[cgma-dev] r1207 - cgm/trunk/init
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jul 17 16:08:29 CDT 2007
Author: kraftche
Date: 2007-07-17 16:08:29 -0500 (Tue, 17 Jul 2007)
New Revision: 1207
Removed:
   cgm/trunk/init/Makefile
Log:
should not have checked this in
Deleted: cgm/trunk/init/Makefile
--- cgm/trunk/init/Makefile	2007-07-17 21:06:46 UTC (rev 1206)
+++ cgm/trunk/init/Makefile	2007-07-17 21:08:29 UTC (rev 1207)
@@ -1,543 +0,0 @@
-# Makefile.in generated by automake 1.9.6 from Makefile.am.
-# init/Makefile.  Generated from Makefile.in by configure.
-# Copyright (C) 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
-# 2003, 2004, 2005  Free Software Foundation, Inc.
-# This Makefile.in is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-srcdir = .
-top_srcdir = ..
-pkgdatadir = $(datadir)/CGMA
-pkglibdir = $(libdir)/CGMA
-pkgincludedir = $(includedir)/CGMA
-top_builddir = ..
-am__cd = CDPATH="$${ZSH_VERSION+.}$(PATH_SEPARATOR)" && cd
-INSTALL = /usr/bin/install -c
-install_sh_DATA = $(install_sh) -c -m 644
-install_sh_PROGRAM = $(install_sh) -c
-install_sh_SCRIPT = $(install_sh) -c
-INSTALL_HEADER = $(INSTALL_DATA)
-transform = $(program_transform_name)
-NORMAL_INSTALL = :
-PRE_INSTALL = :
-POST_INSTALL = :
-NORMAL_UNINSTALL = :
-PRE_UNINSTALL = :
-POST_UNINSTALL = :
-build_triplet = x86_64-unknown-linux-gnu
-host_triplet = x86_64-unknown-linux-gnu
-target_triplet = x86_64-unknown-linux-gnu
-subdir = init
-DIST_COMMON = $(libcgma_init_la_include_HEADERS) $(srcdir)/Makefile.am \
-	$(srcdir)/Makefile.in
-ACLOCAL_M4 = $(top_srcdir)/aclocal.m4
-am__aclocal_m4_deps = $(top_srcdir)/configure.in
-am__configure_deps = $(am__aclocal_m4_deps) $(CONFIGURE_DEPENDENCIES) \
-	$(ACLOCAL_M4)
-mkinstalldirs = $(install_sh) -d
-CONFIG_HEADER = $(top_builddir)/config.h \
-	$(top_builddir)/itaps/iBase_FCDefs.h
-CONFIG_CLEAN_FILES =
-am__vpath_adj_setup = srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`;
-am__vpath_adj = case $$p in \
-    $(srcdir)/*) f=`echo "$$p" | sed "s|^$$srcdirstrip/||"`;; \
-    *) f=$$p;; \
-  esac;
-am__strip_dir = `echo $$p | sed -e 's|^.*/||'`;
-am__installdirs = "$(DESTDIR)$(libdir)" \
-	"$(DESTDIR)$(libcgma_init_la_includedir)"
-libLTLIBRARIES_INSTALL = $(INSTALL)
-LTLIBRARIES = $(lib_LTLIBRARIES)
-libcgma_init_la_LIBADD =
-am_libcgma_init_la_OBJECTS = InitCGMA.lo
-libcgma_init_la_OBJECTS = $(am_libcgma_init_la_OBJECTS)
-DEFAULT_INCLUDES = -I. -I$(srcdir) -I$(top_builddir) -I$(top_builddir)/itaps
-depcomp = $(SHELL) $(top_srcdir)/depcomp
-am__depfiles_maybe = depfiles
-CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
-	$(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
-LTCXXCOMPILE = $(LIBTOOL) --tag=CXX --mode=compile $(CXX) $(DEFS) \
-	$(DEFAULT_INCLUDES) $(INCLUDES) $(AM_CPPFLAGS) $(CPPFLAGS) \
-	$(AM_CXXFLAGS) $(CXXFLAGS)
-CXXLD = $(CXX)
-CXXLINK = $(LIBTOOL) --tag=CXX --mode=link $(CXXLD) $(AM_CXXFLAGS) \
-	$(CXXFLAGS) $(AM_LDFLAGS) $(LDFLAGS) -o $@
-SOURCES = $(libcgma_init_la_SOURCES)
-DIST_SOURCES = $(libcgma_init_la_SOURCES)
-libcgma_init_la_includeHEADERS_INSTALL = $(INSTALL_HEADER)
-HEADERS = $(libcgma_init_la_include_HEADERS)
-ETAGS = etags
-CTAGS = ctags
-DISTFILES = $(DIST_COMMON) $(DIST_SOURCES) $(TEXINFOS) $(EXTRA_DIST)
-ACIS_DEFS =
-ACIS_DIR = no
-ACIS_HEALER =
-ACIS_IGES_TRANSLATOR =
-ACIS_INCLUDES =
-ACIS_LIBS =
-ACIS_LIB_DIR = .
