F #
+coedge $-1 -1 -1 $-1 $13684 $16750 $13672 $15217 forward $15223 $-1 #
+edge $-1 -1 -1 $-1 $15212 1.5707963267948966 $13696 2.0943951023931953 $15216 $16751 forward @7 unknown T -25 -25 20 -22.5 -24.330127018922191 22.500000000000004 #
+face $-1 -1 -1 $-1 $15449 $14040 $11 $-1 $2156 reversed single T -40 -15.669872981077809 2.4999999999999987 -35 -14.999999999999996 7.5 F #
+coedge $-1 -1 -1 $-1 $15210 $16752 $10959 $12331 forward $15306 $-1 #
+face $-1 -1 -1 $-1 $13808 $13951 $11 $-1 $9321 reversed single T -22.500000000000004 -20 -10.000000000000004 -14.999999999999996 -15 4.9999999999999991 F #
+coedge $-1 -1 -1 $-1 $13682 $15518 $16753 $16754 forward $13683 $-1 #
+coedge $-1 -1 -1 $-1 $16750 $13684 $13682 $12254 reversed $15223 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15216 $15215 T -25 -25 17.5 -20 -24.330127018922191 22.500000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $13797 $16755 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 17.500000000000004 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 22.500000000000004 #
+edge $-1 -1 -1 $-1 $15234 27.500000000000004 $15230 37.5 $14823 $16756 forward @7 unknown T -7.5000000000000027 -15.669872981077809 -37.5 -7.5000000000000009 -15.669872981077807 -27.500000000000004 #
+vertex $-1 -1 -1 $-1 $14827 $16757 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13703 $13962 $13817 $15358 forward $15233 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13703 $16758 T -10.000000000000004 -15.669872981077809 -27.500000000000004 -5 -15 -22.499999999999996 unknown #
+vertex $-1 -1 -1 $-1 $13704 $16759 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13706 $13705 $15455 $16760 reversed $13707 $-1 #
+face $-1 -1 -1 $-1 $16758 $13707 $11 $-1 $3328 reversed single T -20 -20 -30 -10 -15 -19.999999999999996 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 -25 #
+coedge $-1 -1 -1 $-1 $16761 $15424 $13710 $15240 reversed $16762 $-1 #
+edge $-1 -1 -1 $-1 $15241 -1.5707963267948966 $15426 -1.047197551196597 $13710 $16763 forward @7 unknown T -22.500000000000004 -15.669872981077809 -27.500000000000004 -20 -15 -25 #
+vertex $-1 -1 -1 $-1 $15240 $16764 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13714 $16735 $16765 $16766 forward $13715 $-1 #
+coedge $-1 -1 -1 $-1 $15453 $13913 $13714 $15246 reversed $15436 $-1 #
+edge $-1 -1 -1 $-1 $16767 -1.5707963267948966 $12272 0 $13714 $15242 forward @7 unknown T -20 -25 -30 -15 -20 -25 #
+loop $-1 -1 -1 $-1 $16768 $16769 $3147 T -50 -10 -15.000000000000004 -50 0 -5.0000000000000036 hole $3148 T #
+coedge $-1 -1 -1 $-1 $15248 $15248 $16770 $16771 forward $13722 $-1 #
+edge $-1 -1 -1 $-1 $16772 0 $16772 6.2831853071795862 $13723 $16773 forward @7 unknown T -50 -10 14.999999999999996 -50 0 24.999999999999996 #
+vertex $-1 -1 -1 $-1 $13724 $16774 #
+ellipse-curve $-1 -1 -1 $-1 -50 -5 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -20 -45 #
+coedge $-1 -1 -1 $-1 $16381 $16775 $16383 $16776 reversed $13728 $-1 #
+coedge $-1 -1 -1 $-1 $13730 $16777 $16778 $16779 forward $12287 $-1 #
+edge $-1 -1 -1 $-1 $14937 -50 $16780 -45 $16781 $16782 forward @7 unknown T -30 25 -50 -30 25 -45 #
+coedge $-1 -1 -1 $-1 $13731 $15028 $16783 $16784 forward $10936 $-1 #
+coedge $-1 -1 -1 $-1 $16785 $16581 $13731 $15258 reversed $16786 $-1 #
+edge $-1 -1 -1 $-1 $16787 -1.5707963267948966 $15259 0 $13731 $16788 forward @7 unknown T -35 5 -45 -30 10 -40 #
+vertex $-1 -1 -1 $-1 $16789 $16790 #
+coedge $-1 -1 -1 $-1 $16791 $16553 $12289 $13732 forward $16792 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16793 $16794 $13733 $15263 reversed $16795 $-1 #
+edge $-1 -1 -1 $-1 $16674 1.047197551196597 $15266 1.5707963267948966 $13733 $16796 forward @7 unknown T -37.5 -10 -42.500000000000007 -35 -9.330127018922191 -40 #
+coedge $-1 -1 -1 $-1 $16676 $13734 $16797 $16798 reversed $15265 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16676 $16688 T -35 -10 -45 -25 -4.9999999999999991 -35 unknown #
+vertex $-1 -1 -1 $-1 $15263 $16799 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $13736 0 $16800 1.5707963267948966 $15270 $15267 forward @7 unknown T -35 -5 -45 -30 0 -40 #
+point $-1 -1 -1 $-1 -30 -5 -45 #
+coedge $-1 -1 -1 $-1 $16801 $13737 $16802 $15268 forward $15271 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13737 $16803 T -37.5 -5 -50 -30 0 -40 unknown #
+coedge $-1 -1 -1 $-1 $13739 $15201 $16804 $16805 reversed $15273 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13893 $15305 T -40 -25 -42.5 -35 -24.330127018922184 -37.499999999999986 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16804 $16806 $13741 $15276 forward $15300 $-1 #
+edge $-1 -1 -1 $-1 $15431 3.1415926535897931 $13743 4.7123889803846897 $15275 $16807 forward @7 unknown T -35 -25 -40 -30 -20 -35 #
+point $-1 -1 -1 $-1 -35 -25 -40 #
+vertex $-1 -1 -1 $-1 $15206 $16808 #
+coedge $-1 -1 -1 $-1 $15282 $13748 $16809 $16810 forward $13750 $-1 #
+edge $-1 -1 -1 $-1 $13751 1.0471975511965965 $15355 1.5707963267948966 $13748 $16811 forward @7 unknown T -37.500000000000007 -25 2.4999999999999929 -35 -24.330127018922187 4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $13749 $15282 $16812 $15340 forward $13750 $-1 #
+coedge $-1 -1 -1 $-1 $15281 $15279 $16813 $13788 reversed $13750 $-1 #
+face $-1 -1 -1 $-1 $16814 $13750 $11 $-1 $8642 reversed single T -37.500000000000007 -25 -10.000000000000002 -30 -20 4.9999999999999982 F #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 2.4999999999999942 #
+vertex $-1 -1 -1 $-1 $13763 $16815 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -10.000000000000002 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13757 $13756 $16816 $16817 reversed $13758 $-1 #
+edge $-1 -1 -1 $-1 $13759 4.1887902047863923 $16818 4.7123889803846906 $13927 $13771 forward @7 unknown T -37.500000000000007 -15.669872981077805 -25.000000000000007 -35 -15 -22.500000000000011 #
+point $-1 -1 -1 $-1 -37.500000000000007 -15.669872981077804 -22.500000000000018 #
+coedge $-1 -1 -1 $-1 $16812 $16819 $13762 $15291 reversed $16820 $-1 #
+edge $-1 -1 -1 $-1 $15285 -1.5707963267948966 $16821 0 $13762 $16822 forward @7 unknown T -35 -25 -15.000000000000002 -30 -20 -10.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -10.000000000000002 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16823 $16824 $13764 $15294 reversed $16825 $-1 #
+edge $-1 -1 -1 $-1 $15321 3.1415926535897931 $13770 4.7123889803846906 $13764 $16826 forward @7 unknown T -35 -25 -25.000000000000007 -29.999999999999993 -20 -20.000000000000004 #
+coedge $-1 -1 -1 $-1 $16827 $15308 $13780 $15296 forward $12321 $-1 #
+edge $-1 -1 -1 $-1 $15321 -20.000000000000004 $16821 -15.000000000000002 $15316 $16828 forward @7 unknown T -30 -20 -20.000000000000004 -29.999999999999993 -20 -15.000000000000002 #
+face $-1 -1 -1 $-1 $16829 $15319 $11 $-1 $3328 reversed single T -35 -20 -30.000000000000004 -24.999999999999996 -15 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $16806 $13768 $16824 $16830 forward $15300 $-1 #
+coedge $-1 -1 -1 $-1 $13768 $16804 $13772 $15303 forward $15300 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16806 $16831 T -37.500000000000007 -25 -40 -30 -20 -25.000000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -20 -25.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -35 -25 -25.000000000000004 #
+edge $-1 -1 -1 $-1 $16743 -37.499999999999986 $13773 -27.500000000000004 $15299 $16832 forward @7 unknown T -37.5 -24.330127018922195 -37.499999999999986 -37.5 -24.330127018922187 -27.500000000000004 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922191 -27.500000000000004 #
+face $-1 -1 -1 $-1 $16745 $15273 $11 $-1 $4210 reversed single T -40 -25 -42.5 -35 -24.330127018922184 -37.499999999999986 F #
+loop $-1 -1 -1 $-1 $-1 $16833 $13776 T -30.000000000000007 -25 4.9999999999999982 -22.5 -20 20 unknown #
+coedge $-1 -1 -1 $-1 $16834 $16835 $16836 $16837 reversed $13777 $-1 #
+coedge $-1 -1 -1 $-1 $15295 $13778 $16823 $16838 reversed $12321 $-1 #
+coedge $-1 -1 -1 $-1 $13778 $16839 $16840 $16841 reversed $12321 $-1 #
+coedge $-1 -1 -1 $-1 $16842 $16843 $13778 $15311 forward $16844 $-1 #
+edge $-1 -1 -1 $-1 $16845 1.5707963267948961 $16846 2.0943951023931939 $15310 $16847 forward @7 unknown T -25.000000000000004 -25 -25 -22.500000000000004 -24.330127018922195 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $16848 $13779 $16849 $16850 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $15424 $16761 $13779 $15314 forward $16762 $-1 #
+edge $-1 -1 -1 $-1 $16851 -2.0943951023931953 $15320 -1.5707963267948961 $15313 $16852 forward @7 unknown T -25.000000000000004 -15.669872981077809 -25 -22.499999999999993 -15 -22.499999999999996 #
+coedge $-1 -1 -1 $-1 $13780 $16848 $13790 $15337 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $15448 $15447 $13765 $15296 forward $13929 $-1 #
+coedge $-1 -1 -1 $-1 $16853 $13781 $15447 $16854 reversed $15319 $-1 #
+coedge $-1 -1 -1 $-1 $13781 $16853 $15423 $16855 forward $15319 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13781 $15297 T -35 -20 -30.000000000000004 -24.999999999999996 -15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $16855 $16856 #
+vertex $-1 -1 -1 $-1 $15294 $16857 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13786 $13783 $13798 $15345 reversed $9746 $-1 #
+coedge $-1 -1 -1 $-1 $15464 $15463 $13783 $15325 forward $13951 $-1 #
+edge $-1 -1 -1 $-1 $16858 -2.4999999999999978 $15329 7.5000000000000027 $15324 $16859 forward @7 unknown T -22.500000000000004 -15.669872981077809 -7.5000000000000027 -22.5 -15.669872981077805 2.4999999999999978 #
+coedge $-1 -1 -1 $-1 $16860 $13784 $16848 $16861 forward $15328 $-1 #
+coedge $-1 -1 -1 $-1 $13784 $16860 $15464 $16862 reversed $15328 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13784 $16863 T -25 -15.669872981077809 -12.500000000000004 -20 -15 -7.5000000000000027 unknown #
+vertex $-1 -1 -1 $-1 $16862 $16864 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15443 $13787 $13805 $15350 forward $13676 $-1 #
+coedge $-1 -1 -1 $-1 $13787 $15442 $13789 $15336 forward $13676 $-1 #
+vertex $-1 -1 -1 $-1 $15350 $16865 #
+straight-curve $-1 -1 -1 $-1 -30 -20 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13790 $13789 $15448 $16866 reversed $13791 $-1 #
+edge $-1 -1 -1 $-1 $15450 1.5707963267948966 $13793 3.1415926535897931 $15332 $16867 forward @7 unknown T -35 -20 -10.000000000000002 -30 -15 -5.0000000000000018 #
+edge $-1 -1 -1 $-1 $16821 -6.1232339957367648e-17 $13792 1.5707963267948966 $13790 $16868 forward @7 unknown T -30 -20 -15.000000000000004 -25 -15 -10.000000000000002 #
+face $-1 -1 -1 $-1 $16869 $13791 $11 $-1 $2664 reversed single T -35 -20 -15.000000000000004 -25 -15 -5.0000000000000018 F #
+point $-1 -1 -1 $-1 -25 -15 -10.000000000000002 #
+edge $-1 -1 -1 $-1 $13793 3.1415926535897931 $15285 4.7123889803846897 $15281 $16867 forward @7 unknown T -35 -25 -10.000000000000002 -30 -20 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -30 -20 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $13829 $13796 $13799 $15346 forward $12230 $-1 #
+straight-curve $-1 -1 -1 $-1 -22.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $13799 $13798 $15463 $16870 reversed $13800 $-1 #
+edge $-1 -1 -1 $-1 $12335 1.5707963267948966 $16858 2.0943951023931948 $13798 $16871 forward @7 unknown T -25 -15.669872981077809 2.4999999999999978 -22.500000000000004 -15 4.9999999999999982 #
+edge $-1 -1 -1 $-1 $13801 4.1887902047863914 $15367 4.7123889803846897 $15342 $16872 forward @7 unknown T -22.5 -15.669872981077805 4.9999999999999991 -20 -15 7.4999999999999982 #
+face $-1 -1 -1 $-1 $15283 $13800 $11 $-1 $2156 reversed single T -25 -15.669872981077809 2.4999999999999956 -20 -15 7.4999999999999991 F #
+point $-1 -1 -1 $-1 -22.499999999999993 -15.669872981077805 7.4999999999999982 #
+point $-1 -1 -1 $-1 -30.000000000000007 -20 14.999999999999996 #
+edge $-1 -1 -1 $-1 $15333 0 $15351 1.5707963267948966 $15331 $16873 forward @7 unknown T -35 -20 -1.7763568394002505e-15 -30 -15 4.9999999999999982 #
+vertex $-1 -1 -1 $-1 $15516 $16874 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 4.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16875 $16876 $11 $-1 $2156 reversed single T -35 -25 -1.7763568394002505e-15 -25 -20 9.9999999999999982 F #
+vertex $-1 -1 -1 $-1 $15280 $16877 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15188 $13817 $13961 $15475 reversed $10972 $-1 #
+edge $-1 -1 -1 $-1 $15476 -2.0943951023931948 $13708 -1.5707963267948961 $15232 $16878 forward @7 unknown T -10.000000000000004 -15.669872981077809 -25 -7.5000000000000027 -15 -22.5 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13821 $13820 $13959 $12492 reversed $12185 $-1 #
+edge $-1 -1 -1 $-1 $13958 1.5707963267948961 $11114 3.1415926535897931 $13949 $13957 forward @7 unknown T -20 -20 -10.000000000000004 -14.999999999999996 -15 -5.0000000000000018 #
+edge $-1 -1 -1 $-1 $11118 -6.1232339957367648e-17 $13822 1.5707963267948966 $13821 $16879 forward @7 unknown T -15.000000000000004 -20 -15.000000000000002 -10.000000000000002 -15 -10 #
+point $-1 -1 -1 $-1 -10.000000000000002 -15 -10 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $12358 1.5707963267948966 $13853 2.0943951023931957 $13825 $16880 forward @7 unknown T -10.000000000000002 -15.669872981077809 2.4999999999999982 -7.5000000000000009 -15 4.9999999999999991 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 7.5000000000000027 #
+vertex $-1 -1 -1 $-1 $16870 $16881 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 4.9999999999999991 0.70710678118654757 0 -0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $16882 $16883 #
+coedge $-1 -1 -1 $-1 $15371 $15371 $13837 $15372 reversed $16357 $-1 #
+edge $-1 -1 -1 $-1 $16884 0 $16884 6.2831853071795862 $13837 $16885 forward @7 unknown T 50 -10 -29.999999999999996 50 0 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $13838 $16886 T 50 -10 -14.999999999999996 50 0 -4.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $13839 $16887 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 -9.9999999999999964 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 -5 3.0616169978683823e-15 #
+ellipse-curve $-1 -1 -1 $-1 4.9999999999999991 -20 -25 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -5 -15 -25 #
+point $-1 -1 -1 $-1 -5 -25 -25 #
+vertex $-1 -1 -1 $-1 $15475 $16888 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 2.4999999999999982 #
+face $-1 -1 -1 $-1 $16889 $16890 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -5 -25 7.5000000000000018 0 -10 F #
+loop $-1 -1 -1 $-1 $-1 $16891 $13858 T -9.3734986416366059e-33 -5 -10 7.5000000000000009 8.8817841970012523e-16 5 unknown #
+coedge $-1 -1 -1 $-1 $16892 $16893 $16720 $16894 reversed $13859 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15512 $13860 T 14.999999999999996 -10.000000000000002 5.0000000000000009 22.500000000000004 -4.9999999999999991 20 unknown #
+coedge $-1 -1 -1 $-1 $16895 $15500 $15502 $16896 reversed $13861 $-1 #
+coedge $-1 -1 -1 $-1 $16897 $13862 $15169 $16727 reversed $12403 $-1 #
+coedge $-1 -1 -1 $-1 $13862 $16898 $15491 $16899 reversed $12403 $-1 #
+edge $-1 -1 -1 $-1 $14782 1.5707963267948961 $16361 2.0943951023931948 $14781 $16900 forward @7 unknown T 19.999999999999996 -10 -25 22.5 -9.3301270189221928 -22.5 #
+coedge $-1 -1 -1 $-1 $16901 $13863 $13992 $15490 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $13864 $16901 $13872 $15405 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $16902 $14785 $16903 $15393 forward $16342 $-1 #
+edge $-1 -1 -1 $-1 $14787 -20 $16904 -15 $15392 $16905 forward @7 unknown T 15 -5 -20 15 -4.9999999999999991 -15 #
+coedge $-1 -1 -1 $-1 $13868 $13865 $13877 $15410 reversed $9830 $-1 #
+coedge $-1 -1 -1 $-1 $13993 $13866 $16901 $15508 forward $14006 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16906 $13869 $13881 $15412 forward $15400 $-1 #
+coedge $-1 -1 -1 $-1 $13869 $16907 $13871 $15404 forward $15400 $-1 #
+coedge $-1 -1 -1 $-1 $16908 $16909 $16910 $13870 reversed $16360 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13869 $16911 T 7.4999999999999964 -5 -10 15.000000000000004 8.8817841970012523e-16 5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $15412 $16912 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13872 $13871 $16902 $16913 reversed $13873 $-1 #
+edge $-1 -1 -1 $-1 $16914 1.5707963267948966 $13875 3.1415926535897931 $15398 $16915 forward @7 unknown T 10 -4.9999999999999991 -10 15 0 -5 #
+edge $-1 -1 -1 $-1 $16904 1.1640334398265733e-16 $13874 1.5707963267948966 $13872 $16916 forward @7 unknown T 15 -5 -15 20 -8.8817841970012523e-16 -9.9999999999999982 #
+face $-1 -1 -1 $-1 $16917 $13873 $11 $-1 $11179 reversed single T 10 -5 -15 20 0 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 20 -8.8817841970012523e-16 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $13875 3.1415926535897931 $16918 4.7123889803846897 $16908 $16915 forward @7 unknown T 10 -10 -10 15 -4.9999999999999991 -5 #
+point $-1 -1 -1 $-1 15 -4.9999999999999991 -5 #
+edge $-1 -1 -1 $-1 $12416 1.5707963267948966 $12578 2.0943951023931948 $13877 $16919 forward @7 unknown T 20 -0.66987298107780768 2.5000000000000036 22.5 0 5.0000000000000009 #
+point $-1 -1 -1 $-1 15 -5 15 #
+edge $-1 -1 -1 $-1 $15401 0 $15413 1.5707963267948966 $15397 $16920 forward @7 unknown T 10 -5 8.8817841970012523e-16 15.000000000000004 8.8817841970012523e-16 5.0000000000000009 #
+vertex $-1 -1 -1 $-1 $16921 $16922 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -5 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $16923 $16924 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16925 $16816 $13890 $15419 forward $16926 $-1 #
+edge $-1 -1 -1 $-1 $15420 27.500000000000004 $16741 37.5 $15418 $16927 forward @7 unknown T -37.5 -15.669872981077805 -37.5 -37.499999999999993 -15.669872981077804 -27.500000000000004 #
+vertex $-1 -1 -1 $-1 $15419 $16928 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -25.000000000000004 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13902 $13900 $15318 $16855 reversed $12439 $-1 #
+coedge $-1 -1 -1 $-1 $15239 $15313 $13900 $15425 forward $16762 $-1 #
+edge $-1 -1 -1 $-1 $15320 1.570796326794897 $15426 2.0943951023931957 $15424 $16929 forward @7 unknown T -25 -15.669872981077809 -27.500000000000004 -22.5 -15 -25 #
+vertex $-1 -1 -1 $-1 $13901 $16930 #
+coedge $-1 -1 -1 $-1 $16931 $16932 $16806 $15429 forward $16926 $-1 #
+edge $-1 -1 -1 $-1 $15431 -35 $16933 -30.000000000000004 $15428 $16934 forward @7 unknown T -30.000000000000007 -20 -35 -30 -20 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $13906 $13903 $16932 $16935 reversed $13907 $-1 #
+vertex $-1 -1 -1 $-1 $15276 $16936 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15207 $13907 $11 $-1 $4210 reversed single T -35 -20 -45 -25 -15 -35 F #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $15456 $13912 T -22.500000000000004 -25 -25 -15 -20 -10.000000000000002 unknown #
+loop $-1 -1 -1 $-1 $-1 $13936 $15173 T -20 -25 -30 -10 -20 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13719 $13915 $11 $-1 $3328 reversed single T -10.000000000000004 -25 -27.500000000000004 -5 -24.330127018922191 -22.5 F #
+point $-1 -1 -1 $-1 -10.000000000000002 -25 -25 #
+point $-1 -1 -1 $-1 -7.5000000000000044 -15.669872981077807 -7.4999999999999956 #
+coedge $-1 -1 -1 $-1 $15332 $13922 $13924 $15445 forward $13676 $-1 #
+coedge $-1 -1 -1 $-1 $13922 $15331 $14039 $15516 forward $13676 $-1 #
+straight-curve $-1 -1 -1 $-1 -37.5 -15.669872981077805 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $13925 4.1887902047863914 $15450 4.7123889803846897 $15442 $15286 forward @7 unknown T -37.5 -15.669872981077807 -10.000000000000002 -35 -15 -7.5000000000000018 #
+point $-1 -1 -1 $-1 -37.499999999999993 -15.669872981077807 -7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $15316 $13927 $15317 $16854 forward $13929 $-1 #
+coedge $-1 -1 -1 $-1 $13928 $15316 $15335 $16866 forward $13929 $-1 #
+face $-1 -1 -1 $-1 $13754 $13929 $11 $-1 $8642 reversed single T -37.500000000000007 -20 -25.000000000000007 -29.999999999999993 -15 -10.000000000000002 F #
+vertex $-1 -1 -1 $-1 $13931 $16937 #
+face $-1 -1 -1 $-1 $12317 $16926 $11 $-1 $8642 reversed single T -37.5 -20 -40 -30 -15 -25.000000000000004 F #
+ellipse-curve $-1 -1 -1 $-1 -5 -20 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13936 $15245 $16938 $15458 reversed $15436 $-1 #
+coedge $-1 -1 -1 $-1 $13941 $16939 $15236 $16760 forward $15457 $-1 #
+coedge $-1 -1 -1 $-1 $16938 $13944 $11106 $12481 reversed $15435 $-1 #
+loop $-1 -1 -1 $-1 $-1 $13941 $16814 T -22.5 -20 -25 -15 -15 -10.000000000000002 unknown #
+edge $-1 -1 -1 $-1 $13942 3.1415926535897931 $16767 4.7123889803846897 $16938 $16940 forward @7 unknown T -20 -25 -25 -15 -20 -20 #
+point $-1 -1 -1 $-1 -15 -20 -20 #
+coedge $-1 -1 -1 $-1 $13944 $16840 $16941 $15470 forward $15435 $-1 #
+coedge $-1 -1 -1 $-1 $13950 $16942 $13946 $15462 forward $13955 $-1 #
+edge $-1 -1 -1 $-1 $15370 -1.5707963267948966 $12486 0 $15461 $15465 forward @7 unknown T -20 -25 -8.8817841970012523e-16 -15 -20 4.9999999999999991 #
+coedge $-1 -1 -1 $-1 $15324 $13948 $15344 $16870 forward $13951 $-1 #
+coedge $-1 -1 -1 $-1 $13949 $15324 $15327 $16862 forward $13951 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 4.9999999999999991 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16942 $13954 $16835 $16943 forward $13955 $-1 #
+coedge $-1 -1 -1 $-1 $16941 $16836 $13954 $15468 reversed $16944 $-1 #
+edge $-1 -1 -1 $-1 $13956 1.5707963267948961 $16945 2.0943951023931948 $13954 $16946 forward @7 unknown T -22.500000000000004 -25 -10.000000000000004 -20 -24.330127018922195 -7.5000000000000036 #
+face $-1 -1 -1 $-1 $8523 $13955 $11 $-1 $9321 reversed single T -22.500000000000004 -25 -10.000000000000004 -14.999999999999996 -20 4.9999999999999991 F #
+edge $-1 -1 -1 $-1 $16947 1.047197551196597 $13956 1.5707963267948961 $15460 $16948 forward @7 unknown T -22.500000000000004 -25 -12.500000000000005 -20 -24.330127018922191 -10.000000000000002 #
+point $-1 -1 -1 $-1 -20 -25 -10.000000000000002 #
+edge $-1 -1 -1 $-1 $13958 -1.5707963267948961 $16949 -1.0471975511965979 $15474 $16948 forward @7 unknown T -22.499999999999996 -15.669872981077807 -12.500000000000002 -20 -15 -10.000000000000002 #
+point $-1 -1 -1 $-1 -20 -15 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $16849 $13959 $16860 $15472 forward $15457 $-1 #
+edge $-1 -1 -1 $-1 $15380 12.500000000000004 $15476 22.5 $13961 $16950 forward @7 unknown T -7.5000000000000027 -15.669872981077809 -22.5 -7.5000000000000009 -15.669872981077807 -12.500000000000004 #
+vertex $-1 -1 -1 $-1 $13963 $16951 #
+straight-curve $-1 -1 -1 $-1 37.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $13966 $13965 $13974 $15483 reversed $12580 $-1 #
+point $-1 -1 -1 $-1 35 -10.000000000000002 5.0000000000000018 #
+point $-1 -1 -1 $-1 37.500000000000007 -9.3301270189221928 7.500000000000008 #
+face $-1 -1 -1 $-1 $9931 $13971 $11 $-1 $11179 reversed single T 24.999999999999996 -10.000000000000002 -15 35 -4.9999999999999991 -4.9999999999999982 F #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $13976 1.0471975511965979 $14023 1.570796326794897 $13974 $12565 forward @7 unknown T 37.499999999999993 -10 2.5000000000000031 40 -9.3301270189221928 5.0000000000000044 #
+point $-1 -1 -1 $-1 37.499999999999993 -9.3301270189221945 2.5000000000000071 #
+vertex $-1 -1 -1 $-1 $13986 $16952 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $13999 $13999 $13985 $15488 reversed $15493 $-1 #
+edge $-1 -1 -1 $-1 $15485 -1.5707963267948966 $12542 1.5707963267948966 $13985 $16953 forward @7 unknown T 40 -10 -14.999999999999998 45 0 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $13266 1.570796326794897 $13264 4.7123889803846897 $13987 $16954 forward @7 unknown T 39.999999999999993 -10 -24.999999999999996 44.999999999999993 0 -19.999999999999996 #
+edge $-1 -1 -1 $-1 $14018 12.499999999999996 $14814 22.500000000000004 $13992 $16955 forward @7 unknown T 22.499999999999993 -0.66987298107780768 -22.500000000000004 22.5 -0.66987298107780635 -12.499999999999996 #
+coedge $-1 -1 -1 $-1 $13995 $13994 $15388 $16899 forward $12533 $-1 #
+coedge $-1 -1 -1 $-1 $15507 $14011 $13995 $12560 reversed $14017 $-1 #
+loop $-1 -1 -1 $-1 $15373 $15487 $16886 T 40 -10 -14.999999999999998 45 0 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -9.9999999999999982 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 -5 5.0000000000000027 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16956 $16957 $11 $-1 $11179 reversed single T -10 -10 -12.500000000000002 -5 -9.330127018922191 -7.5 F #
+loop $-1 -1 -1 $-1 $-1 $16958 $14005 T 5 -0.66987298107780902 -12.5 10 0 -7.5000000000000009 unknown #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 22.500000000000004 -0.66987298107780735 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $15386 $16959 $14010 $15501 reversed $13861 $-1 #
+edge $-1 -1 -1 $-1 $15503 -7.4999999999999982 $12581 2.5000000000000049 $14010 $16960 forward @7 unknown T 22.5 -9.3301270189221945 -7.4999999999999982 22.5 -9.3301270189221945 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $14011 $15507 $15386 $16896 forward $14017 $-1 #
+vertex $-1 -1 -1 $-1 $16896 $16961 #
+coedge $-1 -1 -1 $-1 $14030 $14013 $16959 $16962 forward $14031 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 -5.0000000000000018 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $16963 $14016 T 10 -10 -15 20 -4.9999999999999991 -4.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $15502 $15492 $16898 $16964 forward $14017 $-1 #
+edge $-1 -1 -1 $-1 $13874 1.5707963267948966 $14018 2.0943951023931948 $15395 $16965 forward @7 unknown T 20 -0.66987298107780768 -12.499999999999996 22.5 -8.8817841970012523e-16 -9.9999999999999982 #
+point $-1 -1 -1 $-1 22.5 -0.66987298107780768 -12.499999999999996 #
+point $-1 -1 -1 $-1 22.500000000000004 -9.3301270189221981 -12.499999999999996 #
+point $-1 -1 -1 $-1 40 -10 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $16726 $14028 $14030 $15514 reversed $15385 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $16966 1.5707963267948966 $14032 2.0943951023931948 $14030 $16967 forward @7 unknown T 20 -10 5.0000000000000009 22.499999999999996 -9.3301270189221928 7.5 #
+point $-1 -1 -1 $-1 22.499999999999996 -9.3301270189221928 7.5 #
+edge $-1 -1 -1 $-1 $15351 -1.5707963267948966 $14041 -1.0471975511965979 $15443 $16811 forward @7 unknown T -37.5 -15.669872981077809 2.4999999999999987 -35 -15 4.9999999999999982 #
+point $-1 -1 -1 $-1 -37.5 -15.669872981077805 2.5000000000000013 #
+coedge $-1 -1 -1 $-1 $15221 $14043 $16968 $16969 forward $13683 $-1 #
+coedge $-1 -1 -1 $-1 $15559 $16970 $14045 $14092 reversed $15579 $-1 #
+coedge $-1 -1 -1 $-1 $16971 $14046 $14048 $14113 reversed $15522 $-1 #
+coedge $-1 -1 -1 $-1 $14046 $16972 $12628 $14089 forward $15522 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15521 $16973 T -30 35 35 -22.5 40 50 unknown #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $14048 $14100 $16974 $16975 forward $14049 $-1 #
+face $-1 -1 -1 $-1 $14117 $14049 $11 $-1 $14102 reversed single T -22.5 35 35 -15 40 50 F #
+coedge $-1 -1 -1 $-1 $16976 $15577 $14051 $15527 forward $16977 $-1 #
+edge $-1 -1 -1 $-1 $12641 6.1232339957367648e-17 $15619 1.5707963267948966 $15526 $16978 forward @7 unknown T -15 35 35 -9.9999999999999982 40 40 #
+face $-1 -1 -1 $-1 $16979 $16366 $11 $-1 $12646 reversed single T -15 40 -50 -7.4999999999999982 45 -40 F #
+coedge $-1 -1 -1 $-1 $15544 $14053 $15611 $14130 reversed $12617 $-1 #
+coedge $-1 -1 -1 $-1 $15636 $15532 $14055 $15531 reversed $16980 $-1 #
+edge $-1 -1 -1 $-1 $12683 -2.0943951023931948 $12692 -1.5707963267948966 $14055 $16981 forward @7 unknown T 5.0000000000000027 35 32.5 7.5 35.669872981077809 35 #
+coedge $-1 -1 -1 $-1 $15530 $16982 $14056 $14167 reversed $16980 $-1 #
+face $-1 -1 -1 $-1 $8883 $14060 $11 $-1 $7943 reversed single T 15 35 20 22.5 40 35 F #
+coedge $-1 -1 -1 $-1 $14062 $14187 $16438 $16983 reversed $14060 $-1 #
+coedge $-1 -1 -1 $-1 $14063 $14077 $16984 $16985 forward $14078 $-1 #
+vertex $-1 -1 -1 $-1 $16986 $16987 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15666 $14065 $16988 $16986 forward $14843 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $16989 $16990 $1558 T 50 35 15.000000000000004 50 45 25.000000000000004 hole $1559 T #
+point $-1 -1 -1 $-1 50 40 30.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $16991 $12616 T -50 35 29.999999999999996 -50 45 40 unknown #
+coedge $-1 -1 -1 $-1 $16992 $16992 $16993 $16994 forward $14070 $-1 #
+coedge $-1 -1 -1 $-1 $14071 $15529 $16995 $16996 forward $12617 $-1 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 40 20.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14075 -1.570796326794897 $15683 -1.0471975511965979 $14845 $16997 forward @7 unknown T 37.499999999999993 44.330127018922191 17.500000000000004 40 45 20.000000000000007 #
+point $-1 -1 -1 $-1 40 45 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $15604 $16998 $14077 $15549 forward $11864 $-1 #
+edge $-1 -1 -1 $-1 $16999 1.0471975511965983 $14079 1.570796326794897 $15548 $16997 forward @7 unknown T 37.499999999999993 35 17.500000000000007 40 35.669872981077809 20.000000000000007 #
+point $-1 -1 -1 $-1 40 35 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $17000 $14081 $16970 $17001 reversed $15553 $-1 #
+coedge $-1 -1 -1 $-1 $14081 $17002 $14083 $15557 reversed $15553 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15552 $17003 T -45 35 35 -37.5 45 50 unknown #
+vertex $-1 -1 -1 $-1 $17001 $17004 #
+ellipse-curve $-1 -1 -1 $-1 -40 40 50 -0 -0 -1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $15558 $14083 $17005 $17006 forward $14085 $-1 #
+edge $-1 -1 -1 $-1 $14086 -50 $17007 -37.500000000000007 $14083 $17008 forward @7 unknown T -37.500000000000007 44.330127018922191 37.500000000000007 -37.5 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $14084 $15556 $17009 $17010 forward $14085 $-1 #
+coedge $-1 -1 -1 $-1 $17011 $15519 $15521 $14089 reversed $15579 $-1 #
+face $-1 -1 -1 $-1 $17012 $14085 $11 $-1 $13729 reversed single T -37.500000000000007 40 35 -30 45 50 F #
+point $-1 -1 -1 $-1 -37.5 44.330127018922191 50 #
+coedge $-1 -1 -1 $-1 $17009 $17013 $14088 $15563 forward $17014 $-1 #
+edge $-1 -1 -1 $-1 $17015 -1.5707963267948966 $15564 6.1232339957367648e-17 $15562 $17016 forward @7 unknown T -30 40 35 -24.999999999999996 45 40 #
+vertex $-1 -1 -1 $-1 $17017 $17018 #
+straight-curve $-1 -1 -1 $-1 -30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17019 $14094 $14090 $15567 forward $15571 $-1 #
+edge $-1 -1 -1 $-1 $14096 -2.0943951023931944 $17015 -1.5707963267948966 $15566 $17020 forward @7 unknown T -24.999999999999996 44.330127018922198 35 -22.5 45 37.5 #
+face $-1 -1 -1 $-1 $17021 $17022 $11 $-1 $15569 reversed single T -30 40 -50 -22.499999999999996 45 -40 F #
+cone-surface $-1 -1 -1 $-1 -24.999999999999996 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $14094 $17019 $17023 $17024 reversed $15571 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15566 $17025 T -24.999999999999996 44.330127018922184 32.499999999999993 -20 45 37.5 unknown #
+vertex $-1 -1 -1 $-1 $17024 $17026 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 44.330127018922205 37.5 #
+coedge $-1 -1 -1 $-1 $14103 $14098 $17027 $17028 reversed $14104 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15526 $17029 $14100 $14107 reversed $16977 $-1 #
+face $-1 -1 -1 $-1 $17030 $17031 $11 $-1 $14102 reversed single T -22.500000000000007 40 20 -15 45 35 F #
+loop $-1 -1 -1 $-1 $-1 $15559 $14101 T -37.5 35 35 -30 40 50 unknown #
+coedge $-1 -1 -1 $-1 $17032 $15585 $14103 $15581 reversed $14112 $-1 #
+edge $-1 -1 -1 $-1 $17033 -6.1232339957367648e-17 $14105 1.5707963267948966 $14103 $17034 forward @7 unknown T -15 40 30 -9.9999999999999982 45 35 #
+face $-1 -1 -1 $-1 $17035 $14104 $11 $-1 $8951 reversed single T -20 40 30 -9.9999999999999982 45 40 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 45 35 #
+vertex $-1 -1 -1 $-1 $17036 $17037 #
+coedge $-1 -1 -1 $-1 $15580 $17038 $14109 $15586 reversed $14112 $-1 #
+edge $-1 -1 -1 $-1 $14105 1.5707963267948966 $15594 2.0943951023931953 $14109 $17039 forward @7 unknown T -9.9999999999999982 44.330127018922191 32.5 -7.4999999999999991 45 35 #
+face $-1 -1 -1 $-1 $17040 $17041 $11 $-1 $12646 reversed single T -15 40 -10 -7.4999999999999964 45 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $17042 $14111 T -15 40 4.9999999999999991 -7.4999999999999991 45 20 unknown #
+coedge $-1 -1 -1 $-1 $17043 $17032 $17044 $17045 reversed $14112 $-1 #
+vertex $-1 -1 -1 $-1 $17046 $17047 #
+straight-curve $-1 -1 -1 $-1 -22.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17048 $14115 $17038 $17049 forward $15593 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15596 $15600 T -7.5000000000000018 40 20 8.8817841970012523e-16 45 35 unknown #
+vertex $-1 -1 -1 $-1 $17049 $17050 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14119 $17051 $15625 $15607 forward $15593 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15625 $15611 $14121 $15599 forward $14142 $-1 #
+edge $-1 -1 -1 $-1 $12662 -1.5707963267948966 $14128 0 $15598 $15597 forward @7 unknown T -5 35 30 0 40 35 #
+face $-1 -1 -1 $-1 $17052 $15593 $11 $-1 $10041 reversed single T -7.5000000000000018 40 20 8.8817841970012523e-16 45 35 F #
+loop $-1 -1 -1 $-1 $17053 $17054 $14122 T -45 35 14.999999999999996 -40 45 24.999999999999993 unknown #
+coedge $-1 -1 -1 $-1 $17055 $17056 $17057 $17058 forward $14123 $-1 #
+coedge $-1 -1 -1 $-1 $15603 $15603 $16990 $17059 reversed $14124 $-1 #
+coedge $-1 -1 -1 $-1 $14845 $15548 $14125 $15605 forward $11864 $-1 #
+edge $-1 -1 -1 $-1 $14079 -1.570796326794897 $14075 1.570796326794897 $15604 $17060 forward @7 unknown T 40 35 15.000000000000004 45.000000000000007 45 20.000000000000007 #
+coedge $-1 -1 -1 $-1 $15612 $14126 $17061 $17062 reversed $14127 $-1 #
+edge $-1 -1 -1 $-1 $17063 25 $14128 30 $15596 $17064 forward @7 unknown T 0 40 25 8.8817841970012523e-16 40 30 #
+face $-1 -1 -1 $-1 $17065 $14127 $11 $-1 $10029 reversed single T 0 40 20 7.5000000000000027 45 35 F #
+point $-1 -1 -1 $-1 0 40 30 #
+vertex $-1 -1 -1 $-1 $14130 $17066 #
+coedge $-1 -1 -1 $-1 $15598 $17067 $15529 $14130 forward $14142 $-1 #
+coedge $-1 -1 -1 $-1 $14132 $15606 $17068 $17069 reversed $14127 $-1 #
+coedge $-1 -1 -1 $-1 $16411 $17070 $14879 $16421 reversed $14134 $-1 #
+coedge $-1 -1 -1 $-1 $17071 $14135 $16415 $17072 reversed $12666 $-1 #
+coedge $-1 -1 -1 $-1 $14135 $17073 $17074 $17075 reversed $12666 $-1 #
+coedge $-1 -1 -1 $-1 $17076 $17077 $17078 $15617 forward $17079 $-1 #
+edge $-1 -1 -1 $-1 $17080 -35 $17081 -30 $15616 $17082 forward @7 unknown T 0 40 -35 8.8817841970012523e-16 40 -30 #
+coedge $-1 -1 -1 $-1 $14833 $17083 $14136 $14898 forward $16370 $-1 #
+vertex $-1 -1 -1 $-1 $17084 $17085 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17068 $17086 $14139 $15622 reversed $17087 $-1 #
+edge $-1 -1 -1 $-1 $15623 4.1887902047863923 $17088 4.7123889803846897 $14139 $17089 forward @7 unknown T 7.5000000000000027 44.330127018922198 20 10 45 22.5 #
+vertex $-1 -1 -1 $-1 $15622 $17090 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17091 $15598 $16982 $15607 reversed $14142 $-1 #
+coedge $-1 -1 -1 $-1 $17092 $14144 $14143 $15627 reversed $13359 $-1 #
+edge $-1 -1 -1 $-1 $17088 1.5707963267948966 $14146 3.1415926535897931 $14143 $17093 forward @7 unknown T 10 40 20 15 45 25 #
+coedge $-1 -1 -1 $-1 $14144 $17092 $17094 $17095 forward $13359 $-1 #
+vertex $-1 -1 -1 $-1 $17095 $17096 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $14146 3.1415926535897931 $17097 4.7123889803846897 $14174 $17093 forward @7 unknown T 10 35 20 15 40 25 #
+point $-1 -1 -1 $-1 15 40 25 #
+face $-1 -1 -1 $-1 $17098 $17099 $11 $-1 $7943 reversed single T 15 40 -9.9999999999999982 22.500000000000007 45 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $17100 $14148 T 14.999999999999996 40 5.0000000000000009 22.500000000000011 45 20 unknown #
+coedge $-1 -1 -1 $-1 $14150 $14174 $17101 $17102 forward $11310 $-1 #
+coedge $-1 -1 -1 $-1 $17103 $15530 $14150 $15637 reversed $16980 $-1 #
+edge $-1 -1 -1 $-1 $17104 22.500000000000004 $12683 32.5 $14150 $17105 forward @7 unknown T 7.5 35.669872981077809 22.500000000000004 7.5000000000000018 35.669872981077809 32.5 #
+coedge $-1 -1 -1 $-1 $14169 $14151 $17106 $17107 forward $14170 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14153 $16432 $17108 $17109 reversed $11302 $-1 #
+coedge $-1 -1 -1 $-1 $14156 $14154 $14210 $15708 reversed $10049 $-1 #
+edge $-1 -1 -1 $-1 $15714 -2.0943951023931939 $13347 -1.5707963267948966 $14166 $17110 forward @7 unknown T 20.000000000000004 44.330127018922198 -40 22.500000000000007 45 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14211 $17111 $14156 $15645 forward $15710 $-1 #
+edge $-1 -1 -1 $-1 $15649 1.570796326794897 $15711 2.0943951023931957 $15644 $17112 forward @7 unknown T 20.000000000000004 44.330127018922191 -27.500000000000004 22.500000000000011 45 -25 #
+coedge $-1 -1 -1 $-1 $17113 $14157 $17114 $17115 forward $15648 $-1 #
+coedge $-1 -1 -1 $-1 $14157 $17113 $14159 $15652 reversed $15648 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14157 $17116 T 10 40 -30 20.000000000000007 45 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $14158 $17117 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17118 $14159 $17119 $17120 forward $14162 $-1 #
+edge $-1 -1 -1 $-1 $14164 0 $17121 1.5707963267948966 $14159 $17122 forward @7 unknown T 10 40 -30 15 45 -25 #
+coedge $-1 -1 -1 $-1 $14160 $17118 $16369 $17123 forward $14162 $-1 #
+edge $-1 -1 -1 $-1 $13349 1.5707963267948966 $14163 3.1415926535897931 $14160 $16428 forward @7 unknown T 10 40 -40 15 45 -35 #
+coedge $-1 -1 -1 $-1 $14161 $17124 $17125 $17126 forward $15656 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14161 $17127 T 7.5 35 -40 15.000000000000002 40 -25 unknown #
+point $-1 -1 -1 $-1 15 40 -35 #
+point $-1 -1 -1 $-1 15 40 -30 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17128 $14905 $14169 $15661 forward $11907 $-1 #
+edge $-1 -1 -1 $-1 $14171 -1.5707963267948966 $17129 -1.0471975511965996 $15660 $17130 forward @7 unknown T 22.500000000000011 44.330127018922198 17.500000000000004 25 45 20 #
+face $-1 -1 -1 $-1 $17131 $14170 $11 $-1 $12658 reversed single T 20.000000000000004 44.330127018922198 17.500000000000004 25 45 22.5 F #
+point $-1 -1 -1 $-1 25 45 20 #
+coedge $-1 -1 -1 $-1 $16438 $17132 $14174 $15631 reversed $14904 $-1 #
+edge $-1 -1 -1 $-1 $15668 0 $14171 1.5707963267948961 $14905 $17133 forward @7 unknown T 25 40 15 29.999999999999996 45 20 #
+coedge $-1 -1 -1 $-1 $14177 $15538 $16443 $17134 reversed $14843 $-1 #
+coedge $-1 -1 -1 $-1 $14184 $14178 $13360 $14908 reversed $12709 $-1 #
+vertex $-1 -1 -1 $-1 $15665 $17135 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17136 1.0471975511965974 $14181 1.5707963267948966 $17137 $17130 forward @7 unknown T 22.5 35 17.5 25 35.669872981077809 20 #
+point $-1 -1 -1 $-1 25 35 20 #
+face $-1 -1 -1 $-1 $17138 $17139 $11 $-1 $6121 reversed single T 29.999999999999996 35 -24.999999999999996 37.500000000000014 40 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $14206 $14182 T 29.999999999999996 40 -24.999999999999996 37.500000000000007 45 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $17140 $17141 $17142 $17143 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $14846 $14184 $17144 $17145 reversed $12709 $-1 #
+coedge $-1 -1 -1 $-1 $16440 $17146 $14184 $15677 forward $14912 $-1 #
+edge $-1 -1 -1 $-1 $17147 -1.5707963267948966 $16446 6.1232339957367673e-17 $15676 $17148 forward @7 unknown T 29.999999999999996 40 5.0000000000000018 35 45 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $17149 $14185 $17137 $15670 reversed $15680 $-1 #
+coedge $-1 -1 -1 $-1 $14185 $17149 $14187 $15681 forward $15680 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15679 $14903 T 20.000000000000004 35 17.5 25 35.669872981077809 22.499999999999996 unknown #
+edge $-1 -1 -1 $-1 $17150 1.5707963267948966 $14188 2.094395102393193 $15679 $17151 forward @7 unknown T 20.000000000000004 35 20 22.499999999999993 35.669872981077802 22.499999999999993 #
+point $-1 -1 -1 $-1 22.499999999999993 35.669872981077802 22.499999999999993 #
+vertex $-1 -1 -1 $-1 $14847 $17152 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14839 $16445 $11 $-1 $7024 reversed single T 22.499999999999996 35 4.9999999999999991 30 40 20 F #
+coedge $-1 -1 -1 $-1 $17153 $14193 $17154 $17155 forward $15688 $-1 #
+coedge $-1 -1 -1 $-1 $14193 $17153 $14195 $15692 reversed $15688 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14193 $17156 T 35 35 -27.499999999999993 40.000000000000007 35.669872981077816 -22.499999999999986 unknown #
+vertex $-1 -1 -1 $-1 $14910 $17157 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14840 $14195 $17158 $17159 forward $13303 $-1 #
+edge $-1 -1 -1 $-1 $14196 1.0471975511965992 $17160 1.570796326794897 $14195 $17161 forward @7 unknown T 37.5 35 -27.499999999999993 40 35.669872981077802 -24.999999999999993 #
+point $-1 -1 -1 $-1 37.5 35.669872981077802 -27.499999999999993 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14201 $14200 $17162 $17163 reversed $14202 $-1 #
+edge $-1 -1 -1 $-1 $17164 -1.570796326794897 $14203 -1.0471975511965996 $14840 $17161 forward @7 unknown T 37.5 44.330127018922198 -27.499999999999993 40 45 -24.999999999999993 #
+coedge $-1 -1 -1 $-1 $17165 $14206 $14201 $15698 reversed $15673 $-1 #
+edge $-1 -1 -1 $-1 $17166 -2.0943951023931957 $12728 -1.5707963267948966 $14201 $17167 forward @7 unknown T 35 44.330127018922191 -24.999999999999996 37.500000000000007 45 -22.499999999999989 #
+face $-1 -1 -1 $-1 $17168 $14202 $11 $-1 $15707 reversed single T 35 44.330127018922191 -27.499999999999993 40.000000000000007 45 -22.499999999999989 F #
+point $-1 -1 -1 $-1 37.5 44.330127018922205 -27.499999999999993 #
+coedge $-1 -1 -1 $-1 $17169 $17170 $14205 $15702 forward $17171 $-1 #
+edge $-1 -1 -1 $-1 $14213 1.5707963267948966 $15704 3.1415926535897931 $15701 $17172 forward @7 unknown T 25 40 -25 29.999999999999996 45 -20 #
+coedge $-1 -1 -1 $-1 $14206 $17173 $17169 $17174 reversed $15673 $-1 #
+vertex $-1 -1 -1 $-1 $17175 $17176 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17156 $15718 $11 $-1 $15707 reversed single T 25 35 -30 35 40 -19.999999999999996 F #
+cone-surface $-1 -1 -1 $-1 1.5308084989341911e-15 40 -25 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+edge $-1 -1 -1 $-1 $15711 27.500000000000004 $15714 37.5 $14210 $17177 forward @7 unknown T 22.5 44.330127018922191 -37.5 22.500000000000011 44.330127018922205 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $17111 $14211 $17170 $17178 reversed $15710 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17111 $17179 T 20 44.330127018922191 -27.500000000000004 25 45 -22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $15645 $17180 #
+ellipse-curve $-1 -1 -1 $-1 25 40 -25 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+point $-1 -1 -1 $-1 25 45 -25 #
+vertex $-1 -1 -1 $-1 $14215 $17181 #
+coedge $-1 -1 -1 $-1 $17108 $17182 $14216 $15716 reversed $17183 $-1 #
+edge $-1 -1 -1 $-1 $16434 1.047197551196597 $15719 1.5707963267948966 $14216 $15712 forward @7 unknown T 22.5 35 -27.500000000000004 25 35.669872981077809 -25 #
+coedge $-1 -1 -1 $-1 $16448 $14217 $17184 $17175 reversed $15718 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14909 $15706 T 25 35 -30 35 40 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $15716 $17185 #
+coedge $-1 -1 -1 $-1 $14220 $17186 $14252 $15751 forward $14280 $-1 #
+coedge $-1 -1 -1 $-1 $15722 $14221 $17187 $15796 reversed $14223 $-1 #
+coedge $-1 -1 -1 $-1 $14222 $15721 $17188 $17189 reversed $14223 $-1 #
+face $-1 -1 -1 $-1 $12785 $14223 $11 $-1 $14270 reversed single T -30 20 35 -22.5 25 50 F #
+coedge $-1 -1 -1 $-1 $17190 $17187 $14225 $15725 reversed $17191 $-1 #
+edge $-1 -1 -1 $-1 $14285 1.5707963267948966 $14291 2.0943951023931957 $14225 $14274 forward @7 unknown T -22.500000000000004 20 35 -20 20.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $15779 $14227 $17192 $15834 forward $15727 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14227 $15785 T -20 20 30 -9.9999999999999982 25 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17193 $17194 $11 $-1 $11391 reversed single T -15 25 -40 -7.4999999999999964 30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $15853 $17195 T 0 20 20 7.5000000000000027 25 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14233 $17196 $12820 $14308 forward $15730 $-1 #
+edge $-1 -1 -1 $-1 $12840 6.1232339957367673e-17 $15900 1.5707963267948966 $14989 $17197 forward @7 unknown T 15 20 20 20 25 25 #
+coedge $-1 -1 -1 $-1 $17198 $15738 $14236 $15735 reversed $16546 $-1 #
+edge $-1 -1 -1 $-1 $15749 -2.0943951023931939 $14237 -1.5707963267948966 $14236 $17199 forward @7 unknown T 35 19.999999999999996 17.500000000000011 37.499999999999993 20.669872981077802 20.000000000000004 #
+edge $-1 -1 -1 $-1 $14237 -1.5707963267948966 $14369 6.4931039580273206e-16 $14239 $17200 forward @7 unknown T 29.999999999999996 19.999999999999996 15 35 25 20.000000000000004 #
+point $-1 -1 -1 $-1 35 19.999999999999996 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $15734 $14995 $14239 $15736 reversed $16546 $-1 #
+loop $-1 -1 -1 $-1 $17201 $17202 $1558 T 50 20 2.6645352591003757e-15 50 30 10.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $15740 $15740 $14304 $15809 forward $14241 $-1 #
+coedge $-1 -1 -1 $-1 $15741 $15741 $17203 $17204 reversed $14243 $-1 #
+coedge $-1 -1 -1 $-1 $14244 $14244 $17205 $17206 forward $12764 $-1 #
+coedge $-1 -1 -1 $-1 $17207 $17208 $14244 $15744 reversed $17209 $-1 #
+edge $-1 -1 -1 $-1 $17210 -1.5707963267948966 $17211 1.5707963267948966 $14244 $17212 forward @7 unknown T -45 20.000000000000004 30 -40 30.000000000000004 35 #
+coedge $-1 -1 -1 $-1 $17213 $17192 $14245 $15746 reversed $17214 $-1 #
+edge $-1 -1 -1 $-1 $14311 -2.0943951023931948 $14320 -1.5707963267948966 $14245 $17215 forward @7 unknown T -9.9999999999999982 20 32.5 -7.4999999999999964 20.669872981077805 35 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14249 $16467 $17198 $17216 forward $10600 $-1 #
+vertex $-1 -1 -1 $-1 $14250 $17217 #
+coedge $-1 -1 -1 $-1 $17205 $14252 $17218 $17219 reversed $14254 $-1 #
+edge $-1 -1 -1 $-1 $17220 37.5 $14255 50 $15720 $17221 forward @7 unknown T -37.5 20.669872981077802 37.5 -37.5 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $14253 $17205 $17222 $17223 reversed $14254 $-1 #
+face $-1 -1 -1 $-1 $17224 $14254 $11 $-1 $17225 reversed single T -45 20.000000000000004 35 -37.5 30.000000000000004 50 F #
+point $-1 -1 -1 $-1 -37.5 20.669872981077805 50 #
+coedge $-1 -1 -1 $-1 $17222 $17226 $14257 $15756 reversed $17227 $-1 #
+edge $-1 -1 -1 $-1 $15757 4.1887902047863914 $17228 4.7123889803846897 $14257 $17229 forward @7 unknown T -37.5 29.330127018922195 35 -35 30 37.5 #
+vertex $-1 -1 -1 $-1 $15756 $17230 #
+straight-curve $-1 -1 -1 $-1 -37.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17231 $14263 $14259 $15760 reversed $15764 $-1 #
+edge $-1 -1 -1 $-1 $17228 1.5707963267948966 $14265 3.1415926535897931 $14259 $17232 forward @7 unknown T -35 25 35 -30 30 40 #
+coedge $-1 -1 -1 $-1 $17186 $14260 $17233 $15767 forward $14280 $-1 #
+face $-1 -1 -1 $-1 $17234 $17235 $11 $-1 $12288 reversed single T -37.500000000000007 25 19.999999999999993 -29.999999999999993 30 35 F #
+coedge $-1 -1 -1 $-1 $14263 $17231 $17236 $17237 forward $15764 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14263 $15780 T -35 25 30 -25 30 40 unknown #
+vertex $-1 -1 -1 $-1 $17237 $17238 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14265 3.1415926535897931 $17239 4.7123889803846897 $15761 $17232 forward @7 unknown T -35 20 35 -30 25 40 #
+point $-1 -1 -1 $-1 -30 25 40 #
+coedge $-1 -1 -1 $-1 $14271 $14267 $17240 $17241 forward $14272 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17242 $17243 $11 $-1 $14270 reversed single T -30.000000000000007 25 -40 -22.5 30 -25 F #
+loop $-1 -1 -1 $-1 $-1 $17244 $14269 T -30 25 -50 -22.5 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $17245 $15777 $14271 $15774 forward $15781 $-1 #
+edge $-1 -1 -1 $-1 $14273 -1.5707963267948966 $17246 -1.047197551196597 $15773 $17247 forward @7 unknown T -22.500000000000004 29.330127018922191 32.5 -20 30 35 #
+face $-1 -1 -1 $-1 $17248 $14272 $11 $-1 $8043 reversed single T -25 29.330127018922191 32.5 -20 30 37.500000000000007 F #
+point $-1 -1 -1 $-1 -20 30 35 #
+coedge $-1 -1 -1 $-1 $15773 $17249 $14276 $15778 forward $15781 $-1 #
+edge $-1 -1 -1 $-1 $15783 0 $14273 1.5707963267948966 $15777 $17250 forward @7 unknown T -20 25 30 -15 30 35 #
+coedge $-1 -1 -1 $-1 $14278 $15726 $17251 $17252 reversed $15727 $-1 #
+face $-1 -1 -1 $-1 $17253 $15764 $11 $-1 $8043 reversed single T -35 25 30 -25 30 40 F #
+loop $-1 -1 -1 $-1 $-1 $17249 $14279 T -22.500000000000004 25 20 -15 30 35 unknown #
+coedge $-1 -1 -1 $-1 $14290 $14281 $17249 $17254 reversed $12806 $-1 #
+vertex $-1 -1 -1 $-1 $15778 $17255 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17256 $15727 $11 $-1 $8043 reversed single T -20 20 30 -9.9999999999999982 25 40 F #
+edge $-1 -1 -1 $-1 $17257 1.0471975511965974 $14285 1.5707963267948966 $17258 $17247 forward @7 unknown T -22.500000000000004 20 32.5 -20 20.669872981077813 35 #
+point $-1 -1 -1 $-1 -20 20 35 #
+coedge $-1 -1 -1 $-1 $14286 $15793 $14293 $15799 reversed $12806 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17259 $17260 $11 $-1 $11391 reversed single T -15.000000000000004 25 -25 -7.4999999999999964 30 -10 F #
+loop $-1 -1 -1 $-1 $-1 $17261 $14288 T -15 25 -10 -7.4999999999999964 30 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $17262 $17263 $17264 $17265 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $15788 $14290 $17266 $17267 reversed $12806 $-1 #
+coedge $-1 -1 -1 $-1 $17268 $17269 $14290 $15795 forward $17270 $-1 #
+edge $-1 -1 -1 $-1 $17271 -1.5707963267948966 $17272 6.1232339957367648e-17 $15794 $17273 forward @7 unknown T -15 25 20 -9.9999999999999982 30 25 #
+edge $-1 -1 -1 $-1 $17274 1.5707963267948966 $14291 2.0943951023931948 $17187 $17275 forward @7 unknown T -25 20 35 -22.500000000000004 20.669872981077805 37.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $15801 $14293 $17276 $17277 forward $14294 $-1 #
+edge $-1 -1 -1 $-1 $14295 -32.5 $17278 -22.5 $14293 $17279 forward @7 unknown T -7.5 29.330127018922191 22.5 -7.4999999999999964 29.330127018922195 32.5 #
+point $-1 -1 -1 $-1 -7.5 29.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $14297 $15798 $17280 $17281 forward $14294 $-1 #
+face $-1 -1 -1 $-1 $17282 $17283 $11 $-1 $13449 reversed single T 39.999999999999993 20 2.6645352591003757e-15 50 30 10.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $17284 $12816 T -50 20 14.999999999999996 -50 30 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $17285 $17285 $17286 $17287 forward $14302 $-1 #
+coedge $-1 -1 -1 $-1 $17288 $14303 $17289 $17290 reversed $12817 $-1 #
+coedge $-1 -1 -1 $-1 $14303 $17288 $17291 $17292 forward $12817 $-1 #
+coedge $-1 -1 -1 $-1 $17293 $17213 $14303 $15808 reversed $17214 $-1 #
+edge $-1 -1 -1 $-1 $17294 1.5707963267948966 $17295 2.0943951023931957 $14303 $17296 forward @7 unknown T -9.9999999999999982 20 20 -7.4999999999999973 20.669872981077809 22.500000000000004 #
+edge $-1 -1 -1 $-1 $17297 0 $17297 6.2831853071795862 $15740 $17298 forward @7 unknown T 50 20 15.000000000000004 50 30 25.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17280 $17299 $14307 $15812 forward $14981 $-1 #
+edge $-1 -1 -1 $-1 $17300 -1.5707963267948966 $15813 6.1232339957367648e-17 $15811 $17301 forward @7 unknown T 0 25 20 5.0000000000000018 30 25 #
+vertex $-1 -1 -1 $-1 $17302 $17303 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 25 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $17304 $17305 $11 $-1 $9009 reversed single T 0 25 5 7.5000000000000009 30 20 F #
+point $-1 -1 -1 $-1 -7.4999999999999964 20.669872981077802 32.5 #
+coedge $-1 -1 -1 $-1 $14312 $17289 $17213 $17306 forward $12836 $-1 #
+coedge $-1 -1 -1 $-1 $17307 $14322 $14313 $15819 forward $15837 $-1 #
+edge $-1 -1 -1 $-1 $14324 -2.0943951023931953 $17300 -1.5707963267948966 $15818 $17308 forward @7 unknown T 5.0000000000000018 29.330127018922191 20 7.5000000000000027 30 22.5 #
+coedge $-1 -1 -1 $-1 $14314 $17309 $14975 $16521 reversed $12828 $-1 #
+coedge $-1 -1 -1 $-1 $17310 $14315 $15833 $17311 reversed $11411 $-1 #
+edge $-1 -1 -1 $-1 $14969 -1.5707963267948966 $15830 6.1232339957367648e-17 $14966 $17312 forward @7 unknown T 0 25 -40 5.0000000000000018 30 -35 #
+coedge $-1 -1 -1 $-1 $14316 $17310 $17313 $17314 reversed $11411 $-1 #
+coedge $-1 -1 -1 $-1 $17315 $17316 $14316 $15825 forward $17317 $-1 #
+edge $-1 -1 -1 $-1 $15831 -6.1232339957367648e-17 $17318 1.5707963267948961 $15824 $17319 forward @7 unknown T 0 25 -30 5.0000000000000018 30 -25 #
+coedge $-1 -1 -1 $-1 $17320 $14317 $17316 $17321 forward $15829 $-1 #
+coedge $-1 -1 -1 $-1 $14317 $17322 $16515 $17323 forward $15829 $-1 #
+coedge $-1 -1 -1 $-1 $16507 $17324 $16512 $14318 reversed $17325 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14317 $14978 T -7.5 25 -40 8.8817841970012523e-16 30 -25 unknown #
+vertex $-1 -1 -1 $-1 $16508 $17326 #
+vertex $-1 -1 -1 $-1 $17321 $17327 #
+coedge $-1 -1 -1 $-1 $14319 $14920 $15821 $17311 forward $14921 $-1 #
+edge $-1 -1 -1 $-1 $14320 -1.5707963267948966 $15783 -6.1232339957367648e-17 $15726 $17328 forward @7 unknown T -15 20 30 -9.9999999999999982 25 35 #
+point $-1 -1 -1 $-1 -9.9999999999999982 20 35 #
+coedge $-1 -1 -1 $-1 $14322 $17307 $17329 $17330 reversed $15837 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15818 $17331 T 5.0000000000000018 29.330127018922191 17.5 10 30 22.5 unknown #
+vertex $-1 -1 -1 $-1 $17330 $17332 #
+ellipse-curve $-1 -1 -1 $-1 10 25 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000027 29.330127018922202 22.5 #
+coedge $-1 -1 -1 $-1 $17289 $14326 $17333 $17302 forward $12836 $-1 #
+coedge $-1 -1 -1 $-1 $14329 $14327 $16526 $17334 reversed $11986 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 25 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17335 $15856 $14329 $15845 reversed $14335 $-1 #
+edge $-1 -1 -1 $-1 $17336 -6.1232339957367648e-17 $14330 1.5707963267948966 $14329 $17337 forward @7 unknown T 15 25 15 20 30 20 #
+point $-1 -1 -1 $-1 20 30 20 #
+vertex $-1 -1 -1 $-1 $17338 $17339 #
+face $-1 -1 -1 $-1 $17340 $17341 $11 $-1 $7081 reversed single T 15 25 -25 22.5 30 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $17342 $14334 T 15 25 -9.9999999999999982 22.500000000000004 30 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $17343 $17335 $16535 $17344 reversed $14335 $-1 #
+coedge $-1 -1 -1 $-1 $17345 $17346 $14336 $15852 reversed $17347 $-1 #
+edge $-1 -1 -1 $-1 $15847 1.5707963267948966 $15854 2.0943951023931966 $14336 $15839 forward @7 unknown T 7.4999999999999956 20 20 10 20.669872981077813 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $17196 $14337 $17346 $17348 reversed $15730 $-1 #
+vertex $-1 -1 -1 $-1 $17348 $17349 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15844 $17350 $14339 $15857 reversed $14335 $-1 #
+edge $-1 -1 -1 $-1 $14330 1.5707963267948966 $15879 2.0943951023931957 $14339 $17351 forward @7 unknown T 20 29.330127018922191 17.5 22.500000000000004 30 20 #
+coedge $-1 -1 -1 $-1 $17352 $14416 $14341 $15859 forward $15933 $-1 #
+edge $-1 -1 -1 $-1 $14985 -2.0943951023931957 $17353 -1.570796326794897 $15858 $17354 forward @7 unknown T 20 20 -27.500000000000004 22.500000000000004 20.669872981077809 -25 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14345 $14410 $17355 $17356 forward $14411 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14348 $14347 $17357 $17358 reversed $14349 $-1 #
+coedge $-1 -1 -1 $-1 $17355 $17359 $14347 $15865 reversed $17341 $-1 #
+edge $-1 -1 -1 $-1 $14350 -1.570796326794897 $17360 6.1232339957367648e-17 $14347 $17361 forward @7 unknown T 15 25 -25 20.000000000000004 30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $17362 $14349 $11 $-1 $14408 reversed single T 10 25 -30 20.000000000000004 30 -19.999999999999996 F #
+point $-1 -1 -1 $-1 20 30 -25 #
+coedge $-1 -1 -1 $-1 $14354 $14352 $17310 $17363 forward $12856 $-1 #
+coedge $-1 -1 -1 $-1 $17364 $17313 $14352 $15870 reversed $17365 $-1 #
+edge $-1 -1 -1 $-1 $15871 -1.5707963267948966 $17366 -1.0471975511965979 $14352 $17367 forward @7 unknown T 7.5 29.330127018922191 -27.5 10 30 -25 #
+vertex $-1 -1 -1 $-1 $15870 $17368 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17369 4.1887902047863932 $11976 4.7123889803846897 $14354 $14977 forward @7 unknown T 7.5000000000000027 29.330127018922198 -40 10 30 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $14356 $14975 $17370 $17371 forward $14357 $-1 #
+coedge $-1 -1 -1 $-1 $17372 $16530 $14356 $15876 reversed $17373 $-1 #
+edge $-1 -1 -1 $-1 $17374 -1.5707963267948966 $12858 0 $14356 $15872 forward @7 unknown T 10 20 -30 15 25 -25 #
+face $-1 -1 -1 $-1 $14964 $14357 $11 $-1 $7093 reversed single T 7.5 20 -40 15 25 -25 F #
+coedge $-1 -1 -1 $-1 $14990 $14361 $17350 $17375 forward $10643 $-1 #
+vertex $-1 -1 -1 $-1 $17375 $17376 #
+ellipse-curve $-1 -1 -1 $-1 25 25 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+face $-1 -1 -1 $-1 $12913 $17377 $11 $-1 $7093 reversed single T 7.5 20 5.0000000000000009 15 25 20 F #
+coedge $-1 -1 -1 $-1 $14365 $16536 $17378 $17379 reversed $13440 $-1 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $12875 -1.5707963267948961 $14369 0 $14994 $15883 forward @7 unknown T 25 20 15 29.999999999999996 25 20 #
+point $-1 -1 -1 $-1 29.999999999999996 25 15 #
+vertex $-1 -1 -1 $-1 $14371 $17380 #
+coedge $-1 -1 -1 $-1 $14994 $17381 $14379 $14371 forward $14996 $-1 #
+face $-1 -1 -1 $-1 $17382 $17383 $11 $-1 $5288 reversed single T 29.999999999999996 19.999999999999996 -9.9999999999999982 37.500000000000014 25 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $15904 $14373 T 29.999999999999996 19.999999999999996 -24.999999999999996 37.5 25 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $17384 $14375 $17385 $17386 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $14375 $17387 $17388 $17389 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $17390 $17391 $14375 $15893 forward $17392 $-1 #
+edge $-1 -1 -1 $-1 $17393 -1.5707963267948966 $17394 -6.4931039580273226e-16 $15892 $17395 forward @7 unknown T 29.999999999999996 25 -9.9999999999999982 35 29.999999999999996 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $17396 $14927 $14376 $15895 forward $16471 $-1 #
+edge $-1 -1 -1 $-1 $14929 -2.0943951023931957 $15897 -1.5707963267948966 $15894 $17397 forward @7 unknown T 35 29.330127018922187 5.0000000000000018 37.500000000000007 29.999999999999996 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $14377 $16539 $17387 $17398 forward $13448 $-1 #
+vertex $-1 -1 -1 $-1 $17398 $17399 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $14380 $14379 $17400 $17401 forward $14381 $-1 #
+vertex $-1 -1 -1 $-1 $17402 $17403 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 29.330127018922191 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $14388 $14387 $17404 $17405 reversed $14389 $-1 #
+coedge $-1 -1 -1 $-1 $16548 $17406 $14387 $15905 reversed $15889 $-1 #
+edge $-1 -1 -1 $-1 $14390 1.5707963267948966 $17407 2.0943951023931957 $14387 $17408 forward @7 unknown T 35 19.999999999999996 -24.999999999999996 37.5 20.669872981077805 -22.499999999999989 #
+face $-1 -1 -1 $-1 $14400 $14389 $11 $-1 $14408 reversed single T 35 19.999999999999996 -27.499999999999989 40.000000000000007 20.669872981077809 -22.499999999999989 F #
+point $-1 -1 -1 $-1 35 19.999999999999996 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $17409 $17409 $14392 $15909 reversed $17410 $-1 #
+edge $-1 -1 -1 $-1 $15910 -1.570796326794897 $15914 1.570796326794897 $14392 $17411 forward @7 unknown T 40 20 -29.999999999999996 45.000000000000007 30 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $14393 $17412 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17413 $17414 $14396 $15913 forward $17415 $-1 #
+edge $-1 -1 -1 $-1 $15916 4.1887902047863905 $15914 4.7123889803846897 $15912 $17416 forward @7 unknown T 37.500000000000007 29.330127018922191 -24.999999999999996 40.000000000000007 30 -22.499999999999989 #
+vertex $-1 -1 -1 $-1 $14397 $17417 #
+coedge $-1 -1 -1 $-1 $17418 $14398 $17414 $17419 reversed $14374 $-1 #
+vertex $-1 -1 -1 $-1 $15913 $17420 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17421 $17422 $11 $-1 $6162 reversed single T 22.499999999999996 20 -9.9999999999999982 30 25 5.0000000000000036 F #
+coedge $-1 -1 -1 $-1 $17423 $14402 $17424 $15924 forward $15921 $-1 #
+coedge $-1 -1 -1 $-1 $14402 $17425 $14410 $15928 forward $15921 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15919 $17426 T 22.5 25 -25 30 30 -9.9999999999999964 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 25 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $14404 $17418 $17391 $17427 reversed $14374 $-1 #
+edge $-1 -1 -1 $-1 $14405 -20 $17428 -14.999999999999998 $15919 $17429 forward @7 unknown T 29.999999999999996 25 -20 30 25 -14.999999999999998 #
+edge $-1 -1 -1 $-1 $14405 3.1415926535897931 $14420 4.7123889803846897 $15934 $15922 forward @7 unknown T 25 20 -25 29.999999999999996 25 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 25 -20 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $17430 4.1887902047863923 $12907 4.7123889803846897 $15920 $17431 forward @7 unknown T 22.5 29.330127018922195 -25 25 30 -22.500000000000007 #
+face $-1 -1 -1 $-1 $17432 $14411 $11 $-1 $14408 reversed single T 19.999999999999996 29.330127018922191 -27.500000000000004 25 30 -22.500000000000004 F #
+point $-1 -1 -1 $-1 22.500000000000004 29.330127018922191 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000004 29.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $14416 $17352 $17433 $17434 reversed $15933 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15858 $17435 T 19.999999999999996 20 -27.500000000000004 25 20.669872981077809 -22.499999999999996 unknown #
+coedge $-1 -1 -1 $-1 $17433 $17424 $14418 $15925 forward $17436 $-1 #
+point $-1 -1 -1 $-1 25 20 -25 #
+coedge $-1 -1 -1 $-1 $14421 $14462 $17437 $17438 forward $12974 $-1 #
+coedge $-1 -1 -1 $-1 $14425 $17439 $14422 $14497 forward $15941 $-1 #
+coedge $-1 -1 -1 $-1 $17440 $15983 $14423 $15939 forward $17441 $-1 #
+edge $-1 -1 -1 $-1 $12959 4.1650370783741769e-16 $16024 1.5707963267948966 $15938 $17442 forward @7 unknown T -30 5.0000000000000018 35 -25 10 40 #
+coedge $-1 -1 -1 $-1 $17439 $14425 $16008 $14487 reversed $15941 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15937 $17443 T -25 5 32.5 -20 5.6698729810778099 37.5 unknown #
+coedge $-1 -1 -1 $-1 $14446 $17444 $14427 $14535 reversed $15964 $-1 #
+face $-1 -1 -1 $-1 $12023 $17445 $11 $-1 $10247 reversed single T -15 5 -40 -7.4999999999999991 10 -25 F #
+loop $-1 -1 -1 $-1 $-1 $17446 $14430 T -15 10 -40 -7.4999999999999982 15 -25 unknown #
+face $-1 -1 -1 $-1 $9067 $14431 $11 $-1 $8101 reversed single T 0 4.9999999999999991 20 7.5000000000000018 10 35 F #
+coedge $-1 -1 -1 $-1 $14433 $14554 $16622 $17447 reversed $14431 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $16650 $14435 $14449 $15966 reversed $15097 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $17448 $17449 $1558 T 50 5 -14.999999999999996 50 15 -4.9999999999999964 hole $1559 T #
+coedge $-1 -1 -1 $-1 $15952 $15952 $17450 $17451 forward $14440 $-1 #
+coedge $-1 -1 -1 $-1 $15953 $15953 $14442 $15954 forward $17452 $-1 #
+edge $-1 -1 -1 $-1 $17453 0 $17453 6.2831853071795862 $15953 $17454 forward @7 unknown T -50 5 29.999999999999996 -50 15 40 #
+coedge $-1 -1 -1 $-1 $14453 $14451 $14443 $15956 reversed $12948 $-1 #
+edge $-1 -1 -1 $-1 $15961 -1.5707963267948966 $15960 1.5707963267948966 $14443 $17455 forward @7 unknown T -45 5.0000000000000018 35 -40 15.000000000000002 40 #
+coedge $-1 -1 -1 $-1 $17456 $14444 $17457 $17458 reversed $15959 $-1 #
+coedge $-1 -1 -1 $-1 $14444 $17459 $17460 $17461 reversed $15959 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17462 $17463 T -45 5.0000000000000018 19.999999999999996 -37.5 15.000000000000002 35 unknown #
+vertex $-1 -1 -1 $-1 $14445 $17464 #
+vertex $-1 -1 -1 $-1 $14445 $17465 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14508 $14446 $14518 $16056 reversed $15964 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14508 $17466 T -15 5 20 -7.4999999999999991 10 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17467 7.5000000000000036 $14450 17.500000000000011 $14449 $17468 forward @7 unknown T 37.5 5.6698729810778046 7.5000000000000036 37.500000000000014 5.6698729810778072 17.500000000000011 #
