[AG-TECH] Private Registry Peer
Christoph Willing
c.willing at uq.edu.au
Thu Aug 5 01:54:06 CDT 2010
On 05/08/2010, at 3:41 PM, Gabriel Noronha wrote:
> Thanks for that Chris
> I got it working...
Good to hear.
One last thing, to have a bridge made available via your new registry,
pass the peerlist url to the bridge at startup, using the -u option
again.
chris
> --help doesn't really give enough information sometimes to work it
> out yourself.
> Gabriel
>>>> Christoph Willing <c.willing at uq.edu.au> 5/08/2010 2:44 pm >>>
> On 05/08/2010, at 1:45 PM, Gabriel Noronha wrote:
>> Trying to run my own Peer Registry
>> currently getting errors like the following
>> Traceback (most recent call last):
>> File "/usr/bin/RegistryPeer", line 218, in <module>
>> main()
>> File "/usr/bin/RegistryPeer", line 213, in main
>> r = RegistryPeer(peerListUrl=peerListUrl, port=port)
>> File "/usr/bin/RegistryPeer", line 159, in __init__
>> RegistryBase.__init__(self, port, peerListUrl)
>> File "/usr/bin/RegistryPeer", line 52, in __init__
>> self._readPeerList(url=self.peerListUrl)
>> File "/usr/bin/RegistryPeer", line 67, in _readPeerList
>> raise Exception ("Error: this peer " + localPeerName + " is not
>> listed in the master list. The current registry requires all peers
>> to know about each other.")
>> Exception: Error: this peer cv206-agr3.newcastle.edu.au:8030 is not
>> I can't find anything about a master list ?
> Gabriel,
> The master list is where your registry is advertised and it should
> include the name of the machine you're running the registry on (cv206-
> agr3...). When you start the RegistryPeer, it checks that the service
> its going to provide will be suitably advertised. You can see in the
> traceback that the trouble starts when trying to load some peerListUrl
> - my guess is that you didn't provide such a url when you started
> RegistryPeer. You need to do that with the -u option. Without that, it
> probably defaults to looking at ANL's master list at:
> http://www.accessgrid.org/registry/peers.txt
> which doesn't include your registry. What that url shows is the name
> of a machine and the port number at which its registry service can be
> contacted. In this case, its running on the machine vv3.mcs.anl.gov at
> port 8030.
> What you need to do is create a similar entry, referencing your cv206-
> agr3 machine, on a web server somewhere. Then pass the url of that
> entry (your peerlist url) to the RegistryPeer at startup using the -u
> option.
> BTW, its that same peerlist url that applications use to find your
> registry. In the case AG VenueClients, they know to look up any url(s)
> via entries in the Tools/Preferences/Bridging tab. Anyone wanting to
> use your registry will have to add you peerlist url to the "Bridge
> Registries" section at that tab (and remember to Save after adding).
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
