[AG-TECH] Developers - python2.5 vs 2.6 (was: How to differentiate ...)
Jesus Cea Oliva
jesus.cea at uca.es
Tue May 18 13:00:51 CDT 2010
It works for me Christoph, thank you very much!.
About Lucid, I tryed without exit xD. I've downloaded python 2.5.5 from Python website (http://www.python.org/download/releases/2.5.5/ [ http://www.python.org/download/releases/2.5.5/ ]) and build it:
1 - configure
2 - make
3 - sudo make altinstall
The bin folder is /usr/bin/python2.5.5/bin. So, I supose that I can do like you changing paths:
sudo update-alternatives --install /usr/bin/python python /usr/bin/python2.6 10
sudo update-alternatives --install /usr/bin/python python /usr/bin/python2.5.5/bin/python 20
I run python on a terminal and version appears 2.5.5, however, I run VenueServer3.py and terminal shows the next message:
"Import Error: No module named twisted.internet"
VenueClient3.py shows "ImportError: no module named agversion"
So I suppose that this steps fails and AccessGrid doen't take the Python 2.5.5 modules.
I'll make more tests.
Regards and Thanks again!
El dia 18 may 2010 15:46, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 18/05/2010, at 10:44 PM, Christoph Willing wrote:
>> On 18/05/2010, at 7:12 AM, Jesus Cea Oliva wrote:
>>> Thanks Christoph again for your responses, that, always helps ;).
>>> It's possible install python 2.5 on newer Linux distributions and do something for Access Grid "take" the python 2.5 modules? We have a server with Ubuntu Karmic and reinstall the system is not possible due to there are many programs installed for others purposes.
>> Although 2.6 is the default python on karmic, the official Ubuntu repos have versions 2.4 and 2.5 available too (even 3.1 actually). They can be installed at the same time. Applications can then call any of them explicitly e.g. application script could start with #!/ usr/bin/python2.6 or #!/usr/bin/python2.5 etc. Another mechanism to choose between them is to add python to the "alternatives" framework and then select the version you want to be the default using "update- alternatives".
>> So I think the answer is yes - you may be able to run python 2.5 on your server alongside 2.6. The AccessGrid applications all begin with #!/usr/bin/python so they should use whichever python is set as the default with update-alternatives.
> I just tried this myself on a karmic system which already has python2.6 - first install python2.5 using apt-get or synaptic etc.
> Then add both versions to the alternatives framework:
> sudo update-alternatives --install /usr/bin/python python /usr/ bin/python2.5 20
> sudo update-alternatives --install /usr/bin/python python /usr/ bin/python2.6 10
> Because 2.5 was given a higher priority (20 compared with 10) python2.5 will now be the default.
> Now run a VenueServer and VenueClient - the data upload works perfectly.
> Just to confirm 2.6 bad behaviour, run:
> sudo update-alternatives --configure python
> and select python2.6 to be the new default. Now run a new VenueServer and VenueClient - the data upload is broken.
> Unfortunately Lucid seems to have only pythons 2.6 and 3.1 so can't do the same comparison there.
> chris
>> To protect the other services your server is providing, you would want to check that those services are able to run OK in the different python environment.
>>> Thanks again for your help about differenciate rolles, I'll try as soon as possible :).
>>> It's possible to "work" with the Server? I would like to have a DB (sqlite?) for manage Tests (tests, students, etc) and it should be on the Server due to concurrency issues. So, the shared application should send the data to the server and, then, it insert this data (or manipulate) to the DB.
>> There is a sqlite3 module for python so your idea would probably work OK. See:
>> http://docs.python.org/library/sqlite3.html [ http://docs.python.org/library/sqlite3.html ]
>> chris
>>> El dia 17 may 2010 13:10, Christoph Willing <c.willing at uq.edu.au> escribió:
>>> On 17/05/2010, at 6:41 AM, Jesus Cea Oliva wrote:
>>> Hi list!
>>> Firstly, any news about file uploading and sent/recive events? :P. I have a virtual machine with Fedora 10 and there works all fine, so, I'm working with this machine now.
>>> The fact that Fedora 10 uses python2.5 (and works correctly) supports someone's idea that this is problem is related to the python version being used; so far, all known non-working cases use python2.6.
>>> Well, we are doing some Shared Applications for our project, like a PDF Viewer or, now, I'm developing an application for create evaluation tests and, later, do them.
>>> I need to differenciate two "roles" for my applications: the "creator", I mean, the participant that "invokes" a Shared Application; and the "viewer" or something like this, I mean, the participant that receive the invitation of a Shared Application. (sorry for the roles name xD)
>>> I would like to show differents windows for this roles. For example, on the evaluation tests designer; the application shows to the creator (a teacher, for example) a form to design a evaluation test. However, if the participant is the "viewer" (a student, for example), the application shows a evaluation test designed.
>>> On others Shared application, I would like to differenciate this roles. It this possible?. How?
>>> I suggest you have a look at AccessGrid/AppMonitor.py - it shows how to join a Shared App., obtain its state and then its description. This description seems to include the name of whoever started the app - as is shown if you right click->Open Monitor on any shared app. In your applications, if your own profile's name matches that of the app's creator then you would consider yourself the teacher, otherwise a student.
>>> chris
>>> Christoph Willing +61 7 3365 8316
>>> QCIF Access Grid Manager
>>> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100518/fa67615e/attachment.htm>