+point $-1 -1 -1 $-1 37.5 5.6698729810778046 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $17437 $17457 $14451 $15969 forward $17469 $-1 #
+edge $-1 -1 -1 $-1 $15960 1.5707963267948966 $15970 2.0943951023931953 $15968 $17470 forward @7 unknown T -40 5.0000000000000018 35 -37.5 5.6698729810778099 37.5 #
+vertex $-1 -1 -1 $-1 $15969 $17471 #
+straight-curve $-1 -1 -1 $-1 -37.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17460 $14456 $14453 $15973 forward $15977 $-1 #
+edge $-1 -1 -1 $-1 $14458 -2.0943951023931957 $15961 -1.5707963267948966 $15972 $17472 forward @7 unknown T -40 14.330127018922193 35 -37.499999999999993 15.000000000000002 37.5 #
+face $-1 -1 -1 $-1 $17473 $16576 $11 $-1 $15975 reversed single T -45 5.0000000000000018 -50 -37.5 15.000000000000002 -40 F #
+cone-surface $-1 -1 -1 $-1 -40 10.000000000000002 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $14456 $17460 $17474 $17475 reversed $15977 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15972 $17476 T -40 14.330127018922191 32.5 -35 15.000000000000002 37.5 unknown #
+vertex $-1 -1 -1 $-1 $17475 $17477 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.499999999999993 14.330127018922193 37.499999999999993 #
+coedge $-1 -1 -1 $-1 $14464 $14460 $17478 $17479 reversed $14465 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15938 $17480 $14462 $14468 reversed $17441 $-1 #
+face $-1 -1 -1 $-1 $17476 $17469 $11 $-1 $7181 reversed single T -40 5 32.5 -35 5.6698729810778099 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $17481 $14463 T -37.5 10 19.999999999999993 -29.999999999999993 15 35 unknown #
+coedge $-1 -1 -1 $-1 $17482 $15990 $14464 $15987 reversed $17483 $-1 #
+edge $-1 -1 -1 $-1 $17484 -4.1650370783741769e-16 $14466 1.5707963267948966 $14464 $17485 forward @7 unknown T -30 10 30 -25 15.000000000000002 35 #
+point $-1 -1 -1 $-1 -25 15.000000000000002 35 #
+vertex $-1 -1 -1 $-1 $17486 $17487 #
+coedge $-1 -1 -1 $-1 $15986 $17488 $14470 $15991 reversed $17483 $-1 #
+edge $-1 -1 -1 $-1 $14466 1.5707963267948966 $15996 2.0943951023931948 $14470 $17489 forward @7 unknown T -25 14.330127018922193 32.5 -22.500000000000004 15.000000000000002 35 #
+face $-1 -1 -1 $-1 $15034 $17490 $11 $-1 $12964 reversed single T -30.000000000000007 5.0000000000000018 -40 -22.5 10 -25 F #
+loop $-1 -1 -1 $-1 $-1 $17491 $14472 T -30.000000000000007 10 -40 -22.499999999999993 15.000000000000002 -25 unknown #
+coedge $-1 -1 -1 $-1 $17492 $15004 $15006 $16556 reversed $14473 $-1 #
+coedge $-1 -1 -1 $-1 $17493 $14474 $17488 $17494 forward $14482 $-1 #
+vertex $-1 -1 -1 $-1 $17494 $17495 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17496 $17497 $11 $-1 $10937 reversed single T -37.500000000000007 5 19.999999999999993 -29.999999999999993 10 35 F #
+coedge $-1 -1 -1 $-1 $14478 $17498 $17499 $16004 forward $14482 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17499 $16008 $14480 $16002 forward $17500 $-1 #
+edge $-1 -1 -1 $-1 $12979 -1.5707963267948966 $14484 0 $16001 $16000 forward @7 unknown T -20 5 30 -15 10 35 #
+face $-1 -1 -1 $-1 $17443 $17441 $11 $-1 $7181 reversed single T -35 5 30 -25 10 40 F #
+edge $-1 -1 -1 $-1 $16022 25 $14484 30 $15999 $17501 forward @7 unknown T -15 10 25 -15 10 30 #
+point $-1 -1 -1 $-1 -15 10 30 #
+face $-1 -1 -1 $-1 $17502 $17500 $11 $-1 $11541 reversed single T -22.5 5 20 -15 10 35 F #
+vertex $-1 -1 -1 $-1 $14487 $17503 #
+coedge $-1 -1 -1 $-1 $16001 $17504 $15940 $14487 forward $17500 $-1 #
+face $-1 -1 -1 $-1 $17505 $17506 $11 $-1 $10247 reversed single T -15.000000000000004 5 -25 -7.4999999999999991 10 -10 F #
+loop $-1 -1 -1 $-1 $-1 $17507 $14491 T -15.000000000000004 10 -25 -7.4999999999999982 15 -10 unknown #
+coedge $-1 -1 -1 $-1 $16614 $17508 $16611 $17509 reversed $14492 $-1 #
+coedge $-1 -1 -1 $-1 $17510 $14493 $17511 $17512 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $14493 $17513 $17514 $17515 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $17516 $17517 $14493 $16015 forward $17518 $-1 #
+edge $-1 -1 -1 $-1 $17519 -1.5707963267948966 $17520 6.1232339957367648e-17 $16014 $17521 forward @7 unknown T -15 10 4.9999999999999991 -10 15 10 #
+coedge $-1 -1 -1 $-1 $17522 $16026 $14494 $16017 forward $17523 $-1 #
+edge $-1 -1 -1 $-1 $16028 -2.0943951023931948 $16021 -1.5707963267948966 $16016 $17524 forward @7 unknown T -10 14.330127018922193 20 -7.4999999999999982 15 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $17525 $14495 $17498 $17526 reversed $16020 $-1 #
+coedge $-1 -1 -1 $-1 $14495 $17525 $17513 $17527 forward $16020 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14495 $17528 T -20 10 15 -10 15 25 unknown #
+vertex $-1 -1 -1 $-1 $17527 $17529 #
+vertex $-1 -1 -1 $-1 $17530 $17531 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $17532 $17533 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16016 $17534 $14499 $16027 reversed $17523 $-1 #
+edge $-1 -1 -1 $-1 $16028 4.1887902047863914 $17535 4.7123889803846897 $14499 $17536 forward @7 unknown T -7.4999999999999982 14.330127018922193 20 -5 15 22.499999999999996 #
+vertex $-1 -1 -1 $-1 $16027 $17537 #
+straight-curve $-1 -1 -1 $-1 -7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17538 $14512 $14502 $16031 reversed $13517 $-1 #
+edge $-1 -1 -1 $-1 $17535 1.5707963267948966 $14514 3.1415926535897931 $14502 $17539 forward @7 unknown T -5 10 20 0 15 25 #
+face $-1 -1 -1 $-1 $17540 $17541 $11 $-1 $12076 reversed single T -10 4.9999999999999991 2.4999999999999987 -5 5.669872981077809 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $17542 $16568 $14503 T 39.999999999999993 4.9999999999999991 2.6645352591003757e-15 45.000000000000007 15 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $16034 $16034 $17543 $17544 reversed $14504 $-1 #
+coedge $-1 -1 -1 $-1 $14505 $14505 $17545 $17546 forward $12996 $-1 #
+coedge $-1 -1 -1 $-1 $17547 $17548 $14505 $16037 reversed $17549 $-1 #
+edge $-1 -1 -1 $-1 $17550 -1.5707963267948966 $17551 1.5707963267948966 $14505 $17552 forward @7 unknown T -45 5.0000000000000018 14.999999999999996 -40 15.000000000000002 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $14507 $14506 $17553 $17554 reversed $11562 $-1 #
+coedge $-1 -1 -1 $-1 $14518 $14542 $14506 $16040 forward $11581 $-1 #
+edge $-1 -1 -1 $-1 $17555 1.5707963267948966 $16045 2.0943951023931957 $16039 $17536 forward @7 unknown T -7.5000000000000009 5 20 -5 5.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $17556 $17557 $14507 $16042 reversed $17558 $-1 #
+edge $-1 -1 -1 $-1 $17559 -2.0943951023931957 $16044 -1.5707963267948966 $14507 $17560 forward @7 unknown T -10 5 17.5 -7.4999999999999991 5.669872981077809 20 #
+coedge $-1 -1 -1 $-1 $17444 $14508 $17561 $17562 reversed $15964 $-1 #
+vertex $-1 -1 -1 $-1 $17563 $17564 #
+vertex $-1 -1 -1 $-1 $14509 $17565 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $14510 $17566 #
+ellipse-curve $-1 -1 -1 $-1 50 10 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $14512 $17538 $17567 $17568 forward $13517 $-1 #
+vertex $-1 -1 -1 $-1 $17568 $17569 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14514 3.1415926535897931 $17555 4.7123889803846897 $14542 $17539 forward @7 unknown T -5 5 20 0 10 25 #
+point $-1 -1 -1 $-1 0 10 25 #
+face $-1 -1 -1 $-1 $17570 $17571 $11 $-1 $8101 reversed single T 0 10 -10 7.5000000000000009 15 5 F #
+loop $-1 -1 -1 $-1 $-1 $17572 $14516 T 0 10 5 7.5000000000000027 15 20 unknown #
+edge $-1 -1 -1 $-1 $16045 22.500000000000004 $13005 32.5 $14518 $17573 forward @7 unknown T -7.5 5.6698729810778064 22.500000000000004 -7.5 5.6698729810778072 32.5 #
+coedge $-1 -1 -1 $-1 $14537 $14519 $17574 $17575 forward $14538 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14521 $16616 $17576 $17577 reversed $11573 $-1 #
+coedge $-1 -1 -1 $-1 $14524 $14522 $14569 $16113 reversed $10267 $-1 #
+edge $-1 -1 -1 $-1 $16119 -2.0943951023931948 $13505 -1.5707963267948966 $14534 $17578 forward @7 unknown T 5.0000000000000009 14.330127018922195 -40 7.5000000000000009 15 -37.5 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14570 $17579 $14524 $16064 forward $16115 $-1 #
+edge $-1 -1 -1 $-1 $16068 1.5707963267948966 $16116 2.0943951023931957 $16063 $17580 forward @7 unknown T 5.0000000000000009 14.330127018922193 -27.500000000000004 7.5000000000000027 15 -25 #
+coedge $-1 -1 -1 $-1 $17581 $14525 $17582 $17583 forward $16067 $-1 #
+coedge $-1 -1 -1 $-1 $14525 $17581 $14527 $16071 reversed $16067 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14525 $17584 T -5 10 -30 5.0000000000000009 15 -20 unknown #
+vertex $-1 -1 -1 $-1 $14526 $17585 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17586 $14527 $17587 $17588 forward $14530 $-1 #
+edge $-1 -1 -1 $-1 $14532 0 $17589 1.5707963267948966 $14527 $17590 forward @7 unknown T -5 10 -30 0 15 -25 #
+coedge $-1 -1 -1 $-1 $14528 $17586 $16559 $17591 forward $14530 $-1 #
+edge $-1 -1 -1 $-1 $13507 1.5707963267948966 $14531 3.1415926535897931 $14528 $16608 forward @7 unknown T -5 10 -40 0 15 -35 #
+coedge $-1 -1 -1 $-1 $14529 $17592 $17593 $17594 forward $16075 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14529 $16609 T -7.5000000000000009 5 -40 8.8817841970012523e-16 10 -25 unknown #
+point $-1 -1 -1 $-1 0 10 -35 #
+point $-1 -1 -1 $-1 0 10 -30 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17595 $15077 $14537 $16080 forward $12053 $-1 #
+edge $-1 -1 -1 $-1 $14539 -1.5707963267948966 $17596 -1.0471975511965983 $16079 $17597 forward @7 unknown T 7.5000000000000027 14.330127018922195 17.500000000000004 10 15 20 #
+face $-1 -1 -1 $-1 $17598 $14538 $11 $-1 $10259 reversed single T 5.0000000000000009 14.330127018922195 17.500000000000004 10 15 22.499999999999996 F #
+point $-1 -1 -1 $-1 10 15 20 #
+coedge $-1 -1 -1 $-1 $16622 $17599 $14542 $16052 reversed $15076 $-1 #
+edge $-1 -1 -1 $-1 $16086 0 $14539 1.5707963267948966 $15077 $17600 forward @7 unknown T 10 10 15 15 15 20 #
+coedge $-1 -1 -1 $-1 $14551 $14545 $13518 $15080 reversed $13029 $-1 #
+vertex $-1 -1 -1 $-1 $16084 $17601 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17602 1.0471975511965979 $14548 1.5707963267948966 $17603 $17597 forward @7 unknown T 7.5 5 17.5 10 5.6698729810778081 20 #
+point $-1 -1 -1 $-1 10 5 20 #
+face $-1 -1 -1 $-1 $17604 $17605 $11 $-1 $6219 reversed single T 15 4.9999999999999982 -25 22.500000000000004 10 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $14565 $14549 T 15 10 -25 22.5 14.999999999999998 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $17606 $17607 $17608 $17609 reversed $14550 $-1 #
+coedge $-1 -1 -1 $-1 $16100 $14551 $16637 $17610 reversed $13029 $-1 #
+edge $-1 -1 -1 $-1 $17611 -1.5707963267948966 $16628 -2.9403902792268234e-16 $15086 $17612 forward @7 unknown T 14.999999999999996 10 5.0000000000000009 20 15 10 #
+coedge $-1 -1 -1 $-1 $17613 $14552 $17603 $16088 reversed $16097 $-1 #
+coedge $-1 -1 -1 $-1 $14552 $17613 $14554 $16098 forward $16097 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16096 $15075 T 5.0000000000000009 4.9999999999999991 17.5 10 5.669872981077809 22.500000000000004 unknown #
+edge $-1 -1 -1 $-1 $17614 1.5707963267948966 $14555 2.0943951023931957 $16096 $17615 forward @7 unknown T 5.0000000000000009 4.9999999999999991 20 7.5000000000000018 5.6698729810778072 22.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $14557 $16093 $14579 $16125 reversed $13029 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $14633 $14559 $17616 $17617 forward $14634 $-1 #
+vertex $-1 -1 -1 $-1 $15082 $17618 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17619 $14565 $14562 $16106 reversed $16091 $-1 #
+edge $-1 -1 -1 $-1 $16180 -2.0943951023931939 $13044 -1.5707963267948961 $14562 $17620 forward @7 unknown T 19.999999999999996 14.330127018922193 -25 22.499999999999996 14.999999999999998 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $17621 $17622 $14564 $16108 forward $17623 $-1 #
+edge $-1 -1 -1 $-1 $14572 1.5707963267948966 $16110 3.1415926535897931 $16107 $17624 forward @7 unknown T 10 10 -25 15 15 -20 #
+coedge $-1 -1 -1 $-1 $14565 $17625 $17621 $17626 reversed $16091 $-1 #
+vertex $-1 -1 -1 $-1 $17627 $17628 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16185 $16123 $11 $-1 $13102 reversed single T 10 4.9999999999999982 -30 20.000000000000004 10 -19.999999999999996 F #
+edge $-1 -1 -1 $-1 $16116 27.500000000000004 $16119 37.5 $14569 $17629 forward @7 unknown T 7.5 14.330127018922195 -37.5 7.5000000000000027 14.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $17579 $14570 $17622 $17630 reversed $16115 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17579 $17631 T 5.0000000000000009 14.330127018922191 -27.500000000000004 10 15 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $16064 $17632 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 15 -25 #
+vertex $-1 -1 -1 $-1 $14574 $17633 #
+coedge $-1 -1 -1 $-1 $17576 $17634 $14575 $16121 reversed $17635 $-1 #
+edge $-1 -1 -1 $-1 $16618 1.0471975511965979 $16124 1.5707963267948966 $14575 $16117 forward @7 unknown T 7.5 5 -27.5 10 5.6698729810778081 -25 #
+coedge $-1 -1 -1 $-1 $16630 $14576 $17636 $17627 reversed $16123 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15081 $16112 T 10 4.9999999999999982 -30 20.000000000000004 10 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $16121 $17637 #
+edge $-1 -1 -1 $-1 $14580 -17.5 $16640 -7.5000000000000009 $14579 $17638 forward @7 unknown T 22.5 14.330127018922191 7.5000000000000009 22.500000000000004 14.330127018922196 17.5 #
+point $-1 -1 -1 $-1 22.500000000000004 14.330127018922191 17.5 #
+loop $-1 -1 -1 $-1 $-1 $15079 $14582 T 7.5 4.9999999999999991 5.0000000000000009 15 10 20 unknown #
+coedge $-1 -1 -1 $-1 $15079 $17603 $14583 $16129 forward $16127 $-1 #
+edge $-1 -1 -1 $-1 $14548 -1.5707963267948966 $16086 0 $16128 $17600 forward @7 unknown T 10 5 15 15 10 20 #
+point $-1 -1 -1 $-1 22.500000000000004 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $14588 $15093 $17639 $17640 forward $13532 $-1 #
+face $-1 -1 -1 $-1 $10213 $15097 $11 $-1 $4445 reversed single T 29.999999999999996 4.9999999999999973 5.0000000000000018 37.500000000000014 10 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $17641 $14589 T 29.999999999999996 4.9999999999999973 -9.9999999999999982 37.5 10 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $17642 $14591 $17643 $17644 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $17645 $17646 $14591 $16136 forward $17647 $-1 #
+edge $-1 -1 -1 $-1 $17648 -2.0943951023931948 $16143 -1.5707963267948966 $16135 $17649 forward @7 unknown T 35 14.330127018922193 -9.9999999999999982 37.5 14.999999999999998 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $14592 $17642 $14597 $16148 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $16642 $17650 $17651 $16139 forward $17652 $-1 #
+edge $-1 -1 -1 $-1 $16144 -4.9999999999999982 $17653 1.7763568394002505e-15 $16138 $17654 forward @7 unknown T 29.999999999999996 10 -4.9999999999999982 30 10 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $17655 $14593 $17650 $17656 reversed $16142 $-1 #
+coedge $-1 -1 -1 $-1 $14593 $17655 $14624 $16177 forward $16142 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14593 $17657 T 25 10 -15 35 15 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $16177 $17658 #
+vertex $-1 -1 -1 $-1 $17659 $17660 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15021 $14595 $17642 $17661 forward $15022 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17653 2.9403902792268224e-16 $14598 1.5707963267948966 $14597 $17662 forward @7 unknown T 29.999999999999996 10 1.7763568394002505e-15 35 14.999999999999998 5.0000000000000018 #
+point $-1 -1 -1 $-1 35 14.999999999999998 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $17639 $16636 $14600 $16151 reversed $17663 $-1 #
+edge $-1 -1 -1 $-1 $14587 -2.0943951023931957 $14601 -1.5707963267948966 $14600 $17664 forward @7 unknown T 20 4.9999999999999982 17.5 22.500000000000004 5.6698729810778072 20 #
+edge $-1 -1 -1 $-1 $14601 -1.5707963267948966 $16086 2.9403902792268234e-16 $15087 $17665 forward @7 unknown T 15 4.9999999999999982 15 20 10 20 #
+point $-1 -1 -1 $-1 20 4.9999999999999982 20 #
+coedge $-1 -1 -1 $-1 $17666 $16163 $14604 $16155 forward $16165 $-1 #
+edge $-1 -1 -1 $-1 $14611 1.570796326794897 $16157 2.0943951023931957 $16154 $16166 forward @7 unknown T 37.500000000000007 5 -24.999999999999996 40.000000000000007 5.669872981077809 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $14605 $17667 $17666 $17668 reversed $14590 $-1 #
+vertex $-1 -1 -1 $-1 $17668 $17669 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14609 $14609 $16163 $17670 reversed $16160 $-1 #
+loop $-1 -1 -1 $-1 $17671 $14609 $17672 T 39.999999999999993 5 -29.999999999999996 45.000000000000007 15 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 5 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $16154 $14613 $16159 $17670 forward $16165 $-1 #
+coedge $-1 -1 -1 $-1 $14613 $17673 $14616 $16169 forward $16165 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16164 $17674 T 37.499999999999993 5 -24.999999999999996 45 15 -9.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 15 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $14624 $14616 $17645 $17675 reversed $13068 $-1 #
+edge $-1 -1 -1 $-1 $17676 12.500000000000002 $14617 22.499999999999989 $16164 $17677 forward @7 unknown T 37.499999999999993 14.330127018922186 -22.499999999999989 37.5 14.330127018922195 -12.500000000000002 #
+point $-1 -1 -1 $-1 37.499999999999993 14.330127018922186 -22.499999999999989 #
+face $-1 -1 -1 $-1 $17678 $17679 $11 $-1 $5306 reversed single T 37.5 4.9999999999999991 -9.9999999999999982 45.000000000000007 15 5.0000000000000044 F #
+loop $-1 -1 -1 $-1 $-1 $17651 $14619 T 22.5 4.9999999999999991 -9.9999999999999982 30 10 5.0000000000000036 unknown #
+coedge $-1 -1 -1 $-1 $17680 $14620 $17655 $17681 forward $14622 $-1 #
+coedge $-1 -1 -1 $-1 $14635 $17682 $16652 $14625 reversed $16186 $-1 #
+coedge $-1 -1 -1 $-1 $14621 $17680 $17619 $17683 forward $14622 $-1 #
+face $-1 -1 -1 $-1 $9044 $14622 $11 $-1 $5329 reversed single T 22.499999999999996 10 -25 30 15 -9.9999999999999964 F #
+edge $-1 -1 -1 $-1 $16178 2.9403902792268244e-16 $16143 1.5707963267948966 $16141 $17684 forward @7 unknown T 30 10 -15 35 14.999999999999998 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $17681 $17685 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $14629 $17686 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17687 $17688 $11 $-1 $6231 reversed single T 7.4999999999999991 4.9999999999999991 -10 15.000000000000004 10 5.0000000000000009 F #
+coedge $-1 -1 -1 $-1 $17689 $14635 $14633 $16184 forward $16186 $-1 #
+edge $-1 -1 -1 $-1 $13114 1.5707963267948961 $17690 2.0943951023931948 $16183 $16181 forward @7 unknown T 22.5 5 -25.000000000000004 25 5.6698729810778064 -22.500000000000004 #
+face $-1 -1 -1 $-1 $14630 $14634 $11 $-1 $13102 reversed single T 19.999999999999996 4.9999999999999982 -27.500000000000004 25 5.669872981077809 -22.5 F #
+loop $-1 -1 -1 $-1 $-1 $16174 $17691 T 22.5 4.9999999999999991 -25.000000000000004 30 10 -9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $17692 $14662 $14637 $16188 reversed $16210 $-1 #
+edge $-1 -1 -1 $-1 $14683 1.5707963267948966 $14664 2.0943951023931957 $14637 $14673 forward @7 unknown T -37.5 -10 35 -35 -9.330127018922191 37.5 #
+coedge $-1 -1 -1 $-1 $14638 $14641 $17693 $17694 forward $14642 $-1 #
+coedge $-1 -1 -1 $-1 $16221 $14639 $17695 $16273 forward $16191 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14639 $14697 T -35 -10 30 -25 -4.9999999999999991 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13164 $14642 $11 $-1 $6317 reversed single T -25 -10 32.5 -20 -9.330127018922191 37.5 F #
+coedge $-1 -1 -1 $-1 $14643 $14736 $13171 $14698 forward $14659 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15115 $14644 T -15 -10 -40 -7.4999999999999991 -4.9999999999999991 -25 unknown #
+coedge $-1 -1 -1 $-1 $16695 $17696 $16689 $17697 reversed $14645 $-1 #
+edge $-1 -1 -1 $-1 $13201 -1.1640334398265738e-16 $16337 1.5707963267948966 $15165 $17698 forward @7 unknown T -4.686749320818303e-33 -10 20 5 -4.9999999999999991 25 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $16205 $14652 $17699 $17700 reversed $14654 $-1 #
+coedge $-1 -1 -1 $-1 $14662 $17692 $14652 $16201 forward $16210 $-1 #
+edge $-1 -1 -1 $-1 $17701 -2.0943951023931948 $14655 -1.5707963267948966 $16200 $17702 forward @7 unknown T -40 -9.9999999999999964 32.5 -37.5 -9.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $14653 $17703 $17704 $17705 reversed $14654 $-1 #
+coedge $-1 -1 -1 $-1 $14670 $14666 $14653 $16204 forward $14671 $-1 #
+edge $-1 -1 -1 $-1 $14656 1.5707963267948966 $17706 2.0943951023931944 $16203 $17707 forward @7 unknown T -40 -0.66987298107780635 32.5 -37.5 2.6645352591003757e-15 35 #
+coedge $-1 -1 -1 $-1 $16283 $16199 $17708 $17709 reversed $14654 $-1 #
+face $-1 -1 -1 $-1 $13142 $14654 $11 $-1 $14669 reversed single T -45 -9.9999999999999964 19.999999999999996 -37.5 2.6645352591003757e-15 35 F #
+point $-1 -1 -1 $-1 -40 -9.9999999999999964 35 #
+point $-1 -1 -1 $-1 -40 2.6645352591003757e-15 35 #
+face $-1 -1 -1 $-1 $10347 $14659 $11 $-1 $9224 reversed single T -15 -10 20 -7.5 -4.9999999999999991 35 F #
+loop $-1 -1 -1 $-1 $-1 $14662 $14678 T -40 -10 32.5 -35 -9.3301270189221892 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 -9.3301270189221928 37.5 #
+face $-1 -1 -1 $-1 $11697 $17710 $11 $-1 $14669 reversed single T -45 -9.9999999999999964 -40 -37.499999999999993 2.6645352591003757e-15 -25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $17704 $16219 $14670 $16216 forward $14679 $-1 #
+edge $-1 -1 -1 $-1 $14672 -1.5707963267948966 $17706 -1.0471975511965983 $16215 $17711 forward @7 unknown T -37.5 -0.66987298107780635 32.5 -35 0 35 #
+face $-1 -1 -1 $-1 $17712 $14671 $11 $-1 $6317 reversed single T -40 -0.66987298107781079 32.5 -35 2.6645352591003757e-15 37.500000000000007 F #
+point $-1 -1 -1 $-1 -35 0 35 #
+coedge $-1 -1 -1 $-1 $16215 $16222 $14675 $16220 forward $14679 $-1 #
+edge $-1 -1 -1 $-1 $16225 0 $14672 1.5707963267948966 $16219 $17713 forward @7 unknown T -35 -5 30 -30 0 35 #
+coedge $-1 -1 -1 $-1 $14677 $16190 $17714 $17715 reversed $16191 $-1 #
+coedge $-1 -1 -1 $-1 $16219 $17716 $17717 $17718 forward $14679 $-1 #
+coedge $-1 -1 -1 $-1 $17719 $14680 $16222 $17718 reversed $16224 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17719 $16746 T -30 -5 20 -22.5 1.7763568394002505e-15 35 unknown #
+vertex $-1 -1 -1 $-1 $16220 $17720 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17701 1.0471975511965979 $14683 1.5707963267948966 $17721 $17711 forward @7 unknown T -37.5 -10 32.5 -35 -9.330127018922191 35 #
+point $-1 -1 -1 $-1 -35 -10 35 #
+coedge $-1 -1 -1 $-1 $14684 $17722 $14689 $16235 reversed $16224 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $17723 $14686 T -30.000000000000007 -9.9999999999999982 -40 -22.5 -4.9999999999999991 -25 unknown #
+coedge $-1 -1 -1 $-1 $17724 $17725 $17726 $17727 reversed $14687 $-1 #
+coedge $-1 -1 -1 $-1 $15126 $14688 $15114 $16667 reversed $13161 $-1 #
+coedge $-1 -1 -1 $-1 $16239 $14689 $17728 $17729 forward $13170 $-1 #
+edge $-1 -1 -1 $-1 $14690 -32.5 $17730 -22.5 $14689 $17731 forward @7 unknown T -22.500000000000004 -0.66987298107780746 22.5 -22.5 -0.66987298107780546 32.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 -0.66987298107780746 32.5 #
+face $-1 -1 -1 $-1 $17732 $17733 $11 $-1 $10393 reversed single T -22.500000000000004 -5 4.9999999999999991 -15 8.8817841970012523e-16 20 F #
+loop $-1 -1 -1 $-1 $-1 $17717 $14692 T -37.500000000000007 -10 19.999999999999993 -29.999999999999993 -4.9999999999999991 35 unknown #
+coedge $-1 -1 -1 $-1 $14693 $16234 $14712 $16267 forward $13170 $-1 #
+coedge $-1 -1 -1 $-1 $17734 $14695 $16194 $14698 reversed $16241 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16240 $14700 T -22.5 -10 20 -15 -4.9999999999999991 35 unknown #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $16269 $16264 $11 $-1 $8848 reversed single T -10 -0.66987298107780902 17.5 -5 8.8817841970012523e-16 22.5 F #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221945 32.5 #
+coedge $-1 -1 -1 $-1 $14702 $17735 $17736 $17737 forward $16241 $-1 #
+face $-1 -1 -1 $-1 $17738 $17739 $11 $-1 $9224 reversed single T -15 -10 -10 -7.5000000000000009 -4.9999999999999991 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $17740 $14703 T -15.000000000000004 -10 -25 -7.5 -4.9999999999999991 -10 unknown #
+coedge $-1 -1 -1 $-1 $17741 $17742 $17743 $17744 reversed $14704 $-1 #
+coedge $-1 -1 -1 $-1 $14705 $17745 $17746 $17747 reversed $13180 $-1 #
+edge $-1 -1 -1 $-1 $16713 -1.5707963267948966 $17748 6.1232339957367648e-17 $15154 $17749 forward @7 unknown T -15 -4.9999999999999991 -10 -10 8.8817841970012523e-16 -5 #
+coedge $-1 -1 -1 $-1 $17750 $14706 $17751 $17752 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $17753 $17754 $14706 $16253 forward $17755 $-1 #
+edge $-1 -1 -1 $-1 $17756 -2.0943951023931953 $16260 -1.5707963267948966 $16252 $17757 forward @7 unknown T -10 -0.66987298107780657 4.9999999999999991 -7.4999999999999991 8.8817841970012523e-16 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $14707 $17750 $14713 $16268 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $17758 $17759 $17760 $16256 forward $17733 $-1 #
+edge $-1 -1 -1 $-1 $16261 10 $17761 15 $16255 $17762 forward @7 unknown T -15 -5 10 -15 -4.9999999999999991 15 #
+coedge $-1 -1 -1 $-1 $17763 $14708 $17759 $17764 reversed $16259 $-1 #
+coedge $-1 -1 -1 $-1 $14708 $17763 $17745 $17765 forward $16259 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14708 $17766 T -20 -5 -1.7763568394002505e-15 -10 1.7763568394002505e-15 10 unknown #
+vertex $-1 -1 -1 $-1 $17765 $17767 #
+vertex $-1 -1 -1 $-1 $17768 $17769 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $16275 $14710 $17750 $17770 forward $16264 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14710 $16243 T -10 -0.66987298107780902 17.5 -5 8.8817841970012523e-16 22.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14713 $14712 $17758 $17771 reversed $14714 $-1 #
+edge $-1 -1 -1 $-1 $17772 1.5707963267948966 $14716 3.1415926535897931 $16239 $17773 forward @7 unknown T -20 -4.9999999999999991 20 -15 0 25 #
+edge $-1 -1 -1 $-1 $17761 -2.3886802389739268e-16 $14715 1.5707963267948966 $14713 $17774 forward @7 unknown T -15 -5 15 -10 8.8817841970012523e-16 20 #
+face $-1 -1 -1 $-1 $17775 $14714 $11 $-1 $8848 reversed single T -20 -5 15 -10 8.8817841970012523e-16 25 F #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 20 #
+edge $-1 -1 -1 $-1 $14716 3.1415926535897931 $17776 4.7123889803846897 $17734 $17773 forward @7 unknown T -20 -10 20 -15 -4.9999999999999991 25 #
+point $-1 -1 -1 $-1 -15 -4.9999999999999991 25 #
+edge $-1 -1 -1 $-1 $14718 -1.5707963267948966 $16225 -4.1650370783741769e-16 $16190 $17777 forward @7 unknown T -30 -9.9999999999999982 30 -25 -5 35 #
+point $-1 -1 -1 $-1 -25 -9.9999999999999982 35 #
+coedge $-1 -1 -1 $-1 $14720 $16263 $17778 $17779 reversed $16264 $-1 #
+vertex $-1 -1 -1 $-1 $17779 $17780 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780657 22.5 #
+coedge $-1 -1 -1 $-1 $14740 $14724 $17781 $17782 reversed $12138 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17783 $17784 $11 $-1 $9956 reversed single T -50 -10 -3.5527136788005009e-15 -40 3.5527136788005009e-15 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $17785 $14726 T -10 -10 2.4999999999999982 -5 -9.330127018922191 7.5000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $17703 $16205 $14728 $16284 reversed $14654 $-1 #
+edge $-1 -1 -1 $-1 $16289 -1.5707963267948966 $16288 1.5707963267948966 $14728 $17786 forward @7 unknown T -45 -9.9999999999999964 19.999999999999996 -40 2.6645352591003757e-15 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $17787 $14729 $17788 $17789 reversed $16287 $-1 #
+coedge $-1 -1 -1 $-1 $14729 $17790 $17791 $17792 reversed $16287 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17793 $17794 T -45 -9.9999999999999982 4.9999999999999973 -37.499999999999993 3.5527136788005009e-15 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $14730 $17795 #
+vertex $-1 -1 -1 $-1 $14730 $17796 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17797 $17798 $14731 $16292 forward $17799 $-1 #
+edge $-1 -1 -1 $-1 $16297 1.0471975511965974 $16293 1.5707963267948966 $16291 $17800 forward @7 unknown T -7.5000000000000018 -10 17.499999999999996 -5 -9.330127018922191 20 #
+vertex $-1 -1 -1 $-1 $16292 $17801 #
+coedge $-1 -1 -1 $-1 $17802 $14734 $17798 $17803 reversed $16296 $-1 #
+coedge $-1 -1 -1 $-1 $14734 $17804 $17805 $16301 reversed $16296 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17802 $17738 T -15 -10 4.9999999999999991 -7.4999999999999991 -4.9999999999999991 20 unknown #
+vertex $-1 -1 -1 $-1 $16292 $17806 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17805 $17807 $14736 $16300 forward $17808 $-1 #
+edge $-1 -1 -1 $-1 $14716 6.1232339957367648e-17 $14737 1.5707963267948966 $16299 $17809 forward @7 unknown T -15 -10 20 -10 -4.9999999999999991 25 #
+edge $-1 -1 -1 $-1 $14737 -1.5707963267948966 $17761 -2.3886802389739268e-16 $17805 $17810 forward @7 unknown T -15 -10 15 -10 -5 20 #
+point $-1 -1 -1 $-1 -10 -10 20 #
+point $-1 -1 -1 $-1 -7.5 -9.3301270189221928 22.5 #
+coedge $-1 -1 -1 $-1 $16893 $16308 $14740 $16305 reversed $13859 $-1 #
+edge $-1 -1 -1 $-1 $17811 -6.1232339957367648e-17 $14741 1.5707963267948966 $14740 $17812 forward @7 unknown T -9.3734986416366059e-33 -5 15 5 0 20 #
+point $-1 -1 -1 $-1 5 0 20 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16304 $17813 $14746 $16309 reversed $13859 $-1 #
+edge $-1 -1 -1 $-1 $14741 1.5707963267948966 $16330 2.0943951023931957 $14746 $17814 forward @7 unknown T 5 -0.66987298107780902 17.5 7.5000000000000018 0 20 #
+coedge $-1 -1 -1 $-1 $17815 $14797 $14748 $16311 forward $16352 $-1 #
+edge $-1 -1 -1 $-1 $15161 -2.0943951023931957 $17816 -1.570796326794897 $16310 $17817 forward @7 unknown T 5 -10 -27.500000000000004 7.5000000000000009 -9.330127018922191 -25 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14752 $14791 $17818 $17819 forward $14792 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14755 $14754 $17820 $17821 reversed $14756 $-1 #
+coedge $-1 -1 -1 $-1 $17818 $17822 $14754 $16317 reversed $16890 $-1 #
+edge $-1 -1 -1 $-1 $14757 -1.570796326794897 $17823 -1.1640334398265743e-16 $14754 $17824 forward @7 unknown T 0 -4.9999999999999991 -25 5.0000000000000018 0 -19.999999999999996 #
+face $-1 -1 -1 $-1 $17825 $14756 $11 $-1 $11805 reversed single T -5 -5 -30 5.0000000000000018 0 -19.999999999999996 F #
+point $-1 -1 -1 $-1 5 0 -25 #
+coedge $-1 -1 -1 $-1 $14761 $14759 $17826 $17827 forward $13216 $-1 #
+coedge $-1 -1 -1 $-1 $17828 $17829 $14759 $16322 reversed $17830 $-1 #
+edge $-1 -1 -1 $-1 $16323 -1.5707963267948966 $17831 -1.0471975511965974 $14759 $17832 forward @7 unknown T -7.5000000000000009 -0.66987298107780902 -27.5 -5 0 -25 #
+vertex $-1 -1 -1 $-1 $16322 $17833 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17834 4.1887902047863923 $12128 4.7123889803846897 $14761 $15150 forward @7 unknown T -7.4999999999999991 -0.66987298107780657 -40 -5 0 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $14763 $15148 $17835 $17836 forward $14764 $-1 #
+coedge $-1 -1 -1 $-1 $17837 $16715 $14763 $16328 reversed $17838 $-1 #
+edge $-1 -1 -1 $-1 $17839 -1.5707963267948966 $13218 0 $14763 $16324 forward @7 unknown T -5 -10 -30 0 -5 -25 #
+coedge $-1 -1 -1 $-1 $15166 $14768 $17813 $17840 forward $10783 $-1 #
+vertex $-1 -1 -1 $-1 $17840 $17841 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $13256 $17799 $11 $-1 $7251 reversed single T -7.5000000000000018 -10 5 0 -4.9999999999999991 20 F #
+coedge $-1 -1 -1 $-1 $14772 $16721 $17797 $17842 reversed $13604 $-1 #
+vertex $-1 -1 -1 $-1 $14773 $17843 #
+coedge $-1 -1 -1 $-1 $14803 $17844 $14775 $14773 forward $14802 $-1 #
+coedge $-1 -1 -1 $-1 $14776 $14775 $17845 $17846 forward $14777 $-1 #
+vertex $-1 -1 -1 $-1 $17847 $17848 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 -10 -25 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $14785 $17849 $14791 $16347 forward $16342 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15392 $16917 T 7.5 -5 -25 15 0 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14787 3.1415926535897931 $14801 4.7123889803846897 $16353 $16343 forward @7 unknown T 10 -10 -25 15 -4.9999999999999991 -20 #
+point $-1 -1 -1 $-1 15 -4.9999999999999991 -20 #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $17850 4.1887902047863914 $13250 4.7123889803846897 $16341 $17851 forward @7 unknown T 7.5000000000000009 -0.66987298107780635 -25 10 0 -22.500000000000004 #
+face $-1 -1 -1 $-1 $17852 $14792 $11 $-1 $11805 reversed single T 4.9999999999999973 -0.66987298107780902 -27.5 10 0 -22.5 F #
+point $-1 -1 -1 $-1 7.5000000000000018 -0.66987298107780746 -27.5 #
+point $-1 -1 -1 $-1 7.5000000000000009 -0.66987298107780624 -37.5 #
+coedge $-1 -1 -1 $-1 $14797 $17815 $17853 $17854 reversed $16352 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16310 $17855 T 4.9999999999999973 -10 -27.500000000000004 10 -9.330127018922191 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $17853 $16903 $14799 $16344 forward $17856 $-1 #
+point $-1 -1 -1 $-1 10 -10 -25 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $15371 $16358 T 50 -10 -29.999999999999996 50 0 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $17857 $14810 $11 $-1 $11805 reversed single T 39.999999999999993 -10 -29.999999999999996 50 0 -19.999999999999996 F #
+point $-1 -1 -1 $-1 22.499999999999993 -0.66987298107780691 -22.500000000000004 #
+loop $-1 -1 -1 $-1 $-1 $15399 $14816 T 7.4999999999999991 -10 -10 15.000000000000004 -4.9999999999999991 5.0000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $16899 $17858 #
+coedge $-1 -1 -1 $-1 $16731 $17859 $15180 $16734 reversed $14821 $-1 #
+coedge $-1 -1 -1 $-1 $17860 $14829 $17861 $17862 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $16396 $17863 $14829 $14861 reversed $17864 $-1 #
+coedge $-1 -1 -1 $-1 $17865 $14830 $14832 $14881 reversed $16366 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16365 $15528 T -15 40 -50 -7.4999999999999982 45 -40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $14832 $14876 $17866 $17867 forward $13339 $-1 #
+coedge $-1 -1 -1 $-1 $17083 $14833 $15653 $17123 reversed $16370 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15618 $17868 T 5.0000000000000027 44.330127018922191 -42.5 10 45 -37.500000000000007 unknown #
+coedge $-1 -1 -1 $-1 $16371 $16371 $14837 $16372 forward $17869 $-1 #
+edge $-1 -1 -1 $-1 $17870 0 $17870 6.2831853071795862 $16371 $17871 forward @7 unknown T 50 35 -45 50 45 -35 #
+face $-1 -1 -1 $-1 $17872 $17873 $11 $-1 $11911 reversed single T -24.999999999999996 44.330127018922184 -42.500000000000007 -20 45 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $17874 $14838 T -9.9999999999999982 35 -42.500000000000014 -5 35.669872981077816 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $17875 $14844 $17876 $17877 forward $11864 $-1 #
+coedge $-1 -1 -1 $-1 $17144 $17878 $14844 $16377 reversed $17879 $-1 #
+edge $-1 -1 -1 $-1 $16378 4.1887902047863914 $17880 4.7123889803846897 $14844 $17881 forward @7 unknown T 37.500000000000007 44.330127018922198 5.0000000000000027 40.000000000000007 45 7.5000000000000098 #
+vertex $-1 -1 -1 $-1 $16377 $17882 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $14848 $17860 $17883 $17884 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $17885 $15253 $14848 $16382 reversed $13728 $-1 #
+edge $-1 -1 -1 $-1 $17886 -2.0943951023931957 $16386 0 $14848 $17887 forward @7 unknown T -37.5 35 -50 -30 40 -50 #
+coedge $-1 -1 -1 $-1 $17888 $14849 $17889 $16776 forward $16385 $-1 #
+coedge $-1 -1 -1 $-1 $14849 $17890 $14851 $16389 reversed $16385 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16384 $17891 T -30 35 -50 -22.5 40 -40 unknown #
+vertex $-1 -1 -1 $-1 $17892 $17893 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $16390 $14851 $17894 $17895 forward $14853 $-1 #
+edge $-1 -1 -1 $-1 $14854 -50 $17896 -42.5 $14851 $17897 forward @7 unknown T -22.5 35.669872981077802 -50 -22.5 35.669872981077809 -42.5 #
+coedge $-1 -1 -1 $-1 $14852 $16388 $17898 $17899 forward $14853 $-1 #
+face $-1 -1 -1 $-1 $17900 $14853 $11 $-1 $14102 reversed single T -22.5 35 -50 -15 40 -40 F #
+point $-1 -1 -1 $-1 -22.5 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $17898 $17901 $14856 $16394 forward $17902 $-1 #
+edge $-1 -1 -1 $-1 $17903 -1.5707963267948966 $16397 -6.1232339957367648e-17 $16393 $17904 forward @7 unknown T -15 35 -45 -9.9999999999999982 40 -40 #
+coedge $-1 -1 -1 $-1 $14857 $17865 $17905 $17906 reversed $16366 $-1 #
+coedge $-1 -1 -1 $-1 $17907 $16364 $14852 $14858 forward $17864 $-1 #
+vertex $-1 -1 -1 $-1 $17908 $17909 #
+straight-curve $-1 -1 -1 $-1 -15 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17874 $14863 $14859 $16400 forward $16374 $-1 #
+edge $-1 -1 -1 $-1 $14865 -2.0943951023931975 $17903 -1.5707963267948966 $16399 $17910 forward @7 unknown T -9.9999999999999982 35 -42.500000000000014 -7.4999999999999893 35.669872981077816 -40 #
+vertex $-1 -1 -1 $-1 $17862 $17911 #
+coedge $-1 -1 -1 $-1 $14863 $17874 $17912 $17913 reversed $16374 $-1 #
+vertex $-1 -1 -1 $-1 $14864 $17914 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 35.669872981077816 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $14870 $14867 $17915 $17916 reversed $14871 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17917 $17918 $11 $-1 $16410 reversed single T -20 40 -15.000000000000002 -9.9999999999999982 45 -5 F #
+loop $-1 -1 -1 $-1 $-1 $17919 $14869 T -9.9999999999999982 44.330127018922184 -12.5 -5 45 -7.4999999999999947 unknown #
+cone-surface $-1 -1 -1 $-1 6.1232339957367653e-16 40 -10 1 0 6.1232339957367648e-17 3.0616169978683826e-16 0 -5 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $17920 $15613 $14870 $16412 reversed $14134 $-1 #
+edge $-1 -1 -1 $-1 $17080 6.1232339957367648e-17 $14872 1.5707963267948966 $14870 $17921 forward @7 unknown T 0 35 -40 5.0000000000000027 40 -35 #
+face $-1 -1 -1 $-1 $17922 $14871 $11 $-1 $11911 reversed single T -5 35 -45 5.0000000000000027 40 -35 F #
+point $-1 -1 -1 $-1 5.0000000000000027 35 -40 #
+coedge $-1 -1 -1 $-1 $17923 $14874 $15614 $17072 forward $16417 $-1 #
+coedge $-1 -1 -1 $-1 $14874 $17923 $14876 $14877 reversed $16417 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14874 $17922 T -5 40 -45 5.0000000000000027 45 -35 unknown #
+vertex $-1 -1 -1 $-1 $14875 $17924 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $17867 $17925 #
+edge $-1 -1 -1 $-1 $14872 1.5707963267948966 $16425 2.0943951023931948 $14879 $17926 forward @7 unknown T 5.0000000000000027 35 -40 7.5000000000000018 35.669872981077809 -37.5 #
+vertex $-1 -1 -1 $-1 $17927 $17928 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17124 $14883 $17070 $17929 forward $15656 $-1 #
+vertex $-1 -1 -1 $-1 $17929 $17930 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17931 $17079 $11 $-1 $10041 reversed single T -7.5000000000000018 40 -40 8.8817841970012523e-16 45 -25 F #
+ellipse-curve $-1 -1 -1 $-1 10 40 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17932 $17933 $11 $-1 $12658 reversed single T -5 35 15 5.0000000000000027 40 25 F #
+loop $-1 -1 -1 $-1 $-1 $17061 $14889 T -5 40 15 5.0000000000000027 45 25 unknown #
+coedge $-1 -1 -1 $-1 $17934 $17935 $17936 $17937 forward $14890 $-1 #
+coedge $-1 -1 -1 $-1 $15640 $14891 $17938 $17939 reversed $11302 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $15716 $17940 #
+straight-curve $-1 -1 -1 $-1 22.5 35.669872981077809 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $17941 $17942 $11 $-1 $14913 reversed single T 10 35 -9.3734986416366073e-33 20.000000000000004 40 10 F #
+loop $-1 -1 -1 $-1 $-1 $17943 $14902 T 9.9999999999999982 40 -9.3734986416366073e-33 20.000000000000004 45 10 unknown #
+coedge $-1 -1 -1 $-1 $17944 $15664 $15534 $16983 forward $14904 $-1 #
+coedge $-1 -1 -1 $-1 $14906 $17128 $17945 $17946 forward $11907 $-1 #
+coedge $-1 -1 -1 $-1 $17947 $15676 $14906 $16441 reversed $14912 $-1 #
+edge $-1 -1 -1 $-1 $17948 1.570796326794897 $16446 3.1415926535897931 $14906 $17949 forward @7 unknown T 25 40 5.0000000000000018 29.999999999999996 45 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $17950 $14907 $17951 $17952 forward $16445 $-1 #
+coedge $-1 -1 -1 $-1 $14907 $17137 $15666 $17134 forward $16445 $-1 #
+coedge $-1 -1 -1 $-1 $16988 $17953 $15667 $14908 forward $17954 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14907 $15685 T 22.499999999999996 35 4.9999999999999991 30 40 20 unknown #
+vertex $-1 -1 -1 $-1 $17952 $17955 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $14909 $15717 $17956 $17957 forward $15718 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17958 $17959 $11 $-1 $14913 reversed single T 35 35 2.5000000000000053 40.000000000000007 35.669872981077809 7.5000000000000062 F #
+loop $-1 -1 -1 $-1 $-1 $17960 $14911 T 24.999999999999996 35 1.7763568394002505e-15 35 40 10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $14931 $14914 $17961 $16484 forward $3011 $-1 #
+coedge $-1 -1 -1 $-1 $17244 $16481 $14914 $16454 reversed $15772 $-1 #
+edge $-1 -1 -1 $-1 $14952 -0.5235987755982987 $14937 1.5707963267948966 $14914 $17962 forward @7 unknown T -30 25 -50 -22.5 30 -50 #
+coedge $-1 -1 -1 $-1 $14915 $17963 $17244 $17964 forward $16456 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14947 $17965 T -22.500000000000004 25 -50 -15 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $14946 $14916 $17966 $16519 reversed $14917 $-1 #
+coedge $-1 -1 -1 $-1 $17967 $17966 $14919 $16459 reversed $17968 $-1 #
+edge $-1 -1 -1 $-1 $14971 -1.5707963267948966 $14973 -1.0471975511965974 $14919 $14955 forward @7 unknown T -7.5000000000000009 29.330127018922191 -42.5 -5 30 -40 #
+face $-1 -1 -1 $-1 $13421 $14921 $11 $-1 $10647 reversed single T 5.0000000000000018 29.330127018922191 -42.5 10 30 -37.500000000000007 F #
+loop $-1 -1 -1 $-1 $14067 $14922 $1558 T 50 20 -45 50 30 -35 hole $1559 T #
+vertex $-1 -1 -1 $-1 $14923 $17969 #
+ellipse-curve $-1 -1 -1 $-1 50 25 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $10003 $17970 $11 $-1 $10647 reversed single T -50 20 -45 -40 30.000000000000004 -35 F #
+loop $-1 -1 -1 $-1 $-1 $17971 $14924 T -25 29.330127018922191 -42.5 -20 30 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $14953 $14950 $17972 $17973 forward $14925 $-1 #
+coedge $-1 -1 -1 $-1 $15748 $14926 $17974 $17975 forward $10600 $-1 #
+coedge $-1 -1 -1 $-1 $17976 $17976 $14926 $16469 reversed $17283 $-1 #
+edge $-1 -1 -1 $-1 $16472 1.570796326794897 $17977 4.7123889803846897 $14926 $17978 forward @7 unknown T 39.999999999999993 20 5.0000000000000027 44.999999999999993 30 10.000000000000004 #
+coedge $-1 -1 -1 $-1 $14927 $17396 $17979 $17980 reversed $16471 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15894 $16550 T 35 29.330127018922187 2.5000000000000049 40.000000000000007 30 7.5000000000000098 unknown #
+vertex $-1 -1 -1 $-1 $17980 $17981 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 29.330127018922195 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $17982 $17983 $14931 $16476 reversed $17984 $-1 #
+edge $-1 -1 -1 $-1 $17985 -0.52359877559829893 $16478 3.6651914291880923 $14931 $17986 forward @7 unknown T -45 20.000000000000004 -50 -37.5 30.000000000000004 -50 #
+coedge $-1 -1 -1 $-1 $16777 $14932 $17983 $17987 forward $12287 $-1 #
+vertex $-1 -1 -1 $-1 $14933 $17988 #
+ellipse-curve $-1 -1 -1 $-1 -35 25 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16482 $14934 $17989 $17990 reversed $14936 $-1 #
+coedge $-1 -1 -1 $-1 $16453 $17991 $16781 $15255 reversed $15772 $-1 #
+coedge $-1 -1 -1 $-1 $14935 $16480 $17992 $17993 reversed $14936 $-1 #
+face $-1 -1 -1 $-1 $11382 $14936 $11 $-1 $14270 reversed single T -30 20 -50 -22.499999999999996 25 -40 F #
+edge $-1 -1 -1 $-1 $14937 0 $17985 2.0943951023931948 $16452 $16479 forward @7 unknown T -37.5 25 -50 -30 30 -50 #
+point $-1 -1 -1 $-1 -30 25 -50 #
+coedge $-1 -1 -1 $-1 $17992 $17994 $14939 $16487 reversed $17995 $-1 #
+edge $-1 -1 -1 $-1 $16488 1.0471975511965956 $17996 1.5707963267948966 $14939 $17997 forward @7 unknown T -22.500000000000007 20 -42.500000000000014 -20 20.669872981077813 -40 #
+vertex $-1 -1 -1 $-1 $16487 $17998 #
+straight-curve $-1 -1 -1 $-1 -22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17999 $14944 $14941 $16491 reversed $16494 $-1 #
+edge $-1 -1 -1 $-1 $17996 -1.5707963267948966 $14948 0 $14941 $18000 forward @7 unknown T -20 20 -45 -15 25 -40 #
+face $-1 -1 -1 $-1 $18001 $18002 $11 $-1 $12796 reversed single T -22.500000000000004 25 -40 -15 30 -25 F #
+coedge $-1 -1 -1 $-1 $14944 $17999 $18003 $18004 forward $16494 $-1 #
+loop $-1 -1 -1 $-1 $-1 $14944 $18005 T -20 20 -45 -9.9999999999999982 25 -35 unknown #
+vertex $-1 -1 -1 $-1 $14945 $18006 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18007 $18008 $14946 $16498 forward $18009 $-1 #
+edge $-1 -1 -1 $-1 $14948 -6.1232339957367648e-17 $18010 1.5707963267948966 $16497 $18011 forward @7 unknown T -15 25 -45 -9.9999999999999982 30 -40 #
+coedge $-1 -1 -1 $-1 $17963 $14947 $18008 $16500 forward $16456 $-1 #
+edge $-1 -1 -1 $-1 $14948 0 $18012 1.5707963267948966 $16499 $18000 forward @7 unknown T -20 25 -45 -15 30 -40 #
+point $-1 -1 -1 $-1 -15 25 -45 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 29.330127018922195 -50 #
+coedge $-1 -1 -1 $-1 $18013 $16507 $14953 $16505 forward $17325 $-1 #
+edge $-1 -1 -1 $-1 $14954 1.5707963267948966 $18014 2.0943951023931948 $16504 $18015 forward @7 unknown T -7.5 20 -40 -5 20.669872981077805 -37.5 #
+point $-1 -1 -1 $-1 -5 20 -40 #
+coedge $-1 -1 -1 $-1 $16504 $15828 $14957 $16508 forward $17325 $-1 #
+edge $-1 -1 -1 $-1 $15830 3.1415926535897931 $14954 4.7123889803846897 $16507 $18016 forward @7 unknown T -5 20 -40 0 25 -35 #
+face $-1 -1 -1 $-1 $18017 $18018 $11 $-1 $14961 reversed single T -20 20 -15.000000000000002 -9.9999999999999982 25 -5 F #
+loop $-1 -1 -1 $-1 $-1 $18019 $14959 T -20 25 -15.000000000000002 -9.9999999999999982 30 -5 unknown #
+coedge $-1 -1 -1 $-1 $18020 $18021 $18022 $18023 forward $14960 $-1 #
+coedge $-1 -1 -1 $-1 $18024 $14962 $12829 $14318 forward $12828 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16460 $14968 $11 $-1 $10647 reversed single T -5 25 -45 5.0000000000000018 30 -35 F #
+coedge $-1 -1 -1 $-1 $14967 $14966 $15827 $17323 reversed $14968 $-1 #
+point $-1 -1 -1 $-1 5.0000000000000018 30 -40 #
+point $-1 -1 -1 $-1 -5 30 -40 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18010 1.5707963267948966 $14973 2.0943951023931953 $17966 $18025 forward @7 unknown T -9.9999999999999982 29.330127018922191 -42.5 -7.4999999999999991 30 -40 #
+point $-1 -1 -1 $-1 -7.5 29.330127018922191 -42.5 #
+edge $-1 -1 -1 $-1 $14976 -37.500000000000007 $18026 -27.499999999999996 $14975 $18027 forward @7 unknown T 7.5 20.669872981077805 -37.500000000000007 7.5000000000000009 20.669872981077813 -27.499999999999996 #
+point $-1 -1 -1 $-1 7.5 20.669872981077813 -37.500000000000007 #
+face $-1 -1 -1 $-1 $18028 $18029 $11 $-1 $13449 reversed single T -5 25 -9.3734986416366059e-33 5.0000000000000018 30 10 F #
+face $-1 -1 -1 $-1 $17331 $17347 $11 $-1 $11403 reversed single T 5.0000000000000018 20 17.5 10 20.669872981077813 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $18030 $14980 T -5 20 15 5.0000000000000018 25 25 unknown #
+coedge $-1 -1 -1 $-1 $17329 $14982 $15842 $17334 forward $13426 $-1 #
+coedge $-1 -1 -1 $-1 $14982 $18031 $18032 $18033 forward $13426 $-1 #
+coedge $-1 -1 -1 $-1 $18034 $17378 $18035 $16529 reversed $17377 $-1 #
+edge $-1 -1 -1 $-1 $18036 10 $17336 15 $14982 $18037 forward @7 unknown T 14.999999999999996 25 10 15 25 15 #
+coedge $-1 -1 -1 $-1 $15875 $18038 $14983 $16531 forward $17373 $-1 #
+edge $-1 -1 -1 $-1 $17353 -1.5707963267948961 $12858 -6.1232339957367648e-17 $16530 $18039 forward @7 unknown T 15 20 -30 20 25 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 20.669872981077805 -27.500000000000004 #
+face $-1 -1 -1 $-1 $18040 $18041 $11 $-1 $13449 reversed single T 20 20 2.4999999999999969 25 20.669872981077816 7.5000000000000027 F #
+loop $-1 -1 -1 $-1 $-1 $18042 $14987 T 10 20 -9.3734986416366073e-33 20 25 10 unknown #
+coedge $-1 -1 -1 $-1 $18032 $18043 $15850 $17344 forward $14988 $-1 #
+coedge $-1 -1 -1 $-1 $15882 $14989 $18044 $17402 forward $13440 $-1 #
+coedge $-1 -1 -1 $-1 $18045 $18046 $14990 $16538 reversed $18047 $-1 #
+edge $-1 -1 -1 $-1 $18048 4.1887902047863932 $16540 4.7123889803846897 $14990 $18049 forward @7 unknown T 22.500000000000007 29.330127018922198 5.0000000000000018 25 30 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $15896 $14991 $18050 $18051 reversed $13448 $-1 #
+vertex $-1 -1 -1 $-1 $18052 $18053 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17381 $14993 $18054 $18055 forward $14996 $-1 #
+coedge $-1 -1 -1 $-1 $16552 $18056 $14993 $16544 reversed $15002 $-1 #
+edge $-1 -1 -1 $-1 $14997 3.1415926535897931 $18057 4.7123889803846897 $14993 $16541 forward @7 unknown T 24.999999999999996 20 5.0000000000000018 29.999999999999996 25 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $14995 $18058 $16552 $18059 reversed $16546 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18058 $17382 T 29.999999999999996 19.999999999999996 5.0000000000000018 37.500000000000014 25 20.000000000000004 unknown #
+point $-1 -1 -1 $-1 29.999999999999996 25 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $18060 $15904 $14999 $16549 reversed $15889 $-1 #
+edge $-1 -1 -1 $-1 $14405 -6.4931039580273265e-16 $14390 1.5707963267948966 $14999 $18061 forward @7 unknown T 29.999999999999996 19.999999999999996 -24.999999999999996 35 25 -19.999999999999996 #
+face $-1 -1 -1 $-1 $12902 $16471 $11 $-1 $13449 reversed single T 35 29.330127018922187 2.5000000000000049 40.000000000000007 30 7.5000000000000098 F #
+loop $-1 -1 -1 $-1 $-1 $18062 $15001 T 35 19.999999999999996 2.5000000000000071 40.000000000000007 20.669872981077813 7.5000000000000107 unknown #
+coedge $-1 -1 -1 $-1 $18063 $16543 $16545 $18059 forward $15002 $-1 #
+coedge $-1 -1 -1 $-1 $15260 $18064 $15003 $15035 reversed $16792 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $15006 $15050 $18065 $18066 forward $15007 $-1 #
+edge $-1 -1 -1 $-1 $18067 42.5 $13488 50 $15006 $18068 forward @7 unknown T -22.500000000000004 14.330127018922193 -50 -22.5 14.330127018922195 -42.5 #
+face $-1 -1 -1 $-1 $18069 $15007 $11 $-1 $11541 reversed single T -22.500000000000004 10 -50 -15 15 -40 F #
+coedge $-1 -1 -1 $-1 $15009 $18070 $15008 $15070 forward $16560 $-1 #
+coedge $-1 -1 -1 $-1 $18070 $15009 $16072 $17591 reversed $16560 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18070 $18071 T -10 14.330127018922191 -42.5 -5 15 -37.5 unknown #
+point $-1 -1 -1 $-1 50 10 -45 #
+loop $-1 -1 -1 $-1 $18072 $18073 $15015 T -45 5.0000000000000018 -45 -40 15.000000000000002 -35 unknown #
+coedge $-1 -1 -1 $-1 $18065 $18074 $17492 $18075 forward $15016 $-1 #
+coedge $-1 -1 -1 $-1 $16595 $18076 $15017 $16565 reversed $17445 $-1 #
+edge $-1 -1 -1 $-1 $15046 1.5707963267948966 $16606 2.0943951023931957 $15017 $18077 forward @7 unknown T -10 5 -40 -7.4999999999999991 5.6698729810778081 -37.5 #
+coedge $-1 -1 -1 $-1 $18078 $16654 $15018 $16567 reversed $15102 $-1 #
+edge $-1 -1 -1 $-1 $16569 1.570796326794897 $17467 2.0943951023931948 $15018 $15024 forward @7 unknown T 37.500000000000007 4.9999999999999991 5.0000000000000027 40.000000000000007 5.6698729810778072 7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $15019 $15019 $18079 $18080 reversed $16033 $-1 #
+vertex $-1 -1 -1 $-1 $18081 $18082 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17643 $18079 $15021 $16572 forward $17679 $-1 #
+edge $-1 -1 -1 $-1 $15023 -1.570796326794897 $18083 -1.0471975511965987 $16571 $18084 forward @7 unknown T 37.5 14.330127018922195 2.5000000000000053 40 15 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 15 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $18085 $15026 $18064 $18086 reversed $16576 $-1 #
+coedge $-1 -1 -1 $-1 $15026 $18087 $15028 $16579 reversed $16576 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16574 $15974 T -45 5.0000000000000018 -50 -37.5 15.000000000000002 -40 unknown #
+vertex $-1 -1 -1 $-1 $18086 $18088 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $15029 -50 $18089 -42.500000000000007 $15028 $18090 forward @7 unknown T -37.5 5.6698729810778064 -50 -37.5 5.6698729810778072 -42.500000000000007 #
+point $-1 -1 -1 $-1 -37.5 5.6698729810778064 -50 #
+coedge $-1 -1 -1 $-1 $15257 $18091 $15031 $16582 forward $16786 $-1 #
+edge $-1 -1 -1 $-1 $18092 -1.5707963267948966 $15259 -4.1650370783741769e-16 $16581 $18093 forward @7 unknown T -30 5.0000000000000018 -45 -25 10 -40 #
+coedge $-1 -1 -1 $-1 $15032 $17492 $18094 $18095 reversed $14473 $-1 #
+coedge $-1 -1 -1 $-1 $18096 $15037 $15033 $16585 forward $16587 $-1 #
+edge $-1 -1 -1 $-1 $15039 -2.0943951023931953 $18092 -1.5707963267948966 $16584 $18097 forward @7 unknown T -25 5.0000000000000018 -42.5 -22.5 5.6698729810778099 -40 #
+coedge $-1 -1 -1 $-1 $15037 $18096 $18098 $18099 reversed $16587 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16584 $16593 T -25 5 -42.5 -20 5.6698729810778108 -37.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $15038 $18100 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778081 -42.5 #
+coedge $-1 -1 -1 $-1 $15044 $15041 $18101 $18102 reversed $15045 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18103 $16587 $11 $-1 $9512 reversed single T -25 5 -42.5 -20 5.6698729810778108 -37.499999999999993 F #
+loop $-1 -1 -1 $-1 $-1 $18104 $15043 T -22.500000000000004 10 -40 -15 15 -25 unknown #
+coedge $-1 -1 -1 $-1 $18105 $16564 $15044 $16596 reversed $17445 $-1 #
+edge $-1 -1 -1 $-1 $18106 6.1232339957367648e-17 $15046 1.5707963267948966 $15044 $18107 forward @7 unknown T -15 5 -40 -10 10 -35 #
+face $-1 -1 -1 $-1 $18108 $15045 $11 $-1 $9512 reversed single T -20 5 -45 -10 10 -35 F #
+point $-1 -1 -1 $-1 -10 5 -40 #
+coedge $-1 -1 -1 $-1 $18109 $15048 $18110 $18111 forward $16601 $-1 #
+coedge $-1 -1 -1 $-1 $15048 $18109 $15050 $15051 reversed $16601 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15048 $18112 T -20 10 -45 -10 15 -35 unknown #
+vertex $-1 -1 -1 $-1 $15049 $18113 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $18066 $18114 #
+coedge $-1 -1 -1 $-1 $17592 $15055 $18076 $18115 forward $16075 $-1 #
+vertex $-1 -1 -1 $-1 $16565 $18116 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18117 $16075 $11 $-1 $8113 reversed single T -7.5000000000000009 5 -40 8.8817841970012523e-16 10 -25 F #
+loop $-1 -1 -1 $-1 $-1 $18118 $15060 T -20 5 -15.000000000000002 -10 10 -5 unknown #
+coedge $-1 -1 -1 $-1 $18119 $18120 $16011 $17509 forward $15061 $-1 #
+coedge $-1 -1 -1 $-1 $18121 $15062 $18122 $18123 forward $13496 $-1 #
+coedge $-1 -1 -1 $-1 $15062 $18121 $18124 $18125 reversed $13496 $-1 #
+coedge $-1 -1 -1 $-1 $18126 $16011 $15062 $16615 reversed $14492 $-1 #
+edge $-1 -1 -1 $-1 $18127 -2.0943951023931957 $18128 -1.5707963267948966 $15062 $18129 forward @7 unknown T -10 14.330127018922191 -10 -7.4999999999999982 15 -7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $16059 $15063 $18130 $18131 reversed $11573 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $16121 $18132 #
+straight-curve $-1 -1 -1 $-1 7.5 5.6698729810778064 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $18133 $18134 $11 $-1 $12076 reversed single T -5 4.9999999999999991 -8.8817841970012523e-16 5.0000000000000009 10 10 F #
+loop $-1 -1 -1 $-1 $-1 $18135 $15074 T -5 10 -8.8817841970012523e-16 5.0000000000000009 15 10 unknown #
+coedge $-1 -1 -1 $-1 $18136 $16083 $15946 $17447 forward $15076 $-1 #
+coedge $-1 -1 -1 $-1 $15078 $17595 $18137 $18138 forward $12053 $-1 #
+coedge $-1 -1 -1 $-1 $18139 $15086 $15078 $16625 reversed $13524 $-1 #
+edge $-1 -1 -1 $-1 $18140 1.5707963267948966 $16628 3.1415926535897931 $15078 $18141 forward @7 unknown T 9.9999999999999982 10 5.0000000000000009 14.999999999999996 15 10 #
+coedge $-1 -1 -1 $-1 $18142 $15079 $18143 $18144 forward $16127 $-1 #
+coedge $-1 -1 -1 $-1 $16636 $18145 $16085 $15080 forward $17663 $-1 #
+vertex $-1 -1 -1 $-1 $18144 $18146 #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15081 $16122 $18147 $18148 forward $16123 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14567 $16639 $11 $-1 $12076 reversed single T 20 14.330127018922189 2.5000000000000009 25 15 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $18149 $15084 T 20 4.9999999999999973 2.5000000000000044 25 5.6698729810778064 7.5000000000000027 unknown #
+coedge $-1 -1 -1 $-1 $18150 $18143 $18145 $18151 forward $15085 $-1 #
+coedge $-1 -1 -1 $-1 $15086 $18139 $18152 $18153 forward $13524 $-1 #
+coedge $-1 -1 -1 $-1 $16150 $16627 $15087 $16152 reversed $17663 $-1 #
+coedge $-1 -1 -1 $-1 $18154 $15088 $16093 $17610 forward $16639 $-1 #
+coedge $-1 -1 -1 $-1 $15088 $18154 $18155 $16644 reversed $16639 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16637 $16632 T 20 14.330127018922189 2.5000000000000009 25 15 7.5000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $15089 $18156 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18155 $16138 $15090 $16643 forward $17652 $-1 #
+edge $-1 -1 -1 $-1 $17653 0 $15091 1.5707963267948961 $16642 $18157 forward @7 unknown T 25 10 1.7763568394002505e-15 29.999999999999996 15 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $15091 -1.570796326794897 $18158 -1.0471975511965974 $18155 $18159 forward @7 unknown T 22.499999999999996 14.330127018922189 2.5000000000000009 25 15 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 15 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $18160 $18149 $15093 $16647 reversed $16633 $-1 #
+edge $-1 -1 -1 $-1 $16649 1.5707963267948961 $18161 2.0943951023931939 $15093 $16641 forward @7 unknown T 22.500000000000004 5 4.9999999999999991 25 5.6698729810778064 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $15094 $16655 $18162 $18163 reversed $13538 $-1 #
+vertex $-1 -1 -1 $-1 $18164 $18165 #
+coedge $-1 -1 -1 $-1 $15096 $15948 $16654 $18166 reversed $15097 $-1 #
+edge $-1 -1 -1 $-1 $13533 -2.9403902792268224e-16 $18167 1.5707963267948966 $15103 $18168 forward @7 unknown T 29.999999999999996 4.9999999999999973 5.0000000000000018 35 10 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $18169 $15099 $13098 $14625 forward $14590 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16566 $18170 $16650 $18166 forward $15102 $-1 #
+coedge $-1 -1 -1 $-1 $16648 $15103 $18171 $18172 forward $13538 $-1 #
+coedge $-1 -1 -1 $-1 $15104 $16801 $15117 $16671 forward $15271 $-1 #
+coedge $-1 -1 -1 $-1 $18173 $15114 $15106 $16658 reversed $13552 $-1 #
+edge $-1 -1 -1 $-1 $15147 -1.5707963267948966 $16659 -1.0471975511965974 $15106 $15132 forward @7 unknown T -22.500000000000004 -0.66987298107780902 -42.5 -20 0 -40 #
+vertex $-1 -1 -1 $-1 $16667 $18174 #
+straight-curve $-1 -1 -1 $-1 -22.5 -0.66987298107780546 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $18175 $18176 $11 $-1 $11805 reversed single T -20 -10 -30 -9.9999999999999982 -4.9999999999999991 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $15109 $15110 $18177 $18178 forward $15111 $-1 #
+face $-1 -1 -1 $-1 $16697 $15111 $11 $-1 $8499 reversed single T -10 -0.66987298107780902 -42.5 -5 8.8817841970012523e-16 -37.500000000000007 F #
+loop $-1 -1 -1 $-1 $-1 $18179 $13551 T -50 -10 -45 -50 0 -35 unknown #
+coedge $-1 -1 -1 $-1 $18180 $18180 $18181 $18182 forward $15113 $-1 #
+coedge $-1 -1 -1 $-1 $15114 $18173 $18183 $18184 forward $13552 $-1 #
+edge $-1 -1 -1 $-1 $18185 1.5707963267948966 $16659 2.0943951023931948 $15114 $18186 forward @7 unknown T -25 -0.66987298107780746 -42.5 -22.500000000000004 1.7763568394002505e-15 -40 #
+coedge $-1 -1 -1 $-1 $15115 $18187 $15148 $16700 reversed $16195 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18181 $15117 $18188 $18189 reversed $15119 $-1 #
+edge $-1 -1 -1 $-1 $18190 42.5 $15120 50 $16656 $18191 forward @7 unknown T -37.5 -0.66987298107780635 -50 -37.5 -0.66987298107780457 -42.5 #
+coedge $-1 -1 -1 $-1 $15118 $18181 $16793 $18192 reversed $15119 $-1 #
+point $-1 -1 -1 $-1 -37.5 -0.66987298107780457 -50 #
+vertex $-1 -1 -1 $-1 $15263 $18193 #
+straight-curve $-1 -1 -1 $-1 -37.5 -9.330127018922191 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $15124 $15264 $18194 $18195 forward $15265 $-1 #
+vertex $-1 -1 -1 $-1 $15125 $18196 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18197 $16802 $15126 $16680 forward $18198 $-1 #
+edge $-1 -1 -1 $-1 $13736 -4.1650370783741769e-16 $18185 1.5707963267948966 $16679 $18199 forward @7 unknown T -30 -5 -45 -25 1.7763568394002505e-15 -40 #
+coedge $-1 -1 -1 $-1 $15129 $15127 $17723 $18200 forward $15130 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18201 $16686 $15129 $16684 forward $18202 $-1 #
+edge $-1 -1 -1 $-1 $15131 1.5707963267948966 $18203 2.0943951023931957 $16683 $18204 forward @7 unknown T -22.5 -10 -40 -20 -9.330127018922191 -37.499999999999993 #
+point $-1 -1 -1 $-1 -20 -10 -40 #
+coedge $-1 -1 -1 $-1 $16683 $18205 $15134 $16687 forward $18202 $-1 #
+edge $-1 -1 -1 $-1 $16691 3.1415926535897931 $15131 4.7123889803846897 $16686 $18206 forward @7 unknown T -20 -10 -40 -15 -4.9999999999999991 -35 #
+face $-1 -1 -1 $-1 $18207 $15265 $11 $-1 $8499 reversed single T -35 -10 -45 -25 -4.9999999999999991 -35 F #
+coedge $-1 -1 -1 $-1 $18208 $18209 $18205 $17697 forward $15137 $-1 #
+coedge $-1 -1 -1 $-1 $18210 $15138 $16196 $17697 forward $16195 $-1 #
+vertex $-1 -1 -1 $-1 $16687 $18211 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $9098 $18202 $11 $-1 $10393 reversed single T -22.5 -10 -40 -15 -4.9999999999999991 -25 F #
+coedge $-1 -1 -1 $-1 $15143 $15142 $18209 $18212 reversed $15144 $-1 #
+coedge $-1 -1 -1 $-1 $18177 $16196 $15142 $16696 reversed $14645 $-1 #
+edge $-1 -1 -1 $-1 $15145 -1.5707963267948966 $16691 6.1232339957367648e-17 $15142 $18213 forward @7 unknown T -15 -4.9999999999999991 -40 -10 8.8817841970012523e-16 -35 #
+face $-1 -1 -1 $-1 $15140 $15144 $11 $-1 $8499 reversed single T -20 -5 -45 -10 8.8817841970012523e-16 -35 F #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 -40 #
+point $-1 -1 -1 $-1 -20 0 -40 #
+edge $-1 -1 -1 $-1 $15149 -37.499999999999993 $18214 -27.500000000000004 $15148 $18215 forward @7 unknown T -7.5000000000000018 -9.3301270189221945 -37.499999999999993 -7.5 -9.3301270189221928 -27.500000000000004 #
+point $-1 -1 -1 $-1 -7.5 -9.3301270189221928 -37.499999999999993 #
+face $-1 -1 -1 $-1 $15108 $18216 $11 $-1 $10393 reversed single T -22.500000000000004 -10 -25 -15 -4.9999999999999991 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $18217 $18218 $18219 $18220 forward $15153 $-1 #
+coedge $-1 -1 -1 $-1 $18221 $15154 $18222 $18223 reversed $13589 $-1 #
+coedge $-1 -1 -1 $-1 $15154 $18221 $18224 $18225 forward $13589 $-1 #
+coedge $-1 -1 -1 $-1 $15156 $15155 $18226 $18227 reversed $12118 $-1 #
+coedge $-1 -1 -1 $-1 $18224 $18228 $15155 $16708 reversed $14704 $-1 #
+edge $-1 -1 -1 $-1 $16713 1.5707963267948966 $18229 2.0943951023931957 $15155 $18230 forward @7 unknown T -10 -0.66987298107780813 -12.5 -7.4999999999999991 8.8817841970012523e-16 -10 #
+coedge $-1 -1 -1 $-1 $18231 $18232 $15156 $16710 forward $18233 $-1 #
+edge $-1 -1 -1 $-1 $16712 4.1887902047863914 $18234 4.7123889803846897 $16709 $18235 forward @7 unknown T -7.4999999999999982 -0.66987298107780546 -10 -5 8.8817841970012523e-16 -7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $18236 $15157 $18232 $18237 reversed $13180 $-1 #
+vertex $-1 -1 -1 $-1 $16710 $18238 #
+vertex $-1 -1 -1 $-1 $18225 $18239 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16327 $18240 $15159 $16716 forward $17838 $-1 #
+edge $-1 -1 -1 $-1 $17816 -1.5707963267948961 $13218 -6.1232339957367648e-17 $16715 $18241 forward @7 unknown T -9.3734986416366059e-33 -10 -30 5 -5 -25 #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 -27.500000000000004 #
+face $-1 -1 -1 $-1 $18242 $18243 $11 $-1 $9956 reversed single T 5 -10 2.5000000000000009 10.000000000000002 -9.330127018922191 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $18244 $15163 T -5 -10 -9.3734986416366059e-33 5 -4.9999999999999991 10 unknown #
+coedge $-1 -1 -1 $-1 $18245 $18246 $15384 $16894 forward $15164 $-1 #
+coedge $-1 -1 -1 $-1 $16333 $15165 $18247 $17847 forward $13604 $-1 #
+coedge $-1 -1 -1 $-1 $18248 $18249 $15166 $16723 reversed $18250 $-1 #
+edge $-1 -1 -1 $-1 $18251 4.1887902047863905 $15413 4.7123889803846897 $15166 $18252 forward @7 unknown T 7.4999999999999956 -0.66987298107780724 5.0000000000000009 10 8.8817841970012523e-16 7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $17844 $15167 $18253 $18254 forward $14802 $-1 #
