[AG-TECH] Problems uploading files
Christoph Willing
c.willing at uq.edu.au
Wed Apr 28 20:10:16 CDT 2010
Well my hunch is that the server side of this fault is a python
version issue - based on the following:
1. on a broken system, I've replaced all relevant application packages
with versions used on a working system. These replaced packages
included zsi (and therefore AG itself), m2crypto and openssl. The
problem persists.
2. in all the different Linux versions I've been able to test, the
broken systems are all running python 2.6; all working systems are
running 2.5 or lower.
2b. I don't have any experience of AG on Windows (where there is
apparently no data upload problem) but from the download page it looks
like python 2.4 is being used.
3. while looking through some m2crypto documentation, I found an
article (http://www.heikkitoivonen.net/blog/2008/10/14/ssl-in-
python-26/) which talks about some level of SSL support having been
introduced into python 2.6. My guess is that this added functionality
is somehow interfering with the way we use m2crypto - maybe there's
now a duplicated function name and the wrong one is being executed ...
chris
On 28/04/2010, at 6:08 PM, Jesus Cea Oliva wrote:
> Good morning list :). Here I attached the logs of VenueServer:
> - Log_Ubuntu_Fail: Part of a VenueServer Loggin on a Ubuntu 9.10
> (x64) machine. Upload fails trying upload the file "/home/ercea/
> Documentos/PFC/ag-guide.pdf"
> - Log_Ubuntu_Success: Part of a VenueServer Loggin on a Ubuntu 9.10
> (x64) machine. Upload success with file /home/ercea/.AccessGrid3/
> local_services/AudioService/AudioService.py
> - Log_WindowsXP_Sucess: Part of a VenueServer Loggin on a Windows XP
> (x86) machine. Upload success with file "C:\Documents and Settings
> \Administrator\Mis Documentos\Presentacion.zip"
> I hope this logs helps to find the problem ;)
> Regards!
> El dia 28 abr 2010 02:08, Christoph Willing <c.willing at uq.edu.au>
> escribió:
> Sorry, the output of a _successful_ upload which I sent previously
> was incomplete. Here's the complete transaction:
> 04/28/10 09:57:58 -1245000816 FTPSServer ftps_server.py:338 INFO
> Connection from 130.102.78.192:53807
> 04/28/10 09:57:58 -1245000816 FTPSServer ftps_server.py:271 INFO ==>
> 220 vv3 M2Crypto (Medusa) FTP/TLS server v0.18 ready.
> 04/28/10 09:57:58 -1245000816 FTPSServer ftps_server.py:271 INFO <==
> AUTH TLS
> 234 AUTH TLS successful
> PBSZ 0
> 200 PBSZ=0 successful.
> PROT P
> 200 Protection set to Private
> USER 0a0101d80c2020bf185599cb7beea8bb
> 331 Password required.
> PASS <password>
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:432 INFO in
> authorizeDataTransferCB <AccessGrid.FTPS.ftps_server.ftp_tls_channel
> connected 130.102.78.192:53807 at 0x907eb8c> 0a0101d80c2020bf18
> 5599cb7beea8bb 82664eb24cd2202bad54cf1e46bb0501
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:458 INFO
> authorizeDataTransferCB: user in venue, authorized Jaunty64 Test to
> transfer files to venue Test Room
> 230 Ok.
> 04/28/10 09:57:58 -1245000816 FTPSServer ftps_server.py:275 INFO
> Successful login: Filesystem=<unix-style fs root:Data wd:/>
> cwd /0a0101d80c2020bf185599cb7beea8bb
> 250 CWD command successful.
> TYPE I
> 200 Type set to Binary.
> PASV
> 227 Entering Passive Mode (130,102,78,178,195,93)
> stor killall.diff
> 150 Opening Binary connection for killall.diff
> 226 Transfer complete.
