[CGMa-announce] algorithm to extract closed volume from nonmanifold faces model
Jane Hu janejhu at gmail.com
Mon May 23 11:16:40 CDT 2011
If your iges model contains volumes, they will be improted.
Jane
On Mon, May 23, 2011 at 10:43 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> What does it give you when you read in an iges model, using the OCC port?
>  Just surfaces?
> - tim
> On 05/23/2011 09:35 AM, Jane Hu wrote:
>> No, CGM doesn't have this function. However, if you provide manifold
>> surfaces, CGM can stitch them together to create a volume, stitch_surfs
>> is the function.
>> Jane
>> 2011/5/22 Yu Wenhui <yuwenhui at live.com <mailto:yuwenhui at live.com>>
>>    Hi Gurus,
>>    I’d like to know if CGM have a function which extract closed volumes
>>    ( closed faces, not contained each other ) from nonmanifold faces
>> model.
>>    Thanks,
>>    Yu
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-announce/attachments/20110523/945ad223/attachment-0001.htm>
More information about the cgma-announce mailing list