+coedge $-1 -1 -1 $-1 $15171 $18255 $15167 $13885 reversed $13612 $-1 #
+coedge $-1 -1 -1 $-1 $15168 $15512 $15171 $16729 reversed $15385 $-1 #
+edge $-1 -1 -1 $-1 $14787 -2.9403902792268254e-16 $14782 1.570796326794897 $15169 $18256 forward @7 unknown T 15 -10 -25 20.000000000000004 -4.9999999999999991 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $18255 $15171 $18257 $18258 forward $13612 $-1 #
+edge $-1 -1 -1 $-1 $12417 -2.9403902792268234e-16 $16966 1.5707963267948966 $15171 $18259 forward @7 unknown T 14.999999999999996 -10.000000000000002 5.0000000000000009 20 -4.9999999999999991 10 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 -42.5 #
+coedge $-1 -1 -1 $-1 $18260 $16362 $15177 $16732 reversed $14821 $-1 #
+edge $-1 -1 -1 $-1 $15431 6.1232339957367648e-17 $15178 1.5707963267948966 $15177 $18261 forward @7 unknown T -30 -25 -40 -25 -20 -35 #
+point $-1 -1 -1 $-1 -25 -25 -40 #
+edge $-1 -1 -1 $-1 $15178 1.5707963267948966 $16736 2.0943951023931948 $15180 $18262 forward @7 unknown T -25 -25 -40 -22.500000000000004 -24.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $15244 $15182 $17859 $18263 forward $13715 $-1 #
+vertex $-1 -1 -1 $-1 $16734 $18264 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18265 $16809 $15191 $13810 reversed $16876 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 4.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15199 $15203 $16925 $18266 reversed $15204 $-1 #
+vertex $-1 -1 -1 $-1 $18266 $18267 #
+ellipse-curve $-1 -1 -1 $-1 -40 -19.999999999999996 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $15202 $18268 #
+face $-1 -1 -1 $-1 $18269 $15204 $11 $-1 $4210 reversed single T -40 -15.669872981077809 -42.5 -35 -14.999999999999996 -37.5 F #
+face $-1 -1 -1 $-1 $18270 $16224 $11 $-1 $11706 reversed single T -30 -5 20 -22.5 1.7763568394002505e-15 35 F #
+coedge $-1 -1 -1 $-1 $16753 $15210 $16750 $18271 reversed $15306 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25 -25 20 #
+coedge $-1 -1 -1 $-1 $15216 $15222 $16747 $18271 forward $15223 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15219 $16833 $18265 $18272 reversed $15306 $-1 #
+coedge $-1 -1 -1 $-1 $16833 $16747 $15221 $16754 reversed $15306 $-1 #
+edge $-1 -1 -1 $-1 $18273 7.5 $13694 17.500000000000004 $15221 $18274 forward @7 unknown T -22.500000000000004 -24.330127018922195 7.5 -22.5 -24.330127018922195 17.500000000000004 #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077809 17.499999999999996 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -15.669872981077807 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 -37.5 #
+face $-1 -1 -1 $-1 $15438 $15233 $11 $-1 $3328 reversed single T -10.000000000000004 -15.669872981077809 -27.500000000000004 -5 -15 -22.499999999999996 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 -27.500000000000004 #
+edge $-1 -1 -1 $-1 $15241 1.5707963267948966 $13942 3.1415926535897931 $15455 $16940 forward @7 unknown T -20 -20 -25 -15 -15 -20 #
+coedge $-1 -1 -1 $-1 $15313 $15239 $16939 $18275 reversed $16762 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15313 $18276 T -25.000000000000004 -15.669872981077809 -27.500000000000004 -20 -15 -22.499999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -20 -15 -25 #
+coedge $-1 -1 -1 $-1 $16843 $16842 $15244 $16766 reversed $16844 $-1 #
+edge $-1 -1 -1 $-1 $18277 1.047197551196597 $16767 1.5707963267948966 $15244 $16763 forward @7 unknown T -22.500000000000004 -25 -27.500000000000004 -20 -24.330127018922191 -25 #
+vertex $-1 -1 -1 $-1 $16766 $18278 #
+loop $-1 -1 -1 $-1 $18279 $18280 $3147 T -50 -10 -30.000000000000004 -50 0 -20.000000000000004 hole $3148 T #
+coedge $-1 -1 -1 $-1 $16769 $16769 $18281 $18282 forward $15247 $-1 #
+coedge $-1 -1 -1 $-1 $16770 $16770 $15248 $16771 reversed $18283 $-1 #
+edge $-1 -1 -1 $-1 $18284 0 $18284 6.2831853071795862 $15248 $18285 forward @7 unknown T -50 -10 -3.0616169978683823e-15 -50 0 9.9999999999999964 #
+vertex $-1 -1 -1 $-1 $15249 $18286 #
+ellipse-curve $-1 -1 -1 $-1 -50 -5 19.999999999999996 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -5 29.999999999999996 #
+coedge $-1 -1 -1 $-1 $15253 $18287 $18288 $18289 forward $13728 $-1 #
+edge $-1 -1 -1 $-1 $16386 -50 $18290 -45 $18291 $18292 forward @7 unknown T -30 40 -50 -30 40 -45 #
+coedge $-1 -1 -1 $-1 $15254 $16477 $18293 $18294 forward $12287 $-1 #
+coedge $-1 -1 -1 $-1 $18295 $17989 $15254 $16779 reversed $18296 $-1 #
+edge $-1 -1 -1 $-1 $18297 -1.5707963267948966 $16780 0 $15254 $18298 forward @7 unknown T -35 20 -45 -30 25 -40 #
+vertex $-1 -1 -1 $-1 $18299 $18300 #
+coedge $-1 -1 -1 $-1 $18301 $17961 $13730 $15255 forward $18302 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18303 $18304 $15256 $16784 reversed $18305 $-1 #
+edge $-1 -1 -1 $-1 $18089 1.047197551196597 $16787 1.5707963267948966 $15256 $18306 forward @7 unknown T -37.5 5 -42.500000000000007 -35 5.6698729810778099 -40 #
+coedge $-1 -1 -1 $-1 $18091 $15257 $18307 $18308 reversed $16786 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18091 $18103 T -35 5 -45 -25 10 -35 unknown #
+vertex $-1 -1 -1 $-1 $16784 $18309 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15259 0 $18310 1.5707963267948966 $16791 $16788 forward @7 unknown T -35 10 -45 -30 15 -40 #
+point $-1 -1 -1 $-1 -30 10 -45 #
+coedge $-1 -1 -1 $-1 $18311 $15260 $18312 $16789 forward $16792 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15260 $18313 T -37.5 10 -50 -30 15 -40 unknown #
+coedge $-1 -1 -1 $-1 $18314 $15262 $16672 $18192 forward $16795 $-1 #
+coedge $-1 -1 -1 $-1 $15262 $18314 $18315 $18316 reversed $16795 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16793 $18317 T -40 -10 -42.500000000000007 -35 -9.3301270189221874 -37.499999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18315 $18318 $15264 $16798 forward $18319 $-1 #
+edge $-1 -1 -1 $-1 $18320 3.1415926535897931 $15266 4.7123889803846897 $16797 $18321 forward @7 unknown T -35 -10 -40 -30 -4.9999999999999991 -35 #
+point $-1 -1 -1 $-1 -35 -10 -40 #
+vertex $-1 -1 -1 $-1 $18322 $18323 #
+coedge $-1 -1 -1 $-1 $16656 $15270 $18324 $18322 forward $15271 $-1 #
+coedge $-1 -1 -1 $-1 $16679 $18325 $15270 $15268 reversed $18198 $-1 #
+face $-1 -1 -1 $-1 $18326 $15271 $11 $-1 $9738 reversed single T -37.5 -5 -50 -30 0 -40 F #
+coedge $-1 -1 -1 $-1 $15299 $15275 $15272 $16805 forward $15300 $-1 #
+edge $-1 -1 -1 $-1 $13743 1.5707963267948966 $16743 2.0943951023931975 $16804 $18327 forward @7 unknown T -37.500000000000007 -25 -40 -35 -24.330127018922187 -37.499999999999986 #
+coedge $-1 -1 -1 $-1 $15275 $15298 $18260 $15429 reversed $15300 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -35 -15 -40 #
+coedge $-1 -1 -1 $-1 $16738 $18328 $15279 $16810 reversed $16876 $-1 #
+edge $-1 -1 -1 $-1 $15355 -1.5707963267948966 $15333 0 $15279 $16873 forward @7 unknown T -35 -25 -1.7763568394002505e-15 -30 -20 4.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 4.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18329 $15290 $15281 $15340 reversed $16820 $-1 #
+coedge $-1 -1 -1 $-1 $18330 $16834 $12324 $13788 forward $13777 $-1 #
+face $-1 -1 -1 $-1 $15338 $15457 $11 $-1 $9321 reversed single T -22.5 -20 -25 -15 -15 -10.000000000000002 F #
+point $-1 -1 -1 $-1 -35 -25 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $15418 $16931 $15287 $16817 forward $16926 $-1 #
+edge $-1 -1 -1 $-1 $16818 -1.5707963267948957 $15420 -1.0471975511965979 $16816 $15301 forward @7 unknown T -37.499999999999993 -15.669872981077809 -27.500000000000004 -35 -15 -25.000000000000004 #
+vertex $-1 -1 -1 $-1 $16817 $18331 #
+coedge $-1 -1 -1 $-1 $15290 $18329 $16827 $18332 forward $16820 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18329 $16869 T -35 -25 -15.000000000000004 -25 -20 -5.0000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $16866 $18333 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -10.000000000000002 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18334 $15293 $15308 $16838 forward $16825 $-1 #
+coedge $-1 -1 -1 $-1 $15293 $18334 $15298 $16830 reversed $16825 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16823 $16829 T -35 -25 -30.000000000000004 -24.999999999999996 -20 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -20 -25.000000000000004 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16839 $15295 $16819 $18332 reversed $12321 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 -20 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $18335 $16825 $11 $-1 $3328 reversed single T -35 -25 -30.000000000000004 -24.999999999999996 -20 -19.999999999999996 F #
+edge $-1 -1 -1 $-1 $13770 -1.5707963267948957 $16933 0 $15298 $18336 forward @7 unknown T -35 -25 -30.000000000000004 -30.000000000000007 -20 -25.000000000000004 #
+face $-1 -1 -1 $-1 $10817 $15300 $11 $-1 $8642 reversed single T -37.500000000000007 -25 -40 -30 -20 -25.000000000000004 F #
+straight-curve $-1 -1 -1 $-1 -37.5 -24.330127018922195 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16752 $16753 $18337 $18338 reversed $15306 $-1 #
+coedge $-1 -1 -1 $-1 $16813 $15307 $18329 $18339 reversed $13777 $-1 #
+coedge $-1 -1 -1 $-1 $15307 $18340 $15466 $16943 reversed $13777 $-1 #
+coedge $-1 -1 -1 $-1 $15467 $18341 $15307 $16837 forward $16944 $-1 #
+edge $-1 -1 -1 $-1 $18342 1.5707963267948966 $16945 2.0943951023931944 $16836 $18343 forward @7 unknown T -25 -25 -10.000000000000002 -22.500000000000004 -24.330127018922195 -7.5000000000000036 #
+edge $-1 -1 -1 $-1 $15321 6.1232339957367648e-17 $16845 1.570796326794897 $16823 $18344 forward @7 unknown T -30 -25 -25 -24.999999999999996 -20 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $15309 $16827 $18341 $18345 reversed $12321 $-1 #
+coedge $-1 -1 -1 $-1 $15460 $18346 $15309 $16841 forward $15435 $-1 #
+edge $-1 -1 -1 $-1 $16846 -22.500000000000004 $16947 -12.500000000000005 $16840 $18347 forward @7 unknown T -22.500000000000004 -24.330127018922195 -22.500000000000004 -22.5 -24.330127018922195 -12.500000000000005 #
+coedge $-1 -1 -1 $-1 $16765 $15310 $18346 $18348 reversed $16844 $-1 #
+coedge $-1 -1 -1 $-1 $15310 $16765 $18349 $18350 forward $16844 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15310 $18335 T -25.000000000000004 -25 -27.500000000000004 -20 -24.330127018922191 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $18351 $18352 #
+vertex $-1 -1 -1 $-1 $15311 $18353 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15315 $15312 $15326 $16861 reversed $10956 $-1 #
+coedge $-1 -1 -1 $-1 $16939 $15474 $15312 $16850 forward $15457 $-1 #
+edge $-1 -1 -1 $-1 $16949 12.500000000000002 $16851 22.500000000000004 $16849 $18354 forward @7 unknown T -22.5 -15.669872981077805 -22.500000000000004 -22.499999999999993 -15.669872981077805 -12.500000000000002 #
+vertex $-1 -1 -1 $-1 $18275 $18355 #
+coedge $-1 -1 -1 $-1 $15318 $15317 $16931 $18356 reversed $15319 $-1 #
+edge $-1 -1 -1 $-1 $16818 1.5707963267948957 $15321 3.1415926535897931 $15447 $16826 forward @7 unknown T -35 -20 -25.000000000000007 -29.999999999999993 -15 -20.000000000000004 #
+edge $-1 -1 -1 $-1 $16933 -6.1232339957367648e-17 $15320 1.5707963267948961 $15318 $18357 forward @7 unknown T -30.000000000000007 -20 -30.000000000000004 -25 -15 -25 #
+point $-1 -1 -1 $-1 -25 -15 -25 #
+point $-1 -1 -1 $-1 -29.999999999999993 -20 -20.000000000000004 #
+vertex $-1 -1 -1 $-1 $15325 $18358 #
+straight-curve $-1 -1 -1 $-1 -22.5 -15.669872981077805 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $15327 $15326 $15474 $15472 reversed $15328 $-1 #
+edge $-1 -1 -1 $-1 $13792 1.5707963267948966 $16949 2.0943951023931957 $15326 $18359 forward @7 unknown T -25 -15.669872981077809 -12.500000000000004 -22.499999999999996 -15 -10.000000000000002 #
+edge $-1 -1 -1 $-1 $15329 4.1887902047863914 $13958 4.7123889803846897 $15464 $16946 forward @7 unknown T -22.500000000000004 -15.669872981077807 -10.000000000000002 -20 -15 -7.5000000000000027 #
+face $-1 -1 -1 $-1 $13766 $15328 $11 $-1 $2664 reversed single T -25 -15.669872981077809 -12.500000000000004 -20 -15 -7.5000000000000027 F #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077807 -7.5000000000000027 #
+point $-1 -1 -1 $-1 -30 -20 -1.7763568394002505e-15 #
+edge $-1 -1 -1 $-1 $16821 0 $15450 1.5707963267948966 $15448 $16822 forward @7 unknown T -35 -20 -15.000000000000002 -30 -15 -10.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -10.000000000000002 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18360 $16820 $11 $-1 $2664 reversed single T -35 -25 -15.000000000000004 -25 -20 -5.0000000000000018 F #
+edge $-1 -1 -1 $-1 $15367 -1.5707963267948966 $16858 -1.047197551196597 $15463 $18361 forward @7 unknown T -22.500000000000004 -15.669872981077809 2.4999999999999956 -20 -15 4.9999999999999991 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 4.9999999999999991 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 4.9999999999999982 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -35 -15 4.9999999999999982 #
+face $-1 -1 -1 $-1 $15347 $18362 $11 $-1 $2156 reversed single T -25 -25 2.4999999999999982 -20 -24.330127018922191 7.5 F #
+loop $-1 -1 -1 $-1 $-1 $18265 $15354 T -35 -25 -1.7763568394002505e-15 -25 -20 9.9999999999999982 unknown #
+point $-1 -1 -1 $-1 -35 -25 4.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10.000000000000002 -20 4.9999999999999991 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -20 -15 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $18363 1.0471975511965974 $15370 1.5707963267948966 $16942 $18361 forward @7 unknown T -22.500000000000004 -25 2.4999999999999982 -20 -24.330127018922191 4.9999999999999991 #
+point $-1 -1 -1 $-1 -20 -25 4.9999999999999991 #
+vertex $-1 -1 -1 $-1 $15372 $18364 #
+ellipse-curve $-1 -1 -1 $-1 50 -5 -24.999999999999996 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $11164 $15493 $11 $-1 $11179 reversed single T 40 -10 -14.999999999999998 50 0 -4.9999999999999964 F #
+point $-1 -1 -1 $-1 50 -5 -14.999999999999996 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 -12.500000000000004 #
+face $-1 -1 -1 $-1 $18365 $18366 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 -25 7.5000000000000018 -4.9999999999999991 -10 F #
+loop $-1 -1 -1 $-1 $-1 $16316 $15382 T -9.3734986416366059e-33 -5 -25 7.5000000000000018 0 -10 unknown #
+coedge $-1 -1 -1 $-1 $18367 $18368 $18369 $18370 reversed $15383 $-1 #
+coedge $-1 -1 -1 $-1 $17813 $15384 $18248 $18371 reversed $13859 $-1 #
+coedge $-1 -1 -1 $-1 $15384 $16304 $18372 $18373 reversed $13859 $-1 #
+edge $-1 -1 -1 $-1 $18374 -1.5707963267948966 $18375 -1.1640334398265738e-16 $16720 $18376 forward @7 unknown T 0 -4.9999999999999991 5 5 8.8817841970012523e-16 10 #
+coedge $-1 -1 -1 $-1 $16910 $15386 $16963 $18377 reversed $13861 $-1 #
+edge $-1 -1 -1 $-1 $18378 1.5707963267948966 $15503 2.0943951023931953 $15502 $18379 forward @7 unknown T 20 -10 -9.9999999999999982 22.5 -9.3301270189221928 -7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $18380 $15387 $13864 $15393 forward $12403 $-1 #
+coedge $-1 -1 -1 $-1 $15388 $18380 $15507 $16964 reversed $12403 $-1 #
+edge $-1 -1 -1 $-1 $16361 -22.500000000000004 $14020 -12.499999999999996 $15491 $18381 forward @7 unknown T 22.5 -9.3301270189221981 -22.500000000000004 22.500000000000004 -9.3301270189221928 -12.499999999999996 #
+coedge $-1 -1 -1 $-1 $15391 $15390 $15395 $15508 reversed $11038 $-1 #
+coedge $-1 -1 -1 $-1 $18382 $15392 $15403 $16913 forward $16342 $-1 #
+coedge $-1 -1 -1 $-1 $16353 $18383 $16897 $15393 reversed $17856 $-1 #
+vertex $-1 -1 -1 $-1 $16913 $18384 #
+straight-curve $-1 -1 -1 $-1 15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18385 $15397 $18249 $16921 forward $15400 $-1 #
+coedge $-1 -1 -1 $-1 $15398 $18385 $18386 $18387 forward $15400 $-1 #
+coedge $-1 -1 -1 $-1 $18388 $15399 $18389 $15408 forward $16360 $-1 #
+coedge $-1 -1 -1 $-1 $15399 $18390 $18255 $18391 forward $16360 $-1 #
+coedge $-1 -1 -1 $-1 $18257 $16895 $12406 $13870 forward $13861 $-1 #
+face $-1 -1 -1 $-1 $18392 $15400 $11 $-1 $5398 reversed single T 7.4999999999999964 -5 -10 15.000000000000004 8.8817841970012523e-16 5.0000000000000009 F #
+point $-1 -1 -1 $-1 15.000000000000004 -5 8.8817841970012523e-16 #
+edge $-1 -1 -1 $-1 $16904 0 $16914 1.5707963267948966 $16902 $18393 forward @7 unknown T 10 -5 -15 15 0 -10 #
+vertex $-1 -1 -1 $-1 $18394 $18395 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -10 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $10282 $16342 $11 $-1 $5398 reversed single T 7.5 -5 -25 15 0 -10 F #
+vertex $-1 -1 -1 $-1 $18396 $18397 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -5 5.0000000000000009 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15413 -1.5707963267948966 $18398 -1.0471975511965974 $16906 $18399 forward @7 unknown T 7.4999999999999964 -0.66987298107780813 2.4999999999999996 10 0 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 0 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $18400 1.0471975511965979 $15416 1.5707963267948966 $18390 $18399 forward @7 unknown T 7.4999999999999991 -10 2.5000000000000009 10 -9.3301270189221928 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 -10 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $16932 $15418 $16740 $18266 forward $16926 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15428 $15451 T -37.5 -20 -40 -30 -15 -25.000000000000004 unknown #
+straight-curve $-1 -1 -1 $-1 -37.5 -15.669872981077805 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -37.499999999999993 -15.669872981077804 -27.500000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077809 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $16816 $15428 $16853 $18356 forward $16926 $-1 #
+coedge $-1 -1 -1 $-1 $15428 $16925 $15430 $16935 forward $16926 $-1 #
+vertex $-1 -1 -1 $-1 $18356 $18401 #
+edge $-1 -1 -1 $-1 $15278 1.5707963267948966 $15431 3.1415926535897931 $16932 $16807 forward @7 unknown T -35 -20 -40 -30 -15 -35 #
+point $-1 -1 -1 $-1 -30 -20 -35 #
+point $-1 -1 -1 $-1 -35 -15 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $18346 $15456 $15453 $15458 forward $15435 $-1 #
+coedge $-1 -1 -1 $-1 $15455 $16849 $16761 $18275 forward $15457 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18341 $15467 $15460 $15470 reversed $16944 $-1 #
+coedge $-1 -1 -1 $-1 $15461 $15466 $18402 $16882 forward $13955 $-1 #
+edge $-1 -1 -1 $-1 $16945 -7.5000000000000036 $18363 2.4999999999999996 $15466 $18403 forward @7 unknown T -22.500000000000004 -24.330127018922198 -7.5000000000000036 -22.5 -24.330127018922195 2.4999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $16836 $18360 T -25 -25 -12.500000000000005 -20 -24.330127018922191 -7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $16837 $18404 #
+ellipse-curve $-1 -1 -1 $-1 -20.000000000000004 -20 -10.000000000000002 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $15470 $18405 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 -20 -10.000000000000002 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $16850 $18406 #
+point $-1 -1 -1 $-1 -7.5000000000000027 -15.669872981077809 -22.5 #
+point $-1 -1 -1 $-1 40 -10 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 40 -5 -9.9999999999999982 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 -5 -24.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 22.5 -0.66987298107780635 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $18407 $18408 $11 $-1 $11179 reversed single T -50 -10 -15.000000000000004 -40 2.6645352591003757e-15 -5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $18409 $15496 T -10 -10 -12.500000000000002 -5 -9.330127018922191 -7.5 unknown #
+coedge $-1 -1 -1 $-1 $18410 $18411 $18412 $18413 forward $15497 $-1 #
+coedge $-1 -1 -1 $-1 $15500 $18257 $15504 $16962 reversed $13861 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221945 -7.4999999999999982 #
+edge $-1 -1 -1 $-1 $12581 -2.0943951023931948 $16966 -1.5707963267948966 $15504 $18414 forward @7 unknown T 20 -10.000000000000002 2.5000000000000044 22.5 -9.3301270189221945 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $18415 $18389 $16895 $18377 forward $15506 $-1 #
+edge $-1 -1 -1 $-1 $14020 -2.0943951023931948 $18378 -1.5707963267948966 $15507 $18416 forward @7 unknown T 20 -10 -12.499999999999996 22.500000000000004 -9.3301270189221945 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $18258 $18417 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18402 $18337 $15518 $16969 reversed $18362 $-1 #
+edge $-1 -1 -1 $-1 $15370 1.5707963267948966 $18273 2.0943951023931957 $15518 $16872 forward @7 unknown T -22.500000000000004 -25 4.9999999999999991 -20 -24.330127018922191 7.5 #
+coedge $-1 -1 -1 $-1 $15519 $18418 $15551 $17001 forward $15579 $-1 #
+coedge $-1 -1 -1 $-1 $16972 $15520 $18419 $17046 reversed $15522 $-1 #
+coedge $-1 -1 -1 $-1 $15521 $16971 $18420 $18421 reversed $15522 $-1 #
+face $-1 -1 -1 $-1 $14091 $15522 $11 $-1 $15569 reversed single T -30 35 35 -22.5 40 50 F #
+coedge $-1 -1 -1 $-1 $18422 $18419 $15524 $16975 reversed $18423 $-1 #
+edge $-1 -1 -1 $-1 $15584 1.5707963267948966 $15590 2.0943951023931948 $15524 $15573 forward @7 unknown T -22.5 35 35 -20 35.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $17029 $15526 $18424 $17084 forward $16977 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15526 $17035 T -20 35 30 -9.9999999999999982 40 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18425 $18426 $11 $-1 $12646 reversed single T -15 40 -40 -7.4999999999999991 45 -25 F #
+loop $-1 -1 -1 $-1 $-1 $17103 $18427 T 0 35 20 7.5000000000000036 40 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 35 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15532 $18428 $14126 $15607 forward $16980 $-1 #
+edge $-1 -1 -1 $-1 $14146 6.1232339957367648e-17 $17150 1.5707963267948966 $16438 $18429 forward @7 unknown T 15 35 20 20.000000000000004 40 25 #
+coedge $-1 -1 -1 $-1 $18430 $16988 $15535 $16985 reversed $17954 $-1 #
+edge $-1 -1 -1 $-1 $16999 -2.0943951023931939 $15536 -1.5707963267948966 $15535 $18431 forward @7 unknown T 35 35 17.500000000000007 37.499999999999993 35.669872981077802 20.000000000000004 #
+edge $-1 -1 -1 $-1 $15536 -1.5707963267948966 $15668 -6.1232339957367648e-17 $15538 $18432 forward @7 unknown T 29.999999999999996 35 15 35 40 20.000000000000004 #
+point $-1 -1 -1 $-1 35 35 20.000000000000004 #
+coedge $-1 -1 -1 $-1 $16984 $16444 $15538 $16986 reversed $17954 $-1 #
+loop $-1 -1 -1 $-1 $18433 $18434 $1558 T 50 35 2.6645352591003757e-15 50 45 10.000000000000004 hole $1559 T #
+coedge $-1 -1 -1 $-1 $16990 $16990 $15603 $17059 forward $15540 $-1 #
+coedge $-1 -1 -1 $-1 $16991 $16991 $18435 $18436 reversed $15542 $-1 #
+coedge $-1 -1 -1 $-1 $15543 $15543 $18437 $18438 forward $14070 $-1 #
+coedge $-1 -1 -1 $-1 $18439 $18440 $15543 $16994 reversed $18441 $-1 #
+edge $-1 -1 -1 $-1 $18442 -1.5707963267948966 $18443 1.5707963267948966 $15543 $18444 forward @7 unknown T -45 35 30 -40 45 35 #
+coedge $-1 -1 -1 $-1 $18445 $18424 $15544 $16996 reversed $18446 $-1 #
+edge $-1 -1 -1 $-1 $15610 -2.0943951023931944 $15619 -1.5707963267948966 $15544 $18447 forward @7 unknown T -9.9999999999999982 35 32.500000000000007 -7.5000000000000027 35.669872981077816 35 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 40 20.000000000000004 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15548 $17875 $18430 $18448 forward $11864 $-1 #
+vertex $-1 -1 -1 $-1 $15549 $18449 #
+coedge $-1 -1 -1 $-1 $18437 $15551 $18450 $18451 reversed $15553 $-1 #
+edge $-1 -1 -1 $-1 $18452 37.5 $15554 50 $16970 $18453 forward @7 unknown T -37.5 35.669872981077809 37.5 -37.5 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $15552 $18437 $18454 $18455 reversed $15553 $-1 #
+face $-1 -1 -1 $-1 $18456 $15553 $11 $-1 $18457 reversed single T -45 35 35 -37.5 45 50 F #
+point $-1 -1 -1 $-1 -37.5 35.669872981077809 50 #
+coedge $-1 -1 -1 $-1 $18454 $18458 $15556 $17006 reversed $18459 $-1 #
+edge $-1 -1 -1 $-1 $17007 4.1887902047863896 $18460 4.7123889803846897 $15556 $18461 forward @7 unknown T -37.500000000000007 44.330127018922191 35 -35 45 37.500000000000007 #
+vertex $-1 -1 -1 $-1 $17006 $18462 #
+straight-curve $-1 -1 -1 $-1 -37.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $18463 $15562 $15558 $17010 reversed $17014 $-1 #
+edge $-1 -1 -1 $-1 $18460 1.5707963267948966 $15564 3.1415926535897931 $15558 $18464 forward @7 unknown T -35 40 35 -30 45 40 #
+coedge $-1 -1 -1 $-1 $18418 $15559 $18465 $17017 forward $15579 $-1 #
+face $-1 -1 -1 $-1 $18466 $18467 $11 $-1 $13729 reversed single T -37.500000000000007 40 19.999999999999993 -29.999999999999993 45 35 F #
+coedge $-1 -1 -1 $-1 $15562 $18463 $18468 $18469 forward $17014 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15562 $17030 T -35 40 30 -24.999999999999996 45 40 unknown #
+vertex $-1 -1 -1 $-1 $18469 $18470 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15564 3.1415926535897931 $18471 4.7123889803846897 $17011 $18464 forward @7 unknown T -35 35 35 -30 40 40 #
+point $-1 -1 -1 $-1 -30 40 40 #
+coedge $-1 -1 -1 $-1 $15570 $15566 $18472 $18473 forward $15571 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18474 $18475 $11 $-1 $15569 reversed single T -30.000000000000007 40 -40 -22.499999999999996 45 -25 F #
+loop $-1 -1 -1 $-1 $-1 $18476 $15568 T -30 40 -50 -22.499999999999996 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $18477 $17027 $15570 $17024 forward $17031 $-1 #
+edge $-1 -1 -1 $-1 $15572 -1.5707963267948966 $18478 -1.0471975511965965 $17023 $18479 forward @7 unknown T -22.500000000000007 44.330127018922184 32.499999999999993 -20 45 35 #
+face $-1 -1 -1 $-1 $18480 $15571 $11 $-1 $8951 reversed single T -24.999999999999996 44.330127018922184 32.499999999999993 -20 45 37.5 F #
+point $-1 -1 -1 $-1 -20 45 35 #
+coedge $-1 -1 -1 $-1 $17023 $18481 $15575 $17028 forward $17031 $-1 #
+edge $-1 -1 -1 $-1 $17033 0 $15572 1.5707963267948966 $17027 $18482 forward @7 unknown T -20 40 30 -15 45 35 #
+coedge $-1 -1 -1 $-1 $15577 $16976 $18483 $18484 reversed $16977 $-1 #
+face $-1 -1 -1 $-1 $18485 $17014 $11 $-1 $8951 reversed single T -35 40 30 -24.999999999999996 45 40 F #
+loop $-1 -1 -1 $-1 $-1 $18481 $15578 T -22.500000000000007 40 20 -15 45 35 unknown #
+coedge $-1 -1 -1 $-1 $15589 $15580 $18481 $18486 reversed $14112 $-1 #
+vertex $-1 -1 -1 $-1 $17028 $18487 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18488 $16977 $11 $-1 $8951 reversed single T -20 35 30 -9.9999999999999982 40 40 F #
+edge $-1 -1 -1 $-1 $18489 1.0471975511965983 $15584 1.5707963267948966 $18490 $18479 forward @7 unknown T -22.5 35 32.5 -20 35.669872981077809 35 #
+point $-1 -1 -1 $-1 -20 35 35 #
+coedge $-1 -1 -1 $-1 $15585 $17043 $15592 $17049 reversed $14112 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18491 $18492 $11 $-1 $12646 reversed single T -15.000000000000004 40 -25 -7.4999999999999991 45 -10 F #
+loop $-1 -1 -1 $-1 $-1 $18493 $15587 T -15 40 -10 -7.4999999999999964 45 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $18494 $18495 $18496 $18497 reversed $15588 $-1 #
+coedge $-1 -1 -1 $-1 $17038 $15589 $18498 $18499 reversed $14112 $-1 #
+coedge $-1 -1 -1 $-1 $18500 $18501 $15589 $17045 forward $18502 $-1 #
+edge $-1 -1 -1 $-1 $18503 -1.5707963267948966 $18504 6.1232339957367648e-17 $17044 $18505 forward @7 unknown T -15 40 20 -9.9999999999999982 45 25 #
+edge $-1 -1 -1 $-1 $18506 1.5707963267948966 $15590 2.0943951023931948 $18419 $18507 forward @7 unknown T -24.999999999999996 35 35 -22.5 35.669872981077809 37.5 #
+point $-1 -1 -1 $-1 -22.5 35.669872981077802 37.5 #
+coedge $-1 -1 -1 $-1 $17051 $15592 $18508 $18509 forward $15593 $-1 #
+edge $-1 -1 -1 $-1 $15594 -32.5 $18510 -22.500000000000004 $15592 $18511 forward @7 unknown T -7.5000000000000018 44.330127018922191 22.500000000000004 -7.4999999999999991 44.330127018922191 32.5 #
+point $-1 -1 -1 $-1 -7.5 44.330127018922191 32.5 #
+coedge $-1 -1 -1 $-1 $15596 $17048 $18512 $18513 forward $15593 $-1 #
+face $-1 -1 -1 $-1 $18514 $18515 $11 $-1 $14913 reversed single T 39.999999999999993 35 2.6645352591003757e-15 50 45 10.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $18516 $14122 T -50 35 14.999999999999996 -50 45 24.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $18517 $18517 $18518 $18519 forward $15601 $-1 #
+coedge $-1 -1 -1 $-1 $18520 $15602 $18521 $18522 reversed $14123 $-1 #
+coedge $-1 -1 -1 $-1 $15602 $18520 $18523 $18524 forward $14123 $-1 #
+coedge $-1 -1 -1 $-1 $18525 $18445 $15602 $17058 reversed $18446 $-1 #
+edge $-1 -1 -1 $-1 $18526 1.5707963267948966 $18527 2.0943951023931957 $15602 $18528 forward @7 unknown T -9.9999999999999982 35 20 -7.4999999999999973 35.669872981077809 22.500000000000004 #
+edge $-1 -1 -1 $-1 $18529 0 $18529 6.2831853071795862 $16990 $18530 forward @7 unknown T 50 35 15.000000000000004 50 45 25.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 40 20.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18512 $18531 $15606 $17062 forward $16430 $-1 #
+edge $-1 -1 -1 $-1 $18532 -1.5707963267948966 $17063 6.1232339957367673e-17 $17061 $18533 forward @7 unknown T 0 40 20 5.0000000000000027 45 25 #
+vertex $-1 -1 -1 $-1 $18534 $18535 #
+straight-curve $-1 -1 -1 $-1 8.8817841970012523e-16 40 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $18536 $18537 $11 $-1 $10029 reversed single T 0 40 5 7.5000000000000018 45 20 F #
+point $-1 -1 -1 $-1 -7.5000000000000027 35.669872981077816 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $15611 $18521 $18445 $18538 forward $14142 $-1 #
+coedge $-1 -1 -1 $-1 $18539 $15621 $15612 $17069 forward $17087 $-1 #
+edge $-1 -1 -1 $-1 $15623 -2.0943951023931944 $18532 -1.5707963267948966 $17068 $18540 forward @7 unknown T 5.0000000000000027 44.330127018922198 20 7.5000000000000027 45 22.5 #
+coedge $-1 -1 -1 $-1 $15613 $18541 $16424 $17929 reversed $14134 $-1 #
+coedge $-1 -1 -1 $-1 $18542 $15614 $17083 $18543 reversed $12666 $-1 #
+edge $-1 -1 -1 $-1 $16418 -1.5707963267948966 $17080 6.1232339957367648e-17 $16415 $18544 forward @7 unknown T 0 40 -40 5.0000000000000027 45 -35 #
+coedge $-1 -1 -1 $-1 $15615 $18542 $18545 $18546 reversed $12666 $-1 #
+coedge $-1 -1 -1 $-1 $18547 $18548 $15615 $17075 forward $18549 $-1 #
+edge $-1 -1 -1 $-1 $17081 -6.1232339957367648e-17 $18550 1.5707963267948966 $17074 $18551 forward @7 unknown T 0 40 -30 5.0000000000000027 45 -25 #
+coedge $-1 -1 -1 $-1 $18552 $15616 $18548 $18553 forward $17079 $-1 #
+coedge $-1 -1 -1 $-1 $15616 $18554 $17923 $18555 forward $17079 $-1 #
+coedge $-1 -1 -1 $-1 $17915 $18556 $17920 $15617 reversed $18557 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15616 $16427 T -7.5000000000000018 40 -40 8.8817841970012523e-16 45 -25 unknown #
+vertex $-1 -1 -1 $-1 $17916 $18558 #
+vertex $-1 -1 -1 $-1 $18553 $18559 #
+coedge $-1 -1 -1 $-1 $15618 $16369 $17071 $18543 forward $16370 $-1 #
+edge $-1 -1 -1 $-1 $15619 -1.5707963267948966 $17033 -6.1232339957367648e-17 $16976 $18560 forward @7 unknown T -15 35 30 -9.9999999999999982 40 35 #
+point $-1 -1 -1 $-1 -9.9999999999999982 35 35 #
+coedge $-1 -1 -1 $-1 $15621 $18539 $18561 $18562 reversed $17087 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17068 $18563 T 5.0000000000000027 44.330127018922191 17.5 10 45 22.5 unknown #
+vertex $-1 -1 -1 $-1 $18562 $18564 #
+ellipse-curve $-1 -1 -1 $-1 10 40 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 7.5000000000000027 44.330127018922205 22.5 #
+coedge $-1 -1 -1 $-1 $18521 $15625 $18565 $18534 forward $14142 $-1 #
+coedge $-1 -1 -1 $-1 $15628 $15626 $17934 $18566 reversed $13359 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 40 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18567 $17106 $15628 $17095 reversed $15634 $-1 #
+edge $-1 -1 -1 $-1 $18568 -6.1232339957367648e-17 $15629 1.5707963267948966 $15628 $18569 forward @7 unknown T 15 40 15 20.000000000000004 45 20 #
+point $-1 -1 -1 $-1 20.000000000000004 45 20 #
+vertex $-1 -1 -1 $-1 $18570 $18571 #
+face $-1 -1 -1 $-1 $18572 $18573 $11 $-1 $7943 reversed single T 15 40 -25 22.500000000000004 45 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $18574 $15633 T 15 40 -9.9999999999999982 22.500000000000007 45 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $18575 $18567 $17943 $18576 reversed $15634 $-1 #
+coedge $-1 -1 -1 $-1 $18577 $18578 $15635 $17102 reversed $18579 $-1 #
+edge $-1 -1 -1 $-1 $17097 1.5707963267948966 $17104 2.0943951023931957 $15635 $17089 forward @7 unknown T 7.4999999999999991 35 20 10 35.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $18428 $15636 $18578 $18580 reversed $16980 $-1 #
+vertex $-1 -1 -1 $-1 $18580 $18581 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17094 $18582 $15638 $17107 reversed $15634 $-1 #
+edge $-1 -1 -1 $-1 $15629 1.5707963267948966 $17129 2.0943951023931939 $15638 $18583 forward @7 unknown T 20.000000000000004 44.330127018922198 17.500000000000004 22.500000000000011 45 20 #
+coedge $-1 -1 -1 $-1 $18584 $15715 $15640 $17109 forward $17183 $-1 #
+edge $-1 -1 -1 $-1 $16434 -2.0943951023931957 $18585 -1.570796326794897 $17108 $18586 forward @7 unknown T 20.000000000000004 35 -27.500000000000004 22.500000000000004 35.669872981077809 -25 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15644 $15709 $18587 $18588 forward $15710 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15647 $15646 $18589 $18590 reversed $15648 $-1 #
+coedge $-1 -1 -1 $-1 $18587 $18591 $15646 $17115 reversed $18573 $-1 #
+edge $-1 -1 -1 $-1 $15649 -1.570796326794897 $18592 6.1232339957367648e-17 $15646 $18593 forward @7 unknown T 15 40 -25 20.000000000000007 45 -19.999999999999996 #
+face $-1 -1 -1 $-1 $18594 $15648 $11 $-1 $15707 reversed single T 10 40 -30 20.000000000000007 45 -19.999999999999996 F #
+point $-1 -1 -1 $-1 20.000000000000004 45 -25 #
+coedge $-1 -1 -1 $-1 $15653 $15651 $18542 $18595 forward $14162 $-1 #
+coedge $-1 -1 -1 $-1 $18596 $18545 $15651 $17120 reversed $18597 $-1 #
+edge $-1 -1 -1 $-1 $17121 -1.5707963267948966 $18598 -1.0471975511965979 $15651 $18599 forward @7 unknown T 7.5 44.330127018922191 -27.5 10 45 -25 #
+vertex $-1 -1 -1 $-1 $17120 $18600 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18601 4.1887902047863941 $13349 4.7123889803846897 $15653 $16426 forward @7 unknown T 7.5000000000000027 44.330127018922198 -40 10 45 -37.500000000000014 #
+coedge $-1 -1 -1 $-1 $15655 $16424 $18602 $18603 forward $15656 $-1 #
+coedge $-1 -1 -1 $-1 $18604 $17938 $15655 $17126 reversed $18605 $-1 #
+edge $-1 -1 -1 $-1 $18606 -1.5707963267948966 $14164 0 $15655 $17122 forward @7 unknown T 10 35 -30 15 40 -25 #
+face $-1 -1 -1 $-1 $16413 $15656 $11 $-1 $7955 reversed single T 7.5 35 -40 15.000000000000002 40 -25 F #
+coedge $-1 -1 -1 $-1 $16439 $15660 $18582 $18607 forward $11907 $-1 #
+vertex $-1 -1 -1 $-1 $18607 $18608 #
+ellipse-curve $-1 -1 -1 $-1 25 40 20 -0.70710678118654768 -0 0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+face $-1 -1 -1 $-1 $14219 $18609 $11 $-1 $7955 reversed single T 7.4999999999999991 35 5.0000000000000009 15.000000000000002 40 20 F #
+coedge $-1 -1 -1 $-1 $15664 $17944 $18610 $18611 reversed $14904 $-1 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $14181 -1.5707963267948961 $15668 0 $16443 $17133 forward @7 unknown T 25 35 15 29.999999999999996 40 20 #
+point $-1 -1 -1 $-1 29.999999999999996 40 15 #
+vertex $-1 -1 -1 $-1 $15670 $18612 #
+coedge $-1 -1 -1 $-1 $16443 $18613 $15678 $15670 forward $16445 $-1 #
+face $-1 -1 -1 $-1 $18614 $18615 $11 $-1 $6121 reversed single T 29.999999999999996 35 -9.9999999999999982 37.500000000000007 40 5.0000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $17154 $15672 T 29.999999999999996 35 -24.999999999999996 37.500000000000014 40 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $18616 $15674 $18617 $18618 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $15674 $18619 $18620 $18621 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $18622 $18623 $15674 $17143 forward $18624 $-1 #
+edge $-1 -1 -1 $-1 $18625 -1.5707963267948966 $18626 6.1232339957367648e-17 $17142 $18627 forward @7 unknown T 29.999999999999996 40 -9.9999999999999982 35 45 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $18628 $16376 $15675 $17145 forward $17879 $-1 #
+edge $-1 -1 -1 $-1 $16378 -2.0943951023931957 $17147 -1.5707963267948966 $17144 $18629 forward @7 unknown T 35 44.330127018922191 5.0000000000000018 37.500000000000007 45 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $15676 $17947 $18619 $18630 forward $14912 $-1 #
+vertex $-1 -1 -1 $-1 $18630 $18631 #
+ellipse-curve $-1 -1 -1 $-1 35 40 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $15679 $15678 $18632 $18633 forward $15680 $-1 #
+vertex $-1 -1 -1 $-1 $18634 $18635 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.499999999999993 44.330127018922191 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $15687 $15686 $18636 $18637 reversed $15688 $-1 #
+coedge $-1 -1 -1 $-1 $17956 $18638 $15686 $17155 reversed $17139 $-1 #
+edge $-1 -1 -1 $-1 $15689 1.5707963267948966 $18639 2.0943951023931984 $15686 $18640 forward @7 unknown T 35 35 -24.999999999999996 37.500000000000014 35.669872981077816 -22.499999999999986 #
+face $-1 -1 -1 $-1 $15699 $15688 $11 $-1 $15707 reversed single T 35 35 -27.499999999999993 40.000000000000007 35.669872981077816 -22.499999999999986 F #
+point $-1 -1 -1 $-1 35 35 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $18641 $18641 $15691 $17159 reversed $18642 $-1 #
+edge $-1 -1 -1 $-1 $17160 -1.570796326794897 $17164 1.570796326794897 $15691 $18643 forward @7 unknown T 40 35 -29.999999999999996 45.000000000000007 45 -24.999999999999993 #
+vertex $-1 -1 -1 $-1 $15692 $18644 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 40 -24.999999999999996 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18645 $18646 $15695 $17163 forward $18647 $-1 #
+edge $-1 -1 -1 $-1 $17166 4.1887902047863905 $17164 4.7123889803846897 $17162 $18648 forward @7 unknown T 37.500000000000007 44.330127018922191 -24.999999999999996 40.000000000000007 45 -22.499999999999989 #
+vertex $-1 -1 -1 $-1 $15696 $18649 #
+coedge $-1 -1 -1 $-1 $18650 $15697 $18646 $18651 reversed $15673 $-1 #
+vertex $-1 -1 -1 $-1 $17163 $18652 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18653 $18654 $11 $-1 $7024 reversed single T 22.5 35 -9.9999999999999982 30 40 5.0000000000000036 F #
+coedge $-1 -1 -1 $-1 $18655 $15701 $18656 $17174 forward $17171 $-1 #
+coedge $-1 -1 -1 $-1 $15701 $18657 $15709 $17178 forward $17171 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17169 $18658 T 22.5 40 -25 30 45 -9.9999999999999964 unknown #
+ellipse-curve $-1 -1 -1 $-1 25 40 -25 0.70710678118654768 0 -0.70710678118654724 -4.9999999999999964 0 -5 0.70710678118654779 I I #
+coedge $-1 -1 -1 $-1 $15703 $18650 $18623 $18659 reversed $15673 $-1 #
+edge $-1 -1 -1 $-1 $15704 -20 $18660 -14.999999999999998 $17169 $18661 forward @7 unknown T 29.999999999999996 40 -20 30 40 -14.999999999999998 #
+edge $-1 -1 -1 $-1 $15704 3.1415926535897931 $15719 4.7123889803846897 $17184 $17172 forward @7 unknown T 25 35 -25 29.999999999999996 40 -20 #
+point $-1 -1 -1 $-1 29.999999999999996 40 -20 #
+straight-curve $-1 -1 -1 $-1 22.5 44.330127018922191 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $18662 4.1887902047863932 $14213 4.7123889803846897 $17170 $18663 forward @7 unknown T 22.5 44.330127018922198 -25 25 45 -22.500000000000007 #
+face $-1 -1 -1 $-1 $18664 $15710 $11 $-1 $15707 reversed single T 20 44.330127018922191 -27.500000000000004 25 45 -22.500000000000007 F #
+point $-1 -1 -1 $-1 22.500000000000011 44.330127018922205 -27.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000007 44.330127018922205 -37.5 #
+coedge $-1 -1 -1 $-1 $15715 $18584 $18665 $18666 reversed $17183 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17108 $18667 T 20 35 -27.500000000000004 25 35.669872981077809 -22.500000000000004 unknown #
+coedge $-1 -1 -1 $-1 $18665 $18656 $15717 $17175 forward $18668 $-1 #
+point $-1 -1 -1 $-1 25 35 -25 #
+coedge $-1 -1 -1 $-1 $15720 $15761 $18669 $18670 forward $14280 $-1 #
+coedge $-1 -1 -1 $-1 $15724 $18671 $15721 $15796 forward $17191 $-1 #
+coedge $-1 -1 -1 $-1 $18672 $17233 $15722 $17189 forward $18673 $-1 #
+edge $-1 -1 -1 $-1 $14265 6.1232339957367648e-17 $17274 1.5707963267948966 $17188 $18674 forward @7 unknown T -30 20 35 -25 25 40 #
+coedge $-1 -1 -1 $-1 $18671 $15724 $17258 $15786 reversed $17191 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17187 $18675 T -25 20 32.5 -20 20.669872981077813 37.5 unknown #
+coedge $-1 -1 -1 $-1 $15745 $18676 $15726 $15834 reversed $17214 $-1 #
+face $-1 -1 -1 $-1 $13396 $18677 $11 $-1 $11391 reversed single T -15 20 -40 -7.4999999999999964 25 -25 F #
+loop $-1 -1 -1 $-1 $-1 $18678 $15729 T -15 25 -40 -7.4999999999999964 30 -25 unknown #
+face $-1 -1 -1 $-1 $10087 $15730 $11 $-1 $9009 reversed single T 0 20 20 7.5000000000000027 25 35 F #
+coedge $-1 -1 -1 $-1 $15732 $15853 $18030 $18679 reversed $15730 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18058 $15734 $15748 $17216 reversed $16546 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $18680 $18681 $1558 T 50 20 -14.999999999999996 50 30 -4.9999999999999964 hole $1559 T #
+coedge $-1 -1 -1 $-1 $17202 $17202 $18682 $18683 forward $15739 $-1 #
+coedge $-1 -1 -1 $-1 $17203 $17203 $15741 $17204 forward $18684 $-1 #
+edge $-1 -1 -1 $-1 $18685 0 $18685 6.2831853071795862 $17203 $18686 forward @7 unknown T -50 20 29.999999999999996 -50 30 40 #
+coedge $-1 -1 -1 $-1 $15752 $15750 $15742 $17206 reversed $14254 $-1 #
+edge $-1 -1 -1 $-1 $17211 -1.5707963267948966 $17210 1.5707963267948966 $15742 $18687 forward @7 unknown T -45 20.000000000000004 35 -40 30.000000000000004 40 #
+coedge $-1 -1 -1 $-1 $18688 $15743 $18689 $18690 reversed $17209 $-1 #
+coedge $-1 -1 -1 $-1 $15743 $18691 $18692 $18693 reversed $17209 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18694 $18695 T -45 20.000000000000004 19.999999999999996 -37.5 30.000000000000004 35 unknown #
+vertex $-1 -1 -1 $-1 $15744 $18696 #
+vertex $-1 -1 -1 $-1 $15744 $18697 #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15807 $15745 $15817 $17306 reversed $17214 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15807 $18698 T -15 20 20 -7.4999999999999964 25 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18699 7.5000000000000036 $15749 17.500000000000011 $15748 $18700 forward @7 unknown T 37.499999999999993 20.669872981077802 7.5000000000000036 37.500000000000014 20.669872981077813 17.500000000000011 #
+point $-1 -1 -1 $-1 37.499999999999993 20.669872981077802 17.500000000000011 #
+coedge $-1 -1 -1 $-1 $18669 $18689 $15750 $17219 forward $18701 $-1 #
+edge $-1 -1 -1 $-1 $17210 1.5707963267948966 $17220 2.0943951023931953 $17218 $18702 forward @7 unknown T -40 20.000000000000004 35 -37.5 20.669872981077813 37.5 #
+vertex $-1 -1 -1 $-1 $17219 $18703 #
+straight-curve $-1 -1 -1 $-1 -37.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18692 $15755 $15752 $17223 forward $17227 $-1 #
+edge $-1 -1 -1 $-1 $15757 -2.0943951023931957 $17211 -1.5707963267948966 $17222 $18704 forward @7 unknown T -40 29.330127018922195 35 -37.5 30.000000000000004 37.5 #
+face $-1 -1 -1 $-1 $18705 $17984 $11 $-1 $17225 reversed single T -45 20.000000000000004 -50 -37.5 30.000000000000004 -40 F #
+cone-surface $-1 -1 -1 $-1 -40 25.000000000000004 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $15755 $18692 $18706 $18707 reversed $17227 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17222 $18708 T -40 29.330127018922195 32.5 -35 30.000000000000004 37.5 unknown #
+vertex $-1 -1 -1 $-1 $18707 $18709 #
+ellipse-curve $-1 -1 -1 $-1 -35 25 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 29.330127018922195 37.5 #
+coedge $-1 -1 -1 $-1 $15763 $15759 $18710 $18711 reversed $15764 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 25 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17188 $18712 $15761 $15767 reversed $18673 $-1 #
+face $-1 -1 -1 $-1 $18708 $18701 $11 $-1 $8043 reversed single T -40 20 32.499999999999993 -35 20.669872981077813 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $18713 $15762 T -37.500000000000007 25 19.999999999999993 -29.999999999999993 30 35 unknown #
+coedge $-1 -1 -1 $-1 $18714 $17240 $15763 $17237 reversed $18715 $-1 #
+edge $-1 -1 -1 $-1 $18716 -6.1232339957367648e-17 $15765 1.5707963267948966 $15763 $18717 forward @7 unknown T -30 25 30 -25 30 35 #
+point $-1 -1 -1 $-1 -25 30 35 #
+vertex $-1 -1 -1 $-1 $18718 $18719 #
+coedge $-1 -1 -1 $-1 $17236 $18720 $15769 $17241 reversed $18715 $-1 #
+edge $-1 -1 -1 $-1 $15765 1.5707963267948966 $17246 2.0943951023931948 $15769 $18721 forward @7 unknown T -25 29.330127018922191 32.5 -22.500000000000004 30 35 #
+face $-1 -1 -1 $-1 $16483 $18722 $11 $-1 $14270 reversed single T -30.000000000000007 20 -40 -22.499999999999996 25 -25 F #
+loop $-1 -1 -1 $-1 $-1 $18723 $15771 T -30.000000000000007 25 -40 -22.5 30 -25 unknown #
+coedge $-1 -1 -1 $-1 $18724 $16453 $16455 $17964 reversed $15772 $-1 #
+coedge $-1 -1 -1 $-1 $18725 $15773 $18720 $18726 forward $15781 $-1 #
+vertex $-1 -1 -1 $-1 $18726 $18727 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18728 $18729 $11 $-1 $12288 reversed single T -37.500000000000007 20 19.999999999999993 -29.999999999999993 25 35 F #
+coedge $-1 -1 -1 $-1 $15777 $18730 $18731 $17254 forward $15781 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18731 $17258 $15779 $17252 forward $18732 $-1 #
+edge $-1 -1 -1 $-1 $14285 -1.5707963267948966 $15783 0 $17251 $17250 forward @7 unknown T -20 20 30 -15 25 35 #
+face $-1 -1 -1 $-1 $18675 $18673 $11 $-1 $8043 reversed single T -35 20 30 -25 25 40 F #
+edge $-1 -1 -1 $-1 $17272 25 $15783 30 $17249 $18733 forward @7 unknown T -15 25 25 -15 25 30 #
+point $-1 -1 -1 $-1 -15 25 30 #
+face $-1 -1 -1 $-1 $18734 $18732 $11 $-1 $12796 reversed single T -22.500000000000004 20 20 -15 25 35 F #
+vertex $-1 -1 -1 $-1 $15786 $18735 #
+coedge $-1 -1 -1 $-1 $17251 $18736 $17190 $15786 forward $18732 $-1 #
+face $-1 -1 -1 $-1 $18737 $18738 $11 $-1 $11391 reversed single T -15.000000000000004 20 -25 -7.4999999999999964 25 -10 F #
+loop $-1 -1 -1 $-1 $-1 $18739 $15790 T -15.000000000000004 25 -25 -7.4999999999999964 30 -10 unknown #
+coedge $-1 -1 -1 $-1 $18022 $18740 $18019 $18741 reversed $15791 $-1 #
+coedge $-1 -1 -1 $-1 $18742 $15792 $18743 $18744 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $15792 $18745 $18746 $18747 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $18748 $18749 $15792 $17265 forward $18750 $-1 #
+edge $-1 -1 -1 $-1 $18751 -1.5707963267948966 $18752 6.1232339957367673e-17 $17264 $18753 forward @7 unknown T -15 25 4.9999999999999991 -9.9999999999999982 30 10 #
+coedge $-1 -1 -1 $-1 $18754 $17276 $15793 $17267 forward $18755 $-1 #
+edge $-1 -1 -1 $-1 $17278 -2.0943951023931957 $17271 -1.5707963267948966 $17266 $18756 forward @7 unknown T -9.9999999999999982 29.330127018922191 20 -7.4999999999999964 30 22.5 #
+coedge $-1 -1 -1 $-1 $18757 $15794 $18730 $18758 reversed $17270 $-1 #
+coedge $-1 -1 -1 $-1 $15794 $18757 $18745 $18759 forward $17270 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15794 $18760 T -20 25 15 -9.9999999999999982 30 25 unknown #
+vertex $-1 -1 -1 $-1 $18759 $18761 #
+vertex $-1 -1 -1 $-1 $18762 $18763 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $18764 $18765 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17266 $18766 $15798 $17277 reversed $18755 $-1 #
+edge $-1 -1 -1 $-1 $17278 4.1887902047863914 $18767 4.7123889803846897 $15798 $18768 forward @7 unknown T -7.4999999999999982 29.330127018922191 20 -5 30 22.5 #
+vertex $-1 -1 -1 $-1 $17277 $18769 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $18770 $15811 $15801 $17281 reversed $14981 $-1 #
+edge $-1 -1 -1 $-1 $18767 1.5707963267948966 $15813 3.1415926535897931 $15801 $18771 forward @7 unknown T -5 25 20 0 30 25 #
+face $-1 -1 -1 $-1 $18772 $18773 $11 $-1 $13449 reversed single T -9.9999999999999982 20 2.5000000000000013 -5 20.669872981077805 7.5 F #
+loop $-1 -1 -1 $-1 $18774 $17976 $15802 T 39.999999999999993 20 2.6645352591003757e-15 45.000000000000007 30 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $17284 $17284 $18775 $18776 reversed $15803 $-1 #
+coedge $-1 -1 -1 $-1 $15804 $15804 $18777 $18778 forward $14302 $-1 #
+coedge $-1 -1 -1 $-1 $18779 $18780 $15804 $17287 reversed $18781 $-1 #
+edge $-1 -1 -1 $-1 $18782 -1.5707963267948966 $18783 1.5707963267948966 $15804 $18784 forward @7 unknown T -45 20.000000000000004 14.999999999999996 -40 30.000000000000004 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $15806 $15805 $18785 $18786 reversed $12817 $-1 #
+coedge $-1 -1 -1 $-1 $15817 $15841 $15805 $17290 forward $12836 $-1 #
+edge $-1 -1 -1 $-1 $18787 1.5707963267948966 $17295 2.0943951023931957 $17289 $18768 forward @7 unknown T -7.5000000000000009 20 20 -5 20.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $18788 $18789 $15806 $17292 reversed $18790 $-1 #
+edge $-1 -1 -1 $-1 $18791 -2.0943951023931948 $17294 -1.5707963267948966 $15806 $18792 forward @7 unknown T -9.9999999999999982 20 17.5 -7.4999999999999964 20.669872981077805 20 #
+coedge $-1 -1 -1 $-1 $18676 $15807 $18793 $18794 reversed $17214 $-1 #
+vertex $-1 -1 -1 $-1 $18795 $18796 #
+vertex $-1 -1 -1 $-1 $15808 $18797 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $15809 $18798 #
+ellipse-curve $-1 -1 -1 $-1 50 25 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $15811 $18770 $18799 $18800 forward $14981 $-1 #
+vertex $-1 -1 -1 $-1 $18800 $18801 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $15813 3.1415926535897931 $18787 4.7123889803846897 $15841 $18771 forward @7 unknown T -5 20 20 0 25 25 #
+point $-1 -1 -1 $-1 0 25 25 #
+face $-1 -1 -1 $-1 $18802 $18803 $11 $-1 $9009 reversed single T 0 25 -10 7.5000000000000027 30 5 F #
+loop $-1 -1 -1 $-1 $-1 $18804 $15815 T 0 25 5 7.5000000000000009 30 20 unknown #
+edge $-1 -1 -1 $-1 $17295 22.500000000000004 $14311 32.5 $15817 $18805 forward @7 unknown T -7.5 20.669872981077802 22.500000000000004 -7.4999999999999964 20.669872981077805 32.5 #
+coedge $-1 -1 -1 $-1 $15836 $15818 $18806 $18807 forward $15837 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15820 $18024 $18808 $18809 reversed $12828 $-1 #
+coedge $-1 -1 -1 $-1 $15823 $15821 $15868 $17363 reversed $11411 $-1 #
+edge $-1 -1 -1 $-1 $17369 -2.0943951023931935 $14969 -1.5707963267948966 $15833 $18810 forward @7 unknown T 5.0000000000000018 29.330127018922198 -40 7.5000000000000027 30 -37.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15869 $18811 $15823 $17314 forward $17365 $-1 #
+edge $-1 -1 -1 $-1 $17318 1.570796326794897 $17366 2.0943951023931953 $17313 $18812 forward @7 unknown T 5.0000000000000018 29.330127018922191 -27.499999999999996 7.5000000000000009 30 -25 #
+coedge $-1 -1 -1 $-1 $18813 $15824 $18814 $18815 forward $17317 $-1 #
+coedge $-1 -1 -1 $-1 $15824 $18813 $15826 $17321 reversed $17317 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15824 $18816 T -5 25 -30 5.0000000000000036 30 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $15825 $18817 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18818 $15826 $18819 $18820 forward $15829 $-1 #
+edge $-1 -1 -1 $-1 $15831 0 $18821 1.5707963267948966 $15826 $18822 forward @7 unknown T -5 25 -30 0 30 -25 #
+coedge $-1 -1 -1 $-1 $15827 $18818 $17967 $18823 forward $15829 $-1 #
+edge $-1 -1 -1 $-1 $14971 1.5707963267948966 $15830 3.1415926535897931 $15827 $18016 forward @7 unknown T -5 25 -40 0 30 -35 #
+coedge $-1 -1 -1 $-1 $15828 $18824 $18825 $18826 forward $17325 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15828 $18017 T -7.5 20 -40 8.8817841970012523e-16 25 -25 unknown #
+point $-1 -1 -1 $-1 0 25 -35 #
+point $-1 -1 -1 $-1 0 25 -30 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18827 $16526 $15836 $17330 forward $13426 $-1 #
+edge $-1 -1 -1 $-1 $15838 -1.5707963267948966 $18828 -1.0471975511965974 $17329 $18829 forward @7 unknown T 7.4999999999999991 29.330127018922191 17.5 10 30 20 #
+face $-1 -1 -1 $-1 $18830 $15837 $11 $-1 $11403 reversed single T 5.0000000000000018 29.330127018922191 17.5 10 30 22.5 F #
+point $-1 -1 -1 $-1 10 30 20 #
+coedge $-1 -1 -1 $-1 $18030 $18831 $15841 $17302 reversed $16525 $-1 #
+edge $-1 -1 -1 $-1 $17336 0 $15838 1.5707963267948966 $16526 $18832 forward @7 unknown T 10 25 15 15 30 20 #
+coedge $-1 -1 -1 $-1 $15850 $15844 $14982 $16529 reversed $14335 $-1 #
+vertex $-1 -1 -1 $-1 $17334 $18833 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18834 1.0471975511965979 $15847 1.5707963267948966 $18835 $18829 forward @7 unknown T 7.5 20 17.5 10 20.669872981077809 20 #
+point $-1 -1 -1 $-1 10 20 20 #
+face $-1 -1 -1 $-1 $18836 $18837 $11 $-1 $7081 reversed single T 15 20 -25 22.5 25 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $15864 $15848 T 15 25 -25 22.5 30 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $18838 $18839 $18840 $18841 reversed $15849 $-1 #
+coedge $-1 -1 -1 $-1 $17350 $15850 $18045 $18842 reversed $14335 $-1 #
+edge $-1 -1 -1 $-1 $18843 -1.5707963267948966 $18036 6.1232339957367673e-17 $16535 $18844 forward @7 unknown T 14.999999999999996 25 5.0000000000000009 20 30 10 #
+coedge $-1 -1 -1 $-1 $18845 $15851 $18835 $17338 reversed $17347 $-1 #
+coedge $-1 -1 -1 $-1 $15851 $18845 $15853 $17348 forward $17347 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17346 $16524 T 5.0000000000000018 20 17.5 10 20.669872981077813 22.500000000000004 unknown #
+edge $-1 -1 -1 $-1 $18846 1.5707963267948966 $15854 2.0943951023931957 $17346 $18847 forward @7 unknown T 5.0000000000000018 20 20 7.5000000000000027 20.669872981077813 22.500000000000004 #
+point $-1 -1 -1 $-1 7.5 20.669872981077813 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $15856 $17343 $15878 $17375 reversed $14335 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $15932 $15858 $18848 $18849 forward $15933 $-1 #
+vertex $-1 -1 -1 $-1 $16531 $18850 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18851 $15864 $15861 $17356 reversed $17341 $-1 #
+edge $-1 -1 -1 $-1 $17430 -2.0943951023931939 $14350 -1.5707963267948961 $15861 $18852 forward @7 unknown T 19.999999999999996 29.330127018922195 -25 22.5 30 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $18853 $18854 $15863 $17358 forward $18855 $-1 #
+edge $-1 -1 -1 $-1 $15871 1.5707963267948966 $17360 3.1415926535897931 $17357 $18856 forward @7 unknown T 10 25 -25 15 30 -20 #
+coedge $-1 -1 -1 $-1 $15864 $18857 $18853 $18858 reversed $17341 $-1 #
+vertex $-1 -1 -1 $-1 $18859 $18860 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17435 $17373 $11 $-1 $14408 reversed single T 10 20 -30 20.000000000000004 25 -19.999999999999996 F #
+edge $-1 -1 -1 $-1 $17366 27.499999999999996 $17369 37.500000000000014 $15868 $18861 forward @7 unknown T 7.5 29.330127018922191 -37.500000000000014 7.5000000000000027 29.330127018922202 -27.499999999999996 #
+coedge $-1 -1 -1 $-1 $18811 $15869 $18854 $18862 reversed $17365 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18811 $18863 T 4.9999999999999991 29.330127018922191 -27.5 10 30 -22.500000000000004 unknown #
+vertex $-1 -1 -1 $-1 $17314 $18864 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 30 -25 #
+vertex $-1 -1 -1 $-1 $15873 $18865 #
+coedge $-1 -1 -1 $-1 $18808 $18866 $15874 $17371 reversed $18867 $-1 #
+edge $-1 -1 -1 $-1 $18026 1.0471975511965979 $17374 1.5707963267948966 $15874 $17367 forward @7 unknown T 7.5 20 -27.5 10 20.669872981077809 -25 #
+coedge $-1 -1 -1 $-1 $18038 $15875 $18868 $18859 reversed $17373 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16530 $17362 T 10 20 -30 20.000000000000004 25 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $17371 $18869 #
+edge $-1 -1 -1 $-1 $15879 -17.5 $18048 -7.5000000000000009 $15878 $18870 forward @7 unknown T 22.5 29.330127018922191 7.5000000000000009 22.500000000000007 29.330127018922202 17.5 #
+point $-1 -1 -1 $-1 22.500000000000004 29.330127018922191 17.5 #
+loop $-1 -1 -1 $-1 $-1 $16528 $15881 T 7.5 20 5.0000000000000009 15 25 20 unknown #
+coedge $-1 -1 -1 $-1 $16528 $18835 $15882 $17379 forward $17377 $-1 #
+edge $-1 -1 -1 $-1 $15847 -1.5707963267948966 $17336 0 $17378 $18832 forward @7 unknown T 10 20 15 15 25 20 #
+point $-1 -1 -1 $-1 22.500000000000004 20.669872981077805 17.5 #
+coedge $-1 -1 -1 $-1 $15887 $16542 $18871 $18872 forward $14996 $-1 #
+face $-1 -1 -1 $-1 $11357 $16546 $11 $-1 $5288 reversed single T 29.999999999999996 19.999999999999996 5.0000000000000018 37.500000000000014 25 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $18873 $15888 T 29.999999999999996 19.999999999999996 -9.9999999999999982 37.500000000000014 25 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $18874 $15890 $18875 $18876 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $18877 $18878 $15890 $17386 forward $18879 $-1 #
+edge $-1 -1 -1 $-1 $18880 -2.0943951023931948 $17393 -1.5707963267948966 $17385 $18881 forward @7 unknown T 35 29.330127018922191 -9.9999999999999982 37.5 29.999999999999996 -7.499999999999992 #
+coedge $-1 -1 -1 $-1 $15891 $18874 $15896 $17398 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $18050 $18882 $18883 $17389 forward $18884 $-1 #
+edge $-1 -1 -1 $-1 $17394 -4.9999999999999982 $18885 1.7763568394002505e-15 $17388 $18886 forward @7 unknown T 29.999999999999996 25 -4.9999999999999982 30 25 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $18887 $15892 $18882 $18888 reversed $17392 $-1 #
+coedge $-1 -1 -1 $-1 $15892 $18887 $15923 $17427 forward $17392 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15892 $18889 T 25 25 -15 35 30 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $17427 $18890 #
+vertex $-1 -1 -1 $-1 $18891 $18892 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16470 $15894 $18874 $18893 forward $16471 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18885 6.4931039580273226e-16 $15897 1.5707963267948966 $15896 $18894 forward @7 unknown T 29.999999999999996 25 1.7763568394002505e-15 35 29.999999999999996 5.0000000000000018 #
+point $-1 -1 -1 $-1 35 29.999999999999996 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $18871 $18044 $15899 $17401 reversed $18895 $-1 #
+edge $-1 -1 -1 $-1 $15886 -2.0943951023931957 $15900 -1.5707963267948966 $15899 $18896 forward @7 unknown T 20 20 17.5 22.500000000000004 20.669872981077809 20 #
+edge $-1 -1 -1 $-1 $15900 -1.5707963267948966 $17336 -6.1232339957367648e-17 $16536 $18897 forward @7 unknown T 15 20 15 20 25 20 #
+point $-1 -1 -1 $-1 20 20 20 #
+coedge $-1 -1 -1 $-1 $18898 $17413 $15903 $17405 forward $17415 $-1 #
+edge $-1 -1 -1 $-1 $15910 1.570796326794897 $17407 2.0943951023931957 $17404 $17416 forward @7 unknown T 37.5 20 -24.999999999999996 40.000000000000007 20.669872981077809 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $15904 $18899 $18898 $18900 reversed $15889 $-1 #
+vertex $-1 -1 -1 $-1 $18900 $18901 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $15908 $15908 $17413 $18902 reversed $17410 $-1 #
+loop $-1 -1 -1 $-1 $18903 $15908 $18904 T 39.999999999999993 20 -29.999999999999996 45.000000000000007 30 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 20 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $17404 $15912 $17409 $18902 forward $17415 $-1 #
+coedge $-1 -1 -1 $-1 $15912 $18905 $15915 $17419 forward $17415 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17414 $18906 T 37.499999999999993 20 -24.999999999999996 45 30 -9.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 30 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $15923 $15915 $18877 $18907 reversed $14374 $-1 #
+edge $-1 -1 -1 $-1 $18908 12.500000000000002 $15916 22.499999999999989 $17414 $18909 forward @7 unknown T 37.499999999999993 29.330127018922191 -22.499999999999989 37.500000000000007 29.330127018922195 -12.500000000000002 #
+point $-1 -1 -1 $-1 37.500000000000007 29.330127018922195 -22.499999999999989 #
+face $-1 -1 -1 $-1 $18910 $18911 $11 $-1 $6139 reversed single T 37.499999999999993 20 -9.9999999999999982 45.000000000000007 30 5.0000000000000044 F #
+loop $-1 -1 -1 $-1 $-1 $18883 $15918 T 22.499999999999996 20 -9.9999999999999982 30 25 5.0000000000000036 unknown #
+coedge $-1 -1 -1 $-1 $18912 $15919 $18887 $18913 forward $15921 $-1 #
+coedge $-1 -1 -1 $-1 $15934 $18914 $18060 $15924 reversed $17436 $-1 #
+coedge $-1 -1 -1 $-1 $15920 $18912 $18851 $18915 forward $15921 $-1 #
+face $-1 -1 -1 $-1 $10064 $15921 $11 $-1 $6162 reversed single T 22.5 25 -25 30 30 -9.9999999999999964 F #
+edge $-1 -1 -1 $-1 $17428 6.4931039580273265e-16 $17393 1.5707963267948966 $17391 $18916 forward @7 unknown T 30 25 -15 35 29.999999999999996 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $18913 $18917 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $15928 $18918 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18919 $18920 $11 $-1 $7093 reversed single T 7.5 20 -10 15.000000000000004 25 5.0000000000000009 F #
+coedge $-1 -1 -1 $-1 $18921 $15934 $15932 $17434 forward $17436 $-1 #
+edge $-1 -1 -1 $-1 $14420 1.5707963267948961 $18922 2.0943951023931957 $17433 $17431 forward @7 unknown T 22.499999999999993 20 -25.000000000000004 25 20.669872981077809 -22.499999999999996 #
+face $-1 -1 -1 $-1 $15929 $15933 $11 $-1 $14408 reversed single T 19.999999999999996 20 -27.500000000000004 25 20.669872981077809 -22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $17424 $18923 T 22.499999999999993 20 -25.000000000000004 30 25 -9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $18924 $15968 $15936 $17438 reversed $17469 $-1 #
+edge $-1 -1 -1 $-1 $15989 1.5707963267948966 $15970 2.0943951023931957 $15936 $15979 forward @7 unknown T -37.5 5 35 -35 5.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $15937 $15940 $18925 $18926 forward $15941 $-1 #
+coedge $-1 -1 -1 $-1 $17480 $15938 $18927 $17532 forward $17441 $-1 #
+loop $-1 -1 -1 $-1 $-1 $15938 $16003 T -35 5 30 -25 10 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14476 $15941 $11 $-1 $7181 reversed single T -25 5 32.5 -20 5.6698729810778099 37.5 F #
+coedge $-1 -1 -1 $-1 $15942 $16043 $14483 $16004 forward $15964 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16564 $15943 T -15 5 -40 -7.4999999999999991 10 -25 unknown #
+coedge $-1 -1 -1 $-1 $18110 $18928 $18104 $18929 reversed $15944 $-1 #
+edge $-1 -1 -1 $-1 $14514 6.1232339957367648e-17 $17614 1.5707963267948966 $16622 $18930 forward @7 unknown T 0 4.9999999999999991 20 5.0000000000000009 10 25 #
+loop $-1 -1 -1 $-1 $15012 $18931 $1558 T 50 5 -29.999999999999996 50 15 -19.999999999999996 hole $1559 T #
+coedge $-1 -1 -1 $-1 $17449 $17449 $18932 $18933 forward $15951 $-1 #
+coedge $-1 -1 -1 $-1 $17450 $17450 $15952 $17451 reversed $17542 $-1 #
+edge $-1 -1 -1 $-1 $18934 0 $18934 6.2831853071795862 $15952 $18935 forward @7 unknown T 50 5 2.6645352591003757e-15 50 15 10.000000000000004 #
+loop $-1 -1 -1 $-1 $18936 $15953 $3147 T -50 5 29.999999999999996 -50 15 40 hole $3148 T #
+vertex $-1 -1 -1 $-1 $15954 $18937 #
+ellipse-curve $-1 -1 -1 $-1 -50 10 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $17462 $15957 $18938 $18939 reversed $15959 $-1 #
+coedge $-1 -1 -1 $-1 $15968 $18924 $15957 $17458 forward $17469 $-1 #
+edge $-1 -1 -1 $-1 $18940 -2.0943951023931948 $15960 -1.5707963267948966 $17457 $18941 forward @7 unknown T -40 5.0000000000000018 32.5 -37.5 5.6698729810778081 35 #
+coedge $-1 -1 -1 $-1 $15958 $18942 $18943 $18944 reversed $15959 $-1 #
+coedge $-1 -1 -1 $-1 $15976 $15972 $15958 $17461 forward $15977 $-1 #
+edge $-1 -1 -1 $-1 $15961 1.5707963267948966 $18945 2.0943951023931953 $17460 $18946 forward @7 unknown T -40 14.330127018922193 32.5 -37.5 15.000000000000002 35 #
+coedge $-1 -1 -1 $-1 $17545 $17456 $18947 $18948 reversed $15959 $-1 #
+face $-1 -1 -1 $-1 $14454 $15959 $11 $-1 $15975 reversed single T -45 5.0000000000000018 19.999999999999996 -37.5 15.000000000000002 35 F #
+point $-1 -1 -1 $-1 -40 5.0000000000000018 35 #
+point $-1 -1 -1 $-1 -40 15.000000000000002 35 #
+face $-1 -1 -1 $-1 $11491 $15964 $11 $-1 $10247 reversed single T -15 5 20 -7.4999999999999991 10 35 F #
+vertex $-1 -1 -1 $-1 $18166 $18949 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $15968 $15984 T -40 5 32.5 -35 5.6698729810778099 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 5.6698729810778081 37.5 #
+face $-1 -1 -1 $-1 $12955 $18950 $11 $-1 $15975 reversed single T -45 5.0000000000000018 -40 -37.499999999999993 15.000000000000002 -25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $18943 $17478 $15976 $17475 forward $15985 $-1 #
+edge $-1 -1 -1 $-1 $15978 -1.5707963267948966 $18945 -1.0471975511965974 $17474 $18951 forward @7 unknown T -37.5 14.330127018922191 32.5 -35 15 35 #
+face $-1 -1 -1 $-1 $18952 $15977 $11 $-1 $7181 reversed single T -40 14.330127018922191 32.5 -35 15.000000000000002 37.5 F #