-ACIS_PLATFORM =
-ACIS_STEP_TRANSLATOR =
-ACIS_VERSION = 0
-ACLOCAL = ${SHELL} /home/jason/CGM/missing --run aclocal-1.9
-AMDEP_FALSE = #
-AMDEP_TRUE =
-AMTAR = ${SHELL} /home/jason/CGM/missing --run tar
-AR = ar
-AUTOCONF = ${SHELL} /home/jason/CGM/missing --run autoconf
-AUTOHEADER = ${SHELL} /home/jason/CGM/missing --run autoheader
-AUTOMAKE = ${SHELL} /home/jason/CGM/missing --run automake-1.9
-AWK = gawk
-BABEL_DIR =
-BUILD_CGM_FALSE =
-BUILD_CGM_TRUE = #
-CANT_USE_STD =
-CANT_USE_STD_IO =
-CC = cc
-CCDEPMODE = depmode=gcc3
-CFLAGS =  -g
-CGM_ACIS_LIBS =
-CGM_LIBS_FILES = $(CUBIT_FILE)
-CGM_LIBS_LINK = $(CUBIT_LDFLAGS) $(CUBIT_LIBS)
-CGM_LIBS_LTFLAGS = $(CUBIT_LTFLAGS)
-CGM_PARALLEL_INCLUDE =
-CGM_PARALLEL_LIB =
-CGM_PARALLEL_LIB_FILE =
-CPP = cc -E
-CPPFLAGS =
-CUBIT_CGM = -DCUBIT_CGM
-CUBIT_FILE = /opt/cubit-10.1-amd64//bin/libcubiti19.so
-CUBIT_LDFLAGS =  -L/opt/cubit-10.1-amd64//bin -L/opt/cubit-10.1-amd64//bin/lib -L/opt/cubit-10.1-amd64//libs
-CUBIT_LIBS = -lcubiti19
-CUBIT_LTFLAGS =  -R/opt/cubit-10.1-amd64//bin -R/opt/cubit-10.1-amd64//bin/lib -R/opt/cubit-10.1-amd64//libs
-CXX = c++
-CXXCPP = c++ -E
-CXXDEPMODE = depmode=gcc3
-CXXFLAGS =  -Wall -pipe -g
-CYGPATH_W = echo
-# Override default defines with the ones we want from the configure script
-DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN) $(HAVE_ACIS_DEF) $(CUBIT_CGM)
-DEPDIR = .deps
-ECHO = echo
-ECHO_C =
-ECHO_N = -n
-ECHO_T =
-EGREP = /bin/grep -E
-EXEEXT =
-F77 = g77
-FC = gfortran
-FCFLAGS = -g -O2
-FCLIBS =  -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.1.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -lgfortranbegin -lgfortran -lm
-FFLAGS = -g -O2
-GREP = /bin/grep
-HAVE_ACIS_DEF = -DHAVE_ACIS
-INCLUDE_TEMPLATE_DEFS_FALSE = #
-INCLUDE_TEMPLATE_DEFS_TRUE =
-INSTALL_DATA = ${INSTALL} -m 644
-INSTALL_PROGRAM = ${INSTALL}
-INSTALL_SCRIPT = ${INSTALL}
-INSTALL_STRIP_PROGRAM = ${SHELL} $(install_sh) -c -s
-LDFLAGS =
-LIBOBJS =
-LIBS = -lm
-LIBTOOL = $(SHELL) $(top_builddir)/libtool
