[AG-TECH] RAT Memory leak (ubuntu 10.10)
Christoph Willing
c.willing at uq.edu.au
Sun Nov 28 17:42:43 CST 2010
I've just uploaded a new ag-rat package to the UQVislab maverick repo.
Its based on a slightly earlier version (as was used in Ubuntu 10.4)
and does not exhibit the memory leak problem.
chris
On 28/11/2010, at 4:17 PM, Christoph Willing wrote:
> I can confirm this problem. It appears to involve a small memory
> leak in rat itself when using an ALSA device whenever Talk is
> enabled. This becomes a major memory leak when Pulse audio is
> involved - a 0.1% increase every few seconds in the rat-*-media
> process, as well as a jump in cpu usage from 1 or 2% to 36%.
> It was previously e.g. Ubuntu 10.4, possible to use OSS instead of
> ALSA (and therefore have no memory problem) but OSS is no longer
> available in Ubuntu 10.10.
> Here's a summary of test results using code form the svn trunk (r4891)
> On a system with no Pulse Audio, both OSS and ALSA available:
> OSS selected - uses total 1% cpu, 0.3% mem., irrespective of Talk
> being on or off
> ALSA selected - uses total 1% cpu, 0.3% mem., adds about 0.1% every
> 30mins
> On a system with Pulse Audio & ALSA, but no OSS (Ubuntu 10.10)
> Talk off - uses total 2% cpu, 0.2% mem usage at start, 0.8% after
> ~2hours
> Talk on - uses total 36% cpu, 0.2% mem usage at start, increasing
> by 0.1% every 3 seconds
> i.e. 30% mem usage after 10 minutes
> on the test machine.
> I see from the rat svn repo that there's been no change in the
> source code for a long time, so the problem must have been around
> for a long time; maybe it hasn't been noticed because most users
> have previously chosen to run rat with OSS rather than ALSA+Pulse,
> or perhaps the current version of Pulse particularly exercises the
> faulty code. Also, on the test machine at least, it requires using
> rat with Talk on for about 30 minutes before the problem would be
> noticed (unless you just happen to be carefully watching top at the
> same time).
> chris
> On 25/11/2010, at 8:11 PM, Philippe d'Anfray wrote:
>> Bonjour,
>> We used our ubuntu 10.10 server to retransmit a seminar last week.
>> But RAT was "eating" all the available memory and eventually crashed
>> every 10-15 minutes.
>> syslog:Nov 18 17:02:32 aristotest1 kernel: [31358.739815] Out of
>> memory: kill process 3720 (rat-4.4.01) score 1977288 or a child
>> syslog:Nov 18 17:02:32 aristotest1 kernel: [31358.739820] Killed
>> process 3721 (rat-4.4.01-ui) vsz:44748kB, anon-rss:2044kB, file-rss:
>> 12kB
>> syslog:Nov 18 17:02:32 aristotest1 kernel: [31358.800101]
>> rat-4.4.01-ui: page allocation failure. order:0, mode:0x201da
>> syslog:Nov 18 17:02:32 aristotest1 kernel: [31358.800106] Pid:
>> 3721, comm: rat-4.4.01-ui Not tainted 2.6.35-22-generic #34-Ubuntu
>> Has anyone else experienced a similar problem?
>> Cordialement
>> Philippe
>> <rat.jpg><Philippe_d-Anfray.vcf>
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