+point $-1 -1 -1 $-1 -35 15 35 #
+coedge $-1 -1 -1 $-1 $17474 $17481 $15981 $17479 forward $15985 $-1 #
+edge $-1 -1 -1 $-1 $17484 0 $15978 1.5707963267948966 $17478 $18953 forward @7 unknown T -35 10 30 -30 15 35 #
+coedge $-1 -1 -1 $-1 $15983 $17440 $18954 $18955 reversed $17441 $-1 #
+coedge $-1 -1 -1 $-1 $17478 $18956 $18957 $18958 forward $15985 $-1 #
+coedge $-1 -1 -1 $-1 $18959 $15986 $17481 $18958 reversed $17483 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18959 $18326 T -30 10 20 -22.499999999999993 15.000000000000002 35 unknown #
+vertex $-1 -1 -1 $-1 $17479 $18960 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18940 1.0471975511965974 $15989 1.5707963267948966 $18961 $18951 forward @7 unknown T -37.5 5 32.5 -35 5.669872981077809 35 #
+point $-1 -1 -1 $-1 -35 5 35 #
+coedge $-1 -1 -1 $-1 $15990 $18962 $15995 $17494 reversed $17483 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $18963 $15992 T -30.000000000000007 5.0000000000000018 -40 -22.5 10 -25 unknown #
+coedge $-1 -1 -1 $-1 $18964 $18965 $18966 $18967 reversed $15993 $-1 #
+coedge $-1 -1 -1 $-1 $16583 $15994 $16563 $18075 reversed $14473 $-1 #
+coedge $-1 -1 -1 $-1 $17498 $15995 $18968 $18969 forward $14482 $-1 #
+edge $-1 -1 -1 $-1 $15996 -32.5 $18970 -22.499999999999993 $15995 $18971 forward @7 unknown T -22.500000000000004 14.330127018922193 22.499999999999993 -22.499999999999993 14.330127018922195 32.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 14.330127018922193 32.5 #
+face $-1 -1 -1 $-1 $18972 $18973 $11 $-1 $11541 reversed single T -22.500000000000004 10 4.9999999999999991 -15 15 20 F #
+loop $-1 -1 -1 $-1 $-1 $18957 $15998 T -37.500000000000007 5 19.999999999999993 -29.999999999999993 10 35 unknown #
+coedge $-1 -1 -1 $-1 $15999 $17493 $16018 $17526 forward $14482 $-1 #
+coedge $-1 -1 -1 $-1 $18974 $16001 $17444 $16004 reversed $17500 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17499 $16006 T -22.5 5 20 -15 10 35 unknown #
+straight-curve $-1 -1 -1 $-1 -15 10 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $17528 $17523 $11 $-1 $10259 reversed single T -10 14.330127018922191 17.5 -5 15 22.499999999999996 F #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778081 32.5 #
+coedge $-1 -1 -1 $-1 $16008 $18975 $18976 $18977 forward $17500 $-1 #
+face $-1 -1 -1 $-1 $18978 $18979 $11 $-1 $10247 reversed single T -15 4.9999999999999991 -10 -7.4999999999999991 10 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $18980 $16009 T -15.000000000000004 5 -25 -7.4999999999999991 10 -10 unknown #
+coedge $-1 -1 -1 $-1 $18981 $18982 $18983 $18984 reversed $16010 $-1 #
+coedge $-1 -1 -1 $-1 $16011 $18985 $18986 $18987 reversed $14492 $-1 #
+edge $-1 -1 -1 $-1 $18128 -1.5707963267948966 $18988 6.1232339957367648e-17 $16611 $18989 forward @7 unknown T -15 10 -10 -10 15 -5 #
+coedge $-1 -1 -1 $-1 $18990 $16012 $18991 $18992 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $18993 $18994 $16012 $17512 forward $18995 $-1 #
+edge $-1 -1 -1 $-1 $18996 -2.0943951023931957 $17519 -1.5707963267948966 $17511 $18997 forward @7 unknown T -10 14.330127018922191 4.9999999999999991 -7.4999999999999991 15 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $16013 $18990 $16019 $17527 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $18998 $18999 $19000 $17515 forward $18973 $-1 #
+edge $-1 -1 -1 $-1 $17520 10 $19001 15 $17514 $19002 forward @7 unknown T -15 10 10 -15 10 15 #
+coedge $-1 -1 -1 $-1 $19003 $16014 $18999 $19004 reversed $17518 $-1 #
+coedge $-1 -1 -1 $-1 $16014 $19003 $18985 $19005 forward $17518 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16014 $19006 T -20 10 -1.7763568394002505e-15 -10 15 10 unknown #
+vertex $-1 -1 -1 $-1 $19005 $19007 #
+vertex $-1 -1 -1 $-1 $19008 $19009 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17534 $16016 $18990 $19010 forward $17523 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16016 $17502 T -10 14.330127018922191 17.5 -5 15 22.499999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16019 $16018 $18998 $19011 reversed $16020 $-1 #
+edge $-1 -1 -1 $-1 $19012 1.5707963267948966 $16022 3.1415926535897931 $17498 $19013 forward @7 unknown T -20 10 20 -15 15 25 #
+edge $-1 -1 -1 $-1 $19001 -6.1232339957367648e-17 $16021 1.5707963267948966 $16019 $19014 forward @7 unknown T -15 10 15 -10 15 20 #
+face $-1 -1 -1 $-1 $19015 $16020 $11 $-1 $10259 reversed single T -20 10 15 -10 15 25 F #
+point $-1 -1 -1 $-1 -10 15 20 #
+edge $-1 -1 -1 $-1 $16022 3.1415926535897931 $19016 4.7123889803846897 $18974 $19013 forward @7 unknown T -20 5 20 -15 10 25 #
+point $-1 -1 -1 $-1 -15 10 25 #
+edge $-1 -1 -1 $-1 $16024 -1.5707963267948966 $17484 -4.1650370783741769e-16 $17440 $19017 forward @7 unknown T -30 5.0000000000000018 30 -25 10 35 #
+point $-1 -1 -1 $-1 -25 5.0000000000000018 35 #
+coedge $-1 -1 -1 $-1 $16026 $17522 $19018 $19019 reversed $17523 $-1 #
+vertex $-1 -1 -1 $-1 $19019 $19020 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999982 14.330127018922193 22.499999999999996 #
+coedge $-1 -1 -1 $-1 $16049 $16030 $19021 $19022 reversed $13517 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19023 $19024 $11 $-1 $12076 reversed single T -50 5 -3.5527136788005009e-15 -40 15.000000000000004 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $19025 $16032 T -10 4.9999999999999991 2.4999999999999987 -5 5.669872981077809 7.5000000000000009 unknown #
+loop $-1 -1 -1 $-1 $-1 $17450 $14503 T 50 5 2.6645352591003757e-15 50 15 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $17543 $17543 $16034 $17544 forward $18936 $-1 #
+edge $-1 -1 -1 $-1 $19026 0 $19026 6.2831853071795862 $17543 $19027 forward @7 unknown T -50 5 14.999999999999996 -50 15 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $18942 $17462 $16035 $17546 reversed $15959 $-1 #
+edge $-1 -1 -1 $-1 $17551 -1.5707963267948966 $17550 1.5707963267948966 $16035 $19028 forward @7 unknown T -45 5.0000000000000018 19.999999999999996 -40 15.000000000000002 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $19029 $16036 $19030 $19031 reversed $17549 $-1 #
+coedge $-1 -1 -1 $-1 $16036 $19032 $19033 $19034 reversed $17549 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19035 $19036 T -45 5.0000000000000009 4.9999999999999973 -37.5 15.000000000000004 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $16037 $19037 #
+vertex $-1 -1 -1 $-1 $16037 $19038 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19039 $19040 $16038 $17554 forward $19041 $-1 #
+edge $-1 -1 -1 $-1 $17559 1.0471975511965974 $17555 1.5707963267948966 $17553 $19042 forward @7 unknown T -7.5000000000000009 5 17.5 -5 5.669872981077809 20 #
+vertex $-1 -1 -1 $-1 $17554 $19043 #
+coedge $-1 -1 -1 $-1 $19044 $16041 $19040 $19045 reversed $17558 $-1 #
+coedge $-1 -1 -1 $-1 $16041 $19046 $19047 $17563 reversed $17558 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19044 $18978 T -15 4.9999999999999991 4.9999999999999991 -7.4999999999999991 10 20 unknown #
+vertex $-1 -1 -1 $-1 $17554 $19048 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19047 $19049 $16043 $17562 forward $19050 $-1 #
+edge $-1 -1 -1 $-1 $16022 6.1232339957367648e-17 $16044 1.5707963267948966 $17561 $19051 forward @7 unknown T -15 5 20 -10 10 25 #
+edge $-1 -1 -1 $-1 $16044 -1.5707963267948966 $19001 -6.1232339957367648e-17 $19047 $19052 forward @7 unknown T -15 5 15 -10 10 20 #
+point $-1 -1 -1 $-1 -10 5 20 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 22.500000000000004 #
+point $-1 -1 -1 $-1 50 10 15.000000000000004 #
+coedge $-1 -1 -1 $-1 $19053 $17574 $16049 $17568 reversed $16055 $-1 #
+edge $-1 -1 -1 $-1 $19054 -6.1232339957367648e-17 $16050 1.5707963267948966 $16049 $19055 forward @7 unknown T 0 10 15 5.0000000000000009 15 20 #
+point $-1 -1 -1 $-1 5.0000000000000009 15 20 #
+face $-1 -1 -1 $-1 $19056 $19057 $11 $-1 $8101 reversed single T 0 10 -25 7.5000000000000018 15 -10 F #
+loop $-1 -1 -1 $-1 $-1 $19058 $16054 T 0 10 -10 7.5000000000000009 15 5 unknown #
+coedge $-1 -1 -1 $-1 $19059 $19053 $18135 $19060 reversed $16055 $-1 #
+straight-curve $-1 -1 -1 $-1 -7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17567 $19061 $16057 $17575 reversed $16055 $-1 #
+edge $-1 -1 -1 $-1 $16050 1.5707963267948966 $17596 2.0943951023931948 $16057 $19062 forward @7 unknown T 5.0000000000000009 14.330127018922195 17.500000000000004 7.5000000000000027 15 20 #
+coedge $-1 -1 -1 $-1 $19063 $16120 $16059 $17577 forward $17635 $-1 #
+edge $-1 -1 -1 $-1 $16618 -2.0943951023931957 $19064 -1.5707963267948966 $17576 $19065 forward @7 unknown T 5.0000000000000009 4.9999999999999991 -27.5 7.5000000000000018 5.6698729810778072 -25 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -40 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16063 $16114 $19066 $19067 forward $16115 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16066 $16065 $19068 $19069 reversed $16067 $-1 #
+coedge $-1 -1 -1 $-1 $19066 $19070 $16065 $17583 reversed $19057 $-1 #
+edge $-1 -1 -1 $-1 $16068 -1.5707963267948966 $19071 6.1232339957367648e-17 $16065 $19072 forward @7 unknown T 0 10 -25 5.0000000000000009 15 -20 #
+face $-1 -1 -1 $-1 $19073 $16067 $11 $-1 $13102 reversed single T -5 10 -30 5.0000000000000009 15 -20 F #
+point $-1 -1 -1 $-1 5.0000000000000009 15 -25 #
+coedge $-1 -1 -1 $-1 $16072 $16070 $19074 $19075 forward $14530 $-1 #
+coedge $-1 -1 -1 $-1 $19076 $19077 $16070 $17588 reversed $19078 $-1 #
+edge $-1 -1 -1 $-1 $17589 -1.5707963267948966 $19079 -1.0471975511965979 $16070 $19080 forward @7 unknown T -7.5 14.330127018922191 -27.5 -5 15 -25 #
+vertex $-1 -1 -1 $-1 $17588 $19081 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19082 4.1887902047863914 $13507 4.7123889803846897 $16072 $16607 forward @7 unknown T -7.4999999999999982 14.330127018922193 -40 -5 15 -37.5 #
+coedge $-1 -1 -1 $-1 $16074 $16605 $19083 $19084 forward $16075 $-1 #
+coedge $-1 -1 -1 $-1 $19085 $18130 $16074 $17594 reversed $19086 $-1 #
+edge $-1 -1 -1 $-1 $19087 -1.5707963267948966 $14532 0 $16074 $17590 forward @7 unknown T -5 5 -30 0 10 -25 #
+coedge $-1 -1 -1 $-1 $16623 $16079 $19061 $19088 forward $12053 $-1 #
+vertex $-1 -1 -1 $-1 $19088 $19089 #
+ellipse-curve $-1 -1 -1 $-1 10 10 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $14578 $19041 $11 $-1 $8113 reversed single T -7.5000000000000009 5 5 8.8817841970012523e-16 10 20 F #
+coedge $-1 -1 -1 $-1 $16083 $18136 $19039 $19090 reversed $15076 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 10 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 15 10 15 #
+vertex $-1 -1 -1 $-1 $16088 $19091 #
+coedge $-1 -1 -1 $-1 $16128 $19092 $16095 $16088 forward $16127 $-1 #
+face $-1 -1 -1 $-1 $19093 $19094 $11 $-1 $6219 reversed single T 15 4.9999999999999973 -9.9999999999999982 22.500000000000007 10 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $17616 $16090 T 15 4.9999999999999982 -25 22.500000000000004 10 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $19095 $16092 $19096 $19097 reversed $14550 $-1 #
+coedge $-1 -1 -1 $-1 $16092 $18152 $19098 $19099 reversed $14550 $-1 #
+coedge $-1 -1 -1 $-1 $19100 $19101 $16092 $17609 forward $19102 $-1 #
+edge $-1 -1 -1 $-1 $19103 -1.5707963267948966 $19104 -2.9403902792268244e-16 $17608 $19105 forward @7 unknown T 15 10 -9.9999999999999982 20 14.999999999999998 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $16640 -2.0943951023931948 $17611 -1.5707963267948966 $16637 $19106 forward @7 unknown T 20 14.330127018922193 5.0000000000000009 22.500000000000004 14.999999999999998 7.5000000000000009 #
+vertex $-1 -1 -1 $-1 $18153 $19107 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $16096 $16095 $19108 $19109 forward $16097 $-1 #
+vertex $-1 -1 -1 $-1 $19110 $19111 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18147 $19112 $16102 $17617 reversed $17605 $-1 #
+edge $-1 -1 -1 $-1 $16103 1.5707963267948961 $17690 2.0943951023931948 $16102 $19113 forward @7 unknown T 19.999999999999996 4.9999999999999982 -25 22.5 5.6698729810778055 -22.5 #
+point $-1 -1 -1 $-1 20 4.9999999999999982 -25 #
+coedge $-1 -1 -1 $-1 $19114 $16105 $16175 $17683 reversed $16091 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19115 $16107 $19116 $17626 forward $17623 $-1 #
+coedge $-1 -1 -1 $-1 $16107 $19117 $16114 $17630 forward $17623 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17621 $19118 T 7.5 10 -25 15 15 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 10 10 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16109 $19114 $19101 $19119 reversed $16091 $-1 #
+edge $-1 -1 -1 $-1 $16110 -20 $19120 -15 $17621 $19121 forward @7 unknown T 15 10 -20 15 10 -15 #
+edge $-1 -1 -1 $-1 $16110 3.1415926535897931 $16124 4.7123889803846897 $17636 $17624 forward @7 unknown T 10 5 -25 15 10 -20 #
+point $-1 -1 -1 $-1 15 10 -20 #
+straight-curve $-1 -1 -1 $-1 7.5 14.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $19122 4.1887902047863914 $14572 4.7123889803846897 $17622 $19123 forward @7 unknown T 7.5000000000000009 14.330127018922195 -25 10 15 -22.500000000000004 #
+face $-1 -1 -1 $-1 $19124 $16115 $11 $-1 $13102 reversed single T 5.0000000000000009 14.330127018922191 -27.500000000000004 10 15 -22.500000000000004 F #
+point $-1 -1 -1 $-1 7.5000000000000027 14.330127018922195 -27.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000009 14.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $16120 $19063 $19125 $19126 reversed $17635 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17576 $19127 T 5.0000000000000009 4.9999999999999991 -27.5 10 5.6698729810778081 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $19125 $19116 $16122 $17627 forward $19128 $-1 #
+point $-1 -1 -1 $-1 10 5 -25 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $19129 $16150 $16131 $17640 reversed $17663 $-1 #
+edge $-1 -1 -1 $-1 $18161 7.4999999999999991 $14587 17.5 $16131 $19130 forward @7 unknown T 22.5 5.6698729810778064 7.4999999999999991 22.500000000000004 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $19131 $19132 $19133 $19134 reversed $16133 $-1 #
+coedge $-1 -1 -1 $-1 $16137 $16134 $16146 $17661 reversed $11622 $-1 #
+coedge $-1 -1 -1 $-1 $19135 $16571 $16134 $17644 forward $17679 $-1 #
+edge $-1 -1 -1 $-1 $18083 -2.5000000000000053 $17648 7.4999999999999947 $17643 $19136 forward @7 unknown T 37.5 14.330127018922195 -7.4999999999999947 37.5 14.330127018922195 2.5000000000000053 #
+coedge $-1 -1 -1 $-1 $19137 $16135 $16168 $17675 forward $17647 $-1 #
+coedge $-1 -1 -1 $-1 $16135 $19137 $19135 $19138 reversed $17647 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17645 $19139 T 35 14.330127018922189 -12.500000000000002 40 15 -7.4999999999999947 unknown #
+vertex $-1 -1 -1 $-1 $19138 $19140 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16138 $19141 $16140 $17656 forward $17652 $-1 #
+coedge $-1 -1 -1 $-1 $19142 $18162 $19143 $16139 reversed $16172 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16138 $17687 T 22.499999999999996 10 -9.9999999999999982 30 15 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $16643 $19144 #
+straight-curve $-1 -1 -1 $-1 30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16141 $16140 $16173 $17681 reversed $16142 $-1 #
+edge $-1 -1 -1 $-1 $19145 1.570796326794897 $16144 3.1415926535897931 $17650 $19146 forward @7 unknown T 25 10 -9.9999999999999982 29.999999999999996 15 -4.9999999999999982 #
+face $-1 -1 -1 $-1 $16176 $16142 $11 $-1 $13497 reversed single T 25 10 -15 35 15 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 14.999999999999998 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $16144 3.1415926535897931 $19147 4.7123889803846897 $19142 $19146 forward @7 unknown T 24.999999999999996 5 -9.9999999999999982 29.999999999999996 10 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 10 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $14598 1.5707963267948966 $18083 2.0943951023931948 $16146 $19148 forward @7 unknown T 35 14.330127018922193 2.5000000000000053 37.5 15 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $19129 $19093 T 14.999999999999996 4.9999999999999973 5.0000000000000009 22.500000000000004 10 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19149 $16154 $16156 $17668 forward $16165 $-1 #
+coedge $-1 -1 -1 $-1 $16156 $18169 $19150 $19151 reversed $14590 $-1 #
+edge $-1 -1 -1 $-1 $16157 -22.499999999999989 $19152 -12.5 $17666 $19153 forward @7 unknown T 37.5 5.6698729810778064 -22.499999999999989 37.500000000000007 5.6698729810778081 -12.5 #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778081 -22.499999999999989 #
+edge $-1 -1 -1 $-1 $14615 1.570796326794897 $14611 4.7123889803846897 $16163 $19154 forward @7 unknown T 39.999999999999993 5 -24.999999999999996 44.999999999999993 15 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $19155 $17672 T 50 5 -29.999999999999996 50 15 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $19156 $16160 $11 $-1 $13102 reversed single T 39.999999999999993 5 -29.999999999999996 50 15 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $16164 $19157 $19137 $19158 forward $16165 $-1 #
+face $-1 -1 -1 $-1 $10665 $16165 $11 $-1 $5306 reversed single T 37.499999999999993 5 -24.999999999999996 45 15 -9.9999999999999982 F #
+edge $-1 -1 -1 $-1 $16143 1.5707963267948966 $17676 2.0943951023931957 $17645 $19159 forward @7 unknown T 35 14.330127018922189 -12.500000000000002 37.5 14.999999999999998 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $17675 $19160 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $19161 $19162 $11 $-1 $13497 reversed single T 35 4.9999999999999982 -12.500000000000004 40 5.669872981077809 -7.5000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $17643 $16171 T 37.5 4.9999999999999991 -9.9999999999999982 45.000000000000007 15 5.0000000000000044 unknown #
+coedge $-1 -1 -1 $-1 $16175 $16173 $19163 $19164 forward $14622 $-1 #
+edge $-1 -1 -1 $-1 $16178 0 $19145 1.5707963267948966 $16173 $19165 forward @7 unknown T 25 10 -14.999999999999998 30 15 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $16174 $19166 $19167 $19168 forward $16186 $-1 #
+edge $-1 -1 -1 $-1 $19169 12.499999999999995 $16180 22.500000000000004 $16175 $19170 forward @7 unknown T 22.499999999999996 14.330127018922191 -22.500000000000004 22.5 14.330127018922195 -12.499999999999995 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 30 10 -14.999999999999998 #
+point $-1 -1 -1 $-1 22.499999999999996 14.330127018922193 -22.500000000000004 #
+face $-1 -1 -1 $-1 $19171 $17652 $11 $-1 $5329 reversed single T 22.499999999999996 10 -9.9999999999999982 30 15 5.0000000000000036 F #
+loop $-1 -1 -1 $-1 $-1 $19172 $16182 T 7.4999999999999991 4.9999999999999991 -10 15.000000000000004 10 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $19166 $16183 $19112 $19173 forward $16186 $-1 #
+vertex $-1 -1 -1 $-1 $19173 $19174 #
+face $-1 -1 -1 $-1 $17674 $16186 $11 $-1 $5329 reversed single T 22.5 4.9999999999999991 -25.000000000000004 30 10 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $16200 $16187 $17721 $16227 reversed $16210 $-1 #
+coedge $-1 -1 -1 $-1 $17736 $17695 $16189 $17694 reversed $19175 $-1 #
+edge $-1 -1 -1 $-1 $14701 -2.0943951023931953 $14718 -1.5707963267948966 $16189 $19176 forward @7 unknown T -25 -9.9999999999999982 32.5 -22.5 -9.330127018922191 35 #
+coedge $-1 -1 -1 $-1 $17693 $19177 $16190 $16273 reversed $19175 $-1 #
+coedge $-1 -1 -1 $-1 $16196 $19178 $19179 $19180 reversed $14645 $-1 #
+edge $-1 -1 -1 $-1 $16691 -35 $19181 -30 $16689 $19182 forward @7 unknown T -15 -5 -35 -15 -4.9999999999999991 -30 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17721 $19183 $16199 $17700 forward $16238 $-1 #
+edge $-1 -1 -1 $-1 $19184 22.5 $17701 32.5 $17699 $19185 forward @7 unknown T -37.500000000000007 -9.3301270189221945 22.5 -37.5 -9.330127018922191 32.5 #
+vertex $-1 -1 -1 $-1 $16227 $19186 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 35 -0.70710678118654768 -0 -0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $16202 $16283 $19187 $19188 reversed $14654 $-1 #
+coedge $-1 -1 -1 $-1 $19189 $16215 $16202 $17705 forward $14679 $-1 #
+edge $-1 -1 -1 $-1 $17706 -32.500000000000007 $19190 -22.499999999999989 $17704 $19191 forward @7 unknown T -37.500000000000007 -0.66987298107780635 22.499999999999989 -37.5 -0.66987298107780424 32.500000000000007 #
+vertex $-1 -1 -1 $-1 $17705 $19192 #
+coedge $-1 -1 -1 $-1 $19193 $17788 $16205 $17709 forward $19194 $-1 #
+edge $-1 -1 -1 $-1 $16288 1.5707963267948966 $19184 2.0943951023931948 $17708 $19195 forward @7 unknown T -40 -9.9999999999999964 19.999999999999996 -37.5 -9.330127018922191 22.5 #
+loop $-1 -1 -1 $-1 $-1 $19196 $16214 T -45 -9.9999999999999964 -40 -37.499999999999993 2.6645352591003757e-15 -25.000000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19197 $19198 $11 $-1 $9738 reversed single T -37.5 -5 4.9999999999999982 -30 0 19.999999999999996 F #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17717 $17721 $16221 $17715 forward $16238 $-1 #
+edge $-1 -1 -1 $-1 $14683 -1.5707963267948966 $16225 0 $17714 $17713 forward @7 unknown T -35 -10 30 -30 -5 35 #
+coedge $-1 -1 -1 $-1 $16222 $19189 $19199 $19200 forward $14679 $-1 #
+coedge $-1 -1 -1 $-1 $19201 $17714 $19177 $17718 reversed $16238 $-1 #
+edge $-1 -1 -1 $-1 $19202 24.999999999999996 $16225 30 $16222 $19203 forward @7 unknown T -30 -5 24.999999999999996 -29.999999999999993 -4.9999999999999991 30 #
+coedge $-1 -1 -1 $-1 $17722 $16223 $19204 $19205 reversed $16224 $-1 #
+point $-1 -1 -1 $-1 -30 -5 30 #
+coedge $-1 -1 -1 $-1 $17714 $17699 $17692 $16227 forward $16238 $-1 #
+coedge $-1 -1 -1 $-1 $16229 $17719 $19206 $19207 reversed $16224 $-1 #
+coedge $-1 -1 -1 $-1 $18194 $19208 $16681 $18200 reversed $16231 $-1 #
+coedge $-1 -1 -1 $-1 $18183 $16232 $18197 $19209 reversed $14687 $-1 #
+coedge $-1 -1 -1 $-1 $16232 $19210 $19211 $19212 reversed $14687 $-1 #
+coedge $-1 -1 -1 $-1 $19213 $19214 $18318 $17727 forward $19215 $-1 #
+edge $-1 -1 -1 $-1 $18320 -35 $19216 -30.000000000000004 $17726 $19217 forward @7 unknown T -30.000000000000007 -5 -35 -30 -4.9999999999999991 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $19206 $19218 $16234 $17729 reversed $19219 $-1 #
+edge $-1 -1 -1 $-1 $17730 4.1887902047863914 $17772 4.7123889803846897 $16234 $19220 forward @7 unknown T -22.5 -0.66987298107780657 20 -20 0 22.5 #
+vertex $-1 -1 -1 $-1 $17729 $19221 #
+straight-curve $-1 -1 -1 $-1 -22.5 -0.66987298107780546 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $19222 $19223 $11 $-1 $8848 reversed single T -35 -5 14.999999999999996 -25 1.7763568394002505e-15 25 F #
+loop $-1 -1 -1 $-1 $-1 $16255 $16237 T -22.500000000000004 -5 4.9999999999999991 -15 8.8817841970012523e-16 20 unknown #
+coedge $-1 -1 -1 $-1 $17735 $16240 $17807 $16271 forward $16241 $-1 #
+coedge $-1 -1 -1 $-1 $16245 $17734 $19224 $19225 forward $16241 $-1 #
+coedge $-1 -1 -1 $-1 $19226 $17693 $16245 $17737 reversed $19175 $-1 #
+edge $-1 -1 -1 $-1 $19227 22.5 $14701 32.5 $16245 $19228 forward @7 unknown T -22.5 -9.3301270189221945 22.5 -22.5 -9.3301270189221928 32.5 #
+face $-1 -1 -1 $-1 $16209 $16296 $11 $-1 $9224 reversed single T -15 -10 4.9999999999999991 -7.4999999999999991 -4.9999999999999991 20 F #
+loop $-1 -1 -1 $-1 $-1 $19229 $16246 T -15 -10 -10 -7.5000000000000009 -4.9999999999999991 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $19230 $19231 $19232 $19233 reversed $16247 $-1 #
+coedge $-1 -1 -1 $-1 $18228 $16248 $19234 $19235 reversed $14704 $-1 #
+coedge $-1 -1 -1 $-1 $16248 $18224 $19236 $19237 reversed $14704 $-1 #
+coedge $-1 -1 -1 $-1 $19238 $19179 $16248 $17744 forward $19239 $-1 #
+edge $-1 -1 -1 $-1 $19240 -1.570796326794897 $19241 6.1232339957367648e-17 $17743 $19242 forward @7 unknown T -15 -4.9999999999999991 -25 -9.9999999999999982 8.8817841970012523e-16 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $16249 $18236 $16258 $17765 reversed $13180 $-1 #
+coedge $-1 -1 -1 $-1 $19243 $18222 $19244 $17747 forward $19245 $-1 #
+edge $-1 -1 -1 $-1 $17748 -5.0000000000000018 $19246 -8.8817841970012523e-16 $17746 $19247 forward @7 unknown T -15 -5 -5.0000000000000018 -14.999999999999996 -4.9999999999999991 -8.8817841970012523e-16 #
+vertex $-1 -1 -1 $-1 $19248 $19249 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16254 $16251 $16263 $17770 reversed $11725 $-1 #
+coedge $-1 -1 -1 $-1 $19250 $17778 $16251 $17752 forward $19251 $-1 #
+edge $-1 -1 -1 $-1 $19252 -17.5 $17756 -7.4999999999999991 $17751 $19253 forward @7 unknown T -7.5 -0.66987298107780746 7.4999999999999991 -7.4999999999999991 -0.66987298107780635 17.5 #
+coedge $-1 -1 -1 $-1 $19254 $16252 $18236 $19255 forward $17755 $-1 #
+coedge $-1 -1 -1 $-1 $16252 $19254 $19250 $19256 reversed $17755 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16252 $19257 T -10 -0.66987298107780813 2.5000000000000004 -5 1.7763568394002505e-15 7.4999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $19256 $19258 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19259 $16255 $16266 $17771 forward $17733 $-1 #
+coedge $-1 -1 -1 $-1 $16255 $19260 $16257 $17764 forward $17733 $-1 #
+coedge $-1 -1 -1 $-1 $19261 $19262 $17804 $16256 reversed $19263 $-1 #
+vertex $-1 -1 -1 $-1 $17771 $19264 #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16258 $16257 $19243 $19265 reversed $16259 $-1 #
+edge $-1 -1 -1 $-1 $19266 1.5707963267948966 $16261 3.1415926535897931 $17759 $19267 forward @7 unknown T -20 -4.9999999999999991 4.9999999999999991 -15 8.8817841970012523e-16 10 #
+edge $-1 -1 -1 $-1 $19246 -2.3886802389739268e-16 $16260 1.5707963267948966 $16258 $19268 forward @7 unknown T -15 -5 -1.7763568394002505e-15 -10 8.8817841970012523e-16 4.9999999999999991 #
+face $-1 -1 -1 $-1 $19269 $16259 $11 $-1 $9956 reversed single T -20 -5 -1.7763568394002505e-15 -10 1.7763568394002505e-15 10 F #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $16261 3.1415926535897931 $19270 4.7123889803846897 $19261 $19267 forward @7 unknown T -20 -10 4.9999999999999991 -15 -4.9999999999999991 10 #
+point $-1 -1 -1 $-1 -15 -4.9999999999999991 10 #
+edge $-1 -1 -1 $-1 $14715 1.5707963267948966 $19252 2.0943951023931957 $16263 $19271 forward @7 unknown T -10 -0.66987298107780813 17.5 -7.4999999999999991 8.8817841970012523e-16 20 #
+edge $-1 -1 -1 $-1 $17761 0 $17772 1.5707963267948966 $17758 $19272 forward @7 unknown T -20 -5 15 -15 0 20 #
+vertex $-1 -1 -1 $-1 $19273 $19274 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19275 $17808 $11 $-1 $8848 reversed single T -20 -10 15 -10 -4.9999999999999991 25 F #
+vertex $-1 -1 -1 $-1 $19276 $19277 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17751 $17781 $16275 $17779 forward $19251 $-1 #
+edge $-1 -1 -1 $-1 $16276 -1.5707963267948966 $19252 -1.0471975511965974 $17778 $17800 forward @7 unknown T -7.5000000000000009 -0.66987298107780902 17.5 -5 0 20 #
+point $-1 -1 -1 $-1 -5 0 20 #
+coedge $-1 -1 -1 $-1 $17778 $18372 $16279 $17782 forward $19251 $-1 #
+edge $-1 -1 -1 $-1 $17811 0 $16276 1.5707963267948966 $17781 $19278 forward @7 unknown T -5 -5 15 0 0 20 #
+face $-1 -1 -1 $-1 $16886 $19251 $11 $-1 $7251 reversed single T -7.5000000000000009 -5 5 0 0 20 F #
+loop $-1 -1 -1 $-1 $18283 $19279 $16281 T -45 -9.9999999999999982 -3.5527136788005009e-15 -40 3.5527136788005009e-15 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $19280 $19281 $17802 $19282 forward $16282 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 19.999999999999996 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17793 $16285 $19283 $19284 reversed $16287 $-1 #
+coedge $-1 -1 -1 $-1 $17708 $19285 $16285 $17789 forward $19194 $-1 #
+edge $-1 -1 -1 $-1 $19286 -2.0943951023931957 $16288 -1.5707963267948966 $17788 $19287 forward @7 unknown T -40 -9.9999999999999964 17.499999999999989 -37.5 -9.3301270189221892 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $16286 $19288 $19289 $19290 reversed $16287 $-1 #
+coedge $-1 -1 -1 $-1 $19291 $19187 $16286 $17792 forward $19292 $-1 #
+edge $-1 -1 -1 $-1 $16289 1.5707963267948966 $19293 2.0943951023931957 $17791 $19294 forward @7 unknown T -40 -0.66987298107780724 17.499999999999996 -37.499999999999993 2.6645352591003757e-15 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $19295 $17787 $19296 $19297 reversed $16287 $-1 #
+face $-1 -1 -1 $-1 $16206 $16287 $11 $-1 $14669 reversed single T -45 -9.9999999999999982 4.9999999999999973 -37.499999999999993 3.5527136788005009e-15 19.999999999999996 F #
+point $-1 -1 -1 $-1 -40 -9.9999999999999964 19.999999999999996 #
+point $-1 -1 -1 $-1 -40 2.6645352591003757e-15 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $19298 $16291 $16333 $17842 forward $17799 $-1 #
+coedge $-1 -1 -1 $-1 $16291 $19299 $16294 $17803 forward $17799 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19298 $16332 T -7.5000000000000018 -10 5 0 -4.9999999999999991 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 -10 20 #
+coedge $-1 -1 -1 $-1 $19300 $16294 $17785 $19282 reversed $16296 $-1 #
+edge $-1 -1 -1 $-1 $19301 7.5 $16297 17.499999999999996 $17798 $19302 forward @7 unknown T -7.5000000000000018 -9.3301270189221945 7.5 -7.5 -9.3301270189221928 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $16295 $19300 $14707 $16256 forward $16296 $-1 #
+coedge $-1 -1 -1 $-1 $19303 $16299 $16295 $16301 forward $17808 $-1 #
+point $-1 -1 -1 $-1 -7.5000000000000018 -9.3301270189221945 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $16299 $19303 $17734 $16271 reversed $17808 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16299 $17775 T -20 -10 15 -10 -4.9999999999999991 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $17782 $19304 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16308 $16892 $16329 $17840 reversed $13859 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16351 $16310 $19305 $19306 forward $16352 $-1 #
+vertex $-1 -1 -1 $-1 $16716 $19307 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19308 $16316 $16313 $17819 reversed $16890 $-1 #
+edge $-1 -1 -1 $-1 $17850 -2.0943951023931948 $14757 -1.5707963267948961 $16313 $19309 forward @7 unknown T 4.9999999999999973 -0.66987298107780635 -25 7.5000000000000009 0 -22.5 #
+coedge $-1 -1 -1 $-1 $19310 $19311 $16315 $17821 forward $19312 $-1 #
+edge $-1 -1 -1 $-1 $16323 1.5707963267948966 $17823 3.1415926535897931 $17820 $19313 forward @7 unknown T -5 -4.9999999999999991 -25 0 0 -20 #
+coedge $-1 -1 -1 $-1 $16316 $19314 $19310 $19315 reversed $16890 $-1 #
+vertex $-1 -1 -1 $-1 $19316 $19317 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17855 $17838 $11 $-1 $11805 reversed single T -5 -10 -30 5.0000000000000018 -4.9999999999999991 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $19178 $18177 $16320 $17827 reversed $14645 $-1 #
+edge $-1 -1 -1 $-1 $17831 27.5 $17834 37.500000000000014 $16320 $19318 forward @7 unknown T -7.5 -0.66987298107780746 -37.500000000000014 -7.4999999999999991 -0.66987298107780635 -27.5 #
+coedge $-1 -1 -1 $-1 $19234 $16321 $19311 $19319 reversed $17830 $-1 #
+coedge $-1 -1 -1 $-1 $16321 $19234 $19178 $19320 forward $17830 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17829 $19321 T -10.000000000000002 -0.66987298107780902 -27.5 -5 8.8817841970012523e-16 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $19320 $19322 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 0 -25 #
+vertex $-1 -1 -1 $-1 $16325 $19323 #
+coedge $-1 -1 -1 $-1 $19324 $19325 $16326 $17836 reversed $19326 $-1 #
+edge $-1 -1 -1 $-1 $18214 1.0471975511965974 $17839 1.5707963267948966 $16326 $17832 forward @7 unknown T -7.5000000000000018 -10 -27.500000000000004 -5 -9.330127018922191 -25 #
+coedge $-1 -1 -1 $-1 $18240 $16327 $19327 $19316 reversed $17838 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16715 $17825 T -5 -10 -30 5.0000000000000018 -4.9999999999999991 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $17836 $19328 #
+edge $-1 -1 -1 $-1 $16330 -17.5 $18251 -7.5000000000000018 $16329 $19329 forward @7 unknown T 7.4999999999999956 -0.66987298107780746 7.5000000000000018 7.5000000000000018 -0.66987298107780635 17.5 #
+point $-1 -1 -1 $-1 7.5000000000000018 -0.66987298107780746 17.5 #
+edge $-1 -1 -1 $-1 $16293 -1.5707963267948966 $17811 0 $17797 $19278 forward @7 unknown T -5 -10 15 0 -5 20 #
+point $-1 -1 -1 $-1 7.5 -9.3301270189221945 17.5 #
+coedge $-1 -1 -1 $-1 $16335 $16724 $19330 $19331 forward $14802 $-1 #
+coedge $-1 -1 -1 $-1 $19330 $18247 $16336 $17846 reversed $19332 $-1 #
+edge $-1 -1 -1 $-1 $16334 -2.0943951023931953 $16337 -1.5707963267948966 $16336 $19333 forward @7 unknown T 5 -10 17.5 7.5 -9.330127018922191 20 #
+edge $-1 -1 -1 $-1 $16337 -1.5707963267948966 $17811 -6.1232339957367648e-17 $16721 $19334 forward @7 unknown T -9.3734986416366059e-33 -10 15 5 -5 20 #
+point $-1 -1 -1 $-1 5 -10 20 #
+coedge $-1 -1 -1 $-1 $16341 $18382 $19308 $19335 forward $16342 $-1 #
+vertex $-1 -1 -1 $-1 $16347 $19336 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16911 $19337 $11 $-1 $7251 reversed single T -7.5000000000000027 -10 -10 0 -4.9999999999999991 5 F #
+coedge $-1 -1 -1 $-1 $19338 $16353 $16351 $17854 forward $17856 $-1 #
+edge $-1 -1 -1 $-1 $14801 1.5707963267948966 $19339 2.0943951023931948 $17853 $17851 forward @7 unknown T 7.5000000000000018 -10 -25 10 -9.3301270189221945 -22.5 #
+face $-1 -1 -1 $-1 $16348 $16352 $11 $-1 $11805 reversed single T 4.9999999999999973 -10 -27.500000000000004 10 -9.330127018922191 -22.5 F #
+loop $-1 -1 -1 $-1 $-1 $16903 $19340 T 7.5 -10 -25 15 -4.9999999999999991 -10 unknown #
+face $-1 -1 -1 $-1 $19341 $19342 $11 $-1 $11805 reversed single T -50 -10 -30.000000000000004 -40 2.6645352591003757e-15 -20.000000000000004 F #
+point $-1 -1 -1 $-1 22.5 -9.3301270189221928 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $16362 $18349 $16735 $18263 reversed $14821 $-1 #
+coedge $-1 -1 -1 $-1 $16380 $16363 $19343 $17892 forward $3750 $-1 #
+coedge $-1 -1 -1 $-1 $18476 $17889 $16363 $17862 reversed $17022 $-1 #
+edge $-1 -1 -1 $-1 $16401 -0.52359877559829826 $16386 1.5707963267948966 $16363 $19344 forward @7 unknown T -30 40 -50 -22.5 45 -50 #
+coedge $-1 -1 -1 $-1 $16364 $19345 $18476 $19346 forward $17864 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16396 $19347 T -22.500000000000007 40 -50 -15 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $16395 $16365 $19348 $17927 reversed $16366 $-1 #
+coedge $-1 -1 -1 $-1 $19349 $19348 $16368 $17867 reversed $19350 $-1 #
+edge $-1 -1 -1 $-1 $16420 -1.5707963267948966 $16422 -1.0471975511965974 $16368 $16404 forward @7 unknown T -7.5000000000000009 44.330127018922191 -42.5 -5 45 -40 #
+face $-1 -1 -1 $-1 $14885 $16370 $11 $-1 $11911 reversed single T 5.0000000000000027 44.330127018922191 -42.5 10 45 -37.500000000000007 F #
+loop $-1 -1 -1 $-1 $5226 $16371 $1558 T 50 35 -45 50 45 -35 hole $1559 T #
+vertex $-1 -1 -1 $-1 $16372 $19351 #
+ellipse-curve $-1 -1 -1 $-1 50 40 -40 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+face $-1 -1 -1 $-1 $6627 $19352 $11 $-1 $11911 reversed single T -50 35 -45 -40 45 -35 F #
+loop $-1 -1 -1 $-1 $-1 $19353 $16373 T -24.999999999999996 44.330127018922184 -42.500000000000007 -20 45 -37.5 unknown #
+coedge $-1 -1 -1 $-1 $16402 $16399 $19354 $19355 forward $16374 $-1 #
+coedge $-1 -1 -1 $-1 $16998 $16375 $19356 $19357 forward $11864 $-1 #
+coedge $-1 -1 -1 $-1 $19358 $19358 $16375 $17877 reversed $18515 $-1 #
+edge $-1 -1 -1 $-1 $17880 1.570796326794897 $19359 4.7123889803846897 $16375 $19360 forward @7 unknown T 39.999999999999993 35 5.0000000000000027 44.999999999999993 45 10.000000000000004 #
+coedge $-1 -1 -1 $-1 $16376 $18628 $19361 $19362 reversed $17879 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17144 $17958 T 35 44.330127018922191 2.5000000000000031 40.000000000000007 45 7.5000000000000098 unknown #
+vertex $-1 -1 -1 $-1 $19362 $19363 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 40 5.0000000000000027 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 44.330127018922198 7.5000000000000098 #
+coedge $-1 -1 -1 $-1 $19364 $19365 $16380 $17884 reversed $19366 $-1 #
+edge $-1 -1 -1 $-1 $19367 -0.52359877559829893 $17886 3.6651914291880923 $16380 $19368 forward @7 unknown T -45 35 -50 -37.5 45 -50 #
+coedge $-1 -1 -1 $-1 $18287 $16381 $19365 $19369 forward $13728 $-1 #
+vertex $-1 -1 -1 $-1 $16382 $19370 #
+ellipse-curve $-1 -1 -1 $-1 -35 40 -50 0 0 1 5 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17890 $16383 $19371 $19372 reversed $16385 $-1 #
+coedge $-1 -1 -1 $-1 $17861 $19373 $18291 $16776 reversed $17022 $-1 #
+coedge $-1 -1 -1 $-1 $16384 $17888 $19374 $19375 reversed $16385 $-1 #
+face $-1 -1 -1 $-1 $12637 $16385 $11 $-1 $15569 reversed single T -30 35 -50 -22.5 40 -40 F #
+edge $-1 -1 -1 $-1 $16386 0 $19367 2.0943951023931957 $17860 $17887 forward @7 unknown T -37.5 40 -50 -30 45 -50 #
+point $-1 -1 -1 $-1 -30 40 -50 #
+coedge $-1 -1 -1 $-1 $19374 $19376 $16388 $17895 reversed $19377 $-1 #
+edge $-1 -1 -1 $-1 $17896 1.0471975511965983 $19378 1.5707963267948966 $16388 $19379 forward @7 unknown T -22.5 35 -42.5 -20 35.669872981077809 -40 #
+vertex $-1 -1 -1 $-1 $17895 $19380 #
+straight-curve $-1 -1 -1 $-1 -22.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19381 $16393 $16390 $17899 reversed $17902 $-1 #
+edge $-1 -1 -1 $-1 $19378 -1.5707963267948966 $16397 0 $16390 $19382 forward @7 unknown T -20 35 -45 -15 40 -40 #
+face $-1 -1 -1 $-1 $19383 $19384 $11 $-1 $14102 reversed single T -22.500000000000004 40 -40 -15 45 -25 F #
+coedge $-1 -1 -1 $-1 $16393 $19381 $19385 $19386 forward $17902 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16393 $19387 T -20 35 -45 -9.9999999999999982 40 -35 unknown #
+vertex $-1 -1 -1 $-1 $16394 $19388 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19389 $19390 $16395 $17906 forward $19391 $-1 #
+edge $-1 -1 -1 $-1 $16397 -6.1232339957367648e-17 $19392 1.5707963267948966 $17905 $19393 forward @7 unknown T -15 40 -45 -9.9999999999999982 45 -40 #
+coedge $-1 -1 -1 $-1 $19345 $16396 $19390 $17908 forward $17864 $-1 #
+edge $-1 -1 -1 $-1 $16397 0 $19394 1.5707963267948966 $17907 $19382 forward @7 unknown T -20 40 -45 -15 45 -40 #
+point $-1 -1 -1 $-1 -15 40 -45 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 44.330127018922191 -50 #
+coedge $-1 -1 -1 $-1 $19395 $17915 $16402 $17913 forward $18557 $-1 #
+edge $-1 -1 -1 $-1 $16403 1.5707963267948966 $19396 2.0943951023931948 $17912 $19397 forward @7 unknown T -7.5 35 -40 -5 35.669872981077809 -37.5 #
+point $-1 -1 -1 $-1 -5 35 -40 #
+coedge $-1 -1 -1 $-1 $17912 $17078 $16406 $17916 forward $18557 $-1 #
+edge $-1 -1 -1 $-1 $17080 3.1415926535897931 $16403 4.7123889803846897 $17915 $19398 forward @7 unknown T -5 35 -40 0 40 -35 #
+face $-1 -1 -1 $-1 $19399 $19400 $11 $-1 $16410 reversed single T -20 35 -15.000000000000002 -9.9999999999999982 40 -5 F #
+loop $-1 -1 -1 $-1 $-1 $19401 $16408 T -20 40 -15.000000000000002 -9.9999999999999982 45 -5 unknown #
+coedge $-1 -1 -1 $-1 $19402 $19403 $19404 $19405 forward $16409 $-1 #
+coedge $-1 -1 -1 $-1 $19406 $16411 $14135 $15617 forward $14134 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $17868 $16417 $11 $-1 $11911 reversed single T -5 40 -45 5.0000000000000027 45 -35 F #
+coedge $-1 -1 -1 $-1 $16416 $16415 $17077 $18555 reversed $16417 $-1 #
+point $-1 -1 -1 $-1 5.0000000000000027 45 -40 #
+point $-1 -1 -1 $-1 -5 45 -40 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $19392 1.5707963267948966 $16422 2.0943951023931953 $19348 $19407 forward @7 unknown T -9.9999999999999982 44.330127018922191 -42.5 -7.4999999999999991 45 -40 #
+point $-1 -1 -1 $-1 -7.5 44.330127018922191 -42.5 #
+edge $-1 -1 -1 $-1 $16425 -37.500000000000007 $19408 -27.499999999999996 $16424 $19409 forward @7 unknown T 7.5 35.669872981077809 -37.500000000000007 7.5000000000000018 35.669872981077809 -27.499999999999996 #
+point $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 -37.500000000000007 #
+face $-1 -1 -1 $-1 $19410 $19411 $11 $-1 $14913 reversed single T -5 40 0 5.0000000000000027 45 10 F #
+face $-1 -1 -1 $-1 $18563 $18579 $11 $-1 $12658 reversed single T 5.0000000000000027 35 17.5 10 35.669872981077809 22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $19412 $16429 T -5 35 15 5.0000000000000027 40 25 unknown #
+coedge $-1 -1 -1 $-1 $18561 $16431 $17092 $18566 forward $14890 $-1 #
+coedge $-1 -1 -1 $-1 $16431 $19413 $19414 $19415 forward $14890 $-1 #
+coedge $-1 -1 -1 $-1 $19416 $18610 $19417 $17937 reversed $18609 $-1 #
+edge $-1 -1 -1 $-1 $19418 10 $18568 15 $16431 $19419 forward @7 unknown T 14.999999999999996 40 10 15.000000000000002 40 15 #
+coedge $-1 -1 -1 $-1 $17125 $19420 $16432 $17939 forward $18605 $-1 #
+edge $-1 -1 -1 $-1 $18585 -1.5707963267948961 $14164 -6.1232339957367648e-17 $17938 $19421 forward @7 unknown T 15 35 -30 20.000000000000004 40 -25 #
+point $-1 -1 -1 $-1 22.500000000000004 35.669872981077809 -27.500000000000004 #
+face $-1 -1 -1 $-1 $19422 $19423 $11 $-1 $14913 reversed single T 20.000000000000004 35 2.5000000000000049 25 35.669872981077809 7.5 F #
+loop $-1 -1 -1 $-1 $-1 $19424 $16436 T 10 35 -9.3734986416366073e-33 20.000000000000004 40 10 unknown #
+coedge $-1 -1 -1 $-1 $19414 $19425 $17100 $18576 forward $16437 $-1 #
+coedge $-1 -1 -1 $-1 $17132 $16438 $19426 $18634 forward $14904 $-1 #
+coedge $-1 -1 -1 $-1 $19427 $19428 $16439 $17946 reversed $19429 $-1 #
+edge $-1 -1 -1 $-1 $19430 4.1887902047863932 $17948 4.7123889803846897 $16439 $19431 forward @7 unknown T 22.500000000000007 44.330127018922198 5.0000000000000018 25 45 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $17146 $16440 $19432 $19433 reversed $14912 $-1 #
+vertex $-1 -1 -1 $-1 $19434 $19435 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 5.0000000000000018 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18613 $16442 $19436 $19437 forward $16445 $-1 #
+coedge $-1 -1 -1 $-1 $17960 $19438 $16442 $17952 reversed $16451 $-1 #
+edge $-1 -1 -1 $-1 $16446 3.1415926535897931 $19439 4.7123889803846897 $16442 $17949 forward @7 unknown T 24.999999999999996 35 5.0000000000000018 29.999999999999996 40 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $16444 $19440 $17960 $19441 reversed $17954 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19440 $18614 T 29.999999999999996 35 5.0000000000000018 37.500000000000007 40 20.000000000000004 unknown #
+point $-1 -1 -1 $-1 29.999999999999996 40 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $19442 $17154 $16448 $17957 reversed $17139 $-1 #
+edge $-1 -1 -1 $-1 $15704 6.1232339957367648e-17 $15689 1.5707963267948966 $16448 $19443 forward @7 unknown T 29.999999999999996 35 -24.999999999999996 35 40 -19.999999999999996 #
+face $-1 -1 -1 $-1 $14208 $17879 $11 $-1 $14913 reversed single T 35 44.330127018922191 2.5000000000000031 40.000000000000007 45 7.5000000000000098 F #
+loop $-1 -1 -1 $-1 $-1 $19444 $16450 T 35 35 2.5000000000000053 40.000000000000007 35.669872981077809 7.5000000000000062 unknown #
+coedge $-1 -1 -1 $-1 $19445 $17951 $17953 $19441 forward $16451 $-1 #
+coedge $-1 -1 -1 $-1 $16781 $19446 $16452 $16484 reversed $18302 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $16455 $16499 $19447 $19448 forward $16456 $-1 #
+edge $-1 -1 -1 $-1 $19449 42.5 $14952 50 $16455 $19450 forward @7 unknown T -22.500000000000004 29.330127018922191 -50 -22.5 29.330127018922195 -42.5 #
+face $-1 -1 -1 $-1 $19451 $16456 $11 $-1 $12796 reversed single T -22.500000000000004 25 -50 -15 30 -40 F #
+coedge $-1 -1 -1 $-1 $16458 $19452 $16457 $16519 forward $17968 $-1 #
+coedge $-1 -1 -1 $-1 $19452 $16458 $17322 $18823 reversed $17968 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19452 $19453 T -9.9999999999999982 29.330127018922191 -42.5 -5 30 -37.5 unknown #
+point $-1 -1 -1 $-1 50 25 -45 #
+loop $-1 -1 -1 $-1 $19454 $19455 $16464 T -45 20.000000000000004 -45 -40 30.000000000000004 -35 unknown #
+coedge $-1 -1 -1 $-1 $19447 $19456 $18724 $19457 forward $16465 $-1 #
+coedge $-1 -1 -1 $-1 $18003 $19458 $16466 $17973 reversed $18677 $-1 #
+edge $-1 -1 -1 $-1 $16495 1.5707963267948966 $18014 2.0943951023931944 $16466 $19459 forward @7 unknown T -9.9999999999999982 20 -40 -7.5 20.669872981077805 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $19460 $18062 $16467 $17975 reversed $16551 $-1 #
+edge $-1 -1 -1 $-1 $17977 1.570796326794897 $18699 2.0943951023931948 $16467 $16473 forward @7 unknown T 37.500000000000007 20 5.0000000000000027 40.000000000000007 20.669872981077813 7.5000000000000036 #
+coedge $-1 -1 -1 $-1 $16468 $16468 $19461 $19462 reversed $17283 $-1 #
+vertex $-1 -1 -1 $-1 $19463 $19464 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18875 $19461 $16470 $17980 forward $18911 $-1 #
+edge $-1 -1 -1 $-1 $16472 -1.570796326794897 $19465 -1.0471975511965983 $17979 $19466 forward @7 unknown T 37.499999999999993 29.330127018922191 2.5000000000000049 40 30 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 30 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $19467 $16475 $19446 $19468 reversed $17984 $-1 #
+coedge $-1 -1 -1 $-1 $16475 $19469 $16477 $17987 reversed $17984 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17982 $17224 T -45 20.000000000000004 -50 -37.5 30.000000000000004 -40 unknown #
+vertex $-1 -1 -1 $-1 $19468 $19470 #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $16478 -50 $19471 -42.500000000000007 $16477 $19472 forward @7 unknown T -37.500000000000007 20.669872981077805 -50 -37.5 20.669872981077813 -42.500000000000007 #
+point $-1 -1 -1 $-1 -37.5 20.669872981077805 -50 #
+coedge $-1 -1 -1 $-1 $16778 $19473 $16480 $17990 forward $18296 $-1 #
+edge $-1 -1 -1 $-1 $19474 -1.5707963267948966 $16780 -6.1232339957367648e-17 $17989 $19475 forward @7 unknown T -30 20 -45 -25 25 -40 #
+coedge $-1 -1 -1 $-1 $16481 $18724 $19476 $19477 reversed $15772 $-1 #
+coedge $-1 -1 -1 $-1 $19478 $16486 $16482 $17993 forward $17995 $-1 #
+edge $-1 -1 -1 $-1 $16488 -2.0943951023931966 $19474 -1.5707963267948966 $17992 $19479 forward @7 unknown T -25 20 -42.500000000000014 -22.499999999999996 20.669872981077813 -40 #
+coedge $-1 -1 -1 $-1 $16486 $19478 $19480 $19481 reversed $17995 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17992 $18001 T -25 20 -42.500000000000014 -20 20.669872981077813 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $16487 $19482 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 20.669872981077813 -42.500000000000014 #
+coedge $-1 -1 -1 $-1 $16493 $16490 $19483 $19484 reversed $16494 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19485 $17995 $11 $-1 $10647 reversed single T -25 20 -42.500000000000014 -20 20.669872981077813 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $19486 $16492 T -22.500000000000004 25 -40 -15 30 -25 unknown #
+coedge $-1 -1 -1 $-1 $19487 $17972 $16493 $18004 reversed $18677 $-1 #
+edge $-1 -1 -1 $-1 $19488 6.1232339957367648e-17 $16495 1.5707963267948966 $16493 $19489 forward @7 unknown T -15 20 -40 -9.9999999999999982 25 -35 #
+face $-1 -1 -1 $-1 $19490 $16494 $11 $-1 $10647 reversed single T -20 20 -45 -9.9999999999999982 25 -35 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 20 -40 #
+coedge $-1 -1 -1 $-1 $19491 $16497 $19492 $19493 forward $18009 $-1 #
+coedge $-1 -1 -1 $-1 $16497 $19491 $16499 $16500 reversed $18009 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16497 $19494 T -20 25 -45 -9.9999999999999982 30 -35 unknown #
+vertex $-1 -1 -1 $-1 $16498 $19495 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19448 $19496 #
+coedge $-1 -1 -1 $-1 $18824 $16504 $19458 $19497 forward $17325 $-1 #
+vertex $-1 -1 -1 $-1 $17973 $19498 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19499 $17325 $11 $-1 $9021 reversed single T -7.5 20 -40 8.8817841970012523e-16 25 -25 F #
+loop $-1 -1 -1 $-1 $-1 $19500 $16509 T -20 20 -15.000000000000002 -9.9999999999999982 25 -5 unknown #
+coedge $-1 -1 -1 $-1 $19501 $19502 $17261 $18741 forward $16510 $-1 #
+coedge $-1 -1 -1 $-1 $19503 $16511 $19504 $19505 forward $14960 $-1 #
+coedge $-1 -1 -1 $-1 $16511 $19503 $19506 $19507 reversed $14960 $-1 #
+coedge $-1 -1 -1 $-1 $19508 $17261 $16511 $18023 reversed $15791 $-1 #
+edge $-1 -1 -1 $-1 $19509 -2.0943951023931962 $19510 -1.5707963267948966 $16511 $19511 forward @7 unknown T -9.9999999999999982 29.330127018922184 -10 -7.4999999999999964 30 -7.4999999999999956 #
+coedge $-1 -1 -1 $-1 $17309 $16512 $19512 $19513 reversed $12828 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $17371 $19514 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 20.669872981077805 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $19515 $19516 $11 $-1 $13449 reversed single T -5 20 -9.3734986416366059e-33 5.0000000000000018 25 10 F #
+loop $-1 -1 -1 $-1 $-1 $19517 $16523 T -5 25 -9.3734986416366059e-33 5.0000000000000018 30 10 unknown #
+coedge $-1 -1 -1 $-1 $19518 $17333 $17196 $18679 forward $16525 $-1 #
+coedge $-1 -1 -1 $-1 $16527 $18827 $19519 $19520 forward $13426 $-1 #
+coedge $-1 -1 -1 $-1 $19521 $16535 $16527 $18033 reversed $14988 $-1 #
+edge $-1 -1 -1 $-1 $19522 1.5707963267948966 $18036 3.1415926535897931 $16527 $19523 forward @7 unknown T 9.9999999999999982 25 5.0000000000000009 14.999999999999996 30 10 #
+coedge $-1 -1 -1 $-1 $19524 $16528 $19525 $19526 forward $17377 $-1 #
+coedge $-1 -1 -1 $-1 $18044 $19527 $17335 $16529 forward $18895 $-1 #
+vertex $-1 -1 -1 $-1 $19526 $19528 #
+straight-curve $-1 -1 -1 $-1 15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16530 $17372 $19529 $19530 forward $17373 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15866 $18047 $11 $-1 $13449 reversed single T 20 29.330127018922195 2.5000000000000036 25 30 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $19531 $16533 T 20 20 2.4999999999999969 25 20.669872981077816 7.5000000000000027 unknown #
+coedge $-1 -1 -1 $-1 $19532 $19525 $19527 $19533 forward $16534 $-1 #
+coedge $-1 -1 -1 $-1 $16535 $19521 $19534 $19535 forward $14988 $-1 #
+coedge $-1 -1 -1 $-1 $17400 $18035 $16536 $17402 reversed $18895 $-1 #
+coedge $-1 -1 -1 $-1 $19536 $16537 $17343 $18842 forward $18047 $-1 #
+coedge $-1 -1 -1 $-1 $16537 $19536 $19537 $18052 reversed $18047 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18045 $18040 T 20 29.330127018922195 2.5000000000000036 25 30 7.5000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $16538 $19538 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19537 $17388 $16539 $18051 forward $18884 $-1 #
+edge $-1 -1 -1 $-1 $18885 0 $16540 1.5707963267948961 $18050 $19539 forward @7 unknown T 25 25 1.7763568394002505e-15 29.999999999999996 30 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $16540 -1.570796326794897 $19540 -1.0471975511965983 $19537 $19541 forward @7 unknown T 22.5 29.330127018922195 2.5000000000000036 25 30 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 30 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $19542 $19531 $16542 $18055 reversed $18041 $-1 #
+edge $-1 -1 -1 $-1 $18057 1.5707963267948961 $19543 2.0943951023931957 $16542 $18049 forward @7 unknown T 22.499999999999996 20 4.9999999999999991 25 20.669872981077809 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $16543 $18063 $19544 $19545 reversed $15002 $-1 #
+vertex $-1 -1 -1 $-1 $19546 $19547 #
+coedge $-1 -1 -1 $-1 $16545 $17198 $18062 $19548 reversed $16546 $-1 #
+edge $-1 -1 -1 $-1 $14997 -6.4931039580273206e-16 $19549 1.5707963267948966 $16552 $19550 forward @7 unknown T 29.999999999999996 19.999999999999996 5.0000000000000018 35 25 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $19551 $16548 $14404 $15924 forward $15889 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17974 $19552 $18058 $19548 forward $16551 $-1 #
+coedge $-1 -1 -1 $-1 $18056 $16552 $19553 $19554 forward $15002 $-1 #
+coedge $-1 -1 -1 $-1 $16553 $18311 $16574 $18086 forward $16792 $-1 #
+coedge $-1 -1 -1 $-1 $19555 $16563 $16555 $18066 reversed $15016 $-1 #
+edge $-1 -1 -1 $-1 $16604 -1.5707963267948966 $18067 -1.0471975511965974 $16555 $16589 forward @7 unknown T -22.500000000000004 14.330127018922191 -42.5 -20 15 -40 #
+vertex $-1 -1 -1 $-1 $18075 $19556 #
+straight-curve $-1 -1 -1 $-1 -22.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $19557 $19558 $11 $-1 $13102 reversed single T -20 5 -30 -9.9999999999999982 10 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $16558 $16559 $19559 $19560 forward $16560 $-1 #
+face $-1 -1 -1 $-1 $18112 $16560 $11 $-1 $9512 reversed single T -10 14.330127018922191 -42.5 -5 15 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $19561 $15015 T -50 5 -45 -50 15 -35 unknown #
+coedge $-1 -1 -1 $-1 $19562 $19562 $19563 $19564 forward $16562 $-1 #
+coedge $-1 -1 -1 $-1 $16563 $19555 $19565 $19566 forward $15016 $-1 #
+edge $-1 -1 -1 $-1 $19567 1.5707963267948966 $18067 2.0943951023931948 $16563 $19568 forward @7 unknown T -25 14.330127018922193 -42.5 -22.500000000000004 15.000000000000002 -40 #
+coedge $-1 -1 -1 $-1 $16564 $19569 $16605 $18115 reversed $17445 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18170 $16566 $19570 $18081 reversed $15102 $-1 #
+coedge $-1 -1 -1 $-1 $16571 $19570 $16568 $18080 forward $17679 $-1 #
+edge $-1 -1 -1 $-1 $16569 -1.570796326794897 $15023 1.570796326794897 $18079 $19571 forward @7 unknown T 40 4.9999999999999991 2.6645352591003757e-15 45.000000000000007 15 5.0000000000000044 #
+edge $-1 -1 -1 $-1 $19572 1.0471975511965987 $16569 1.570796326794897 $19570 $18084 forward @7 unknown T 37.5 5 2.5000000000000071 40 5.6698729810778046 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 5 5.0000000000000027 #
+vertex $-1 -1 -1 $-1 $17644 $19573 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19563 $16574 $19574 $19575 reversed $16576 $-1 #
+edge $-1 -1 -1 $-1 $19576 42.5 $16577 50 $18064 $19577 forward @7 unknown T -37.5 14.330127018922193 -50 -37.5 14.330127018922195 -42.5 #
+coedge $-1 -1 -1 $-1 $16575 $19563 $18303 $19578 reversed $16576 $-1 #
+point $-1 -1 -1 $-1 -37.5 14.330127018922195 -50 #
+vertex $-1 -1 -1 $-1 $16784 $19579 #
+straight-curve $-1 -1 -1 $-1 -37.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $16581 $16785 $19580 $19581 forward $16786 $-1 #
+vertex $-1 -1 -1 $-1 $16582 $19582 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19583 $18312 $16583 $18095 forward $19584 $-1 #
+edge $-1 -1 -1 $-1 $15259 -4.1650370783741769e-16 $19567 1.5707963267948966 $18094 $19585 forward @7 unknown T -30 10 -45 -25 15.000000000000002 -40 #
+coedge $-1 -1 -1 $-1 $16586 $16584 $18963 $19586 forward $16587 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19587 $18101 $16586 $18099 forward $19588 $-1 #
+edge $-1 -1 -1 $-1 $16588 1.5707963267948966 $19589 2.0943951023931957 $18098 $19590 forward @7 unknown T -22.5 5 -40 -20 5.669872981077809 -37.499999999999993 #
+point $-1 -1 -1 $-1 -20 5 -40 #
+coedge $-1 -1 -1 $-1 $18098 $19591 $16591 $18102 forward $19588 $-1 #
+edge $-1 -1 -1 $-1 $18106 3.1415926535897931 $16588 4.7123889803846897 $18101 $19592 forward @7 unknown T -20 5 -40 -15 10 -35 #
+face $-1 -1 -1 $-1 $19593 $16786 $11 $-1 $9512 reversed single T -35 5 -45 -25 10 -35 F #
+coedge $-1 -1 -1 $-1 $19594 $19595 $19591 $18929 forward $16594 $-1 #
+coedge $-1 -1 -1 $-1 $19596 $16595 $17446 $18929 forward $17445 $-1 #
+vertex $-1 -1 -1 $-1 $18102 $19597 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+face $-1 -1 -1 $-1 $10118 $19588 $11 $-1 $11541 reversed single T -22.500000000000004 5 -40 -15 10 -25 F #
+coedge $-1 -1 -1 $-1 $16600 $16599 $19595 $19598 reversed $16601 $-1 #
+coedge $-1 -1 -1 $-1 $19559 $17446 $16599 $18111 reversed $15944 $-1 #
+edge $-1 -1 -1 $-1 $16602 -1.5707963267948966 $18106 6.1232339957367648e-17 $16599 $19599 forward @7 unknown T -15 10 -40 -10 15 -35 #
+face $-1 -1 -1 $-1 $16597 $16601 $11 $-1 $9512 reversed single T -20 10 -45 -10 15 -35 F #
+point $-1 -1 -1 $-1 -10 15 -40 #
+point $-1 -1 -1 $-1 -20 15 -40 #
+edge $-1 -1 -1 $-1 $16606 -37.5 $19600 -27.500000000000004 $16605 $19601 forward @7 unknown T -7.5 5.6698729810778064 -37.5 -7.5 5.6698729810778072 -27.500000000000004 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 -37.5 #
+face $-1 -1 -1 $-1 $16557 $19602 $11 $-1 $11541 reversed single T -22.5 5 -25 -15 10 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $19603 $19604 $19605 $19606 forward $16610 $-1 #
+coedge $-1 -1 -1 $-1 $19607 $16611 $19608 $19609 reversed $15061 $-1 #
+coedge $-1 -1 -1 $-1 $16611 $19607 $19610 $19611 forward $15061 $-1 #
+coedge $-1 -1 -1 $-1 $16613 $16612 $19612 $19613 reversed $13496 $-1 #
+coedge $-1 -1 -1 $-1 $19610 $19614 $16612 $18123 reversed $16010 $-1 #
+edge $-1 -1 -1 $-1 $18128 1.5707963267948966 $19615 2.0943951023931957 $16612 $19616 forward @7 unknown T -10 14.330127018922191 -12.5 -7.4999999999999991 15 -10 #
+coedge $-1 -1 -1 $-1 $19617 $19618 $16613 $18125 forward $19619 $-1 #
+edge $-1 -1 -1 $-1 $18127 4.1887902047863914 $19620 4.7123889803846897 $18124 $19621 forward @7 unknown T -7.4999999999999982 14.330127018922195 -10 -5 15 -7.5 #
+coedge $-1 -1 -1 $-1 $19622 $16614 $19618 $19623 reversed $14492 $-1 #
+vertex $-1 -1 -1 $-1 $18125 $19624 #
+vertex $-1 -1 -1 $-1 $19611 $19625 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17593 $19626 $16616 $18131 forward $19086 $-1 #
+edge $-1 -1 -1 $-1 $19064 -1.5707963267948966 $14532 -6.1232339957367648e-17 $18130 $19627 forward @7 unknown T 0 4.9999999999999991 -30 5.0000000000000009 10 -25 #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 -27.5 #
+face $-1 -1 -1 $-1 $19628 $19629 $11 $-1 $12076 reversed single T 5.0000000000000009 4.9999999999999991 2.5000000000000013 10.000000000000002 5.6698729810778072 7.5000000000000018 F #
+loop $-1 -1 -1 $-1 $-1 $19630 $16620 T -5 4.9999999999999991 -8.8817841970012523e-16 5.0000000000000009 10 10 unknown #
+coedge $-1 -1 -1 $-1 $19631 $19632 $17572 $19060 forward $16621 $-1 #
+coedge $-1 -1 -1 $-1 $17599 $16622 $19633 $19110 forward $15076 $-1 #
+coedge $-1 -1 -1 $-1 $19634 $19635 $16623 $18138 reversed $19636 $-1 #
+edge $-1 -1 -1 $-1 $19637 4.1887902047863914 $18140 4.7123889803846897 $16623 $19638 forward @7 unknown T 7.5000000000000027 14.330127018922195 5.0000000000000009 10 15 7.5 #
+coedge $-1 -1 -1 $-1 $16635 $16624 $19639 $19640 reversed $13524 $-1 #
+vertex $-1 -1 -1 $-1 $19641 $19642 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 10 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19092 $16626 $19643 $19644 forward $16127 $-1 #
+coedge $-1 -1 -1 $-1 $16634 $19645 $16626 $18144 reversed $15085 $-1 #
+edge $-1 -1 -1 $-1 $16628 3.1415926535897931 $19646 4.7123889803846897 $16626 $18141 forward @7 unknown T 10 5 5.0000000000000009 14.999999999999996 10 10 #
+coedge $-1 -1 -1 $-1 $16627 $19129 $16634 $18151 reversed $17663 $-1 #
+point $-1 -1 -1 $-1 14.999999999999996 10 10 #
+coedge $-1 -1 -1 $-1 $19647 $17616 $16630 $18148 reversed $17605 $-1 #
+edge $-1 -1 -1 $-1 $16110 -2.9403902792268254e-16 $16103 1.570796326794897 $16630 $19648 forward @7 unknown T 15 4.9999999999999982 -25 20.000000000000004 10 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $16646 $19649 $19129 $19650 forward $16633 $-1 #
+coedge $-1 -1 -1 $-1 $19645 $16634 $19651 $19652 forward $15085 $-1 #
+edge $-1 -1 -1 $-1 $16628 -2.9403902792268234e-16 $19653 1.5707963267948966 $16634 $19654 forward @7 unknown T 14.999999999999996 4.9999999999999973 5.0000000000000009 20 10 10 #
+coedge $-1 -1 -1 $-1 $17607 $19655 $16635 $18153 reversed $14550 $-1 #
+edge $-1 -1 -1 $-1 $19656 2.9403902792268254e-16 $17611 1.5707963267948966 $16635 $19657 forward @7 unknown T 15 10 4.501174429623904e-32 20 14.999999999999998 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $16638 $16637 $19655 $19658 forward $16639 $-1 #
+coedge $-1 -1 -1 $-1 $19659 $16642 $16638 $16644 forward $17652 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 14.330127018922196 7.5000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19660 $19661 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19649 $16646 $19662 $18164 reversed $16633 $-1 #
+vertex $-1 -1 -1 $-1 $19650 $19663 #
+coedge $-1 -1 -1 $-1 $17651 $19662 $16648 $18163 forward $16172 $-1 #
+edge $-1 -1 -1 $-1 $16649 -1.5707963267948961 $17653 0 $18162 $18157 forward @7 unknown T 25 5 1.7763568394002505e-15 29.999999999999996 10 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $19664 1.0471975511965983 $16649 1.570796326794897 $19662 $18159 forward @7 unknown T 22.5 5 2.5000000000000044 25 5.6698729810778064 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 5 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $18167 1.5707963267948966 $17467 2.0943951023931966 $16654 $19665 forward @7 unknown T 35 4.9999999999999982 5.0000000000000018 37.500000000000014 5.669872981077809 7.5000000000000062 #
+vertex $-1 -1 -1 $-1 $18172 $19666 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17667 $16652 $19667 $19668 reversed $14590 $-1 #
+coedge $-1 -1 -1 $-1 $16654 $18078 $19669 $19670 forward $15102 $-1 #
+coedge $-1 -1 -1 $-1 $19669 $19143 $16655 $18172 reversed $16133 $-1 #
+edge $-1 -1 -1 $-1 $18167 -1.5707963267948966 $17653 2.9403902792268224e-16 $16655 $19671 forward @7 unknown T 29.999999999999996 4.9999999999999982 1.7763568394002505e-15 35 10 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $16666 $16657 $19672 $19673 reversed $13552 $-1 #
+point $-1 -1 -1 $-1 -22.500000000000004 -0.66987298107780746 -42.5 #
+face $-1 -1 -1 $-1 $19321 $19239 $11 $-1 $11805 reversed single T -20 -5 -30 -9.9999999999999982 8.8817841970012523e-16 -19.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $19674 $16661 T -20 -10 -30 -9.9999999999999982 -4.9999999999999991 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $17826 $16695 $16662 $18178 reversed $14645 $-1 #
+edge $-1 -1 -1 $-1 $17834 -2.0943951023931939 $15145 -1.5707963267948966 $16662 $19675 forward @7 unknown T -10 -0.66987298107780657 -40 -7.4999999999999991 8.8817841970012523e-16 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $18179 $18179 $19676 $19677 reversed $16664 $-1 #
+coedge $-1 -1 -1 $-1 $16665 $16665 $19196 $19678 forward $15113 $-1 #
+coedge $-1 -1 -1 $-1 $16672 $16670 $16665 $18182 reversed $15119 $-1 #
+edge $-1 -1 -1 $-1 $19679 -1.5707963267948966 $19680 1.5707963267948966 $16665 $19681 forward @7 unknown T -45 -9.9999999999999964 -45 -40 2.6645352591003757e-15 -40 #
+coedge $-1 -1 -1 $-1 $19682 $17724 $16666 $18184 reversed $14687 $-1 #
+edge $-1 -1 -1 $-1 $19683 -2.0943951023931939 $18185 -1.5707963267948966 $16666 $19684 forward @7 unknown T -25 -0.66987298107780657 -40 -22.5 1.7763568394002505e-15 -37.500000000000007 #
+vertex $-1 -1 -1 $-1 $16680 $19685 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16668 $18210 $19324 $19686 reversed $16195 $-1 #
+coedge $-1 -1 -1 $-1 $18324 $19687 $16670 $18189 forward $19688 $-1 #
+edge $-1 -1 -1 $-1 $19680 1.5707963267948966 $18190 2.0943951023931957 $18188 $19689 forward @7 unknown T -40 -0.66987298107780635 -42.5 -37.5 2.6645352591003757e-15 -40 #
+vertex $-1 -1 -1 $-1 $18189 $19690 #
+straight-curve $-1 -1 -1 $-1 -37.5 -0.66987298107780457 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $16674 -2.0943951023931957 $19679 -1.5707963267948966 $16793 $19691 forward @7 unknown T -40 -9.9999999999999964 -42.500000000000007 -37.5 -9.3301270189221874 -40 #
+point $-1 -1 -1 $-1 -37.5 -9.3301270189221945 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $19692 $17723 $16676 $18195 reversed $16231 $-1 #
+edge $-1 -1 -1 $-1 $18320 2.3886802389739268e-16 $16677 1.5707963267948966 $16676 $19693 forward @7 unknown T -30 -9.9999999999999982 -40 -25 -4.9999999999999991 -35 #
+point $-1 -1 -1 $-1 -25 -9.9999999999999982 -40 #
+coedge $-1 -1 -1 $-1 $18325 $16679 $17724 $19209 forward $18198 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18197 $18207 T -35 -5 -45 -25 1.7763568394002505e-15 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16677 1.5707963267948966 $18203 2.0943951023931957 $16681 $19694 forward @7 unknown T -25 -9.9999999999999982 -40 -22.5 -9.3301270189221892 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $19695 $16683 $19208 $19696 forward $18202 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18205 $16693 T -22.5 -10 -40 -15 -4.9999999999999991 -25 unknown #
+vertex $-1 -1 -1 $-1 $18200 $19697 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16686 $19698 $16690 $17697 reversed $18202 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16803 $18198 $11 $-1 $8499 reversed single T -35 -5 -45 -25 1.7763568394002505e-15 -35 F #
+coedge $-1 -1 -1 $-1 $19699 $16689 $19700 $19701 forward $15137 $-1 #
+coedge $-1 -1 -1 $-1 $16689 $19672 $16694 $18212 forward $15137 $-1 #
+coedge $-1 -1 -1 $-1 $18187 $16690 $19702 $19703 reversed $16195 $-1 #
+point $-1 -1 -1 $-1 -15 -4.9999999999999991 -35 #
+edge $-1 -1 -1 $-1 $15147 1.5707963267948966 $16691 3.1415926535897931 $18209 $18206 forward @7 unknown T -20 -4.9999999999999991 -40 -15 0 -35 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $17836 $19704 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $19705 $16702 T -22.500000000000004 -10 -25 -15 -4.9999999999999991 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $19706 $16703 $19707 $19708 forward $15153 $-1 #