-LITTLE_ENDIAN = -DLITTLE_ENDIAN=BYTE_ORDER
-LN_S = ln -s
-LTLIBOBJS =
-MAKEINFO = ${SHELL} /home/jason/CGM/missing --run makeinfo
-OBJEXT = o
-PACKAGE = CGMA
-PACKAGE_BUGREPORT =
-PACKAGE_NAME = CGMA
-PACKAGE_STRING = CGMA 10.2.2
-PACKAGE_TARNAME = cgma
-PACKAGE_VERSION = 10.2.2
-PATH_SEPARATOR = :
-RANLIB = ranlib
-SET_MAKE =
-SHELL = /bin/sh
-STRIP = strip
-TEMPLATE_DEFS_INCLUDED = -DTEMPLATE_DEFS_INCLUDED
-USE_BABEL = no
-USE_BABEL_FALSE =
-USE_BABEL_TRUE = #
-USE_MPI_FALSE =
-USE_MPI_TRUE = #
-VERSION = 10.2.2
-ac_ct_CC = cc
-ac_ct_CXX = c++
-ac_ct_F77 = g77
-ac_ct_FC = gfortran
-am__fastdepCC_FALSE = #
-am__fastdepCC_TRUE =
-am__fastdepCXX_FALSE = #
-am__fastdepCXX_TRUE =
-am__include = include
-am__leading_dot = .
-am__quote =
-am__tar = ${AMTAR} chof - "$$tardir"
-am__untar = ${AMTAR} xf -
-bindir = ${exec_prefix}/bin
-build = x86_64-unknown-linux-gnu
-build_ACIS_FALSE =
-build_ACIS_TRUE = #
-build_alias =
-build_cpu = x86_64
-build_os = linux-gnu
-build_parallel_FALSE =
-build_parallel_TRUE = #
-build_vendor = unknown
-datadir = ${datarootdir}
-datarootdir = ${prefix}/share
-docdir = ${datarootdir}/doc/${PACKAGE_TARNAME}
-dvidir = ${docdir}
-exec_prefix = ${prefix}
-host = x86_64-unknown-linux-gnu
-host_alias =
-host_cpu = x86_64
-host_os = linux-gnu
-host_vendor = unknown
-htmldir = ${docdir}
-includedir = ${prefix}/include
-infodir = ${datarootdir}/info
-install_sh = /home/jason/CGM/install-sh
-libdir = ${exec_prefix}/lib
-libexecdir = ${exec_prefix}/libexec
-localedir = ${datarootdir}/locale
-localstatedir = ${prefix}/var
-mandir = ${datarootdir}/man
-mkdir_p = mkdir -p --
-oldincludedir = /usr/include
-pdfdir = ${docdir}
-prefix = /usr/local
-program_transform_name = s,x,x,
-psdir = ${docdir}
-sbindir = ${exec_prefix}/sbin
-sharedstatedir = ${prefix}/com
-sysconfdir = ${prefix}/etc
-target = x86_64-unknown-linux-gnu
-target_alias =
-target_cpu = x86_64
-target_os = linux-gnu
-target_vendor = unknown
-# Don't require GNU-standard files (Changelog, README, etc.)