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:468 DEBUG
> dataActivityCB: command = RECV
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:469 INFO
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:470 INFO
> dataActivityCB: line = Data/0a0101d80c2020bf185599cb7beea8bb/
> killall.diff
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:474 DEBUG
> dataActivityCB: Pathpart is: Data
> dataActivityCB: Pathpart is: 0a0101d80c2020bf185599cb7beea8bb
> dataActivityCB: Pathpart is: killall.diff
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:486 DEBUG
> dataActivityCB: VenueID 0a0101d80c2020bf185599cb7beea8bb ;
> Filename: killall.diff
> 04/28/10 09:57:58 -1245000816 VenueServer VenueServer.py:489 DEBUG
> dataActivityCB: Venue is: 0a0101d80c2020bf6aaa4d18fcbbdee7
> dataActivityCB: Venue is: 0a0101d80c0620949d2e08d15558b0bc
> dataActivityCB: Venue is: 0a0101d80c0a209f1c9d810227f4cc4b
> [snip] all venues are inspected but omitted here for brevity ...
> 04/28/10 09:57:59 -1245000816 VenueServer VenueServer.py:489 DEBUG
> dataActivityCB: Venue is: 82664ec0087e59823554e75b6a03e049
> 04/28/10 09:57:59 -1245000816 VenueServer VenueServer.py:491 DEBUG
> dataActivityCB: Key existing? 1
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:796 DEBUG
> GetDownLoadDescriptor: Pathname is Data/
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:797 DEBUG
> GetDownLoadDescriptor: Filename is killall.diff
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:801 DEBUG
> GetDownLoadDescriptor: Joined Path is Data/
> 0a0101d80c2020bf185599cb7beea8bb/killall.diff
> 04/28/10 09:57:59 -1245000816 FTPSServer FTPSServer.py:104 DEBUG
> Entered FTPSServer.GetDownloadDescriptor
> 04/28/10 09:57:59 -1245000816 FTPSServer FTPSServer.py:110 DEBUG
> descriptor = ftps://vv3.ap-accessgrid.org:8006/0a0101d80c2020bf185599cb7beea8bb/killall.diff
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:934 DEBUG
> AddFile: URL to download location is: ftps://vv3.ap-accessgrid.org:8006/0a0101d80c2020bf185599cb7beea8bb/killall.diff
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:935 DEBUG
> AddFile: Path to FTP location of file is: Data/
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:951 DEBUG
> AddFile: Determined parentID is: -1
> 04/28/10 09:57:59 -1245000816 DataStore DataStore.py:961 DEBUG
> AddFile: URI is ftps://vv3.ap-accessgrid.org:8006/0a0101d80c2020bf185599cb7beea8bb/killall.diff
> 04/28/10 09:57:59 -1245000816 VenueServer Venue.py:1859 DEBUG
> DataDescription value: DataDescription: {'status': 'present',
> 'description': None, 'checksum': None, 'parentId': '-1', 'uri': 'ftps://vv3.ap
> -accessgrid.org:8006/0a0101d80c2020bf185599cb7beea8bb/killall.diff',
> 'name': 'killall.diff', 'lastModified': 'Wed, Apr 28, 2010,
> 09:57:59', 'owner': '', 'hierarchyLevel': -2, 'objectType': 'File',
> 'type': N
> one, 'id': '82664eb24cd2202bb7f27e7e11f0e457', 'size': 428}
> 04/28/10 09:57:59 -1245000816 FTPSServer ftps_server.py:271 INFO <==
> QUIT
> 04/28/10 09:57:59 -1245000816 FTPSServer ftps_server.py:271 INFO ==>
> 221 Goodbye.
> On 28/04/2010, at 7:11 AM, Christoph Willing wrote:
> On 28/04/2010, at 6:38 AM, Vine, Derek A wrote:
> At least in my case, I connect to the venue locally from the venue
> server, I can upload files like expected. Connecting from any other
> node will not allow upload of files, at least not "live". Sometimes
> after you try to upload a file and leave and come back the file is
> there.
> Derek,
> That looks like a network problem then, like when I was testing from
> home and small file uploads were OK but large ones didn't seem to
> work - it was just that big files took a lot longer to via the
> relatively slow ADSL upload bandwidth.
> All,
> For comparison with previous log output, here's the server log
> output of a successful upload:
> [snip]
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
> Log_Ubuntu_Fail.log><Log_Ubuntu_Sucess.log><Log_WindowsXP_Success.log>
