[cgma-dev] r1184 - cgm/trunk
kraftche at mcs.anl.gov
Thu Jul 5 13:50:23 CDT 2007
Author: kraftche
Date: 2007-07-05 13:50:23 -0500 (Thu, 05 Jul 2007)
New Revision: 1184
Modified:
cgm/trunk/cgm.make.in
cgm/trunk/configure.in
Log:
Fix cubit detection for cubit 10.1: also include libraries in
bin/lib libs/ and lib/ subdirectories.
Modified: cgm/trunk/cgm.make.in
--- cgm/trunk/cgm.make.in 2007-07-05 17:53:09 UTC (rev 1183)
+++ cgm/trunk/cgm.make.in 2007-07-05 18:50:23 UTC (rev 1184)
@@ -60,8 +60,9 @@
$(CGM_LIBDIR)/libcubit_util.a \
${CGM_PARALLEL_LIB_FILE}
-CUBIT_BIN_DIR = @CUBIT_BIN_DIR@
-CUBIT_LINK = @CUBIT_LINK@
+CUBIT_LDFLAGS = @CUBIT_LDFLAGS@
+CUBIT_LTFLAGS = @CUBIT_LTFLAGS@
+CUBIT_LIBS = @CUBIT_LIBS@
CUBIT_FILE = @CUBIT_FILE@
CGM_LIBS_LINK = @CGM_LIBS_LINK@
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2007-07-05 17:53:09 UTC (rev 1183)
+++ cgm/trunk/configure.in 2007-07-05 18:50:23 UTC (rev 1184)
@@ -70,6 +70,29 @@
if test "x$CUBIT_DIR" == "xyes"; then
AC_MSG_ERROR([Option --with-CUBIT without specifying Cubit directory.])
elif test "x$CUBIT_DIR" != "xno"; then
+ if ! test -d "$CUBIT_DIR"; then
+ AC_MSG_ERROR([$CUBIT_DIR: not a directory.])
+ fi
+ CUBIT_LDFLAGS=
+ CUBIT_LTFLAGS=
+ CUBIT_LIBS=no
+ if test -d "$CUBIT_DIR/bin"; then
+ CUBIT_LDFLAGS="$CUBIT_LDFLAGS -L$CUBIT_DIR/bin"
+ CUBIT_LTFLAGS="$CUBIT_LTFLAGS -R$CUBIT_DIR/bin"
+ if test -d "$CUBIT_DIR/bin/lib"; then
+ CUBIT_LDFLAGS="$CUBIT_LDFLAGS -L$CUBIT_DIR/bin/lib"
+ CUBIT_LTFLAGS="$CUBIT_LTFLAGS -R$CUBIT_DIR/bin/lib"
+ fi
+ fi
+ if test -d "$CUBIT_DIR/lib"; then
+ CUBIT_LDFLAGS="$CUBIT_LDFLAGS -L$CUBIT_DIR/lib"
+ CUBIT_LTFLAGS="$CUBIT_LTFLAGS -R$CUBIT_DIR/lib"
+ fi
+ if test -d "$CUBIT_DIR/libs"; then
+ CUBIT_LDFLAGS="$CUBIT_LDFLAGS -L$CUBIT_DIR/libs"
+ CUBIT_LTFLAGS="$CUBIT_LTFLAGS -R$CUBIT_DIR/libs"
+ fi
CUBIT_BIN_DIR="$CUBIT_DIR/bin"
cat >conftest.cc <<EOCUBITCT
class AcisQueryEngine { public: static AcisQueryEngine* instance_; };
@@ -82,10 +105,10 @@
for file in $pattern; do
AC_MSG_CHECKING([for AcisQueryEngine::instance_ in $file])
num=[`expr X"$file" : X".*cubiti\([0-9][0-9]\)\..*"`]
- if ./libtool --mode=link $CXX $LDFLAGS -L$CUBIT_BIN_DIR -R$CUBIT_BIN_DIR -lcubiti$num conftest.cc -o conftest >&5 2>&5; then
- CUBIT_LINK="-L\$(CUBIT_BIN_DIR) -lcubiti$num"
- CUBIT_FILE=`expr x"$file" : x"$CUBIT_BIN_DIR/\(.*\)"`
- CUBIT_FILE="\$(CUBIT_BIN_DIR)/$CUBIT_FILE"
+ if ./libtool --mode=link $CXX $LDFLAGS $CUBIT_LDFLAGS $CUBIT_LTFLAGS -lcubiti$num conftest.cc -o conftest >&5 2>&5; then
+ CUBIT_LIBS="-lcubiti$num"
+ CUBIT_FILE=`expr x"$file" : x"$CUBIT_DIR/bin/\(.*\)"`
+ CUBIT_FILE="${CUBIT_DIR}/bin/$CUBIT_FILE"
AC_MSG_RESULT(yes)
else
AC_MSG_RESULT(no)
@@ -93,21 +116,22 @@
done
rm -f conftest.cc
- if test "x$CUBIT_LINK" = "xno"; then
+ if test "x$CUBIT_LIBS" = "xno"; then
AC_MSG_ERROR("Cubit library not found in $CUBIT_BIN_DIR")
fi
- CGM_LIBS_LINK='$(CUBIT_LINK)'
+ CGM_LIBS_LINK='$(CUBIT_LDFLAGS) $(CUBIT_LIBS)'
CGM_LIBS_FILES='$(CUBIT_FILE)'
- CGM_LIBS_LTFLAGS='-R$(CUBIT_BIN_DIR)'
+ CGM_LIBS_LTFLAGS='$(CUBIT_LTFLAGS)'
CUBIT_CGM="-DCUBIT_CGM"
dnl AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" )
HAVE_ACIS_DEF=-DHAVE_ACIS
fi
+AC_SUBST(CUBIT_LDFLAGS)
+AC_SUBST(CUBIT_LTFLAGS)
+AC_SUBST(CUBIT_LIBS)
AC_SUBST(CUBIT_FILE)
AC_SUBST(CUBIT_CGM)
-AC_SUBST(CUBIT_LINK)
-AC_SUBST(CUBIT_BIN_DIR)
AC_SUBST(CGM_LIBS_LINK)
AC_SUBST(CGM_LIBS_FILES)
AC_SUBST(CGM_LIBS_LTFLAGS)
More information about the cgma-dev