-AUTOMAKE_OPTIONS = foreign
-INCLUDES = -I$(top_srcdir)/geom \
-           -I$(top_srcdir)/util \
-           -I$(top_srcdir)/geom/ACIS \
-           -I$(top_srcdir)/geom/virtual \
-           -I$(top_srcdir)/geom/facet \
-           -I$(top_srcdir)/geom/cholla \
-           -I$(srcdir)
-lib_LTLIBRARIES = libcgma_init.la
-libcgma_init_la_includedir = $(includedir)
-libcgma_init_la_SOURCES = InitCGMA.cpp
-libcgma_init_la_include_HEADERS = InitCGMA.hpp
-all: all-am
-.SUFFIXES:
-.SUFFIXES: .cpp .lo .o .obj
-$(srcdir)/Makefile.in:  $(srcdir)/Makefile.am  $(am__configure_deps)
-	@for dep in $?; do \
-	  case '$(am__configure_deps)' in \
-	    *$$dep*) \
-	      cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh \
-		&& exit 0; \
-	      exit 1;; \
-	  esac; \
-	done; \
-	echo ' cd $(top_srcdir) && $(AUTOMAKE) --foreign  init/Makefile'; \
-	cd $(top_srcdir) && \
-	  $(AUTOMAKE) --foreign  init/Makefile
-.PRECIOUS: Makefile
-Makefile: $(srcdir)/Makefile.in $(top_builddir)/config.status
-	@case '$?' in \
-	  *config.status*) \
-	    cd $(top_builddir) && $(MAKE) $(AM_MAKEFLAGS) am--refresh;; \
-	    echo ' cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe)'; \
-	    cd $(top_builddir) && $(SHELL) ./config.status $(subdir)/$@ $(am__depfiles_maybe);; \
-	esac;
-$(top_builddir)/config.status: $(top_srcdir)/configure $(CONFIG_STATUS_DEPENDENCIES)
-$(top_srcdir)/configure:  $(am__configure_deps)
-$(ACLOCAL_M4):  $(am__aclocal_m4_deps)
-install-libLTLIBRARIES: $(lib_LTLIBRARIES)
-	@$(NORMAL_INSTALL)
-	test -z "$(libdir)" || $(mkdir_p) "$(DESTDIR)$(libdir)"
-	@list='$(lib_LTLIBRARIES)'; for p in $$list; do \
-	  if test -f $$p; then \
-	    f=$(am__strip_dir) \
-	    echo " $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) '$$p' '$(DESTDIR)$(libdir)/$$f'"; \
-	    $(LIBTOOL) --mode=install $(libLTLIBRARIES_INSTALL) $(INSTALL_STRIP_FLAG) "$$p" "$(DESTDIR)$(libdir)/$$f"; \
-	  else :; fi; \
-	done
-uninstall-libLTLIBRARIES:
-	@$(NORMAL_UNINSTALL)
-	@set -x; list='$(lib_LTLIBRARIES)'; for p in $$list; do \
-	  p=$(am__strip_dir) \
-	  echo " $(LIBTOOL) --mode=uninstall rm -f '$(DESTDIR)$(libdir)/$$p'"; \
-	  $(LIBTOOL) --mode=uninstall rm -f "$(DESTDIR)$(libdir)/$$p"; \
-	done
-clean-libLTLIBRARIES:
-	-test -z "$(lib_LTLIBRARIES)" || rm -f $(lib_LTLIBRARIES)
-	  dir="`echo $$p | sed -e 's|/[^/]*$$||'`"; \
-	  test "$$dir" != "$$p" || dir=.; \
-	  echo "rm -f \"$${dir}/so_locations\""; \
-	  rm -f "$${dir}/so_locations"; \
-	done
-libcgma_init.la: $(libcgma_init_la_OBJECTS) $(libcgma_init_la_DEPENDENCIES)
-	$(CXXLINK) -rpath $(libdir) $(libcgma_init_la_LDFLAGS) $(libcgma_init_la_OBJECTS) $(libcgma_init_la_LIBADD) $(LIBS)
-mostlyclean-compile:
-	-rm -f *.$(OBJEXT)
-distclean-compile:
-	-rm -f *.tab.c
-include ./$(DEPDIR)/InitCGMA.Plo
-.cpp.o:
-	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
-	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Po"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
-#	source='$<' object='$@' libtool=no \
-#	DEPDIR=$(DEPDIR) $(CXXDEPMODE) $(depcomp) \
