[AG-TECH] Bidirectional video/audio conference problem
N. Satyanarayana
nanduris at cdac.in
Wed Feb 2 23:25:27 CST 2011
Hi Jason,
Thank you for your inputs. I will go thru the material and hope the
problem will be solved.
Satya
On Thu, Feb 3, 2011, Jason Bell <j.bell at cqu.edu.au> said:
> G'day Satya
> Generally speaking, the Access Grid uses the network protocol "Multicast" by default to enable communication between "joined" parties.
> You might find the following document http://www.accessgrid.org/firewall-doc useful.
> I am not 100% sure whether the AG supports " Source Specific Multicast ", but I simply know that the AG by default uses the multicast protocol (whether this is Source Specific or not - I am not sure, haven't heard the use of that terminology much before).
> In regards to your problems, I suspect that the issue is more related to audio device and configuration. You could conduct some self-testing on each of your Access Grids to assist with trouble shooting. I suggest you have a look at http://www.accessgrid.org/qa-improve, as it provides some practical examples on testing Access Grid systems.
> Additionally, you may wish to attend the ASIA-Pacific weekly test session to receive feedback about your Access Grid from other AG users. Details for the session are as follows:
> When: Every Monday
> Time:
> Bangkok 8.00am
> Beijing 9:00am
> Manila 9.00am
> Singapore 9.00am
> Taipei 9.00am
> Perth 9.00am
> Seoul 10.00am
> Tokyo 10.00am
> Brisbane 11.00am
> Adelaide 11.30am
> Canberra 12.00pm
> Hobart 12.00pm
> Melbourne 12.00pm
> Sydney 12.00pm
> Auckland 2.00pm
> Venue: APAG Lobby -> AG-EVO at AU Bridge Lobby -> EVO-AG Testing Room
> (https://130.102.78.178:8000/Venues/ac10cd0111eb76b4d3d7bb213a5aa975b)
> Version: AG3
> Additionally, some presentation material, including AG testing and network information can be found http://www.arcs.org.au/index.php/component/content/article/77-video-collaboration/390-video-collab-pres.
> Anyway - I hope helps you with solving your problems.
> Cheers,
> Jason.
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of N. Satyanarayana
> Sent: Tuesday, 1 February 2011 03:00 PM
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Bidirectional video/audio conference problem
> Hi,
> We are facing problem in realizing two way interaction with Access grid.
> We have a dedicated network across three different cities with multicast enabled in our routers. I believe each venue can be configured with only one multicast group ip address with separate ports for video and audio transmission.
> The network provider is saying that a node cannot be source as well as receiver at the same time but in AG it is observed that all the hosts participating in a particular venue session are transmitting both audio and video. He is saying it is not the right way of experimenting bidirectional communication thru audio/video.
> He is asking whether AG supports Source Specific Multicast or not, because he is saying bidirectional communication thru audio/video can be realized only thru SSM support. But i did not find any means on how to configure SSM in access grid. I am using AG 3.1 all in one windows installer.
> Some times we are facing audio echo and some times noise problem. I am not able to understand whether it is because of audio devices or network configuration.
> Can you throw some light on where the problem could be as we are not able to conclude whether it is due to network or audio devices.
> Regards,
> Satya
> N. Satyanarayana
> Centre for Development of Advanced Computing (C-DAC) No. 1, Shivbagh Ameerpet Hyderabad - 500 016
> (Off) +91-40-23737124/25
> http://www.cdachyd.in/econtentquality
> This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
N. Satyanarayana
No. 1, Shivbagh
Ameerpet
Hyderabad - 500 016
http://180.149.48.114/ccr
