[AG-TECH] SSL Certificate change for AGSchedule
    Miller, Michael B
    myk at illinois.edu
    Thu Jan  5 16:20:09 CST 2012
The CA certificate for AGSchedule has changed. This may cause your browser to give a warning/error message when connecting to AGSchedule. To avoid such messages, install the new NCSA CA certificate which can be had here:
http://agschedule.ncsa.illinois.edu/NCSA_ROOT_CERTIFICATE_2027.cer
Consult the documentation for your browser for instructions on installing the certificate. Contact the AGSchedule Administrator at agschedule at ncsa.illinois.edu.
Michael Miller
System Engineer
NCSA
217 649 0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20120105/74bdfcd0/attachment.htm>
