[AG-TECH] Make a agpkg3 with subfolders?
Jesus Cea Oliva
jesus.cea at uca.es
Mon Aug 30 12:47:18 CDT 2010
Hi again Christoph, yes, I can confirm the correct files & directories structs exists, unziping correctly. I modified the .app file to contains only 1 image file ignoring the rest of images files:
[application]
name = Shared_PDF_Viewer
mimetype = application/x-ag-shared-pdf-viewer
extension = sharedpdfviewer
files = Shared_wxPDF_Viewer.py wxPDF_Viewer.py ./images/document-open.png
[commands]
Open = %(python)s Shared_wxPDF_Viewer.py -a %(appUrl)s -v %(venueUrl)s
When I execute:
sudo agpm.py -s -p Shared_wxPDF_Viewer.agpkg
The terimnal shows the following messages:
UnpackPkg: /home/ercea/SharedPDFViewer.agpkg
Couldn't copy file into place (undoing register).
Unregistration of application Shared_PDF_Viewer complete
(...) # Many times like images exists in the subfolder
Application Shared_PDF_Viewer not found; skipping
Regards! and thanks for your help Chris ;).
El dia 30 ago 2010 15:59, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 30/08/2010, at 11:30 PM, Jesus Cea Oliva wrote:
>> Hi Christoph, I don't understand very well what do you mean.
>> I have problems when I tried unpacking the Shared Application with the command:
>> sudo agpm.py -s -p SharedApp.agpkg
>> because show me messages errors about there are files that don't exists (the image files).
> Firstly, can you confirm that the correct files & directory structure exists in the package before you install it? You can test that with:
> unzip -t SharedApp.agpkg
> (which just lists the contents of the agpkg archive).
> chris
>> My first .app file was:
>> [application]
>> name = MySharedApp
>> mimetype = application/x-ag-my-shared-app
>> extension = mysharedapp
>> files = MySharedApp.py MySharedApp_GUI.py ./images/*
>> [commands]
>> Open = %(python)s FicheroPrincipal.py -a %(appUrl)s -v %(venueUrl)s
>> but it doesn't work. Then, I tried this:
>> [application]
>> name = MySharedApp
>> files = MySharedApp.py MySharedApp_GUI.py ./images/icon1.png ./ images/icon2.png ...
>> [commands]
>> but, it doen't work too :S.
>> Regards again! ;)
>> El dia 30 ago 2010 14:55, Christoph Willing <c.willing at uq.edu.au> escribió:
>> On 30/08/2010, at 9:19 PM, Jesus Cea Oliva wrote:
>> Hi list.
>> First all, I hope you had a good holiday ^^. Well, I've developed a Shared Application (that soon, I would like to shared with yours), and it has a subfolder, called 'images', that contains several icons from the app.
>> When I created the .app file, on section 'files', I tried putting relatives paths to references this images (./images/icon1.png, etc), but it didn't work.
>> Is it possible create agpkg3 files that contains subfolders with other files?
>> Just a guess - you probably have to reference the file in a subdirectory with something like:
>> icon1 = os.path.join(os.getcwd(), "images", "incon1.png")
>> Then do something with icon1
>> chris
>> Christoph Willing +61 7 3365 8316
>> QCIF Access Grid Manager
>> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100830/37561c3c/attachment.htm>
