[AG-TECH] Adobe PDF Reader causing VNCserver to crash
Brian Corrie
bcorrie at sfu.ca
Thu Sep 24 12:12:24 CDT 2009
Hi Jason,
Thanks for bringing this up - good to know it isn't just me as I have
seen this as well. When I run into this problem I hide the toolbars,
maximize the window, and run it that way. This does not crash, it is the
fullscreen mode without borders that causes the problem.
Brian
Jason Bell wrote:
> Colleagues
> For those who use VenueVNC (or simply VNC), It has been found that if
> using the newer versions for Adobe PDF Viewer and switching it to full
> screen mode causes the VNCserver to crash. This has been seen to occur
> within Windows systems (XP and 64bit XP).
> As a work around, if you use an older version of the software (say
> Version 7), then everything works fine.
> Just thought I would provide a brief "heads up" on this issue, as it has
> recently caused some problems within AG sessions.
> Regards,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Research Systems Support Officer
> Information Technology Division
> CQ University Australia
> Australian Research Collaboration Service
> http://www.arcs.org.au/
> E-mail : j.bell at cqu.edu.au
> jason.bell at arcs.org.au
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19
> Central Queensland University
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
