[CGMa-announce] error in make check
Jason Kraftcheck
kraftche at cae.wisc.edu
Thu Dec 16 22:08:38 CST 2010
On 12/16/2010 06:57 PM, Rajeev Jain wrote:
> Please ignore: This must addressed to "Developer information for cgma"<cgma-dev at lists.mcs.anl.gov>;
> Rajeev
> From: "Rajeev Jain"<jain at mcs.anl.gov>
> To: "Announcements for CGM-Argonne"<cgma-announce at lists.mcs.anl.gov>
> Sent: Thursday, December 16, 2010 6:41:07 PM
> Subject: [CGMa-announce] error in make check
> Hi,
> I'm trying to build a serial, static version of CGM. autoreconf, ./configure and make goes well, but, make check fails with the following error, looking for /libcubit_geom.so. I'm attaching my config.log file. My config options are:
> ./configure --prefix=/home/rajeev/FATHOM/lib/CGM --with-cubit=/home/rajeev/cubit-32 --enable-debug
> rajeev at nix:~/FATHOM/source/CGM/itaps$ make testgeom
> /bin/bash ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -g -R/home/rajeev/cubit-32/bin -L/home/rajeev/cubit-32/bin -o testgeom testgeom.o libiGeom.la -lm
> libtool: link: g++ -Wall -pipe -pedantic -g -o testgeom testgeom.o -L/home/rajeev/cubit-32/bin ./.libs/libiGeom.a /home/rajeev/FATHOM/source/CGM/.libs/libcgm.a -lcubiti19 -lm -Wl,-rpath -Wl,/home/rajeev/cubit-32/bin
> ./.libs/libiGeom.a(iGeom_CGMA.o): In function `iGeom_load_cub_geometry':
> /home/rajeev/FATHOM/source/CGM/itaps/iGeom_CGMA.cc:6260: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
> /usr/bin/ld.bfd.real: ./.libs/libiGeom.a(iGeom_CGMA.o): undefined reference to symbol 'MergeTool::merge_volumes(DLIList<RefVolume*>&, bool)'
> /usr/bin/ld.bfd.real: note: 'MergeTool::merge_volumes(DLIList<RefVolume*>&, bool)' is defined in DSO /home/rajeev/cubit-32/bin/libcubit_geom.so so try adding it to the linker command line
> /home/rajeev/cubit-32/bin/libcubit_geom.so: could not read symbols: Invalid operation
> collect2: ld returned 1 exit status
> make: *** [testgeom] Error 1
> rajeev at nix:~/FATHOM/source/CGM/itaps$ ls -l .libs/
> total 1420
> -rw-r--r-- 1 rajeev rajeev 1444022 2010-12-16 18:10 libiGeom.a
> lrwxrwxrwx 1 rajeev rajeev 14 2010-12-16 18:10 libiGeom.la -> ../libiGeom.la
> -rw-r--r-- 1 rajeev rajeev 1020 2010-12-16 18:10 libiGeom.lai
> Tried explicitly adding the linker by using "LDFLAGS=-L/home/rajeev/cubit-32/bin LIBS=-lcubit_geom" in the config line, it doesn't work.
You need to have the cubit 'bin' directory in your LD_LIBRARY_PATH
- jason
More information about the cgma-announce