-#	$(CXXCOMPILE) -c -o $@ $<
-.cpp.obj:
-	if $(CXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ `$(CYGPATH_W) '$<'`; \
-#	$(CXXCOMPILE) -c -o $@ `$(CYGPATH_W) '$<'`
-.cpp.lo:
-	if $(LTCXXCOMPILE) -MT $@ -MD -MP -MF "$(DEPDIR)/$*.Tpo" -c -o $@ $<; \
-	then mv -f "$(DEPDIR)/$*.Tpo" "$(DEPDIR)/$*.Plo"; else rm -f "$(DEPDIR)/$*.Tpo"; exit 1; fi
-#	source='$<' object='$@' libtool=yes \
-#	$(LTCXXCOMPILE) -c -o $@ $<
-mostlyclean-libtool:
-	-rm -f *.lo
-clean-libtool:
-	-rm -rf .libs _libs
-distclean-libtool:
-	-rm -f libtool
-uninstall-info-am:
-install-libcgma_init_la_includeHEADERS: $(libcgma_init_la_include_HEADERS)
-	test -z "$(libcgma_init_la_includedir)" || $(mkdir_p) "$(DESTDIR)$(libcgma_init_la_includedir)"
-	@list='$(libcgma_init_la_include_HEADERS)'; for p in $$list; do \
-	  if test -f "$$p"; then d=; else d="$(srcdir)/"; fi; \
-	  echo " $(libcgma_init_la_includeHEADERS_INSTALL) '$$d$$p' '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \
-	  $(libcgma_init_la_includeHEADERS_INSTALL) "$$d$$p" "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \
-	done
-uninstall-libcgma_init_la_includeHEADERS:
-	  echo " rm -f '$(DESTDIR)$(libcgma_init_la_includedir)/$$f'"; \
-	  rm -f "$(DESTDIR)$(libcgma_init_la_includedir)/$$f"; \
-	done
-ID: $(HEADERS) $(SOURCES) $(LISP) $(TAGS_FILES)
-	list='$(SOURCES) $(HEADERS) $(LISP) $(TAGS_FILES)'; \
-	unique=`for i in $$list; do \
-	    if test -f "$$i"; then echo $$i; else echo $(srcdir)/$$i; fi; \
-	  done | \
-	  $(AWK) '    { files[$$0] = 1; } \
-	       END { for (i in files) print i; }'`; \
-	mkid -fID $$unique
-tags: TAGS
-TAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-		$(TAGS_FILES) $(LISP)
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	if test -z "$(ETAGS_ARGS)$$tags$$unique"; then :; else \
-	  test -n "$$unique" || unique=$$empty_fix; \
-	  $(ETAGS) $(ETAGSFLAGS) $(AM_ETAGSFLAGS) $(ETAGS_ARGS) \
-	    $$tags $$unique; \
-	fi
-ctags: CTAGS
-CTAGS:  $(HEADERS) $(SOURCES)  $(TAGS_DEPENDENCIES) \
-	tags=; \
-	here=`pwd`; \
-	  done | \
-	test -z "$(CTAGS_ARGS)$$tags$$unique" \
-	  || $(CTAGS) $(CTAGSFLAGS) $(AM_CTAGSFLAGS) $(CTAGS_ARGS) \
-	     $$tags $$unique
-GTAGS:
-	here=`$(am__cd) $(top_builddir) && pwd` \
-	  && cd $(top_srcdir) \
-	  && gtags -i $(GTAGS_ARGS) $$here
-distclean-tags:
-	-rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
-distdir: $(DISTFILES)
-	@srcdirstrip=`echo "$(srcdir)" | sed 's|.|.|g'`; \
-	topsrcdirstrip=`echo "$(top_srcdir)" | sed 's|.|.|g'`; \
-	list='$(DISTFILES)'; for file in $$list; do \
-	  case $$file in \
-	    $(srcdir)/*) file=`echo "$$file" | sed "s|^$$srcdirstrip/||"`;; \
-	    $(top_srcdir)/*) file=`echo "$$file" | sed "s|^$$topsrcdirstrip/|$(top_builddir)/|"`;; \
-	  esac; \
-	  if test -f $$file || test -d $$file; then d=.; else d=$(srcdir); fi; \
-	  dir=`echo "$$file" | sed -e 's,/[^/]*$$,,'`; \
-	  if test "$$dir" != "$$file" && test "$$dir" != "."; then \
-	    dir="/$$dir"; \
-	    $(mkdir_p) "$(distdir)$$dir"; \
-	  else \
-	    dir=''; \
-	  fi; \
-	  if test -d $$d/$$file; then \
