[AG-TECH] Bridge question.
Jimmy Miklavcic
jimmy.miklavcic at utah.edu
Tue Oct 6 14:46:02 CDT 2009
We seem to have our bridge working now. It looks like a network configuration problem on the machine itself. If someone could select UTAH_CHPC, after you purge your bridge cache to refresh, as your bridge, you should see the bridge address (155.101.28.50) at the bottom of the main VIC window. You bridge list should see UTAH_CHPC as enabled with a valid ping time.
Jimmy
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu<mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org<http://www.anotherlanguage.org/>
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Jimmy Miklavcic
Sent: Tuesday, October 06, 2009 10:35 AM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Bridge question.
We're finding that our bridge, UTAH_CHPC, is Unreachable according to the venue client. We have verified this locally, from Australia and Kansas. So my question is, if one can successfully ping the bridge manually, why can't the venue client get a successful ping?
Jimmy
Jimmy Miklavcic
UNIVERSITY OF UTAH
Fax: 801.585.5366
Sent: Monday, October 05, 2009 9:42 AM
Subject: [AG-TECH] Bridge question.
We are running our own bridge, on Red Hat,here at Utah. It runs on the same subnet as my AG system. I activate unicast and select our bridge (UTAH_CHPC) the venue client does not reset the vic and rat as it normally does when I select other bridges. So I force the update by selecting GO. When I do this, usually I will se the IP address of the bridge in the vic and rat windows, but for our bridge, I see a multicast address. So now I'm really confused.
Has anyone run into this symptom at all? Could someone test this out from the outside. Our bridge is registered and the IP is 155.101.28.50.
Jimmy
Jimmy Miklavcic
UNIVERSITY OF UTAH
Fax: 801.585.5366
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20091006/4d92f36a/attachment.htm>
Name: Blank Bkgrd.gif
Type: image/gif
Desc: Blank Bkgrd.gif
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20091006/4d92f36a/attachment.gif>