+coedge $-1 -1 -1 $-1 $16703 $19706 $19709 $19248 reversed $15153 $-1 #
+coedge $-1 -1 -1 $-1 $19710 $19229 $16703 $18220 reversed $17739 $-1 #
+edge $-1 -1 -1 $-1 $17748 6.1232339957367648e-17 $19711 1.5707963267948966 $16703 $19712 forward @7 unknown T -15 -10 -10 -10 -4.9999999999999991 -5 #
+coedge $-1 -1 -1 $-1 $16705 $16704 $19713 $19714 reversed $13589 $-1 #
+coedge $-1 -1 -1 $-1 $17746 $19715 $16704 $18223 forward $19245 $-1 #
+edge $-1 -1 -1 $-1 $19716 1.5707963267948961 $17748 3.1415926535897931 $18222 $19717 forward @7 unknown T -20 -4.9999999999999991 -10.000000000000004 -14.999999999999996 0 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $17742 $16707 $16705 $18225 reversed $14704 $-1 #
+edge $-1 -1 -1 $-1 $19718 -2.3886802389739258e-16 $16713 1.5707963267948966 $16705 $19719 forward @7 unknown T -15.000000000000004 -5 -15.000000000000002 -10 8.8817841970012523e-16 -10 #
+coedge $-1 -1 -1 $-1 $19720 $19721 $16706 $18227 forward $19312 $-1 #
+edge $-1 -1 -1 $-1 $18234 -1.5707963267948966 $18229 -1.0471975511965974 $18226 $19722 forward @7 unknown T -7.5000000000000009 -0.66987298107780902 -12.5 -5 0 -10 #
+coedge $-1 -1 -1 $-1 $16707 $17741 $19720 $19723 reversed $14704 $-1 #
+vertex $-1 -1 -1 $-1 $19723 $19724 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19725 $16709 $19726 $19727 forward $18233 $-1 #
+coedge $-1 -1 -1 $-1 $16709 $19728 $16711 $18237 forward $18233 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19725 $18407 T -7.5 -5 -10 0 8.8817841970012523e-16 5 unknown #
+vertex $-1 -1 -1 $-1 $18227 $19729 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -10 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17745 $16711 $17753 $19255 reversed $13180 $-1 #
+edge $-1 -1 -1 $-1 $19730 -2.5000000000000009 $16712 7.5000000000000009 $18232 $19731 forward @7 unknown T -7.5 -0.66987298107780746 -7.5000000000000009 -7.4999999999999982 -0.66987298107780469 2.5000000000000009 #
+point $-1 -1 -1 $-1 -7.4999999999999982 -0.66987298107780469 -7.5000000000000009 #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 -10 #
+coedge $-1 -1 -1 $-1 $16715 $17837 $19732 $19733 forward $17838 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16318 $18250 $11 $-1 $9956 reversed single T 5 -0.66987298107780813 2.4999999999999996 10 8.8817841970012523e-16 7.5000000000000036 F #
+loop $-1 -1 -1 $-1 $-1 $19734 $16718 T 5 -10 2.5000000000000009 10.000000000000002 -9.330127018922191 7.5000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $19735 $19736 $19737 $19738 forward $16719 $-1 #
+coedge $-1 -1 -1 $-1 $19739 $16720 $19740 $19741 reversed $15164 $-1 #
+coedge $-1 -1 -1 $-1 $16720 $19739 $19742 $19743 forward $15164 $-1 #
+coedge $-1 -1 -1 $-1 $17845 $19744 $16721 $17847 reversed $19332 $-1 #
+coedge $-1 -1 -1 $-1 $19745 $16722 $16892 $18371 forward $18250 $-1 #
+coedge $-1 -1 -1 $-1 $16722 $19745 $16906 $16921 reversed $18250 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18248 $18242 T 5 -0.66987298107780813 2.4999999999999996 10 8.8817841970012523e-16 7.5000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $16723 $19746 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 -5 5.0000000000000009 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19747 $19734 $16724 $18254 reversed $18243 $-1 #
+edge $-1 -1 -1 $-1 $15416 1.5707963267948966 $19748 2.0943951023931948 $16724 $18252 forward @7 unknown T 7.5000000000000027 -10 5.0000000000000009 10.000000000000002 -9.3301270189221945 7.5 #
+coedge $-1 -1 -1 $-1 $16725 $16728 $16909 $18391 reversed $13612 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16959 $16910 $16728 $18258 reversed $13861 $-1 #
+edge $-1 -1 -1 $-1 $16966 -1.5707963267948966 $15401 1.1640334398265748e-16 $16728 $19749 forward @7 unknown T 15 -10 -4.6867493208183037e-33 20 -5 5.0000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19750 $16731 $13902 $15429 forward $14821 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16736 -37.5 $18277 -27.500000000000004 $16735 $19751 forward @7 unknown T -22.500000000000004 -24.330127018922195 -37.5 -22.5 -24.330127018922195 -27.500000000000004 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 -37.5 #
+coedge $-1 -1 -1 $-1 $18328 $16738 $16752 $18272 forward $16876 $-1 #
+edge $-1 -1 -1 $-1 $16741 4.1887902047863914 $15278 4.7123889803846897 $16925 $18327 forward @7 unknown T -37.5 -15.669872981077805 -40 -35 -15 -37.5 #
+point $-1 -1 -1 $-1 -37.499999999999993 -15.669872981077805 -37.5 #
+point $-1 -1 -1 $-1 -37.5 -24.330127018922187 -37.499999999999986 #
+face $-1 -1 -1 $-1 $19752 $19753 $11 $-1 $14669 reversed single T -45 -9.9999999999999964 -25.000000000000004 -37.5 2.6645352591003757e-15 -10.000000000000002 F #
+face $-1 -1 -1 $-1 $19754 $19755 $11 $-1 $11706 reversed single T -30.000000000000007 -5 4.9999999999999982 -22.5 2.6645352591003757e-15 20 F #
+edge $-1 -1 -1 $-1 $13694 -2.0943951023931948 $15212 -1.5707963267948966 $16750 $19756 forward @7 unknown T -25 -25 17.500000000000004 -22.500000000000004 -24.330127018922195 20 #
+edge $-1 -1 -1 $-1 $12336 6.1232339957367648e-17 $19757 1.5707963267948966 $18265 $19758 forward @7 unknown T -30 -25 4.9999999999999982 -25 -20 9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $18338 $19759 #
+straight-curve $-1 -1 -1 $-1 -22.5 -24.330127018922195 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $16851 4.1887902047863923 $15241 4.7123889803846897 $16939 $19760 forward @7 unknown T -22.499999999999993 -15.669872981077805 -25 -20 -15 -22.500000000000004 #
+face $-1 -1 -1 $-1 $16831 $16762 $11 $-1 $3328 reversed single T -25.000000000000004 -15.669872981077809 -27.500000000000004 -20 -15 -22.499999999999996 F #
+vertex $-1 -1 -1 $-1 $16766 $19761 #
+point $-1 -1 -1 $-1 -20 -25 -25 #
+loop $-1 -1 -1 $-1 $17452 $19676 $3147 T -50 -10 -45 -50 0 -35 hole $3148 T #
+coedge $-1 -1 -1 $-1 $18280 $18280 $19762 $19763 forward $16768 $-1 #
+coedge $-1 -1 -1 $-1 $18281 $18281 $16769 $18282 reversed $19764 $-1 #
+edge $-1 -1 -1 $-1 $19765 0 $19765 6.2831853071795862 $16769 $19766 forward @7 unknown T -50 -10 -15.000000000000004 -50 0 -5.0000000000000036 #
+loop $-1 -1 -1 $-1 $-1 $16770 $16281 T -50 -10 -3.0616169978683823e-15 -50 0 9.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $16771 $19767 #
+ellipse-curve $-1 -1 -1 $-1 -50 -5 4.9999999999999973 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -5 14.999999999999996 #
+coedge $-1 -1 -1 $-1 $16775 $17885 $19768 $19769 forward $13728 $-1 #
+coedge $-1 -1 -1 $-1 $19770 $19371 $16775 $18289 reversed $19771 $-1 #
+edge $-1 -1 -1 $-1 $19772 -1.5707963267948966 $18290 0 $16775 $19773 forward @7 unknown T -35 35 -45 -30 40 -40 #
+vertex $-1 -1 -1 $-1 $19774 $19775 #
+coedge $-1 -1 -1 $-1 $19776 $19343 $15253 $16776 forward $19777 $-1 #
+straight-curve $-1 -1 -1 $-1 -30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19778 $19779 $16777 $18294 reversed $19780 $-1 #
+edge $-1 -1 -1 $-1 $19471 1.0471975511965956 $18297 1.5707963267948966 $16777 $19781 forward @7 unknown T -37.500000000000007 20 -42.500000000000007 -35 20.669872981077813 -40 #
+coedge $-1 -1 -1 $-1 $19473 $16778 $19782 $19783 reversed $18296 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19473 $19485 T -35 20 -45 -25 25 -35 unknown #
+vertex $-1 -1 -1 $-1 $18294 $19784 #
+ellipse-curve $-1 -1 -1 $-1 -35 25 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16780 0 $19785 1.5707963267948966 $18301 $18298 forward @7 unknown T -35 25 -45 -30 30 -40 #
+point $-1 -1 -1 $-1 -30 25 -45 #
+coedge $-1 -1 -1 $-1 $19786 $16781 $19787 $18299 forward $18302 $-1 #
+loop $-1 -1 -1 $-1 $-1 $16781 $19788 T -37.500000000000007 25 -50 -30 30 -40 unknown #
+coedge $-1 -1 -1 $-1 $19789 $16783 $18087 $19578 forward $18305 $-1 #
+coedge $-1 -1 -1 $-1 $16783 $19789 $19790 $19791 reversed $18305 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18303 $19792 T -40 5 -42.500000000000007 -35 5.6698729810778108 -37.499999999999993 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 10 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19790 $19793 $16785 $18308 forward $19794 $-1 #
+edge $-1 -1 -1 $-1 $19795 3.1415926535897931 $16787 4.7123889803846897 $18307 $19796 forward @7 unknown T -35 5 -40 -30 10 -35 #
+point $-1 -1 -1 $-1 -35 5 -40 #
+vertex $-1 -1 -1 $-1 $19797 $19798 #
+coedge $-1 -1 -1 $-1 $18064 $16791 $19799 $19797 forward $16792 $-1 #
+coedge $-1 -1 -1 $-1 $18094 $19800 $16791 $16789 reversed $19584 $-1 #
+face $-1 -1 -1 $-1 $19801 $16792 $11 $-1 $10937 reversed single T -37.5 10 -50 -30 15 -40 F #
+coedge $-1 -1 -1 $-1 $16794 $16793 $19802 $19803 forward $16795 $-1 #
+coedge $-1 -1 -1 $-1 $19804 $16797 $16794 $18316 forward $18319 $-1 #
+edge $-1 -1 -1 $-1 $15266 1.5707963267948966 $19805 2.0943951023931957 $18315 $19806 forward @7 unknown T -37.5 -10 -40 -35 -9.330127018922191 -37.499999999999993 #
+face $-1 -1 -1 $-1 $19807 $16795 $11 $-1 $8499 reversed single T -40 -10 -42.500000000000007 -35 -9.3301270189221874 -37.499999999999993 F #
+coedge $-1 -1 -1 $-1 $16797 $19808 $19692 $17727 reversed $18319 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18318 $19809 T -37.5 -10 -40 -30 -4.9999999999999991 -25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $16798 $19810 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16800 -1.5707963267948966 $18190 -1.0471975511965979 $16801 $16796 forward @7 unknown T -37.5 -0.66987298107780813 -42.5 -35 0 -40 #
+point $-1 -1 -1 $-1 -35 0 -40 #
+coedge $-1 -1 -1 $-1 $19811 $18188 $16801 $18322 reversed $19688 $-1 #
+coedge $-1 -1 -1 $-1 $16802 $18197 $19214 $19812 reversed $18198 $-1 #
+face $-1 -1 -1 $-1 $19813 $17483 $11 $-1 $12964 reversed single T -30 10 20 -22.499999999999993 15.000000000000002 35 F #
+ellipse-curve $-1 -1 -1 $-1 -35 -20 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16809 $18265 $18330 $19814 forward $16876 $-1 #
+coedge $-1 -1 -1 $-1 $16819 $16812 $16834 $18339 forward $16820 $-1 #
+coedge $-1 -1 -1 $-1 $18340 $16813 $18328 $19814 reversed $13777 $-1 #
+point $-1 -1 -1 $-1 -35 -15 -25.000000000000004 #
+edge $-1 -1 -1 $-1 $18342 -1.5707963267948966 $16821 -6.1232339957367648e-17 $16819 $19815 forward @7 unknown T -30 -25 -15.000000000000004 -25 -20 -10.000000000000002 #
+point $-1 -1 -1 $-1 -30 -20 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $16824 $16823 $19750 $18351 forward $16825 $-1 #
+face $-1 -1 -1 $-1 $18276 $16844 $11 $-1 $3328 reversed single T -25.000000000000004 -25 -27.500000000000004 -20 -24.330127018922191 -22.500000000000004 F #
+ellipse-curve $-1 -1 -1 $-1 -35.000000000000007 -20 -25.000000000000004 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16968 $19816 $16833 $18338 forward $18362 $-1 #
+edge $-1 -1 -1 $-1 $19757 1.5707963267948966 $18273 2.0943951023931948 $18337 $19817 forward @7 unknown T -25 -25 4.9999999999999982 -22.500000000000004 -24.330127018922195 7.5 #
+edge $-1 -1 -1 $-1 $13793 6.1232339957367648e-17 $18342 1.5707963267948966 $18329 $19818 forward @7 unknown T -30 -25 -10.000000000000002 -25 -20 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $16835 $18330 $19816 $19819 reversed $13777 $-1 #
+coedge $-1 -1 -1 $-1 $16836 $16941 $16839 $18345 forward $16944 $-1 #
+vertex $-1 -1 -1 $-1 $18332 $19820 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16947 -2.0943951023931953 $18342 -1.5707963267948966 $18341 $19821 forward @7 unknown T -25 -25 -12.500000000000005 -22.5 -24.330127018922191 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $16840 $16938 $16842 $18348 forward $15435 $-1 #
+edge $-1 -1 -1 $-1 $16767 1.5707963267948966 $16846 2.0943951023931948 $18346 $19760 forward @7 unknown T -22.500000000000004 -25 -25 -20 -24.330127018922195 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $17859 $19750 $16843 $18350 reversed $14821 $-1 #
+edge $-1 -1 -1 $-1 $18277 -2.0943951023931957 $16845 -1.570796326794897 $16843 $19822 forward @7 unknown T -25 -25 -27.500000000000004 -22.5 -24.330127018922191 -25 #
+edge $-1 -1 -1 $-1 $16845 -1.5707963267948961 $16933 -6.1232339957367648e-17 $18334 $19823 forward @7 unknown T -30.000000000000007 -25 -30.000000000000004 -25 -20 -25 #
+point $-1 -1 -1 $-1 -25 -25 -25 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 -22.500000000000004 #
+straight-curve $-1 -1 -1 $-1 -22.5 -15.669872981077805 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -22.499999999999993 -15.669872981077805 -22.500000000000004 #
+edge $-1 -1 -1 $-1 $16933 0 $16818 1.5707963267948957 $16931 $18336 forward @7 unknown T -35 -20 -30.000000000000004 -30.000000000000007 -15 -25.000000000000004 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -15.669872981077809 2.4999999999999978 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16863 $16944 $11 $-1 $2664 reversed single T -25 -25 -12.500000000000005 -20 -24.330127018922191 -7.5000000000000036 F #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 4.9999999999999991 -0.70710678118654757 -0 0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $18337 $16875 T -25 -25 2.4999999999999982 -20 -24.330127018922191 7.5 unknown #
+vertex $-1 -1 -1 $-1 $16882 $19824 #
+point $-1 -1 -1 $-1 50 -5 -29.999999999999996 #
+face $-1 -1 -1 $-1 $19825 $19826 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 -10 7.5000000000000018 -4.9999999999999991 5 F #
+loop $-1 -1 -1 $-1 $-1 $19305 $16889 T -9.3734986416366059e-33 -10 -25 7.5000000000000018 -4.9999999999999991 -10 unknown #
+coedge $-1 -1 -1 $-1 $19827 $16891 $18411 $19828 reversed $15383 $-1 #
+coedge $-1 -1 -1 $-1 $16891 $19742 $19725 $19829 reversed $15383 $-1 #
+coedge $-1 -1 -1 $-1 $19726 $19830 $16891 $18370 forward $19831 $-1 #
+edge $-1 -1 -1 $-1 $19832 -1.5707963267948966 $19833 -1.1640334398265738e-16 $18369 $19834 forward @7 unknown T 0 -4.9999999999999991 -10 5 0 -5 #
+edge $-1 -1 -1 $-1 $18251 -2.0943951023931948 $18374 -1.5707963267948966 $18248 $19835 forward @7 unknown T 5 -0.66987298107780657 5 7.4999999999999964 0 7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $17781 $19740 $19298 $18373 forward $19251 $-1 #
+edge $-1 -1 -1 $-1 $18375 10 $17811 15 $18372 $19836 forward @7 unknown T 0 -5 10 0 -4.9999999999999991 15 #
+vertex $-1 -1 -1 $-1 $19743 $19837 #
+vertex $-1 -1 -1 $-1 $19838 $19839 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 5 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $13875 -2.9403902792268244e-16 $18378 1.5707963267948966 $16963 $19840 forward @7 unknown T 15 -10 -9.9999999999999982 20 -4.9999999999999991 -4.9999999999999982 #
+vertex $-1 -1 -1 $-1 $19841 $19842 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $16898 $16897 $18415 $19841 reversed $12403 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17849 $16902 $18410 $18394 forward $16342 $-1 #
+coedge $-1 -1 -1 $-1 $16903 $19843 $19844 $19845 forward $17856 $-1 #
+point $-1 -1 -1 $-1 15 -5 -15 #
+coedge $-1 -1 -1 $-1 $16907 $16906 $19827 $19846 forward $15400 $-1 #
+coedge $-1 -1 -1 $-1 $18411 $18410 $16907 $18387 reversed $15497 $-1 #
+edge $-1 -1 -1 $-1 $19847 4.1887902047863914 $16914 4.7123889803846897 $16907 $19848 forward @7 unknown T 7.5000000000000009 -0.66987298107780635 -10 10 0 -7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $19849 $16908 $19850 $19851 forward $16360 $-1 #
+coedge $-1 -1 -1 $-1 $16963 $19844 $16908 $15408 reversed $15506 $-1 #
+coedge $-1 -1 -1 $-1 $16909 $19849 $19747 $16923 forward $16360 $-1 #
+edge $-1 -1 -1 $-1 $15416 -1.5707963267948966 $15401 0 $16909 $16920 forward @7 unknown T 10 -10 8.8817841970012523e-16 15.000000000000004 -5 5.0000000000000009 #
+face $-1 -1 -1 $-1 $19852 $19853 $11 $-1 $11179 reversed single T 5 -10 -12.500000000000004 10 -9.330127018922191 -7.5000000000000018 F #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -10 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $16914 -1.5707963267948966 $19854 -1.0471975511965979 $18382 $19855 forward @7 unknown T 7.5000000000000009 -0.66987298107780724 -12.5 10 0 -10 #
+point $-1 -1 -1 $-1 10 0 -10 #
+edge $-1 -1 -1 $-1 $19856 1.0471975511965974 $16918 1.5707963267948966 $19843 $19855 forward @7 unknown T 7.5 -10 -12.500000000000004 10 -9.330127018922191 -10 #
+point $-1 -1 -1 $-1 10 -10 -10 #
+vertex $-1 -1 -1 $-1 $19846 $19857 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 -5 5.0000000000000009 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $16923 $19858 #
+point $-1 -1 -1 $-1 -30.000000000000007 -20 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $19816 $16968 $16942 $16882 reversed $18362 $-1 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922198 -7.5000000000000036 #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 -12.500000000000005 #
+point $-1 -1 -1 $-1 -22.499999999999996 -15.669872981077805 -12.500000000000002 #
+face $-1 -1 -1 $-1 $16358 $18233 $11 $-1 $7251 reversed single T -7.5 -5 -10 0 8.8817841970012523e-16 5 F #
+loop $-1 -1 -1 $-1 $19764 $19859 $16956 T -45 -9.9999999999999964 -15.000000000000002 -40 2.6645352591003757e-15 -5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $19860 $19861 $19229 $19862 forward $16957 $-1 #
+coedge $-1 -1 -1 $-1 $18386 $16958 $18382 $18394 reversed $15497 $-1 #
+coedge $-1 -1 -1 $-1 $16958 $18386 $18367 $19828 forward $15497 $-1 #
+coedge $-1 -1 -1 $-1 $19314 $19308 $16958 $18413 reversed $16890 $-1 #
+edge $-1 -1 -1 $-1 $19832 1.5707963267948966 $19854 2.0943951023931957 $16958 $19863 forward @7 unknown T 5 -0.66987298107780902 -12.5 7.5000000000000018 0 -10 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19844 $16963 $18380 $19841 forward $15506 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 -10 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $16970 $17011 $19864 $19865 forward $15579 $-1 #
+coedge $-1 -1 -1 $-1 $16974 $19866 $16971 $17046 forward $18423 $-1 #
+coedge $-1 -1 -1 $-1 $19867 $18465 $16972 $18421 forward $19868 $-1 #
+edge $-1 -1 -1 $-1 $15564 6.1232339957367648e-17 $18506 1.5707963267948966 $18420 $19869 forward @7 unknown T -30 35 35 -24.999999999999996 40 40 #
+coedge $-1 -1 -1 $-1 $19866 $16974 $18490 $17036 reversed $18423 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18419 $19870 T -24.999999999999996 35 32.5 -20 35.669872981077809 37.5 unknown #
+coedge $-1 -1 -1 $-1 $16995 $19871 $16976 $17084 reversed $18446 $-1 #
+face $-1 -1 -1 $-1 $14860 $19872 $11 $-1 $12646 reversed single T -15 35 -40 -7.4999999999999938 40 -25 F #
+loop $-1 -1 -1 $-1 $-1 $19873 $16979 T -15 40 -40 -7.4999999999999991 45 -25 unknown #
+face $-1 -1 -1 $-1 $11231 $16980 $11 $-1 $10029 reversed single T 0 35 20 7.5000000000000036 40 35 F #
+coedge $-1 -1 -1 $-1 $16982 $17103 $19412 $19874 reversed $16980 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19440 $16984 $16998 $18448 reversed $17954 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 40 20.000000000000004 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $19875 $19876 $1558 T 50 35 -14.999999999999996 50 45 -4.9999999999999964 hole $1559 T #
+coedge $-1 -1 -1 $-1 $18434 $18434 $19877 $19878 forward $16989 $-1 #
+coedge $-1 -1 -1 $-1 $18435 $18435 $16991 $18436 forward $19879 $-1 #
+edge $-1 -1 -1 $-1 $19880 0 $19880 6.2831853071795862 $18435 $19881 forward @7 unknown T -50 35 29.999999999999996 -50 45 40 #
+coedge $-1 -1 -1 $-1 $17002 $17000 $16992 $18438 reversed $15553 $-1 #
+edge $-1 -1 -1 $-1 $18443 -1.5707963267948966 $18442 1.5707963267948966 $16992 $19882 forward @7 unknown T -45 35 35 -40 45 40 #
+coedge $-1 -1 -1 $-1 $19883 $16993 $19884 $19885 reversed $18441 $-1 #
+coedge $-1 -1 -1 $-1 $16993 $19886 $19887 $19888 reversed $18441 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19889 $19890 T -45 35 19.999999999999996 -37.5 45 35 unknown #
+vertex $-1 -1 -1 $-1 $16994 $19891 #
+vertex $-1 -1 -1 $-1 $16994 $19892 #
+ellipse-curve $-1 -1 -1 $-1 -40 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17057 $16995 $17067 $18538 reversed $18446 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17057 $19893 T -15 35 20 -7.4999999999999973 40 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19894 7.5000000000000044 $16999 17.500000000000007 $16998 $19895 forward @7 unknown T 37.499999999999993 35.669872981077802 7.5000000000000044 37.500000000000007 35.669872981077809 17.500000000000007 #
+point $-1 -1 -1 $-1 37.499999999999993 35.669872981077802 17.500000000000007 #
+coedge $-1 -1 -1 $-1 $19864 $19884 $17000 $18451 forward $19896 $-1 #
+edge $-1 -1 -1 $-1 $18442 1.5707963267948966 $18452 2.0943951023931957 $18450 $19897 forward @7 unknown T -40 35 35 -37.5 35.669872981077809 37.5 #
+vertex $-1 -1 -1 $-1 $18451 $19898 #
+straight-curve $-1 -1 -1 $-1 -37.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19887 $17005 $17002 $18455 forward $18459 $-1 #
+edge $-1 -1 -1 $-1 $17007 -2.0943951023931957 $18443 -1.5707963267948966 $18454 $19899 forward @7 unknown T -40 44.330127018922191 35 -37.5 45 37.500000000000007 #
+face $-1 -1 -1 $-1 $19900 $19366 $11 $-1 $18457 reversed single T -45 35 -50 -37.5 45 -40 F #
+cone-surface $-1 -1 -1 $-1 -40 40 0 0 0 1 3.0616169978683826e-16 5 0 1 I I 0 1 5 forward I I I I #
+coedge $-1 -1 -1 $-1 $17005 $19887 $19901 $19902 reversed $18459 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18454 $19903 T -40 44.330127018922191 32.5 -35 45 37.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $19902 $19904 #
+ellipse-curve $-1 -1 -1 $-1 -35 40 35 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.500000000000007 44.330127018922191 37.500000000000007 #
+coedge $-1 -1 -1 $-1 $17013 $17009 $19905 $19906 reversed $17014 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -35 40 35 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18420 $19907 $17011 $17017 reversed $19868 $-1 #
+face $-1 -1 -1 $-1 $19903 $19896 $11 $-1 $8951 reversed single T -40 35 32.499999999999993 -35 35.669872981077816 37.5 F #
+loop $-1 -1 -1 $-1 $-1 $19908 $17012 T -37.500000000000007 40 19.999999999999993 -29.999999999999993 45 35 unknown #
+coedge $-1 -1 -1 $-1 $19909 $18472 $17013 $18469 reversed $19910 $-1 #
+edge $-1 -1 -1 $-1 $19911 -6.1232339957367648e-17 $17015 1.5707963267948966 $17013 $19912 forward @7 unknown T -30 40 30 -24.999999999999996 45 35 #
+point $-1 -1 -1 $-1 -24.999999999999996 45 35 #
+vertex $-1 -1 -1 $-1 $19913 $19914 #
+coedge $-1 -1 -1 $-1 $18468 $19915 $17019 $18473 reversed $19910 $-1 #
+edge $-1 -1 -1 $-1 $17015 1.5707963267948966 $18478 2.0943951023931953 $17019 $19916 forward @7 unknown T -24.999999999999996 44.330127018922184 32.5 -22.499999999999996 45 35 #
+face $-1 -1 -1 $-1 $17891 $19917 $11 $-1 $15569 reversed single T -30.000000000000007 35 -40 -22.5 40 -25 F #
+loop $-1 -1 -1 $-1 $-1 $19918 $17021 T -30.000000000000007 40 -40 -22.499999999999996 45 -25 unknown #
+coedge $-1 -1 -1 $-1 $19919 $17861 $17863 $19346 reversed $17022 $-1 #
+coedge $-1 -1 -1 $-1 $19920 $17023 $19915 $19921 forward $17031 $-1 #
+vertex $-1 -1 -1 $-1 $19921 $19922 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19923 $19924 $11 $-1 $13729 reversed single T -37.500000000000014 35 19.999999999999993 -29.999999999999993 40 35 F #
+coedge $-1 -1 -1 $-1 $17027 $19925 $19926 $18486 forward $17031 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19926 $18490 $17029 $18484 forward $19927 $-1 #
+edge $-1 -1 -1 $-1 $15584 -1.5707963267948966 $17033 0 $18483 $18482 forward @7 unknown T -20 35 30 -15 40 35 #
+face $-1 -1 -1 $-1 $19870 $19868 $11 $-1 $8951 reversed single T -35 35 30 -24.999999999999996 40 40 F #
+edge $-1 -1 -1 $-1 $18504 25 $17033 30 $18481 $19928 forward @7 unknown T -15 40 25 -15 40 30 #
+point $-1 -1 -1 $-1 -15 40 30 #
+face $-1 -1 -1 $-1 $19929 $19927 $11 $-1 $14102 reversed single T -22.5 35 20 -15 40 35 F #
+vertex $-1 -1 -1 $-1 $17036 $19930 #
+coedge $-1 -1 -1 $-1 $18483 $19931 $18422 $17036 forward $19927 $-1 #
+face $-1 -1 -1 $-1 $19932 $19933 $11 $-1 $12646 reversed single T -15.000000000000004 35 -25 -7.4999999999999964 40 -10 F #
+loop $-1 -1 -1 $-1 $-1 $19934 $17040 T -15.000000000000004 40 -25 -7.4999999999999991 45 -10 unknown #
+coedge $-1 -1 -1 $-1 $19404 $19935 $19401 $19936 reversed $17041 $-1 #
+coedge $-1 -1 -1 $-1 $19937 $17042 $19938 $19939 reversed $15588 $-1 #
+coedge $-1 -1 -1 $-1 $17042 $19940 $19941 $19942 reversed $15588 $-1 #
+coedge $-1 -1 -1 $-1 $19943 $19944 $17042 $18497 forward $19945 $-1 #
+edge $-1 -1 -1 $-1 $19946 -1.5707963267948966 $19947 6.1232339957367673e-17 $18496 $19948 forward @7 unknown T -15 40 4.9999999999999991 -9.9999999999999982 45 10 #
+coedge $-1 -1 -1 $-1 $19949 $18508 $17043 $18499 forward $19950 $-1 #
+edge $-1 -1 -1 $-1 $18510 -2.0943951023931957 $18503 -1.5707963267948966 $18498 $19951 forward @7 unknown T -9.9999999999999982 44.330127018922191 20 -7.4999999999999973 45 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $19952 $17044 $19925 $19953 reversed $18502 $-1 #
+coedge $-1 -1 -1 $-1 $17044 $19952 $19940 $19954 forward $18502 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17044 $19955 T -20 40 15 -9.9999999999999982 45 25 unknown #
+vertex $-1 -1 -1 $-1 $19954 $19956 #
+vertex $-1 -1 -1 $-1 $19957 $19958 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19959 $19960 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18498 $19961 $17048 $18509 reversed $19950 $-1 #
+edge $-1 -1 -1 $-1 $18510 4.1887902047863905 $19962 4.7123889803846897 $17048 $19963 forward @7 unknown T -7.5000000000000018 44.330127018922191 20 -5 45 22.500000000000004 #
+vertex $-1 -1 -1 $-1 $18509 $19964 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $19965 $17061 $17051 $18513 reversed $16430 $-1 #
+edge $-1 -1 -1 $-1 $19962 1.5707963267948966 $17063 3.1415926535897931 $17051 $19966 forward @7 unknown T -5 40 20 0 45 25 #
+face $-1 -1 -1 $-1 $19967 $19968 $11 $-1 $14913 reversed single T -9.9999999999999982 35 2.4999999999999947 -5 35.669872981077816 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $19969 $19358 $17052 T 39.999999999999993 35 2.6645352591003757e-15 45.000000000000007 45 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $18516 $18516 $19970 $19971 reversed $17053 $-1 #
+coedge $-1 -1 -1 $-1 $17054 $17054 $19972 $19973 forward $15601 $-1 #
+coedge $-1 -1 -1 $-1 $19974 $19975 $17054 $18519 reversed $19976 $-1 #
+edge $-1 -1 -1 $-1 $19977 -1.5707963267948966 $19978 1.5707963267948966 $17054 $19979 forward @7 unknown T -45 35 14.999999999999996 -40 45 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $17056 $17055 $19980 $19981 reversed $14123 $-1 #
+coedge $-1 -1 -1 $-1 $17067 $17091 $17055 $18522 forward $14142 $-1 #
+edge $-1 -1 -1 $-1 $19982 1.5707963267948966 $18527 2.0943951023931957 $18521 $19963 forward @7 unknown T -7.5000000000000009 35 20 -5 35.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $19983 $19984 $17056 $18524 reversed $19985 $-1 #
+edge $-1 -1 -1 $-1 $19986 -2.0943951023931953 $18526 -1.5707963267948966 $17056 $19987 forward @7 unknown T -9.9999999999999982 35 17.5 -7.4999999999999991 35.669872981077816 20 #
+coedge $-1 -1 -1 $-1 $19871 $17057 $19988 $19989 reversed $18446 $-1 #
+vertex $-1 -1 -1 $-1 $19990 $19991 #
+vertex $-1 -1 -1 $-1 $17058 $19992 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $17059 $19993 #
+ellipse-curve $-1 -1 -1 $-1 50 40 20.000000000000004 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+coedge $-1 -1 -1 $-1 $17061 $19965 $19994 $19995 forward $16430 $-1 #
+vertex $-1 -1 -1 $-1 $19995 $19996 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 20 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17063 3.1415926535897931 $19982 4.7123889803846897 $17091 $19966 forward @7 unknown T -5 35 20 0 40 25 #
+point $-1 -1 -1 $-1 0 40 25 #
+face $-1 -1 -1 $-1 $19997 $19998 $11 $-1 $10029 reversed single T 0 40 -10 7.5000000000000027 45 5 F #
+loop $-1 -1 -1 $-1 $-1 $19999 $17065 T 0 40 5 7.5000000000000018 45 20 unknown #
+edge $-1 -1 -1 $-1 $18527 22.500000000000004 $15610 32.500000000000007 $17067 $20000 forward @7 unknown T -7.5000000000000027 35.669872981077809 22.500000000000004 -7.4999999999999991 35.669872981077816 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $17086 $17068 $20001 $20002 forward $17087 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 20 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17070 $19406 $20003 $20004 reversed $14134 $-1 #
+coedge $-1 -1 -1 $-1 $17073 $17071 $17118 $18595 reversed $12666 $-1 #
+edge $-1 -1 -1 $-1 $18601 -2.0943951023931935 $16418 -1.5707963267948966 $17083 $20005 forward @7 unknown T 5.0000000000000027 44.330127018922198 -40 7.5000000000000027 45 -37.500000000000007 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17119 $20006 $17073 $18546 forward $18597 $-1 #
+edge $-1 -1 -1 $-1 $18550 1.5707963267948966 $18598 2.0943951023931948 $18545 $20007 forward @7 unknown T 5.0000000000000027 44.330127018922191 -27.499999999999996 7.5 45 -25 #
+coedge $-1 -1 -1 $-1 $20008 $17074 $20009 $20010 forward $18549 $-1 #
+coedge $-1 -1 -1 $-1 $17074 $20008 $17076 $18553 reversed $18549 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17074 $20011 T -5 40 -30 5.0000000000000027 45 -20 unknown #
+vertex $-1 -1 -1 $-1 $17075 $20012 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -25 0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20013 $17076 $20014 $20015 forward $17079 $-1 #
+edge $-1 -1 -1 $-1 $17081 0 $20016 1.5707963267948966 $17076 $20017 forward @7 unknown T -5 40 -30 0 45 -25 #
+coedge $-1 -1 -1 $-1 $17077 $20013 $19349 $20018 forward $17079 $-1 #
+edge $-1 -1 -1 $-1 $16420 1.5707963267948966 $17080 3.1415926535897931 $17077 $19398 forward @7 unknown T -5 40 -40 0 45 -35 #
+coedge $-1 -1 -1 $-1 $17078 $20019 $20020 $20021 forward $18557 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17078 $19399 T -7.5000000000000071 35 -40 8.8817841970012523e-16 40 -25 unknown #
+point $-1 -1 -1 $-1 0 40 -35 #
+point $-1 -1 -1 $-1 0 40 -30 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20022 $17934 $17086 $18562 forward $14890 $-1 #
+edge $-1 -1 -1 $-1 $17088 -1.5707963267948966 $20023 -1.0471975511965974 $18561 $20024 forward @7 unknown T 7.4999999999999991 44.330127018922191 17.5 10 45 20 #
+face $-1 -1 -1 $-1 $20025 $17087 $11 $-1 $12658 reversed single T 5.0000000000000027 44.330127018922191 17.5 10 45 22.5 F #
+point $-1 -1 -1 $-1 10 45 20 #
+coedge $-1 -1 -1 $-1 $19412 $20026 $17091 $18534 reversed $17933 $-1 #
+edge $-1 -1 -1 $-1 $18568 0 $17088 1.5707963267948966 $17934 $20027 forward @7 unknown T 10 40 15 15 45 20 #
+coedge $-1 -1 -1 $-1 $17100 $17094 $16431 $17937 reversed $15634 $-1 #
+vertex $-1 -1 -1 $-1 $18566 $20028 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $20029 1.0471975511965974 $17097 1.5707963267948966 $20030 $20024 forward @7 unknown T 7.4999999999999991 35 17.5 10 35.669872981077809 20 #
+point $-1 -1 -1 $-1 10 35 20 #
+face $-1 -1 -1 $-1 $20031 $20032 $11 $-1 $7943 reversed single T 15 35 -25 22.500000000000004 40 -9.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $17114 $17098 T 15 40 -25 22.500000000000004 45 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $20033 $20034 $20035 $20036 reversed $17099 $-1 #
+coedge $-1 -1 -1 $-1 $18582 $17100 $19427 $20037 reversed $15634 $-1 #
+edge $-1 -1 -1 $-1 $20038 -1.5707963267948966 $19418 6.1232339957367648e-17 $17943 $20039 forward @7 unknown T 14.999999999999996 40 5.0000000000000009 20.000000000000004 45 10 #
+coedge $-1 -1 -1 $-1 $20040 $17101 $20030 $18570 reversed $18579 $-1 #
+coedge $-1 -1 -1 $-1 $17101 $20040 $17103 $18580 forward $18579 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18578 $17932 T 5.0000000000000027 35 17.5 10 35.669872981077809 22.500000000000004 unknown #
+edge $-1 -1 -1 $-1 $20041 1.5707963267948966 $17104 2.0943951023931957 $18578 $20042 forward @7 unknown T 5.0000000000000027 35 20 7.5000000000000036 35.669872981077809 22.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $17106 $18575 $17128 $18607 reversed $15634 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17182 $17108 $20043 $20044 forward $17183 $-1 #
+vertex $-1 -1 -1 $-1 $17939 $20045 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20046 $17114 $17111 $18588 reversed $18573 $-1 #
+edge $-1 -1 -1 $-1 $18662 -2.0943951023931935 $15649 -1.5707963267948961 $17111 $20047 forward @7 unknown T 20 44.330127018922198 -25 22.5 45 -22.500000000000007 #
+coedge $-1 -1 -1 $-1 $20048 $20049 $17113 $18590 forward $20050 $-1 #
+edge $-1 -1 -1 $-1 $17121 1.5707963267948966 $18592 3.1415926535897931 $18589 $20051 forward @7 unknown T 10 40 -25 15 45 -20 #
+coedge $-1 -1 -1 $-1 $17114 $20052 $20048 $20053 reversed $18573 $-1 #
+vertex $-1 -1 -1 $-1 $20054 $20055 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18667 $18605 $11 $-1 $15707 reversed single T 10 35 -30 20.000000000000007 40 -19.999999999999996 F #
+edge $-1 -1 -1 $-1 $18598 27.499999999999996 $18601 37.500000000000014 $17118 $20056 forward @7 unknown T 7.5 44.330127018922191 -37.500000000000014 7.5000000000000027 44.330127018922205 -27.499999999999996 #
+coedge $-1 -1 -1 $-1 $20006 $17119 $20049 $20057 reversed $18597 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20006 $20058 T 5.0000000000000027 44.330127018922191 -27.5 10 45 -22.500000000000007 unknown #
+vertex $-1 -1 -1 $-1 $18546 $20059 #
+ellipse-curve $-1 -1 -1 $-1 10 40 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 10 45 -25 #
+vertex $-1 -1 -1 $-1 $17123 $20060 #
+coedge $-1 -1 -1 $-1 $20003 $20061 $17124 $18603 reversed $20062 $-1 #
+edge $-1 -1 -1 $-1 $19408 1.0471975511965979 $18606 1.5707963267948966 $17124 $18599 forward @7 unknown T 7.5 35 -27.5 10 35.669872981077809 -25 #
+coedge $-1 -1 -1 $-1 $19420 $17125 $20063 $20054 reversed $18605 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17938 $18594 T 10 35 -30 20.000000000000007 40 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $18603 $20064 #
+edge $-1 -1 -1 $-1 $17129 -17.500000000000004 $19430 -7.5000000000000009 $17128 $20065 forward @7 unknown T 22.5 44.330127018922191 7.5000000000000009 22.500000000000011 44.330127018922205 17.500000000000004 #
+point $-1 -1 -1 $-1 22.500000000000011 44.330127018922205 17.500000000000004 #
+loop $-1 -1 -1 $-1 $-1 $17936 $17131 T 7.4999999999999991 35 5.0000000000000009 15.000000000000002 40 20 unknown #
+coedge $-1 -1 -1 $-1 $17936 $20030 $17132 $18611 forward $18609 $-1 #
+edge $-1 -1 -1 $-1 $17097 -1.5707963267948966 $18568 0 $18610 $20027 forward @7 unknown T 10 35 15 15 40 20 #
+point $-1 -1 -1 $-1 22.500000000000004 35.669872981077809 17.5 #
+coedge $-1 -1 -1 $-1 $17137 $17950 $20066 $20067 forward $16445 $-1 #
+face $-1 -1 -1 $-1 $12612 $17954 $11 $-1 $6121 reversed single T 29.999999999999996 35 5.0000000000000018 37.500000000000007 40 20.000000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $20068 $17138 T 29.999999999999996 35 -9.9999999999999982 37.500000000000007 40 5.0000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $20069 $17140 $20070 $20071 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $20072 $20073 $17140 $18618 forward $20074 $-1 #
+edge $-1 -1 -1 $-1 $20075 -2.0943951023931948 $18625 -1.5707963267948966 $18617 $20076 forward @7 unknown T 35 44.330127018922198 -9.9999999999999982 37.500000000000007 45 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $17141 $20069 $17146 $18630 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $19432 $20077 $20078 $18621 forward $20079 $-1 #
+edge $-1 -1 -1 $-1 $18626 -4.9999999999999982 $20080 1.7763568394002505e-15 $18620 $20081 forward @7 unknown T 29.999999999999996 40 -4.9999999999999982 30 40 1.7763568394002505e-15 #
+coedge $-1 -1 -1 $-1 $20082 $17142 $20077 $20083 reversed $18624 $-1 #
+coedge $-1 -1 -1 $-1 $17142 $20082 $17173 $18659 forward $18624 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17142 $20084 T 25 40 -15 35 45 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $18659 $20085 #
+vertex $-1 -1 -1 $-1 $20086 $20087 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17878 $17144 $20069 $20088 forward $17879 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $20080 -6.1232339957367648e-17 $17147 1.5707963267948966 $17146 $20089 forward @7 unknown T 29.999999999999996 40 1.7763568394002505e-15 35 45 5.0000000000000018 #
+point $-1 -1 -1 $-1 35 45 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $20066 $19426 $17149 $18633 reversed $20090 $-1 #
+edge $-1 -1 -1 $-1 $17136 -2.0943951023931957 $17150 -1.5707963267948966 $17149 $20091 forward @7 unknown T 20.000000000000004 35 17.5 22.500000000000004 35.669872981077809 20 #
+edge $-1 -1 -1 $-1 $17150 -1.5707963267948966 $18568 -6.1232339957367648e-17 $17944 $20092 forward @7 unknown T 15 35 15 20.000000000000004 40 20 #
+point $-1 -1 -1 $-1 20.000000000000004 35 20 #
+coedge $-1 -1 -1 $-1 $20093 $18645 $17153 $18637 forward $18647 $-1 #
+edge $-1 -1 -1 $-1 $17160 1.570796326794897 $18639 2.0943951023931966 $18636 $18648 forward @7 unknown T 37.5 35 -24.999999999999996 40.000000000000007 35.669872981077816 -22.499999999999989 #
+coedge $-1 -1 -1 $-1 $17154 $20094 $20093 $20095 reversed $17139 $-1 #
+vertex $-1 -1 -1 $-1 $20095 $20096 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17158 $17158 $18645 $20097 reversed $18642 $-1 #
+loop $-1 -1 -1 $-1 $20098 $17158 $20099 T 39.999999999999993 35 -29.999999999999996 45.000000000000007 45 -19.999999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 40 -24.999999999999996 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 35 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $18636 $17162 $18641 $20097 forward $18647 $-1 #
+coedge $-1 -1 -1 $-1 $17162 $20100 $17165 $18651 forward $18647 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18646 $20101 T 37.5 35 -24.999999999999996 45 45 -9.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 40 -24.999999999999996 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 40 45 -24.999999999999996 #
+coedge $-1 -1 -1 $-1 $17173 $17165 $20072 $20102 reversed $15673 $-1 #
+edge $-1 -1 -1 $-1 $20103 12.5 $17166 22.499999999999989 $18646 $20104 forward @7 unknown T 37.5 44.330127018922191 -22.499999999999989 37.500000000000007 44.330127018922205 -12.5 #
+point $-1 -1 -1 $-1 37.500000000000007 44.330127018922198 -22.499999999999989 #
+face $-1 -1 -1 $-1 $20105 $20106 $11 $-1 $7001 reversed single T 37.499999999999993 35 -9.9999999999999982 45.000000000000007 45 5.0000000000000044 F #
+loop $-1 -1 -1 $-1 $-1 $20078 $17168 T 22.5 35 -9.9999999999999982 30 40 5.0000000000000036 unknown #
+coedge $-1 -1 -1 $-1 $20107 $17169 $20082 $20108 forward $17171 $-1 #
+coedge $-1 -1 -1 $-1 $17184 $20109 $19442 $17174 reversed $18668 $-1 #
+coedge $-1 -1 -1 $-1 $17170 $20107 $20046 $20110 forward $17171 $-1 #
+face $-1 -1 -1 $-1 $768 $17171 $11 $-1 $7024 reversed single T 22.5 40 -25 30 45 -9.9999999999999964 F #
+edge $-1 -1 -1 $-1 $18660 -6.1232339957367648e-17 $18625 1.5707963267948966 $18623 $20111 forward @7 unknown T 30 40 -15 35 45 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $20108 $20112 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $17178 $20113 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20114 $20115 $11 $-1 $7955 reversed single T 7.5000000000000018 35 -10 15.000000000000004 40 5.0000000000000009 F #
+coedge $-1 -1 -1 $-1 $20116 $17184 $17182 $18666 forward $18668 $-1 #
+edge $-1 -1 -1 $-1 $15719 1.5707963267948961 $20117 2.0943951023931948 $18665 $18663 forward @7 unknown T 22.499999999999993 35 -25.000000000000004 25 35.669872981077809 -22.500000000000004 #
+face $-1 -1 -1 $-1 $17179 $17183 $11 $-1 $15707 reversed single T 20 35 -27.500000000000004 25 35.669872981077809 -22.500000000000004 F #
+loop $-1 -1 -1 $-1 $-1 $18656 $20118 T 22.499999999999993 35 -25.000000000000004 30 40 -9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $20119 $17218 $17186 $18670 reversed $18701 $-1 #
+edge $-1 -1 -1 $-1 $17239 1.5707963267948966 $17220 2.0943951023931948 $17186 $17229 forward @7 unknown T -37.5 20 35 -35 20.669872981077805 37.5 #
+coedge $-1 -1 -1 $-1 $17187 $17190 $20120 $20121 forward $17191 $-1 #
+coedge $-1 -1 -1 $-1 $18712 $17188 $20122 $18764 forward $18673 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17188 $17253 T -35 20 30 -25 25 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15775 $17191 $11 $-1 $8043 reversed single T -25 20 32.5 -20 20.669872981077813 37.5 F #
+coedge $-1 -1 -1 $-1 $17192 $17293 $15782 $17254 forward $17214 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17972 $17193 T -15 20 -40 -7.4999999999999964 25 -25 unknown #
+coedge $-1 -1 -1 $-1 $19492 $20123 $19486 $20124 reversed $17194 $-1 #
+edge $-1 -1 -1 $-1 $15813 6.1232339957367648e-17 $18846 1.5707963267948966 $18030 $20125 forward @7 unknown T 0 20 20 5.0000000000000018 25 25 #
+loop $-1 -1 -1 $-1 $16461 $20126 $1558 T 50 20 -29.999999999999996 50 30 -19.999999999999996 hole $1559 T #
+coedge $-1 -1 -1 $-1 $18681 $18681 $20127 $20128 forward $17201 $-1 #
+coedge $-1 -1 -1 $-1 $18682 $18682 $17202 $18683 reversed $18774 $-1 #
+edge $-1 -1 -1 $-1 $20129 0 $20129 6.2831853071795862 $17202 $20130 forward @7 unknown T 50 20 2.6645352591003757e-15 50 30 10.000000000000004 #
+loop $-1 -1 -1 $-1 $20131 $17203 $3147 T -50 20 29.999999999999996 -50 30 40 hole $3148 T #
+vertex $-1 -1 -1 $-1 $17204 $20132 #
+ellipse-curve $-1 -1 -1 $-1 -50 25 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $18694 $17207 $20133 $20134 reversed $17209 $-1 #
+coedge $-1 -1 -1 $-1 $17218 $20119 $17207 $18690 forward $18701 $-1 #
+edge $-1 -1 -1 $-1 $20135 -2.0943951023931944 $17210 -1.5707963267948966 $18689 $20136 forward @7 unknown T -40 20.000000000000004 32.5 -37.500000000000007 20.669872981077813 35 #
+coedge $-1 -1 -1 $-1 $17208 $20137 $20138 $20139 reversed $17209 $-1 #
+coedge $-1 -1 -1 $-1 $17226 $17222 $17208 $18693 forward $17227 $-1 #
+edge $-1 -1 -1 $-1 $17211 1.5707963267948966 $20140 2.0943951023931935 $18692 $20141 forward @7 unknown T -40 29.330127018922198 32.500000000000007 -37.500000000000007 30.000000000000004 35 #
+coedge $-1 -1 -1 $-1 $18777 $18688 $20142 $20143 reversed $17209 $-1 #
+face $-1 -1 -1 $-1 $15753 $17209 $11 $-1 $17225 reversed single T -45 20.000000000000004 19.999999999999996 -37.5 30.000000000000004 35 F #
+point $-1 -1 -1 $-1 -40 20.000000000000004 35 #
+point $-1 -1 -1 $-1 -40 30.000000000000004 35 #
+face $-1 -1 -1 $-1 $12746 $17214 $11 $-1 $11391 reversed single T -15 20 20 -7.4999999999999964 25 35 F #
+vertex $-1 -1 -1 $-1 $19548 $20144 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $17218 $17234 T -40 20 32.499999999999993 -35 20.669872981077813 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 20.669872981077802 37.5 #
+face $-1 -1 -1 $-1 $14261 $20145 $11 $-1 $17225 reversed single T -45 20.000000000000004 -40 -37.499999999999993 30.000000000000004 -25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $20138 $18710 $17226 $18707 forward $17235 $-1 #
+edge $-1 -1 -1 $-1 $17228 -1.5707963267948966 $20140 -1.0471975511965983 $18706 $20146 forward @7 unknown T -37.500000000000007 29.330127018922195 32.5 -35 30 35 #
+face $-1 -1 -1 $-1 $20147 $17227 $11 $-1 $8043 reversed single T -40 29.330127018922195 32.5 -35 30.000000000000004 37.5 F #
+point $-1 -1 -1 $-1 -35 30 35 #
+coedge $-1 -1 -1 $-1 $18706 $18713 $17231 $18711 forward $17235 $-1 #
+edge $-1 -1 -1 $-1 $18716 0 $17228 1.5707963267948966 $18710 $20148 forward @7 unknown T -35 25 30 -30 30 35 #
+coedge $-1 -1 -1 $-1 $17233 $18672 $20149 $20150 reversed $18673 $-1 #
+coedge $-1 -1 -1 $-1 $18710 $20151 $20152 $20153 forward $17235 $-1 #
+coedge $-1 -1 -1 $-1 $20154 $17236 $18713 $20153 reversed $18715 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20154 $19801 T -30 25 20 -22.5 30 35 unknown #
+vertex $-1 -1 -1 $-1 $18711 $20155 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $20135 1.0471975511965965 $17239 1.5707963267948966 $20156 $20146 forward @7 unknown T -37.500000000000007 20 32.499999999999993 -35 20.669872981077813 35 #
+point $-1 -1 -1 $-1 -35 20 35 #
+coedge $-1 -1 -1 $-1 $17240 $20157 $17245 $18726 reversed $18715 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $20158 $17242 T -30.000000000000007 20 -40 -22.499999999999996 25 -25 unknown #
+coedge $-1 -1 -1 $-1 $20159 $20160 $20161 $20162 reversed $17243 $-1 #
+coedge $-1 -1 -1 $-1 $17991 $17244 $17971 $19457 reversed $15772 $-1 #
+coedge $-1 -1 -1 $-1 $18730 $17245 $20163 $20164 forward $15781 $-1 #
+edge $-1 -1 -1 $-1 $17246 -32.5 $20165 -22.500000000000004 $17245 $20166 forward @7 unknown T -22.500000000000004 29.330127018922191 22.500000000000004 -22.5 29.330127018922195 32.5 #
+point $-1 -1 -1 $-1 -22.500000000000004 29.330127018922191 32.5 #
+face $-1 -1 -1 $-1 $20167 $20168 $11 $-1 $12796 reversed single T -22.500000000000004 25 4.9999999999999991 -15 30 20 F #
+loop $-1 -1 -1 $-1 $-1 $20152 $17248 T -37.500000000000007 20 19.999999999999993 -29.999999999999993 25 35 unknown #
+coedge $-1 -1 -1 $-1 $17249 $18725 $17268 $18758 forward $15781 $-1 #
+coedge $-1 -1 -1 $-1 $20169 $17251 $18676 $17254 reversed $18732 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18731 $17256 T -22.500000000000004 20 20 -15 25 35 unknown #
+straight-curve $-1 -1 -1 $-1 -15 25 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $18760 $18755 $11 $-1 $11403 reversed single T -9.9999999999999982 29.330127018922191 17.5 -5 30 22.5 F #
+point $-1 -1 -1 $-1 -22.500000000000004 20.669872981077813 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $17258 $20170 $20171 $20172 forward $18732 $-1 #
+face $-1 -1 -1 $-1 $20173 $20174 $11 $-1 $11391 reversed single T -15 20 -10 -7.4999999999999964 25 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $20175 $17259 T -15.000000000000004 20 -25 -7.4999999999999964 25 -10 unknown #
+coedge $-1 -1 -1 $-1 $20176 $20177 $20178 $20179 reversed $17260 $-1 #
+coedge $-1 -1 -1 $-1 $17261 $20180 $20181 $20182 reversed $15791 $-1 #
+edge $-1 -1 -1 $-1 $19510 -1.5707963267948966 $20183 6.1232339957367648e-17 $18019 $20184 forward @7 unknown T -14.999999999999998 25 -10 -9.9999999999999982 30 -5 #
+coedge $-1 -1 -1 $-1 $20185 $17262 $20186 $20187 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $20188 $20189 $17262 $18744 forward $20190 $-1 #
+edge $-1 -1 -1 $-1 $20191 -2.0943951023931953 $18751 -1.5707963267948966 $18743 $20192 forward @7 unknown T -9.9999999999999982 29.330127018922191 4.9999999999999991 -7.4999999999999964 30 7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $17263 $20185 $17269 $18759 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $20193 $20194 $20195 $18747 forward $20168 $-1 #
+edge $-1 -1 -1 $-1 $18752 10 $20196 15 $18746 $20197 forward @7 unknown T -15 25 10 -15 25 15 #
+coedge $-1 -1 -1 $-1 $20198 $17264 $20194 $20199 reversed $18750 $-1 #
+coedge $-1 -1 -1 $-1 $17264 $20198 $20180 $20200 forward $18750 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17264 $20201 T -20 25 -1.7763568394002505e-15 -9.9999999999999982 30 10 unknown #
+vertex $-1 -1 -1 $-1 $20200 $20202 #
+vertex $-1 -1 -1 $-1 $20203 $20204 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18766 $17266 $20185 $20205 forward $18755 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17266 $18734 T -9.9999999999999982 29.330127018922191 17.5 -5 30 22.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17269 $17268 $20193 $20206 reversed $17270 $-1 #
+edge $-1 -1 -1 $-1 $20207 1.5707963267948966 $17272 3.1415926535897931 $18730 $20208 forward @7 unknown T -20 25 20 -15 30 25 #
+edge $-1 -1 -1 $-1 $20196 -6.1232339957367648e-17 $17271 1.5707963267948966 $17269 $20209 forward @7 unknown T -15 25 15 -9.9999999999999982 30 20 #
+face $-1 -1 -1 $-1 $20210 $17270 $11 $-1 $11403 reversed single T -20 25 15 -9.9999999999999982 30 25 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 30 20 #
+edge $-1 -1 -1 $-1 $17272 3.1415926535897931 $20211 4.7123889803846897 $20169 $20208 forward @7 unknown T -20 20 20 -15 25 25 #
+point $-1 -1 -1 $-1 -15 25 25 #
+edge $-1 -1 -1 $-1 $17274 -1.5707963267948966 $18716 -6.1232339957367648e-17 $18672 $20212 forward @7 unknown T -30 20 30 -25 25 35 #
+point $-1 -1 -1 $-1 -25 20 35 #
+coedge $-1 -1 -1 $-1 $17276 $18754 $20213 $20214 reversed $18755 $-1 #
+vertex $-1 -1 -1 $-1 $20214 $20215 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.4999999999999964 29.330127018922191 22.5 #
+coedge $-1 -1 -1 $-1 $17299 $17280 $20216 $20217 reversed $14981 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20218 $20219 $11 $-1 $13449 reversed single T -50 20 -3.5527136788005009e-15 -40 30.000000000000004 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $20220 $17282 T -9.9999999999999982 20 2.5000000000000013 -5 20.669872981077805 7.5 unknown #
+loop $-1 -1 -1 $-1 $-1 $18682 $15802 T 50 20 2.6645352591003757e-15 50 30 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $18775 $18775 $17284 $18776 forward $20131 $-1 #
+edge $-1 -1 -1 $-1 $20221 0 $20221 6.2831853071795862 $18775 $20222 forward @7 unknown T -50 20 14.999999999999996 -50 30 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $20137 $18694 $17285 $18778 reversed $17209 $-1 #
+edge $-1 -1 -1 $-1 $18783 -1.5707963267948966 $18782 1.5707963267948966 $17285 $20223 forward @7 unknown T -45 20.000000000000004 19.999999999999996 -40 30.000000000000004 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $20224 $17286 $20225 $20226 reversed $18781 $-1 #
+coedge $-1 -1 -1 $-1 $17286 $20227 $20228 $20229 reversed $18781 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20230 $20231 T -45 20.000000000000004 4.9999999999999973 -37.499999999999993 30.000000000000004 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $17287 $20232 #
+vertex $-1 -1 -1 $-1 $17287 $20233 #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20234 $20235 $17288 $18786 forward $20236 $-1 #
+edge $-1 -1 -1 $-1 $18791 1.0471975511965983 $18787 1.5707963267948966 $18785 $20237 forward @7 unknown T -7.4999999999999973 20 17.5 -5 20.669872981077805 20 #
+vertex $-1 -1 -1 $-1 $18786 $20238 #
+coedge $-1 -1 -1 $-1 $20239 $17291 $20235 $20240 reversed $18790 $-1 #
+coedge $-1 -1 -1 $-1 $17291 $20241 $20242 $18795 reversed $18790 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20239 $20173 T -15 20 4.9999999999999991 -7.4999999999999964 25 20 unknown #
+vertex $-1 -1 -1 $-1 $18786 $20243 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20242 $20244 $17293 $18794 forward $20245 $-1 #
+edge $-1 -1 -1 $-1 $17272 6.1232339957367648e-17 $17294 1.5707963267948966 $18793 $20246 forward @7 unknown T -15 20 20 -9.9999999999999982 25 25 #
+edge $-1 -1 -1 $-1 $17294 -1.5707963267948966 $20196 -6.1232339957367648e-17 $20242 $20247 forward @7 unknown T -15 20 15 -9.9999999999999982 25 20 #
+point $-1 -1 -1 $-1 -9.9999999999999982 20 20 #
+point $-1 -1 -1 $-1 -7.5 20.669872981077805 22.500000000000004 #
+point $-1 -1 -1 $-1 50 25 15.000000000000004 #
+coedge $-1 -1 -1 $-1 $20248 $18806 $17299 $18800 reversed $17305 $-1 #
+edge $-1 -1 -1 $-1 $20249 -6.1232339957367648e-17 $17300 1.5707963267948966 $17299 $20250 forward @7 unknown T 0 25 15 5.0000000000000018 30 20 #
+point $-1 -1 -1 $-1 5.0000000000000018 30 20 #
+face $-1 -1 -1 $-1 $20251 $20252 $11 $-1 $9009 reversed single T 0 25 -25 7.5000000000000027 30 -10 F #
+loop $-1 -1 -1 $-1 $-1 $20253 $17304 T 0 25 -10 7.5000000000000027 30 5 unknown #
+coedge $-1 -1 -1 $-1 $20254 $20248 $19517 $20255 reversed $17305 $-1 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18799 $20256 $17307 $18807 reversed $17305 $-1 #
+edge $-1 -1 -1 $-1 $17300 1.5707963267948966 $18828 2.0943951023931953 $17307 $20257 forward @7 unknown T 5.0000000000000018 29.330127018922191 17.5 7.5000000000000009 30 20 #
+coedge $-1 -1 -1 $-1 $20258 $17370 $17309 $18809 forward $18867 $-1 #
+edge $-1 -1 -1 $-1 $18026 -2.0943951023931948 $20259 -1.570796326794897 $18808 $20260 forward @7 unknown T 5.0000000000000018 20 -27.499999999999996 7.5 20.669872981077805 -25 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17313 $17364 $20261 $20262 forward $17365 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17316 $17315 $20263 $20264 reversed $17317 $-1 #
+coedge $-1 -1 -1 $-1 $20261 $20265 $17315 $18815 reversed $20252 $-1 #
+edge $-1 -1 -1 $-1 $17318 -1.570796326794897 $20266 6.1232339957367648e-17 $17315 $20267 forward @7 unknown T 0 25 -25 5.0000000000000036 30 -19.999999999999996 #
+face $-1 -1 -1 $-1 $20268 $17317 $11 $-1 $14408 reversed single T -5 25 -30 5.0000000000000036 30 -19.999999999999996 F #
+point $-1 -1 -1 $-1 5.0000000000000018 30 -25 #
+coedge $-1 -1 -1 $-1 $17322 $17320 $20269 $20270 forward $15829 $-1 #
+coedge $-1 -1 -1 $-1 $20271 $20272 $17320 $18820 reversed $20273 $-1 #
+edge $-1 -1 -1 $-1 $18821 -1.5707963267948966 $20274 -1.0471975511965979 $17320 $20275 forward @7 unknown T -7.5 29.330127018922191 -27.5 -5 30 -25 #
+vertex $-1 -1 -1 $-1 $18820 $20276 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $20277 4.1887902047863914 $14971 4.7123889803846897 $17322 $18015 forward @7 unknown T -7.4999999999999982 29.330127018922191 -40 -5 30 -37.5 #
+coedge $-1 -1 -1 $-1 $17324 $18013 $20278 $20279 forward $17325 $-1 #
+coedge $-1 -1 -1 $-1 $20280 $19512 $17324 $18826 reversed $20281 $-1 #
+edge $-1 -1 -1 $-1 $20282 -1.5707963267948966 $15831 0 $17324 $18822 forward @7 unknown T -5 20 -30 0 25 -25 #
+coedge $-1 -1 -1 $-1 $18031 $17329 $20256 $20283 forward $13426 $-1 #
+vertex $-1 -1 -1 $-1 $20283 $20284 #
+ellipse-curve $-1 -1 -1 $-1 10 25 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $15877 $20236 $11 $-1 $9021 reversed single T -7.5 20 5 8.8817841970012523e-16 25 20 F #
+coedge $-1 -1 -1 $-1 $17333 $19518 $20234 $20285 reversed $16525 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 25 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 15 25 15 #
+vertex $-1 -1 -1 $-1 $17338 $20286 #
+coedge $-1 -1 -1 $-1 $17378 $20287 $17345 $17338 forward $17377 $-1 #
+face $-1 -1 -1 $-1 $20288 $20289 $11 $-1 $7081 reversed single T 15 20 -9.9999999999999982 22.500000000000004 25 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $18848 $17340 T 15 20 -25 22.5 25 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $20290 $17342 $20291 $20292 reversed $15849 $-1 #
+coedge $-1 -1 -1 $-1 $17342 $19534 $20293 $20294 reversed $15849 $-1 #
+coedge $-1 -1 -1 $-1 $20295 $20296 $17342 $18841 forward $20297 $-1 #
+edge $-1 -1 -1 $-1 $20298 -1.5707963267948966 $20299 6.1232339957367648e-17 $18840 $20300 forward @7 unknown T 15 25 -9.9999999999999982 20 30 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $18048 -2.0943951023931948 $18843 -1.5707963267948966 $18045 $20301 forward @7 unknown T 20 29.330127018922195 5.0000000000000009 22.500000000000007 30 7.5000000000000009 #
+vertex $-1 -1 -1 $-1 $19535 $20302 #
+ellipse-curve $-1 -1 -1 $-1 20 25 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17346 $17345 $20303 $20304 forward $17347 $-1 #
+vertex $-1 -1 -1 $-1 $20305 $20306 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19529 $20307 $17352 $18849 reversed $18837 $-1 #
+edge $-1 -1 -1 $-1 $17353 1.5707963267948961 $18922 2.0943951023931944 $17352 $20308 forward @7 unknown T 19.999999999999996 20 -25 22.499999999999996 20.669872981077805 -22.499999999999996 #
+point $-1 -1 -1 $-1 20 20 -25 #
+coedge $-1 -1 -1 $-1 $20309 $17355 $17425 $18915 reversed $17341 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20310 $17357 $20311 $18858 forward $18855 $-1 #
+coedge $-1 -1 -1 $-1 $17357 $20312 $17364 $18862 forward $18855 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18853 $20313 T 7.5000000000000009 25 -25 15 30 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 10 25 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17359 $20309 $20296 $20314 reversed $17341 $-1 #
+edge $-1 -1 -1 $-1 $17360 -20 $20315 -15 $18853 $20316 forward @7 unknown T 15 25 -20 15 25 -15 #
+edge $-1 -1 -1 $-1 $17360 3.1415926535897931 $17374 4.7123889803846897 $18868 $18856 forward @7 unknown T 10 20 -25 15 25 -20 #
+point $-1 -1 -1 $-1 15 25 -20 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000009 29.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $20317 4.1887902047863923 $15871 4.7123889803846897 $18854 $20318 forward @7 unknown T 7.5000000000000027 29.330127018922195 -25 10 30 -22.500000000000007 #
+face $-1 -1 -1 $-1 $20319 $17365 $11 $-1 $14408 reversed single T 4.9999999999999991 29.330127018922191 -27.5 10 30 -22.500000000000004 F #
+point $-1 -1 -1 $-1 7.5 29.330127018922191 -27.499999999999996 #
+point $-1 -1 -1 $-1 7.5000000000000027 29.330127018922202 -37.500000000000014 #
+coedge $-1 -1 -1 $-1 $17370 $20258 $20320 $20321 reversed $18867 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18808 $20322 T 4.9999999999999991 20 -27.5 10 20.669872981077813 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $20320 $20311 $17372 $18859 forward $20323 $-1 #
+point $-1 -1 -1 $-1 10 20 -25 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $20324 $17400 $17381 $18872 reversed $18895 $-1 #
+edge $-1 -1 -1 $-1 $19543 7.5000000000000027 $15886 17.5 $17381 $20325 forward @7 unknown T 22.499999999999996 20.669872981077805 7.5000000000000027 22.500000000000004 20.669872981077809 17.5 #
+coedge $-1 -1 -1 $-1 $20326 $20327 $20328 $20329 reversed $17383 $-1 #
+coedge $-1 -1 -1 $-1 $17387 $17384 $17396 $18893 reversed $12877 $-1 #
+coedge $-1 -1 -1 $-1 $20330 $17979 $17384 $18876 forward $18911 $-1 #
+edge $-1 -1 -1 $-1 $19465 -2.5000000000000049 $18880 7.499999999999992 $18875 $20331 forward @7 unknown T 37.499999999999993 29.330127018922191 -7.499999999999992 37.5 29.330127018922195 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $20332 $17385 $17418 $18907 forward $18879 $-1 #
+coedge $-1 -1 -1 $-1 $17385 $20332 $20330 $20333 reversed $18879 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18877 $20334 T 35 29.330127018922191 -12.500000000000004 40 30 -7.499999999999992 unknown #
+vertex $-1 -1 -1 $-1 $20333 $20335 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17388 $20336 $17390 $18888 forward $18884 $-1 #
+coedge $-1 -1 -1 $-1 $20337 $19544 $20338 $17389 reversed $17422 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17388 $18919 T 22.5 25 -9.9999999999999982 30 30 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $18051 $20339 #
+straight-curve $-1 -1 -1 $-1 30 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17391 $17390 $17423 $18913 reversed $17392 $-1 #
+edge $-1 -1 -1 $-1 $20340 1.570796326794897 $17394 3.1415926535897931 $18882 $20341 forward @7 unknown T 25 25 -9.9999999999999982 29.999999999999996 30 -4.9999999999999982 #
+face $-1 -1 -1 $-1 $17426 $17392 $11 $-1 $14961 reversed single T 25 25 -15 35 30 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 29.999999999999996 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $17394 3.1415926535897931 $20342 4.7123889803846897 $20337 $20341 forward @7 unknown T 24.999999999999996 20 -9.9999999999999982 29.999999999999996 25 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 25 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $15897 1.5707963267948966 $19465 2.0943951023931948 $17396 $20343 forward @7 unknown T 35 29.330127018922191 2.5000000000000049 37.5 29.999999999999996 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $20324 $20288 T 14.999999999999996 20 5.0000000000000009 22.500000000000004 25 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20 25 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20344 $17404 $17406 $18900 forward $17415 $-1 #
+coedge $-1 -1 -1 $-1 $17406 $19551 $20345 $20346 reversed $15889 $-1 #
+edge $-1 -1 -1 $-1 $17407 -22.499999999999989 $20347 -12.499999999999995 $18898 $20348 forward @7 unknown T 37.5 20.669872981077802 -22.499999999999989 37.5 20.669872981077805 -12.499999999999995 #
+point $-1 -1 -1 $-1 37.5 20.669872981077802 -22.499999999999989 #
+edge $-1 -1 -1 $-1 $15914 1.570796326794897 $15910 4.7123889803846897 $17413 $20349 forward @7 unknown T 39.999999999999993 20 -24.999999999999996 44.999999999999993 30 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $20350 $18904 T 50 20 -29.999999999999996 50 30 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $20351 $17410 $11 $-1 $14408 reversed single T 39.999999999999993 20 -29.999999999999996 50 30 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $17414 $20352 $20332 $20353 forward $17415 $-1 #
+face $-1 -1 -1 $-1 $11929 $17415 $11 $-1 $6139 reversed single T 37.499999999999993 20 -24.999999999999996 45 30 -9.9999999999999982 F #
+edge $-1 -1 -1 $-1 $17393 1.5707963267948966 $18908 2.0943951023931948 $18877 $20354 forward @7 unknown T 35 29.330127018922191 -12.500000000000002 37.5 29.999999999999996 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $18907 $20355 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $20356 $20357 $11 $-1 $14961 reversed single T 35 19.999999999999996 -12.499999999999996 40 20.669872981077809 -7.4999999999999929 F #
+loop $-1 -1 -1 $-1 $-1 $18875 $17421 T 37.499999999999993 20 -9.9999999999999982 45.000000000000007 30 5.0000000000000044 unknown #
+coedge $-1 -1 -1 $-1 $17425 $17423 $20358 $20359 forward $15921 $-1 #
+edge $-1 -1 -1 $-1 $17428 0 $20340 1.5707963267948966 $17423 $20360 forward @7 unknown T 25 25 -14.999999999999998 30 30 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $17424 $20361 $20362 $20363 forward $17436 $-1 #
+edge $-1 -1 -1 $-1 $20364 12.499999999999996 $17430 22.500000000000007 $17425 $20365 forward @7 unknown T 22.5 29.330127018922195 -22.500000000000007 22.5 29.330127018922195 -12.499999999999996 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 30 25 -14.999999999999998 #
+point $-1 -1 -1 $-1 22.5 29.330127018922195 -22.500000000000007 #
+face $-1 -1 -1 $-1 $20366 $18884 $11 $-1 $6162 reversed single T 22.5 25 -9.9999999999999982 30 30 5.0000000000000036 F #
+loop $-1 -1 -1 $-1 $-1 $20367 $17432 T 7.5 20 -10 15.000000000000004 25 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $20361 $17433 $20307 $20368 forward $17436 $-1 #
+vertex $-1 -1 -1 $-1 $20368 $20369 #
+face $-1 -1 -1 $-1 $18906 $17436 $11 $-1 $6162 reversed single T 22.499999999999993 20 -25.000000000000004 30 25 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $17457 $17437 $18961 $17486 reversed $17469 $-1 #
+coedge $-1 -1 -1 $-1 $18976 $18927 $17439 $18926 reversed $20370 $-1 #
+edge $-1 -1 -1 $-1 $16007 -2.0943951023931953 $16024 -1.5707963267948966 $17439 $20371 forward @7 unknown T -25 5.0000000000000018 32.5 -22.5 5.6698729810778099 35 #
+coedge $-1 -1 -1 $-1 $18925 $20372 $17440 $17532 reversed $20370 $-1 #
+coedge $-1 -1 -1 $-1 $17446 $20373 $20374 $20375 reversed $15944 $-1 #
+edge $-1 -1 -1 $-1 $18106 -35 $20376 -30 $18104 $20377 forward @7 unknown T -15 10 -35 -15 10 -30 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18931 $18931 $19155 $20378 forward $17448 $-1 #
+coedge $-1 -1 -1 $-1 $18932 $18932 $17449 $18933 reversed $20379 $-1 #
+edge $-1 -1 -1 $-1 $20380 0 $20380 6.2831853071795862 $17449 $20381 forward @7 unknown T 50 5 -14.999999999999996 50 15 -4.9999999999999964 #
+vertex $-1 -1 -1 $-1 $17451 $20382 #
+ellipse-curve $-1 -1 -1 $-1 50 10 5.0000000000000027 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $20383 $17543 $3147 T -50 5 14.999999999999996 -50 15 24.999999999999996 hole $3148 T #
+point $-1 -1 -1 $-1 -50 10 29.999999999999996 #
+coedge $-1 -1 -1 $-1 $18961 $20384 $17456 $18939 forward $17497 $-1 #
+edge $-1 -1 -1 $-1 $20385 22.499999999999996 $18940 32.5 $18938 $20386 forward @7 unknown T -37.500000000000007 5.6698729810778064 22.499999999999996 -37.5 5.6698729810778072 32.5 #
+vertex $-1 -1 -1 $-1 $17486 $20387 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 35 -0.70710678118654768 -0 -0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $17459 $17545 $20388 $20389 reversed $15959 $-1 #
+coedge $-1 -1 -1 $-1 $20390 $17474 $17459 $18944 forward $15985 $-1 #
+edge $-1 -1 -1 $-1 $18945 -32.5 $20391 -22.499999999999993 $18943 $20392 forward @7 unknown T -37.5 14.330127018922193 22.499999999999993 -37.5 14.330127018922195 32.5 #
+vertex $-1 -1 -1 $-1 $18944 $20393 #
+coedge $-1 -1 -1 $-1 $20394 $19030 $17462 $18948 forward $20395 $-1 #
+edge $-1 -1 -1 $-1 $17550 1.5707963267948966 $20385 2.0943951023931948 $18947 $20396 forward @7 unknown T -40 5.0000000000000018 19.999999999999996 -37.5 5.6698729810778081 22.499999999999996 #
+point $-1 -1 -1 $-1 37.500000000000014 5.6698729810778072 7.5000000000000036 #
+loop $-1 -1 -1 $-1 $-1 $20397 $17473 T -45 5.0000000000000018 -40 -37.499999999999993 15.000000000000002 -25.000000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 10 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20398 $20399 $11 $-1 $10937 reversed single T -37.500000000000007 10 4.9999999999999982 -30 15 19.999999999999996 F #
+ellipse-curve $-1 -1 -1 $-1 -35 10 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18957 $18961 $17480 $18955 forward $17497 $-1 #
+edge $-1 -1 -1 $-1 $15989 -1.5707963267948966 $17484 0 $18954 $18953 forward @7 unknown T -35 5 30 -30 10 35 #
