[AG-USERS] venue client hangs
Eric Olson
eolson at mcs.anl.gov
Wed Mar 9 15:53:39 CST 2005
Hi David,
The most likely reason is that the GLOBUS_HOSTNAME environment variable is
set. Unsetting/deleting it should fix your problem. If you haven't
worked with environment variables on windows XP, you can find them by
right-clicking "My Computer", clicking "Properties", the "Advanced" tab,
and the "Environment Variables" button.
If that doesn't work, let us know and we'll try something else.
Older versions of the AG Toolkit set GLOBUS_HOSTNAME -- currently it's
only used to override the hostname that AG Toolkit uses. Here is slightly
more background:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2004/06/msg00025.html
Eric
On Wed, 9 Mar 2005, David Fitzgerald wrote:
> Hi All,
> I have been running AG toolkit 2.3 on a Win XP box. Yesterday, our
> networking folks made me change the IP address of my AG node, and since then
> the venue client hangs when I start it up. I deleted the certificates,
> uninstalled and re-installed the toolkit, and got a new certificate, and it
> still hangs. I ran ethereal when starting the toolkit, and it shows that my
> node will try to send tcp packets to port 59684 of the OLD IP address. I'm
> guessing I need to reconfigure something, but what? Can anyone help?
> Thanks!!
> Dave
> David Fitzgerald
> Distributed System Specialist II
> Millersville University
> Millersville PA 17551
> Phone: 717-871-2394
> Fax: 717-871-4725
> E-mail: david.fitzgerald at millersville.edu
> <mailto:david.fitzgerald at millersville.edu>
> Oh, so they have internet on computers now!
> -- Homer Simpson
More information about the ag-users
