[AG-TECH] VPC Screen h261AS converting.
    Nagykaldi, Zsolt F. (HSC)
    Zsolt-Nagykaldi at ouhsc.edu
    Wed Nov 25 11:36:58 CST 2009
The NCSA unicast bridge seems to be down. Jeremy, the UTHSCSA bridge is also down.
Zsolt
Zsolt Nagykaldi, PhD
Assistant Professor of Research
Clinical IT Specialist
University of Oklahoma Health Sciences Center
Department of Family & Preventive Medicine
900 N.E. 10th Street
Oklahoma City, OK 73104
Phone: (405) 271-8000 ext.1-32208
Fax:     (405) 271-2784
From: ag-tech-bounces at lists.mcs.anl.gov [ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Gabriel Noronha [Gabriel.Noronha at newcastle.edu.au]
Sent: Wednesday, November 04, 2009 11:37 PM
To: Andrew Rowley; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] VPC Screen h261AS converting.
The new project looks interesting, I had a quick look through the svn.
what license is it under ? (it seemed to only state that no Warranties, public domain but with credit ??)
I am attempting to use AGVCRToMPEG2 at the moment which seems to lack any license and also lacks 64-bit support. which means i have to either change it's code or wait for yours.
What is the UI going to be for your program I'm not good enough at java to tell from the source ?
Gabriel Noronha
Access Grid Support Officer
University of Newcastle
>>> Andrew Rowley <Andrew.Rowley at manchester.ac.uk> 5/11/2009 2:21 am >>>
I am in the process of writing software that will allow conversion of H261AS streams and other AG streams to other formats.  H261AS is a simple modification of the H261 format that allows Any or Arbitrary Size i.e. it is not restricted to 352x288 video.  The best documentation on the format is to look in the codecs e.g. the vic source code.  There is no ffmpeg support for this and h261 support in ffmpeg itself is limited in that it doesn't support the RTP packetization or depacketization of h261.
If you are willing to wait, the ViCoVRE project (http://www.rcs.manchester.ac.uk/research/ViCoVRE) should be complete by March next year, and will support both conversions to and from other common media formats such as avi.
Andrew :)
   Andrew G D Rowley
   Senior Development Officer
   Research Computing Services
   The University of Manchester
   Devonshire House, Oxford Road
   Manchester, M13 9PL
   t :  +44 (0) 161 275 0685
   e :  Andrew.Rowley at manchester.ac.uk
   w :  www.manchester.ac.uk/researchcomputing
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Gabriel Noronha
Sent: 29 October 2009 01:07
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] VPC Screen h261AS converting.
I'm trying to find more information out about the h261as codec.
I'm trying to work it so that i can convert a h261as stream recorded in AGVCR and convert in to another format eg. avi.
I can't seem to locate much information on the codec if there is ffmpeg support for etc..
Anyone able to point in the right direction.
Gabriel Noronha
