[AG-USERS] AGSchedule Update
Michael Miller
mimiller at ncsa.uiuc.edu
Tue Mar 16 10:11:37 CST 2004
To all users of AGSchedule:
In order to enhance security for AGSchedule we have implemented a function
which allows node operators to specify a set of valid domains that will be
allowed to register for their site. For example, at NCSA we would have a
string that looks like this:
ncsa.uiuc.edu;uiuc.edu;ncsa.edu
The domains are separated by semi-colons. The Edit Site Info page has a
text entry box that allows node operators to edit this string.
Once the string is entered, email addresses from other domains will not be
accepted for that site by the registration process. This may cause
confusion for users who utilize non-standard email addresses at your
site. Please make sure that all appropriate persons are notified of this
change.
This change does not affect any currently registered accounts. Part of the
installation process added the domains from the node operators' email
addresses to the string that designates valid domains for that site. Some
sites do not have a designated node operator. This leaves no domain to
specify for that site. Therefore, that site will stop accepting
registrations from any email address. Should you need to register a node
operator for your site, please send email to agschedule at ncsa.uiuc.edu.
Please check the entries made to be sure that the domains specified for
your site are valid.
If you have any questions about this change please send email to
Thanx,
Michael Miller
System Engineer
Visualization Technology Support
Computing and Data Management
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
More information about the ag-users