+coedge $-1 -1 -1 $-1 $17481 $20390 $20400 $20401 forward $15985 $-1 #
+coedge $-1 -1 -1 $-1 $20402 $18954 $20372 $18958 reversed $17497 $-1 #
+edge $-1 -1 -1 $-1 $20403 24.999999999999996 $17484 30 $17481 $20404 forward @7 unknown T -30 10 24.999999999999996 -29.999999999999993 10 30 #
+coedge $-1 -1 -1 $-1 $18962 $17482 $20405 $20406 reversed $17483 $-1 #
+point $-1 -1 -1 $-1 -30 10 30 #
+coedge $-1 -1 -1 $-1 $18954 $18938 $18924 $17486 forward $17497 $-1 #
+coedge $-1 -1 -1 $-1 $17488 $18959 $20407 $20408 reversed $17483 $-1 #
+coedge $-1 -1 -1 $-1 $19580 $20409 $18096 $19586 reversed $17490 $-1 #
+coedge $-1 -1 -1 $-1 $19565 $17491 $19583 $20410 reversed $15993 $-1 #
+coedge $-1 -1 -1 $-1 $17491 $20411 $20412 $20413 reversed $15993 $-1 #
+coedge $-1 -1 -1 $-1 $20414 $20415 $19793 $18967 forward $20416 $-1 #
+edge $-1 -1 -1 $-1 $19795 -35 $20417 -30.000000000000004 $18966 $20418 forward @7 unknown T -30.000000000000007 10 -35 -30 10 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $20407 $20419 $17493 $18969 reversed $20420 $-1 #
+edge $-1 -1 -1 $-1 $18970 4.1887902047863923 $19012 4.7123889803846897 $17493 $20421 forward @7 unknown T -22.499999999999993 14.330127018922193 20 -20 15 22.499999999999993 #
+vertex $-1 -1 -1 $-1 $18969 $20422 #
+straight-curve $-1 -1 -1 $-1 -22.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $20423 $20424 $11 $-1 $10259 reversed single T -35 10 14.999999999999996 -25 15.000000000000002 25 F #
+loop $-1 -1 -1 $-1 $-1 $17514 $17496 T -22.500000000000004 10 4.9999999999999991 -15 15 20 unknown #
+coedge $-1 -1 -1 $-1 $18975 $17499 $19049 $17530 forward $17500 $-1 #
+coedge $-1 -1 -1 $-1 $17504 $18974 $20425 $20426 forward $17500 $-1 #
+coedge $-1 -1 -1 $-1 $20427 $18925 $17504 $18977 reversed $20370 $-1 #
+edge $-1 -1 -1 $-1 $20428 22.5 $16007 32.5 $17504 $20429 forward @7 unknown T -22.5 5.6698729810778064 22.5 -22.5 5.6698729810778081 32.5 #
+face $-1 -1 -1 $-1 $17466 $17558 $11 $-1 $10247 reversed single T -15 4.9999999999999991 4.9999999999999991 -7.4999999999999991 10 20 F #
+loop $-1 -1 -1 $-1 $-1 $20430 $17505 T -15 4.9999999999999991 -10 -7.4999999999999991 10 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $20431 $20432 $20433 $20434 reversed $17506 $-1 #
+coedge $-1 -1 -1 $-1 $19614 $17507 $20435 $20436 reversed $16010 $-1 #
+coedge $-1 -1 -1 $-1 $17507 $19610 $20437 $20438 reversed $16010 $-1 #
+coedge $-1 -1 -1 $-1 $20439 $20374 $17507 $18984 forward $20440 $-1 #
+edge $-1 -1 -1 $-1 $20441 -1.570796326794897 $20442 6.1232339957367648e-17 $18983 $20443 forward @7 unknown T -15 10 -25 -9.9999999999999982 15 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $17508 $19622 $17517 $19005 reversed $14492 $-1 #
+coedge $-1 -1 -1 $-1 $20444 $19608 $20445 $18987 forward $20446 $-1 #
+edge $-1 -1 -1 $-1 $18988 -5.0000000000000018 $20447 -8.8817841970012523e-16 $18986 $20448 forward @7 unknown T -15 10 -5.0000000000000018 -14.999999999999996 10 -8.8817841970012523e-16 #
+vertex $-1 -1 -1 $-1 $20449 $20450 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17513 $17510 $17522 $19010 reversed $12983 $-1 #
+coedge $-1 -1 -1 $-1 $20451 $19018 $17510 $18992 forward $20452 $-1 #
+edge $-1 -1 -1 $-1 $20453 -17.5 $18996 -7.5000000000000044 $18991 $20454 forward @7 unknown T -7.5000000000000044 14.330127018922193 7.5000000000000044 -7.5 14.330127018922195 17.5 #
+coedge $-1 -1 -1 $-1 $20455 $17511 $19622 $20456 forward $18995 $-1 #
+coedge $-1 -1 -1 $-1 $17511 $20455 $20451 $20457 reversed $18995 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17511 $20458 T -10 14.330127018922191 2.4999999999999991 -5 15 7.5000000000000044 unknown #
+vertex $-1 -1 -1 $-1 $20457 $20459 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20460 $17514 $17525 $19011 forward $18973 $-1 #
+coedge $-1 -1 -1 $-1 $17514 $20461 $17516 $19004 forward $18973 $-1 #
+coedge $-1 -1 -1 $-1 $20462 $20463 $19046 $17515 reversed $20464 $-1 #
+vertex $-1 -1 -1 $-1 $19011 $20465 #
+straight-curve $-1 -1 -1 $-1 -15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17517 $17516 $20444 $20466 reversed $17518 $-1 #
+edge $-1 -1 -1 $-1 $20467 1.5707963267948966 $17520 3.1415926535897931 $18999 $20468 forward @7 unknown T -20 10 4.9999999999999991 -15 15 10 #
+edge $-1 -1 -1 $-1 $20447 -6.1232339957367648e-17 $17519 1.5707963267948966 $17517 $20469 forward @7 unknown T -15 10 -1.7763568394002505e-15 -10 15 4.9999999999999991 #
+face $-1 -1 -1 $-1 $20470 $17518 $11 $-1 $12076 reversed single T -20 10 -1.7763568394002505e-15 -10 15 10 F #
+point $-1 -1 -1 $-1 -10 15 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $17520 3.1415926535897931 $20471 4.7123889803846897 $20462 $20468 forward @7 unknown T -20 4.9999999999999991 4.9999999999999991 -15 10 10 #
+point $-1 -1 -1 $-1 -15 10 10 #
+edge $-1 -1 -1 $-1 $16021 1.5707963267948966 $20453 2.0943951023931957 $17522 $20472 forward @7 unknown T -10 14.330127018922191 17.5 -7.4999999999999991 15 20 #
+edge $-1 -1 -1 $-1 $19001 0 $19012 1.5707963267948966 $18998 $20473 forward @7 unknown T -20 10 15 -15 15 20 #
+vertex $-1 -1 -1 $-1 $20474 $20475 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20476 $19050 $11 $-1 $10259 reversed single T -20 5 15 -10 10 25 F #
+vertex $-1 -1 -1 $-1 $20477 $20478 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18991 $19021 $17534 $19019 forward $20452 $-1 #
+edge $-1 -1 -1 $-1 $17535 -1.5707963267948966 $20453 -1.0471975511965974 $19018 $19042 forward @7 unknown T -7.5000000000000009 14.330127018922191 17.5 -5 15 20 #
+point $-1 -1 -1 $-1 -5 15 20 #
+coedge $-1 -1 -1 $-1 $19018 $20479 $17538 $19022 forward $20452 $-1 #
+edge $-1 -1 -1 $-1 $19054 0 $17535 1.5707963267948966 $19021 $20480 forward @7 unknown T -5 10 15 0 15 20 #
+face $-1 -1 -1 $-1 $20481 $20452 $11 $-1 $8113 reversed single T -7.5000000000000044 10 5 8.8817841970012523e-16 15 20 F #
+loop $-1 -1 -1 $-1 $20482 $20483 $17540 T -45 5.0000000000000009 -3.5527136788005009e-15 -40 15.000000000000004 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $20484 $20485 $19044 $20486 forward $17541 $-1 #
+vertex $-1 -1 -1 $-1 $17544 $20487 #
+ellipse-curve $-1 -1 -1 $-1 -50 10 19.999999999999996 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 19.999999999999996 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19035 $17547 $20488 $20489 reversed $17549 $-1 #
+coedge $-1 -1 -1 $-1 $18947 $20490 $17547 $19031 forward $20395 $-1 #
+edge $-1 -1 -1 $-1 $20491 -2.0943951023931944 $17550 -1.5707963267948966 $19030 $20492 forward @7 unknown T -40 5.0000000000000018 17.5 -37.500000000000007 5.6698729810778108 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $17548 $20493 $20494 $20495 reversed $17549 $-1 #
+coedge $-1 -1 -1 $-1 $20496 $20388 $17548 $19034 forward $20497 $-1 #
+edge $-1 -1 -1 $-1 $17551 1.5707963267948966 $20498 2.0943951023931948 $19033 $20499 forward @7 unknown T -40 14.330127018922195 17.499999999999993 -37.5 15.000000000000002 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $20500 $19029 $20501 $20502 reversed $17549 $-1 #
+face $-1 -1 -1 $-1 $17463 $17549 $11 $-1 $15975 reversed single T -45 5.0000000000000009 4.9999999999999973 -37.5 15.000000000000004 19.999999999999996 F #
+point $-1 -1 -1 $-1 -40 5.0000000000000018 19.999999999999996 #
+point $-1 -1 -1 $-1 -40 15.000000000000002 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $20503 $17553 $17599 $19090 forward $19041 $-1 #
+coedge $-1 -1 -1 $-1 $17553 $20504 $17556 $19045 forward $19041 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20503 $17598 T -7.5000000000000009 5 5 8.8817841970012523e-16 10 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 10 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 5 20 #
+coedge $-1 -1 -1 $-1 $20505 $17556 $19025 $20486 reversed $17558 $-1 #
+edge $-1 -1 -1 $-1 $20506 7.5 $17559 17.5 $19040 $20507 forward @7 unknown T -7.5 5.6698729810778064 7.5 -7.5 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $17557 $20505 $16013 $17515 forward $17558 $-1 #
+coedge $-1 -1 -1 $-1 $20508 $17561 $17557 $17563 forward $19050 $-1 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $17561 $20508 $18974 $17530 reversed $19050 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17561 $19015 T -20 5 15 -10 10 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17572 $17567 $20479 $20509 reversed $16055 $-1 #
+vertex $-1 -1 -1 $-1 $19022 $20510 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20511 $20512 $11 $-1 $8101 reversed single T 0 4.9999999999999991 -25 7.5000000000000018 10 -10 F #
+loop $-1 -1 -1 $-1 $-1 $17582 $17570 T 0 10 -25 7.5000000000000018 15 -10 unknown #
+coedge $-1 -1 -1 $-1 $20513 $20514 $20515 $20516 reversed $17571 $-1 #
+coedge $-1 -1 -1 $-1 $19061 $17572 $19634 $20517 reversed $16055 $-1 #
+edge $-1 -1 -1 $-1 $20518 -1.5707963267948966 $20519 6.1232339957367673e-17 $18135 $20520 forward @7 unknown T 0 10 5 5.0000000000000009 15 10 #
+coedge $-1 -1 -1 $-1 $17574 $19059 $17595 $19088 reversed $16055 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17634 $17576 $20521 $20522 forward $17635 $-1 #
+vertex $-1 -1 -1 $-1 $18131 $20523 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20524 $17582 $17579 $19067 reversed $19057 $-1 #
+edge $-1 -1 -1 $-1 $19122 -2.0943951023931948 $16068 -1.5707963267948966 $17579 $20525 forward @7 unknown T 5.0000000000000009 14.330127018922195 -25 7.5000000000000009 15 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $20526 $20527 $17581 $19069 forward $20528 $-1 #
+edge $-1 -1 -1 $-1 $17589 1.5707963267948966 $19071 3.1415926535897931 $19068 $20529 forward @7 unknown T -5 10 -25 0 15 -20 #
+coedge $-1 -1 -1 $-1 $17582 $20530 $20526 $20531 reversed $19057 $-1 #
+vertex $-1 -1 -1 $-1 $20532 $20533 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19127 $19086 $11 $-1 $13102 reversed single T -5 4.9999999999999991 -30 5.0000000000000009 10 -20 F #
+coedge $-1 -1 -1 $-1 $20373 $19559 $17586 $19075 reversed $15944 $-1 #
+edge $-1 -1 -1 $-1 $19079 27.499999999999996 $19082 37.5 $17586 $20534 forward @7 unknown T -7.5 14.330127018922193 -37.5 -7.4999999999999982 14.330127018922195 -27.499999999999996 #
+coedge $-1 -1 -1 $-1 $20435 $17587 $20527 $20535 reversed $19078 $-1 #
+coedge $-1 -1 -1 $-1 $17587 $20435 $20373 $20536 forward $19078 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19077 $20537 T -10.000000000000002 14.330127018922191 -27.5 -5 15 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $20536 $20538 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 15 -25 #
+vertex $-1 -1 -1 $-1 $17591 $20539 #
+coedge $-1 -1 -1 $-1 $20540 $20541 $17592 $19084 reversed $20542 $-1 #
+edge $-1 -1 -1 $-1 $19600 1.0471975511965974 $19087 1.5707963267948966 $17592 $19080 forward @7 unknown T -7.5000000000000009 5 -27.500000000000004 -5 5.669872981077809 -25 #
+coedge $-1 -1 -1 $-1 $19626 $17593 $20543 $20532 reversed $19086 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18130 $19073 T -5 4.9999999999999991 -30 5.0000000000000009 10 -20 unknown #
+vertex $-1 -1 -1 $-1 $19084 $20544 #
+edge $-1 -1 -1 $-1 $17596 -17.500000000000004 $19637 -7.5 $17595 $20545 forward @7 unknown T 7.5 14.330127018922195 7.5 7.5000000000000027 14.330127018922195 17.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000027 14.330127018922195 17.500000000000004 #
+edge $-1 -1 -1 $-1 $17555 -1.5707963267948966 $19054 0 $19039 $20480 forward @7 unknown T -5 5 15 0 10 20 #
+point $-1 -1 -1 $-1 7.5000000000000018 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $17603 $18142 $20546 $20547 forward $16127 $-1 #
+face $-1 -1 -1 $-1 $12928 $17663 $11 $-1 $6219 reversed single T 14.999999999999996 4.9999999999999973 5.0000000000000009 22.500000000000004 10 20 F #
+loop $-1 -1 -1 $-1 $-1 $20548 $17604 T 15 4.9999999999999973 -9.9999999999999982 22.500000000000007 10 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $19655 $17606 $19659 $19660 reversed $14550 $-1 #
+coedge $-1 -1 -1 $-1 $20549 $20550 $17606 $19097 forward $20551 $-1 #
+edge $-1 -1 -1 $-1 $20552 -2.0943951023931948 $19103 -1.5707963267948966 $19096 $20553 forward @7 unknown T 20 14.330127018922191 -9.9999999999999982 22.5 14.999999999999998 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $19639 $20554 $19172 $19099 forward $20555 $-1 #
+edge $-1 -1 -1 $-1 $19104 -5 $19656 8.8817841970012523e-16 $19098 $20556 forward @7 unknown T 15 10 -5 15.000000000000004 10 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $20557 $17608 $20554 $20558 reversed $19102 $-1 #
+coedge $-1 -1 -1 $-1 $17608 $20557 $17625 $19119 forward $19102 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17608 $20559 T 10 10 -15 20 15 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $19119 $20560 #
+vertex $-1 -1 -1 $-1 $20561 $20562 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 14.999999999999998 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $20546 $19633 $17613 $19109 reversed $20563 $-1 #
+edge $-1 -1 -1 $-1 $17602 -2.0943951023931957 $17614 -1.5707963267948966 $17613 $20564 forward @7 unknown T 5.0000000000000009 4.9999999999999991 17.5 7.5000000000000018 5.6698729810778072 20 #
+edge $-1 -1 -1 $-1 $17614 -1.5707963267948966 $19054 -6.1232339957367648e-17 $18136 $20565 forward @7 unknown T 0 4.9999999999999991 15 5.0000000000000009 10 20 #
+point $-1 -1 -1 $-1 5.0000000000000009 5 20 #
+coedge $-1 -1 -1 $-1 $17616 $20566 $17689 $19173 reversed $17605 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17625 $17619 $20549 $20567 reversed $16091 $-1 #
+coedge $-1 -1 -1 $-1 $20568 $17621 $20557 $20569 forward $17623 $-1 #
+coedge $-1 -1 -1 $-1 $17636 $20570 $19647 $17626 reversed $19128 $-1 #
+coedge $-1 -1 -1 $-1 $17622 $20568 $20524 $20571 forward $17623 $-1 #
+face $-1 -1 -1 $-1 $11426 $17623 $11 $-1 $6231 reversed single T 7.5 10 -25 15 15 -10 F #
+edge $-1 -1 -1 $-1 $19120 2.9403902792268234e-16 $19103 1.5707963267948966 $19101 $20572 forward @7 unknown T 15 10 -15 20 14.999999999999998 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $20569 $20573 #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $17630 $20574 #
+ellipse-curve $-1 -1 -1 $-1 10 10 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20575 $20576 $11 $-1 $8113 reversed single T -7.5000000000000009 4.9999999999999991 -10 8.8817841970012523e-16 10 5 F #
+coedge $-1 -1 -1 $-1 $20577 $17636 $17634 $19126 forward $19128 $-1 #
+edge $-1 -1 -1 $-1 $16124 1.5707963267948966 $20578 2.0943951023931948 $19125 $19123 forward @7 unknown T 7.5000000000000018 5 -25 10 5.6698729810778072 -22.5 #
+face $-1 -1 -1 $-1 $17631 $17635 $11 $-1 $13102 reversed single T 5.0000000000000009 4.9999999999999991 -27.5 10 5.6698729810778081 -22.5 F #
+loop $-1 -1 -1 $-1 $-1 $19116 $20579 T 7.5 5 -25 15 10 -10 unknown #
+coedge $-1 -1 -1 $-1 $18145 $17639 $18149 $19650 reversed $17663 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19143 $17641 $20580 $20581 reversed $16133 $-1 #
+coedge $-1 -1 -1 $-1 $17641 $19669 $20582 $20583 reversed $16133 $-1 #
+coedge $-1 -1 -1 $-1 $20584 $19150 $17641 $19134 forward $19162 $-1 #
+edge $-1 -1 -1 $-1 $20585 1.5707963267948966 $20586 2.0943951023931948 $19133 $20587 forward @7 unknown T 35 4.9999999999999982 -9.9999999999999982 37.5 5.6698729810778064 -7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $20588 $17643 $17646 $19138 forward $17679 $-1 #
+straight-curve $-1 -1 -1 $-1 37.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17646 $17645 $17673 $19158 reversed $17647 $-1 #
+edge $-1 -1 -1 $-1 $17648 4.1887902047863905 $20589 4.7123889803846897 $19135 $20590 forward @7 unknown T 37.5 14.330127018922191 -9.9999999999999982 40 15 -7.4999999999999947 #
+face $-1 -1 -1 $-1 $20591 $17647 $11 $-1 $13497 reversed single T 35 14.330127018922189 -12.500000000000002 40 15 -7.4999999999999947 F #
+point $-1 -1 -1 $-1 37.5 14.330127018922195 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $17650 $19659 $20550 $20592 forward $17652 $-1 #
+coedge $-1 -1 -1 $-1 $20593 $17651 $20594 $17659 forward $16172 $-1 #
+coedge $-1 -1 -1 $-1 $18171 $19131 $14592 $16139 forward $16133 $-1 #
+point $-1 -1 -1 $-1 29.999999999999996 10 1.7763568394002505e-15 #
+vertex $-1 -1 -1 $-1 $19164 $20595 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 -9.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $20596 $20597 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19157 $17666 $20598 $20599 forward $16165 $-1 #
+coedge $-1 -1 -1 $-1 $19133 $20598 $17667 $19151 forward $19162 $-1 #
+edge $-1 -1 -1 $-1 $19152 -2.0943951023931966 $20585 -1.5707963267948966 $19150 $20600 forward @7 unknown T 35 4.9999999999999982 -12.500000000000004 37.500000000000007 5.669872981077809 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $20599 $20601 #
+straight-curve $-1 -1 -1 $-1 37.5 5.6698729810778064 0 0 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 10 -24.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19155 $19155 $18931 $20378 reversed $17671 $-1 #
+face $-1 -1 -1 $-1 $20602 $20603 $11 $-1 $13102 reversed single T -50 5 -30.000000000000004 -40 15.000000000000002 -20.000000000000004 F #
+coedge $-1 -1 -1 $-1 $17673 $19149 $20604 $20605 forward $16165 $-1 #
+edge $-1 -1 -1 $-1 $20589 -1.5707963267948966 $17676 -1.0471975511965974 $17673 $20606 forward @7 unknown T 37.5 14.330127018922191 -12.500000000000002 40 15 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.5 14.330127018922193 -12.500000000000002 #
+face $-1 -1 -1 $-1 $17657 $20607 $11 $-1 $13497 reversed single T 24.999999999999996 4.9999999999999982 -15 35 10 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $19150 $17678 T 35 4.9999999999999982 -12.500000000000004 40 5.669872981077809 -7.5000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $20550 $20549 $17680 $19164 reversed $20551 $-1 #
+edge $-1 -1 -1 $-1 $19145 -1.570796326794897 $19169 -1.0471975511965979 $17680 $20608 forward @7 unknown T 22.499999999999996 14.330127018922191 -12.499999999999998 25 15 -9.9999999999999964 #
+ellipse-curve $-1 -1 -1 $-1 25 10 -9.9999999999999982 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17682 $17689 $20609 $20596 forward $16186 $-1 #
+coedge $-1 -1 -1 $-1 $20594 $19667 $17682 $19168 reversed $20607 $-1 #
+edge $-1 -1 -1 $-1 $19147 -1.5707963267948966 $16178 0 $17682 $19165 forward @7 unknown T 25 4.9999999999999991 -14.999999999999998 30 10 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $20567 $20610 #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $20611 $20612 $11 $-1 $13497 reversed single T 20 4.9999999999999982 -12.5 25 5.6698729810778072 -7.4999999999999973 F #
+coedge $-1 -1 -1 $-1 $20613 $20614 $20615 $19099 reversed $17688 $-1 #
+edge $-1 -1 -1 $-1 $17690 -22.500000000000004 $20616 -12.499999999999996 $17689 $20617 forward @7 unknown T 22.5 5.6698729810778055 -22.500000000000004 22.500000000000004 5.6698729810778072 -12.499999999999996 #
+point $-1 -1 -1 $-1 22.5 5.6698729810778055 -22.500000000000004 #
+loop $-1 -1 -1 $-1 $-1 $19226 $20618 T -30 -9.9999999999999982 20 -22.5 -4.9999999999999991 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17695 $20619 $16223 $17718 forward $19175 $-1 #
+coedge $-1 -1 -1 $-1 $17696 $17826 $17829 $19320 reversed $14645 $-1 #
+coedge $-1 -1 -1 $-1 $17743 $19700 $17696 $19180 forward $19239 $-1 #
+edge $-1 -1 -1 $-1 $19181 -2.3886802389739258e-16 $19240 1.5707963267948961 $19179 $20620 forward @7 unknown T -15 -5 -30 -10 8.8817841970012523e-16 -25 #
+vertex $-1 -1 -1 $-1 $19701 $20621 #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17699 $19201 $19193 $20622 forward $16238 $-1 #
+vertex $-1 -1 -1 $-1 $17709 $20623 #
+straight-curve $-1 -1 -1 $-1 -37.5 -9.330127018922191 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -37.5 -9.3301270189221945 32.5 #
+coedge $-1 -1 -1 $-1 $17791 $20624 $17703 $19188 forward $19292 $-1 #
+edge $-1 -1 -1 $-1 $19190 -2.0943951023931939 $16289 -1.5707963267948966 $19187 $20625 forward @7 unknown T -40 -0.66987298107780424 19.999999999999996 -37.500000000000007 2.6645352591003757e-15 22.499999999999989 #
+coedge $-1 -1 -1 $-1 $17716 $17704 $20624 $20626 forward $14679 $-1 #
+vertex $-1 -1 -1 $-1 $20626 $20627 #
+straight-curve $-1 -1 -1 $-1 -37.5 -0.66987298107780457 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -37.5 -0.66987298107780635 32.500000000000007 #
+coedge $-1 -1 -1 $-1 $19285 $17708 $19183 $20622 reversed $19194 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17708 $19197 T -40 -10 17.499999999999989 -35 -9.3301270189221874 22.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20628 $19802 $18180 $19678 reversed $17710 $-1 #
+face $-1 -1 -1 $-1 $20629 $19194 $11 $-1 $8848 reversed single T -40 -10 17.499999999999989 -35 -9.3301270189221874 22.5 F #
+loop $-1 -1 -1 $-1 $-1 $20630 $17712 T -37.5 -5 4.9999999999999982 -30 0 19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $20631 $19204 $17716 $19200 reversed $19223 $-1 #
+edge $-1 -1 -1 $-1 $20632 1.5707963267948957 $19202 3.1415926535897931 $17716 $20633 forward @7 unknown T -35 -4.9999999999999991 19.999999999999993 -29.999999999999993 0 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $19183 $17717 $20634 $20635 forward $16238 $-1 #
+vertex $-1 -1 -1 $-1 $20635 $20636 #
+straight-curve $-1 -1 -1 $-1 -30 -4.9999999999999991 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19199 $20637 $17719 $19205 forward $19223 $-1 #
+edge $-1 -1 -1 $-1 $20638 -1.5707963267948966 $19202 2.3886802389739288e-16 $19204 $20639 forward @7 unknown T -30 -4.9999999999999991 20 -25 1.7763568394002505e-15 25 #
+coedge $-1 -1 -1 $-1 $20640 $17728 $17722 $19207 forward $19219 $-1 #
+edge $-1 -1 -1 $-1 $17730 -2.0943951023931957 $20638 -1.5707963267948966 $19206 $20641 forward @7 unknown T -25 -0.66987298107780724 20 -22.5 1.7763568394002505e-15 22.5 #
+coedge $-1 -1 -1 $-1 $17723 $20642 $18201 $19696 reversed $16231 $-1 #
+edge $-1 -1 -1 $-1 $18185 -1.5707963267948966 $18320 2.3886802389739268e-16 $18197 $20643 forward @7 unknown T -30 -4.9999999999999991 -40 -25 1.7763568394002505e-15 -35 #
+coedge $-1 -1 -1 $-1 $17725 $19682 $20644 $20645 reversed $14687 $-1 #
+coedge $-1 -1 -1 $-1 $20646 $20647 $17725 $19212 forward $20648 $-1 #
+edge $-1 -1 -1 $-1 $19216 -4.1650370783741719e-16 $20649 1.5707963267948961 $19211 $20650 forward @7 unknown T -30.000000000000007 -5 -30.000000000000004 -25 1.7763568394002505e-15 -25 #
+coedge $-1 -1 -1 $-1 $20651 $17726 $20647 $20652 forward $19215 $-1 #
+coedge $-1 -1 -1 $-1 $17726 $20653 $18325 $19812 forward $19215 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17726 $20654 T -37.500000000000007 -5 -40 -30 0 -25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $20652 $20655 #
+coedge $-1 -1 -1 $-1 $17728 $20640 $19259 $19273 reversed $19219 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19206 $20656 T -25 -0.66987298107780902 17.5 -20 1.7763568394002505e-15 22.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 -0.66987298107780657 22.5 #
+face $-1 -1 -1 $-1 $20657 $20658 $11 $-1 $8848 reversed single T -35 -10 14.999999999999996 -25 -4.9999999999999991 25 F #
+loop $-1 -1 -1 $-1 $-1 $19204 $17732 T -35 -5 14.999999999999996 -25 1.7763568394002505e-15 25 unknown #
+coedge $-1 -1 -1 $-1 $20659 $20660 $17735 $19225 reversed $20661 $-1 #
+edge $-1 -1 -1 $-1 $17776 1.5707963267948966 $19227 2.0943951023931957 $17735 $19220 forward @7 unknown T -22.5 -10 20 -20 -9.330127018922191 22.5 #
+coedge $-1 -1 -1 $-1 $20619 $17736 $20660 $20662 reversed $19175 $-1 #
+vertex $-1 -1 -1 $-1 $20662 $20663 #
+straight-curve $-1 -1 -1 $-1 -22.5 -9.3301270189221928 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18219 $20664 $18409 $19862 reversed $17739 $-1 #
+coedge $-1 -1 -1 $-1 $20665 $17740 $19674 $20666 reversed $16247 $-1 #
+coedge $-1 -1 -1 $-1 $17740 $20667 $20668 $20669 reversed $16247 $-1 #
+coedge $-1 -1 -1 $-1 $19325 $19324 $17740 $19233 forward $19326 $-1 #
+edge $-1 -1 -1 $-1 $20670 1.5707963267948961 $20671 2.0943951023931948 $19232 $20672 forward @7 unknown T -10.000000000000002 -10 -25 -7.5 -9.3301270189221928 -22.5 #
+coedge $-1 -1 -1 $-1 $17829 $17828 $17741 $19235 forward $17830 $-1 #
+edge $-1 -1 -1 $-1 $20673 -2.0943951023931944 $19240 -1.5707963267948961 $19234 $20674 forward @7 unknown T -10.000000000000002 -0.66987298107780657 -25 -7.4999999999999991 8.8817841970012523e-16 -22.5 #
+coedge $-1 -1 -1 $-1 $19713 $20675 $19705 $19237 forward $20676 $-1 #
+edge $-1 -1 -1 $-1 $19241 -20 $19718 -15.000000000000002 $19236 $20677 forward @7 unknown T -15.000000000000004 -5 -20 -15 -4.9999999999999991 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $19700 $17743 $20675 $20678 reversed $19239 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17743 $18175 T -20 -5 -30 -9.9999999999999982 8.8817841970012523e-16 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $19180 $20679 #
+vertex $-1 -1 -1 $-1 $20680 $20681 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20682 $17746 $17763 $19265 forward $19245 $-1 #
+coedge $-1 -1 -1 $-1 $19709 $20683 $19710 $17747 reversed $20684 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17746 $20685 T -22.500000000000004 -5 -10.000000000000004 -14.999999999999996 8.8817841970012523e-16 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $19265 $20686 #
+edge $-1 -1 -1 $-1 $17748 3.1415926535897931 $20687 4.7123889803846897 $19709 $19717 forward @7 unknown T -20 -10 -10.000000000000002 -14.999999999999996 -4.9999999999999991 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -14.999999999999996 -4.9999999999999991 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $19740 $17751 $17754 $19256 forward $19251 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18372 $17783 T -7.5000000000000009 -5 5 0 0 20 unknown #
+vertex $-1 -1 -1 $-1 $17752 $20688 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $17754 $17753 $19728 $20689 reversed $17755 $-1 #
+edge $-1 -1 -1 $-1 $16260 1.5707963267948966 $19730 2.0943951023931948 $17753 $20690 forward @7 unknown T -10 -0.66987298107780746 2.5000000000000009 -7.5 1.7763568394002505e-15 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $17756 4.1887902047863914 $20691 4.7123889803846897 $19250 $20692 forward @7 unknown T -7.4999999999999991 -0.66987298107780657 5 -5 0 7.4999999999999991 #
+face $-1 -1 -1 $-1 $17766 $17755 $11 $-1 $9956 reversed single T -10 -0.66987298107780813 2.5000000000000004 -5 1.7763568394002505e-15 7.4999999999999991 F #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780657 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $20693 $17758 $19218 $19273 forward $17733 $-1 #
+coedge $-1 -1 -1 $-1 $17759 $20693 $20694 $20695 forward $17733 $-1 #
+coedge $-1 -1 -1 $-1 $20696 $17760 $20697 $17768 forward $19263 $-1 #
+coedge $-1 -1 -1 $-1 $17760 $20698 $19303 $20699 forward $19263 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17760 $19275 T -22.500000000000004 -10 4.9999999999999991 -15 -4.9999999999999991 20 unknown #
+point $-1 -1 -1 $-1 -15 -5 15 #
+edge $-1 -1 -1 $-1 $19246 0 $19266 1.5707963267948966 $19243 $20700 forward @7 unknown T -20 -5 -8.8817841970012523e-16 -15 8.8817841970012523e-16 4.9999999999999991 #
+vertex $-1 -1 -1 $-1 $20701 $20702 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 4.9999999999999991 0.70710678118654757 0 -0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20703 $20704 $11 $-1 $9956 reversed single T -20 -10 -1.7763568394002505e-15 -10 -4.9999999999999991 10 F #
+vertex $-1 -1 -1 $-1 $20705 $20706 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17772 -1.5707963267948966 $20707 -1.0471975511965974 $19259 $20708 forward @7 unknown T -22.500000000000004 -0.66987298107780902 17.5 -20 0 20 #
+point $-1 -1 -1 $-1 -20 0 20 #
+face $-1 -1 -1 $-1 $19257 $19263 $11 $-1 $10393 reversed single T -22.500000000000004 -10 4.9999999999999991 -15 -4.9999999999999991 20 F #
+edge $-1 -1 -1 $-1 $20709 1.0471975511965974 $17776 1.5707963267948966 $20698 $20708 forward @7 unknown T -22.5 -10 17.499999999999996 -20 -9.330127018922191 20 #
+point $-1 -1 -1 $-1 -20 -10 20 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20710 $20710 $20711 $20712 forward $17784 $-1 #
+coedge $-1 -1 -1 $-1 $20713 $17785 $19299 $20714 reversed $16282 $-1 #
+coedge $-1 -1 -1 $-1 $17785 $20713 $20715 $20716 forward $16282 $-1 #
+edge $-1 -1 -1 $-1 $20717 1.5707963267948966 $19301 2.0943951023931957 $17785 $20718 forward @7 unknown T -10 -10 4.9999999999999991 -7.4999999999999991 -9.330127018922191 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $20719 $20720 $17787 $19284 forward $20721 $-1 #
+edge $-1 -1 -1 $-1 $20722 7.5 $19286 17.499999999999989 $19283 $20723 forward @7 unknown T -37.500000000000007 -9.3301270189221945 7.5 -37.5 -9.3301270189221892 17.499999999999989 #
+coedge $-1 -1 -1 $-1 $17788 $19193 $20719 $20724 reversed $19194 $-1 #
+vertex $-1 -1 -1 $-1 $20724 $20725 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 19.999999999999996 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $17790 $19295 $20726 $20727 reversed $16287 $-1 #
+coedge $-1 -1 -1 $-1 $20728 $20729 $17790 $19290 forward $19198 $-1 #
+edge $-1 -1 -1 $-1 $19293 -17.499999999999996 $20730 -7.4999999999999982 $19289 $20731 forward @7 unknown T -37.5 -0.66987298107780724 7.4999999999999982 -37.499999999999993 -0.66987298107780457 17.499999999999996 #
+coedge $-1 -1 -1 $-1 $20624 $17791 $20729 $20732 reversed $19292 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19187 $20629 T -40 -0.66987298107780902 17.499999999999996 -35 2.6645352591003757e-15 22.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $19290 $20733 #
+coedge $-1 -1 -1 $-1 $19288 $17793 $20710 $20734 reversed $16287 $-1 #
+coedge $-1 -1 -1 $-1 $20735 $20736 $17793 $19297 forward $20737 $-1 #
+edge $-1 -1 -1 $-1 $20738 1.5707963267948966 $20722 2.0943951023931948 $19296 $20739 forward @7 unknown T -40 -9.9999999999999964 4.9999999999999973 -37.5 -9.330127018922191 7.5 #
+coedge $-1 -1 -1 $-1 $20740 $17797 $19744 $18373 reversed $17799 $-1 #
+coedge $-1 -1 -1 $-1 $17798 $20740 $19280 $20714 forward $17799 $-1 #
+coedge $-1 -1 -1 $-1 $17804 $17802 $20741 $20742 reversed $16296 $-1 #
+vertex $-1 -1 -1 $-1 $19282 $20743 #
+straight-curve $-1 -1 -1 $-1 -7.5000000000000009 -9.3301270189221945 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17807 $17805 $19262 $20699 reversed $17808 $-1 #
+point $-1 -1 -1 $-1 0 -5 15 #
+coedge $-1 -1 -1 $-1 $19732 $20744 $17815 $19306 reversed $18366 $-1 #
+edge $-1 -1 -1 $-1 $17816 1.5707963267948961 $19339 2.0943951023931948 $17815 $20745 forward @7 unknown T 4.9999999999999973 -10 -25 7.5000000000000018 -9.3301270189221945 -22.5 #
+point $-1 -1 -1 $-1 5 -10 -25 #
+coedge $-1 -1 -1 $-1 $18412 $17818 $17849 $19335 reversed $16890 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19721 $17820 $20746 $19315 forward $19312 $-1 #
+coedge $-1 -1 -1 $-1 $17820 $19720 $17828 $19319 forward $19312 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19310 $20747 T -7.5000000000000009 -5 -25 8.8817841970012523e-16 8.8817841970012523e-16 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $17822 $18412 $19830 $20748 reversed $16890 $-1 #
+edge $-1 -1 -1 $-1 $17823 -20 $20749 -15 $19310 $20750 forward @7 unknown T 0 -5 -20 8.8817841970012523e-16 -4.9999999999999991 -15 #
+edge $-1 -1 -1 $-1 $17823 3.1415926535897931 $17839 4.7123889803846897 $19327 $19313 forward @7 unknown T -5 -10 -25 0 -4.9999999999999991 -20 #
+point $-1 -1 -1 $-1 0 -4.9999999999999991 -20 #
+edge $-1 -1 -1 $-1 $20673 4.1887902047863914 $16323 4.7123889803846897 $19311 $20751 forward @7 unknown T -7.4999999999999991 -0.66987298107780657 -25 -5 0 -22.500000000000004 #
+edge $-1 -1 -1 $-1 $19240 1.570796326794897 $17831 2.0943951023931957 $17829 $20752 forward @7 unknown T -10 -0.66987298107780813 -27.5 -7.4999999999999991 8.8817841970012523e-16 -25 #
+face $-1 -1 -1 $-1 $20753 $17830 $11 $-1 $11805 reversed single T -10.000000000000002 -0.66987298107780902 -27.5 -5 8.8817841970012523e-16 -22.5 F #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 -27.5 #
+point $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780657 -37.500000000000014 #
+coedge $-1 -1 -1 $-1 $19232 $17835 $18187 $19686 forward $19326 $-1 #
+coedge $-1 -1 -1 $-1 $17835 $19232 $20754 $20755 reversed $19326 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19324 $20753 T -10.000000000000002 -10 -27.500000000000004 -5 -9.330127018922191 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $20754 $20746 $17837 $19316 forward $20756 $-1 #
+point $-1 -1 -1 $-1 -5 -10 -25 #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $20757 $17845 $17844 $19331 reversed $19332 $-1 #
+edge $-1 -1 -1 $-1 $19748 7.5 $16334 17.5 $17844 $20758 forward @7 unknown T 7.5 -9.3301270189221945 7.5 7.5000000000000027 -9.3301270189221945 17.5 #
+loop $-1 -1 -1 $-1 $-1 $20757 $19825 T -9.3734986416366059e-33 -10 5 7.5000000000000027 -4.9999999999999991 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 5 -5 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19854 12.5 $17850 22.500000000000004 $17849 $20759 forward @7 unknown T 7.5 -0.66987298107780668 -22.500000000000004 7.5000000000000018 -0.66987298107780624 -12.5 #
+point $-1 -1 -1 $-1 7.5000000000000009 -0.66987298107780624 -22.500000000000004 #
+loop $-1 -1 -1 $-1 $-1 $20760 $17852 T -7.5000000000000027 -10 -10 0 -4.9999999999999991 5 unknown #
+coedge $-1 -1 -1 $-1 $19843 $17853 $20744 $20761 forward $17856 $-1 #
+vertex $-1 -1 -1 $-1 $20761 $20762 #
+face $-1 -1 -1 $-1 $13998 $17856 $11 $-1 $5398 reversed single T 7.5 -10 -25 15 -4.9999999999999991 -10 F #
+face $-1 -1 -1 $-1 $19340 $20756 $11 $-1 $7251 reversed single T -7.5000000000000018 -10 -25 8.8817841970012523e-16 -4.9999999999999991 -10 F #
+loop $-1 -1 -1 $-1 $20763 $20764 $17857 T -45 -9.9999999999999964 -30.000000000000004 -40 2.6645352591003757e-15 -20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $18291 $20765 $17860 $17892 reversed $19777 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+coedge $-1 -1 -1 $-1 $17863 $17907 $20766 $20767 forward $17864 $-1 #
+edge $-1 -1 -1 $-1 $20768 42.5 $16401 50 $17863 $20769 forward @7 unknown T -22.5 44.330127018922184 -50 -22.5 44.330127018922191 -42.5 #
+face $-1 -1 -1 $-1 $20770 $17864 $11 $-1 $14102 reversed single T -22.500000000000007 40 -50 -15 45 -40 F #
+coedge $-1 -1 -1 $-1 $17866 $20771 $17865 $17927 forward $19350 $-1 #
+coedge $-1 -1 -1 $-1 $20771 $17866 $18554 $20018 reversed $19350 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20771 $20772 T -9.9999999999999982 44.330127018922191 -42.5 -5 45 -37.5 unknown #
+point $-1 -1 -1 $-1 50 40 -45 #
+loop $-1 -1 -1 $-1 $20773 $20774 $17872 T -45 35 -45 -40 45 -35 unknown #
+coedge $-1 -1 -1 $-1 $20766 $20775 $19919 $20776 forward $17873 $-1 #
+coedge $-1 -1 -1 $-1 $19385 $20777 $17874 $19355 reversed $19872 $-1 #
+edge $-1 -1 -1 $-1 $17903 1.5707963267948966 $19396 2.0943951023931944 $17874 $20778 forward @7 unknown T -9.9999999999999982 35 -40 -7.5 35.669872981077809 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $20779 $19444 $17875 $19357 reversed $17959 $-1 #
+edge $-1 -1 -1 $-1 $19359 1.570796326794897 $19894 2.0943951023931957 $17875 $17881 forward @7 unknown T 37.500000000000007 35 5.0000000000000027 40.000000000000007 35.669872981077809 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $17876 $17876 $20780 $20781 reversed $18515 $-1 #
+vertex $-1 -1 -1 $-1 $20782 $20783 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 40 5.0000000000000027 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20070 $20780 $17878 $19362 forward $20106 $-1 #
+edge $-1 -1 -1 $-1 $17880 -1.570796326794897 $20784 -1.0471975511965979 $19361 $20785 forward @7 unknown T 37.499999999999993 44.330127018922191 2.5000000000000031 40 45 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 45 5.0000000000000027 #
+coedge $-1 -1 -1 $-1 $20786 $17883 $20765 $20787 reversed $19366 $-1 #
+coedge $-1 -1 -1 $-1 $17883 $20788 $17885 $19369 reversed $19366 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19364 $18456 T -45 35 -50 -37.5 45 -40 unknown #
+vertex $-1 -1 -1 $-1 $20787 $20789 #
+ellipse-curve $-1 -1 -1 $-1 -40 40 -50 0 0 1 3.0616169978683826e-16 5 0 1 I I #
+edge $-1 -1 -1 $-1 $17886 -50 $20790 -42.500000000000014 $17885 $20791 forward @7 unknown T -37.500000000000014 35.669872981077809 -50 -37.5 35.669872981077816 -42.500000000000014 #
+point $-1 -1 -1 $-1 -37.5 35.669872981077809 -50 #
+coedge $-1 -1 -1 $-1 $18288 $20792 $17888 $19372 forward $19771 $-1 #
+edge $-1 -1 -1 $-1 $20793 -1.5707963267948966 $18290 -6.1232339957367648e-17 $19371 $20794 forward @7 unknown T -30 35 -45 -24.999999999999996 40 -40 #
+coedge $-1 -1 -1 $-1 $17889 $19919 $20795 $20796 reversed $17022 $-1 #
+coedge $-1 -1 -1 $-1 $20797 $17894 $17890 $19375 forward $19377 $-1 #
+edge $-1 -1 -1 $-1 $17896 -2.0943951023931948 $20793 -1.5707963267948966 $19374 $20798 forward @7 unknown T -24.999999999999996 35 -42.5 -22.5 35.669872981077809 -40 #
+coedge $-1 -1 -1 $-1 $17894 $20797 $20799 $20800 reversed $19377 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19374 $19383 T -24.999999999999996 35 -42.5 -20 35.669872981077809 -37.5 unknown #
+vertex $-1 -1 -1 $-1 $17895 $20801 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.5 35.669872981077802 -42.5 #
+coedge $-1 -1 -1 $-1 $17901 $17898 $20802 $20803 reversed $17902 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20804 $19377 $11 $-1 $11911 reversed single T -24.999999999999996 35 -42.5 -20 35.669872981077809 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $20805 $17900 T -22.500000000000004 40 -40 -15 45 -25 unknown #
+coedge $-1 -1 -1 $-1 $20806 $19354 $17901 $19386 reversed $19872 $-1 #
+edge $-1 -1 -1 $-1 $20807 6.1232339957367648e-17 $17903 1.5707963267948966 $17901 $20808 forward @7 unknown T -15 35 -40 -9.9999999999999982 40 -35 #
+face $-1 -1 -1 $-1 $20809 $17902 $11 $-1 $11911 reversed single T -20 35 -45 -9.9999999999999982 40 -35 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 35 -40 #
+coedge $-1 -1 -1 $-1 $20810 $17905 $20811 $20812 forward $19391 $-1 #
+coedge $-1 -1 -1 $-1 $17905 $20810 $17907 $17908 reversed $19391 $-1 #
+loop $-1 -1 -1 $-1 $-1 $17905 $20813 T -20 40 -45 -9.9999999999999982 45 -35 unknown #
+vertex $-1 -1 -1 $-1 $17906 $20814 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $20767 $20815 #
+coedge $-1 -1 -1 $-1 $20019 $17912 $20777 $20816 forward $18557 $-1 #
+vertex $-1 -1 -1 $-1 $19355 $20817 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20818 $18557 $11 $-1 $10041 reversed single T -7.5000000000000071 35 -40 8.8817841970012523e-16 40 -25 F #
+loop $-1 -1 -1 $-1 $-1 $20819 $17917 T -20 35 -15.000000000000002 -9.9999999999999982 40 -5 unknown #
+coedge $-1 -1 -1 $-1 $20820 $20821 $18493 $19936 forward $17918 $-1 #
+coedge $-1 -1 -1 $-1 $20822 $17919 $20823 $20824 forward $16409 $-1 #
+coedge $-1 -1 -1 $-1 $17919 $20822 $20825 $20826 reversed $16409 $-1 #
+coedge $-1 -1 -1 $-1 $20827 $18493 $17919 $19405 reversed $17041 $-1 #
+edge $-1 -1 -1 $-1 $20828 -2.0943951023931962 $20829 -1.5707963267948966 $17919 $20830 forward @7 unknown T -9.9999999999999982 44.330127018922184 -10 -7.4999999999999964 45 -7.4999999999999956 #
+coedge $-1 -1 -1 $-1 $18541 $17920 $20831 $20832 reversed $14134 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $18603 $20833 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 35.669872981077809 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $20834 $20835 $11 $-1 $14913 reversed single T -5 35 0 5.0000000000000027 40 10 F #
+loop $-1 -1 -1 $-1 $-1 $20836 $17931 T -5 40 0 5.0000000000000027 45 10 unknown #
+coedge $-1 -1 -1 $-1 $20837 $18565 $18428 $19874 forward $17933 $-1 #
+coedge $-1 -1 -1 $-1 $17935 $20022 $20838 $20839 forward $14890 $-1 #
+coedge $-1 -1 -1 $-1 $20840 $17943 $17935 $19415 reversed $16437 $-1 #
+edge $-1 -1 -1 $-1 $20841 1.5707963267948966 $19418 3.1415926535897931 $17935 $20842 forward @7 unknown T 9.9999999999999982 40 5.0000000000000009 14.999999999999996 45 10 #
+coedge $-1 -1 -1 $-1 $20843 $17936 $20844 $20845 forward $18609 $-1 #
+coedge $-1 -1 -1 $-1 $19426 $20846 $18567 $17937 forward $20090 $-1 #
+vertex $-1 -1 -1 $-1 $20845 $20847 #
+straight-curve $-1 -1 -1 $-1 15.000000000000002 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17938 $18604 $20848 $20849 forward $18605 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17116 $19429 $11 $-1 $14913 reversed single T 20.000000000000004 44.330127018922198 2.5000000000000036 25 45 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $20850 $17941 T 20.000000000000004 35 2.5000000000000049 25 35.669872981077809 7.5 unknown #
+coedge $-1 -1 -1 $-1 $20851 $20844 $20846 $20852 forward $17942 $-1 #
+coedge $-1 -1 -1 $-1 $17943 $20840 $20853 $20854 forward $16437 $-1 #
+coedge $-1 -1 -1 $-1 $18632 $19417 $17944 $18634 reversed $20090 $-1 #
+coedge $-1 -1 -1 $-1 $20855 $17945 $18575 $20037 forward $19429 $-1 #
+coedge $-1 -1 -1 $-1 $17945 $20855 $20856 $19434 reversed $19429 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19427 $19422 T 20.000000000000004 44.330127018922198 2.5000000000000036 25 45 7.5000000000000009 unknown #
+vertex $-1 -1 -1 $-1 $17946 $20857 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 5.0000000000000018 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20856 $18620 $17947 $19433 forward $20079 $-1 #
+edge $-1 -1 -1 $-1 $20080 0 $17948 1.5707963267948961 $19432 $20858 forward @7 unknown T 25 40 1.7763568394002505e-15 29.999999999999996 45 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $17948 -1.570796326794897 $20859 -1.0471975511965987 $20856 $20860 forward @7 unknown T 22.5 44.330127018922198 2.5000000000000036 25 45 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 45 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $20861 $20850 $17950 $19437 reversed $19423 $-1 #
+edge $-1 -1 -1 $-1 $19439 1.5707963267948961 $20862 2.0943951023931948 $17950 $19431 forward @7 unknown T 22.499999999999996 35 4.9999999999999991 25 35.669872981077809 7.5 #
+coedge $-1 -1 -1 $-1 $17951 $19445 $20863 $20864 reversed $16451 $-1 #
+vertex $-1 -1 -1 $-1 $20865 $20866 #
+coedge $-1 -1 -1 $-1 $17953 $18430 $19444 $20867 reversed $17954 $-1 #
+edge $-1 -1 -1 $-1 $16446 6.1232339957367673e-17 $20868 1.5707963267948966 $17960 $20869 forward @7 unknown T 29.999999999999996 35 5.0000000000000018 35 40 10.000000000000002 #
+coedge $-1 -1 -1 $-1 $20870 $17956 $15703 $17174 forward $17139 $-1 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19356 $20871 $19440 $20867 forward $17959 $-1 #
+coedge $-1 -1 -1 $-1 $19438 $17960 $20872 $20873 forward $16451 $-1 #
+coedge $-1 -1 -1 $-1 $17961 $19786 $17982 $19468 forward $18302 $-1 #
+coedge $-1 -1 -1 $-1 $20874 $17971 $17963 $19448 reversed $16465 $-1 #
+edge $-1 -1 -1 $-1 $18012 -1.5707963267948966 $19449 -1.047197551196597 $17963 $17997 forward @7 unknown T -22.500000000000004 29.330127018922191 -42.5 -20 30 -40 #
+vertex $-1 -1 -1 $-1 $19457 $20875 #
+straight-curve $-1 -1 -1 $-1 -22.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $20876 $20877 $11 $-1 $14408 reversed single T -20 20 -30 -9.9999999999999964 25 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $17966 $17967 $20878 $20879 forward $17968 $-1 #
+face $-1 -1 -1 $-1 $19494 $17968 $11 $-1 $10647 reversed single T -9.9999999999999982 29.330127018922191 -42.5 -5 30 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $20880 $16464 T -50 20 -45 -50 30 -35 unknown #
+coedge $-1 -1 -1 $-1 $20881 $20881 $20882 $20883 forward $17970 $-1 #
+coedge $-1 -1 -1 $-1 $17971 $20874 $20884 $20885 forward $16465 $-1 #
+edge $-1 -1 -1 $-1 $20886 1.5707963267948966 $19449 2.0943951023931948 $17971 $20887 forward @7 unknown T -25 29.330127018922191 -42.5 -22.500000000000004 30 -40 #
+coedge $-1 -1 -1 $-1 $17972 $20888 $18013 $19497 reversed $18677 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19552 $17974 $20889 $19463 reversed $16551 $-1 #
+coedge $-1 -1 -1 $-1 $17979 $20889 $17976 $19462 forward $18911 $-1 #
+edge $-1 -1 -1 $-1 $17977 -1.570796326794897 $16472 1.570796326794897 $19461 $20890 forward @7 unknown T 40 20 2.6645352591003757e-15 45.000000000000007 30 5.0000000000000044 #
+edge $-1 -1 -1 $-1 $20891 1.0471975511965987 $17977 1.570796326794897 $20889 $19466 forward @7 unknown T 37.499999999999993 20 2.5000000000000071 40 20.669872981077805 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 20 5.0000000000000027 #
+vertex $-1 -1 -1 $-1 $18876 $20892 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20882 $17982 $20893 $20894 reversed $17984 $-1 #
+edge $-1 -1 -1 $-1 $20895 42.5 $17985 50 $19446 $20896 forward @7 unknown T -37.500000000000007 29.330127018922195 -50 -37.5 29.330127018922198 -42.5 #
+coedge $-1 -1 -1 $-1 $17983 $20882 $19778 $20897 reversed $17984 $-1 #
+point $-1 -1 -1 $-1 -37.5 29.330127018922195 -50 #
+vertex $-1 -1 -1 $-1 $18294 $20898 #
+straight-curve $-1 -1 -1 $-1 -37.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $17989 $18295 $20899 $20900 forward $18296 $-1 #
+vertex $-1 -1 -1 $-1 $17990 $20901 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20902 $19787 $17991 $19477 forward $20903 $-1 #
+edge $-1 -1 -1 $-1 $16780 -6.1232339957367648e-17 $20886 1.5707963267948966 $19476 $20904 forward @7 unknown T -30 25 -45 -25 30 -40 #
+coedge $-1 -1 -1 $-1 $17994 $17992 $20158 $20905 forward $17995 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20906 $19483 $17994 $19481 forward $20907 $-1 #
+edge $-1 -1 -1 $-1 $17996 1.5707963267948966 $20908 2.0943951023931948 $19480 $20909 forward @7 unknown T -22.500000000000004 20 -40 -20 20.669872981077805 -37.5 #
+point $-1 -1 -1 $-1 -20 20 -40 #
+coedge $-1 -1 -1 $-1 $19480 $20910 $17999 $19484 forward $20907 $-1 #
+edge $-1 -1 -1 $-1 $19488 3.1415926535897931 $17996 4.7123889803846897 $19483 $20911 forward @7 unknown T -20 20 -40 -15 25 -35 #
+face $-1 -1 -1 $-1 $20912 $18296 $11 $-1 $10647 reversed single T -35 20 -45 -25 25 -35 F #
+coedge $-1 -1 -1 $-1 $20913 $20914 $20910 $20124 forward $18002 $-1 #
+coedge $-1 -1 -1 $-1 $20915 $18003 $18678 $20124 forward $18677 $-1 #
+vertex $-1 -1 -1 $-1 $19484 $20916 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $11262 $20907 $11 $-1 $12796 reversed single T -22.500000000000007 20 -40 -15 25 -25 F #
+coedge $-1 -1 -1 $-1 $18008 $18007 $20914 $20917 reversed $18009 $-1 #
+coedge $-1 -1 -1 $-1 $20878 $18678 $18007 $19493 reversed $17194 $-1 #
+edge $-1 -1 -1 $-1 $18010 -1.5707963267948966 $19488 6.1232339957367648e-17 $18007 $20918 forward @7 unknown T -15 25 -40 -9.9999999999999982 30 -35 #
+face $-1 -1 -1 $-1 $18005 $18009 $11 $-1 $10647 reversed single T -20 25 -45 -9.9999999999999982 30 -35 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 30 -40 #
+point $-1 -1 -1 $-1 -20 30 -40 #
+edge $-1 -1 -1 $-1 $18014 -37.500000000000007 $20919 -27.499999999999996 $18013 $20920 forward @7 unknown T -7.5 20.669872981077802 -37.500000000000007 -7.4999999999999964 20.669872981077805 -27.499999999999996 #
+point $-1 -1 -1 $-1 -7.5 20.669872981077805 -37.500000000000007 #
+face $-1 -1 -1 $-1 $17965 $20921 $11 $-1 $12796 reversed single T -22.500000000000004 20 -25 -15 25 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $20922 $20923 $20924 $20925 forward $18018 $-1 #
+coedge $-1 -1 -1 $-1 $20926 $18019 $20927 $20928 reversed $16510 $-1 #
+coedge $-1 -1 -1 $-1 $18019 $20926 $20929 $20930 forward $16510 $-1 #
+coedge $-1 -1 -1 $-1 $18021 $18020 $20931 $20932 reversed $14960 $-1 #
+coedge $-1 -1 -1 $-1 $20929 $20933 $18020 $19505 reversed $17260 $-1 #
+edge $-1 -1 -1 $-1 $19510 1.5707963267948966 $20934 2.0943951023931953 $18020 $20935 forward @7 unknown T -9.9999999999999982 29.330127018922191 -12.5 -7.4999999999999991 30 -10 #
+coedge $-1 -1 -1 $-1 $20936 $20937 $18021 $19507 forward $20938 $-1 #
+edge $-1 -1 -1 $-1 $19509 4.1887902047863896 $20939 4.7123889803846897 $19506 $20940 forward @7 unknown T -7.5000000000000062 29.330127018922184 -10 -5 30 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $20941 $18022 $20937 $20942 reversed $15791 $-1 #
+vertex $-1 -1 -1 $-1 $19507 $20943 #
+vertex $-1 -1 -1 $-1 $20930 $20944 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18825 $20945 $18024 $19513 forward $20281 $-1 #
+edge $-1 -1 -1 $-1 $20259 -1.5707963267948961 $15831 -6.1232339957367648e-17 $19512 $20946 forward @7 unknown T 0 20 -30 5.0000000000000018 25 -25 #
+point $-1 -1 -1 $-1 7.5 20.669872981077805 -27.499999999999996 #
+face $-1 -1 -1 $-1 $20947 $20948 $11 $-1 $13449 reversed single T 5.0000000000000018 20 2.5000000000000018 10.000000000000002 20.669872981077809 7.5000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $20949 $18028 T -5 20 -9.3734986416366059e-33 5.0000000000000018 25 10 unknown #
+coedge $-1 -1 -1 $-1 $20950 $20951 $18804 $20255 forward $18029 $-1 #
+coedge $-1 -1 -1 $-1 $18831 $18030 $20952 $20305 forward $16525 $-1 #
+coedge $-1 -1 -1 $-1 $20953 $20954 $18031 $19520 reversed $20955 $-1 #
+edge $-1 -1 -1 $-1 $20956 4.1887902047863896 $19522 4.7123889803846897 $18031 $20957 forward @7 unknown T 7.4999999999999956 29.330127018922184 5.0000000000000009 10 30 7.5000000000000062 #
+coedge $-1 -1 -1 $-1 $18043 $18032 $20958 $20959 reversed $14988 $-1 #
+vertex $-1 -1 -1 $-1 $20960 $20961 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 25 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20287 $18034 $20962 $20963 forward $17377 $-1 #
+coedge $-1 -1 -1 $-1 $18042 $20964 $18034 $19526 reversed $16534 $-1 #
+edge $-1 -1 -1 $-1 $18036 3.1415926535897931 $20965 4.7123889803846897 $18034 $19523 forward @7 unknown T 10 20 5.0000000000000009 14.999999999999996 25 10 #
+coedge $-1 -1 -1 $-1 $18035 $20324 $18042 $19533 reversed $18895 $-1 #
+point $-1 -1 -1 $-1 14.999999999999996 25 10 #
+coedge $-1 -1 -1 $-1 $20966 $18848 $18038 $19530 reversed $18837 $-1 #
+edge $-1 -1 -1 $-1 $17360 6.1232339957367648e-17 $17353 1.570796326794897 $18038 $20967 forward @7 unknown T 15 20 -25 20.000000000000004 25 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $18054 $20968 $20324 $20969 forward $18041 $-1 #
+coedge $-1 -1 -1 $-1 $20964 $18042 $20970 $20971 forward $16534 $-1 #
+edge $-1 -1 -1 $-1 $18036 6.1232339957367673e-17 $20972 1.5707963267948966 $18042 $20973 forward @7 unknown T 14.999999999999996 20 5.0000000000000009 20 25 10 #
+coedge $-1 -1 -1 $-1 $18839 $20974 $18043 $19535 reversed $15849 $-1 #
+edge $-1 -1 -1 $-1 $20975 -6.1232339957367648e-17 $18843 1.5707963267948966 $18043 $20976 forward @7 unknown T 15 25 -9.3734986416366073e-33 20 30 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $18046 $18045 $20974 $20977 forward $18047 $-1 #
+coedge $-1 -1 -1 $-1 $20978 $18050 $18046 $18052 forward $18884 $-1 #
+point $-1 -1 -1 $-1 22.500000000000007 29.330127018922202 7.5000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $20979 $20980 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20968 $18054 $20981 $19546 reversed $18041 $-1 #
+vertex $-1 -1 -1 $-1 $20969 $20982 #
+coedge $-1 -1 -1 $-1 $18883 $20981 $18056 $19545 forward $17422 $-1 #
+edge $-1 -1 -1 $-1 $18057 -1.5707963267948961 $18885 0 $19544 $19539 forward @7 unknown T 25 20 1.7763568394002505e-15 29.999999999999996 25 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $20983 1.0471975511965974 $18057 1.570796326794897 $20981 $19541 forward @7 unknown T 22.499999999999996 20 2.5000000000000009 25 20.669872981077816 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 20 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $19549 1.5707963267948966 $18699 2.0943951023931975 $18062 $20984 forward @7 unknown T 35 19.999999999999996 5.0000000000000018 37.500000000000014 20.669872981077813 7.5000000000000107 #
+vertex $-1 -1 -1 $-1 $19554 $20985 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18899 $18060 $20986 $20987 reversed $15889 $-1 #
+coedge $-1 -1 -1 $-1 $18062 $19460 $20988 $20989 forward $16551 $-1 #
+coedge $-1 -1 -1 $-1 $20988 $20338 $18063 $19554 reversed $17383 $-1 #
+edge $-1 -1 -1 $-1 $19549 -1.5707963267948966 $18885 6.4931039580273226e-16 $18063 $20990 forward @7 unknown T 29.999999999999996 19.999999999999996 1.7763568394002505e-15 35 25 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $18074 $18065 $20991 $20992 reversed $15016 $-1 #
+point $-1 -1 -1 $-1 -22.500000000000004 14.330127018922193 -42.5 #
+face $-1 -1 -1 $-1 $20537 $20440 $11 $-1 $13102 reversed single T -20 10 -30 -9.9999999999999982 15 -19.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $20993 $18069 T -20 5 -30 -9.9999999999999982 10 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $19074 $18110 $18070 $19560 reversed $15944 $-1 #
+edge $-1 -1 -1 $-1 $19082 -2.0943951023931957 $16602 -1.5707963267948966 $18070 $20994 forward @7 unknown T -10 14.330127018922191 -40 -7.4999999999999982 15 -37.5 #
+coedge $-1 -1 -1 $-1 $19561 $19561 $20995 $20996 reversed $18072 $-1 #
+coedge $-1 -1 -1 $-1 $18073 $18073 $20397 $20997 forward $16562 $-1 #
+coedge $-1 -1 -1 $-1 $18087 $18085 $18073 $19564 reversed $16576 $-1 #
+edge $-1 -1 -1 $-1 $20998 -1.5707963267948966 $20999 1.5707963267948966 $18073 $21000 forward @7 unknown T -45 5.0000000000000018 -45 -40 15.000000000000002 -40 #
+coedge $-1 -1 -1 $-1 $21001 $18964 $18074 $19566 reversed $15993 $-1 #
+edge $-1 -1 -1 $-1 $21002 -2.0943951023931957 $19567 -1.5707963267948966 $18074 $21003 forward @7 unknown T -25 14.330127018922193 -40 -22.499999999999993 15.000000000000002 -37.5 #
+vertex $-1 -1 -1 $-1 $18095 $21004 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18076 $19596 $20540 $21005 reversed $17445 $-1 #
+coedge $-1 -1 -1 $-1 $18079 $20582 $18078 $18081 forward $17679 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 10 5.0000000000000027 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $18081 $21006 #
+point $-1 -1 -1 $-1 37.5 14.330127018922195 2.5000000000000053 #
+coedge $-1 -1 -1 $-1 $19799 $21007 $18085 $19575 forward $21008 $-1 #
+edge $-1 -1 -1 $-1 $20999 1.5707963267948966 $19576 2.0943951023931957 $19574 $21009 forward @7 unknown T -40 14.330127018922193 -42.5 -37.5 15.000000000000002 -40 #
+vertex $-1 -1 -1 $-1 $19575 $21010 #
+straight-curve $-1 -1 -1 $-1 -37.5 14.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $18089 -2.0943951023931957 $20998 -1.5707963267948966 $18303 $21011 forward @7 unknown T -40 5.0000000000000018 -42.500000000000007 -37.5 5.6698729810778108 -40 #
+point $-1 -1 -1 $-1 -37.5 5.6698729810778072 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $21012 $18963 $18091 $19581 reversed $17490 $-1 #
+edge $-1 -1 -1 $-1 $19795 4.1650370783741769e-16 $18092 1.5707963267948966 $18091 $21013 forward @7 unknown T -30 5.0000000000000018 -40 -25 10 -35 #
+point $-1 -1 -1 $-1 -25 5.0000000000000018 -40 #
+coedge $-1 -1 -1 $-1 $19800 $18094 $18964 $20410 forward $19584 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19583 $19593 T -35 10 -45 -25 15.000000000000002 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18092 1.5707963267948966 $19589 2.0943951023931957 $18096 $21014 forward @7 unknown T -25 5.0000000000000018 -40 -22.5 5.6698729810778108 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $21015 $18098 $20409 $21016 forward $19588 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19591 $18108 T -22.500000000000004 5 -40 -15 10 -25 unknown #
+vertex $-1 -1 -1 $-1 $19586 $21017 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18101 $21018 $18105 $18929 reversed $19588 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18313 $19584 $11 $-1 $9512 reversed single T -35 10 -45 -25 15.000000000000002 -35 F #
+coedge $-1 -1 -1 $-1 $21019 $18104 $21020 $21021 forward $16594 $-1 #
+coedge $-1 -1 -1 $-1 $18104 $20991 $18109 $19598 forward $16594 $-1 #
+coedge $-1 -1 -1 $-1 $19569 $18105 $21022 $21023 reversed $17445 $-1 #
+point $-1 -1 -1 $-1 -15 10 -35 #
+edge $-1 -1 -1 $-1 $16604 1.5707963267948966 $18106 3.1415926535897931 $19595 $19592 forward @7 unknown T -20 10 -40 -15 15 -35 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $19084 $21024 #
+straight-curve $-1 -1 -1 $-1 -7.5 5.6698729810778064 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $21025 $18117 T -22.5 5 -25 -15 10 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $21026 $18118 $21027 $21028 forward $16610 $-1 #
+coedge $-1 -1 -1 $-1 $18118 $21026 $21029 $20449 reversed $16610 $-1 #
+coedge $-1 -1 -1 $-1 $21030 $20430 $18118 $19606 reversed $18979 $-1 #
+edge $-1 -1 -1 $-1 $18988 6.1232339957367648e-17 $21031 1.5707963267948966 $18118 $21032 forward @7 unknown T -15 5 -10 -10 10 -5 #
+coedge $-1 -1 -1 $-1 $18120 $18119 $21033 $21034 reversed $15061 $-1 #
+coedge $-1 -1 -1 $-1 $18986 $21035 $18119 $19609 forward $20446 $-1 #
+edge $-1 -1 -1 $-1 $21036 1.5707963267948961 $18988 3.1415926535897931 $19608 $21037 forward @7 unknown T -20 10 -10.000000000000004 -14.999999999999996 15 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $18982 $18122 $18120 $19611 reversed $16010 $-1 #
+edge $-1 -1 -1 $-1 $21038 -6.1232339957367648e-17 $18128 1.5707963267948966 $18120 $21039 forward @7 unknown T -15.000000000000004 10 -15.000000000000002 -10 15 -10 #
+coedge $-1 -1 -1 $-1 $21040 $21041 $18121 $19613 forward $20528 $-1 #
+edge $-1 -1 -1 $-1 $19620 -1.5707963267948966 $19615 -1.0471975511965974 $19612 $21042 forward @7 unknown T -7.5000000000000009 14.330127018922191 -12.5 -5 15 -10 #
+coedge $-1 -1 -1 $-1 $18122 $18981 $21040 $21043 reversed $16010 $-1 #
+vertex $-1 -1 -1 $-1 $21043 $21044 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21045 $18124 $21046 $21047 forward $19619 $-1 #
+coedge $-1 -1 -1 $-1 $18124 $21048 $18126 $19623 forward $19619 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21045 $21049 T -7.5000000000000009 10 -10 8.8817841970012523e-16 15 5 unknown #
+vertex $-1 -1 -1 $-1 $19613 $21050 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -10 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18985 $18126 $18993 $20456 reversed $14492 $-1 #
+edge $-1 -1 -1 $-1 $21051 -2.5000000000000004 $18127 7.5 $19618 $21052 forward @7 unknown T -7.5 14.330127018922193 -7.5 -7.4999999999999982 14.330127018922195 2.5000000000000004 #
+point $-1 -1 -1 $-1 -7.4999999999999982 14.330127018922195 -7.5 #
+point $-1 -1 -1 $-1 -10 15 -10 #
+coedge $-1 -1 -1 $-1 $18130 $19085 $21053 $21054 forward $19086 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17584 $19636 $11 $-1 $12076 reversed single T 5.0000000000000009 14.330127018922195 2.5000000000000018 10 15 7.5 F #
+loop $-1 -1 -1 $-1 $-1 $21055 $18133 T 5.0000000000000009 4.9999999999999991 2.5000000000000013 10.000000000000002 5.6698729810778072 7.5000000000000018 unknown #
+coedge $-1 -1 -1 $-1 $21056 $21057 $21058 $21059 forward $18134 $-1 #
+coedge $-1 -1 -1 $-1 $21060 $18135 $21061 $21062 reversed $16621 $-1 #
+coedge $-1 -1 -1 $-1 $18135 $21060 $21063 $21064 forward $16621 $-1 #
+coedge $-1 -1 -1 $-1 $19108 $21065 $18136 $19110 reversed $20563 $-1 #
+coedge $-1 -1 -1 $-1 $21066 $18137 $19059 $20517 forward $19636 $-1 #
+coedge $-1 -1 -1 $-1 $18137 $21066 $21067 $19641 reversed $19636 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19634 $19628 T 5.0000000000000009 14.330127018922195 2.5000000000000018 10 15 7.5 unknown #
+vertex $-1 -1 -1 $-1 $18138 $21068 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 10 5.0000000000000009 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21067 $19098 $18139 $19640 forward $20555 $-1 #
+edge $-1 -1 -1 $-1 $19656 0 $18140 1.5707963267948966 $19639 $21069 forward @7 unknown T 10 10 8.8817841970012523e-16 15.000000000000004 15 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $18140 -1.5707963267948966 $21070 -1.0471975511965983 $21067 $21071 forward @7 unknown T 7.5 14.330127018922195 2.5000000000000018 10 15 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 15 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $21072 $21055 $18142 $19644 reversed $19629 $-1 #
+edge $-1 -1 -1 $-1 $19646 1.5707963267948966 $21073 2.0943951023931957 $18142 $19638 forward @7 unknown T 7.5 4.9999999999999991 5.0000000000000009 10.000000000000002 5.6698729810778072 7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $18143 $18150 $20614 $21074 reversed $15085 $-1 #
+vertex $-1 -1 -1 $-1 $21075 $21076 #
+coedge $-1 -1 -1 $-1 $21077 $18147 $16109 $17626 forward $17605 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18149 $18160 $21078 $21079 forward $16633 $-1 #
+edge $-1 -1 -1 $-1 $19653 1.5707963267948966 $18161 2.0943951023931957 $18149 $21080 forward @7 unknown T 20 4.9999999999999982 5.0000000000000009 22.500000000000004 5.6698729810778064 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $21078 $20615 $18150 $19652 reversed $19094 $-1 #
+edge $-1 -1 -1 $-1 $19653 -1.5707963267948966 $19656 2.9403902792268254e-16 $18150 $21081 forward @7 unknown T 15 4.9999999999999982 -4.6867493208183037e-33 20 10 5.0000000000000009 #
+vertex $-1 -1 -1 $-1 $19652 $21082 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18152 $19095 $18154 $19658 reversed $14550 $-1 #
+vertex $-1 -1 -1 $-1 $19640 $21083 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $17611 1.5707963267948966 $18158 2.0943951023931948 $18154 $21084 forward @7 unknown T 20 14.330127018922189 2.5000000000000013 22.499999999999996 15 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $19141 $18155 $19095 $19660 forward $17652 $-1 #
+edge $-1 -1 -1 $-1 $18158 -2.5000000000000013 $20552 7.4999999999999947 $19659 $21085 forward @7 unknown T 22.499999999999996 14.330127018922189 -7.4999999999999947 22.5 14.330127018922195 2.5000000000000013 #
+point $-1 -1 -1 $-1 22.499999999999996 14.330127018922189 2.5000000000000013 #
+coedge $-1 -1 -1 $-1 $18162 $21086 $18160 $18164 forward $16172 $-1 #
+point $-1 -1 -1 $-1 22.500000000000004 5.6698729810778064 7.4999999999999991 #
+vertex $-1 -1 -1 $-1 $18164 $21087 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 35 4.9999999999999982 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $19167 $20580 $18169 $19668 forward $20607 $-1 #
+edge $-1 -1 -1 $-1 $20585 -1.5707963267948966 $16178 2.9403902792268244e-16 $19667 $21088 forward @7 unknown T 30 4.9999999999999982 -15 35 10 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $19132 $18171 $18170 $19670 reversed $16133 $-1 #
+edge $-1 -1 -1 $-1 $19572 -2.0943951023931948 $18167 -1.5707963267948966 $18170 $21089 forward @7 unknown T 35 4.9999999999999973 2.5000000000000053 37.5 5.6698729810778046 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18209 $21090 $18173 $19673 forward $15137 $-1 #
+edge $-1 -1 -1 $-1 $19683 4.1887902047863923 $15147 4.7123889803846897 $19672 $18204 forward @7 unknown T -22.5 -0.66987298107780657 -40 -20 0 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $19702 $21091 $19230 $20666 forward $18176 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19676 $19676 $18179 $19677 forward $18279 $-1 #
+edge $-1 -1 -1 $-1 $21092 0 $21092 6.2831853071795862 $19676 $21093 forward @7 unknown T -50 -10 -45 -50 0 -35 #
+edge $-1 -1 -1 $-1 $19680 -1.5707963267948966 $19679 1.5707963267948966 $18180 $21094 forward @7 unknown T -45 -9.9999999999999964 -40 -40 2.6645352591003757e-15 -35 #
+vertex $-1 -1 -1 $-1 $18182 $21095 #
+vertex $-1 -1 -1 $-1 $18182 $21096 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19210 $18183 $21090 $21097 reversed $14687 $-1 #
+vertex $-1 -1 -1 $-1 $19673 $21098 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25 1.7763568394002505e-15 -40 #
+edge $-1 -1 -1 $-1 $18214 -2.0943951023931957 $20670 -1.570796326794897 $19324 $21099 forward @7 unknown T -10 -10 -27.500000000000004 -7.4999999999999991 -9.330127018922191 -25 #
+coedge $-1 -1 -1 $-1 $18188 $19811 $20628 $21100 forward $19688 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18188 $19807 T -40 -0.66987298107780813 -42.5 -35 2.6645352591003757e-15 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 -0.66987298107780635 -42.5 #
+coedge $-1 -1 -1 $-1 $21101 $18194 $16232 $17727 forward $16231 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19698 $18201 $21102 $21103 forward $18202 $-1 #
+edge $-1 -1 -1 $-1 $18203 -37.499999999999993 $21104 -27.500000000000004 $18201 $21105 forward @7 unknown T -22.5 -9.3301270189221945 -37.499999999999993 -22.5 -9.3301270189221928 -27.500000000000004 #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221928 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $18205 $19695 $21106 $21107 forward $18202 $-1 #
+coedge $-1 -1 -1 $-1 $21090 $18208 $21108 $21109 forward $15137 $-1 #
+coedge $-1 -1 -1 $-1 $19179 $19238 $18208 $19701 reversed $19239 $-1 #
+edge $-1 -1 -1 $-1 $19181 0 $21110 1.5707963267948966 $18208 $21111 forward @7 unknown T -20 -5 -30 -15 0 -25 #
+coedge $-1 -1 -1 $-1 $21106 $19674 $18210 $19703 forward $18176 $-1 #
+edge $-1 -1 -1 $-1 $20670 -1.5707963267948961 $19181 -2.3886802389739258e-16 $19702 $21112 forward @7 unknown T -15 -10 -30 -10 -5 -25 #
+point $-1 -1 -1 $-1 -7.5000000000000018 -9.3301270189221945 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $21113 $21114 $20665 $19237 reversed $18216 $-1 #
