[AG-TECH] AG 3.2 comments and problem list
Lloyd Pearson
lloyd.pearson at otago.ac.nz
Wed Sep 29 23:28:23 CDT 2010
Hello team,
Some comments to 30 Sept 2010 on the Access Grid 3.2 final release on a Windows XP SP3 PC.
- If two or more VIC's are in use, each has the same title which is the name of the virtual room. They need the names of each camera to identify the VIC. This is important because with identical VIC's it isn't obvious which VIC the opened camera windows on display in a conference came from, and if one wishes to disable a camera during a conference, there is a risk that all cams on the display will disappear!
- All VIC's open in same place, and I'd prefer tiled or offset layout as each VIC appears, rather than being invisible behind another window.
- "Open in venue" command is still available in data folder for Powerpoint files.
- Can still get RAT 4.40 MBUS errors by moving RAT window or RAT preferences window. Holding left mouse button down while mouse is on the window is sufficient to cause the mbus error.
- After rebooting the PC, 3.2 starts in unicast even though the preferences "use unicast" box is unticked. Multicast unavailable remains on display in Venue client window even after "use multicast" is selected. But after closing and restarting AG, multicast available is displayed.
- The name of the selected virtual venue is no longer displayed under the server address in big bold type. Not essential, but useful since some people give a single-click on the virtual room and don't actually go there as it normally requires a double-click.
Lloyd Pearson
AVCC Operator
University of Otago
Ph +64 3 479 8997
