[AG-TECH] Is possible modify AudioService to Select an audio device?
    Jesus Cea Oliva
    jesus.cea at uca.es
    Tue Jun  1 11:01:04 CDT 2010
Hi, list. Today, I found a interesting "need". We have installed a Access Grid client on a normal machine where the audio is a external multifunctional microphone (concretly, a Yamaha PJP-25EUR: http://www.gizmos.es/1828/audio-portatil/yamaha-pjp-25ur-microfono-multidireccional/ [ http://www.gizmos.es/1828/audio-portatil/yamaha-pjp-25ur-microfono-multidireccional/ ]), this has a speaker and a set of microphones and, usualy, it is used for Meetings Venues, etc.
Audio on Access Grid, works fine, but, I have to modify RAT to select the audio device (in audio tab), because, by default, the audio device selected is the sound card. On audio tab, I can select the default audio device to use on RAT... so, I think that is interesting add an aditional option to AudioService to select the audio device prefered.
I already modify the AudioService code tu add a new option, adding to the end of __init__ function the next lines:
self.audioDevice = OptionSetParameter( "Audio device:", audioDefault, self.listAudio)
self.configuration.append(self.audioDevice)
Where, self.listAudio is a list where I want to store the differents audio devices that has the system. And here is my doubt, how can I obtain the audio devices installed on my system, like RAT show me? I thought to modify RAT to permit storage the configuration, or see the code to see how RAT does it, but I think that RAT is a compiled program (C or C++), right? I saw the "aplay -L" and "aplay -l" commands, but I don't know if with this commands I can do something (I don't, for example, if RAT detect the audio names that this commands show me).
I know that I can modify the .RATdefault file to permanently save the configuration.  But I think that I'm going to see this in the future and I thought that is interesting save the config with AudioService like Gains, etc. I add this lines too on AudioService.py on WriteRatDefaults function:
ratDefaults["*audioDevice"] = str(self.audioDevice.value )
To save, the selected audio in AudioService window, to the .RATdefault file.
Sorry, as usual, for my bad English.
Thanks and Regards!
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100601/650cf57b/attachment.htm>
