[AG-TECH] VPCscreen TTL (patch for VPMedia)
Thomas Uram
turam at mcs.anl.gov
Fri Apr 2 09:42:41 CDT 2010
Chris:
That code lives in the svn repo here at svn.ci.uchicago.edu/svn/if-media. Do you want to commit it or should I?
Tom
----- Original Message -----
To: "Philippe d'Anfray" <Philippe.d-Anfray at cea.fr>
Cc: ag-tech at mcs.anl.gov
Sent: Friday, April 2, 2010 9:30:25 AM GMT -06:00 US/Canada Central
Subject: Re: [AG-TECH] VPCscreen TTL (patch for VPMedia)
On 02/04/2010, at 10:39 PM, Philippe d'Anfray wrote:
> Bonjour
> Great !! with this test version of VPCScreen, the multicast packets
> are
> given a TTL of 127 and can be received normally at other multicast
> locations (at least in France....) (and also through bridges).
OK, thanks for raising the problem and doing the test Philippe.
And also thanks to Andrew Rowley for suggesting a ttl issue as the
cause of the problem!
This change should be applied to all the various release packages.
Attached below is the patch I've used - it just sets a default ttl of
127. A better fix would be to use whatever the user asks for, so if
anyone has time ....
chris
> Christoph Willing a écrit :
>> Philippe,
>> Could you try some tests with:
>> http://www.vislab.uq.edu.au/debuntu/tests/
>> vpcscreen_0.2-4_amd64.deb
>> You'll have to download manually and use dpkg to install (rather than
>> apt-get etc.):
>> sudo dpkg -i vpcscreen_0.2-4_amd64.deb
>>>> Anyway, I think I've found the cause in the vpcscreen code and will
>>>> apply a simple minded fix for testing. Would you be able to test
>>>> it? I
>>>> can't easily replicate your problem here to confirm that the fix
>>>> works. If you are able to help with the testing, could you confirm
>>>> that you're using Ubuntu 9.10 and whether you're using 32 or 64bit
>>>> version please, so that I can build the appropriate version for
>>>> you?
> <Philippe_d-Anfray.vcf>
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
