[AG-TECH] Debian broken packages... now fixed
Miguel A- Sáez Llorente
miguelangel.saez at usc.es
Wed Oct 19 07:18:59 CDT 2011
Chris,
Now it works!.
Thanks a lot,
Miguel
El 19/10/2011 1:21, Christoph Willing escribió:
> Miguel,
> The missing 32bit packages are now in the UQVislab repository so the
> accessgrid3.2 package should install correctly (after running sudo
> apt-get update). I've done some light testing and it all seems to be
> running correctly but please advise if you have any problems.
> chris
> On 18/10/2011, at 5:41 PM, Miguel A- Sáez Llorente wrote:
>> Hello,
>> Thanks for ur fast replies.
>> I have tried installing it with a regular user using sudo and i still
>> get the same error.
>> The repositories im using are the next ones:
>> deb http://ftp.es.debian.org/debian/ squeeze main
>> deb-src http://ftp.es.debian.org/debian/ squeeze main
>> deb http://security.debian.org/ squeeze/updates main
>> deb-src http://security.debian.org/ squeeze/updates main
>> Both computers are using i686 architecture so i guess thats the
>> problem if only amd64 packages are available for those dependencies.
>> El 18/10/2011 2:40, Christoph Willing escribió:
>>> On 18/10/2011, at 12:12 AM, Christoph Willing wrote:
>>>> On 17/10/2011, at 10:05 PM, Miguel A- Sáez Llorente wrote:
>>>>> Hello!,
>>>>> I'm trying to install the AG3 package on two computers with Debian
>>>>> Squeeze, i get the same error on both:
>>>>> root at agserver:/home/user# apt-get install accessgrid3.2
>>>>> Reading package lists... Done
>>>>> Building dependency tree
>>>>> Reading state information... Done
>>>>> Some packages could not be installed. This may mean that you have
>>>>> requested an impossible situation or if you are using the unstable
>>>>> distribution that some required packages have not yet been created
>>>>> or been moved out of Incoming.
>>>>> The following information may help to resolve the situation:
>>>>> The following packages have unmet dependencies:
>>>>> accessgrid3.2 : Depends: agcommon but it is not installable
>>>>> Depends: ag-vic2.8ucl but it is not installable
>>>>> Depends: ag-rat but it is not installable
>>>>> Depends: quickbridge but it is not installable
>>>>> Depends: vpcscreen but it is not installable
>>>>> E: Broken packages
>>>>> root at agserver:/home/user# uname -a
>>>>> Linux agserver 2.6.32-5-686-bigmem #1 SMP Mon Oct 3 05:03:32 UTC
>>>>> 2011 i686 GNU/Linux
>>>>> I'm not sure if something is wrong on my installation or the source
>>>>> packages are bad. Would be nice if someone can take a loot into
>>>>> this...
>>>> Miguel,
>>>> I just had a quick look at this - I removed the accessgrid3.2 package
>>>> as well as the dependencies you mentioned above which would not
>>>> install for some reason. I then installed again as you did (except I
>>>> ran as ordinary user and used sudo). They all installed as expected -
>>>> I was unable to reproduce your problem.
>>>> I wonder if you have the same Debian repositories enabled that I do?
>>>> In my /etc/apt/sources.list, I have listed:
>>>> deb http://mirror.aarnet.edu.au/debian/ squeeze main contrib non-free
>>>> deb http://security.debian.org/ squeeze/updates main contrib non-free
>>>> i.e. main, contrib and non-free repositories. Do you have all these
>>>> enabled?
>>> Another question - what architecture are you trying?
>>> At the moment, only amd64 is available for the dependent packages
>>> you're having problems with. I'll have to create the i386 versions
>>> if thats the architecture you're using.
>>> chris
>>> Christoph Willing +61 7 3365 8316
>>> Research Computing Centre
>>> University of Queensland
>> Miguel A. Sáez Llorente
>> Soporte tareas multimedia - ATIC
>> Univ. Santiago de Compostela (USC)
>> Rúa de José María Suárez Núñez (Campus Sur) - Pavellón de Servicios
>> 15705 Santiago de Compostela - SPAIN
>> E-mail: miguelangel.saez at usc.es
>> Tel: (+34 881811000) ext. 13035 / Directo 881813035
>> Tel AG: (+34 881811000) ext. 16273 / Directo 881970144
>> Fax: +34 981547070
>> Web: http://www.usc.es/atic
>> https://connectnow.acrobat.com/miguelangelsaez770
Fax: +34 981547070