-	    if test -d $(srcdir)/$$file && test $$d != $(srcdir); then \
-	      cp -pR $(srcdir)/$$file $(distdir)$$dir || exit 1; \
-	    fi; \
-	    cp -pR $$d/$$file $(distdir)$$dir || exit 1; \
-	  else \
-	    test -f $(distdir)/$$file \
-	    || cp -p $$d/$$file $(distdir)/$$file \
-	    || exit 1; \
-	  fi; \
-	done
-check-am: all-am
-check: check-am
-all-am: Makefile $(LTLIBRARIES) $(HEADERS)
-installdirs:
-	for dir in "$(DESTDIR)$(libdir)" "$(DESTDIR)$(libcgma_init_la_includedir)"; do \
-	  test -z "$$dir" || $(mkdir_p) "$$dir"; \
-	done
-install: install-am
-install-exec: install-exec-am
-install-data: install-data-am
-uninstall: uninstall-am
-install-am: all-am
-	@$(MAKE) $(AM_MAKEFLAGS) install-exec-am install-data-am
-installcheck: installcheck-am
-install-strip:
-	$(MAKE) $(AM_MAKEFLAGS) INSTALL_PROGRAM="$(INSTALL_STRIP_PROGRAM)" \
-	  install_sh_PROGRAM="$(INSTALL_STRIP_PROGRAM)" INSTALL_STRIP_FLAG=-s \
-	  `test -z '$(STRIP)' || \
-	    echo "INSTALL_PROGRAM_ENV=STRIPPROG='$(STRIP)'"` install
-mostlyclean-generic:
-clean-generic:
-distclean-generic:
-	-test -z "$(CONFIG_CLEAN_FILES)" || rm -f $(CONFIG_CLEAN_FILES)
-maintainer-clean-generic:
-	@echo "This command is intended for maintainers to use"
-	@echo "it deletes files that may require special tools to rebuild."
-clean: clean-am
-clean-am: clean-generic clean-libLTLIBRARIES clean-libtool \
-	mostlyclean-am
-distclean: distclean-am
-	-rm -rf ./$(DEPDIR)
-	-rm -f Makefile
-distclean-am: clean-am distclean-compile distclean-generic \
-	distclean-libtool distclean-tags
-dvi: dvi-am
-dvi-am:
-html: html-am
-info: info-am
-info-am:
-install-data-am: install-libcgma_init_la_includeHEADERS
-install-exec-am: install-libLTLIBRARIES
-install-info: install-info-am
-install-man:
-installcheck-am:
-maintainer-clean: maintainer-clean-am
-	-rm -f Makefile
-maintainer-clean-am: distclean-am maintainer-clean-generic
-mostlyclean: mostlyclean-am
-mostlyclean-am: mostlyclean-compile mostlyclean-generic \
-	mostlyclean-libtool
-pdf: pdf-am
-pdf-am:
-ps: ps-am
-ps-am:
-uninstall-am: uninstall-info-am uninstall-libLTLIBRARIES \
-	uninstall-libcgma_init_la_includeHEADERS
-.PHONY: CTAGS GTAGS all all-am check check-am clean clean-generic \
-	clean-libLTLIBRARIES clean-libtool ctags distclean \
-	distclean-compile distclean-generic distclean-libtool \
-	distclean-tags distdir dvi dvi-am html html-am info info-am \
-	install install-am install-data install-data-am install-exec \
-	install-exec-am install-info install-info-am \
-	install-libLTLIBRARIES install-libcgma_init_la_includeHEADERS \
-	install-man install-strip installcheck installcheck-am \
-	installdirs maintainer-clean maintainer-clean-generic \
-	mostlyclean mostlyclean-compile mostlyclean-generic \
-	mostlyclean-libtool pdf pdf-am ps ps-am tags uninstall \
-	uninstall-am uninstall-info-am uninstall-libLTLIBRARIES \
-# Tell versions [3.59,3.63) of GNU make to not export all variables.
-# Otherwise a system limit (for SysV at least) may be exceeded.
-.NOEXPORT:
More information about the cgma-dev mailing list
