[AG-TECH] Insecure Server in AG
Aabhas Garg
aabhasgarg at gmail.com
Sun Feb 27 00:21:50 CST 2011
I tried to run the venue server on DOS Prompt as follows:
C:\Program Files\AGTk-3\bin>VenueServer3.py --secure=0
No certificate is available to start a secure server.
Please run the CertificateManager to request and retrieve
a certificate before attempting to start the VenueServer again.
How to run the venue server without installing the certificate (insecure
server) ?
Please let me know if you have any ideas ?
On Sat, Feb 26, 2011 at 1:00 PM, <ag-tech-request at lists.mcs.anl.gov> wrote:
> Send ag-tech mailing list submissions to
> ag-tech at lists.mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.mcs.anl.gov/mailman/listinfo/ag-tech
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ag-tech-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of ag-tech digest..."
> Today's Topics:
> 1. Duel*Ality - A Telematic Cinema Performance (Jimmy Miklavcic)
> 2. Re: Access Grid Hardware/Software Questions (Griebel, Keith)
> Message: 1
> Date: Fri, 25 Feb 2011 15:03:15 -0700
> From: Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
> Subject: [AG-TECH] Duel*Ality - A Telematic Cinema Performance
> To: "ag-tech at lists.mcs.anl.gov" <ag-tech at lists.mcs.anl.gov>
> Message-ID:
> <3E5F591958142A40B693A5FC6672D4946DE32CDE58 at C8V1.xds.umail.utah.edu
> Content-Type: text/plain; charset="us-ascii"
> Duel*Ality, presented by Another Language Performing Arts Company and the
> University of Utah Center for High Performance Computing, will be performed
> February 25 - 27 & March 4 - 6. The performance can be viewed through the
> Access Grid in the Theatre venue at
> https://artgridvs.chpc.utah.edu:8000/Venues/default. The performance times
> are Friday & Saturday at 19:00 MDT & Sunday at 16:00 MDT. Please enter the
> venue with your audio off. For more information go to
> www.anotherlanguage.org<http://www.anotherlanguage.org>. Check out other
> viewing options at
> http://www.anotherlanguage.org/tele_cinema/2011_duel/video/viewingoptions.html
> Thanks,
> Jimmy
> Jimmy Miklavcic
> Multimedia Specialist
> University of Utah CHPC
> 155 S 1452 E RM 405
> Salt Lake City, UT 84112
> 801-585-9335
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110225/440bad35/attachment-0001.htm
> Message: 2
> Date: Fri, 25 Feb 2011 19:28:05 -0600
> From: "Griebel, Keith" <Keith.Griebel at sdstate.edu>
> Subject: Re: [AG-TECH] Access Grid Hardware/Software Questions
> To: 'Jonathan Klubek' <jhklubek at buffalo.edu>
> Cc: "ag-tech at lists.mcs.anl.gov" <ag-tech at lists.mcs.anl.gov>
> Message-ID:
> <CE067C1C585E274CB996CF68197DC7120E71B6CE92 at SDSU-MBX.jacks.local>
> Hi Jonathan,
> We use Windows 7 Professional 64bit on our HP Z800 capture computer in our
> Access Grid node, along with the Datapath VisionRGB-E1 card and the Osprey
> 450e. First, be sure to disable the Multicast Beacon to allow Access Grid
> to enter a venue using Windows 7.
> Sadly, at this time Access Grid (Vic) does not natively support the
> Datapath card, but we use the display software that comes with it and
> VPCScreen to capture that window only and send it through Access Grid. The
> software that comes with the Datapath card allows you to strip off all the
> borders and scale however you want, so even though it is a workaround, it
> works well. The only caveat is that this particular window must be in front
> of all other windows or it will not capture whatever is covered up by
> something else. Our solution for that is to drag it off to a 2nd monitor
> (actually a second connection to our same monitor on a different input,
> thereby making it more of a "virtual" 2nd monitor).
> The Osprey 450e card seems to work well on a Windows 7 32bit machine, but
> is fussy (not really useable) on our 64bit machine. We are still trying to
> determine exactly what is causing the issues, but we are also using this
> same 64bit capture machine to capture 3 HD video feeds (3 more capture
> cards) in addition to the Osprey and Datapath feeds mentioned above (yes a
> total of 5 cards - 8 video captures!). Our problems may very well be
> related to the combination of all these cards on 1 system; I guess we have
> never tried stripping it down to just the Osprey and Datapath cards, so your
> results may vary. Perhaps someone else can vouch for using this particular
> 450e card by itself successfully on a Windows 7 64bit system. Until we get
> it figured out, we just use it in the older 32bit "SD Capture" machine with
> no problems.
> We also use the HP Z800's onboard audio (Realtek) with no problems.
