[AG-TECH] Accessgrid Error Certificate
ada1 at uma.es
ada1 at uma.es
Wed Apr 6 12:53:38 CDT 2011
Greetings from the University of Malaga
Asked recently by a problem of Venue Management Tool by which we could not
assign a multicast to a certain range Venue.
We really need to solve this problem, as there is a project to
interconnect all universities in Andalusia 233.2.254.45 multicast using
the range for UDP. Rank assigned by the CICA.
Our OS is XP. Is there a manual way to do this? I mean, I can manually
enter this data into a file? What?
Thanks.
I know you're busy, but it is important to solve this problem.
More information about de problem:
Greetings from Malaga University
last few days we can not access to "venue management tool" to the
configuration of multicast. Running "Venue Server" in debug mode shows
the
error "SSLError: TLSv1 alert unknow ca".
We have requested a new certificate type "service", we've installed it
and
the error is the same (NOTE: we have requested the certificate as
"service" type, but once is installed changes to "identity" type. Is it
normal?)
Do you think we have to try deleting all certificates and re-requesting
an "identity" (not "service" type this time) certificate instead of? In
any case we have requested a identity certificate for probing it. If no
is a problem we'll contact you again for help if the error exists
How many certificates are recomendable to have installed? With one is
sufficient? Is a problem to have installed two or more valid
certificates?
Screen capture attached.
Thanks for your dedication with us.
Thanks.
the
and
normal?)
certificates?
Type: image/bmp
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110406/ee995f0e/attachment-0001.bin>