+coedge $-1 -1 -1 $-1 $18218 $18217 $21114 $21115 reversed $15153 $-1 #
+coedge $-1 -1 -1 $-1 $20667 $20665 $18217 $19708 reversed $16247 $-1 #
+edge $-1 -1 -1 $-1 $19711 -1.5707963267948966 $19718 -2.3886802389739258e-16 $18217 $21116 forward @7 unknown T -15.000000000000004 -10 -15.000000000000002 -10 -5 -10 #
+coedge $-1 -1 -1 $-1 $21117 $19244 $18218 $19248 forward $20684 $-1 #
+coedge $-1 -1 -1 $-1 $21118 $18219 $16249 $17747 forward $17739 $-1 #
+vertex $-1 -1 -1 $-1 $19708 $21119 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21120 $19236 $18221 $19714 forward $20676 $-1 #
+edge $-1 -1 -1 $-1 $19718 0 $19716 1.5707963267948961 $19713 $21121 forward @7 unknown T -20 -5 -15.000000000000002 -15.000000000000004 0 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $18222 $21122 $21123 $21124 forward $19245 $-1 #
+vertex $-1 -1 -1 $-1 $21125 $21126 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 -5 -10.000000000000002 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $19714 $21127 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19311 $18226 $18228 $19723 forward $19312 $-1 #
+coedge $-1 -1 -1 $-1 $18226 $19310 $21128 $21129 forward $19312 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -10 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18229 12.5 $20673 22.500000000000007 $19720 $21130 forward @7 unknown T -7.5 -0.66987298107780746 -22.500000000000007 -7.4999999999999991 -0.66987298107780635 -12.5 #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 -12.5 #
+coedge $-1 -1 -1 $-1 $21131 $18231 $20760 $19829 forward $18233 $-1 #
+coedge $-1 -1 -1 $-1 $21128 $18369 $18231 $19727 reversed $19831 $-1 #
+edge $-1 -1 -1 $-1 $18234 1.5707963267948966 $19833 3.1415926535897931 $18231 $21132 forward @7 unknown T -5 -4.9999999999999991 -10 0 0 -5 #
+coedge $-1 -1 -1 $-1 $18232 $21131 $19254 $20689 forward $18233 $-1 #
+point $-1 -1 -1 $-1 -5 0 -10 #
+vertex $-1 -1 -1 $-1 $18237 $21133 #
+coedge $-1 -1 -1 $-1 $21134 $19305 $18240 $19733 reversed $18366 $-1 #
+edge $-1 -1 -1 $-1 $17823 -1.1640334398265743e-16 $17816 1.570796326794897 $18240 $21135 forward @7 unknown T -4.686749320818303e-33 -10 -25 5.0000000000000018 -4.9999999999999991 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $18253 $21136 $20757 $21137 forward $18243 $-1 #
+coedge $-1 -1 -1 $-1 $21138 $18244 $21139 $21140 forward $16719 $-1 #
+coedge $-1 -1 -1 $-1 $18244 $21138 $20740 $19838 reversed $16719 $-1 #
+coedge $-1 -1 -1 $-1 $19744 $20757 $18244 $19738 reversed $19332 $-1 #
+edge $-1 -1 -1 $-1 $18375 -1.1640334398265738e-16 $21141 1.5707963267948966 $18244 $21142 forward @7 unknown T -4.686749320818305e-33 -10 5 5 -4.9999999999999991 10 #
+coedge $-1 -1 -1 $-1 $18246 $18245 $21131 $21143 reversed $15164 $-1 #
+coedge $-1 -1 -1 $-1 $18372 $19250 $18245 $19741 forward $19251 $-1 #
+edge $-1 -1 -1 $-1 $20691 1.5707963267948966 $18375 3.1415926535897931 $19740 $21144 forward @7 unknown T -5 -4.9999999999999991 5 0 0 10 #
+coedge $-1 -1 -1 $-1 $18368 $21145 $18246 $19743 reversed $15383 $-1 #
+edge $-1 -1 -1 $-1 $21146 -6.1232339957367648e-17 $18374 1.5707963267948966 $18246 $21147 forward @7 unknown T -9.3734986416366059e-33 -5 -9.3734986416366059e-33 5 0 5 #
+coedge $-1 -1 -1 $-1 $18247 $19737 $16893 $18373 forward $19332 $-1 #
+coedge $-1 -1 -1 $-1 $18249 $18248 $21145 $21148 forward $18250 $-1 #
+point $-1 -1 -1 $-1 7.4999999999999956 -0.66987298107780657 7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $21136 $18253 $18390 $16923 reversed $18243 $-1 #
+vertex $-1 -1 -1 $-1 $21137 $21149 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18349 $18260 $18334 $18351 reversed $14821 $-1 #
+straight-curve $-1 -1 -1 $-1 -22.5 -24.330127018922195 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $17794 $21150 $11 $-1 $14669 reversed single T -45 -9.9999999999999982 -10.000000000000002 -37.499999999999993 3.5527136788005009e-15 4.9999999999999973 F #
+loop $-1 -1 -1 $-1 $-1 $21151 $18269 T -45 -9.9999999999999964 -25.000000000000004 -37.5 2.6645352591003757e-15 -10.000000000000002 unknown #
+face $-1 -1 -1 $-1 $21152 $21153 $11 $-1 $11706 reversed single T -30 -5 -10.000000000000002 -22.5 2.6645352591003757e-15 4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $21154 $18270 T -30.000000000000007 -5 4.9999999999999982 -22.5 2.6645352591003757e-15 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 20 -0.70710678118654757 -0 -0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19814 $21155 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 7.5 #
+ellipse-curve $-1 -1 -1 $-1 -20 -20 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $19762 $19762 $18280 $19763 reversed $20763 $-1 #
+edge $-1 -1 -1 $-1 $21156 0 $21156 6.2831853071795862 $18280 $21157 forward @7 unknown T -50 -10 -30.000000000000004 -50 0 -20.000000000000004 #
+loop $-1 -1 -1 $-1 $-1 $18281 $16956 T -50 -10 -15.000000000000004 -50 0 -5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $18282 $21158 #
+ellipse-curve $-1 -1 -1 $-1 -50 -5 -10.000000000000004 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 -50 -5 -3.0616169978683823e-15 #
+coedge $-1 -1 -1 $-1 $21159 $21160 $18287 $19769 reversed $21161 $-1 #
+edge $-1 -1 -1 $-1 $20790 1.0471975511965943 $19772 1.5707963267948966 $18287 $21162 forward @7 unknown T -37.500000000000014 35 -42.500000000000014 -35 35.669872981077816 -40 #
+coedge $-1 -1 -1 $-1 $20792 $18288 $21163 $21164 reversed $19771 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20792 $20804 T -35 35 -45 -24.999999999999996 40 -35 unknown #
+vertex $-1 -1 -1 $-1 $19769 $21165 #
+ellipse-curve $-1 -1 -1 $-1 -35 40 -40 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18290 0 $21166 1.5707963267948966 $19776 $19773 forward @7 unknown T -35 40 -45 -30 45 -40 #
+point $-1 -1 -1 $-1 -30 40 -45 #
+coedge $-1 -1 -1 $-1 $21167 $18291 $21168 $19774 forward $19777 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18291 $21169 T -37.5 40 -50 -30 45 -40 unknown #
+coedge $-1 -1 -1 $-1 $21170 $18293 $19469 $20897 forward $19780 $-1 #
+coedge $-1 -1 -1 $-1 $18293 $21170 $21171 $21172 reversed $19780 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19778 $21173 T -40 20 -42.500000000000007 -35 20.669872981077813 -37.499999999999986 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 25 -40 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21171 $21174 $18295 $19783 forward $21175 $-1 #
+edge $-1 -1 -1 $-1 $21176 3.1415926535897931 $18297 4.7123889803846897 $19782 $21177 forward @7 unknown T -35 20 -40 -30 25 -35 #
+point $-1 -1 -1 $-1 -35 20 -40 #
+vertex $-1 -1 -1 $-1 $21178 $21179 #
+coedge $-1 -1 -1 $-1 $19446 $18301 $21180 $21178 forward $18302 $-1 #
+coedge $-1 -1 -1 $-1 $19476 $21181 $18301 $18299 reversed $20903 $-1 #
+face $-1 -1 -1 $-1 $21182 $18302 $11 $-1 $12288 reversed single T -37.500000000000007 25 -50 -30 30 -40 F #
+coedge $-1 -1 -1 $-1 $18304 $18303 $21183 $21184 forward $18305 $-1 #
+coedge $-1 -1 -1 $-1 $21185 $18307 $18304 $19791 forward $19794 $-1 #
+edge $-1 -1 -1 $-1 $16787 1.5707963267948966 $21186 2.0943951023931957 $19790 $21187 forward @7 unknown T -37.5 5 -40 -35 5.669872981077809 -37.499999999999993 #
+face $-1 -1 -1 $-1 $21188 $18305 $11 $-1 $9512 reversed single T -40 5 -42.500000000000007 -35 5.6698729810778108 -37.499999999999993 F #
+coedge $-1 -1 -1 $-1 $18307 $21189 $21012 $18967 reversed $19794 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19793 $21190 T -37.5 5 -40 -30 10 -25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $18308 $21191 #
+ellipse-curve $-1 -1 -1 $-1 -35 10 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18310 -1.5707963267948966 $19576 -1.0471975511965974 $18311 $18306 forward @7 unknown T -37.5 14.330127018922191 -42.5 -35 15 -40 #
+point $-1 -1 -1 $-1 -35 15 -40 #
+coedge $-1 -1 -1 $-1 $21192 $19574 $18311 $19797 reversed $21008 $-1 #
+coedge $-1 -1 -1 $-1 $18312 $19583 $20415 $21193 reversed $19584 $-1 #
+face $-1 -1 -1 $-1 $21194 $18715 $11 $-1 $14270 reversed single T -30 25 20 -22.5 30 35 F #
+coedge $-1 -1 -1 $-1 $19196 $21195 $18314 $19803 reversed $17710 $-1 #
+edge $-1 -1 -1 $-1 $19679 1.5707963267948966 $19805 2.0943951023931957 $18314 $21196 forward @7 unknown T -40 -9.9999999999999964 -40 -37.5 -9.3301270189221874 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $21197 $18315 $21195 $21198 forward $18319 $-1 #
+vertex $-1 -1 -1 $-1 $19803 $21199 #
+ellipse-curve $-1 -1 -1 $-1 -35 -5 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21200 $19688 $11 $-1 $8499 reversed single T -40 -0.66987298107780813 -42.5 -35 2.6645352591003757e-15 -37.5 F #
+coedge $-1 -1 -1 $-1 $18318 $21197 $21201 $21202 forward $18319 $-1 #
+face $-1 -1 -1 $-1 $12100 $18319 $11 $-1 $9738 reversed single T -37.5 -10 -40 -30 -4.9999999999999991 -25.000000000000004 F #
+point $-1 -1 -1 $-1 -30 -4.9999999999999991 -35 #
+coedge $-1 -1 -1 $-1 $19687 $18324 $20653 $21203 reversed $19688 $-1 #
+edge $-1 -1 -1 $-1 $16800 1.5707963267948966 $18320 3.1415926535897931 $19214 $18321 forward @7 unknown T -35 -4.9999999999999991 -40 -30 0 -35 #
+face $-1 -1 -1 $-1 $21204 $21205 $11 $-1 $12964 reversed single T -30.000000000000007 10 4.9999999999999982 -22.499999999999993 15.000000000000004 20 F #
+edge $-1 -1 -1 $-1 $19757 -1.5707963267948966 $15333 -6.1232339957367648e-17 $18328 $21206 forward @7 unknown T -30 -25 -1.7763568394002505e-15 -25 -20 4.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18337 $18402 $18340 $19819 forward $18362 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 4.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18363 -2.0943951023931948 $19757 -1.5707963267948966 $19816 $21207 forward @7 unknown T -25 -25 2.4999999999999996 -22.500000000000004 -24.330127018922195 4.9999999999999982 #
+point $-1 -1 -1 $-1 -25 -25 -10.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -10.000000000000002 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -25 -20 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.500000000000004 -24.330127018922195 2.4999999999999996 #
+face $-1 -1 -1 $-1 $14646 $19332 $11 $-1 $7239 reversed single T -9.3734986416366059e-33 -10 5 7.5000000000000027 -4.9999999999999991 20 F #
+loop $-1 -1 -1 $-1 $-1 $21208 $18365 T -9.3734986416366059e-33 -10 -10 7.5000000000000018 -4.9999999999999991 5 unknown #
+coedge $-1 -1 -1 $-1 $21145 $18367 $18385 $19846 reversed $15383 $-1 #
+edge $-1 -1 -1 $-1 $19847 -2.0943951023931948 $19832 -1.5707963267948966 $18411 $21209 forward @7 unknown T 5 -0.66987298107780624 -10 7.5000000000000009 0 -7.5000000000000009 #
+edge $-1 -1 -1 $-1 $19833 -5 $21146 0 $19725 $21210 forward @7 unknown T 0 -5 -5 0 -4.9999999999999991 0 #
+coedge $-1 -1 -1 $-1 $18369 $21128 $19314 $20748 forward $19831 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18369 $21211 T -5 -5 -15 5 8.8817841970012523e-16 -5 unknown #
+vertex $-1 -1 -1 $-1 $20748 $21212 #
+vertex $-1 -1 -1 $-1 $21213 $21214 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 5 -5 5 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+straight-curve $-1 -1 -1 $-1 0 -5 0 0 0 1 I I #
+point $-1 -1 -1 $-1 5 0 5 #
+edge $-1 -1 -1 $-1 $18375 3.1415926535897931 $21215 4.7123889803846897 $20740 $21144 forward @7 unknown T -5 -10 5 0 -4.9999999999999991 10 #
+point $-1 -1 -1 $-1 0 -4.9999999999999991 10 #
+ellipse-curve $-1 -1 -1 $-1 20 -5.0000000000000009 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18378 -1.5707963267948966 $16904 1.1640334398265733e-16 $18415 $21216 forward @7 unknown T 15 -10 -15 20 -5 -9.9999999999999982 #
+point $-1 -1 -1 $-1 20 -10 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $18383 $19338 $21217 $18396 forward $17856 $-1 #
+coedge $-1 -1 -1 $-1 $18389 $18415 $18383 $19845 reversed $15506 $-1 #
+edge $-1 -1 -1 $-1 $16918 -1.5707963267948966 $16904 0 $18383 $18393 forward @7 unknown T 10 -10 -15 15 -5 -10 #
+edge $-1 -1 -1 $-1 $18398 -2.4999999999999996 $19847 7.5000000000000009 $18385 $21218 forward @7 unknown T 7.4999999999999964 -0.66987298107780768 -7.5000000000000009 7.5000000000000009 -0.66987298107780624 2.4999999999999996 #
+vertex $-1 -1 -1 $-1 $18387 $21219 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -10 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18390 $18388 $21220 $21221 forward $16360 $-1 #
+coedge $-1 -1 -1 $-1 $21217 $21222 $18388 $19851 reversed $19853 $-1 #
+edge $-1 -1 -1 $-1 $16918 1.5707963267948966 $21223 2.0943951023931948 $18388 $19848 forward @7 unknown T 7.5000000000000018 -10 -10 10 -9.3301270189221945 -7.5000000000000018 #
+face $-1 -1 -1 $-1 $21211 $21224 $11 $-1 $11179 reversed single T -5 -10 -15 5 -4.9999999999999991 -5 F #
+loop $-1 -1 -1 $-1 $-1 $21225 $18392 T 5 -10 -12.500000000000004 10 -9.330127018922191 -7.5000000000000018 unknown #
+vertex $-1 -1 -1 $-1 $18413 $21226 #
+ellipse-curve $-1 -1 -1 $-1 10 -5 -10 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $18396 $21227 #
+point $-1 -1 -1 $-1 7.4999999999999964 -0.66987298107780768 2.4999999999999996 #
+point $-1 -1 -1 $-1 7.4999999999999991 -9.3301270189221963 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $21228 $21228 $21229 $21230 forward $18408 $-1 #
+coedge $-1 -1 -1 $-1 $21231 $18409 $21232 $21233 reversed $16957 $-1 #
+coedge $-1 -1 -1 $-1 $18409 $21231 $20667 $21234 forward $16957 $-1 #
+edge $-1 -1 -1 $-1 $19711 1.5707963267948966 $21235 2.0943951023931948 $18409 $21236 forward @7 unknown T -10 -10 -10 -7.5000000000000027 -9.3301270189221928 -7.5 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21237 $18450 $18418 $19865 reversed $19896 $-1 #
+edge $-1 -1 -1 $-1 $18471 1.5707963267948966 $18452 2.0943951023931957 $18418 $18461 forward @7 unknown T -37.5 35 35 -35 35.669872981077809 37.5 #
+coedge $-1 -1 -1 $-1 $18419 $18422 $21238 $21239 forward $18423 $-1 #
+coedge $-1 -1 -1 $-1 $19907 $18420 $21240 $19959 forward $19868 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18420 $18485 T -35 35 30 -24.999999999999996 40 40 unknown #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17025 $18423 $11 $-1 $8951 reversed single T -24.999999999999996 35 32.5 -20 35.669872981077809 37.5 F #
+coedge $-1 -1 -1 $-1 $18424 $18525 $17032 $18486 forward $18446 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19354 $18425 T -15 35 -40 -7.4999999999999938 40 -25 unknown #
+coedge $-1 -1 -1 $-1 $20811 $21241 $20805 $21242 reversed $18426 $-1 #
+edge $-1 -1 -1 $-1 $17063 6.1232339957367673e-17 $20041 1.5707963267948966 $19412 $21243 forward @7 unknown T 0 35 20 5.0000000000000027 40 25 #
+loop $-1 -1 -1 $-1 $17869 $21244 $1558 T 50 35 -29.999999999999996 50 45 -19.999999999999996 hole $1559 T #
+coedge $-1 -1 -1 $-1 $19876 $19876 $21245 $21246 forward $18433 $-1 #
+coedge $-1 -1 -1 $-1 $19877 $19877 $18434 $19878 reversed $19969 $-1 #
+edge $-1 -1 -1 $-1 $21247 0 $21247 6.2831853071795862 $18434 $21248 forward @7 unknown T 50 35 2.6645352591003757e-15 50 45 10.000000000000004 #
+loop $-1 -1 -1 $-1 $21249 $18435 $3147 T -50 35 29.999999999999996 -50 45 40 hole $3148 T #
+vertex $-1 -1 -1 $-1 $18436 $21250 #
+ellipse-curve $-1 -1 -1 $-1 -50 40 35 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 40 35 0.70710678118654768 0 0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $19889 $18439 $21251 $21252 reversed $18441 $-1 #
+coedge $-1 -1 -1 $-1 $18450 $21237 $18439 $19885 forward $19896 $-1 #
+edge $-1 -1 -1 $-1 $21253 -2.0943951023931935 $18442 -1.5707963267948966 $19884 $21254 forward @7 unknown T -40 35 32.500000000000007 -37.500000000000007 35.669872981077816 35 #
+coedge $-1 -1 -1 $-1 $18440 $21255 $21256 $21257 reversed $18441 $-1 #
+coedge $-1 -1 -1 $-1 $18458 $18454 $18440 $19888 forward $18459 $-1 #
+edge $-1 -1 -1 $-1 $18443 1.5707963267948966 $21258 2.0943951023931953 $19887 $21259 forward @7 unknown T -40 44.330127018922191 32.5 -37.5 45 35 #
+coedge $-1 -1 -1 $-1 $19972 $19883 $21260 $21261 reversed $18441 $-1 #
+face $-1 -1 -1 $-1 $17003 $18441 $11 $-1 $18457 reversed single T -45 35 19.999999999999996 -37.5 45 35 F #
+point $-1 -1 -1 $-1 -40 35 35 #
+point $-1 -1 -1 $-1 -40 45 35 #
+face $-1 -1 -1 $-1 $14052 $18446 $11 $-1 $12646 reversed single T -15 35 20 -7.4999999999999973 40 35 F #
+vertex $-1 -1 -1 $-1 $20867 $21262 #
+straight-curve $-1 -1 -1 $-1 37.5 35.669872981077809 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $18450 $18466 T -40 35 32.499999999999993 -35 35.669872981077816 37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 40 35 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 35.669872981077809 37.5 #
+face $-1 -1 -1 $-1 $15560 $21263 $11 $-1 $18457 reversed single T -45 35 -40 -37.499999999999993 45 -25.000000000000004 F #
+coedge $-1 -1 -1 $-1 $21256 $19905 $18458 $19902 forward $18467 $-1 #
+edge $-1 -1 -1 $-1 $18460 -1.5707963267948966 $21258 -1.0471975511965974 $19901 $21264 forward @7 unknown T -37.5 44.330127018922191 32.5 -35 45 35 #
+face $-1 -1 -1 $-1 $21265 $18459 $11 $-1 $8951 reversed single T -40 44.330127018922191 32.5 -35 45 37.500000000000007 F #
+point $-1 -1 -1 $-1 -35 45 35 #
+coedge $-1 -1 -1 $-1 $19901 $19908 $18463 $19906 forward $18467 $-1 #
+edge $-1 -1 -1 $-1 $19911 0 $18460 1.5707963267948966 $19905 $21266 forward @7 unknown T -35 40 30 -30 45 35 #
+coedge $-1 -1 -1 $-1 $18465 $19867 $21267 $21268 reversed $19868 $-1 #
+coedge $-1 -1 -1 $-1 $19905 $21269 $21270 $21271 forward $18467 $-1 #
+coedge $-1 -1 -1 $-1 $21272 $18468 $19908 $21271 reversed $19910 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21272 $21182 T -30 40 20 -22.499999999999996 45 35 unknown #
+vertex $-1 -1 -1 $-1 $19906 $21273 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $21253 1.0471975511965961 $18471 1.5707963267948966 $21274 $21264 forward @7 unknown T -37.500000000000014 35 32.499999999999993 -35 35.669872981077816 35 #
+point $-1 -1 -1 $-1 -35 35 35 #
+coedge $-1 -1 -1 $-1 $18472 $21275 $18477 $19921 reversed $19910 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $21276 $18474 T -30.000000000000007 35 -40 -22.5 40 -25 unknown #
+coedge $-1 -1 -1 $-1 $21277 $21278 $21279 $21280 reversed $18475 $-1 #
+coedge $-1 -1 -1 $-1 $19373 $18476 $19353 $20776 reversed $17022 $-1 #
+coedge $-1 -1 -1 $-1 $19925 $18477 $21281 $21282 forward $17031 $-1 #
+edge $-1 -1 -1 $-1 $18478 -32.5 $21283 -22.5 $18477 $21284 forward @7 unknown T -22.5 44.330127018922184 22.5 -22.5 44.330127018922205 32.5 #
+point $-1 -1 -1 $-1 -22.5 44.330127018922184 32.5 #
+face $-1 -1 -1 $-1 $21285 $21286 $11 $-1 $14102 reversed single T -22.500000000000007 40 4.9999999999999991 -15 45 20 F #
+loop $-1 -1 -1 $-1 $-1 $21270 $18480 T -37.500000000000014 35 19.999999999999993 -29.999999999999993 40 35 unknown #
+coedge $-1 -1 -1 $-1 $18481 $19920 $18500 $19953 forward $17031 $-1 #
+coedge $-1 -1 -1 $-1 $21287 $18483 $19871 $18486 reversed $19927 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19926 $18488 T -22.5 35 20 -15 40 35 unknown #
+straight-curve $-1 -1 -1 $-1 -15 40 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $19955 $19950 $11 $-1 $12658 reversed single T -9.9999999999999982 44.330127018922191 17.5 -5 45 22.500000000000004 F #
+point $-1 -1 -1 $-1 -22.5 35.669872981077802 32.5 #
+coedge $-1 -1 -1 $-1 $18490 $21288 $21289 $21290 forward $19927 $-1 #
+face $-1 -1 -1 $-1 $21291 $21292 $11 $-1 $12646 reversed single T -15 35 -10 -7.4999999999999991 40 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $21293 $18491 T -15.000000000000004 35 -25 -7.4999999999999964 40 -10 unknown #
+coedge $-1 -1 -1 $-1 $21294 $21295 $21296 $21297 reversed $18492 $-1 #
+coedge $-1 -1 -1 $-1 $18493 $21298 $21299 $21300 reversed $17041 $-1 #
+edge $-1 -1 -1 $-1 $20829 -1.5707963267948966 $21301 6.1232339957367648e-17 $19401 $21302 forward @7 unknown T -14.999999999999998 40 -10 -9.9999999999999982 45 -5 #
+coedge $-1 -1 -1 $-1 $21303 $18494 $21304 $21305 reversed $15588 $-1 #
+coedge $-1 -1 -1 $-1 $21306 $21307 $18494 $19939 forward $21308 $-1 #
+edge $-1 -1 -1 $-1 $21309 -2.0943951023931953 $19946 -1.5707963267948966 $19938 $21310 forward @7 unknown T -9.9999999999999982 44.330127018922184 4.9999999999999991 -7.4999999999999991 45 7.5 #
+coedge $-1 -1 -1 $-1 $18495 $21303 $18501 $19954 reversed $15588 $-1 #
+coedge $-1 -1 -1 $-1 $21311 $21312 $21313 $19942 forward $21286 $-1 #
+edge $-1 -1 -1 $-1 $19947 10 $21314 15 $19941 $21315 forward @7 unknown T -15 40 10 -15 40 15 #
+coedge $-1 -1 -1 $-1 $21316 $18496 $21312 $21317 reversed $19945 $-1 #
+coedge $-1 -1 -1 $-1 $18496 $21316 $21298 $21318 forward $19945 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18496 $21319 T -20 40 -1.7763568394002505e-15 -9.9999999999999982 45 10 unknown #
+vertex $-1 -1 -1 $-1 $21318 $21320 #
+vertex $-1 -1 -1 $-1 $21321 $21322 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 4.9999999999999991 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19961 $18498 $21303 $21323 forward $19950 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18498 $19929 T -9.9999999999999982 44.330127018922191 17.5 -5 45 22.500000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18501 $18500 $21311 $21324 reversed $18502 $-1 #
+edge $-1 -1 -1 $-1 $21325 1.5707963267948966 $18504 3.1415926535897931 $19925 $21326 forward @7 unknown T -20 40 20 -15 45 25 #
+edge $-1 -1 -1 $-1 $21314 -6.1232339957367648e-17 $18503 1.5707963267948966 $18501 $21327 forward @7 unknown T -15 40 15 -9.9999999999999982 45 20 #
+face $-1 -1 -1 $-1 $21328 $18502 $11 $-1 $12658 reversed single T -20 40 15 -9.9999999999999982 45 25 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 45 20 #
+edge $-1 -1 -1 $-1 $18504 3.1415926535897931 $21329 4.7123889803846897 $21287 $21326 forward @7 unknown T -20 35 20 -15 40 25 #
+point $-1 -1 -1 $-1 -15 40 25 #
+edge $-1 -1 -1 $-1 $18506 -1.5707963267948966 $19911 -6.1232339957367648e-17 $19867 $21330 forward @7 unknown T -30 35 30 -24.999999999999996 40 35 #
+point $-1 -1 -1 $-1 -24.999999999999996 35 35 #
+coedge $-1 -1 -1 $-1 $18508 $19949 $21331 $21332 reversed $19950 $-1 #
+vertex $-1 -1 -1 $-1 $21332 $21333 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5000000000000018 44.330127018922191 22.500000000000004 #
+coedge $-1 -1 -1 $-1 $18531 $18512 $21334 $21335 reversed $16430 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21336 $21337 $11 $-1 $14913 reversed single T -50 35 -3.5527136788005009e-15 -40 45 9.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $21338 $18514 T -9.9999999999999982 35 2.4999999999999947 -5 35.669872981077816 7.5000000000000009 unknown #
+loop $-1 -1 -1 $-1 $-1 $19877 $17052 T 50 35 2.6645352591003757e-15 50 45 10.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $19970 $19970 $18516 $19971 forward $21249 $-1 #
+edge $-1 -1 -1 $-1 $21339 0 $21339 6.2831853071795862 $19970 $21340 forward @7 unknown T -50 35 14.999999999999996 -50 45 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $21255 $19889 $18517 $19973 reversed $18441 $-1 #
+edge $-1 -1 -1 $-1 $19978 -1.5707963267948966 $19977 1.5707963267948966 $18517 $21341 forward @7 unknown T -45 35 19.999999999999996 -40 45 24.999999999999993 #
+coedge $-1 -1 -1 $-1 $21342 $18518 $21343 $21344 reversed $19976 $-1 #
+coedge $-1 -1 -1 $-1 $18518 $21345 $21346 $21347 reversed $19976 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21348 $21349 T -45 35 4.9999999999999973 -37.499999999999993 45 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $18519 $21350 #
+vertex $-1 -1 -1 $-1 $18519 $21351 #
+ellipse-curve $-1 -1 -1 $-1 -40 40 19.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21352 $21353 $18520 $19981 forward $21354 $-1 #
+edge $-1 -1 -1 $-1 $19986 1.047197551196597 $19982 1.5707963267948966 $19980 $21355 forward @7 unknown T -7.5000000000000036 35 17.499999999999996 -5 35.669872981077816 20 #
+vertex $-1 -1 -1 $-1 $19981 $21356 #
+coedge $-1 -1 -1 $-1 $21357 $18523 $21353 $21358 reversed $19985 $-1 #
+coedge $-1 -1 -1 $-1 $18523 $21359 $21360 $19990 reversed $19985 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21357 $21291 T -15 35 4.9999999999999991 -7.4999999999999991 40 20 unknown #
+vertex $-1 -1 -1 $-1 $19981 $21361 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21360 $21362 $18525 $19989 forward $21363 $-1 #
+edge $-1 -1 -1 $-1 $18504 6.1232339957367648e-17 $18526 1.5707963267948966 $19988 $21364 forward @7 unknown T -15 35 20 -9.9999999999999982 40 25 #
+edge $-1 -1 -1 $-1 $18526 -1.5707963267948966 $21314 -6.1232339957367648e-17 $21360 $21365 forward @7 unknown T -15 35 15 -9.9999999999999982 40 20 #
+point $-1 -1 -1 $-1 -9.9999999999999982 35 20 #
+point $-1 -1 -1 $-1 -7.5 35.669872981077809 22.500000000000004 #
+point $-1 -1 -1 $-1 50 40 15.000000000000004 #
+coedge $-1 -1 -1 $-1 $21366 $20001 $18531 $19995 reversed $18537 $-1 #
+edge $-1 -1 -1 $-1 $21367 -6.1232339957367673e-17 $18532 1.5707963267948966 $18531 $21368 forward @7 unknown T 0 40 15 5.0000000000000027 45 20 #
+point $-1 -1 -1 $-1 5.0000000000000027 45 20 #
+face $-1 -1 -1 $-1 $21369 $21370 $11 $-1 $10029 reversed single T 0 40 -25 7.5000000000000027 45 -10 F #
+loop $-1 -1 -1 $-1 $-1 $21371 $18536 T 0 40 -10 7.5000000000000027 45 5 unknown #
+coedge $-1 -1 -1 $-1 $21372 $21366 $20836 $21373 reversed $18537 $-1 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19994 $21374 $18539 $20002 reversed $18537 $-1 #
+edge $-1 -1 -1 $-1 $18532 1.5707963267948966 $20023 2.0943951023931948 $18539 $21375 forward @7 unknown T 5.0000000000000027 44.330127018922191 17.5 7.5 45 20 #
+coedge $-1 -1 -1 $-1 $21376 $18602 $18541 $20004 forward $20062 $-1 #
+edge $-1 -1 -1 $-1 $19408 -2.0943951023931948 $21377 -1.5707963267948966 $20003 $21378 forward @7 unknown T 5.0000000000000027 35 -27.499999999999996 7.5 35.669872981077809 -25 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18545 $18596 $21379 $21380 forward $18597 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 -25 -0.70710678118654746 -0 -0.70710678118654757 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18548 $18547 $21381 $21382 reversed $18549 $-1 #
+coedge $-1 -1 -1 $-1 $21379 $21383 $18547 $20010 reversed $21370 $-1 #
+edge $-1 -1 -1 $-1 $18550 -1.5707963267948966 $21384 6.1232339957367648e-17 $18547 $21385 forward @7 unknown T 0 40 -25 5.0000000000000027 45 -20 #
+face $-1 -1 -1 $-1 $21386 $18549 $11 $-1 $15707 reversed single T -5 40 -30 5.0000000000000027 45 -20 F #
+point $-1 -1 -1 $-1 5.0000000000000027 45 -25 #
+coedge $-1 -1 -1 $-1 $18554 $18552 $21387 $21388 forward $17079 $-1 #
+coedge $-1 -1 -1 $-1 $21389 $21390 $18552 $20015 reversed $21391 $-1 #
+edge $-1 -1 -1 $-1 $20016 -1.5707963267948966 $21392 -1.0471975511965979 $18552 $21393 forward @7 unknown T -7.5 44.330127018922191 -27.5 -5 45 -25 #
+vertex $-1 -1 -1 $-1 $20015 $21394 #
+ellipse-curve $-1 -1 -1 $-1 -5 40 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $21395 4.1887902047863905 $16420 4.7123889803846897 $18554 $19397 forward @7 unknown T -7.5000000000000018 44.330127018922191 -40 -5 45 -37.5 #
+coedge $-1 -1 -1 $-1 $18556 $19395 $21396 $21397 forward $18557 $-1 #
+coedge $-1 -1 -1 $-1 $21398 $20831 $18556 $20021 reversed $21399 $-1 #
+edge $-1 -1 -1 $-1 $21400 -1.5707963267948966 $17081 0 $18556 $20017 forward @7 unknown T -5 35 -30 0 40 -25 #
+coedge $-1 -1 -1 $-1 $19413 $18561 $21374 $21401 forward $14890 $-1 #
+vertex $-1 -1 -1 $-1 $21401 $21402 #
+ellipse-curve $-1 -1 -1 $-1 10 40 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $17127 $21354 $11 $-1 $10041 reversed single T -7.5000000000000036 35 5 8.8817841970012523e-16 40 20 F #
+coedge $-1 -1 -1 $-1 $18565 $20837 $21352 $21403 reversed $17933 $-1 #
+ellipse-curve $-1 -1 -1 $-1 10 40 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 15 40 15 #
+vertex $-1 -1 -1 $-1 $18570 $21404 #
+coedge $-1 -1 -1 $-1 $18610 $21405 $18577 $18570 forward $18609 $-1 #
+face $-1 -1 -1 $-1 $21406 $21407 $11 $-1 $7943 reversed single T 15 35 -9.9999999999999982 22.500000000000007 40 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $20043 $18572 T 15 35 -25 22.500000000000004 40 -9.9999999999999982 unknown #
+coedge $-1 -1 -1 $-1 $21408 $18574 $21409 $21410 reversed $17099 $-1 #
+coedge $-1 -1 -1 $-1 $18574 $20853 $21411 $21412 reversed $17099 $-1 #
+coedge $-1 -1 -1 $-1 $21413 $21414 $18574 $20036 forward $21415 $-1 #
+edge $-1 -1 -1 $-1 $21416 -1.5707963267948966 $21417 6.1232339957367648e-17 $20035 $21418 forward @7 unknown T 15 40 -9.9999999999999982 20.000000000000004 45 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $19430 -2.0943951023931939 $20038 -1.5707963267948966 $19427 $21419 forward @7 unknown T 20.000000000000004 44.330127018922198 5.0000000000000009 22.500000000000007 45 7.5000000000000009 #
+vertex $-1 -1 -1 $-1 $20854 $21420 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $18578 $18577 $21421 $21422 forward $18579 $-1 #
+vertex $-1 -1 -1 $-1 $21423 $21424 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000027 40 20 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20848 $21425 $18584 $20044 reversed $20032 $-1 #
+edge $-1 -1 -1 $-1 $18585 1.5707963267948961 $20117 2.094395102393193 $18584 $21426 forward @7 unknown T 20 35 -25 22.499999999999993 35.669872981077802 -22.500000000000004 #
+point $-1 -1 -1 $-1 20.000000000000004 35 -25 #
+coedge $-1 -1 -1 $-1 $21427 $18587 $18657 $20110 reversed $18573 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21428 $18589 $21429 $20053 forward $20050 $-1 #
+coedge $-1 -1 -1 $-1 $18589 $21430 $18596 $20057 forward $20050 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20048 $21431 T 7.5000000000000009 40 -25 15.000000000000002 45 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 10 40 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18591 $21427 $21414 $21432 reversed $18573 $-1 #
+edge $-1 -1 -1 $-1 $18592 -20 $21433 -15 $20048 $21434 forward @7 unknown T 15 40 -20 15.000000000000002 40 -15 #
+edge $-1 -1 -1 $-1 $18592 3.1415926535897931 $18606 4.7123889803846897 $20063 $20051 forward @7 unknown T 10 35 -25 15 40 -20 #
+point $-1 -1 -1 $-1 15 40 -20 #
+straight-curve $-1 -1 -1 $-1 7.5000000000000018 44.330127018922191 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $21435 4.1887902047863932 $17121 4.7123889803846897 $20049 $21436 forward @7 unknown T 7.5000000000000027 44.330127018922198 -25 10 45 -22.500000000000007 #
+face $-1 -1 -1 $-1 $21437 $18597 $11 $-1 $15707 reversed single T 5.0000000000000027 44.330127018922191 -27.5 10 45 -22.500000000000007 F #
+point $-1 -1 -1 $-1 7.5 44.330127018922191 -27.499999999999996 #
+point $-1 -1 -1 $-1 7.5000000000000027 44.330127018922205 -37.500000000000014 #
+coedge $-1 -1 -1 $-1 $18602 $21376 $21438 $21439 reversed $20062 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20003 $21440 T 5.0000000000000027 35 -27.5 10 35.669872981077809 -22.500000000000004 unknown #
+coedge $-1 -1 -1 $-1 $21438 $21429 $18604 $20054 forward $21441 $-1 #
+point $-1 -1 -1 $-1 10 35 -25 #
+straight-curve $-1 -1 -1 $-1 22.5 44.330127018922191 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $21442 $18632 $18613 $20067 reversed $20090 $-1 #
+edge $-1 -1 -1 $-1 $20862 7.5 $17136 17.5 $18613 $21443 forward @7 unknown T 22.499999999999996 35.669872981077802 7.5 22.500000000000004 35.669872981077809 17.5 #
+coedge $-1 -1 -1 $-1 $21444 $21445 $21446 $21447 reversed $18615 $-1 #
+coedge $-1 -1 -1 $-1 $18619 $18616 $18628 $20088 reversed $14183 $-1 #
+coedge $-1 -1 -1 $-1 $21448 $19361 $18616 $20071 forward $20106 $-1 #
+edge $-1 -1 -1 $-1 $20784 -2.5000000000000067 $20075 7.4999999999999964 $20070 $21449 forward @7 unknown T 37.499999999999993 44.330127018922191 -7.4999999999999964 37.500000000000007 44.330127018922205 2.5000000000000067 #
+coedge $-1 -1 -1 $-1 $21450 $18617 $18650 $20102 forward $20074 $-1 #
+coedge $-1 -1 -1 $-1 $18617 $21450 $21448 $21451 reversed $20074 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20072 $21452 T 35 44.330127018922191 -12.5 40 45 -7.4999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $21451 $21453 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18620 $21454 $18622 $20083 forward $20079 $-1 #
+coedge $-1 -1 -1 $-1 $21455 $20863 $21456 $18621 reversed $18654 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18620 $20114 T 22.5 40 -9.9999999999999982 30 45 5.0000000000000036 unknown #
+vertex $-1 -1 -1 $-1 $19433 $21457 #
+straight-curve $-1 -1 -1 $-1 30 40 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18623 $18622 $18655 $20108 reversed $18624 $-1 #
+edge $-1 -1 -1 $-1 $21458 1.570796326794897 $18626 3.1415926535897931 $20077 $21459 forward @7 unknown T 25 40 -9.9999999999999982 29.999999999999996 45 -4.9999999999999982 #
+face $-1 -1 -1 $-1 $18658 $18624 $11 $-1 $16410 reversed single T 25 40 -15 35 45 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 35 45 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $18626 3.1415926535897931 $21460 4.7123889803846897 $21455 $21459 forward @7 unknown T 24.999999999999996 35 -9.9999999999999982 29.999999999999996 40 -4.9999999999999982 #
+point $-1 -1 -1 $-1 29.999999999999996 40 -4.9999999999999982 #
+edge $-1 -1 -1 $-1 $17147 1.5707963267948966 $20784 2.0943951023931944 $18628 $21461 forward @7 unknown T 35 44.330127018922191 2.5000000000000067 37.499999999999993 45 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 35 40 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+loop $-1 -1 -1 $-1 $-1 $21442 $21406 T 14.999999999999996 35 5.0000000000000009 22.500000000000004 40 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+ellipse-curve $-1 -1 -1 $-1 20.000000000000004 40 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21462 $18636 $18638 $20095 forward $18647 $-1 #
+coedge $-1 -1 -1 $-1 $18638 $20870 $21463 $21464 reversed $17139 $-1 #
+edge $-1 -1 -1 $-1 $18639 -22.499999999999989 $21465 -12.500000000000002 $20093 $21466 forward @7 unknown T 37.5 35.669872981077809 -22.499999999999989 37.500000000000014 35.669872981077816 -12.500000000000002 #
+point $-1 -1 -1 $-1 37.500000000000014 35.669872981077816 -22.499999999999989 #
+edge $-1 -1 -1 $-1 $17164 1.570796326794897 $17160 4.7123889803846897 $18645 $21467 forward @7 unknown T 39.999999999999993 35 -24.999999999999996 44.999999999999993 45 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $21468 $20099 T 50 35 -29.999999999999996 50 45 -19.999999999999996 unknown #
+face $-1 -1 -1 $-1 $21469 $18642 $11 $-1 $15707 reversed single T 39.999999999999993 35 -29.999999999999996 50 45 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $18646 $21470 $21450 $21471 forward $18647 $-1 #
+face $-1 -1 -1 $-1 $13302 $18647 $11 $-1 $7001 reversed single T 37.5 35 -24.999999999999996 45 45 -9.9999999999999982 F #
+edge $-1 -1 -1 $-1 $18625 1.5707963267948966 $20103 2.0943951023931948 $20072 $21472 forward @7 unknown T 35 44.330127018922191 -12.5 37.500000000000007 45 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $20102 $21473 #
+straight-curve $-1 -1 -1 $-1 37.5 44.330127018922191 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $21474 $21475 $11 $-1 $16410 reversed single T 35 35 -12.500000000000004 40 35.669872981077809 -7.4999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $20070 $18653 T 37.499999999999993 35 -9.9999999999999982 45.000000000000007 45 5.0000000000000044 unknown #
+coedge $-1 -1 -1 $-1 $18657 $18655 $21476 $21477 forward $17171 $-1 #
+edge $-1 -1 -1 $-1 $18660 0 $21458 1.5707963267948966 $18655 $21478 forward @7 unknown T 25 40 -14.999999999999998 30 45 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $18656 $21479 $21480 $21481 forward $18668 $-1 #
+edge $-1 -1 -1 $-1 $21482 12.499999999999996 $18662 22.500000000000007 $18657 $21483 forward @7 unknown T 22.5 44.330127018922191 -22.500000000000007 22.500000000000004 44.330127018922205 -12.499999999999996 #
+ellipse-curve $-1 -1 -1 $-1 35 40 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 30 40 -14.999999999999998 #
+point $-1 -1 -1 $-1 22.5 44.330127018922205 -22.500000000000007 #
+face $-1 -1 -1 $-1 $21484 $20079 $11 $-1 $7024 reversed single T 22.5 40 -9.9999999999999982 30 45 5.0000000000000036 F #
+loop $-1 -1 -1 $-1 $-1 $21485 $18664 T 7.5000000000000018 35 -10 15.000000000000004 40 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $21479 $18665 $21425 $21486 forward $18668 $-1 #
+vertex $-1 -1 -1 $-1 $21486 $21487 #
+face $-1 -1 -1 $-1 $20101 $18668 $11 $-1 $7024 reversed single T 22.499999999999993 35 -25.000000000000004 30 40 -9.9999999999999964 F #
+coedge $-1 -1 -1 $-1 $18689 $18669 $20156 $18718 reversed $18701 $-1 #
+coedge $-1 -1 -1 $-1 $20171 $20122 $18671 $20121 reversed $21488 $-1 #
+edge $-1 -1 -1 $-1 $17257 -2.0943951023931944 $17274 -1.5707963267948966 $18671 $21489 forward @7 unknown T -25 20 32.500000000000007 -22.500000000000004 20.669872981077813 35 #
+coedge $-1 -1 -1 $-1 $20120 $21490 $18672 $18764 reversed $21488 $-1 #
+coedge $-1 -1 -1 $-1 $18678 $21491 $21492 $21493 reversed $17194 $-1 #
+edge $-1 -1 -1 $-1 $19488 -35 $21494 -30 $19486 $21495 forward @7 unknown T -15 25 -35 -15 25 -30 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20126 $20126 $20350 $21496 forward $18680 $-1 #
+coedge $-1 -1 -1 $-1 $20127 $20127 $18681 $20128 reversed $21497 $-1 #
+edge $-1 -1 -1 $-1 $21498 0 $21498 6.2831853071795862 $18681 $21499 forward @7 unknown T 50 20 -14.999999999999996 50 30 -4.9999999999999964 #
+vertex $-1 -1 -1 $-1 $18683 $21500 #
+ellipse-curve $-1 -1 -1 $-1 50 25 5.0000000000000027 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+loop $-1 -1 -1 $-1 $21501 $18775 $3147 T -50 20 14.999999999999996 -50 30 24.999999999999996 hole $3148 T #
+point $-1 -1 -1 $-1 -50 25 29.999999999999996 #
+coedge $-1 -1 -1 $-1 $20156 $21502 $18688 $20134 forward $18729 $-1 #
+edge $-1 -1 -1 $-1 $21503 22.5 $20135 32.5 $20133 $21504 forward @7 unknown T -37.500000000000007 20.669872981077805 22.5 -37.5 20.669872981077813 32.5 #
+vertex $-1 -1 -1 $-1 $18718 $21505 #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 35 -0.70710678118654768 -0 -0.70710678118654724 -5 3.0616169978683826e-16 5.0000000000000036 0.70710678118654724 I I #
+coedge $-1 -1 -1 $-1 $18691 $18777 $21506 $21507 reversed $17209 $-1 #
+coedge $-1 -1 -1 $-1 $21508 $18706 $18691 $20139 forward $17235 $-1 #
+edge $-1 -1 -1 $-1 $20140 -32.500000000000007 $21509 -22.499999999999993 $20138 $21510 forward @7 unknown T -37.500000000000007 29.330127018922195 22.499999999999993 -37.5 29.330127018922198 32.500000000000007 #
+vertex $-1 -1 -1 $-1 $20139 $21511 #
+coedge $-1 -1 -1 $-1 $21512 $20225 $18694 $20143 forward $21513 $-1 #
+edge $-1 -1 -1 $-1 $18782 1.5707963267948966 $21503 2.0943951023931948 $20142 $21514 forward @7 unknown T -40 20.000000000000004 19.999999999999996 -37.5 20.669872981077809 22.5 #
+point $-1 -1 -1 $-1 37.500000000000014 20.669872981077813 7.5000000000000036 #
+loop $-1 -1 -1 $-1 $-1 $21515 $18705 T -45 20.000000000000004 -40 -37.499999999999993 30.000000000000004 -25.000000000000004 unknown #
+ellipse-curve $-1 -1 -1 $-1 -35 25 35 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21516 $21517 $11 $-1 $12288 reversed single T -37.500000000000007 25 4.9999999999999982 -30 30 19.999999999999996 F #
+ellipse-curve $-1 -1 -1 $-1 -35 25 35 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20152 $20156 $18712 $20150 forward $18729 $-1 #
+edge $-1 -1 -1 $-1 $17239 -1.5707963267948966 $18716 0 $20149 $20148 forward @7 unknown T -35 20 30 -30 25 35 #
+coedge $-1 -1 -1 $-1 $18713 $21508 $21518 $21519 forward $17235 $-1 #
+coedge $-1 -1 -1 $-1 $21520 $20149 $21490 $20153 reversed $18729 $-1 #
+edge $-1 -1 -1 $-1 $21521 24.999999999999996 $18716 30 $18713 $21522 forward @7 unknown T -30 25 24.999999999999996 -29.999999999999993 25 30 #
+coedge $-1 -1 -1 $-1 $20157 $18714 $21523 $21524 reversed $18715 $-1 #
+point $-1 -1 -1 $-1 -30 25 30 #
+coedge $-1 -1 -1 $-1 $20149 $20133 $20119 $18718 forward $18729 $-1 #
+coedge $-1 -1 -1 $-1 $18720 $20154 $21525 $21526 reversed $18715 $-1 #
+coedge $-1 -1 -1 $-1 $20899 $21527 $19478 $20905 reversed $18722 $-1 #
+coedge $-1 -1 -1 $-1 $20884 $18723 $20902 $21528 reversed $17243 $-1 #
+coedge $-1 -1 -1 $-1 $18723 $21529 $21530 $21531 reversed $17243 $-1 #
+coedge $-1 -1 -1 $-1 $21532 $21533 $21174 $20162 forward $21534 $-1 #
+edge $-1 -1 -1 $-1 $21176 -35 $21535 -30.000000000000004 $20161 $21536 forward @7 unknown T -30.000000000000007 25 -35 -30 25 -30.000000000000004 #
+coedge $-1 -1 -1 $-1 $21525 $21537 $18725 $20164 reversed $21538 $-1 #
+edge $-1 -1 -1 $-1 $20165 4.1887902047863905 $20207 4.7123889803846897 $18725 $21539 forward @7 unknown T -22.500000000000004 29.330127018922191 20 -20 30 22.500000000000004 #
+vertex $-1 -1 -1 $-1 $20164 $21540 #
+straight-curve $-1 -1 -1 $-1 -22.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $21541 $21542 $11 $-1 $11403 reversed single T -35 25 14.999999999999996 -25 30 25 F #
+loop $-1 -1 -1 $-1 $-1 $18746 $18728 T -22.500000000000004 25 4.9999999999999991 -15 30 20 unknown #
+coedge $-1 -1 -1 $-1 $20170 $18731 $20244 $18762 forward $18732 $-1 #
+coedge $-1 -1 -1 $-1 $18736 $20169 $21543 $21544 forward $18732 $-1 #
+coedge $-1 -1 -1 $-1 $21545 $20120 $18736 $20172 reversed $21488 $-1 #
+edge $-1 -1 -1 $-1 $21546 22.500000000000004 $17257 32.500000000000007 $18736 $21547 forward @7 unknown T -22.500000000000004 20.669872981077805 22.500000000000004 -22.5 20.669872981077813 32.500000000000007 #
+face $-1 -1 -1 $-1 $18698 $18790 $11 $-1 $11391 reversed single T -15 20 4.9999999999999991 -7.4999999999999964 25 20 F #
+loop $-1 -1 -1 $-1 $-1 $21548 $18737 T -15 20 -10 -7.4999999999999964 25 4.9999999999999991 unknown #
+coedge $-1 -1 -1 $-1 $21549 $21550 $21551 $21552 reversed $18738 $-1 #
+coedge $-1 -1 -1 $-1 $20933 $18739 $21553 $21554 reversed $17260 $-1 #
+coedge $-1 -1 -1 $-1 $18739 $20929 $21555 $21556 reversed $17260 $-1 #
+coedge $-1 -1 -1 $-1 $21557 $21492 $18739 $20179 forward $21558 $-1 #
+edge $-1 -1 -1 $-1 $21559 -1.570796326794897 $21560 6.1232339957367648e-17 $20178 $21561 forward @7 unknown T -15 25 -25 -9.9999999999999964 30 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $18740 $20941 $18749 $20200 reversed $15791 $-1 #
+coedge $-1 -1 -1 $-1 $21562 $20927 $21563 $20182 forward $21564 $-1 #
+edge $-1 -1 -1 $-1 $20183 -5.0000000000000018 $21565 -8.8817841970012523e-16 $20181 $21566 forward @7 unknown T -15 25 -5.0000000000000018 -14.999999999999996 25 -8.8817841970012523e-16 #
+vertex $-1 -1 -1 $-1 $21567 $21568 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18745 $18742 $18754 $20205 reversed $14289 $-1 #
+coedge $-1 -1 -1 $-1 $21569 $20213 $18742 $20187 forward $21570 $-1 #
+edge $-1 -1 -1 $-1 $21571 -17.5 $20191 -7.4999999999999964 $20186 $21572 forward @7 unknown T -7.5 29.330127018922191 7.4999999999999964 -7.4999999999999964 29.330127018922195 17.5 #
+coedge $-1 -1 -1 $-1 $21573 $18743 $20941 $21574 forward $20190 $-1 #
+coedge $-1 -1 -1 $-1 $18743 $21573 $21569 $21575 reversed $20190 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18743 $21576 T -9.9999999999999982 29.330127018922191 2.4999999999999991 -5 30 7.4999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $21575 $21577 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21578 $18746 $18757 $20206 forward $20168 $-1 #
+coedge $-1 -1 -1 $-1 $18746 $21579 $18748 $20199 forward $20168 $-1 #
+coedge $-1 -1 -1 $-1 $21580 $21581 $20241 $18747 reversed $21582 $-1 #
+vertex $-1 -1 -1 $-1 $20206 $21583 #
+straight-curve $-1 -1 -1 $-1 -15 25 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $18749 $18748 $21562 $21584 reversed $18750 $-1 #
+edge $-1 -1 -1 $-1 $21585 1.5707963267948966 $18752 3.1415926535897931 $20194 $21586 forward @7 unknown T -20 25 4.9999999999999991 -15 30 10 #
+edge $-1 -1 -1 $-1 $21565 -6.1232339957367648e-17 $18751 1.5707963267948966 $18749 $21587 forward @7 unknown T -15 25 -1.7763568394002505e-15 -9.9999999999999982 30 4.9999999999999991 #
+face $-1 -1 -1 $-1 $21588 $18750 $11 $-1 $13449 reversed single T -20 25 -1.7763568394002505e-15 -9.9999999999999982 30 10 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 30 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $18752 3.1415926535897931 $21589 4.7123889803846897 $21580 $21586 forward @7 unknown T -20 20 4.9999999999999991 -15 25 10 #
+point $-1 -1 -1 $-1 -15 25 10 #
+edge $-1 -1 -1 $-1 $17271 1.5707963267948966 $21571 2.0943951023931953 $18754 $21590 forward @7 unknown T -9.9999999999999982 29.330127018922191 17.5 -7.4999999999999991 30 20 #
+edge $-1 -1 -1 $-1 $20196 0 $20207 1.5707963267948966 $20193 $21591 forward @7 unknown T -20 25 15 -15 30 20 #
+vertex $-1 -1 -1 $-1 $21592 $21593 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 20 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21594 $20245 $11 $-1 $11403 reversed single T -20 20 15 -9.9999999999999982 25 25 F #
+vertex $-1 -1 -1 $-1 $21595 $21596 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 35 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20186 $20216 $18766 $20214 forward $21570 $-1 #
+edge $-1 -1 -1 $-1 $18767 -1.5707963267948966 $21571 -1.0471975511965974 $20213 $20237 forward @7 unknown T -7.5000000000000009 29.330127018922191 17.5 -5 30 20 #
+point $-1 -1 -1 $-1 -5 30 20 #
+coedge $-1 -1 -1 $-1 $20213 $21597 $18770 $20217 forward $21570 $-1 #
+edge $-1 -1 -1 $-1 $20249 0 $18767 1.5707963267948966 $20216 $21598 forward @7 unknown T -5 25 15 0 30 20 #
+face $-1 -1 -1 $-1 $21599 $21570 $11 $-1 $9021 reversed single T -7.5000000000000009 25 5 8.8817841970012523e-16 30 20 F #
+loop $-1 -1 -1 $-1 $21600 $21601 $18772 T -45 20.000000000000004 -3.5527136788005009e-15 -40 30.000000000000004 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $21602 $21603 $20239 $21604 forward $18773 $-1 #
+vertex $-1 -1 -1 $-1 $18776 $21605 #
+ellipse-curve $-1 -1 -1 $-1 -50 25 19.999999999999996 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 25.000000000000004 19.999999999999996 0.70710678118654746 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20230 $18779 $21606 $21607 reversed $18781 $-1 #
+coedge $-1 -1 -1 $-1 $20142 $21608 $18779 $20226 forward $21513 $-1 #
+edge $-1 -1 -1 $-1 $21609 -2.0943951023931957 $18782 -1.5707963267948966 $20225 $21610 forward @7 unknown T -40 20.000000000000004 17.499999999999996 -37.5 20.669872981077813 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $18780 $21611 $21612 $21613 reversed $18781 $-1 #
+coedge $-1 -1 -1 $-1 $21614 $21506 $18780 $20229 forward $21615 $-1 #
+edge $-1 -1 -1 $-1 $18783 1.5707963267948966 $21616 2.0943951023931957 $20228 $21617 forward @7 unknown T -40 29.330127018922195 17.499999999999996 -37.499999999999993 30.000000000000004 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $21618 $20224 $21619 $21620 reversed $18781 $-1 #
+face $-1 -1 -1 $-1 $18695 $18781 $11 $-1 $17225 reversed single T -45 20.000000000000004 4.9999999999999973 -37.499999999999993 30.000000000000004 19.999999999999996 F #
+point $-1 -1 -1 $-1 -40 20.000000000000004 19.999999999999996 #
+point $-1 -1 -1 $-1 -40 30.000000000000004 19.999999999999996 #
+coedge $-1 -1 -1 $-1 $21621 $18785 $18831 $20285 forward $20236 $-1 #
+coedge $-1 -1 -1 $-1 $18785 $21622 $18788 $20240 forward $20236 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21621 $18830 T -7.5 20 5 8.8817841970012523e-16 25 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 25 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 20 20 #
+coedge $-1 -1 -1 $-1 $21623 $18788 $20220 $21604 reversed $18790 $-1 #
+edge $-1 -1 -1 $-1 $21624 7.5 $18791 17.5 $20235 $21625 forward @7 unknown T -7.5 20.669872981077802 7.5 -7.4999999999999964 20.669872981077805 17.5 #
+coedge $-1 -1 -1 $-1 $18789 $21623 $17263 $18747 forward $18790 $-1 #
+coedge $-1 -1 -1 $-1 $21626 $18793 $18789 $18795 forward $20245 $-1 #
+point $-1 -1 -1 $-1 -7.4999999999999964 20.669872981077802 17.5 #
+coedge $-1 -1 -1 $-1 $18793 $21626 $20169 $18762 reversed $20245 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18793 $20210 T -20 20 15 -9.9999999999999982 25 25 unknown #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 20 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18804 $18799 $21597 $21627 reversed $17305 $-1 #
+vertex $-1 -1 -1 $-1 $20217 $21628 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21629 $21630 $11 $-1 $9009 reversed single T 0 20 -25 7.5000000000000027 25 -10 F #
+loop $-1 -1 -1 $-1 $-1 $18814 $18802 T 0 25 -25 7.5000000000000027 30 -10 unknown #
+coedge $-1 -1 -1 $-1 $21631 $21632 $21633 $21634 reversed $18803 $-1 #
+coedge $-1 -1 -1 $-1 $20256 $18804 $20953 $21635 reversed $17305 $-1 #
+edge $-1 -1 -1 $-1 $21636 -1.5707963267948966 $21637 6.1232339957367648e-17 $19517 $21638 forward @7 unknown T 0 25 5 5.0000000000000018 30 10 #
+coedge $-1 -1 -1 $-1 $18806 $20254 $18827 $20283 reversed $17305 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18866 $18808 $21639 $21640 forward $18867 $-1 #
+vertex $-1 -1 -1 $-1 $19513 $21641 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21642 $18814 $18811 $20262 reversed $20252 $-1 #
+edge $-1 -1 -1 $-1 $20317 -2.0943951023931939 $17318 -1.5707963267948961 $18811 $21643 forward @7 unknown T 4.9999999999999991 29.330127018922195 -25 7.5000000000000027 30 -22.500000000000004 #
+coedge $-1 -1 -1 $-1 $21644 $21645 $18813 $20264 forward $21646 $-1 #
+edge $-1 -1 -1 $-1 $18821 1.5707963267948966 $20266 3.1415926535897931 $20263 $21647 forward @7 unknown T -5 25 -25 0 30 -20 #
+coedge $-1 -1 -1 $-1 $18814 $21648 $21644 $21649 reversed $20252 $-1 #
+vertex $-1 -1 -1 $-1 $21650 $21651 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $20322 $20281 $11 $-1 $14408 reversed single T -5 20 -30 5.0000000000000036 25 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $21491 $20878 $18818 $20270 reversed $17194 $-1 #
+edge $-1 -1 -1 $-1 $20274 27.499999999999996 $20277 37.5 $18818 $21652 forward @7 unknown T -7.5 29.330127018922191 -37.5 -7.4999999999999964 29.330127018922195 -27.499999999999996 #
+coedge $-1 -1 -1 $-1 $21553 $18819 $21645 $21653 reversed $20273 $-1 #
+coedge $-1 -1 -1 $-1 $18819 $21553 $21491 $21654 forward $20273 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20272 $21655 T -10 29.330127018922191 -27.5 -5 30 -22.5 unknown #
+vertex $-1 -1 -1 $-1 $21654 $21656 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -25 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -5 30 -25 #
+vertex $-1 -1 -1 $-1 $18823 $21657 #
+coedge $-1 -1 -1 $-1 $21658 $21659 $18824 $20279 reversed $21660 $-1 #
+edge $-1 -1 -1 $-1 $20919 1.0471975511965987 $20282 1.5707963267948966 $18824 $20275 forward @7 unknown T -7.4999999999999964 20 -27.499999999999996 -5 20.669872981077805 -25 #
+coedge $-1 -1 -1 $-1 $20945 $18825 $21661 $21650 reversed $20281 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19512 $20268 T -5 20 -30 5.0000000000000036 25 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $20279 $21662 #
+edge $-1 -1 -1 $-1 $18828 -17.5 $20956 -7.5000000000000018 $18827 $21663 forward @7 unknown T 7.4999999999999956 29.330127018922184 7.5000000000000018 7.5000000000000009 29.330127018922195 17.5 #
+point $-1 -1 -1 $-1 7.5 29.330127018922191 17.5 #
+edge $-1 -1 -1 $-1 $18787 -1.5707963267948966 $20249 0 $20234 $21598 forward @7 unknown T -5 20 15 0 25 20 #
+point $-1 -1 -1 $-1 7.5 20.669872981077805 17.5 #
+coedge $-1 -1 -1 $-1 $18835 $19524 $21664 $21665 forward $17377 $-1 #
+face $-1 -1 -1 $-1 $14234 $18895 $11 $-1 $7081 reversed single T 14.999999999999996 20 5.0000000000000009 22.500000000000004 25 20 F #
+loop $-1 -1 -1 $-1 $-1 $21666 $18836 T 15 20 -9.9999999999999982 22.500000000000004 25 5.0000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $20974 $18838 $20978 $20979 reversed $15849 $-1 #
+coedge $-1 -1 -1 $-1 $21667 $21668 $18838 $20292 forward $21669 $-1 #
+edge $-1 -1 -1 $-1 $21670 -2.0943951023931957 $20298 -1.5707963267948966 $20291 $21671 forward @7 unknown T 20 29.330127018922191 -9.9999999999999982 22.500000000000004 30 -7.4999999999999964 #
+coedge $-1 -1 -1 $-1 $20958 $21672 $20367 $20294 forward $21673 $-1 #
+edge $-1 -1 -1 $-1 $20299 -5 $20975 8.8817841970012523e-16 $20293 $21674 forward @7 unknown T 15 25 -5 15.000000000000004 25 8.8817841970012523e-16 #
+coedge $-1 -1 -1 $-1 $21675 $18840 $21672 $21676 reversed $20297 $-1 #
+coedge $-1 -1 -1 $-1 $18840 $21675 $18857 $20314 forward $20297 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18840 $21677 T 10 25 -15 20 30 -4.9999999999999982 unknown #
+vertex $-1 -1 -1 $-1 $20314 $21678 #
+vertex $-1 -1 -1 $-1 $21679 $21680 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -9.9999999999999982 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 25 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 30 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $21664 $20952 $18845 $20304 reversed $21681 $-1 #
+edge $-1 -1 -1 $-1 $18834 -2.0943951023931948 $18846 -1.5707963267948966 $18845 $21682 forward @7 unknown T 5.0000000000000018 20 17.5 7.5 20.669872981077805 20 #
+edge $-1 -1 -1 $-1 $18846 -1.5707963267948966 $20249 -6.1232339957367648e-17 $19518 $21683 forward @7 unknown T 0 20 15 5.0000000000000018 25 20 #
+point $-1 -1 -1 $-1 5.0000000000000018 20 20 #
+coedge $-1 -1 -1 $-1 $18848 $21684 $18921 $20368 reversed $18837 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18857 $18851 $21667 $21685 reversed $17341 $-1 #
+coedge $-1 -1 -1 $-1 $21686 $18853 $21675 $21687 forward $18855 $-1 #
+coedge $-1 -1 -1 $-1 $18868 $21688 $20966 $18858 reversed $20323 $-1 #
+coedge $-1 -1 -1 $-1 $18854 $21686 $21642 $21689 forward $18855 $-1 #
+face $-1 -1 -1 $-1 $12681 $18855 $11 $-1 $7093 reversed single T 7.5000000000000009 25 -25 15 30 -10 F #
+edge $-1 -1 -1 $-1 $20315 -6.1232339957367648e-17 $20298 1.5707963267948966 $20296 $21690 forward @7 unknown T 15 25 -15 20 30 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $21687 $21691 #
+straight-curve $-1 -1 -1 $-1 15 25 0 0 0 1 I I #
+vertex $-1 -1 -1 $-1 $18862 $21692 #
+ellipse-curve $-1 -1 -1 $-1 10 25 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21693 $21694 $11 $-1 $9021 reversed single T -7.5000000000000027 20 -10 8.8817841970012523e-16 25 5 F #
+coedge $-1 -1 -1 $-1 $21695 $18868 $18866 $20321 forward $20323 $-1 #
+edge $-1 -1 -1 $-1 $17374 1.5707963267948966 $21696 2.0943951023931957 $20320 $20318 forward @7 unknown T 7.4999999999999991 20 -25 10 20.669872981077813 -22.5 #
+face $-1 -1 -1 $-1 $18863 $18867 $11 $-1 $14408 reversed single T 4.9999999999999991 20 -27.5 10 20.669872981077813 -22.5 F #
+loop $-1 -1 -1 $-1 $-1 $20311 $21697 T 7.4999999999999991 20 -25 15 25 -10 unknown #
+coedge $-1 -1 -1 $-1 $19527 $18871 $19531 $20969 reversed $18895 $-1 #
+straight-curve $-1 -1 -1 $-1 22.5 20.669872981077805 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $20338 $18873 $21698 $21699 reversed $17383 $-1 #
+coedge $-1 -1 -1 $-1 $18873 $20988 $21700 $21701 reversed $17383 $-1 #
+coedge $-1 -1 -1 $-1 $21702 $20345 $18873 $20329 forward $20357 $-1 #
+edge $-1 -1 -1 $-1 $21703 1.5707963267948966 $21704 2.0943951023931966 $20328 $21705 forward @7 unknown T 35 19.999999999999996 -9.9999999999999982 37.500000000000014 20.669872981077809 -7.4999999999999929 #
+coedge $-1 -1 -1 $-1 $21706 $18875 $18878 $20333 forward $18911 $-1 #
+straight-curve $-1 -1 -1 $-1 37.5 29.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $18878 $18877 $18905 $20353 reversed $18879 $-1 #
+edge $-1 -1 -1 $-1 $18880 4.1887902047863896 $21707 4.7123889803846897 $20330 $21708 forward @7 unknown T 37.499999999999993 29.330127018922191 -9.9999999999999982 40 30 -7.499999999999992 #
+face $-1 -1 -1 $-1 $21709 $18879 $11 $-1 $14961 reversed single T 35 29.330127018922191 -12.500000000000004 40 30 -7.499999999999992 F #
+point $-1 -1 -1 $-1 37.499999999999993 29.330127018922195 -7.499999999999992 #
+coedge $-1 -1 -1 $-1 $18882 $20978 $21668 $21710 forward $18884 $-1 #
+coedge $-1 -1 -1 $-1 $21711 $18883 $21712 $18891 forward $17422 $-1 #
+coedge $-1 -1 -1 $-1 $19553 $20326 $15891 $17389 forward $17383 $-1 #
+point $-1 -1 -1 $-1 29.999999999999996 25 1.7763568394002505e-15 #
+vertex $-1 -1 -1 $-1 $20359 $21713 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 25 -9.9999999999999982 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $21714 $21715 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20352 $18898 $21716 $21717 forward $17415 $-1 #
+coedge $-1 -1 -1 $-1 $20328 $21716 $18899 $20346 forward $20357 $-1 #
+edge $-1 -1 -1 $-1 $20347 -2.0943951023931948 $21703 -1.5707963267948966 $20345 $21718 forward @7 unknown T 35 19.999999999999996 -12.499999999999995 37.5 20.669872981077802 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $21717 $21719 #
+straight-curve $-1 -1 -1 $-1 37.5 20.669872981077805 0 0 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 25 -24.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20350 $20350 $20126 $21496 reversed $18903 $-1 #
+face $-1 -1 -1 $-1 $21720 $21721 $11 $-1 $14408 reversed single T -50 20 -30.000000000000004 -40 30.000000000000004 -20.000000000000004 F #
+coedge $-1 -1 -1 $-1 $18905 $20344 $21722 $21723 forward $17415 $-1 #
+edge $-1 -1 -1 $-1 $21707 -1.5707963267948966 $18908 -1.0471975511965965 $18905 $21724 forward @7 unknown T 37.499999999999993 29.330127018922191 -12.500000000000004 40 30 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.499999999999993 29.330127018922191 -12.500000000000002 #
+face $-1 -1 -1 $-1 $18889 $21725 $11 $-1 $14961 reversed single T 24.999999999999996 19.999999999999996 -15 35 25 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $20345 $18910 T 35 19.999999999999996 -12.499999999999996 40 20.669872981077809 -7.4999999999999929 unknown #
+coedge $-1 -1 -1 $-1 $21668 $21667 $18912 $20359 reversed $21669 $-1 #
+edge $-1 -1 -1 $-1 $20340 -1.570796326794897 $20364 -1.0471975511965983 $18912 $21726 forward @7 unknown T 22.5 29.330127018922195 -12.499999999999996 25 30 -9.9999999999999964 #
+ellipse-curve $-1 -1 -1 $-1 25 25 -9.9999999999999982 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18914 $18921 $21727 $21714 forward $17436 $-1 #
+coedge $-1 -1 -1 $-1 $21712 $20986 $18914 $20363 reversed $21725 $-1 #
+edge $-1 -1 -1 $-1 $20342 -1.5707963267948966 $17428 0 $18914 $20360 forward @7 unknown T 25 20 -14.999999999999998 30 25 -9.9999999999999982 #
+vertex $-1 -1 -1 $-1 $21685 $21728 #
+straight-curve $-1 -1 -1 $-1 22.5 29.330127018922195 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $21729 $21730 $11 $-1 $14961 reversed single T 20 20 -12.5 25 20.669872981077813 -7.4999999999999973 F #
+coedge $-1 -1 -1 $-1 $21731 $21732 $21733 $20294 reversed $18920 $-1 #
+edge $-1 -1 -1 $-1 $18922 -22.499999999999996 $21734 -12.499999999999998 $18921 $21735 forward @7 unknown T 22.499999999999993 20.669872981077802 -22.499999999999996 22.5 20.669872981077813 -12.499999999999998 #
+point $-1 -1 -1 $-1 22.499999999999993 20.669872981077802 -22.499999999999996 #
+loop $-1 -1 -1 $-1 $-1 $20427 $21736 T -30 5.0000000000000018 20 -22.5 10 35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 35 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $18927 $21737 $17482 $18958 forward $20370 $-1 #
+coedge $-1 -1 -1 $-1 $18928 $19074 $19077 $20536 reversed $15944 $-1 #
+coedge $-1 -1 -1 $-1 $18983 $21020 $18928 $20375 forward $20440 $-1 #
+edge $-1 -1 -1 $-1 $20376 -6.1232339957367648e-17 $20441 1.5707963267948961 $20374 $21738 forward @7 unknown T -15 10 -30 -10 15 -25 #
+vertex $-1 -1 -1 $-1 $21021 $21739 #
+straight-curve $-1 -1 -1 $-1 -15 10 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $21740 0 $21740 6.2831853071795862 $18931 $21741 forward @7 unknown T 50 5 -29.999999999999996 50 15 -19.999999999999996 #
+loop $-1 -1 -1 $-1 $-1 $18932 $20481 T 50 5 -14.999999999999996 50 15 -4.9999999999999964 unknown #
+vertex $-1 -1 -1 $-1 $18933 $21742 #
+ellipse-curve $-1 -1 -1 $-1 50 10 -9.9999999999999964 -1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+point $-1 -1 -1 $-1 50 10 3.0616169978683823e-15 #
+loop $-1 -1 -1 $-1 $21743 $21744 $3147 T -50 5 -3.0616169978683823e-15 -50 15 9.9999999999999964 hole $3148 T #
+coedge $-1 -1 -1 $-1 $18938 $20402 $20394 $21745 forward $17497 $-1 #
+vertex $-1 -1 -1 $-1 $18948 $21746 #
+straight-curve $-1 -1 -1 $-1 -37.5 5.6698729810778064 0 0 0 1 I I #
+point $-1 -1 -1 $-1 -37.5 5.6698729810778072 32.5 #
+coedge $-1 -1 -1 $-1 $19033 $21747 $18942 $20389 forward $20497 $-1 #
+edge $-1 -1 -1 $-1 $20391 -2.0943951023931948 $17551 -1.5707963267948966 $20388 $21748 forward @7 unknown T -40 14.330127018922193 19.999999999999996 -37.5 15.000000000000002 22.499999999999993 #
+coedge $-1 -1 -1 $-1 $18956 $18943 $21747 $21749 forward $15985 $-1 #
+vertex $-1 -1 -1 $-1 $21749 $21750 #
+straight-curve $-1 -1 -1 $-1 -37.5 14.330127018922195 0 -0 -0 -1 I I #
+point $-1 -1 -1 $-1 -37.5 14.330127018922193 32.5 #
+coedge $-1 -1 -1 $-1 $20490 $18947 $20384 $21745 reversed $20395 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18947 $20398 T -40 5 17.499999999999993 -35 5.6698729810778108 22.499999999999996 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21751 $21183 $19562 $20997 reversed $18950 $-1 #
+face $-1 -1 -1 $-1 $21752 $20395 $11 $-1 $10259 reversed single T -40 5 17.499999999999993 -35 5.6698729810778108 22.499999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $21753 $18952 T -37.500000000000007 10 4.9999999999999982 -30 15 19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $21754 $20405 $18956 $20401 reversed $20424 $-1 #
+edge $-1 -1 -1 $-1 $21755 1.5707963267948957 $20403 3.1415926535897931 $18956 $21756 forward @7 unknown T -35 10 19.999999999999993 -29.999999999999993 15 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $20384 $18957 $21757 $21758 forward $17497 $-1 #
+vertex $-1 -1 -1 $-1 $21758 $21759 #
+straight-curve $-1 -1 -1 $-1 -30 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $20400 $21760 $18959 $20406 forward $20424 $-1 #
+edge $-1 -1 -1 $-1 $21761 -1.5707963267948966 $20403 4.1650370783741808e-16 $20405 $21762 forward @7 unknown T -30 10 20 -25 15.000000000000002 25 #
+coedge $-1 -1 -1 $-1 $21763 $18968 $18962 $20408 forward $20420 $-1 #
+edge $-1 -1 -1 $-1 $18970 -2.0943951023931957 $21761 -1.5707963267948966 $20407 $21764 forward @7 unknown T -25 14.330127018922193 20 -22.499999999999993 15.000000000000002 22.5 #
+coedge $-1 -1 -1 $-1 $18963 $21765 $19587 $21016 reversed $17490 $-1 #
+edge $-1 -1 -1 $-1 $19567 -1.5707963267948966 $19795 4.1650370783741769e-16 $19583 $21766 forward @7 unknown T -30 10 -40 -25 15.000000000000002 -35 #
+coedge $-1 -1 -1 $-1 $18965 $21001 $21767 $21768 reversed $15993 $-1 #
+coedge $-1 -1 -1 $-1 $21769 $21770 $18965 $20413 forward $21771 $-1 #
+edge $-1 -1 -1 $-1 $20417 -4.1650370783741719e-16 $21772 1.5707963267948961 $20412 $21773 forward @7 unknown T -30.000000000000007 10 -30.000000000000004 -25 15.000000000000002 -25 #
+coedge $-1 -1 -1 $-1 $21774 $18966 $21770 $21775 forward $20416 $-1 #
+coedge $-1 -1 -1 $-1 $18966 $21776 $19800 $21193 forward $20416 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18966 $21777 T -37.500000000000007 10 -40 -30 15 -25.000000000000004 unknown #
+vertex $-1 -1 -1 $-1 $21775 $21778 #
+coedge $-1 -1 -1 $-1 $18968 $21763 $20460 $20474 reversed $20420 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20407 $21779 T -25 14.330127018922191 17.5 -20 15.000000000000002 22.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -20 10 20 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -22.499999999999993 14.330127018922193 22.499999999999993 #
+face $-1 -1 -1 $-1 $21780 $21781 $11 $-1 $10259 reversed single T -35 5 14.999999999999996 -25 10 25 F #
+loop $-1 -1 -1 $-1 $-1 $20405 $18972 T -35 10 14.999999999999996 -25 15.000000000000002 25 unknown #
+coedge $-1 -1 -1 $-1 $21782 $21783 $18975 $20426 reversed $21784 $-1 #
+edge $-1 -1 -1 $-1 $19016 1.5707963267948966 $20428 2.0943951023931957 $18975 $20421 forward @7 unknown T -22.5 5 20 -20 5.669872981077809 22.5 #
+coedge $-1 -1 -1 $-1 $21737 $18976 $21783 $21785 reversed $20370 $-1 #
+vertex $-1 -1 -1 $-1 $21785 $21786 #
+straight-curve $-1 -1 -1 $-1 -22.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19605 $21787 $21788 $21789 reversed $18979 $-1 #
+coedge $-1 -1 -1 $-1 $21790 $18980 $20993 $21791 reversed $17506 $-1 #
+coedge $-1 -1 -1 $-1 $18980 $21792 $21793 $21794 reversed $17506 $-1 #
+coedge $-1 -1 -1 $-1 $20541 $20540 $18980 $20434 forward $20542 $-1 #
+edge $-1 -1 -1 $-1 $21795 1.5707963267948961 $21796 2.0943951023931948 $20433 $21797 forward @7 unknown T -10.000000000000002 5 -25 -7.5 5.6698729810778072 -22.5 #
+coedge $-1 -1 -1 $-1 $19077 $19076 $18981 $20436 forward $19078 $-1 #
+edge $-1 -1 -1 $-1 $21798 -2.0943951023931948 $20441 -1.5707963267948961 $20435 $21799 forward @7 unknown T -10.000000000000002 14.330127018922193 -25 -7.4999999999999982 15 -22.5 #
+coedge $-1 -1 -1 $-1 $21033 $21800 $21025 $20438 forward $21801 $-1 #
