[AG-TECH] Developers - How to diferenciate between "creator" and "viewer"?
Jesus Cea Oliva
jesus.cea at uca.es
Mon May 17 16:12:15 CDT 2010
Thanks Christoph again for your responses, that, always helps ;).
It's possible install python 2.5 on newer Linux distributions and do something for Access Grid "take" the python 2.5 modules? We have a server with Ubuntu Karmic and reinstall the system is not possible due to there are many programs installed for others purposes.
Thanks again for your help about differenciate rolles, I'll try as soon as possible :).
It's possible to "work" with the Server? I would like to have a DB (sqlite?) for manage Tests (tests, students, etc) and it should be on the Server due to concurrency issues. So, the shared application should send the data to the server and, then, it insert this data (or manipulate) to the DB.
Regards!! and thanks again ;)
El dia 17 may 2010 13:10, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 17/05/2010, at 6:41 AM, Jesus Cea Oliva wrote:
>> Hi list!
>> Firstly, any news about file uploading and sent/recive events? :P. I have a virtual machine with Fedora 10 and there works all fine, so, I'm working with this machine now.
> The fact that Fedora 10 uses python2.5 (and works correctly) supports someone's idea that this is problem is related to the python version being used; so far, all known non-working cases use python2.6.
>> Well, we are doing some Shared Applications for our project, like a PDF Viewer or, now, I'm developing an application for create evaluation tests and, later, do them.
>> I need to differenciate two "roles" for my applications: the "creator", I mean, the participant that "invokes" a Shared Application; and the "viewer" or something like this, I mean, the participant that receive the invitation of a Shared Application. (sorry for the roles name xD)
>> I would like to show differents windows for this roles. For example, on the evaluation tests designer; the application shows to the creator (a teacher, for example) a form to design a evaluation test. However, if the participant is the "viewer" (a student, for example), the application shows a evaluation test designed.
>> On others Shared application, I would like to differenciate this roles. It this possible?. How?
> I suggest you have a look at AccessGrid/AppMonitor.py - it shows how to join a Shared App., obtain its state and then its description. This description seems to include the name of whoever started the app - as is shown if you right click->Open Monitor on any shared app. In your applications, if your own profile's name matches that of the app's creator then you would consider yourself the teacher, otherwise a student.
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100517/e3313baf/attachment.htm>