> Hope that helps!
> Keith
> Keith Griebel
> Communications Technician
> Classroom Technology Services
> South Dakota State University
> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:
> ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of John I. Quebedeaux, Jr
> Sent: Friday, February 25, 2011 10:08 AM
> To: John Quebedeaux; Adam Taylor; 'Jonathan Klubek';
> Sorry, ment to say Osprey 450e in that 2nd paragraph.... - John
> ________________________________
> From: John Quebedeaux <johnq at lsu.edu>
> Date: Fri, 25 Feb 2011 10:02:05 -0600
> To: Adam Taylor <ataylor at ulm.edu>, 'Jonathan Klubek' <jhklubek at buffalo.edu>,
> Adam, wasn't that machine a Dell T5500....? And yes, on Windows XP/Vista/7
> the 4th input wouldn't work on that Osprey 440, but it works just great (all
> 4 inputs) on a Dell T5400, something changed on that machine... note: my guy
> Chris noted new (non-beta) drivers on the Osprey 440, maybe we test it
> again.
> I understand from someone that the Osprey 440e works OK with the AG
> toolkit....
> We too found that the onboard audio worked just fine on our Dells.
> -John Q.
> John I. Quebedeaux, Jr.; Louisiana State University
> Computer Manager LBRN; 131 Life Sciences Bldg.
> e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
> phone: 225-578-0062 / fax: 225-578-2597
> From: Adam Taylor <ataylor at ulm.edu>
> Date: Fri, 25 Feb 2011 09:51:10 -0600 (CST)
> To: 'Jonathan Klubek' <jhklubek at buffalo.edu>, <ag-tech at lists.mcs.anl.gov>
> Well, my two cents.
> We are running a T7500 fully loaded with windows 7 64bit. We run
> everything on it except for the video capture which we run on an Ubuntu
> machine. The reason for this is driver issues with most to not all capture
> cards and windows. We have an Osprey 440 and no matter how hard we tried we
> could never get the 4th input to work. Under Ubuntu, it works just fine
> without any tuning, and is as stable as can be. Any machine that is a first
> gen Core2Duo can run the video capture part without a problem.
> As far as the sound, we had horrid problems with the Soundblaster X-FI that
> came with it. We ended up taking it out and just using the onboard audio
> that comes with the machine. We have not had a single problem since.
> Thanks,
> Adam Taylor
> Computing Center
> University of Louisiana Monroe
> ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Jonathan Klubek
> Sent: Friday, February 25, 2011 8:30 AM
> To: ag-tech at lists.mcs.anl.gov
> Subject: [AG-TECH] Access Grid Hardware/Software Questions
> My group at our university was recently tasked by one of our departments to
> construct an access grid facility (this facility will also function for
> other types of conferencing and classroom needs also). After much reading
> we have determined many pieces we need to get including things such as
> several ClearOne, Crestron and Extron products to control the various audio
> and video pieces ranging from scaling windows on the projectors and
> switching sources to mixing and cancelling echo on the microphones on the
> various tables. The problem we are running into in examining everything is
> with the access grid machine itself. We have looked at the technology and
> many of the pieces of hardware are many years old and we are seeing possible
> issues with integration as things such as PCI are replaced with PCI-e.
> We are looking at going with a Dell Precision workstation T7500 to be the
> access grid machine and have thought about adding more memory and a second
> processor to it (remember that it will serve multiple purposes. . My
> questions are the following:
> 1. I see that the software is listed for Linux, OS X, and Windows.
> We most likely will be going with Windows so we can support Microsoft Link
> also. This software is listed for Windows XP but does it work with Windows
> 7 32-bit and 64-bit. This is extremely important with Windows XP support
> coming to a close. Also, with the increased resources we plan to use it may
> be necessary to use 64-bit to take advantage of things such as 4+ GB of
> memory.
> 2. As mentioned before the technologies listed are out of date. We
> are especially seeing this with the video capture cards and audio cards. I
> was wondering if the following would be supported:
> a. SoundBlaster X-FI XtremeMusic (D)w/Dolby Digital 5.1 (this was the
> card option on the Dell) - if not is there a newer card than the one listed
> that is? We will of course need to integrate with our other products.
> b. Datapath VisionRGB-E1 PCI-e RGB/DVI capture card
> c. Osprey Osprey-450e PCI-e Analog video capture card
> If not we are looking for several recommendations of much newer technology
> that is supported as we see this to be extremely important.
> Jonathan
> URL: <
> http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110225/50dd34ee/attachment-0001.htm
> End of ag-tech Digest, Vol 27, Issue 15
Thanks and Regards,
Aabhas Garg
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110227/d689cbfd/attachment.htm>