+edge $-1 -1 -1 $-1 $20442 -20 $21038 -15.000000000000002 $20437 $21802 forward @7 unknown T -15.000000000000004 10 -20 -15 10 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $21020 $18983 $21800 $21803 reversed $20440 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18983 $19557 T -20 10 -30 -9.9999999999999982 15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $20375 $21804 #
+vertex $-1 -1 -1 $-1 $21805 $21806 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21807 $18986 $19003 $20466 forward $20446 $-1 #
+coedge $-1 -1 -1 $-1 $21029 $21808 $21030 $18987 reversed $21809 $-1 #
+loop $-1 -1 -1 $-1 $-1 $18986 $21810 T -22.500000000000004 10 -10.000000000000004 -14.999999999999996 15 4.9999999999999991 unknown #
+vertex $-1 -1 -1 $-1 $20466 $21811 #
+edge $-1 -1 -1 $-1 $18988 3.1415926535897931 $21812 4.7123889803846897 $21029 $21037 forward @7 unknown T -20 5 -10.000000000000002 -14.999999999999996 10 -5.0000000000000018 #
+point $-1 -1 -1 $-1 -14.999999999999996 10 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $21061 $18991 $18994 $20457 forward $20452 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20479 $19023 T -7.5000000000000044 10 5 8.8817841970012523e-16 15 20 unknown #
+vertex $-1 -1 -1 $-1 $18992 $21813 #
+straight-curve $-1 -1 -1 $-1 -7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $18994 $18993 $21048 $21814 reversed $18995 $-1 #
+edge $-1 -1 -1 $-1 $17519 1.5707963267948966 $21051 2.0943951023931948 $18993 $21815 forward @7 unknown T -10 14.330127018922193 2.5000000000000004 -7.5 15 4.9999999999999991 #
+edge $-1 -1 -1 $-1 $18996 4.1887902047863905 $21816 4.7123889803846897 $20451 $21817 forward @7 unknown T -7.5000000000000044 14.330127018922191 5 -5 15 7.5000000000000044 #
+face $-1 -1 -1 $-1 $19006 $18995 $11 $-1 $12076 reversed single T -10 14.330127018922191 2.4999999999999991 -5 15 7.5000000000000044 F #
+point $-1 -1 -1 $-1 -7.5000000000000044 14.330127018922193 7.5000000000000044 #
+coedge $-1 -1 -1 $-1 $21818 $18998 $20419 $20474 forward $18973 $-1 #
+coedge $-1 -1 -1 $-1 $18999 $21818 $21819 $21820 forward $18973 $-1 #
+coedge $-1 -1 -1 $-1 $21821 $19000 $21822 $19008 forward $20464 $-1 #
+coedge $-1 -1 -1 $-1 $19000 $21823 $20508 $21824 forward $20464 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19000 $20476 T -22.500000000000004 4.9999999999999991 4.9999999999999991 -15 10 20 unknown #
+point $-1 -1 -1 $-1 -15 10 15 #
+edge $-1 -1 -1 $-1 $20447 0 $20467 1.5707963267948966 $20444 $21825 forward @7 unknown T -20 10 -8.8817841970012523e-16 -15 15 4.9999999999999991 #
+vertex $-1 -1 -1 $-1 $21826 $21827 #
+ellipse-curve $-1 -1 -1 $-1 -20 10 4.9999999999999991 0.70710678118654757 0 -0.70710678118654768 -5.0000000000000009 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10 10 4.9999999999999991 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21828 $21829 $11 $-1 $12076 reversed single T -20 4.9999999999999991 -1.7763568394002505e-15 -10 10 10 F #
+vertex $-1 -1 -1 $-1 $21830 $21831 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 20 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -20 10 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19012 -1.5707963267948966 $21832 -1.0471975511965974 $20460 $21833 forward @7 unknown T -22.500000000000004 14.330127018922191 17.5 -20 15 20 #
+point $-1 -1 -1 $-1 -20 15 20 #
+face $-1 -1 -1 $-1 $20458 $20464 $11 $-1 $11541 reversed single T -22.500000000000004 4.9999999999999991 4.9999999999999991 -15 10 20 F #
+edge $-1 -1 -1 $-1 $21834 1.047197551196597 $19016 1.5707963267948966 $21823 $21833 forward @7 unknown T -22.500000000000004 5 17.499999999999996 -20 5.6698729810778099 20 #
+point $-1 -1 -1 $-1 -20 5 20 #
+coedge $-1 -1 -1 $-1 $19021 $21061 $20503 $20509 forward $20452 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 20 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19139 $21835 $11 $-1 $13497 reversed single T 40 5 -14.999999999999998 50 15 -4.9999999999999964 F #
+loop $-1 -1 -1 $-1 $-1 $21836 $17540 T -50 5 -3.0616169978683823e-15 -50 15 9.9999999999999964 unknown #
+coedge $-1 -1 -1 $-1 $21837 $21837 $21838 $21839 forward $19024 $-1 #
+coedge $-1 -1 -1 $-1 $21840 $19025 $20504 $21841 reversed $17541 $-1 #
+coedge $-1 -1 -1 $-1 $19025 $21840 $21842 $21843 forward $17541 $-1 #
+edge $-1 -1 -1 $-1 $21844 1.5707963267948966 $20506 2.0943951023931957 $19025 $21845 forward @7 unknown T -10 5 4.9999999999999991 -7.4999999999999991 5.6698729810778081 7.5000000000000009 #
+point $-1 -1 -1 $-1 -50 10 14.999999999999996 #
+coedge $-1 -1 -1 $-1 $21846 $21847 $19029 $20489 forward $21848 $-1 #
+edge $-1 -1 -1 $-1 $21849 7.5 $20491 17.5 $20488 $21850 forward @7 unknown T -37.500000000000007 5.6698729810778064 7.5 -37.5 5.6698729810778108 17.5 #
+coedge $-1 -1 -1 $-1 $19030 $20394 $21846 $21851 reversed $20395 $-1 #
+vertex $-1 -1 -1 $-1 $21851 $21852 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 19.999999999999996 -0.70710678118654746 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999982 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19032 $20500 $21853 $21854 reversed $17549 $-1 #
+coedge $-1 -1 -1 $-1 $21855 $21856 $19032 $20495 forward $20399 $-1 #
+edge $-1 -1 -1 $-1 $20498 -17.499999999999993 $21857 -7.4999999999999982 $20494 $21858 forward @7 unknown T -37.500000000000007 14.330127018922195 7.4999999999999982 -37.5 14.330127018922196 17.499999999999993 #
+coedge $-1 -1 -1 $-1 $21747 $19033 $21856 $21859 reversed $20497 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20388 $21752 T -40 14.330127018922187 17.499999999999989 -35 15.000000000000002 22.499999999999993 unknown #
+vertex $-1 -1 -1 $-1 $20495 $21860 #
+coedge $-1 -1 -1 $-1 $20493 $19035 $21837 $21861 reversed $17549 $-1 #
+coedge $-1 -1 -1 $-1 $21862 $21863 $19035 $20502 forward $21864 $-1 #
+edge $-1 -1 -1 $-1 $21865 1.5707963267948966 $21849 2.0943951023931948 $20501 $21866 forward @7 unknown T -40 5.0000000000000018 4.9999999999999973 -37.5 5.6698729810778081 7.5 #
+coedge $-1 -1 -1 $-1 $21867 $19039 $21065 $20509 reversed $19041 $-1 #
+coedge $-1 -1 -1 $-1 $19040 $21867 $20484 $21841 forward $19041 $-1 #
+coedge $-1 -1 -1 $-1 $19046 $19044 $21868 $21869 reversed $17558 $-1 #
+vertex $-1 -1 -1 $-1 $20486 $21870 #
+straight-curve $-1 -1 -1 $-1 -7.5 5.6698729810778064 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19049 $19047 $20463 $21824 reversed $19050 $-1 #
+edge $-1 -1 -1 $-1 $20519 10 $19054 15 $20479 $21871 forward @7 unknown T 0 10 10 8.8817841970012523e-16 10 15 #
+point $-1 -1 -1 $-1 0 10 15 #
+face $-1 -1 -1 $-1 $21872 $21873 $11 $-1 $8101 reversed single T 0 4.9999999999999991 -10 7.5 10 5 F #
+loop $-1 -1 -1 $-1 $-1 $20521 $19056 T 0 4.9999999999999991 -25 7.5000000000000018 10 -10 unknown #
+coedge $-1 -1 -1 $-1 $21874 $19058 $21875 $21876 reversed $17571 $-1 #
+coedge $-1 -1 -1 $-1 $19058 $21063 $21045 $21877 reversed $17571 $-1 #
+coedge $-1 -1 -1 $-1 $21046 $21878 $19058 $20516 forward $21879 $-1 #
+edge $-1 -1 -1 $-1 $21880 -1.5707963267948966 $21881 6.1232339957367648e-17 $20515 $21882 forward @7 unknown T 0 10 -10 5.0000000000000009 15 -4.9999999999999991 #
+edge $-1 -1 -1 $-1 $19637 -2.0943951023931953 $20518 -1.5707963267948966 $19634 $21883 forward @7 unknown T 5.0000000000000009 14.330127018922195 5 7.5000000000000027 15 7.5 #
+vertex $-1 -1 -1 $-1 $21064 $21884 #
+vertex $-1 -1 -1 $-1 $21885 $21886 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 5 0.70710678118654757 0 0.70710678118654757 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21053 $21887 $19063 $20522 reversed $20512 $-1 #
+edge $-1 -1 -1 $-1 $19064 1.5707963267948966 $20578 2.0943951023931957 $19063 $21888 forward @7 unknown T 5.0000000000000009 4.9999999999999991 -25 7.5000000000000018 5.6698729810778072 -22.5 #
+point $-1 -1 -1 $-1 5.0000000000000009 5 -25 #
+coedge $-1 -1 -1 $-1 $21889 $19066 $19117 $20571 reversed $19057 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 -25 -0.70710678118654768 0 0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21041 $19068 $21890 $20531 forward $20528 $-1 #
+coedge $-1 -1 -1 $-1 $19068 $21040 $19076 $20535 forward $20528 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20526 $21891 T -7.5000000000000009 10 -25 8.8817841970012523e-16 15 -10 unknown #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -25 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19070 $21889 $21878 $21892 reversed $19057 $-1 #
+edge $-1 -1 -1 $-1 $19071 -20 $21893 -15 $20526 $21894 forward @7 unknown T 0 10 -20 8.8817841970012523e-16 10 -15 #
+edge $-1 -1 -1 $-1 $19071 3.1415926535897931 $19087 4.7123889803846897 $20543 $20529 forward @7 unknown T -5 5 -25 0 10 -20 #
+point $-1 -1 -1 $-1 0 10 -20 #
+edge $-1 -1 -1 $-1 $21798 4.1887902047863914 $17589 4.7123889803846897 $20527 $21895 forward @7 unknown T -7.4999999999999982 14.330127018922193 -25 -5 15 -22.500000000000004 #
+edge $-1 -1 -1 $-1 $20441 1.570796326794897 $19079 2.0943951023931957 $19077 $21896 forward @7 unknown T -10 14.330127018922191 -27.499999999999996 -7.4999999999999991 15 -25 #
+face $-1 -1 -1 $-1 $21897 $19078 $11 $-1 $13102 reversed single T -10.000000000000002 14.330127018922191 -27.5 -5 15 -22.5 F #
+point $-1 -1 -1 $-1 -7.5 14.330127018922193 -27.499999999999996 #
+point $-1 -1 -1 $-1 -7.4999999999999982 14.330127018922193 -37.5 #
+coedge $-1 -1 -1 $-1 $20433 $19083 $19569 $21005 forward $20542 $-1 #
+coedge $-1 -1 -1 $-1 $19083 $20433 $21898 $21899 reversed $20542 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20540 $21897 T -10.000000000000002 5 -27.500000000000004 -5 5.669872981077809 -22.5 unknown #
+coedge $-1 -1 -1 $-1 $21898 $21890 $19085 $20532 forward $21900 $-1 #
+point $-1 -1 -1 $-1 -5 5 -25 #
+straight-curve $-1 -1 -1 $-1 7.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $21901 $19108 $19092 $20547 reversed $20563 $-1 #
+edge $-1 -1 -1 $-1 $21073 7.5000000000000018 $17602 17.5 $19092 $21902 forward @7 unknown T 7.5 5.6698729810778064 7.5000000000000018 7.5000000000000018 5.6698729810778072 17.5 #
+coedge $-1 -1 -1 $-1 $21903 $21904 $21905 $21906 reversed $19094 $-1 #
+coedge $-1 -1 -1 $-1 $19163 $19096 $19114 $20567 forward $20551 $-1 #
+coedge $-1 -1 -1 $-1 $19096 $19163 $19141 $20592 reversed $20551 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20549 $20591 T 20 14.330127018922191 -12.499999999999998 25 15 -7.4999999999999947 unknown #
+vertex $-1 -1 -1 $-1 $20592 $21907 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -9.9999999999999982 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19098 $21908 $19100 $20558 forward $20555 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19098 $20575 T 7.5 10 -10 15.000000000000004 15 5.0000000000000009 unknown #
+straight-curve $-1 -1 -1 $-1 15 10 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19101 $19100 $19115 $20569 reversed $19102 $-1 #
+edge $-1 -1 -1 $-1 $21909 1.5707963267948966 $19104 3.1415926535897931 $20554 $21910 forward @7 unknown T 10 10 -10 15 15 -5 #
+face $-1 -1 -1 $-1 $19118 $19102 $11 $-1 $13497 reversed single T 10 10 -15 20 15 -4.9999999999999982 F #
+point $-1 -1 -1 $-1 20 14.999999999999998 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $19104 3.1415926535897931 $21911 4.7123889803846897 $20613 $21910 forward @7 unknown T 10 5 -10 15 10 -5 #
+point $-1 -1 -1 $-1 15 10 -5 #
+loop $-1 -1 -1 $-1 $-1 $21901 $21872 T 0 4.9999999999999991 5 7.5000000000000018 10 20 unknown #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 -0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000009 10 20 0.70710678118654768 -0 -0.70710678118654757 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19112 $21077 $21912 $21913 reversed $17605 $-1 #
+edge $-1 -1 -1 $-1 $19103 1.5707963267948966 $19169 2.0943951023931948 $20549 $21914 forward @7 unknown T 20 14.330127018922191 -12.499999999999995 22.499999999999996 14.999999999999998 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $19117 $19115 $21915 $21916 forward $17623 $-1 #
+edge $-1 -1 -1 $-1 $19120 0 $21909 1.5707963267948966 $19115 $21917 forward @7 unknown T 10 10 -15 15 15 -10 #
+coedge $-1 -1 -1 $-1 $19116 $21918 $21919 $21920 forward $19128 $-1 #
+edge $-1 -1 -1 $-1 $21921 12.5 $19122 22.500000000000004 $19117 $21922 forward @7 unknown T 7.5 14.330127018922195 -22.500000000000004 7.5000000000000018 14.330127018922196 -12.5 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 -9.9999999999999982 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 15 10 -15 #
+point $-1 -1 -1 $-1 7.5000000000000009 14.330127018922195 -22.500000000000004 #
+face $-1 -1 -1 $-1 $21923 $20555 $11 $-1 $6231 reversed single T 7.5 10 -10 15.000000000000004 15 5.0000000000000009 F #
+loop $-1 -1 -1 $-1 $-1 $21924 $19124 T -7.5000000000000009 4.9999999999999991 -10 8.8817841970012523e-16 10 5 unknown #
+coedge $-1 -1 -1 $-1 $21918 $19125 $21887 $21925 forward $19128 $-1 #
+vertex $-1 -1 -1 $-1 $21925 $21926 #
+face $-1 -1 -1 $-1 $17691 $19128 $11 $-1 $6231 reversed single T 7.5 5 -25 15 10 -10 F #
+coedge $-1 -1 -1 $-1 $19667 $20594 $19131 $20581 forward $20607 $-1 #
+edge $-1 -1 -1 $-1 $16144 -2.9403902792268224e-16 $20585 1.5707963267948966 $20580 $21927 forward @7 unknown T 29.999999999999996 4.9999999999999982 -9.9999999999999982 35 10 -4.9999999999999982 #
+coedge $-1 -1 -1 $-1 $19570 $21928 $19132 $20583 forward $17679 $-1 #
+edge $-1 -1 -1 $-1 $20586 -7.5000000000000027 $19572 2.5000000000000071 $20582 $21929 forward @7 unknown T 37.5 5.6698729810778046 -7.5000000000000027 37.5 5.6698729810778064 2.5000000000000071 #
+coedge $-1 -1 -1 $-1 $20598 $19133 $21928 $21930 reversed $19162 $-1 #
+vertex $-1 -1 -1 $-1 $19668 $21931 #
+vertex $-1 -1 -1 $-1 $19134 $21932 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21928 $19135 $21933 $21934 forward $17679 $-1 #
+vertex $-1 -1 -1 $-1 $19158 $21935 #
+ellipse-curve $-1 -1 -1 $-1 40 10 -9.9999999999999982 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $21936 $20551 $11 $-1 $13497 reversed single T 20 14.330127018922191 -12.499999999999998 25 15 -7.4999999999999947 F #
+edge $-1 -1 -1 $-1 $20552 4.1887902047863905 $19145 4.7123889803846897 $19141 $21937 forward @7 unknown T 22.499999999999996 14.330127018922193 -9.9999999999999982 25 15 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $21086 $19142 $21938 $21939 forward $16172 $-1 #
+coedge $-1 -1 -1 $-1 $20580 $19167 $19142 $17659 reversed $20607 $-1 #
+point $-1 -1 -1 $-1 25 15 -9.9999999999999982 #
+edge $-1 -1 -1 $-1 $20616 1.0471975511965983 $19147 1.570796326794897 $19166 $20608 forward @7 unknown T 22.5 5 -12.499999999999996 25 5.6698729810778072 -9.9999999999999964 #
+point $-1 -1 -1 $-1 25 5 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $19150 $20584 $19149 $20599 reversed $19162 $-1 #
+edge $-1 -1 -1 $-1 $19152 1.0471975511965979 $21940 1.5707963267948966 $19149 $20606 forward @7 unknown T 37.5 5 -12.5 40 5.6698729810778072 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 37.500000000000007 5.6698729810778072 -12.5 #
+face $-1 -1 -1 $-1 $20579 $21900 $11 $-1 $8113 reversed single T -7.5000000000000009 4.9999999999999991 -25 8.8817841970012523e-16 10 -10 F #
+loop $-1 -1 -1 $-1 $21941 $21942 $19156 T -45 5.0000000000000018 -30.000000000000004 -40 15.000000000000002 -20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $21933 $21933 $19157 $20605 reversed $21835 $-1 #
+edge $-1 -1 -1 $-1 $21940 -1.5707963267948966 $20589 1.5707963267948966 $19157 $21943 forward @7 unknown T 40 5 -14.999999999999998 45 15 -9.9999999999999982 #
+ellipse-curve $-1 -1 -1 $-1 40 10 -9.9999999999999982 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+loop $-1 -1 -1 $-1 $-1 $20580 $19161 T 24.999999999999996 4.9999999999999982 -15 35 10 -4.9999999999999982 unknown #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 10 -9.9999999999999982 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21912 $21938 $19166 $20596 reversed $20612 $-1 #
+point $-1 -1 -1 $-1 22.499999999999996 14.330127018922191 -12.499999999999995 #
+face $-1 -1 -1 $-1 $20559 $21944 $11 $-1 $13497 reversed single T 10 4.9999999999999982 -15 20 10 -4.9999999999999982 F #
+loop $-1 -1 -1 $-1 $-1 $21912 $19171 T 20 4.9999999999999982 -12.5 25 5.6698729810778072 -7.4999999999999973 unknown #
+coedge $-1 -1 -1 $-1 $21945 $19172 $21946 $20561 forward $17688 $-1 #
+coedge $-1 -1 -1 $-1 $19172 $21947 $19645 $21074 forward $17688 $-1 #
+coedge $-1 -1 -1 $-1 $19651 $21903 $17607 $19099 forward $19094 $-1 #
+vertex $-1 -1 -1 $-1 $20596 $21948 #
+straight-curve $-1 -1 -1 $-1 22.5 5.6698729810778064 0 0 0 1 I I #
+face $-1 -1 -1 $-1 $13118 $19175 $11 $-1 $11706 reversed single T -30 -9.9999999999999982 20 -22.5 -4.9999999999999991 35 F #
+coedge $-1 -1 -1 $-1 $19177 $19226 $21949 $21950 reversed $19175 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -15 -5 -30 #
+edge $-1 -1 -1 $-1 $21951 1.5707963267948957 $19184 2.0943951023931957 $19183 $21952 forward @7 unknown T -37.500000000000007 -10 19.999999999999993 -35 -9.330127018922191 22.5 #
+point $-1 -1 -1 $-1 -37.500000000000007 -9.3301270189221945 22.5 #
+coedge $-1 -1 -1 $-1 $19187 $19291 $19189 $20626 reversed $19292 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 19.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19190 4.1887902047863914 $20632 4.7123889803846906 $19189 $21952 forward @7 unknown T -37.500000000000007 -0.66987298107780635 19.999999999999993 -35 0 22.499999999999993 #
+point $-1 -1 -1 $-1 -37.500000000000007 -0.66987298107780424 22.499999999999989 #
+coedge $-1 -1 -1 $-1 $21953 $19196 $19687 $21100 reversed $17710 $-1 #
+face $-1 -1 -1 $-1 $21954 $19292 $11 $-1 $8848 reversed single T -40 -0.66987298107780902 17.499999999999996 -35 2.6645352591003757e-15 22.499999999999993 F #
+coedge $-1 -1 -1 $-1 $21955 $21956 $21957 $21958 forward $19198 $-1 #
+coedge $-1 -1 -1 $-1 $20637 $19199 $21955 $21959 reversed $19223 $-1 #
+vertex $-1 -1 -1 $-1 $20732 $21960 #
+ellipse-curve $-1 -1 -1 $-1 -34.999999999999993 -5 19.999999999999996 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21949 $21961 $19201 $20635 reversed $20658 $-1 #
+edge $-1 -1 -1 $-1 $19202 3.1415926535897931 $21951 4.7123889803846906 $19201 $20633 forward @7 unknown T -35 -10 19.999999999999993 -29.999999999999993 -4.9999999999999991 24.999999999999996 #
+point $-1 -1 -1 $-1 -29.999999999999993 -4.9999999999999991 24.999999999999996 #
+coedge $-1 -1 -1 $-1 $19204 $20631 $21962 $21963 forward $19223 $-1 #
+vertex $-1 -1 -1 $-1 $21963 $21964 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 20 0.70710678118654757 0 0.70710678118654735 -5 3.0616169978683826e-16 5.0000000000000018 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19218 $19206 $21965 $21966 forward $19219 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 20 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19208 $21101 $21967 $21968 reversed $16231 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21108 $21969 $19210 $20645 forward $21970 $-1 #
+edge $-1 -1 -1 $-1 $20649 1.570796326794897 $21971 2.0943951023931957 $20644 $21972 forward @7 unknown T -25 -0.66987298107780746 -27.5 -22.5 1.7763568394002505e-15 -25 #
+coedge $-1 -1 -1 $-1 $21973 $19211 $21974 $21975 forward $20648 $-1 #
+coedge $-1 -1 -1 $-1 $19211 $21973 $19213 $20652 reversed $20648 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20646 $21976 T -35 -5 -30.000000000000004 -24.999999999999996 1.7763568394002505e-15 -19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $19212 $21977 #
+ellipse-curve $-1 -1 -1 $-1 -25 -4.9999999999999982 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21978 $19213 $21979 $21980 forward $19215 $-1 #
+edge $-1 -1 -1 $-1 $19216 0 $21981 1.5707963267948957 $19213 $21982 forward @7 unknown T -35 -5 -30.000000000000004 -30.000000000000007 0 -25.000000000000004 #
+coedge $-1 -1 -1 $-1 $19214 $21978 $19811 $21203 forward $19215 $-1 #
+face $-1 -1 -1 $-1 $21983 $19215 $11 $-1 $9738 reversed single T -37.500000000000007 -5 -40 -30 0 -25.000000000000004 F #
+point $-1 -1 -1 $-1 -30.000000000000007 -5 -30.000000000000004 #
+face $-1 -1 -1 $-1 $21984 $19219 $11 $-1 $8848 reversed single T -25 -0.66987298107780902 17.5 -20 1.7763568394002505e-15 22.5 F #
+face $-1 -1 -1 $-1 $20656 $20661 $11 $-1 $8848 reversed single T -25 -10 17.499999999999996 -20 -9.330127018922191 22.5 F #
+loop $-1 -1 -1 $-1 $-1 $21949 $19222 T -35 -10 14.999999999999996 -25 -4.9999999999999991 25 unknown #
+coedge $-1 -1 -1 $-1 $21985 $19224 $20698 $19276 reversed $20661 $-1 #
+coedge $-1 -1 -1 $-1 $19224 $21985 $19226 $20662 forward $20661 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20660 $20657 T -25 -10 17.499999999999996 -20 -9.330127018922191 22.5 unknown #
+edge $-1 -1 -1 $-1 $21986 1.5707963267948966 $19227 2.0943951023931953 $20660 $21987 forward @7 unknown T -25 -9.9999999999999982 20 -22.5 -9.330127018922191 22.5 #
+point $-1 -1 -1 $-1 -22.5 -9.3301270189221928 22.5 #
+coedge $-1 -1 -1 $-1 $19229 $20715 $21988 $21989 reversed $17739 $-1 #
+coedge $-1 -1 -1 $-1 $19707 $19230 $17742 $19237 forward $16247 $-1 #
+edge $-1 -1 -1 $-1 $19241 6.1232339957367648e-17 $20670 1.570796326794897 $19674 $21990 forward @7 unknown T -15 -10 -25 -9.9999999999999982 -4.9999999999999991 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $19231 $19707 $19861 $21234 reversed $16247 $-1 #
+coedge $-1 -1 -1 $-1 $21991 $20754 $19231 $20669 forward $20756 $-1 #
+edge $-1 -1 -1 $-1 $20671 -22.5 $21992 -12.500000000000002 $20668 $21993 forward @7 unknown T -7.5000000000000018 -9.3301270189221945 -22.5 -7.5 -9.3301270189221928 -12.500000000000002 #
+vertex $-1 -1 -1 $-1 $19703 $21994 #
+vertex $-1 -1 -1 $-1 $19233 $21995 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19319 $21996 #
+coedge $-1 -1 -1 $-1 $19236 $21997 $19238 $20678 forward $20676 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19236 $21998 T -22.5 -5 -25 -15 0 -10.000000000000002 unknown #
+straight-curve $-1 -1 -1 $-1 -15 -5 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $21110 1.5707963267948966 $19241 3.1415926535897931 $20675 $21999 forward @7 unknown T -20 -4.9999999999999991 -25 -15 0 -20 #
+point $-1 -1 -1 $-1 -10 8.8817841970012523e-16 -25 #
+edge $-1 -1 -1 $-1 $19241 3.1415926535897931 $22000 4.7123889803846897 $21113 $21999 forward @7 unknown T -20 -10 -25 -15 -4.9999999999999991 -20 #
+point $-1 -1 -1 $-1 -15 -4.9999999999999991 -20 #
+coedge $-1 -1 -1 $-1 $21122 $19243 $22001 $20701 forward $19245 $-1 #
+coedge $-1 -1 -1 $-1 $19244 $22002 $22003 $22004 forward $20684 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19244 $20703 T -22.500000000000004 -10 -10.000000000000004 -14.999999999999996 -4.9999999999999991 4.9999999999999991 unknown #
+face $-1 -1 -1 $-1 $22005 $19245 $11 $-1 $10393 reversed single T -22.500000000000004 -5 -10.000000000000004 -14.999999999999996 8.8817841970012523e-16 4.9999999999999991 F #
+point $-1 -1 -1 $-1 -15 -5 -8.8817841970012523e-16 #
+vertex $-1 -1 -1 $-1 $22006 $22007 #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 17.5 #
+edge $-1 -1 -1 $-1 $20691 -1.5707963267948966 $19730 -1.0471975511965979 $19728 $22008 forward @7 unknown T -7.5 -0.66987298107780813 2.5000000000000004 -5 0 5 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 4.9999999999999991 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $20689 $22009 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 5 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19260 $19259 $22010 $22011 forward $17733 $-1 #
+coedge $-1 -1 -1 $-1 $22012 $22001 $19260 $20695 reversed $22013 $-1 #
+edge $-1 -1 -1 $-1 $22014 4.1887902047863914 $19266 4.7123889803846897 $19260 $22015 forward @7 unknown T -22.5 -0.66987298107780546 4.9999999999999991 -20 8.8817841970012523e-16 7.4999999999999982 #
+coedge $-1 -1 -1 $-1 $22016 $19261 $22017 $22018 forward $19263 $-1 #
+coedge $-1 -1 -1 $-1 $20741 $22003 $19261 $17768 reversed $20704 $-1 #
+coedge $-1 -1 -1 $-1 $19262 $22016 $20659 $19276 forward $19263 $-1 #
+edge $-1 -1 -1 $-1 $17776 -1.5707963267948966 $17761 0 $19262 $19272 forward @7 unknown T -20 -10 15 -15 -5 20 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 4.9999999999999991 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19266 -1.5707963267948966 $22019 -1.0471975511965979 $20682 $22020 forward @7 unknown T -22.500000000000004 -0.66987298107780635 2.4999999999999996 -20 8.8817841970012523e-16 4.9999999999999991 #
+point $-1 -1 -1 $-1 -20 0 4.9999999999999991 #
+face $-1 -1 -1 $-1 $9546 $20684 $11 $-1 $10393 reversed single T -22.500000000000004 -10 -10.000000000000004 -14.999999999999996 -4.9999999999999991 4.9999999999999991 F #
+loop $-1 -1 -1 $-1 $-1 $20741 $19269 T -20 -10 -1.7763568394002505e-15 -10 -4.9999999999999991 10 unknown #
+edge $-1 -1 -1 $-1 $22021 1.0471975511965974 $19270 1.5707963267948966 $22002 $22020 forward @7 unknown T -22.500000000000004 -10 2.4999999999999978 -20 -9.3301270189221928 4.9999999999999991 #
+point $-1 -1 -1 $-1 -20 -10 4.9999999999999991 #
+vertex $-1 -1 -1 $-1 $22011 $22022 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 20 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19276 $22023 #
+coedge $-1 -1 -1 $-1 $19279 $19279 $19295 $20734 forward $17784 $-1 #
+coedge $-1 -1 -1 $-1 $22024 $22025 $19279 $20712 reversed $21150 $-1 #
+edge $-1 -1 -1 $-1 $20738 -1.5707963267948966 $22026 1.5707963267948966 $19279 $22027 forward @7 unknown T -45 -9.9999999999999964 -3.5527136788005009e-15 -40 2.6645352591003757e-15 4.9999999999999973 #
+coedge $-1 -1 -1 $-1 $19281 $19280 $22028 $22029 reversed $16282 $-1 #
+edge $-1 -1 -1 $-1 $21215 1.5707963267948966 $19301 2.0943951023931957 $19299 $20692 forward @7 unknown T -7.5000000000000009 -10 5 -5 -9.330127018922191 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $20664 $21118 $19281 $20716 reversed $17739 $-1 #
+edge $-1 -1 -1 $-1 $22030 -2.0943951023931948 $20717 -1.5707963267948966 $19281 $22031 forward @7 unknown T -10 -10 2.4999999999999982 -7.5000000000000018 -9.3301270189221945 4.9999999999999991 #
+vertex $-1 -1 -1 $-1 $22032 $22033 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 4.9999999999999991 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22034 $19283 $19285 $20724 forward $20721 $-1 #
+coedge $-1 -1 -1 $-1 $19283 $22035 $20735 $22036 forward $20721 $-1 #
+loop $-1 -1 -1 $-1 $-1 $21957 $21984 T -37.500000000000007 -10 4.9999999999999982 -30 -4.9999999999999991 19.999999999999996 unknown #
+vertex $-1 -1 -1 $-1 $19297 $22037 #
+straight-curve $-1 -1 -1 $-1 -37.5 -9.330127018922191 0 0 0 1 I I #
+edge $-1 -1 -1 $-1 $19286 1.0471975511965961 $21951 1.5707963267948957 $20719 $22038 forward @7 unknown T -37.5 -10 17.499999999999989 -35 -9.3301270189221874 19.999999999999996 #
+point $-1 -1 -1 $-1 -37.5 -9.3301270189221892 17.499999999999989 #
+coedge $-1 -1 -1 $-1 $22039 $22040 $19288 $20727 forward $22041 $-1 #
+edge $-1 -1 -1 $-1 $20730 -2.0943951023931966 $22026 -1.5707963267948966 $20726 $22042 forward @7 unknown T -40 -0.66987298107780813 4.9999999999999973 -37.499999999999993 2.6645352591003757e-15 7.5000000000000018 #
+coedge $-1 -1 -1 $-1 $21956 $19289 $22040 $22043 forward $19198 $-1 #
+coedge $-1 -1 -1 $-1 $19289 $21955 $19291 $20732 forward $19198 $-1 #
+vertex $-1 -1 -1 $-1 $22043 $22044 #
+straight-curve $-1 -1 -1 $-1 -37.5 -0.66987298107780457 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $20632 -1.5707963267948957 $19293 -1.0471975511965974 $20729 $22038 forward @7 unknown T -37.499999999999993 -0.66987298107780902 17.499999999999996 -35 0 19.999999999999996 #
+point $-1 -1 -1 $-1 -37.499999999999993 -0.66987298107780724 17.499999999999996 #
+edge $-1 -1 -1 $-1 $22026 -1.5707963267948966 $20738 1.5707963267948966 $20710 $22045 forward @7 unknown T -45 -9.9999999999999982 4.9999999999999973 -40 3.5527136788005009e-15 9.9999999999999964 #
+coedge $-1 -1 -1 $-1 $22046 $19296 $20720 $22036 reversed $20737 $-1 #
+coedge $-1 -1 -1 $-1 $19296 $22046 $22024 $22047 forward $20737 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19296 $22048 T -40 -10 2.4999999999999964 -35 -9.330127018922191 7.5 unknown #
+vertex $-1 -1 -1 $-1 $20712 $22049 #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 4.9999999999999973 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19299 $19298 $19736 $19838 forward $17799 $-1 #
+coedge $-1 -1 -1 $-1 $22050 $20697 $19300 $20742 forward $20704 $-1 #
+edge $-1 -1 -1 $-1 $16261 6.1232339957367648e-17 $20717 1.5707963267948966 $20741 $22051 forward @7 unknown T -15 -10 4.9999999999999991 -10 -4.9999999999999991 10 #
+point $-1 -1 -1 $-1 -7.5 -9.3301270189221928 7.5 #
+coedge $-1 -1 -1 $-1 $19305 $22052 $19338 $20761 reversed $18366 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19327 $22053 $21134 $19315 reversed $20756 $-1 #
+face $-1 -1 -1 $-1 $13003 $19312 $11 $-1 $7251 reversed single T -7.5000000000000009 -5 -25 8.8817841970012523e-16 8.8817841970012523e-16 -10 F #
+edge $-1 -1 -1 $-1 $20749 -6.1232339957367648e-17 $19832 1.5707963267948966 $19830 $22054 forward @7 unknown T -9.3734986416366059e-33 -5 -15 5 0 -10 #
+vertex $-1 -1 -1 $-1 $21129 $22055 #
+straight-curve $-1 -1 -1 $-1 0 -5 0 0 0 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -25 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -24.999999999999996 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $16663 $19326 $11 $-1 $11805 reversed single T -10.000000000000002 -10 -27.500000000000004 -5 -9.330127018922191 -22.5 F #
+coedge $-1 -1 -1 $-1 $20668 $19327 $19325 $20755 forward $20756 $-1 #
+edge $-1 -1 -1 $-1 $17839 1.5707963267948966 $20671 2.0943951023931957 $20754 $20751 forward @7 unknown T -7.5000000000000009 -10 -25 -5 -9.330127018922191 -22.5 #
+loop $-1 -1 -1 $-1 $-1 $20746 $19341 T -7.5000000000000018 -10 -25 8.8817841970012523e-16 -4.9999999999999991 -10 unknown #
+coedge $-1 -1 -1 $-1 $19737 $19330 $19734 $21137 reversed $19332 $-1 #
+straight-curve $-1 -1 -1 $-1 7.5 -9.3301270189221945 0 0 0 1 I I #
+straight-curve $-1 -1 -1 $-1 7.5 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $22056 $22057 $22058 $19829 reversed $19337 $-1 #
+edge $-1 -1 -1 $-1 $19339 -22.5 $19856 -12.500000000000004 $19338 $22059 forward @7 unknown T 7.5 -9.3301270189221945 -22.5 7.5000000000000018 -9.3301270189221945 -12.500000000000004 #
+point $-1 -1 -1 $-1 7.5000000000000018 -9.3301270189221945 -22.5 #
+loop $-1 -1 -1 $-1 $-1 $19762 $17857 T -50 -10 -30.000000000000004 -50 0 -20.000000000000004 unknown #
+coedge $-1 -1 -1 $-1 $22060 $22060 $22061 $22062 forward $19342 $-1 #
+coedge $-1 -1 -1 $-1 $19343 $21167 $19364 $20787 forward $19777 $-1 #
+coedge $-1 -1 -1 $-1 $22063 $19353 $19345 $20767 reversed $17873 $-1 #
+edge $-1 -1 -1 $-1 $19394 -1.5707963267948966 $20768 -1.0471975511965965 $19345 $19379 forward @7 unknown T -22.500000000000007 44.330127018922184 -42.500000000000007 -20 45 -40 #
+vertex $-1 -1 -1 $-1 $20776 $22064 #
+straight-curve $-1 -1 -1 $-1 -22.5 44.330127018922191 0 -0 -0 -1 I I #
+face $-1 -1 -1 $-1 $22065 $22066 $11 $-1 $15707 reversed single T -20 35 -30 -9.9999999999999964 40 -19.999999999999996 F #
+coedge $-1 -1 -1 $-1 $19348 $19349 $22067 $22068 forward $19350 $-1 #
+face $-1 -1 -1 $-1 $20813 $19350 $11 $-1 $11911 reversed single T -9.9999999999999982 44.330127018922191 -42.5 -5 45 -37.5 F #
+loop $-1 -1 -1 $-1 $-1 $22069 $17872 T -50 35 -45 -50 45 -35 unknown #
+coedge $-1 -1 -1 $-1 $22070 $22070 $22071 $22072 forward $19352 $-1 #
+coedge $-1 -1 -1 $-1 $19353 $22063 $22073 $22074 forward $17873 $-1 #
+edge $-1 -1 -1 $-1 $22075 1.5707963267948966 $20768 2.0943951023931953 $19353 $22076 forward @7 unknown T -24.999999999999996 44.330127018922184 -42.5 -22.499999999999996 45 -40 #
+coedge $-1 -1 -1 $-1 $19354 $22077 $19395 $20816 reversed $19872 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20871 $19356 $22078 $20782 reversed $17959 $-1 #
+coedge $-1 -1 -1 $-1 $19361 $22078 $19358 $20781 forward $20106 $-1 #
+edge $-1 -1 -1 $-1 $19359 -1.570796326794897 $17880 1.570796326794897 $20780 $22079 forward @7 unknown T 40 35 2.6645352591003757e-15 45.000000000000007 45 5.0000000000000044 #
+edge $-1 -1 -1 $-1 $22080 1.0471975511965983 $19359 1.570796326794897 $22078 $20785 forward @7 unknown T 37.499999999999993 35 2.5000000000000053 40 35.669872981077802 5.0000000000000044 #
+point $-1 -1 -1 $-1 40 35 5.0000000000000027 #
+vertex $-1 -1 -1 $-1 $20071 $22081 #
+ellipse-curve $-1 -1 -1 $-1 39.999999999999993 40 5.0000000000000027 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $22071 $19364 $22082 $22083 reversed $19366 $-1 #
+edge $-1 -1 -1 $-1 $22084 42.5 $19367 50 $20765 $22085 forward @7 unknown T -37.5 44.330127018922191 -50 -37.5 44.330127018922191 -42.5 #
+coedge $-1 -1 -1 $-1 $19365 $22071 $21159 $22086 reversed $19366 $-1 #
+point $-1 -1 -1 $-1 -37.5 44.330127018922191 -50 #
+vertex $-1 -1 -1 $-1 $19769 $22087 #
+straight-curve $-1 -1 -1 $-1 -37.5 35.669872981077809 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $19371 $19770 $22088 $22089 forward $19771 $-1 #
+vertex $-1 -1 -1 $-1 $19372 $22090 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22091 $21168 $19373 $20796 forward $22092 $-1 #
+edge $-1 -1 -1 $-1 $18290 -6.1232339957367648e-17 $22075 1.5707963267948966 $20795 $22093 forward @7 unknown T -30 40 -45 -24.999999999999996 45 -40 #
+coedge $-1 -1 -1 $-1 $19376 $19374 $21276 $22094 forward $19377 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -24.999999999999996 40 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22095 $20802 $19376 $20800 forward $22096 $-1 #
+edge $-1 -1 -1 $-1 $19378 1.5707963267948966 $22097 2.0943951023931948 $20799 $22098 forward @7 unknown T -22.5 35 -40 -20 35.669872981077809 -37.5 #
+point $-1 -1 -1 $-1 -20 35 -40 #
+coedge $-1 -1 -1 $-1 $20799 $22099 $19381 $20803 forward $22096 $-1 #
+edge $-1 -1 -1 $-1 $20807 3.1415926535897931 $19378 4.7123889803846897 $20802 $22100 forward @7 unknown T -20 35 -40 -15 40 -35 #
+face $-1 -1 -1 $-1 $22101 $19771 $11 $-1 $11911 reversed single T -35 35 -45 -24.999999999999996 40 -35 F #
+coedge $-1 -1 -1 $-1 $22102 $22103 $22099 $21242 forward $19384 $-1 #
+coedge $-1 -1 -1 $-1 $22104 $19385 $19873 $21242 forward $19872 $-1 #
+vertex $-1 -1 -1 $-1 $20803 $22105 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $8866 $22096 $11 $-1 $14102 reversed single T -22.5 35 -40 -15 40 -25 F #
+coedge $-1 -1 -1 $-1 $19390 $19389 $22103 $22106 reversed $19391 $-1 #
+coedge $-1 -1 -1 $-1 $22067 $19873 $19389 $20812 reversed $18426 $-1 #
+edge $-1 -1 -1 $-1 $19392 -1.5707963267948966 $20807 6.1232339957367648e-17 $19389 $22107 forward @7 unknown T -15 40 -40 -9.9999999999999982 45 -35 #
+face $-1 -1 -1 $-1 $19387 $19391 $11 $-1 $11911 reversed single T -20 40 -45 -9.9999999999999982 45 -35 F #
+point $-1 -1 -1 $-1 -9.9999999999999982 45 -40 #
+point $-1 -1 -1 $-1 -20 45 -40 #
+edge $-1 -1 -1 $-1 $19396 -37.500000000000007 $22108 -27.500000000000004 $19395 $22109 forward @7 unknown T -7.5000000000000027 35.669872981077809 -37.500000000000007 -7.4999999999999991 35.669872981077816 -27.500000000000004 #
+point $-1 -1 -1 $-1 -7.5 35.669872981077809 -37.500000000000007 #
+face $-1 -1 -1 $-1 $19347 $22110 $11 $-1 $14102 reversed single T -22.5 35 -25 -15 40 -10.000000000000002 F #
+coedge $-1 -1 -1 $-1 $22111 $22112 $22113 $22114 forward $19400 $-1 #
+coedge $-1 -1 -1 $-1 $22115 $19401 $22116 $22117 reversed $17918 $-1 #
+coedge $-1 -1 -1 $-1 $19401 $22115 $22118 $22119 forward $17918 $-1 #
+coedge $-1 -1 -1 $-1 $19403 $19402 $22120 $22121 reversed $16409 $-1 #
+coedge $-1 -1 -1 $-1 $22118 $22122 $19402 $20824 reversed $18492 $-1 #
+edge $-1 -1 -1 $-1 $20829 1.5707963267948966 $22123 2.0943951023931953 $19402 $22124 forward @7 unknown T -9.9999999999999982 44.330127018922191 -12.5 -7.4999999999999991 45 -10 #
+coedge $-1 -1 -1 $-1 $22125 $22126 $19403 $20826 forward $22127 $-1 #
+edge $-1 -1 -1 $-1 $20828 4.1887902047863896 $22128 4.7123889803846897 $20825 $22129 forward @7 unknown T -7.5000000000000062 44.330127018922184 -10 -5 45 -7.4999999999999947 #
+coedge $-1 -1 -1 $-1 $22130 $19404 $22126 $22131 reversed $17041 $-1 #
+vertex $-1 -1 -1 $-1 $20826 $22132 #
+vertex $-1 -1 -1 $-1 $22119 $22133 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 40 -10 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20020 $22134 $19406 $20832 forward $21399 $-1 #
+edge $-1 -1 -1 $-1 $21377 -1.5707963267948966 $17081 -6.1232339957367648e-17 $20831 $22135 forward @7 unknown T 0 35 -30 5.0000000000000027 40 -25 #
+point $-1 -1 -1 $-1 7.5 35.669872981077809 -27.499999999999996 #
+face $-1 -1 -1 $-1 $22136 $22137 $11 $-1 $14913 reversed single T 5.0000000000000027 35 2.500000000000004 10.000000000000002 35.669872981077809 7.5 F #
+loop $-1 -1 -1 $-1 $-1 $22138 $19410 T -5 35 0 5.0000000000000027 40 10 unknown #
+coedge $-1 -1 -1 $-1 $22139 $22140 $19999 $21373 forward $19411 $-1 #
+coedge $-1 -1 -1 $-1 $20026 $19412 $22141 $21423 forward $17933 $-1 #
+coedge $-1 -1 -1 $-1 $22142 $22143 $19413 $20839 reversed $22144 $-1 #
+edge $-1 -1 -1 $-1 $22145 4.1887902047863914 $20841 4.7123889803846897 $19413 $22146 forward @7 unknown T 7.5000000000000018 44.330127018922191 5.0000000000000009 10 45 7.4999999999999991 #
+coedge $-1 -1 -1 $-1 $19425 $19414 $22147 $22148 reversed $16437 $-1 #
+vertex $-1 -1 -1 $-1 $22149 $22150 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 40 5.0000000000000009 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $21405 $19416 $22151 $22152 forward $18609 $-1 #
+coedge $-1 -1 -1 $-1 $19424 $22153 $19416 $20845 reversed $17942 $-1 #
+edge $-1 -1 -1 $-1 $19418 3.1415926535897931 $22154 4.7123889803846897 $19416 $20842 forward @7 unknown T 10 35 5.0000000000000009 14.999999999999996 40 10 #
+coedge $-1 -1 -1 $-1 $19417 $21442 $19424 $20852 reversed $20090 $-1 #
+point $-1 -1 -1 $-1 14.999999999999996 40 10 #
+coedge $-1 -1 -1 $-1 $22155 $20043 $19420 $20849 reversed $20032 $-1 #
+edge $-1 -1 -1 $-1 $18592 6.1232339957367648e-17 $18585 1.570796326794897 $19420 $22156 forward @7 unknown T 15 35 -25 20.000000000000007 40 -19.999999999999996 #
+coedge $-1 -1 -1 $-1 $19436 $22157 $21442 $22158 forward $19423 $-1 #
+coedge $-1 -1 -1 $-1 $22153 $19424 $22159 $22160 forward $17942 $-1 #
+edge $-1 -1 -1 $-1 $19418 6.1232339957367648e-17 $22161 1.5707963267948966 $19424 $22162 forward @7 unknown T 14.999999999999996 35 5.0000000000000009 20.000000000000004 40 10 #
+coedge $-1 -1 -1 $-1 $20034 $22163 $19425 $20854 reversed $17099 $-1 #
+edge $-1 -1 -1 $-1 $22164 -6.1232339957367648e-17 $20038 1.5707963267948966 $19425 $22165 forward @7 unknown T 15.000000000000004 40 -9.3734986416366073e-33 20.000000000000004 45 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $19428 $19427 $22163 $22166 forward $19429 $-1 #
+coedge $-1 -1 -1 $-1 $22167 $19432 $19428 $19434 forward $20079 $-1 #
+point $-1 -1 -1 $-1 22.500000000000007 44.330127018922205 7.5000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 5.0000000000000018 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $22168 $22169 #
+ellipse-curve $-1 -1 -1 $-1 24.999999999999996 40 5.0000000000000018 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22157 $19436 $22170 $20865 reversed $19423 $-1 #
+vertex $-1 -1 -1 $-1 $22158 $22171 #
+coedge $-1 -1 -1 $-1 $20078 $22170 $19438 $20864 forward $18654 $-1 #
+edge $-1 -1 -1 $-1 $19439 -1.5707963267948961 $20080 0 $20863 $20858 forward @7 unknown T 25 35 1.7763568394002505e-15 29.999999999999996 40 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $22172 1.0471975511965987 $19439 1.570796326794897 $22170 $20860 forward @7 unknown T 22.5 35 2.5000000000000049 25 35.669872981077802 5.0000000000000036 #
+point $-1 -1 -1 $-1 25 35 5.0000000000000018 #
+edge $-1 -1 -1 $-1 $20868 1.5707963267948966 $19894 2.0943951023931966 $19444 $22173 forward @7 unknown T 35 35 5.0000000000000018 37.500000000000007 35.669872981077809 7.5000000000000062 #
+vertex $-1 -1 -1 $-1 $20873 $22174 #
+ellipse-curve $-1 -1 -1 $-1 35 40 5.0000000000000018 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20094 $19442 $22175 $22176 reversed $17139 $-1 #
+coedge $-1 -1 -1 $-1 $19444 $20779 $22177 $22178 forward $17959 $-1 #
+coedge $-1 -1 -1 $-1 $22177 $21456 $19445 $20873 reversed $18615 $-1 #
+edge $-1 -1 -1 $-1 $20868 -1.5707963267948966 $20080 -6.1232339957367648e-17 $19445 $22179 forward @7 unknown T 29.999999999999996 35 1.7763568394002505e-15 35 40 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $19456 $19447 $22180 $22181 reversed $16465 $-1 #
+point $-1 -1 -1 $-1 -22.500000000000004 29.330127018922191 -42.5 #
+face $-1 -1 -1 $-1 $21655 $21558 $11 $-1 $14408 reversed single T -20 25 -30 -9.9999999999999964 30 -19.999999999999996 F #
+loop $-1 -1 -1 $-1 $-1 $22182 $19451 T -20 20 -30 -9.9999999999999964 25 -19.999999999999996 unknown #
+coedge $-1 -1 -1 $-1 $20269 $19492 $19452 $20879 reversed $17194 $-1 #
+edge $-1 -1 -1 $-1 $20277 -2.0943951023931957 $18010 -1.5707963267948966 $19452 $22183 forward @7 unknown T -9.9999999999999982 29.330127018922191 -40 -7.4999999999999964 30 -37.5 #
+coedge $-1 -1 -1 $-1 $20880 $20880 $22184 $22185 reversed $19454 $-1 #
+coedge $-1 -1 -1 $-1 $19455 $19455 $21515 $22186 forward $17970 $-1 #
+coedge $-1 -1 -1 $-1 $19469 $19467 $19455 $20883 reversed $17984 $-1 #
+edge $-1 -1 -1 $-1 $22187 -1.5707963267948966 $22188 1.5707963267948966 $19455 $22189 forward @7 unknown T -45 20.000000000000004 -45 -40 30.000000000000004 -40 #
+coedge $-1 -1 -1 $-1 $22190 $20159 $19456 $20885 reversed $17243 $-1 #
+edge $-1 -1 -1 $-1 $22191 -2.0943951023931948 $20886 -1.5707963267948966 $19456 $22192 forward @7 unknown T -25 29.330127018922195 -40 -22.500000000000004 30 -37.5 #
+vertex $-1 -1 -1 $-1 $19477 $22193 #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19458 $20915 $21658 $22194 reversed $18677 $-1 #
+coedge $-1 -1 -1 $-1 $19461 $21700 $19460 $19463 forward $18911 $-1 #
+ellipse-curve $-1 -1 -1 $-1 40.000000000000007 25 5.0000000000000027 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $19463 $22195 #
+point $-1 -1 -1 $-1 37.5 29.330127018922191 2.5000000000000049 #
+coedge $-1 -1 -1 $-1 $21180 $22196 $19467 $20894 forward $22197 $-1 #
+edge $-1 -1 -1 $-1 $22188 1.5707963267948966 $20895 2.0943951023931948 $20893 $22198 forward @7 unknown T -40 29.330127018922198 -42.5 -37.5 30.000000000000004 -40 #
+vertex $-1 -1 -1 $-1 $20894 $22199 #
+straight-curve $-1 -1 -1 $-1 -37.5 29.330127018922195 0 -0 -0 -1 I I #
+edge $-1 -1 -1 $-1 $19471 -2.0943951023931957 $22187 -1.5707963267948966 $19778 $22200 forward @7 unknown T -40 20.000000000000004 -42.500000000000007 -37.5 20.669872981077813 -40 #
+point $-1 -1 -1 $-1 -37.500000000000007 20.669872981077813 -42.500000000000007 #
+coedge $-1 -1 -1 $-1 $22201 $20158 $19473 $20900 reversed $18722 $-1 #
+edge $-1 -1 -1 $-1 $21176 6.1232339957367648e-17 $19474 1.5707963267948966 $19473 $22202 forward @7 unknown T -30 20 -40 -25 25 -35 #
+point $-1 -1 -1 $-1 -25 20 -40 #
+coedge $-1 -1 -1 $-1 $21181 $19476 $20159 $21528 forward $20903 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20902 $20912 T -35 25 -45 -25 30 -35 unknown #
+ellipse-curve $-1 -1 -1 $-1 -25 25 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19474 1.5707963267948966 $20908 2.0943951023931939 $19478 $22203 forward @7 unknown T -25 20 -40 -22.500000000000004 20.669872981077805 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $22204 $19480 $21527 $22205 forward $20907 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20910 $19490 T -22.500000000000007 20 -40 -15 25 -25 unknown #
+vertex $-1 -1 -1 $-1 $20905 $22206 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 -40 -0.70710678118654746 0 -0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19483 $22207 $19487 $20124 reversed $20907 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20 25 -40 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $19788 $20903 $11 $-1 $10647 reversed single T -35 25 -45 -25 30 -35 F #
+coedge $-1 -1 -1 $-1 $22208 $19486 $22209 $22210 forward $18002 $-1 #
+coedge $-1 -1 -1 $-1 $19486 $22180 $19491 $20917 forward $18002 $-1 #
+coedge $-1 -1 -1 $-1 $20888 $19487 $22211 $22212 reversed $18677 $-1 #
+point $-1 -1 -1 $-1 -15 25 -35 #
+edge $-1 -1 -1 $-1 $18012 1.5707963267948966 $19488 3.1415926535897931 $20914 $20911 forward @7 unknown T -20 25 -40 -15 30 -35 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $20279 $22213 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 20.669872981077805 0 0 0 1 I I #
+loop $-1 -1 -1 $-1 $-1 $22214 $19499 T -22.500000000000004 20 -25 -15 25 -10.000000000000002 unknown #
+coedge $-1 -1 -1 $-1 $22215 $19500 $22216 $22217 forward $18018 $-1 #
+coedge $-1 -1 -1 $-1 $19500 $22215 $22218 $21567 reversed $18018 $-1 #
+coedge $-1 -1 -1 $-1 $22219 $21548 $19500 $20925 reversed $20174 $-1 #
+edge $-1 -1 -1 $-1 $20183 6.1232339957367648e-17 $22220 1.5707963267948966 $19500 $22221 forward @7 unknown T -14.999999999999998 20 -10 -9.9999999999999982 25 -5 #
+coedge $-1 -1 -1 $-1 $19502 $19501 $22222 $22223 reversed $16510 $-1 #
+coedge $-1 -1 -1 $-1 $20181 $22224 $19501 $20928 forward $21564 $-1 #
+edge $-1 -1 -1 $-1 $22225 1.5707963267948961 $20183 3.1415926535897931 $20927 $22226 forward @7 unknown T -20 25 -10.000000000000004 -14.999999999999996 30 -5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $20177 $19504 $19502 $20930 reversed $17260 $-1 #
+edge $-1 -1 -1 $-1 $22227 -6.1232339957367648e-17 $19510 1.5707963267948966 $19502 $22228 forward @7 unknown T -15.000000000000004 25 -15.000000000000002 -9.9999999999999982 30 -10 #
+coedge $-1 -1 -1 $-1 $22229 $22230 $19503 $20932 forward $21646 $-1 #
+edge $-1 -1 -1 $-1 $20939 -1.5707963267948966 $20934 -1.0471975511965974 $20931 $22231 forward @7 unknown T -7.5000000000000009 29.330127018922191 -12.5 -5 30 -10 #
+coedge $-1 -1 -1 $-1 $19504 $20176 $22229 $22232 reversed $17260 $-1 #
+vertex $-1 -1 -1 $-1 $22232 $22233 #
+ellipse-curve $-1 -1 -1 $-1 -9.9999999999999982 25 -10 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22234 $19506 $22235 $22236 forward $20938 $-1 #
+coedge $-1 -1 -1 $-1 $19506 $22237 $19508 $20942 forward $20938 $-1 #
+loop $-1 -1 -1 $-1 $-1 $22234 $22238 T -7.5000000000000062 25 -10 8.8817841970012523e-16 30 5 unknown #
+vertex $-1 -1 -1 $-1 $20932 $22239 #
+ellipse-curve $-1 -1 -1 $-1 -5 25 -10 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20180 $19508 $20188 $21574 reversed $15791 $-1 #
+edge $-1 -1 -1 $-1 $22240 -2.5000000000000004 $19509 7.4999999999999956 $20937 $22241 forward @7 unknown T -7.5000000000000018 29.330127018922184 -7.4999999999999956 -7.4999999999999991 29.330127018922195 2.5000000000000004 #
+point $-1 -1 -1 $-1 -7.5000000000000018 29.330127018922184 -7.4999999999999956 #
+point $-1 -1 -1 $-1 -9.9999999999999982 30 -10 #
+coedge $-1 -1 -1 $-1 $19512 $20280 $22242 $22243 forward $20281 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5.0000000000000018 25 -24.999999999999996 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+face $-1 -1 -1 $-1 $18816 $20955 $11 $-1 $13449 reversed single T 5.0000000000000018 29.330127018922184 2.5000000000000036 10 30 7.5000000000000062 F #
+loop $-1 -1 -1 $-1 $-1 $22244 $19515 T 5.0000000000000018 20 2.5000000000000018 10.000000000000002 20.669872981077809 7.5000000000000009 unknown #
+coedge $-1 -1 -1 $-1 $22245 $22246 $22247 $22248 forward $19516 $-1 #
+coedge $-1 -1 -1 $-1 $22249 $19517 $22250 $22251 reversed $18029 $-1 #
+coedge $-1 -1 -1 $-1 $19517 $22249 $22252 $22253 forward $18029 $-1 #
+coedge $-1 -1 -1 $-1 $20303 $22254 $19518 $20305 reversed $21681 $-1 #
+coedge $-1 -1 -1 $-1 $22255 $19519 $20254 $21635 forward $20955 $-1 #
+coedge $-1 -1 -1 $-1 $19519 $22255 $22256 $20960 reversed $20955 $-1 #
+loop $-1 -1 -1 $-1 $-1 $20953 $20947 T 5.0000000000000018 29.330127018922184 2.5000000000000036 10 30 7.5000000000000062 unknown #
+vertex $-1 -1 -1 $-1 $19520 $22257 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 25 5.0000000000000009 -0.70710678118654757 0 -0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22256 $20293 $19521 $20959 forward $21673 $-1 #
+edge $-1 -1 -1 $-1 $20975 0 $19522 1.5707963267948966 $20958 $22258 forward @7 unknown T 10 25 8.8817841970012523e-16 15.000000000000004 30 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $19522 -1.5707963267948966 $22259 -1.0471975511965987 $22256 $22260 forward @7 unknown T 7.5000000000000018 29.330127018922195 2.500000000000004 10 30 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 30 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $22261 $22244 $19524 $20963 reversed $20948 $-1 #
+edge $-1 -1 -1 $-1 $20965 1.5707963267948966 $22262 2.0943951023931948 $19524 $20957 forward @7 unknown T 7.5000000000000027 20 5.0000000000000009 10.000000000000002 20.669872981077805 7.5 #
+coedge $-1 -1 -1 $-1 $19525 $19532 $21732 $22263 reversed $16534 $-1 #
+vertex $-1 -1 -1 $-1 $22264 $22265 #
+coedge $-1 -1 -1 $-1 $22266 $19529 $17359 $18858 forward $18837 $-1 #
+ellipse-curve $-1 -1 -1 $-1 20 25 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19531 $19542 $22267 $22268 forward $18041 $-1 #
+edge $-1 -1 -1 $-1 $20972 1.5707963267948966 $19543 2.0943951023931953 $19531 $22269 forward @7 unknown T 20 20 5.0000000000000009 22.5 20.669872981077809 7.5000000000000027 #
+coedge $-1 -1 -1 $-1 $22267 $21733 $19532 $20971 reversed $20289 $-1 #
+edge $-1 -1 -1 $-1 $20972 -1.5707963267948966 $20975 -6.1232339957367648e-17 $19532 $22270 forward @7 unknown T 15 20 -9.3734986416366073e-33 20 25 5.0000000000000009 #
+vertex $-1 -1 -1 $-1 $20971 $22271 #
+ellipse-curve $-1 -1 -1 $-1 20 25 5.0000000000000009 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19534 $20290 $19536 $20977 reversed $15849 $-1 #
+vertex $-1 -1 -1 $-1 $20959 $22272 #
+ellipse-curve $-1 -1 -1 $-1 20 25 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $18843 1.5707963267948966 $19540 2.0943951023931948 $19536 $22273 forward @7 unknown T 20 29.330127018922195 2.5000000000000036 22.5 30 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $20336 $19537 $20290 $20979 forward $18884 $-1 #
+edge $-1 -1 -1 $-1 $19540 -2.5000000000000036 $21670 7.4999999999999964 $20978 $22274 forward @7 unknown T 22.5 29.330127018922195 -7.4999999999999964 22.500000000000004 29.330127018922198 2.5000000000000036 #
+point $-1 -1 -1 $-1 22.5 29.330127018922195 2.5000000000000036 #
+coedge $-1 -1 -1 $-1 $19544 $22275 $19542 $19546 forward $17422 $-1 #
+point $-1 -1 -1 $-1 22.499999999999996 20.669872981077809 7.5000000000000027 #
+vertex $-1 -1 -1 $-1 $19546 $22276 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 35 19.999999999999996 5.0000000000000018 #
+coedge $-1 -1 -1 $-1 $20362 $21698 $19551 $20987 forward $21725 $-1 #
+edge $-1 -1 -1 $-1 $21703 -1.5707963267948966 $17428 6.4931039580273265e-16 $20986 $22277 forward @7 unknown T 30 19.999999999999996 -15 35 25 -9.9999999999999982 #
+coedge $-1 -1 -1 $-1 $20327 $19553 $19552 $20989 reversed $17383 $-1 #
+edge $-1 -1 -1 $-1 $20891 -2.0943951023931939 $19549 -1.5707963267948966 $19552 $22278 forward @7 unknown T 35 19.999999999999996 2.500000000000008 37.499999999999993 20.669872981077802 5.0000000000000018 #
+ellipse-curve $-1 -1 -1 $-1 35 24.999999999999996 5.0000000000000018 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19595 $22279 $19555 $20992 forward $16594 $-1 #
+edge $-1 -1 -1 $-1 $21002 4.1887902047863914 $16604 4.7123889803846897 $20991 $19590 forward @7 unknown T -22.499999999999996 14.330127018922193 -40 -20 15 -37.5 #
+coedge $-1 -1 -1 $-1 $21022 $22280 $20431 $21791 forward $19558 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -40 -0.70710678118654746 0 0.70710678118654757 -5 3.0616169978683826e-16 -4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $20995 $20995 $19561 $20996 forward $22281 $-1 #
+edge $-1 -1 -1 $-1 $22282 0 $22282 6.2831853071795862 $20995 $22283 forward @7 unknown T -50 5 -45 -50 15 -35 #
+edge $-1 -1 -1 $-1 $20999 -1.5707963267948966 $20998 1.5707963267948966 $19562 $22284 forward @7 unknown T -45 5.0000000000000018 -40 -40 15.000000000000002 -35 #
+vertex $-1 -1 -1 $-1 $19564 $22285 #
+vertex $-1 -1 -1 $-1 $19564 $22286 #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 -40 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20411 $19565 $22279 $22287 reversed $15993 $-1 #
+vertex $-1 -1 -1 $-1 $20992 $22288 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 -0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -25 15.000000000000002 -40 #
+edge $-1 -1 -1 $-1 $19600 -2.0943951023931957 $21795 -1.570796326794897 $20540 $22289 forward @7 unknown T -10 5 -27.500000000000004 -7.4999999999999991 5.669872981077809 -25 #
+point $-1 -1 -1 $-1 37.5 5.6698729810778046 2.5000000000000071 #
+coedge $-1 -1 -1 $-1 $19574 $21192 $21751 $22290 forward $21008 $-1 #
+loop $-1 -1 -1 $-1 $-1 $19574 $21188 T -40 14.330127018922191 -42.5 -35 15.000000000000002 -37.5 unknown #
+ellipse-curve $-1 -1 -1 $-1 -40 10.000000000000002 -40 -0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -37.5 14.330127018922193 -42.5 #
+coedge $-1 -1 -1 $-1 $22291 $19580 $17491 $18967 forward $17490 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -25 10.000000000000002 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $21018 $19587 $22292 $22293 forward $19588 $-1 #
+edge $-1 -1 -1 $-1 $19589 -37.499999999999993 $22294 -27.500000000000004 $19587 $22295 forward @7 unknown T -22.5 5.6698729810778064 -37.499999999999993 -22.5 5.6698729810778081 -27.500000000000004 #
+point $-1 -1 -1 $-1 -22.5 5.6698729810778081 -37.499999999999993 #
+coedge $-1 -1 -1 $-1 $19591 $21015 $22296 $22297 forward $19588 $-1 #
+coedge $-1 -1 -1 $-1 $22279 $19594 $22298 $22299 forward $16594 $-1 #
+coedge $-1 -1 -1 $-1 $20374 $20439 $19594 $21021 reversed $20440 $-1 #
+edge $-1 -1 -1 $-1 $20376 0 $22300 1.5707963267948966 $19594 $22301 forward @7 unknown T -20 10 -30 -15 15 -25 #
+coedge $-1 -1 -1 $-1 $22296 $20993 $19596 $21023 forward $19558 $-1 #
+edge $-1 -1 -1 $-1 $21795 -1.5707963267948961 $20376 -6.1232339957367648e-17 $21022 $22302 forward @7 unknown T -15 5 -30 -10 10 -25 #
+point $-1 -1 -1 $-1 -7.5 5.6698729810778072 -27.500000000000004 #
+coedge $-1 -1 -1 $-1 $22303 $22304 $21790 $20438 reversed $19602 $-1 #
+coedge $-1 -1 -1 $-1 $19604 $19603 $22304 $22305 reversed $16610 $-1 #
+coedge $-1 -1 -1 $-1 $21792 $21790 $19603 $21028 reversed $17506 $-1 #
+edge $-1 -1 -1 $-1 $21031 -1.5707963267948966 $21038 -6.1232339957367648e-17 $19603 $22306 forward @7 unknown T -15.000000000000004 5 -15.000000000000002 -10 10 -10 #
+coedge $-1 -1 -1 $-1 $22307 $20445 $19604 $20449 forward $21809 $-1 #
+coedge $-1 -1 -1 $-1 $22308 $19605 $17508 $18987 forward $18979 $-1 #
+vertex $-1 -1 -1 $-1 $21028 $22309 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -10 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22310 $20437 $19607 $21034 forward $21801 $-1 #
+edge $-1 -1 -1 $-1 $21038 0 $21036 1.5707963267948961 $21033 $22311 forward @7 unknown T -20 10 -15.000000000000002 -15.000000000000004 15 -10.000000000000002 #
+coedge $-1 -1 -1 $-1 $19608 $22312 $22313 $22314 forward $20446 $-1 #
+vertex $-1 -1 -1 $-1 $22315 $22316 #
+ellipse-curve $-1 -1 -1 $-1 -19.999999999999996 10 -10.000000000000002 0.70710678118654757 0 -0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+vertex $-1 -1 -1 $-1 $21034 $22317 #
+ellipse-curve $-1 -1 -1 $-1 -10 10 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $20527 $19612 $19614 $21043 forward $20528 $-1 #
+coedge $-1 -1 -1 $-1 $19612 $20526 $22318 $22319 forward $20528 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 10 -10 -0.70710678118654746 -0 0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+edge $-1 -1 -1 $-1 $19615 12.5 $21798 22.500000000000004 $21040 $22320 forward @7 unknown T -7.5 14.330127018922193 -22.500000000000004 -7.4999999999999982 14.330127018922195 -12.5 #
+point $-1 -1 -1 $-1 -7.5 14.330127018922193 -12.5 #
+coedge $-1 -1 -1 $-1 $22321 $19617 $21924 $21877 forward $19619 $-1 #
+coedge $-1 -1 -1 $-1 $22318 $20515 $19617 $21047 reversed $21879 $-1 #
+edge $-1 -1 -1 $-1 $19620 1.5707963267948966 $21881 3.1415926535897931 $19617 $22322 forward @7 unknown T -5 10 -10 0 15 -5 #
+coedge $-1 -1 -1 $-1 $19618 $22321 $20455 $21814 forward $19619 $-1 #
+face $-1 -1 -1 $-1 $17672 $19619 $11 $-1 $8113 reversed single T -7.5000000000000009 10 -10 8.8817841970012523e-16 15 5 F #
+point $-1 -1 -1 $-1 -5 15 -10 #
+vertex $-1 -1 -1 $-1 $19623 $22323 #
+coedge $-1 -1 -1 $-1 $22324 $20521 $19626 $21054 reversed $20512 $-1 #
+edge $-1 -1 -1 $-1 $19071 6.1232339957367648e-17 $19064 1.5707963267948966 $19626 $22325 forward @7 unknown T 0 4.9999999999999991 -25 5.0000000000000009 10 -20 #
+coedge $-1 -1 -1 $-1 $19643 $22326 $21901 $22327 forward $19629 $-1 #
+coedge $-1 -1 -1 $-1 $22328 $19630 $22329 $22330 forward $18134 $-1 #
+coedge $-1 -1 -1 $-1 $19630 $22328 $21867 $21885 reversed $18134 $-1 #
+coedge $-1 -1 -1 $-1 $21065 $21901 $19630 $21059 reversed $20563 $-1 #
+edge $-1 -1 -1 $-1 $20519 6.1232339957367673e-17 $22331 1.5707963267948966 $19630 $22332 forward @7 unknown T 0 5 5 5.0000000000000009 10 10 #
+coedge $-1 -1 -1 $-1 $19632 $19631 $22321 $22333 reversed $16621 $-1 #
+coedge $-1 -1 -1 $-1 $20479 $20451 $19631 $21062 forward $20452 $-1 #
+edge $-1 -1 -1 $-1 $21816 1.5707963267948966 $20519 3.1415926535897931 $21061 $22334 forward @7 unknown T -5 10 5 0 15 10 #
+coedge $-1 -1 -1 $-1 $20514 $22335 $19632 $21064 reversed $17571 $-1 #
+edge $-1 -1 -1 $-1 $22336 -6.1232339957367648e-17 $20518 1.5707963267948966 $19632 $22337 forward @7 unknown T 0 10 -8.8817841970012523e-16 5.0000000000000009 15 5 #
+coedge $-1 -1 -1 $-1 $19633 $21058 $19053 $20509 forward $20563 $-1 #
+coedge $-1 -1 -1 $-1 $19635 $19634 $22335 $22338 forward $19636 $-1 #
+coedge $-1 -1 -1 $-1 $22339 $19639 $19635 $19641 forward $20555 $-1 #
+point $-1 -1 -1 $-1 7.5000000000000027 14.330127018922195 7.5 #
+ellipse-curve $-1 -1 -1 $-1 10.000000000000002 10 5.0000000000000009 0.70710678118654757 -0 0.70710678118654768 5.0000000000000009 0 -5 0.70710678118654746 I I #
+vertex $-1 -1 -1 $-1 $22340 $22341 #
+ellipse-curve $-1 -1 -1 $-1 9.9999999999999982 10 5.0000000000000009 -0.70710678118654757 -0 0.70710678118654746 -4.9999999999999991 0 -5 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $22326 $19643 $21947 $21075 reversed $19629 $-1 #
+vertex $-1 -1 -1 $-1 $22327 $22342 #
+edge $-1 -1 -1 $-1 $19646 -1.5707963267948966 $19656 0 $20614 $21069 forward @7 unknown T 10 4.9999999999999991 8.8817841970012523e-16 15.000000000000004 10 5.0000000000000009 #
+edge $-1 -1 -1 $-1 $22343 1.0471975511965979 $19646 1.5707963267948966 $21947 $21071 forward @7 unknown T 7.4999999999999991 5 2.5000000000000013 10 5.6698729810778072 5.0000000000000009 #
+point $-1 -1 -1 $-1 10 5 5.0000000000000009 #
+coedge $-1 -1 -1 $-1 $20566 $19647 $22344 $22345 reversed $17605 $-1 #
+coedge $-1 -1 -1 $-1 $21904 $19651 $19649 $21079 reversed $19094 $-1 #
+edge $-1 -1 -1 $-1 $19664 -2.0943951023931948 $19653 -1.5707963267948966 $19649 $22346 forward @7 unknown T 20 4.9999999999999973 2.5000000000000044 22.5 5.6698729810778055 5.0000000000000009 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 -0.70710678118654757 0 0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 20 4.9999999999999982 5.0000000000000009 #
+point $-1 -1 -1 $-1 15.000000000000004 10 8.8817841970012523e-16 #
+ellipse-curve $-1 -1 -1 $-1 20 9.9999999999999982 5.0000000000000009 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+straight-curve $-1 -1 -1 $-1 22.5 14.330127018922195 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $19662 $20593 $21904 $22347 forward $16172 $-1 #
+point $-1 -1 -1 $-1 22.5 5.6698729810778055 2.5000000000000049 #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 -9.9999999999999982 0.70710678118654757 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5.0000000000000009 0.70710678118654746 I I #
+ellipse-curve $-1 -1 -1 $-1 35 9.9999999999999982 5.0000000000000018 -0.70710678118654757 -0 -0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+coedge $-1 -1 -1 $-1 $19672 $19699 $19682 $21097 forward $15137 $-1 #
+coedge $-1 -1 -1 $-1 $19674 $21106 $21113 $20680 reversed $18176 $-1 #
+vertex $-1 -1 -1 $-1 $19677 $22348 #
+ellipse-curve $-1 -1 -1 $-1 -50 -5 -40 1 0 0 3.0616169978683826e-16 0 -5 1 I I #
+ellipse-curve $-1 -1 -1 $-1 -40 -4.9999999999999973 -40 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -40 -9.9999999999999964 -40 #
+point $-1 -1 -1 $-1 -40 2.6645352591003757e-15 -40 #
+edge $-1 -1 -1 $-1 $21971 27.5 $19683 37.500000000000014 $21090 $22349 forward @7 unknown T -22.500000000000004 -0.66987298107780746 -37.500000000000014 -22.5 -0.66987298107780546 -27.5 #
+point $-1 -1 -1 $-1 -22.5 -0.66987298107780657 -37.500000000000014 #
+edge $-1 -1 -1 $-1 $22350 -2.0943951023931935 $19680 -1.5707963267948966 $19687 $22351 forward @7 unknown T -40 -0.66987298107780657 -40 -37.500000000000007 2.6645352591003757e-15 -37.500000000000007 #
+coedge $-1 -1 -1 $-1 $20642 $19692 $22352 $22353 reversed $16231 $-1 #
+coedge $-1 -1 -1 $-1 $21967 $22354 $19695 $21103 reversed $22355 $-1 #
+edge $-1 -1 -1 $-1 $21104 1.0471975511965974 $22000 1.5707963267948966 $19695 $22356 forward @7 unknown T -22.5 -10 -27.500000000000004 -20 -9.330127018922191 -25 #
+vertex $-1 -1 -1 $-1 $21103 $22357 #
+straight-curve $-1 -1 -1 $-1 -22.5 -9.3301270189221928 0 0 0 1 I I #
+coedge $-1 -1 -1 $-1 $21091 $19702 $19698 $21107 reversed $18176 $-1 #
+edge $-1 -1 -1 $-1 $22000 -1.5707963267948966 $19181 0 $19698 $21111 forward @7 unknown T -20 -10 -30 -15 -5 -25 #
+coedge $-1 -1 -1 $-1 $22358 $20644 $19699 $21109 reversed $21970 $-1 #
+edge $-1 -1 -1 $-1 $21110 -1.5707963267948966 $21971 -1.0471975511965974 $19699 $22356 forward @7 unknown T -22.500000000000004 -0.66987298107780902 -27.5 -20 0 -25 #
+vertex $-1 -1 -1 $-1 $21109 $22359 #
+ellipse-curve $-1 -1 -1 $-1 -20 -5 -25 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22360 $19705 $21091 $20680 forward $18216 $-1 #
+coedge $-1 -1 -1 $-1 $19705 $22361 $19706 $21115 forward $18216 $-1 #
+edge $-1 -1 -1 $-1 $20687 -1.5707963267948961 $19718 0 $21114 $21121 forward @7 unknown T -20 -10 -15.000000000000002 -15.000000000000004 -5 -10.000000000000002 #
+ellipse-curve $-1 -1 -1 $-1 -10 -4.9999999999999991 -10 0.70710678118654746 -0 -0.70710678118654746 -5 3.0616169978683826e-16 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $22362 $19709 $22363 $22364 forward $20684 $-1 #
+coedge $-1 -1 -1 $-1 $20715 $19710 $22050 $22032 reversed $17739 $-1 #
+point $-1 -1 -1 $-1 -10 -10 -10 #
+coedge $-1 -1 -1 $-1 $22365 $19713 $22366 $21125 forward $20676 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -20.000000000000004 -5 -10.000000000000002 0.70710678118654746 -0 0.70710678118654746 5 0 -5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19715 $20682 $22367 $22368 forward $19245 $-1 #
+coedge $-1 -1 -1 $-1 $22369 $22366 $19715 $21124 reversed $22370 $-1 #
+edge $-1 -1 -1 $-1 $22371 4.1887902047863914 $19716 4.7123889803846897 $19715 $22372 forward @7 unknown T -22.500000000000004 -0.66987298107780635 -10.000000000000002 -20 0 -7.5000000000000027 #
+edge $-1 -1 -1 $-1 $19716 -1.5707963267948961 $22373 -1.0471975511965979 $21120 $22374 forward @7 unknown T -22.499999999999996 -0.66987298107780724 -12.500000000000002 -20 0 -10.000000000000002 #
+point $-1 -1 -1 $-1 -20 0 -10.000000000000002 #
+point $-1 -1 -1 $-1 -15.000000000000004 -5 -15.000000000000002 #
+coedge $-1 -1 -1 $-1 $19830 $19726 $19721 $21129 reversed $19831 $-1 #
+edge $-1 -1 -1 $-1 $20749 0 $18234 1.5707963267948966 $19721 $22375 forward @7 unknown T -5 -5 -15 8.8817841970012523e-16 8.8817841970012523e-16 -10 #
+straight-curve $-1 -1 -1 $-1 -7.4999999999999991 -0.66987298107780635 0 -0 -0 -1 I I #
+coedge $-1 -1 -1 $-1 $19728 $19725 $19739 $21143 forward $18233 $-1 #
+ellipse-curve $-1 -1 -1 $-1 -5 -5 -10 0.70710678118654746 0 -0.70710678118654746 -5 0 -5 0.70710678118654746 I I #
+point $-1 -1 -1 $-1 -7.5 -0.66987298107780746 2.5000000000000009 #
+coedge $-1 -1 -1 $-1 $22376 $19732 $17822 $19315 forward $18366 $-1 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 -24.999999999999996 0.70710678118654746 0 0.70710678118654746 -5 3.0616169978683826e-16 5 0.70710678118654746 I I #
+coedge $-1 -1 -1 $-1 $19734 $19747 $22377 $22378 forward $18243 $-1 #
+edge $-1 -1 -1 $-1 $21141 1.5707963267948966 $19748 2.0943951023931957 $19734 $22379 forward @7 unknown T 5 -10 5 7.5000000000000027 -9.330127018922191 7.5000000000000009 #
+coedge $-1 -1 -1 $-1 $19736 $19735 $22057 $22380 reversed $16719 $-1 #
+coedge $-1 -1 -1 $-1 $22377 $22058 $19735 $21140 reversed $19826 $-1 #
+edge $-1 -1 -1 $-1 $21141 -1.5707963267948966 $21146 -6.1232339957367648e-17 $19735 $22381 forward @7 unknown T -9.3734986416366059e-33 -10 -9.3734986416366059e-33 5 -5 5 #
+vertex $-1 -1 -1 $-1 $21140 $22382 #
+ellipse-curve $-1 -1 -1 $-1 5 -5 5 0.70710678118654757 0 0.70710678118654768 -5 3.0616169978683826e-16 4.9999999999999991 0.70710678118654757 I I #
+edge $-1 -1 -1 $-1 $21146 0 $20691 1.5707963267948966 $21131 $22383 forward @7 unknown T -5 -5 0 0 0 5 #
+ellip
