[cgma-dev] r1211 - cgm/trunk
kraftche at mcs.anl.gov
Wed Jul 18 13:25:05 CDT 2007
Author: kraftche
Date: 2007-07-18 13:25:05 -0500 (Wed, 18 Jul 2007)
New Revision: 1211
Modified:
cgm/trunk/cgm.make.in
Log:
more fixes to use CGM build w/out installing
Modified: cgm/trunk/cgm.make.in
--- cgm/trunk/cgm.make.in 2007-07-17 21:22:01 UTC (rev 1210)
+++ cgm/trunk/cgm.make.in 2007-07-18 18:25:05 UTC (rev 1211)
@@ -31,7 +31,7 @@
CGM_PARALLEL_LIB_FILE = @CGM_PARALLEL_LIB_FILE@
# These get redefined by a makefile target during *install*
# by appending correct values to the end of the file.
-CGM_LIBDIR = @abs_builddir@/.libs
+CGM_LIBDIR = @abs_builddir@
CGM_INCLUDEDIR = @abs_srcdir@
CGM_CXX = @CXX@
@@ -41,23 +41,29 @@
CGM_CFLAGS = @CFLAGS@
CGM_LDFLAGS = @LDFLAGS@
-CGM_INCLUDES = -I$(CGM_DIR)/util -I$(CGM_DIR)/init -I$(CGM_DIR)/geom -I$(CGM_DIR)/geom/ACIS $(CGM_PARALLEL_INCLUDE) -I$(CGM_INCLUDEDIR) ${ACIS_INCLUDES}
+CGM_INCLUDES = -I$(CGM_INCLUDEDIR)/util \
+ -I$(CGM_INCLUDEDIR)/init \
+ -I$(CGM_INCLUDEDIR)/geom \
+ -I$(CGM_INCLUDEDIR)/geom/ACIS \
+ $(CGM_PARALLEL_INCLUDE) \
+ -I$(CGM_INCLUDEDIR) \
+ ${ACIS_INCLUDES}
CGM_LIBS_LINK_INTERNAL = ${LDFLAGS} \
- -L$(CGM_DIR)/geom/virtual/.libs \
- -L$(CGM_DIR)/geom/facetbool/.libs \
- -L$(CGM_DIR)/geom/facet/.libs \
- -L$(CGM_DIR)/geom/Cholla/.libs \
- -L$(CGM_DIR)/geom/ACIS/.libs \
- -L$(CGM_DIR)/geom/.libs \
- -L$(CGM_DIR)/util/.libs \
- -L$(CGM_DIR)/geom/virtual \
- -L$(CGM_DIR)/geom/facetbool \
- -L$(CGM_DIR)/geom/facet \
- -L$(CGM_DIR)/geom/Cholla \
- -L$(CGM_DIR)/geom/ACIS \
- -L$(CGM_DIR)/geom \
- -L$(CGM_DIR)/util \
+ -L$(CGM_LIBDIR)/geom/virtual/.libs \
+ -L$(CGM_LIBDIR)/geom/facetbool/.libs \
+ -L$(CGM_LIBDIR)/geom/facet/.libs \
+ -L$(CGM_LIBDIR)/geom/Cholla/.libs \
+ -L$(CGM_LIBDIR)/geom/ACIS/.libs \
+ -L$(CGM_LIBDIR)/geom/.libs \
+ -L$(CGM_LIBDIR)/util/.libs \
+ -L$(CGM_LIBDIR)/geom/virtual \
+ -L$(CGM_LIBDIR)/geom/facetbool \
+ -L$(CGM_LIBDIR)/geom/facet \
+ -L$(CGM_LIBDIR)/geom/Cholla \
+ -L$(CGM_LIBDIR)/geom/ACIS \
+ -L$(CGM_LIBDIR)/geom \
+ -L$(CGM_LIBDIR)/util \
-L${ACIS_LIB_DIR} \
-L$(CGM_LIBDIR) \
${ACIS_LIBS} \
@@ -84,6 +90,6 @@
CUBIT_LIBS = @CUBIT_LIBS@
CUBIT_FILE = @CUBIT_FILE@
-CGM_LIBS_LINK = @CGM_LIBS_LINK@ -L$(CGM_DIR)/init -L$(CGM_DIR)/init/.libs -lcgma_init
+CGM_LIBS_LINK = @CGM_LIBS_LINK@ -L$(CGM_LIBDIR)/init -L$(CGM_LIBDIR)/init/.libs -lcgma_init
CGM_LIBS_FILES = @CGM_LIBS_FILES@ $(CGM_LIBDIR)/libcgma_init.a
CGM_LIBS_LTFLAGS = @CGM_LIBS_LTFLAGS@
More information about the cgma-dev
