[AG-TECH] Problem getting a new certificate
Thomas Uram
turam at mcs.anl.gov
Tue Sep 7 13:54:46 CDT 2010
The proxy support is relatively new. If you can reproduce it and send the relevant logfile, that'd be a big help. If you're requesting the cert from within the VenueClient, then send VenueClient.log; if CertificateManager, then CertificateManager.log. On Mac/Linux, you'll find these in ~/.AccessGrid3/Logs.
I've issued certs just now, and found many successful requests from you; among them I'm sure you'll find the 1 or 2 that correspond to your successful requests.
Tom
On Sep 7, 2010, at 8:13 AM, Andrew Leahy wrote:
> Hi, yeah... sorry we didn't provide much info did we!
> Chris was on a Linux Fedora 7 with AG 3.1 kit (AccessGrid-3.1-2.fc7) which is a Venue Server and QuickBridge.
> I was on a Mac OSX 10.5.8, AG 3.2beta.
> Both machines require and use a http proxy for port 80 (web) from on campus.
> However, tonight from home requesting an Identity cert with CertificateManager from my MacBook has worked fine (using transparent proxy).
> So it could be a local issue with proxies at UWS... we get that a bit. We'll check again in the morning.
> When I was able to see the proxy log entry which kinda looked okay, so I was hoping it was not our problem :)
> Cheers, Andrew.
> On 7 September 2010 22:59, Christoph Willing <c.willing at uq.edu.au> wrote:
> On 07/09/2010, at 6:00 PM, Chris Sheerman wrote:
> Just got it to work using certificate request from Windows XP using AccessGrid 3.2 "Request a Certificate"
> Chris,
> What were you using when you first had the failure?
> Andrew,
> With your failure, which version of MacOS X and AG Toolkit?
> chris
> On 07/09/2010, at 5:23 PM, Andrew Leahy wrote:
> Just to add to this, attempting to request an identity cert from the same network here at UWS using CertificateManager on MacOSX and getting the same problem (certificate request failed). This is the request URL logged on the http proxy -
> TCP_MISS/200 POST http://www-unix.mcs.anl.gov/fl/research/accessgrid/ca/agdev/certReqServer.cgi
> 200 response suggests we're getting something back from that webserver, but maybe not what the CertificateManager is expecting?
> Cheers, Andrew.
> On 7 September 2010 17:15, Chris Sheerman <c.sheerman at uws.edu.au> wrote:
> Hi
> I am have problems getting a service certificate for our venue server through our proxy.
> The request is getting through the proxy OK
> but I get the message:
> Certificate Request Failed
> regards
> Chris
> _______________________________
> Chris Sheerman - PC Specialist
> AccessGrid Manager
> University of Western Sydney
> School of Computing and Mathematics
> Locked Bag 1797
> Penrith South DC 1797
> Tel :+61247360774 Fax: +61247360346
> Mob: 0419124056
> lex parsimoniae
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> "There is no one so great as the one who does not try to accomplish anything." (Masanobu Fukuoka)
> My household GHG emissions from energy & transport ~4kg CO2e/day or ~1.4tonnes/year
> Household daily use of Water 120L, Electricity 4.0kWh, Petrol 1.2L, Gas 0MJ
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100907/65370d06/attachment.htm>
